Momed80
150
35,046
International Truck LT RH Series Interactive Schematics 00000018829 2025
Brand: International, Navistar
Type of Manual: Interactive Schematics
Model: International LT Series, RH Series Truck
Part Number: 00000018829
Publication Date: 2025
Number of Pages: 863 Pages
BCM (Body Control Module)
BODY CONTROL MODULE (Body Control Module) Design 1
ABS Private J1939
ABS Private J1939 Design 9
Cab J1939 (250Kbps)
Cab J1939 (250Kbps) Design 10
Engine Private J1939
Engine Private J1939 Design 11
Fusion Private J1939
Fusion Private J1939 Design 12
Low Speed J1939 (125Kbps)
Low Speed J1939 (125Kbps) Design 13
Powertrain J1939 (500Kbps)
Powertrain J1939 (500Kbps) Design 14
Telematics J1708
Telematics J1708 Design 15
Body J1939 (250Kbps) Splice Pack 1024
Body J1939 (250Kbps) Splice Pack 1024 Design 16
Body J1939 (250Kbps) Splice Pack 1025
Body J1939 (250Kbps) Splice Pack 1025 Design 17
Body J1939 (250Kbps) Splice Pack 1029
Body J1939 (250Kbps) Splice Pack 1029 Design 18
Body J1939 (250Kbps) W/ 3 Splice Packs
Body J1939 (250Kbps) W/ 3 Splice Packs Design 19
ECM Euro 5 ISX
ECM Euro 5 ISX Design 20
Instrument Cluster (Premium)
Instrument Cluster (Premium) Design 21
Instrument Cluster (Standard)
Instrument Cluster (Standard) Design 22
Instrument Cluster - Bulb Check
Instrument Cluster - Bulb Check Design 23
Cab Ground Studs
Cab Ground Studs Design 24
Ground Splice Packs - 1022 & 1023
Ground Splice Packs - 1022 & 1023 Design 25
Ground Splice Packs - 1027
Ground Splice Packs - 1027 Design 26
Ground Splice Packs - 1410
Ground Splice Packs - 1410 Design 27
TABLE OF CONTENTS
iGround Splice Pack 1620
Ground Splice Pack 1620 Design 28
Sleeper Ground Splice Packs - 5007
Sleeper Ground Splice Packs - 5007 Design 29
Center Chassis Ground Splice Packs - 8803 & 8804
Center Chassis Ground Splice Packs - 8803 & 8804 Design 30
Center Chassis ZVR Splice Packs - 8802
Center Chassis ZVR Splice Packs - 8802 Design 31
Forward Chassis Ground Splice Packs - 8800
Forward Chassis Ground Splice Packs - 8800 Design 32
Powertrain Ground Splice Packs
Powertrain Ground Splice Packs Design 34
Powertrain ZVR Splice Packs
Powertrain ZVR Splice Packs Design 35
Lighting Control Module
Lighting Control Module Design 36
Underhood PDM
Underhood PDM Design 37
Aftertreatment PDM
Aftertreatment PDM Design 38
Accessory PDM (Loadshed)
Accessory PDM (Loadshed) Design 39
Grid Management (CA2 W/Load Shed Sleeper Cab)
Grid Management (CA2 W/Load Shed Sleeper Cab) Design 40
Ignition OPER1 PDM (Non-Loadshed)
Ignition OPER1 PDM (Non-Loadshed) Design 41
Ignition OPER2 PDM (Loadshed)
Ignition OPER2 PDM (Loadshed) Design 43
Battery Grid 1 (Non-Loadshed)
Battery Grid 1 (Non-Loadshed) Design 44
Battery Grid 2 (Loadshed)
Battery Grid 2 (Loadshed) Design 46
Front Turn Signal & Back-Up Light Splice Packs - 1030
& 1040
Front Turn Signal & Back-Up Light Splice Packs - 1030 & 1040 Design 47
Marker/Park Lights Splice Pack - 1028
Marker/Park Lights Splice Pack - 1028 Design 48
Panel Dimmer Splice Pack - 1021
Panel Dimmer Splice Pack - 1021 Design 49
Sleeper PDM
Sleeper PDM Design 50
TABLE OF CONTENTS
iiSpecial Power Distribution
Special Power Distribution Design 51
Back-Up Alarm (Manual) and UltraShift+
Back-Up Alarm (Manual) and UltraShift+ Design 52
City Horn W/ 10PIN CLK W/O RKA
City Horn W/ 10PIN CLK W/O RKA Design 56
Door Ajar Reminder (Entry/Exit)
Door Ajar Reminder (Entry/Exit) Design 57
Multiplexed Switch Pack (Primary Switch)
Multiplexed Switch Pack (Primary Switch) Design 58
Real Time Clock (RTC) (Standard)
Real Time Clock (RTC) (Standard) Design 59
Vehicle Sleep Mode
Vehicle Sleep Mode Design 60
Radio (Bluetooth) W/Steering Wheel Pod N/ Remote
W/MIC
Radio (Bluetooth) W/Steering Wheel Pod N/ Remote W/MIC Design 61
Cigar Lighter
Cigar Lighter Design 62
Cigar Lighter Aux APO
Cigar Lighter Aux APO Design 63
Cigar Lighter Aux APO Overhead APO
Cigar Lighter Aux APO Overhead APO Design 65
Cigar Lighter Aux APO Rear Std APO Rear APO
W/Cover 12V Panel
Cigar Lighter Aux APO Rear Std APO Rear APO W/Cover 12V Panel Design 67
w/Cover 12V Panel Overhead APO
Cigar Lighter Aux APO Rear Std APO Rear APO w/Cover 12V Panel Overhead
APO Design 71
w/Cover 12V Panel Upr Bnk APO
Cigar Lighter Aux APO Rear Std APO Rear APO w/Cover 12V Panel Upr Bnk
APO Design 75
w/Cover 12V Panel Upr Bnk APO Rear Overhead APO
APO Rear Overhead APO Design 79
Cigar Lighter Overhead APO
Cigar Lighter Overhead APO Design 83
Cigar Lighter Rear Std APO APO W/Cover 12V Panel
Cigar Lighter Rear Std APO APO W/Cover 12V Panel Design 84
TABLE OF CONTENTS
iiiCigar Lighter Rear Std APO Rear APO W/Cover 12V
Panel Overhead APO
Cigar Lighter Rear Std APO Rear APO W/Cover 12V Panel Overhead APO
Design 86
Panel Upr Bnk APO
Cigar Lighter Rear Std APO Rear APO W/Cover 12V Panel Upr Bnk APO
Design 88
Cigar Lighter Rear Std APO Rear APO w/Cover 12V
Cigar Lighter Rear Std APO Rear APO w/Cover 12V Panel Upr Bnk APO Rear
Overhead APO Design 90
Standard APO
Standard APO Design 92
Standard APO Aux APO
Standard APO Aux APO Design 93
Standard APO Aux APO Overhead APO
Standard APO Aux APO Overhead APO Design 95
Standard APO Aux APO Rear Std APO Rear APO
W/Cover 12V Panel
Standard APO Aux APO Rear Std APO Rear APO W/Cover 12V Panel Design 97
Standard APO Aux APO Rear Std APO Rear APO W/Cover 12V Panel Overhead
APO Design 101
Standard APO Aux APO Rear Std APO Rear APO W/Cover 12V Panel Upr Bnk
APO Design 105
Standard APO Aux APO Rear Std APO Rear APO w/Cover 12V Panel Upr Bnk
APO Rear Overhead APO Design 109
Standard APO Overhead APO
Standard APO Overhead APO Design 113
Standard APO Rear Std APO Rear APO W/Cover 12V
Panel
Standard APO Rear Std APO Rear APO W/Cover 12V Panel Design 114
Panel Rear Overhead APO
Standard APO Rear Std APO Rear APO W/Cover 12V Panel Rear Overhead
APO Design 116
Panel Upr Bnk APO
TABLE OF CONTENTS
ivStandard APO Rear Std APO Rear APO W/Cover 12V Panel Upr Bnk APO
Design 118
Standard APO Rear Std APO Rear APO w/Cover 12V
Standard APO Rear Std APO Rear APO w/Cover 12V Panel Upr Bnk APO Rear
Overhead APO Design 120
Adaptive Cruise Control (Bendix - Fusion W/O DIU &
N/ Safety Direct & Reg Speakers)
Adaptive Cruise Control (Bendix - Fusion W/O DIU & N/ Safety Direct & Reg
Speakers) Design 122
Vehicle Speed Control (Cruise Control) 10 - Pin
Vehicle Speed Control (Cruise Control) 10 - Pin Design 123
Power Door Locks
Power Door Locks Design 124
Heated Mirrors (Door Pod Actuated Cab and Hood
Mounted)
Heated Mirrors (Door Pod Actuated Cab and Hood Mounted) Design 125
Heated Mirrors (Door Pod Actuated Cab Mounted)
Heated Mirrors (Door Pod Actuated Cab Mounted) Design 126
Mirrors (Heat) [Switch Pack Actuated Relay Driven]
Mirrors (Heat) [Switch Pack Actuated Relay Driven] Design 127
Mirrors (Power) [Door Pod Actuated]
Mirrors (Power) [Door Pod Actuated] Design 128
Mirror Lighting (Turns without Door Pods)
Mirror Lighting (Turns without Door Pods) Design 129
Mirror Lighting (Turns with Door Pods)
Mirror Lighting (Turns with Door Pods) Design 130
Power Windows
Power Windows Design 131
Antenna (Film Antenna Sleeper Cab OTAPM and
Radio)
Antenna (Film Antenna Sleeper Cab OTAPM and Radio) Design 132
Antenna (Shark Fin Day Cab OTAPM and Radio)
Antenna (Shark Fin Day Cab OTAPM and Radio) Design 133
Navistar Telematics Module - Programming
Navistar Telematics Module - Programming Design 134
Navistar Telematics Module - Wiring
Navistar Telematics Module - Wiring Design 135
Single USB
Single USB Design 136
Selective Catalytic Reduction (SCR) (W/ CA2.0
Architecture)
Selective Catalytic Reduction (SCR) (W/ CA2.0 Architecture) Design 137
TABLE OF CONTENTS
vDPF Regen Switch Only
DPF Regen Switch Only Design 138
Traction Control (Bendix Controller)
Traction Control (Bendix Controller) Design 139
Left Side Air Dryer-Bendix
Left Side Air Dryer-Bendix Design 141
Park Brake Controls
Park Brake Controls Design 143
Park Brake Controls (Non Lever Park Brake)
Park Brake Controls (Non Lever Park Brake) Design 144
Collision Avoidance System (Warning)
Collision Avoidance System (Warning) Design 145
Lane Departure Warning - Bendix
Lane Departure Warning - Bendix Design 146
Adjustable Engine Speed Control (PTO) 10-PIN
ClockSpring
Adjustable Engine Speed Control (PTO) 10-PIN ClockSpring Design 147
Coolant Level Monitoring
Coolant Level Monitoring Design 148
Cooling Fan Control
Cooling Fan Control Design 149
Engine Idle Increment/Decrement (Steering Wheel
Switch - 10 Pin)
Engine Idle Increment/Decrement (Steering Wheel Switch - 10 Pin) Design 150
Fuel Delivery System (Fuel Lift Pump)
Fuel Delivery System (Fuel Lift Pump) Design 151
Vehicle Acceleration (w/ Two PWR Two GND & Two
STS)
Vehicle Acceleration (w/ Two PWR Two GND & Two STS) Design 152
Water-In-Fuel (WIF) (Racor N/ Heater)
Water-In-Fuel (WIF) (Racor N/ Heater) Design 153
EGNR Diagnostic Connector
EGNR Diagnostic Connector Design 154
Engine Diagnostic Connector
Engine Diagnostic Connector Design 155
Backup Lights (Dual Reverse Light) Eaton/Manual
Backup Lights (Dual Reverse Light) Eaton/Manual Transmission Design 156
Beacon/Strobe Light
Beacon/Strobe Light Design 158
Brake Switch
Brake Switch Design 160
TABLE OF CONTENTS
viClearance and Identification Lights (W/ Sunshade)
Clearance and Identification Lights (W/ Sunshade) Design 161
Hazard Warning (CA 2.0)
Hazard Warning (CA 2.0) Design 162
Headlights (LED-125) N/ INT N/LOWW LT
Headlights (LED-125) N/ INT N/LOWW LT Design 163
MARKER/PARK LIGHTS - W/Marker Interrupt 10pin
CLCKSPRING
MARKER/PARK LIGHTS - W/Marker Interrupt 10pin CLCKSPRING Design 164
Work Lights -LED W/ Sw Pack - Sleeper
Work Lights -LED W/ Sw Pack - Sleeper Design 165
Work Lights -LED W/ Sw Pack - Sleeper W/O RKE
Work Lights -LED W/ Sw Pack - Sleeper W/O RKE Design 166
W/MAN REV
Work Lights -LED W/ Sw Pack - Sleeper W/O RKE W/MAN REV Design 167
Work Lights -LED W/ Sw Pack - Sleeper W/ RKE
W/MAN REV
Work Lights -LED W/ Sw Pack - Sleeper W/ RKE W/MAN REV Design 168
Heating Ventilation & Air Conditioning (HVAC) Auto
Temp Control
Heating Ventilation & Air Conditioning (HVAC) Auto Temp Control Design 169
Rear HVAC (Sleeper W/ Premium)
Rear HVAC (Sleeper W/ Premium) Design 171
Vehicle Speedometer System (Manual XMSN)
Vehicle Speedometer System (Manual XMSN) Design 173
Ambient Air Temperature Option 1
Ambient Air Temperature Option 1 Design 174
Ambient Air Temperature Option 2
Ambient Air Temperature Option 2 Design 175
Auxilary Gauges (Secondary)
Auxilary Gauges (Secondary) Design 176
Auxiliary Gauges (Primary)
Auxiliary Gauges (Primary) Design 177
Tandem Axle Temperature Monitoring w/ Single
SNSR and AUX Gauge
Tandem Axle Temperature Monitoring w/ Single SNSR and AUX Gauge
Design 178
Compressed Air Supply (Primary and Secondary
Gauge)
Compressed Air Supply (Primary and Secondary Gauge) Design 179
TABLE OF CONTENTS
viiDEF Economy Monitor (GEN IV Cluster w/ Cummins
ENG)
DEF Economy Monitor (GEN IV Cluster w/ Cummins ENG) Design 180
Engine Usage Monitoring (Base)
Engine Usage Monitoring (Base) Design 181
Engine Oil Pressure
Engine Oil Pressure Design 182
Engine Speed (Tachometer_J1939)
Engine Speed (Tachometer_J1939) Design 183
Fuel Level (Single Tank - Left Side)
Fuel Level (Single Tank - Left Side) Design 184
Odometer (Cluster)
Odometer (Cluster) Design 190
Trip Odometer (Cluster)
Trip Odometer (Cluster) Design 191
Voltage Monitoring (Voltmeter) Option 1
Voltage Monitoring (Voltmeter) Option 1 Design 192
Voltage Monitoring (Voltmeter) Option 2
Voltage Monitoring (Voltmeter) Option 2 Design 193
Engine Warning (DM1 LAMPS - MUX)
Engine Warning (DM1 LAMPS - MUX) Design 194
Coolant Temperature Monitoring (J1939 Comm)
Coolant Temperature Monitoring (J1939 Comm) Design 195
Air Flow Restriction Monitoring
Air Flow Restriction Monitoring Design 196
Fuel Economy Monitor
Fuel Economy Monitor Design 197
Courtesy Light Cab
Courtesy Light Cab Design 198
Floor/Search Lights Sleeper
Floor/Search Lights Sleeper Design 199
Interior Task Lights (Map Light-Separate map light
from cab dome) - Sleeper Cab
Interior Task Lights (Map Light-Separate map light from cab dome) - Sleeper Cab
Design 200
Luggage Compartment Lights - W/O No Idle HVAC
Luggage Compartment Lights - W/O No Idle HVAC Design 201
Reading Lighting - W/Lower
Reading Lighting - W/Lower Design 202
Rear Interior Dimming (Accent Light)
Rear Interior Dimming (Accent Light) Design 203
Cab Dome Light - (Sleeper Cab)
TABLE OF CONTENTS
viiiCab Dome Light - (Sleeper Cab) Design 204
Lighting Sleeper Dome
Lighting Sleeper Dome Design 205
Panel Backlighting (Cabin Dimmer) Option 1
Panel Backlighting (Cabin Dimmer) Option 1 Design 206
Panel Backlighting (Cabin Dimmer) Option 2
Panel Backlighting (Cabin Dimmer) Option 2 Design 207
Power Divider Lock Control and Monitoring
Power Divider Lock Control and Monitoring Design 208
Trailer Interface (Lighting) – BOC NA
Trailer Interface (Lighting) – BOC NA Design 209
Battery International (4) 12V
Battery International (4) 12V Design 211
Key Switch (Operator Input)
Key Switch (Operator Input) Design 212
Delco Remy 28SI Alternator
Delco Remy 28SI Alternator Design 213
Cranking (Starter) GEN4 BCM W/ Thermal Overcrank -
External Switch
Cranking (Starter) GEN4 BODY CONTROL MODULE W/ Thermal Overcrank -
External Switch Design 214
Clutch Monitoring (High and Low Switch to BCM)
Clutch Monitoring (High and Low Switch to BCM) Design 215
Cranking Request (BCM Controlled)
Cranking Request (BCM Controlled) Design 216
Engine Speed Inhibit Only
Engine Speed Inhibit Only Design 217
Starter Interlock (BCM HSD controlled W/ Clutch
Switch N/ Auto Start Stop)
Starter Interlock (BCM HSD controlled W/ Clutch Switch N/ Auto Start Stop)
Design 218
9 Pin Diagnostic Connector (Green)
9 Pin Diagnostic Connector (Green) Design 219
9 Pin Diagnostic Connector (Green)(Export)
9 Pin Diagnostic Connector (Green)(Export) Design 220
Connectors 221
Index 844
