Isuzu Engine UM2AB1 1971-1991 Parts Catalog 51057
Model: Isuzu UM2AB1 1971-1991 Engine
Part Number: 51057
Publication Date: 1971, 1972, 1973, 1974, 1975, 1976, 1977, 1978, 1979, 1980, 1981, 1982, 1983, 1984, 1985, 1986, 1987, 1988, 1989, 1990, 1991
Number of Pages: 167 Pages
001_Section Index 51057 Spare Parts Catalog.pdf
004_0 10A CYLINDER HEAD COVER Spare Parts Catalog.pdf
005_0 11A CYLINDER HEAD Spare Parts Catalog.pdf
006_0 12A CYLINDER BLOCK Spare Parts Catalog.pdf
007_0 13A OIL PAN AND LEVEL GAUGE Spare Parts Catalog.pdf
008_0 14A CAMSHAFT AND VALVE Spare Parts Catalog.pdf
009_0 15A CRANKSHAFT PISTON AND FL Spare Parts Catalog.pdf
010_0 20A TIMING GEAR CASE AND FLY Spare Parts Catalog.pdf
011_0 22A ENGINE MOUNTING Spare Parts Catalog.pdf
012_0 25A INLET MANIFOLD Spare Parts Catalog.pdf
013_0 27A EXHAUST MANIFOLD Spare Parts Catalog.pdf
014_0 30A WATER PUMP AND CORROSION Spare Parts Catalog.pdf
015_0 31A THERMOSTAT AND HOUSING Spare Parts Catalog.pdf
016_0 32A WATER PIPING ENGINE Spare Parts Catalog.pdf
017_0 33A FAN AND FAN BELT Spare Parts Catalog.pdf
018_0 35A ENGINE CONTROL VALVE AND Spare Parts Catalog.pdf
019_0 40A FUEL INJECTION SYSTEM Spare Parts Catalog.pdf
020_0 41A FUEL FILTER AND BRACKET Spare Parts Catalog.pdf
021_0 42A FUEL PUMP AND PIPE Spare Parts Catalog.pdf
022_0 50A OIL COOLER AND OIL FILTE Spare Parts Catalog.pdf
023_0 51A OIL PUMP AND OIL STRAINE Spare Parts Catalog.pdf
024_0 52A OIL AND VACUUM PIPING E Spare Parts Catalog.pdf
025_0 60A ENGINE ELECTRICAL CONTRO Spare Parts Catalog.pdf
026_0 65A STARTER Spare Parts Catalog.pdf
027_0 66A GENERATOR Spare Parts Catalog.pdf
028_0 80A INJECTION PUMP Spare Parts Catalog.pdf
029_0 81A GOVERNOR INJECTION PUMP Spare Parts Catalog.pdf
030_0 84A FEED PUMP INJECTION PUM Spare Parts Catalog.pdf
031_0 86A MISCELLANEOUS PARTS INJ Spare Parts Catalog.pdf
032_0 87A COUPLING INJECTION PUMP Spare Parts Catalog.pdf
033_1 ACCELERATOR COOLING FUEL AND Spare Parts Catalog.pdf
034_1 01A ACCELERATOR PEDAL AND CO Spare Parts Catalog.pdf
035_1 20A SEA WATER PIPE Spare Parts Catalog.pdf
036_1 21A SEA WATER PUMP Spare Parts Catalog.pdf
037_1 30A AIR CLEANER Spare Parts Catalog.pdf
038_1 40A FUEL TANK Spare Parts Catalog.pdf
039_1 50A EXHAUST PIPE AND SILENCE Spare Parts Catalog.pdf
040_2 CLUTCH AND TRANSMISSION AXLE Spare Parts Catalog.pdf
041_2 01A CLUTCH Spare Parts Catalog.pdf
042_2 03A CLUTCH PEDAL AND CONTROL Spare Parts Catalog.pdf
043_2 90A MARINE GEAR Spare Parts Catalog.pdf
044_2 94A MARINE GEAR INPUT Spare Parts Catalog.pdf
045_2 95A MARINE GEAR DRIVE Spare Parts Catalog.pdf
046_2 96A MARINE GEAR OUTPUT Spare Parts Catalog.pdf
047_2 97A MARINE GEAR HOUSING Spare Parts Catalog.pdf
048_8 ELECTRICAL PARTS LAMP METER Spare Parts Catalog.pdf
049_8 10A WIRING HARNESS AND FUSE Spare Parts Catalog.pdf
050_8 15A FIXING PARTS WIRING HAR Spare Parts Catalog.pdf
051_8 20A METER CABLE Spare Parts Catalog.pdf
052_8 21A METER ASM Spare Parts Catalog.pdf
053_8 25A SWITCH AND RELAY INSTRU Spare Parts Catalog.pdf
054_8 26A ELECTRICAL CONTROL AND O Spare Parts Catalog.pdf
055_9 TOOLS WINCH AND REAR BODY Spare Parts Catalog.pdf
056_9 01A TOOLS Spare Parts Catalog.pdf
057_9 50A BILGE PUMP AND KINGSTONE Spare Parts Catalog.pdf
