Isuzu LR Series 2019 Mechanical Repair Procedures MBHTML-WEN-1991
Type of Machine: Bus Chassis
Type of Manual: Workshop Manual - Mechanical Repair Procedures
Model: Isuzu LR Series Bus Chassis
Date: 2019
Engine: Isuzu 4HK1 Euro4 ; 4HK1 Euro6 Engine
Hong Kong, Singapore and Vietnam only (Date: 2020/10/09)
Parts Number: MBHTML-WEN-1991
Number of Pages: 4726 Pages
1.1. Engine (4HK1 (Euro4 specification))
1B. Mechanical​
Camshaft - disassembly​
Camshaft - inspection​
Camshaft - installation​
Camshaft - reassembly​
Camshaft - removal​
Crankshaft - disassembly​
Crankshaft - inspection​
Crankshaft - installation​
Crankshaft - reassembly​
Crankshaft - removal​
Crankshaft front oil seal - installation​
Crankshaft front oil seal - removal​
Crankshaft pulley - installation​
Crankshaft pulley - removal​
Crankshaft rear oil seal - installation​
Crankshaft rear oil seal - removal​
Cylinder block - disassembly​
Cylinder block - inspection​
Cylinder block - installation​
Cylinder block - reassembly​
Cylinder block - removal​
Cylinder head - disassembly​
Cylinder head - inspection​
Cylinder head - installation​
Cylinder head - reassembly​
Cylinder head - removal​
Cylinder head cover - installation​
Cylinder head cover - removal​
Engine - installation​
Engine - removal​
Engine mounting - installation​
Engine mounting - removal​
Exhaust manifold - inspection​
Exhaust manifold - installation​
Exhaust manifold - removal​
Flywheel - disassembly​
Flywheel - inspection​
Flywheel - installation​
Flywheel - reassembly​
Flywheel - removal​
Flywheel housing - installation​
Flywheel housing - removal​
Front cover - installation​
Front cover - removal​
Idle gear - inspection​
Idle gear - installation​
Idle gear - removal​
Inlet cover - installation​
Inlet cover - removal​
Intake throttle valve - installation​
Intake throttle valve - removal​
Piston - disassembly​
Piston - inspection​
Piston - installation​
Piston - reassembly​
Piston - removal​
Rocker arm shaft - disassembly​
Rocker arm shaft - inspection​
Rocker arm shaft - installation​
Rocker arm shaft - reassembly​
Rocker arm shaft - removal​
Supplementary Information​
1C. Fuel System​
Common rail (fuel rail) - installation​
Common rail (fuel rail) - removal​
FRP regulator - installation​
FRP regulator - removal​
Fuel - air bleed​
Fuel - drain water​
Fuel - inspection​
Fuel filter - installation​
Fuel filter - removal​
Fuel filter element - installation​
Fuel filter element - removal​
Fuel supply pump - installation​
Fuel supply pump - removal​
Fuel tank - installation​
Fuel tank - removal​
Fuel tank unit - inspection​
Fuel tank unit - installation​
Fuel tank unit - removal​
Injector - installation​
Injector - removal​
Pre-fuel filter - installation​
Pre-fuel filter - removal​
Pre-fuel filter element - inspection​
Pre-fuel filter element - installation​
Pre-fuel filter element - removal​
Pressure limiter - installation​
Pressure limiter - removal​
Water sedimenter switch - inspection​
Water sedimenter switch - installation​
Water sedimenter switch - removal​
1D. Cooling​
Coolant - inspection​
Coolant - replacement​
Cooling fan belt - inspection​
Cooling fan belt - installation​
Cooling fan belt - removal​
Cooling fan clutch - inspection​
Cooling fan clutch - installation​
Cooling fan clutch - removal​
Engine coolant level switch - inspection​
Engine coolant level switch - installation​
Engine coolant level switch - removal​
Fan drive belt - inspection​
Fan drive belt - installation​
Fan drive belt - removal​
Radiator - inspection​
Radiator - installation​
Radiator - removal​
Radiator reserve tank - installation​
Radiator reserve tank - removal​
Thermostat - inspection​
Thermostat - installation​
Thermostat - removal​
Water pump - inspection​
Water pump - installation​
Water pump - removal​
1E. Lubrication​
Engine oil - inspection​
Engine oil - replacement​
Oil cooler - disassembly​
Oil cooler - installation​
Oil cooler - reassembly​
Oil cooler - removal​
Oil filter - installation​
Oil filter - removal​
Oil filter element - installation​
Oil filter element - removal​
Oil pan - installation​
Oil pan - removal​
Oil pressure sensor - installation​
Oil pressure sensor - removal​
Oil pressure switch - inspection​
Oil pressure switch - installation​
Oil pressure switch - removal​
Oil pump - disassembly​
Oil pump - inspection​
Oil pump - installation​
Oil pump - reassembly​
Oil pump - removal​
Oil separator - installation​
Oil separator - removal​
1F. Induction​
Air cleaner element - inspection​
Air cleaner element - installation​
Air cleaner element - removal​
Intercooler - inspection​
Intercooler - installation​
Intercooler - removal​
Turbocharger - inspection​
Turbocharger - installation​
Turbocharger - removal​
1G. Exhaust​
Exhaust pipe - inspection​
Exhaust pipe - installation​
Exhaust pipe - removal​
1H. Aux. Emission Control Devices​
EGR - inspection​
EGR - installation​
EGR - removal​
1I. Speed Control Systems​
Accelerator control link - installation​
Accelerator control link - removal​
Accelerator pedal - installation​
Accelerator pedal - removal​
Idle up sensor - inspection​
Idle up sensor - installation​
Idle up sensor - removal​
1J. Electrical​
Cooler generator - installation​
Cooler generator - removal​
Generator - disassembly​
Generator - inspection​
Generator - installation​
Generator - reassembly​
Generator - removal​
Generator drive belt - inspection​
Generator drive belt - installation​
Generator drive belt - removal​
Glow plug - inspection​
Glow plug - installation​
Glow plug - removal​
Starter motor - disassembly​
Starter motor - inspection​
Starter motor - installation​
Starter motor - reassembly​
Starter motor - removal​
1Z. Engine Electrical Control​
Barometric pressure sensor - inspection​
Barometric pressure sensor - installation​
Barometric pressure sensor - removal​
Boost pressure sensor - inspection​
Boost pressure sensor - installation​
Boost pressure sensor - removal​
CKP sensor - inspection​
CKP sensor - installation​
CKP sensor - removal​
CMP sensor - inspection​
CMP sensor - installation​
CMP sensor - removal​
ECM - installation​
ECM - removal​
ECM - setting​
Engine coolant temperature sensor - inspection​
Engine coolant temperature sensor - installation​
Engine coolant temperature sensor - removal​
FRP sensor - inspection​
FRP sensor - installation​
FRP sensor - removal​
Fuel temperature sensor - inspection​
Fuel temperature sensor - installation​
Fuel temperature sensor - removal​
MAF and IAT sensor - inspection​
MAF and IAT sensor - installation​
MAF and IAT sensor - removal​
VGS control unit - installation​
VGS control unit - removal​
1.2. Engine (4HK1 (Euro6 specification))
1B. Mechanical​
Camshaft - removal​
Engine - removal​
Flywheel - removal​
Piston - removal​
1C. Fuel System​
Fuel - air bleed​
Fuel - drain water​
Fuel - inspection​
Injector - removal​
1D. Cooling​
Radiator - removal​
1E. Lubrication​
Oil pan - removal​
Oil pump - removal​
1F. Induction​
1G. Exhaust​
DPD - disassembly​
DPD - inspection​
DPD - installation​
DPD - reassembly​
DPD - removal​
Exhaust throttle solenoid valve - inspection​
Exhaust throttle solenoid valve - installation​
Exhaust throttle solenoid valve - removal​
Exhaust throttle valve - inspection​
Exhaust throttle valve - installation​
Exhaust throttle valve - removal​
Dosing module - disassembly​
Dosing module - installation​
Dosing module - reassembly​
Dosing module - removal​
EGR - inspection​
EGR - installation​
EGR - removal​
Urea fluid - inspection​
Urea fluid supply module - disassembly​
Urea fluid supply module - inspection​
Urea fluid supply module - installation​
Urea fluid supply module - reassembly​
Urea fluid supply module - removal​
Urea fluid supply module filter - installation​
Urea fluid supply module filter - removal​
Urea fluid tank - installation​
Urea fluid tank - removal​
Urea fluid tank heater coolant control valve - installation​
Urea fluid tank heater coolant control valve - removal​
Urea fluid tank level gauge - installation​
Urea fluid tank level gauge - removal​
Urea SCR - disassembly​
Urea SCR - inspection​
Urea SCR - installation​
Urea SCR - reassembly​
Urea SCR - removal​
1J. Electrical​
Charge air cooler temperature sensor 1 - inspection​
Charge air cooler temperature sensor 1 - installation​
Charge air cooler temperature sensor 1 - removal​
Charge air cooler temperature sensor - inspection​
Charge air cooler temperature sensor - installation​
Charge air cooler temperature sensor - removal​
DCU - installation​
DCU - removal​
DCU - setting​
ECM - inspection​
ECM - installation​
ECM - removal​
ECM - setting​
EGR gas temperature sensor 1 - inspection​
EGR gas temperature sensor 1 - installation​
EGR gas temperature sensor 1 - removal​
EGR gas temperature sensor 2 - inspection​
EGR gas temperature sensor 2 - installation​
EGR gas temperature sensor 2 - removal​
Exhaust differential pressure sensor - inspection​
Exhaust differential pressure sensor - installation​
Exhaust differential pressure sensor - removal​
Exhaust gas temperature sensor 3 - installation​
Exhaust gas temperature sensor 3 - removal​
Exhaust gas temperature sensor - inspection​
Exhaust gas temperature sensor - installation​
Exhaust gas temperature sensor - removal​
IMT sensor - inspection​
IMT sensor - installation​
IMT sensor - removal​
NOx sensor 1 - inspection​
NOx sensor 1 - installation​
NOx sensor 1 - removal​
NOx sensor 2 - inspection​
NOx sensor 2 - installation​
NOx sensor 2 - removal​
PM sensor - installation​
PM sensor - removal​
Turbocharger outlet temperature sensor - inspection​
Turbocharger outlet temperature sensor - installation​
Turbocharger outlet temperature sensor - removal​
Urea fluid sensor - inspection​
Urea fluid sensor - installation​
Urea fluid sensor - removal​
2. Suspension
2B. Front Suspension​
Leaf rigid suspension - disassembly​
Leaf rigid suspension - inspection​
Leaf rigid suspension - installation​
Leaf rigid suspension - reassembly​
Leaf rigid suspension - removal​
Leveling valve - disassembly​
Leveling valve - inspection​
Leveling valve - installation​
Leveling valve - reassembly​
Leveling valve - removal​
2C. Rear Suspension​
Air suspension - disassembly​
Air suspension - inspection​
Air suspension - installation​
Air suspension - reassembly​
Air suspension - removal​
2D. Wheel, Tire System​
Disc wheel and tire - inspection​
Disc wheel and tire - installation​
Disc wheel and tire - removal​
3. Driveline, Axle
3B. Differentials​
Differential oil - replacement​
Rear differential (single) (14.5H) - disassembly​
Rear differential (single) (14.5H) - inspection​
Rear differential (single) (14.5H) - installation​
Rear differential (single) (14.5H) - reassembly​
Rear differential (single) (14.5H) - removal​
3C. Drive Shaft System​
Front axle - disassembly​
Front axle - inspection​
Front axle - installation​
Front axle - reassembly​
Front axle - removal​
Front hub - inspection​
Front hub - installation​
Front hub - removal​
Knuckle - disassembly​
Knuckle - inspection​
Knuckle - installation​
Knuckle - reassembly​
Knuckle - removal​
Knuckle arm - inspection​
Knuckle arm - installation​
Knuckle arm - removal​
Rear axle - disassembly​
Rear axle - inspection​
Rear axle - installation​
Rear axle - reassembly​
Rear axle - removal​
Rear axle shaft - inspection​
Rear axle shaft - installation​
Rear axle shaft - removal​
Rear hub - inspection​
Rear hub - installation​
Rear hub - removal​
Rear propeller shaft - disassembly​
Rear propeller shaft - inspection​
Rear propeller shaft - installation​
Rear propeller shaft - reassembly​
Rear propeller shaft - removal​
Tie rod - disassembly​
Tie rod - inspection​
Tie rod - installation​
Tie rod - reassembly​
Tie rod - removal​
Tie rod arm - inspection​
Tie rod arm - installation​
Tie rod arm - removal​
Wheel alignment check​
4. Brakes
4B. Brake System​
Air dryer (with integrated governor) - disassembly​
Air dryer (with integrated governor) - inspection​
Air dryer (with integrated governor) - installation​
Air dryer (with integrated governor) - reassembly​
Air dryer (with integrated governor) - removal​
Brake pedal - inspection​
Brake pedal - installation​
Brake pedal - removal​
Brake valve - disassembly​
Brake valve - inspection​
Brake valve - installation​
Brake valve - reassembly​
Brake valve - removal​
Check valve - inspection​
Check valve - installation​
Check valve - removal​
Dual relay valve - disassembly​
Dual relay valve - inspection​
Dual relay valve - installation​
Dual relay valve - reassembly​
Dual relay valve - removal​
Front brake chamber (power) - disassembly​
Front brake chamber (power) - inspection​
Front brake chamber (power) - installation​
Front brake chamber (power) - reassembly​
Front brake chamber (power) - removal​
Front drum brake - disassembly​
Front drum brake - inspection​
Front drum brake - installation​
Front drum brake - reassembly​
Front drum brake - removal​
Front expander - disassembly​
Front expander - inspection​
Front expander - installation​
Front expander - reassembly​
Front expander - removal​
HSA valve - disassembly​
HSA valve - inspection​
HSA valve - installation​
HSA valve - reassembly​
HSA valve - removal​
Low pressure switch - inspection​
Low pressure switch - installation​
Low pressure switch - removal​
Multi-protection valve - disassembly​
Multi-protection valve - inspection​
Multi-protection valve - installation​
Multi-protection valve - reassembly​
Multi-protection valve - removal​
Rear brake chamber (spring) - disassembly​
Rear brake chamber (spring) - inspection​
Rear brake chamber (spring) - installation​
Rear brake chamber (spring) - reassembly​
Rear brake chamber (spring) - removal​
Rear drum brake - disassembly​
Rear drum brake - inspection​
Rear drum brake - installation​
Rear drum brake - reassembly​
Rear drum brake - removal​
Rear expander - disassembly​
Rear expander - inspection​
Rear expander - installation​
Rear expander - reassembly​
Rear expander - removal​
Relay valve - disassembly​
Relay valve - inspection​
Relay valve - installation​
Relay valve - reassembly​
Relay valve - removal​
Safety valve - inspection​
Safety valve - installation​
Safety valve - removal​
Stoplight switch - inspection​
Stoplight switch - installation​
Stoplight switch - removal​
4C. Parking Brake System​
Hand control brake valve - disassembly​
Hand control brake valve - inspection​
Hand control brake valve - installation​
Hand control brake valve - reassembly​
Hand control brake valve - removal​
Parking brake switch - inspection​
Parking brake switch - installation​
Parking brake switch - removal​
4D. ABS​
Front ABS modulator - disassembly​
Front ABS modulator - inspection​
Front ABS modulator - installation​
Front ABS modulator - reassembly​
Front ABS modulator - removal​
Front exciter ring - inspection​
Front exciter ring - installation​
Front exciter ring - removal​
Front relay valve - disassembly​
Front relay valve - inspection​
Front relay valve - installation​
Front relay valve - reassembly​
Front relay valve - removal​
Rear ABS modulator - disassembly​
Rear ABS modulator - inspection​
Rear ABS modulator - installation​
Rear ABS modulator - reassembly​
Rear ABS modulator - removal​
Rear exciter ring - inspection​
Rear exciter ring - installation​
Rear exciter ring - removal​
Rear relay valve - disassembly​
Rear relay valve - inspection​
Rear relay valve - installation​
Rear relay valve - reassembly​
Rear relay valve - removal​
4E. Speed Retarder System​
Exhaust brake solenoid valve - inspection​
Exhaust brake solenoid valve - installation​
Exhaust brake solenoid valve - removal​
Exhaust brake valve (4HK1 (Euro4 specification)) - inspection​
Exhaust brake valve (4HK1 (Euro4 specification)) - installation​
Exhaust brake valve (4HK1 (Euro4 specification)) - removal​
Exhaust brake valve (4HK1 (Euro6 specification)) - inspection​
Exhaust brake valve (4HK1 (Euro6 specification)) - installation​
Exhaust brake valve (4HK1 (Euro6 specification)) - removal​
4Z. Brake Electrical Control​
ABS control unit - installation​
ABS control unit - removal​
EBS control unit - installation​
EBS control unit - removal​
EBS control unit - setting​
Front wheel speed sensor - inspection​
Front wheel speed sensor - installation​
Front wheel speed sensor - removal​
Rear wheel speed sensor - inspection​
Rear wheel speed sensor - installation​
Rear wheel speed sensor - removal​
Yaw rate sensor - installation​
Yaw rate sensor - removal​
Yaw rate sensor - setting​
5.1. Transmission, Transaxle (MZW)
5C. Manual​
Backup light switch - inspection​
Backup light switch - installation​
Backup light switch - removal​
Control box - disassembly​
Control box - inspection​
Control box - reassembly​
Counter shaft - disassembly​
Counter shaft - inspection​
Counter shaft - reassembly​
Gear control - disassembly​
Gear control - inspection​
Gear control - reassembly​
Gear control cable - installation​
Gear control cable - removal​
Input shaft - disassembly​
Input shaft - inspection​
Input shaft - reassembly​
Neutral switch - inspection​
Neutral switch - installation​
Neutral switch - removal​
Rear oil seal - installation​
Rear oil seal - removal​
Relay lever - disassembly​
Relay lever - reassembly​
Shift lever - disassembly​
Shift lever - inspection​
Shift lever - installation​
Shift lever - reassembly​
Shift lever - removal​
Transmission - disassembly​
Transmission - inspection​
Transmission - installation​
Transmission - reassembly​
Transmission - removal​
Transmission oil - inspection​
Transmission oil - replacement​
5E. Clutch System​
Clutch - disassembly​
Clutch - inspection​
Clutch - installation​
Clutch - reassembly​
Clutch - removal​
Clutch booster - disassembly​
Clutch booster - inspection​
Clutch booster - installation​
Clutch booster - reassembly​
Clutch booster - removal​
Clutch master cylinder - disassembly​
Clutch master cylinder - inspection​
Clutch master cylinder - installation​
Clutch master cylinder - reassembly​
Clutch master cylinder - removal​
Clutch switch - installation​
Clutch switch - removal​
Shift fork - inspection​
Shift fork - installation​
Shift fork - removal​
5Z. Transmission Electrical Control​
Vehicle speed sensor - inspection​
Vehicle speed sensor - installation​
Vehicle speed sensor - removal​
5.2. Transmission, Transaxle (MZZ)
5C. Manual​
Main shaft - disassembly​
Main shaft - inspection​
Main shaft - reassembly​
Speedometer driven gear - installation​
Speedometer driven gear - removal​
5E. Clutch System​
Clutch (13 inch) - inspection​
Clutch (13 inch) - installation​
Clutch (13 inch) - removal​
Clutch (14 inch) - disassembly​
Clutch (14 inch) - inspection​
Clutch (14 inch) - installation​
Clutch (14 inch) - reassembly​
Clutch (14 inch) - removal​
Clutch booster (14 inch clutch) - disassembly​
Clutch booster (14 inch clutch) - inspection​
Clutch booster (14 inch clutch) - installation​
Clutch booster (14 inch clutch) - reassembly​
Clutch booster (14 inch clutch) - removal​
Clutch control (13 inch clutch) - inspection​
Clutch control (13 inch clutch) - installation​
Clutch control (13 inch clutch) - removal​
Shift fork (13 inch clutch) - inspection​
Shift fork (13 inch clutch) - installation​
Shift fork (13 inch clutch) - removal​
Shift fork (14 inch clutch) - inspection​
Shift fork (14 inch clutch) - installation​
Shift fork (14 inch clutch) - removal​
Slave cylinder (13 inch clutch) - disassembly​
Slave cylinder (13 inch clutch) - inspection​
Slave cylinder (13 inch clutch) - reassembly​
5.3. Transmission, Transaxle (Smoother (MZW))
5C. Manual​
ATF - inspection​
ATF - replacement​
ATF cooler pipe - inspection​
ATF cooler pipe - installation​
ATF cooler pipe - removal​
Gear shift unit - disassembly​
Gear shift unit - inspection​
Gear shift unit - reassembly​
Smoother parts - inspection​
Smoother parts - installation​
Smoother parts - removal​
Input speed sensor - inspection​
Input speed sensor - installation​
Input speed sensor - removal​
Select stroke sensor - inspection​
Select stroke sensor - installation​
Select stroke sensor - removal​
Shift stroke sensor - inspection​
Shift stroke sensor - installation​
Shift stroke sensor - removal​
TCM - installation​
TCM - removal​
TCM - setting​
Transmission oil temperature sensor - inspection​
Transmission oil temperature sensor - installation​
Transmission oil temperature sensor - removal​
Turbine speed sensor - inspection​
Turbine speed sensor - installation​
Turbine speed sensor - removal​
6. Steering
6B. Power Assisted System​
Drag link - disassembly​
Drag link - inspection​
Drag link - installation​
Drag link - reassembly​
Drag link - removal​
Power steering fluid - replacement​
Power steering oil pump - disassembly​
Power steering oil pump - inspection​
Power steering oil pump - installation​
Power steering oil pump - reassembly​
Power steering oil pump - removal​
Power steering unit - disassembly​
Power steering unit - inspection​
Power steering unit - installation​
Power steering unit - reassembly​
Power steering unit - removal​
Steering shaft - inspection​
Steering shaft - installation​
Steering shaft - removal​
6Z. Steering Electrical Control​
Steering angle sensor - installation​
Steering angle sensor - removal​
Steering angle sensor - setting​
7. Body, Cab, Accessories
9A. Lighting Systems​
Backup light bulb - installation​
Backup light bulb - removal​
Combination switch - inspection​
Combination switch - installation​
Combination switch - removal​
Fog light bulb - installation​
Fog light bulb - removal​
Fog light switch - inspection​
Front clearance light bulb - installation​
Front clearance light bulb - removal​
Front turn signal light bulb - installation​
Front turn signal light bulb - removal​
Headlight bulb - installation​
Headlight bulb - removal​
License plate light bulb - installation​
License plate light bulb - removal​
Rear fog light bulb - installation​
Rear fog light bulb - removal​
Rear fog light switch - inspection​
Rear turn signal light bulb - installation​
Rear turn signal light bulb - removal​
Tail stoplight bulb - installation​
Tail stoplight bulb - removal​
9C. Electrical Control, Entertainment​
Air horn - inspection​
Air horn - installation​
Air horn - removal​
Battery relay switch - inspection​
Cut switch interlocked with exhaust brake - inspection​
DPD switch - inspection​
DPD switch and HSA OFF switch - inspection​
Emergency stop switch - inspection​
Engine stop switch - inspection​
ESC OFF switch - inspection​
Horn - inspection​
Horn - installation​
Horn - removal​
Horn switch - inspection​
Horn switch - installation​
Horn switch - removal​
HSA adjustment switch - inspection​
Ignition switch - inspection​
Ignition switch - installation​
Ignition switch - removal​
Oil pressure gauge switch - inspection​
Smoother emergency switch - inspection​
Starter safety switch - inspection​
Sub-starter switch - inspection​
Warm up switch - inspection​
9E. Instrumentation, Driver Info​
Back buzzer - inspection​
Back buzzer - installation​
Back buzzer - removal​
Instrument panel cluster - diagnostics​
Oil pressure gauge - inspection​
Speed sensor control unit - setting​
9Z. Body, Cab, Accessories Electrical Control​
Auto light control unit - setting​
Auto light sensor - inspection​
CAN converter control unit (FCG) - setting​
Information module - setting​
VCM - setting​
