Momed80
150
35,046
Isuzu Transmission TF Series JR405E Workshop Manual
Type of Machine: Transmission
Type of Manual: Workshop Manual, Diagnostic Trouble Code - DTC
Model: Isuzu TF Series JR405E Transmission
Number of Pages: 320 Pages
Section 7a1
Description
Construction
Main Data And Specification
Number Plate Location
Electronic Control Components Location
Transmission Control Unit (Tcm) Peripheral Circuit
Structure And Function Of Component
Torque Converter (With Lock-Up Function)
Oil Pump
Input Shaft
Output Shaft
Gear Shifting Mechanism
Control Valve
Oil Passage
Parking Function
Inhibitor Switch
Turbine Sensor
Speed Sensor
Throttle Position Sensor (Tps)
Engine Speed Sensor (=Tdc Sensor)
Brake Switch
Mode Select Switch
Transmission Control Module (Tcm)
Control Mechanism
Content Of Function And Control
Control Item, Input And Output
Line Pressure Control
Procarmanuals.Com7a1-2 Construction And Function
Page
Lock-Up Control
Direct Electric Shift Control (Desc)
Learning Control
Major Input/Output Component And Their Functions
Control Circuit Block Diagram
Gear Train (Transmission Mechanism) Operation And
Hydraulic Circuit
Construction And Operation
Component Name And Function
Component And Their Operating Condition
Section 7a2
Basic Trouble Shooting
Check Trans Indicator & Self Diagnosis
Diagnosis With Tech 2
Tech 2 Connection
Tech 2 Operating Flow Chart (Start Up)
Typical Scan Data
Miscellaneous Test
Intermittent Diagnosis
Snapshot Display With Tis 2000
Service Programming System (Sps)
Circuit Diagram
Part Location
Connector List
Diagnosis Trouble Code Table
Fail-Safe Function
Section 7a3
Description
Automatic Transmission Fluid (Atf)
Atf Level
Atf Change
Inhibitor Switch
Speed Sensor
Turbine Sensor
Power And 3rd Start Switch
Select Lever
Shift Cable
Solenoids, Oil Pressure Switch And Oil Temperature Sensor
Control Valve Assembly
Flushing The Transmission Fluid Cooler And Line
Transmission Assembly
Section 7a4
Automatic Transmission Disassembly
Control Valve Upper Body
Control Valve Lower Body
Oil Pump Assembly
Clutch Pack (Reverse And High Clutch Assembly)
Carrier And Low Clutch Assembly
Transmission Case
Bearing And Bearing Race Installation Position
Automatic Transmission Reassembly
Service Standard
Special Service Tool
Procarm
