Isuzu LT Series 2017 to 2024 Mechanical Repair Procedures MHBHTML-WEN-1771
Type of Machine: Bus
Type of Manual: Workshop Manual - Mechanical Repair Procedures
Model: Isuzu LT Series Bus Chassis
Date: 2017 to 2024
Engine: Isuzu 6HK1 Engine
Euro6 models, Hong Kong, Singapore only (Date: 2024/11/15)
Parts Number: MHBHTML-WEN-1771
Number of Pages: 3212 Pages
Body, Cab, Accessories
Date: 2017 to 2024
9A. Lighting Systems
Backup light bulb - installation
Backup light bulb - removal
Combination switch - inspection
Combination switch - installation
Combination switch - removal
Fog light bulb - installation
Fog light bulb - removal
Fog light switch - inspection
Front clearance light bulb - installation
Front clearance light bulb - removal
Front turn signal light bulb - installation
Front turn signal light bulb - removal
Headlight bulb - installation
Headlight bulb - removal
License plate light bulb - installation
License plate light bulb - removal
Rear fog light bulb - installation
Rear fog light bulb - removal
Rear fog light switch - inspection
Rear turn signal light bulb - installation
Rear turn signal light bulb - removal
Tail stoplight bulb - installation
Tail stoplight bulb - removal
9C. Electrical Control, Entertainment
Air horn - inspection
Air horn - installation
Air horn - removal
Battery relay switch - inspection
Cut switch interlocked with exhaust brake - inspection
DPD switch - inspection
DPD switch and HSA OFF switch - inspection
Emergency stop switch - inspection
Engine stop switch - inspection
Horn - inspection
Horn - installation
Horn - removal
Horn switch - inspection
Horn switch - installation
Horn switch - removal
HSA adjustment switch - inspection
HSA reset switch - inspection
Ignition switch - inspection
Ignition switch - installation
Ignition switch - removal
Oil pressure gauge switch - inspection
Starter safety switch - inspection
Sub-starter switch - inspection
Warm up switch - inspection
9E. Instrumentation, Driver Info
Back buzzer - inspection
Back buzzer - installation
Back buzzer - removal
Instrument panel cluster - diagnostics
Oil pressure gauge - inspection
Speed sensor control unit - setting
9Z. Body, Cab, Accessories Electrical Control
CAN converter control unit (FCG) - setting
Information module - setting
Brakes4B. Brake System
Air dryer - disassembly
Air dryer - inspection
Air dryer - installation
Air dryer - reassembly
Air dryer - removal
Brake pedal - inspection
Brake pedal - installation
Brake pedal - removal
Brake valve - disassembly
Brake valve - inspection
Brake valve - installation
Brake valve - reassembly
Brake valve - removal
Check valve - inspection
Check valve - installation
Check valve - removal
Dual relay valve - disassembly
Dual relay valve - inspection
Dual relay valve - installation
Dual relay valve - reassembly
Dual relay valve - removal
Front brake chamber (power) - disassembly
Front brake chamber (power) - inspection
Front brake chamber (power) - installation
Front brake chamber (power) - reassembly
Front brake chamber (power) - removal
Front drum brake - disassembly
Front drum brake - inspection
Front drum brake - installation
Front drum brake - reassembly
Front drum brake - removal
Front expander - disassembly
Front expander - inspection
Front expander - installation
Front expander - reassembly
Front expander - removal
HSA valve - disassembly
HSA valve - inspection
HSA valve - installation
HSA valve - reassembly
HSA valve - removal
Low pressure switch - inspection
Low pressure switch - installation
Low pressure switch - removal
Multi-protection valve - disassembly
Multi-protection valve - inspection
Multi-protection valve - installation
Multi-protection valve - reassembly
Multi-protection valve - removal
Rear brake chamber (spring) - disassembly
Rear brake chamber (spring) - inspection
Rear brake chamber (spring) - installation
Rear brake chamber (spring) - reassembly
Rear brake chamber (spring) - removal
Rear drum brake - disassembly
Rear drum brake - inspection
Rear drum brake - installation
Rear drum brake - reassembly
Rear drum brake - removal
Rear expander - disassembly
Rear expander - inspection
Rear expander - installation
Rear expander - reassembly
Rear expander - removal
Regulating valve - inspection
Regulating valve - installation
Regulating valve - removal
Relay valve - disassembly
Relay valve - inspection
Relay valve - installation
Relay valve - reassembly
Relay valve - removal
Safety valve - inspection
Safety valve - installation
Safety valve - removal
Single air compressor - disassembly
Single air compressor - inspection
Single air compressor - installation
Single air compressor - reassembly
Single air compressor - removal
Stoplight switch - inspection
Stoplight switch - installation
Stoplight switch - removal
Supplementary Information
4C. Parking Brake System
Hand control brake valve - inspection
Hand control brake valve - installation
Hand control brake valve - removal
Parking brake switch - inspection
Parking brake switch - installation
Parking brake switch - removal
4D. ABS
Front ABS modulator - disassembly
Front ABS modulator - inspection
Front ABS modulator - installation
Front ABS modulator - reassembly
Front ABS modulator - removal
Front exciter ring - inspection
Front exciter ring - installation
Front exciter ring - removal
Rear ABS modulator - disassembly
Rear ABS modulator - inspection
Rear ABS modulator - installation
Rear ABS modulator - reassembly
Rear ABS modulator - removal
Rear exciter ring - inspection
Rear exciter ring - installation
Rear exciter ring - removal
4E. Speed Retarder System
Air cylinder - disassembly
Air cylinder - inspection
Air cylinder - installation
Air cylinder - reassembly
Air cylinder - removal
Exhaust brake solenoid valve - inspection
Exhaust brake solenoid valve - installation
Exhaust brake solenoid valve - removal
Exhaust brake valve - inspection
Exhaust brake valve - installation
Exhaust brake valve - removal
Retarder drum - inspection
Retarder drum - installation
Retarder drum - removal
Retarder magnetic valve - inspection
Retarder magnetic valve - installation
Retarder magnetic valve - removal
Stator - disassembly
Stator - inspection
Stator - installation
Stator - reassembly
Stator - removal
4Z. Brake Electrical Control
ABS control unit - installation
ABS control unit - removal
Front wheel speed sensor - inspection
Front wheel speed sensor - installation
Front wheel speed sensor - removal
HSA control unit - installation
HSA control unit - removal
HSA control unit - setting
Rear wheel speed sensor - inspection
Rear wheel speed sensor - installation
Rear wheel speed sensor - removal
Driveline, Axle3B. Differentials
Differential oil - replacement
Rear differential (single) (16.5H) - disassembly
Rear differential (single) (16.5H) - inspection
Rear differential (single) (16.5H) - installation
Rear differential (single) (16.5H) - reassembly
Rear differential (single) (16.5H) - removal
3C. Drive Shaft System
Front axle - disassembly
Front axle - inspection
Front axle - installation
Front axle - reassembly
Front axle - removal
Front hub - inspection
Front hub - installation
Front hub - removal
Knuckle - disassembly
Knuckle - inspection
Knuckle - installation
Knuckle - reassembly
Knuckle - removal
Knuckle arm - inspection
Knuckle arm - installation
Knuckle arm - removal
Propeller shaft - disassembly
Propeller shaft - inspection
Propeller shaft - installation
Propeller shaft - reassembly
Propeller shaft - removal
Rear axle - disassembly
Rear axle - inspection
Rear axle - installation
Rear axle - reassembly
Rear axle - removal
Rear axle shaft - inspection
Rear axle shaft - installation
Rear axle shaft - removal
Rear hub - inspection
Rear hub - installation
Rear hub - removal
Tie rod - disassembly
Tie rod - inspection
Tie rod - installation
Tie rod - reassembly
Tie rod - removal
Tie rod arm - inspection
Tie rod arm - installation
Tie rod arm - removal
Wheel alignment check
Engine (6HK1)1B. Mechanical
Camshaft - disassembly
Camshaft - inspection
Camshaft - installation
Camshaft - reassembly
Camshaft - removal
Crankshaft - disassembly
Crankshaft - inspection
Crankshaft - installation
Crankshaft - reassembly
Crankshaft - removal
Crankshaft front oil seal - installation
Crankshaft front oil seal - removal
Crankshaft pulley - inspection
Crankshaft pulley - installation
Crankshaft pulley - removal
Crankshaft rear oil seal - installation
Crankshaft rear oil seal - removal
Cylinder block - disassembly
Cylinder block - inspection
Cylinder block - installation
Cylinder block - reassembly
Cylinder block - removal
Cylinder head - disassembly
Cylinder head - inspection
Cylinder head - installation
Cylinder head - reassembly
Cylinder head - removal
Cylinder head cover - installation
Cylinder head cover - removal
Engine - installation
Engine - removal
Engine mounting - installation
Engine mounting - removal
Exhaust manifold - inspection
Exhaust manifold - installation
Exhaust manifold - removal
Flywheel - disassembly
Flywheel - inspection
Flywheel - installation
Flywheel - reassembly
Flywheel - removal
Flywheel housing - installation
Flywheel housing - removal
Idle gear - inspection
Idle gear - installation
Idle gear - removal
Inlet cover - installation
Inlet cover - removal
Intake throttle valve - installation
Intake throttle valve - removal
Piston - disassembly
Piston - inspection
Piston - installation
Piston - reassembly
Piston - removal
Rocker arm shaft - disassembly
Rocker arm shaft - inspection
Rocker arm shaft - installation
Rocker arm shaft - reassembly
Rocker arm shaft - removal
Timing gear case - installation
Timing gear case - removal
1C. Fuel System
Common rail (fuel rail) - installation
Common rail (fuel rail) - removal
FRP regulator - installation
FRP regulator - removal
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel filter - installation
Fuel filter - removal
Fuel filter element - installation
Fuel filter element - removal
Fuel supply pump - installation
Fuel supply pump - removal
Fuel tank - installation
Fuel tank - removal
Fuel tank unit - inspection
Fuel tank unit - installation
Fuel tank unit - removal
Injector - installation
Injector - removal
Pre-fuel filter - inspection
Pre-fuel filter - installation
Pre-fuel filter - removal
Pre-fuel filter element - inspection
Pre-fuel filter element - installation
Pre-fuel filter element - removal
Pressure limiter - installation
Pressure limiter - removal
Water sedimenter switch - inspection
Water sedimenter switch - installation
Water sedimenter switch - removal
1D. Cooling
Coolant - inspection
Coolant - replacement
Cooling fan belt - inspection
Cooling fan belt - installation
Cooling fan belt - removal
Cooling fan clutch - inspection
Cooling fan clutch - installation
Cooling fan clutch - removal
Engine coolant level switch - inspection
Engine coolant level switch - installation
Engine coolant level switch - removal
Fan drive belt - inspection
Fan drive belt - installation
Fan drive belt - removal
Radiator - inspection
Radiator - installation
Radiator - removal
Radiator reserve tank - installation
Radiator reserve tank - removal
Thermostat - inspection
Thermostat - installation
Thermostat - removal
Water pump - disassembly
Water pump - inspection
Water pump - installation
Water pump - reassembly
Water pump - removal
1E. Lubrication
Engine oil - inspection
Engine oil - replacement
Oil cooler - disassembly
Oil cooler - installation
Oil cooler - reassembly
Oil cooler - removal
Oil filter - installation
Oil filter - removal
Oil filter element - inspection
Oil filter element - installation
Oil filter element - removal
Oil pan - installation
Oil pan - removal
Oil pressure switch - inspection
Oil pressure switch - installation
Oil pressure switch - removal
Oil pump - disassembly
Oil pump - inspection
Oil pump - installation
Oil pump - reassembly
Oil pump - removal
Oil separator - installation
Oil separator - removal
Oil separator element - installation
Oil separator element - removal
1F. Induction
Air cleaner element - inspection
Air cleaner element - installation
Air cleaner element - removal
Intercooler - inspection
Intercooler - installation
Intercooler - removal
Turbocharger - inspection
Turbocharger - installation
Turbocharger - removal
1G. Exhaust
DPD - disassembly
DPD - inspection
DPD - installation
DPD - reassembly
DPD - removal
Exhaust pipe - inspection
Exhaust pipe - installation
Exhaust pipe - removal
Exhaust throttle solenoid valve - inspection
Exhaust throttle solenoid valve - installation
Exhaust throttle solenoid valve - removal
Exhaust throttle valve - inspection
Exhaust throttle valve - installation
Exhaust throttle valve - removal
1H. Aux. Emission Control Devices
Dosing module - disassembly
Dosing module - installation
Dosing module - reassembly
Dosing module - removal
EGR cooler (cylinder head side) - inspection
EGR cooler (cylinder head side) - installation
EGR cooler (cylinder head side) - removal
EGR cooler (oil cooler side) - inspection
EGR cooler (oil cooler side) - installation
EGR cooler (oil cooler side) - removal
EGR valve - inspection
EGR valve - installation
EGR valve - removal
Urea fluid - inspection
Urea fluid supply module - disassembly
Urea fluid supply module - installation
Urea fluid supply module - reassembly
Urea fluid supply module - removal
Urea fluid supply module filter - installation
Urea fluid supply module filter - removal
Urea fluid tank - installation
Urea fluid tank - removal
Urea fluid tank heater coolant control valve - installation
Urea fluid tank heater coolant control valve - removal
Urea fluid tank level gauge - installation
Urea fluid tank level gauge - removal
Urea SCR - disassembly
Urea SCR - inspection
Urea SCR - installation
Urea SCR - reassembly
Urea SCR - removal
1I. Speed Control Systems
Accelerator control link - installation
Accelerator control link - removal
Accelerator pedal - installation
Accelerator pedal - removal
Idle up sensor - inspection
Idle up sensor - installation
Idle up sensor - removal
1J. Electrical
Generator - disassembly
Generator - inspection
Generator - installation
Generator - reassembly
Generator - removal
Generator drive belt - inspection
Generator drive belt - installation
Generator drive belt - removal
Glow plug - inspection
Glow plug - installation
Glow plug - removal
Starter motor - disassembly
Starter motor - inspection
Starter motor - installation
Starter motor - reassembly
Starter motor - removal
1Z. Engine Electrical Control
Boost pressure sensor - inspection
Boost pressure sensor - installation
Boost pressure sensor - removal
Charge air cooler temperature sensor 1 - inspection
Charge air cooler temperature sensor 1 - installation
Charge air cooler temperature sensor 1 - removal
Charge air cooler temperature sensor - inspection
Charge air cooler temperature sensor - installation
Charge air cooler temperature sensor - removal
CKP sensor - inspection
CKP sensor - installation
CKP sensor - removal
CMP sensor - inspection
CMP sensor - installation
CMP sensor - removal
DCU - installation
DCU - removal
DCU - setting
ECM - inspection
ECM - installation
ECM - removal
ECM - setting
EGR gas temperature sensor 1 - inspection
EGR gas temperature sensor 1 - installation
EGR gas temperature sensor 1 - removal
EGR gas temperature sensor 2 - inspection
EGR gas temperature sensor 2 - installation
EGR gas temperature sensor 2 - removal
Engine coolant temperature sensor - inspection
Engine coolant temperature sensor - installation
Engine coolant temperature sensor - removal
Exhaust differential pressure sensor - inspection
Exhaust differential pressure sensor - installation
Exhaust differential pressure sensor - removal
Exhaust gas temperature sensor 3 - installation
Exhaust gas temperature sensor 3 - removal
Exhaust gas temperature sensor - inspection
Exhaust gas temperature sensor - installation
Exhaust gas temperature sensor - removal
FRP sensor - inspection
FRP sensor - installation
FRP sensor - removal
Fuel temperature sensor - inspection
Fuel temperature sensor - installation
Fuel temperature sensor - removal
IMT sensor - inspection
IMT sensor - installation
IMT sensor - removal
MAF and IAT sensor - inspection
MAF and IAT sensor - installation
MAF and IAT sensor - removal
NOx sensor 1 - inspection
NOx sensor 1 - installation
NOx sensor 1 - removal
NOx sensor 2 - inspection
NOx sensor 2 - installation
NOx sensor 2 - removal
PM sensor - installation
PM sensor - removal
Turbocharger outlet temperature sensor - inspection
Turbocharger outlet temperature sensor - installation
Turbocharger outlet temperature sensor - removal
Urea fluid sensor - inspection
Urea fluid sensor - installation
Urea fluid sensor - removal
Steering6B. Power Assisted System
Drag link - disassembly
Drag link - inspection
Drag link - installation
Drag link - reassembly
Drag link - removal
Power steering fluid - replacement
Power steering oil pump - disassembly
Power steering oil pump - inspection
Power steering oil pump - installation
Power steering oil pump - reassembly
Power steering oil pump - removal
Power steering unit - disassembly
Power steering unit - inspection
Power steering unit - installation
Power steering unit - reassembly
Power steering unit - removal
Steering shaft - inspection
Steering shaft - installation
Steering shaft - removal
Suspension2B. Front Suspension
Air suspension (Holland) - disassembly
Air suspension (Holland) - inspection
Air suspension (Holland) - installation
Air suspension (Holland) - reassembly
Air suspension (Holland) - removal
Leveling valve - disassembly
Leveling valve - inspection
Leveling valve - installation
Leveling valve - reassembly
Leveling valve - removal
2C. Rear Suspension
Air suspension - disassembly
Air suspension - inspection
Air suspension - installation
Air suspension - reassembly
Air suspension - removal
2D. Wheel, Tire System
Disc wheel and tire - inspection
Disc wheel and tire - installation
Disc wheel and tire - removal
Transmission, Transaxle (MAL)5C. Manual
Counter shaft - disassembly
Counter shaft - inspection
Counter shaft - reassembly
Gear control cable - installation
Gear control cable - removal
Input shaft - disassembly
Input shaft - inspection
Input shaft - reassembly
Lower quadrant box - disassembly
Lower quadrant box - inspection
Lower quadrant box - reassembly
Main shaft - disassembly
Main shaft - inspection
Main shaft - reassembly
Oil cooler - inspection
Power assist - disassembly
Power assist - inspection
Power assist - reassembly
Shift lever - installation
Shift lever - removal
Transmission - disassembly
Transmission - inspection
Transmission - installation
Transmission - reassembly
Transmission - removal
Transmission oil - inspection
Transmission oil - replacement
Upper quadrant box - disassembly
Upper quadrant box - inspection
Upper quadrant box - reassembly
5E. Clutch System
Clutch (single plate push type) - disassembly
Clutch (single plate push type) - inspection
Clutch (single plate push type) - installation
Clutch (single plate push type) - reassembly
Clutch (single plate push type) - removal
Clutch booster - disassembly
Clutch booster - inspection
Clutch booster - installation
Clutch booster - reassembly
Clutch booster - removal
Clutch master cylinder - disassembly
Clutch master cylinder - inspection
Clutch master cylinder - installation
Clutch master cylinder - reassembly
Clutch master cylinder - removal
Clutch oil pressure switch - installation
Clutch oil pressure switch - removal
Clutch switch - inspection
Clutch switch - installation
Clutch switch - removal
Shift fork - installation
Shift fork - removal
5Z. Transmission Electrical Control
Clutch pedal stroke sensor - installation
Clutch pedal stroke sensor - removal
Vehicle speed sensor - inspection
Vehicle speed sensor - installation
Vehicle speed sensor - removal
Transmission, Transaxle (T310)5B. Automatic
Accumulator - inspection
Accumulator - installation
Accumulator - removal
ATF - inspection
ATF - replacement
Oil filter - inspection
Range selector switch - installation
Range selector switch - removal
TCM - installation
TCM - removal
