Momed80
150
35,046
International Truck MV Series Interactive Schematics 0000018826 2019
Brand: International, Navistar
Type of Manual: Interactive Schematics
Model: International MV Series Truck
Built: 2018 - 2020
Part Number: 0000018826
Publication Date: 2019
Number of Pages: 1762 Pages
BCM (Body Control Module)
BCM (Body Control Module) Design 1
B6.7 - CAN Layout
B6.7 - CAN Layout Design 9
L9 - CAN Layout
L9 - CAN Layout Design 14
B6.7 - Engine (Control) [Cummins Euro]
B6.7 - Engine (Control) [Cummins Euro] Design 20
L9 - Engine (Control) [Cummins Euro]
L9 - Engine (Control) [Cummins Euro] Design 23
B6.7 - Auxilary Gauges (Secondary)
B6.7 - Auxilary Gauges (Secondary) Design 26
B6.7 - Auxiliary Gauges (Primary)
B6.7 - Auxiliary Gauges (Primary) Design 27
B6.7 - Instrument Cluster - Bulb Check
B6.7 - Instrument Cluster - Bulb Check Design 28
Instrument Cluster (Premium)
Instrument Cluster (Premium) Design 29
Instrument Cluster - Request and Status
Instrument Cluster - Request and Status Design 31
ABS Splice Packs - 1410
ABS Splice Packs - 1410 Design 32
Ground Splice Packs
Ground Splice Packs Design 33
Ground Splice Packs - 1022 & 1023
Ground Splice Packs - 1022 & 1023 Design 34
Ground Splice Packs - 1027
Ground Splice Packs - 1027 Design 35
IP ZVR - 1620
IP ZVR - 1620 Design 36
Panel Dimmer Splice Packs - 1021
Panel Dimmer Splice Packs - 1021 Design 37
B6.7 - Engine Ground Distribution - 6704
B6.7 - Engine Ground Distribution - 6704 Design 38
L9 - Engine Ground Distribution - 6704
L9 - Engine Ground Distribution - 6704 Design 39
B6.7 - ZVR Splice Packs - 6747
B6.7 - ZVR Splice Packs - 6747 Design 40
L9 - ZVR Splice Packs - 6747
L9 - ZVR Splice Packs - 6747 Design 41
TABLE OF CONTENTS
iIP Light Splice Packs - 1625/1623/400
IP Light Splice Packs - 1625/1623/400 Design 42
B6.7 - Center Chassis Ground Splice Packs -
8809/8807/8805/8802
B6.7 - Center Chassis Ground Splice Packs - 8809/8807/8805/8802 Design 43
B6.7 - Forward Chassis Ground Splice Packs - 8800
B6.7 - Forward Chassis Ground Splice Packs - 8800 Design 44
L9 - Center Chassis Ground Splice Packs -
8802/8805/8807/8809
L9 - Center Chassis Ground Splice Packs - 8802/8805/8807/8809 Design 45
L9 - Forward Chassis Ground Splice Packs - 8800
L9 - Forward Chassis Ground Splice Packs - 8800 Design 46
Lighting Control Module
Lighting Control Module Design 47
Chassis PDM
Chassis PDM Design 49
B6.7 - Aftertreatment PDM
B6.7 - Aftertreatment PDM Design 50
L9 - Aftertreatment PDM
L9 - Aftertreatment PDM Design 51
B6.7 - Grid Management (CA2) Day Cab
B6.7 - Grid Management (CA2) Day Cab Design 52
L9 - Grid Management (CA2) Day Cab
L9 - Grid Management (CA2) Day Cab Design 53
Battery Feed
Battery Feed Design 54
Key Switch Accessory
Key Switch Accessory Design 55
Key Switch Ignition
Key Switch Ignition Design 56
B6.7 - Forward Chassis Power
B6.7 - Forward Chassis Power Design 57
B6.7 - Underhood PDM
B6.7 - Underhood PDM Design 58
L9 - Forward Chassis Power
L9 - Forward Chassis Power Design 59
L9 - Underhood PDM
L9 - Underhood PDM Design 60
Banana Plugs Receptacle
Banana Plugs Receptacle Design 61
TABLE OF CONTENTS
iiB6.7 - Drain Valve Heater
B6.7 - Drain Valve Heater Design 62
B6.7 - Theft Deterrent (Without additional relay)
B6.7 - Theft Deterrent (Without additional relay) Design 64
CB Radio Power Only
CB Radio Power Only Design 65
CB Radio Power Only (Single Antenna)
CB Radio Power Only (Single Antenna) Design 66
L9 - Drain Valve Heater
L9 - Drain Valve Heater Design 67
L9 - Theft Deterrent (Without additional relay)
L9 - Theft Deterrent (Without additional relay) Design 71
Real Time Clock
Real Time Clock Design 72
Remote Keyless Access
Remote Keyless Access Design 73
2-Way Radio
2-Way Radio Design 74
Radio
Radio Design 76
Radio w/Bluetooth
Radio w/Bluetooth Design 77
Radio w/Bluetooth without Steering Wheel Pod
Radio w/Bluetooth without Steering Wheel Pod Design 79
Radio w/Steering Wheel Pod
Radio w/Steering Wheel Pod Design 80
Speakers:Four Speakers Daycab BT n/QC
Speakers:Four Speakers Daycab BT n/QC Design 82
Speakers:Four Speakers Daycab n/BT n/QC
Speakers:Four Speakers Daycab n/BT n/QC Design 83
Speakers:Two Speakers Daycab BT n/QC
Speakers:Two Speakers Daycab BT n/QC Design 84
Speakers:Two Speakers Daycab n/BT n/QC
Speakers:Two Speakers Daycab n/BT n/QC Design 85
B6.7 - Auxiliary Power (40A) HSD
B6.7 - Auxiliary Power (40A) HSD Design 86
Cigar Lighter
Cigar Lighter Design 87
Cigar Lighter Aux APO
Cigar Lighter Aux APO Design 88
TABLE OF CONTENTS
iiiL9 - Auxiliary Power (40A) HSD
L9 - Auxiliary Power (40A) HSD Design 91
Standard APO
Standard APO Design 92
Standard APO and Aux APO
Standard APO and Aux APO Design 93
Cruise Control (W/ One Telltale 10 Pin)
Cruise Control (W/ One Telltale 10 Pin) Design 96
Cruise Control (W/ One Telltale 4 Pin)
Cruise Control (W/ One Telltale 4 Pin) Design 98
Vehicle Speed Control (Cruise Control) 10 Pin
Vehicle Speed Control (Cruise Control) 10 Pin Design 100
Vehicle Speed Control (Cruise Control) 4 Pin
Vehicle Speed Control (Cruise Control) 4 Pin Design 101
B6.7 - City Horn (W/ 4PIN CLK & P. Brake)
B6.7 - City Horn (W/ 4PIN CLK & P. Brake) Design 102
B6.7 - City Horn (W/ 4PIN CLK)
B6.7 - City Horn (W/ 4PIN CLK) Design 104
L9 - City Horn (W/ 10PIN CLK & P. Brake)
L9 - City Horn (W/ 10PIN CLK & P. Brake) Design 106
L9 - City Horn (W/ 10PIN CLK)
L9 - City Horn (W/ 10PIN CLK) Design 107
L9 - City Horn (W/ 4PIN CLK & P. Brake)
L9 - City Horn (W/ 4PIN CLK & P. Brake) Design 108
L9 - City Horn (W/ 4PIN CLK)
L9 - City Horn (W/ 4PIN CLK) Design 110
Door Ajar Reminder (Entry/Exit)
Door Ajar Reminder (Entry/Exit) Design 112
Door Ajar Reminder(Entry /Exit):4 Door
Door Ajar Reminder(Entry /Exit):4 Door Design 113
Power Door Locks
Power Door Locks Design 114
Power Door Locks Crew Cab
Power Door Locks Crew Cab Design 115
Mirrors (Heated)
Mirrors (Heated) Design 116
Mirrors (Heat) [Switch Pack Actuated Relay Driven]
Mirrors (Heat) [Switch Pack Actuated Relay Driven] Design 117
Mirrors (Power) Control Switch Actuated
Mirrors (Power) Control Switch Actuated Design 118
TABLE OF CONTENTS
ivMirrors (Power) Door Pod Actuated
Mirrors (Power) Door Pod Actuated Design 120
Power Windows
Power Windows Design 121
Power Windows 4-Door N/W RKE
Power Windows 4-Door N/W RKE Design 122
Power Windows 4-Door W/RKE
Power Windows 4-Door W/RKE Design 123
B6.7 - Selective Catalytic Reduction (SCR) - (Euro 4/
Euro 5)
B6.7 - Selective Catalytic Reduction (SCR) - (Euro 4/ Euro 5) Design 124
L9 - Selective Catalytic Reduction (SCR) - (Euro 4/
Euro 5)
L9 - Selective Catalytic Reduction (SCR) - (Euro 4/ Euro 5) Design 125
B6.7 - DPF - Regen Switch Only
B6.7 - DPF - Regen Switch Only Design 126
B6.7 - Back-Up Alarm (Automatic) W/O Tailboard
B6.7 - Back-Up Alarm (Automatic) W/O Tailboard Design 127
B6.7 - Back-Up Alarm (Automatic) W/ Tailboard
B6.7 - Back-Up Alarm (Automatic) W/ Tailboard Design 128
B6.7 - Back-Up Alarm (Manual) W/O Tailboard
B6.7 - Back-Up Alarm (Manual) W/O Tailboard Design 129
B6.7 - Back-Up Alarm (Manual) W/ Tailboard
B6.7 - Back-Up Alarm (Manual) W/ Tailboard Design 130
L9 - Back-Up Alarm (Automatic) W/O Tailboard
L9 - Back-Up Alarm (Automatic) W/O Tailboard Design 131
L9 - Back-Up Alarm (Automatic) W/ Tailboard
L9 - Back-Up Alarm (Automatic) W/ Tailboard Design 132
L9 - Back-Up Alarm (Manual) W/O Tailboard
L9 - Back-Up Alarm (Manual) W/O Tailboard Design 133
L9 - Back-Up Alarm (Manual) W/ Tailboard
L9 - Back-Up Alarm (Manual) W/ Tailboard Design 134
B6.7 - RIGHTSIDE AIR DRYER
B6.7 - RIGHTSIDE AIR DRYER Design 135
L9 - RIGHTSIDE AIR DRYER
L9 - RIGHTSIDE AIR DRYER Design 136
Multiplexed Switch Pack (Primary Switch)
Multiplexed Switch Pack (Primary Switch) Design 143
B6.7 - Auxiliary Air Solenoids (1 Normally Closed)
B6.7 - Auxiliary Air Solenoids (1 Normally Closed) Design 144
TABLE OF CONTENTS
vB6.7 - Auxillary Air Solenoids Normally Open
B6.7 - Auxillary Air Solenoids Normally Open Design 145
L9 - Auxiliary Air Solenoids (1 Normally Closed)
L9 - Auxiliary Air Solenoids (1 Normally Closed) Design 146
L9 - Auxiliary Air Solenoids (2 Normally Closed)
L9 - Auxiliary Air Solenoids (2 Normally Closed) Design 147
L9 - Auxiliary Air Solenoids (3 Normally Closed)
L9 - Auxiliary Air Solenoids (3 Normally Closed) Design 150
B6.7 - I/O Expansion
B6.7 - I/O Expansion Design 151
L9 - I/O Expansion
L9 - I/O Expansion Design 152
L9 - Power Lift Gate
L9 - Power Lift Gate Design 153
B6.7 - DLB - Remote Power Modules (1 RPM n/ Switch
Packs)
B6.7 - DLB - Remote Power Modules (1 RPM n/ Switch Packs) Design 154
B6.7 - DLB - Remote Power Modules (1 RPM w/ Switch
Packs)
B6.7 - DLB - Remote Power Modules (1 RPM w/ Switch Packs) Design 156
B6.7 - DLB - Remote Power Modules (2 RPM n/ Switch
Pack)
B6.7 - DLB - Remote Power Modules (2 RPM n/ Switch Pack) Design 158
B6.7 - DLB - Remote Power Modules (2 RPM w/ Switch
Packs)
B6.7 - DLB - Remote Power Modules (2 RPM w/ Switch Packs) Design 159
L9 - DLB - Remote Power Modules (1 RPM n/ Switch
Packs)
L9 - DLB - Remote Power Modules (1 RPM n/ Switch Packs) Design 160
L9 - DLB - Remote Power Modules (1 RPM w/ Switch
Packs)
L9 - DLB - Remote Power Modules (1 RPM w/ Switch Packs) Design 161
L9 - DLB - Remote Power Modules (2 RPM n/ Switch
Pack)
L9 - DLB - Remote Power Modules (2 RPM n/ Switch Pack) Design 162
L9 - DLB - Remote Power Modules (2 RPM w/ Switch
Packs)
L9 - DLB - Remote Power Modules (2 RPM w/ Switch Packs) Design 163
L9 - Remote Start/Stop
L9 - Remote Start/Stop Design 164
L9 - Remote Start/Stop w/ Emergency Pump
L9 - Remote Start/Stop w/ Emergency Pump Design 165
TABLE OF CONTENTS
viB6.7 - Adjustable Engine Speed Control (PTO) 10-pin
B6.7 - Adjustable Engine Speed Control (PTO) 10-pin Design 166
B6.7 - Adjustable Engine Speed Control (PTO) 4-pin
B6.7 - Adjustable Engine Speed Control (PTO) 4-pin Design 168
B6.7 - PTO (Fuel and Hours)
B6.7 - PTO (Fuel and Hours) Design 169
B6.7 - Transmission Power Take Off (Auto Trans
Single PTO w/21 Parameters)
B6.7 - Transmission Power Take Off (Auto Trans Single PTO w/21 Parameters)
Design 170
B6.7 - Transmission Power Take Off (Manual Trans
Single PTO w/ 21 Parameters)
B6.7 - Transmission Power Take Off (Manual Trans Single PTO w/ 21
Parameters) Design 171
B6.7 - Transmission Power Take Off (Single Input
configurable pull up or pull down)
B6.7 - Transmission Power Take Off (Single Input configurable pull up or pull
down) Design 172
B6.7 - Transmission Power Take Off (Single PTO W/
RPM and Manual Trans)
B6.7 - Transmission Power Take Off (Single PTO W/ RPM and Manual Trans)
Design 173
L9 - Adjustable Engine Speed Control (PTO) 10-pin
L9 - Adjustable Engine Speed Control (PTO) 10-pin Design 174
L9 - Adjustable Engine Speed Control (PTO) 4-pin
L9 - Adjustable Engine Speed Control (PTO) 4-pin Design 176
L9 - PTO (Fuel and Hours)
L9 - PTO (Fuel and Hours) Design 177
L9 - Transmission Power Take Off (Auto Trans Single
L9 - Transmission Power Take Off (Auto Trans Single PTO w/21 Parameters)
Design 178
L9 - Transmission Power Take Off (Auto Trans with
Lectradrive)
L9 - Transmission Power Take Off (Auto Trans with Lectradrive) Design 179
L9 - Transmission Power Take Off (Lectrashift PTO
with Manual Trans)
L9 - Transmission Power Take Off (Lectrashift PTO with Manual Trans)
Design 180
L9 - Transmission Power Take Off (Manual Trans
L9 - Transmission Power Take Off (Manual Trans Single PTO w/ 21 Parameters)
Design 181
TABLE OF CONTENTS
viiL9 - Transmission Power Take Off (Single Input
L9 - Transmission Power Take Off (Single Input configurable pull up or pull down)
Design 182
L9 - Transmission Power Take Off (Single PTO W/
RPM and Auto Trans)
L9 - Transmission Power Take Off (Single PTO W/ RPM and Auto Trans)
Design 183
L9 - Transmission Power Take Off (Single PTO W/ RPM and Manual Trans)
Design 184
B6.7 - Antilock Brake System (ABS)-BENDIX 4
Channel Implemenation
B6.7 - Antilock Brake System (ABS)-BENDIX 4 Channel Implemenation
Design 185
B6.7 - Traction Control Bendix
B6.7 - Traction Control Bendix Design 186
L9 - Antilock Brake System (ABS) - BENDIX 4 Channel
Implemenation
L9 - Antilock Brake System (ABS) - BENDIX 4 Channel Implemenation Design188
L9 - Traction Control Bendix
L9 - Traction Control Bendix Design 189
Park Brake Controls (Monitoring) W (Door Switch City
Horn)
Park Brake Controls (Monitoring) W (Door Switch City Horn) Design 190
Park Brake Control (Monitoring) (GEN IV BCM)
Park Brake Control (Monitoring) (GEN IV BCM) Design 191
Park Brake Control (Monitoring) (W/Vehicle Speed)
Park Brake Control (Monitoring) (W/Vehicle Speed) Design 192
Vehicle Alarm System
Vehicle Alarm System Design 193
B6.7 - Cooling Fan Control Two-Speed
B6.7 - Cooling Fan Control Two-Speed Design 194
B6.7 - Engine Warning MUX
B6.7 - Engine Warning MUX Design 195
B6.7 - Vehicle Sleep Mode
B6.7 - Vehicle Sleep Mode Design 196
B6.7 - Vehicle Speed Limit Override
B6.7 - Vehicle Speed Limit Override Design 197
Engine Block Heater
Engine Block Heater Design 198
Engine Brake Mux Switch
Engine Brake Mux Switch Design 199
TABLE OF CONTENTS
viiiEngine Brake W/ Stalk Shifter
Engine Brake W/ Stalk Shifter Design 200
Engine Oil and Block Heaters (Purchased Assembly)
Engine Oil and Block Heaters (Purchased Assembly) Design 201
Exhaust Brake (Cummins)
Exhaust Brake (Cummins) Design 202
Fuel Heater (Vehicle Powered)(Racor)
Fuel Heater (Vehicle Powered)(Racor) Design 203
L9 - Cooling Fan Control Two-Speed
L9 - Cooling Fan Control Two-Speed Design 207
L9 - Engine Warning MUX
L9 - Engine Warning MUX Design 208
L9 - Vehicle Speed Limit Override
L9 - Vehicle Speed Limit Override Design 209
Vehicle Acceleration (w/ Two PWR Two GND & Two
STS)
Vehicle Acceleration (w/ Two PWR Two GND & Two STS) Design 210
Automatic Lighting
Automatic Lighting Design 211
Automatic Lighting - Dual Sensor Twilight/Solar
Automatic Lighting - Dual Sensor Twilight/Solar Design 213
B6.7 - Service Brake Switch
B6.7 - Service Brake Switch Design 215
L9 - Service Brake Switch
L9 - Service Brake Switch Design 216
B6.7 - Backup Light(Single Reverse Light) Allison
3K/4K
B6.7 - Backup Light(Single Reverse Light) Allison 3K/4K Design 217
L9 - Backup Lights (Single Reverse Lights)
Eaton/Manual Trans
L9 - Backup Lights (Single Reverse Lights) Eaton/Manual Trans Design 219
L9 - Backup Light (Single Reverse Light) Allison
3K/4K 07
L9 - Backup Light (Single Reverse Light) Allison 3K/4K 07 Design 220
L9 - Body Builder Lighting - Combined Turn and Stop
Lamps (Automatic)
L9 - Body Builder Lighting - Combined Turn and Stop Lamps (Automatic)
Design 222
Lamps (Manual) Option2
L9 - Body Builder Lighting - Combined Turn and Stop Lamps (Manual) Option2
Design 224
TABLE OF CONTENTS
ixL9 - Body Builder Lighting - Separate Turn and Stop
Lamps (Blunt Cut)
L9 - Body Builder Lighting - Separate Turn and Stop Lamps (Blunt Cut)
Design 226
B6.7 - Exterior Lamp Check
B6.7 - Exterior Lamp Check Design 227
L9 - Exterior Lamp Check
L9 - Exterior Lamp Check Design 228
B6.7 - Exterior Lamp Reminder
B6.7 - Exterior Lamp Reminder Design 229
L9 - Fog Lights (LED White TOP MTG)
L9 - Fog Lights (LED White TOP MTG) Design 230
L9 - Front Fog Lamps
L9 - Front Fog Lamps Design 231
B6.7 - Front Fog Lights W CONNECTOR
B6.7 - Front Fog Lights W CONNECTOR Design 232
L9 - Front Fog Lights W CONNECTOR
L9 - Front Fog Lights W CONNECTOR Design 233
B6.7 - Headlights W 10PIN CLK W/LOWW W/O
Interrupt
B6.7 - Headlights W 10PIN CLK W/LOWW W/O Interrupt Design 234
B6.7 - Headlights W/O Lights ON With Wipers (LOWW)
W/O Headlights Interrupt
B6.7 - Headlights W/O Lights ON With Wipers (LOWW) W/O Headlights Interrupt
Design 236
B6.7 - Headlights W/O Lights ON with wipers (LOWW)
W/ Headlights Interrupt
B6.7 - Headlights W/O Lights ON with wipers (LOWW) W/ Headlights Interrupt
Design 238
L9 - Headlights W 10PIN CLK W/LOWW W/Interrupt
L9 - Headlights W 10PIN CLK W/LOWW W/Interrupt Design 240
L9 - Headlights W 10PIN CLK W/LOWW W/O Interrupt
L9 - Headlights W 10PIN CLK W/LOWW W/O Interrupt Design 242
L9 - Headlights W/O Lights ON With Wipers (LOWW)
L9 - Headlights W/O Lights ON With Wipers (LOWW) W/O Headlights Interrupt
Design 244
L9 - Headlights W/O Lights ON with wipers (LOWW)
L9 - Headlights W/O Lights ON with wipers (LOWW) W/ Headlights Interrupt
Design 246
B6.7 - Front Marker Lights
B6.7 - Front Marker Lights Design 248
TABLE OF CONTENTS
xB6.7 - PARK LIGHTS - N/Marker Interrupt
B6.7 - PARK LIGHTS - N/Marker Interrupt Design 249
Clearance and Identification Lights
Clearance and Identification Lights Design 251
L9 - Front Marker Lights
L9 - Front Marker Lights Design 252
L9 - PARK LIGHTS - N/Marker Interrupt
L9 - PARK LIGHTS - N/Marker Interrupt Design 253
L9 - PARK LIGHTS - W/Marker Interrupt 10pin
CLCKSPRING
L9 - PARK LIGHTS - W/Marker Interrupt 10pin CLCKSPRING Design 255
L9 - PARK LIGHTS - W/Marker Interrupt 4 pin
clockspring
L9 - PARK LIGHTS - W/Marker Interrupt 4 pin clockspring Design 257
B6.7 - Directional Signal (Turn) W/ Single Tail Board
W/Hazard SW
B6.7 - Directional Signal (Turn) W/ Single Tail Board W/Hazard SW Design 259
B6.7 - License Plate Light (Tail Light Single Assy.)
W/Less Power Module
B6.7 - License Plate Light (Tail Light Single Assy.) W/Less Power Module
Design 260
B6.7 - Rear Lights Stop - Single Assemby
B6.7 - Rear Lights Stop - Single Assemby Design 261
B6.7 - Rear Light (Tail Light)
B6.7 - Rear Light (Tail Light) Design 262
Hazard Warning Light N/Trlr Socket
Hazard Warning Light N/Trlr Socket Design 263
L9 - Directional Signal (Turn) W/ LED BOX LAMPS
L9 - Directional Signal (Turn) W/ LED BOX LAMPS Design 265
L9 - Directional Signal (Turn) W/ Single Tail Board
W/Hazard SW
L9 - Directional Signal (Turn) W/ Single Tail Board W/Hazard SW Design 266
L9 - License Plate Light (LED BOX LAMP Tail Light)
L9 - License Plate Light (LED BOX LAMP Tail Light) Design 267
L9 - License Plate Light (Tail Light Single Assy)
L9 - License Plate Light (Tail Light Single Assy) Design 268
Option2
L9 - License Plate Light (Tail Light Single Assy) Option2 Design 269
Option3
L9 - License Plate Light (Tail Light Single Assy) Option3 Design 270
TABLE OF CONTENTS
xiL9 - License Plate Light (Tail Light Single Assy)
W/Less Power Module
L9 - License Plate Light (Tail Light Single Assy) W/Less Power Module Design271
L9 - Rear Lights Stop - Single Assemby
L9 - Rear Lights Stop - Single Assemby Design 272
L9 - Rear Light (Tail Light)
L9 - Rear Light (Tail Light) Design 273
B6.7 - WORK LIGHT W BackUP 1 BULB
B6.7 - WORK LIGHT W BackUP 1 BULB Design 274
B6.7 - WORK LIGHT W BackUP 1 BULB Option 2
B6.7 - WORK LIGHT W BackUP 1 BULB Option 2 Design 276
B6.7 - WORK LIGHT W RKE 1 BULB
B6.7 - WORK LIGHT W RKE 1 BULB Design 278
B6.7 - WORK LIGHT 1 BULB
B6.7 - WORK LIGHT 1 BULB Design 280
L9 - Work Lights LED W/ Sw Pack - Day Cab
L9 - Work Lights LED W/ Sw Pack - Day Cab Design 282
L9 - WORK LIGHT W BackUP 1 BULB
L9 - WORK LIGHT W BackUP 1 BULB Design 284
L9 - WORK LIGHT W BackUP 1 BULB Option2
L9 - WORK LIGHT W BackUP 1 BULB Option2 Design 286
L9 - WORK LIGHT W RKE 1 BULB
L9 - WORK LIGHT W RKE 1 BULB Design 288
L9 - WORK LIGHT 1 BULB
L9 - WORK LIGHT 1 BULB Design 290
B6.7 - Heating Ventilation & Air Conditioning (HVAC)
Manual
B6.7 - Heating Ventilation & Air Conditioning (HVAC) Manual Design 292
Heating Ventilation & Air Conditioning (HVAC) Auto
Temp Control
Heating Ventilation & Air Conditioning (HVAC) Auto Temp Control Design 293
L9 - Heating Ventilation & Air Conditioning (HVAC)
Manual
L9 - Heating Ventilation & Air Conditioning (HVAC) Manual Design 296
B6.7 - GEN IV Cluster
B6.7 - GEN IV Cluster Design 297
L9 - GEN IV Cluster
L9 - GEN IV Cluster Design 298
B6.7 - 26" Fuel Tank
B6.7 - 26" Fuel Tank Design 299
B6.7 - 26" Fuel Tank - Secondary
B6.7 - 26" Fuel Tank - Secondary Design 300
TABLE OF CONTENTS
xiiL9 - 26" Fuel Tank
L9 - 26" Fuel Tank Design 302
L9 - 26" Fuel Tank - Secondary
L9 - 26" Fuel Tank - Secondary Design 303
B6.7 - Current Monitoring (Ammeter)
B6.7 - Current Monitoring (Ammeter) Design 305
B6.7 - Engine Speed (Tachometer)
B6.7 - Engine Speed (Tachometer) Design 307
Compressed Air Supply
Compressed Air Supply Design 308
Compressed Air Supply (Aux Gauge)
Compressed Air Supply (Aux Gauge) Design 309
High Exhaust System Temperature (HEST) Monitoring
High Exhaust System Temperature (HEST) Monitoring Design 310
L9 - Engine Speed (Tachometer)
L9 - Engine Speed (Tachometer) Design 311
Ambient Air Temperature
Ambient Air Temperature Design 312
B6.7 - Coolant Temperature Monitoring
B6.7 - Coolant Temperature Monitoring Design 313
L9 - Coolant Temperature Monitoring
L9 - Coolant Temperature Monitoring Design 314
B6.7 - Engine Oil Pressure
B6.7 - Engine Oil Pressure Design 315
B6.7 - Engine Oil Temperature NA MUX
B6.7 - Engine Oil Temperature NA MUX Design 316
L9 - Engine Oil Pressure
L9 - Engine Oil Pressure Design 317
L9 - Engine Oil Temperature NA MUX
L9 - Engine Oil Temperature NA MUX Design 318
L9 - Engine Oil Temperature NA MUX AUX Gauge
L9 - Engine Oil Temperature NA MUX AUX Gauge Design 319
B6.7 - Engine Usage Monitoring (Base) NA
B6.7 - Engine Usage Monitoring (Base) NA Design 320
L9 - Engine Usage Monitoring (Base) NA
L9 - Engine Usage Monitoring (Base) NA Design 321
L9 - Engine Usage Monitoring (VID Option)
L9 - Engine Usage Monitoring (VID Option) Design 322
Rear Axle Load Distribution
Rear Axle Load Distribution Design 323
TABLE OF CONTENTS
xiiiL9 - Axle Temperature Monitoring (Single Rear Aux
Gauge)
L9 - Axle Temperature Monitoring (Single Rear Aux Gauge) Design 324
L9 - Axle Temperature Monitoring (Single Rear Virtual
Gauge)
L9 - Axle Temperature Monitoring (Single Rear Virtual Gauge) Design 325
L9 - Axle Temperature Monitoring (Tandem Rear Aux
Gauge)
L9 - Axle Temperature Monitoring (Tandem Rear Aux Gauge) Design 326
Virtual Gauge)
L9 - Axle Temperature Monitoring (Tandem Rear Virtual Gauge) Design 327
L9 - Transmission Oil Temperature - Manual Trans
L9 - Transmission Oil Temperature - Manual Trans Design 328
w/Aux Gauge
L9 - Transmission Oil Temperature - Manual Trans w/Aux Gauge Design 329
L9 - Transmission Oil Temperature-Automatic Trans
w/Aux Gauge
L9 - Transmission Oil Temperature-Automatic Trans w/Aux Gauge Design 330
Transmission Oil Temperature Automatic Trans
Option2
Transmission Oil Temperature Automatic Trans Option2 Design 331
Vehicle Speedometer System (Automatic XMSN) NA
Vehicle Speedometer System (Automatic XMSN) NA Design 332
Vehicle Speedometer System (Manual XMSN) NA
Vehicle Speedometer System (Manual XMSN) NA Design 333
B6.7 - Odometer (via BCM/EGC)
B6.7 - Odometer (via BCM/EGC) Design 334
B6.7 - Trans Range Inhibit (J1939 Comm)
B6.7 - Trans Range Inhibit (J1939 Comm) Design 335
Coolant Level Monitoring (No CLA Module)
Coolant Level Monitoring (No CLA Module) Design 336
L9 - Engine Oil Level Monitoring
L9 - Engine Oil Level Monitoring Design 337
L9 - Odometer (via BCM/EGC)
L9 - Odometer (via BCM/EGC) Design 338
Operator Input
Operator Input Design 339
Vehicle Information Display Premium w/ Wi-Fi VID
Vehicle Information Display Premium w/ Wi-Fi VID Design 341
Vehicle Information Display W/O BT
TABLE OF CONTENTS
xivVehicle Information Display W/O BT Design 342
Vehicle Information Display (W/ BT)
Vehicle Information Display (W/ BT) Design 343
Voltage Monitoring Voltmeter
Voltage Monitoring Voltmeter Design 344
Voltage Monitoring Voltmeter Aux Gauge
Voltage Monitoring Voltmeter Aux Gauge Design 345
B6.7 - Economy Monitor
B6.7 - Economy Monitor Design 346
L9 - Economy Monitor
L9 - Economy Monitor Design 347
B6.7 - Trip Odometer (w/ECM & TCM)
B6.7 - Trip Odometer (w/ECM & TCM) Design 348
B6.7 - Trip Odometer (w/ECM)
B6.7 - Trip Odometer (w/ECM) Design 349
L9 - Trip Odometer (w/ECM & TCM)
L9 - Trip Odometer (w/ECM & TCM) Design 350
L9 - Trip Odometer (w/ECM)
L9 - Trip Odometer (w/ECM) Design 351
Trip Odometer (w/VID)
Trip Odometer (w/VID) Design 352
B6.7 - Up Shift Indicator NA
B6.7 - Up Shift Indicator NA Design 353
L9 - Up Shift Indicator NA
L9 - Up Shift Indicator NA Design 354
B6.7 - Panel Backlighting (Cabin Dimmer)
B6.7 - Panel Backlighting (Cabin Dimmer) Design 355
Cab Dome Light W/Classic Trim
Cab Dome Light W/Classic Trim Design 356
Cab Dome Light W/ Combo in Diamond Trim
Cab Dome Light W/ Combo in Diamond Trim Design 357
Courtesy Light Crew Cab
Courtesy Light Crew Cab Design 358
Courtesy Light Day Cab
Courtesy Light Day Cab Design 359
Interior Task Lights (Map) - Dome Combo
Interior Task Lights (Map) - Dome Combo Design 360
B6.7 - Power Divider Lock Control and Monitoring
B6.7 - Power Divider Lock Control and Monitoring Design 361
B6.7 - Two Speed Axle (AirShift on Shifter)
TABLE OF CONTENTS
xvB6.7 - Two Speed Axle (AirShift on Shifter) Design 362
B6.7 - Two Speed Axle (with BCM; Automactic
Transmission and switch on dash)
B6.7 - Two Speed Axle (with BCM; Automactic Transmission and switch on dash)
Design 363
Height Control
Height Control Design 364
L9 - Two Speed Axle (AirShift on Shifter)
L9 - Two Speed Axle (AirShift on Shifter) Design 365
L9 - Two Speed Axle (with BCM; Automactic
L9 - Two Speed Axle (with BCM; Automactic Transmission and switch on dash)
Design 366
B6.7 - Driver Controlled Locking Differential - RR Axle
(Dana w/ one sw)
B6.7 - Driver Controlled Locking Differential - RR Axle (Dana w/ one sw)
Design 367
(Meritor w/ one sw)
B6.7 - Driver Controlled Locking Differential - RR Axle (Meritor w/ one sw)
Design 368
L9 - Driver Controlled Locking Differential - RR Axle
(Meritor w/ one sw)
L9 - Driver Controlled Locking Differential - RR Axle (Meritor w/ one sw)
Design 369
B6.7 - Rear Suspension Pressure Monitoring (Virtual
Gauge)
B6.7 - Rear Suspension Pressure Monitoring (Virtual Gauge) Design 370
L9 - Rear Suspension Pressure Monitoring (Auxiliary
Gauge)
L9 - Rear Suspension Pressure Monitoring (Auxiliary Gauge) Design 372
L9 - Rear Suspension Pressure Monitoring (Virtual
Gauge)
L9 - Rear Suspension Pressure Monitoring (Virtual Gauge) Design 374
L9 - Seatbelt Reminder (Warning)(Driver only)
L9 - Seatbelt Reminder (Warning)(Driver only) Design 376
L9 - Seatbelt Reminder (Warning)(Driver & Passenger
in parallel)
L9 - Seatbelt Reminder (Warning)(Driver & Passenger in parallel) Design 377
L9 - TEM _Electric Trailer Brake Controller Activated
Stop LT
L9 - TEM _Electric Trailer Brake Controller Activated Stop LT Design 378
TABLE OF CONTENTS
xviL9 - Trailer Interface (Lighting) – BLUNT CUT (Part of
Electric Trailer Brakes)
L9 - Trailer Interface (Lighting) – BLUNT CUT (Part of Electric Trailer Brakes)
Design 379
B6.7 - Transmission (Allison 3K/4K)
B6.7 - Transmission (Allison 3K/4K) Design 380
B6.7 - Transmission - MODE Selection
B6.7 - Transmission - MODE Selection Design 382
L9 - Allision without Switch and with Confirmation
Telltale
L9 - Allision without Switch and with Confirmation Telltale Design 383
L9 - Transmission (Allison 3K/4K)
L9 - Transmission (Allison 3K/4K) Design 385
L9 - Transmission - MODE Selection
L9 - Transmission - MODE Selection Design 387
B6.7 - Transmission Shifter (Stalk Shifter Allison)
B6.7 - Transmission Shifter (Stalk Shifter Allison) Design 388
L9 - Transmission Shifter (Stalk Shifter Allison)
L9 - Transmission Shifter (Stalk Shifter Allison) Design 390
B6.7 - Windshield Washer Pump
B6.7 - Windshield Washer Pump Design 392
B6.7 - Windshield Washer Pump & Low Fluid Sensor
B6.7 - Windshield Washer Pump & Low Fluid Sensor Design 394
B6.7 - Windshield Wipers
B6.7 - Windshield Wipers Design 396
L9 - Windshield Washer Pump
L9 - Windshield Washer Pump Design 397
L9 - Windshield Washer Pump & Low Fluid Sensor
L9 - Windshield Washer Pump & Low Fluid Sensor Design 399
L9 - Windshield Wipers
L9 - Windshield Wipers Design 401
B6.7 - Battery International (4) 12V
B6.7 - Battery International (4) 12V Design 402
B6.7 - Starting Aid (Grid Heater)
B6.7 - Starting Aid (Grid Heater) Design 403
L9 - Battery International (4) 12V
L9 - Battery International (4) 12V Design 404
L9 - Starting Aid (Grid Heater)
L9 - Starting Aid (Grid Heater) Design 405
B6.7 - Delco Remy 28SI Alternator W/Sensor
B6.7 - Delco Remy 28SI Alternator W/Sensor Design 406
TABLE OF CONTENTS
xviiB6.7 - Leece-Neville AVI160-210A/240A Alternator
W/Sensor
B6.7 - Leece-Neville AVI160-210A/240A Alternator W/Sensor Design 407
L9 - Bosch LH160_LH200 Alternator
L9 - Bosch LH160_LH200 Alternator Design 408
L9 - Delco Remy 28SI Alternator W/Sensor
L9 - Delco Remy 28SI Alternator W/Sensor Design 410
L9 - Delco Remy 36SI Alternator W/Sensor
L9 - Delco Remy 36SI Alternator W/Sensor Design 412
L9 - Leece-Neville AVI160-210A/240A Alternator
W/Sensor
L9 - Leece-Neville AVI160-210A/240A Alternator W/Sensor Design 413
L9 - Leece-Neville - LN 325A Alternator W/Sensor
L9 - Leece-Neville - LN 325A Alternator W/Sensor Design 414
B6.7 - Cranking Request (w/ Key Switch w/ BCM)
B6.7 - Cranking Request (w/ Key Switch w/ BCM) Design 415
B6.7 - Cranking (Starter) GEN4 BCM W/O Thermal
Overcrank
B6.7 - Cranking (Starter) GEN4 BCM W/O Thermal Overcrank Design 417
L9 - Cranking Request (w/ Key Switch w/ BCM)
L9 - Cranking Request (w/ Key Switch w/ BCM) Design 418
L9 - Cranking (Starter) GEN4 BCM W/O Thermal
Overcrank
L9 - Cranking (Starter) GEN4 BCM W/O Thermal Overcrank Design 420
L9 - Cranking (Starter) GEN4 BCM W/ Thermal
Overcrank - External Switch
L9 - Cranking (Starter) GEN4 BCM W/ Thermal Overcrank - External Switch
Design 421
B6.7 - Clutch Monitoring (High and Low Switch to
BCM)
B6.7 - Clutch Monitoring (High and Low Switch to BCM) Design 422
B6.7 - Starter Interlocks (BCM Controlled with Input
from Allison 3K/4K TCM)
B6.7 - Starter Interlocks (BCM Controlled with Input from Allison 3K/4K TCM)
Design 423
Crank Inhibit (with ECM --> BCM ONLY)
Crank Inhibit (with ECM --> BCM ONLY) Design 425
L9 - Clutch Monitoring (High and Low Switch to BCM)
L9 - Clutch Monitoring (High and Low Switch to BCM) Design 426
L9 - Starter Interlocks (BCM Controlled with Input
L9 - Starter Interlocks (BCM Controlled with Input from Allison 3K/4K TCM)
Design 427
TABLE OF CONTENTS
xviiiStarter Interlock (BCM HSD controlled W/ Clutch SW &
N/Auto SS)
Starter Interlock (BCM HSD controlled W/ Clutch SW & N/Auto SS) Design 429
Connectors 430
Part Assembly List
Connector Assembly List 1403
Index 1728
