Isuzu Engine 2KA1 2KB1 2KC1 1983-1993 Parts Catalog 51056
Model: Isuzu 2KA1 2KB1 2KC1 1983-1993 Engine
Part Number: 51056
Publication Date: 1983, 1984, 1985, 1986, 1987, 1988, 1989, 1990, 1991, 1992, 1993
Number of Pages: 227 Pages
001_Section Index 51056 Spare Parts Catalog.pdf
005_0 10A CYLINDER HEAD COVER Spare Parts Catalog.pdf
006_0 10B CYLINDER HEAD COVER Spare Parts Catalog.pdf
007_0 11A CYLINDER HEAD Spare Parts Catalog.pdf
008_0 11B CYLINDER HEAD Spare Parts Catalog.pdf
009_0 12A CYLINDER BLOCK Spare Parts Catalog.pdf
010_0 12B CYLINDER BLOCK Spare Parts Catalog.pdf
011_0 13A OIL PAN AND LEVEL GAUGE Spare Parts Catalog.pdf
012_0 13B OIL PAN AND LEVEL GAUGE Spare Parts Catalog.pdf
013_0 14A CAMSHAFT AND VALVE Spare Parts Catalog.pdf
014_0 14B CAMSHAFT AND VALVE Spare Parts Catalog.pdf
015_0 15A CRANKSHAFT PISTON AND FL Spare Parts Catalog.pdf
016_0 15B CRANKSHAFT PISTON AND FL Spare Parts Catalog.pdf
017_0 20A TIMING GEAR CASE AND FLY Spare Parts Catalog.pdf
018_0 20B TIMING GEAR CASE AND FLY Spare Parts Catalog.pdf
019_0 22A ENGINE MOUNTING Spare Parts Catalog.pdf
020_0 22B ENGINE MOUNTING Spare Parts Catalog.pdf
021_0 25A INLET MANIFOLD Spare Parts Catalog.pdf
022_0 25B INLET MANIFOLD Spare Parts Catalog.pdf
023_0 27A EXHAUST MANIFOLD Spare Parts Catalog.pdf
024_0 27B EXHAUST MANIFOLD Spare Parts Catalog.pdf
025_0 30A WATER PUMP AND CORROSION Spare Parts Catalog.pdf
026_0 30B WATER PUMP AND CORROSION Spare Parts Catalog.pdf
027_0 31A THERMOSTAT AND HOUSING Spare Parts Catalog.pdf
028_0 31B THERMOSTAT AND HOUSING Spare Parts Catalog.pdf
029_0 32A WATER PIPING ENGINE Spare Parts Catalog.pdf
030_0 32B WATER PIPING ENGINE Spare Parts Catalog.pdf
031_0 33A FAN AND FAN BELT Spare Parts Catalog.pdf
032_0 33B FAN AND FAN BELT Spare Parts Catalog.pdf
033_0 40A FUEL INJECTION SYSTEM Spare Parts Catalog.pdf
034_0 40B FUEL INJECTION SYSTEM Spare Parts Catalog.pdf
035_0 41A FUEL FILTER AND BRACKET Spare Parts Catalog.pdf
036_0 41B FUEL FILTER AND BRACKET Spare Parts Catalog.pdf
037_0 42A FUEL PUMP AND PIPE Spare Parts Catalog.pdf
038_0 42B FUEL PUMP AND PIPE Spare Parts Catalog.pdf
039_0 50A OIL COOLER AND OIL FILTE Spare Parts Catalog.pdf
040_0 50B OIL COOLER AND OIL FILTE Spare Parts Catalog.pdf
041_0 51A OIL PUMP AND OIL STRAINE Spare Parts Catalog.pdf
042_0 51B OIL PUMP AND OIL STRAINE Spare Parts Catalog.pdf
043_0 60A ENGINE ELECTRICAL CONTRO Spare Parts Catalog.pdf
044_0 60B ENGINE ELECTRICAL CONTRO Spare Parts Catalog.pdf
045_0 65A STARTER Spare Parts Catalog.pdf
046_0 66A GENERATOR Spare Parts Catalog.pdf
047_0 80A INJECTION PUMP Spare Parts Catalog.pdf
048_0 86A MISCELLANEOUS PARTS INJ Spare Parts Catalog.pdf
049_0 86B MISCELLANEOUS PARTS INJ Spare Parts Catalog.pdf
050_0 89A TIMING CHAIN CASE Spare Parts Catalog.pdf
051_0 89B TIMING CHAIN CASE Spare Parts Catalog.pdf
052_1 ACCELERATOR COOLING FUEL AND Spare Parts Catalog.pdf
053_1 01A ACCELERATOR PEDAL AND CO Spare Parts Catalog.pdf
054_1 01B ACCELERATOR PEDAL AND CO Spare Parts Catalog.pdf
055_1 10A RADIATOR Spare Parts Catalog.pdf
056_1 10B RADIATOR Spare Parts Catalog.pdf
057_1 11A RADIATOR HOSE AND SUB TA Spare Parts Catalog.pdf
058_1 11B RADIATOR HOSE AND SUB TA Spare Parts Catalog.pdf
059_1 30A AIR CLEANER Spare Parts Catalog.pdf
060_1 30B AIR CLEANER Spare Parts Catalog.pdf
061_1 31A AIR DUCT Spare Parts Catalog.pdf
062_1 31B AIR DUCT Spare Parts Catalog.pdf
063_1 40A FUEL TANK Spare Parts Catalog.pdf
064_1 40B FUEL TANK Spare Parts Catalog.pdf
065_1 50A EXHAUST PIPE AND SILENCE Spare Parts Catalog.pdf
066_1 50B EXHAUST PIPE AND SILENCE Spare Parts Catalog.pdf
067_2 CLUTCH AND TRANSMISSION AXLE Spare Parts Catalog.pdf
068_2 01A CLUTCH Spare Parts Catalog.pdf
069_2 01B CLUTCH Spare Parts Catalog.pdf
070_5 FRAME CAB MOUNTING AND BATTER Spare Parts Catalog.pdf
071_5 20B BATTERY CARRIER Spare Parts Catalog.pdf
072_7 BODY PARTS ORNAMENT MIRROR Spare Parts Catalog.pdf
073_7 01A EMBLEM AND NAME PLATE Spare Parts Catalog.pdf
074_7 01B EMBLEM AND NAME PLATE Spare Parts Catalog.pdf
075_8 ELECTRICAL PARTS LAMP METER Spare Parts Catalog.pdf
076_8 10A WIRING HARNESS AND FUSE Spare Parts Catalog.pdf
077_8 10B WIRING HARNESS AND FUSE Spare Parts Catalog.pdf
078_8 21A METER ASM Spare Parts Catalog.pdf
079_8 21B METER ASM Spare Parts Catalog.pdf
080_8 25A SWITCH AND RELAY INSTRU Spare Parts Catalog.pdf
081_8 25B SWITCH AND RELAY INSTRU Spare Parts Catalog.pdf
082_8 26B ELECTRICAL CONTROL AND O Spare Parts Catalog.pdf
Part Number: 51056
