Isuzu D-Max TFS EV Series 2026 Mechanical Repair Procedures TFHTML-WEN-2651EV
Type of Machine: Automotive-Pickup
Type of Manual: Workshop Manual - Mechanical Repair Procedures
Model: Isuzu D-Max TFS EV Series 20 Cab model Pickup
Date: 2026
Except Australia, Thailand (Date:2026/01/08)
Parts Number: TFHTML-WEN-2651EV
Number of Pages: 3320 Pages
2. Suspension
2B. Front Suspension​
Independent suspension - disassembly​
Independent suspension - inspection​
Independent suspension - installation​
Independent suspension - reassembly​
Independent suspension - removal​
Supplementary Information​
2C. Rear Suspension​
Leaf rigid suspension - disassembly​
Leaf rigid suspension - inspection​
Leaf rigid suspension - installation​
Leaf rigid suspension - reassembly​
Leaf rigid suspension - removal​
2D. Wheel, Tire System​
Barometric pressure sensor - inspection​
Barometric pressure sensor - installation​
Barometric pressure sensor - removal​
Disc wheel and tire - inspection​
Disc wheel and tire - installation​
Disc wheel and tire - removal​
Tire air pressure sensor - installation​
Tire air pressure sensor - removal​
Tire air pressure sensor - setting​
3. Driveline, Axle
3C. Drive Shaft System​
Front drive shaft - disassembly​
Front drive shaft - inspection​
Front drive shaft - installation​
Front drive shaft - reassembly​
Front drive shaft - removal​
Front hub - disassembly​
Front hub - inspection​
Front hub - installation​
Front hub - reassembly​
Front hub - removal​
Knuckle - inspection​
Knuckle - installation​
Knuckle - removal​
Rear axle - inspection​
Rear axle - installation​
Rear axle - removal​
Rear drive shaft - disassembly​
Rear drive shaft - inspection​
Rear drive shaft - installation​
Rear drive shaft - reassembly​
Rear drive shaft - removal​
Rear hub - installation​
Rear hub - removal​
Wheel alignment check​
4. Brakes
4B. Brake System​
Brake booster - inspection​
Brake booster - installation​
Brake booster - removal​
Brake fluid - inspection​
Brake fluid - replacement​
Brake master cylinder - disassembly​
Brake master cylinder - inspection​
Brake master cylinder - installation​
Brake master cylinder - reassembly​
Brake master cylinder - removal​
Brake pedal - inspection​
Brake pedal - installation​
Brake pedal - removal​
Disc brake pad - inspection​
Disc brake pad - installation​
Disc brake pad - removal​
Electric vacuum pump - inspection​
Electric vacuum pump - installation​
Electric vacuum pump - removal​
Front disc brake - disassembly​
Front disc brake - inspection​
Front disc brake - installation​
Front disc brake - reassembly​
Front disc brake - removal​
Rear drum brake - inspection​
Rear drum brake - installation​
Rear drum brake - removal​
Rear wheel cylinder - disassembly​
Rear wheel cylinder - inspection​
Rear wheel cylinder - installation​
Rear wheel cylinder - reassembly​
Rear wheel cylinder - removal​
Silencer - inspection​
Silencer - installation​
Silencer - removal​
Stoplight switch - inspection​
Stoplight switch - installation​
Stoplight switch - removal​
Vacuum tank - inspection​
Vacuum tank - installation​
Vacuum tank - removal​
4C. Parking Brake System​
Parking brake - inspection​
Parking brake - installation​
Parking brake - removal​
Parking brake lever - installation​
Parking brake lever - removal​
Parking brake switch - inspection​
Parking brake switch - installation​
Parking brake switch - removal​
4D. ABS​
Front exciter ring - installation​
Front exciter ring - removal​
4Z. Brake Electrical Control​
EHCU - installation​
EHCU - removal​
EHCU - setting​
Front wheel speed sensor - inspection​
Front wheel speed sensor - installation​
Front wheel speed sensor - removal​
Rear wheel speed sensor - inspection​
Rear wheel speed sensor - installation​
Rear wheel speed sensor - removal​
6. Steering
6B. Power Assisted System​
Power steering unit - disassembly​
Power steering unit - inspection​
Power steering unit - installation​
Power steering unit - reassembly​
Power steering unit - removal​
Power steering unit - setting​
Steering column - inspection​
Steering column - installation​
Steering column - removal​
6Z. Steering Electrical Control​
Steering angle sensor - installation​
Steering angle sensor - removal​
Steering angle sensor - setting​
7. HVAC
7B. Heater Ventilator Airconditioner​
Accumulator - installation​
Accumulator - removal​
Actuator - installation​
Actuator - removal​
Blower - installation​
Blower - removal​
Blower module - inspection​
Blower module - installation​
Blower module - removal​
Blower motor - inspection​
Blower motor - installation​
Blower motor - removal​
Compressor oil - replacement​
Condenser - installation​
Condenser - removal​
Control panel - inspection​
Control panel - installation​
Control panel - removal​
Control panel - setting​
Coolant for cabin heater - inspection​
Coolant for cabin heater - replacement​
Coolant level sensor (for air conditioning) - inspection​
Coolant level sensor (for air conditioning) - installation​
Coolant level sensor (for air conditioning) - removal​
Electric compressor - installation​
Electric compressor - removal​
Evaporator core - installation​
Evaporator core - removal​
Heater core - installation​
Heater core - removal​
Heater evaporator unit - installation​
Heater evaporator unit - removal​
High voltage heater (for air conditioning) - inspection​
High voltage heater (for air conditioning) - installation​
High voltage heater (for air conditioning) - removal​
Intake door - installation​
Intake door - removal​
Rear ventilation duct - installation​
Rear ventilation duct - removal​
Sub tank (for air conditioning) - installation​
Sub tank (for air conditioning) - removal​
Vent grille - installation​
Vent grille - removal​
Ventilation duct - installation​
Ventilation duct - removal​
Water pump (for air conditioning) - installation​
Water pump (for air conditioning) - removal​
Water-cooled condenser - installation​
Water-cooled condenser - removal​
7Z. HVAC Control​
A_C control unit - installation​
A_C control unit - removal​
A_C control unit - setting​
Battery expansion valve - inspection​
Battery expansion valve - installation​
Battery expansion valve - removal​
Cooling expansion valve - inspection​
Cooling expansion valve - installation​
Cooling expansion valve - removal​
Evaporator temperature sensor - inspection​
Evaporator temperature sensor - installation​
Evaporator temperature sensor - removal​
Heating expansion valve - inspection​
Heating expansion valve - installation​
Heating expansion valve - removal​
Inside air temperature sensor - inspection​
Inside air temperature sensor - installation​
Inside air temperature sensor - removal​
Low pressure solenoid valve - inspection​
Low pressure solenoid valve - installation​
Low pressure solenoid valve - removal​
Outside air temperature sensor - inspection​
Outside air temperature sensor - installation​
Outside air temperature sensor - removal​
Pressure sensor - inspection​
Pressure sensor - installation​
Pressure sensor - removal​
Refrigerant temperature sensor (outside cab) - inspection​
Refrigerant temperature sensor (outside cab) - installation​
Refrigerant temperature sensor (outside cab) - removal​
Sun sensor - inspection​
Sun sensor - installation​
Sun sensor - removal​
Thermal management control unit - installation​
Thermal management control unit - removal​
8. Restraints
8B. Airbag Systems​
Curtain airbag - installation​
Curtain airbag - removal​
Curtain airbag - scrapping​
Driver airbag - installation​
Driver airbag - removal​
Driver airbag - scrapping​
Far side air bag - installation​
Far side air bag - removal​
Far side air bag - scrapping​
Knee air bag - installation​
Knee air bag - removal​
Knee air bag - scrapping​
Passenger airbag - installation​
Passenger airbag - removal​
Passenger airbag - scrapping​
Side airbag - installation​
Side airbag - removal​
Side airbag - scrapping​
SRS coil - installation​
SRS coil - removal​
8C. Seat Belt Systems​
Front buckle side seat belt - installation​
Front buckle side seat belt - removal​
Front tongue side seat belt (with pretensioner) (crew cab) - installation​
Front tongue side seat belt (with pretensioner) (crew cab) - removal​
Front tongue side seat belt (with pretensioner) (crew cab) - scrapping​
Front tongue side seat belt (with pretensioner) (extend cab) - installation​
Front tongue side seat belt (with pretensioner) (extend cab) - removal​
Front tongue side seat belt (with pretensioner) (extend cab) - scrapping​
Rear buckle side seat belt - installation​
Rear buckle side seat belt - removal​
Rear tongue side seat belt (with pretensioner) - installation​
Rear tongue side seat belt (with pretensioner) - removal​
Rear tongue side seat belt (with pretensioner) - scrapping​
Rear tongue side seat belt - installation​
Rear tongue side seat belt - removal​
8Z. Seat Belt and SRS Airbag Electrical Control​
Door side airbag sensor - installation​
Door side airbag sensor - removal​
Floor side airbag sensor - installation​
Floor side airbag sensor - removal​
Front airbag sensor - installation​
Front airbag sensor - removal​
Rear side airbag sensor (crew cab) - installation​
Rear side airbag sensor (crew cab) - removal​
Rear side airbag sensor (extend cab) - installation​
Rear side airbag sensor (extend cab) - removal​
SRS control unit - installation​
SRS control unit - removal​
SRS control unit - setting​
9 .Body, Cab, Accessories
9A. Lighting Systems​
Backup light bulb - installation​
Backup light bulb - removal​
Combination switch - inspection​
Combination switch - installation​
Combination switch - removal​
Dome light bulb - installation​
Dome light bulb - removal​
Door switch - inspection​
Door switch - installation​
Door switch - removal​
Fog light - installation​
Fog light - removal​
Front turn signal light bulb - installation​
Front turn signal light bulb - removal​
Hazard warning flasher switch - inspection​
Hazard warning flasher switch - installation​
Hazard warning flasher switch - removal​
Headlight - inspection​
Headlight - installation​
Headlight - removal​
Headlight leveling switch - inspection​
Headlight leveling switch - installation​
Headlight leveling switch - removal​
High mounted stoplight - installation​
High mounted stoplight - removal​
License plate light bulb - installation​
License plate light bulb - removal​
Map light bulb - installation​
Map light bulb - removal​
Rear combination light - installation​
Rear combination light - removal​
Rear turn signal light bulb - installation​
Rear turn signal light bulb - removal​
Side turn signal light (door mirror integrated type) - installation​
Side turn signal light (door mirror integrated type) - removal​
9B. Wiper, Washer Systems​
Washer motor - inspection​
Washer motor - installation​
Washer motor - removal​
Washer nozzle - installation​
Washer nozzle - removal​
Washer tank - installation​
Washer tank - removal​
Wiper arm - installation​
Wiper arm - removal​
Wiper blade rubber - installation​
Wiper blade rubber - removal​
Wiper linkage - installation​
Wiper linkage - removal​
Wiper motor - inspection​
Wiper motor - installation​
Wiper motor - removal​
9C. Electrical Control, Entertainment​
Accessory socket - installation​
Accessory socket - removal​
Antenna - installation​
Antenna - removal​
Audio and navigation system - installation​
Audio and navigation system - removal​
Audio and navigation system - setting​
Audio control steering wheel switch - inspection​
Audio control steering wheel switch - installation​
Audio control steering wheel switch - removal​
Cruise control steering wheel switch - inspection​
Cruise control steering wheel switch - installation​
Cruise control steering wheel switch - removal​
ECO switch - inspection​
ECO switch - installation​
ECO switch - removal​
ESC OFF switch - inspection​
ESC OFF switch - installation​
ESC OFF switch - removal​
EV system start_stop button - inspection​
EV system start_stop button - installation​
EV system start_stop button - removal​
Front door speaker - inspection​
Front door speaker - installation​
Front door speaker - removal​
Front seat USB port - installation​
Front seat USB port - removal​
Heated seat switch - inspection​
Heated seat switch - installation​
Heated seat switch - removal​
Hill descent control switch - inspection​
Hill descent control switch - installation​
Hill descent control switch - removal​
Horn - inspection​
Horn - installation​
Horn - removal​
Horn switch - inspection​
Horn switch - installation​
Horn switch - removal​
Illumination control switch - installation​
Illumination control switch - removal​
Parking aid system OFF switch - inspection​
Parking aid system OFF switch - installation​
Parking aid system OFF switch - removal​
Passenger airbag cut off switch - inspection​
Passenger airbag cut off switch - installation​
Passenger airbag cut off switch - removal​
Rear door speaker - inspection​
Rear door speaker - installation​
Rear door speaker - removal​
Rear seat USB charge port - installation​
Rear seat USB charge port - removal​
Regenerative brake level switch - inspection​
Regenerative brake level switch - installation​
Regenerative brake level switch - removal​
Roof speaker - inspection​
Roof speaker - installation​
Roof speaker - removal​
Rough terrain mode switch - inspection​
Rough terrain mode switch - installation​
Rough terrain mode switch - removal​
SOS button - inspection​
SOS button - installation​
SOS button - removal​
TPMS load selector switch - inspection​
TPMS load selector switch - installation​
TPMS load selector switch - removal​
Tweeter - installation​
Tweeter - removal​
Vehicle approaching speaker - inspection​
Vehicle approaching speaker - installation​
Vehicle approaching speaker - removal​
9E. Instrumentation, Driver Info​
Antenna - removal​
Forward collision warning light - installation​
Forward collision warning light - removal​
Front camera - installation​
Front camera - removal​
Instrument panel cluster - diagnostics​
Instrument panel cluster - installation​
Instrument panel cluster - removal​
Instrument panel cluster - setting​
Microphone - installation​
Microphone - removal​
Passenger airbag indicator - installation​
Passenger airbag indicator - removal​
Radar sensor (Type 1) - installation​
Radar sensor (Type 1) - removal​
Radar sensor (Type 1) - setting​
Radar sensor (Type 2) - installation​
Radar sensor (Type 2) - removal​
Radar sensor (Type 2) - setting​
Rearview camera - installation​
Rearview camera - removal​
Side camera - installation​
Side camera - removal​
Sonar sensor - installation​
Sonar sensor - removal​
Stereo camera - cleaning​
Stereo camera - installation​
Stereo camera - removal​
Stereo camera - setting​
Stereo camera - writing​
9G. Hood, Fenders, Doors​
Front door - disassembly​
Front door - installation​
Front door - reassembly​
Front door - removal​
Front fender panel - installation​
Front fender panel - removal​
Hood - installation​
Hood - removal​
Hood control cable - installation​
Hood control cable - removal​
Hood lock - installation​
Hood lock - removal​
Rear door - disassembly​
Rear door - installation​
Rear door - reassembly​
Rear door - removal​
Rear mudguard - installation​
Rear mudguard - removal​
Side access panel - disassembly​
Side access panel - installation​
Side access panel - reassembly​
Side access panel - removal​
Underguard - installation​
Underguard - removal​
9H. Cab Structure​
Air outlet valve - installation​
Air outlet valve - removal​
Back panel seal - installation​
Back panel seal - removal​
Front bumper - disassembly​
Front bumper - installation​
Front bumper - reassembly​
Front bumper - removal​
Radiator grille - installation​
Radiator grille - removal​
Rear step bumper - disassembly​
Rear step bumper - installation​
Rear step bumper - reassembly​
Rear step bumper - removal​
Roof rail - installation​
Roof rail - removal​
Side step - installation​
Side step - removal​
9I. Seats​
Driver seat - disassembly​
Driver seat - installation​
Driver seat - reassembly​
Driver seat - removal​
Passenger seat - disassembly​
Passenger seat - installation​
Passenger seat - reassembly​
Passenger seat - removal​
Rear seat - disassembly​
Rear seat - installation​
Rear seat - reassembly​
Rear seat - removal​
9J. Security and Locks​
Anti theft horn - installation​
Anti theft horn - removal​
Center in-vehicle antenna - installation​
Center in-vehicle antenna - removal​
Charging port lid cable - installation​
Charging port lid cable - removal​
Electronic key - disassembly​
Electronic key - reassembly​
Electronic key - setting​
External buzzer - installation​
External buzzer - removal​
Front door lock - inspection​
Front door lock - installation​
Front door lock - removal​
Immobilizer coil - installation​
Immobilizer coil - removal​
Key cylinder (door) - installation​
Key cylinder (door) - removal​
Key cylinder (tailgate) - installation​
Key cylinder (tailgate) - removal​
Rear door lock - inspection​
Rear door lock - installation​
Rear door lock - removal​
Steering lock - installation​
Steering lock - removal​
Steering lock - setting​
9L. Exterior, Interior Trim​
Center pillar upper trim cover - installation​
Center pillar upper trim cover - removal​
Console box - installation​
Console box - removal​
Front pillar trim cover - installation​
Front pillar trim cover - removal​
Head lining (crew cab) - disassembly​
Head lining (crew cab) - installation​
Head lining (crew cab) - reassembly​
Head lining (crew cab) - removal​
Head lining (extended cab) - disassembly​
Head lining (extended cab) - installation​
Head lining (extended cab) - reassembly​
Head lining (extended cab) - removal​
Instrument panel - installation​
Instrument panel - removal​
Rear end trim cover - installation​
Rear end trim cover - removal​
Rear pillar trim cover (crew cab) - installation​
Rear pillar trim cover (crew cab) - removal​
Rear pillar trim cover (extended cab) - installation​
Rear pillar trim cover (extended cab) - removal​
Reinforcement - installation​
Reinforcement - removal​
9P. Unibody Sub-frames​
Body mounting - installation​
Body mounting - removal​
Rear body - installation​
Rear body - removal​
Tail gate - installation​
Tail gate - removal​
9T. Glass, Windows, Mirrors​
Backlight glass - installation​
Backlight glass - removal​
Front door power window switch - inspection​
Front door power window switch - installation​
Front door power window switch - removal​
Front door power window switch - setting​
Front windshield glass - installation​
Front windshield glass - removal​
Outside rearview mirror - disassembly​
Outside rearview mirror - installation​
Outside rearview mirror - reassembly​
Outside rearview mirror - removal​
Rear door power window switch - inspection​
Rear door power window switch - installation​
Rear door power window switch - removal​
Remote control mirror switch - inspection​
Remote control mirror switch - installation​
Remote control mirror switch - removal​
9Z. Body, Cab, Accessories Electrical Control​
BCM - installation​
BCM - removal​
BCM - setting​
Central gateway control unit - installation​
Central gateway control unit - removal​
Central gateway control unit - setting​
DRM - installation​
DRM - removal​
ECall unit - installation​
ECall unit - removal​
ECall unit - setting​
ECall unit backup battery - installation​
ECall unit backup battery - removal​
Headlight auto leveling control unit - installation​
Headlight auto leveling control unit - removal​
Headlight auto leveling control unit - setting​
Heated seat control unit - installation​
Heated seat control unit - removal​
Information module - installation​
Information module - removal​
Information module - setting​
MAP unit - installation​
MAP unit - removal​
MAP unit - setting​
Parking aid system control unit - installation​
Parking aid system control unit - removal​
Parking aid system control unit - setting​
Rain and light sensor - installation​
Rain and light sensor - removal​
Surround view control unit - installation​
Surround view control unit - removal​
Surround view control unit - setting​
Surround view control unit - writing​
Vehicle approaching speaker control unit - installation​
Vehicle approaching speaker control unit - removal​
Wireless access module - installation​
Wireless access module - removal​
Wireless access module - setting (with passive entry and start system)​
51. EV Control
51B. Mechanical​
Accelerator pedal - inspection​
Accelerator pedal - installation​
Accelerator pedal - removal​
Breather - installation​
Breather - removal​
eAxle (front) - inspection​
eAxle (front) - installation​
eAxle (front) - removal​
eAxle (front) - setting​
eAxle (front) oil cooler - installation​
eAxle (front) oil cooler - removal​
eAxle (front) oil seal - installation​
eAxle (front) oil seal - removal​
eAxle (rear) - inspection​
eAxle (rear) - installation​
eAxle (rear) - removal​
eAxle (rear) - setting​
eAxle (rear) oil cooler - installation​
eAxle (rear) oil cooler - removal​
eAxle (rear) oil seal - installation​
eAxle (rear) oil seal - removal​
eAxle gear oil - replacement​
PBW - installation​
PBW - removal​
PBW - setting​
Selector lever - disassembly​
Selector lever - installation​
Selector lever - reassembly​
Selector lever - removal​
51D. Cooling Warm up System​
Chiller - installation​
Chiller - removal​
Coolant for EV system - inspection​
Coolant for EV system - replacement​
Coolant for high voltage battery pack - inspection​
Coolant for high voltage battery pack - replacement​
High voltage heater (high voltage battery pack) - inspection​
High voltage heater (high voltage battery pack) - installation​
High voltage heater (high voltage battery pack) - removal​
Radiator (EV system) - inspection​
Radiator (EV system) - installation​
Radiator (EV system) - removal​
Radiator (high voltage battery pack) - inspection​
Radiator (high voltage battery pack) - installation​
Radiator (high voltage battery pack) - removal​
Reserve tank (EV system) - installation​
Reserve tank (EV system) - removal​
Sub-tank (high voltage battery pack) - installation​
Sub-tank (high voltage battery pack) - removal​
Water control valve - inspection​
Water control valve - installation​
Water control valve - removal​
Water pump1 (for EV system) - installation​
Water pump1 (for EV system) - removal​
Water pump2 (for EV system) - installation​
Water pump2 (for EV system) - removal​
Water pump (high voltage battery pack) - installation​
Water pump (high voltage battery pack) - removal​
51J. Electrical System​
Charge indicator light (green) and charging error light (red) and charging cancel switch - inspection​
Charge indicator light (green) and charging error light (red) and charging cancel switch - installation​
Charge indicator light (green) and charging error light (red) and charging cancel switch - removal​
Charging inlet - inspection​
Charging inlet - installation​
Charging inlet - removal​
DC-DC converter (12V) - installation​
DC-DC converter (12V) - removal​
High voltage battery pack - inspection​
High voltage battery pack - installation​
High voltage battery pack - removal​
High voltage battery pack - setting​
High voltage motor cable - installation​
High voltage motor cable - removal​
Junction box - installation​
Junction box - removal​
Junction box cover - installation​
Junction box cover - removal​
Junction box fuse - installation​
Junction box fuse - removal​
OBC - installation​
OBC - removal​
OBC - setting​
Service plug - installation​
Service plug - removal​
51Z. EV Control Electrical Control​
Coolant level sensor (high voltage battery pack) - inspection​
Coolant level sensor (high voltage battery pack) - installation​
Coolant level sensor (high voltage battery pack) - removal​
Coolant temperature sensor (Front of high voltage battery pack) - inspection​
Coolant temperature sensor (Front of high voltage battery pack) - installation​
Coolant temperature sensor (Front of high voltage battery pack) - removal​
Coolant temperature sensor (Front of radiator for EV system) - inspection​
Coolant temperature sensor (Front of radiator for EV system) - installation​
Coolant temperature sensor (Front of radiator for EV system) - removal​
Coolant temperature sensor (Rear of high voltage battery pack) - inspection​
Coolant temperature sensor (Rear of high voltage battery pack) - installation​
Coolant temperature sensor (Rear of high voltage battery pack) - removal​
Coolant temperature sensor (Rear of radiator for EV system) - inspection​
Coolant temperature sensor (Rear of radiator for EV system) - installation​
Coolant temperature sensor (Rear of radiator for EV system) - removal​
Coolant temperature sensor (Rear of Radiator for high voltage battery pack) - inspection​
Coolant temperature sensor (Rear of Radiator for high voltage battery pack) - installation​
Coolant temperature sensor (Rear of Radiator for high voltage battery pack) - removal​
VCU - installation​
VCU - removal​
VCU - setting​
