Isuzu N Series 2026 Mechanical Repair Procedures LGHTML-WEN-2761
Type of Manual: Workshop Manual - Mechanical Repair Procedures
Model: Isuzu N Series 24 Cab Model Truck
Date: 2026
Engine: Isuzu 4HK1 Euro2 ; 4HK1 Euro3 ; 4HK1 Euro5 ; 4HK1 Euro6 ; 4JJ1 Euro2 ; 4JJ1 Euro3 ; 4JJ1 Euro5 ; 4JZ1 Euro6 Engine
General Export (Date: 2026/07/17)
Parts Number: LGHTML-WEN-2761
Number of Pages: 15975 Pages
1.1. Engine (4HK1 (Euro2 and Euro3 specification) (Hydraulic brake))
Date: 2026
1B. Mechanical
Camshaft - disassembly
Camshaft - inspection
Camshaft - installation
Camshaft - reassembly
Camshaft - removal
Crankshaft - disassembly
Crankshaft - inspection
Crankshaft - installation
Crankshaft - reassembly
Crankshaft - removal
Crankshaft front oil seal - installation
Crankshaft front oil seal - removal
Crankshaft pulley - installation
Crankshaft pulley - removal
Crankshaft rear oil seal - installation
Crankshaft rear oil seal - removal
Cylinder block - disassembly
Cylinder block - inspection
Cylinder block - installation
Cylinder block - reassembly
Cylinder block - removal
Cylinder head - disassembly
Cylinder head - inspection
Cylinder head - installation
Cylinder head - reassembly
Cylinder head - removal
Cylinder head cover - installation
Cylinder head cover - removal
Engine - installation
Engine - removal
Engine mounting - installation
Engine mounting - removal
Exhaust manifold - inspection
Exhaust manifold - installation
Exhaust manifold - removal
Flywheel - disassembly
Flywheel - inspection
Flywheel - installation
Flywheel - reassembly
Flywheel - removal
Flywheel housing - installation
Flywheel housing - removal
Front cover - installation
Front cover - removal
Idle gear - inspection
Idle gear - installation
Idle gear - removal
Inlet cover - installation
Inlet cover - removal
Piston - disassembly
Piston - inspection
Piston - installation
Piston - reassembly
Piston - removal
Rocker arm shaft - disassembly
Rocker arm shaft - inspection
Rocker arm shaft - installation
Rocker arm shaft - reassembly
Rocker arm shaft - removal
Supplementary Information
1C. Fuel System
Common rail (fuel rail) - installation
Common rail (fuel rail) - removal
FRP regulator - installation
FRP regulator - removal
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel filter - installation
Fuel filter - removal
Fuel filter element - installation
Fuel filter element - removal
Fuel supply pump - installation
Fuel supply pump - removal
Fuel tank - installation
Fuel tank - removal
Fuel tank unit - inspection
Fuel tank unit - installation
Fuel tank unit - removal
Injector - installation
Injector - removal
Pre-fuel filter - installation
Pre-fuel filter - removal
Pre-fuel filter element - installation
Pre-fuel filter element - removal
Pressure limiter - installation
Pressure limiter - removal
Water sedimenter switch (fuel filter side) - inspection
Water sedimenter switch (fuel filter side) - installation
Water sedimenter switch (fuel filter side) - removal
Water sedimenter switch (pre-fuel filter side) - inspection
Water sedimenter switch (pre-fuel filter side) - installation
Water sedimenter switch (pre-fuel filter side) - removal
1D. Cooling
Coolant - inspection
Coolant - replacement
Cooling fan belt - inspection
Cooling fan belt - installation
Cooling fan belt - removal
Cooling fan clutch - inspection
Cooling fan clutch - installation
Cooling fan clutch - removal
Radiator - inspection
Radiator - installation
Radiator - removal
Radiator reserve tank - installation
Radiator reserve tank - removal
Thermostat - inspection
Thermostat - installation
Thermostat - removal
Water pump - inspection
Water pump - installation
Water pump - removal
1E. Lubrication
Engine oil - inspection
Engine oil - replacement
Oil catch tank - installation
Oil catch tank - removal
Oil cooler - disassembly
Oil cooler - installation
Oil cooler - reassembly
Oil cooler - removal
Oil filter - installation
Oil filter - removal
Oil filter element - installation
Oil filter element - removal
Oil pan - installation
Oil pan - removal
Oil pressure switch - inspection
Oil pressure switch - installation
Oil pressure switch - removal
Oil pump - disassembly
Oil pump - inspection
Oil pump - installation
Oil pump - reassembly
Oil pump - removal
1F. Induction
Air cleaner element - inspection
Air cleaner element - installation
Air cleaner element - removal
Intercooler - inspection
Intercooler - installation
Intercooler - removal
Turbocharger - inspection
Turbocharger - installation
Turbocharger - removal
Ventilator - installation
Ventilator - removal
Vertical air intake duct - installation
Vertical air intake duct - removal
1G. Exhaust
Exhaust pipe - inspection
Exhaust pipe - installation
Exhaust pipe - removal
1H. Aux. Emission Control Devices
EGR - inspection
EGR - installation
EGR - removal
1I. Speed Control Systems
Accelerator pedal - installation
Accelerator pedal - removal
Idle up sensor - inspection
Idle up sensor - installation
Idle up sensor - removal
1J. Electrical
Generator - disassembly
Generator - inspection
Generator - installation
Generator - reassembly
Generator - removal
Glow plug - inspection
Glow plug - installation
Glow plug - removal
Starter motor - disassembly
Starter motor - inspection
Starter motor - installation
Starter motor - reassembly
Starter motor - removal
1Z. Engine Electrical Control
Barometric pressure sensor - inspection
Barometric pressure sensor - installation
Barometric pressure sensor - removal
Boost pressure sensor - inspection
Boost pressure sensor - installation
Boost pressure sensor - removal
CKP sensor - inspection
CKP sensor - installation
CKP sensor - removal
CMP sensor - inspection
CMP sensor - installation
CMP sensor - removal
ECM - installation
ECM - removal
ECM - setting
Engine coolant temperature sensor - inspection
Engine coolant temperature sensor - installation
Engine coolant temperature sensor - removal
FRP sensor - inspection
FRP sensor - installation
FRP sensor - removal
Fuel temperature sensor - inspection
Fuel temperature sensor - installation
Fuel temperature sensor - removal
IAT sensor - inspection
IAT sensor - installation
IAT sensor - removal
1.2. Engine (4HK1 (Euro2 specification) (Full air brake))1B. Mechanical
Camshaft - removal
Engine - removal
Flywheel - removal
Idle gear - removal
Piston - inspection
Piston - reassembly
Piston - removal
1C. Fuel System
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel tank - removal
Injector - removal
1D. Cooling
Radiator - removal
1E. Lubrication
Oil pan - removal
Oil pump - removal
1F. Induction
1G. Exhaust
1J. Electrical
Generator - removal
Glow plug - removal
ECM - installation
ECM - removal
ECM - setting
1.3. Engine (4HK1 (Euro5 specification) (Full air brake))1B. Mechanical
Camshaft - removal
Engine - removal
Flywheel - removal
Idle gear - removal
Intake throttle valve - installation
Intake throttle valve - removal
Piston - inspection
Piston - reassembly
Piston - removal
1C. Fuel System
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel cooler - installation
Fuel cooler - removal
Fuel tank - removal
Injector - removal
Pre-fuel filter element - inspection
Water sedimenter switch - inspection
Water sedimenter switch - installation
Water sedimenter switch - removal
1D. Cooling
Radiator - removal
1E. Lubrication
Oil pan - removal
Oil pump - removal
1F. Induction
1G. Exhaust
EGR - inspection
EGR - installation
EGR - removal
1J. Electrical
Generator - removal
Glow plug - removal
ECM - installation
ECM - removal
ECM - setting
MAF and IAT sensor - inspection
MAF and IAT sensor - installation
MAF and IAT sensor - removal
VGS control unit - installation
VGS control unit - removal
1.4. Engine (4HK1 (Euro5 specification) (Hydraulic brake))1B. Mechanical
Camshaft - removal
Engine - removal
Flywheel - removal
Idle gear - removal
Piston - inspection
Piston - reassembly
Piston - removal
1C. Fuel System
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel tank - removal
Injector - removal
1D. Cooling
Radiator - removal
1E. Lubrication
Oil pan - removal
Oil pump - removal
1F. Induction
Air cleaner indicator switch - inspection
Air cleaner indicator switch - installation
Air cleaner indicator switch - removal
1G. Exhaust
EGR - inspection
EGR - installation
EGR - removal
1J. Electrical
Generator - removal
Glow plug - removal
ECM - installation
ECM - removal
ECM - setting
1.5. Engine (4HK1 (Euro6 specification (Full air brake)))1B. Mechanical
Camshaft - removal
Engine - removal
Flywheel - removal
Idle gear - removal
Piston - inspection
Piston - reassembly
Piston - removal
1C. Fuel System
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel tank - removal
Injector - removal
1D. Cooling
Radiator - removal
1E. Lubrication
Oil pan - removal
Oil pump - removal
1F. Induction
1G. Exhaust
DPD - disassembly
DPD - inspection
DPD - installation
DPD - reassembly
DPD - removal
Dosing module - disassembly
Dosing module - installation
Dosing module - reassembly
Dosing module - removal
EGR - inspection
EGR - installation
EGR - removal
Urea fluid - inspection
Urea fluid supply module - disassembly
Urea fluid supply module - inspection
Urea fluid supply module - installation
Urea fluid supply module - reassembly
Urea fluid supply module - removal
Urea fluid supply module filter - installation
Urea fluid supply module filter - removal
Urea fluid tank - installation
Urea fluid tank - removal
Urea fluid tank heater coolant control valve - installation
Urea fluid tank heater coolant control valve - removal
Urea fluid tank level gauge - installation
Urea fluid tank level gauge - removal
Urea SCR - disassembly
Urea SCR - inspection
Urea SCR - installation
Urea SCR - reassembly
Urea SCR - removal
1J. Electrical
Generator - removal
Glow plug - removal
Charge air cooler temperature sensor 1 - inspection
Charge air cooler temperature sensor 1 - installation
Charge air cooler temperature sensor 1 - removal
Charge air cooler temperature sensor - inspection
Charge air cooler temperature sensor - installation
Charge air cooler temperature sensor - removal
DCU - installation
DCU - removal
DCU - setting
ECM - inspection
ECM - installation
ECM - removal
ECM - setting
EGR gas temperature sensor 1 - inspection
EGR gas temperature sensor 1 - installation
EGR gas temperature sensor 1 - removal
EGR gas temperature sensor 2 - inspection
EGR gas temperature sensor 2 - installation
EGR gas temperature sensor 2 - removal
Exhaust differential pressure sensor - inspection
Exhaust differential pressure sensor - installation
Exhaust differential pressure sensor - removal
Exhaust gas temperature sensor 3 - installation
Exhaust gas temperature sensor 3 - removal
Exhaust gas temperature sensor - inspection
Exhaust gas temperature sensor - installation
Exhaust gas temperature sensor - removal
IMT sensor - inspection
IMT sensor - installation
IMT sensor - removal
NOx sensor 1 - inspection
NOx sensor 1 - installation
NOx sensor 1 - removal
NOx sensor 2 - inspection
NOx sensor 2 - installation
NOx sensor 2 - removal
PM sensor - installation
PM sensor - removal
Turbocharger outlet temperature sensor - inspection
Turbocharger outlet temperature sensor - installation
Turbocharger outlet temperature sensor - removal
Urea fluid sensor - inspection
Urea fluid sensor - installation
Urea fluid sensor - removal
1.6. Engine (4HK1 (Euro6 specification (Hydraulic Brake)))1B. Mechanical
Camshaft - removal
Engine - removal
Flywheel - removal
Idle gear - removal
Piston - inspection
Piston - reassembly
Piston - removal
1C. Fuel System
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel tank - removal
Injector - removal
1D. Cooling
Radiator - removal
1E. Lubrication
Oil pan - removal
Oil pump - removal
1F. Induction
1G. Exhaust
DPD - disassembly
DPD - inspection
DPD - installation
DPD - reassembly
DPD - removal
EGR - inspection
EGR - installation
EGR - removal
Urea SCR - removal
1J. Electrical
Generator(Mitsubishi) - disassembly
Generator(Mitsubishi) - inspection
Generator(Mitsubishi) - installation
Generator(Mitsubishi) - reassembly
Generator(Mitsubishi) - removal
Glow plug - removal
DCU - installation
DCU - removal
DCU - setting
ECM - inspection
ECM - installation
ECM - removal
ECM - setting
PM sensor - removal
1.7. Engine (4JJ1 (Euro2 and Euro3 specification))1B. Mechanical
Camshaft - removal
Crankcase - disassembly
Crankcase - installation
Crankcase - reassembly
Crankcase - removal
Engine - removal
Flywheel - removal
Idle gear - removal
Inlet manifold - installation
Inlet manifold - removal
Piston - inspection
Piston - reassembly
Piston - removal
Timing chain - installation
Timing chain - removal
Timing gear case - installation
Timing gear case - removal
1C. Fuel System
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel tank - removal
Injector - removal
1D. Cooling
Radiator - removal
1E. Lubrication
Oil pan - removal
Oil pump - removal
1F. Induction
1G. Exhaust
EGR cooler - inspection
EGR cooler - installation
EGR cooler - removal
EGR valve - inspection
EGR valve - installation
EGR valve - removal
1J. Electrical
Generator - removal
Glow plug - removal
ECM - installation
ECM - removal
ECM - setting
1.8. Engine (4JJ1 (Euro5 specification))1B. Mechanical
Camshaft - removal
Crankcase - removal
Engine - removal
Flywheel - removal
Idle gear - removal
Piston - inspection
Piston - reassembly
Piston - removal
1C. Fuel System
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel tank - removal
Injector - removal
1D. Cooling
Radiator - removal
1E. Lubrication
Oil level switch - installation
Oil level switch - removal
Oil pan - removal
Oil pump - removal
1F. Induction
Turbocharger control solenoid valve - installation
Turbocharger control solenoid valve - removal
1G. Exhaust
POC silencer - inspection
POC silencer - installation
POC silencer - removal
EGR valve - removal
1J. Electrical
Generator - removal
Glow plug - removal
ECM - inspection
ECM - installation
ECM - removal
ECM - setting
1.9. Engine (4JZ1 (Euro6 specification))1B. Mechanical
Camshaft - removal
Engine - removal
Flywheel - removal
Idle gear - removal
PCV valve - installation
PCV valve - removal
Piston - inspection
Piston - reassembly
Piston - removal
VVT control valve - inspection
VVT control valve - installation
VVT control valve - removal
1C. Fuel System
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel tank - removal
Injector - removal
1D. Cooling
Auto tensioner - installation
Auto tensioner - removal
Radiator - removal
1E. Lubrication
Oil check valve - installation
Oil check valve - removal
Oil cooler - inspection
Oil pan - removal
Oil pump - removal
1F. Induction
1G. Exhaust
DPD - disassembly
DPD - inspection
DPD - installation
DPD - reassembly
DPD - removal
EGR valve - removal
Urea fluid electro-thermal heater - installation
Urea fluid electro-thermal heater - removal
Urea SCR - removal
1J. Electrical
Generator - removal
Glow plug - removal
DCU - installation
DCU - removal
DCU - setting
ECM - inspection
ECM - installation
ECM - removal
ECM - setting
EDU - inspection
EDU - installation
EDU - removal
EGR gas temperature sensor - inspection
EGR gas temperature sensor - installation
EGR gas temperature sensor - removal
Engine oil temperature sensor - inspection
Engine oil temperature sensor - installation
Engine oil temperature sensor - removal
Exhaust gas temperature sensor (DPD) - inspection
Exhaust gas temperature sensor (DPD) - installation
Exhaust gas temperature sensor (DPD) - removal
Exhaust gas temperature sensor (oxidation catalyst) - inspection
Exhaust gas temperature sensor (oxidation catalyst) - installation
Exhaust gas temperature sensor (oxidation catalyst) - removal
Exhaust gas temperature sensor (urea SCR) - inspection
Exhaust gas temperature sensor (urea SCR) - installation
Exhaust gas temperature sensor (urea SCR) - removal
Oil level sensor - inspection
Oil level sensor - installation
Oil level sensor - removal
Oil level sensor control unit - installation
Oil level sensor control unit - removal
Oil pressure sensor - inspection
Oil pressure sensor - installation
Oil pressure sensor - removal
PM sensor - removal
Urea fluid quality sensor - inspection
Urea fluid quality sensor - installation
Urea fluid quality sensor - removal
2. Suspension2B. Front Suspension
Leaf rigid suspension - disassembly
Leaf rigid suspension - inspection
Leaf rigid suspension - installation
Leaf rigid suspension - reassembly
Leaf rigid suspension - removal
2C. Rear Suspension
2D. Wheel, Tire System
Disc wheel and tire - inspection
Disc wheel and tire - installation
Disc wheel and tire - removal
3. Driveline, Axle3B. Differentials
Differential oil - replacement
Front final drive (φ244 mm { 9.61 in }) - disassembly
Front final drive (φ244 mm { 9.61 in }) - inspection
Front final drive (φ244 mm { 9.61 in }) - installation
Front final drive (φ244 mm { 9.61 in }) - reassembly
Front final drive (φ244 mm { 9.61 in }) - removal
Rear final drive (φ292 mm { 11.50 in }) - disassembly
Rear final drive (φ292 mm { 11.50 in }) - inspection
Rear final drive (φ292 mm { 11.50 in }) - installation
Rear final drive (φ292 mm { 11.50 in }) - reassembly
Rear final drive (φ292 mm { 11.50 in }) - removal
Rear final drive (φ292 mm { 11.50 in })(LSD) - disassembly
Rear final drive (φ292 mm { 11.50 in })(LSD) - inspection
Rear final drive (φ292 mm { 11.50 in })(LSD) - installation
Rear final drive (φ292 mm { 11.50 in })(LSD) - reassembly
Rear final drive (φ292 mm { 11.50 in })(LSD) - removal
Rear final drive (φ320 mm { 12.6 in }) - disassembly
Rear final drive (φ320 mm { 12.6 in }) - inspection
Rear final drive (φ320 mm { 12.6 in }) - installation
Rear final drive (φ320 mm { 12.6 in }) - reassembly
Rear final drive (φ320 mm { 12.6 in }) - removal
Rear final drive (φ320 mm { 12.6 in })(LSD) - disassembly
Rear final drive (φ320 mm { 12.6 in })(LSD) - inspection
Rear final drive (φ320 mm { 12.6 in })(LSD) - installation
Rear final drive (φ320 mm { 12.6 in })(LSD) - reassembly
Rear final drive (φ320 mm { 12.6 in })(LSD) - removal
3C. Drive Shaft System
Front axle (full air drum brake) - inspection
Front axle (full air drum brake) - installation
Front axle (full air drum brake) - removal
Front axle (hydraulic drum brake) - inspection
Front axle (hydraulic drum brake) - installation
Front axle (hydraulic drum brake) - removal
Front axle shaft (leaf rigid suspension) - inspection
Front axle shaft (leaf rigid suspension) - installation
Front axle shaft (leaf rigid suspension) - removal
Front drive axle (φ244 mm { 9.61 in }) - installation
Front drive axle (φ244 mm { 9.61 in }) - removal
Front hub (drum brake) - disassembly
Front hub (drum brake) - inspection
Front hub (drum brake) - installation
Front hub (drum brake) - reassembly
Front hub (drum brake) - removal
Front propeller shaft - disassembly
Front propeller shaft - inspection
Front propeller shaft - installation
Front propeller shaft - reassembly
Front propeller shaft - removal
Knuckle (full air drum brake) (leaf rigid suspension) - disassembly
Knuckle (full air drum brake) (leaf rigid suspension) - inspection
Knuckle (full air drum brake) (leaf rigid suspension) - installation
Knuckle (full air drum brake) (leaf rigid suspension) - reassembly
Knuckle (full air drum brake) (leaf rigid suspension) - removal
Knuckle (hydraulic drum brake) (leaf rigid suspension) - disassembly
Knuckle (hydraulic drum brake) (leaf rigid suspension) - inspection
Knuckle (hydraulic drum brake) (leaf rigid suspension) - installation
Knuckle (hydraulic drum brake) (leaf rigid suspension) - reassembly
Knuckle (hydraulic drum brake) (leaf rigid suspension) - removal
Knuckle arm (leaf rigid suspension) - inspection
Knuckle arm (leaf rigid suspension) - installation
Knuckle arm (leaf rigid suspension) - removal
Propeller shaft - disassembly
Propeller shaft - inspection
Propeller shaft - installation
Propeller shaft - reassembly
Propeller shaft - removal
Rear axle (full air drum brake) - disassembly
Rear axle (full air drum brake) - inspection
Rear axle (full air drum brake) - installation
Rear axle (full air drum brake) - reassembly
Rear axle (full air drum brake) - removal
Rear axle (hydraulic drum brake) - disassembly
Rear axle (hydraulic drum brake) - inspection
Rear axle (hydraulic drum brake) - installation
Rear axle (hydraulic drum brake) - reassembly
Rear axle (hydraulic drum brake) - removal
Rear axle shaft - inspection
Rear axle shaft - installation
Rear axle shaft - removal
Rear hub (drum brake) - disassembly
Rear hub (drum brake) - inspection
Rear hub (drum brake) - installation
Rear hub (drum brake) - reassembly
Rear hub (drum brake) - removal
Tie rod (leaf rigid suspension) - disassembly
Tie rod (leaf rigid suspension) - inspection
Tie rod (leaf rigid suspension) - installation
Tie rod (leaf rigid suspension) - reassembly
Tie rod (leaf rigid suspension) - removal
Tie rod arm (leaf rigid suspension) - inspection
Tie rod arm (leaf rigid suspension) - installation
Tie rod arm (leaf rigid suspension) - removal
Wheel alignment check
3D. Transfer Case
Front output shaft oil seal (rigid type) - installation
Front output shaft oil seal (rigid type) - removal
Rear output shaft oil seal (rigid type) - installation
Rear output shaft oil seal (rigid type) - removal
Transfer (rigid type) - disassembly
Transfer (rigid type) - inspection
Transfer (rigid type) - installation
Transfer (rigid type) - reassembly
Transfer (rigid type) - removal
4.1. Brakes (Full air)4B. Brake System
Air compressor (4HK1 (Euro2 and Euro3 specification)) - disassembly
Air compressor (4HK1 (Euro2 and Euro3 specification)) - inspection
Air compressor (4HK1 (Euro2 and Euro3 specification)) - installation
Air compressor (4HK1 (Euro2 and Euro3 specification)) - reassembly
Air compressor (4HK1 (Euro2 and Euro3 specification)) - removal
Air compressor (4HK1 (Euro5)) - disassembly
Air compressor (4HK1 (Euro5)) - inspection
Air compressor (4HK1 (Euro5)) - installation
Air compressor (4HK1 (Euro5)) - reassembly
Air compressor (4HK1 (Euro5)) - removal
Air compressor (4HK1 (Euro6)) - disassembly
Air compressor (4HK1 (Euro6)) - inspection
Air compressor (4HK1 (Euro6)) - installation
Air compressor (4HK1 (Euro6)) - reassembly
Air compressor (4HK1 (Euro6)) - removal
Air dryer - disassembly
Air dryer - inspection
Air dryer - installation
Air dryer - reassembly
Air dryer - removal
Brake pedal box - disassembly
Brake pedal box - installation
Brake pedal box - reassembly
Brake pedal box - removal
Brake valve - disassembly
Brake valve - inspection
Brake valve - installation
Brake valve - reassembly
Brake valve - removal
Double check valve - inspection
Double check valve - installation
Double check valve - removal
Front brake chamber (power) - disassembly
Front brake chamber (power) - inspection
Front brake chamber (power) - installation
Front brake chamber (power) - reassembly
Front brake chamber (power) - removal
Front drum brake - disassembly
Front drum brake - inspection
Front drum brake - installation
Front drum brake - reassembly
Front drum brake - removal
Front expander - disassembly
Front expander - inspection
Front expander - installation
Front expander - reassembly
Front expander - removal
Low pressure switch - inspection
Low pressure switch - installation
Low pressure switch - removal
Multi-protection valve - disassembly
Multi-protection valve - inspection
Multi-protection valve - installation
Multi-protection valve - reassembly
Multi-protection valve - removal
Quick release valve - inspection
Quick release valve - installation
Quick release valve - removal
Rear brake chamber (spring) - disassembly
Rear brake chamber (spring) - inspection
Rear brake chamber (spring) - installation
Rear brake chamber (spring) - reassembly
Rear brake chamber (spring) - removal
Rear drum brake - disassembly
Rear drum brake - inspection
Rear drum brake - installation
Rear drum brake - reassembly
Rear drum brake - removal
Rear expander - disassembly
Rear expander - inspection
Rear expander - installation
Rear expander - reassembly
Rear expander - removal
Safety valve - inspection
Safety valve - installation
Safety valve - removal
Stoplight switch - inspection
Stoplight switch - installation
Stoplight switch - removal
4C. Parking Brake System
Hand control brake valve - inspection
Hand control brake valve - installation
Hand control brake valve - removal
Parking brake switch - inspection
Parking brake switch - installation
Parking brake switch - removal
4D. ABS
Front ABS modulator - disassembly
Front ABS modulator - inspection
Front ABS modulator - installation
Front ABS modulator - reassembly
Front ABS modulator - removal
Front exciter ring - inspection
Front exciter ring - installation
Front exciter ring - removal
Front relay valve - disassembly
Front relay valve - inspection
Front relay valve - installation
Front relay valve - reassembly
Front relay valve - removal
Rear ABS modulator - disassembly
Rear ABS modulator - inspection
Rear ABS modulator - installation
Rear ABS modulator - reassembly
Rear ABS modulator - removal
Rear exciter ring - inspection
Rear exciter ring - installation
Rear exciter ring - removal
Rear relay valve - disassembly
Rear relay valve - inspection
Rear relay valve - installation
Rear relay valve - reassembly
Rear relay valve - removal
4E. Speed Retarder System
Exhaust brake solenoid valve - inspection
Exhaust brake solenoid valve - installation
Exhaust brake solenoid valve - removal
Exhaust brake valve (4HK1) - disassembly
Exhaust brake valve (4HK1) - inspection
Exhaust brake valve (4HK1) - installation
Exhaust brake valve (4HK1) - reassembly
Exhaust brake valve (4HK1) - removal
4Z. Brake Electrical Control
ABS control unit - installation
ABS control unit - removal
Front wheel speed sensor - inspection
Front wheel speed sensor - installation
Front wheel speed sensor - removal
Rear wheel speed sensor - inspection
Rear wheel speed sensor - installation
Rear wheel speed sensor - removal
Yaw rate sensor - installation
Yaw rate sensor - removal
Yaw rate sensor - setting
4.2. Brakes (Hydraulic)4B. Brake System
Brake fluid - inspection
Brake fluid - replacement
Brake fluid tank (standard cab) - inspection
Brake fluid tank (standard cab) - installation
Brake fluid tank (standard cab) - removal
Brake fluid tank (wide cab) - inspection
Brake fluid tank (wide cab) - installation
Brake fluid tank (wide cab) - removal
Brake master cylinder - installation
Brake master cylinder - removal
Front wheel cylinder - disassembly
Front wheel cylinder - inspection
Front wheel cylinder - installation
Front wheel cylinder - reassembly
Front wheel cylinder - removal
Rear wheel cylinder - disassembly
Rear wheel cylinder - inspection
Rear wheel cylinder - installation
Rear wheel cylinder - reassembly
Rear wheel cylinder - removal
Vacuum brake booster (standard cab) - inspection
Vacuum brake booster (standard cab) - installation
Vacuum brake booster (standard cab) - removal
Vacuum brake booster (wide cab) - inspection
Vacuum brake booster (wide cab) - installation
Vacuum brake booster (wide cab) - removal
Vacuum pump(4HK1) - installation
Vacuum pump(4HK1) - removal
Vacuum pump(4JZ1) - disassembly
Vacuum pump(4JZ1) - inspection
Vacuum pump(4JZ1) - installation
Vacuum pump(4JZ1) - reassembly
Vacuum pump(4JZ1) - removal
Vacuum switch - inspection
Vacuum switch - installation
Vacuum switch - removal
Parking brake - inspection
Parking brake - installation
Parking brake - removal
Parking brake lever - installation
Parking brake lever - removal
4D. ABS
Front exciter ring (drum brake) - inspection
Front exciter ring (drum brake) - installation
Front exciter ring (drum brake) - removal
Rear exciter ring (drum brake) - inspection
Rear exciter ring (drum brake) - installation
Rear exciter ring (drum brake) - removal
Exhaust brake valve (4JJ1) - disassembly
Exhaust brake valve (4JJ1) - inspection
Exhaust brake valve (4JJ1) - installation
Exhaust brake valve (4JJ1) - reassembly
Exhaust brake valve (4JJ1) - removal
Exhaust brake valve(4JZ1) - inspection
Exhaust brake valve(4JZ1) - installation
Exhaust brake valve(4JZ1) - removal
EHCU - installation
EHCU - removal
EHCU - setting
Front wheel speed sensor (2WD (drum brake)) - inspection
Front wheel speed sensor (2WD (drum brake)) - installation
Front wheel speed sensor (2WD (drum brake)) - removal
Front wheel speed sensor (4WD (drum brake)) - inspection
Front wheel speed sensor (4WD (drum brake)) - installation
Front wheel speed sensor (4WD (drum brake)) - removal
G sensor - inspection
G sensor - installation
G sensor - removal
Rear wheel speed sensor (drum brake) - inspection
Rear wheel speed sensor (drum brake) - installation
Rear wheel speed sensor (drum brake) - removal
Vacuum sensor - installation
Vacuum sensor - removal
5.1. Transmission, Transaxle (MYY)5C. Manual
Backup light switch - inspection
Backup light switch - installation
Backup light switch - removal
Control box - disassembly
Control box - inspection
Control box - reassembly
Counter shaft (5-speed) - disassembly
Counter shaft (5-speed) - inspection
Counter shaft (5-speed) - reassembly
Counter shaft (6-speed) - disassembly
Counter shaft (6-speed) - inspection
Counter shaft (6-speed) - reassembly
Gear control cable - inspection
Gear control cable - installation
Gear control cable - removal
Input shaft - disassembly
Input shaft - inspection
Input shaft - reassembly
Main shaft (5-speed) - disassembly
Main shaft (5-speed) - inspection
Main shaft (5-speed) - reassembly
Main shaft (6-speed) - disassembly
Main shaft (6-speed) - inspection
Main shaft (6-speed) - reassembly
Neutral switch - inspection
Neutral switch - installation
Neutral switch - removal
Rear oil seal (5-speed) - installation
Rear oil seal (5-speed) - removal
Rear oil seal (6-speed) - installation
Rear oil seal (6-speed) - removal
Shift lever - installation
Shift lever - removal
Speedometer driven gear - installation
Speedometer driven gear - removal
Transmission (5-speed) - disassembly
Transmission (5-speed) - inspection
Transmission (5-speed) - installation
Transmission (5-speed) - reassembly
Transmission (5-speed) - removal
Transmission (6-speed) - disassembly
Transmission (6-speed) - inspection
Transmission (6-speed) - installation
Transmission (6-speed) - reassembly
Transmission (6-speed) - removal
Transmission oil - inspection
Transmission oil - replacement
5E. Clutch System
Clutch - inspection
Clutch - installation
Clutch - removal
Clutch booster - disassembly
Clutch booster - inspection
Clutch booster - reassembly
Clutch control - inspection
Clutch control - installation
Clutch control - removal
Clutch master cylinder - disassembly
Clutch master cylinder - inspection
Clutch master cylinder - reassembly
Clutch oil pressure switch - inspection
Clutch oil pressure switch - installation
Clutch oil pressure switch - removal
Clutch switch - installation
Clutch switch - removal
Shift fork - inspection
Shift fork - installation
Shift fork - removal
Slave cylinder (automatic adjustment) - disassembly
Slave cylinder (automatic adjustment) - inspection
Slave cylinder (automatic adjustment) - reassembly
Slave cylinder (manual adjustment) - disassembly
Slave cylinder (manual adjustment) - inspection
Slave cylinder (manual adjustment) - reassembly
5F. PTO
PTO control cable (oil pump direct-mounted type) - installation
PTO control cable (oil pump direct-mounted type) - removal
PTO control lever - disassembly
PTO control lever - installation
PTO control lever - reassembly
PTO control lever - removal
Side PTO (cable control) - disassembly
Side PTO (cable control) - inspection
Side PTO (cable control) - installation
Side PTO (cable control) - reassembly
Side PTO (cable control) - removal
Side PTO (electronic control) - disassembly
Side PTO (electronic control) - inspection
Side PTO (electronic control) - installation
Side PTO (electronic control) - reassembly
Side PTO (electronic control) - removal
Side PTO (oil pump direct-mounted type) - disassembly
Side PTO (oil pump direct-mounted type) - inspection
Side PTO (oil pump direct-mounted type) - installation
Side PTO (oil pump direct-mounted type) - reassembly
Side PTO (oil pump direct-mounted type) - removal
5Z. Transmission Electrical Control
Clutch stroke sensor - inspection
Clutch stroke sensor - installation
Clutch stroke sensor - removal
PTO control unit - installation
PTO control unit - removal
Vehicle speed sensor - inspection
Vehicle speed sensor - installation
Vehicle speed sensor - removal
5.2. Transmission, Transaxle (MZZ)5C. Manual
Counter shaft - disassembly
Counter shaft - inspection
Counter shaft - reassembly
Main shaft - disassembly
Main shaft - inspection
Main shaft - reassembly
Rear oil seal - installation
Rear oil seal - removal
Transmission - disassembly
Transmission - inspection
Transmission - installation
Transmission - reassembly
Transmission - removal
5E. Clutch System
Clutch - inspection
Clutch - removal
5F. PTO
5.3. Transmission, Transaxle (Smoother (MYY))5C. Manual
ATF - inspection
ATF - replacement
ATF cooler - inspection
ATF cooler - installation
ATF cooler - removal
Gear shift unit - disassembly
Gear shift unit - inspection
Gear shift unit - reassembly
Smoother parts - inspection
Smoother parts - installation
Smoother parts - removal
5F. PTO
Input speed sensor - inspection
Input speed sensor - installation
Input speed sensor - removal
Select stroke sensor - inspection
Select stroke sensor - installation
Select stroke sensor - removal
Shift stroke sensor - inspection
Shift stroke sensor - installation
Shift stroke sensor - removal
TCM - installation
TCM - removal
TCM - setting
Turbine speed sensor - inspection
Turbine speed sensor - installation
Turbine speed sensor - removal
6. Steering6B. Power Assisted System
Drag link - inspection
Drag link - installation
Drag link - removal
Power steering fluid - replacement
Power steering oil pump (4H series engine) - disassembly
Power steering oil pump (4H series engine) - inspection
Power steering oil pump (4H series engine) - installation
Power steering oil pump (4H series engine) - reassembly
Power steering oil pump (4H series engine) - removal
Power steering oil pump (4JJ1) - disassembly
Power steering oil pump (4JJ1) - inspection
Power steering oil pump (4JJ1) - installation
Power steering oil pump (4JJ1) - reassembly
Power steering oil pump (4JJ1) - removal
Power steering oil pump (4JZ1) - disassembly
Power steering oil pump (4JZ1) - inspection
Power steering oil pump (4JZ1) - installation
Power steering oil pump (4JZ1) - reassembly
Power steering oil pump (4JZ1) - removal
Power steering unit (leaf rigid suspension) - disassembly
Power steering unit (leaf rigid suspension) - inspection
Power steering unit (leaf rigid suspension) - installation
Power steering unit (leaf rigid suspension) - reassembly
Power steering unit (leaf rigid suspension) - removal
Steering shaft - inspection
Steering shaft - installation
Steering shaft - removal
7. HVAC7B. Heater Ventilator Airconditioner
A_C compressor (4HK1) - installation
A_C compressor (4HK1) - removal
A_C compressor (4JJ1) - installation
A_C compressor (4JJ1) - removal
A_C compressor (4JZ1) - installation
A_C compressor (4JZ1) - removal
A_C compressor drive belt(4HK1) - inspection
A_C compressor drive belt(4HK1) - installation
A_C compressor drive belt(4HK1) - removal
A_C compressor drive belt(4JJ1) - inspection
A_C compressor drive belt(4JJ1) - installation
A_C compressor drive belt(4JJ1) - removal
Air mix door - installation
Air mix door - removal
Blower - installation
Blower - removal
Blower module - inspection
Blower module - installation
Blower module - removal
Blower motor - inspection
Blower motor - installation
Blower motor - removal
Condenser - installation
Condenser - removal
Condenser fan - inspection
Condenser fan - installation
Condenser fan - removal
Control panel - inspection
Control panel - installation
Control panel - removal
Control panel - setting
Evaporator core - installation
Evaporator core - removal
Expansion valve - installation
Expansion valve - removal
Heater core - installation
Heater core - removal
Heater evaporator unit - installation
Heater evaporator unit - removal
Inside and outside air filter - installation
Inside and outside air filter - removal
Intake actuator - installation
Intake actuator - removal
Intake door - installation
Intake door - removal
Mix actuator - installation
Mix actuator - removal
Mode actuator - installation
Mode actuator - removal
Mode door - installation
Mode door - removal
Pressure switch - inspection
Pressure switch - installation
Pressure switch - removal
Rear cooler switch - inspection
Rear cooler switch - installation
Rear cooler switch - removal
Rear cooler unit - disassembly
Rear cooler unit - inspection
Rear cooler unit - installation
Rear cooler unit - reassembly
Rear cooler unit - removal
Receiver dryer - installation
Receiver dryer - removal
Vent grille (center and driver side) - installation
Vent grille (center and driver side) - removal
Vent grille (passenger side) - installation
Vent grille (passenger side) - removal
Ventilation duct - installation
Ventilation duct - removal
8. Restraints8B. Airbag Systems
Driver airbag - installation
Driver airbag - removal
Driver airbag - scrapping
Passenger airbag - installation
Passenger airbag - removal
Passenger airbag - scrapping
SRS coil - installation
SRS coil - removal
8C. Seat Belt Systems
Buckle side driver seat belt - installation
Buckle side driver seat belt - removal
Buckle side passenger seat belt - installation
Buckle side passenger seat belt - removal
Front buckle side center seat belt - installation
Front buckle side center seat belt - removal
Front tongue side center seat belt - installation
Front tongue side center seat belt - removal
Rear buckle side center seat belt - installation
Rear buckle side center seat belt - removal
Rear buckle side seat belt - installation
Rear buckle side seat belt - removal
Rear tongue side center seat belt - installation
Rear tongue side center seat belt - removal
Seat belt with pretensioner - installation
Seat belt with pretensioner - removal
Seat belt with pretensioner - scrapping
Seat belt without pretensioner - installation
Seat belt without pretensioner - removal
8Z. Seat Belt and SRS Airbag Electrical Control
Satellite sensor - installation
Satellite sensor - removal
SRS control unit - installation
SRS control unit - removal
SRS control unit - setting
9. Body, Cab, Accessories9A. Lighting Systems
Backup light bulb - installation
Backup light bulb - removal
Clearance light - installation
Clearance light - removal
Combination switch - inspection
Combination switch - installation
Combination switch - removal
Daytime running light - installation
Daytime running light - removal
Dome light bulb - installation
Dome light bulb - removal
Door switch - inspection
Door switch - installation
Door switch - removal
Fog light - installation
Fog light - removal
Front turn signal light - installation
Front turn signal light - removal
Front turn signal light bulb - installation
Front turn signal light bulb - removal
Hazard warning flasher switch - inspection
Hazard warning flasher switch - installation
Hazard warning flasher switch - removal
Headlight - inspection
Headlight - installation
Headlight - removal
Headlight bulb - installation
Headlight bulb - removal
Headlight leveling switch - inspection
Headlight leveling switch - installation
Headlight leveling switch - removal
License plate light bulb - installation
License plate light bulb - removal
Rear combination light - inspection
Rear combination light - installation
Rear combination light - removal
Rear fog light bulb - installation
Rear fog light bulb - removal
Rear turn signal light bulb - installation
Rear turn signal light bulb - removal
Side turn signal light - installation
Side turn signal light - removal
Side turn signal light bulb - installation
Side turn signal light bulb - removal
Tail stoplight bulb - installation
Tail stoplight bulb - removal
9B. Wiper, Washer Systems
Washer motor - inspection
Washer motor - installation
Washer motor - removal
Wiper arm - installation
Wiper arm - removal
Wiper blade rubber - installation
Wiper blade rubber - removal
Wiper linkage - installation
Wiper linkage - removal
Wiper motor - installation
Wiper motor - removal
9C. Electrical Control, Entertainment
Accessory socket - installation
Accessory socket - removal
Antenna - inspection
Antenna - installation
Antenna - removal
DC-DC converter (display audio, headlight, fog light, headlight leveling) - installation
DC-DC converter (display audio, headlight, fog light, headlight leveling) - removal
DC-DC converter (headlight, fog light, headlight leveling) - installation
DC-DC converter (headlight, fog light, headlight leveling) - removal
DC-DC converter (wireless access module, roof antenna) - installation
DC-DC converter (wireless access module, roof antenna) - removal
Display audio - installation
Display audio - removal
Door speaker - inspection
Door speaker - installation
Door speaker - removal
DPD switch - inspection
DPD switch - installation
DPD switch - removal
Horn - inspection
Horn - installation
Horn - removal
Horn switch - installation
Horn switch - removal
Ignition switch - inspection
Ignition switch - installation
Ignition switch - removal
Radio - installation
Radio - removal
Smoother emergency switch - inspection
Smoother emergency switch - installation
Smoother emergency switch - removal
Steering wheel switch - inspection
Steering wheel switch - installation
Steering wheel switch - removal
USB charger - installation
USB charger - removal
9E. Instrumentation, Driver Info
Back buzzer - inspection
Back buzzer - installation
Back buzzer - removal
Instrument panel cluster - diagnostics
Instrument panel cluster - installation
Instrument panel cluster - removal
9G. Hood, Fenders, Doors
Cab back cover - installation
Cab back cover - removal
Engine under cover - installation
Engine under cover - removal
Front door (standard cab, wide cab) - disassembly
Front door (standard cab, wide cab) - installation
Front door (standard cab, wide cab) - reassembly
Front door (standard cab, wide cab) - removal
Front step - installation
Front step - removal
Mud valance cover - installation
Mud valance cover - removal
Rear door (standard cab, wide cab) - disassembly
Rear door (standard cab, wide cab) - installation
Rear door (standard cab, wide cab) - reassembly
Rear door (standard cab, wide cab) - removal
Rear mudguard - installation
Rear mudguard - removal
Rear step - installation
Rear step - removal
9H. Cab Structure
Air outlet valve - installation
Air outlet valve - removal
Engine cover - installation
Engine cover - removal
Engine cover lock - installation
Engine cover lock - removal
Front bumper - disassembly
Front bumper - installation
Front bumper - reassembly
Front bumper - removal
Front panel - installation
Front panel - removal
Front side panel - installation
Front side panel - removal
Radiator grille - disassembly
Radiator grille - installation
Radiator grille - reassembly
Radiator grille - removal
9I. Seats
Driver seat - disassembly
Driver seat - installation
Driver seat - reassembly
Driver seat - removal
Driver suspension seat - installation
Driver suspension seat - removal
Passenger seat (integrated type) - disassembly
Passenger seat (integrated type) - installation
Passenger seat (integrated type) - reassembly
Passenger seat (integrated type) - removal
Passenger seat (separate type) - disassembly
Passenger seat (separate type) - installation
Passenger seat (separate type) - reassembly
Passenger seat (separate type) - removal
Rear seat (stationary type) - installation
Rear seat (stationary type) - removal
9J. Security and Locks
Front door lock (standard cab, wide cab) - installation
Front door lock (standard cab, wide cab) - removal
Key cylinder (standard cab, wide cab) - installation
Key cylinder (standard cab, wide cab) - removal
Rear door lock (standard cab, wide cab) - installation
Rear door lock (standard cab, wide cab) - removal
Steering lock - installation
Steering lock - removal
Steering lock barrel - installation
Steering lock barrel - removal
Transponder key - setting
9L. Exterior, Interior Trim
Back lower trim (standard cab) - installation
Back lower trim (standard cab) - removal
Back lower trim (wide cab) - installation
Back lower trim (wide cab) - removal
Front pillar trim cover - installation
Front pillar trim cover - removal
Head lining (crew cab) - installation
Head lining (crew cab) - removal
Head lining (single cab) - installation
Head lining (single cab) - removal
Header tray - installation
Header tray - removal
Instrument panel (standard cab) - disassembly
Instrument panel (standard cab) - installation
Instrument panel (standard cab) - reassembly
Instrument panel (standard cab) - removal
Instrument panel (wide cab) - disassembly
Instrument panel (wide cab) - installation
Instrument panel (wide cab) - reassembly
Instrument panel (wide cab) - removal
Rear pillar trim - installation
Rear pillar trim - removal
Reinforcement - installation
Reinforcement - removal
9M. Cab Mounting
Cab - installation
Cab - removal
Cab lock - installation
Cab lock - removal
Cab lock switch - inspection
Cab lock switch - installation
Cab lock switch - removal
Cab tilt stay - installation
Cab tilt stay - removal
Front cab mounting - installation
Front cab mounting - removal
Rear cab mounting (crew cab) - installation
Rear cab mounting (crew cab) - removal
Rear cab mounting (single cab) - installation
Rear cab mounting (single cab) - removal
9T. Glass, Windows, Mirrors
Backlight glass - installation
Backlight glass - removal
Door mounted outside rearview mirror - disassembly
Door mounted outside rearview mirror - installation
Door mounted outside rearview mirror - reassembly
Door mounted outside rearview mirror - removal
Front door power window switch - inspection
Front door power window switch - installation
Front door power window switch - removal
Front windshield glass - installation
Front windshield glass - removal
Rear door power window switch - inspection
Rear door power window switch - installation
Rear door power window switch - removal
9Z. Body, Cab, Accessories Electrical Control
BCM - installation
BCM - removal
BCM - setting
CAN converter control unit (FCG) - installation
CAN converter control unit (FCG) - removal
CAN converter control unit (FCG) - setting
Information module - installation
Information module - removal
Information module - setting
Wireless access module - installation
Wireless access module - removal
Wireless access module - setting
