Isuzu N Series 2025 2026 Electronic Service Information Wiring Diagram LGHTML-WEN-2541
Type of Manual: Electronic Service Information - Mechanical Repair Procedures, Diagnostics Service Information - Troubleshooting(DTC), Wiring Diagram
Model: Isuzu N Series 24 Cab Model Truck
Date: 2025, 2026
Engine: Isuzu 4HK1 ; 4JZ1 Euro6 ; 4JZ1 PPNLT ; RZ4E-TC Euro6 Engine
2WD models for Australia and New Zealand only (Date: 2026/01/16)
Parts Number: LGHTML-WEN-2541
Purchase Options: You can buy the Full Package or click on the individual links below to buy them separately.
------ List of Files ------
1. [Mechanical Repair Procedures]
2. [Diagnostics Service Information - Troubleshooting(DTC)]
3. [Wiring Diagram]
LHD ABSIESCEBS.pdf​
LHD Backup Light.pdf​
LHD Battery Equalizer.pdf​
LHD Body Control.pdf​
LHD Center DisplayMonitorAudio (Audio).pdf​
LHD Central ECU.pdf​
LHD Central Gateway.pdf​
LHD Combination Meter.pdf​
LHD Combination Switch.pdf​
LHD Controller Area Network (ADAS Local CAN1).pdf​
LHD Controller Area Network (ADAS Local CAN2).pdf​
LHD Controller Area Network (ADAS Local CAN3).pdf​
LHD Controller Area Network (Chassis CAN).pdf​
LHD Controller Area Network (Data Storage CAN).pdf​
LHD Controller Area Network (DIAG CAN).pdf​
LHD Controller Area Network (INFO CAN).pdf​
LHD Controller Area Network (ISO CAN).pdf​
LHD Controller Area Network (PT CAN).pdf​
LHD Controller Area Network (Vehicle CAN (J1939)).pdf​
LHD Daytime Running Light.pdf​
LHD DC-DC Converter.pdf​
LHD DCT.pdf​
LHD DLC.pdf​
LHD Dome Light.pdf​
LHD Electric Parking Brake.pdf​
LHD Electrical Socket.pdf​
LHD Engine Control (4HK1).pdf​
LHD Engine Control (4JZ1).pdf​
LHD Fog Light (Front Fog Light).pdf​
LHD Fog Light (Rear Fog Light).pdf​
LHD Fuse Load.pdf​
LHD Ground Distribution (Cab).pdf​
LHD Ground Distribution (Chassis).pdf​
LHD Headlight.pdf​
LHD Horn.pdf​
LHD HVAC.pdf​
LHD Illumination.pdf​
LHD Information Module.pdf​
LHD IO Control.pdf​
LHD Outside Mirror.pdf​
LHD Power Distribution.pdf​
LHD Power Door Locks.pdf​
LHD Power Windows.pdf​
LHD PTO (Cable Control).pdf​
LHD Radar Sensor.pdf​
LHD Seats.pdf​
LHD Service Connector (CAN Converter CU (FCG)).pdf​
LHD Service Connector (Service Connector).pdf​
LHD Smoother.pdf​
LHD SRS airbag.pdf​
LHD Starter and Charging (DCT Smoother).pdf​
LHD Starter and Charging (MT).pdf​
LHD Stereo Camera.pdf​
LHD Stoplight.pdf​
LHD Tachograph.pdf​
LHD Taillight.pdf​
LHD Tire Pressure Monitoring System.pdf​
LHD Turn Signal Light.pdf​
LHD Urea SCR (4HK1).pdf​
LHD Urea SCR (4JZ1).pdf​
LHD Windshield Wiper and Washer.pdf​
LHD Wireless Access Module.pdf​
RHD ABSIESCEBS.pdf​
RHD Backup Light.pdf​
RHD Battery Equalizer.pdf​
RHD Body Control.pdf​
RHD Center DisplayMonitorAudio (Audio).pdf​
RHD Central ECU.pdf​
RHD Central Gateway.pdf​
RHD Combination Meter.pdf​
RHD Combination Switch.pdf​
RHD Controller Area Network (ADAS Local CAN1).pdf​
RHD Controller Area Network (ADAS Local CAN2).pdf​
RHD Controller Area Network (ADAS Local CAN3).pdf​
RHD Controller Area Network (Chassis CAN).pdf​
RHD Controller Area Network (Data Storage CAN).pdf​
RHD Controller Area Network (DIAG CAN).pdf​
RHD Controller Area Network (INFO CAN).pdf​
RHD Controller Area Network (ISO CAN).pdf​
RHD Controller Area Network (PT CAN).pdf​
RHD Controller Area Network (Vehicle CAN (J1939)).pdf​
RHD Cornering Light.pdf​
RHD Daytime Running Light.pdf​
RHD DC-DC Converter.pdf​
RHD DCT.pdf​
RHD DLC.pdf​
RHD Dome Light.pdf​
RHD Electric Parking Brake.pdf​
RHD Electrical Socket.pdf​
RHD Engine Control (4HK1).pdf​
RHD Engine Control (4JZ1 Independent Suspention).pdf​
RHD Engine Control (4JZ1 Rigid Suspention).pdf​
RHD Fog Light (Front Fog Light).pdf​
RHD Fuse Load.pdf​
RHD Ground Distribution (Cab).pdf​
RHD Ground Distribution (Chassis).pdf​
RHD Headlight Washer.pdf​
RHD Headlight.pdf​
RHD Horn.pdf​
RHD HVAC (Front).pdf​
RHD HVAC (Rear).pdf​
RHD Illumination.pdf​
RHD Information Module.pdf​
RHD IO Control.pdf​
RHD Keyless Ride.pdf​
RHD Outside Mirror (Door Mounted Mirror Type).pdf​
RHD Outside Mirror (Pillar Mirror Type).pdf​
RHD Power Distribution.pdf​
RHD Power Door Locks.pdf​
RHD Power Windows.pdf​
RHD PTO (Cable Control).pdf​
RHD PTO (Electrical Control (DCT Smoother)).pdf​
RHD PTO (Electrical Control (MT)).pdf​
RHD Radar Sensor.pdf​
RHD Seats.pdf​
RHD Service Connector (CAN Converter CU (FCG)).pdf​
RHD Service Connector (Service Connector).pdf​
RHD Smoother.pdf​
RHD SRS airbag.pdf​
RHD Starter and Charging (DCT Smoother).pdf​
RHD Starter and Charging (MT).pdf​
RHD Stereo Camera.pdf​
RHD Stoplight.pdf​
RHD Taillight.pdf​
RHD Tire Pressure Monitoring System.pdf​
RHD Turn Signal Light.pdf​
RHD Urea SCR (4HK1).pdf​
RHD Urea SCR (4JZ1).pdf​
RHD Windshield Wiper and Washer.pdf​
RHD Wireless Access Module.pdf​
