Isuzu Engine 6BD1 1977-1992 Parts Catalog 10382
Model: Isuzu 6BD1 1977-1992 Engine
Part Number: 10382
Publication Date: 1977, 1978, 1979, 1980, 1981, 1982, 1983, 1984, 1985, 1986, 1987, 1988, 1989, 1990, 1991, 1992
Number of Pages: 886 Pages
001_Section Index 10382 Spare Parts Catalog.pdf
005_0 05C ENGINE GASKET KIT Spare Parts Catalog.pdf
006_0 05D ENGINE GASKET KIT Spare Parts Catalog.pdf
007_0 10A CYLINDER HEAD COVER Spare Parts Catalog.pdf
008_0 10B CYLINDER HEAD COVER Spare Parts Catalog.pdf
009_0 10C CYLINDER HEAD COVER Spare Parts Catalog.pdf
010_0 10D CYLINDER HEAD COVER Spare Parts Catalog.pdf
011_0 11A CYLINDER HEAD Spare Parts Catalog.pdf
012_0 11B CYLINDER HEAD Spare Parts Catalog.pdf
013_0 11C CYLINDER HEAD Spare Parts Catalog.pdf
014_0 11D CYLINDER HEAD Spare Parts Catalog.pdf
015_0 12A CYLINDER BLOCK Spare Parts Catalog.pdf
016_0 12B CYLINDER BLOCK Spare Parts Catalog.pdf
017_0 12C CYLINDER BLOCK Spare Parts Catalog.pdf
018_0 12D CYLINDER BLOCK Spare Parts Catalog.pdf
019_0 13A OIL PAN AND LEVEL GAUGE Spare Parts Catalog.pdf
020_0 13B OIL PAN AND LEVEL GAUGE Spare Parts Catalog.pdf
021_0 13C OIL PAN AND LEVEL GAUGE Spare Parts Catalog.pdf
022_0 13D OIL PAN AND LEVEL GAUGE Spare Parts Catalog.pdf
023_0 14A CAMSHAFT AND VALVE Spare Parts Catalog.pdf
024_0 14B CAMSHAFT AND VALVE Spare Parts Catalog.pdf
025_0 14C CAMSHAFT AND VALVE Spare Parts Catalog.pdf
026_0 14D CAMSHAFT AND VALVE Spare Parts Catalog.pdf
027_0 15A CRANKSHAFT PISTON AND FL Spare Parts Catalog.pdf
028_0 15B CRANKSHAFT PISTON AND FL Spare Parts Catalog.pdf
029_0 15C CRANKSHAFT PISTON AND FL Spare Parts Catalog.pdf
030_0 15D CRANKSHAFT PISTON AND FL Spare Parts Catalog.pdf
031_0 20A TIMING GEAR CASE AND FLY Spare Parts Catalog.pdf
032_0 20B TIMING GEAR CASE AND FLY Spare Parts Catalog.pdf
033_0 20C TIMING GEAR CASE AND FLY Spare Parts Catalog.pdf
034_0 20D TIMING GEAR CASE AND FLY Spare Parts Catalog.pdf
035_0 22A ENGINE MOUNTING Spare Parts Catalog.pdf
036_0 22B ENGINE MOUNTING Spare Parts Catalog.pdf
037_0 22C ENGINE MOUNTING Spare Parts Catalog.pdf
038_0 22D ENGINE MOUNTING Spare Parts Catalog.pdf
039_0 25A INLET MANIFOLD Spare Parts Catalog.pdf
040_0 25B INLET MANIFOLD Spare Parts Catalog.pdf
041_0 25C INLET MANIFOLD Spare Parts Catalog.pdf
042_0 25D INLET MANIFOLD Spare Parts Catalog.pdf
043_0 27A EXHAUST MANIFOLD Spare Parts Catalog.pdf
044_0 27B EXHAUST MANIFOLD Spare Parts Catalog.pdf
045_0 27C EXHAUST MANIFOLD Spare Parts Catalog.pdf
046_0 27D EXHAUST MANIFOLD Spare Parts Catalog.pdf
047_0 28A VENTILATION SYSTEM Spare Parts Catalog.pdf
048_0 28B VENTILATION SYSTEM Spare Parts Catalog.pdf
049_0 28C VENTILATION SYSTEM Spare Parts Catalog.pdf
050_0 28D VENTILATION SYSTEM Spare Parts Catalog.pdf
051_0 30A WATER PUMP AND CORROSION Spare Parts Catalog.pdf
052_0 30B WATER PUMP AND CORROSION Spare Parts Catalog.pdf
053_0 30C WATER PUMP AND CORROSION Spare Parts Catalog.pdf
054_0 30D WATER PUMP AND CORROSION Spare Parts Catalog.pdf
055_0 31A THERMOSTAT AND HOUSING Spare Parts Catalog.pdf
056_0 31B THERMOSTAT AND HOUSING Spare Parts Catalog.pdf
057_0 31C THERMOSTAT AND HOUSING Spare Parts Catalog.pdf
058_0 31D THERMOSTAT AND HOUSING Spare Parts Catalog.pdf
059_0 33A FAN AND FAN BELT Spare Parts Catalog.pdf
060_0 33B FAN AND FAN BELT Spare Parts Catalog.pdf
061_0 33C FAN AND FAN BELT Spare Parts Catalog.pdf
062_0 33D FAN AND FAN BELT Spare Parts Catalog.pdf
063_0 35A ENGINE CONTROL VALVE AND Spare Parts Catalog.pdf
064_0 35B ENGINE CONTROL VALVE AND Spare Parts Catalog.pdf
065_0 35C ENGINE CONTROL VALVE AND Spare Parts Catalog.pdf
066_0 35D ENGINE CONTROL VALVE AND Spare Parts Catalog.pdf
067_0 36A TURBOCHARGER SYSTEM Spare Parts Catalog.pdf
068_0 36B TURBOCHARGER SYSTEM Spare Parts Catalog.pdf
069_0 37A TURBOCHARGER Spare Parts Catalog.pdf
070_0 38A AIR COMPRESSOR PIPING E Spare Parts Catalog.pdf
071_0 38B AIR COMPRESSOR PIPING E Spare Parts Catalog.pdf
072_0 38C AIR COMPRESSOR PIPING E Spare Parts Catalog.pdf
073_0 38D AIR COMPRESSOR PIPING E Spare Parts Catalog.pdf
074_0 39A AIR COMPRESSOR BRAKE Spare Parts Catalog.pdf
075_0 39B AIR COMPRESSOR BRAKE Spare Parts Catalog.pdf
076_0 39C AIR COMPRESSOR BRAKE Spare Parts Catalog.pdf
077_0 39D AIR COMPRESSOR BRAKE Spare Parts Catalog.pdf
078_0 40A FUEL INJECTION SYSTEM Spare Parts Catalog.pdf
079_0 40B FUEL INJECTION SYSTEM Spare Parts Catalog.pdf
080_0 40C FUEL INJECTION SYSTEM Spare Parts Catalog.pdf
081_0 40D FUEL INJECTION SYSTEM Spare Parts Catalog.pdf
082_0 41A FUEL FILTER AND BRACKET Spare Parts Catalog.pdf
083_0 41B FUEL FILTER AND BRACKET Spare Parts Catalog.pdf
084_0 41C FUEL FILTER AND BRACKET Spare Parts Catalog.pdf
085_0 41D FUEL FILTER AND BRACKET Spare Parts Catalog.pdf
086_0 42A FUEL PUMP AND PIPE Spare Parts Catalog.pdf
087_0 42B FUEL PUMP AND PIPE Spare Parts Catalog.pdf
088_0 42C FUEL PUMP AND PIPE Spare Parts Catalog.pdf
089_0 42D FUEL PUMP AND PIPE Spare Parts Catalog.pdf
090_0 50A OIL COOLER AND OIL FILTE Spare Parts Catalog.pdf
091_0 50B OIL COOLER AND OIL FILTE Spare Parts Catalog.pdf
092_0 50C OIL COOLER AND OIL FILTE Spare Parts Catalog.pdf
093_0 50D OIL COOLER AND OIL FILTE Spare Parts Catalog.pdf
094_0 51A OIL PUMP AND OIL STRAINE Spare Parts Catalog.pdf
095_0 51B OIL PUMP AND OIL STRAINE Spare Parts Catalog.pdf
096_0 51C OIL PUMP AND OIL STRAINE Spare Parts Catalog.pdf
097_0 51D OIL PUMP AND OIL STRAINE Spare Parts Catalog.pdf
098_0 52A OIL AND VACUUM PIPING E Spare Parts Catalog.pdf
099_0 52B OIL AND VACUUM PIPING E Spare Parts Catalog.pdf
100_0 52C OIL AND VACUUM PIPING E Spare Parts Catalog.pdf
101_0 52D OIL AND VACUUM PIPING E Spare Parts Catalog.pdf
102_0 60A ENGINE ELECTRICAL CONTRO Spare Parts Catalog.pdf
103_0 60B ENGINE ELECTRICAL CONTRO Spare Parts Catalog.pdf
104_0 60C ENGINE ELECTRICAL CONTRO Spare Parts Catalog.pdf
105_0 60D ENGINE ELECTRICAL CONTRO Spare Parts Catalog.pdf
106_0 61A BATTERY AND ENGINE ELECT Spare Parts Catalog.pdf
107_0 61B BATTERY AND ENGINE ELECT Spare Parts Catalog.pdf
108_0 61C BATTERY AND ENGINE ELECT Spare Parts Catalog.pdf
109_0 61D BATTERY AND ENGINE ELECT Spare Parts Catalog.pdf
110_0 65A STARTER Spare Parts Catalog.pdf
111_0 66A GENERATOR Spare Parts Catalog.pdf
112_0 80A INJECTION PUMP Spare Parts Catalog.pdf
113_0 80B INJECTION PUMP Spare Parts Catalog.pdf
114_0 81A GOVERNOR INJECTION PUMP Spare Parts Catalog.pdf
115_0 81B GOVERNOR INJECTION PUMP Spare Parts Catalog.pdf
116_0 82A BOOST COMPENSATOR INJEC Spare Parts Catalog.pdf
117_0 84A FEED PUMP INJECTION PUM Spare Parts Catalog.pdf
118_0 84B FEED PUMP INJECTION PUM Spare Parts Catalog.pdf
119_0 85B AUTO TIMER INJECTION PU Spare Parts Catalog.pdf
120_0 86A MISCELLANEOUS PARTS INJ Spare Parts Catalog.pdf
121_0 86B MISCELLANEOUS PARTS INJ Spare Parts Catalog.pdf
122_0 86C MISCELLANEOUS PARTS INJ Spare Parts Catalog.pdf
123_0 86D MISCELLANEOUS PARTS INJ Spare Parts Catalog.pdf
124_0 87A COUPLING INJECTION PUMP Spare Parts Catalog.pdf
125_0 87B COUPLING INJECTION PUMP Spare Parts Catalog.pdf
126_0 87C COUPLING INJECTION PUMP Spare Parts Catalog.pdf
127_0 87D COUPLING INJECTION PUMP Spare Parts Catalog.pdf
128_0 90A POWER TAKE OFF FLYWHEEL Spare Parts Catalog.pdf
129_0 90B POWER TAKE OFF FLYWHEEL Spare Parts Catalog.pdf
130_0 90C POWER TAKE OFF FLYWHEEL Spare Parts Catalog.pdf
131_1 ACCELERATOR COOLING FUEL AND Spare Parts Catalog.pdf
132_1 01A ACCELERATOR PEDAL AND CO Spare Parts Catalog.pdf
133_1 01B ACCELERATOR PEDAL AND CO Spare Parts Catalog.pdf
134_1 01D ACCELERATOR PEDAL AND CO Spare Parts Catalog.pdf
135_1 10A RADIATOR Spare Parts Catalog.pdf
136_1 10B RADIATOR Spare Parts Catalog.pdf
137_1 10D RADIATOR Spare Parts Catalog.pdf
138_1 11A RADIATOR HOSE AND SUB TA Spare Parts Catalog.pdf
139_1 11B RADIATOR HOSE AND SUB TA Spare Parts Catalog.pdf
140_1 11D RADIATOR HOSE AND SUB TA Spare Parts Catalog.pdf
141_1 30A AIR CLEANER Spare Parts Catalog.pdf
142_1 30B AIR CLEANER Spare Parts Catalog.pdf
143_1 30C AIR CLEANER Spare Parts Catalog.pdf
144_1 30D AIR CLEANER Spare Parts Catalog.pdf
145_1 31A AIR DUCT Spare Parts Catalog.pdf
146_1 31B AIR DUCT Spare Parts Catalog.pdf
147_1 31C AIR DUCT Spare Parts Catalog.pdf
148_1 31D AIR DUCT Spare Parts Catalog.pdf
149_1 40A FUEL TANK Spare Parts Catalog.pdf
150_1 40D FUEL TANK Spare Parts Catalog.pdf
151_1 41A FUEL PIPING CHASSIS Spare Parts Catalog.pdf
152_1 41D FUEL PIPING CHASSIS Spare Parts Catalog.pdf
153_1 45B WATER SEDIMENTER FUEL Spare Parts Catalog.pdf
154_1 45D WATER SEDIMENTER FUEL Spare Parts Catalog.pdf
155_1 50A EXHAUST PIPE AND SILENCE Spare Parts Catalog.pdf
156_1 50B EXHAUST PIPE AND SILENCE Spare Parts Catalog.pdf
157_1 50D EXHAUST PIPE AND SILENCE Spare Parts Catalog.pdf
158_2 CLUTCH AND TRANSMISSION AXLE Spare Parts Catalog.pdf
159_2 01A CLUTCH Spare Parts Catalog.pdf
160_2 01B CLUTCH Spare Parts Catalog.pdf
161_2 01D CLUTCH Spare Parts Catalog.pdf
162_2 03A CLUTCH PEDAL AND CONTROL Spare Parts Catalog.pdf
163_2 05A CLUTCH PIPING Spare Parts Catalog.pdf
164_2 06A CLUTCH SLAVE CYLINDER Spare Parts Catalog.pdf
165_2 06B CLUTCH SLAVE CYLINDER Spare Parts Catalog.pdf
166_2 06D CLUTCH SLAVE CYLINDER Spare Parts Catalog.pdf
167_2 07A CLUTCH BOOSTER MINIPACK Spare Parts Catalog.pdf
168_2 10A REPAIR KIT TRANSMISSION Spare Parts Catalog.pdf
169_2 20A MANUAL TRANSMISSION ASM Spare Parts Catalog.pdf
170_2 25A SPEEDOMETER DRIVEN GEAR Spare Parts Catalog.pdf
171_2 25D SPEEDOMETER DRIVEN GEAR Spare Parts Catalog.pdf
172_2 26A MANUAL TRANSMISSION GEAR Spare Parts Catalog.pdf
173_2 30A GEAR SHIFTER AND QUADRAN Spare Parts Catalog.pdf
174_2 35A MANUAL TRANSMISSION SHIF Spare Parts Catalog.pdf
175_2 36A MANUAL TRANSMISSION CONT Spare Parts Catalog.pdf
176_2 40D AUTO TRANS ASM AND REPAI Spare Parts Catalog.pdf
177_2 42D AUTO TRANS OIL PAN AND O Spare Parts Catalog.pdf
178_2 53D TRANSMISSION OIL COOLER Spare Parts Catalog.pdf
179_2 55D AUTO TRANS SHIFT CONTROL Spare Parts Catalog.pdf
180_2 56D AUTO TRANS CONTROL LINK Spare Parts Catalog.pdf
181_2 91A POWER DRIVE Spare Parts Catalog.pdf
182_2 91B POWER DRIVE Spare Parts Catalog.pdf
183_3 BRAKE SYSTEM FRONT REAR BRA Spare Parts Catalog.pdf
184_3 08A PARKING BRAKE Spare Parts Catalog.pdf
185_3 08D PARKING BRAKE Spare Parts Catalog.pdf
186_3 11A PARKING BRAKE CONTROL Spare Parts Catalog.pdf
187_4 STEERING PROPELLER SHAFT AXLE Spare Parts Catalog.pdf
188_4 01A PROPELLER SHAFT Spare Parts Catalog.pdf
189_4 01D PROPELLER SHAFT Spare Parts Catalog.pdf
190_4 35A POWER STEERING CONTROL Spare Parts Catalog.pdf
191_4 35B POWER STEERING CONTROL Spare Parts Catalog.pdf
192_4 35C POWER STEERING CONTROL Spare Parts Catalog.pdf
193_4 35D POWER STEERING CONTROL Spare Parts Catalog.pdf
194_4 36A POWER STEERING CONTROL Spare Parts Catalog.pdf
195_4 36B POWER STEERING CONTROL Spare Parts Catalog.pdf
196_4 36D POWER STEERING CONTROL Spare Parts Catalog.pdf
197_4 42A POWER STEERING OIL PUMP Spare Parts Catalog.pdf
198_6 BODY PARTS PANEL TRIM GLAS Spare Parts Catalog.pdf
199_6 98A POWER UNIT BODY Spare Parts Catalog.pdf
200_6 98D POWER UNIT BODY Spare Parts Catalog.pdf
201_7 BODY PARTS ORNAMENT MIRROR Spare Parts Catalog.pdf
202_7 10A CAUTION PLATE AND LABEL Spare Parts Catalog.pdf
203_7 10C CAUTION PLATE AND LABEL Spare Parts Catalog.pdf
204_7 10D CAUTION PLATE AND LABEL Spare Parts Catalog.pdf
205_8 ELECTRICAL PARTS LAMP METER Spare Parts Catalog.pdf
206_8 10A WIRING HARNESS AND FUSE Spare Parts Catalog.pdf
207_8 10B WIRING HARNESS AND FUSE Spare Parts Catalog.pdf
208_8 10D WIRING HARNESS AND FUSE Spare Parts Catalog.pdf
209_8 15D FIXING PARTS WIRING HAR Spare Parts Catalog.pdf
210_8 20D METER CABLE Spare Parts Catalog.pdf
211_8 21A METER ASM Spare Parts Catalog.pdf
212_8 21B METER ASM Spare Parts Catalog.pdf
213_8 21C METER ASM Spare Parts Catalog.pdf
214_8 21D METER ASM Spare Parts Catalog.pdf
215_8 25A SWITCH AND RELAY INSTRU Spare Parts Catalog.pdf
216_8 25B SWITCH AND RELAY INSTRU Spare Parts Catalog.pdf
217_8 25C SWITCH AND RELAY INSTRU Spare Parts Catalog.pdf
218_8 25D SWITCH AND RELAY INSTRU Spare Parts Catalog.pdf
219_8 26A ELECTRICAL CONTROL AND O Spare Parts Catalog.pdf
220_8 26D ELECTRICAL CONTROL AND O Spare Parts Catalog.pdf
221_8 28D CHASSIS ELECTRICAL Spare Parts Catalog.pdf
