International Truck MV Series Interactive Schematics 00000018834 2025
Brand: International, Navistar
Type of Manual: Interactive Schematics
Model: International MV Series Truck
Built 12/10/2021 To 12/31/2025
Part Number: 00000018834
Publication Date: 2025
Number of Pages: 3448 Pages
B6.7/L9 - Body Control Module (BCM)
B6.7/L9 - Body Control Module (BCM) Design 1
B6.7 - ABS Proprietary J1939
B6.7 - ABS Proprietary J1939 Design 9
B6.7 - Body Standard J1939 (250Kbps) - 05/26/2025
and Newer Models
B6.7 - Body Standard J1939 (250Kbps) - 05/26/2025 and Newer Models
Design 10
B6.7 - Body Standard J1939 (250Kbps) - 12/10/2021-
05/25/2025
B6.7 - Body Standard J1939 (250Kbps) - 12/10/2021-05/25/2025 Design 11
B6.7 - Cab Standard J1939 (250Kbps)
B6.7 - Cab Standard J1939 (250Kbps) Design 12
B6.7 - Engine Proprietary J1939
B6.7 - Engine Proprietary J1939 Design 13
B6.7 - Fusion Proprietary J1939
B6.7 - Fusion Proprietary J1939 Design 14
B6.7 - Low Speed (125 kbps) J1939
B6.7 - Low Speed (125 kbps) J1939 Design 15
B6.7 - Powertrain Standard J1939 (500kbps) -
06/30/2025 and Newer Models
B6.7 - Powertrain Standard J1939 (500kbps) - 06/30/2025 and Newer Models
Design 16
12/10/2021 - 06/29/2025 Models
B6.7 - Powertrain Standard J1939 (500kbps) - 12/10/2021 - 06/29/2025 Models
Design 17
B6.7 - Telematics J1708
B6.7 - Telematics J1708 Design 18
B6.7 - 2017-2027 N2 Proprietary J1939
B6.7 - 2017-2027 N2 Proprietary J1939 Design 19
L9 - ABS Proprietary J1939
L9 - ABS Proprietary J1939 Design 20
L9 - Body Standard J1939 (250Kbps) - 05/26/2025 and
Newer Models
L9 - Body Standard J1939 (250Kbps) - 05/26/2025 and Newer Models Design 21
L9 - Body Standard J1939 (250Kbps) - 12/10/2021-
05/25/2025
L9 - Body Standard J1939 (250Kbps) - 12/10/2021-05/25/2025 Design 22
L9 - Cab Standard J1939 (250Kbps)
L9 - Cab Standard J1939 (250Kbps) Design 23
L9 - Engine Proprietary J1939
L9 - Engine Proprietary J1939 Design 24
iL9 - Fusion Proprietary J1939
L9 - Fusion Proprietary J1939 Design 25
L9 - Low Speed J1939 (125kbps)
L9 - Low Speed J1939 (125kbps) Design 26
L9 - Powertrain Standard J1939 (500kbps) - 06/30/2025
and Newer Models
L9 - Powertrain Standard J1939 (500kbps) - 06/30/2025 and Newer Models
Design 27
L9 - Powertrain Standard J1939 (500kbps) - 12/10/2021
- 06/29/2025 Models
L9 - Powertrain Standard J1939 (500kbps) - 12/10/2021 - 06/29/2025 Models
Design 28
L9 - Telematics J1708
L9 - Telematics J1708 Design 29
L9 - 2017-2027 N2 Proprietary J1939
L9 - 2017-2027 N2 Proprietary J1939 Design 30
B6.7 - Engine (Control) Cummins
B6.7 - Engine (Control) Cummins Design 31
L9 - Engine (Control) Cummins
L9 - Engine (Control) Cummins Design 32
B6.7/L9 - GEN IV Cluster (Monitor)
B6.7/L9 - GEN IV Cluster (Monitor) Design 33
B6.7/L9 - Instrument Cluster (Premium)
B6.7/L9 - Instrument Cluster (Premium) Design 34
B6.7/L9 - Instrument Cluster (Standard)
B6.7/L9 - Instrument Cluster (Standard) Design 36
B6.7/L9 - Instrument Cluster - Bulb Check
B6.7/L9 - Instrument Cluster - Bulb Check Design 37
B6.7/L9 - Instrument Cluster - Request and Status
B6.7/L9 - Instrument Cluster - Request and Status Design 38
B6.7/L9 - Ground Splice Packs 1022 & 1023
B6.7/L9 - Ground Splice Packs 1022 & 1023 Design 39
B6.7/L9 - Ground Splice Pack 1027
B6.7/L9 - Ground Splice Pack 1027 Design 40
B6.7/L9 - Interior Dual Post Ground Stud-Cowl Wall
B6.7/L9 - Interior Dual Post Ground Stud-Cowl Wall Design 41
B6.7/L9 - ZVR Splice Packs 1620
B6.7/L9 - ZVR Splice Packs 1620 Design 42
B6.7 - Center Chassis Ground Splice Packs
8802/8805/8807/8809
B6.7 - Center Chassis Ground Splice Packs 8802/8805/8807/8809 Design 43
iiL9 - Center Chassis Ground Splice Packs
8802/8805/8807/8809
L9 - Center Chassis Ground Splice Packs 8802/8805/8807/8809 Design 44
B6.7 - Forward Chassis Ground Splice Pack 8800
B6.7 - Forward Chassis Ground Splice Pack 8800 Design 45
B6.7/L9 - Forward Chassis Splice Pack 8801
B6.7/L9 - Forward Chassis Splice Pack 8801 Design 46
L9 - Forward Chassis Ground Splice Pack 8800
L9 - Forward Chassis Ground Splice Pack 8800 Design 47
B6.7 - Engine Ground Distribution - Ring Terminals
B6.7 - Engine Ground Distribution - Ring Terminals Design 48
B6.7 - Engine Ground Distribution- Splice Packs
B6.7 - Engine Ground Distribution- Splice Packs Design 49
B6.7 - Powertrain ZVR Splice Pack 6747
B6.7 - Powertrain ZVR Splice Pack 6747 Design 50
B6.7 - Power Train Splice Pack 6704
B6.7 - Power Train Splice Pack 6704 Design 51
L9 - Powertrain Ground Splice Packs 6704 & 6704B
L9 - Powertrain Ground Splice Packs 6704 & 6704B Design 52
L9 - Powertrain ZVR Splice Pack 6702
L9 - Powertrain ZVR Splice Pack 6702 Design 53
L9 - Powertrain ZVR Splice Pack 6747
L9 - Powertrain ZVR Splice Pack 6747 Design 54
B6.7/L9 - Lighting Control Module
B6.7/L9 - Lighting Control Module Design 55
B6.7 - Aftertreatment PDM
B6.7 - Aftertreatment PDM Design 57
L9 - Aftertreatment PDM
L9 - Aftertreatment PDM Design 58
B6.7 - Auxilary Power Fuse
B6.7 - Auxilary Power Fuse Design 59
L9 - Auxilary Power Fuse
L9 - Auxilary Power Fuse Design 60
B6.7/L9 - Chassis PDM
B6.7/L9 - Chassis PDM Design 61
B6.7/L9 - Battery Feed
B6.7/L9 - Battery Feed Design 62
B6.7/L9 - Interior PDM Chart
B6.7/L9 - Interior PDM Chart Design 63
B6.7/L9 - Key Switch Accessory
B6.7/L9 - Key Switch Accessory Design 64
iiiB6.7/L9 - Key Switch Ignition
B6.7/L9 - Key Switch Ignition Design 65
B6.7/L9 - Relays - Grid Management
B6.7/L9 - Relays - Grid Management Design 66
B6.7/L9 - ABS CAN Splice Pack - 1410
B6.7/L9 - ABS CAN Splice Pack - 1410 Design 67
B6.7/L9 - Panel Light Dimmer Splice Pack - 1021
B6.7/L9 - Panel Light Dimmer Splice Pack - 1021 Design 68
B6.7/L9 - Park / Turn Lights Splice Packs
1623/1625/400
B6.7/L9 - Park / Turn Lights Splice Packs 1623/1625/400 Design 69
B6.7 - Underhood PDM
B6.7 - Underhood PDM Design 70
L9 - Underhood PDM
L9 - Underhood PDM Design 71
Air Horn (Highway) W/Hardwired Switch
Air Horn (Highway) W/Hardwired Switch Design 72
B6.7/L9 - Radio
B6.7/L9 - Radio Design 73
B6.7/L9 - Radio w/Bluetooth
B6.7/L9 - Radio w/Bluetooth Design 74
B6.7/L9 - Radio w/Bluetooth without Steering Wheel
Pod
B6.7/L9 - Radio w/Bluetooth without Steering Wheel Pod Design 76
B6.7/L9 - Radio w/Steering Wheel Pod
B6.7/L9 - Radio w/Steering Wheel Pod Design 77
B6.7/L9 - Speakers: Four Speakers Daycab BT n/QC
B6.7/L9 - Speakers:Four Speakers Daycab BT n/QC Design 79
B6.7/L9 - Speakers: Four Speakers Daycab n/BT n/QC
B6.7/L9 - Speakers:Four Speakers Daycab n/BT n/QC Design 80
B6.7/L9 - Speakers: Four Speakers Daycab n/BT w/QC
B6.7/L9 - Speakers:Four Speakers Daycab n/BT w/QC Design 81
B6.7/L9 - Speakers: Four Speakers Daycab w/BT w/QC
B6.7/L9 - Speakers:Four Speakers Daycab w/BT w/QC Design 82
B6.7/L9 - Speakers: Two Speakers Daycab BT n/QC
B6.7/L9 - Speakers:Two Speakers Daycab BT n/QC Design 83
B6.7/L9 - Speakers: Two Speakers Daycab n/BT n/QC
B6.7/L9 - Speakers:Two Speakers Daycab n/BT n/QC Design 84
B6.7/L9 - Speakers: Two Speakers n/BT w/QC
B6.7/L9 - Speakers:Two Speakers n/BT w/QC Design 85
B6.7/L9 - Speakers: Two Speakers w/BT w/QC
B6.7/L9 - Speakers:Two Speakers w/BT w/QC Design 86
ivB6.7/L9 - Auxiliary Power (40A) HSD
B6.7/L9 - Auxiliary Power (40A) HSD Design 87
B6.7 - Backup Alarm (From Relay to 5 Pin Daisy Chain
Backup Alarm Plugs in)
B6.7 - Backup Alarm (From Relay to 5 Pin Daisy Chain Backup Alarm Plugs in)
Design 88
to Backup Alarm W/ Extension)
B6.7 - Backup Alarm (From Relay to 5 Pin Daisy Chain to Backup Alarm W/
Extension) Design 89
to Backup Alarm)
B6.7 - Backup Alarm (From Relay to 5 Pin Daisy Chain to Backup Alarm)
Design 90
Chain. Backup Alarm Plugs in W/ Extension)
B6.7 - Backup Alarm (From Relay to 5 Pin Daisy Chain. Backup Alarm Plugs in
W/ Extension) Design 91
B6.7 - Back-Up Alarm (Automatic) W/O Tailboard
B6.7 - Back-Up Alarm (Automatic) W/O Tailboard Design 92
B6.7 - Back-Up Alarm (Automatic) W/ Tailboard
B6.7 - Back-Up Alarm (Automatic) W/ Tailboard Design 93
B6.7 - Back-Up Alarm (Manual) W/O Tailboard
B6.7 - Back-Up Alarm (Manual) W/O Tailboard Design 94
B6.7 - Back-Up Alarm (Manual) W/ Tailboard
B6.7 - Back-Up Alarm (Manual) W/ Tailboard Design 95
L9 - Backup Alarm (From Relay to 5 Pin Daisy Chain
L9 - Backup Alarm (From Relay to 5 Pin Daisy Chain Backup Alarm Plugs in)
Design 96
L9 - Backup Alarm (From Relay to 5 Pin Daisy Chain to Backup Alarm W/
Extension) Design 97
to Backup Alarm)
L9 - Backup Alarm (From Relay to 5 Pin Daisy Chain to Backup Alarm) Design 98
L9 - Backup Alarm (From Relay to 5 Pin Daisy Chain.
L9 - Backup Alarm (From Relay to 5 Pin Daisy Chain. Backup Alarm Plugs in W/
Extension) Design 99
L9 - Back-Up Alarm (Automatic) W/O Tailboard
L9 - Back-Up Alarm (Automatic) W/O Tailboard Design 100
L9 - Back-Up Alarm (Automatic) W/ Tailboard
vL9 - Back-Up Alarm (Automatic) W/ Tailboard Design 101
L9 - Back-Up Alarm (Manual) W/O Tailboard
L9 - Back-Up Alarm (Manual) W/O Tailboard Design 102
L9 - Back-Up Alarm (Manual) W/ Tailboard
L9 - Back-Up Alarm (Manual) W/ Tailboard Design 104
B6.7/L9 - Banana Plugs Receptacle
B6.7/L9 - Banana Plugs Receptacle Design 106
B6.7/L9 - Surround View (Camera Display, 1 Camera
EOF, Prewire)
B6.7/L9 - Surround View (Camera Display, 1 Camera EOF, Prewire) Design 107
B6.7/L9 - CB Radio Power Only
B6.7/L9 - CB Radio Power Only Design 108
B6.7/L9 - CB Radio Power Only (Single Antenna)
B6.7/L9 - CB Radio Power Only (Single Antenna) Design 109
B6.7/L9 - Cigar Lighter
B6.7/L9 - Cigar Lighter Design 110
B6.7/L9 - Cigar Lighter Aux APO
B6.7/L9 - Cigar Lighter Aux APO Design 111
B6.7/L9 - Cigar LighterB6.7/L9 - Cigar Lighter- Design 114
B6.7/L9 - Forward Auxiliary Power Source (1 APO)
B6.7/L9 - Forward Auxiliary Power Source (1 APO) Design 115
B6.7/L9 - Forward Auxiliary Power Source (2 APO)
B6.7/L9 - Forward Auxiliary Power Source (2 APO) Design 119
B6.7/L9 - Forward Auxiliary Power Source (3 APO)
B6.7/L9 - Forward Auxiliary Power Source (3 APO) Design 125
B6.7/L9 - Standard APO
B6.7/L9 - Standard APO Design 129
B6.7/L9 - Standard APO and Aux APO
B6.7/L9 - Standard APO and Aux APO Design 130
B6.7/L9 - Cruise Control (W/ One Telltale 10 Pin)
B6.7/L9 - Cruise Control (W/ One Telltale 10 Pin) Design 133
B6.7/L9 - Cruise Control (W/ One Telltale 4 Pin)
B6.7/L9 - Cruise Control (W/ One Telltale 4 Pin) Design 135
B6.7/L9 - Vehicle Speed Control (Cruise Control) 10
Pin
B6.7/L9 - Vehicle Speed Control (Cruise Control) 10 Pin Design 137
B6.7/L9 - Vehicle Speed Control (Cruise Control) 4 Pin
B6.7/L9 - Vehicle Speed Control (Cruise Control) 4 Pin Design 138
viB6.7/ L9 - Vehicle Speed Control (Cruise Control)
(Steering Wheel Controls) (No PIM)
B6.7/ L9 - Vehicle Speed Control (Cruise Control) (Steering Wheel Controls) (No
PIM) Design 139
B6.7/L9 - Door Ajar Reminder (Entry/Exit) 2 Door
B6.7/L9 - Door Ajar Reminder (Entry/Exit) 2 Door Design 140
B6.7/L9 - Door Ajar Reminder(Entry /Exit): 4 Door
B6.7/L9 - Door Ajar Reminder(Entry /Exit):4 Door Design 141
B6.7/L9 - Door Pod Module (2 Door)
B6.7/L9 - Door Pod Module (2 Door) Design 142
B6.7/L9 - Door Pod Module (4 Door)
B6.7/L9 - Door Pod Module (4 Door) Design 143
B6.7/L9 - Mirrors (Heated) (Door Pod Actuated, 2 Cab
and 1 Hood Mirror Right Side Only)
B6.7/L9 - Mirrors (Heated) (Door Pod Actuated, 2 Cab and 1 Hood Mirror Right
Side Only) Design 144
and 2 Hood Mirrors)
B6.7/L9 - Mirrors (Heated) (Door Pod Actuated, 2 Cab and 2 Hood Mirrors)
Design 146
B6.7/L9 - Mirrors (Heated) (MUX Switch, 2 Cab and 2
Hood Mirrors)
B6.7/L9 - Mirrors (Heated) (MUX Switch, 2 Cab and 2 Hood Mirrors) Design 148
B6.7/L9 - Mirrors (Power) Control Switch Actuated
B6.7/L9 - Mirrors (Power) Control Switch Actuated Design 150
B6.7 - City Horn W/10PIN CLK
B6.7 - City Horn W/10PIN CLK Design 152
B6.7 - City Horn W/4PIN CLK
B6.7 - City Horn W/4PIN CLK Design 154
L9 - City Horn W/10PIN CLK
L9 - City Horn W/10PIN CLK Design 156
L9 - City Horn W/4PIN CLK
L9 - City Horn W/4PIN CLK Design 158
B6.7/L9 - Heated Windshield
B6.7/L9 - Heated Windshield Design 160
B6.7/ L9 - Heated Windshield (W/ DS Heating Grid)
B6.7/ L9 - Heated Windshield (W/ DS Heating Grid) Design 161
B6.7/L9 - Hood Switch
B6.7/L9 - Hood Switch Design 162
B6.7/L9 - Multiplexed Switch Pack (Primary Switch)
B6.7/L9 - Multiplexed Switch Pack (Primary Switch) Design 164
B6.7/L9 - Real Time Clock
viiB6.7/L9 - Real Time Clock Design 165
B6.7/L9 - Remote Keyless Access
B6.7/L9 - Remote Keyless Access Design 166
B6.7 - Over The Air Electrical I/O (OnCommand Link /
N2 Module)
B6.7 - Over The Air Electrical I/O (OnCommand Link / N2 Module) Design 167
B6.7/L9 - Telematics (Omnivision w/J1939)
B6.7/L9 - Telematics (Omnivision w/J1939) Design 168
B6.7/L9 - Telematics (Peoplenet PMG)
B6.7/L9 - Telematics (Peoplenet PMG) Design 169
B6.7/L9 - Telematics (PEOPLE NET MD)
B6.7/L9 - Telematics (PEOPLE NET MD) Design 170
B6.7/L9 - Telematics (XATANET W/J1708)
B6.7/L9 - Telematics (XATANET W/J1708) Design 171
B6.7/L9 - Telematics (XATANET W/J1939)
B6.7/L9 - Telematics (XATANET W/J1939) Design 172
B6.7/L9 - Telematics (Zonar)
B6.7/L9 - Telematics (Zonar) Design 173
L9 - Over The Air Electrical I/O (OnCommand Link / N2
Module)
L9 - Over The Air Electrical I/O (OnCommand Link / N2 Module) Design 174
N2 Module) (2024 & Newer Models)
B6.7 - Over The Air Electrical I/O (OnCommand Link / N2 Module) (2024 & Newer
Models) Design 175
B6.7/L9 - Over The Air Electrical I/O (OnCommand
Link / N2 Module)
B6.7/L9 - Over The Air Electrical I/O (OnCommand Link / N2 Module) Design 176
B6.7/L9 - Over the Air Programming (OnCommand
Link / N2 Module)
B6.7/L9 - Over the Air Programming (OnCommand Link / N2 Module) Design 177
L9 - Over The Air Electrical I/O (OnCommand Link / N2 Module) (2024 & Newer
Models) Design 178
B6.7/L9 - Telematics (Aftermarket W/ 3 TMC
Connector)
B6.7/L9 - Telematics (Aftermarket W/ 3 TMC Connector) Design 179
B6.7/L9 - Theft Deterrent (Without additional relay)
B6.7/L9 - Theft Deterrent (Without additional relay) Design 181
B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 AutoLocate -
1 Repeater)
B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 AutoLocate - 1 Repeater) Design 182
viiiB6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)
B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater) Design 190
Repeater)(Option 2)
B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(Option 2) Design 194
B6.7/L9 - Aux Power (USB) - 1 USB A, 1 USB C
B6.7/L9 - Aux Power (USB) - 1 USB A, 1 USB C Design 198
B6.7/L9 - Aux Power (USB) - 2 USB A, 2 USB C
B6.7/L9 - Aux Power (USB) - 2 USB A, 2 USB C Design 203
B6.7/L9 - Aux Power (USB) - 3 USB A, 3 USB C
B6.7/L9 - Aux Power (USB) - 3 USB A, 3 USB C Design 213
B6.7/L9 - One USB
B6.7/L9 - One USB Design 222
B6.7/L9 - Two USB
B6.7/L9 - Two USB Design 223
B6.7/L9 - Vehicle Alarm System
B6.7/L9 - Vehicle Alarm System Design 225
B6.7/L9 - Vehicle Sleep Mode
B6.7/L9 - Vehicle Sleep Mode Design 226
B6.7/L9 2-Way Radio
B6.7/L9 2-Way Radio Design 227
Diesel Particulate Filter (DPF) (Regen Switch Only)
Diesel Particulate Filter (DPF) (Regen Switch Only) Design 229
Diesel Particulate Filter (DPF) (With Monostable Inhibit
SW)
Diesel Particulate Filter (DPF) (With Monostable Inhibit SW) Design 230
Diesel Particulate Filter (DPF) (W/ Bi-Stable Inhibit
SW)
Diesel Particulate Filter (DPF) (W/ Bi-Stable Inhibit SW) Design 231
B6.7/L9 - DPF - Regen Switch Only
B6.7/L9 - DPF - Regen Switch Only Design 232
B6.7/L9 - DPF - With Bistable Inhibit Sw
B6.7/L9 - DPF - With Bistable Inhibit Sw Design 233
B6.7/L9 - DPF - With Monostable Inhibit Sw
B6.7/L9 - DPF - With Monostable Inhibit Sw Design 234
B6.7 - Selective Catalytic Reduction (SCR)
B6.7 - Selective Catalytic Reduction (SCR) Design 235
B6.7 - Selective Catalytic Reduction (SCR): 2024 and
newer models
B6.7 - Selective Catalytic Reduction (SCR):2024 and newer models Design 237
L9 - Selective Catalytic Reduction (SCR)
L9 - Selective Catalytic Reduction (SCR) Design 239
ixL9 - Selective Catalytic Reduction (SCR): 2024 and
newer models
L9 - Selective Catalytic Reduction (SCR):2024 and newer models Design 241
B6.7/L9 - Adjustable Engine Speed Control (PTO) 10-
pin
B6.7/L9 - Adjustable Engine Speed Control (PTO) 10-pin Design 243
B6.7/L9 - Adjustable Engine Speed Control (PTO) 4-
pin
B6.7/L9 - Adjustable Engine Speed Control (PTO) 4-pin Design 245
B6.7/ L9 - Engine Idle Increment/Decrement (Steering
Wheel Controls)
B6.7/ L9 - Engine Idle Increment/Decrement (Steering Wheel Controls)
Design 246
B6.7/ L9 - Engine Speed Control (PTO) (Steering
Wheel Controls)
B6.7/ L9 - Engine Speed Control (PTO) (Steering Wheel Controls) Design 247
B6.7 - Auxiliary Air Solenoids (1 Normally Closed)
B6.7 - Auxiliary Air Solenoids (1 Normally Closed) Design 248
B6.7 - Auxillary Air Solenoids Normally Open
B6.7 - Auxillary Air Solenoids Normally Open Design 249
L9 - Auxiliary Air Solenoids (1 Normally Closed)
L9 - Auxiliary Air Solenoids (1 Normally Closed) Design 250
L9 - Auxiliary Air Solenoids (2 Normally Closed)
L9 - Auxiliary Air Solenoids (2 Normally Closed) Design 251
L9 - Auxiliary Air Solenoids (3 Normally Closed)
L9 - Auxiliary Air Solenoids (3 Normally Closed) Design 254
B6.7 - Altec (N/BB & W/Manual XMSN & W/ CUMMINS
Engine)
B6.7 - Altec (N/BB & W/Manual XMSN & W/ CUMMINS Engine) Design 255
Engine) (2024 & Newer Models)
B6.7 - Altec (N/BB & W/Manual XMSN & W/ CUMMINS Engine) (2024 & Newer
Models) Design 258
B6.7 - Body Builder - Altec (N/BB & W/1K2K Trans)
B6.7 - Body Builder - Altec (N/BB & W/1K2K Trans) Design 261
B6.7 - Body Builder - Altec (N/BB & W/3K4K Trans &
W/ CUMMINS Engine)
B6.7 - Body Builder - Altec (N/BB & W/3K4K Trans & W/ CUMMINS Engine)
Design 264
B6.7 - Body Builder - Altec (W/BB & W/Manual Trans &
W/ CUMMINS Engine)
B6.7 - Body Builder - Altec (W/BB & W/Manual Trans & W/ CUMMINS Engine)
Design 267
xB6.7 - Body Builder - Altec (W/BB & W/Manual Trans &
W/ CUMMINS Engine): 2021-2024
Engine):2021-2024 Design 273
B6.7 - Body Builder - Altec (W/BB & W/1K2K Trans)
B6.7 - Body Builder - Altec (W/BB & W/1K2K Trans) Design 279
B6.7 - Body Builder - Altec (W/BB & W/3K4K Trans &
W/ CUMMINS Engine)
B6.7 - Body Builder - Altec (W/BB & W/3K4K Trans & W/ CUMMINS Engine)
Design 285
L9 - Body Builder - Altec (N/BB & W/Manual XMSN &
W/ CUMMINS Engine)
L9 - Body Builder - Altec (N/BB & W/Manual XMSN & W/ CUMMINS Engine)
Design 291
Engine):2021-2024 Design 294
L9 - Body Builder - Altec (N/BB & W/1K2K Trans)
L9 - Body Builder - Altec (N/BB & W/1K2K Trans) Design 297
L9 - Body Builder - Altec (N/BB & W/3K4K Trans & W/
CUMMINS Engine)
L9 - Body Builder - Altec (N/BB & W/3K4K Trans & W/ CUMMINS Engine)
Design 299
L9 - Body Builder - Altec (W/BB & W/Manual Trans &
W/ CUMMINS Engine)
L9 - Body Builder - Altec (W/BB & W/Manual Trans & W/ CUMMINS Engine)
Design 301
Engine):2021-2024 Design 307
L9 - Body Builder - Altec (W/BB & W/1K2K Trans)
L9 - Body Builder - Altec (W/BB & W/1K2K Trans) Design 313
L9 - Body Builder - Altec (W/BB & W/3K4K Trans & W/
CUMMINS Engine)
L9 - Body Builder - Altec (W/BB & W/3K4K Trans & W/ CUMMINS Engine)
Design 318
B6.7/L9 - Auxiliary Power (40A) HSD 1
B6.7/L9 - Auxiliary Power (40A) HSD 1 Design 323
B6.7/L9 - Body Builder Aux Power (In Cab, BOC, or
EOF)
B6.7/L9 - Body Builder Aux Power (In Cab, BOC, or EOF) Design 324
B6.7/L9 - Dual Auxiliary Power with Interlock
B6.7/L9 - Dual Auxiliary Power with Interlock Design 327
xiB6.7 - Body Builder Lighting - Separate Turn and Stop
Lamps (Blunt Cut)
B6.7 - Body Builder Lighting - Separate Turn and Stop Lamps (Blunt Cut)
Design 328
Lamps (Blunt Cut) Option2
B6.7 - Body Builder Lighting - Separate Turn and Stop Lamps (Blunt Cut) Option2
Design 329
L9 - Body Builder Lighting - Combined Turn and Stop
Lamps (Automatic)
L9 - Body Builder Lighting - Combined Turn and Stop Lamps (Automatic)
Design 330
Lamps (Manual) Option2
L9 - Body Builder Lighting - Combined Turn and Stop Lamps (Manual) Option2
Design 332
L9 - Body Builder Lighting - Separate Turn and Stop
Lamps (Blunt Cut)
L9 - Body Builder Lighting - Separate Turn and Stop Lamps (Blunt Cut)
Design 336
L9 - Body Builder Lighting - Separate Turn and Stop Lamps (Blunt Cut) Option2
Design 337
B6.7/L9 - Body Builder Prewire (8 Wire Firewall Pass
through)
B6.7/L9 - Body Builder Prewire (8 Wire Firewall Pass through) Design 338
B6.7 - I/O Expansion
B6.7 - I/O Expansion Design 339
L9 - I/O Expansion
L9 - I/O Expansion Design 340
B6.7 - Powertrain Body Builder Connector (12XAT)
B6.7 - Powertrain Body Builder Connector (12XAT) Design 341
B6.7 - Powertrain Body Builder Connector (12XBM)
B6.7 - Powertrain Body Builder Connector (12XBM) Design 342
L9 - Powertrain Body Builder Connector (12XAT)
L9 - Powertrain Body Builder Connector (12XAT) Design 343
L9 - Powertrain Body Builder Connector (12XBM)
L9 - Powertrain Body Builder Connector (12XBM) Design 344
B6.7 - Power Lift Gate
B6.7 - Power Lift Gate Design 345
L9 - Power Lift Gate
L9 - Power Lift Gate Design 346
xiiB6.7/L9 - DLB - Remote Power Modules (1 RPM n/
Switch Packs)
B6.7/L9 - DLB - Remote Power Modules (1 RPM n/ Switch Packs) Design 347
B6.7/L9 - DLB - Remote Power Modules (1 RPM w/
Switch Packs) Option2
B6.7/L9 - DLB - Remote Power Modules (1 RPM w/ Switch Packs) Option2
Design 350
Switch Packs) Option 1
B6.7/L9 - DLB - Remote Power Modules (1 RPM w/ Switch Packs) Option 1
Design 352
B6.7/L9 - DLB - Remote Power Modules (2 RPM n/
Switch Pack)
B6.7/L9 - DLB - Remote Power Modules (2 RPM n/ Switch Pack) Design 355
B6.7/L9 - DLB - Remote Power Modules (2 RPM w/
Switch Packs)
B6.7/L9 - DLB - Remote Power Modules (2 RPM w/ Switch Packs) Design 359
B6.7/L9 - DLB - Remote Power Modules (3 RPM w/
Swtich Packs)
B6.7/L9 - DLB - Remote Power Modules (3 RPM w/ Swtich Packs) Design 363
B6.7/L9 - DLB - Remote Power Module (3 RPM
n/Switch Pack)
B6.7/L9 - DLB - Remote Power Module (3 RPM n/Switch Pack) Design 364
B6.7 - Remote Start/Stop
B6.7 - Remote Start/Stop Design 365
B6.7 - Remote Start/Stop w/ Emergency Pump
B6.7 - Remote Start/Stop w/ Emergency Pump Design 366
L9 - Remote Start/Stop
L9 - Remote Start/Stop Design 367
L9 - Remote Start/Stop w/ Emergency Pump
L9 - Remote Start/Stop w/ Emergency Pump Design 368
B6.7 - Transmission I/O (Allison Gen 6 1K/2K W/ Body
Builder)
B6.7 - Transmission I/O (Allison Gen 6 1K/2K W/ Body Builder) Design 369
B6.7 - Transmission I/O (Allison Gen 6 3K W/ Body
Builder)
B6.7 - Transmission I/O (Allison Gen 6 3K W/ Body Builder) Design 373
L9 - Transmission I/O (Allison Gen 6 3K W/ Body
Builder)
L9 - Transmission I/O (Allison Gen 6 3K W/ Body Builder) Design 379
B6.7 - Transmission Power Take Off (Auto Trans
Single PTO w/21 Parameters)
B6.7 - Transmission Power Take Off (Auto Trans Single PTO w/21 Parameters)
Design 385
xiiiB6.7 - Transmission Power Take Off (Auto Trans with
Lectradrive)
B6.7 - Transmission Power Take Off (Auto Trans with Lectradrive) Design 386
B6.7 - Transmission Power Take Off (Lectrashift PTO
with Manual Trans)
B6.7 - Transmission Power Take Off (Lectrashift PTO with Manual Trans)
Design 387
B6.7 - Transmission Power Take Off (Manual Trans
Single PTO w/ 21 Parameters)
B6.7 - Transmission Power Take Off (Manual Trans Single PTO w/ 21
Parameters) Design 388
B6.7 - Transmission Power Take Off (Single Input
configurable pull up or pull down)
B6.7 - Transmission Power Take Off (Single Input configurable pull up or pull
down) Design 389
B6.7 - Transmission Power Take Off (Single PTO W/
RPM and Auto Trans)
B6.7 - Transmission Power Take Off (Single PTO W/ RPM and Auto Trans)
Design 390
RPM and Manual Trans)
B6.7 - Transmission Power Take Off (Single PTO W/ RPM and Manual Trans)
Design 391
B6.7 - Transmission Power Take Off (60AKG)
B6.7 - Transmission Power Take Off (60AKG) Design 392
L9 - Transmission Power Take Off (Auto Trans Single
L9 - Transmission Power Take Off (Auto Trans Single PTO w/21 Parameters)
Design 393
L9 - Transmission Power Take Off (Auto Trans with
Lectradrive)
L9 - Transmission Power Take Off (Auto Trans with Lectradrive) Design 394
L9 - Transmission Power Take Off (Lectrashift PTO
with Manual Trans)
L9 - Transmission Power Take Off (Lectrashift PTO with Manual Trans)
Design 395
L9 - Transmission Power Take Off (Manual Trans
L9 - Transmission Power Take Off (Manual Trans Single PTO w/ 21 Parameters)
Design 396
L9 - Transmission Power Take Off (Single Input
L9 - Transmission Power Take Off (Single Input configurable pull up or pull down)
Design 397
L9 - Transmission Power Take Off (Single PTO W/
RPM and Auto Trans)
xivL9 - Transmission Power Take Off (Single PTO W/ RPM and Auto Trans)
Design 398
L9 - Transmission Power Take Off (Single PTO W/ RPM and Manual Trans)
Design 399
L9 - Transmission Power Take Off (60AKG)
L9 - Transmission Power Take Off (60AKG) Design 400
Dual Brake Switch
Dual Brake Switch Design 401
B6.7/L9 - Air Dryer (Single)
B6.7/L9 - Air Dryer (Single) Design 402
B6.7/ L9 - Air Dryer (Single)
B6.7/ L9 - Air Dryer (Single) Design 403
B6.7 - Drain Valve Heater
B6.7 - Drain Valve Heater Design 409
L9 - Drain Valve Heater
L9 - Drain Valve Heater Design 415
B6.7/L9 - Antilock Brake System (ABS) - Wabco 4
Channel Implementation
B6.7/L9 - Antilock Brake System (ABS) - Wabco 4 Channel Implementation
Design 419
B6.7/L9 - Antilock Brake System (ABS)- BENDIX 4
Channel Implemenation
B6.7/L9 - Antilock Brake System (ABS)- BENDIX 4 Channel Implemenation
Design 420
B6.7 - Hydraulic Brakes System
B6.7 - Hydraulic Brakes System Design 421
B6.7/L9 - Antilock Brake Systems (ABS) (Wabco
Hydraulic 4 Channel N/ Stability)
B6.7/L9 - Antilock Brake Systems (ABS) (Wabco Hydraulic 4 Channel N/ Stability)
Design 422
Hydraulic 4 Channel W/ Stability)
B6.7/L9 - Antilock Brake Systems (ABS) (Wabco Hydraulic 4 Channel W/
Stability) Design 423
L9 - Hydraulic Brakes System
L9 - Hydraulic Brakes System Design 424
B6.7/L9 - Park Brake Controls (Air Chassis Park
Brake)
B6.7/L9 - Park Brake Controls (Air Chassis Park Brake) Design 425
B6.7/L9 - Park Brake Controls (Monitoring) W (Door
Switch City Horn Hydraulic with Lever)
B6.7/L9 - Park Brake Controls (Monitoring) W (Door Switch City Horn Hydraulic
with Lever) Design 426
xvB6.7/L9 - Park Brake Controls (Monitoring) W (Door
Switch City Horn)
B6.7/L9 - Park Brake Controls (Monitoring) W (Door Switch City Horn) Design 427
(Hydraulic with Lever)
B6.7/L9 - Park Brake Controls (Monitoring) W (Hydraulic with Lever) Design 428
B6.7/L9 - Park Brake Controls (Monitoring) (Door
B6.7/L9 - Park Brake Controls (Monitoring) (Door Switch City Horn Hydraulic with
Lever) Design 429
Switch City Horn)
B6.7/L9 - Park Brake Controls (Monitoring) (Door Switch City Horn) Design 430
B6.7/L9 - Park Brake Controls (Monitoring) (Hydraulic
with Lever)
B6.7/L9 - Park Brake Controls (Monitoring) (Hydraulic with Lever) Design 431
B6.7/L9 - Park Brake Controls (Park Brake W/ Interlock
N/ Lift Air Chassis)
B6.7/L9 - Park Brake Controls (Park Brake W/ Interlock N/ Lift Air Chassis)
Design 432
B6.7/L9 - Park Brake Controls (Straight Truck)
Intellipark
B6.7/L9 - Park Brake Controls (Straight Truck) Intellipark Design 433
B6.7/L9 - Park Brake Controls (Tractor) Intellipark
B6.7/L9 - Park Brake Controls (Tractor) Intellipark Design 434
B6.7/L9 - Park Brake Control (Monitoring) (GEN IV
BCM)
B6.7/L9 - Park Brake Control (Monitoring) (GEN IV BCM) Design 436
B6.7/L9 - Park Brake Control (Monitoring) (W/Vehicle
Speed)
B6.7/L9 - Park Brake Control (Monitoring) (W/Vehicle Speed) Design 437
B6.7/L9 - Park Brake W/Motion Alarm W/O Stationary
Alarm (SAAR)
B6.7/L9 - Park Brake W/Motion Alarm W/O Stationary Alarm (SAAR) Design 438
B6.7/L9 - Park Brake W/Motion Alarm W/Stationary
Alarm (SAAR)
B6.7/L9 - Park Brake W/Motion Alarm W/Stationary Alarm (SAAR) Design 439
B6.7/L9 - Park Brake W/O Motion Alarm W/O
B6.7/L9 - Park Brake W/O Motion Alarm W/O Stationary Alarm (SAAR)
Design 440
B6.7/L9 - Park Brake W/O Motion Alarm W/Stationary
Alarm (SAAR)
B6.7/L9 - Park Brake W/O Motion Alarm W/Stationary Alarm (SAAR) Design 441
xviB6.7 - Stability Control (Bendix Straight Truck J1939
Driven Lamp)
B6.7 - Stability Control (Bendix Straight Truck J1939 Driven Lamp) Design 442
L9 - Bendix; Tractor or Towing Truck; N/ Air SUSP;
J1939 Driven Lamp
L9 - Bendix; Tractor or Towing Truck; N/ Air SUSP; J1939 Driven Lamp
Design 443
L9 - Bendix; Tractor or Towing Truck; W/ Air SUSP;
J1939 Driven Lamp
L9 - Bendix; Tractor or Towing Truck; W/ Air SUSP; J1939 Driven Lamp
Design 444
L9 - Stability Control (Bendix Straight Truck J1939
Driven Lamp)
L9 - Stability Control (Bendix Straight Truck J1939 Driven Lamp) Design 445
B6.7 - Traction Control Bendix
B6.7 - Traction Control Bendix Design 446
L9 - Traction Control Bendix
L9 - Traction Control Bendix Design 448
Oncoming Detection (Fusion 3.0)
Oncoming Detection (Fusion 3.0) Design 449
ACC Following Mode Selection (Bendix Wingman
Fusion 3.0)
ACC Following Mode Selection (Bendix Wingman Fusion 3.0) Design 450
Adaptive Cruise Control (Fusion 3.0 N/ DIU W/LDW
Audio Mute)
Adaptive Cruise Control (Fusion 3.0 N/ DIU W/LDW Audio Mute) Design 451
Adaptive Cruise Control (Fusion 3.0 N/ DIU)
Adaptive Cruise Control (Fusion 3.0 N/ DIU) Design 452
B6.7 - Adaptive Cruise Control w/o Display (Bendix)
B6.7 - Adaptive Cruise Control w/o Display (Bendix) Design 453
B6.7/L9 - Adaptive Cruise Control (Bendix Wingman
Advanced N/ DIU)
B6.7/L9 - Adaptive Cruise Control (Bendix Wingman Advanced N/ DIU)
Design 454
B6.7/L9 - Adaptive Cruise Control (Bendix - Fusion
W/O DIU & N/ Safety Direct & Reg Speakers)
B6.7/L9 - Adaptive Cruise Control (Bendix - Fusion W/O DIU & N/ Safety Direct &
Reg Speakers) Design 455
B6.7/L9 - Adaptive Cruise Control (Bendix - Fusion 2.0
N/ Safety Direct Conn & W/ Reg Speakers)
B6.7/L9 - Adaptive Cruise Control (Bendix - Fusion 2.0 N/ Safety Direct Conn &
W/ Reg Speakers) Design 456
& W/ Safety Direct Conn & W/ Reg Speakers)
xviiB6.7/L9 - Adaptive Cruise Control (Bendix - Fusion 2.0 & W/ Safety Direct Conn &
W/ Reg Speakers) Design 458
2.8/2.9 N/ Safety Direct Conn W/ Reg Speakers)
B6.7/L9 - Adaptive Cruise Control (Bendix - Fusion 2.8/2.9 N/ Safety Direct Conn
W/ Reg Speakers) Design 460
2.8/2.9 W/ Safety Direct Conn W/ Reg Speakers)
B6.7/L9 - Adaptive Cruise Control (Bendix - Fusion 2.8/2.9 W/ Safety Direct Conn
W/ Reg Speakers) Design 462
B6.7/L9 - Adaptive Cruise Control (Fusion 2.0 & W/
Safety Direct & Reg Speakers) option 1
B6.7/L9 - Adaptive Cruise Control (Fusion 2.0 & W/ Safety Direct & Reg
Speakers) option 1 Design 464
Safety Direct & Reg Speakers) option 2
Speakers) option 2 Design 465
B6.7/L9 - Adaptive Cruise Control (Fusion 3.0 N/ DIU)
B6.7/L9 - Adaptive Cruise Control (Fusion 3.0 N/ DIU) Design 466
L9 - Adaptive Cruise Control w/o Display (Bendix)
L9 - Adaptive Cruise Control w/o Display (Bendix) Design 467
B6.7/L9 - Collision Avoidance System (Warning)
B6.7/L9 - Collision Avoidance System (Warning) Design 468
B6.7/L9 - Camera Event Recorder N/Safety Direct
Cable
B6.7/L9 - Camera Event Recorder N/Safety Direct Cable Design 469
B6.7/L9 - Camera Event Recorder W/Safety Direct
Cable
B6.7/L9 - Camera Event Recorder W/Safety Direct Cable Design 470
Camera Event Recorder N/Safety Direct Cable Design 471
Camera Event Recorder W/Safety Direct Cable Design 472
B6.7 - Lane Departure Warning - (Bendix Fusion N/
Safety Direct)
B6.7 - Lane Departure Warning - (Bendix Fusion N/ Safety Direct) Design 473
L9 - Lane Departure Warning - (Bendix Fusion N/
Safety Direct)
L9 - Lane Departure Warning - (Bendix Fusion N/ Safety Direct) Design 475
B6.7 - Air Filter Flow Restriction Monitoring (LED
Indicator)
B6.7 - Air Filter Flow Restriction Monitoring (LED Indicator) Design 477
xviiiL9 - Air Filter Flow Restriction Monitoring (LED
Indicator)
L9 - Air Filter Flow Restriction Monitoring (LED Indicator) Design 478
B6.7/L9 - Engine Block Heater
B6.7/L9 - Engine Block Heater Design 479
B6.7/L9 - Engine Fuel and Block Heaters (Purchased
Assembly)
B6.7/L9 - Engine Fuel and Block Heaters (Purchased Assembly) Design 480
B6.7/L9 - Engine Oil and Block Heaters (Purchased
Assembly)
B6.7/L9 - Engine Oil and Block Heaters (Purchased Assembly) Design 481
B6.7/L9 - Engine Oil Fuel and Block Heaters
B6.7/L9 - Engine Oil Fuel and Block Heaters Design 482
B6.7/L9 - Engine Brake Mux Switch
B6.7/L9 - Engine Brake Mux Switch Design 483
B6.7/L9 - Engine Brake W/ Stalk Shifter
B6.7/L9 - Engine Brake W/ Stalk Shifter Design 484
B6.7 - Coolant Level Monitoring (No CLA Module)
B6.7 - Coolant Level Monitoring (No CLA Module) Design 485
B6.7 - Coolant Level Monitoring (No CLA Module) (2024 & Newer Models)
Design 486
L9 - Coolant Level Monitoring (No CLA Module)
L9 - Coolant Level Monitoring (No CLA Module) Design 487
L9 - Coolant Level Monitoring (No CLA Module) (2024
& Newer Models)
L9 - Coolant Level Monitoring (No CLA Module) (2024 & Newer Models)
Design 488
B6.7 - Cooling Fan Control (Fan Override, Cummins,
No Radiator GND)
B6.7 - Cooling Fan Control (Fan Override, Cummins, No Radiator GND)
Design 489
No Radiator GND): 2024 and newer models
B6.7 - Cooling Fan Control (Fan Override, Cummins, No Radiator GND):2024 and
newer models Design 490
B6.7 - Cooling Fan Control (No Fan Override,
Cummins, No Radiator)
B6.7 - Cooling Fan Control (No Fan Override, Cummins, No Radiator) Design 491
Cummins, No Radiator): 2024 and newer models
B6.7 - Cooling Fan Control (No Fan Override, Cummins, No Radiator):2024 and
newer models Design 492
xixL9 - Cooling Fan Control (Fan Override, Cummins, No
Radiator GND)
L9 - Cooling Fan Control (Fan Override, Cummins, No Radiator GND) Design 493
L9 - Cooling Fan Control (Fan Override, Cummins, No Radiator GND):2024 and
newer models Design 494
L9 - Cooling Fan Control (No Fan Override, Cummins,
No Radiator)
L9 - Cooling Fan Control (No Fan Override, Cummins, No Radiator) Design 495
L9 - Cooling Fan Control (No Fan Override, Cummins, No Radiator):2024 and
newer models Design 496
Engine Ramp UP (60AJA W/Cummins W/ Manual
Trans)
Engine Ramp UP (60AJA W/Cummins W/ Manual Trans) Design 497
Engine Ramp Up (60AJA W/ Cummins W/ AUTO AMT)
Engine Ramp Up (60AJA W/ Cummins W/ AUTO AMT) Design 498
Engine Ramp Up (60AJE 60AJJ W/ CUMMINS W/
AUTO AMT)
Engine Ramp Up (60AJE 60AJJ W/ CUMMINS W/ AUTO AMT) Design 499
MANUAL)
Engine Ramp Up (60AJE 60AJJ W/ CUMMINS W/ MANUAL) Design 500
Engine Ramp Up (60AJG W/CUMMINS W/ AUTO AMT)
Engine Ramp Up (60AJG W/CUMMINS W/ AUTO AMT) Design 501
Engine Ramp Up (60AJG W/CUMMINS W/ MANUAL)
Engine Ramp Up (60AJG W/CUMMINS W/ MANUAL) Design 502
B6.7/L9 - Exhaust Brake Horizon (Cummins) (2024 &
Newer Models)
B6.7/L9 - Exhaust Brake Horizon (Cummins) (2024 & Newer Models) Design 503
B6.7/L9 - Exhaust Brake (Cummins)
B6.7/L9 - Exhaust Brake (Cummins) Design 504
B6.7 - Starting Aid (Grid Heater)
B6.7 - Starting Aid (Grid Heater) Design 505
B6.7 - Starting Aid (Grid Heater) (2024 & Newer
Models)
B6.7 - Starting Aid (Grid Heater) (2024 & Newer Models) Design 506
L9 - Starting Aid (Grid Heater)
L9 - Starting Aid (Grid Heater) Design 508
L9 - Starting Aid (Grid Heater) (2024 & Newer Models)
L9 - Starting Aid (Grid Heater) (2024 & Newer Models) Design 509
xxB6.7 - Vehicle Acceleration (Wired to the ECM)
B6.7 - Vehicle Acceleration (Wired to the ECM) Design 510
B6.7 - Vehicle Acceleration (w/ Two PWR Two GND &
Two STS)
B6.7 - Vehicle Acceleration (w/ Two PWR Two GND & Two STS) Design 511
L9 - Vehicle Acceleration (Wired to the ECM)
L9 - Vehicle Acceleration (Wired to the ECM) Design 512
L9 - Vehicle Acceleration (w/ Two PWR Two GND &
Two STS)
L9 - Vehicle Acceleration (w/ Two PWR Two GND & Two STS) Design 513
B6.7/L9 - Alternate Flashing (Wig Wag) - Park Brake
disables High Beams
B6.7/L9 - Alternate Flashing (Wig Wag) - Park Brake disables High Beams
Design 514
disables Wig Wag
B6.7/L9 - Alternate Flashing (Wig Wag) - Park Brake disables Wig Wag
Design 515
B6.7/L9 - Automatic Lighting (Dual Sensor
Twilight/Solar)
B6.7/L9 - Automatic Lighting (Dual Sensor Twilight/Solar) Design 516
B6.7/L9 - Automatic Lighting (Single Sensor, Twilight)
B6.7/L9 - Automatic Lighting (Single Sensor, Twilight) Design 518
B6.7 - Backup Lights (Dual Daisy with extension)
Eaton/Manual Trans
B6.7 - Backup Lights (Dual Daisy with extension) Eaton/Manual Trans Design 520
B6.7 - Backup Light (Dual Daisy Reverse LT)Allison/ZF
Trans
B6.7 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans Design 521
Allison/ZF Trans 1K/2K
B6.7 - Backup Light (Dual Daisy Reverse LT) Allison/ZF Trans 1K/2K Design 522
Allison/ZF Trans 3K/4K
B6.7 - Backup Light (Dual Daisy Reverse LT) Allison/ZF Trans 3K/4K Design 524
B6.7 - Backup Light (Dual Daisy with
extension)Allison/ZF Trans
B6.7 - Backup Light (Dual Daisy with extension)Allison/ZF Trans Design 526
B6.7 - Backup Light (Dual Reverse Light) Allison/ZF
Trans 1K/2K
B6.7 - Backup Light (Dual Reverse Light) Allison/ZF Trans 1K/2K Design 527
Trans 3K/4K
B6.7 - Backup Light (Dual Reverse Light) Allison/ZF Trans 3K/4K Design 529
xxiB6.7 - Backup Lights (Dual Daisy Reverse Light)
Eaton/Manual Trans
B6.7 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans Design 531
B6.7 - Backup Lights (Dual Daisy Reverse)
Eaton/Manual Trans
B6.7 - Backup Lights (Dual Daisy Reverse) Eaton/Manual Trans Design 532
B6.7 - Backup Lights (Dual Reverse Light)
Eaton/Manual Trans
B6.7 - Backup Lights (Dual Reverse Light) Eaton/Manual Trans Design 533
B6.7 - Backup Lights (Reverse Lights) - Dual Lights
with Procision
B6.7 - Backup Lights (Reverse Lights) - Dual Lights with Procision Design 534
B6.7 - Backup Lights (Reverse Lights) - Procision
Daisy Chain
B6.7 - Backup Lights (Reverse Lights) - Procision Daisy Chain Design 535
B6.7 - Backup Lights (Reverse Lights) (Crossmember
Dual STT N/Back Up) Allison Trans
B6.7 - Backup Lights (Reverse Lights) (Crossmember Dual STT N/Back Up)
Allison Trans Design 536
B6.7 - Backup Light Single Reverse Light Allison
1K/2K
B6.7 - Backup Light Single Reverse Light Allison 1K/2K Design 537
3K/4K
B6.7 - Backup Light Single Reverse Light Allison 3K/4K Design 539
B6.7 - Backup Light (Single Reverse Light) Allison
1K/2K
B6.7 - Backup Light (Single Reverse Light) Allison 1K/2K Design 541
3K/4K
B6.7 - Backup Light (Single Reverse Light) Allison 3K/4K Design 543
B6.7 - Backup Light(Single Reverse Light) Allison
1K/2K
B6.7 - Backup Light(Single Reverse Light) Allison 1K/2K Design 545
3K/4K
B6.7 - Backup Light(Single Reverse Light) Allison 3K/4K Design 547
Dual STT N/Back Up) Eaton/Manual Trans
Eaton/Manual Trans Design 549
B6.7 - Backup Lights (Single Reverse Lights)
Eaton/Manual Trans
B6.7 - Backup Lights (Single Reverse Lights) Eaton/Manual Trans Design 550
xxiiB6.7 - Backup Lights (Reverse Lights) - Procision with
Tailboard Lights
B6.7 - Backup Lights (Reverse Lights) - Procision with Tailboard Lights
Design 551
L9 - Backup Light (Dual Daisy Reverse LT)Allison/ZF
Trans
L9 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans Design 552
L9 - Backup Light (Dual Daisy Reverse) Allison/ZF
Trans 3K/4K
L9 - Backup Light (Dual Daisy Reverse) Allison/ZF Trans 3K/4K Design 553
L9 - Backup Light (Dual Daisy with
L9 - Backup Light (Dual Daisy with extension)Allison/ZF Trans Design 555
L9 - Backup Light (Dual Reverse Light) Allison/ZF
Trans 3K/4K
L9 - Backup Light (Dual Reverse Light) Allison/ZF Trans 3K/4K Design 556
L9 - Backup Lights (Dual Daisy Reverse Light)
Eaton/Manual Trans
L9 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans Design 558
L9 - Backup Lights (Dual Daisy Reverse)
Eaton/Manual Trans
L9 - Backup Lights (Dual Daisy Reverse) Eaton/Manual Trans Design 559
L9 - Backup Lights (Dual Daisy with extension)
Eaton/Manual Trans
L9 - Backup Lights (Dual Daisy with extension) Eaton/Manual Trans Design 561
L9 - Backup Lights (Dual Reverse Light) Eaton/Manual
Trans
L9 - Backup Lights (Dual Reverse Light) Eaton/Manual Trans Design 562
L9 - Backup Lights (Reverse Lights) (Crossmember
L9 - Backup Lights (Reverse Lights) (Crossmember Dual STT N/Back Up) Allison
Trans Design 564
L9 - Backup Light (Single Reverse Light) Allison
3K/4K
L9 - Backup Light (Single Reverse Light) Allison 3K/4K Design 565
L9 - Backup Light (Single Reverse Light) - Allison
3K/4K
L9 - Backup Light (Single Reverse Light) - Allison 3K/4K Design 567
L9 - Backup Light - (Single Reverse Light) Allison
3K/4K
L9 - Backup Light - (Single Reverse Light) Allison 3K/4K Design 569
Eaton/Manual Trans Design 571
xxiiiL9 - Backup Lights (Single Reverse Lights)
Eaton/Manual Trans
L9 - Backup Lights (Single Reverse Lights) Eaton/Manual Trans Design 572
B6.7 - Rear Lights Stop (Daisy Chain)
B6.7 - Rear Lights Stop (Daisy Chain) Design 574
B6.7 - Rear Lights Stop - Dual Assembly
B6.7 - Rear Lights Stop - Dual Assembly Design 575
B6.7 - Rear Lights Stop - Single Assemby
B6.7 - Rear Lights Stop - Single Assemby Design 576
B6.7 - Rear Lights (Stop) (Daisy Chain N/ Extension
Harness)
B6.7 - Rear Lights (Stop) (Daisy Chain N/ Extension Harness) Design 577
B6.7 - Rear Light (Stop) Crossmember Dual STT
N/Back-Up
B6.7 - Rear Light (Stop) Crossmember Dual STT N/Back-Up Design 578
B6.7 - Rear Lights (Stop) (Daisy Chain W/ Extension
Harness)
B6.7 - Rear Lights (Stop) (Daisy Chain W/ Extension Harness) Design 579
L9 - Rear Lights Stop (Daisy Chain)
L9 - Rear Lights Stop (Daisy Chain) Design 580
L9 - Rear Lights Stop - Dual Assembly
L9 - Rear Lights Stop - Dual Assembly Design 581
L9 - Rear Lights Stop - Single Assemby
L9 - Rear Lights Stop - Single Assemby Design 582
L9 - Rear Lights (Stop) (Daisy Chain N/ Extension
Harness)
L9 - Rear Lights (Stop) (Daisy Chain N/ Extension Harness) Design 583
L9 - Rear Lights (Stop) (Daisy Chain W/ Extension
Harness)
L9 - Rear Lights (Stop) (Daisy Chain W/ Extension Harness) Design 584
L9 - Rear Light (Stop) Crossmember Dual STT N/BackUp
L9 - Rear Light (Stop) Crossmember Dual STT N/Back-Up Design 585
B6.7/L9 - Clearance and Identification Lights
B6.7/L9 - Clearance and Identification Lights Design 586
B6.7/L9 - Daytime Running Lights W/CAN
Headlamps(Post 11/22)
B6.7/L9 - Daytime Running Lights W/CAN Headlamps(Post 11/22) Design 587
Headlamps(Pre 11/22)
B6.7/L9 - Daytime Running Lights W/CAN Headlamps(Pre 11/22) Design 588
B6.7/ L9 - Daytime Running Lights N/CAN Headlamps
xxivB6.7/ L9 - Daytime Running Lights N/CAN Headlamps Design 589
B6.7/L9 - Directional Signals (Turn) (Halogen W/ Plow
Lights & W/ Fender Lights)
B6.7/L9 - Directional Signals (Turn) (Halogen W/ Plow Lights & W/ Fender Lights)
Design 590
B6.7/L9 - Directional Signals (Turn) (HALOGEN) W/O
Plow Lights W/O Fender Lights
B6.7/L9 - Directional Signals (Turn) (HALOGEN) W/O Plow Lights W/O Fender
Lights Design 592
Plow Lights W/ Fender Lights
B6.7/L9 - Directional Signals (Turn) (HALOGEN) W/O Plow Lights W/ Fender
Lights Design 594
B6.7/L9 - Directional Signals (Turn) (HALOGEN) W/ Plow Lights W/O Fender
Lights Design 596
B6.7/L9 - Directional Signals (Turn) (LED CAN
W/Heated) W/O Plow Lights, W/O Fender Lights
B6.7/L9 - Directional Signals (Turn) (LED CAN W/Heated) W/O Plow Lights, W/O
Fender Lights Design 598
W/Heated) W/O Plow Lights, W/ Fender Lights
Fender Lights Design 599
W/Heated) W/ Plow Lights, W/O Fender Lights
B6.7/L9 - Directional Signals (Turn) (LED CAN W/Heated) W/ Plow Lights, W/O
Fender Lights Design 600
W/Heated) W/ Plow Lights, W/ Fender Lights
Fender Lights Design 601
B6.7/L9 - Directional Signals (Turn) (LED CAN) W/O
B6.7/L9 - Directional Signals (Turn) (LED CAN) W/O Plow Lights W/O Fender
Lights Design 602
B6.7/L9 - Directional Signals (Turn) (LED CAN) W/O Plow Lights W/ Fender
Lights Design 604
B6.7/L9 - Directional Signals (Turn) (LED CAN) W/ Plow Lights W/O Fender
Lights Design 606
xxvB6.7/L9 - Directional Signal (Turn) (LED CAN W/ Plow
Lights W/ Fender Lights)
B6.7/L9 - Directional Signal (Turn) (LED CAN W/ Plow Lights W/ Fender Lights)
Design 608
B6.7/L9 - Exterior Lamp Reminder
B6.7/L9 - Exterior Lamp Reminder Design 610
B6.7 - Exterior Lamp Check
B6.7 - Exterior Lamp Check Design 611
L9 - Exterior Lamp Check
L9 - Exterior Lamp Check Design 612
B6.7/L9 - Front Fog Lamps
B6.7/L9 - Front Fog Lamps Design 613
B6.7/L9 - Prewire Front Fog Lights
B6.7/L9 - Prewire Front Fog Lights Design 614
B6.7/L9 - Marker Lighting (Halogen Headlights)
N/Plowlights N/Fender W/Guide Posts
B6.7/L9 - Marker Lighting (Halogen Headlights) N/Plowlights N/Fender W/Guide
Posts Design 615
N/Plowlights W/Fender N/Guide Posts
B6.7/L9 - Marker Lighting (Halogen Headlights) N/Plowlights W/Fender N/Guide
Posts Design 617
N/Plowlights W/Fender W/Guide Posts
B6.7/L9 - Marker Lighting (Halogen Headlights) N/Plowlights W/Fender W/Guide
Posts Design 619
N/Plowlight N/Fender N/Guide Posts
B6.7/L9 - Marker Lighting (Halogen Headlights) N/Plowlight N/Fender N/Guide
Posts Design 621
W/Plowlights W/Fender N/Guide Posts
B6.7/L9 - Marker Lighting (Halogen Headlights) W/Plowlights W/Fender N/Guide
Posts Design 623
W/Plowlight N/Fender N/Guide Posts
B6.7/L9 - Marker Lighting (Halogen Headlights) W/Plowlight N/Fender N/Guide
Posts Design 625
B6.7/L9 - Marker Lighting (LED CAN Headlamp
W/Heated) N/Plow Lts, N/Fender Lts, N/Guide Posts
B6.7/L9 - Marker Lighting (LED CAN Headlamp W/Heated) N/Plow Lts, N/Fender
Lts, N/Guide Posts Design 627
W/Heated) N/Plow Lts, N/Fender Lts, W/Guide Posts
Lts, W/Guide Posts Design 628
xxviB6.7/L9 - Marker Lighting (LED CAN Headlamp
W/Heated) N/Plow Lts, W/Fender Lts, N/Guide Posts
B6.7/L9 - Marker Lighting (LED CAN Headlamp W/Heated) N/Plow Lts, W/Fender
Lts, N/Guide Posts Design 629
W/Heated) W/Plow Lts, N/Fender Lts, N/Guide Posts
B6.7/L9 - Marker Lighting (LED CAN Headlamp W/Heated) W/Plow Lts, N/Fender
Lts, N/Guide Posts Design 630
W/Heated) W/Plow Lts, W/Fender Lts, N/Guide Posts
B6.7/L9 - Marker Lighting (LED CAN Headlamp W/Heated) W/Plow Lts, W/Fender
Lts, N/Guide Posts Design 631
B6.7/L9 - Marker Lighting (LED CAN Headlamp)
N/Plow Lts N/Fender Lts N/Guide Posts
B6.7/L9 - Marker Lighting (LED CAN Headlamp) N/Plow Lts N/Fender Lts
N/Guide Posts Design 632
N/Plow Lts N/Fender Lts W/Guide Posts
W/Guide Posts Design 634
N/Plow Lts W/Fender Lts N/Guide Posts
B6.7/L9 - Marker Lighting (LED CAN Headlamp) N/Plow Lts W/Fender Lts
N/Guide Posts Design 636
W/Plow Lts N/Fender Lts N/Guide Posts
B6.7/L9 - Marker Lighting (LED CAN Headlamp) W/Plow Lts N/Fender Lts
N/Guide Posts Design 638
W/Plow Lts W/Fender Lts N/Guide Posts
B6.7/L9 - Marker Lighting (LED CAN Headlamp) W/Plow Lts W/Fender Lts
N/Guide Posts Design 640
B6.7/L9 - Hazard Warning Light N/Trlr Socket
B6.7/L9 - Hazard Warning Light N/Trlr Socket Design 642
B6.7/L9 - Headlights (Halogen) W/O Plow Lights
B6.7/L9 - Headlights (Halogen) W/O Plow Lights Design 644
B6.7/L9 - Headlights (Halogen) W/ Plow Lights
B6.7/L9 - Headlights (Halogen) W/ Plow Lights Design 648
B6.7/L9 - Headlights (LED CAN ) W/ Plow Lights
B6.7/L9 - Headlights (LED CAN ) W/ Plow Lights Design 650
B6.7/L9 - Headlights (LED CAN) W/O Plow Lights
B6.7/L9 - Headlights (LED CAN) W/O Plow Lights Design 654
B6.7/L9 - Headlights (LED CAN) W/O Plow Lights,
W/Heated
B6.7/L9 - Headlights (LED CAN) W/O Plow Lights, W/Heated Design 658
xxviiB6.7/L9 - Headlights (LED CAN) W/ Plow Lights,
W/Heated
B6.7/L9 - Headlights (LED CAN) W/ Plow Lights, W/Heated Design 660
B6.7 - License Plate Light (Direct To Light)
B6.7 - License Plate Light (Direct To Light) Design 662
B6.7 - License Plate Light (LED BOX LAMP Daisy
Chain Tail Light with extension)
B6.7 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light with extension)
Design 663
Chain Tail Light)
B6.7 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light) Design 664
B6.7 - License Plate Light (Tail Light Single Assy.)
W/Less Power Module
B6.7 - License Plate Light (Tail Light Single Assy.) W/Less Power Module
Design 665
L9 - License Plate Light (Direct To Light)
L9 - License Plate Light (Direct To Light) Design 666
L9 - License Plate Light (LED BOX LAMP Daisy Chain
L9 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light with extension)
Design 667
Tail Light)
L9 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light) Design 668
Tail Light)
L9 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light) Design 669
L9 - License Plate Light (LED BOX LAMP Tail Light)
L9 - License Plate Light (LED BOX LAMP Tail Light) Design 670
L9 - License Plate Light (Tail Light Single Assy)
L9 - License Plate Light (Tail Light Single Assy) Design 671
Option2
L9 - License Plate Light (Tail Light Single Assy) Option2 Design 672
Option3
L9 - License Plate Light (Tail Light Single Assy) Option3 Design 673
W/Less Power Module
L9 - License Plate Light (Tail Light Single Assy) W/Less Power Module Design674
B6.7 - PARK LIGHTS - N/Marker Interrupt
B6.7 - PARK LIGHTS - N/Marker Interrupt Design 675
xxviiiB6.7 - PARK LIGHTS - W/Marker Interrupt 10pin
CLCKSPRING
B6.7 - PARK LIGHTS - W/Marker Interrupt 10pin CLCKSPRING Design 677
B6.7 - PARK LIGHTS - W/Marker Interrupt 4 pin
clockspring
B6.7 - PARK LIGHTS - W/Marker Interrupt 4 pin clockspring Design 679
L9 - PARK LIGHTS - N/Marker Interrupt
L9 - PARK LIGHTS - N/Marker Interrupt Design 681
L9 - PARK LIGHTS - W/Marker Interrupt 10pin
CLCKSPRING
L9 - PARK LIGHTS - W/Marker Interrupt 10pin CLCKSPRING Design 683
L9 - PARK LIGHTS - W/Marker Interrupt 4 pin
clockspring
L9 - PARK LIGHTS - W/Marker Interrupt 4 pin clockspring Design 685
B6.7/L9 - Mirror Lighting (Turns and Markers W/O
Door Pods)
B6.7/L9 - Mirror Lighting (Turns and Markers W/O Door Pods) Design 687
B6.7/L9 - Mirror Lighting (Turns and Markers W/ Door
Pods)
B6.7/L9 - Mirror Lighting (Turns and Markers W/ Door Pods) Design 688
B6.7/L9 - Snow Plow Lights Switch
B6.7/L9 - Snow Plow Lights Switch Design 689
B6.7 - Rear Lights (Tail Lights) Crossmember Dual
STT N/Back-Up
B6.7 - Rear Lights (Tail Lights) Crossmember Dual STT N/Back-Up Design 690
B6.7 - Rear Light Tail Light
B6.7 - Rear Light Tail Light Design 691
B6.7 - Rear Light (LED BOX LAMP Tail Light)
B6.7 - Rear Light (LED BOX LAMP Tail Light) Design 692
B6.7 - Rear Light (Tail Light)
B6.7 - Rear Light (Tail Light) Design 693
B6.7 - Rear Light (Tail Light) Daisy Chain W/ Extension
B6.7 - Rear Light (Tail Light) Daisy Chain W/ Extension Design 694
B6.7 - Rear Light (Tail Light) W Daisy Chain pair of
Box Lamps
B6.7 - Rear Light (Tail Light) W Daisy Chain pair of Box Lamps Design 695
B6.7 - Rear Light (Tail Light) W/Daisy Chain Pair of
Box Lamps
B6.7 - Rear Light (Tail Light) W/Daisy Chain Pair of Box Lamps Design 696
L9 - Rear Lights (Tail Lights) Crossmember Dual STT
N/Back-Up
L9 - Rear Lights (Tail Lights) Crossmember Dual STT N/Back-Up Design 697
L9 - Rear Light (LED BOX LAMP Tail Light)
xxixL9 - Rear Light (LED BOX LAMP Tail Light) Design 698
L9 - Rear Light (Tail Light)
L9 - Rear Light (Tail Light) Design 699
L9 - Rear Light (Tail Light) Daisy Chain W/ Extension
L9 - Rear Light (Tail Light) Daisy Chain W/ Extension Design 700
L9 - Rear Light (Tail Light) W/Daisy Chain pair of Box
Lamps
L9 - Rear Light (Tail Light) W/Daisy Chain pair of Box Lamps Design 701
L9 - Rear Light (Tail Light) W/Daisy Chain Pair of Box
Lamps
L9 - Rear Light (Tail Light) W/Daisy Chain Pair of Box Lamps Design 702
B6.7 - Work Lights LED With Switch Pack - Day Cab
B6.7 - Work Lights LED With Switch Pack - Day Cab Design 703
B6.7 - WORK LIGHT With BackUP Alarm - 1 BULB
B6.7 - WORK LIGHT With BackUP Alarm - 1 BULB Design 705
B6.7 - WORK LIGHT With BackUP 1 BULB - Manual
Trans
B6.7 - WORK LIGHT With BackUP 1 BULB - Manual Trans Design 707
B6.7 - WORK LIGHT With RKE - 1 BULB
B6.7 - WORK LIGHT With RKE - 1 BULB Design 709
B6.7 - WORK LIGHT - 1 BULB
B6.7 - WORK LIGHT - 1 BULB Design 711
L9 - Work Lights LED With Switch Pack - Day Cab
L9 - Work Lights LED With Switch Pack - Day Cab Design 713
L9 - WORK LIGHT With BackUP Alarm - 1 BULB
L9 - WORK LIGHT With BackUP Alarm - 1 BULB Design 715
L9 - WORK LIGHT With BackUP - 1 BULB - Manual
Trans
L9 - WORK LIGHT With BackUP - 1 BULB - Manual Trans Design 717
L9 - WORK LIGHT With RKE 1 BULB
L9 - WORK LIGHT With RKE 1 BULB Design 721
L9 - WORK LIGHT - 1 BULB
L9 - WORK LIGHT - 1 BULB Design 723
B6.7/L9 - Fifth Wheel Slide
B6.7/L9 - Fifth Wheel Slide Design 725
B6.7/L9 - Jaw Unlock Control
B6.7/L9 - Jaw Unlock Control Design 726
B6.7/L9 - Jaw Unlock Control W/ SOLENOIDS
W/SWITCH PACKS
B6.7/L9 - Jaw Unlock Control W/ SOLENOIDS W/SWITCH PACKS Design 727
xxxB6.7/L9 - Fuel Heater (Vehicle Powered) Davco 245
B6.7/L9 - Fuel Heater (Vehicle Powered) Davco 245 Design 728
B6.7/L9 - Fuel Heater (Vehicle Powered) (Racor 400
Series)
B6.7/L9 - Fuel Heater (Vehicle Powered) (Racor 400 Series) Design 729
B6.7 - Fuel Level (Single Sensor)
B6.7 - Fuel Level (Single Sensor) Design 730
B6.7 - Fuel Level (Single Sensor) Post E36
B6.7 - Fuel Level (Single Sensor) Post E36 Design 735
B6.7 - Fuel Level (Single Sensor) Pre E36
B6.7 - Fuel Level (Single Sensor) Pre E36 Design 737
B6.7 - 26" Fuel Tank
B6.7 - 26" Fuel Tank Design 743
B6.7 - 26" Fuel Tank - Secondary
B6.7 - 26" Fuel Tank - Secondary Design 744
L9 - Fuel Level (Single Sensor)
L9 - Fuel Level (Single Sensor) Design 746
L9 - Fuel Level (Single Sensor) Post E36
L9 - Fuel Level (Single Sensor) Post E36 Design 750
L9 - Fuel Level (Single Sensor) Pre E36
L9 - Fuel Level (Single Sensor) Pre E36 Design 752
L9 - 26" Fuel Tank
L9 - 26" Fuel Tank Design 756
L9 - 26" Fuel Tank - Secondary
L9 - 26" Fuel Tank - Secondary Design 757
B6.7 - Water In Fuel (WIF) Davco 245 W/ Heater
B6.7 - Water In Fuel (WIF) Davco 245 W/ Heater Design 759
B6.7 - Water In Fuel (WIF) Racor N/ Heater
B6.7 - Water In Fuel (WIF) Racor N/ Heater Design 760
B6.7 - Water In Fuel (WIF) Racor W/ Heater
B6.7 - Water In Fuel (WIF) Racor W/ Heater Design 765
L9 - Water In Fuel (WIF) Davco 245 W/ Heater
L9 - Water In Fuel (WIF) Davco 245 W/ Heater Design 770
L9 - Water In Fuel (WIF) Racor N/ Heater
L9 - Water In Fuel (WIF) Racor N/ Heater Design 771
HVAC Actuators
HVAC Actuators Design 775
B6.7 - Heating Ventilation & Air Conditioning (HVAC)
(Auto Control head W/PT Transducer N/Low Pressure
SW)
B6.7 - Heating Ventilation & Air Conditioning (HVAC) (Auto Control head W/PT
Transducer N/Low Pressure SW) Design 776
xxxiL9 - Heating Ventilation & Air Conditioning (HVAC)
SW)
L9 - Heating Ventilation & Air Conditioning (HVAC) (Auto Control head W/PT
Transducer N/Low Pressure SW) Design 778
(Manual W/PT Transducer N/Low Pressure SW)
B6.7 - Heating Ventilation & Air Conditioning (HVAC) (Manual W/PT Transducer
N/Low Pressure SW) Design 780
L9 - Heating Ventilation & Air Conditioning (HVAC) (Manual W/PT Transducer
N/Low Pressure SW) Design 781
B6.7 - Ambient Air Temperature
B6.7 - Ambient Air Temperature Design 782
B6.7 - Ambient Air Temperature (no Display, Bumper
Sensor)
B6.7 - Ambient Air Temperature (no Display, Bumper Sensor) Design 783
Sensor): 2024 and newer models
B6.7 - Ambient Air Temperature (no Display, Bumper Sensor):2024 and newer
models Design 784
B6.7 - Ambient Temperature Monitoring
B6.7 - Ambient Temperature Monitoring Design 785
B6.7 - Ambient Temperature Monitoring (HorizonBumper Sensor)
B6.7 - Ambient Temperature Monitoring (Horizon-Bumper Sensor) Design 786
B6.7 - Ambient Temperature Monitoring (HorizonBumper Sensor): 2024 and newer models
B6.7 - Ambient Temperature Monitoring (Horizon-Bumper Sensor):2024 and
newer models Design 787
B6.7 - Ambient Temperature (Horizon-Mirror Sensor)
B6.7 - Ambient Temperature (Horizon-Mirror Sensor) Design 788
B6.7 - Ambient Temperature (No Display, Mirror
Sensor)
B6.7 - Ambient Temperature (No Display, Mirror Sensor) Design 789
L9 - Ambient Air Temperature
L9 - Ambient Air Temperature Design 790
L9 - Ambient Temperature (Horizon-Mirror Sensor)
L9 - Ambient Temperature (Horizon-Mirror Sensor) Design 791
L9 - Ambient Temperature (No Display, Mirror Sensor)
L9 - Ambient Temperature (No Display, Mirror Sensor) Design 792
B6.7/L9 - Auxilary Gauges (Secondary)
B6.7/L9 - Auxilary Gauges (Secondary) Design 793
xxxiiB6.7/L9 - Auxiliary Gauge
B6.7/L9 - Auxiliary Gauge Design 794
B6.7/L9 - Auxiliary Gauges (Primary)
B6.7/L9 - Auxiliary Gauges (Primary) Design 795
B6.7 - Brake Pressure (Auxiliary Gauge)
B6.7 - Brake Pressure (Auxiliary Gauge) Design 796
B6.7 - Brake Pressure (Virtual Gauge)
B6.7 - Brake Pressure (Virtual Gauge) Design 797
L9 - Brake Pressure (Auxiliary Gauge)
L9 - Brake Pressure (Auxiliary Gauge) Design 798
L9 - Brake Pressure (Virtual Gauge)
L9 - Brake Pressure (Virtual Gauge) Design 799
B6.7/L9 - Compressed Air Supply
B6.7/L9 - Compressed Air Supply Design 800
B6.7/L9 - Compressed Air Supply (Aux Air Pressure
Gauge) (Hydraulic Split Brake System)
B6.7/L9 - Compressed Air Supply (Aux Air Pressure Gauge) (Hydraulic Split
Brake System) Design 801
B6.7/L9 - Compressed Air Supply (Aux Gauge)
B6.7/L9 - Compressed Air Supply (Aux Gauge) Design 803
B6.7 - Current Monitoring (Ammeter)
B6.7 - Current Monitoring (Ammeter) Design 804
B6.7/L9 - DEF Economy Monitor (GEN IV Horizon
Cluster w/ Cummins ENG)
B6.7/L9 - DEF Economy Monitor (GEN IV Horizon Cluster w/ Cummins ENG)
Design 806
B6.7/L9 - Coolant Temperature Monitoring
B6.7/L9 - Coolant Temperature Monitoring Design 807
B6.7/L9 - Engine Usage Monitoring (Base) NA
B6.7/L9 - Engine Usage Monitoring (Base) NA Design 808
B6.7/L9 - Engine Usage Monitoring (VID Option)
B6.7/L9 - Engine Usage Monitoring (VID Option) Design 809
B6.7/L9 - Engine Oil Level Monitoring
B6.7/L9 - Engine Oil Level Monitoring Design 810
B6.7/L9 - Engine Oil Pressure
B6.7/L9 - Engine Oil Pressure Design 811
B6.7/L9 - Engine Oil Temperature NA MUX
B6.7/L9 - Engine Oil Temperature NA MUX Design 812
B6.7/L9 - Engine Oil Temperature NA MUX AUX Gauge
B6.7/L9 - Engine Oil Temperature NA MUX AUX Gauge Design 813
B6.7/L9 - Engine Speed (Tachometer)
B6.7/L9 - Engine Speed (Tachometer) Design 814
xxxiiiB6.7/L9 - Economy Monitor
B6.7/L9 - Economy Monitor Design 815
B6.7/L9 - Intake Manifold Pressure (IMP) (Cummins
2350A and MX-1 NA) AUX gauge
B6.7/L9 - Intake Manifold Pressure (IMP) (Cummins 2350A and MX-1 NA) AUX
gauge Design 816
2350A NA)
B6.7/L9 - Intake Manifold Pressure (IMP) (Cummins 2350A NA) Design 817
B6.7/L9 - Odometer (via BCM/EGC)-Horizon
B6.7/L9 - Odometer (via BCM/EGC)-Horizon Design 818
B6.7/L9 - Trip Odometer (w/ECM & TCM)
B6.7/L9 - Trip Odometer (w/ECM & TCM) Design 819
B6.7/L9 - Trip Odometer (w/ECM)
B6.7/L9 - Trip Odometer (w/ECM) Design 820
B6.7/L9 - Trip Odometer (w/VID)
B6.7/L9 - Trip Odometer (w/VID) Design 821
B6.7/L9 - PTO (Fuel and Hours)
B6.7/L9 - PTO (Fuel and Hours) Design 822
B6.7/L9 - Transmission Oil Temperature Automatic
Trans Option2
B6.7/L9 - Transmission Oil Temperature Automatic Trans Option2 Design 823
B6.7/L9 - Transmission Oil Temperature-Automatic
Trans w/Aux Gauge
B6.7/L9 - Transmission Oil Temperature-Automatic Trans w/Aux Gauge
Design 824
L9 - Transmission Oil Temperature - Manual Trans
L9 - Transmission Oil Temperature - Manual Trans Design 825
w/Aux Gauge
L9 - Transmission Oil Temperature - Manual Trans w/Aux Gauge Design 826
B6.7/L9 - Vehicle Speedometer System (Automatic
XMSN) NA
B6.7/L9 - Vehicle Speedometer System (Automatic XMSN) NA Design 827
B6.7 - Vehicle Speedometer System (Manual XMSN)
NA
B6.7 - Vehicle Speedometer System (Manual XMSN) NA Design 828
L9 - Vehicle Speedometer System (Manual XMSN) NA
L9 - Vehicle Speedometer System (Manual XMSN) NA Design 829
B6.7/L9 - Vehicle Speed Limit Override
B6.7/L9 - Vehicle Speed Limit Override Design 830
B6.7/L9 - Voltage Monitoring Voltmeter
xxxivB6.7/L9 - Voltage Monitoring Voltmeter Design 831
B6.7/L9 - Voltage Monitoring (Voltmeter) (with Aux
gauge)
B6.7/L9 - Voltage Monitoring (Voltmeter) (with Aux gauge) Design 832
B6.7/L9 - Engine Warning MUX
B6.7/L9 - Engine Warning MUX Design 833
B6.7/L9 - High Exhaust System Temperature (HEST)
Monitoring
B6.7/L9 - High Exhaust System Temperature (HEST) Monitoring Design 834
Monitoring (Horizon) (2024 & Newer Models)
B6.7/L9 - High Exhaust System Temperature (HEST) Monitoring (Horizon) (2024
& Newer Models) Design 835
B6.7/L9 - Up Shift Indicator
B6.7/L9 - Up Shift Indicator Design 836
B6.7 - Range Inhibit (sixth gear inhibit switch) (Option
1)
B6.7 - Range Inhibit (sixth gear inhibit switch) (Option 1) Design 837
B6.7 - Range Inhibit (Sixth Gear Inhibit Switch) (Option
2)
B6.7 - Range Inhibit (Sixth Gear Inhibit Switch) (Option 2) Design 839
B6.7/L9 - Trans Range Inhibit (J1939 Comm) (Option 1)
B6.7/L9 - Trans Range Inhibit (J1939 Comm) (Option 1) Design 841
B6.7/L9 - Trans Range Inhibit (J1939 Comm) (Option 2)
B6.7/L9 - Trans Range Inhibit (J1939 Comm) (Option 2) Design 842
B6.7/L9 - Vehicle Information Display Premium w/ WiFi VID
B6.7/L9 - Vehicle Information Display Premium w/ Wi-Fi VID Design 843
B6.7/L9 - Vehicle Information Display W/O BT
B6.7/L9 - Vehicle Information Display W/O BT Design 844
B6.7/L9 - Vehicle Information Display (W/ BT)
B6.7/L9 - Vehicle Information Display (W/ BT) Design 845
B6.7/L9 - Cab Dome Light W/Classic Trim
B6.7/L9 - Cab Dome Light W/Classic Trim Design 846
B6.7/L9 - Cab Dome Light W/ Combo in Diamond Trim
B6.7/L9 - Cab Dome Light W/ Combo in Diamond Trim Design 847
B6.7/L9 - Courtesy Light Crew Cab
B6.7/L9 - Courtesy Light Crew Cab Design 848
B6.7/L9 - Courtesy Light Day Cab
B6.7/L9 - Courtesy Light Day Cab Design 849
B6.7/L9 - Interior Task Lights (Map) - Dome Combo
B6.7/L9 - Interior Task Lights (Map) - Dome Combo Design 850
xxxvB6.7/L9 - Panel Backlighting (Cabin Dimmer)
B6.7/L9 - Panel Backlighting (Cabin Dimmer) Design 851
B6.7 - Axle Loading (Weight) Rear
B6.7 - Axle Loading (Weight) Rear Design 852
B6.7 - Axle Loading (Weight) (Rear, Horizon)
B6.7 - Axle Loading (Weight) (Rear, Horizon) Design 854
L9 - Axle Loading (Weight) Rear
L9 - Axle Loading (Weight) Rear Design 858
L9 - Axle Loading (Weight) (Rear, Horizon)
L9 - Axle Loading (Weight) (Rear, Horizon) Design 860
B6.7 - Driver Controlled Locking Differential - RR Axle
(Dana w/ one sw )
B6.7 - Driver Controlled Locking Differential - RR Axle (Dana w/ one sw )
Design 864
(Dana w/ one sw)
B6.7 - Driver Controlled Locking Differential - RR Axle (Dana w/ one sw)
Design 865
(Meritor w/ one sw)
B6.7 - Driver Controlled Locking Differential - RR Axle (Meritor w/ one sw)
Design 866
L9 - Driver Controlled Locking Differenntial - FR and
RR Axles (Meritor w/ two sw)
L9 - Driver Controlled Locking Differenntial - FR and RR Axles (Meritor w/ two sw)
Design 867
L9 - Driver Controlled Locking Differential - FR & RR
Axle (Dana w/ one switch)
L9 - Driver Controlled Locking Differential - FR & RR Axle (Dana w/ one switch)
Design 868
L9 - Driver Controlled Locking Differential - FR & RR Axle (Meritor w/ one sw)
Design 869
L9 - Driver Controlled Locking Differential - RR Axle
(Dana w/ one sw)
L9 - Driver Controlled Locking Differential - RR Axle (Dana w/ one sw) Design 870
(Meritor w/ one sw)
L9 - Driver Controlled Locking Differential - RR Axle (Meritor w/ one sw)
Design 871
B6.7/L9 - Height Control
B6.7/L9 - Height Control Design 872
B6.7/L9 - Power Divider Lock Control and Monitoring
B6.7/L9 - Power Divider Lock Control and Monitoring Design 873
xxxviB6.7/L9 - Rear Axle Load Distribution
B6.7/L9 - Rear Axle Load Distribution Design 874
L9 - Axle Temperature Monitoring (Single Rear Aux
Gauge)
L9 - Axle Temperature Monitoring (Single Rear Aux Gauge) Design 875
L9 - Axle Temperature Monitoring (Single Rear Virtual
Gauge)
L9 - Axle Temperature Monitoring (Single Rear Virtual Gauge) Design 876
L9 - Axle Temperature Monitoring (Tandem Rear Aux
Gauge)
L9 - Axle Temperature Monitoring (Tandem Rear Aux Gauge) Design 877
Virtual Gauge)
L9 - Axle Temperature Monitoring (Tandem Rear Virtual Gauge) Design 878
B6.7 - Rear Suspension Pressure Monitoring
(Auxiliary Gauge)
B6.7 - Rear Suspension Pressure Monitoring (Auxiliary Gauge) Design 879
B6.7 - Rear Suspension Pressure Monitoring (Virtual
Gauge)
B6.7 - Rear Suspension Pressure Monitoring (Virtual Gauge) Design 881
L9 - Rear Suspension Pressure Monitoring (Auxiliary
Gauge)
L9 - Rear Suspension Pressure Monitoring (Auxiliary Gauge) Design 883
L9 - Rear Suspension Pressure Monitoring (Virtual
Gauge)
L9 - Rear Suspension Pressure Monitoring (Virtual Gauge) Design 885
B6.7 - Two Speed Axle (AirShift on Shifter)
B6.7 - Two Speed Axle (AirShift on Shifter) Design 887
B6.7 - Two Speed Axle (with BCM; Automactic
Transmission and switch on dash)
B6.7 - Two Speed Axle (with BCM; Automactic Transmission and switch on dash)
Design 888
L9 - Two Speed Axle (AirShift on Shifter)
L9 - Two Speed Axle (AirShift on Shifter) Design 889
L9 - Two Speed Axle (with BCM; Automactic
L9 - Two Speed Axle (with BCM; Automactic Transmission and switch on dash)
Design 890
B6.7/L9 - Driver and Passenger Seats - RollTek (Hard
Wired)
B6.7/L9 - Driver and Passenger Seats - RollTek (Hard Wired) Design 891
B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard
Wired) - Leather
B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard Wired) - Leather Design 892
xxxviiB6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard
Wired) - Mordular
B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard Wired) - Mordular Design 893
Wired) - Vinyl
B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard Wired) - Vinyl Design 894
B6.7/L9 - Seatbelt Reminder (Warning)(Driver only)
B6.7/L9 - Seatbelt Reminder (Warning)(Driver only) Design 895
B6.7/L9 - Seatbelt Reminder (Warning)(Driver &
Passenger in parallel)
B6.7/L9 - Seatbelt Reminder (Warning)(Driver & Passenger in parallel) Design896
Vehicle Data Recorder (No Display)
Vehicle Data Recorder (No Display) Design 897
Vehicle Data Recorder (W/Display, 2 front seats)
Vehicle Data Recorder (W/Display, 2 front seats) Design 899
Vehicle Data Recorder (W/ Display)
Vehicle Data Recorder (W/ Display) Design 901
L9 - Auxiliary Trailer Power
L9 - Auxiliary Trailer Power Design 903
B6.7 - TEM _Electric Trailer Brake Controller Activated
Stop
B6.7 - TEM _Electric Trailer Brake Controller Activated Stop Design 904
Stop Option2
B6.7 - TEM _Electric Trailer Brake Controller Activated Stop Option2 Design 905
L9 - TEM _Electric Trailer Brake Controller Activated
Stop LT
L9 - TEM _Electric Trailer Brake Controller Activated Stop LT Design 906
B6.7 - Trailer Interface (Lighting) – BLUNT CUT (Part
of Electric Trailer Brakes)
B6.7 - Trailer Interface (Lighting) – BLUNT CUT (Part of Electric Trailer Brakes)
Design 907
of Electric Trailer Brakes) Option2
Option2 Design 908
L9 - Trailer Interface (Lighting) – BLUNT CUT (Part of
L9 - Trailer Interface (Lighting) – BLUNT CUT (Part of Electric Trailer Brakes)
Design 909
Option2 Design 910
xxxviiiB6.7 - Auto Neutral (Allision N/ Switch & W/
Confirmation Telltale)
B6.7 - Auto Neutral (Allision N/ Switch & W/ Confirmation Telltale) Design 911
B6.7 - Auto Neutral (Allison W/ Multiplex Switch &
B6.7 - Auto Neutral (Allison W/ Multiplex Switch & Confirmation Telltale)
Design 913
B6.7 - Auto Neutral (HS Drive N/ SW N/ Relay)
B6.7 - Auto Neutral (HS Drive N/ SW N/ Relay) Design 914
B6.7/L9 - Auto Neutral (Eaton Procision)
B6.7/L9 - Auto Neutral (Eaton Procision) Design 916
L9 - Auto Neutral (Allision N/ Switch & W/
L9 - Auto Neutral (Allision N/ Switch & W/ Confirmation Telltale) Design 917
L9 - Auto Neutral (Allison W/ Multiplex Switch &
L9 - Auto Neutral (Allison W/ Multiplex Switch & Confirmation Telltale) Design 919
Hill Start Aid (HSA) (Bendix CA 2.0)
Hill Start Aid (HSA) (Bendix CA 2.0) Design 920
B6.7 - Transmission Shifter (Push Button Shifter -
Allison 3K/4K) (Option 1)
B6.7 - Transmission Shifter (Push Button Shifter - Allison 3K/4K) (Option 1)
Design 921
Allison 3K/4K) (Option 2)
B6.7 - Transmission Shifter (Push Button Shifter - Allison 3K/4K) (Option 2)
Design 923
L9 - Transmission Shifter (Push Button Shifter -
L9 - Transmission Shifter (Push Button Shifter - Allison 3K/4K) (Option 1)
Design 925
L9 - Transmission Shifter (Push Button Shifter - Allison 3K/4K) (Option 2)
Design 927
B6.7 - Transmission Shifter (Eaton Procision)
B6.7 - Transmission Shifter (Eaton Procision) Design 929
B6.7 - Transmission Shifter (Stalk Shifter Allison)
B6.7 - Transmission Shifter (Stalk Shifter Allison) Design 930
B6.7 - Transmission Shifter (Universal Stalk Shifter -
Allison 1K/2K N/Park Position)
B6.7 - Transmission Shifter (Universal Stalk Shifter - Allison 1K/2K N/Park
Position) Design 932
xxxixB6.7 - Transmission Shifter (Universal Stalk Shifter -
Allison 1K/2K, W/Park Position)
B6.7 - Transmission Shifter (Universal Stalk Shifter - Allison 1K/2K, W/Park
Position) Design 933
Allison 3K/4K)
B6.7 - Transmission Shifter (Universal Stalk Shifter - Allison 3K/4K) Design 934
L9 - Transmission Shifter (Stalk Shifter Allison)
L9 - Transmission Shifter (Stalk Shifter Allison) Design 936
L9 - Transmission Shifter (Universal Stalk Shifter -
Allison 3K/4K)
L9 - Transmission Shifter (Universal Stalk Shifter - Allison 3K/4K) Design 938
B6.7 - Transmission Shifter (Eaton T-Handle with Park
Pawl)
B6.7 - Transmission Shifter (Eaton T-Handle with Park Pawl) Design 940
B6.7 - Transmission Shifter (T-Handle for Allison; With
Park Position)
B6.7 - Transmission Shifter (T-Handle for Allison; With Park Position) Design 942
B6.7 - T-Handle for Allison Without Park Position
B6.7 - T-Handle for Allison Without Park Position Design 944
B6.7/L9 - Auto Park Brake (T-Handle Shifter, Auto Park
Brake)
B6.7/L9 - Auto Park Brake (T-Handle Shifter, Auto Park Brake) Design 946
B6.7/L9 - Transmission Shifter (T-Handle for Allison N/
Park Position)
B6.7/L9 - Transmission Shifter (T-Handle for Allison N/ Park Position) Design 947
W/ Park Position)
B6.7/L9 - Transmission Shifter (T-Handle for Allison W/ Park Position) Design 948
B6.7/L9 - Transfer Case - High/Low Air Sol
B6.7/L9 - Transfer Case - High/Low Air Sol Design 949
B6.7/L9 - Transfer Case - High/Neu/Low Air Sol
B6.7/L9 - Transfer Case - High/Neu/Low Air Sol Design 950
B6.7 - Transmission (Allison 1K/2K)
B6.7 - Transmission (Allison 1K/2K) Design 951
B6.7 - Transmission (Allison 3K/4K)
B6.7 - Transmission (Allison 3K/4K) Design 952
L9 - Allision without Switch and with Confirmation
Telltale
L9 - Allision without Switch and with Confirmation Telltale Design 954
L9 - Transmission (Allison 3K/4K)
L9 - Transmission (Allison 3K/4K) Design 956
xlB6.7 - Transmission I/O (Procision W/ Body Builder)
B6.7 - Transmission I/O (Procision W/ Body Builder) Design 958
B6.7 - Transmission (Procision)
B6.7 - Transmission (Procision) Design 959
B6.7 - Transmission (Fuller Advantage)
B6.7 - Transmission (Fuller Advantage) Design 960
L9 - Transmission (Fuller Advantage)
L9 - Transmission (Fuller Advantage) Design 961
L9 - Transmissions Electrical I/O (Fuller Advantage)
L9 - Transmissions Electrical I/O (Fuller Advantage) Design 962
B6.7/L9 - Transmission Mode Button (1K/2K)
B6.7/L9 - Transmission Mode Button (1K/2K) Design 963
B6.7/L9 - Transmission - MODE Selection (Option 1)
B6.7/L9 - Transmission - MODE Selection (Option 1) Design 964
B6.7/L9 - Transmission - MODE Selection (Option 2)
B6.7/L9 - Transmission - MODE Selection (Option 2) Design 965
B6.7 - Windshield Washer Pump W/O Low Fluid
Sensor
B6.7 - Windshield Washer Pump W/O Low Fluid Sensor Design 966
B6.7 - Windshield Washer Pump & Low Fluid Sensor
B6.7 - Windshield Washer Pump & Low Fluid Sensor Design 967
L9 - Windshield Washer Pump W/O Low Fluid Sensor
L9 - Windshield Washer Pump W/O Low Fluid Sensor Design 969
L9 - Windshield Washer Pump & Low Fluid Sensor
L9 - Windshield Washer Pump & Low Fluid Sensor Design 970
B6.7 - Windshield Wipers
B6.7 - Windshield Wipers Design 972
L9 - Windshield Wipers
L9 - Windshield Wipers Design 973
B6.7/L9 - Battery Disconnect (W/Switch and
W/Solenoid)
B6.7/L9 - Battery Disconnect (W/Switch and W/Solenoid) Design 974
B6.7 - Bosch LH160_LH200 Alternator
B6.7 - Bosch LH160_LH200 Alternator Design 975
B6.7 - Charging System (Delco Remy & Mitsubishi
Alternator W/ Remote Sense)
B6.7 - Charging System (Delco Remy & Mitsubishi Alternator W/ Remote Sense)
Design 977
B6.7 - Delco Remy 28SI Alternator W/Sensor
B6.7 - Delco Remy 28SI Alternator W/Sensor Design 979
B6.7 - Delco Remy 36SI Alternator W/Sensor
B6.7 - Delco Remy 36SI Alternator W/Sensor Design 980
xliB6.7 - Leece-Neville AVI160 Alternator
B6.7 - Leece-Neville AVI160 Alternator Design 981
B6.7 - Leece-Neville AVI160-210A/240A Alternator
W/Sensor
B6.7 - Leece-Neville AVI160-210A/240A Alternator W/Sensor Design 983
B6.7 - Leece-Neville - LN 325A Alternator W/Sensor
B6.7 - Leece-Neville - LN 325A Alternator W/Sensor Design 984
L9 - Bosch LH160_LH200 Alternator
L9 - Bosch LH160_LH200 Alternator Design 985
L9 - Charging System (Delco Remy & Mitsubishi
L9 - Charging System (Delco Remy & Mitsubishi Alternator W/ Remote Sense)
Design 986
L9 - Delco Remy 28SI Alternator W/Sensor
L9 - Delco Remy 28SI Alternator W/Sensor Design 988
L9 - Delco Remy 36SI Alternator W/Sensor
L9 - Delco Remy 36SI Alternator W/Sensor Design 989
L9 - Leece-Neville AVI160 Alternator
L9 - Leece-Neville AVI160 Alternator Design 990
L9 - Leece-Neville AVI160-210A/240A Alternator
W/Sensor
L9 - Leece-Neville AVI160-210A/240A Alternator W/Sensor Design 991
L9 - Leece-Neville - LN 325A Alternator W/Sensor
L9 - Leece-Neville - LN 325A Alternator W/Sensor Design 992
B6.7/L9 - Maxwell 12V Ultracapacitor Engine Start
Module (ESM)
B6.7/L9 - Maxwell 12V Ultracapacitor Engine Start Module (ESM) Design 993
B6.7/L9 - Crank Inhibit (W/ Hood Switch)
B6.7/L9 - Crank Inhibit (W/ Hood Switch) Design 994
B6.7 - Cranking (Starter) GEN4 BCM W/O Thermal
Overcrank
B6.7 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/O Thermal
Overcrank Design 996
B6.7 - Crank Inhibit (with ECM --> BCM ONLY)
B6.7 - Crank Inhibit (with ECM --> BODY CONTROL MODULE ONLY)
Design 1001
L9 - Cranking (Starter) GEN4 BCM W/O Thermal
Overcrank
L9 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/O Thermal
Overcrank Design 1002
L9 - Cranking (Starter) GEN4 BCM W/ Thermal
Overcrank - External Switch
L9 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/ Thermal Overcrank
- External Switch Design 1003
xliiL9 - Crank Inhibit (with ECM --> BCM ONLY)
L9 - Crank Inhibit (with ECM --> BODY CONTROL MODULE ONLY) Design 1004
B6.7 - Cranking Request (w/ Key Switch w/ BCM)
B6.7 - Cranking Request (w/ Key Switch w/ BCM) Design 1005
B6.7/L9 - Operator Input
B6.7/L9 - Operator Input Design 1007
L9 - Cranking Request (w/ Key Switch w/ BCM)
L9 - Cranking Request (w/ Key Switch w/ BCM) Design 1009
B6.7 - Clutch Monitoring (High and Low Switch to
BCM)
B6.7 - Clutch Monitoring (High and Low Switch to BCM) Design 1011
B6.7 - Starter Interlocks (BCM Controlled with Input
from Allison 1K/2K TCM)
B6.7 - Starter Interlocks (BCM Controlled with Input from Allison 1K/2K TCM)
Design 1012
from Allison 3K/4K TCM)
B6.7 - Starter Interlocks (BCM Controlled with Input from Allison 3K/4K TCM)
Design 1014
B6.7 - Starter Interlock (BCM HSD controlled W/
Clutch SW & N/Auto SS)
B6.7 - Starter Interlock (BCM HSD controlled W/ Clutch SW & N/Auto SS)
Design 1016
B6.7 - Starter Interlock (BCM LSD Controlled w/ Relay
& N/ Auto SS) EATON XMSN
B6.7 - Starter Interlock (BCM LSD Controlled w/ Relay & N/ Auto SS) EATON
XMSN Design 1017
B6.7 - Starter Interlock (BCM LSD Controlled w/ Relay)
Eaton Procision
B6.7 - Starter Interlock (BCM LSD Controlled w/ Relay) Eaton Procision
Design 1018
L9 - Clutch Monitoring (High and Low Switch to BCM)
L9 - Clutch Monitoring (High and Low Switch to BCM) Design 1019
L9 - Starter Interlocks (BCM Controlled with Input
L9 - Starter Interlocks (BCM Controlled with Input from Allison 3K/4K TCM)
Design 1020
L9 - Starter Interlock (BCM LSD Controlled w/ Relay &
L9 - Starter Interlock (BCM LSD Controlled w/ Relay & N/ Auto SS) EATON
XMSN Design 1022
B6.7 - Battery International (4) 12V
B6.7 - Battery International (4) 12V Design 1023
L9 - Battery International (4) 12V
xliiiL9 - Battery International (4) 12V Design 1024
Connectors 1025
Index 3367
Brand: International, Navistar
Type of Manual: Interactive Schematics
Model: International MV Series Truck
Built 12/10/2021 To 12/31/2025
Part Number: 00000018834
Publication Date: 2025
Number of Pages: 3448 Pages
B6.7/L9 - Body Control Module (BCM)
B6.7/L9 - Body Control Module (BCM) Design 1
B6.7 - ABS Proprietary J1939
B6.7 - ABS Proprietary J1939 Design 9
B6.7 - Body Standard J1939 (250Kbps) - 05/26/2025
and Newer Models
B6.7 - Body Standard J1939 (250Kbps) - 05/26/2025 and Newer Models
Design 10
B6.7 - Body Standard J1939 (250Kbps) - 12/10/2021-
05/25/2025
B6.7 - Body Standard J1939 (250Kbps) - 12/10/2021-05/25/2025 Design 11
B6.7 - Cab Standard J1939 (250Kbps)
B6.7 - Cab Standard J1939 (250Kbps) Design 12
B6.7 - Engine Proprietary J1939
B6.7 - Engine Proprietary J1939 Design 13
B6.7 - Fusion Proprietary J1939
B6.7 - Fusion Proprietary J1939 Design 14
B6.7 - Low Speed (125 kbps) J1939
B6.7 - Low Speed (125 kbps) J1939 Design 15
B6.7 - Powertrain Standard J1939 (500kbps) -
06/30/2025 and Newer Models
B6.7 - Powertrain Standard J1939 (500kbps) - 06/30/2025 and Newer Models
Design 16
12/10/2021 - 06/29/2025 Models
B6.7 - Powertrain Standard J1939 (500kbps) - 12/10/2021 - 06/29/2025 Models
Design 17
B6.7 - Telematics J1708
B6.7 - Telematics J1708 Design 18
B6.7 - 2017-2027 N2 Proprietary J1939
B6.7 - 2017-2027 N2 Proprietary J1939 Design 19
L9 - ABS Proprietary J1939
L9 - ABS Proprietary J1939 Design 20
L9 - Body Standard J1939 (250Kbps) - 05/26/2025 and
Newer Models
L9 - Body Standard J1939 (250Kbps) - 05/26/2025 and Newer Models Design 21
L9 - Body Standard J1939 (250Kbps) - 12/10/2021-
05/25/2025
L9 - Body Standard J1939 (250Kbps) - 12/10/2021-05/25/2025 Design 22
L9 - Cab Standard J1939 (250Kbps)
L9 - Cab Standard J1939 (250Kbps) Design 23
L9 - Engine Proprietary J1939
L9 - Engine Proprietary J1939 Design 24
iL9 - Fusion Proprietary J1939
L9 - Fusion Proprietary J1939 Design 25
L9 - Low Speed J1939 (125kbps)
L9 - Low Speed J1939 (125kbps) Design 26
L9 - Powertrain Standard J1939 (500kbps) - 06/30/2025
and Newer Models
L9 - Powertrain Standard J1939 (500kbps) - 06/30/2025 and Newer Models
Design 27
L9 - Powertrain Standard J1939 (500kbps) - 12/10/2021
- 06/29/2025 Models
L9 - Powertrain Standard J1939 (500kbps) - 12/10/2021 - 06/29/2025 Models
Design 28
L9 - Telematics J1708
L9 - Telematics J1708 Design 29
L9 - 2017-2027 N2 Proprietary J1939
L9 - 2017-2027 N2 Proprietary J1939 Design 30
B6.7 - Engine (Control) Cummins
B6.7 - Engine (Control) Cummins Design 31
L9 - Engine (Control) Cummins
L9 - Engine (Control) Cummins Design 32
B6.7/L9 - GEN IV Cluster (Monitor)
B6.7/L9 - GEN IV Cluster (Monitor) Design 33
B6.7/L9 - Instrument Cluster (Premium)
B6.7/L9 - Instrument Cluster (Premium) Design 34
B6.7/L9 - Instrument Cluster (Standard)
B6.7/L9 - Instrument Cluster (Standard) Design 36
B6.7/L9 - Instrument Cluster - Bulb Check
B6.7/L9 - Instrument Cluster - Bulb Check Design 37
B6.7/L9 - Instrument Cluster - Request and Status
B6.7/L9 - Instrument Cluster - Request and Status Design 38
B6.7/L9 - Ground Splice Packs 1022 & 1023
B6.7/L9 - Ground Splice Packs 1022 & 1023 Design 39
B6.7/L9 - Ground Splice Pack 1027
B6.7/L9 - Ground Splice Pack 1027 Design 40
B6.7/L9 - Interior Dual Post Ground Stud-Cowl Wall
B6.7/L9 - Interior Dual Post Ground Stud-Cowl Wall Design 41
B6.7/L9 - ZVR Splice Packs 1620
B6.7/L9 - ZVR Splice Packs 1620 Design 42
B6.7 - Center Chassis Ground Splice Packs
8802/8805/8807/8809
B6.7 - Center Chassis Ground Splice Packs 8802/8805/8807/8809 Design 43
iiL9 - Center Chassis Ground Splice Packs
8802/8805/8807/8809
L9 - Center Chassis Ground Splice Packs 8802/8805/8807/8809 Design 44
B6.7 - Forward Chassis Ground Splice Pack 8800
B6.7 - Forward Chassis Ground Splice Pack 8800 Design 45
B6.7/L9 - Forward Chassis Splice Pack 8801
B6.7/L9 - Forward Chassis Splice Pack 8801 Design 46
L9 - Forward Chassis Ground Splice Pack 8800
L9 - Forward Chassis Ground Splice Pack 8800 Design 47
B6.7 - Engine Ground Distribution - Ring Terminals
B6.7 - Engine Ground Distribution - Ring Terminals Design 48
B6.7 - Engine Ground Distribution- Splice Packs
B6.7 - Engine Ground Distribution- Splice Packs Design 49
B6.7 - Powertrain ZVR Splice Pack 6747
B6.7 - Powertrain ZVR Splice Pack 6747 Design 50
B6.7 - Power Train Splice Pack 6704
B6.7 - Power Train Splice Pack 6704 Design 51
L9 - Powertrain Ground Splice Packs 6704 & 6704B
L9 - Powertrain Ground Splice Packs 6704 & 6704B Design 52
L9 - Powertrain ZVR Splice Pack 6702
L9 - Powertrain ZVR Splice Pack 6702 Design 53
L9 - Powertrain ZVR Splice Pack 6747
L9 - Powertrain ZVR Splice Pack 6747 Design 54
B6.7/L9 - Lighting Control Module
B6.7/L9 - Lighting Control Module Design 55
B6.7 - Aftertreatment PDM
B6.7 - Aftertreatment PDM Design 57
L9 - Aftertreatment PDM
L9 - Aftertreatment PDM Design 58
B6.7 - Auxilary Power Fuse
B6.7 - Auxilary Power Fuse Design 59
L9 - Auxilary Power Fuse
L9 - Auxilary Power Fuse Design 60
B6.7/L9 - Chassis PDM
B6.7/L9 - Chassis PDM Design 61
B6.7/L9 - Battery Feed
B6.7/L9 - Battery Feed Design 62
B6.7/L9 - Interior PDM Chart
B6.7/L9 - Interior PDM Chart Design 63
B6.7/L9 - Key Switch Accessory
B6.7/L9 - Key Switch Accessory Design 64
iiiB6.7/L9 - Key Switch Ignition
B6.7/L9 - Key Switch Ignition Design 65
B6.7/L9 - Relays - Grid Management
B6.7/L9 - Relays - Grid Management Design 66
B6.7/L9 - ABS CAN Splice Pack - 1410
B6.7/L9 - ABS CAN Splice Pack - 1410 Design 67
B6.7/L9 - Panel Light Dimmer Splice Pack - 1021
B6.7/L9 - Panel Light Dimmer Splice Pack - 1021 Design 68
B6.7/L9 - Park / Turn Lights Splice Packs
1623/1625/400
B6.7/L9 - Park / Turn Lights Splice Packs 1623/1625/400 Design 69
B6.7 - Underhood PDM
B6.7 - Underhood PDM Design 70
L9 - Underhood PDM
L9 - Underhood PDM Design 71
Air Horn (Highway) W/Hardwired Switch
Air Horn (Highway) W/Hardwired Switch Design 72
B6.7/L9 - Radio
B6.7/L9 - Radio Design 73
B6.7/L9 - Radio w/Bluetooth
B6.7/L9 - Radio w/Bluetooth Design 74
B6.7/L9 - Radio w/Bluetooth without Steering Wheel
Pod
B6.7/L9 - Radio w/Bluetooth without Steering Wheel Pod Design 76
B6.7/L9 - Radio w/Steering Wheel Pod
B6.7/L9 - Radio w/Steering Wheel Pod Design 77
B6.7/L9 - Speakers: Four Speakers Daycab BT n/QC
B6.7/L9 - Speakers:Four Speakers Daycab BT n/QC Design 79
B6.7/L9 - Speakers: Four Speakers Daycab n/BT n/QC
B6.7/L9 - Speakers:Four Speakers Daycab n/BT n/QC Design 80
B6.7/L9 - Speakers: Four Speakers Daycab n/BT w/QC
B6.7/L9 - Speakers:Four Speakers Daycab n/BT w/QC Design 81
B6.7/L9 - Speakers: Four Speakers Daycab w/BT w/QC
B6.7/L9 - Speakers:Four Speakers Daycab w/BT w/QC Design 82
B6.7/L9 - Speakers: Two Speakers Daycab BT n/QC
B6.7/L9 - Speakers:Two Speakers Daycab BT n/QC Design 83
B6.7/L9 - Speakers: Two Speakers Daycab n/BT n/QC
B6.7/L9 - Speakers:Two Speakers Daycab n/BT n/QC Design 84
B6.7/L9 - Speakers: Two Speakers n/BT w/QC
B6.7/L9 - Speakers:Two Speakers n/BT w/QC Design 85
B6.7/L9 - Speakers: Two Speakers w/BT w/QC
B6.7/L9 - Speakers:Two Speakers w/BT w/QC Design 86
ivB6.7/L9 - Auxiliary Power (40A) HSD
B6.7/L9 - Auxiliary Power (40A) HSD Design 87
B6.7 - Backup Alarm (From Relay to 5 Pin Daisy Chain
Backup Alarm Plugs in)
B6.7 - Backup Alarm (From Relay to 5 Pin Daisy Chain Backup Alarm Plugs in)
Design 88
to Backup Alarm W/ Extension)
B6.7 - Backup Alarm (From Relay to 5 Pin Daisy Chain to Backup Alarm W/
Extension) Design 89
to Backup Alarm)
B6.7 - Backup Alarm (From Relay to 5 Pin Daisy Chain to Backup Alarm)
Design 90
Chain. Backup Alarm Plugs in W/ Extension)
B6.7 - Backup Alarm (From Relay to 5 Pin Daisy Chain. Backup Alarm Plugs in
W/ Extension) Design 91
B6.7 - Back-Up Alarm (Automatic) W/O Tailboard
B6.7 - Back-Up Alarm (Automatic) W/O Tailboard Design 92
B6.7 - Back-Up Alarm (Automatic) W/ Tailboard
B6.7 - Back-Up Alarm (Automatic) W/ Tailboard Design 93
B6.7 - Back-Up Alarm (Manual) W/O Tailboard
B6.7 - Back-Up Alarm (Manual) W/O Tailboard Design 94
B6.7 - Back-Up Alarm (Manual) W/ Tailboard
B6.7 - Back-Up Alarm (Manual) W/ Tailboard Design 95
L9 - Backup Alarm (From Relay to 5 Pin Daisy Chain
L9 - Backup Alarm (From Relay to 5 Pin Daisy Chain Backup Alarm Plugs in)
Design 96
L9 - Backup Alarm (From Relay to 5 Pin Daisy Chain to Backup Alarm W/
Extension) Design 97
to Backup Alarm)
L9 - Backup Alarm (From Relay to 5 Pin Daisy Chain to Backup Alarm) Design 98
L9 - Backup Alarm (From Relay to 5 Pin Daisy Chain.
L9 - Backup Alarm (From Relay to 5 Pin Daisy Chain. Backup Alarm Plugs in W/
Extension) Design 99
L9 - Back-Up Alarm (Automatic) W/O Tailboard
L9 - Back-Up Alarm (Automatic) W/O Tailboard Design 100
L9 - Back-Up Alarm (Automatic) W/ Tailboard
vL9 - Back-Up Alarm (Automatic) W/ Tailboard Design 101
L9 - Back-Up Alarm (Manual) W/O Tailboard
L9 - Back-Up Alarm (Manual) W/O Tailboard Design 102
L9 - Back-Up Alarm (Manual) W/ Tailboard
L9 - Back-Up Alarm (Manual) W/ Tailboard Design 104
B6.7/L9 - Banana Plugs Receptacle
B6.7/L9 - Banana Plugs Receptacle Design 106
B6.7/L9 - Surround View (Camera Display, 1 Camera
EOF, Prewire)
B6.7/L9 - Surround View (Camera Display, 1 Camera EOF, Prewire) Design 107
B6.7/L9 - CB Radio Power Only
B6.7/L9 - CB Radio Power Only Design 108
B6.7/L9 - CB Radio Power Only (Single Antenna)
B6.7/L9 - CB Radio Power Only (Single Antenna) Design 109
B6.7/L9 - Cigar Lighter
B6.7/L9 - Cigar Lighter Design 110
B6.7/L9 - Cigar Lighter Aux APO
B6.7/L9 - Cigar Lighter Aux APO Design 111
B6.7/L9 - Cigar LighterB6.7/L9 - Cigar Lighter- Design 114
B6.7/L9 - Forward Auxiliary Power Source (1 APO)
B6.7/L9 - Forward Auxiliary Power Source (1 APO) Design 115
B6.7/L9 - Forward Auxiliary Power Source (2 APO)
B6.7/L9 - Forward Auxiliary Power Source (2 APO) Design 119
B6.7/L9 - Forward Auxiliary Power Source (3 APO)
B6.7/L9 - Forward Auxiliary Power Source (3 APO) Design 125
B6.7/L9 - Standard APO
B6.7/L9 - Standard APO Design 129
B6.7/L9 - Standard APO and Aux APO
B6.7/L9 - Standard APO and Aux APO Design 130
B6.7/L9 - Cruise Control (W/ One Telltale 10 Pin)
B6.7/L9 - Cruise Control (W/ One Telltale 10 Pin) Design 133
B6.7/L9 - Cruise Control (W/ One Telltale 4 Pin)
B6.7/L9 - Cruise Control (W/ One Telltale 4 Pin) Design 135
B6.7/L9 - Vehicle Speed Control (Cruise Control) 10
Pin
B6.7/L9 - Vehicle Speed Control (Cruise Control) 10 Pin Design 137
B6.7/L9 - Vehicle Speed Control (Cruise Control) 4 Pin
B6.7/L9 - Vehicle Speed Control (Cruise Control) 4 Pin Design 138
viB6.7/ L9 - Vehicle Speed Control (Cruise Control)
(Steering Wheel Controls) (No PIM)
B6.7/ L9 - Vehicle Speed Control (Cruise Control) (Steering Wheel Controls) (No
PIM) Design 139
B6.7/L9 - Door Ajar Reminder (Entry/Exit) 2 Door
B6.7/L9 - Door Ajar Reminder (Entry/Exit) 2 Door Design 140
B6.7/L9 - Door Ajar Reminder(Entry /Exit): 4 Door
B6.7/L9 - Door Ajar Reminder(Entry /Exit):4 Door Design 141
B6.7/L9 - Door Pod Module (2 Door)
B6.7/L9 - Door Pod Module (2 Door) Design 142
B6.7/L9 - Door Pod Module (4 Door)
B6.7/L9 - Door Pod Module (4 Door) Design 143
B6.7/L9 - Mirrors (Heated) (Door Pod Actuated, 2 Cab
and 1 Hood Mirror Right Side Only)
B6.7/L9 - Mirrors (Heated) (Door Pod Actuated, 2 Cab and 1 Hood Mirror Right
Side Only) Design 144
and 2 Hood Mirrors)
B6.7/L9 - Mirrors (Heated) (Door Pod Actuated, 2 Cab and 2 Hood Mirrors)
Design 146
B6.7/L9 - Mirrors (Heated) (MUX Switch, 2 Cab and 2
Hood Mirrors)
B6.7/L9 - Mirrors (Heated) (MUX Switch, 2 Cab and 2 Hood Mirrors) Design 148
B6.7/L9 - Mirrors (Power) Control Switch Actuated
B6.7/L9 - Mirrors (Power) Control Switch Actuated Design 150
B6.7 - City Horn W/10PIN CLK
B6.7 - City Horn W/10PIN CLK Design 152
B6.7 - City Horn W/4PIN CLK
B6.7 - City Horn W/4PIN CLK Design 154
L9 - City Horn W/10PIN CLK
L9 - City Horn W/10PIN CLK Design 156
L9 - City Horn W/4PIN CLK
L9 - City Horn W/4PIN CLK Design 158
B6.7/L9 - Heated Windshield
B6.7/L9 - Heated Windshield Design 160
B6.7/ L9 - Heated Windshield (W/ DS Heating Grid)
B6.7/ L9 - Heated Windshield (W/ DS Heating Grid) Design 161
B6.7/L9 - Hood Switch
B6.7/L9 - Hood Switch Design 162
B6.7/L9 - Multiplexed Switch Pack (Primary Switch)
B6.7/L9 - Multiplexed Switch Pack (Primary Switch) Design 164
B6.7/L9 - Real Time Clock
viiB6.7/L9 - Real Time Clock Design 165
B6.7/L9 - Remote Keyless Access
B6.7/L9 - Remote Keyless Access Design 166
B6.7 - Over The Air Electrical I/O (OnCommand Link /
N2 Module)
B6.7 - Over The Air Electrical I/O (OnCommand Link / N2 Module) Design 167
B6.7/L9 - Telematics (Omnivision w/J1939)
B6.7/L9 - Telematics (Omnivision w/J1939) Design 168
B6.7/L9 - Telematics (Peoplenet PMG)
B6.7/L9 - Telematics (Peoplenet PMG) Design 169
B6.7/L9 - Telematics (PEOPLE NET MD)
B6.7/L9 - Telematics (PEOPLE NET MD) Design 170
B6.7/L9 - Telematics (XATANET W/J1708)
B6.7/L9 - Telematics (XATANET W/J1708) Design 171
B6.7/L9 - Telematics (XATANET W/J1939)
B6.7/L9 - Telematics (XATANET W/J1939) Design 172
B6.7/L9 - Telematics (Zonar)
B6.7/L9 - Telematics (Zonar) Design 173
L9 - Over The Air Electrical I/O (OnCommand Link / N2
Module)
L9 - Over The Air Electrical I/O (OnCommand Link / N2 Module) Design 174
N2 Module) (2024 & Newer Models)
B6.7 - Over The Air Electrical I/O (OnCommand Link / N2 Module) (2024 & Newer
Models) Design 175
B6.7/L9 - Over The Air Electrical I/O (OnCommand
Link / N2 Module)
B6.7/L9 - Over The Air Electrical I/O (OnCommand Link / N2 Module) Design 176
B6.7/L9 - Over the Air Programming (OnCommand
Link / N2 Module)
B6.7/L9 - Over the Air Programming (OnCommand Link / N2 Module) Design 177
L9 - Over The Air Electrical I/O (OnCommand Link / N2 Module) (2024 & Newer
Models) Design 178
B6.7/L9 - Telematics (Aftermarket W/ 3 TMC
Connector)
B6.7/L9 - Telematics (Aftermarket W/ 3 TMC Connector) Design 179
B6.7/L9 - Theft Deterrent (Without additional relay)
B6.7/L9 - Theft Deterrent (Without additional relay) Design 181
B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 AutoLocate -
1 Repeater)
B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 AutoLocate - 1 Repeater) Design 182
viiiB6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)
B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater) Design 190
Repeater)(Option 2)
B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(Option 2) Design 194
B6.7/L9 - Aux Power (USB) - 1 USB A, 1 USB C
B6.7/L9 - Aux Power (USB) - 1 USB A, 1 USB C Design 198
B6.7/L9 - Aux Power (USB) - 2 USB A, 2 USB C
B6.7/L9 - Aux Power (USB) - 2 USB A, 2 USB C Design 203
B6.7/L9 - Aux Power (USB) - 3 USB A, 3 USB C
B6.7/L9 - Aux Power (USB) - 3 USB A, 3 USB C Design 213
B6.7/L9 - One USB
B6.7/L9 - One USB Design 222
B6.7/L9 - Two USB
B6.7/L9 - Two USB Design 223
B6.7/L9 - Vehicle Alarm System
B6.7/L9 - Vehicle Alarm System Design 225
B6.7/L9 - Vehicle Sleep Mode
B6.7/L9 - Vehicle Sleep Mode Design 226
B6.7/L9 2-Way Radio
B6.7/L9 2-Way Radio Design 227
Diesel Particulate Filter (DPF) (Regen Switch Only)
Diesel Particulate Filter (DPF) (Regen Switch Only) Design 229
Diesel Particulate Filter (DPF) (With Monostable Inhibit
SW)
Diesel Particulate Filter (DPF) (With Monostable Inhibit SW) Design 230
Diesel Particulate Filter (DPF) (W/ Bi-Stable Inhibit
SW)
Diesel Particulate Filter (DPF) (W/ Bi-Stable Inhibit SW) Design 231
B6.7/L9 - DPF - Regen Switch Only
B6.7/L9 - DPF - Regen Switch Only Design 232
B6.7/L9 - DPF - With Bistable Inhibit Sw
B6.7/L9 - DPF - With Bistable Inhibit Sw Design 233
B6.7/L9 - DPF - With Monostable Inhibit Sw
B6.7/L9 - DPF - With Monostable Inhibit Sw Design 234
B6.7 - Selective Catalytic Reduction (SCR)
B6.7 - Selective Catalytic Reduction (SCR) Design 235
B6.7 - Selective Catalytic Reduction (SCR): 2024 and
newer models
B6.7 - Selective Catalytic Reduction (SCR):2024 and newer models Design 237
L9 - Selective Catalytic Reduction (SCR)
L9 - Selective Catalytic Reduction (SCR) Design 239
ixL9 - Selective Catalytic Reduction (SCR): 2024 and
newer models
L9 - Selective Catalytic Reduction (SCR):2024 and newer models Design 241
B6.7/L9 - Adjustable Engine Speed Control (PTO) 10-
pin
B6.7/L9 - Adjustable Engine Speed Control (PTO) 10-pin Design 243
B6.7/L9 - Adjustable Engine Speed Control (PTO) 4-
pin
B6.7/L9 - Adjustable Engine Speed Control (PTO) 4-pin Design 245
B6.7/ L9 - Engine Idle Increment/Decrement (Steering
Wheel Controls)
B6.7/ L9 - Engine Idle Increment/Decrement (Steering Wheel Controls)
Design 246
B6.7/ L9 - Engine Speed Control (PTO) (Steering
Wheel Controls)
B6.7/ L9 - Engine Speed Control (PTO) (Steering Wheel Controls) Design 247
B6.7 - Auxiliary Air Solenoids (1 Normally Closed)
B6.7 - Auxiliary Air Solenoids (1 Normally Closed) Design 248
B6.7 - Auxillary Air Solenoids Normally Open
B6.7 - Auxillary Air Solenoids Normally Open Design 249
L9 - Auxiliary Air Solenoids (1 Normally Closed)
L9 - Auxiliary Air Solenoids (1 Normally Closed) Design 250
L9 - Auxiliary Air Solenoids (2 Normally Closed)
L9 - Auxiliary Air Solenoids (2 Normally Closed) Design 251
L9 - Auxiliary Air Solenoids (3 Normally Closed)
L9 - Auxiliary Air Solenoids (3 Normally Closed) Design 254
B6.7 - Altec (N/BB & W/Manual XMSN & W/ CUMMINS
Engine)
B6.7 - Altec (N/BB & W/Manual XMSN & W/ CUMMINS Engine) Design 255
Engine) (2024 & Newer Models)
B6.7 - Altec (N/BB & W/Manual XMSN & W/ CUMMINS Engine) (2024 & Newer
Models) Design 258
B6.7 - Body Builder - Altec (N/BB & W/1K2K Trans)
B6.7 - Body Builder - Altec (N/BB & W/1K2K Trans) Design 261
B6.7 - Body Builder - Altec (N/BB & W/3K4K Trans &
W/ CUMMINS Engine)
B6.7 - Body Builder - Altec (N/BB & W/3K4K Trans & W/ CUMMINS Engine)
Design 264
B6.7 - Body Builder - Altec (W/BB & W/Manual Trans &
W/ CUMMINS Engine)
B6.7 - Body Builder - Altec (W/BB & W/Manual Trans & W/ CUMMINS Engine)
Design 267
xB6.7 - Body Builder - Altec (W/BB & W/Manual Trans &
W/ CUMMINS Engine): 2021-2024
Engine):2021-2024 Design 273
B6.7 - Body Builder - Altec (W/BB & W/1K2K Trans)
B6.7 - Body Builder - Altec (W/BB & W/1K2K Trans) Design 279
B6.7 - Body Builder - Altec (W/BB & W/3K4K Trans &
W/ CUMMINS Engine)
B6.7 - Body Builder - Altec (W/BB & W/3K4K Trans & W/ CUMMINS Engine)
Design 285
L9 - Body Builder - Altec (N/BB & W/Manual XMSN &
W/ CUMMINS Engine)
L9 - Body Builder - Altec (N/BB & W/Manual XMSN & W/ CUMMINS Engine)
Design 291
Engine):2021-2024 Design 294
L9 - Body Builder - Altec (N/BB & W/1K2K Trans)
L9 - Body Builder - Altec (N/BB & W/1K2K Trans) Design 297
L9 - Body Builder - Altec (N/BB & W/3K4K Trans & W/
CUMMINS Engine)
L9 - Body Builder - Altec (N/BB & W/3K4K Trans & W/ CUMMINS Engine)
Design 299
L9 - Body Builder - Altec (W/BB & W/Manual Trans &
W/ CUMMINS Engine)
L9 - Body Builder - Altec (W/BB & W/Manual Trans & W/ CUMMINS Engine)
Design 301
Engine):2021-2024 Design 307
L9 - Body Builder - Altec (W/BB & W/1K2K Trans)
L9 - Body Builder - Altec (W/BB & W/1K2K Trans) Design 313
L9 - Body Builder - Altec (W/BB & W/3K4K Trans & W/
CUMMINS Engine)
L9 - Body Builder - Altec (W/BB & W/3K4K Trans & W/ CUMMINS Engine)
Design 318
B6.7/L9 - Auxiliary Power (40A) HSD 1
B6.7/L9 - Auxiliary Power (40A) HSD 1 Design 323
B6.7/L9 - Body Builder Aux Power (In Cab, BOC, or
EOF)
B6.7/L9 - Body Builder Aux Power (In Cab, BOC, or EOF) Design 324
B6.7/L9 - Dual Auxiliary Power with Interlock
B6.7/L9 - Dual Auxiliary Power with Interlock Design 327
xiB6.7 - Body Builder Lighting - Separate Turn and Stop
Lamps (Blunt Cut)
B6.7 - Body Builder Lighting - Separate Turn and Stop Lamps (Blunt Cut)
Design 328
Lamps (Blunt Cut) Option2
B6.7 - Body Builder Lighting - Separate Turn and Stop Lamps (Blunt Cut) Option2
Design 329
L9 - Body Builder Lighting - Combined Turn and Stop
Lamps (Automatic)
L9 - Body Builder Lighting - Combined Turn and Stop Lamps (Automatic)
Design 330
Lamps (Manual) Option2
L9 - Body Builder Lighting - Combined Turn and Stop Lamps (Manual) Option2
Design 332
L9 - Body Builder Lighting - Separate Turn and Stop
Lamps (Blunt Cut)
L9 - Body Builder Lighting - Separate Turn and Stop Lamps (Blunt Cut)
Design 336
L9 - Body Builder Lighting - Separate Turn and Stop Lamps (Blunt Cut) Option2
Design 337
B6.7/L9 - Body Builder Prewire (8 Wire Firewall Pass
through)
B6.7/L9 - Body Builder Prewire (8 Wire Firewall Pass through) Design 338
B6.7 - I/O Expansion
B6.7 - I/O Expansion Design 339
L9 - I/O Expansion
L9 - I/O Expansion Design 340
B6.7 - Powertrain Body Builder Connector (12XAT)
B6.7 - Powertrain Body Builder Connector (12XAT) Design 341
B6.7 - Powertrain Body Builder Connector (12XBM)
B6.7 - Powertrain Body Builder Connector (12XBM) Design 342
L9 - Powertrain Body Builder Connector (12XAT)
L9 - Powertrain Body Builder Connector (12XAT) Design 343
L9 - Powertrain Body Builder Connector (12XBM)
L9 - Powertrain Body Builder Connector (12XBM) Design 344
B6.7 - Power Lift Gate
B6.7 - Power Lift Gate Design 345
L9 - Power Lift Gate
L9 - Power Lift Gate Design 346
xiiB6.7/L9 - DLB - Remote Power Modules (1 RPM n/
Switch Packs)
B6.7/L9 - DLB - Remote Power Modules (1 RPM n/ Switch Packs) Design 347
B6.7/L9 - DLB - Remote Power Modules (1 RPM w/
Switch Packs) Option2
B6.7/L9 - DLB - Remote Power Modules (1 RPM w/ Switch Packs) Option2
Design 350
Switch Packs) Option 1
B6.7/L9 - DLB - Remote Power Modules (1 RPM w/ Switch Packs) Option 1
Design 352
B6.7/L9 - DLB - Remote Power Modules (2 RPM n/
Switch Pack)
B6.7/L9 - DLB - Remote Power Modules (2 RPM n/ Switch Pack) Design 355
B6.7/L9 - DLB - Remote Power Modules (2 RPM w/
Switch Packs)
B6.7/L9 - DLB - Remote Power Modules (2 RPM w/ Switch Packs) Design 359
B6.7/L9 - DLB - Remote Power Modules (3 RPM w/
Swtich Packs)
B6.7/L9 - DLB - Remote Power Modules (3 RPM w/ Swtich Packs) Design 363
B6.7/L9 - DLB - Remote Power Module (3 RPM
n/Switch Pack)
B6.7/L9 - DLB - Remote Power Module (3 RPM n/Switch Pack) Design 364
B6.7 - Remote Start/Stop
B6.7 - Remote Start/Stop Design 365
B6.7 - Remote Start/Stop w/ Emergency Pump
B6.7 - Remote Start/Stop w/ Emergency Pump Design 366
L9 - Remote Start/Stop
L9 - Remote Start/Stop Design 367
L9 - Remote Start/Stop w/ Emergency Pump
L9 - Remote Start/Stop w/ Emergency Pump Design 368
B6.7 - Transmission I/O (Allison Gen 6 1K/2K W/ Body
Builder)
B6.7 - Transmission I/O (Allison Gen 6 1K/2K W/ Body Builder) Design 369
B6.7 - Transmission I/O (Allison Gen 6 3K W/ Body
Builder)
B6.7 - Transmission I/O (Allison Gen 6 3K W/ Body Builder) Design 373
L9 - Transmission I/O (Allison Gen 6 3K W/ Body
Builder)
L9 - Transmission I/O (Allison Gen 6 3K W/ Body Builder) Design 379
B6.7 - Transmission Power Take Off (Auto Trans
Single PTO w/21 Parameters)
B6.7 - Transmission Power Take Off (Auto Trans Single PTO w/21 Parameters)
Design 385
xiiiB6.7 - Transmission Power Take Off (Auto Trans with
Lectradrive)
B6.7 - Transmission Power Take Off (Auto Trans with Lectradrive) Design 386
B6.7 - Transmission Power Take Off (Lectrashift PTO
with Manual Trans)
B6.7 - Transmission Power Take Off (Lectrashift PTO with Manual Trans)
Design 387
B6.7 - Transmission Power Take Off (Manual Trans
Single PTO w/ 21 Parameters)
B6.7 - Transmission Power Take Off (Manual Trans Single PTO w/ 21
Parameters) Design 388
B6.7 - Transmission Power Take Off (Single Input
configurable pull up or pull down)
B6.7 - Transmission Power Take Off (Single Input configurable pull up or pull
down) Design 389
B6.7 - Transmission Power Take Off (Single PTO W/
RPM and Auto Trans)
B6.7 - Transmission Power Take Off (Single PTO W/ RPM and Auto Trans)
Design 390
RPM and Manual Trans)
B6.7 - Transmission Power Take Off (Single PTO W/ RPM and Manual Trans)
Design 391
B6.7 - Transmission Power Take Off (60AKG)
B6.7 - Transmission Power Take Off (60AKG) Design 392
L9 - Transmission Power Take Off (Auto Trans Single
L9 - Transmission Power Take Off (Auto Trans Single PTO w/21 Parameters)
Design 393
L9 - Transmission Power Take Off (Auto Trans with
Lectradrive)
L9 - Transmission Power Take Off (Auto Trans with Lectradrive) Design 394
L9 - Transmission Power Take Off (Lectrashift PTO
with Manual Trans)
L9 - Transmission Power Take Off (Lectrashift PTO with Manual Trans)
Design 395
L9 - Transmission Power Take Off (Manual Trans
L9 - Transmission Power Take Off (Manual Trans Single PTO w/ 21 Parameters)
Design 396
L9 - Transmission Power Take Off (Single Input
L9 - Transmission Power Take Off (Single Input configurable pull up or pull down)
Design 397
L9 - Transmission Power Take Off (Single PTO W/
RPM and Auto Trans)
xivL9 - Transmission Power Take Off (Single PTO W/ RPM and Auto Trans)
Design 398
L9 - Transmission Power Take Off (Single PTO W/ RPM and Manual Trans)
Design 399
L9 - Transmission Power Take Off (60AKG)
L9 - Transmission Power Take Off (60AKG) Design 400
Dual Brake Switch
Dual Brake Switch Design 401
B6.7/L9 - Air Dryer (Single)
B6.7/L9 - Air Dryer (Single) Design 402
B6.7/ L9 - Air Dryer (Single)
B6.7/ L9 - Air Dryer (Single) Design 403
B6.7 - Drain Valve Heater
B6.7 - Drain Valve Heater Design 409
L9 - Drain Valve Heater
L9 - Drain Valve Heater Design 415
B6.7/L9 - Antilock Brake System (ABS) - Wabco 4
Channel Implementation
B6.7/L9 - Antilock Brake System (ABS) - Wabco 4 Channel Implementation
Design 419
B6.7/L9 - Antilock Brake System (ABS)- BENDIX 4
Channel Implemenation
B6.7/L9 - Antilock Brake System (ABS)- BENDIX 4 Channel Implemenation
Design 420
B6.7 - Hydraulic Brakes System
B6.7 - Hydraulic Brakes System Design 421
B6.7/L9 - Antilock Brake Systems (ABS) (Wabco
Hydraulic 4 Channel N/ Stability)
B6.7/L9 - Antilock Brake Systems (ABS) (Wabco Hydraulic 4 Channel N/ Stability)
Design 422
Hydraulic 4 Channel W/ Stability)
B6.7/L9 - Antilock Brake Systems (ABS) (Wabco Hydraulic 4 Channel W/
Stability) Design 423
L9 - Hydraulic Brakes System
L9 - Hydraulic Brakes System Design 424
B6.7/L9 - Park Brake Controls (Air Chassis Park
Brake)
B6.7/L9 - Park Brake Controls (Air Chassis Park Brake) Design 425
B6.7/L9 - Park Brake Controls (Monitoring) W (Door
Switch City Horn Hydraulic with Lever)
B6.7/L9 - Park Brake Controls (Monitoring) W (Door Switch City Horn Hydraulic
with Lever) Design 426
xvB6.7/L9 - Park Brake Controls (Monitoring) W (Door
Switch City Horn)
B6.7/L9 - Park Brake Controls (Monitoring) W (Door Switch City Horn) Design 427
(Hydraulic with Lever)
B6.7/L9 - Park Brake Controls (Monitoring) W (Hydraulic with Lever) Design 428
B6.7/L9 - Park Brake Controls (Monitoring) (Door
B6.7/L9 - Park Brake Controls (Monitoring) (Door Switch City Horn Hydraulic with
Lever) Design 429
Switch City Horn)
B6.7/L9 - Park Brake Controls (Monitoring) (Door Switch City Horn) Design 430
B6.7/L9 - Park Brake Controls (Monitoring) (Hydraulic
with Lever)
B6.7/L9 - Park Brake Controls (Monitoring) (Hydraulic with Lever) Design 431
B6.7/L9 - Park Brake Controls (Park Brake W/ Interlock
N/ Lift Air Chassis)
B6.7/L9 - Park Brake Controls (Park Brake W/ Interlock N/ Lift Air Chassis)
Design 432
B6.7/L9 - Park Brake Controls (Straight Truck)
Intellipark
B6.7/L9 - Park Brake Controls (Straight Truck) Intellipark Design 433
B6.7/L9 - Park Brake Controls (Tractor) Intellipark
B6.7/L9 - Park Brake Controls (Tractor) Intellipark Design 434
B6.7/L9 - Park Brake Control (Monitoring) (GEN IV
BCM)
B6.7/L9 - Park Brake Control (Monitoring) (GEN IV BCM) Design 436
B6.7/L9 - Park Brake Control (Monitoring) (W/Vehicle
Speed)
B6.7/L9 - Park Brake Control (Monitoring) (W/Vehicle Speed) Design 437
B6.7/L9 - Park Brake W/Motion Alarm W/O Stationary
Alarm (SAAR)
B6.7/L9 - Park Brake W/Motion Alarm W/O Stationary Alarm (SAAR) Design 438
B6.7/L9 - Park Brake W/Motion Alarm W/Stationary
Alarm (SAAR)
B6.7/L9 - Park Brake W/Motion Alarm W/Stationary Alarm (SAAR) Design 439
B6.7/L9 - Park Brake W/O Motion Alarm W/O
B6.7/L9 - Park Brake W/O Motion Alarm W/O Stationary Alarm (SAAR)
Design 440
B6.7/L9 - Park Brake W/O Motion Alarm W/Stationary
Alarm (SAAR)
B6.7/L9 - Park Brake W/O Motion Alarm W/Stationary Alarm (SAAR) Design 441
xviB6.7 - Stability Control (Bendix Straight Truck J1939
Driven Lamp)
B6.7 - Stability Control (Bendix Straight Truck J1939 Driven Lamp) Design 442
L9 - Bendix; Tractor or Towing Truck; N/ Air SUSP;
J1939 Driven Lamp
L9 - Bendix; Tractor or Towing Truck; N/ Air SUSP; J1939 Driven Lamp
Design 443
L9 - Bendix; Tractor or Towing Truck; W/ Air SUSP;
J1939 Driven Lamp
L9 - Bendix; Tractor or Towing Truck; W/ Air SUSP; J1939 Driven Lamp
Design 444
L9 - Stability Control (Bendix Straight Truck J1939
Driven Lamp)
L9 - Stability Control (Bendix Straight Truck J1939 Driven Lamp) Design 445
B6.7 - Traction Control Bendix
B6.7 - Traction Control Bendix Design 446
L9 - Traction Control Bendix
L9 - Traction Control Bendix Design 448
Oncoming Detection (Fusion 3.0)
Oncoming Detection (Fusion 3.0) Design 449
ACC Following Mode Selection (Bendix Wingman
Fusion 3.0)
ACC Following Mode Selection (Bendix Wingman Fusion 3.0) Design 450
Adaptive Cruise Control (Fusion 3.0 N/ DIU W/LDW
Audio Mute)
Adaptive Cruise Control (Fusion 3.0 N/ DIU W/LDW Audio Mute) Design 451
Adaptive Cruise Control (Fusion 3.0 N/ DIU)
Adaptive Cruise Control (Fusion 3.0 N/ DIU) Design 452
B6.7 - Adaptive Cruise Control w/o Display (Bendix)
B6.7 - Adaptive Cruise Control w/o Display (Bendix) Design 453
B6.7/L9 - Adaptive Cruise Control (Bendix Wingman
Advanced N/ DIU)
B6.7/L9 - Adaptive Cruise Control (Bendix Wingman Advanced N/ DIU)
Design 454
B6.7/L9 - Adaptive Cruise Control (Bendix - Fusion
W/O DIU & N/ Safety Direct & Reg Speakers)
B6.7/L9 - Adaptive Cruise Control (Bendix - Fusion W/O DIU & N/ Safety Direct &
Reg Speakers) Design 455
B6.7/L9 - Adaptive Cruise Control (Bendix - Fusion 2.0
N/ Safety Direct Conn & W/ Reg Speakers)
B6.7/L9 - Adaptive Cruise Control (Bendix - Fusion 2.0 N/ Safety Direct Conn &
W/ Reg Speakers) Design 456
& W/ Safety Direct Conn & W/ Reg Speakers)
xviiB6.7/L9 - Adaptive Cruise Control (Bendix - Fusion 2.0 & W/ Safety Direct Conn &
W/ Reg Speakers) Design 458
2.8/2.9 N/ Safety Direct Conn W/ Reg Speakers)
B6.7/L9 - Adaptive Cruise Control (Bendix - Fusion 2.8/2.9 N/ Safety Direct Conn
W/ Reg Speakers) Design 460
2.8/2.9 W/ Safety Direct Conn W/ Reg Speakers)
B6.7/L9 - Adaptive Cruise Control (Bendix - Fusion 2.8/2.9 W/ Safety Direct Conn
W/ Reg Speakers) Design 462
B6.7/L9 - Adaptive Cruise Control (Fusion 2.0 & W/
Safety Direct & Reg Speakers) option 1
B6.7/L9 - Adaptive Cruise Control (Fusion 2.0 & W/ Safety Direct & Reg
Speakers) option 1 Design 464
Safety Direct & Reg Speakers) option 2
Speakers) option 2 Design 465
B6.7/L9 - Adaptive Cruise Control (Fusion 3.0 N/ DIU)
B6.7/L9 - Adaptive Cruise Control (Fusion 3.0 N/ DIU) Design 466
L9 - Adaptive Cruise Control w/o Display (Bendix)
L9 - Adaptive Cruise Control w/o Display (Bendix) Design 467
B6.7/L9 - Collision Avoidance System (Warning)
B6.7/L9 - Collision Avoidance System (Warning) Design 468
B6.7/L9 - Camera Event Recorder N/Safety Direct
Cable
B6.7/L9 - Camera Event Recorder N/Safety Direct Cable Design 469
B6.7/L9 - Camera Event Recorder W/Safety Direct
Cable
B6.7/L9 - Camera Event Recorder W/Safety Direct Cable Design 470
Camera Event Recorder N/Safety Direct Cable Design 471
Camera Event Recorder W/Safety Direct Cable Design 472
B6.7 - Lane Departure Warning - (Bendix Fusion N/
Safety Direct)
B6.7 - Lane Departure Warning - (Bendix Fusion N/ Safety Direct) Design 473
L9 - Lane Departure Warning - (Bendix Fusion N/
Safety Direct)
L9 - Lane Departure Warning - (Bendix Fusion N/ Safety Direct) Design 475
B6.7 - Air Filter Flow Restriction Monitoring (LED
Indicator)
B6.7 - Air Filter Flow Restriction Monitoring (LED Indicator) Design 477
xviiiL9 - Air Filter Flow Restriction Monitoring (LED
Indicator)
L9 - Air Filter Flow Restriction Monitoring (LED Indicator) Design 478
B6.7/L9 - Engine Block Heater
B6.7/L9 - Engine Block Heater Design 479
B6.7/L9 - Engine Fuel and Block Heaters (Purchased
Assembly)
B6.7/L9 - Engine Fuel and Block Heaters (Purchased Assembly) Design 480
B6.7/L9 - Engine Oil and Block Heaters (Purchased
Assembly)
B6.7/L9 - Engine Oil and Block Heaters (Purchased Assembly) Design 481
B6.7/L9 - Engine Oil Fuel and Block Heaters
B6.7/L9 - Engine Oil Fuel and Block Heaters Design 482
B6.7/L9 - Engine Brake Mux Switch
B6.7/L9 - Engine Brake Mux Switch Design 483
B6.7/L9 - Engine Brake W/ Stalk Shifter
B6.7/L9 - Engine Brake W/ Stalk Shifter Design 484
B6.7 - Coolant Level Monitoring (No CLA Module)
B6.7 - Coolant Level Monitoring (No CLA Module) Design 485
B6.7 - Coolant Level Monitoring (No CLA Module) (2024 & Newer Models)
Design 486
L9 - Coolant Level Monitoring (No CLA Module)
L9 - Coolant Level Monitoring (No CLA Module) Design 487
L9 - Coolant Level Monitoring (No CLA Module) (2024
& Newer Models)
L9 - Coolant Level Monitoring (No CLA Module) (2024 & Newer Models)
Design 488
B6.7 - Cooling Fan Control (Fan Override, Cummins,
No Radiator GND)
B6.7 - Cooling Fan Control (Fan Override, Cummins, No Radiator GND)
Design 489
No Radiator GND): 2024 and newer models
B6.7 - Cooling Fan Control (Fan Override, Cummins, No Radiator GND):2024 and
newer models Design 490
B6.7 - Cooling Fan Control (No Fan Override,
Cummins, No Radiator)
B6.7 - Cooling Fan Control (No Fan Override, Cummins, No Radiator) Design 491
Cummins, No Radiator): 2024 and newer models
B6.7 - Cooling Fan Control (No Fan Override, Cummins, No Radiator):2024 and
newer models Design 492
xixL9 - Cooling Fan Control (Fan Override, Cummins, No
Radiator GND)
L9 - Cooling Fan Control (Fan Override, Cummins, No Radiator GND) Design 493
L9 - Cooling Fan Control (Fan Override, Cummins, No Radiator GND):2024 and
newer models Design 494
L9 - Cooling Fan Control (No Fan Override, Cummins,
No Radiator)
L9 - Cooling Fan Control (No Fan Override, Cummins, No Radiator) Design 495
L9 - Cooling Fan Control (No Fan Override, Cummins, No Radiator):2024 and
newer models Design 496
Engine Ramp UP (60AJA W/Cummins W/ Manual
Trans)
Engine Ramp UP (60AJA W/Cummins W/ Manual Trans) Design 497
Engine Ramp Up (60AJA W/ Cummins W/ AUTO AMT)
Engine Ramp Up (60AJA W/ Cummins W/ AUTO AMT) Design 498
Engine Ramp Up (60AJE 60AJJ W/ CUMMINS W/
AUTO AMT)
Engine Ramp Up (60AJE 60AJJ W/ CUMMINS W/ AUTO AMT) Design 499
MANUAL)
Engine Ramp Up (60AJE 60AJJ W/ CUMMINS W/ MANUAL) Design 500
Engine Ramp Up (60AJG W/CUMMINS W/ AUTO AMT)
Engine Ramp Up (60AJG W/CUMMINS W/ AUTO AMT) Design 501
Engine Ramp Up (60AJG W/CUMMINS W/ MANUAL)
Engine Ramp Up (60AJG W/CUMMINS W/ MANUAL) Design 502
B6.7/L9 - Exhaust Brake Horizon (Cummins) (2024 &
Newer Models)
B6.7/L9 - Exhaust Brake Horizon (Cummins) (2024 & Newer Models) Design 503
B6.7/L9 - Exhaust Brake (Cummins)
B6.7/L9 - Exhaust Brake (Cummins) Design 504
B6.7 - Starting Aid (Grid Heater)
B6.7 - Starting Aid (Grid Heater) Design 505
B6.7 - Starting Aid (Grid Heater) (2024 & Newer
Models)
B6.7 - Starting Aid (Grid Heater) (2024 & Newer Models) Design 506
L9 - Starting Aid (Grid Heater)
L9 - Starting Aid (Grid Heater) Design 508
L9 - Starting Aid (Grid Heater) (2024 & Newer Models)
L9 - Starting Aid (Grid Heater) (2024 & Newer Models) Design 509
xxB6.7 - Vehicle Acceleration (Wired to the ECM)
B6.7 - Vehicle Acceleration (Wired to the ECM) Design 510
B6.7 - Vehicle Acceleration (w/ Two PWR Two GND &
Two STS)
B6.7 - Vehicle Acceleration (w/ Two PWR Two GND & Two STS) Design 511
L9 - Vehicle Acceleration (Wired to the ECM)
L9 - Vehicle Acceleration (Wired to the ECM) Design 512
L9 - Vehicle Acceleration (w/ Two PWR Two GND &
Two STS)
L9 - Vehicle Acceleration (w/ Two PWR Two GND & Two STS) Design 513
B6.7/L9 - Alternate Flashing (Wig Wag) - Park Brake
disables High Beams
B6.7/L9 - Alternate Flashing (Wig Wag) - Park Brake disables High Beams
Design 514
disables Wig Wag
B6.7/L9 - Alternate Flashing (Wig Wag) - Park Brake disables Wig Wag
Design 515
B6.7/L9 - Automatic Lighting (Dual Sensor
Twilight/Solar)
B6.7/L9 - Automatic Lighting (Dual Sensor Twilight/Solar) Design 516
B6.7/L9 - Automatic Lighting (Single Sensor, Twilight)
B6.7/L9 - Automatic Lighting (Single Sensor, Twilight) Design 518
B6.7 - Backup Lights (Dual Daisy with extension)
Eaton/Manual Trans
B6.7 - Backup Lights (Dual Daisy with extension) Eaton/Manual Trans Design 520
B6.7 - Backup Light (Dual Daisy Reverse LT)Allison/ZF
Trans
B6.7 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans Design 521
Allison/ZF Trans 1K/2K
B6.7 - Backup Light (Dual Daisy Reverse LT) Allison/ZF Trans 1K/2K Design 522
Allison/ZF Trans 3K/4K
B6.7 - Backup Light (Dual Daisy Reverse LT) Allison/ZF Trans 3K/4K Design 524
B6.7 - Backup Light (Dual Daisy with
extension)Allison/ZF Trans
B6.7 - Backup Light (Dual Daisy with extension)Allison/ZF Trans Design 526
B6.7 - Backup Light (Dual Reverse Light) Allison/ZF
Trans 1K/2K
B6.7 - Backup Light (Dual Reverse Light) Allison/ZF Trans 1K/2K Design 527
Trans 3K/4K
B6.7 - Backup Light (Dual Reverse Light) Allison/ZF Trans 3K/4K Design 529
xxiB6.7 - Backup Lights (Dual Daisy Reverse Light)
Eaton/Manual Trans
B6.7 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans Design 531
B6.7 - Backup Lights (Dual Daisy Reverse)
Eaton/Manual Trans
B6.7 - Backup Lights (Dual Daisy Reverse) Eaton/Manual Trans Design 532
B6.7 - Backup Lights (Dual Reverse Light)
Eaton/Manual Trans
B6.7 - Backup Lights (Dual Reverse Light) Eaton/Manual Trans Design 533
B6.7 - Backup Lights (Reverse Lights) - Dual Lights
with Procision
B6.7 - Backup Lights (Reverse Lights) - Dual Lights with Procision Design 534
B6.7 - Backup Lights (Reverse Lights) - Procision
Daisy Chain
B6.7 - Backup Lights (Reverse Lights) - Procision Daisy Chain Design 535
B6.7 - Backup Lights (Reverse Lights) (Crossmember
Dual STT N/Back Up) Allison Trans
B6.7 - Backup Lights (Reverse Lights) (Crossmember Dual STT N/Back Up)
Allison Trans Design 536
B6.7 - Backup Light Single Reverse Light Allison
1K/2K
B6.7 - Backup Light Single Reverse Light Allison 1K/2K Design 537
3K/4K
B6.7 - Backup Light Single Reverse Light Allison 3K/4K Design 539
B6.7 - Backup Light (Single Reverse Light) Allison
1K/2K
B6.7 - Backup Light (Single Reverse Light) Allison 1K/2K Design 541
3K/4K
B6.7 - Backup Light (Single Reverse Light) Allison 3K/4K Design 543
B6.7 - Backup Light(Single Reverse Light) Allison
1K/2K
B6.7 - Backup Light(Single Reverse Light) Allison 1K/2K Design 545
3K/4K
B6.7 - Backup Light(Single Reverse Light) Allison 3K/4K Design 547
Dual STT N/Back Up) Eaton/Manual Trans
Eaton/Manual Trans Design 549
B6.7 - Backup Lights (Single Reverse Lights)
Eaton/Manual Trans
B6.7 - Backup Lights (Single Reverse Lights) Eaton/Manual Trans Design 550
xxiiB6.7 - Backup Lights (Reverse Lights) - Procision with
Tailboard Lights
B6.7 - Backup Lights (Reverse Lights) - Procision with Tailboard Lights
Design 551
L9 - Backup Light (Dual Daisy Reverse LT)Allison/ZF
Trans
L9 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans Design 552
L9 - Backup Light (Dual Daisy Reverse) Allison/ZF
Trans 3K/4K
L9 - Backup Light (Dual Daisy Reverse) Allison/ZF Trans 3K/4K Design 553
L9 - Backup Light (Dual Daisy with
L9 - Backup Light (Dual Daisy with extension)Allison/ZF Trans Design 555
L9 - Backup Light (Dual Reverse Light) Allison/ZF
Trans 3K/4K
L9 - Backup Light (Dual Reverse Light) Allison/ZF Trans 3K/4K Design 556
L9 - Backup Lights (Dual Daisy Reverse Light)
Eaton/Manual Trans
L9 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans Design 558
L9 - Backup Lights (Dual Daisy Reverse)
Eaton/Manual Trans
L9 - Backup Lights (Dual Daisy Reverse) Eaton/Manual Trans Design 559
L9 - Backup Lights (Dual Daisy with extension)
Eaton/Manual Trans
L9 - Backup Lights (Dual Daisy with extension) Eaton/Manual Trans Design 561
L9 - Backup Lights (Dual Reverse Light) Eaton/Manual
Trans
L9 - Backup Lights (Dual Reverse Light) Eaton/Manual Trans Design 562
L9 - Backup Lights (Reverse Lights) (Crossmember
L9 - Backup Lights (Reverse Lights) (Crossmember Dual STT N/Back Up) Allison
Trans Design 564
L9 - Backup Light (Single Reverse Light) Allison
3K/4K
L9 - Backup Light (Single Reverse Light) Allison 3K/4K Design 565
L9 - Backup Light (Single Reverse Light) - Allison
3K/4K
L9 - Backup Light (Single Reverse Light) - Allison 3K/4K Design 567
L9 - Backup Light - (Single Reverse Light) Allison
3K/4K
L9 - Backup Light - (Single Reverse Light) Allison 3K/4K Design 569
Eaton/Manual Trans Design 571
xxiiiL9 - Backup Lights (Single Reverse Lights)
Eaton/Manual Trans
L9 - Backup Lights (Single Reverse Lights) Eaton/Manual Trans Design 572
B6.7 - Rear Lights Stop (Daisy Chain)
B6.7 - Rear Lights Stop (Daisy Chain) Design 574
B6.7 - Rear Lights Stop - Dual Assembly
B6.7 - Rear Lights Stop - Dual Assembly Design 575
B6.7 - Rear Lights Stop - Single Assemby
B6.7 - Rear Lights Stop - Single Assemby Design 576
B6.7 - Rear Lights (Stop) (Daisy Chain N/ Extension
Harness)
B6.7 - Rear Lights (Stop) (Daisy Chain N/ Extension Harness) Design 577
B6.7 - Rear Light (Stop) Crossmember Dual STT
N/Back-Up
B6.7 - Rear Light (Stop) Crossmember Dual STT N/Back-Up Design 578
B6.7 - Rear Lights (Stop) (Daisy Chain W/ Extension
Harness)
B6.7 - Rear Lights (Stop) (Daisy Chain W/ Extension Harness) Design 579
L9 - Rear Lights Stop (Daisy Chain)
L9 - Rear Lights Stop (Daisy Chain) Design 580
L9 - Rear Lights Stop - Dual Assembly
L9 - Rear Lights Stop - Dual Assembly Design 581
L9 - Rear Lights Stop - Single Assemby
L9 - Rear Lights Stop - Single Assemby Design 582
L9 - Rear Lights (Stop) (Daisy Chain N/ Extension
Harness)
L9 - Rear Lights (Stop) (Daisy Chain N/ Extension Harness) Design 583
L9 - Rear Lights (Stop) (Daisy Chain W/ Extension
Harness)
L9 - Rear Lights (Stop) (Daisy Chain W/ Extension Harness) Design 584
L9 - Rear Light (Stop) Crossmember Dual STT N/BackUp
L9 - Rear Light (Stop) Crossmember Dual STT N/Back-Up Design 585
B6.7/L9 - Clearance and Identification Lights
B6.7/L9 - Clearance and Identification Lights Design 586
B6.7/L9 - Daytime Running Lights W/CAN
Headlamps(Post 11/22)
B6.7/L9 - Daytime Running Lights W/CAN Headlamps(Post 11/22) Design 587
Headlamps(Pre 11/22)
B6.7/L9 - Daytime Running Lights W/CAN Headlamps(Pre 11/22) Design 588
B6.7/ L9 - Daytime Running Lights N/CAN Headlamps
xxivB6.7/ L9 - Daytime Running Lights N/CAN Headlamps Design 589
B6.7/L9 - Directional Signals (Turn) (Halogen W/ Plow
Lights & W/ Fender Lights)
B6.7/L9 - Directional Signals (Turn) (Halogen W/ Plow Lights & W/ Fender Lights)
Design 590
B6.7/L9 - Directional Signals (Turn) (HALOGEN) W/O
Plow Lights W/O Fender Lights
B6.7/L9 - Directional Signals (Turn) (HALOGEN) W/O Plow Lights W/O Fender
Lights Design 592
Plow Lights W/ Fender Lights
B6.7/L9 - Directional Signals (Turn) (HALOGEN) W/O Plow Lights W/ Fender
Lights Design 594
B6.7/L9 - Directional Signals (Turn) (HALOGEN) W/ Plow Lights W/O Fender
Lights Design 596
B6.7/L9 - Directional Signals (Turn) (LED CAN
W/Heated) W/O Plow Lights, W/O Fender Lights
B6.7/L9 - Directional Signals (Turn) (LED CAN W/Heated) W/O Plow Lights, W/O
Fender Lights Design 598
W/Heated) W/O Plow Lights, W/ Fender Lights
Fender Lights Design 599
W/Heated) W/ Plow Lights, W/O Fender Lights
B6.7/L9 - Directional Signals (Turn) (LED CAN W/Heated) W/ Plow Lights, W/O
Fender Lights Design 600
W/Heated) W/ Plow Lights, W/ Fender Lights
Fender Lights Design 601
B6.7/L9 - Directional Signals (Turn) (LED CAN) W/O
B6.7/L9 - Directional Signals (Turn) (LED CAN) W/O Plow Lights W/O Fender
Lights Design 602
B6.7/L9 - Directional Signals (Turn) (LED CAN) W/O Plow Lights W/ Fender
Lights Design 604
B6.7/L9 - Directional Signals (Turn) (LED CAN) W/ Plow Lights W/O Fender
Lights Design 606
xxvB6.7/L9 - Directional Signal (Turn) (LED CAN W/ Plow
Lights W/ Fender Lights)
B6.7/L9 - Directional Signal (Turn) (LED CAN W/ Plow Lights W/ Fender Lights)
Design 608
B6.7/L9 - Exterior Lamp Reminder
B6.7/L9 - Exterior Lamp Reminder Design 610
B6.7 - Exterior Lamp Check
B6.7 - Exterior Lamp Check Design 611
L9 - Exterior Lamp Check
L9 - Exterior Lamp Check Design 612
B6.7/L9 - Front Fog Lamps
B6.7/L9 - Front Fog Lamps Design 613
B6.7/L9 - Prewire Front Fog Lights
B6.7/L9 - Prewire Front Fog Lights Design 614
B6.7/L9 - Marker Lighting (Halogen Headlights)
N/Plowlights N/Fender W/Guide Posts
B6.7/L9 - Marker Lighting (Halogen Headlights) N/Plowlights N/Fender W/Guide
Posts Design 615
N/Plowlights W/Fender N/Guide Posts
B6.7/L9 - Marker Lighting (Halogen Headlights) N/Plowlights W/Fender N/Guide
Posts Design 617
N/Plowlights W/Fender W/Guide Posts
B6.7/L9 - Marker Lighting (Halogen Headlights) N/Plowlights W/Fender W/Guide
Posts Design 619
N/Plowlight N/Fender N/Guide Posts
B6.7/L9 - Marker Lighting (Halogen Headlights) N/Plowlight N/Fender N/Guide
Posts Design 621
W/Plowlights W/Fender N/Guide Posts
B6.7/L9 - Marker Lighting (Halogen Headlights) W/Plowlights W/Fender N/Guide
Posts Design 623
W/Plowlight N/Fender N/Guide Posts
B6.7/L9 - Marker Lighting (Halogen Headlights) W/Plowlight N/Fender N/Guide
Posts Design 625
B6.7/L9 - Marker Lighting (LED CAN Headlamp
W/Heated) N/Plow Lts, N/Fender Lts, N/Guide Posts
B6.7/L9 - Marker Lighting (LED CAN Headlamp W/Heated) N/Plow Lts, N/Fender
Lts, N/Guide Posts Design 627
W/Heated) N/Plow Lts, N/Fender Lts, W/Guide Posts
Lts, W/Guide Posts Design 628
xxviB6.7/L9 - Marker Lighting (LED CAN Headlamp
W/Heated) N/Plow Lts, W/Fender Lts, N/Guide Posts
B6.7/L9 - Marker Lighting (LED CAN Headlamp W/Heated) N/Plow Lts, W/Fender
Lts, N/Guide Posts Design 629
W/Heated) W/Plow Lts, N/Fender Lts, N/Guide Posts
B6.7/L9 - Marker Lighting (LED CAN Headlamp W/Heated) W/Plow Lts, N/Fender
Lts, N/Guide Posts Design 630
W/Heated) W/Plow Lts, W/Fender Lts, N/Guide Posts
B6.7/L9 - Marker Lighting (LED CAN Headlamp W/Heated) W/Plow Lts, W/Fender
Lts, N/Guide Posts Design 631
B6.7/L9 - Marker Lighting (LED CAN Headlamp)
N/Plow Lts N/Fender Lts N/Guide Posts
B6.7/L9 - Marker Lighting (LED CAN Headlamp) N/Plow Lts N/Fender Lts
N/Guide Posts Design 632
N/Plow Lts N/Fender Lts W/Guide Posts
W/Guide Posts Design 634
N/Plow Lts W/Fender Lts N/Guide Posts
B6.7/L9 - Marker Lighting (LED CAN Headlamp) N/Plow Lts W/Fender Lts
N/Guide Posts Design 636
W/Plow Lts N/Fender Lts N/Guide Posts
B6.7/L9 - Marker Lighting (LED CAN Headlamp) W/Plow Lts N/Fender Lts
N/Guide Posts Design 638
W/Plow Lts W/Fender Lts N/Guide Posts
B6.7/L9 - Marker Lighting (LED CAN Headlamp) W/Plow Lts W/Fender Lts
N/Guide Posts Design 640
B6.7/L9 - Hazard Warning Light N/Trlr Socket
B6.7/L9 - Hazard Warning Light N/Trlr Socket Design 642
B6.7/L9 - Headlights (Halogen) W/O Plow Lights
B6.7/L9 - Headlights (Halogen) W/O Plow Lights Design 644
B6.7/L9 - Headlights (Halogen) W/ Plow Lights
B6.7/L9 - Headlights (Halogen) W/ Plow Lights Design 648
B6.7/L9 - Headlights (LED CAN ) W/ Plow Lights
B6.7/L9 - Headlights (LED CAN ) W/ Plow Lights Design 650
B6.7/L9 - Headlights (LED CAN) W/O Plow Lights
B6.7/L9 - Headlights (LED CAN) W/O Plow Lights Design 654
B6.7/L9 - Headlights (LED CAN) W/O Plow Lights,
W/Heated
B6.7/L9 - Headlights (LED CAN) W/O Plow Lights, W/Heated Design 658
xxviiB6.7/L9 - Headlights (LED CAN) W/ Plow Lights,
W/Heated
B6.7/L9 - Headlights (LED CAN) W/ Plow Lights, W/Heated Design 660
B6.7 - License Plate Light (Direct To Light)
B6.7 - License Plate Light (Direct To Light) Design 662
B6.7 - License Plate Light (LED BOX LAMP Daisy
Chain Tail Light with extension)
B6.7 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light with extension)
Design 663
Chain Tail Light)
B6.7 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light) Design 664
B6.7 - License Plate Light (Tail Light Single Assy.)
W/Less Power Module
B6.7 - License Plate Light (Tail Light Single Assy.) W/Less Power Module
Design 665
L9 - License Plate Light (Direct To Light)
L9 - License Plate Light (Direct To Light) Design 666
L9 - License Plate Light (LED BOX LAMP Daisy Chain
L9 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light with extension)
Design 667
Tail Light)
L9 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light) Design 668
Tail Light)
L9 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light) Design 669
L9 - License Plate Light (LED BOX LAMP Tail Light)
L9 - License Plate Light (LED BOX LAMP Tail Light) Design 670
L9 - License Plate Light (Tail Light Single Assy)
L9 - License Plate Light (Tail Light Single Assy) Design 671
Option2
L9 - License Plate Light (Tail Light Single Assy) Option2 Design 672
Option3
L9 - License Plate Light (Tail Light Single Assy) Option3 Design 673
W/Less Power Module
L9 - License Plate Light (Tail Light Single Assy) W/Less Power Module Design674
B6.7 - PARK LIGHTS - N/Marker Interrupt
B6.7 - PARK LIGHTS - N/Marker Interrupt Design 675
xxviiiB6.7 - PARK LIGHTS - W/Marker Interrupt 10pin
CLCKSPRING
B6.7 - PARK LIGHTS - W/Marker Interrupt 10pin CLCKSPRING Design 677
B6.7 - PARK LIGHTS - W/Marker Interrupt 4 pin
clockspring
B6.7 - PARK LIGHTS - W/Marker Interrupt 4 pin clockspring Design 679
L9 - PARK LIGHTS - N/Marker Interrupt
L9 - PARK LIGHTS - N/Marker Interrupt Design 681
L9 - PARK LIGHTS - W/Marker Interrupt 10pin
CLCKSPRING
L9 - PARK LIGHTS - W/Marker Interrupt 10pin CLCKSPRING Design 683
L9 - PARK LIGHTS - W/Marker Interrupt 4 pin
clockspring
L9 - PARK LIGHTS - W/Marker Interrupt 4 pin clockspring Design 685
B6.7/L9 - Mirror Lighting (Turns and Markers W/O
Door Pods)
B6.7/L9 - Mirror Lighting (Turns and Markers W/O Door Pods) Design 687
B6.7/L9 - Mirror Lighting (Turns and Markers W/ Door
Pods)
B6.7/L9 - Mirror Lighting (Turns and Markers W/ Door Pods) Design 688
B6.7/L9 - Snow Plow Lights Switch
B6.7/L9 - Snow Plow Lights Switch Design 689
B6.7 - Rear Lights (Tail Lights) Crossmember Dual
STT N/Back-Up
B6.7 - Rear Lights (Tail Lights) Crossmember Dual STT N/Back-Up Design 690
B6.7 - Rear Light Tail Light
B6.7 - Rear Light Tail Light Design 691
B6.7 - Rear Light (LED BOX LAMP Tail Light)
B6.7 - Rear Light (LED BOX LAMP Tail Light) Design 692
B6.7 - Rear Light (Tail Light)
B6.7 - Rear Light (Tail Light) Design 693
B6.7 - Rear Light (Tail Light) Daisy Chain W/ Extension
B6.7 - Rear Light (Tail Light) Daisy Chain W/ Extension Design 694
B6.7 - Rear Light (Tail Light) W Daisy Chain pair of
Box Lamps
B6.7 - Rear Light (Tail Light) W Daisy Chain pair of Box Lamps Design 695
B6.7 - Rear Light (Tail Light) W/Daisy Chain Pair of
Box Lamps
B6.7 - Rear Light (Tail Light) W/Daisy Chain Pair of Box Lamps Design 696
L9 - Rear Lights (Tail Lights) Crossmember Dual STT
N/Back-Up
L9 - Rear Lights (Tail Lights) Crossmember Dual STT N/Back-Up Design 697
L9 - Rear Light (LED BOX LAMP Tail Light)
xxixL9 - Rear Light (LED BOX LAMP Tail Light) Design 698
L9 - Rear Light (Tail Light)
L9 - Rear Light (Tail Light) Design 699
L9 - Rear Light (Tail Light) Daisy Chain W/ Extension
L9 - Rear Light (Tail Light) Daisy Chain W/ Extension Design 700
L9 - Rear Light (Tail Light) W/Daisy Chain pair of Box
Lamps
L9 - Rear Light (Tail Light) W/Daisy Chain pair of Box Lamps Design 701
L9 - Rear Light (Tail Light) W/Daisy Chain Pair of Box
Lamps
L9 - Rear Light (Tail Light) W/Daisy Chain Pair of Box Lamps Design 702
B6.7 - Work Lights LED With Switch Pack - Day Cab
B6.7 - Work Lights LED With Switch Pack - Day Cab Design 703
B6.7 - WORK LIGHT With BackUP Alarm - 1 BULB
B6.7 - WORK LIGHT With BackUP Alarm - 1 BULB Design 705
B6.7 - WORK LIGHT With BackUP 1 BULB - Manual
Trans
B6.7 - WORK LIGHT With BackUP 1 BULB - Manual Trans Design 707
B6.7 - WORK LIGHT With RKE - 1 BULB
B6.7 - WORK LIGHT With RKE - 1 BULB Design 709
B6.7 - WORK LIGHT - 1 BULB
B6.7 - WORK LIGHT - 1 BULB Design 711
L9 - Work Lights LED With Switch Pack - Day Cab
L9 - Work Lights LED With Switch Pack - Day Cab Design 713
L9 - WORK LIGHT With BackUP Alarm - 1 BULB
L9 - WORK LIGHT With BackUP Alarm - 1 BULB Design 715
L9 - WORK LIGHT With BackUP - 1 BULB - Manual
Trans
L9 - WORK LIGHT With BackUP - 1 BULB - Manual Trans Design 717
L9 - WORK LIGHT With RKE 1 BULB
L9 - WORK LIGHT With RKE 1 BULB Design 721
L9 - WORK LIGHT - 1 BULB
L9 - WORK LIGHT - 1 BULB Design 723
B6.7/L9 - Fifth Wheel Slide
B6.7/L9 - Fifth Wheel Slide Design 725
B6.7/L9 - Jaw Unlock Control
B6.7/L9 - Jaw Unlock Control Design 726
B6.7/L9 - Jaw Unlock Control W/ SOLENOIDS
W/SWITCH PACKS
B6.7/L9 - Jaw Unlock Control W/ SOLENOIDS W/SWITCH PACKS Design 727
xxxB6.7/L9 - Fuel Heater (Vehicle Powered) Davco 245
B6.7/L9 - Fuel Heater (Vehicle Powered) Davco 245 Design 728
B6.7/L9 - Fuel Heater (Vehicle Powered) (Racor 400
Series)
B6.7/L9 - Fuel Heater (Vehicle Powered) (Racor 400 Series) Design 729
B6.7 - Fuel Level (Single Sensor)
B6.7 - Fuel Level (Single Sensor) Design 730
B6.7 - Fuel Level (Single Sensor) Post E36
B6.7 - Fuel Level (Single Sensor) Post E36 Design 735
B6.7 - Fuel Level (Single Sensor) Pre E36
B6.7 - Fuel Level (Single Sensor) Pre E36 Design 737
B6.7 - 26" Fuel Tank
B6.7 - 26" Fuel Tank Design 743
B6.7 - 26" Fuel Tank - Secondary
B6.7 - 26" Fuel Tank - Secondary Design 744
L9 - Fuel Level (Single Sensor)
L9 - Fuel Level (Single Sensor) Design 746
L9 - Fuel Level (Single Sensor) Post E36
L9 - Fuel Level (Single Sensor) Post E36 Design 750
L9 - Fuel Level (Single Sensor) Pre E36
L9 - Fuel Level (Single Sensor) Pre E36 Design 752
L9 - 26" Fuel Tank
L9 - 26" Fuel Tank Design 756
L9 - 26" Fuel Tank - Secondary
L9 - 26" Fuel Tank - Secondary Design 757
B6.7 - Water In Fuel (WIF) Davco 245 W/ Heater
B6.7 - Water In Fuel (WIF) Davco 245 W/ Heater Design 759
B6.7 - Water In Fuel (WIF) Racor N/ Heater
B6.7 - Water In Fuel (WIF) Racor N/ Heater Design 760
B6.7 - Water In Fuel (WIF) Racor W/ Heater
B6.7 - Water In Fuel (WIF) Racor W/ Heater Design 765
L9 - Water In Fuel (WIF) Davco 245 W/ Heater
L9 - Water In Fuel (WIF) Davco 245 W/ Heater Design 770
L9 - Water In Fuel (WIF) Racor N/ Heater
L9 - Water In Fuel (WIF) Racor N/ Heater Design 771
HVAC Actuators
HVAC Actuators Design 775
B6.7 - Heating Ventilation & Air Conditioning (HVAC)
(Auto Control head W/PT Transducer N/Low Pressure
SW)
B6.7 - Heating Ventilation & Air Conditioning (HVAC) (Auto Control head W/PT
Transducer N/Low Pressure SW) Design 776
xxxiL9 - Heating Ventilation & Air Conditioning (HVAC)
SW)
L9 - Heating Ventilation & Air Conditioning (HVAC) (Auto Control head W/PT
Transducer N/Low Pressure SW) Design 778
(Manual W/PT Transducer N/Low Pressure SW)
B6.7 - Heating Ventilation & Air Conditioning (HVAC) (Manual W/PT Transducer
N/Low Pressure SW) Design 780
L9 - Heating Ventilation & Air Conditioning (HVAC) (Manual W/PT Transducer
N/Low Pressure SW) Design 781
B6.7 - Ambient Air Temperature
B6.7 - Ambient Air Temperature Design 782
B6.7 - Ambient Air Temperature (no Display, Bumper
Sensor)
B6.7 - Ambient Air Temperature (no Display, Bumper Sensor) Design 783
Sensor): 2024 and newer models
B6.7 - Ambient Air Temperature (no Display, Bumper Sensor):2024 and newer
models Design 784
B6.7 - Ambient Temperature Monitoring
B6.7 - Ambient Temperature Monitoring Design 785
B6.7 - Ambient Temperature Monitoring (HorizonBumper Sensor)
B6.7 - Ambient Temperature Monitoring (Horizon-Bumper Sensor) Design 786
B6.7 - Ambient Temperature Monitoring (HorizonBumper Sensor): 2024 and newer models
B6.7 - Ambient Temperature Monitoring (Horizon-Bumper Sensor):2024 and
newer models Design 787
B6.7 - Ambient Temperature (Horizon-Mirror Sensor)
B6.7 - Ambient Temperature (Horizon-Mirror Sensor) Design 788
B6.7 - Ambient Temperature (No Display, Mirror
Sensor)
B6.7 - Ambient Temperature (No Display, Mirror Sensor) Design 789
L9 - Ambient Air Temperature
L9 - Ambient Air Temperature Design 790
L9 - Ambient Temperature (Horizon-Mirror Sensor)
L9 - Ambient Temperature (Horizon-Mirror Sensor) Design 791
L9 - Ambient Temperature (No Display, Mirror Sensor)
L9 - Ambient Temperature (No Display, Mirror Sensor) Design 792
B6.7/L9 - Auxilary Gauges (Secondary)
B6.7/L9 - Auxilary Gauges (Secondary) Design 793
xxxiiB6.7/L9 - Auxiliary Gauge
B6.7/L9 - Auxiliary Gauge Design 794
B6.7/L9 - Auxiliary Gauges (Primary)
B6.7/L9 - Auxiliary Gauges (Primary) Design 795
B6.7 - Brake Pressure (Auxiliary Gauge)
B6.7 - Brake Pressure (Auxiliary Gauge) Design 796
B6.7 - Brake Pressure (Virtual Gauge)
B6.7 - Brake Pressure (Virtual Gauge) Design 797
L9 - Brake Pressure (Auxiliary Gauge)
L9 - Brake Pressure (Auxiliary Gauge) Design 798
L9 - Brake Pressure (Virtual Gauge)
L9 - Brake Pressure (Virtual Gauge) Design 799
B6.7/L9 - Compressed Air Supply
B6.7/L9 - Compressed Air Supply Design 800
B6.7/L9 - Compressed Air Supply (Aux Air Pressure
Gauge) (Hydraulic Split Brake System)
B6.7/L9 - Compressed Air Supply (Aux Air Pressure Gauge) (Hydraulic Split
Brake System) Design 801
B6.7/L9 - Compressed Air Supply (Aux Gauge)
B6.7/L9 - Compressed Air Supply (Aux Gauge) Design 803
B6.7 - Current Monitoring (Ammeter)
B6.7 - Current Monitoring (Ammeter) Design 804
B6.7/L9 - DEF Economy Monitor (GEN IV Horizon
Cluster w/ Cummins ENG)
B6.7/L9 - DEF Economy Monitor (GEN IV Horizon Cluster w/ Cummins ENG)
Design 806
B6.7/L9 - Coolant Temperature Monitoring
B6.7/L9 - Coolant Temperature Monitoring Design 807
B6.7/L9 - Engine Usage Monitoring (Base) NA
B6.7/L9 - Engine Usage Monitoring (Base) NA Design 808
B6.7/L9 - Engine Usage Monitoring (VID Option)
B6.7/L9 - Engine Usage Monitoring (VID Option) Design 809
B6.7/L9 - Engine Oil Level Monitoring
B6.7/L9 - Engine Oil Level Monitoring Design 810
B6.7/L9 - Engine Oil Pressure
B6.7/L9 - Engine Oil Pressure Design 811
B6.7/L9 - Engine Oil Temperature NA MUX
B6.7/L9 - Engine Oil Temperature NA MUX Design 812
B6.7/L9 - Engine Oil Temperature NA MUX AUX Gauge
B6.7/L9 - Engine Oil Temperature NA MUX AUX Gauge Design 813
B6.7/L9 - Engine Speed (Tachometer)
B6.7/L9 - Engine Speed (Tachometer) Design 814
xxxiiiB6.7/L9 - Economy Monitor
B6.7/L9 - Economy Monitor Design 815
B6.7/L9 - Intake Manifold Pressure (IMP) (Cummins
2350A and MX-1 NA) AUX gauge
B6.7/L9 - Intake Manifold Pressure (IMP) (Cummins 2350A and MX-1 NA) AUX
gauge Design 816
2350A NA)
B6.7/L9 - Intake Manifold Pressure (IMP) (Cummins 2350A NA) Design 817
B6.7/L9 - Odometer (via BCM/EGC)-Horizon
B6.7/L9 - Odometer (via BCM/EGC)-Horizon Design 818
B6.7/L9 - Trip Odometer (w/ECM & TCM)
B6.7/L9 - Trip Odometer (w/ECM & TCM) Design 819
B6.7/L9 - Trip Odometer (w/ECM)
B6.7/L9 - Trip Odometer (w/ECM) Design 820
B6.7/L9 - Trip Odometer (w/VID)
B6.7/L9 - Trip Odometer (w/VID) Design 821
B6.7/L9 - PTO (Fuel and Hours)
B6.7/L9 - PTO (Fuel and Hours) Design 822
B6.7/L9 - Transmission Oil Temperature Automatic
Trans Option2
B6.7/L9 - Transmission Oil Temperature Automatic Trans Option2 Design 823
B6.7/L9 - Transmission Oil Temperature-Automatic
Trans w/Aux Gauge
B6.7/L9 - Transmission Oil Temperature-Automatic Trans w/Aux Gauge
Design 824
L9 - Transmission Oil Temperature - Manual Trans
L9 - Transmission Oil Temperature - Manual Trans Design 825
w/Aux Gauge
L9 - Transmission Oil Temperature - Manual Trans w/Aux Gauge Design 826
B6.7/L9 - Vehicle Speedometer System (Automatic
XMSN) NA
B6.7/L9 - Vehicle Speedometer System (Automatic XMSN) NA Design 827
B6.7 - Vehicle Speedometer System (Manual XMSN)
NA
B6.7 - Vehicle Speedometer System (Manual XMSN) NA Design 828
L9 - Vehicle Speedometer System (Manual XMSN) NA
L9 - Vehicle Speedometer System (Manual XMSN) NA Design 829
B6.7/L9 - Vehicle Speed Limit Override
B6.7/L9 - Vehicle Speed Limit Override Design 830
B6.7/L9 - Voltage Monitoring Voltmeter
xxxivB6.7/L9 - Voltage Monitoring Voltmeter Design 831
B6.7/L9 - Voltage Monitoring (Voltmeter) (with Aux
gauge)
B6.7/L9 - Voltage Monitoring (Voltmeter) (with Aux gauge) Design 832
B6.7/L9 - Engine Warning MUX
B6.7/L9 - Engine Warning MUX Design 833
B6.7/L9 - High Exhaust System Temperature (HEST)
Monitoring
B6.7/L9 - High Exhaust System Temperature (HEST) Monitoring Design 834
Monitoring (Horizon) (2024 & Newer Models)
B6.7/L9 - High Exhaust System Temperature (HEST) Monitoring (Horizon) (2024
& Newer Models) Design 835
B6.7/L9 - Up Shift Indicator
B6.7/L9 - Up Shift Indicator Design 836
B6.7 - Range Inhibit (sixth gear inhibit switch) (Option
1)
B6.7 - Range Inhibit (sixth gear inhibit switch) (Option 1) Design 837
B6.7 - Range Inhibit (Sixth Gear Inhibit Switch) (Option
2)
B6.7 - Range Inhibit (Sixth Gear Inhibit Switch) (Option 2) Design 839
B6.7/L9 - Trans Range Inhibit (J1939 Comm) (Option 1)
B6.7/L9 - Trans Range Inhibit (J1939 Comm) (Option 1) Design 841
B6.7/L9 - Trans Range Inhibit (J1939 Comm) (Option 2)
B6.7/L9 - Trans Range Inhibit (J1939 Comm) (Option 2) Design 842
B6.7/L9 - Vehicle Information Display Premium w/ WiFi VID
B6.7/L9 - Vehicle Information Display Premium w/ Wi-Fi VID Design 843
B6.7/L9 - Vehicle Information Display W/O BT
B6.7/L9 - Vehicle Information Display W/O BT Design 844
B6.7/L9 - Vehicle Information Display (W/ BT)
B6.7/L9 - Vehicle Information Display (W/ BT) Design 845
B6.7/L9 - Cab Dome Light W/Classic Trim
B6.7/L9 - Cab Dome Light W/Classic Trim Design 846
B6.7/L9 - Cab Dome Light W/ Combo in Diamond Trim
B6.7/L9 - Cab Dome Light W/ Combo in Diamond Trim Design 847
B6.7/L9 - Courtesy Light Crew Cab
B6.7/L9 - Courtesy Light Crew Cab Design 848
B6.7/L9 - Courtesy Light Day Cab
B6.7/L9 - Courtesy Light Day Cab Design 849
B6.7/L9 - Interior Task Lights (Map) - Dome Combo
B6.7/L9 - Interior Task Lights (Map) - Dome Combo Design 850
xxxvB6.7/L9 - Panel Backlighting (Cabin Dimmer)
B6.7/L9 - Panel Backlighting (Cabin Dimmer) Design 851
B6.7 - Axle Loading (Weight) Rear
B6.7 - Axle Loading (Weight) Rear Design 852
B6.7 - Axle Loading (Weight) (Rear, Horizon)
B6.7 - Axle Loading (Weight) (Rear, Horizon) Design 854
L9 - Axle Loading (Weight) Rear
L9 - Axle Loading (Weight) Rear Design 858
L9 - Axle Loading (Weight) (Rear, Horizon)
L9 - Axle Loading (Weight) (Rear, Horizon) Design 860
B6.7 - Driver Controlled Locking Differential - RR Axle
(Dana w/ one sw )
B6.7 - Driver Controlled Locking Differential - RR Axle (Dana w/ one sw )
Design 864
(Dana w/ one sw)
B6.7 - Driver Controlled Locking Differential - RR Axle (Dana w/ one sw)
Design 865
(Meritor w/ one sw)
B6.7 - Driver Controlled Locking Differential - RR Axle (Meritor w/ one sw)
Design 866
L9 - Driver Controlled Locking Differenntial - FR and
RR Axles (Meritor w/ two sw)
L9 - Driver Controlled Locking Differenntial - FR and RR Axles (Meritor w/ two sw)
Design 867
L9 - Driver Controlled Locking Differential - FR & RR
Axle (Dana w/ one switch)
L9 - Driver Controlled Locking Differential - FR & RR Axle (Dana w/ one switch)
Design 868
L9 - Driver Controlled Locking Differential - FR & RR Axle (Meritor w/ one sw)
Design 869
L9 - Driver Controlled Locking Differential - RR Axle
(Dana w/ one sw)
L9 - Driver Controlled Locking Differential - RR Axle (Dana w/ one sw) Design 870
(Meritor w/ one sw)
L9 - Driver Controlled Locking Differential - RR Axle (Meritor w/ one sw)
Design 871
B6.7/L9 - Height Control
B6.7/L9 - Height Control Design 872
B6.7/L9 - Power Divider Lock Control and Monitoring
B6.7/L9 - Power Divider Lock Control and Monitoring Design 873
xxxviB6.7/L9 - Rear Axle Load Distribution
B6.7/L9 - Rear Axle Load Distribution Design 874
L9 - Axle Temperature Monitoring (Single Rear Aux
Gauge)
L9 - Axle Temperature Monitoring (Single Rear Aux Gauge) Design 875
L9 - Axle Temperature Monitoring (Single Rear Virtual
Gauge)
L9 - Axle Temperature Monitoring (Single Rear Virtual Gauge) Design 876
L9 - Axle Temperature Monitoring (Tandem Rear Aux
Gauge)
L9 - Axle Temperature Monitoring (Tandem Rear Aux Gauge) Design 877
Virtual Gauge)
L9 - Axle Temperature Monitoring (Tandem Rear Virtual Gauge) Design 878
B6.7 - Rear Suspension Pressure Monitoring
(Auxiliary Gauge)
B6.7 - Rear Suspension Pressure Monitoring (Auxiliary Gauge) Design 879
B6.7 - Rear Suspension Pressure Monitoring (Virtual
Gauge)
B6.7 - Rear Suspension Pressure Monitoring (Virtual Gauge) Design 881
L9 - Rear Suspension Pressure Monitoring (Auxiliary
Gauge)
L9 - Rear Suspension Pressure Monitoring (Auxiliary Gauge) Design 883
L9 - Rear Suspension Pressure Monitoring (Virtual
Gauge)
L9 - Rear Suspension Pressure Monitoring (Virtual Gauge) Design 885
B6.7 - Two Speed Axle (AirShift on Shifter)
B6.7 - Two Speed Axle (AirShift on Shifter) Design 887
B6.7 - Two Speed Axle (with BCM; Automactic
Transmission and switch on dash)
B6.7 - Two Speed Axle (with BCM; Automactic Transmission and switch on dash)
Design 888
L9 - Two Speed Axle (AirShift on Shifter)
L9 - Two Speed Axle (AirShift on Shifter) Design 889
L9 - Two Speed Axle (with BCM; Automactic
L9 - Two Speed Axle (with BCM; Automactic Transmission and switch on dash)
Design 890
B6.7/L9 - Driver and Passenger Seats - RollTek (Hard
Wired)
B6.7/L9 - Driver and Passenger Seats - RollTek (Hard Wired) Design 891
B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard
Wired) - Leather
B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard Wired) - Leather Design 892
xxxviiB6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard
Wired) - Mordular
B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard Wired) - Mordular Design 893
Wired) - Vinyl
B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard Wired) - Vinyl Design 894
B6.7/L9 - Seatbelt Reminder (Warning)(Driver only)
B6.7/L9 - Seatbelt Reminder (Warning)(Driver only) Design 895
B6.7/L9 - Seatbelt Reminder (Warning)(Driver &
Passenger in parallel)
B6.7/L9 - Seatbelt Reminder (Warning)(Driver & Passenger in parallel) Design896
Vehicle Data Recorder (No Display)
Vehicle Data Recorder (No Display) Design 897
Vehicle Data Recorder (W/Display, 2 front seats)
Vehicle Data Recorder (W/Display, 2 front seats) Design 899
Vehicle Data Recorder (W/ Display)
Vehicle Data Recorder (W/ Display) Design 901
L9 - Auxiliary Trailer Power
L9 - Auxiliary Trailer Power Design 903
B6.7 - TEM _Electric Trailer Brake Controller Activated
Stop
B6.7 - TEM _Electric Trailer Brake Controller Activated Stop Design 904
Stop Option2
B6.7 - TEM _Electric Trailer Brake Controller Activated Stop Option2 Design 905
L9 - TEM _Electric Trailer Brake Controller Activated
Stop LT
L9 - TEM _Electric Trailer Brake Controller Activated Stop LT Design 906
B6.7 - Trailer Interface (Lighting) – BLUNT CUT (Part
of Electric Trailer Brakes)
B6.7 - Trailer Interface (Lighting) – BLUNT CUT (Part of Electric Trailer Brakes)
Design 907
of Electric Trailer Brakes) Option2
Option2 Design 908
L9 - Trailer Interface (Lighting) – BLUNT CUT (Part of
L9 - Trailer Interface (Lighting) – BLUNT CUT (Part of Electric Trailer Brakes)
Design 909
Option2 Design 910
xxxviiiB6.7 - Auto Neutral (Allision N/ Switch & W/
Confirmation Telltale)
B6.7 - Auto Neutral (Allision N/ Switch & W/ Confirmation Telltale) Design 911
B6.7 - Auto Neutral (Allison W/ Multiplex Switch &
B6.7 - Auto Neutral (Allison W/ Multiplex Switch & Confirmation Telltale)
Design 913
B6.7 - Auto Neutral (HS Drive N/ SW N/ Relay)
B6.7 - Auto Neutral (HS Drive N/ SW N/ Relay) Design 914
B6.7/L9 - Auto Neutral (Eaton Procision)
B6.7/L9 - Auto Neutral (Eaton Procision) Design 916
L9 - Auto Neutral (Allision N/ Switch & W/
L9 - Auto Neutral (Allision N/ Switch & W/ Confirmation Telltale) Design 917
L9 - Auto Neutral (Allison W/ Multiplex Switch &
L9 - Auto Neutral (Allison W/ Multiplex Switch & Confirmation Telltale) Design 919
Hill Start Aid (HSA) (Bendix CA 2.0)
Hill Start Aid (HSA) (Bendix CA 2.0) Design 920
B6.7 - Transmission Shifter (Push Button Shifter -
Allison 3K/4K) (Option 1)
B6.7 - Transmission Shifter (Push Button Shifter - Allison 3K/4K) (Option 1)
Design 921
Allison 3K/4K) (Option 2)
B6.7 - Transmission Shifter (Push Button Shifter - Allison 3K/4K) (Option 2)
Design 923
L9 - Transmission Shifter (Push Button Shifter -
L9 - Transmission Shifter (Push Button Shifter - Allison 3K/4K) (Option 1)
Design 925
L9 - Transmission Shifter (Push Button Shifter - Allison 3K/4K) (Option 2)
Design 927
B6.7 - Transmission Shifter (Eaton Procision)
B6.7 - Transmission Shifter (Eaton Procision) Design 929
B6.7 - Transmission Shifter (Stalk Shifter Allison)
B6.7 - Transmission Shifter (Stalk Shifter Allison) Design 930
B6.7 - Transmission Shifter (Universal Stalk Shifter -
Allison 1K/2K N/Park Position)
B6.7 - Transmission Shifter (Universal Stalk Shifter - Allison 1K/2K N/Park
Position) Design 932
xxxixB6.7 - Transmission Shifter (Universal Stalk Shifter -
Allison 1K/2K, W/Park Position)
B6.7 - Transmission Shifter (Universal Stalk Shifter - Allison 1K/2K, W/Park
Position) Design 933
Allison 3K/4K)
B6.7 - Transmission Shifter (Universal Stalk Shifter - Allison 3K/4K) Design 934
L9 - Transmission Shifter (Stalk Shifter Allison)
L9 - Transmission Shifter (Stalk Shifter Allison) Design 936
L9 - Transmission Shifter (Universal Stalk Shifter -
Allison 3K/4K)
L9 - Transmission Shifter (Universal Stalk Shifter - Allison 3K/4K) Design 938
B6.7 - Transmission Shifter (Eaton T-Handle with Park
Pawl)
B6.7 - Transmission Shifter (Eaton T-Handle with Park Pawl) Design 940
B6.7 - Transmission Shifter (T-Handle for Allison; With
Park Position)
B6.7 - Transmission Shifter (T-Handle for Allison; With Park Position) Design 942
B6.7 - T-Handle for Allison Without Park Position
B6.7 - T-Handle for Allison Without Park Position Design 944
B6.7/L9 - Auto Park Brake (T-Handle Shifter, Auto Park
Brake)
B6.7/L9 - Auto Park Brake (T-Handle Shifter, Auto Park Brake) Design 946
B6.7/L9 - Transmission Shifter (T-Handle for Allison N/
Park Position)
B6.7/L9 - Transmission Shifter (T-Handle for Allison N/ Park Position) Design 947
W/ Park Position)
B6.7/L9 - Transmission Shifter (T-Handle for Allison W/ Park Position) Design 948
B6.7/L9 - Transfer Case - High/Low Air Sol
B6.7/L9 - Transfer Case - High/Low Air Sol Design 949
B6.7/L9 - Transfer Case - High/Neu/Low Air Sol
B6.7/L9 - Transfer Case - High/Neu/Low Air Sol Design 950
B6.7 - Transmission (Allison 1K/2K)
B6.7 - Transmission (Allison 1K/2K) Design 951
B6.7 - Transmission (Allison 3K/4K)
B6.7 - Transmission (Allison 3K/4K) Design 952
L9 - Allision without Switch and with Confirmation
Telltale
L9 - Allision without Switch and with Confirmation Telltale Design 954
L9 - Transmission (Allison 3K/4K)
L9 - Transmission (Allison 3K/4K) Design 956
xlB6.7 - Transmission I/O (Procision W/ Body Builder)
B6.7 - Transmission I/O (Procision W/ Body Builder) Design 958
B6.7 - Transmission (Procision)
B6.7 - Transmission (Procision) Design 959
B6.7 - Transmission (Fuller Advantage)
B6.7 - Transmission (Fuller Advantage) Design 960
L9 - Transmission (Fuller Advantage)
L9 - Transmission (Fuller Advantage) Design 961
L9 - Transmissions Electrical I/O (Fuller Advantage)
L9 - Transmissions Electrical I/O (Fuller Advantage) Design 962
B6.7/L9 - Transmission Mode Button (1K/2K)
B6.7/L9 - Transmission Mode Button (1K/2K) Design 963
B6.7/L9 - Transmission - MODE Selection (Option 1)
B6.7/L9 - Transmission - MODE Selection (Option 1) Design 964
B6.7/L9 - Transmission - MODE Selection (Option 2)
B6.7/L9 - Transmission - MODE Selection (Option 2) Design 965
B6.7 - Windshield Washer Pump W/O Low Fluid
Sensor
B6.7 - Windshield Washer Pump W/O Low Fluid Sensor Design 966
B6.7 - Windshield Washer Pump & Low Fluid Sensor
B6.7 - Windshield Washer Pump & Low Fluid Sensor Design 967
L9 - Windshield Washer Pump W/O Low Fluid Sensor
L9 - Windshield Washer Pump W/O Low Fluid Sensor Design 969
L9 - Windshield Washer Pump & Low Fluid Sensor
L9 - Windshield Washer Pump & Low Fluid Sensor Design 970
B6.7 - Windshield Wipers
B6.7 - Windshield Wipers Design 972
L9 - Windshield Wipers
L9 - Windshield Wipers Design 973
B6.7/L9 - Battery Disconnect (W/Switch and
W/Solenoid)
B6.7/L9 - Battery Disconnect (W/Switch and W/Solenoid) Design 974
B6.7 - Bosch LH160_LH200 Alternator
B6.7 - Bosch LH160_LH200 Alternator Design 975
B6.7 - Charging System (Delco Remy & Mitsubishi
Alternator W/ Remote Sense)
B6.7 - Charging System (Delco Remy & Mitsubishi Alternator W/ Remote Sense)
Design 977
B6.7 - Delco Remy 28SI Alternator W/Sensor
B6.7 - Delco Remy 28SI Alternator W/Sensor Design 979
B6.7 - Delco Remy 36SI Alternator W/Sensor
B6.7 - Delco Remy 36SI Alternator W/Sensor Design 980
xliB6.7 - Leece-Neville AVI160 Alternator
B6.7 - Leece-Neville AVI160 Alternator Design 981
B6.7 - Leece-Neville AVI160-210A/240A Alternator
W/Sensor
B6.7 - Leece-Neville AVI160-210A/240A Alternator W/Sensor Design 983
B6.7 - Leece-Neville - LN 325A Alternator W/Sensor
B6.7 - Leece-Neville - LN 325A Alternator W/Sensor Design 984
L9 - Bosch LH160_LH200 Alternator
L9 - Bosch LH160_LH200 Alternator Design 985
L9 - Charging System (Delco Remy & Mitsubishi
L9 - Charging System (Delco Remy & Mitsubishi Alternator W/ Remote Sense)
Design 986
L9 - Delco Remy 28SI Alternator W/Sensor
L9 - Delco Remy 28SI Alternator W/Sensor Design 988
L9 - Delco Remy 36SI Alternator W/Sensor
L9 - Delco Remy 36SI Alternator W/Sensor Design 989
L9 - Leece-Neville AVI160 Alternator
L9 - Leece-Neville AVI160 Alternator Design 990
L9 - Leece-Neville AVI160-210A/240A Alternator
W/Sensor
L9 - Leece-Neville AVI160-210A/240A Alternator W/Sensor Design 991
L9 - Leece-Neville - LN 325A Alternator W/Sensor
L9 - Leece-Neville - LN 325A Alternator W/Sensor Design 992
B6.7/L9 - Maxwell 12V Ultracapacitor Engine Start
Module (ESM)
B6.7/L9 - Maxwell 12V Ultracapacitor Engine Start Module (ESM) Design 993
B6.7/L9 - Crank Inhibit (W/ Hood Switch)
B6.7/L9 - Crank Inhibit (W/ Hood Switch) Design 994
B6.7 - Cranking (Starter) GEN4 BCM W/O Thermal
Overcrank
B6.7 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/O Thermal
Overcrank Design 996
B6.7 - Crank Inhibit (with ECM --> BCM ONLY)
B6.7 - Crank Inhibit (with ECM --> BODY CONTROL MODULE ONLY)
Design 1001
L9 - Cranking (Starter) GEN4 BCM W/O Thermal
Overcrank
L9 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/O Thermal
Overcrank Design 1002
L9 - Cranking (Starter) GEN4 BCM W/ Thermal
Overcrank - External Switch
L9 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/ Thermal Overcrank
- External Switch Design 1003
xliiL9 - Crank Inhibit (with ECM --> BCM ONLY)
L9 - Crank Inhibit (with ECM --> BODY CONTROL MODULE ONLY) Design 1004
B6.7 - Cranking Request (w/ Key Switch w/ BCM)
B6.7 - Cranking Request (w/ Key Switch w/ BCM) Design 1005
B6.7/L9 - Operator Input
B6.7/L9 - Operator Input Design 1007
L9 - Cranking Request (w/ Key Switch w/ BCM)
L9 - Cranking Request (w/ Key Switch w/ BCM) Design 1009
B6.7 - Clutch Monitoring (High and Low Switch to
BCM)
B6.7 - Clutch Monitoring (High and Low Switch to BCM) Design 1011
B6.7 - Starter Interlocks (BCM Controlled with Input
from Allison 1K/2K TCM)
B6.7 - Starter Interlocks (BCM Controlled with Input from Allison 1K/2K TCM)
Design 1012
from Allison 3K/4K TCM)
B6.7 - Starter Interlocks (BCM Controlled with Input from Allison 3K/4K TCM)
Design 1014
B6.7 - Starter Interlock (BCM HSD controlled W/
Clutch SW & N/Auto SS)
B6.7 - Starter Interlock (BCM HSD controlled W/ Clutch SW & N/Auto SS)
Design 1016
B6.7 - Starter Interlock (BCM LSD Controlled w/ Relay
& N/ Auto SS) EATON XMSN
B6.7 - Starter Interlock (BCM LSD Controlled w/ Relay & N/ Auto SS) EATON
XMSN Design 1017
B6.7 - Starter Interlock (BCM LSD Controlled w/ Relay)
Eaton Procision
B6.7 - Starter Interlock (BCM LSD Controlled w/ Relay) Eaton Procision
Design 1018
L9 - Clutch Monitoring (High and Low Switch to BCM)
L9 - Clutch Monitoring (High and Low Switch to BCM) Design 1019
L9 - Starter Interlocks (BCM Controlled with Input
L9 - Starter Interlocks (BCM Controlled with Input from Allison 3K/4K TCM)
Design 1020
L9 - Starter Interlock (BCM LSD Controlled w/ Relay &
L9 - Starter Interlock (BCM LSD Controlled w/ Relay & N/ Auto SS) EATON
XMSN Design 1022
B6.7 - Battery International (4) 12V
B6.7 - Battery International (4) 12V Design 1023
L9 - Battery International (4) 12V
xliiiL9 - Battery International (4) 12V Design 1024
Connectors 1025
Index 3367
- International DT466,DT570,HT570 Diesel Engine Service Manual
- International DT466E Wiring Schematic
- International 365, 444, 466, 530 Service Manuals
- Navistar Diagnostic Trouble Code Index
- SCANIA 420 DC11 - DC12 Motor
- International 9800 Electrical Schematic
- International Truck DT466E Engine Repair Manual
- International - VT365 Schematic (SPA)
- Scania Manual Transmission GRS900
- International Truck 5000i,9200i,9400i and 9900i Chassis Built Electrical Circuit Diagram
- International Trucks Body Controller Diagnostic Trouble Codes
- International Wiring Diagram
- International Truck CF500 CF600 Service Manual
- Scania Manual Transmission GR 900
- International DT466, DT530 Electronic Diagram
