Isuzu Engine UM4BD1 1971-1992 Parts Catalog 50323
Model: Isuzu UM4BD1 1971-1992 Engine
Part Number: 50323
Publication Date: 1971, 1972, 1973, 1974, 1975, 1976, 1977, 1978, 1979, 1980, 1981, 1982, 1983, 1984, 1985, 1986, 1987, 1988, 1989, 1990, 1991, 1992
Number of Pages: 419 Pages
001_Section Index 50323 Spare Parts Catalog.pdf
005_0 10A CYLINDER HEAD COVER Spare Parts Catalog.pdf
006_0 10B CYLINDER HEAD COVER Spare Parts Catalog.pdf
007_0 11A CYLINDER HEAD Spare Parts Catalog.pdf
008_0 11B CYLINDER HEAD Spare Parts Catalog.pdf
009_0 12A CYLINDER BLOCK Spare Parts Catalog.pdf
010_0 12B CYLINDER BLOCK Spare Parts Catalog.pdf
011_0 13A OIL PAN AND LEVEL GAUGE Spare Parts Catalog.pdf
012_0 13B OIL PAN AND LEVEL GAUGE Spare Parts Catalog.pdf
013_0 14A CAMSHAFT AND VALVE Spare Parts Catalog.pdf
014_0 14B CAMSHAFT AND VALVE Spare Parts Catalog.pdf
015_0 15A CRANKSHAFT PISTON AND FL Spare Parts Catalog.pdf
016_0 15B CRANKSHAFT PISTON AND FL Spare Parts Catalog.pdf
017_0 20A TIMING GEAR CASE AND FLY Spare Parts Catalog.pdf
018_0 20B TIMING GEAR CASE AND FLY Spare Parts Catalog.pdf
019_0 22A ENGINE MOUNTING Spare Parts Catalog.pdf
020_0 22B ENGINE MOUNTING Spare Parts Catalog.pdf
021_0 25A INLET MANIFOLD Spare Parts Catalog.pdf
022_0 25B INLET MANIFOLD Spare Parts Catalog.pdf
023_0 27A EXHAUST MANIFOLD Spare Parts Catalog.pdf
024_0 27B EXHAUST MANIFOLD Spare Parts Catalog.pdf
025_0 28A VENTILATION SYSTEM Spare Parts Catalog.pdf
026_0 28B VENTILATION SYSTEM Spare Parts Catalog.pdf
027_0 30A WATER PUMP AND CORROSION Spare Parts Catalog.pdf
028_0 30B WATER PUMP AND CORROSION Spare Parts Catalog.pdf
029_0 31A THERMOSTAT AND HOUSING Spare Parts Catalog.pdf
030_0 31B THERMOSTAT AND HOUSING Spare Parts Catalog.pdf
031_0 32A WATER PIPING ENGINE Spare Parts Catalog.pdf
032_0 32B WATER PIPING ENGINE Spare Parts Catalog.pdf
033_0 33A FAN AND FAN BELT Spare Parts Catalog.pdf
034_0 33B FAN AND FAN BELT Spare Parts Catalog.pdf
035_0 35A ENGINE CONTROL VALVE AND Spare Parts Catalog.pdf
036_0 35B ENGINE CONTROL VALVE AND Spare Parts Catalog.pdf
037_0 36A TURBOCHARGER SYSTEM Spare Parts Catalog.pdf
038_0 36B TURBOCHARGER SYSTEM Spare Parts Catalog.pdf
039_0 37A TURBOCHARGER Spare Parts Catalog.pdf
040_0 40A FUEL INJECTION SYSTEM Spare Parts Catalog.pdf
041_0 40B FUEL INJECTION SYSTEM Spare Parts Catalog.pdf
042_0 41A FUEL FILTER AND BRACKET Spare Parts Catalog.pdf
043_0 41B FUEL FILTER AND BRACKET Spare Parts Catalog.pdf
044_0 42A FUEL PUMP AND PIPE Spare Parts Catalog.pdf
045_0 42B FUEL PUMP AND PIPE Spare Parts Catalog.pdf
046_0 50A OIL COOLER AND OIL FILTE Spare Parts Catalog.pdf
047_0 50B OIL COOLER AND OIL FILTE Spare Parts Catalog.pdf
048_0 51A OIL PUMP AND OIL STRAINE Spare Parts Catalog.pdf
049_0 51B OIL PUMP AND OIL STRAINE Spare Parts Catalog.pdf
050_0 52A OIL AND VACUUM PIPING E Spare Parts Catalog.pdf
051_0 52B OIL AND VACUUM PIPING E Spare Parts Catalog.pdf
052_0 60A ENGINE ELECTRICAL CONTRO Spare Parts Catalog.pdf
053_0 60B ENGINE ELECTRICAL CONTRO Spare Parts Catalog.pdf
054_0 61A BATTERY AND ENGINE ELECT Spare Parts Catalog.pdf
055_0 61B BATTERY AND ENGINE ELECT Spare Parts Catalog.pdf
056_0 65A STARTER Spare Parts Catalog.pdf
057_0 66A GENERATOR Spare Parts Catalog.pdf
058_0 80A INJECTION PUMP Spare Parts Catalog.pdf
059_0 81A GOVERNOR INJECTION PUMP Spare Parts Catalog.pdf
060_0 84A FEED PUMP INJECTION PUM Spare Parts Catalog.pdf
061_0 85A AUTO TIMER INJECTION PU Spare Parts Catalog.pdf
062_0 86A MISCELLANEOUS PARTS INJ Spare Parts Catalog.pdf
063_0 86B MISCELLANEOUS PARTS INJ Spare Parts Catalog.pdf
064_0 87A COUPLING INJECTION PUMP Spare Parts Catalog.pdf
065_0 87B COUPLING INJECTION PUMP Spare Parts Catalog.pdf
066_1 ACCELERATOR COOLING FUEL AND Spare Parts Catalog.pdf
067_1 01A ACCELERATOR PEDAL AND CO Spare Parts Catalog.pdf
068_1 01B ACCELERATOR PEDAL AND CO Spare Parts Catalog.pdf
069_1 11A RADIATOR HOSE AND SUB TA Spare Parts Catalog.pdf
070_1 11B RADIATOR HOSE AND SUB TA Spare Parts Catalog.pdf
071_1 20A SEA WATER PIPE Spare Parts Catalog.pdf
072_1 20B SEA WATER PIPE Spare Parts Catalog.pdf
073_1 21A SEA WATER PUMP Spare Parts Catalog.pdf
074_1 21B SEA WATER PUMP Spare Parts Catalog.pdf
075_1 22A HEAT EXCHANGER Spare Parts Catalog.pdf
076_1 22B HEAT EXCHANGER Spare Parts Catalog.pdf
077_1 30A AIR CLEANER Spare Parts Catalog.pdf
078_1 30B AIR CLEANER Spare Parts Catalog.pdf
079_1 31A AIR DUCT Spare Parts Catalog.pdf
080_1 31B AIR DUCT Spare Parts Catalog.pdf
081_1 35A CHARGE AIR COOLER Spare Parts Catalog.pdf
082_1 35B CHARGE AIR COOLER Spare Parts Catalog.pdf
083_1 41A FUEL PIPING CHASSIS Spare Parts Catalog.pdf
084_1 41B FUEL PIPING CHASSIS Spare Parts Catalog.pdf
085_1 45A WATER SEDIMENTER FUEL Spare Parts Catalog.pdf
086_1 45B WATER SEDIMENTER FUEL Spare Parts Catalog.pdf
087_1 50A EXHAUST PIPE AND SILENCE Spare Parts Catalog.pdf
088_1 50B EXHAUST PIPE AND SILENCE Spare Parts Catalog.pdf
089_2 CLUTCH AND TRANSMISSION AXLE Spare Parts Catalog.pdf
090_2 90A MARINE GEAR Spare Parts Catalog.pdf
091_2 90B MARINE GEAR Spare Parts Catalog.pdf
092_2 93A TROLLING VALVE Spare Parts Catalog.pdf
093_2 93B TROLLING VALVE Spare Parts Catalog.pdf
094_2 94A MARINE GEAR INPUT Spare Parts Catalog.pdf
095_2 95A MARINE GEAR DRIVE Spare Parts Catalog.pdf
096_2 96A MARINE GEAR OUTPUT Spare Parts Catalog.pdf
097_2 97A MARINE GEAR HOUSING Spare Parts Catalog.pdf
098_8 ELECTRICAL PARTS LAMP METER Spare Parts Catalog.pdf
099_8 10A WIRING HARNESS AND FUSE Spare Parts Catalog.pdf
100_8 10B WIRING HARNESS AND FUSE Spare Parts Catalog.pdf
101_8 15A FIXING PARTS WIRING HAR Spare Parts Catalog.pdf
102_8 15B FIXING PARTS WIRING HAR Spare Parts Catalog.pdf
103_8 20A METER CABLE Spare Parts Catalog.pdf
104_8 20B METER CABLE Spare Parts Catalog.pdf
105_8 21A METER ASM Spare Parts Catalog.pdf
106_8 21B METER ASM Spare Parts Catalog.pdf
107_9 TOOLS WINCH AND REAR BODY Spare Parts Catalog.pdf
108_9 01A TOOLS Spare Parts Catalog.pdf
109_9 01B TOOLS Spare Parts Catalog.pdf
110_9 50A BILGE PUMP AND KINGSTONE Spare Parts Catalog.pdf
111_9 50B BILGE PUMP AND KINGSTONE Spare Parts Catalog.pdf
112_9 51A OIL DRAIN PUMP Spare Parts Catalog.pdf
113_9 51B OIL DRAIN PUMP Spare Parts Catalog.pdf
