Isuzu SUV UCR UCS INDONESIA 2016 Parts Catalog 51652
Type of Machine: SUV
Model: Isuzu UCR UCS INDONESIA 2016 SUV
Part Number: 51652
Publication Date: 2016
Number of Pages: 619 Pages
001_Section Index 51652 Spare Parts Catalog.pdf
025_0 56 EMISSION SYSTEM Spare Parts Catalog.pdf
030_0 66 GENERATOR Spare Parts Catalog.pdf
031_1 FUEL TANK COOLING AIR INTAKE Spare Parts Catalog.pdf
032_1 01 ACCELERATOR PEDAL AND Spare Parts Catalog.pdf
033_1 10 RADIATOR Spare Parts Catalog.pdf
034_1 11 RADIATOR HOSE AND SUB Spare Parts Catalog.pdf
035_1 30 AIR CLEANER Spare Parts Catalog.pdf
036_1 31 AIR DUCT Spare Parts Catalog.pdf
037_1 35 CHARGE AIR COOLER Spare Parts Catalog.pdf
038_1 40 FUEL TANK Spare Parts Catalog.pdf
039_1 41 FUEL PIPING CHASSIS Spare Parts Catalog.pdf
040_1 50 EXHAUST PIPE AND SILE Spare Parts Catalog.pdf
041_2 CLUTCH TRANSMISSION TRANS AXL Spare Parts Catalog.pdf
042_2 01 CLUTCH Spare Parts Catalog.pdf
043_2 03 CLUTCH PEDAL AND CONT Spare Parts Catalog.pdf
044_2 05 CLUTCH PIPING Spare Parts Catalog.pdf
045_2 06 CLUTCH SLAVE CYLINDER Spare Parts Catalog.pdf
046_2 08 CLUTCH MASTER CYLINDE Spare Parts Catalog.pdf
047_2 10 REPAIR KIT TRANSMISS Spare Parts Catalog.pdf
048_2 20 MANUAL TRANSMISSION A Spare Parts Catalog.pdf
049_2 25 SPEEDOMETER DRIVEN GE Spare Parts Catalog.pdf
050_2 26 MANUAL TRANSMISSION G Spare Parts Catalog.pdf
051_2 30 GEAR SHIFTER AND QUAD Spare Parts Catalog.pdf
052_2 35 MANUAL TRANSMISSION S Spare Parts Catalog.pdf
053_2 40 AUTO TRANS ASM AND RE Spare Parts Catalog.pdf
054_2 41 AUTO TRANS CASE CONVE Spare Parts Catalog.pdf
055_2 42 AUTO TRANS OIL PAN AN Spare Parts Catalog.pdf
056_2 44 AUTO TRANS CONTROL VA Spare Parts Catalog.pdf
057_2 46 AUTO TRANS SUPPORT AN Spare Parts Catalog.pdf
058_2 47 AUTO TRANS PLANETARY Spare Parts Catalog.pdf
059_2 48 AUTO TRANS MULTIPLE D Spare Parts Catalog.pdf
060_2 49 AUTO TRANS INHIBITOR Spare Parts Catalog.pdf
061_2 53 TRANSMISSION OIL COOL Spare Parts Catalog.pdf
062_2 55 AUTO TRANS SHIFT CONT Spare Parts Catalog.pdf
063_2 56 AUTO TRANS CONTROL LI Spare Parts Catalog.pdf
064_2 60 TRANSFER Spare Parts Catalog.pdf
065_2 61 TRANSFER CASE AND GEA Spare Parts Catalog.pdf
066_2 62 TRANSFER SIDE CASE AN Spare Parts Catalog.pdf
067_2 65 MANUAL TRANSFER GEAR Spare Parts Catalog.pdf
068_2 66 MANUAL TRANSFER GEAR Spare Parts Catalog.pdf
070_3 02 FRONT DISC BRAKE CALI Spare Parts Catalog.pdf
072_3 06 REAR DISC BRAKE CALIP Spare Parts Catalog.pdf
073_3 08 PARKING BRAKE Spare Parts Catalog.pdf
074_3 10 BRAKE PEDAL AND CONTR Spare Parts Catalog.pdf
075_3 11 PARKING BRAKE CONTROL Spare Parts Catalog.pdf
076_3 30 BRAKE MASTER CYLINDER Spare Parts Catalog.pdf
077_3 31 BRAKE MASTER VAC AND Spare Parts Catalog.pdf
078_3 50 BRAKE PIPING OIL MAS Spare Parts Catalog.pdf
079_3 52 BRAKE PIPING OIL FRO Spare Parts Catalog.pdf
082_3 60 BRAKE PIPING VACUUM Spare Parts Catalog.pdf
083_4 PROPELLER SHAFT AXLES STEERIN Spare Parts Catalog.pdf
084_4 01 PROPELLER SHAFT Spare Parts Catalog.pdf
085_4 10 FRONT AXLE Spare Parts Catalog.pdf
086_4 11 FRONT HUB AND DRUM OR Spare Parts Catalog.pdf
087_4 12 FRONT DRIVE SHAFT Spare Parts Catalog.pdf
088_4 15 FRONT FINAL DRIVE Spare Parts Catalog.pdf
089_4 20 REAR AXLE CASE AND SH Spare Parts Catalog.pdf
090_4 25 REAR FINAL DRIVE Spare Parts Catalog.pdf
091_4 30 STEERING WHEEL AND CO Spare Parts Catalog.pdf
092_4 31 STEERING COLUMN AND S Spare Parts Catalog.pdf
093_4 33 STEERING LINKAGE Spare Parts Catalog.pdf
094_4 35 POWER STEERING CONTRO Spare Parts Catalog.pdf
095_4 36 POWER STEERING CONTRO Spare Parts Catalog.pdf
096_4 40 STEERING UNIT Spare Parts Catalog.pdf
097_4 42 POWER STEERING OIL PU Spare Parts Catalog.pdf
098_4 50 FRONT SUSPENSION Spare Parts Catalog.pdf
100_4 61 SHOCK ABSORBER REAR Spare Parts Catalog.pdf
101_4 80 ROAD WHEEL Spare Parts Catalog.pdf
102_5 FRAME CAB MOUNTING Spare Parts Catalog.pdf
103_5 01 FRAME AND OTHER PARTS Spare Parts Catalog.pdf
104_5 10 CAB MOUNTING FRAME S Spare Parts Catalog.pdf
105_5 15 CAB MOUNTING CAB SID Spare Parts Catalog.pdf
108_5 40 ENGINE ROOM INSULATOR Spare Parts Catalog.pdf
109_6 EXTERIOR BODY GLASS MOUNTING Spare Parts Catalog.pdf
110_6 01 FRONT BUMPER Spare Parts Catalog.pdf
111_6 03 RADIATOR GRILLE Spare Parts Catalog.pdf
112_6 05 FRONT PANEL Spare Parts Catalog.pdf
113_6 07 FRONT WINDOW GLASS AN Spare Parts Catalog.pdf
114_6 10 ENGINE HOOD AND LOCK Spare Parts Catalog.pdf
115_6 14 DASH PANEL AND FENDER Spare Parts Catalog.pdf
121_6 41 SIDE WINDOW GLASS AND Spare Parts Catalog.pdf
123_6 45 MOLDING AND STRIPE Spare Parts Catalog.pdf
124_6 47 MUD GUARD AND INSULAT Spare Parts Catalog.pdf
125_6 50 REAR DOOR AND HINGE Spare Parts Catalog.pdf
126_6 51 REAR DOOR GLASS AND R Spare Parts Catalog.pdf
127_6 52 REAR DOOR LOCK AND HA Spare Parts Catalog.pdf
128_6 55 REAR DOOR TRIM Spare Parts Catalog.pdf
136_6 81 BACK DOOR AND HINGE Spare Parts Catalog.pdf
137_6 82 BACK GLASS AND WEATHE Spare Parts Catalog.pdf
138_6 83 BACK DOOR LOCK AND HA Spare Parts Catalog.pdf
139_6 84 BACK TRIM Spare Parts Catalog.pdf
140_6 86 TRUNK OPENER AND FUEL Spare Parts Catalog.pdf
141_6 87 TRUNK ROOM PACKAGE AN Spare Parts Catalog.pdf
142_6 90 REAR BUMPER Spare Parts Catalog.pdf
143_7 INTERIOR TRIM EMBLEMS LABELS Spare Parts Catalog.pdf
144_7 01 EMBLEM AND NAME PLATE Spare Parts Catalog.pdf
145_7 10 CAUTION PLATE AND LAB Spare Parts Catalog.pdf
146_7 20 MIRROR AND MIRROR STA Spare Parts Catalog.pdf
147_7 30 LOCK CYLINDER SET Spare Parts Catalog.pdf
148_7 40 INSTRUMENT PANEL AND Spare Parts Catalog.pdf
149_7 42 ASH TRAY Spare Parts Catalog.pdf
150_7 43 SUN VISOR AND ASSIST Spare Parts Catalog.pdf
151_7 45 CONSOLE BOX Spare Parts Catalog.pdf
152_7 50 FRONT SEAT Spare Parts Catalog.pdf
153_7 55 REAR SEAT Spare Parts Catalog.pdf
154_7 60 SEAT BELT Spare Parts Catalog.pdf
155_8 CHASSIS ELECTRICAL HEATING AI Spare Parts Catalog.pdf
156_8 01 LAMP FRONT AND FRONT Spare Parts Catalog.pdf
157_8 03 LAMP REAR AND REAR S Spare Parts Catalog.pdf
158_8 05 INTERIOR LAMP Spare Parts Catalog.pdf
159_8 10 WIRING HARNESS AND FU Spare Parts Catalog.pdf
160_8 15 FIXING PARTS WIRING Spare Parts Catalog.pdf
161_8 21 METER ASM Spare Parts Catalog.pdf
162_8 25 SWITCH AND RELAY INS Spare Parts Catalog.pdf
163_8 26 ELECTRICAL CONTROL AN Spare Parts Catalog.pdf
164_8 27 SUPPLEMENTAL INFLATAB Spare Parts Catalog.pdf
165_8 28 CHASSIS ELECTRICAL Spare Parts Catalog.pdf
166_8 40 HEATER SYSTEM Spare Parts Catalog.pdf
167_8 45 HEATER PIPING Spare Parts Catalog.pdf
168_8 50 AIR CONDITIONING SYST Spare Parts Catalog.pdf
169_8 52 PIPING AIR CONDITION Spare Parts Catalog.pdf
170_8 60 HEATER UNIT FRONT Spare Parts Catalog.pdf
171_8 65 CONTROL LEVER HEATER Spare Parts Catalog.pdf
172_8 71 COMPRESSOR AIR CONDI Spare Parts Catalog.pdf
173_8 72 COOLER UNIT Spare Parts Catalog.pdf
174_8 73 BLOWER UNIT Spare Parts Catalog.pdf
175_8 75 CONDENSER Spare Parts Catalog.pdf
176_8 80 WINDSHIELD WIPER AND Spare Parts Catalog.pdf
177_8 85 REAR WIPER AND WASHER Spare Parts Catalog.pdf
178_8 90 RADIO AND TV Spare Parts Catalog.pdf
179_9 TOOLS REAR BODY Spare Parts Catalog.pdf
180_9 01 TOOLS Spare Parts Catalog.pdf
181_9 31 REAR BODY FLOOR AND Spare Parts Catalog.pdf
182_9 33 REAR BODY GATE AND S Spare Parts Catalog.pdf
Part Number: 51652
