Isuzu Truck FTR INDONESIA WB3600 WB4200 1997-2004 Parts Catalog 10752
Model: Isuzu FTR INDONESIA WB3600 WB4200 1997-2004 Truck
Part Number: 10752
Publication Date: 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004
Number of Pages: 533 Pages
001_Section Index 10752 Spare Parts Catalog.pdf
033_0 80 INJECTION PUMP Spare Parts Catalog.pdf
034_0 81 GOVERNOR INJECTION P Spare Parts Catalog.pdf
035_0 84 FEED PUMP INJECTION Spare Parts Catalog.pdf
036_0 85 AUTO TIMER INJECTION Spare Parts Catalog.pdf
037_0 87 COUPLING INJECTION P Spare Parts Catalog.pdf
054_2 06 CLUTCH SLAVE CYLINDER Spare Parts Catalog.pdf
064_2 81 POWER TAKE OFF TRANS Spare Parts Catalog.pdf
065_2 85 POWER TAKE OFF CONTRO Spare Parts Catalog.pdf
069_3 08 PARKING BRAKE Spare Parts Catalog.pdf
072_3 20 AIR TANK Spare Parts Catalog.pdf
073_3 22 AIR CONTROL PARTS Spare Parts Catalog.pdf
074_3 33 AIR MASTER Spare Parts Catalog.pdf
075_3 34 BRAKE VALVE AIR Spare Parts Catalog.pdf
076_3 52 BRAKE PIPING OIL FRO Spare Parts Catalog.pdf
077_3 55 BRAKE PIPING OIL REA Spare Parts Catalog.pdf
078_3 58 FIXING PARTS OIL PIP Spare Parts Catalog.pdf
079_3 70 BRAKE PIPING AIR AIR Spare Parts Catalog.pdf
080_3 75 BRAKE PIPING AIR FRO Spare Parts Catalog.pdf
081_3 77 BRAKE PIPING AIR REA Spare Parts Catalog.pdf
082_3 78 FIXING PARTS AIR PIP Spare Parts Catalog.pdf
083_4 PROPELLER SHAFT AXLES STEERIN Spare Parts Catalog.pdf
084_4 01 PROPELLER SHAFT Spare Parts Catalog.pdf
085_4 10 FRONT AXLE Spare Parts Catalog.pdf
086_4 11 FRONT HUB AND DRUM OR Spare Parts Catalog.pdf
087_4 20 REAR AXLE CASE AND SH Spare Parts Catalog.pdf
088_4 25 REAR FINAL DRIVE Spare Parts Catalog.pdf
089_4 30 STEERING WHEEL AND CO Spare Parts Catalog.pdf
090_4 31 STEERING COLUMN AND S Spare Parts Catalog.pdf
091_4 33 STEERING LINKAGE Spare Parts Catalog.pdf
092_4 35 POWER STEERING CONTRO Spare Parts Catalog.pdf
093_4 36 POWER STEERING CONTRO Spare Parts Catalog.pdf
094_4 40 STEERING UNIT Spare Parts Catalog.pdf
095_4 42 POWER STEERING OIL PU Spare Parts Catalog.pdf
096_4 50 FRONT SUSPENSION Spare Parts Catalog.pdf
097_4 55 FRONT LEAF SPRING Spare Parts Catalog.pdf
098_4 60 REAR SUSPENSION Spare Parts Catalog.pdf
099_4 65 REAR LEAF SPRING Spare Parts Catalog.pdf
100_4 80 ROAD WHEEL Spare Parts Catalog.pdf
101_5 FRAME CAB MOUNTING Spare Parts Catalog.pdf
102_5 01 FRAME AND OTHER PARTS Spare Parts Catalog.pdf
103_5 10 CAB MOUNTING FRAME S Spare Parts Catalog.pdf
104_5 15 CAB MOUNTING CAB SID Spare Parts Catalog.pdf
105_5 20 BATTERY CARRIER Spare Parts Catalog.pdf
106_5 30 SPARE TIRE CARRIER AN Spare Parts Catalog.pdf
107_6 EXTERIOR BODY GLASS MOUNTING Spare Parts Catalog.pdf
108_6 01 FRONT BUMPER Spare Parts Catalog.pdf
109_6 03 RADIATOR GRILLE Spare Parts Catalog.pdf
110_6 05 FRONT PANEL Spare Parts Catalog.pdf
111_6 07 FRONT WINDOW GLASS AN Spare Parts Catalog.pdf
112_6 20 SIDE PANEL AND STEP Spare Parts Catalog.pdf
113_6 30 FRONT DOOR AND HINGE Spare Parts Catalog.pdf
114_6 31 FRONT DOOR GLASS AND Spare Parts Catalog.pdf
115_6 32 FRONT DOOR LOCK AND H Spare Parts Catalog.pdf
116_6 35 FRONT DOOR TRIM Spare Parts Catalog.pdf
117_6 41 SIDE WINDOW GLASS AND Spare Parts Catalog.pdf
118_6 43 SIDE TRIM Spare Parts Catalog.pdf
119_6 47 MUD GUARD AND INSULAT Spare Parts Catalog.pdf
120_6 60 ROOF PANEL Spare Parts Catalog.pdf
121_6 66 HEAD LINING AND TRIM Spare Parts Catalog.pdf
122_6 70 FLOOR PANEL Spare Parts Catalog.pdf
123_6 75 MAT AND CARPET Spare Parts Catalog.pdf
124_6 76 FLOOR EQUIPMENT AND S Spare Parts Catalog.pdf
125_6 78 FLOOR HOLE PLUG Spare Parts Catalog.pdf
126_6 80 BACK PANEL Spare Parts Catalog.pdf
127_6 82 BACK GLASS AND WEATHE Spare Parts Catalog.pdf
128_6 84 BACK TRIM Spare Parts Catalog.pdf
129_6 90 REAR BUMPER Spare Parts Catalog.pdf
130_7 INTERIOR TRIM EMBLEMS LABELS Spare Parts Catalog.pdf
131_7 01 EMBLEM AND NAME PLATE Spare Parts Catalog.pdf
132_7 10 CAUTION PLATE AND LAB Spare Parts Catalog.pdf
133_7 20 MIRROR AND MIRROR STA Spare Parts Catalog.pdf
134_7 30 LOCK CYLINDER SET Spare Parts Catalog.pdf
135_7 40 INSTRUMENT PANEL AND Spare Parts Catalog.pdf
136_7 43 SUN VISOR AND ASSIST Spare Parts Catalog.pdf
137_7 45 CONSOLE BOX Spare Parts Catalog.pdf
138_7 50 FRONT SEAT Spare Parts Catalog.pdf
139_7 60 SEAT BELT Spare Parts Catalog.pdf
140_7 70 SEPARATER AND BED Spare Parts Catalog.pdf
141_8 CHASSIS ELECTRICAL HEATING AI Spare Parts Catalog.pdf
142_8 01 LAMP FRONT AND FRONT Spare Parts Catalog.pdf
143_8 03 LAMP REAR AND REAR S Spare Parts Catalog.pdf
144_8 05 INTERIOR LAMP Spare Parts Catalog.pdf
145_8 10 WIRING HARNESS AND FU Spare Parts Catalog.pdf
146_8 15 FIXING PARTS WIRING Spare Parts Catalog.pdf
147_8 21 METER ASM Spare Parts Catalog.pdf
148_8 25 SWITCH AND RELAY INS Spare Parts Catalog.pdf
149_8 26 ELECTRICAL CONTROL AN Spare Parts Catalog.pdf
150_8 28 CHASSIS ELECTRICAL Spare Parts Catalog.pdf
151_8 40 HEATER SYSTEM Spare Parts Catalog.pdf
152_8 45 HEATER PIPING Spare Parts Catalog.pdf
153_8 52 PIPING AIR CONDITION Spare Parts Catalog.pdf
154_8 60 HEATER UNIT FRONT Spare Parts Catalog.pdf
155_8 73 BLOWER UNIT Spare Parts Catalog.pdf
156_8 80 WINDSHIELD WIPER AND Spare Parts Catalog.pdf
157_8 90 RADIO AND TV Spare Parts Catalog.pdf
158_9 TOOLS REAR BODY Spare Parts Catalog.pdf
159_9 01 TOOLS Spare Parts Catalog.pdf
