Isuzu FX FY GX Series 2025 2026 Mechanical Repair Procedures FXHTML-WEN-2541
Type of Manual: Workshop Manual - Mechanical Repair Procedures
Model: Isuzu FX Series ; FY Series ; GX Series 25 Cab model Truck
Date: 2025, 2026
Engine: Isuzu 6UZ1 Engine
General Export (Date: 2026/08/28)
Part Number: FXHTML-WEN-2541
Number of Pages: 6797 Pages
1. Engine (6UZ1)
Date: 2025, 2026
1. Engine (6UZ1)
1B. Mechanical
Camshaft - disassembly
Camshaft - inspection
Camshaft - installation
Camshaft - reassembly
Camshaft - removal
Crankshaft - disassembly
Crankshaft - inspection
Crankshaft - installation
Crankshaft - reassembly
Crankshaft - removal
Crankshaft front oil seal - installation
Crankshaft front oil seal - removal
Crankshaft pulley - disassembly
Crankshaft pulley - inspection
Crankshaft pulley - installation
Crankshaft pulley - reassembly
Crankshaft pulley - removal
Crankshaft rear oil seal - installation
Crankshaft rear oil seal - removal
Cylinder block - disassembly
Cylinder block - inspection
Cylinder block - installation
Cylinder block - reassembly
Cylinder block - removal
Cylinder head - disassembly
Cylinder head - inspection
Cylinder head - installation
Cylinder head - reassembly
Cylinder head - removal
Cylinder head cover - installation
Cylinder head cover - removal
Engine - installation
Engine - removal
Engine mounting - installation
Engine mounting - removal
Exhaust manifold - inspection
Exhaust manifold - installation
Exhaust manifold - removal
Flywheel - disassembly
Flywheel - inspection
Flywheel - installation
Flywheel - reassembly
Flywheel - removal
Flywheel housing - installation
Flywheel housing - removal
Front cover - installation
Front cover - removal
Idle gear - inspection
Idle gear - installation
Idle gear - removal
Inlet cover - installation
Inlet cover - removal
Intake throttle valve - installation
Intake throttle valve - removal
Piston - disassembly
Piston - inspection
Piston - installation
Piston - reassembly
Piston - removal
Rocker arm shaft - disassembly
Rocker arm shaft - inspection
Rocker arm shaft - installation
Rocker arm shaft - reassembly
Rocker arm shaft - removal
Supplementary Information
1C. Fuel System
Common rail (fuel rail) - installation
Common rail (fuel rail) - removal
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel filter - installation
Fuel filter - removal
Fuel filter element - installation
Fuel filter element - removal
Fuel supply pump - inspection
Fuel supply pump - installation
Fuel supply pump - removal
Fuel tank - installation
Fuel tank - removal
Fuel tank unit - inspection
Fuel tank unit - installation
Fuel tank unit - removal
Injector - inspection
Injector - installation
Injector - removal
Pre-fuel filter - installation
Pre-fuel filter - removal
Pre-fuel filter element - inspection
Pre-fuel filter element - installation
Pre-fuel filter element - removal
Pressure limiter - installation
Pressure limiter - removal
Water sedimenter switch - inspection
Water sedimenter switch - installation
Water sedimenter switch - removal
1D. Cooling
Coolant - inspection
Coolant - replacement
Cooling fan belt - inspection
Cooling fan belt - installation
Cooling fan belt - removal
Cooling fan clutch - inspection
Cooling fan clutch - installation
Cooling fan clutch - removal
Insect screen - inspection
Insect screen - installation
Insect screen - removal
Radiator - inspection
Radiator - installation
Radiator - removal
Radiator sub-tank - installation
Radiator sub-tank - removal
Thermostat - inspection
Thermostat - installation
Thermostat - removal
Water pump - inspection
Water pump - installation
Water pump - removal
1E. Lubrication
Engine oil - inspection
Engine oil - replacement
Oil cooler - disassembly
Oil cooler - inspection
Oil cooler - installation
Oil cooler - reassembly
Oil cooler - removal
Oil filter - installation
Oil filter - removal
Oil filter element - installation
Oil filter element - removal
Oil pan - installation
Oil pan - removal
Oil pressure switch - installation
Oil pressure switch - removal
Oil pump - inspection
Oil pump - installation
Oil pump - removal
Oil separator - installation
Oil separator - removal
Oil separator element - installation
Oil separator element - removal
Partial oil filter - installation
Partial oil filter - removal
Partial oil filter element - installation
Partial oil filter element - removal
1F. Induction
Air cleaner element - inspection
Air cleaner element - installation
Air cleaner element - removal
Intercooler - inspection
Intercooler - installation
Intercooler - removal
Turbocharger - inspection
Turbocharger - installation
Turbocharger - removal
Vertical air intake duct - installation
Vertical air intake duct - removal
1G. Exhaust
DPD - disassembly
DPD - inspection
DPD - installation
DPD - reassembly
DPD - removal
Exhaust pipe - inspection
Exhaust pipe - installation
Exhaust pipe - removal
Exhaust throttle solenoid valve - inspection
Exhaust throttle solenoid valve - installation
Exhaust throttle solenoid valve - removal
Exhaust throttle valve - inspection
Exhaust throttle valve - installation
Exhaust throttle valve - removal
1H. Aux. Emission Control Devices
Dosing module - disassembly
Dosing module - installation
Dosing module - reassembly
Dosing module - removal
EGR cooler - inspection
EGR cooler - installation
EGR cooler - removal
EGR valve - inspection
EGR valve - installation
EGR valve - removal
Urea fluid - inspection
Urea fluid supply module - disassembly
Urea fluid supply module - inspection
Urea fluid supply module - installation
Urea fluid supply module - reassembly
Urea fluid supply module - removal
Urea fluid supply module filter - installation
Urea fluid supply module filter - removal
Urea fluid tank - installation
Urea fluid tank - removal
Urea fluid tank heater coolant control valve - installation
Urea fluid tank heater coolant control valve - removal
Urea fluid tank level gauge - installation
Urea fluid tank level gauge - removal
Urea SCR - disassembly
Urea SCR - inspection
Urea SCR - installation
Urea SCR - reassembly
Urea SCR - removal
1I. Speed Control Systems
Accelerator control link - inspection
Accelerator control link - installation
Accelerator control link - removal
Accelerator pedal - installation
Accelerator pedal - removal
Idle up sensor - installation
Idle up sensor - removal
1J. Electrical
Generator (Nikko) - disassembly
Generator (Nikko) - inspection
Generator (Nikko) - installation
Generator (Nikko) - reassembly
Generator (Nikko) - removal
Generator(Mitsubishi) - disassembly
Generator(Mitsubishi) - inspection
Generator(Mitsubishi) - installation
Generator(Mitsubishi) - reassembly
Generator(Mitsubishi) - removal
Starter motor - disassembly
Starter motor - inspection
Starter motor - installation
Starter motor - reassembly
Starter motor - removal
1M. Flywheel PTO
Flywheel PTO - disassembly
Flywheel PTO - inspection
Flywheel PTO - installation
Flywheel PTO - reassembly
Flywheel PTO - removal
1Z. Engine Electrical Control
Atmospheric temperature sensor - inspection
Atmospheric temperature sensor - installation
Atmospheric temperature sensor - removal
Boost pressure sensor - inspection
Boost pressure sensor - installation
Boost pressure sensor - removal
Charge air cooler temperature sensor 1 - inspection
Charge air cooler temperature sensor 1 - installation
Charge air cooler temperature sensor 1 - removal
Charge air cooler temperature sensor - inspection
Charge air cooler temperature sensor - installation
Charge air cooler temperature sensor - removal
CKP sensor - inspection
CKP sensor - installation
CKP sensor - removal
DCU - installation
DCU - removal
DCU - setting
ECM - inspection
ECM - installation
ECM - removal
ECM - setting
EGR gas temperature sensor 1 - inspection
EGR gas temperature sensor 1 - installation
EGR gas temperature sensor 1 - removal
EGR gas temperature sensor 2 - inspection
EGR gas temperature sensor 2 - installation
EGR gas temperature sensor 2 - removal
EGR gas temperature sensor 3 - inspection
EGR gas temperature sensor 3 - installation
EGR gas temperature sensor 3 - removal
EGR gas temperature sensor 4 - inspection
EGR gas temperature sensor 4 - installation
EGR gas temperature sensor 4 - removal
Engine coolant temperature sensor - inspection
Engine coolant temperature sensor - installation
Engine coolant temperature sensor - removal
Exhaust differential pressure sensor - inspection
Exhaust differential pressure sensor - installation
Exhaust differential pressure sensor - removal
Exhaust gas temperature sensor 3 - installation
Exhaust gas temperature sensor 3 - removal
Exhaust gas temperature sensor 4 - installation
Exhaust gas temperature sensor 4 - removal
Exhaust gas temperature sensor - inspection
Exhaust gas temperature sensor - installation
Exhaust gas temperature sensor - removal
FRP sensor - inspection
FRP sensor - installation
FRP sensor - removal
Fuel temperature sensor - inspection
Fuel temperature sensor - installation
Fuel temperature sensor - removal
IMT sensor - inspection
IMT sensor - installation
IMT sensor - removal
MAF and IAT sensor - inspection
MAF and IAT sensor - installation
MAF and IAT sensor - removal
NOx sensor 1 - inspection
NOx sensor 1 - installation
NOx sensor 1 - removal
NOx sensor 2 - inspection
NOx sensor 2 - installation
NOx sensor 2 - removal
PM sensor - installation
PM sensor - removal
Turbocharger outlet temperature sensor - inspection
Turbocharger outlet temperature sensor - installation
Turbocharger outlet temperature sensor - removal
Urea fluid sensor - installation
Urea fluid sensor - removal
VGS control unit - installation
VGS control unit - removal
2. Suspension2B. Front Suspension
Leaf rigid suspension - disassembly
Leaf rigid suspension - inspection
Leaf rigid suspension - installation
Leaf rigid suspension - reassembly
Leaf rigid suspension - removal
2C. Rear Suspension
Air suspension (HENDRICKSON) - inspection
Air suspension (HENDRICKSON) - installation
Air suspension (HENDRICKSON) - removal
Trunnion suspension - disassembly
Trunnion suspension - inspection
Trunnion suspension - installation
Trunnion suspension - reassembly
Trunnion suspension - removal
2D. Wheel, Tire System
Disc wheel and tire - inspection
Disc wheel and tire - installation
Disc wheel and tire - removal
3.1. Driveline, Axle (Isuzu production model)3B. Differentials
Differential oil - replacement
Inter axle differential lock shift unit (16.5HT) - disassembly
Inter axle differential lock shift unit (16.5HT) - inspection
Inter axle differential lock shift unit (16.5HT) - installation
Inter axle differential lock shift unit (16.5HT) - reassembly
Inter axle differential lock shift unit (16.5HT) - removal
Inter axle differential lock shift unit (17.5HT) - disassembly
Inter axle differential lock shift unit (17.5HT) - inspection
Inter axle differential lock shift unit (17.5HT) - installation
Inter axle differential lock shift unit (17.5HT) - reassembly
Inter axle differential lock shift unit (17.5HT) - removal
Rear differential (single) (16.5H) - disassembly
Rear differential (single) (16.5H) - inspection
Rear differential (single) (16.5H) - installation
Rear differential (single) (16.5H) - reassembly
Rear differential (single) (16.5H) - removal
Rear differential (single) (17.5H) - disassembly
Rear differential (single) (17.5H) - inspection
Rear differential (single) (17.5H) - installation
Rear differential (single) (17.5H) - reassembly
Rear differential (single) (17.5H) - removal
Rear differential (tandem)(16.5HT) - disassembly
Rear differential (tandem)(16.5HT) - inspection
Rear differential (tandem)(16.5HT) - installation
Rear differential (tandem)(16.5HT) - reassembly
Rear differential (tandem)(16.5HT) - removal
Rear differential (tandem)(17.5HT) - disassembly
Rear differential (tandem)(17.5HT) - inspection
Rear differential (tandem)(17.5HT) - installation
Rear differential (tandem)(17.5HT) - reassembly
Rear differential (tandem)(17.5HT) - removal
3C. Drive Shaft System
Front axle (full air brake) - disassembly
Front axle (full air brake) - inspection
Front axle (full air brake) - installation
Front axle (full air brake) - reassembly
Front axle (full air brake) - removal
Front hub - disassembly
Front hub - inspection
Front hub - installation
Front hub - reassembly
Front hub - removal
Knuckle (full air brake) - disassembly
Knuckle (full air brake) - inspection
Knuckle (full air brake) - installation
Knuckle (full air brake) - reassembly
Knuckle (full air brake) - removal
Knuckle arm - inspection
Knuckle arm - installation
Knuckle arm - removal
Propeller shaft - disassembly
Propeller shaft - inspection
Propeller shaft - installation
Propeller shaft - reassembly
Propeller shaft - removal
Propeller shaft between tandem axles - disassembly
Propeller shaft between tandem axles - inspection
Propeller shaft between tandem axles - installation
Propeller shaft between tandem axles - reassembly
Propeller shaft between tandem axles - removal
Rear axle (full air brake) - disassembly
Rear axle (full air brake) - inspection
Rear axle (full air brake) - installation
Rear axle (full air brake) - reassembly
Rear axle (full air brake) - removal
Rear axle shaft - installation
Rear axle shaft - removal
Rear hub - disassembly
Rear hub - inspection
Rear hub - installation
Rear hub - reassembly
Rear hub - removal
Tie rod - disassembly
Tie rod - inspection
Tie rod - installation
Tie rod - reassembly
Tie rod - removal
Tie rod arm - inspection
Tie rod arm - installation
Tie rod arm - removal
Wheel alignment check
3.2. Driveline, Axle (Meritor production model)3B. Differentials
Driver controlled main differential lock (forward rear differential) - installation
Driver controlled main differential lock (forward rear differential) - removal
Driver controlled main differential lock (single and rearward rear differential) - installation
Driver controlled main differential lock (single and rearward rear differential) - removal
Rear differential (single) - disassembly
Rear differential (single) - inspection
Rear differential (single) - installation
Rear differential (single) - reassembly
Rear differential (single) - removal
Rear differential (tandem) - disassembly
Rear differential (tandem) - inspection
Rear differential (tandem) - installation
Rear differential (tandem) - reassembly
Rear differential (tandem) - removal
Front axle (disc brake) - installation
Front axle (disc brake) - removal
Front hub (disc brake) - disassembly
Front hub (disc brake) - inspection
Front hub (disc brake) - installation
Front hub (disc brake) - reassembly
Front hub (disc brake) - removal
Knuckle (disc brake) - disassembly
Knuckle (disc brake) - inspection
Knuckle (disc brake) - installation
Knuckle (disc brake) - reassembly
Knuckle (disc brake) - removal
Rear axle (air suspension) - disassembly
Rear axle (air suspension) - inspection
Rear axle (air suspension) - installation
Rear axle (air suspension) - reassembly
Rear axle (air suspension) - removal
Rear axle (leaf spring suspension) - disassembly
Rear axle (leaf spring suspension) - inspection
Rear axle (leaf spring suspension) - installation
Rear axle (leaf spring suspension) - reassembly
Rear axle (leaf spring suspension) - removal
Rear axle (trunnion suspension) - disassembly
Rear axle (trunnion suspension) - inspection
Rear axle (trunnion suspension) - installation
Rear axle (trunnion suspension) - reassembly
Rear axle (trunnion suspension) - removal
Rear hub (disc brake) - disassembly
Rear hub (disc brake) - inspection
Rear hub (disc brake) - installation
Rear hub (disc brake) - reassembly
Rear hub (disc brake) - removal
Tie rod - removal
4.1. Brakes (Isuzu production model)4B. Brake System
Air dryer - disassembly
Air dryer - inspection
Air dryer - installation
Air dryer - reassembly
Air dryer - removal
Brake pedal box - disassembly
Brake pedal box - installation
Brake pedal box - reassembly
Brake pedal box - removal
Brake valve - inspection
Brake valve - installation
Brake valve - removal
Dual relay valve - disassembly
Dual relay valve - inspection
Dual relay valve - installation
Dual relay valve - reassembly
Dual relay valve - removal
Front brake chamber (power) - disassembly
Front brake chamber (power) - inspection
Front brake chamber (power) - installation
Front brake chamber (power) - reassembly
Front brake chamber (power) - removal
Front drum brake - disassembly
Front drum brake - inspection
Front drum brake - installation
Front drum brake - reassembly
Front drum brake - removal
Front expander - disassembly
Front expander - inspection
Front expander - installation
Front expander - reassembly
Front expander - removal
Low pressure switch - inspection
Low pressure switch - installation
Low pressure switch - removal
Multi-protection valve - inspection
Multi-protection valve - installation
Multi-protection valve - removal
Rear brake chamber (spring) - disassembly
Rear brake chamber (spring) - inspection
Rear brake chamber (spring) - installation
Rear brake chamber (spring) - reassembly
Rear brake chamber (spring) - removal
Rear drum brake - disassembly
Rear drum brake - inspection
Rear drum brake - installation
Rear drum brake - reassembly
Rear drum brake - removal
Rear expander - disassembly
Rear expander - inspection
Rear expander - installation
Rear expander - reassembly
Rear expander - removal
Silencer - inspection
Silencer - installation
Silencer - removal
Single air compressor - disassembly
Single air compressor - inspection
Single air compressor - installation
Single air compressor - reassembly
Single air compressor - removal
Stoplight switch - inspection
Stoplight switch - installation
Stoplight switch - removal
4C. Parking Brake System
Hand control brake valve - disassembly
Hand control brake valve - inspection
Hand control brake valve - installation
Hand control brake valve - reassembly
Hand control brake valve - removal
Parking brake switch - inspection
Parking brake switch - installation
Parking brake switch - removal
4D. ABS
Front ABS modulator - disassembly
Front ABS modulator - inspection
Front ABS modulator - installation
Front ABS modulator - reassembly
Front ABS modulator - removal
Front exciter ring - inspection
Front exciter ring - installation
Front exciter ring - removal
Front relay valve - disassembly
Front relay valve - inspection
Front relay valve - installation
Front relay valve - reassembly
Front relay valve - removal
Rear exciter ring - inspection
Rear exciter ring - installation
Rear exciter ring - removal
Rear relay valve - disassembly
Rear relay valve - inspection
Rear relay valve - installation
Rear relay valve - reassembly
Rear relay valve - removal
4E. Speed Retarder System
Exhaust brake solenoid valve - inspection
Exhaust brake solenoid valve - installation
Exhaust brake solenoid valve - removal
Exhaust brake valve - inspection
Exhaust brake valve - installation
Exhaust brake valve - removal
4Z. Brake Electrical Control
EBS control unit - installation
EBS control unit - removal
EBS control unit - setting
Front wheel speed sensor - inspection
Front wheel speed sensor - installation
Front wheel speed sensor - removal
Rear wheel speed sensor - inspection
Rear wheel speed sensor - installation
Rear wheel speed sensor - removal
Yaw rate sensor - installation
Yaw rate sensor - removal
Yaw rate sensor - setting
4.2. Brakes (Meritor production model)4B. Brake System
Air dryer - removal
Front disc brake - disassembly
Front disc brake - inspection
Front disc brake - installation
Front disc brake - reassembly
Front disc brake - removal
Front disc brake pad - inspection
Front disc brake pad - installation
Front disc brake pad - removal
Rear disc brake - disassembly
Rear disc brake - inspection
Rear disc brake - installation
Rear disc brake - reassembly
Rear disc brake - removal
Rear disc brake pad - inspection
Rear disc brake pad - installation
Rear disc brake pad - removal
Silencer - removal
4D. ABS
Front pad wear sensor - installation
Front pad wear sensor - removal
Rear pad wear sensor - installation
Rear pad wear sensor - removal
Wheel park air tank pressure sensor - installation
Wheel park air tank pressure sensor - removal
4.3. Transmission, Transaxle (Allison 4430)5B. Automatic
ATF - inspection
ATF - replacement
ATF cooler - disassembly
ATF cooler - inspection
ATF cooler - reassembly
ATF filter - inspection
ATF filter - installation
ATF filter - removal
Selector button - installation
Selector button - removal
Transmission - inspection
Transmission - installation
Transmission - removal
5Z. Transmission Electrical Control
TCM - installation
TCM - removal
Vehicle speed sensor - installation
Vehicle speed sensor - removal
4.4. Transmission, Transaxle (MJT)5C. Manual
Counter shaft - disassembly
Counter shaft - inspection
Counter shaft - reassembly
Gear control cable - installation
Gear control cable - removal
Input shaft - disassembly
Input shaft - inspection
Input shaft - reassembly
Main shaft - disassembly
Main shaft - inspection
Main shaft - reassembly
Power assist - disassembly
Power assist - inspection
Power assist - reassembly
Relay lever cover - disassembly
Relay lever cover - reassembly
Shift lever - installation
Shift lever - removal
Shift rod - disassembly
Shift rod - inspection
Shift rod - reassembly
Transmission - disassembly
Transmission - reassembly
Transmission oil - inspection
Transmission oil - replacement
Upper quadrant box - disassembly
Upper quadrant box - inspection
Upper quadrant box - reassembly
5E. Clutch System
Clutch (single plate push type) - disassembly
Clutch (single plate push type) - inspection
Clutch (single plate push type) - installation
Clutch (single plate push type) - reassembly
Clutch (single plate push type) - removal
Clutch booster - disassembly
Clutch booster - inspection
Clutch booster - installation
Clutch booster - reassembly
Clutch booster - removal
Clutch master cylinder - disassembly
Clutch master cylinder - inspection
Clutch master cylinder - installation
Clutch master cylinder - reassembly
Clutch master cylinder - removal
Clutch oil pressure switch - installation
Clutch oil pressure switch - removal
Clutch switch - installation
Clutch switch - removal
Shift fork(single plate push-type) - installation
Shift fork(single plate push-type) - removal
5F. PTO
Side PTO - disassembly
Side PTO - inspection
Side PTO - installation
Side PTO - reassembly
Side PTO - removal
Side PTO(large capacity type) - disassembly
Side PTO(large capacity type) - inspection
Side PTO(large capacity type) - installation
Side PTO(large capacity type) - reassembly
Side PTO(large capacity type) - removal
Clutch pedal stroke sensor - installation
Clutch pedal stroke sensor - removal
Vehicle speed sensor - inspection
4.5. Transmission, Transaxle (ZF9S1310)5C. Manual
Clutch housing - installation
Clutch housing - removal
Flange - installation
Flange - removal
Planetary drive (with synchronizer unit) - disassembly
Planetary drive (with synchronizer unit) - reassembly
Rear cover - disassembly
Rear cover - reassembly
Shift lever - disassembly
Shift lever - inspection
Shift lever - reassembly
Shift turret (double H) - disassembly
Shift turret (double H) - reassembly
Transmission (double H) - disassembly
Transmission (double H) - installation
Transmission (double H) - reassembly
Transmission (double H) - removal
Transmission case - disassembly
Transmission case - reassembly
5E. Clutch System
Shift fork(single plate push-type) - inspection
6. Steering6B. Power Assisted System
Drag link - disassembly
Drag link - inspection
Drag link - installation
Drag link - reassembly
Drag link - removal
Link rod - disassembly
Link rod - inspection
Link rod - installation
Link rod - reassembly
Link rod - removal
Power steering booster - disassembly
Power steering booster - inspection
Power steering booster - installation
Power steering booster - reassembly
Power steering booster - removal
Power steering fluid - replacement
Power steering oil pump (6U series engine) - disassembly
Power steering oil pump (6U series engine) - inspection
Power steering oil pump (6U series engine) - installation
Power steering oil pump (6U series engine) - reassembly
Power steering oil pump (6U series engine) - removal
Power steering unit - disassembly
Power steering unit - inspection
Power steering unit - installation
Power steering unit - reassembly
Power steering unit - removal
Steering shaft (with steering motor control unit) - inspection
Steering shaft (with steering motor control unit) - installation
Steering shaft (with steering motor control unit) - removal
Steering shaft (with steering motor control unit) - setting
Steering shaft - inspection
Steering shaft - installation
Steering shaft - removal
6Z. Steering Electrical Control
DC-DC converter (EHPS) - installation
DC-DC converter (EHPS) - removal
Steering angle sensor - installation
Steering angle sensor - removal
Steering angle sensor - setting
Steering angle sensor - writing
7. HVAC7B. Heater Ventilator Airconditioner
A_C compressor (6UZ1) - installation
A_C compressor (6UZ1) - removal
A_C compressor drive belt(6UZ1) - inspection
A_C compressor drive belt(6UZ1) - installation
A_C compressor drive belt(6UZ1) - removal
Air mix door - installation
Air mix door - removal
Blower - installation
Blower - removal
Blower module - inspection
Blower module - installation
Blower module - removal
Blower motor - inspection
Blower motor - installation
Blower motor - removal
Condenser - installation
Condenser - removal
Condenser fan - inspection
Condenser fan - installation
Condenser fan - removal
Control panel - inspection
Control panel - installation
Control panel - removal
Control panel - setting
Evaporator core - installation
Evaporator core - removal
Expansion valve - installation
Expansion valve - removal
Heater core - installation
Heater core - removal
Heater evaporator unit - installation
Heater evaporator unit - removal
Inside air filter - installation
Inside air filter - removal
Intake actuator - installation
Intake actuator - removal
Intake door - installation
Intake door - removal
Mix actuator - installation
Mix actuator - removal
Mode actuator - installation
Mode actuator - removal
Mode door - installation
Mode door - removal
Outside air filter - installation
Outside air filter - removal
Receiver dryer - installation
Receiver dryer - removal
Vent grille (center and driver side) - installation
Vent grille (center and driver side) - removal
Vent grille (passenger side) - installation
Vent grille (passenger side) - removal
Ventilation duct - installation
Ventilation duct - removal
7Z. HVAC Control
A_C control unit - installation
A_C control unit - removal
A_C control unit - setting
Inside air temperature sensor - inspection
Inside air temperature sensor - installation
Inside air temperature sensor - removal
Outside air temperature sensor - inspection
Outside air temperature sensor - installation
Outside air temperature sensor - removal
Sun sensor - inspection
Sun sensor - installation
Sun sensor - removal
8. Restraints8B. Airbag Systems
Driver airbag - installation
Driver airbag - removal
Driver airbag - scrapping
Passenger airbag - installation
Passenger airbag - removal
Passenger airbag - scrapping
SRS coil - installation
SRS coil - removal
8C. Seat Belt Systems
Buckle side driver seat belt - installation
Buckle side driver seat belt - removal
Buckle side passenger seat belt - installation
Buckle side passenger seat belt - removal
Front buckle side center seat belt - installation
Front buckle side center seat belt - removal
Front tongue side center seat belt - installation
Front tongue side center seat belt - removal
Seat belt with pretensioner - installation
Seat belt with pretensioner - removal
Seat belt with pretensioner - scrapping
Seat belt without pretensioner - installation
Seat belt without pretensioner - removal
8Z. Seat Belt and SRS Airbag Electrical Control
Satellite sensor - installation
Satellite sensor - removal
SRS control unit - installation
SRS control unit - removal
SRS control unit - setting
9. Body, Cab, Accessories9A. Lighting Systems
Backup light bulb - installation
Backup light bulb - removal
Clearance light - installation
Clearance light - removal
Combination switch - inspection
Combination switch - installation
Combination switch - removal
Daytime running light - installation
Daytime running light - removal
Door interlocking switch - inspection
Door interlocking switch - installation
Door interlocking switch - removal
Door switch - inspection
Door switch - installation
Door switch - removal
Fog light - installation
Fog light - removal
Front turn signal light - installation
Front turn signal light - removal
Hazard warning flasher switch - inspection
Hazard warning flasher switch - installation
Hazard warning flasher switch - removal
Headlight - inspection
Headlight - installation
Headlight - removal
Headlight leveling switch - inspection
Headlight leveling switch - installation
Headlight leveling switch - removal
Key reminder switch - inspection
Key reminder switch - installation
Key reminder switch - removal
LED dome light - installation
LED dome light - removal
LED dome light and map light - installation
LED dome light and map light - removal
LED dome light bulb - installation
LED dome light bulb - removal
LED interior light - installation
LED interior light - removal
LED interior light switch - inspection
LED interior light switch - installation
LED interior light switch - removal
License plate light bulb - installation
License plate light bulb - removal
Push switch - inspection
Push switch - installation
Push switch - removal
Rear combination light - inspection
Rear combination light - installation
Rear combination light - removal
Rear turn signal light bulb - installation
Rear turn signal light bulb - removal
Roof-mounted clearance light bulb - installation
Roof-mounted clearance light bulb - removal
Side turn signal light - installation
Side turn signal light - removal
Tail stoplight bulb - installation
Tail stoplight bulb - removal
9B. Wiper, Washer Systems
Headlight washer nozzle - installation
Headlight washer nozzle - removal
Washer motor - inspection
Washer motor - installation
Washer motor - removal
Washer nozzle - installation
Washer nozzle - removal
Wiper arm - installation
Wiper arm - removal
Wiper blade rubber - installation
Wiper blade rubber - removal
Wiper linkage - installation
Wiper linkage - removal
Wiper motor - installation
Wiper motor - removal
9C. Electrical Control, Entertainment
Accessory socket - installation
Accessory socket - removal
Antenna - inspection
Antenna - installation
Antenna - removal
Differential lock switch - inspection
Differential lock switch - installation
Differential lock switch - removal
Door speaker - inspection
Door speaker - installation
Door speaker - removal
DPD switch - inspection
DPD switch - installation
DPD switch - removal
Horn - inspection
Horn - installation
Horn - removal
Horn switch - installation
Horn switch - removal
Ignition switch - inspection
Ignition switch - installation
Ignition switch - removal
Integrated DC-DC converter (single cab) - installation
Integrated DC-DC converter (single cab) - removal
LDWS switch and ESC OFF switch - inspection
LDWS switch and ESC OFF switch - installation
LDWS switch and ESC OFF switch - removal
Radio - installation
Radio - removal
Steering wheel switch - inspection
Steering wheel switch - installation
Steering wheel switch - removal
USB charger - installation
USB charger - removal
9E. Instrumentation, Driver Info
Back buzzer - inspection
Back buzzer - installation
Back buzzer - removal
Camera (vehicle front sensing) - installation
Camera (vehicle front sensing) - removal
Camera (vehicle front sensing) - setting
Camera (vehicle front sensing) - writing
Instrument panel cluster - installation
Instrument panel cluster - removal
Instrument panel cluster - setting
9G. Hood, Fenders, Doors
Cab back panel - installation
Cab back panel - removal
Engine hood insulator - installation
Engine hood insulator - removal
Front door - disassembly
Front door - installation
Front door - reassembly
Front door - removal
Front fender - installation
Front fender - removal
Front step - installation
Front step - removal
Rear fender - installation
Rear fender - removal
Rear mudguard - installation
Rear mudguard - removal
9H. Cab Structure
Air outlet valve - installation
Air outlet valve - removal
Front bumper - disassembly
Front bumper - installation
Front bumper - reassembly
Front bumper - removal
Front lid - disassembly
Front lid - installation
Front lid - reassembly
Front lid - removal
Front panel - installation
Front panel - removal
Front side panel - installation
Front side panel - removal
Front underrun protection - installation
Front underrun protection - removal
Lower radiator grille - installation
Lower radiator grille - removal
Upper radiator grille - disassembly
Upper radiator grille - installation
Upper radiator grille - reassembly
Upper radiator grille - removal
Wiper panel - installation
Wiper panel - removal
9I. Seats
Center seat - disassembly
Center seat - installation
Center seat - reassembly
Center seat - removal
Driver seat - disassembly
Driver seat - installation
Driver seat - reassembly
Driver seat - removal
High performance seat (ISRI) - disassembly
High performance seat (ISRI) - inspection
High performance seat (ISRI) - installation
High performance seat (ISRI) - reassembly
High performance seat (ISRI) - removal
Passenger seat - disassembly
Passenger seat - installation
Passenger seat - reassembly
Passenger seat - removal
9J. Security and Locks
Cab external antenna - installation
Cab external antenna - removal
Cab internal antenna - installation
Cab internal antenna - removal
Electronic key - disassembly
Electronic key - reassembly
Electronic key - setting
External buzzer - installation
External buzzer - removal
Front door lock - installation
Front door lock - removal
Key cylinder - installation
Key cylinder - removal
Receiver - installation
Receiver - removal
Remote controller key - disassembly
Remote controller key - reassembly
Remote controller key - setting
Steering lock - installation
Steering lock - removal
Steering lock - setting
Steering lock barrel - installation
Steering lock barrel - removal
Transponder key - setting
9L. Exterior, Interior Trim
Back upper trim - installation
Back upper trim - removal
Center console box - installation
Center console box - removal
Floor carpet (short cab, full cab) - installation
Floor carpet (short cab, full cab) - removal
Head lining (short cab, full cab) - installation
Head lining (short cab, full cab) - removal
Header console - installation
Header console - removal
Header tray - installation
Header tray - removal
Instrument panel - disassembly
Instrument panel - installation
Instrument panel - reassembly
Instrument panel - removal
Reinforcement - installation
Reinforcement - removal
9M. Cab Mounting
Cab - installation
Cab - removal
Cab lock - installation
Cab lock - removal
Cab lock switch - inspection
Cab lock switch - installation
Cab lock switch - removal
Cab tilt cylinder - disassembly
Cab tilt cylinder - inspection
Cab tilt cylinder - installation
Cab tilt cylinder - reassembly
Cab tilt cylinder - removal
Electric - hydraulic power tilt pump - disassembly
Electric - hydraulic power tilt pump - inspection
Electric - hydraulic power tilt pump - installation
Electric - hydraulic power tilt pump - reassembly
Electric - hydraulic power tilt pump - removal
Front cab mounting (full-floating cab suspension) - inspection
Front cab mounting (full-floating cab suspension) - installation
Front cab mounting (full-floating cab suspension) - removal
Rear cab mounting (full-floating cab suspension) - inspection
Rear cab mounting (full-floating cab suspension) - installation
Rear cab mounting (full-floating cab suspension) - removal
9T. Glass, Windows, Mirrors
Backlight glass - installation
Backlight glass - removal
Door mounted outside rearview mirror - installation
Door mounted outside rearview mirror - removal
Front door power window switch - inspection
Front door power window switch - installation
Front door power window switch - removal
Front windshield glass - installation
Front windshield glass - removal
Mirror heater switch - inspection
Mirror heater switch - installation
Mirror heater switch - removal
Mirror remote switch - inspection
Mirror remote switch - installation
Mirror remote switch - removal
Pillar mounted outside rearview mirror (driver side) - disassembly
Pillar mounted outside rearview mirror (driver side) - inspection
Pillar mounted outside rearview mirror (driver side) - installation
Pillar mounted outside rearview mirror (driver side) - reassembly
Pillar mounted outside rearview mirror (driver side) - removal
Pillar mounted outside rearview mirror (passenger side) - disassembly
Pillar mounted outside rearview mirror (passenger side) - inspection
Pillar mounted outside rearview mirror (passenger side) - installation
Pillar mounted outside rearview mirror (passenger side) - reassembly
Pillar mounted outside rearview mirror (passenger side) - removal
9Z. Body, Cab, Accessories Electrical Control
Adaptive driving beam headlight control unit - installation
Adaptive driving beam headlight control unit - removal
Adaptive driving beam headlight control unit - setting
Air pressure sensor - inspection
Air pressure sensor - installation
Air pressure sensor - removal
BCM - installation
BCM - removal
BCM - setting
CAN converter control unit (FCG) - installation
CAN converter control unit (FCG) - removal
CAN converter control unit (FCG) - setting
Central ECU - installation
Central ECU - removal
Central ECU - setting
Central gateway control unit - installation
Central gateway control unit - removal
Central gateway control unit - setting
Front height sensor - inspection
Front height sensor - installation
Front height sensor - removal
I_O control unit - installation
I_O control unit - removal
I_O control unit - setting
Illuminance sensor - inspection
Illuminance sensor - installation
Illuminance sensor - removal
Image processing unit (vehicle front sensing) - installation
Image processing unit (vehicle front sensing) - removal
Image processing unit (vehicle front sensing) - setting
Information module - installation
Information module - removal
Information module - setting
Milliwave radar unit - installation
Milliwave radar unit - removal
Milliwave radar unit - setting
Milliwave radar unit - writing
Rain sensor - installation
Rain sensor - removal
Rear height sensor - inspection
Rear height sensor - installation
Rear height sensor - removal
Wireless access module - installation
Wireless access module - removal
Wireless access module - setting (with passive entry and start system)
Wireless access module - setting (without passive entry and start system)
