Isuzu Engine 4BD1 1980-1993 Parts Catalog 50320
Model: Isuzu 4BD1 1980-1993 Engine
Part Number: 50320
Publication Date: 1980, 1981, 1982, 1983, 1984, 1985, 1986, 1987, 1988, 1989, 1990, 1991, 1992, 1993
Number of Pages: 686 Pages
001_Section Index 50320 Spare Parts Catalog.pdf
005_0 05C ENGINE GASKET KIT Spare Parts Catalog.pdf
006_0 10A CYLINDER HEAD COVER Spare Parts Catalog.pdf
007_0 10B CYLINDER HEAD COVER Spare Parts Catalog.pdf
008_0 10C CYLINDER HEAD COVER Spare Parts Catalog.pdf
009_0 11A CYLINDER HEAD Spare Parts Catalog.pdf
010_0 11B CYLINDER HEAD Spare Parts Catalog.pdf
011_0 11C CYLINDER HEAD Spare Parts Catalog.pdf
012_0 12A CYLINDER BLOCK Spare Parts Catalog.pdf
013_0 12B CYLINDER BLOCK Spare Parts Catalog.pdf
014_0 12C CYLINDER BLOCK Spare Parts Catalog.pdf
015_0 13A OIL PAN AND LEVEL GAUGE Spare Parts Catalog.pdf
016_0 13B OIL PAN AND LEVEL GAUGE Spare Parts Catalog.pdf
017_0 13C OIL PAN AND LEVEL GAUGE Spare Parts Catalog.pdf
018_0 14A CAMSHAFT AND VALVE Spare Parts Catalog.pdf
019_0 14B CAMSHAFT AND VALVE Spare Parts Catalog.pdf
020_0 14C CAMSHAFT AND VALVE Spare Parts Catalog.pdf
021_0 15A CRANKSHAFT PISTON AND FL Spare Parts Catalog.pdf
022_0 15B CRANKSHAFT PISTON AND FL Spare Parts Catalog.pdf
023_0 15C CRANKSHAFT PISTON AND FL Spare Parts Catalog.pdf
024_0 20A TIMING GEAR CASE AND FLY Spare Parts Catalog.pdf
025_0 20B TIMING GEAR CASE AND FLY Spare Parts Catalog.pdf
026_0 20C TIMING GEAR CASE AND FLY Spare Parts Catalog.pdf
027_0 22A ENGINE MOUNTING Spare Parts Catalog.pdf
028_0 22B ENGINE MOUNTING Spare Parts Catalog.pdf
029_0 22C ENGINE MOUNTING Spare Parts Catalog.pdf
030_0 25A INLET MANIFOLD Spare Parts Catalog.pdf
031_0 25B INLET MANIFOLD Spare Parts Catalog.pdf
032_0 25C INLET MANIFOLD Spare Parts Catalog.pdf
033_0 27A EXHAUST MANIFOLD Spare Parts Catalog.pdf
034_0 27B EXHAUST MANIFOLD Spare Parts Catalog.pdf
035_0 27C EXHAUST MANIFOLD Spare Parts Catalog.pdf
036_0 28A VENTILATION SYSTEM Spare Parts Catalog.pdf
037_0 28B VENTILATION SYSTEM Spare Parts Catalog.pdf
038_0 28C VENTILATION SYSTEM Spare Parts Catalog.pdf
039_0 30A WATER PUMP AND CORROSION Spare Parts Catalog.pdf
040_0 30B WATER PUMP AND CORROSION Spare Parts Catalog.pdf
041_0 30C WATER PUMP AND CORROSION Spare Parts Catalog.pdf
042_0 31A THERMOSTAT AND HOUSING Spare Parts Catalog.pdf
043_0 31B THERMOSTAT AND HOUSING Spare Parts Catalog.pdf
044_0 31C THERMOSTAT AND HOUSING Spare Parts Catalog.pdf
045_0 32A WATER PIPING ENGINE Spare Parts Catalog.pdf
046_0 32B WATER PIPING ENGINE Spare Parts Catalog.pdf
047_0 32C WATER PIPING ENGINE Spare Parts Catalog.pdf
048_0 33A FAN AND FAN BELT Spare Parts Catalog.pdf
049_0 33B FAN AND FAN BELT Spare Parts Catalog.pdf
050_0 33C FAN AND FAN BELT Spare Parts Catalog.pdf
051_0 35A ENGINE CONTROL VALVE AND Spare Parts Catalog.pdf
052_0 35B ENGINE CONTROL VALVE AND Spare Parts Catalog.pdf
053_0 35C ENGINE CONTROL VALVE AND Spare Parts Catalog.pdf
054_0 36A TURBOCHARGER SYSTEM Spare Parts Catalog.pdf
055_0 36C TURBOCHARGER SYSTEM Spare Parts Catalog.pdf
056_0 37A TURBOCHARGER Spare Parts Catalog.pdf
057_0 38C AIR COMPRESSOR PIPING E Spare Parts Catalog.pdf
058_0 39C AIR COMPRESSOR BRAKE Spare Parts Catalog.pdf
059_0 40A FUEL INJECTION SYSTEM Spare Parts Catalog.pdf
060_0 40B FUEL INJECTION SYSTEM Spare Parts Catalog.pdf
061_0 40C FUEL INJECTION SYSTEM Spare Parts Catalog.pdf
062_0 41A FUEL FILTER AND BRACKET Spare Parts Catalog.pdf
063_0 41B FUEL FILTER AND BRACKET Spare Parts Catalog.pdf
064_0 41C FUEL FILTER AND BRACKET Spare Parts Catalog.pdf
065_0 42A FUEL PUMP AND PIPE Spare Parts Catalog.pdf
066_0 42B FUEL PUMP AND PIPE Spare Parts Catalog.pdf
067_0 42C FUEL PUMP AND PIPE Spare Parts Catalog.pdf
068_0 50A OIL COOLER AND OIL FILTE Spare Parts Catalog.pdf
069_0 50B OIL COOLER AND OIL FILTE Spare Parts Catalog.pdf
070_0 50C OIL COOLER AND OIL FILTE Spare Parts Catalog.pdf
071_0 51A OIL PUMP AND OIL STRAINE Spare Parts Catalog.pdf
072_0 51B OIL PUMP AND OIL STRAINE Spare Parts Catalog.pdf
073_0 51C OIL PUMP AND OIL STRAINE Spare Parts Catalog.pdf
074_0 52A OIL AND VACUUM PIPING E Spare Parts Catalog.pdf
075_0 52B OIL AND VACUUM PIPING E Spare Parts Catalog.pdf
076_0 52C OIL AND VACUUM PIPING E Spare Parts Catalog.pdf
077_0 60A ENGINE ELECTRICAL CONTRO Spare Parts Catalog.pdf
078_0 60B ENGINE ELECTRICAL CONTRO Spare Parts Catalog.pdf
079_0 60C ENGINE ELECTRICAL CONTRO Spare Parts Catalog.pdf
080_0 61A BATTERY AND ENGINE ELECT Spare Parts Catalog.pdf
081_0 61B BATTERY AND ENGINE ELECT Spare Parts Catalog.pdf
082_0 61C BATTERY AND ENGINE ELECT Spare Parts Catalog.pdf
083_0 65A STARTER Spare Parts Catalog.pdf
084_0 66A GENERATOR Spare Parts Catalog.pdf
085_0 80A INJECTION PUMP Spare Parts Catalog.pdf
086_0 80B INJECTION PUMP Spare Parts Catalog.pdf
087_0 81A GOVERNOR INJECTION PUMP Spare Parts Catalog.pdf
088_0 81B GOVERNOR INJECTION PUMP Spare Parts Catalog.pdf
089_0 82A BOOST COMPENSATOR INJEC Spare Parts Catalog.pdf
090_0 84A FEED PUMP INJECTION PUM Spare Parts Catalog.pdf
091_0 84B FEED PUMP INJECTION PUM Spare Parts Catalog.pdf
092_0 85A AUTO TIMER INJECTION PU Spare Parts Catalog.pdf
093_0 86A MISCELLANEOUS PARTS INJ Spare Parts Catalog.pdf
094_0 86B MISCELLANEOUS PARTS INJ Spare Parts Catalog.pdf
095_0 86C MISCELLANEOUS PARTS INJ Spare Parts Catalog.pdf
096_0 87A COUPLING INJECTION PUMP Spare Parts Catalog.pdf
097_0 87B COUPLING INJECTION PUMP Spare Parts Catalog.pdf
098_0 87C COUPLING INJECTION PUMP Spare Parts Catalog.pdf
099_0 90B POWER TAKE OFF FLYWHEEL Spare Parts Catalog.pdf
100_0 90C POWER TAKE OFF FLYWHEEL Spare Parts Catalog.pdf
101_1 ACCELERATOR COOLING FUEL AND Spare Parts Catalog.pdf
102_1 01A ACCELERATOR PEDAL AND CO Spare Parts Catalog.pdf
103_1 01B ACCELERATOR PEDAL AND CO Spare Parts Catalog.pdf
104_1 01C ACCELERATOR PEDAL AND CO Spare Parts Catalog.pdf
105_1 10A RADIATOR Spare Parts Catalog.pdf
106_1 10B RADIATOR Spare Parts Catalog.pdf
107_1 10C RADIATOR Spare Parts Catalog.pdf
108_1 11A RADIATOR HOSE AND SUB TA Spare Parts Catalog.pdf
109_1 11B RADIATOR HOSE AND SUB TA Spare Parts Catalog.pdf
110_1 11C RADIATOR HOSE AND SUB TA Spare Parts Catalog.pdf
111_1 30A AIR CLEANER Spare Parts Catalog.pdf
112_1 30B AIR CLEANER Spare Parts Catalog.pdf
113_1 30C AIR CLEANER Spare Parts Catalog.pdf
114_1 31A AIR DUCT Spare Parts Catalog.pdf
115_1 31B AIR DUCT Spare Parts Catalog.pdf
116_1 31C AIR DUCT Spare Parts Catalog.pdf
117_1 40A FUEL TANK Spare Parts Catalog.pdf
118_1 40B FUEL TANK Spare Parts Catalog.pdf
119_1 41A FUEL PIPING CHASSIS Spare Parts Catalog.pdf
120_1 41B FUEL PIPING CHASSIS Spare Parts Catalog.pdf
121_1 45A WATER SEDIMENTER FUEL Spare Parts Catalog.pdf
122_1 45B WATER SEDIMENTER FUEL Spare Parts Catalog.pdf
123_1 45C WATER SEDIMENTER FUEL Spare Parts Catalog.pdf
124_1 50A EXHAUST PIPE AND SILENCE Spare Parts Catalog.pdf
125_1 50B EXHAUST PIPE AND SILENCE Spare Parts Catalog.pdf
126_1 50C EXHAUST PIPE AND SILENCE Spare Parts Catalog.pdf
127_2 CLUTCH AND TRANSMISSION AXLE Spare Parts Catalog.pdf
128_2 01A CLUTCH Spare Parts Catalog.pdf
129_2 01B CLUTCH Spare Parts Catalog.pdf
130_2 01C CLUTCH Spare Parts Catalog.pdf
131_2 05A CLUTCH PIPING Spare Parts Catalog.pdf
132_2 06A CLUTCH SLAVE CYLINDER Spare Parts Catalog.pdf
133_2 08A CLUTCH MASTER CYLINDER Spare Parts Catalog.pdf
134_2 20A MANUAL TRANSMISSION ASM Spare Parts Catalog.pdf
135_2 25A SPEEDOMETER DRIVEN GEAR Spare Parts Catalog.pdf
136_2 25B SPEEDOMETER DRIVEN GEAR Spare Parts Catalog.pdf
137_2 25C SPEEDOMETER DRIVEN GEAR Spare Parts Catalog.pdf
138_2 26A MANUAL TRANSMISSION GEAR Spare Parts Catalog.pdf
139_2 30A GEAR SHIFTER AND QUADRAN Spare Parts Catalog.pdf
140_2 35A MANUAL TRANSMISSION SHIF Spare Parts Catalog.pdf
141_2 37A MANUAL TRANSMISSION CONT Spare Parts Catalog.pdf
142_2 40B AUTO TRANS ASM AND REPAI Spare Parts Catalog.pdf
143_2 41B AUTO TRANS CASE CONVERTE Spare Parts Catalog.pdf
144_2 41C AUTO TRANS CASE CONVERTE Spare Parts Catalog.pdf
145_2 42B AUTO TRANS OIL PAN AND O Spare Parts Catalog.pdf
146_2 42C AUTO TRANS OIL PAN AND O Spare Parts Catalog.pdf
147_2 49B AUTO TRANS INHIBITOR SWI Spare Parts Catalog.pdf
148_2 49C AUTO TRANS INHIBITOR SWI Spare Parts Catalog.pdf
149_3 BRAKE SYSTEM FRONT REAR BRA Spare Parts Catalog.pdf
150_3 01A FRONT WHEEL BRAKE Spare Parts Catalog.pdf
151_3 08B PARKING BRAKE Spare Parts Catalog.pdf
152_3 08C PARKING BRAKE Spare Parts Catalog.pdf
153_3 11B PARKING BRAKE CONTROL Spare Parts Catalog.pdf
154_3 11C PARKING BRAKE CONTROL Spare Parts Catalog.pdf
155_4 STEERING PROPELLER SHAFT AXLE Spare Parts Catalog.pdf
156_4 10A FRONT AXLE Spare Parts Catalog.pdf
157_4 11A FRONT HUB AND DRUM OR RO Spare Parts Catalog.pdf
158_4 33A STEERING LINKAGE Spare Parts Catalog.pdf
159_5 FRAME CAB MOUNTING AND BATTER Spare Parts Catalog.pdf
160_5 20B BATTERY CARRIER Spare Parts Catalog.pdf
161_6 BODY PARTS PANEL TRIM GLAS Spare Parts Catalog.pdf
162_6 98A POWER UNIT BODY Spare Parts Catalog.pdf
163_6 98B POWER UNIT BODY Spare Parts Catalog.pdf
164_7 BODY PARTS ORNAMENT MIRROR Spare Parts Catalog.pdf
165_7 01A EMBLEM AND NAME PLATE Spare Parts Catalog.pdf
166_7 01B EMBLEM AND NAME PLATE Spare Parts Catalog.pdf
167_8 ELECTRICAL PARTS LAMP METER Spare Parts Catalog.pdf
168_8 10A WIRING HARNESS AND FUSE Spare Parts Catalog.pdf
169_8 10B WIRING HARNESS AND FUSE Spare Parts Catalog.pdf
170_8 10C WIRING HARNESS AND FUSE Spare Parts Catalog.pdf
171_8 15B FIXING PARTS WIRING HAR Spare Parts Catalog.pdf
172_8 15C FIXING PARTS WIRING HAR Spare Parts Catalog.pdf
173_8 20A METER CABLE Spare Parts Catalog.pdf
174_8 20B METER CABLE Spare Parts Catalog.pdf
175_8 21A METER ASM Spare Parts Catalog.pdf
176_8 21B METER ASM Spare Parts Catalog.pdf
177_8 21C METER ASM Spare Parts Catalog.pdf
178_8 25A SWITCH AND RELAY INSTRU Spare Parts Catalog.pdf
179_8 25B SWITCH AND RELAY INSTRU Spare Parts Catalog.pdf
180_8 25C SWITCH AND RELAY INSTRU Spare Parts Catalog.pdf
181_8 26A ELECTRICAL CONTROL AND O Spare Parts Catalog.pdf
182_8 26B ELECTRICAL CONTROL AND O Spare Parts Catalog.pdf
183_8 26C ELECTRICAL CONTROL AND O Spare Parts Catalog.pdf
184_8 28B CHASSIS ELECTRICAL Spare Parts Catalog.pdf
Part Number: 50320
