International Truck LT RH Series (S13) Interactive Schematics 00000018835 2025
Brand: International, Navistar
Type of Manual: Interactive Schematics
Model: International LT Series, RH Series (S13) Truck
Built: 9/29/2023 To 12/31/2025
Part Number: 00000018835
Publication Date: 2025
Number of Pages: 2060 Pages
9pin Diagnositic Connector
9pin Diagnositic Connector Design 1
LT/RH - Body Control Module (BCM)
LT/RH - Body Control Module (BCM) Design 2
LT/RH - Bendix Fusion / Wabco OnGuard Proprietary
J1939
LT/RH - Bendix Fusion / Wabco OnGuard Proprietary J1939 Design 10
LT/RH - Body Standard J1939
LT/RH - Body Standard J1939 Design 11
LT/RH - Cab Standard J1939
LT/RH - Cab Standard J1939 Design 12
LT/RH - Engine Proprietary J1939
LT/RH - Engine Proprietary J1939 Design 13
LT/RH - Low Speed Standard J1939
LT/RH - Low Speed Standard J1939 Design 14
LT/RH - Powertrain Standard J1939-
LT/RH - Powertrain Standard J1939- Design 15
LT/RH - Engine Electrical I/O (CBE1)
LT/RH - Engine Electrical I/O (CBE1) Design 16
LT/RH - Instrument Cluster (EGC)
LT/RH - Instrument Cluster (EGC) Design 17
LT/RH - Instrument Cluster - Request and Status
LT/RH - Instrument Cluster - Request and Status Design 18
LT/RH - IP Grounds
LT/RH - IP Grounds Design 19
LT/RH - IP Ground Splice Packs
LT/RH - IP Ground Splice Packs Design 20
LT/RH - IP ZVR Splice Packs - 1620
LT/RH - IP ZVR Splice Packs - 1620 Design 22
LT/RH - Center Chassis Grounds - D7007
LT/RH - Center Chassis Grounds - D7007 Design 23
LT/RH - Center Chassis Ground Splice Packs -
D7010/D7011/D7012
LT/RH - Center Chassis Ground Splice Packs - D7010/D7011/D7012 Design 24
LT/RH - Center Chassis ZVR Splice Pack
LT/RH - Center Chassis ZVR Splice Pack Design 25
LT/RH - Frame Grounds
LT/RH - Frame Grounds Design 26
LT/RH - Front Chassis Grounds
LT/RH - Front Chassis Grounds Design 27
TABLE OF CONTENTS
iLT/RH - Front Chassis Ground Splice Packs
D6606/D6607
LT/RH - Front Chassis Ground Splice Packs D6606/D6607 Design 28
LT/RH - S13 Powertrain Grounds
LT/RH - S13 Powertrain Grounds Design 29
LT/RH - S13 Powertrain ZVR Splice Packs - D5032
LT/RH - S13 Powertrain ZVR Splice Packs - D5032 Design 30
LT/RH - Rear Chassis Ground Splice Packs - D9000
LT/RH - Rear Chassis Ground Splice Packs - D9000 Design 31
LT/RH - Sleeper Grounds
LT/RH - Sleeper Grounds Design 32
LT/RH - Sleeper Ground Splice Packs - 4007/4008
LT/RH - Sleeper Ground Splice Packs - 4007/4008 Design 33
LT/RH - Lighting Control Module
LT/RH - Lighting Control Module Design 34
LT/RH - Powertrain Interface Module (PIM) Electrical
I/O (PIM) W/104 Pin (D265) Connector
LT/RH - Powertrain Interface Module (PIM) Electrical I/O (PIM) W/104 Pin (D265)
Connector Design 35
I/O (PIM) W/ 76 Pin (D265) Connector
LT/RH - Powertrain Interface Module (PIM) Electrical I/O (PIM) W/ 76 Pin (D265)
Connector Design 36
LT/RH - Battery Grid 1 (Non-Loadshed)(Post
1/10/2023)
LT/RH - Battery Grid 1 (Non-Loadshed)(Post 1/10/2023) Design 37
LT/RH - Battery Grid 2 (Loadshed)
LT/RH - Battery Grid 2 (Loadshed) Design 39
LT/RH - Key Switch Accessory Grid 2 (Loadshed)
LT/RH - Key Switch Accessory Grid 2 (Loadshed) Design 40
LT/RH - Key Switch Ignition Grid 1 (Non-Loadshed) -
Option 1
LT/RH - Key Switch Ignition Grid 1 (Non-Loadshed) - Option 1 Design 41
Option 2
LT/RH - Key Switch Ignition Grid 1 (Non-Loadshed) - Option 2 Design 43
LT/RH - Key Switch Ignition Grid 2 (Loadshed)
LT/RH - Key Switch Ignition Grid 2 (Loadshed) Design 45
LT/RH - 2023 and Newer Models - Interior PDM Chart
LT/RH - 2023 and Newer Models - Interior PDM Chart Design 46
LT/RH - Grid Management (CA2 W/Load Shed,
Conventional Cab)
TABLE OF CONTENTS
iiLT/RH - Grid Management (CA2 W/Load Shed, Conventional Cab) Design 47
LT/RH - Grid Management (CA2 W/Load Shed, Sleeper
Cab)
LT/RH - Grid Management (CA2 W/Load Shed, Sleeper Cab) Design 48
LT/RH - Grid Management (CA2, N/Load Shed,
Conventional Cab)(Option 1)
LT/RH - Grid Management (CA2, N/Load Shed, Conventional Cab)(Option 1)
Design 49
Conventional Cab)(Option 2)
LT/RH - Grid Management (CA2, N/Load Shed, Conventional Cab)(Option 2)
Design 50
LT/RH - IP Marker Splice Pack - 1590
LT/RH - IP Marker Splice Pack - 1590 Design 51
LT/RH - IP Panel Dimmer Splice Packs - 1040
LT/RH - IP Panel Dimmer Splice Packs - 1040 Design 52
LT/RH - IP Turn Signal Splice Packs - 1592
LT/RH - IP Turn Signal Splice Packs - 1592 Design 53
LT/RH - N01 Lighting Splice Packs -
7145/7146/7147/7148
LT/RH - N01 Lighting Splice Packs - 7145/7146/7147/7148 Design 54
LT - Series Version 1 of Sleeper Battery Grid 3 (NonLoadshed)
LT - Series Version 1 of Sleeper Battery Grid 3 (Non-Loadshed) Design 55
LT/RH - LT Series Version 1 of Sleeper Battery Grid 4
(Loadshed)
LT/RH - LT Series Version 1 of Sleeper Battery Grid 4 (Loadshed) Design 56
LT/RH - Series Version 1 of Sleeper Convenience Grid
1 (Non-Loadshed)
LT/RH - Series Version 1 of Sleeper Convenience Grid 1 (Non-Loadshed)
Design 57
LT Series Version 1 of Special PDM
LT Series Version 1 of Special PDM Design 58
LT/RH - Pre 2023 - IP Underhood PDM W/ S13 Engine
LT/RH - Pre 2023 - IP Underhood PDM W/ S13 Engine Design 59
LT/RH - 2023 and Newer Models - IP Underhood PDM
W/ CBE1 Engine
LT/RH - 2023 and Newer Models - IP Underhood PDM W/ CBE1 Engine
Design 60
LT/RH - Air Solenoids 4-pack (1 pack/4 solenoids)
LT/RH - Air Solenoids 4-pack (1 pack/4 solenoids) Design 61
LT/RH - Air Solenoids 4-pack (2 packs/8 solenoids)
LT/RH - Air Solenoids 4-pack (2 packs/8 solenoids) Design 62
TABLE OF CONTENTS
iiiLT/RH - Radio
LT/RH - Radio Design 63
LT/RH - Radio W/ Steering Wheel Pod
LT/RH - Radio W/ Steering Wheel Pod Design 64
LT/RH - Radio W/ Steering Wheel Pod & W/ RSA
LT/RH - Radio W/ Steering Wheel Pod & W/ RSA Design 65
LT/RH - Radio W/ Bluetooth W/ Steering Wheel Pod &
W/ RSA
LT/RH - Radio W/ Bluetooth W/ Steering Wheel Pod & W/ RSA Design 66
LT/RH - Radio W/ Bluetooth & W/ Steering Wheel Pod
LT/RH - Radio W/ Bluetooth & W/ Steering Wheel Pod Design 67
Speakers W/Amp & N/QC (LS, HRZN, HX)
Speakers W/Amp & N/QC (LS, HRZN, HX) Design 68
Speakers W/Amp & N/QC (New Amp - LS, HRZN, HX)
Speakers W/Amp & N/QC (New Amp - LS, HRZN, HX) Design 70
Speakers: 4 Speakers & N/QC
Speakers:4 Speakers & N/QC Design 72
Speakers: 4 Speakers & W/QC
Speakers:4 Speakers & W/QC Design 74
LT/RH - Auxiliary Power Source (Sleeper) - 4 APO, 1
USB (Option 1)
LT/RH - Auxiliary Power Source (Sleeper) - 4 APO, 1 USB (Option 1) Design 75
USB (Option 2)
LT/RH - Auxiliary Power Source (Sleeper) - 4 APO, 1 USB (Option 2) Design 77
LT/RH - Auxiliary Power Source (Sleeper) - 5 APO, 1
USB
LT/RH - Auxiliary Power Source (Sleeper) - 5 APO, 1 USB Design 79
LT/RH - Auxiliary Power Source - Overhead
(Daycab/low roof sleeper, in Center Overhead Panel)
LT/RH - Auxiliary Power Source - Overhead (Daycab/low roof sleeper, in Center
Overhead Panel) Design 81
LT/RH - Auxiliary Power Source - Overhead (Sleeper,
LT/RH - Auxiliary Power Source - Overhead (Sleeper, in Center Overhead Panel)
Design 82
LT/RH - Auxiliary Power Source - Overhead (Truck, in
LT/RH - Auxiliary Power Source - Overhead (Truck, in Center Overhead Panel)
Design 83
LT/RH - Aux Power (Banana Plug)
LT/RH - Aux Power (Banana Plug) Design 84
TABLE OF CONTENTS
ivLT/RH - Forward Auxiliary Power Source (1 APO)
LT/RH - Forward Auxiliary Power Source (1 APO) Design 85
LT/RH - Forward Auxiliary Power Source (2 APO)
LT/RH - Forward Auxiliary Power Source (2 APO) Design 86
LT/RH - Forward Auxiliary Power Source (3 APO)
LT/RH - Forward Auxiliary Power Source (3 APO) Design 88
LT/RH - AUX Power Hardwired Switches (Four Aux
Switches)
LT/RH - AUX Power Hardwired Switches (Four Aux Switches) Design 90
LT/RH - AUX Power Hardwired Switches (Two Aux
Switches)
LT/RH - AUX Power Hardwired Switches (Two Aux Switches) Design 92
LT/RH - AUX Power Hardwired Switch (Single Aux
Switch 30A)
LT/RH - AUX Power Hardwired Switch (Single Aux Switch 30A) Design 93
LT/RH - Backup Alarm (Direct from Relay to Alarm
Connector)
LT/RH - Backup Alarm (Direct from Relay to Alarm Connector) Design 94
LT/RH - Backup Alarm (Relay to 6 Pin Tailboard.
Backup Alarm Plugs in)
LT/RH - Backup Alarm (Relay to 6 Pin Tailboard. Backup Alarm Plugs in)
Design 97
LT/RH - CB Radio Power Only
LT/RH - CB Radio Power Only Design 98
LT/RH - Door Ajar Reminder (Entry/Exit) (2 Doors)
LT/RH - Door Ajar Reminder (Entry/Exit) (2 Doors) Design 99
LT/RH - Power Door Locks (2-Door)
LT/RH - Power Door Locks (2-Door) Design 100
LT/RH - Mirrors (Heated) (Door Pod Actuated, 2 Cab
and 1 Hood Mirror Right Side Only)
LT/RH - Mirrors (Heated) (Door Pod Actuated, 2 Cab and 1 Hood Mirror Right
Side Only) Design 101
and 2 Hood Mirrors)
LT/RH - Mirrors (Heated) (Door Pod Actuated, 2 Cab and 2 Hood Mirrors)
Design 102
Mirrors)
LT/RH - Mirrors (Heated) (Door Pod Actuated, 2 Cab Mirrors) Design 103
LT/RH - Mirrors (Heated) (MUX Switch, 2 Cab and 1
LT/RH - Mirrors (Heated) (MUX Switch, 2 Cab and 1 Hood Mirror Right Side Only)
Design 104
TABLE OF CONTENTS
vLT/RH - Mirrors (Heated) (MUX Switch, 2 Cab and 2
Hood Mirrors)
LT/RH - Mirrors (Heated) (MUX Switch, 2 Cab and 2 Hood Mirrors) Design 105
LT/RH - Mirrors (Heated) (MUX Switch, 2 Cab Mirrors)
LT/RH - Mirrors (Heated) (MUX Switch, 2 Cab Mirrors) Design 106
LT/RH - Mirrors (Power) (Control Switch Actuated, 1-
Door)
LT/RH - Mirrors (Power) (Control Switch Actuated, 1-Door) Design 107
LT/RH - Mirrors (Power) (1 Door Pod, Left Mirror)
LT/RH - Mirrors (Power) (1 Door Pod, Left Mirror) Design 108
LT/RH - Mirrors (Power) (2 Door Pods)
LT/RH - Mirrors (Power) (2 Door Pods) Design 109
LT/RH - Mirror Lighting (Turns without Door Pods)
LT/RH - Mirror Lighting (Turns without Door Pods) Design 110
LT/RH - Mirror Lighting (Turns with Door Pods)
LT/RH - Mirror Lighting (Turns with Door Pods) Design 111
LT/RH - Powered Mirrors (Control Switch Actuated)
LT/RH - Powered Mirrors (Control Switch Actuated) Design 112
LT/RH - Power Windows (2-Door)
LT/RH - Power Windows (2-Door) Design 113
LT/RH - City Horn
LT/RH - City Horn Design 114
LT/RH - Fan - Sleeper/Bunk
LT/RH - Fan - Sleeper/Bunk Design 115
Height Control (Hadley Smart Valve)
Height Control (Hadley Smart Valve) Design 116
LT/RH - Switch Packs
LT/RH - Switch Packs Design 117
LT/RH - Power Lift Gate (Dual Pole Terminal)
LT/RH - Power Lift Gate (Dual Pole Terminal) Design 118
LT/RH - Power Lift Gate (Single Terminal)
LT/RH - Power Lift Gate (Single Terminal) Design 119
LT/RH - Refrigerator (Power and Ground Only)
LT/RH - Refrigerator (Power and Ground Only) Design 120
LT/RH - Refrigerator (Switch Control)
LT/RH - Refrigerator (Switch Control) Design 121
LT/RH - Remote Keyless Access
LT/RH - Remote Keyless Access Design 122
LT/RH - Telematics W/Feeder Data Terminal
System(FDT)
LT/RH - Telematics W/Feeder Data Terminal System(FDT) Design 123
TABLE OF CONTENTS
viLT/RH - Telematics (Aftermarket W/ 4 TMC Connector)
LT/RH - Telematics (Aftermarket W/ 4 TMC Connector) Design 124
LT/RH - Antenna (Film Antenna, Sleeper, OTAPM,
AM/FM, XM Radio)
LT/RH - Antenna (Film Antenna, Sleeper, OTAPM, AM/FM, XM Radio) Design126
LT/RH - Antenna (Shark Fin, Day Cab, OTAPM, AM/FM,
XM Radio)
LT/RH - Antenna (Shark Fin, Day Cab, OTAPM, AM/FM, XM Radio) Design 127
LT/RH - Over The Air Electrical I/O (OnCommand Link
/ N2 Module N/ Engine Diagnostic Connector)
LT/RH - Over The Air Electrical I/O (OnCommand Link / N2 Module N/ Engine
Diagnostic Connector) Design 128
/ N2 Module / S13)
LT/RH - Over The Air Electrical I/O (OnCommand Link / N2 Module / S13)
Design 130
LT/RH - Telematics Omnitracs W/Feeder Data Terminal
System(FDT) (Option 1)
LT/RH - Telematics Omnitracs W/Feeder Data Terminal System(FDT) (Option 1)
Design 132
System(FDT) (Option 2)
LT/RH - Telematics Omnitracs W/Feeder Data Terminal System(FDT) (Option 2)
Design 133
LT/RH - Telematics Omnitracs W/Panic Button (Option
1)
LT/RH - Telematics Omnitracs W/Panic Button (Option 1) Design 134
2)
LT/RH - Telematics Omnitracs W/Panic Button (Option 2) Design 135
LT/RH - Telematics Omnitracs W/Safety Direct
Disconnect (Option 1)
LT/RH - Telematics Omnitracs W/Safety Direct Disconnect (Option 1) Design 136
Disconnect (Option 2)
LT/RH - Telematics Omnitracs W/Safety Direct Disconnect (Option 2) Design 137
LT/RH - Telematics (Omnitracs XRS/IVG) (Option 1)
LT/RH - Telematics (Omnitracs XRS/IVG) (Option 1) Design 138
LT/RH - Telematics (Omnitracs XRS/IVG) (Option 2)
LT/RH - Telematics (Omnitracs XRS/IVG) (Option 2) Design 139
LT/RH - Telematics Peoplenet N/Feeder Data Terminal
LT/RH - Telematics Peoplenet N/Feeder Data Terminal System(FDT) (Option 1)
Design 140
TABLE OF CONTENTS
viiLT/RH - Telematics Peoplenet N/Feeder Data Terminal
LT/RH - Telematics Peoplenet N/Feeder Data Terminal System(FDT) (Option 2)
Design 142
LT/RH - Telematics Peoplenet W/DVR
LT/RH - Telematics Peoplenet W/DVR Design 144
LT/RH - Telematics Peoplenet W/Feeder Data Terminal
LT/RH - Telematics Peoplenet W/Feeder Data Terminal System(FDT) (Option 1)
Design 146
LT/RH - Telematics Peoplenet W/Feeder Data Terminal System(FDT) (Option 2)
Design 148
LT/RH - Telematics QUALCOMM W/Feeder Data
LT/RH - Telematics QUALCOMM W/Feeder Data Terminal System(FDT)
Design 150
LT/RH - Telematics (QUALCOMM MCP20)
LT/RH - Telematics (QUALCOMM MCP20) Design 152
LT/RH - Telematics Zonar
LT/RH - Telematics Zonar Design 154
LT/RH - Steering Wheel Left and Right Pod N/Air Bag
LT/RH - Steering Wheel Left and Right Pod N/Air Bag Design 155
LT/RH - Steering Wheel Left Pod
LT/RH - Steering Wheel Left Pod Design 156
LT/RH - Steering Wheel Right Pod
LT/RH - Steering Wheel Right Pod Design 157
LT/RH - Tire Pressure (TPMS) (LDL 2.0 - 1
Repeater)(Option 1)
LT/RH - Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(Option 1) Design 158
Repeater)(Option 2)
LT/RH - Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(Option 2) Design 161
LT/RH - Aux Power (USB) - 1 USB
LT/RH - Aux Power (USB) - 1 USB Design 162
LT/RH - Aux Power (USB) - 1 USB A, 1 USB C
LT/RH - Aux Power (USB) - 1 USB A, 1 USB C Design 163
LT/RH - Aux Power (USB) - 2 USB
LT/RH - Aux Power (USB) - 2 USB Design 164
LT/RH - Aux Power (USB) - 2 USB A, 2 USB C
LT/RH - Aux Power (USB) - 2 USB A, 2 USB C Design 165
TABLE OF CONTENTS
viiiLT/RH - Aux Power (USB) - 3 USB
LT/RH - Aux Power (USB) - 3 USB Design 166
LT/RH - Aux Power (USB) - 3 USB A, 3 USB C
LT/RH - Aux Power (USB) - 3 USB A, 3 USB C Design 167
LT/RH - Selective Catalytic Reduction (SCR)
LT/RH - Selective Catalytic Reduction (SCR) Design 168
LT/RH - Airbag (Driver Seat and Passenger Seat)
LT/RH - Airbag (Driver Seat and Passenger Seat) Design 169
LT/RH - Airbag (Driver Seat Only)
LT/RH - Airbag (Driver Seat Only) Design 171
LT/RH - Airbag (Driver Seat, Passenger Seat, and
Steering Wheel)
LT/RH - Airbag (Driver Seat, Passenger Seat, and Steering Wheel) Design 172
LT/RH - Airbag (Steering Wheel and Driver Seat)
LT/RH - Airbag (Steering Wheel and Driver Seat) Design 174
LT/RH - Airbag (Steering Wheel Only)
LT/RH - Airbag (Steering Wheel Only) Design 175
LT/RH - Steering Wheel W/Air Bag
LT/RH - Steering Wheel W/Air Bag Design 176
LT/RH - Body Builder Aux Power (Blunt Cut)
LT/RH - Body Builder Aux Power (Blunt Cut) Design 177
LT/RH - Body Builder Aux Power (EOF)
LT/RH - Body Builder Aux Power (EOF) Design 178
LT/RH - Body Builder Aux Power ( In Cab)
LT/RH - Body Builder Aux Power ( In Cab) Design 180
LT/RH - Body Builder Lighting - (8HAA) (Blunt Cut)
LT/RH - Body Builder Lighting - (8HAA) (Blunt Cut) Design 181
LT/RH - Body Builder Aux Power (In Cab, BOC, or
EOF)
LT/RH - Body Builder Aux Power (In Cab, BOC, or EOF) Design 182
Transmission I/O (Allison Gen 6 3K W/ Body Builder)
Transmission I/O (Allison Gen 6 3K W/ Body Builder) Design 184
Transmission Power Take Off (Dual PTO W/ 42
Parameters & W/ Auto, AMT Trans) Option 1
Transmission Power Take Off (Dual PTO W/ 42 Parameters & W/ Auto, AMT
Trans) Option 1 Design 187
Parameters & W/ Auto, AMT Trans) Option 2
Trans) Option 2 Design 188
Transmission Power Take Off (Single PTO W/42
TABLE OF CONTENTS
ixTransmission Power Take Off (Single PTO W/42 Parameters & W/ Auto, AMT
Trans) Option 1 Design 189
Trans) Option 2 Design 190
LT/RH - Service Brake Switch (1 SLS/1 Transducer/ 1
RDS to PIM)(Option 1)
LT/RH - Service Brake Switch (1 SLS/1 Transducer/ 1 RDS to PIM)(Option 1)
Design 191
RDS to PIM)(Option 2)
LT/RH - Service Brake Switch (1 SLS/1 Transducer/ 1 RDS to PIM)(Option 2)
Design 192
Service Brake Switch (1 SLS/1 Transducer)
Service Brake Switch (1 SLS/1 Transducer) Design 193
LT/RH - Air Dryer (Dual)
LT/RH - Air Dryer (Dual) Design 194
LT/RH - Air Dryer (Intelligent Air Governor)
LT/RH - Air Dryer (Intelligent Air Governor) Design 195
LT/RH - Air Dryer (Single)
LT/RH - Air Dryer (Single) Design 196
LT/RH - Air Governor Control (Intelligent Air Governor,
CBE1)(Option 1)
LT/RH - Air Governor Control (Intelligent Air Governor, CBE1)(Option 1)
Design 197
CBE1)(Option 2)
LT/RH - Air Governor Control (Intelligent Air Governor, CBE1)(Option 2)
Design 198
LT/RH - Drain Valve One (1) Heater
LT/RH - Drain Valve One (1) Heater Design 199
LT/RH - Drain Valve W/ Three (3) Heaters
LT/RH - Drain Valve W/ Three (3) Heaters Design 200
LT/RH - Drain Valve W/ Two (2) Heaters (Option1)
LT/RH - Drain Valve W/ Two (2) Heaters (Option1) Design 202
LT/RH - Drain Valve W/ Two (2) Heaters (Option 2)
LT/RH - Drain Valve W/ Two (2) Heaters (Option 2) Design 204
LT/RH - Antilock Brake System (ABS) (BENDIX 4
Channel Implemenation - No Modulator Twist)
LT/RH - Antilock Brake System (ABS) (BENDIX 4 Channel Implemenation - No
Modulator Twist) Design 206
LT/RH - Antilock Brake System (ABS) (Bendix 6
Channel Implementation - No Modulator Twist)
TABLE OF CONTENTS
xLT/RH - Antilock Brake System (ABS) (Bendix 6 Channel Implementation - No
Modulator Twist) Design 210
LT/RH - Antilock Brake System (ABS) - Wabco 4
LT/RH - Antilock Brake System (ABS) - Wabco 4 Channel Implementation
Design 214
LT/RH - Antilock Brake System (ABS) - Wabco 6
LT/RH - Antilock Brake System (ABS) - Wabco 6 Channel Implementation
Design 218
LT/RH - Park Brake Controls (Air Chassis Park Brake)
LT/RH - Park Brake Controls (Air Chassis Park Brake) Design 222
LT/RH - Park Brake Controls (Tractor) Intellipark
LT/RH - Park Brake Controls (Tractor) Intellipark Design 223
LT/RH - Bendix; Tractor or Towing Truck; W/ Air
SUSP; J1939 Driven Lamp
LT/RH - Bendix; Tractor or Towing Truck; W/ Air SUSP; J1939 Driven Lamp
Design 225
LT/RH - Stability Controls (Wabco Air - Straight Truck)
LT/RH - Stability Controls (Wabco Air - Straight Truck) Design 227
LT/RH - Stability Control (Wabco AIR -
TRACTOR/TOW)
LT/RH - Stability Control (Wabco AIR - TRACTOR/TOW) Design 229
LT/RH - Traction Control (Bendix, ECM)
LT/RH - Traction Control (Bendix, ECM) Design 231
LT/RH - Traction Control (Wabco Air)
LT/RH - Traction Control (Wabco Air) Design 233
LT/RH - Adaptive Cruise Control (Bendix Wingman
Advanced N/ DIU)(Option 1)
LT/RH - Adaptive Cruise Control (Bendix Wingman Advanced N/ DIU)(Option 1)
Design 234
Advanced N/ DIU)(Option 2)
LT/RH - Adaptive Cruise Control (Bendix Wingman Advanced N/ DIU)(Option 2)
Design 235
LT/RH - Adaptive Cruise Control (Bendix - Fusion
2.8/2.9 N/ Safety Direct Conn W/ Reg Speakers)(Option
1)
LT/RH - Adaptive Cruise Control (Bendix - Fusion 2.8/2.9 N/ Safety Direct Conn
W/ Reg Speakers)(Option 1) Design 236
2)
W/ Reg Speakers)(Option 2) Design 239
TABLE OF CONTENTS
xiLT/RH - Adaptive Cruise Control (Bendix - Fusion
2.8/2.9 N/ Safety Direct Conn W/ Tweeters)(Option 1)
W/ Tweeters)(Option 1) Design 242
2.8/2.9 N/ Safety Direct Conn W/ Tweeters)(Option 2)
W/ Tweeters)(Option 2) Design 244
2.8/2.9 W/N2 Conn W/ Tweeters)
LT/RH - Adaptive Cruise Control (Bendix - Fusion 2.8/2.9 W/N2 Conn W/
Tweeters) Design 246
2.8/2.9 W/ N2 Conn W/ Reg Speakers)
LT/RH - Adaptive Cruise Control (Bendix - Fusion 2.8/2.9 W/ N2 Conn W/ Reg
Speakers) Design 248
2.8/2.9 W/ Safety Direct Conn W/ Reg
Speakers)(Option 1)
LT/RH - Adaptive Cruise Control (Bendix - Fusion 2.8/2.9 W/ Safety Direct Conn
W/ Reg Speakers)(Option 1) Design 251
Speakers)(Option 2)
W/ Reg Speakers)(Option 2) Design 256
2.8/2.9 W/ Safety Direct Conn W/ Tweeters)(Option 1)
W/ Tweeters)(Option 1) Design 260
2.8/2.9 W/ Safety Direct Conn W/ Tweeters)(Option 2)
W/ Tweeters)(Option 2) Design 265
LT/RH - Adaptive Cruise Control (Fusion 3.0 N/ DIU
W/LDW Audio Mute)(Option 1)
LT/RH - Adaptive Cruise Control (Fusion 3.0 N/ DIU W/LDW Audio Mute)(Option
1) Design 269
W/LDW Audio Mute)(Option 2)
2) Design 270
DIU)(Option 1)
LT/RH - Adaptive Cruise Control (Fusion 3.0 N/ DIU)(Option 1) Design 271
DIU)(Option 2)
TABLE OF CONTENTS
xiiLT/RH - Adaptive Cruise Control (Fusion 3.0 N/ DIU)(Option 2) Design 272
LT/RH - Adaptive Cruise Control (Wabco OnGuard N/
DIU)
LT/RH - Adaptive Cruise Control (Wabco OnGuard N/ DIU) Design 273
LT/RH - Collision Avoidance System (Warning)
(Blindspotter 2.0)
LT/RH - Collision Avoidance System (Warning) (Blindspotter 2.0) Design 274
LT/RH - Camera Event Recorder N/Safety Direct Cable
(Option 1)
LT/RH - Camera Event Recorder N/Safety Direct Cable (Option 1) Design 275
(Option 2)
LT/RH - Camera Event Recorder N/Safety Direct Cable (Option 2) Design 276
LT/RH - Camera Event Recorder W/N2 Conn
LT/RH - Camera Event Recorder W/N2 Conn Design 277
LT/RH - Camera Event Recorder W/Safety Direct Cable
LT/RH - Camera Event Recorder W/Safety Direct Cable Design 279
LT/RH - CAMERA (DriveCam Switch & Power PreWire
LT/RH - CAMERA (DriveCam Switch & Power PreWire Design 282
LT/RH - Camera (LYTX Prewire) N/Event Recording
Button
LT/RH - Camera (LYTX Prewire) N/Event Recording Button Design 283
LT/RH - Camera (LYTX Prewire) W/Event Recording
Button
LT/RH - Camera (LYTX Prewire) W/Event Recording Button Design 284
LT/RH - Lane Departure Warning (Wabco OnLane2 N/
Tweeters)
LT/RH - Lane Departure Warning (Wabco OnLane2 N/ Tweeters) Design 286
LT/RH - Lane Departure Warning (Wabco OnLane2 W/
Tweeters)
LT/RH - Lane Departure Warning (Wabco OnLane2 W/ Tweeters) Design 288
LT/RH - Lane Keep Assist
LT/RH - Lane Keep Assist Design 289
Lane Keep Assist Module
Lane Keep Assist Module Design 290
ZF Steering Gear
ZF Steering Gear Design 291
LT/RH - Collision Avoidance System (Warning) (Side
Object Detection, Left & Right Side)
LT/RH - Collision Avoidance System (Warning) (Side Object Detection, Left &
Right Side) Design 293
TABLE OF CONTENTS
xiiiLT/RH - Collision Avoidance System (Warning) (Side
Object Detection, Right Side)
LT/RH - Collision Avoidance System (Warning) (Side Object Detection, Right
Side) Design 299
LT/RH - Air Filter Flow Restriction Monitoring (LED
Indicator & W/Hood switch & W/Auto Start-Stop)
LT/RH - Air Filter Flow Restriction Monitoring (LED Indicator & W/Hood switch &
W/Auto Start-Stop) Design 302
Indicator & W/Hood switch)
LT/RH - Air Filter Flow Restriction Monitoring (LED Indicator & W/Hood switch)
Design 304
LT -Air Filter Flow Restriction Monitoring (LED
Indicator) Option 2
LT -Air Filter Flow Restriction Monitoring (LED Indicator) Option 2 Design 306
LT - Air Filter Flow Restriction Monitoring (Horizon)
Option 1
LT - Air Filter Flow Restriction Monitoring (Horizon) Option 1 Design 307
Option 2
LT - Air Filter Flow Restriction Monitoring (Horizon) Option 2 Design 308
LT - Air Filter Flow Restriction Monitoring (LED
Indicator) Option 1
LT - Air Filter Flow Restriction Monitoring (LED Indicator) Option 1 Design 309
RH - Air Filter Flow Restriction Monitoring (Horizon)
Option 1
RH - Air Filter Flow Restriction Monitoring (Horizon) Option 1 Design 310
Option 2
RH - Air Filter Flow Restriction Monitoring (Horizon) Option 2 Design 311
Indicator) Option 1
RH - Air Filter Flow Restriction Monitoring (LED Indicator) Option 1 Design 312
Indicator) Option 2
RH - Air Filter Flow Restriction Monitoring (LED Indicator) Option 2 Design 313
Coolant Level Monitoring (W/ PIM)
Coolant Level Monitoring (W/ PIM) Design 314
LT/RH - Coolant Level Monitoring (No CLA Module)
LT/RH - Coolant Level Monitoring (No CLA Module) Design 316
LT/RH - Coolant Level Monitoring (W/ PIM)
LT/RH - Coolant Level Monitoring (W/ PIM) Design 317
LT/RH - Cooling Fan Control (Fan Override, CBE1)
LT/RH - Cooling Fan Control (Fan Override, CBE1) Design 318
TABLE OF CONTENTS
xivLT/RH - Cooling Fan Control (No Fan Override, CBE1)
LT/RH - Cooling Fan Control (No Fan Override, CBE1) Design 319
LT/RH - Vehicle Acceleration (Accel Pedal wired to
PIM) Option 1
LT/RH - Vehicle Acceleration (Accel Pedal wired to PIM) Option 1 Design 320
PIM) Option 2
LT/RH - Vehicle Acceleration (Accel Pedal wired to PIM) Option 2 Design 321
LT/RH - CBE1 - Engine Electrical I/O
LT/RH - CBE1 - Engine Electrical I/O Design 322
LT/RH - Air Shield Lighting W/ One Light
LT/RH - Air Shield Lighting W/ One Light Design 323
LT/RH - Automatic Lighting W/Twilight & W/Sunload
LT/RH - Automatic Lighting W/Twilight & W/Sunload Design 325
LT/RH - Backup Lights (Reverse Lights)
(Crossmember Dual STT N/Back Up) T14 Trans
LT/RH - Backup Lights (Reverse Lights) (Crossmember Dual STT N/Back Up)
T14 Trans Design 326
LT/RH - Backup Light (Dual Reverse) T14 Trans, 6 Pin
(Option 1)
LT/RH - Backup Light (Dual Reverse) T14 Trans, 6 Pin (Option 1) Design 327
(Option 2)
LT/RH - Backup Light (Dual Reverse) T14 Trans, 6 Pin (Option 2) Design 328
LT/RH - Backup Light (Single Reverse Light) T14
Trans (Option 1)
LT/RH - Backup Light (Single Reverse Light) T14 Trans (Option 1) Design 329
Trans (Option 2)
LT/RH - Backup Light (Single Reverse Light) T14 Trans (Option 2) Design 330
LT/RH - Backup Light (Single Reverse Light) T14 Trans, 6 Pin (Option 1)
Design 331
LT/RH - Backup Light (Single Reverse Light) T14 Trans, 6 Pin (Option 2)
Design 332
LT/RH - Back Up Lights (Reverse Lights) (Tailboard
Dual STT W/Back Up) T14 Trans
LT/RH - Back Up Lights (Reverse Lights) (Tailboard Dual STT W/Back Up) T14
Trans Design 333
LT/RH - Beacon/Strobe Light (1 Blunt Cut, Horizon)
LT/RH - Beacon/Strobe Light (1 Blunt Cut, Horizon) Design 334
TABLE OF CONTENTS
xvLT/RH - Beacon/Strobe Light (2 Blunt Cuts, Horizon)
LT/RH - Beacon/Strobe Light (2 Blunt Cuts, Horizon) Design 336
LT/RH - Clearance and Identification Lights
N/SUNSHADE AMBER LENS
LT/RH - Clearance and Identification Lights N/SUNSHADE AMBER LENS
Design 338
W/SUNSHADE AMBER LENS
LT/RH - Clearance and Identification Lights W/SUNSHADE AMBER LENS
Design 339
LT/RH - Directional Signals (Turn) W/HEADLIGHTS
(113BBC HALOGEN)
LT/RH - Directional Signals (Turn) W/HEADLIGHTS (113BBC HALOGEN)
Design 340
LT/RH - Directional Signals (Turn) (125BBC Halogen)
LT/RH - Directional Signals (Turn) (125BBC Halogen) Design 341
(113BBC LED)
LT/RH - Directional Signals (Turn) W/HEADLIGHTS (113BBC LED) Design 342
LT/RH - Directional Signals (Turn) W/HEATED
HEADLIGHTS (LED 125BBC)
LT/RH - Directional Signals (Turn) W/HEATED HEADLIGHTS (LED 125BBC)
Design 343
LT/RH - Directional Signals (Turn) (LED 125BBC)
LT/RH - Directional Signals (Turn) (LED 125BBC) Design 344
LT/RH - Front Fog Lamps
LT/RH - Front Fog Lamps Design 345
LT/RH - Prewire Front Fog Lights
LT/RH - Prewire Front Fog Lights Design 346
LT/RH - Hazard Warning (CA 2.0)
LT/RH - Hazard Warning (CA 2.0) Design 347
LT/RH - Headlights (Halogen 113 BBC)
LT/RH - Headlights (Halogen 113 BBC) Design 348
LT/RH - Headlights (Halogen 125BBC) W/LOWW
LT/RH - Headlights (Halogen 125BBC) W/LOWW Design 349
LT/RH - Headlights (Halogen 125BBC) W/O LOWW
LT/RH - Headlights (Halogen 125BBC) W/O LOWW Design 350
LT/RH - Headlights (LED 113 BBC)
LT/RH - Headlights (LED 113 BBC) Design 351
LT/RH - Headlights (LED 125 BBC) N/LOWW
LT/RH - Headlights (LED 125 BBC) N/LOWW Design 352
LT/RH - Headlights (LED 125 BBC) N/LOWW &
W/HEATER
LT/RH - Headlights (LED 125 BBC) N/LOWW & W/HEATER Design 353
TABLE OF CONTENTS
xviLT/RH - Headlights (LED 125 BBC) W/LOWW
LT/RH - Headlights (LED 125 BBC) W/LOWW Design 354
LT/RH - Headlights (LED 125 BBC) W/LOWW &
W/HEATER
LT/RH - Headlights (LED 125 BBC) W/LOWW & W/HEATER Design 355
LT/RH - License Plate Light (Direct To Light)
LT/RH - License Plate Light (Direct To Light) Design 356
LT/RH - License Plate Light (LED BOX LAMP Tail
Light)
LT/RH - License Plate Light (LED BOX LAMP Tail Light) Design 358
LT/RH - License Plate Light (Tail Light Single Assy.)
LT/RH - License Plate Light (Tail Light Single Assy.) Design 359
(HRZN)
LT/RH - License Plate Light (Tail Light Single Assy.) (HRZN) Design 360
LT/RH - Marker Lighting (Halogen 113 BBC)
LT/RH - Marker Lighting (Halogen 113 BBC) Design 361
LT/RH - Marker Lighting (Halogen 125 BBC)
LT/RH - Marker Lighting (Halogen 125 BBC) Design 362
LT/RH - Marker Lighting (LED 113 BBC)
LT/RH - Marker Lighting (LED 113 BBC) Design 363
LT/RH - Marker Lighting (LED 125BBC W/HEATER)
LT/RH - Marker Lighting (LED 125BBC W/HEATER) Design 364
LT/RH - Marker Lighting (LED 125BBC)
LT/RH - Marker Lighting (LED 125BBC) Design 365
LT/RH - Daycab Modesty Lighting W/ 2 Turn /0 Marker
DayCab (HRZN, LS)
LT/RH - Daycab Modesty Lighting W/ 2 Turn /0 Marker DayCab (HRZN, LS)
Design 366
LT/RH - Sleeper, Modesty Lighting W/ 4 Side Turns / 0
Marker (HRZN, LS) Sleeper
LT/RH - Sleeper, Modesty Lighting W/ 4 Side Turns / 0 Marker (HRZN, LS)
Sleeper Design 368
LT/RH - Panic Switch
LT/RH - Panic Switch Design 370
LT/RH - Rear Light (LED BOX LAMP Tail Light)
LT/RH - Rear Light (LED BOX LAMP Tail Light) Design 371
LT/RH - Rear Light (Tail Light)
LT/RH - Rear Light (Tail Light) Design 372
LT/RH - Rear Light (Tail Light) W/ 6 Pin Connector
LT/RH - Rear Light (Tail Light) W/ 6 Pin Connector Design 373
TABLE OF CONTENTS
xviiLT/RH - Skirt Light, Customer Supplied (Horizon)
(Option 1)
LT/RH - Skirt Light, Customer Supplied (Horizon) (Option 1) Design 374
(Option 2)
LT/RH - Skirt Light, Customer Supplied (Horizon) (Option 2) Design 375
LT/RH - Rear Lights Stop - Single Assembly (HRZN)
LT/RH - Rear Lights Stop - Single Assembly (HRZN) Design 376
LT/RH - Rear Lights (Stop) (Tailboard Dual STT
W/Back Up)
LT/RH - Rear Lights (Stop) (Tailboard Dual STT W/Back Up) Design 377
LT/RH - Rear Lights (Stop) - Dual Lamp Assembly
LT/RH - Rear Lights (Stop) - Dual Lamp Assembly Design 378
LT/RH - Rear Lights (Stop) - Single Assembly
LT/RH - Rear Lights (Stop) - Single Assembly Design 379
LT/RH - Rear Lights (Tail Lights) Crossmember Dual
STT N/Back-Up
LT/RH - Rear Lights (Tail Lights) Crossmember Dual STT N/Back-Up Design 380
LT/RH - Rear Lights (Tail Lights) (Tailboard Dual STT
W/Back Up)
LT/RH - Rear Lights (Tail Lights) (Tailboard Dual STT W/Back Up) Design 381
LT/RH - Rear Light (Stop) Crossmember Dual STT
N/Back-Up
LT/RH - Rear Light (Stop) Crossmember Dual STT N/Back-Up Design 382
LT/RH - Work Lights 1 Bulb Daycab W/RKE (Option 1)
LT/RH - Work Lights 1 Bulb Daycab W/RKE (Option 1) Design 383
LT/RH - Work Lights 1 Bulb Daycab W/RKE (Option 2)
LT/RH - Work Lights 1 Bulb Daycab W/RKE (Option 2) Design 384
LT/RH - Work Lights 1 Bulb Daycab (Option 1)
LT/RH - Work Lights 1 Bulb Daycab (Option 1) Design 385
LT/RH - Work Lights 1 Bulb Daycab (Option 2)
LT/RH - Work Lights 1 Bulb Daycab (Option 2) Design 386
LT/RH - Work Lights - 1 Bulb W/ Backup W/ RKE
(Auto)
LT/RH - Work Lights - 1 Bulb W/ Backup W/ RKE (Auto) Design 387
LT/RH - Work Lights - 1 Bulb W/ Backup (Auto)
LT/RH - Work Lights - 1 Bulb W/ Backup (Auto) Design 388
LT/RH - Work Lights 2 Bulbs Sleeper W/RKE (Option
1)
LT/RH - Work Lights 2 Bulbs Sleeper W/RKE (Option 1) Design 389
2)
TABLE OF CONTENTS
xviiiLT/RH - Work Lights 2 Bulbs Sleeper W/RKE (Option 2) Design 390
LT/RH - Work Lights 2 Bulbs Sleeper (Option 1)
LT/RH - Work Lights 2 Bulbs Sleeper (Option 1) Design 391
LT/RH - Work Lights 2 Bulbs Sleeper (Option 2)
LT/RH - Work Lights 2 Bulbs Sleeper (Option 2) Design 392
LT/RH - Work Lights - 2 Bulbs W/ Backup W/ RKE
(Auto)
LT/RH - Work Lights - 2 Bulbs W/ Backup W/ RKE (Auto) Design 393
LT/RH - Work Lights - 2 Bulbs W/ Backup (Auto)
LT/RH - Work Lights - 2 Bulbs W/ Backup (Auto) Design 394
LT/RH - Back of Cab Aux Work Light (2 blunt cuts
W/Reverse)
LT/RH - Back of Cab Aux Work Light (2 blunt cuts W/Reverse) Design 395
LT/RH - Back of Cab Aux Work Light (2 blunt cuts)
LT/RH - Back of Cab Aux Work Light (2 blunt cuts) Design 397
LT/RH - Back of Cab Aux Work Light (4 blunt cuts
W/Reverse)
LT/RH - Back of Cab Aux Work Light (4 blunt cuts W/Reverse) Design 399
LT/RH - Back of Cab Aux Work Light (4 blunt cuts)
LT/RH - Back of Cab Aux Work Light (4 blunt cuts) Design 401
LT/RH - Jaw Monitoring (Holland Elite LED Indicator)
LT/RH - Jaw Monitoring (Holland Elite LED Indicator) Design 403
LT/RH - Jaw Monitoring (Jost Sensor & In Cab
Display)
LT/RH - Jaw Monitoring (Jost Sensor & In Cab Display) Design 404
LT/RH - Fuel Delivery System (Smart Pump)(Option 1)
LT/RH - Fuel Delivery System (Smart Pump)(Option 1) Design 405
LT/RH - Fuel Delivery System (Smart Pump)(Option 2)
LT/RH - Fuel Delivery System (Smart Pump)(Option 2) Design 406
LT/RH - Fuel Heater (Vehicle Powered)(Option 1)
LT/RH - Fuel Heater (Vehicle Powered)(Option 1) Design 407
LT/RH - Fuel Heater (Vehicle Powered)(Option 2)
LT/RH - Fuel Heater (Vehicle Powered)(Option 2) Design 409
LT/RH - Fuel Level (Single Sensor)
LT/RH - Fuel Level (Single Sensor) Design 410
LT/RH - Water In Fuel (WIF) Davco N/ Heater
LT/RH - Water In Fuel (WIF) Davco N/ Heater Design 412
LT/RH - Water In Fuel (WIF) W/ Heater
LT/RH - Water In Fuel (WIF) W/ Heater Design 413
TABLE OF CONTENTS
xixLT/RH - Water In Fuel (WIF) (WIF to PIM Davco N/
Heater)(Option1)
LT/RH - Water In Fuel (WIF) (WIF to PIM Davco N/ Heater)(Option1) Design 414
Heater)(Option 2)
LT/RH - Water In Fuel (WIF) (WIF to PIM Davco N/ Heater)(Option 2) Design 415
LT/RH - Water In Fuel (WIF) (WIF to PIM Racor N/
Heater)
LT/RH - Water In Fuel (WIF) (WIF to PIM Racor N/ Heater) Design 416
LT/RH - Water In Fuel (WIF) (WIF to PIM W/
Heater)(Option 1)
LT/RH - Water In Fuel (WIF) (WIF to PIM W/ Heater)(Option 1) Design 417
Heater)(Option 2)
LT/RH - Water In Fuel (WIF) (WIF to PIM W/ Heater)(Option 2) Design 418
LT/RH - Heating, Ventilation, & Air Conditioning
(HVAC) Manual Heater Only
LT/RH - Heating, Ventilation, & Air Conditioning (HVAC) Manual Heater Only
Design 419
(HVAC) (Auto Control head W/PT Transducer, N/Low
Pressure SW)
LT/RH - Heating, Ventilation, & Air Conditioning (HVAC) (Auto Control head W/PT
Transducer, N/Low Pressure SW) Design 421
(HVAC) (Manual, W/PT Transducer, N/Low Pressure
SW) - N/ M-LT-ELECTRIC & W/ 16BAM & N/ 16ATC
LT/RH - Heating, Ventilation, & Air Conditioning (HVAC) (Manual, W/PT
Transducer, N/Low Pressure SW) - N/ M-LT-ELECTRIC & W/ 16BAM & N/
16ATC Design 424
SW) - N/ M-RH-ELEC & W/ 16BAM & N/ 16ATC & N/FINTL-2027-S13-ENG
Transducer, N/Low Pressure SW) - N/ M-RH-ELEC & W/ 16BAM & N/ 16ATC &
N/F-INTL-2027-S13-ENG Design 426
LT/RH - Version A of No Idle Voltage Sense
LT/RH - Version A of No Idle Voltage Sense Design 428
LT/RH - Rear HVAC No Idle (HRZN, HX) W/Pre-Heat
Bergstrom Heat and Cool N/2 addl Switches
LT/RH - Rear HVAC No Idle (HRZN, HX) W/Pre-Heat Bergstrom Heat and Cool
N/2 addl Switches Design 429
Bergstrom Heat and Cool & W/Espar Air Heat
TABLE OF CONTENTS
xxLT/RH - Rear HVAC No Idle (HRZN, HX) W/Pre-Heat Bergstrom Heat and Cool &
W/Espar Air Heat Design 432
LT/RH - Rear HVAC No Idle(HRZN, HX) W/ Pre-Heat
Bergstrom Heat and Cool W/2 addl switches
LT/RH - Rear HVAC No Idle(HRZN, HX) W/ Pre-Heat Bergstrom Heat and Cool
W/2 addl switches Design 435
LT/RH - No-Idle HVAC W/Espar Airtronic &
W/Bergstrom AC (HRZN, HX)
LT/RH - No-Idle HVAC W/Espar Airtronic & W/Bergstrom AC (HRZN, HX)
Design 438
LT/RH - Rear HVAC No Idle (HRZN, HX) Heater Espar
LT/RH - Rear HVAC No Idle (HRZN, HX) Heater Espar Design 441
LT/RH - Rear No-Idle HVAC ( Espar W/ Timer)
LT/RH - Rear No-Idle HVAC ( Espar W/ Timer) Design 442
LT/RH - Rear HVAC No Idle (HRZN) Heater Webasto
Smartemp
LT/RH - Rear HVAC No Idle (HRZN) Heater Webasto Smartemp Design 443
Std N/Swift
LT/RH - Rear HVAC No Idle (HRZN) Heater Webasto Std N/Swift Design 444
Std W/Swift
LT/RH - Rear HVAC No Idle (HRZN) Heater Webasto Std W/Swift Design 445
LT/RH - TRI-PAC No Idle
LT/RH - TRI-PAC No Idle Design 446
LT/RH - Rear AUX Heating, Ventilation & Air
Conditioning (HVAC) (Deluxe control head) - Option 1
LT/RH - Rear AUX Heating, Ventilation & Air Conditioning (HVAC) (Deluxe control
head) - Option 1 Design 447
Conditioning (HVAC) (Deluxe control head) - Option 2
head) - Option 2 Design 449
LT/RH - Rear Heating, Ventilation & Air Conditioning
(HVAC) (Premium control head) - Option 1
LT/RH - Rear Heating, Ventilation & Air Conditioning (HVAC) (Premium control
head) - Option 1 Design 451
(HVAC) (Premium control head)- Option 2
head)- Option 2 Design 453
LT/RH - Ambient Temperature Monitoring (W/ PIM) -
Option 1
LT/RH - Ambient Temperature Monitoring (W/ PIM) - Option 1 Design 455
TABLE OF CONTENTS
xxiLT/RH - Ambient Temperature Monitoring (W/ PIM) -
Option 2
LT/RH - Ambient Temperature Monitoring (W/ PIM) - Option 2 Design 456
LT/RH - Ambient Temperature (Horizon-Mirror Sensor)
LT/RH - Ambient Temperature (Horizon-Mirror Sensor) Design 457
LT/RH - Ambient Temperature (No Display, Mirror
Sensor)
LT/RH - Ambient Temperature (No Display, Mirror Sensor) Design 458
Sensor, W/ PIM) - Option 1
LT/RH - Ambient Temperature (No Display, Mirror Sensor, W/ PIM) - Option 1
Design 459
Sensor, W/ PIM) - Option 2
LT/RH - Ambient Temperature (No Display, Mirror Sensor, W/ PIM) - Option 2
Design 460
LT - Series Version 0 Auxiliary Gauges (Single)
LT - Series Version 0 Auxiliary Gauges (Single) Design 461
LT - Series Version 1 Auxiliary Gauges (Multiple)
LT - Series Version 1 Auxiliary Gauges (Multiple) Design 462
LT/RH - Service Brake Pressure (Auxiliary Gauge)
LT/RH - Service Brake Pressure (Auxiliary Gauge) Design 463
LT/RH - Service Brake Pressure (No Gauges)
LT/RH - Service Brake Pressure (No Gauges) Design 464
LT/RH - Service Brake Pressure (Virtual Gauge)
LT/RH - Service Brake Pressure (Virtual Gauge) Design 465
LT/RH - Compressed Air Supply (Primary & Secondary
Gauge) (Dual Air Brake System)
LT/RH - Compressed Air Supply (Primary & Secondary Gauge) (Dual Air Brake
System) Design 466
LT/RH - Intake Manifold Pressure (Horizon)
LT/RH - Intake Manifold Pressure (Horizon) Design 467
LT/RH - Lighting - Cabinet Lights (Horizon)
LT/RH - Lighting - Cabinet Lights (Horizon) Design 468
LT/RH - Courtesy Step Lighting (2 Door)
LT/RH - Courtesy Step Lighting (2 Door) Design 469
LT/RH - Cab Dome Lights (CA 2.0 Hi-Rise/ Sky-Rise
Sleeper Cab)
LT/RH - Cab Dome Lights (CA 2.0 Hi-Rise/ Sky-Rise Sleeper Cab) Design 470
LT/RH - Cab Dome Lights (CA 2.0 Standard Cab/Low
Rise Sleeper)
LT/RH - Cab Dome Lights (CA 2.0 Standard Cab/Low Rise Sleeper) Design 471
LT/RH - Lighting Sleeper Dome (Horizon)
TABLE OF CONTENTS
xxiiLT/RH - Lighting Sleeper Dome (Horizon) Design 472
LT/RH - Floor/Search Lights (DayCab) (Option 1)
LT/RH - Floor/Search Lights (DayCab) (Option 1) Design 473
LT/RH - Floor/Search Lights (DayCab) (Option 2)
LT/RH - Floor/Search Lights (DayCab) (Option 2) Design 474
LT/RH - Floor/Search Lighting (Sleeper 1 Light)
LT/RH - Floor/Search Lighting (Sleeper 1 Light) Design 475
LT/RH - Floor/Search Lighting (Sleeper 3 Lights)
(Option 1)
LT/RH - Floor/Search Lighting (Sleeper 3 Lights) (Option 1) Design 476
(Option 2)
LT/RH - Floor/Search Lighting (Sleeper 3 Lights) (Option 2) Design 477
LT/RH - Interior Task Lighting (Map Light) (CA 2.0 HiRise/ Sky-Rise Sleeper Cab)
LT/RH - Interior Task Lighting (Map Light) (CA 2.0 Hi-Rise/ Sky-Rise Sleeper
Cab) Design 478
LT/RH - Interior Task Lighting (Map Light) (CA 2.0 Standard Cab/Low Rise
Sleeper) Design 479
LT/RH - Luggage Compartment Lights - W/O No Idle
HVAC (Horizon, HX)
LT/RH - Luggage Compartment Lights - W/O No Idle HVAC (Horizon, HX)
Design 480
LT/RH - Luggage Compartment Lights - W/ No Idle
HVAC (Horizon, HX)
LT/RH - Luggage Compartment Lights - W/ No Idle HVAC (Horizon, HX)
Design 481
LT/RH - Rear Interior Dimming (Accent Light)
LT/RH - Rear Interior Dimming (Accent Light) Design 482
LT/RH - Rear Interior Dimming (Accent/Mood for SkyRise Sleeper)
LT/RH - Rear Interior Dimming (Accent/Mood for Sky-Rise Sleeper) Design 484
LT/RH - Rear Reading Lighting (Lower Bunk)
LT/RH - Rear Reading Lighting (Lower Bunk) Design 486
LT/RH - Rear Reading Lighting (Upper and Lower
Bunks)
LT/RH - Rear Reading Lighting (Upper and Lower Bunks) Design 487
LT/RH - Automated Suspension Transfer System
{BENDIX E-TRAC}(Option 1)
LT/RH - Automated Suspension Transfer System {BENDIX E-TRAC}(Option 1)
Design 488
TABLE OF CONTENTS
xxiiiLT/RH - Automated Suspension Transfer System
{BENDIX E-TRAC}(Option 2)
LT/RH - Automated Suspension Transfer System {BENDIX E-TRAC}(Option 2)
Design 490
LT/RH - Axle Loading (Weight) (Rear, Horizon)
LT/RH - Axle Loading (Weight) (Rear, Horizon) Design 491
LT/RH - Axle Temperature (Single w/Aux
Gauge)(Option 1)
LT/RH - Axle Temperature (Single w/Aux Gauge)(Option 1) Design 492
Gauge)(Option 2)
LT/RH - Axle Temperature (Single w/Aux Gauge)(Option 2) Design 494
LT/RH - Axle Temperature (Single w/Virtual
Gauge)(Option 1)
LT/RH - Axle Temperature (Single w/Virtual Gauge)(Option 1) Design 495
Gauge)(Option 2)
LT/RH - Axle Temperature (Single w/Virtual Gauge)(Option 2) Design 497
LT/RH - Axle Temperature (Tandem w/Single Sensor,
LT/RH - Axle Temperature (Tandem w/Single Sensor, Aux Gauge)(Option 1)
Design 498
LT/RH - Axle Temperature (Tandem w/Single Sensor, Aux Gauge)(Option 2)
Design 499
LT/RH - Axle Temperature (Tandem w/Single Sensor, Virtual Gauge)(Option 1)
Design 500
LT/RH - Axle Temperature (Tandem w/Single Sensor, Virtual Gauge)(Option 2)
Design 501
LT/RH - Axle Temperature (Tandem, Aux
Gauges)(Option 1)
LT/RH - Axle Temperature (Tandem, Aux Gauges)(Option 1) Design 502
Gauges)(Option 2)
LT/RH - Axle Temperature (Tandem, Aux Gauges)(Option 2) Design 504
LT/RH - Axle Temperature (Tandem, Virtual
Gauges)(Option 1)
LT/RH - Axle Temperature (Tandem, Virtual Gauges)(Option 1) Design 506
Gauges)(Option 2)
TABLE OF CONTENTS
xxivLT/RH - Axle Temperature (Tandem, Virtual Gauges)(Option 2) Design 507
Gauges)(Option 3)
LT/RH - Axle Temperature (Tandem, Virtual Gauges)(Option 3) Design 508
LT/RH - Driver Controlled Locking Differential - (Dana -
1 Control - 1 Feedback - RR)
LT/RH - Driver Controlled Locking Differential - (Dana - 1 Control - 1 Feedback -
RR) Design 510
LT/RH - Driver Controlled Locking Differential (Meritor
- 2 Control - 2 Feedback - FR&RR)
LT/RH - Driver Controlled Locking Differential (Meritor - 2 Control - 2 Feedback -
FR&RR) Design 512
(Meritor - 1 Control - 1 Feedback - FR)
LT/RH - Driver Controlled Locking Differential - (Meritor - 1 Control - 1 Feedback -
FR) Design 514
(Meritor - 1 Control - 1 Feedback - RR)(Option2)
RR)(Option2) Design 515
(Meritor - 1 Control - 1 Feedback - RR)(Option 1)
RR)(Option 1) Design 518
(Meritor - 1 Control - 2 Feedback - FR&RR)
LT/RH - Driver Controlled Locking Differential - (Meritor - 1 Control - 2 Feedback -
FR&RR) Design 520
LT/RH - Seats - Climate Controlled (Drivers Heated
Seat)
LT/RH - Seats - Climate Controlled (Drivers Heated Seat) Design 522
LT/RH - Seats - Climate Controlled (Driver and
Passenger Heated Seat)
LT/RH - Seats - Climate Controlled (Driver and Passenger Heated Seat)
Design 523
LT/RH - Seatbelt Reminder (Warning)(Driver only)
LT/RH - Seatbelt Reminder (Warning)(Driver only) Design 524
LT/RH - Seatbelt Reminder (Warning)(Driver &
Passenger in parallel)(Horizon)
LT/RH - Seatbelt Reminder (Warning)(Driver & Passenger in parallel)(Horizon)
Design 525
LT/RH - Auxiliary Trailer Power (BOC, ACC
Bias)(Option 1)
LT/RH - Auxiliary Trailer Power (BOC, ACC Bias)(Option 1) Design 526
TABLE OF CONTENTS
xxvLT/RH - Auxiliary Trailer Power (BOC, ACC
Bias)(Option 2)
LT/RH - Auxiliary Trailer Power (BOC, ACC Bias)(Option 2) Design 527
Bias)(Option 3)
LT/RH - Auxiliary Trailer Power (BOC, ACC Bias)(Option 3) Design 528
LT/RH - Auxiliary Trailer Power (BOC, BAT
Bias)(Option 1)
LT/RH - Auxiliary Trailer Power (BOC, BATTERY Bias)(Option 1) Design 530
Bias)(Option 2)
LT/RH - Auxiliary Trailer Power (BOC, BATTERY Bias)(Option 2) Design 531
Bias)(Option 3)
LT/RH - Auxiliary Trailer Power (BOC, BATTERY Bias)(Option 3) Design 532
LT/RH - Auxiliary Trailer Power (BOC/ISO, ACC
Bias)(Option 1)
LT/RH - Auxiliary Trailer Power (BOC/ISO, ACC Bias)(Option 1) Design 534
Bias)(Option 2)
LT/RH - Auxiliary Trailer Power (BOC/ISO, ACC Bias)(Option 2) Design 535
Bias)(Option 3)
LT/RH - Auxiliary Trailer Power (BOC/ISO, ACC Bias)(Option 3) Design 536
LT/RH - Auxiliary Trailer Power (W/ Park Brake)(Option
1)
LT/RH - Auxiliary Trailer Power (W/ Park Brake)(Option 1) Design 538
2)
LT/RH - Auxiliary Trailer Power (W/ Park Brake)(Option 2) Design 540
LT/RH - Trailer Interface (ABS) (BOC and EOF TRLR
Socket)
LT/RH - Trailer Interface (ABS) (BOC and EOF TRLR Socket) Design 542
LT/RH - Trailer Interface (ABS) (BOC TRLR Socket)
LT/RH - Trailer Interface (ABS) (BOC TRLR Socket) Design 544
LT/RH - Trailer Interface (ABS) (EOF TRLR Socket)
LT/RH - Trailer Interface (ABS) (EOF TRLR Socket) Design 546
LT/RH - Trailer Interface (ABS) (ISO TRLR Socket)
LT/RH - Trailer Interface (ABS) (ISO TRLR Socket) Design 547
LT/RH - Trailer Interface (Lighting) - Separate Turns -
EOF (RING GND)
LT/RH - Trailer Interface (Lighting) - Separate Turns - EOF (RING GND)
Design 549
TABLE OF CONTENTS
xxviLT/RH - Trailer Interface (Lighting) – BOC & EOF_NA
LT/RH - Trailer Interface (Lighting) – BOC & EOF_NA Design 550
LT/RH - Trailer Interface (Lighting) – Separate Turns -
BOC
LT/RH - Trailer Interface (Lighting) – Separate Turns - BOC Design 552
BOC & EOF (Ring Ground)
LT/RH - Trailer Interface (Lighting) – Separate Turns - BOC & EOF (Ring Ground)
Design 554
Auto Neutral (Allison W/ Multiplex Switch &
Confirmation Telltale)
Auto Neutral (Allison W/ Multiplex Switch & Confirmation Telltale) Design 556
LT/RH - Transmission (Allison 3K/4K, 12-Volt)
LT/RH - Transmission (Allison 3K/4K, 12-Volt) Design 557
Transmission (Allison 3K/4K, 24-Volt)
Transmission (Allison 3K/4K, 24-Volt) Design 558
LT/RH - Transmission Electrical I/O(GW TRANS W/
12V TCM)
LT/RH - Transmission Electrical I/O(GW TRANS W/ 12V TCM) Design 559
LT/RH - Transmission Electrical I/O(GW TRANS) -
(February 2023 and Newer Models)
LT/RH - Transmission Electrical I/O(GW TRANS) - (February 2023 and Newer
Models) Design 560
(Prior to February 2023)
LT/RH - Transmission Electrical I/O(GW TRANS) - (Prior to February 2023)
Design 561
LT/RH - Hill Start Aid (HSA) (Bendix CA 2.0)(Option1)
LT/RH - Hill Start Aid (HSA) (Bendix CA 2.0)(Option1) Design 562
LT/RH - Hill Start Aid (HSA) (Bendix CA 2.0)(Option 2)
LT/RH - Hill Start Aid (HSA) (Bendix CA 2.0)(Option 2) Design 565
LT/RH - Transmission Shifter (INTL Transmission)
LT/RH - Transmission Shifter (INTL Transmission) Design 566
Transmission Shifter (Universal Stalk Shifter - Allison
3K/4K)
Transmission Shifter (Universal Stalk Shifter - Allison 3K/4K) Design 567
LT/RH - Heated Windshield (W/ DS Heating Grid)
LT/RH - Heated Windshield (W/ DS Heating Grid) Design 568
LT/RH - Windshield Washer Pump W/O Low Fluid
Sensor
LT/RH - Windshield Washer Pump W/O Low Fluid Sensor Design 569
TABLE OF CONTENTS
xxviiLT/RH - Windshield Washer Pump & Low Fluid Sensor
(LT, RH, LS, HV, HX)
LT/RH - Windshield Washer Pump & Low Fluid Sensor (LT, RH, LS, HV, HX)
Design 570
LT/RH - Windshield Wipers
LT/RH - Windshield Wipers Design 571
LT/RH - Auto Start Stop and Sleeper Auto Climate,
Cab Temp, Oil Mapping, Manual Trans
LT/RH - Auto Start Stop and Sleeper Auto Climate, Cab Temp, Oil Mapping,
Manual Trans Design 572
LT/RH - Auto Start Stop with Sleeper Auto Climate,
Cab Temp, Oil Mapping, Auto Trans
LT/RH - Auto Start Stop with Sleeper Auto Climate, Cab Temp, Oil Mapping, Auto
Trans Design 573
LT/RH - Auto Start Stop (Horizon) Battery & Oil Temp
Mapping, Auto Trans
LT/RH - Auto Start Stop (Horizon) Battery & Oil Temp Mapping, Auto Trans
Design 574
LT/RH - Auto Start Stop (Horizon) Battery, Oil Temp
LT/RH - Auto Start Stop (Horizon) Battery, Oil Temp Mapping, Manual Trans
Design 575
LT/RH - Battery Disconnect (Switch Only)
LT/RH - Battery Disconnect (Switch Only) Design 576
LT/RH - Charging System (Delco Remy 36SI Alternator
W/ Remote Sense)
LT/RH - Charging System (Delco Remy 36SI Alternator W/ Remote Sense)
Design 577
LT/RH - Charging System (Delco Remy 40SI/38SI
LT/RH - Charging System (Delco Remy 40SI/38SI Alternator W/ Remote Sense)
Design 578
LT/RH - Charging System (Delco Remy & Mitsubishi
LT/RH - Charging System (Delco Remy & Mitsubishi Alternator W/ Remote
Sense) Design 579
LT/RH - Charging System (Leece-Neville AVI160-
190A/210A/240A Alternator W/ Remote Sense)
LT/RH - Charging System (Leece-Neville AVI160-190A/210A/240A Alternator W/
Remote Sense) Design 580
LT/RH - Charging System (Leece-Neville - LN 325A
LT/RH - Charging System (Leece-Neville - LN 325A Alternator W/ Remote Sense)
Design 581
LT/RH - Cranking (Starter) (BCM Controlled & N/ Wired
Thermal Overcrank, Skelstart)
TABLE OF CONTENTS
xxviiiLT/RH - Cranking (Starter) (BCM Controlled & N/ Wired Thermal Overcrank,
Skelstart) Design 582
Thermal Overcrank, W/ Disconnect)
LT/RH - Cranking (Starter) (BCM Controlled & N/ Wired Thermal Overcrank, W/
Disconnect) Design 583
LT/RH - DC/AC Inverter (Horizon)
LT/RH - DC/AC Inverter (Horizon) Design 584
LT/RH - DC/AC Inverter (with switch control)
LT/RH - DC/AC Inverter (with switch control) Design 585
LT/RH - Jump Start Stud (Dual)
LT/RH - Jump Start Stud (Dual) Design 586
LT/RH - Jump Start Stud (Single)
LT/RH - Jump Start Stud (Single) Design 587
LT/RH - Key Switch (Operator Input)
LT/RH - Key Switch (Operator Input) Design 588
LT/RH - Key Switch (Operator Input) (W/ Starter
Interrupt)
LT/RH - Key Switch (Operator Input) (W/ Starter Interrupt) Design 589
LT/RH - Crank Inhibit (W/ Hood Switch)
LT/RH - Crank Inhibit (W/ Hood Switch) Design 590
LT/RH - Hood Switch (Option 1)
LT/RH - Hood Switch (Option 1) Design 591
LT/RH - Hood Switch (Option 2)
LT/RH - Hood Switch (Option 2) Design 592
LT/RH - Hood Switch (W/ Underhood Work Light)
LT/RH - Hood Switch (W/ Underhood Work Light) Design 593
LT/RH - Battery International (3 12V Battery)
LT/RH - Battery International (3 12V Battery) Design 594
LT/RH - Battery International (4 12V Battery)
LT/RH - Battery International (4 12V Battery) Design 595
LT/RH - Battery International (8 12V Battery)
LT/RH - Battery International (8 12V Battery) Design 596
Connectors 597
Index 2009
J1939
LT/RH - IP Grounds
D7010/D7011/D7012
TABLE OF CONTENTS
D6606/D6607
Connector Design 35
Connector Design 36
1/10/2023)
Option 1
Option 2
Conventional Cab)
TABLE OF CONTENTS
Cab)
Design 49
Design 50
7145/7146/7147/7148
(Loadshed)
1 (Non-Loadshed)
Design 57
W/ CBE1 Engine
Design 60
TABLE OF CONTENTS
iiiLT/RH - Radio
W/ RSA
USB (Option 1)
USB (Option 2)
USB
Design 82
Design 83
TABLE OF CONTENTS
Switches)
Switches)
Switch 30A)
Connector)
Design 97
and 2 Hood Mirrors)
Design 102
Mirrors)
Design 104
TABLE OF CONTENTS
Hood Mirrors)
Door)
LT/RH - City Horn
System(FDT)
TABLE OF CONTENTS
AM/FM, XM Radio)
XM Radio)
/ N2 Module / S13)
Design 130
Design 132
Design 133
1)
2)
Design 140
TABLE OF CONTENTS
Design 142
Design 146
Design 148
Design 150
Repeater)(Option 1)
Repeater)(Option 2)
TABLE OF CONTENTS
Steering Wheel)
EOF)
TABLE OF CONTENTS
Design 191
Design 192
CBE1)(Option 1)
Design 197
CBE1)(Option 2)
Design 198
TABLE OF CONTENTS
Design 214
Design 218
Design 225
TRACTOR/TOW)
Design 234
Design 235
1)
2)
TABLE OF CONTENTS
Speakers)(Option 1)
Speakers)(Option 2)
1) Design 269
2) Design 270
DIU)(Option 1)
DIU)(Option 2)
TABLE OF CONTENTS
DIU)
(Blindspotter 2.0)
(Option 1)
(Option 2)
Button
Button
Tweeters)
Tweeters)
ZF Steering Gear
TABLE OF CONTENTS
Side) Design 299
Design 304
Indicator) Option 2
Option 1
Option 2
Indicator) Option 1
Option 1
Option 2
Indicator) Option 1
Indicator) Option 2
TABLE OF CONTENTS
PIM) Option 1
PIM) Option 2
(Option 1)
(Option 2)
Trans (Option 1)
Trans (Option 2)
Design 331
Design 332
Trans Design 333
TABLE OF CONTENTS
Design 338
Design 339
(113BBC HALOGEN)
Design 340
(113BBC LED)
Design 343
W/HEATER
TABLE OF CONTENTS
W/HEATER
Light)
(HRZN)
DayCab (HRZN, LS)
Design 366
Sleeper Design 368
TABLE OF CONTENTS
(Option 1)
(Option 2)
W/Back Up)
STT N/Back-Up
W/Back Up)
N/Back-Up
(Auto)
1)
2)
TABLE OF CONTENTS
(Auto)
W/Reverse)
W/Reverse)
Display)
TABLE OF CONTENTS
Heater)(Option1)
Heater)(Option 2)
Heater)
Heater)(Option 1)
Heater)(Option 2)
Design 419
Pressure SW)
16ATC Design 424
TABLE OF CONTENTS
Design 438
Smartemp
Std N/Swift
Std W/Swift
Option 1
TABLE OF CONTENTS
Option 2
Sensor)
Design 459
Design 460
System) Design 466
Sleeper Cab)
Rise Sleeper)
TABLE OF CONTENTS
(Option 1)
(Option 2)
Cab) Design 478
Sleeper) Design 479
HVAC (Horizon, HX)
Design 480
HVAC (Horizon, HX)
Design 481
Bunks)
Design 488
TABLE OF CONTENTS
Design 490
Gauge)(Option 1)
Gauge)(Option 2)
Gauge)(Option 1)
Gauge)(Option 2)
Design 498
Design 499
Design 500
Design 501
Gauges)(Option 1)
Gauges)(Option 2)
Gauges)(Option 1)
Gauges)(Option 2)
TABLE OF CONTENTS
Gauges)(Option 3)
RR) Design 510
FR&RR) Design 512
FR) Design 514
FR&RR) Design 520
Seat)
Design 523
Design 525
Bias)(Option 1)
TABLE OF CONTENTS
Bias)(Option 2)
Bias)(Option 3)
Bias)(Option 1)
Bias)(Option 2)
Bias)(Option 3)
Bias)(Option 1)
Bias)(Option 2)
Bias)(Option 3)
1)
2)
Socket)
EOF (RING GND)
Design 549
TABLE OF CONTENTS
BOC
Design 554
12V TCM)
Models) Design 560
Design 561
3K/4K)
Sensor
TABLE OF CONTENTS
Design 570
Trans Design 573
Mapping, Auto Trans
Design 574
Design 575
W/ Remote Sense)
Design 577
Design 578
Sense) Design 579
Design 581
TABLE OF CONTENTS
Interrupt)
Connectors 597
Index 2009
- International DT466,DT570,HT570 Diesel Engine Service Manual
- International DT466E Wiring Schematic
- International 365, 444, 466, 530 Service Manuals
- Navistar Diagnostic Trouble Code Index
- SCANIA 420 DC11 - DC12 Motor
- International 9800 Electrical Schematic
- International Truck DT466E Engine Repair Manual
- International - VT365 Schematic (SPA)
- Scania Manual Transmission GRS900
- International Truck 5000i,9200i,9400i and 9900i Chassis Built Electrical Circuit Diagram
- International Trucks Body Controller Diagnostic Trouble Codes
- International Wiring Diagram
- International Truck CF500 CF600 Service Manual
- Scania Manual Transmission GR 900
- International DT466, DT530 Electronic Diagram
