Isuzu MT&MV Series 2023 to 2025 Mechanical Repair Procedures HBHTML-WEN-2221
Type of Machine: Bus
Type of Manual: Workshop Manual - Mechanical Repair Procedures
Model: Isuzu MT Series ; MV Series Bus Chassis
Date: 2023 to 2025
Engine: Isuzu 6HK1 Euro2 ; 6HK1 Euro3 ; 6HK1 Euro5 Engine
4th edition, General Export (Date: 2025/06/20)
Parts Number: HBHTML-WEN-2221
Number of Pages: 5025 Pages
Body, Cab, Accessories
9A. Lighting Systems​
Backup light bulb - installation​
Backup light bulb - removal​
Combination switch - inspection​
Combination switch - installation​
Combination switch - removal​
Fog light bulb - installation​
Fog light bulb - removal​
Fog light switch - inspection​
Front clearance light bulb - installation​
Front clearance light bulb - removal​
Front turn signal light bulb - installation​
Front turn signal light bulb - removal​
Hazard warning flasher switch - inspection​
Headlight bulb - installation​
Headlight bulb - removal​
License plate light bulb - installation​
License plate light bulb - removal​
Rear fog light bulb - installation​
Rear fog light bulb - removal​
Rear fog light switch - inspection​
Rear turn signal light bulb - installation​
Rear turn signal light bulb - removal​
Side turn signal light bulb - installation​
Side turn signal light bulb - removal​
Tail stoplight bulb - installation​
Tail stoplight bulb - removal​
9C. Electrical Control, Entertainment​
Cut switch interlocked with exhaust brake - inspection​
Horn - inspection​
Horn - installation​
Horn - removal​
Horn switch - inspection​
Horn switch - installation​
Horn switch - removal​
Ignition switch - inspection​
Ignition switch - installation​
Ignition switch - removal​
9E. Instrumentation, Driver Info​
Back buzzer - inspection​
Back buzzer - installation​
Back buzzer - removal​
Instrument panel cluster - diagnostics​
Instrument panel cluster - setting​
Speed sensor control unit - setting​
9Z. Body, Cab, Accessories Electrical Control​
Auto light control unit - setting​
Auto light sensor - inspection​
BCM - setting​
Brakes (Air over hydraulic)
4B. Brake System​
Air booster - disassembly​
Air booster - inspection​
Air booster - installation​
Air booster - reassembly​
Air booster - removal​
Air compressor (6HK1) - disassembly​
Air compressor (6HK1) - inspection​
Air compressor (6HK1) - installation​
Air compressor (6HK1) - reassembly​
Air compressor (6HK1) - removal​
Air dryer (with separate governor) - disassembly​
Air dryer (with separate governor) - inspection​
Air dryer (with separate governor) - installation​
Air dryer (with separate governor) - reassembly​
Air dryer (with separate governor) - removal​
Air governor - disassembly​
Air governor - inspection​
Air governor - installation​
Air governor - reassembly​
Air governor - removal​
Brake fluid - inspection​
Brake fluid - replacement​
Brake fluid tank - inspection​
Brake fluid tank - installation​
Brake fluid tank - removal​
Brake pedal - inspection​
Brake pedal - installation​
Brake pedal - removal​
Brake valve - disassembly​
Brake valve - inspection​
Brake valve - installation​
Brake valve - reassembly​
Brake valve - removal​
Check valve - inspection​
Check valve - installation​
Check valve - removal​
Front drum brake - disassembly​
Front drum brake - inspection​
Front drum brake - installation​
Front drum brake - reassembly​
Front drum brake - removal​
Front wheel cylinder - disassembly​
Front wheel cylinder - inspection​
Front wheel cylinder - installation​
Front wheel cylinder - reassembly​
Front wheel cylinder - removal​
Low pressure switch - inspection​
Low pressure switch - installation​
Low pressure switch - removal​
Over stroke switch - inspection​
Over stroke switch - installation​
Over stroke switch - removal​
Rear drum brake - disassembly​
Rear drum brake - inspection​
Rear drum brake - installation​
Rear drum brake - reassembly​
Rear drum brake - removal​
Rear wheel cylinder - disassembly​
Rear wheel cylinder - inspection​
Rear wheel cylinder - installation​
Rear wheel cylinder - reassembly​
Rear wheel cylinder - removal​
Safety valve - inspection​
Safety valve - installation​
Safety valve - removal​
Stoplight switch - inspection​
Stoplight switch - installation​
Stoplight switch - removal​
Supplementary Information​
4C. Parking Brake System​
Parking brake - inspection​
Parking brake - installation​
Parking brake - removal​
Parking brake lever - installation​
Parking brake lever - removal​
Parking brake switch - inspection​
Parking brake switch - installation​
Parking brake switch - removal​
4E. Speed Retarder System​
Exhaust brake solenoid valve - inspection​
Exhaust brake solenoid valve - installation​
Exhaust brake solenoid valve - removal​
Exhaust brake valve (6HK1) - inspection​
Exhaust brake valve (6HK1) - installation​
Exhaust brake valve (6HK1) - removal​
Brakes (Full air)
4B. Brake System​
Air compressor (6HK1 (Euro2 and Euro3 specification)) - disassembly​
Air compressor (6HK1 (Euro2 and Euro3 specification)) - inspection​
Air compressor (6HK1 (Euro2 and Euro3 specification)) - installation​
Air compressor (6HK1 (Euro2 and Euro3 specification)) - reassembly​
Air compressor (6HK1 (Euro2 and Euro3 specification)) - removal​
Air compressor (6HK1 (Euro5 specification)) - disassembly​
Air compressor (6HK1 (Euro5 specification)) - inspection​
Air compressor (6HK1 (Euro5 specification)) - installation​
Air compressor (6HK1 (Euro5 specification)) - reassembly​
Air compressor (6HK1 (Euro5 specification)) - removal​
Air dryer (with integrated governor) - disassembly​
Air dryer (with integrated governor) - inspection​
Air dryer (with integrated governor) - installation​
Air dryer (with integrated governor) - reassembly​
Air dryer (with integrated governor) - removal​
Dual relay valve - disassembly​
Dual relay valve - inspection​
Dual relay valve - installation​
Dual relay valve - reassembly​
Dual relay valve - removal​
Front brake chamber (power) - inspection​
Front brake chamber (power) - installation​
Front brake chamber (power) - reassembly​
Front brake chamber (power) - removal​
Front expander - disassembly​
Front expander - inspection​
Front expander - installation​
Front expander - reassembly​
Front expander - removal​
Multi-protection valve - disassembly​
Multi-protection valve - inspection​
Multi-protection valve - installation​
Multi-protection valve - reassembly​
Multi-protection valve - removal​
Rear brake chamber (spring) - disassembly​
Rear brake chamber (spring) - inspection​
Rear brake chamber (spring) - installation​
Rear brake chamber (spring) - reassembly​
Rear brake chamber (spring) - removal​
Rear expander - disassembly​
Rear expander - inspection​
Rear expander - installation​
Rear expander - reassembly​
Rear expander - removal​
Relay valve - disassembly​
Relay valve - inspection​
Relay valve - installation​
Relay valve - reassembly​
Relay valve - removal​
Hand control brake valve - disassembly​
Hand control brake valve - inspection​
Hand control brake valve - installation​
Hand control brake valve - reassembly​
Hand control brake valve - removal​
4D. ABS​
Front ABS modulator - disassembly​
Front ABS modulator - inspection​
Front ABS modulator - installation​
Front ABS modulator - reassembly​
Front ABS modulator - removal​
Front exciter ring - inspection​
Front exciter ring - installation​
Front exciter ring - removal​
Rear ABS modulator - disassembly​
Rear ABS modulator - inspection​
Rear ABS modulator - installation​
Rear ABS modulator - reassembly​
Rear ABS modulator - removal​
Rear exciter ring - inspection​
Rear exciter ring - installation​
Rear exciter ring - removal​
Air cylinder - disassembly​
Air cylinder - inspection​
Air cylinder - installation​
Air cylinder - reassembly​
Air cylinder - removal​
Exhaust brake valve (6HK1 (Euro2 and Euro3 specification)) - inspection​
Exhaust brake valve (6HK1 (Euro2 and Euro3 specification)) - installation​
Exhaust brake valve (6HK1 (Euro2 and Euro3 specification)) - removal​
Exhaust brake valve (6HK1 (Euro5 specification)) - inspection​
Exhaust brake valve (6HK1 (Euro5 specification)) - installation​
Exhaust brake valve (6HK1 (Euro5 specification)) - removal​
Retarder drum - inspection​
Retarder drum - installation​
Retarder drum - removal​
Retarder magnetic valve - inspection​
Retarder magnetic valve - installation​
Retarder magnetic valve - removal​
Stator - disassembly​
Stator - inspection​
Stator - installation​
Stator - reassembly​
Stator - removal​
4Z. Brake Electrical Control​
ABS control unit - installation​
ABS control unit - removal​
Front wheel speed sensor - inspection​
Front wheel speed sensor - installation​
Front wheel speed sensor - removal​
Rear wheel speed sensor - inspection​
Rear wheel speed sensor - installation​
Rear wheel speed sensor - removal​
Driveline, Axle
3B. Differentials​
Differential oil - replacement​
Rear differential (single) (15.5H) - disassembly​
Rear differential (single) (15.5H) - inspection​
Rear differential (single) (15.5H) - installation​
Rear differential (single) (15.5H) - reassembly​
Rear differential (single) (15.5H) - removal​
Rear differential (single) (16.5H) - disassembly​
Rear differential (single) (16.5H) - inspection​
Rear differential (single) (16.5H) - installation​
Rear differential (single) (16.5H) - reassembly​
Rear differential (single) (16.5H) - removal​
3C. Drive Shaft System​
Front axle (air over hydraulic brake) - disassembly​
Front axle (air over hydraulic brake) - inspection​
Front axle (air over hydraulic brake) - installation​
Front axle (air over hydraulic brake) - reassembly​
Front axle (air over hydraulic brake) - removal​
Front axle (full air brake) - disassembly​
Front axle (full air brake) - inspection​
Front axle (full air brake) - installation​
Front axle (full air brake) - reassembly​
Front axle (full air brake) - removal​
Front hub - inspection​
Front hub - installation​
Front hub - removal​
Knuckle (air over hydraulic brake) - disassembly​
Knuckle (air over hydraulic brake) - inspection​
Knuckle (air over hydraulic brake) - installation​
Knuckle (air over hydraulic brake) - reassembly​
Knuckle (air over hydraulic brake) - removal​
Knuckle (full air brake) - disassembly​
Knuckle (full air brake) - inspection​
Knuckle (full air brake) - installation​
Knuckle (full air brake) - reassembly​
Knuckle (full air brake) - removal​
Knuckle arm (air over hydraulic brake) - inspection​
Knuckle arm (air over hydraulic brake) - installation​
Knuckle arm (air over hydraulic brake) - removal​
Knuckle arm (full air brake) - inspection​
Knuckle arm (full air brake) - installation​
Knuckle arm (full air brake) - removal​
Propeller shaft - disassembly​
Propeller shaft - inspection​
Propeller shaft - installation​
Propeller shaft - reassembly​
Propeller shaft - removal​
Rear axle (air over hydraulic brake) - disassembly​
Rear axle (air over hydraulic brake) - inspection​
Rear axle (air over hydraulic brake) - installation​
Rear axle (air over hydraulic brake) - reassembly​
Rear axle (air over hydraulic brake) - removal​
Rear axle (full air brake) - disassembly​
Rear axle (full air brake) - inspection​
Rear axle (full air brake) - installation​
Rear axle (full air brake) - reassembly​
Rear axle (full air brake) - removal​
Rear axle shaft - inspection​
Rear axle shaft - installation​
Rear axle shaft - removal​
Rear hub - inspection​
Rear hub - installation​
Rear hub - removal​
Tie rod - disassembly​
Tie rod - inspection​
Tie rod - installation​
Tie rod - reassembly​
Tie rod - removal​
Tie rod arm (air over hydraulic brake) - inspection​
Tie rod arm (air over hydraulic brake) - installation​
Tie rod arm (air over hydraulic brake) - removal​
Tie rod arm (full air brake) - inspection​
Tie rod arm (full air brake) - installation​
Tie rod arm (full air brake) - removal​
Wheel alignment check​
Engine (6HK1 (Euro2 and Euro3 specification))
1B. Mechanical​
Camshaft - disassembly​
Camshaft - inspection​
Camshaft - installation​
Camshaft - reassembly​
Camshaft - removal​
Crankshaft - disassembly​
Crankshaft - inspection​
Crankshaft - installation​
Crankshaft - reassembly​
Crankshaft - removal​
Crankshaft front oil seal - installation​
Crankshaft front oil seal - removal​
Crankshaft pulley - inspection​
Crankshaft pulley - installation​
Crankshaft pulley - removal​
Crankshaft rear oil seal - installation​
Crankshaft rear oil seal - removal​
Cylinder block - disassembly​
Cylinder block - inspection​
Cylinder block - installation​
Cylinder block - reassembly​
Cylinder block - removal​
Cylinder head - disassembly​
Cylinder head - inspection​
Cylinder head - installation​
Cylinder head - reassembly​
Cylinder head - removal​
Cylinder head cover - installation​
Cylinder head cover - removal​
Engine - installation​
Engine - removal​
Engine mounting - installation​
Engine mounting - removal​
Exhaust manifold - inspection​
Exhaust manifold - installation​
Exhaust manifold - removal​
Flywheel - disassembly​
Flywheel - inspection​
Flywheel - installation​
Flywheel - reassembly​
Flywheel - removal​
Flywheel housing - installation​
Flywheel housing - removal​
Idle gear - inspection​
Idle gear - installation​
Idle gear - removal​
Inlet cover - installation​
Inlet cover - removal​
Intake throttle valve - installation​
Intake throttle valve - removal​
Piston - disassembly​
Piston - inspection​
Piston - installation​
Piston - reassembly​
Piston - removal​
Rocker arm shaft - disassembly​
Rocker arm shaft - inspection​
Rocker arm shaft - installation​
Rocker arm shaft - reassembly​
Rocker arm shaft - removal​
Timing gear case - installation​
Timing gear case - removal​
1C. Fuel System​
Common rail (fuel rail) - installation​
Common rail (fuel rail) - removal​
FRP regulator - installation​
FRP regulator - removal​
Fuel - air bleed​
Fuel - drain water​
Fuel - inspection​
Fuel filter - installation​
Fuel filter - removal​
Fuel filter element - installation​
Fuel filter element - removal​
Fuel supply pump - installation​
Fuel supply pump - removal​
Fuel tank - installation​
Fuel tank - removal​
Fuel tank unit - inspection​
Fuel tank unit - installation​
Fuel tank unit - removal​
Injector - installation​
Injector - removal​
Pre-fuel filter - installation​
Pre-fuel filter - removal​
Pre-fuel filter element - inspection​
Pre-fuel filter element - installation​
Pre-fuel filter element - removal​
Pressure limiter - installation​
Pressure limiter - removal​
Water sedimenter switch - inspection​
Water sedimenter switch - installation​
Water sedimenter switch - removal​
1D. Cooling​
Coolant - inspection​
Coolant - replacement​
Cooling fan belt - inspection​
Cooling fan belt - installation​
Cooling fan belt - removal​
Cooling fan clutch - inspection​
Cooling fan clutch - installation​
Cooling fan clutch - removal​
Radiator - inspection​
Radiator - installation​
Radiator - removal​
Radiator reserve tank - installation​
Radiator reserve tank - removal​
Thermostat - inspection​
Thermostat - installation​
Thermostat - removal​
Water pump - disassembly​
Water pump - inspection​
Water pump - installation​
Water pump - reassembly​
Water pump - removal​
1E. Lubrication​
Engine oil - inspection​
Engine oil - replacement​
Oil cooler - disassembly​
Oil cooler - installation​
Oil cooler - reassembly​
Oil cooler - removal​
Oil filter - inspection​
Oil filter - installation​
Oil filter - removal​
Oil filter element - installation​
Oil filter element - removal​
Oil pan - installation​
Oil pan - removal​
Oil pressure switch - installation​
Oil pressure switch - removal​
Oil pump - disassembly​
Oil pump - inspection​
Oil pump - installation​
Oil pump - reassembly​
Oil pump - removal​
1F. Induction​
Air cleaner element - inspection​
Air cleaner element - installation​
Air cleaner element - removal​
Intercooler - inspection​
Intercooler - installation​
Intercooler - removal​
Turbocharger - inspection​
Turbocharger - installation​
Turbocharger - removal​
1G. Exhaust​
Exhaust pipe - inspection​
Exhaust pipe - installation​
Exhaust pipe - removal​
1H. Aux. Emission Control Devices​
EGR cooler - inspection​
EGR cooler - installation​
EGR cooler - removal​
EGR pipe - inspection​
EGR pipe - installation​
EGR pipe - removal​
EGR valve - inspection​
EGR valve - installation​
EGR valve - removal​
1I. Speed Control Systems​
Accelerator control link - installation​
Accelerator control link - removal​
Accelerator pedal - installation​
Accelerator pedal - removal​
Idle up sensor - installation​
Idle up sensor - removal​
1J. Electrical​
Generator - disassembly​
Generator - inspection​
Generator - installation​
Generator - reassembly​
Generator - removal​
Glow plug - inspection​
Glow plug - installation​
Glow plug - removal​
Starter motor - disassembly​
Starter motor - inspection​
Starter motor - installation​
Starter motor - reassembly​
Starter motor - removal​
1Z. Engine Electrical Control​
Barometric pressure sensor - inspection​
Barometric pressure sensor - installation​
Barometric pressure sensor - removal​
Boost pressure sensor - inspection​
Boost pressure sensor - installation​
Boost pressure sensor - removal​
CKP sensor - inspection​
CKP sensor - installation​
CKP sensor - removal​
CMP sensor - inspection​
CMP sensor - installation​
CMP sensor - removal​
ECM - installation​
ECM - removal​
ECM - setting​
Engine coolant temperature sensor - inspection​
Engine coolant temperature sensor - installation​
Engine coolant temperature sensor - removal​
FRP sensor - inspection​
FRP sensor - installation​
FRP sensor - removal​
Fuel temperature sensor - inspection​
Fuel temperature sensor - installation​
Fuel temperature sensor - removal​
IAT sensor - inspection​
IAT sensor - installation​
IAT sensor - removal​
Engine (6HK1 (Euro5 specification))
1B. Mechanical​
Camshaft - removal​
Engine - removal​
Flywheel - removal​
Piston - removal​
1C. Fuel System​
Fuel - air bleed​
Fuel - drain water​
Fuel - inspection​
Injector - removal​
1D. Cooling​
Radiator - removal​
1E. Lubrication​
Oil pan - removal​
Oil pump - removal​
1F. Induction​
1G. Exhaust​
EGR cooler (cylinder head side) - inspection​
EGR cooler (cylinder head side) - installation​
EGR cooler (cylinder head side) - removal​
EGR cooler (oil cooler side) - inspection​
EGR cooler (oil cooler side) - installation​
EGR cooler (oil cooler side) - removal​
Idle up sensor - inspection​
1J. Electrical​
ECM - installation​
ECM - removal​
ECM - setting​
MAF and IAT sensor - inspection​
MAF and IAT sensor - installation​
MAF and IAT sensor - removal​
Steering
6B. Power Assisted System​
Drag link - disassembly​
Drag link - inspection​
Drag link - installation​
Drag link - reassembly​
Drag link - removal​
Power steering fluid - replacement​
Power steering oil pump - disassembly​
Power steering oil pump - inspection​
Power steering oil pump - installation​
Power steering oil pump - reassembly​
Power steering oil pump - removal​
Power steering unit - disassembly​
Power steering unit - inspection​
Power steering unit - installation​
Power steering unit - reassembly​
Power steering unit - removal​
Steering shaft - inspection​
Steering shaft - installation​
Steering shaft - removal​
Suspension
2B. Front Suspension​
Leaf rigid suspension - disassembly​
Leaf rigid suspension - inspection​
Leaf rigid suspension - installation​
Leaf rigid suspension - reassembly​
Leaf rigid suspension - removal​
2C. Rear Suspension​
2D. Wheel, Tire System​
Disc wheel and tire - inspection​
Disc wheel and tire - installation​
Disc wheel and tire - removal​
Transmission, Transaxle (ESO11306A)
5C. Manual​
Counter shaft - disassembly​
Counter shaft - reassembly​
Gear control cable - installation​
Gear control cable - removal​
Input shaft - disassembly​
Input shaft - reassembly​
Lower quadrant box - disassembly​
Lower quadrant box - reassembly​
Main shaft - disassembly​
Main shaft - inspection​
Main shaft - reassembly​
Shift lever - disassembly​
Shift lever - inspection​
Shift lever - installation​
Shift lever - reassembly​
Shift lever - removal​
Transmission - disassembly​
Transmission - installation​
Transmission - reassembly​
Transmission - removal​
Transmission oil - inspection​
Transmission oil - replacement​
Upper quadrant box - disassembly​
Upper quadrant box - reassembly​
5E. Clutch System​
Clutch - disassembly​
Clutch - inspection​
Clutch - installation​
Clutch - reassembly​
Clutch - removal​
Clutch booster - disassembly​
Clutch booster - inspection​
Clutch booster - installation​
Clutch booster - reassembly​
Clutch booster - removal​
Clutch master cylinder - disassembly​
Clutch master cylinder - inspection​
Clutch master cylinder - installation​
Clutch master cylinder - reassembly​
Clutch master cylinder - removal​
Clutch switch - installation​
Clutch switch - removal​
Shift fork - inspection​
Shift fork - installation​
Shift fork - removal​
5Z. Transmission Electrical Control​
Vehicle speed sensor - installation​
Vehicle speed sensor - removal​
Transmission, Transaxle (MLD)
5C. Manual​
Backup light switch - inspection​
Backup light switch - installation​
Backup light switch - removal​
Counter shaft - inspection​
Input shaft - inspection​
Lower quadrant box - inspection​
Neutral switch - inspection​
Neutral switch - installation​
Neutral switch - removal​
Power assist - disassembly​
Power assist - inspection​
Power assist - reassembly​
Rear oil seal - installation​
Rear oil seal - removal​
Transmission - inspection​
Upper quadrant box - inspection​
5E. Clutch System​
Clutch - removal​
Vehicle speed sensor - inspection​
Transmission, Transaxle (MZW)
5C. Manual​
Control box - disassembly​
Control box - inspection​
Control box - reassembly​
Gear control - disassembly​
Gear control - inspection​
Gear control - reassembly​
Relay lever - disassembly​
Relay lever - reassembly​
5E. Clutch System​
Clutch - removal​
