Isuzu Truck CXZ RHD 1990-1995 Parts Catalog 10660
Model: Isuzu CXZ RHD 1990-1995 Truck
Part Number: 10660
Publication Date: 1990, 1991, 1992, 1993, 1994, 1995
Number of Pages: 1522 Pages
001_Section Index 10660 Spare Parts Catalog.pdf
003_0 05A ENGINE GASKET KIT A L Spare Parts Catalog.pdf
004_0 05B ENGINE GASKET KIT B V Spare Parts Catalog.pdf
005_0 10A CYLINDER HEAD COVER A Spare Parts Catalog.pdf
006_0 10B CYLINDER HEAD COVER B Spare Parts Catalog.pdf
007_0 11A CYLINDER HEAD A L TYP Spare Parts Catalog.pdf
008_0 11B CYLINDER HEAD B V TYP Spare Parts Catalog.pdf
009_0 12A CYLINDER BLOCK A L TY Spare Parts Catalog.pdf
010_0 12B CYLINDER BLOCK B V TY Spare Parts Catalog.pdf
011_0 13A OIL PAN AND LEVEL GAUG Spare Parts Catalog.pdf
012_0 13B OIL PAN AND LEVEL GAUG Spare Parts Catalog.pdf
013_0 14A CAMSHAFT AND VALVE A Spare Parts Catalog.pdf
014_0 14B CAMSHAFT AND VALVE B Spare Parts Catalog.pdf
015_0 15A CRANKSHAFT PISTON AND Spare Parts Catalog.pdf
016_0 15B CRANKSHAFT PISTON AND Spare Parts Catalog.pdf
017_0 20A TIMING GEAR CASE AND F Spare Parts Catalog.pdf
018_0 20B TIMING GEAR CASE AND F Spare Parts Catalog.pdf
019_0 22A ENGINE MOUNTING A L T Spare Parts Catalog.pdf
020_0 22B ENGINE MOUNTING B V T Spare Parts Catalog.pdf
021_0 25A INLET MANIFOLD A L TY Spare Parts Catalog.pdf
022_0 25B INLET MANIFOLD B V TY Spare Parts Catalog.pdf
023_0 27A EXHAUST MANIFOLD A L Spare Parts Catalog.pdf
024_0 27B EXHAUST MANIFOLD B V Spare Parts Catalog.pdf
025_0 28A VENTILATION SYSTEM A Spare Parts Catalog.pdf
026_0 28B VENTILATION SYSTEM B Spare Parts Catalog.pdf
027_0 30A WATER PUMP AND CORROSI Spare Parts Catalog.pdf
028_0 30B WATER PUMP AND CORROSI Spare Parts Catalog.pdf
029_0 31A THERMOSTAT AND HOUSING Spare Parts Catalog.pdf
030_0 31B THERMOSTAT AND HOUSING Spare Parts Catalog.pdf
031_0 32A WATER PIPING ENGINE Spare Parts Catalog.pdf
032_0 32B WATER PIPING ENGINE Spare Parts Catalog.pdf
033_0 33A FAN AND FAN BELT A L Spare Parts Catalog.pdf
034_0 33B FAN AND FAN BELT B V Spare Parts Catalog.pdf
035_0 34A INTAKE HEATER A L TYP Spare Parts Catalog.pdf
036_0 34B INTAKE HEATER B V TYP Spare Parts Catalog.pdf
037_0 35A ENGINE CONTROL VALVE A Spare Parts Catalog.pdf
038_0 35B ENGINE CONTROL VALVE A Spare Parts Catalog.pdf
039_0 36A TURBOCHARGER SYSTEM A Spare Parts Catalog.pdf
040_0 37 TURBOCHARGER Spare Parts Catalog.pdf
041_0 38A AIR COMPRESSOR PIPING Spare Parts Catalog.pdf
042_0 38B AIR COMPRESSOR PIPING Spare Parts Catalog.pdf
043_0 39A AIR COMPRESSOR BRAKE Spare Parts Catalog.pdf
044_0 39B AIR COMPRESSOR BRAKE Spare Parts Catalog.pdf
045_0 40A FUEL INJECTION SYSTEM Spare Parts Catalog.pdf
046_0 40B FUEL INJECTION SYSTEM Spare Parts Catalog.pdf
047_0 41A FUEL FILTER AND BRACKE Spare Parts Catalog.pdf
048_0 41B FUEL FILTER AND BRACKE Spare Parts Catalog.pdf
049_0 42A FUEL PUMP AND PIPE A Spare Parts Catalog.pdf
050_0 42B FUEL PUMP AND PIPE B Spare Parts Catalog.pdf
051_0 50A OIL COOLER AND OIL FIL Spare Parts Catalog.pdf
052_0 50B OIL COOLER AND OIL FIL Spare Parts Catalog.pdf
053_0 51A OIL PUMP AND OIL STRAI Spare Parts Catalog.pdf
054_0 51B OIL PUMP AND OIL STRAI Spare Parts Catalog.pdf
055_0 52A OIL AND VACUUM PIPING Spare Parts Catalog.pdf
056_0 52B OIL AND VACUUM PIPING Spare Parts Catalog.pdf
057_0 60A ENGINE ELECTRICAL CONT Spare Parts Catalog.pdf
058_0 60B ENGINE ELECTRICAL CONT Spare Parts Catalog.pdf
059_0 61A BATTERY AND ENGINE ELE Spare Parts Catalog.pdf
060_0 61B BATTERY AND ENGINE ELE Spare Parts Catalog.pdf
061_0 65 STARTER Spare Parts Catalog.pdf
062_0 66 GENERATOR Spare Parts Catalog.pdf
063_0 80 INJECTION PUMP Spare Parts Catalog.pdf
064_0 81 GOVERNOR INJECTION P Spare Parts Catalog.pdf
065_0 82 BOOST COMPENSATOR IN Spare Parts Catalog.pdf
066_0 83 ANEROID COMPENSATOR Spare Parts Catalog.pdf
067_0 84 FEED PUMP INJECTION Spare Parts Catalog.pdf
068_0 85 AUTO TIMER INJECTION Spare Parts Catalog.pdf
069_0 86 MISCELLANEOUS PARTS Spare Parts Catalog.pdf
070_0 87A COUPLING INJECTION PU Spare Parts Catalog.pdf
071_0 90A POWER TAKE OFF FLYWHE Spare Parts Catalog.pdf
072_0 90B POWER TAKE OFF FLYWHE Spare Parts Catalog.pdf
073_1 FUEL TANK COOLING AIR INTAKE Spare Parts Catalog.pdf
074_1 01A ACCELERATOR PEDAL AND Spare Parts Catalog.pdf
075_1 01B ACCELERATOR PEDAL AND Spare Parts Catalog.pdf
076_1 10A RADIATOR A L TYPE ENG Spare Parts Catalog.pdf
077_1 10B RADIATOR B V TYPE ENG Spare Parts Catalog.pdf
078_1 11A RADIATOR HOSE AND SUB Spare Parts Catalog.pdf
079_1 11B RADIATOR HOSE AND SUB Spare Parts Catalog.pdf
080_1 30A AIR CLEANER A L TYPE Spare Parts Catalog.pdf
081_1 30B AIR CLEANER B V TYPE Spare Parts Catalog.pdf
082_1 31A AIR DUCT A L TYPE ENG Spare Parts Catalog.pdf
083_1 31B AIR DUCT B V TYPE ENG Spare Parts Catalog.pdf
084_1 35A CHARGE AIR COOLER A L Spare Parts Catalog.pdf
085_1 40A FUEL TANK A L TYPE EN Spare Parts Catalog.pdf
086_1 40B FUEL TANK B V TYPE EN Spare Parts Catalog.pdf
087_1 41A FUEL PIPING CHASSIS Spare Parts Catalog.pdf
088_1 41B FUEL PIPING CHASSIS Spare Parts Catalog.pdf
089_1 45A WATER SEDIMENTER FUEL Spare Parts Catalog.pdf
090_1 45B WATER SEDIMENTER FUEL Spare Parts Catalog.pdf
091_1 50A EXHAUST PIPE AND SILEN Spare Parts Catalog.pdf
092_1 50B EXHAUST PIPE AND SILEN Spare Parts Catalog.pdf
093_1 55A EXHAUST BRAKE VALVE AN Spare Parts Catalog.pdf
094_1 55B EXHAUST BRAKE VALVE AN Spare Parts Catalog.pdf
095_1 56A EXHAUST BRAKE SYSTEM Spare Parts Catalog.pdf
096_1 56B EXHAUST BRAKE SYSTEM Spare Parts Catalog.pdf
097_2 CLUTCH TRANSMISSION TRANS AXL Spare Parts Catalog.pdf
098_2 01A CLUTCH A ISUZU M T Spare Parts Catalog.pdf
099_2 01B CLUTCH B FULLER M T Spare Parts Catalog.pdf
100_2 03 CLUTCH PEDAL AND CONT Spare Parts Catalog.pdf
101_2 05A CLUTCH PIPING A ISUZU Spare Parts Catalog.pdf
102_2 05B CLUTCH PIPING B FULLE Spare Parts Catalog.pdf
103_2 07A CLUTCH BOOSTER MINIPA Spare Parts Catalog.pdf
104_2 07B CLUTCH BOOSTER MINIPA Spare Parts Catalog.pdf
105_2 08A CLUTCH MASTER CYLINDER Spare Parts Catalog.pdf
106_2 08B CLUTCH MASTER CYLINDER Spare Parts Catalog.pdf
107_2 10A REPAIR KIT TRANSMISSI Spare Parts Catalog.pdf
108_2 20A MANUAL TRANSMISSION AS Spare Parts Catalog.pdf
109_2 20B MANUAL TRANSMISSION AS Spare Parts Catalog.pdf
110_2 25A SPEEDOMETER DRIVEN GEA Spare Parts Catalog.pdf
111_2 25B SPEEDOMETER DRIVEN GEA Spare Parts Catalog.pdf
112_2 26A MANUAL TRANSMISSION GE Spare Parts Catalog.pdf
113_2 26B MANUAL TRANSMISSION GE Spare Parts Catalog.pdf
114_2 30A GEAR SHIFTER AND QUADR Spare Parts Catalog.pdf
115_2 30B GEAR SHIFTER AND QUADR Spare Parts Catalog.pdf
116_2 35A MANUAL TRANSMISSION SH Spare Parts Catalog.pdf
117_2 35B MANUAL TRANSMISSION SH Spare Parts Catalog.pdf
118_2 36A MANUAL TRANSMISSION CO Spare Parts Catalog.pdf
119_2 36B MANUAL TRANSMISSION CO Spare Parts Catalog.pdf
120_2 37A MANUAL TRANSMISSION CO Spare Parts Catalog.pdf
121_2 37B MANUAL TRANSMISSION CO Spare Parts Catalog.pdf
122_2 39A POWER ASSISTOR A ISUZ Spare Parts Catalog.pdf
123_2 81A POWER TAKE OFF TRANSM Spare Parts Catalog.pdf
124_2 85A POWER TAKE OFF CONTROL Spare Parts Catalog.pdf
125_2 85B POWER TAKE OFF CONTROL Spare Parts Catalog.pdf
126_3 BRAKE BRAKES SYSTEM Spare Parts Catalog.pdf
127_3 01 FRONT WHEEL BRAKE Spare Parts Catalog.pdf
128_3 05 REAR WHEEL BRAKE Spare Parts Catalog.pdf
129_3 10 BRAKE PEDAL AND CONTR Spare Parts Catalog.pdf
130_3 11 PARKING BRAKE CONTROL Spare Parts Catalog.pdf
131_3 20 AIR TANK Spare Parts Catalog.pdf
132_3 22 AIR CONTROL PARTS Spare Parts Catalog.pdf
133_3 26 TRAILER CONTROL Spare Parts Catalog.pdf
134_3 34 BRAKE VALVE AIR Spare Parts Catalog.pdf
135_3 40 FRONT BRAKE POWER CHA Spare Parts Catalog.pdf
136_3 41 REAR BRAKE POWER CHAM Spare Parts Catalog.pdf
137_3 45 LOAD SENSING PROPORTI Spare Parts Catalog.pdf
138_3 46 AIR DRYER Spare Parts Catalog.pdf
139_3 55 BRAKE PIPING OIL REA Spare Parts Catalog.pdf
140_3 58 FIXING PARTS OIL PIP Spare Parts Catalog.pdf
141_3 70 BRAKE PIPING AIR AIR Spare Parts Catalog.pdf
142_3 75 BRAKE PIPING AIR FRO Spare Parts Catalog.pdf
143_3 77 BRAKE PIPING AIR REA Spare Parts Catalog.pdf
144_3 78 FIXING PARTS AIR PIP Spare Parts Catalog.pdf
145_3 80 BRAKE PIPING TRAILER Spare Parts Catalog.pdf
146_3 83 FIXING PARTS TRAILER Spare Parts Catalog.pdf
147_4 PROPELLER SHAFT AXLES STEERIN Spare Parts Catalog.pdf
148_4 01 PROPELLER SHAFT Spare Parts Catalog.pdf
149_4 10 FRONT AXLE Spare Parts Catalog.pdf
150_4 11 FRONT HUB AND DRUM OR Spare Parts Catalog.pdf
151_4 20 REAR AXLE CASE AND SH Spare Parts Catalog.pdf
152_4 25 REAR FINAL DRIVE Spare Parts Catalog.pdf
153_4 30 STEERING WHEEL AND CO Spare Parts Catalog.pdf
154_4 31 STEERING COLUMN AND S Spare Parts Catalog.pdf
155_4 33 STEERING LINKAGE Spare Parts Catalog.pdf
156_4 35 POWER STEERING CONTRO Spare Parts Catalog.pdf
157_4 36 POWER STEERING CONTRO Spare Parts Catalog.pdf
158_4 40 STEERING UNIT Spare Parts Catalog.pdf
159_4 42 POWER STEERING OIL PU Spare Parts Catalog.pdf
160_4 50 FRONT SUSPENSION Spare Parts Catalog.pdf
161_4 55 FRONT LEAF SPRING Spare Parts Catalog.pdf
162_4 60 REAR SUSPENSION Spare Parts Catalog.pdf
163_4 65 REAR LEAF SPRING Spare Parts Catalog.pdf
164_4 80 ROAD WHEEL Spare Parts Catalog.pdf
165_5 FRAME CAB MOUNTING Spare Parts Catalog.pdf
166_5 01 FRAME AND OTHER PARTS Spare Parts Catalog.pdf
167_5 10 CAB MOUNTING FRAME S Spare Parts Catalog.pdf
168_5 15 CAB MOUNTING CAB SID Spare Parts Catalog.pdf
169_5 16 OIL PUMP CAB TILT Spare Parts Catalog.pdf
170_5 17 CYLINDER CAB TILT Spare Parts Catalog.pdf
171_5 20 BATTERY CARRIER Spare Parts Catalog.pdf
172_5 30 SPARE TIRE CARRIER AN Spare Parts Catalog.pdf
173_5 40 ENGINE ROOM INSULATOR Spare Parts Catalog.pdf
174_6 EXTERIOR BODY GLASS MOUNTING Spare Parts Catalog.pdf
175_6 01 FRONT BUMPER Spare Parts Catalog.pdf
176_6 03 RADIATOR GRILLE Spare Parts Catalog.pdf
177_6 04 CAB ASM Spare Parts Catalog.pdf
178_6 05 FRONT PANEL Spare Parts Catalog.pdf
179_6 07 FRONT WINDOW GLASS AN Spare Parts Catalog.pdf
180_6 20 SIDE PANEL AND STEP Spare Parts Catalog.pdf
181_6 30 FRONT DOOR AND HINGE Spare Parts Catalog.pdf
182_6 31 FRONT DOOR GLASS AND Spare Parts Catalog.pdf
183_6 32 FRONT DOOR LOCK AND H Spare Parts Catalog.pdf
184_6 35 FRONT DOOR TRIM Spare Parts Catalog.pdf
185_6 41 SIDE WINDOW GLASS AND Spare Parts Catalog.pdf
186_6 43 SIDE TRIM Spare Parts Catalog.pdf
187_6 47 MUD GUARD AND INSULAT Spare Parts Catalog.pdf
188_6 60 ROOF PANEL Spare Parts Catalog.pdf
189_6 66 HEAD LINING AND TRIM Spare Parts Catalog.pdf
190_6 68 ROOF VENTILATOR Spare Parts Catalog.pdf
191_6 70 FLOOR PANEL Spare Parts Catalog.pdf
192_6 75 MAT AND CARPET Spare Parts Catalog.pdf
193_6 76 FLOOR EQUIPMENT AND S Spare Parts Catalog.pdf
194_6 78 FLOOR HOLE PLUG Spare Parts Catalog.pdf
195_6 80 BACK PANEL Spare Parts Catalog.pdf
196_6 82 BACK GLASS AND WEATHE Spare Parts Catalog.pdf
197_6 84 BACK TRIM Spare Parts Catalog.pdf
198_6 90 REAR BUMPER Spare Parts Catalog.pdf
199_7 INTERIOR TRIM EMBLEMS LABELS Spare Parts Catalog.pdf
200_7 01 EMBLEM AND NAME PLATE Spare Parts Catalog.pdf
201_7 10 CAUTION PLATE AND LAB Spare Parts Catalog.pdf
202_7 20 MIRROR AND MIRROR STA Spare Parts Catalog.pdf
203_7 30 LOCK CYLINDER SET Spare Parts Catalog.pdf
204_7 40 INSTRUMENT PANEL AND Spare Parts Catalog.pdf
205_7 41 UNDER COVER INSTRUME Spare Parts Catalog.pdf
206_7 42 ASH TRAY Spare Parts Catalog.pdf
207_7 43 SUN VISOR AND ASSIST Spare Parts Catalog.pdf
208_7 45 CONSOLE BOX Spare Parts Catalog.pdf
209_7 50 FRONT SEAT Spare Parts Catalog.pdf
210_7 60 SEAT BELT Spare Parts Catalog.pdf
211_7 70 SEPARATER AND BED Spare Parts Catalog.pdf
212_8 CHASSIS ELECTRICAL HEATING AI Spare Parts Catalog.pdf
213_8 01 LAMP FRONT AND FRONT Spare Parts Catalog.pdf
214_8 03 LAMP REAR AND REAR S Spare Parts Catalog.pdf
215_8 05 INTERIOR LAMP Spare Parts Catalog.pdf
216_8 10 WIRING HARNESS AND FU Spare Parts Catalog.pdf
217_8 15 FIXING PARTS WIRING Spare Parts Catalog.pdf
218_8 20 METER CABLE Spare Parts Catalog.pdf
219_8 21 METER ASM Spare Parts Catalog.pdf
220_8 25 SWITCH AND RELAY INS Spare Parts Catalog.pdf
221_8 26 ELECTRICAL CONTROL AN Spare Parts Catalog.pdf
222_8 28 CHASSIS ELECTRICAL Spare Parts Catalog.pdf
223_8 40 HEATER SYSTEM Spare Parts Catalog.pdf
224_8 45 HEATER PIPING Spare Parts Catalog.pdf
225_8 50 AIR CONDITIONING SYST Spare Parts Catalog.pdf
226_8 52 PIPING AIR CONDITION Spare Parts Catalog.pdf
227_8 60 HEATER UNIT FRONT Spare Parts Catalog.pdf
228_8 65 CONTROL LEVER HEATER Spare Parts Catalog.pdf
229_8 71 COMPRESSOR AIR CONDI Spare Parts Catalog.pdf
230_8 73 BLOWER UNIT Spare Parts Catalog.pdf
231_8 74 EVAPORATOR Spare Parts Catalog.pdf
232_8 75 CONDENSER Spare Parts Catalog.pdf
233_8 80 WINDSHIELD WIPER AND Spare Parts Catalog.pdf
234_8 90 RADIO AND TV Spare Parts Catalog.pdf
235_9 TOOLS REAR BODY Spare Parts Catalog.pdf
236_9 01 TOOLS Spare Parts Catalog.pdf
Part Number: 10660
