Isuzu Engine 3KA1 3KB1 3KC1 1985-1992 Parts Catalog 50330
Model: Isuzu 3KA1 3KB1 3KC1 1985-1992 Engine
Part Number: 50330
Publication Date: 1985, 1986, 1987, 1988, 1989, 1990, 1991, 1992
Number of Pages: 464 Pages
001_Section Index 50330 Spare Parts Catalog.pdf
005_0 05C ENGINE GASKET KIT Spare Parts Catalog.pdf
006_0 05D ENGINE GASKET KIT Spare Parts Catalog.pdf
007_0 10A CYLINDER HEAD COVER Spare Parts Catalog.pdf
008_0 10B CYLINDER HEAD COVER Spare Parts Catalog.pdf
009_0 10C CYLINDER HEAD COVER Spare Parts Catalog.pdf
010_0 10D CYLINDER HEAD COVER Spare Parts Catalog.pdf
011_0 11A CYLINDER HEAD Spare Parts Catalog.pdf
012_0 11B CYLINDER HEAD Spare Parts Catalog.pdf
013_0 11C CYLINDER HEAD Spare Parts Catalog.pdf
014_0 11D CYLINDER HEAD Spare Parts Catalog.pdf
015_0 12A CYLINDER BLOCK Spare Parts Catalog.pdf
016_0 12B CYLINDER BLOCK Spare Parts Catalog.pdf
017_0 12C CYLINDER BLOCK Spare Parts Catalog.pdf
018_0 12D CYLINDER BLOCK Spare Parts Catalog.pdf
019_0 13A OIL PAN AND LEVEL GAUGE Spare Parts Catalog.pdf
020_0 13B OIL PAN AND LEVEL GAUGE Spare Parts Catalog.pdf
021_0 13C OIL PAN AND LEVEL GAUGE Spare Parts Catalog.pdf
022_0 13D OIL PAN AND LEVEL GAUGE Spare Parts Catalog.pdf
023_0 14A CAMSHAFT AND VALVE Spare Parts Catalog.pdf
024_0 14B CAMSHAFT AND VALVE Spare Parts Catalog.pdf
025_0 14C CAMSHAFT AND VALVE Spare Parts Catalog.pdf
026_0 14D CAMSHAFT AND VALVE Spare Parts Catalog.pdf
027_0 15A CRANKSHAFT PISTON AND FL Spare Parts Catalog.pdf
028_0 15B CRANKSHAFT PISTON AND FL Spare Parts Catalog.pdf
029_0 15C CRANKSHAFT PISTON AND FL Spare Parts Catalog.pdf
030_0 15D CRANKSHAFT PISTON AND FL Spare Parts Catalog.pdf
031_0 20A TIMING GEAR CASE AND FLY Spare Parts Catalog.pdf
032_0 20B TIMING GEAR CASE AND FLY Spare Parts Catalog.pdf
033_0 20C TIMING GEAR CASE AND FLY Spare Parts Catalog.pdf
034_0 20D TIMING GEAR CASE AND FLY Spare Parts Catalog.pdf
035_0 22A ENGINE MOUNTING Spare Parts Catalog.pdf
036_0 22B ENGINE MOUNTING Spare Parts Catalog.pdf
037_0 22C ENGINE MOUNTING Spare Parts Catalog.pdf
038_0 22D ENGINE MOUNTING Spare Parts Catalog.pdf
039_0 25A INLET MANIFOLD Spare Parts Catalog.pdf
040_0 25B INLET MANIFOLD Spare Parts Catalog.pdf
041_0 25C INLET MANIFOLD Spare Parts Catalog.pdf
042_0 25D INLET MANIFOLD Spare Parts Catalog.pdf
043_0 27A EXHAUST MANIFOLD Spare Parts Catalog.pdf
044_0 27B EXHAUST MANIFOLD Spare Parts Catalog.pdf
045_0 27C EXHAUST MANIFOLD Spare Parts Catalog.pdf
046_0 27D EXHAUST MANIFOLD Spare Parts Catalog.pdf
047_0 28A VENTILATION SYSTEM Spare Parts Catalog.pdf
048_0 28B VENTILATION SYSTEM Spare Parts Catalog.pdf
049_0 28C VENTILATION SYSTEM Spare Parts Catalog.pdf
050_0 28D VENTILATION SYSTEM Spare Parts Catalog.pdf
051_0 30A WATER PUMP AND CORROSION Spare Parts Catalog.pdf
052_0 30B WATER PUMP AND CORROSION Spare Parts Catalog.pdf
053_0 30C WATER PUMP AND CORROSION Spare Parts Catalog.pdf
054_0 30D WATER PUMP AND CORROSION Spare Parts Catalog.pdf
055_0 31A THERMOSTAT AND HOUSING Spare Parts Catalog.pdf
056_0 31B THERMOSTAT AND HOUSING Spare Parts Catalog.pdf
057_0 31C THERMOSTAT AND HOUSING Spare Parts Catalog.pdf
058_0 31D THERMOSTAT AND HOUSING Spare Parts Catalog.pdf
059_0 32A WATER PIPING ENGINE Spare Parts Catalog.pdf
060_0 32B WATER PIPING ENGINE Spare Parts Catalog.pdf
061_0 32C WATER PIPING ENGINE Spare Parts Catalog.pdf
062_0 32D WATER PIPING ENGINE Spare Parts Catalog.pdf
063_0 33A FAN AND FAN BELT Spare Parts Catalog.pdf
064_0 33B FAN AND FAN BELT Spare Parts Catalog.pdf
065_0 33C FAN AND FAN BELT Spare Parts Catalog.pdf
066_0 33D FAN AND FAN BELT Spare Parts Catalog.pdf
067_0 40A FUEL INJECTION SYSTEM Spare Parts Catalog.pdf
068_0 40B FUEL INJECTION SYSTEM Spare Parts Catalog.pdf
069_0 40C FUEL INJECTION SYSTEM Spare Parts Catalog.pdf
070_0 40D FUEL INJECTION SYSTEM Spare Parts Catalog.pdf
071_0 41A FUEL FILTER AND BRACKET Spare Parts Catalog.pdf
072_0 41B FUEL FILTER AND BRACKET Spare Parts Catalog.pdf
073_0 41C FUEL FILTER AND BRACKET Spare Parts Catalog.pdf
074_0 41D FUEL FILTER AND BRACKET Spare Parts Catalog.pdf
075_0 42A FUEL PUMP AND PIPE Spare Parts Catalog.pdf
076_0 42B FUEL PUMP AND PIPE Spare Parts Catalog.pdf
077_0 42C FUEL PUMP AND PIPE Spare Parts Catalog.pdf
078_0 42D FUEL PUMP AND PIPE Spare Parts Catalog.pdf
079_0 50A OIL COOLER AND OIL FILTE Spare Parts Catalog.pdf
080_0 50B OIL COOLER AND OIL FILTE Spare Parts Catalog.pdf
081_0 50C OIL COOLER AND OIL FILTE Spare Parts Catalog.pdf
082_0 50D OIL COOLER AND OIL FILTE Spare Parts Catalog.pdf
083_0 51A OIL PUMP AND OIL STRAINE Spare Parts Catalog.pdf
084_0 51B OIL PUMP AND OIL STRAINE Spare Parts Catalog.pdf
085_0 51C OIL PUMP AND OIL STRAINE Spare Parts Catalog.pdf
086_0 51D OIL PUMP AND OIL STRAINE Spare Parts Catalog.pdf
087_0 60A ENGINE ELECTRICAL CONTRO Spare Parts Catalog.pdf
088_0 60B ENGINE ELECTRICAL CONTRO Spare Parts Catalog.pdf
089_0 60C ENGINE ELECTRICAL CONTRO Spare Parts Catalog.pdf
090_0 60D ENGINE ELECTRICAL CONTRO Spare Parts Catalog.pdf
091_0 61A BATTERY AND ENGINE ELECT Spare Parts Catalog.pdf
092_0 61B BATTERY AND ENGINE ELECT Spare Parts Catalog.pdf
093_0 61D BATTERY AND ENGINE ELECT Spare Parts Catalog.pdf
094_0 65A STARTER Spare Parts Catalog.pdf
095_0 66A GENERATOR Spare Parts Catalog.pdf
096_0 80A INJECTION PUMP Spare Parts Catalog.pdf
097_0 86A MISCELLANEOUS PARTS INJ Spare Parts Catalog.pdf
098_0 86B MISCELLANEOUS PARTS INJ Spare Parts Catalog.pdf
099_0 86C MISCELLANEOUS PARTS INJ Spare Parts Catalog.pdf
100_0 86D MISCELLANEOUS PARTS INJ Spare Parts Catalog.pdf
101_0 89A TIMING CHAIN CASE Spare Parts Catalog.pdf
102_0 89B TIMING CHAIN CASE Spare Parts Catalog.pdf
103_0 89C TIMING CHAIN CASE Spare Parts Catalog.pdf
104_0 89D TIMING CHAIN CASE Spare Parts Catalog.pdf
105_1 ACCELERATOR COOLING FUEL AND Spare Parts Catalog.pdf
106_1 01A ACCELERATOR PEDAL AND CO Spare Parts Catalog.pdf
107_1 01B ACCELERATOR PEDAL AND CO Spare Parts Catalog.pdf
108_1 01C ACCELERATOR PEDAL AND CO Spare Parts Catalog.pdf
109_1 01D ACCELERATOR PEDAL AND CO Spare Parts Catalog.pdf
110_1 10A RADIATOR Spare Parts Catalog.pdf
111_1 10B RADIATOR Spare Parts Catalog.pdf
112_1 10C RADIATOR Spare Parts Catalog.pdf
113_1 10D RADIATOR Spare Parts Catalog.pdf
114_1 11A RADIATOR HOSE AND SUB TA Spare Parts Catalog.pdf
115_1 11B RADIATOR HOSE AND SUB TA Spare Parts Catalog.pdf
116_1 11C RADIATOR HOSE AND SUB TA Spare Parts Catalog.pdf
117_1 11D RADIATOR HOSE AND SUB TA Spare Parts Catalog.pdf
118_1 30A AIR CLEANER Spare Parts Catalog.pdf
119_1 30B AIR CLEANER Spare Parts Catalog.pdf
120_1 30C AIR CLEANER Spare Parts Catalog.pdf
121_1 30D AIR CLEANER Spare Parts Catalog.pdf
122_1 31A AIR DUCT Spare Parts Catalog.pdf
123_1 31B AIR DUCT Spare Parts Catalog.pdf
124_1 31C AIR DUCT Spare Parts Catalog.pdf
125_1 31D AIR DUCT Spare Parts Catalog.pdf
126_1 40A FUEL TANK Spare Parts Catalog.pdf
127_1 40B FUEL TANK Spare Parts Catalog.pdf
128_1 40C FUEL TANK Spare Parts Catalog.pdf
129_1 40D FUEL TANK Spare Parts Catalog.pdf
130_1 45A WATER SEDIMENTER FUEL Spare Parts Catalog.pdf
131_1 45B WATER SEDIMENTER FUEL Spare Parts Catalog.pdf
132_1 45C WATER SEDIMENTER FUEL Spare Parts Catalog.pdf
133_1 45D WATER SEDIMENTER FUEL Spare Parts Catalog.pdf
134_1 50A EXHAUST PIPE AND SILENCE Spare Parts Catalog.pdf
135_1 50B EXHAUST PIPE AND SILENCE Spare Parts Catalog.pdf
136_1 50C EXHAUST PIPE AND SILENCE Spare Parts Catalog.pdf
137_1 50D EXHAUST PIPE AND SILENCE Spare Parts Catalog.pdf
138_2 CLUTCH AND TRANSMISSION AXLE Spare Parts Catalog.pdf
139_2 01A CLUTCH Spare Parts Catalog.pdf
140_2 01B CLUTCH Spare Parts Catalog.pdf
141_2 01C CLUTCH Spare Parts Catalog.pdf
142_2 01D CLUTCH Spare Parts Catalog.pdf
143_2 20C MANUAL TRANSMISSION ASM Spare Parts Catalog.pdf
144_2 25C SPEEDOMETER DRIVEN GEAR Spare Parts Catalog.pdf
145_2 26C MANUAL TRANSMISSION GEAR Spare Parts Catalog.pdf
146_2 30C GEAR SHIFTER AND QUADRAN Spare Parts Catalog.pdf
147_5 FRAME CAB MOUNTING AND BATTER Spare Parts Catalog.pdf
148_5 20B BATTERY CARRIER Spare Parts Catalog.pdf
149_8 ELECTRICAL PARTS LAMP METER Spare Parts Catalog.pdf
150_8 10A WIRING HARNESS AND FUSE Spare Parts Catalog.pdf
151_8 10B WIRING HARNESS AND FUSE Spare Parts Catalog.pdf
152_8 10C WIRING HARNESS AND FUSE Spare Parts Catalog.pdf
153_8 10D WIRING HARNESS AND FUSE Spare Parts Catalog.pdf
154_8 21A METER ASM Spare Parts Catalog.pdf
155_8 21B METER ASM Spare Parts Catalog.pdf
156_8 21C METER ASM Spare Parts Catalog.pdf
157_8 21D METER ASM Spare Parts Catalog.pdf
158_8 25A SWITCH AND RELAY INSTRU Spare Parts Catalog.pdf
159_8 25B SWITCH AND RELAY INSTRU Spare Parts Catalog.pdf
160_8 25C SWITCH AND RELAY INSTRU Spare Parts Catalog.pdf
161_8 25D SWITCH AND RELAY INSTRU Spare Parts Catalog.pdf
162_8 26A ELECTRICAL CONTROL AND O Spare Parts Catalog.pdf
163_8 26B ELECTRICAL CONTROL AND O Spare Parts Catalog.pdf
164_8 26C ELECTRICAL CONTROL AND O Spare Parts Catalog.pdf
