Isuzu F&G Series 2022 to 2025 Mechanical Repair Procedures MGHTML-WEN-2111
Type of Manual: Workshop Manual - Mechanical Repair Procedures
Model: Isuzu F&G Series 08 Cab model Truck
Date: 2022 to 2025
Engine: Isuzu 4HK1 Euro2 ; 4HK1 Euro4 ; 4HK1 Euro5 ; 6HK1 Euro2 ; 6HK1 Euro4 ; 6HK1 Euro5 ; 6NX1 Engine
9th edition, Vietnam, Philippines, Malaysia and Kenya only (Date: 2025/08/08)
Parts Number: MGHTML-WEN-2111
Number of Pages: 17379 Pages
1.1. Engine (4HK1 (Euro2 specification))
Date: 2022 to 2025
1B. Mechanical
Camshaft - disassembly
Camshaft - inspection
Camshaft - installation
Camshaft - reassembly
Camshaft - removal
Crankshaft - disassembly
Crankshaft - inspection
Crankshaft - installation
Crankshaft - reassembly
Crankshaft - removal
Crankshaft front oil seal - installation
Crankshaft front oil seal - removal
Crankshaft pulley - installation
Crankshaft pulley - removal
Crankshaft rear oil seal - installation
Crankshaft rear oil seal - removal
Cylinder block - disassembly
Cylinder block - inspection
Cylinder block - installation
Cylinder block - reassembly
Cylinder block - removal
Cylinder head - disassembly
Cylinder head - inspection
Cylinder head - installation
Cylinder head - reassembly
Cylinder head - removal
Cylinder head cover - installation
Cylinder head cover - removal
Engine - installation
Engine - removal
Engine mounting - installation
Engine mounting - removal
Exhaust manifold - inspection
Exhaust manifold - installation
Exhaust manifold - removal
Flywheel - disassembly
Flywheel - inspection
Flywheel - installation
Flywheel - reassembly
Flywheel - removal
Flywheel housing - installation
Flywheel housing - removal
Front cover - installation
Front cover - removal
Idle gear - inspection
Idle gear - installation
Idle gear - removal
Inlet cover - installation
Inlet cover - removal
Piston - disassembly
Piston - inspection
Piston - installation
Piston - reassembly
Piston - removal
Rocker arm shaft - disassembly
Rocker arm shaft - inspection
Rocker arm shaft - installation
Rocker arm shaft - reassembly
Rocker arm shaft - removal
Supplementary Information
1C. Fuel System
Common rail (fuel rail) - installation
Common rail (fuel rail) - removal
FRP regulator - installation
FRP regulator - removal
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel filter - installation
Fuel filter - removal
Fuel filter element - installation
Fuel filter element - removal
Fuel supply pump - installation
Fuel supply pump - removal
Fuel tank - installation
Fuel tank - removal
Fuel tank unit - inspection
Fuel tank unit - installation
Fuel tank unit - removal
Injector - installation
Injector - removal
Pre-fuel filter - installation
Pre-fuel filter - removal
Pre-fuel filter element - inspection
Pre-fuel filter element - installation
Pre-fuel filter element - removal
Pressure limiter - installation
Pressure limiter - removal
Water sedimenter switch - inspection
Water sedimenter switch - installation
Water sedimenter switch - removal
1D. Cooling
Coolant - inspection
Coolant - replacement
Cooling fan belt - inspection
Cooling fan belt - installation
Cooling fan belt - removal
Cooling fan clutch - inspection
Cooling fan clutch - installation
Cooling fan clutch - removal
Radiator - inspection
Radiator - installation
Radiator - removal
Radiator reserve tank - installation
Radiator reserve tank - removal
Thermostat - inspection
Thermostat - installation
Thermostat - removal
Water pump - inspection
Water pump - installation
Water pump - removal
1E. Lubrication
Engine oil - inspection
Engine oil - replacement
Oil catch tank - installation
Oil catch tank - removal
Oil cooler - disassembly
Oil cooler - installation
Oil cooler - reassembly
Oil cooler - removal
Oil filter - installation
Oil filter - removal
Oil filter element - installation
Oil filter element - removal
Oil pan - installation
Oil pan - removal
Oil pressure switch - inspection
Oil pressure switch - installation
Oil pressure switch - removal
Oil pump - disassembly
Oil pump - inspection
Oil pump - installation
Oil pump - reassembly
Oil pump - removal
1F. Induction
Air cleaner element - inspection
Air cleaner element - installation
Air cleaner element - removal
Intercooler - inspection
Intercooler - installation
Intercooler - removal
Turbocharger - inspection
Turbocharger - installation
Turbocharger - removal
Ventilator - installation
Ventilator - removal
Vertical air intake duct - installation
Vertical air intake duct - removal
1G. Exhaust
Exhaust pipe - inspection
Exhaust pipe - installation
Exhaust pipe - removal
1I. Speed Control Systems
Accelerator control link - installation
Accelerator control link - removal
Accelerator pedal - installation
Accelerator pedal - removal
Idle up sensor - installation
Idle up sensor - removal
1J. Electrical
Generator - disassembly
Generator - inspection
Generator - installation
Generator - reassembly
Generator - removal
Glow plug - inspection
Glow plug - installation
Glow plug - removal
Starter motor - disassembly
Starter motor - inspection
Starter motor - installation
Starter motor - reassembly
Starter motor - removal
1Z. Engine Electrical Control
Barometric pressure sensor - inspection
Barometric pressure sensor - installation
Barometric pressure sensor - removal
Boost pressure sensor - inspection
Boost pressure sensor - installation
Boost pressure sensor - removal
CKP sensor - inspection
CKP sensor - installation
CKP sensor - removal
CMP sensor - inspection
CMP sensor - installation
CMP sensor - removal
ECM - installation
ECM - removal
ECM - setting
Engine coolant temperature sensor - inspection
Engine coolant temperature sensor - installation
Engine coolant temperature sensor - removal
FRP sensor - inspection
FRP sensor - installation
FRP sensor - removal
Fuel temperature sensor - inspection
Fuel temperature sensor - installation
Fuel temperature sensor - removal
IAT sensor - inspection
IAT sensor - installation
IAT sensor - removal
1.2. Engine (4HK1 (Euro4 specification))1B. Mechanical
Camshaft - removal
Engine - removal
Flywheel - removal
Idle gear - removal
Intake throttle valve - installation
Intake throttle valve - removal
Piston - inspection
Piston - reassembly
Piston - removal
1C. Fuel System
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel tank - removal
Injector - removal
1D. Cooling
Radiator - removal
1E. Lubrication
Oil level switch - installation
Oil level switch - removal
Oil pan - removal
Oil pump - removal
Oil separator - installation
Oil separator - removal
Oil separator element - installation
Oil separator element - removal
1F. Induction
1G. Exhaust
1H. Aux. Emission Control Devices
EGR - inspection
EGR - installation
EGR - removal
1J. Electrical
Generator - removal
ECM - installation
ECM - removal
ECM - setting
MAF and IAT sensor - inspection
MAF and IAT sensor - installation
MAF and IAT sensor - removal
VGS control unit - installation
VGS control unit - removal
1.3. Engine (4HK1 (Euro5 specification with DPD))1B. Mechanical
Camshaft - removal
Engine - removal
Flywheel - removal
Idle gear - removal
Piston - inspection
Piston - reassembly
Piston - removal
1C. Fuel System
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel cooler - installation
Fuel cooler - removal
Fuel tank - removal
Injector - removal
1D. Cooling
Radiator - removal
1E. Lubrication
Oil pan - removal
Oil pump - removal
1F. Induction
1G. Exhaust
DPD - disassembly
DPD - inspection
DPD - installation
DPD - reassembly
DPD - removal
Exhaust throttle solenoid valve - inspection
Exhaust throttle solenoid valve - installation
Exhaust throttle solenoid valve - removal
Exhaust throttle valve - inspection
Exhaust throttle valve - installation
Exhaust throttle valve - removal
EGR - inspection
EGR - installation
EGR - removal
1J. Electrical
Generator - removal
Glow plug - removal
ECM - installation
ECM - removal
ECM - setting
Exhaust differential pressure sensor - inspection
Exhaust differential pressure sensor - installation
Exhaust differential pressure sensor - removal
Exhaust gas temperature sensor - inspection
Exhaust gas temperature sensor - installation
Exhaust gas temperature sensor - removal
1.4. Engine (4HK1 (Euro5 specification without DPD))1B. Mechanical
Camshaft - removal
Engine - removal
Flywheel - removal
Idle gear - removal
Piston - inspection
Piston - reassembly
Piston - removal
1C. Fuel System
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel tank - removal
Injector - removal
1D. Cooling
Radiator - removal
1E. Lubrication
Oil pan - removal
Oil pump - removal
1F. Induction
1G. Exhaust
EGR - inspection
EGR - installation
EGR - removal
1J. Electrical
Generator - removal
Glow plug - removal
ECM - installation
ECM - removal
ECM - setting
1.5. Engine (6HK1 (Euro2 specification))1B. Mechanical
Camshaft - removal
Crankshaft pulley - inspection
Engine - removal
Flywheel - removal
Idle gear - removal
Piston - inspection
Piston - reassembly
Piston - removal
Timing gear case - installation
Timing gear case - removal
1C. Fuel System
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel tank - removal
Injector - removal
1D. Cooling
Radiator - removal
Water pump - disassembly
Water pump - reassembly
1E. Lubrication
Oil filter - inspection
Oil pan - removal
Oil pump - removal
1F. Induction
1G. Exhaust
1J. Electrical
Generator - removal
Glow plug - removal
ECM - installation
ECM - removal
ECM - setting
1.6. Engine (6HK1 (Euro4 specification))1B. Mechanical
Camshaft - removal
Engine - removal
Flywheel - removal
Idle gear - removal
Piston - inspection
Piston - reassembly
Piston - removal
1C. Fuel System
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel tank - removal
Injector - removal
1D. Cooling
Radiator - removal
1E. Lubrication
Oil pan - removal
Oil pump - removal
1F. Induction
1G. Exhaust
EGR cooler (cylinder head side) - inspection
EGR cooler (cylinder head side) - installation
EGR cooler (cylinder head side) - removal
EGR cooler (oil cooler side) - inspection
EGR cooler (oil cooler side) - installation
EGR cooler (oil cooler side) - removal
EGR valve - inspection
EGR valve - installation
EGR valve - removal
Idle up sensor - inspection
1J. Electrical
Generator - removal
ECM - installation
ECM - removal
ECM - setting
1.7. Engine (6HK1 (Euro5 specification))1B. Mechanical
Camshaft - removal
Engine - removal
Flywheel - removal
Idle gear - removal
Piston - inspection
Piston - reassembly
Piston - removal
1C. Fuel System
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel tank - removal
Injector - removal
1D. Cooling
Radiator - removal
1E. Lubrication
Oil pan - removal
Oil pump - removal
1F. Induction
1G. Exhaust
EGR valve - removal
1J. Electrical
Generator - removal
Glow plug - removal
ECM - installation
ECM - removal
ECM - setting
1.8. Engine (6NX1)1B. Mechanical
Camshaft - removal
Crankshaft pulley - disassembly
Crankshaft pulley - reassembly
Engine - removal
Flywheel - removal
Gear case - installation
Gear case - removal
Idle gear - removal
Piston - inspection
Piston - reassembly
Piston - removal
1C. Fuel System
Fuel - air bleed
Fuel - drain water
Fuel - inspection
Fuel tank - removal
Injector - inspection
Injector - removal
1D. Cooling
Radiator - removal
1E. Lubrication
Oil cooler - inspection
Oil pan - removal
Oil pump - removal
1F. Induction
1G. Exhaust
EGR cooler - inspection
EGR cooler - installation
EGR cooler - removal
EGR valve - removal
1J. Electrical
Generator - removal
ECM - installation
ECM - removal
ECM - setting
Turbocharger outlet temperature sensor - inspection
Turbocharger outlet temperature sensor - installation
Turbocharger outlet temperature sensor - removal
2. Suspension2B. Front Suspension
Leaf rigid suspension - disassembly
Leaf rigid suspension - inspection
Leaf rigid suspension - installation
Leaf rigid suspension - reassembly
Leaf rigid suspension - removal
2C. Rear Suspension
Trunnion suspension - disassembly
Trunnion suspension - inspection
Trunnion suspension - installation
Trunnion suspension - reassembly
Trunnion suspension - removal
2D. Wheel, Tire System
Disc wheel and tire - inspection
Disc wheel and tire - installation
Disc wheel and tire - removal
Step disc - installation
Step disc - removal
Wheel nut cover - installation
Wheel nut cover - removal
3.1. Driveline, Axle (AAM Production)3B. Differentials
Differential oil - replacement
Rear differential (single) (18H) - disassembly
Rear differential (single) (18H) - inspection
Rear differential (single) (18H) - installation
Rear differential (single) (18H) - reassembly
Rear differential (single) (18H) - removal
3C. Drive Shaft System
Front axle (full air brake) - disassembly
Front axle (full air brake) - inspection
Front axle (full air brake) - installation
Front axle (full air brake) - reassembly
Front axle (full air brake) - removal
Front hub - disassembly
Front hub - inspection
Front hub - installation
Front hub - reassembly
Front hub - removal
Knuckle (full air brake) - disassembly
Knuckle (full air brake) - inspection
Knuckle (full air brake) - installation
Knuckle (full air brake) - reassembly
Knuckle (full air brake) - removal
Knuckle arm (full air brake) - inspection
Knuckle arm (full air brake) - installation
Knuckle arm (full air brake) - removal
Propeller shaft - disassembly
Propeller shaft - inspection
Propeller shaft - installation
Propeller shaft - reassembly
Propeller shaft - removal
Rear axle (full air brake) - disassembly
Rear axle (full air brake) - inspection
Rear axle (full air brake) - installation
Rear axle (full air brake) - reassembly
Rear axle (full air brake) - removal
Rear axle shaft - inspection
Rear axle shaft - installation
Rear axle shaft - removal
Rear hub - disassembly
Rear hub - inspection
Rear hub - installation
Rear hub - reassembly
Rear hub - removal
Tie rod - disassembly
Tie rod - inspection
Tie rod - installation
Tie rod - reassembly
Tie rod - removal
Tie rod arm - inspection
Tie rod arm - installation
Tie rod arm - removal
Wheel alignment check
3.2. Driveline, Axle (ISUZU Production)3B. Differentials
Inter axle differential lock shift unit (17.5HT) - disassembly
Inter axle differential lock shift unit (17.5HT) - inspection
Inter axle differential lock shift unit (17.5HT) - installation
Inter axle differential lock shift unit (17.5HT) - reassembly
Inter axle differential lock shift unit (17.5HT) - removal
Rear differential (single) (13.5H) (no-spin differential) - disassembly
Rear differential (single) (13.5H) (no-spin differential) - inspection
Rear differential (single) (13.5H) (no-spin differential) - installation
Rear differential (single) (13.5H) (no-spin differential) - reassembly
Rear differential (single) (13.5H) (no-spin differential) - removal
Rear differential (single) (13.5H) - disassembly
Rear differential (single) (13.5H) - inspection
Rear differential (single) (13.5H) - installation
Rear differential (single) (13.5H) - reassembly
Rear differential (single) (13.5H) - removal
Rear differential (single) (14.5H) (no-spin differential) - disassembly
Rear differential (single) (14.5H) (no-spin differential) - inspection
Rear differential (single) (14.5H) (no-spin differential) - installation
Rear differential (single) (14.5H) (no-spin differential) - reassembly
Rear differential (single) (14.5H) (no-spin differential) - removal
Rear differential (single) (14.5H) - disassembly
Rear differential (single) (14.5H) - inspection
Rear differential (single) (14.5H) - installation
Rear differential (single) (14.5H) - reassembly
Rear differential (single) (14.5H) - removal
Rear differential (single) (15.5H) (no-spin differential) - disassembly
Rear differential (single) (15.5H) (no-spin differential) - inspection
Rear differential (single) (15.5H) (no-spin differential) - installation
Rear differential (single) (15.5H) (no-spin differential) - reassembly
Rear differential (single) (15.5H) (no-spin differential) - removal
Rear differential (single) (15.5H) - disassembly
Rear differential (single) (15.5H) - inspection
Rear differential (single) (15.5H) - installation
Rear differential (single) (15.5H) - reassembly
Rear differential (single) (15.5H) - removal
Rear differential (single) (16.5H) - disassembly
Rear differential (single) (16.5H) - inspection
Rear differential (single) (16.5H) - installation
Rear differential (single) (16.5H) - reassembly
Rear differential (single) (16.5H) - removal
Rear differential (single) (17.5H) - disassembly
Rear differential (single) (17.5H) - inspection
Rear differential (single) (17.5H) - installation
Rear differential (single) (17.5H) - reassembly
Rear differential (single) (17.5H) - removal
Rear differential (tandem)(17.5HT) - disassembly
Rear differential (tandem)(17.5HT) - inspection
Rear differential (tandem)(17.5HT) - installation
Rear differential (tandem)(17.5HT) - reassembly
Rear differential (tandem)(17.5HT) - removal
Front axle (air over hydraulic brake) - disassembly
Front axle (air over hydraulic brake) - inspection
Front axle (air over hydraulic brake) - installation
Front axle (air over hydraulic brake) - reassembly
Front axle (air over hydraulic brake) - removal
Front hub - removal
Knuckle (air over hydraulic brake) - disassembly
Knuckle (air over hydraulic brake) - inspection
Knuckle (air over hydraulic brake) - installation
Knuckle (air over hydraulic brake) - reassembly
Knuckle (air over hydraulic brake) - removal
Knuckle arm (air over hydraulic brake) - inspection
Knuckle arm (air over hydraulic brake) - installation
Knuckle arm (air over hydraulic brake) - removal
Propeller shaft between tandem axles - disassembly
Propeller shaft between tandem axles - inspection
Propeller shaft between tandem axles - installation
Propeller shaft between tandem axles - reassembly
Propeller shaft between tandem axles - removal
Rear axle (air over hydraulic brake) - disassembly
Rear axle (air over hydraulic brake) - inspection
Rear axle (air over hydraulic brake) - installation
Rear axle (air over hydraulic brake) - reassembly
Rear axle (air over hydraulic brake) - removal
Rear hub - removal
Tie rod - removal
4.1. Brakes (AAM production model (full air))4B. Brake System
Air compressor (6HK1 (Euro2 specification)) - disassembly
Air compressor (6HK1 (Euro2 specification)) - inspection
Air compressor (6HK1 (Euro2 specification)) - installation
Air compressor (6HK1 (Euro2 specification)) - reassembly
Air compressor (6HK1 (Euro2 specification)) - removal
Air compressor (6HK1 (Euro4 specification)) - disassembly
Air compressor (6HK1 (Euro4 specification)) - inspection
Air compressor (6HK1 (Euro4 specification)) - installation
Air compressor (6HK1 (Euro4 specification)) - reassembly
Air compressor (6HK1 (Euro4 specification)) - removal
Air compressor (6HK1 (Euro5 specification)) - disassembly
Air compressor (6HK1 (Euro5 specification)) - inspection
Air compressor (6HK1 (Euro5 specification)) - installation
Air compressor (6HK1 (Euro5 specification)) - reassembly
Air compressor (6HK1 (Euro5 specification)) - removal
Air dryer (DR-5 type) - disassembly
Air dryer (DR-5 type) - inspection
Air dryer (DR-5 type) - installation
Air dryer (DR-5 type) - reassembly
Air dryer (DR-5 type) - removal
Air dryer (with integrated governor) - disassembly
Air dryer (with integrated governor) - inspection
Air dryer (with integrated governor) - installation
Air dryer (with integrated governor) - reassembly
Air dryer (with integrated governor) - removal
Air governor - disassembly
Air governor - inspection
Air governor - installation
Air governor - reassembly
Air governor - removal
Brake pedal box - disassembly
Brake pedal box - installation
Brake pedal box - reassembly
Brake pedal box - removal
Brake valve - disassembly
Brake valve - inspection
Brake valve - installation
Brake valve - reassembly
Brake valve - removal
Check valve - inspection
Check valve - installation
Check valve - removal
Dual relay valve - disassembly
Dual relay valve - inspection
Dual relay valve - installation
Dual relay valve - reassembly
Dual relay valve - removal
Front brake chamber (power) - inspection
Front brake chamber (power) - installation
Front brake chamber (power) - removal
Front brake chamber (spring) - inspection
Front brake chamber (spring) - installation
Front brake chamber (spring) - removal
Front drum brake - inspection
Front drum brake - installation
Front drum brake - removal
HSA valve - disassembly
HSA valve - inspection
HSA valve - installation
HSA valve - reassembly
HSA valve - removal
Low pressure switch - inspection
Low pressure switch - installation
Low pressure switch - removal
Multi-protection valve - disassembly
Multi-protection valve - inspection
Multi-protection valve - installation
Multi-protection valve - reassembly
Multi-protection valve - removal
Rear brake chamber (spring) - inspection
Rear brake chamber (spring) - installation
Rear brake chamber (spring) - removal
Rear drum brake - inspection
Rear drum brake - installation
Rear drum brake - removal
Relay valve - disassembly
Relay valve - inspection
Relay valve - installation
Relay valve - reassembly
Relay valve - removal
Safety valve - inspection
Safety valve - installation
Safety valve - removal
Stoplight switch - inspection
Stoplight switch - installation
Stoplight switch - removal
4C. Parking Brake System
Parking brake switch - inspection
Parking brake switch - installation
Parking brake switch - removal
Parking brake valve - inspection
Parking brake valve - installation
Parking brake valve - removal
4D. ABS
Front ABS modulator - disassembly
Front ABS modulator - inspection
Front ABS modulator - installation
Front ABS modulator - reassembly
Front ABS modulator - removal
Front exciter ring - inspection
Front exciter ring - installation
Front exciter ring - removal
Front relay valve - disassembly
Front relay valve - inspection
Front relay valve - installation
Front relay valve - reassembly
Front relay valve - removal
Rear ABS modulator - disassembly
Rear ABS modulator - inspection
Rear ABS modulator - installation
Rear ABS modulator - reassembly
Rear ABS modulator - removal
Rear exciter ring - inspection
Rear exciter ring - installation
Rear exciter ring - removal
Rear relay valve - disassembly
Rear relay valve - inspection
Rear relay valve - installation
Rear relay valve - reassembly
Rear relay valve - removal
4E. Speed Retarder System
Exhaust brake solenoid valve - inspection
Exhaust brake solenoid valve - installation
Exhaust brake solenoid valve - removal
Exhaust brake valve (6HK1 (Euro2 specification)) - inspection
Exhaust brake valve (6HK1 (Euro2 specification)) - installation
Exhaust brake valve (6HK1 (Euro2 specification)) - removal
Exhaust brake valve (6HK1 (Euro4 specification)) - inspection
Exhaust brake valve (6HK1 (Euro4 specification)) - installation
Exhaust brake valve (6HK1 (Euro4 specification)) - removal
Exhaust brake valve (6HK1 (Euro5 specification)) - inspection
Exhaust brake valve (6HK1 (Euro5 specification)) - installation
Exhaust brake valve (6HK1 (Euro5 specification)) - removal
4Z. Brake Electrical Control
ABS control unit - installation
ABS control unit - removal
Front wheel speed sensor - inspection
Front wheel speed sensor - installation
Front wheel speed sensor - removal
Rear wheel speed sensor - inspection
Rear wheel speed sensor - installation
Rear wheel speed sensor - removal
4.2. Brakes (Full air)4B. Brake System
Air compressor (6NX1) - disassembly
Air compressor (6NX1) - inspection
Air compressor (6NX1) - installation
Air compressor (6NX1) - reassembly
Air compressor (6NX1) - removal
Front brake chamber (power) - disassembly
Front brake chamber (power) - reassembly
Front brake chamber (spring) - disassembly
Front brake chamber (spring) - reassembly
Front drum brake - disassembly
Front drum brake - reassembly
HSA valve - removal
Rear brake chamber (power) - disassembly
Rear brake chamber (power) - inspection
Rear brake chamber (power) - installation
Rear brake chamber (power) - reassembly
Rear brake chamber (power) - removal
Rear brake chamber (spring) - disassembly
Rear brake chamber (spring) - reassembly
Rear drum brake - disassembly
Rear drum brake - reassembly
4D. ABS
Exhaust brake valve (6NX1) - inspection
Exhaust brake valve (6NX1) - installation
Exhaust brake valve (6NX1) - removal
EBS control unit - installation
EBS control unit - removal
EBS control unit - setting
ESC module - installation
ESC module - removal
ESC module - setting
4.3. Brakes (Hydraulically-controlled air over hydraulic)4B. Brake System
Air compressor (4HK1) - disassembly
Air compressor (4HK1) - inspection
Air compressor (4HK1) - installation
Air compressor (4HK1) - reassembly
Air compressor (4HK1) - removal
Air dryer - disassembly
Air dryer - inspection
Air dryer - installation
Air dryer - reassembly
Air dryer - removal
Brake fluid - inspection
Brake fluid - replacement
Brake fluid tank - inspection
Brake fluid tank - installation
Brake fluid tank - removal
Front wheel cylinder - disassembly
Front wheel cylinder - inspection
Front wheel cylinder - installation
Front wheel cylinder - reassembly
Front wheel cylinder - removal
HSA valve - removal
Over stroke switch - inspection
Over stroke switch - installation
Over stroke switch - removal
Quick release valve - disassembly
Quick release valve - inspection
Quick release valve - installation
Quick release valve - reassembly
Quick release valve - removal
Rear wheel cylinder - disassembly
Rear wheel cylinder - inspection
Rear wheel cylinder - installation
Rear wheel cylinder - reassembly
Rear wheel cylinder - removal
Servo unit - disassembly
Servo unit - inspection
Servo unit - installation
Servo unit - reassembly
Servo unit - removal
Hand control brake valve - disassembly
Hand control brake valve - inspection
Hand control brake valve - installation
Hand control brake valve - reassembly
Hand control brake valve - removal
Parking brake - inspection
Parking brake - installation
Parking brake - removal
Parking brake lever - installation
Parking brake lever - removal
Parking brake switch (center parking brake models) - inspection
Parking brake switch (center parking brake models) - installation
Parking brake switch (center parking brake models) - removal
Parking brake switch (wheel park specification) - inspection
Parking brake switch (wheel park specification) - installation
Parking brake switch (wheel park specification) - removal
4D. ABS
Exhaust brake valve (4HK1 (Euro2 specification)) - inspection
Exhaust brake valve (4HK1 (Euro2 specification)) - installation
Exhaust brake valve (4HK1 (Euro2 specification)) - removal
Exhaust brake valve (4HK1 (Euro4 specification without DPD)) - inspection
Exhaust brake valve (4HK1 (Euro4 specification without DPD)) - installation
Exhaust brake valve (4HK1 (Euro4 specification without DPD)) - removal
Exhaust brake valve (4HK1 (Euro5 specification with DPD)) - inspection
Exhaust brake valve (4HK1 (Euro5 specification with DPD)) - installation
Exhaust brake valve (4HK1 (Euro5 specification with DPD)) - removal
Exhaust brake valve (4HK1 (Euro5 specification without DPD)) - inspection
Exhaust brake valve (4HK1 (Euro5 specification without DPD)) - installation
Exhaust brake valve (4HK1 (Euro5 specification without DPD)) - removal
Brake air pressure sensor - inspection
Brake air pressure sensor - installation
Brake air pressure sensor - removal
EHCU - installation
EHCU - removal
EHCU - setting
HSA control unit - installation
HSA control unit - removal
HSA control unit - setting
5.1. Transmission, Transaxle (Allison 3000)5B. Automatic
ATF - inspection
ATF - replacement
Range selector switch - installation
Range selector switch - removal
Transmission - inspection
Transmission - installation
Transmission - removal
5Z. Transmission Electrical Control
TCM - installation
TCM - removal
Vehicle speed sensor - installation
Vehicle speed sensor - removal
5.2. Transmission, Transaxle (ES11109)5C. Manual
Clutch housing - installation
Clutch housing - removal
Counter shaft - disassembly
Counter shaft - reassembly
Gear control cable - installation
Gear control cable - removal
Input shaft - disassembly
Input shaft - installation
Input shaft - reassembly
Input shaft - removal
Main shaft - disassembly
Main shaft - inspection
Main shaft - reassembly
Output shaft - disassembly
Output shaft - reassembly
Rear cover - disassembly
Rear cover - reassembly
Remote control - disassembly
Remote control - reassembly
Selector shaft - disassembly
Selector shaft - reassembly
Shift lever - disassembly
Shift lever - inspection
Shift lever - installation
Shift lever - reassembly
Shift lever - removal
Transmission - disassembly
Transmission - reassembly
Transmission oil - inspection
Transmission oil - replacement
5E. Clutch System
Clutch - disassembly
Clutch - inspection
Clutch - installation
Clutch - reassembly
Clutch - removal
Clutch booster (automatic adjustment) - disassembly
Clutch booster (automatic adjustment) - inspection
Clutch booster (automatic adjustment) - installation
Clutch booster (automatic adjustment) - reassembly
Clutch booster (automatic adjustment) - removal
Clutch booster - disassembly
Clutch booster - inspection
Clutch booster - installation
Clutch booster - reassembly
Clutch booster - removal
Clutch master cylinder - disassembly
Clutch master cylinder - inspection
Clutch master cylinder - installation
Clutch master cylinder - reassembly
Clutch master cylinder - removal
Clutch switch - installation
Clutch switch - removal
Shift fork - inspection
Shift fork - installation
Shift fork - removal
5F. PTO
Side PTO - disassembly
Side PTO - installation
Side PTO - reassembly
Side PTO - removal
5.3. Transmission, Transaxle (MZW)5C. Manual
Backup light switch - inspection
Backup light switch - installation
Backup light switch - removal
Control box - disassembly
Control box - inspection
Control box - reassembly
Counter shaft - inspection
Gear control - disassembly
Gear control - inspection
Gear control - reassembly
Input shaft - inspection
Neutral switch - inspection
Neutral switch - installation
Neutral switch - removal
Rear oil seal - installation
Rear oil seal - removal
Relay lever - disassembly
Relay lever - reassembly
5E. Clutch System
Clutch - inspection
Clutch - reassembly
Clutch - removal
5F. PTO
Side PTO - inspection
Side PTO - removal
Vehicle speed sensor - inspection
5.4. Transmission, Transaxle (MZZ)5C. Manual
Speedometer driven gear - installation
Speedometer driven gear - removal
5E. Clutch System
Clutch - inspection
Clutch - reassembly
Clutch - removal
5F. PTO
Side PTO - removal
5.5. Transmission, Transaxle (Smoother (MZW))5C. Manual
ATF - inspection
ATF - replacement
ATF cooler pipe - inspection
ATF cooler pipe - installation
ATF cooler pipe - removal
Gear shift unit - disassembly
Gear shift unit - inspection
Gear shift unit - reassembly
Smoother parts - inspection
Smoother parts - installation
Smoother parts - removal
5F. PTO
Side PTO - removal
Input speed sensor - inspection
Input speed sensor - installation
Input speed sensor - removal
Select stroke sensor - inspection
Select stroke sensor - installation
Select stroke sensor - removal
Shift stroke sensor - inspection
Shift stroke sensor - installation
Shift stroke sensor - removal
TCM - installation
TCM - removal
TCM - setting
Turbine speed sensor - inspection
Turbine speed sensor - installation
Turbine speed sensor - removal
5.6. Transmission, Transaxle (Smoother (MZZ))5C. Manual
ATF - inspection
ATF - replacement
5F. PTO
Side PTO - removal
TCM - installation
TCM - removal
TCM - setting
5.7. Transmission, Transaxle (ZF9S1110)5C. Manual
Flange - installation
Flange - removal
Planetary drive (with synchronizer unit) - disassembly
Planetary drive (with synchronizer unit) - reassembly
Shift turret (double H) - disassembly
Shift turret (double H) - reassembly
Transmission (double H) - disassembly
Transmission (double H) - installation
Transmission (double H) - reassembly
Transmission (double H) - removal
Transmission case - disassembly
Transmission case - reassembly
5E. Clutch System
Clutch - inspection
Clutch - reassembly
Clutch - removal
5F. PTO
Rear PTO - installation
Rear PTO - removal
6. Steering6B. Power Assisted System
Drag link - disassembly
Drag link - inspection
Drag link - installation
Drag link - reassembly
Drag link - removal
Power steering fluid - replacement
Power steering oil pump (4H series engine) - disassembly
Power steering oil pump (4H series engine) - inspection
Power steering oil pump (4H series engine) - installation
Power steering oil pump (4H series engine) - reassembly
Power steering oil pump (4H series engine) - removal
Power steering oil pump (6H series engine) - disassembly
Power steering oil pump (6H series engine) - inspection
Power steering oil pump (6H series engine) - installation
Power steering oil pump (6H series engine) - reassembly
Power steering oil pump (6H series engine) - removal
Power steering oil pump (6N series engine) - disassembly
Power steering oil pump (6N series engine) - inspection
Power steering oil pump (6N series engine) - installation
Power steering oil pump (6N series engine) - reassembly
Power steering oil pump (6N series engine) - removal
Power steering unit - disassembly
Power steering unit - inspection
Power steering unit - installation
Power steering unit - reassembly
Power steering unit - removal
Steering shaft - inspection
Steering shaft - installation
Steering shaft - removal
6Z. Steering Electrical Control
Steering angle sensor - installation
Steering angle sensor - removal
Steering angle sensor - setting
7. HVAC7B. Heater Ventilator Airconditioner
A_C compressor (4HK1) - installation
A_C compressor (4HK1) - removal
A_C compressor (6HK1) - installation
A_C compressor (6HK1) - removal
A_C compressor (6NX1) - installation
A_C compressor (6NX1) - removal
A_C compressor drive belt(4HK1) - inspection
A_C compressor drive belt(4HK1) - installation
A_C compressor drive belt(4HK1) - removal
A_C compressor drive belt(6HK1) - inspection
A_C compressor drive belt(6HK1) - installation
A_C compressor drive belt(6HK1) - removal
A_C compressor drive belt(6NX1) - inspection
A_C compressor drive belt(6NX1) - installation
A_C compressor drive belt(6NX1) - removal
A_C switch - inspection
A_C switch - installation
A_C switch - removal
Air mix door - installation
Air mix door - removal
Blower - installation
Blower - removal
Blower motor - inspection
Blower motor - installation
Blower motor - removal
Blower resistor - inspection
Blower resistor - installation
Blower resistor - removal
Condenser - installation
Condenser - removal
Condenser fan - inspection
Condenser fan - installation
Condenser fan - removal
Control panel and control lever - inspection
Control panel and control lever - installation
Control panel and control lever - removal
Electronic thermostat - inspection
Electronic thermostat - installation
Electronic thermostat - removal
Evaporator core - installation
Evaporator core - removal
Expansion valve - installation
Expansion valve - removal
Heater core - disassembly
Heater core - installation
Heater core - reassembly
Heater core - removal
Heater evaporator unit - installation
Heater evaporator unit - removal
Inside air filter - installation
Inside air filter - removal
Intake door - installation
Intake door - removal
Intake duct - installation
Intake duct - removal
Mode door - installation
Mode door - removal
Outside air filter - installation
Outside air filter - removal
Pressure switch - inspection
Pressure switch - installation
Pressure switch - removal
Receiver dryer - installation
Receiver dryer - removal
Vent grille - installation
Vent grille - removal
Ventilation duct - installation
Ventilation duct - removal
8. Restraints8B. Airbag Systems
Driver airbag - installation
Driver airbag - removal
Driver airbag - scrapping
SRS coil - installation
SRS coil - removal
8C. Seat Belt Systems
Buckle side driver seat belt - installation
Buckle side driver seat belt - removal
Buckle side passenger seat belt - installation
Buckle side passenger seat belt - removal
Front buckle side center seat belt - installation
Front buckle side center seat belt - removal
Front tongue side center seat belt - installation
Front tongue side center seat belt - removal
Front tongue side seat belt - installation
Front tongue side seat belt - removal
Seat belt with pretensioner - installation
Seat belt with pretensioner - removal
Seat belt with pretensioner - scrapping
8Z. Seat Belt and SRS Airbag Electrical Control
Satellite sensor - installation
Satellite sensor - removal
SRS control unit - installation
SRS control unit - removal
9. Body, Cab, Accessories9A. Lighting Systems
Backup light bulb - installation
Backup light bulb - removal
Clearance light bulb - installation
Clearance light bulb - removal
Combination switch - inspection
Combination switch - installation
Combination switch - removal
DC-DC converter - inspection
DC-DC converter - installation
DC-DC converter - removal
Dome light bulb - installation
Dome light bulb - removal
Door switch - inspection
Door switch - installation
Door switch - removal
Fog light bulb - installation
Fog light bulb - removal
Fog light switch - inspection
Fog light switch - installation
Fog light switch - removal
Front turn signal light - installation
Front turn signal light - removal
Front turn signal light bulb - installation
Front turn signal light bulb - removal
Hazard warning flasher switch - inspection
Hazard warning flasher switch - installation
Hazard warning flasher switch - removal
Headlight (bumper mounted headlight specification) - inspection
Headlight (bumper mounted headlight specification) - installation
Headlight (bumper mounted headlight specification) - removal
Headlight (cab mounted headlight specification) - inspection
Headlight (cab mounted headlight specification) - installation
Headlight (cab mounted headlight specification) - removal
Headlight bulb (bumper mounted headlight specification) - installation
Headlight bulb (bumper mounted headlight specification) - removal
Headlight bulb (cab mounted headlight specification) - installation
Headlight bulb (cab mounted headlight specification) - removal
Headlight leveling switch - inspection
Headlight leveling switch - installation
Headlight leveling switch - removal
Key reminder switch - inspection
Key reminder switch - installation
Key reminder switch - removal
License plate light bulb - installation
License plate light bulb - removal
Rear fog light bulb - installation
Rear fog light bulb - removal
Rear fog light switch - inspection
Rear fog light switch - installation
Rear fog light switch - removal
Rear turn signal light bulb - installation
Rear turn signal light bulb - removal
Side turn signal light bulb - installation
Side turn signal light bulb - removal
Tail stoplight bulb - installation
Tail stoplight bulb - removal
9B. Wiper, Washer Systems
Washer motor - inspection
Washer motor - installation
Washer motor - removal
Washer nozzle - installation
Washer nozzle - removal
Wiper arm - installation
Wiper arm - removal
Wiper blade rubber - installation
Wiper blade rubber - removal
Wiper linkage - installation
Wiper linkage - removal
Wiper motor - installation
Wiper motor - removal
9C. Electrical Control, Entertainment
Antenna - inspection
Antenna - installation
Antenna - removal
Audio - installation
Audio - removal
Cigarette lighter - installation
Cigarette lighter - removal
Control lever illumination bulb - installation
Control lever illumination bulb - removal
Door speaker - inspection
Door speaker - installation
Door speaker - removal
DPD switch - inspection
DPD switch - installation
DPD switch - removal
ESC OFF switch - inspection
ESC OFF switch - installation
ESC OFF switch - removal
Horn - inspection
Horn - installation
Horn - removal
Horn switch - inspection
Horn switch - installation
Horn switch - removal
HSA adjustment switch - inspection
HSA adjustment switch - installation
HSA adjustment switch - removal
HSA off switch - inspection
HSA off switch - installation
HSA off switch - removal
HSA reset switch - inspection
HSA reset switch - installation
HSA reset switch - removal
Ignition switch - inspection
Ignition switch - installation
Ignition switch - removal
Inter differential lock switch - inspection
Inter differential lock switch - installation
Inter differential lock switch - removal
PTO switch - inspection
PTO switch - installation
PTO switch - removal
Smoother emergency switch - inspection
Smoother emergency switch - installation
Smoother emergency switch - removal
USB charger - installation
USB charger - removal
9E. Instrumentation, Driver Info
Back buzzer - inspection
Back buzzer - installation
Back buzzer - removal
Instrument panel cluster - diagnostics
Instrument panel cluster - installation
Instrument panel cluster - removal
Instrument panel cluster - setting
Speed sensor control unit - installation
Speed sensor control unit - removal
Speed sensor control unit - setting
Tachograph - installation
Tachograph - removal
9F. Body Structure
Decal - installation
Emblem - installation
9G. Hood, Fenders, Doors
Engine hood insulator - installation
Engine hood insulator - removal
Front door - disassembly
Front door - installation
Front door - reassembly
Front door - removal
Front fender - installation
Front fender - removal
Front step - installation
Front step - removal
Rear fender - installation
Rear fender - removal
Rear mudguard - installation
Rear mudguard - removal
9H. Cab Structure
Front bumper (bumper mounted headlight specification) - disassembly
Front bumper (bumper mounted headlight specification) - installation
Front bumper (bumper mounted headlight specification) - reassembly
Front bumper (bumper mounted headlight specification) - removal
Front bumper (cab mounted headlight specification) - disassembly
Front bumper (cab mounted headlight specification) - installation
Front bumper (cab mounted headlight specification) - reassembly
Front bumper (cab mounted headlight specification) - removal
Front lid - disassembly
Front lid - installation
Front lid - reassembly
Front lid - removal
Front side panel (bumper mounted headlight specification) - installation
Front side panel (bumper mounted headlight specification) - removal
Front side panel (cab mounted headlight specification) - installation
Front side panel (cab mounted headlight specification) - removal
Front underrun protection (bumper mounted headlight specification) - disassembly
Front underrun protection (bumper mounted headlight specification) - installation
Front underrun protection (bumper mounted headlight specification) - reassembly
Front underrun protection (bumper mounted headlight specification) - removal
Front underrun protection (cab mounted headlight specification) - disassembly
Front underrun protection (cab mounted headlight specification) - installation
Front underrun protection (cab mounted headlight specification) - reassembly
Front underrun protection (cab mounted headlight specification) - removal
Radiator grille - installation
Radiator grille - removal
9I. Seats
Center seat - disassembly
Center seat - installation
Center seat - reassembly
Center seat - removal
Driver seat - disassembly
Driver seat - installation
Driver seat - reassembly
Driver seat - removal
Passenger seat - disassembly
Passenger seat - installation
Passenger seat - reassembly
Passenger seat - removal
9J. Security and Locks
Front door lock - installation
Front door lock - removal
Key cylinder - installation
Key cylinder - removal
Steering lock barrel - installation
Steering lock barrel - removal
9L. Exterior, Interior Trim
Floor mat (single cab) - installation
Floor mat (single cab) - removal
Head lining (single cab) - installation
Head lining (single cab) - removal
Header tray - installation
Header tray - removal
Instrument panel - disassembly
Instrument panel - installation
Instrument panel - reassembly
Instrument panel - removal
Reinforcement - installation
Reinforcement - removal
9M. Cab Mounting
Cab - installation
Cab - removal
Cab lock - installation
Cab lock - removal
Cab lock switch - inspection
Cab lock switch - installation
Cab lock switch - removal
Cab tilt cylinder - disassembly
Cab tilt cylinder - inspection
Cab tilt cylinder - installation
Cab tilt cylinder - reassembly
Cab tilt cylinder - removal
Cab tilt stay - installation
Cab tilt stay - removal
Electric - hydraulic power tilt pump - disassembly
Electric - hydraulic power tilt pump - inspection
Electric - hydraulic power tilt pump - installation
Electric - hydraulic power tilt pump - reassembly
Electric - hydraulic power tilt pump - removal
Front cab mounting (full-floating cab suspension) - inspection
Front cab mounting (full-floating cab suspension) - installation
Front cab mounting (full-floating cab suspension) - removal
Front cab mounting (semi-floating cab sus, rigid cab suspension) - installation
Front cab mounting (semi-floating cab sus, rigid cab suspension) - removal
Limit switch - installation
Limit switch - removal
Rear cab mounting (full-floating cab suspension) - inspection
Rear cab mounting (full-floating cab suspension) - installation
Rear cab mounting (full-floating cab suspension) - removal
Rear cab mounting (semi-floating cab sus, rigid cab suspension) - installation
Rear cab mounting (semi-floating cab sus, rigid cab suspension) - removal
9T. Glass, Windows, Mirrors
Backlight glass - installation
Backlight glass - removal
Door mounted outside rearview mirror - installation
Door mounted outside rearview mirror - removal
Front door power window switch - inspection
Front door power window switch - installation
Front door power window switch - removal
Front windshield glass - installation
Front windshield glass - removal
Pillar mounted outside rearview mirror (driver side) - installation
Pillar mounted outside rearview mirror (driver side) - removal
Pillar mounted outside rearview mirror (passenger side) - installation
Pillar mounted outside rearview mirror (passenger side) - removal
9Z. Body, Cab, Accessories Electrical Control
Air pressure sensor - inspection
DRM - installation
DRM - removal
Flasher unit - installation
Flasher unit - removal
FMS CAN interface control unit - installation
FMS CAN interface control unit - removal
FMS CAN interface control unit - setting
ICU - installation
ICU - removal
ICU - setting
VCM - installation
VCM - removal
VCM - setting
