Isuzu Engine 4JA1 4JB1 4JC1 1984-1994 Parts Catalog 50319
Model: Isuzu 4JA1 4JB1 4JC1 1984-1994 Engine
Part Number: 50319
Publication Date: 1984, 1985, 1986, 1987, 1988, 1989, 1990, 1991, 1992, 1993, 1994
Number of Pages: 433 Pages
001_Section Index 50319 Spare Parts Catalog.pdf
003_0 01A PARTIAL ENGINE Spare Parts Catalog.pdf
004_0 05A ENGINE GASKET KIT Spare Parts Catalog.pdf
005_0 05B ENGINE GASKET KIT Spare Parts Catalog.pdf
006_0 10A CYLINDER HEAD COVER Spare Parts Catalog.pdf
007_0 10B CYLINDER HEAD COVER Spare Parts Catalog.pdf
008_0 11A CYLINDER HEAD Spare Parts Catalog.pdf
009_0 11B CYLINDER HEAD Spare Parts Catalog.pdf
010_0 12A CYLINDER BLOCK Spare Parts Catalog.pdf
011_0 12B CYLINDER BLOCK Spare Parts Catalog.pdf
012_0 13A OIL PAN AND LEVEL GAUGE Spare Parts Catalog.pdf
013_0 13B OIL PAN AND LEVEL GAUGE Spare Parts Catalog.pdf
014_0 14A CAMSHAFT AND VALVE Spare Parts Catalog.pdf
015_0 14B CAMSHAFT AND VALVE Spare Parts Catalog.pdf
016_0 15A CRANKSHAFT PISTON AND FL Spare Parts Catalog.pdf
017_0 15B CRANKSHAFT PISTON AND FL Spare Parts Catalog.pdf
018_0 20A TIMING GEAR CASE AND FLY Spare Parts Catalog.pdf
019_0 20B TIMING GEAR CASE AND FLY Spare Parts Catalog.pdf
020_0 22A ENGINE MOUNTING Spare Parts Catalog.pdf
021_0 22B ENGINE MOUNTING Spare Parts Catalog.pdf
022_0 25A INLET MANIFOLD Spare Parts Catalog.pdf
023_0 25B INLET MANIFOLD Spare Parts Catalog.pdf
024_0 27A EXHAUST MANIFOLD Spare Parts Catalog.pdf
025_0 27B EXHAUST MANIFOLD Spare Parts Catalog.pdf
026_0 28A VENTILATION SYSTEM Spare Parts Catalog.pdf
027_0 28B VENTILATION SYSTEM Spare Parts Catalog.pdf
028_0 30A WATER PUMP AND CORROSION Spare Parts Catalog.pdf
029_0 30B WATER PUMP AND CORROSION Spare Parts Catalog.pdf
030_0 31A THERMOSTAT AND HOUSING Spare Parts Catalog.pdf
031_0 31B THERMOSTAT AND HOUSING Spare Parts Catalog.pdf
032_0 32A WATER PIPING ENGINE Spare Parts Catalog.pdf
033_0 32B WATER PIPING ENGINE Spare Parts Catalog.pdf
034_0 33A FAN AND FAN BELT Spare Parts Catalog.pdf
035_0 33B FAN AND FAN BELT Spare Parts Catalog.pdf
036_0 35A ENGINE CONTROL VALVE AND Spare Parts Catalog.pdf
037_0 35B ENGINE CONTROL VALVE AND Spare Parts Catalog.pdf
038_0 36B TURBOCHARGER SYSTEM Spare Parts Catalog.pdf
039_0 37A TURBOCHARGER Spare Parts Catalog.pdf
040_0 38B AIR COMPRESSOR PIPING E Spare Parts Catalog.pdf
041_0 39B AIR COMPRESSOR BRAKE Spare Parts Catalog.pdf
042_0 40A FUEL INJECTION SYSTEM Spare Parts Catalog.pdf
043_0 40B FUEL INJECTION SYSTEM Spare Parts Catalog.pdf
044_0 41A FUEL FILTER AND BRACKET Spare Parts Catalog.pdf
045_0 41B FUEL FILTER AND BRACKET Spare Parts Catalog.pdf
046_0 42A FUEL PUMP AND PIPE Spare Parts Catalog.pdf
047_0 42B FUEL PUMP AND PIPE Spare Parts Catalog.pdf
048_0 50A OIL COOLER AND OIL FILTE Spare Parts Catalog.pdf
049_0 50B OIL COOLER AND OIL FILTE Spare Parts Catalog.pdf
050_0 51A OIL PUMP AND OIL STRAINE Spare Parts Catalog.pdf
051_0 51B OIL PUMP AND OIL STRAINE Spare Parts Catalog.pdf
052_0 52A OIL AND VACUUM PIPING E Spare Parts Catalog.pdf
053_0 52B OIL AND VACUUM PIPING E Spare Parts Catalog.pdf
054_0 60A ENGINE ELECTRICAL CONTRO Spare Parts Catalog.pdf
055_0 60B ENGINE ELECTRICAL CONTRO Spare Parts Catalog.pdf
056_0 61A BATTERY AND ENGINE ELECT Spare Parts Catalog.pdf
057_0 61B BATTERY AND ENGINE ELECT Spare Parts Catalog.pdf
058_0 65A STARTER Spare Parts Catalog.pdf
059_0 66A GENERATOR Spare Parts Catalog.pdf
060_0 80A INJECTION PUMP Spare Parts Catalog.pdf
061_0 80B INJECTION PUMP Spare Parts Catalog.pdf
062_0 81A GOVERNOR INJECTION PUMP Spare Parts Catalog.pdf
063_0 81B GOVERNOR INJECTION PUMP Spare Parts Catalog.pdf
064_0 84A FEED PUMP INJECTION PUM Spare Parts Catalog.pdf
065_0 84B FEED PUMP INJECTION PUM Spare Parts Catalog.pdf
066_0 85A AUTO TIMER INJECTION PU Spare Parts Catalog.pdf
067_0 85B AUTO TIMER INJECTION PU Spare Parts Catalog.pdf
068_0 86A MISCELLANEOUS PARTS INJ Spare Parts Catalog.pdf
069_0 86B MISCELLANEOUS PARTS INJ Spare Parts Catalog.pdf
070_0 87A COUPLING INJECTION PUMP Spare Parts Catalog.pdf
071_0 87B COUPLING INJECTION PUMP Spare Parts Catalog.pdf
072_1 ACCELERATOR COOLING FUEL AND Spare Parts Catalog.pdf
073_1 01A ACCELERATOR PEDAL AND CO Spare Parts Catalog.pdf
074_1 01B ACCELERATOR PEDAL AND CO Spare Parts Catalog.pdf
075_1 10A RADIATOR Spare Parts Catalog.pdf
076_1 10B RADIATOR Spare Parts Catalog.pdf
077_1 11A RADIATOR HOSE AND SUB TA Spare Parts Catalog.pdf
078_1 11B RADIATOR HOSE AND SUB TA Spare Parts Catalog.pdf
079_1 30A AIR CLEANER Spare Parts Catalog.pdf
080_1 30B AIR CLEANER Spare Parts Catalog.pdf
081_1 31B AIR DUCT Spare Parts Catalog.pdf
082_1 40A FUEL TANK Spare Parts Catalog.pdf
083_1 40B FUEL TANK Spare Parts Catalog.pdf
084_1 41A FUEL PIPING CHASSIS Spare Parts Catalog.pdf
085_1 41B FUEL PIPING CHASSIS Spare Parts Catalog.pdf
086_1 45A WATER SEDIMENTER FUEL Spare Parts Catalog.pdf
087_1 45B WATER SEDIMENTER FUEL Spare Parts Catalog.pdf
088_1 50A EXHAUST PIPE AND SILENCE Spare Parts Catalog.pdf
089_1 50B EXHAUST PIPE AND SILENCE Spare Parts Catalog.pdf
090_2 CLUTCH AND TRANSMISSION AXLE Spare Parts Catalog.pdf
091_2 01A CLUTCH Spare Parts Catalog.pdf
092_2 01B CLUTCH Spare Parts Catalog.pdf
093_2 05A CLUTCH PIPING Spare Parts Catalog.pdf
094_2 05B CLUTCH PIPING Spare Parts Catalog.pdf
095_2 06A CLUTCH SLAVE CYLINDER Spare Parts Catalog.pdf
096_2 06B CLUTCH SLAVE CYLINDER Spare Parts Catalog.pdf
097_2 20A MANUAL TRANSMISSION ASM Spare Parts Catalog.pdf
098_2 20B MANUAL TRANSMISSION ASM Spare Parts Catalog.pdf
099_2 25A SPEEDOMETER DRIVEN GEAR Spare Parts Catalog.pdf
100_2 25B SPEEDOMETER DRIVEN GEAR Spare Parts Catalog.pdf
101_2 26A MANUAL TRANSMISSION GEAR Spare Parts Catalog.pdf
102_2 26B MANUAL TRANSMISSION GEAR Spare Parts Catalog.pdf
103_2 30A GEAR SHIFTER AND QUADRAN Spare Parts Catalog.pdf
104_2 30B GEAR SHIFTER AND QUADRAN Spare Parts Catalog.pdf
105_3 BRAKE SYSTEM FRONT REAR BRA Spare Parts Catalog.pdf
106_3 08B PARKING BRAKE Spare Parts Catalog.pdf
107_3 11B PARKING BRAKE CONTROL Spare Parts Catalog.pdf
108_8 ELECTRICAL PARTS LAMP METER Spare Parts Catalog.pdf
109_8 10A WIRING HARNESS AND FUSE Spare Parts Catalog.pdf
110_8 10B WIRING HARNESS AND FUSE Spare Parts Catalog.pdf
111_8 15A FIXING PARTS WIRING HAR Spare Parts Catalog.pdf
112_8 15B FIXING PARTS WIRING HAR Spare Parts Catalog.pdf
113_8 21A METER ASM Spare Parts Catalog.pdf
114_8 21B METER ASM Spare Parts Catalog.pdf
115_8 25A SWITCH AND RELAY INSTRU Spare Parts Catalog.pdf
116_8 25B SWITCH AND RELAY INSTRU Spare Parts Catalog.pdf
117_8 26A ELECTRICAL CONTROL AND O Spare Parts Catalog.pdf
118_8 26B ELECTRICAL CONTROL AND O Spare Parts Catalog.pdf
