Momed80
150
35,046
International Truck LT RH Lonestar Series Interactive Schematics 0000018828 2022
Brand: International, Navistar
Type of Manual: Interactive Schematics
Model: International LT Series, RH Series, Lonestar Series Truck
Built: 1/14/2019 To 12/10/2021
Part Number: 0000018828
Publication Date: 2022
Number of Pages: 3172 Pages
LT/RH/LoneStar - X15/A26 - BODY CONTROL
MODULE (Body Control Module)
LT/RH/LoneStar - X15/A26 - BODY CONTROL MODULE (Body Control Module)
Design 1
ABS Private J1939
ABS Private J1939 Design 9
Cab J1939 (250Kbps)
Cab J1939 (250Kbps) Design 10
Engine Private J1939 A26
Engine Private J1939 A26 Design 11
Engine Private J1939 X15
Engine Private J1939 X15 Design 12
Fusion Private J1939
Fusion Private J1939 Design 13
Low Speed J1939 (125Kbps)
Low Speed J1939 (125Kbps) Design 14
Telematics J1708
Telematics J1708 Design 15
Body J1939 (250Kbps) Splice Pack 1024
Body J1939 (250Kbps) Splice Pack 1024 Design 16
Body J1939 (250Kbps) Splice Pack 1025
Body J1939 (250Kbps) Splice Pack 1025 Design 17
Body J1939 (250Kbps) Splice Pack 1029
Body J1939 (250Kbps) Splice Pack 1029 Design 18
Body J1939 (250Kbps) W/ 3 Splice Packs
Body J1939 (250Kbps) W/ 3 Splice Packs Design 19
Powertrain J1939 (500Kbps) Allison 3K Transmission
A26
Powertrain J1939 (500Kbps) Allison 3K Transmission A26 Design 20
Powertrain J1939 (500Kbps) Eaton Ultrashift+
Transmission A26
Powertrain J1939 (500Kbps) Eaton Ultrashift+ Transmission A26 Design 21
Powertrain J1939 (500Kbps) Edurant Transmission
A26
Powertrain J1939 (500Kbps) Edurant Transmission A26 Design 22
Powertrain J1939 (500Kbps) Manual Transmission
A26
Powertrain J1939 (500Kbps) Manual Transmission A26 Design 23
Powertrain J1939 (500Kbps) TC10 Transmission A26
Powertrain J1939 (500Kbps) TC10 Transmission A26 Design 24
Transmission X15
iPowertrain J1939 (500Kbps) Eaton Ultrashift+ Transmission X15 Design 25
Powertrain J1939 (500Kbps) Endurant Transmission
X15
Powertrain J1939 (500Kbps) Endurant Transmission X15 Design 26
Powertrain J1939 (500Kbps) Manual Transmission X15
Powertrain J1939 (500Kbps) Manual Transmission X15 Design 27
Powertrain J1939 (500Kbps) TC10 Transmission X15
Powertrain J1939 (500Kbps) TC10 Transmission X15 Design 28
LT/RH - Navistar A26 ECM
LT/RH - Navistar A26 ECM Design 29
LT/RH/LoneStar - Cummins X15 ECM
LT/RH/LoneStar - Cummins X15 ECM Design 31
LT/RH/LoneStar - X15/A26 - Instrument Cluster
(Premium)
LT/RH/LoneStar - X15/A26 - Instrument Cluster (Premium) Design 32
(Standard)
LT/RH/LoneStar - X15/A26 - Instrument Cluster (Standard) Design 33
LT/RH/LoneStar - X15/A26 - Instrument Cluster - Bulb
Check
LT/RH/LoneStar - X15/A26 - Instrument Cluster - Bulb Check Design 34
Request and Status
LT/RH/LoneStar - X15/A26 - Instrument Cluster - Request and Status Design 35
LT/RH/LoneStar - X15/A26 - Cab Ground Studs
LT/RH/LoneStar - X15/A26 - Cab Ground Studs Design 36
LT/RH/LoneStar - X15/A26 - Ground Splice Packs -
1022 & 1023
LT/RH/LoneStar - X15/A26 - Ground Splice Packs - 1022 & 1023 Design 37
1027
LT/RH/LoneStar - X15/A26 - Ground Splice Packs - 1027 Design 38
LT/RH/LoneStar - X15/A26 - Ground Splice Pack 1620
LT/RH/LoneStar - X15/A26 - Ground Splice Pack 1620 Design 39
LT/RH/LoneStar - X15/A26 - Sleeper Ground Splice
Packs - 5007
LT/RH/LoneStar - X15/A26 - Sleeper Ground Splice Packs - 5007 Design 40
LT/RH/LoneStar - X15/A26 - Center Chassis Ground
Splice Packs - 8803 & 8804
LT/RH/LoneStar - X15/A26 - Center Chassis Ground Splice Packs - 8803 & 8804
Design 41
LT/RH/LoneStar - X15/A26 - Center Chassis ZVR
Splice Packs - 8802
iiLT/RH/LoneStar - X15/A26 - Center Chassis ZVR Splice Packs - 8802 Design 42
LT/RH/LoneStar - X15/A26 - Forward Chassis Ground
Splice Packs - 8800
LT/RH/LoneStar - X15/A26 - Forward Chassis Ground Splice Packs - 8800
Design 43
LT/RH A26 - Powertrain Ground Splice Packs - 6704
LT/RH A26 - Powertrain Ground Splice Packs - 6704 Design 45
LT/RH A26 - ZVR Splice Packs - 6702 & 6704B
LT/RH A26 - ZVR Splice Packs - 6702 & 6704B Design 46
LT/RH/LoneStar X15 - Powertrain Ground Splice
Packs - 6704 & 6704A
LT/RH/LoneStar X15 - Powertrain Ground Splice Packs - 6704 & 6704A Design47
LT/RH/LoneStar X15 - ZVR Splice Packs - 6702 & 6703
LT/RH/LoneStar X15 - ZVR Splice Packs - 6702 & 6703 Design 48
LT/RH/LoneStar - X15/A26 - Lighting Control Module
LT/RH/LoneStar - X15/A26 - Lighting Control Module Design 49
LT/RH A26 - Aftertreatment PDM
LT/RH A26 - Aftertreatment PDM Design 50
LT/RH/LoneStar X15 - Aftertreatment PDM
LT/RH/LoneStar X15 - Aftertreatment PDM Design 51
Battery Feed
Battery Feed Design 52
Interior PDM Chart
Interior PDM Chart Design 53
Key Switch Accessory
Key Switch Accessory Design 54
Key Switch Ignition
Key Switch Ignition Design 55
Relays - Grid Management (N/Load Shed Day Cab)
Relays - Grid Management (N/Load Shed Day Cab) Design 56
Relays - Grid Management (W/Load Shed Day Cab)
Relays - Grid Management (W/Load Shed Day Cab) Design 57
Relays - Grid Management (W/Load Shed Sleeper Cab)
Relays - Grid Management (W/Load Shed Sleeper Cab) Design 58
LT/RH/LoneStar - X15/A26 - ABS CAN Splice Pack -
1410
LT/RH/LoneStar - X15/A26 - ABS CAN Splice Pack - 1410 Design 59
LT/RH/LoneStar - X15/A26 - Front Turn Signal & BackUp Light Splice Packs - 1030 & 1040
LT/RH/LoneStar - X15/A26 - Front Turn Signal & Back-Up Light Splice Packs -
1030 & 1040 Design 60
iiiLT/RH/LoneStar - X15/A26 - Marker/Park Lights Splice
Pack - 1028
LT/RH/LoneStar - X15/A26 - Marker/Park Lights Splice Pack - 1028 Design 61
LT/RH/LoneStar - X15/A26 - Panel Dimmer Splice Pack
- 1021
LT/RH/LoneStar - X15/A26 - Panel Dimmer Splice Pack - 1021 Design 62
LT/RH/LoneStar - X15/A26 - Sleeper PDM
LT/RH/LoneStar - X15/A26 - Sleeper PDM Design 63
LT/RH/LoneStar - X15/A26 - Special Power Distribution
LT/RH/LoneStar - X15/A26 - Special Power Distribution Design 64
LT/RH A26 - Underhood PDM
LT/RH A26 - Underhood PDM Design 65
LT/RH/LoneStar X15 - Underhood PDM
LT/RH/LoneStar X15 - Underhood PDM Design 66
LT/RH/LoneStar - X15/A26 - Auxiliary Air Solenoids 4-
pack (1 pack/4 solenoids)
LT/RH/LoneStar - X15/A26 - Auxiliary Air Solenoids 4-pack (1 pack/4 solenoids)
Design 67
pack (2 packs/8 solenoids)
LT/RH/LoneStar - X15/A26 - Auxiliary Air Solenoids 4-pack (2 packs/8 solenoids)
Design 72
LT/RH - X15/A26 - Radio N/ Sterring Wheel Pod N/
Remote
LT/RH - X15/A26 - Radio N/ Sterring Wheel Pod N/ Remote Design 77
LT/RH - X15/A26 - Radio W/Steering Wheel Pod N/
Remote
LT/RH - X15/A26 - Radio W/Steering Wheel Pod N/ Remote Design 78
LT/RH/LoneStar - X15/A26 - Radio N/ Steering Wheel
Pod W/Remote
LT/RH/LoneStar - X15/A26 - Radio N/ Steering Wheel Pod W/Remote Design 79
LT/RH/LoneStar - X15/A26 - Radio W/Steering Wheel
Pod W/Remote
LT/RH/LoneStar - X15/A26 - Radio W/Steering Wheel Pod W/Remote Design 80
LT/RH/LoneStar - X15/A26 - Radio (Bluetooth)
W/Steering Wheel Pod N/ Remote W/MIC
LT/RH/LoneStar - X15/A26 - Radio (Bluetooth) W/Steering Wheel Pod N/ Remote
W/MIC Design 81
LT/RH/LoneStar - X15/A26 - Radio(Bluetooth)
W/Steering Wheel W/Remote W/MIC
LT/RH/LoneStar - X15/A26 - Radio(Bluetooth) W/Steering Wheel W/Remote
W/MIC Design 82
LT/RH LoneStar - X15/A26 - Speakers:Four Speakers
N/BT N/QC
LT/RH LoneStar - X15/A26 - Speakers:Four Speakers N/BT N/QC Design 83
ivLT/RH LoneStar - X15/A26 - Speakers:Four Speakers
N/BT W/QC
LT/RH LoneStar - X15/A26 - Speakers:Four Speakers N/BT W/QC Design 85
LT/RH LoneStar - X15/A26 - Speakers:Speakers N/BT
W/AMP N/QC
LT/RH LoneStar - X15/A26 - Speakers:Speakers N/BT W/AMP N/QC Design 87
W/BT N/QC
LT/RH LoneStar - X15/A26 - Speakers:Four Speakers W/BT N/QC Design 88
W/BT W/QC
LT/RH LoneStar - X15/A26 - Speakers:Four Speakers W/BT W/QC Design 90
LT/RH LoneStar - X15/A26 - Speakers:Speakers W/BT
W/AMP N/QC
LT/RH LoneStar - X15/A26 - Speakers:Speakers W/BT W/AMP N/QC Design 92
LT/RH/LoneStar - X15/A26 - Dual Aux Switch
LT/RH/LoneStar - X15/A26 - Dual Aux Switch Design 93
LT/RH/LoneStar - X15/A26 - Single Aux Switch
LT/RH/LoneStar - X15/A26 - Single Aux Switch Design 94
LT/RH/LoneStar - X15/A26 - Back-Up Alarm
(Automatic) TC10
LT/RH/LoneStar - X15/A26 - Back-Up Alarm (Automatic) TC10 Design 96
(Automatic) (W/ Tail Light Bar Assy)
LT/RH/LoneStar - X15/A26 - Back-Up Alarm (Automatic) (W/ Tail Light Bar Assy)
Design 100
LT/RH A26 - Back-Up Alarm (Manual) and UltraShift+
LT/RH A26 - Back-Up Alarm (Manual) and UltraShift+ Design 102
LT/RH A26 - Back-Up Alarm (Manual) (W/ Tail Light
Bar Assy)
LT/RH A26 - Back-Up Alarm (Manual) (W/ Tail Light Bar Assy) Design 110
LT/RH/LoneStar X15 - Back-Up Alarm (Manual) and
UltraShift+
LT/RH/LoneStar X15 - Back-Up Alarm (Manual) and UltraShift+ Design 114
LT/RH/LoneStar X15 - Back-Up Alarm (Manual) (W/ Tail
Light Bar Assy)
LT/RH/LoneStar X15 - Back-Up Alarm (Manual) (W/ Tail Light Bar Assy)
Design 118
LT/RH/LoneStar - X15/A26 - Banana Plugs Receptacle
LT/RH/LoneStar - X15/A26 - Banana Plugs Receptacle Design 120
LT/RH/LoneStar - X15/A26 - CB Radio Power Only
LT/RH/LoneStar - X15/A26 - CB Radio Power Only Design 121
LT/RH/LoneStar - X15/A26 - Cigar Lighter
LT/RH/LoneStar - X15/A26 - Cigar Lighter Design 122
vLT/RH/LoneStar - X15/A26 - Cigar Lighter Aux APO
LT/RH/LoneStar - X15/A26 - Cigar Lighter Aux APO Design 123
Overhead APO
LT/RH/LoneStar - X15/A26 - Cigar Lighter Aux APO Overhead APO Design 125
Rear Std APO Rear APO W/Cover 12V Panel
LT/RH/LoneStar - X15/A26 - Cigar Lighter Aux APO Rear Std APO Rear APO
W/Cover 12V Panel Design 127
Rear Std APO Rear APO w/Cover 12V Panel Overhead
APO
w/Cover 12V Panel Overhead APO Design 131
Rear Std APO Rear APO w/Cover 12V Panel Upr Bnk
APO
w/Cover 12V Panel Upr Bnk APO Design 135
APO Rear Overhead APO
w/Cover 12V Panel Upr Bnk APO Rear Overhead APO Design 139
LT/RH/LoneStar - X15/A26 - Cigar Lighter Overhead
APO
LT/RH/LoneStar - X15/A26 - Cigar Lighter Overhead APO Design 143
LT/RH/LoneStar - X15/A26 - Cigar Lighter Rear Std
APO APO W/Cover 12V Panel
LT/RH/LoneStar - X15/A26 - Cigar Lighter Rear Std APO APO W/Cover 12V
Panel Design 144
APO Rear APO W/Cover 12V Panel Overhead APO
LT/RH/LoneStar - X15/A26 - Cigar Lighter Rear Std APO Rear APO W/Cover 12V
Panel Overhead APO Design 146
APO Rear APO W/Cover 12V Panel Upr Bnk APO
Panel Upr Bnk APO Design 148
APO Rear APO w/Cover 12V Panel Upr Bnk APO Rear
Overhead APO
LT/RH/LoneStar - X15/A26 - Cigar Lighter Rear Std APO Rear APO w/Cover 12V
Panel Upr Bnk APO Rear Overhead APO Design 150
LT/RH/LoneStar - X15/A26 - Standard APO
LT/RH/LoneStar - X15/A26 - Standard APO Design 152
LT/RH/LoneStar - X15/A26 - Standard APO Aux APO
viLT/RH/LoneStar - X15/A26 - Standard APO Aux APO Design 153
Overhead APO
LT/RH/LoneStar - X15/A26 - Standard APO Aux APO Overhead APO Design 155
LT/RH/LoneStar - X15/A26 - Standard APO Overhead
APO
LT/RH/LoneStar - X15/A26 - Standard APO Overhead APO Design 157
LT/RH/LoneStar - X15/A26 - Std APO Aux APO Rear
LT/RH/LoneStar - X15/A26 - Std APO Aux APO Rear Std APO Rear APO
W/Cover 12V Panel Design 158
Std APO Rear APO W/Cover 12V Panel Overhead APO
W/Cover 12V Panel Overhead APO Design 162
Std APO Rear APO W/Cover 12V Panel Upr Bnk APO
W/Cover 12V Panel Upr Bnk APO Design 166
Std APO Rear APO w/Cover 12V Panel Upr Bnk APO
Rear Overhead APO
w/Cover 12V Panel Upr Bnk APO Rear Overhead APO Design 170
LT/RH/LoneStar - X15/A26 - Std APO Rear Std APO
LT/RH/LoneStar - X15/A26 - Std APO Rear Std APO Rear APO W/Cover 12V
Panel Design 174
Rear APO W/Cover 12V Panel Rear Overhead APO
Panel Rear Overhead APO Design 176
Panel Upr Bnk APO Design 178
Overhead APO
LT/RH/LoneStar - X15/A26 - Std APO Rear Std APO Rear APO w/Cover 12V
Panel Upr Bnk APO Rear Overhead APO Design 180
LoneStar - X15 - Adaptive Cruise Control w/o Display
(Bendix)
LoneStar - X15 - Adaptive Cruise Control w/o Display (Bendix) Design 182
viiLoneStar - X15 - Adaptive Cruise Control (Bendix -
Fusion W/O DIU & N/ Safety Direct & Tweeters)
LoneStar - X15 - Adaptive Cruise Control (Bendix - Fusion W/O DIU & N/ Safety
Direct & Tweeters) Design 183
Fusion W/O DIU & W/ Safety Direct & Reg Speakers)
Option 1
LoneStar - X15 - Adaptive Cruise Control (Bendix - Fusion W/O DIU & W/ Safety
Direct & Reg Speakers) Option 1 Design 184
Option 2
Direct & Reg Speakers) Option 2 Design 185
Fusion W/O DIU & W/ Safety Direct & W/ Tweeters)
Direct & W/ Tweeters) Design 186
LT/RH - X15/A26 - Adaptive Cruise Control w/o Display
(Bendix)
LT/RH - X15/A26 - Adaptive Cruise Control w/o Display (Bendix) Design 187
LT/RH - X15/A26 - Adaptive Cruise Control (Bendix -
Fusion W/O DIU & N/ Safety Direct & Reg Speakers)
LT/RH - X15/A26 - Adaptive Cruise Control (Bendix - Fusion W/O DIU & N/ Safety
Direct & Reg Speakers) Design 188
Direct & Tweeters) Design 189
LT/RH - X15/A26 - Adaptive Cruise Control (Bendix - Fusion W/O DIU & W/
Safety Direct & Reg Speakers) Design 190
Safety Direct & W/ Tweeters) Design 191
(Wabco)
LoneStar - X15 - Adaptive Cruise Control w/o Display (Wabco) Design 192
(Wabco)
LT/RH - X15/A26 - Adaptive Cruise Control w/o Display (Wabco) Design 193
LT/RH/LoneStar - X15/A26 - Analytic Cruise Control
LT/RH/LoneStar - X15/A26 - Analytic Cruise Control Design 194
viiiLT/RH - X15/A26 - 10 PIN ClockSpring
LT/RH - X15/A26 - 10 PIN ClockSpring Design 195
LT/RH/LoneStar - X15/A26 - Vehicle Speed Control
(Cruise Control) 4 - PIN
LT/RH/LoneStar - X15/A26 - Vehicle Speed Control (Cruise Control) 4 - PIN
Design 196
LT/RH/LoneStar - X15/A26 - Door Ajar Reminder
(Entry/Exit)
LT/RH/LoneStar - X15/A26 - Door Ajar Reminder (Entry/Exit) Design 197
LT/RH/LoneStar - X15/A26 - Power Door Locks
LT/RH/LoneStar - X15/A26 - Power Door Locks Design 198
LT/RH - X15/A26 - Mirrors (Heat) [Switch Pack
Actuated Relay Driven]
LT/RH - X15/A26 - Mirrors (Heat) [Switch Pack Actuated Relay Driven] Design199
LT/RH/LoneStar - X15/A26 - Heated Mirrors (Door Pod
Actuated Cab and Hood Mounted)
LT/RH/LoneStar - X15/A26 - Heated Mirrors (Door Pod Actuated Cab and Hood
Mounted) Design 200
Actuated Cab Mounted)
LT/RH/LoneStar - X15/A26 - Heated Mirrors (Door Pod Actuated Cab Mounted)
Design 201
LT/RH/LoneStar - X15/A26 - Mirrors (Power) [Door Pod
Actuated]
LT/RH/LoneStar - X15/A26 - Mirrors (Power) [Door Pod Actuated] Design 202
LT/RH/LoneStar - X15/A26 - Mirror Lighting (Turns
without Door Pods)
LT/RH/LoneStar - X15/A26 - Mirror Lighting (Turns without Door Pods) Design203
with Door Pods)
LT/RH/LoneStar - X15/A26 - Mirror Lighting (Turns with Door Pods) Design 204
LT/RH/LoneStar - X15/A26 - Power Windows
LT/RH/LoneStar - X15/A26 - Power Windows Design 205
LoneStar - X15 - City Horn W/ 10PIN CLK W/O RKA
LoneStar - X15 - City Horn W/ 10PIN CLK W/O RKA Design 206
LoneStar - X15 - City Horn W/ 10PIN CLK W/RKA
LoneStar - X15 - City Horn W/ 10PIN CLK W/RKA Design 207
LoneStar - X15 - City Horn W/ 4PIN CLK W/O RKA
LoneStar - X15 - City Horn W/ 4PIN CLK W/O RKA Design 208
LoneStar - X15 - City Horn W/ 4PIN CLK W/RKA
LoneStar - X15 - City Horn W/ 4PIN CLK W/RKA Design 209
LT/RH - X15/A26 - City Horn W/ 10PIN CLK W/O RKA
LT/RH - X15/A26 - City Horn W/ 10PIN CLK W/O RKA Design 210
ixLT/RH - X15/A26 - City Horn W/ 10PIN CLK W/RKA
LT/RH - X15/A26 - City Horn W/ 10PIN CLK W/RKA Design 211
LT/RH - X15/A26 - City Horn W/ 4PIN CLK W/O RKA
LT/RH - X15/A26 - City Horn W/ 4PIN CLK W/O RKA Design 212
LT/RH - X15/A26 - City Horn W/ 4PIN CLK W/RKA
LT/RH - X15/A26 - City Horn W/ 4PIN CLK W/RKA Design 213
LT/RH LoneStar - X15/A26 - Fan - Sleeper/Bunk
LT/RH LoneStar - X15/A26 - Fan - Sleeper/Bunk Design 214
LT/RH/LoneStar - X15/A26 - (Rand Mcnallly) GPS
Display
LT/RH/LoneStar - X15/A26 - (Rand Mcnallly) GPS Display Design 215
LT A26/X15 Hadley Smart Valve - 14WCS
LT A26/X15 Hadley Smart Valve - 14WCS Design 216
LT/RH/LoneStar - X15/A26 - Multiplexed Switch Pack
(Primary Switch)
LT/RH/LoneStar - X15/A26 - Multiplexed Switch Pack (Primary Switch) Design217
LT/RH/LoneStar - X15/A26 - Real Time Clock (RTC)
(Standard)
LT/RH/LoneStar - X15/A26 - Real Time Clock (RTC) (Standard) Design 218
LT/RH/LoneStar - X15/A26 - Cabinet Refrigerator
N/Relay
LT/RH/LoneStar - X15/A26 - Cabinet Refrigerator N/Relay Design 219
W/Relay
LT/RH/LoneStar - X15/A26 - Cabinet Refrigerator W/Relay Design 220
LT/RH/LoneStar - X15/A26 - Underbunk Refrigerator
N/Relay
LT/RH/LoneStar - X15/A26 - Underbunk Refrigerator N/Relay Design 221
LT/RH/LoneStar - X15/A26 - Remote Keyless Access
LT/RH/LoneStar - X15/A26 - Remote Keyless Access Design 222
LT/RH/LoneStar - X15/A26 - Telematics (DRIVERTECH
DAYCAB W/ J1939)
LT/RH/LoneStar - X15/A26 - Telematics (DRIVERTECH DAYCAB W/ J1939)
Design 223
SLEEPER W/ J1939)
LT/RH/LoneStar - X15/A26 - Telematics (DRIVERTECH SLEEPER W/ J1939)
Design 224
LT/RH/LoneStar - X15/A26 - Antenna (Film Antenna
Sleeper Cab OTAPM and Radio)
LT/RH/LoneStar - X15/A26 - Antenna (Film Antenna Sleeper Cab OTAPM and
Radio) Design 225
xLT/RH/LoneStar - X15/A26 - Antenna (Shark Fin Day
LT/RH/LoneStar - X15/A26 - Antenna (Shark Fin Day Cab OTAPM and Radio)
Design 226
LT/RH/LoneStar - X15/A26 - Navistar Telematics
Module - Programming
LT/RH/LoneStar - X15/A26 - Navistar Telematics Module - Programming
Design 227
Module - Wiring
LT/RH/LoneStar - X15/A26 - Navistar Telematics Module - Wiring Design 228
LT/RH/LoneStar - X15/A26 - Telematics (OMNIVISION
MD)
LT/RH/LoneStar - X15/A26 - Telematics (OMNIVISION MD) Design 229
W/ J1939 & PANIC BUTTON)
LT/RH/LoneStar - X15/A26 - Telematics (OMNIVISION W/ J1939 & PANIC
BUTTON) Design 231
LT/RH/LoneStar - X15/A26 - Telematics:OnCommand
Telematics Module
LT/RH/LoneStar - X15/A26 - Telematics:OnCommand Telematics Module
Design 233
LT/RH/LoneStar - X15/A26 - Telematics (PEOPLE NET
DAYCAB)
LT/RH/LoneStar - X15/A26 - Telematics (PEOPLE NET DAYCAB) Design 234
SLEEPER)
LT/RH/LoneStar - X15/A26 - Telematics (PEOPLE NET SLEEPER) Design 235
LT/RH/LoneStar - X15/A26 - Telematics QUALCOMM
IMCT DAYCAB With MVPC
LT/RH/LoneStar - X15/A26 - Telematics QUALCOMM IMCT DAYCAB With
MVPC Design 236
IMCT DAYCAB With MVPC & PANIC BUTTON
MVPC & PANIC BUTTON Design 237
IMCT DAYCAB With PANIC BUTTON
PANIC BUTTON Design 238
IMCT MD
LT/RH/LoneStar - X15/A26 - Telematics QUALCOMM IMCT MD Design 240
TMCT
xiLT/RH/LoneStar - X15/A26 - Telematics QUALCOMM TMCT Design 242
TMCT With PANIC BUTTON
LT/RH/LoneStar - X15/A26 - Telematics QUALCOMM TMCT With PANIC
BUTTON Design 243
LT/RH/LoneStar - X15/A26 - Telematics (QUALCOMM
MCP50)
LT/RH/LoneStar - X15/A26 - Telematics (QUALCOMM MCP50) Design 244
MCT w/o Tracs)
LT/RH/LoneStar - X15/A26 - Telematics (QUALCOMM MCT w/o Tracs)
Design 245
MCT w/ TRACS)
LT/RH/LoneStar - X15/A26 - Telematics (QUALCOMM MCT w/ TRACS)
Design 246
LT/RH/LoneStar - X15/A26 - Telematics (TRIPMASTER
DAYCAB)
LT/RH/LoneStar - X15/A26 - Telematics (TRIPMASTER DAYCAB) Design 247
SLEEPER)
LT/RH/LoneStar - X15/A26 - Telematics (TRIPMASTER SLEEPER) Design 248
LT/RH/LoneStar - X15/A26 - Theft Deterrent (Standard
J1939 Mux SW)
LT/RH/LoneStar - X15/A26 - Theft Deterrent (Standard J1939 Mux SW)
Design 249
LoneStar - X15 - Tire Pressure (TPMS) (US & Canada)
LoneStar - X15 - Tire Pressure (TPMS) (US & Canada) Design 250
LT/RH - X15/A26 - Tire Pressure (TPMS) (US &
Canada)
LT/RH - X15/A26 - Tire Pressure (TPMS) (US & Canada) Design 251
LT/RH/LoneStar - X15/A26 - Single USB
LT/RH/LoneStar - X15/A26 - Single USB Design 252
LT/RH/LoneStar - X15/A26 - Two USB
LT/RH/LoneStar - X15/A26 - Two USB Design 253
LT/RH/LoneStar - Vehicle Accessory Connector -
0008XMB
LT/RH/LoneStar - Vehicle Accessory Connector - 0008XMB Design 255
LT/RH/LoneStar - X15/A26 - Vehicle Sleep Mode
LT/RH/LoneStar - X15/A26 - Vehicle Sleep Mode Design 256
LT/RH/LoneStar - X15/A26 - DPF Regen Switch Only
LT/RH/LoneStar - X15/A26 - DPF Regen Switch Only Design 257
xiiLT/RH/LoneStar - X15/A26 - DPF With Monostable
Inhibit Switch
LT/RH/LoneStar - X15/A26 - DPF With Monostable Inhibit Switch Design 258
LT/RH/LoneStar - X15/A26 - DPF With/ Bi-Stable Inhibit
Switch
LT/RH/LoneStar - X15/A26 - DPF With/ Bi-Stable Inhibit Switch Design 259
LT/RH - A26 - Selective Catalytic Reduction (SCR)
LT/RH - A26 - Selective Catalytic Reduction (SCR) Design 260
LT/RH/LoneStar - 2017 X15 - Selective Catalytic
Reduction (SCR)
LT/RH/LoneStar - 2017 X15 - Selective Catalytic Reduction (SCR) Design 266
LT/RH/LoneStar - X15 - Selective Catalytic Reduction
(SCR)
LT/RH/LoneStar - X15 - Selective Catalytic Reduction (SCR) Design 272
LT/RH/LoneStar - X15/A26 - Adjustable Engine Speed
Control (PTO) 10-PIN ClockSpring
LT/RH/LoneStar - X15/A26 - Adjustable Engine Speed Control (PTO) 10-PIN
ClockSpring Design 277
Control (PTO) 4-pin Clockspring
LT/RH/LoneStar - X15/A26 - Adjustable Engine Speed Control (PTO) 4-pin
Clockspring Design 278
LoneStar - X15 - Body Builder Lighting - (BOC EOF In
Cab) (8HAB 8HAE 8HAU) (Automatic)
LoneStar - X15 - Body Builder Lighting - (BOC EOF In Cab) (8HAB 8HAE 8HAU)
(Automatic) Design 279
LT/RH - X15/A26 - Body Builder Lighting - (BOC EOF
In Cab) (8HAB 8HAE 8HAU) (Automatic)
LT/RH - X15/A26 - Body Builder Lighting - (BOC EOF In Cab) (8HAB 8HAE
8HAU) (Automatic) Design 281
LT/RH/LoneStar - X15/A26 - Body Builder Lighting -
(Blunt Cut)
LT/RH/LoneStar - X15/A26 - Body Builder Lighting - (Blunt Cut) Design 283
Cab) (8HAB 8HAE 8HAU) (Manual)
(Manual) Design 285
LT/RH - A26 - Body Builder Lighting - (BOC EOF In
LT/RH - A26 - Body Builder Lighting - (BOC EOF In Cab) (8HAB 8HAE 8HAU)
(Manual) Design 287
LT/RH - X15 - Body Builder Lighting - (BOC EOF In
LT/RH - X15 - Body Builder Lighting - (BOC EOF In Cab) (8HAB 8HAE 8HAU)
(Manual) Design 291
xiiiLT/RH A26 - Body Builder - Powertrain_MX1
LT/RH A26 - Body Builder - Powertrain_MX1 Design 293
LT/RH/LoneStar - X15/A26 - DLB - Remote Power
Module (2 RPM w/ Switch Packs)
LT/RH/LoneStar - X15/A26 - DLB - Remote Power Module (2 RPM w/ Switch
Packs) Design 294
LT/RH A26 - Transmission (TC10 Series A65 w/Body
Builder)
LT/RH A26 - Transmission (TC10 Series A65 w/Body Builder) Design 295
LT/RH/LoneStar X15 - Transmission (TC10 Series A65
w/Body Builder)
LT/RH/LoneStar X15 - Transmission (TC10 Series A65 w/Body Builder)
Design 296
LT/RH - A26 - Transmission Power Take Off Dual PTO
with Clutch Interlock
LT/RH - A26 - Transmission Power Take Off Dual PTO with Clutch Interlock
Design 297
Solenoid AUTO
LT/RH - A26 - Transmission Power Take Off Dual Solenoid AUTO Design 298
LT/RH - A26 - Transmission Power Take Off Option 1
LT/RH - A26 - Transmission Power Take Off Option 1 Design 299
LT/RH - A26 - Transmission Power Take Off Option 2
LT/RH - A26 - Transmission Power Take Off Option 2 Design 300
LT/RH - A26 - Transmission Power Take Off W/ Clutch
Interlock
LT/RH - A26 - Transmission Power Take Off W/ Clutch Interlock Design 301
LT/RH/LoneStar - X15 - Transmission Power Take Off
LT/RH/LoneStar - X15 - Transmission Power Take Off Design 302
Dual PTO with Clutch Interlock MANUAL
LT/RH/LoneStar - X15 - Transmission Power Take Off Dual PTO with Clutch
Interlock MANUAL Design 303
Dual Solenoid AUTO
LT/RH/LoneStar - X15 - Transmission Power Take Off Dual Solenoid AUTO
Design 304
W/ Clutch Interlock
LT/RH/LoneStar - X15 - Transmission Power Take Off W/ Clutch Interlock
Design 305
LT/RH/LoneStar - X15 - Transmission SINGLE Power
Take Off MANUAL
LT/RH/LoneStar - X15 - Transmission SINGLE Power Take Off MANUAL
Design 306
xivLT/RH/LoneStar - X15/A26 - Brake Switch
LT/RH/LoneStar - X15/A26 - Brake Switch Design 307
LT/RH/LoneStar - X15/A26 - Dual Air Dryers
LT/RH/LoneStar - X15/A26 - Dual Air Dryers Design 308
LT/RH/LoneStar - X15/A26 - Left Side Air Dryer-Bendix
LT/RH/LoneStar - X15/A26 - Left Side Air Dryer-Bendix Design 310
LT/RH/LoneStar - X15/A26 - Drain Valve Heater
LT/RH/LoneStar - X15/A26 - Drain Valve Heater Design 312
LoneStar - X15 - Antilock Brake System (ABS) [Bendix
6 Channel Implementation]
LoneStar - X15 - Antilock Brake System (ABS) [Bendix 6 Channel
Implementation] Design 313
LoneStar - X15 - Antilock Brake System (ABS)-BENDIX
4 Channel Implemenation
LoneStar - X15 - Antilock Brake System (ABS)-BENDIX 4 Channel Implemenation
Design 316
LT/RH - X15/A26 - Antilock Brake System (ABS)
LT/RH - X15/A26 - Antilock Brake System (ABS) BENDIX 4 Channel
Implemenation Design 320
Bendix 6 Channel Implementation
LT/RH - X15/A26 - Antilock Brake System (ABS) Bendix 6 Channel
Implementation Design 324
LoneStar - X15 - Antilock Brake System (ABS) -
Wabco 4 Channel Implementation
LoneStar - X15 - Antilock Brake System (ABS) - Wabco 4 Channel
Implementation Design 327
LoneStar - X15 - Antilock Brake System - Wabco ABS
LoneStar - X15 - Antilock Brake System - Wabco ABS 6 Channel Implementation
Design 331
LT/RH - X15/A26 - Antilock Brake System (ABS) -
LT/RH - X15/A26 - Antilock Brake System (ABS) - Wabco 4 Channel
Implementation Design 334
LT/RH - X15/A26 - Antilock Brake System - Wabco
LT/RH - X15/A26 - Antilock Brake System - Wabco ABS 6 Channel
Implementation Design 338
LT/RH - X15/A26 - Park Brake Control (Monitoring)
(W/Vehicle Speed)
LT/RH - X15/A26 - Park Brake Control (Monitoring) (W/Vehicle Speed) Design341
(Monitoring)(GEN IV BCM)
xvLT/RH - X15/A26 - Park Brake Control (Monitoring)(GEN IV BCM) Design 342
LT/RH/LoneStar - X15/A26 - Park Brake Controls (Non
Lever Park Brake)
LT/RH/LoneStar - X15/A26 - Park Brake Controls (Non Lever Park Brake)
Design 343
LT/RH/LoneStar - X15/A26 - Park Brake Controls (with
Alarm IGN ON/OFF)
LT/RH/LoneStar - X15/A26 - Park Brake Controls (with Alarm IGN ON/OFF)
Design 344
LT/RH/LoneStar - X15/A26 - Park Brake Reminder
(Non-Stationary) (CA2.0)
LT/RH/LoneStar - X15/A26 - Park Brake Reminder (Non-Stationary) (CA2.0)
Design 345
(Stationary) (CA2.0)
LT/RH/LoneStar - X15/A26 - Park Brake Reminder (Stationary) (CA2.0)
Design 346
LT/RH - X15/A26 - Bendix Stability Control For Tractor
or Tractors with Trailer Tow
LT/RH - X15/A26 - Bendix Stability Control For Tractor or Tractors with Trailer
Tow Design 347
LT/RH - X15/A26 - Bendix; Tractor or Towing Truck; W/
Air SUSP; J1939 Driven Lamp
LT/RH - X15/A26 - Bendix; Tractor or Towing Truck; W/ Air SUSP; J1939 Driven
Lamp Design 349
LT/RH - X15/A26 - Wabco Full Stability Control
LT/RH - X15/A26 - Wabco Full Stability Control Design 351
LT/RH/LoneStar - X15/A26 - Traction Control (Bendix
Controller)
LT/RH/LoneStar - X15/A26 - Traction Control (Bendix Controller) Design 353
Controller) With ABS Trailer
LT/RH/LoneStar - X15/A26 - Traction Control (Bendix Controller) With ABS Trailer
Design 355
LT/RH/LoneStar - X15/A26 - Traction Control (Wabco
Controller)
LT/RH/LoneStar - X15/A26 - Traction Control (Wabco Controller) Design 357
LT/RH - X15/A26 - Lane Keep Assist
LT/RH - X15/A26 - Lane Keep Assist Design 360
LT/RH - X15/A26 - Steering Hands Off Detection
LT/RH - X15/A26 - Steering Hands Off Detection Design 361
LT/RH - X15/A26 - Steering Performance
LT/RH - X15/A26 - Steering Performance Design 362
xviLT/RH/LoneStar - X15/A26 - Collision Avoidance
System (Warning)
LT/RH/LoneStar - X15/A26 - Collision Avoidance System (Warning) Design 363
LoneStar - X15 - Lane Departure Warning - (Bendix
Fusion W/Safety Direct))(US & Canada)
LoneStar - X15 - Lane Departure Warning - (Bendix Fusion W/Safety Direct))(US
& Canada) Design 364
Fusion W/Safety Direct))(US & Canada)-
& Canada)- Design 365
LT/RH - X15/A26 - Land Departure Warning - (Bendix -
AutoVue W/ Qualcomm Safety Direct)
LT/RH - X15/A26 - Land Departure Warning - (Bendix - AutoVue W/ Qualcomm
Safety Direct) Design 366
LT/RH - X15/A26 - Lane Departure Warning - Bendix
LT/RH - X15/A26 - Lane Departure Warning - Bendix Design 367
LT/RH - X15/A26 - Lane Departure Warning - (Bendix
LT/RH - X15/A26 - Lane Departure Warning - (Bendix Fusion W/Safety
Direct))(US & Canada) Design 368
LT/RH - X15/A26 - Lane Departure Warning - (Bendix -
AutoVue N/ Qualcomm Safety Direct)
LT/RH - X15/A26 - Lane Departure Warning - (Bendix - AutoVue N/ Qualcomm
Safety Direct) Design 369
LT/RH - X15/A26 - Lane Departure Warning (Mobileye
Per-Wire)
LT/RH - X15/A26 - Lane Departure Warning (Mobileye Per-Wire) Design 370
LT/RH - X15/A26 - Lane Departure Warning - (Wabco
OnLane 2.0 w/ roof speakers)
LT/RH - X15/A26 - Lane Departure Warning - (Wabco OnLane 2.0 w/ roof
speakers) Design 371
OnLane 2.0 w/ tweeter)
LT/RH - X15/A26 - Lane Departure Warning - (Wabco OnLane 2.0 w/ tweeter)
Design 372
OnLane)
LT/RH - X15/A26 - Lane Departure Warning - (Wabco OnLane) Design 373
LT/RH - X15 - Accelerator Interlock W/ Park Brake
Controls
LT/RH - X15 - Accelerator Interlock W/ Park Brake Controls Design 374
LT/RH/LoneStar - X15/A26 - Engine Brake (CA2.0; Mux
Switch)
LT/RH/LoneStar - X15/A26 - Engine Brake (CA2.0; Mux Switch) Design 375
xviiLT/RH/LoneStar - X15/A26 - Engine Brake (CA2.0;
Stalk Shifter)
LT/RH/LoneStar - X15/A26 - Engine Brake (CA2.0; Stalk Shifter) Design 376
LT/RH/LoneStar - X15/A26 - Engine/Exhaust Brake
LT/RH/LoneStar - X15/A26 - Engine/Exhaust Brake Design 377
LT/RH A26 - Coolant Level Monitoring
LT/RH A26 - Coolant Level Monitoring Design 378
LT/RH X15 - Coolant Level Monitoring
LT/RH X15 - Coolant Level Monitoring Design 379
LT/RH/LoneStar - X15 - Coolant Level Monitoring
LT/RH/LoneStar - X15 - Coolant Level Monitoring Design 380
LT/RH A26 - Cooling Fan Control Without Switch
LT/RH A26 - Cooling Fan Control Without Switch Design 381
LT/RH A26 - Cooling Fan Control With Switch
LT/RH A26 - Cooling Fan Control With Switch Design 382
LT/RH X15 - Cooling Fan Control (No Fan Override,
Cummins) (Early 2019)
LT/RH X15 - Cooling Fan Control (No Fan Override, Cummins) (Early 2019)
Design 383
LT/RH/LoneStar X15 - Cooling Fan Control (Fan
LT/RH/LoneStar X15 - Cooling Fan Control (Fan Override, Cummins) (Early
2019) Design 384
Cummins)
LT/RH X15 - Cooling Fan Control (No Fan Override, Cummins) Design 385
LT/RH/Lonestar X15 - Cooling Fan Control (Fan
Override, Cummins)
LT/RH/Lonestar X15 - Cooling Fan Control (Fan Override, Cummins) Design 386
LT/RH/LoneStar - X15/A26 - EGNR Diagnostic
Connector
LT/RH/LoneStar - X15/A26 - EGNR Diagnostic Connector Design 387
LT/RH/LoneStar - X15/A26 - Engine Diagnostic
Connector
LT/RH/LoneStar - X15/A26 - Engine Diagnostic Connector Design 388
LT/RH/LoneStar - X15/A26 - Engine Idle
Increment/Decrement (Steering Wheel Switch - 10 Pin)
LT/RH/LoneStar - X15/A26 - Engine Idle Increment/Decrement (Steering Wheel
Switch - 10 Pin) Design 389
Increment/Decrement (Steering Wheel Switch - 4 Pin)
Switch - 4 Pin) Design 390
xviiiLT/RH - X15/A26 - Engine Block Heater (Purchased
Assembly)
LT/RH - X15/A26 - Engine Block Heater (Purchased Assembly) Design 391
LT/RH - X15/A26 - Engine Fuel and Block Heaters
LT/RH - X15/A26 - Engine Fuel and Block Heaters (Purchased Assembly)
Design 392
LT/RH - X15/A26 - Engine Oil and Block Heaters
LT/RH - X15/A26 - Engine Oil and Block Heaters (Purchased Assembly)
Design 393
LT/RH - X15/A26 - Engine Oil, Fuel, and Block Heaters
LT/RH - X15/A26 - Engine Oil, Fuel, and Block Heaters (Purchased Assembly)
Design 394
LT/RH - A26 - Interface Connector
LT/RH - A26 - Interface Connector Design 395
LT/RH A26 - Starting Aid (Flame Start)
LT/RH A26 - Starting Aid (Flame Start) Design 396
LT/RH/LoneStar - X15 - Starting Aid (Ether Start)
LT/RH/LoneStar - X15 - Starting Aid (Ether Start) Design 397
LT/RH/LoneStar - A26 - Vehicle Acceleration (w/ Two
PWR Two GND & Two STS)
LT/RH/LoneStar - A26 - Vehicle Acceleration (w/ Two PWR Two GND & Two
STS) Design 398
LT/RH/LoneStar - X15 - Vehicle Acceleration (w/ Two
LT/RH/LoneStar - X15 - Vehicle Acceleration (w/ Two PWR Two GND & Two
STS) Design 399
LT/RH/LoneStar - X15/A26 - Vehicle Speed Limit
Override
LT/RH/LoneStar - X15/A26 - Vehicle Speed Limit Override Design 400
LT/RH/LoneStar - X15/A26 - Air Shield Lighting w/ One
Light
LT/RH/LoneStar - X15/A26 - Air Shield Lighting w/ One Light Design 401
LT/RH/LoneStar - X15/A26 - Automatic Lighting (Dual
Sensor Solar/Twilight)
LT/RH/LoneStar - X15/A26 - Automatic Lighting (Dual Sensor Solar/Twilight)
Design 403
(Single Sensor Twilight)
LT/RH/LoneStar - X15/A26 - Automatic Lighting (Single Sensor Twilight)
Design 404
xixLT/RH A26 - Backup Light (Dual Reverse Light)
Allison-TC10
LT/RH A26 - Backup Light (Dual Reverse Light) Allison-TC10 Design 405
LT/RH A26 - Backup Light (Reverse Light ) Allison
TC10
LT/RH A26 - Backup Light (Reverse Light ) Allison TC10 Design 407
LT/RH A26 - Backup Light (Single Reverse Light)
Allison TC10
LT/RH A26 - Backup Light (Single Reverse Light) Allison TC10 Design 409
W/Allison TC10
LT/RH A26 - Backup Light (Single Reverse Light) W/Allison TC10 Design 411
Allison-3K
LT/RH A26 - Backup Light (Dual Reverse Light) Allison-3K Design 413
LT/RH A26 - Backup Light (Reverse Light ) Allison-3K
LT/RH A26 - Backup Light (Reverse Light ) Allison-3K Design 415
Allison 3K
LT/RH A26 - Backup Light (Single Reverse Light) Allison 3K Design 417
W/Allison 3K
LT/RH A26 - Backup Light (Single Reverse Light) W/Allison 3K Design 419
LT/RH A26 - Backup Lights (Dual Reverse Light)
Eaton/Manual Trans
LT/RH A26 - Backup Lights (Dual Reverse Light) Eaton/Manual Trans Design 421
LT/RH A26 - Backup Lights (Reverse Lights)
Eaton/Manual Trans
LT/RH A26 - Backup Lights (Reverse Lights) Eaton/Manual Trans Design 425
LT/RH A26 - Backup Lights (Reverse Light)
Eaton/Manual Trans
LT/RH A26 - Backup Lights (Reverse Light) Eaton/Manual Trans Design 429
LT/RH A26 - Backup Lights (Single Reverse Light)
Eaton/Manual Trans
LT/RH A26 - Backup Lights (Single Reverse Light) Eaton/Manual Trans
Design 433
Eaton/Manual Trans/
LT/RH A26 - Backup Lights (Single Reverse Light) Eaton/Manual Trans/
Design 437
LT/RH A26 - Backup Light Endurant Trans
LT/RH A26 - Backup Light Endurant Trans Design 441
LT/RH A26 - Backup Light (Dual Reverse Light) Design 443
xxLT/RH A26 - Backup Light (Single Reverse Light)
LT/RH A26 - Backup Light (Single Reverse Light) Design 445
Endurant
LT/RH A26 - Backup Light (Single Reverse Light) Endurant Design 447
LT/RH X15 - Backup Light (Dual Reverse Light)
Allison-TC10
LT/RH X15 - Backup Light (Dual Reverse Light) Allison-TC10 Design 449
LT/RH X15 - Backup Light (Reverse Light ) Allison
TC10
LT/RH X15 - Backup Light (Reverse Light ) Allison TC10 Design 451
LT/RH X15 - Backup Light (Single Reverse Light)
Allison TC10
LT/RH X15 - Backup Light (Single Reverse Light) Allison TC10 Design 453
LT/RH/LoneStar X15 - Backup Light (Single Reverse
LT/RH/LoneStar X15 - Backup Light (Single Reverse Light) W/Allison TC10
Design 455
LT/RH X15 - Backup Lights (Dual Reverse Light)
Eaton/Manual Trans
LT/RH X15 - Backup Lights (Dual Reverse Light) Eaton/Manual Trans Design 457
LT/RH X15 - Backup Lights (Reverse Lights)
Eaton/Manual Trans
LT/RH X15 - Backup Lights (Reverse Lights) Eaton/Manual Trans Design 459
LT/RH X15 - Backup Lights (Reverse Light)
Eaton/Manual Trans
LT/RH X15 - Backup Lights (Reverse Light) Eaton/Manual Trans Design 461
LT/RH X15 - Backup Lights (Single Reverse Light)
Eaton/Manual Trans
LT/RH X15 - Backup Lights (Single Reverse Light) Eaton/Manual Trans
Design 463
LT/RH/LoneStar X15 - Backup Lights (Single Reverse
LT/RH/LoneStar X15 - Backup Lights (Single Reverse Light) Eaton/Manual Trans
Design 465
LT/RH X15 - Backup Light (Dual Reverse LT)
Procosion/Endurant
LT/RH X15 - Backup Light (Dual Reverse LT) Procosion/Endurant Design 467
Endurant
LT/RH X15 - Backup Light (Single Reverse Light) Endurant Design 469
LT/RH/LoneStar X15 - Backup Light Endurant
LT/RH/LoneStar X15 - Backup Light Endurant Design 471
xxiLT/RH/LoneStar X15 - Backup Light (Single Reverse
Light) Endurant
LT/RH/LoneStar X15 - Backup Light (Single Reverse Light) Endurant Design 473
LT/RH/LoneStar - X15/A26 - Beacon/Strobe Light
LT/RH/LoneStar - X15/A26 - Beacon/Strobe Light Design 475
LT/RH/LoneStar - X15/A26 - Clearance and
Identification Lights (W/ Sunshade)
LT/RH/LoneStar - X15/A26 - Clearance and Identification Lights (W/ Sunshade)
Design 477
LT/RH/LoneStar - X15/A26 - Daytime Running Lights
LT/RH/LoneStar - X15/A26 - Daytime Running Lights Design 478
LT/RH - X15/A26 - Directional Signal (Turn) With
HEADLIGHTS
LT/RH - X15/A26 - Directional Signal (Turn) With HEADLIGHTS Design 479
HEADLIGHTS (HAL-125)
LT/RH - X15/A26 - Directional Signal (Turn) With HEADLIGHTS (HAL-125)
Design 480
W/HEADLIGHTS
RH - X15/A26 - Directional Signal (Turn) W/HEADLIGHTS Design 481
HEADLIGHTS Option2
LT/RH - X15/A26 - Directional Signal (Turn) With HEADLIGHTS Option2
Design 482
HEADLIGHTS (LED-125)
LT/RH - X15/A26 - Directional Signal (Turn) With HEADLIGHTS (LED-125)
Design 483
LT/RH/LoneStar - X15/A26 - Exterior Lamp Check
LT/RH/LoneStar - X15/A26 - Exterior Lamp Check Design 484
LT/RH/LoneStar - X15/A26 - Exterior Lamp Reminder
LT/RH/LoneStar - X15/A26 - Exterior Lamp Reminder Design 485
LoneStar - X15/A26 - Front Fog Lamps
LoneStar - X15/A26 - Front Fog Lamps Design 486
LT/RH - X15/A26 - Fog Lights Lamps
LT/RH - X15/A26 - Fog Lights Lamps Design 487
LT/RH/LoneStar - X15/A26 - Hazard Warning (CA 2.0)
LT/RH/LoneStar - X15/A26 - Hazard Warning (CA 2.0) Design 488
LoneStar - X15 - Headlights Halogen N/INT N/LOWW
LoneStar - X15 - Headlights Halogen N/INT N/LOWW Design 489
LoneStar - X15 - Headlights Halogen N/INT W/LOWW
LoneStar - X15 - Headlights Halogen N/INT W/LOWW Design 490
xxiiLoneStar - X15 - Headlights Halogen W/INT N/LOWW
LoneStar - X15 - Headlights Halogen W/INT N/LOWW Design 491
LoneStar - X15 - Headlights Halogen W/INT W/LOWW
LoneStar - X15 - Headlights Halogen W/INT W/LOWW Design 492
LT - X15/A26 - Headlights Halogen N/INT N/LOWW
LT - X15/A26 - Headlights Halogen N/INT N/LOWW Design 493
LT - X15/A26 - Headlights Halogen N/INT W/LOWW
LT - X15/A26 - Headlights Halogen N/INT W/LOWW Design 494
LT - X15/A26 - Headlights Halogen W/INT N/LOWW
LT - X15/A26 - Headlights Halogen W/INT N/LOWW Design 495
LT - X15/A26 - Headlights Halogen W/INT W/LOWW
LT - X15/A26 - Headlights Halogen W/INT W/LOWW Design 496
LT - X15/A26 - Headlights LED N/ INT N/LOWW
LT - X15/A26 - Headlights LED N/ INT N/LOWW Design 497
LT - X15/A26 - Headlights LED N/ INT W/LOWW
LT - X15/A26 - Headlights LED N/ INT W/LOWW Design 498
LT - X15/A26 - Headlights LED W/INT N/LOWW
LT - X15/A26 - Headlights LED W/INT N/LOWW Design 499
LT - X15/A26 - Headlights LED W/INT W/LOWW
LT - X15/A26 - Headlights LED W/INT W/LOWW Design 500
RH - X15/A26 - Headlights Halogen N/INT N/LOWW
RH - X15/A26 - Headlights Halogen N/INT N/LOWW Design 501
RH - X15/A26 - Headlights Halogen N/INT W/LOWW
RH - X15/A26 - Headlights Halogen N/INT W/LOWW Design 502
RH - X15/A26 - Headlights Halogen W/INT N/LOWW
RH - X15/A26 - Headlights Halogen W/INT N/LOWW Design 503
RH - X15/A26 - Headlights Halogen W/INT W/LOWW
RH - X15/A26 - Headlights Halogen W/INT W/LOWW Design 504
RH - X15/A26 - Headlights LED N/INT N/LOWW LT
RH - X15/A26 - Headlights LED N/INT N/LOWW LT Design 505
RH - X15/A26 - Headlights LED N/INT W/LOWW LT
RH - X15/A26 - Headlights LED N/INT W/LOWW LT Design 506
RH - X15/A26 - Headlights LED W/INT N/LOWW LT
RH - X15/A26 - Headlights LED W/INT N/LOWW LT Design 507
RH - X15/A26 - Headlights LED W/INT W/LOWW LT
RH - X15/A26 - Headlights LED W/INT W/LOWW LT Design 508
LT/RH - X15/A26 - License Plate Light (Dual LED Lamp
Tail Light) Option 1
LT/RH - X15/A26 - License Plate Light (Dual LED Lamp Tail Light) Option 1
Design 509
xxiiiLT/RH - X15/A26 - License Plate Light (Dual LED Lamp
Tail Light) Option 2
LT/RH - X15/A26 - License Plate Light (Dual LED Lamp Tail Light) Option 2
Design 511
LT/RH - X15/A26 - License Plate Light (Tail Light
Single Assy.)Option 2
LT/RH - X15/A26 - License Plate Light (Tail Light Single Assy.)Option 2
Design 513
Single Assy.) Option 1
LT/RH - X15/A26 - License Plate Light (Tail Light Single Assy.) Option 1
Design 515
LT/RH/LoneStar - X15/A26 - License Plate Light (Tail
LT/RH/LoneStar - X15/A26 - License Plate Light (Tail Light Single Assy.) Option 1
Design 517
Light Single Assy.) Option 2
LT/RH/LoneStar - X15/A26 - License Plate Light (Tail Light Single Assy.) Option 2
Design 519
LoneStar - X15/A26 - Marker Lights (Halogen)
LoneStar - X15/A26 - Marker Lights (Halogen) Design 521
LT/RH - X15/A26 - Marker Lights (With 113 Halogen)
LT/RH - X15/A26 - Marker Lights (With 113 Halogen) Design 522
LT/RH - X15/A26 - Marker Lights (With 125 Halogen)
LT/RH - X15/A26 - Marker Lights (With 125 Halogen) Design 523
LT/RH - X15/A26 - Marker Lights (With113 LED)
LT/RH - X15/A26 - Marker Lights (With113 LED) Design 524
LT/RH - X15/A26 - Marker Lights (With 125 LED)
LT/RH - X15/A26 - Marker Lights (With 125 LED) Design 525
LT/RH/LoneStar - X15/A26 - MARKER/PARK LIGHTS -
W/Marker Interrupt 10pin CLCKSPRING
LT/RH/LoneStar - X15/A26 - MARKER/PARK LIGHTS - W/Marker Interrupt 10pin
CLCKSPRING Design 526
LT/RH/LoneStar - X15/A26 - PARK LIGHTS - W/Marker
Interrupt 4 pin clockspring
LT/RH/LoneStar - X15/A26 - PARK LIGHTS - W/Marker Interrupt 4 pin
clockspring Design 527
LoneStar - X15 - Modesty Lighting W/ Day Cab W/ 2
Turn /0 Marker
LoneStar - X15 - Modesty Lighting W/ Day Cab W/ 2 Turn /0 Marker Design 528
LoneStar - X15 - Modesty Lighting W/ Sleeper W/ 4
Side Turns / 0 Marker
LoneStar - X15 - Modesty Lighting W/ Sleeper W/ 4 Side Turns / 0 Marker
Design 529
xxivLT/RH - X15/A26 - Modesty Lighting W/ Day Cab W/ 2
Turn /0 Marker
LT/RH - X15/A26 - Modesty Lighting W/ Day Cab W/ 2 Turn /0 Marker Design 530
LT/RH - X15/A26 - Modesty Lighting W/ Sleeper W/ 4
LT/RH - X15/A26 - Modesty Lighting W/ Sleeper W/ 4 Side Turns / 0 Marker
Design 531
LT/RH - X15/A26 - Panic Switch (Sleeper)
LT/RH - X15/A26 - Panic Switch (Sleeper) Design 532
LT/RH - X15/A26 - Skirt Light Customer Supplied
LT/RH - X15/A26 - Skirt Light Customer Supplied Design 533
LT/RH/LoneStar - X15/A26 - Rear Lights Stop - Dual
Assembly
LT/RH/LoneStar - X15/A26 - Rear Lights Stop - Dual Assembly Design 534
LT/RH/LoneStar - X15/A26 - Rear Lights Stop - Single
Assembly Option 1
LT/RH/LoneStar - X15/A26 - Rear Lights Stop - Single Assembly Option 1
Design 536
Assembly Option 2
LT/RH/LoneStar - X15/A26 - Rear Lights Stop - Single Assembly Option 2
Design 538
LT/RH/LoneStar - X15/A26 - Work Lights W/ Sw Pack -
Customer Supplied W/O RKE W/AUTO REV
LT/RH/LoneStar - X15/A26 - Work Lights W/ Sw Pack - Customer Supplied W/O
RKE W/AUTO REV Design 540
Customer Supplied W/ RKE W/AUTO REV
RKE W/AUTO REV Design 542
LT/RH - A26 - Work Lights W/ Sw Pack - Customer
Supplied W/O RKE W/MAN REV
LT/RH - A26 - Work Lights W/ Sw Pack - Customer Supplied W/O RKE W/MAN
REV Design 544
Supplied W/ RKE W/MAN REV
LT/RH - A26 - Work Lights W/ Sw Pack - Customer Supplied W/ RKE W/MAN
REV Design 548
LT/RH/LoneStar X15 - Work Lights LED W/ Sw Pack -
Day Cab W/O RKE W/MAN REV
LT/RH/LoneStar X15 - Work Lights LED W/ Sw Pack - Day Cab W/O RKE
W/MAN REV Design 552
LT/RH - X15/A26 - Work Lights W/ Sw Pack - Customer
Supplied
LT/RH - X15/A26 - Work Lights W/ Sw Pack - Customer Supplied Design 553
xxvLT/RH/LoneStar - X15 - Work Lights W/ Sw Pack -
Customer Supplied W/O RKE W/MAN REV
LT/RH/LoneStar - X15 - Work Lights W/ Sw Pack - Customer Supplied W/O RKE
W/MAN REV Design 555
Customer Supplied W/ RKE W/MAN REV
LT/RH/LoneStar - X15 - Work Lights W/ Sw Pack - Customer Supplied W/ RKE
W/MAN REV Design 557
Customer Supplied
Design 559
LT/RH/LoneStar - X15/A26 - Work Lights - LED W/ Sw
Pack - Customer Supplied - Sleeper W/O RKE W/AUTO
REV
LT/RH/LoneStar - X15/A26 - Work Lights - LED W/ Sw Pack - Customer Supplied
- Sleeper W/O RKE W/AUTO REV Design 561
Pack - Customer Supplied - Sleeper W/ RKE W/AUTO
REV
- Sleeper W/ RKE W/AUTO REV Design 563
LT/RH - A26 - Work Lights - LED W/ Sw Pack -
Customer Supplied - Sleeper W/O RKE W/MAN REV
LT/RH - A26 - Work Lights - LED W/ Sw Pack - Customer Supplied - Sleeper W/O
RKE W/MAN REV Design 565
Customer Supplied - Sleeper W/ RKE W/MAN REV
RKE W/MAN REV Design 569
LT/RH/LoneStar - X15 - Work Lights - LED W/ Sw Pack
- Customer Supplied - Sleeper W/O RKE W/MAN REV
LT/RH/LoneStar - X15 - Work Lights - LED W/ Sw Pack - Customer Supplied -
Sleeper W/O RKE W/MAN REV Design 573
- Customer Supplied - Sleeper W/ RKE W/MAN REV
Sleeper W/ RKE W/MAN REV Design 575
W/Endurant (Schneider)
- Sleeper W/O RKE W/Endurant (Schneider) Design 577
- Sleeper Design 579
xxviLT/RH/LoneStar - X15/A26 - Work Lights - LED W/ Sw
- Sleeper W/O RKE Design 581
LT/RH/LoneStar - X15/A26 - Work Lights LED W/ Sw
Pack - Day Cab W/O RKE W/AUTO REV
LT/RH/LoneStar - X15/A26 - Work Lights LED W/ Sw Pack - Day Cab W/O RKE
W/AUTO REV Design 583
Pack - Day Cab W/ RKE W/AUTO REV
LT/RH/LoneStar - X15/A26 - Work Lights LED W/ Sw Pack - Day Cab W/ RKE
W/AUTO REV Design 584
LT/RH/LoneStar - X15/A26 - Work Lights (2 Blunt Cuts
Only W/O Relay) W/Backup W/Auto Trans (Allison and
Endurant)
LT/RH/LoneStar - X15/A26 - Work Lights (2 Blunt Cuts Only W/O Relay)
W/Backup W/Auto Trans (Allison and Endurant) Design 585
LT/RH - A26 - Work Lights LED W/ Sw Pack - Day Cab
W/O RKE W/MAN REV
LT/RH - A26 - Work Lights LED W/ Sw Pack - Day Cab W/O RKE W/MAN REV
Design 587
W/ RKE W/MAN REV
LT/RH - A26 - Work Lights LED W/ Sw Pack - Day Cab W/ RKE W/MAN REV
Design 589
LT/RH - A26 - Work Lights (2 Blunt Cuts Only W/O
Relay) W/Backup W/Manual Trans Day Cab
LT/RH - A26 - Work Lights (2 Blunt Cuts Only W/O Relay) W/Backup W/Manual
Trans Day Cab Design 591
LT/RH/LoneStar - X15 - Work Lights (2 Blunt Cuts Only
W/O Relay) W/Backup W/Manual Trans
LT/RH/LoneStar - X15 - Work Lights (2 Blunt Cuts Only W/O Relay) W/Backup
W/Manual Trans Design 595
LT/RH/LoneStar X15 - Work Lights LED W/ Sw Pack - Day Cab W/ RKE W/MAN
REV Design 597
Pack - Day Cab
LT/RH/LoneStar - X15/A26 - Work Lights LED W/ Sw Pack - Day Cab Design 598
Design 599
Only W/O Relay)
xxviiLT/RH/LoneStar - X15/A26 - Work Lights (2 Blunt Cuts Only W/O Relay)
Design 600
LT/RH/LoneStar - X15/A26 - Work Lights -LED W/ Sw
Pack - Sleeper W/O RKE W/AUTO REV
LT/RH/LoneStar - X15/A26 - Work Lights -LED W/ Sw Pack - Sleeper W/O RKE
W/AUTO REV Design 602
Pack - Sleeper W/ RKE W/AUTO REV
LT/RH/LoneStar - X15/A26 - Work Lights -LED W/ Sw Pack - Sleeper W/ RKE
W/AUTO REV Design 603
LT/RH - A26 - Work Lights -LED W/ Sw Pack - Sleeper
W/O RKE W/MAN REV
LT/RH - A26 - Work Lights -LED W/ Sw Pack - Sleeper W/O RKE W/MAN REV
Design 604
W/ RKE W/MAN REV
LT/RH - A26 - Work Lights -LED W/ Sw Pack - Sleeper W/ RKE W/MAN REV
Design 606
LT/RH/LoneStar - X15 - Work Lights -LED W/ Sw Pack
LT/RH/LoneStar - X15 - Work Lights -LED W/ Sw Pack - Sleeper W/O RKE
W/MAN REV Design 608
LT/RH/LoneStar - X15 - Work Lights -LED W/ Sw Pack - Sleeper W/ RKE W/MAN
REV Design 609
Pack - Sleeper
LT/RH/LoneStar - X15/A26 - Work Lights -LED W/ Sw Pack - Sleeper Design 610
Design 611
LT/RH/LoneStar - X15/A26 - Fifth Wheel Slide
LT/RH/LoneStar - X15/A26 - Fifth Wheel Slide Design 612
LT/RH/LoneStar - X15/A26 - Jaw Monitoring
LT/RH/LoneStar - X15/A26 - Jaw Monitoring Design 613
LT/RH/LoneStar - X15/A26 - Jaw Unlock Control W/
SOLENOIDS W/SWITCH PACKS
LT/RH/LoneStar - X15/A26 - Jaw Unlock Control W/ SOLENOIDS W/SWITCH
PACKS Design 614
(Standard)
LT/RH/LoneStar - X15/A26 - Jaw Unlock Control (Standard) Design 615
xxviiiLoneStar - X15 - Fuel Heater (Vehicle Powered)
(Davco)
LoneStar - X15 - Fuel Heater (Vehicle Powered) (Davco) Design 616
LT/RH - X15/A26 - Fuel Heater (Vehicle Powered)
(Davco)
LT/RH - X15/A26 - Fuel Heater (Vehicle Powered) (Davco) Design 617
(RAVCOR)
LT/RH - X15/A26 - Fuel Heater (Vehicle Powered) (RAVCOR) Design 619
LT/RH/LoneStar - X15/A26 - Fuel Heater (120VAC)
LT/RH/LoneStar - X15/A26 - Fuel Heater (120VAC) Design 620
LT/RH/LoneStar - X15/A26 - Fuel Level (Single Tank -
Left Side)
LT/RH/LoneStar - X15/A26 - Fuel Level (Single Tank - Left Side) Design 621
LT/RH - A26 - Water In Fuel (WIF) DAVCO N/ Heater
LT/RH - A26 - Water In Fuel (WIF) DAVCO N/ Heater Design 627
LT/RH - A26 - Water In Fuel (WIF) Davco W/Heater
LT/RH - A26 - Water In Fuel (WIF) Davco W/Heater Design 629
LT/RH - A26 - Water In Fuel (WIF) RACOR N/ Heater
LT/RH - A26 - Water In Fuel (WIF) RACOR N/ Heater Design 631
LT/RH/LoneStar - X15 - Water In Fuel (WIF) DAVCO N/
Heater
LT/RH/LoneStar - X15 - Water In Fuel (WIF) DAVCO N/ Heater Design 632
LT/RH/LoneStar - X15 - Water In Fuel (WIF) DAVCO W/
Heater
LT/RH/LoneStar - X15 - Water In Fuel (WIF) DAVCO W/ Heater Design 634
LT/RH/LoneStar - X15 - Water In Fuel (WIF) RACOR N/
Heater
LT/RH/LoneStar - X15 - Water In Fuel (WIF) RACOR N/ Heater Design 636
LT/RH A26 - Heating Ventilation & Air Conditioning
(HVAC) Auto Temp Control
LT/RH A26 - Heating Ventilation & Air Conditioning (HVAC) Auto Temp Control
Design 637
LT/RH - A26 - Heating Ventilation & Air Conditioning
(HVAC) Manual
LT/RH - A26 - Heating Ventilation & Air Conditioning (HVAC) Manual Design 643
LT/RH/LoneStar X15 - Heating Ventilation & Air
LT/RH/LoneStar X15 - Heating Ventilation & Air Conditioning (HVAC) Auto Temp
Control Design 647
xxixLT/RH/LoneStar X15 - Heating Ventilation & Air Conditioning (HVAC) Manual
Design 650
LT/RH/LoneStar - X15/A26 - Rear AUTO HVAC (No
Idle) W/ Pre-Heat (Bergstrom Heat and Cool w/
Condensation) 2 SWITCHES
LT/RH/LoneStar - X15/A26 - Rear AUTO HVAC (No Idle) W/ Pre-Heat (Bergstrom
Heat and Cool w/ Condensation) 2 SWITCHES Design 652
LT/RH/LoneStar - X15/A26 - Rear HVAC (No Idle) W/
Pre-Heat (Bergstrom Heat and Cool w/ Condensation)
2 SWITCHES Option 1
LT/RH/LoneStar - X15/A26 - Rear HVAC (No Idle) W/ Pre-Heat (Bergstrom Heat
and Cool w/ Condensation) 2 SWITCHES Option 1 Design 655
2 SWITCHES Option 2
and Cool w/ Condensation) 2 SWITCHES Option 2 Design 657
4 SWITCHES Option 1
and Cool w/ Condensation) 4 SWITCHES Option 1 Design 659
4 SWITCHES Option 2
and Cool w/ Condensation) 4 SWITCHES Option 2 Design 661
LT/RH/LoneStar - X15/A26 - Rear Manual HVAC (No
LT/RH/LoneStar - X15/A26 - Rear Manual HVAC (No Idle) W/ Pre-Heat
(Bergstrom Heat and Cool w/ Condensation) 2 SWITCHES Design 663
Heater) (Espar) Option 1
LT/RH/LoneStar - X15/A26 - Rear HVAC (No Idle Heater) (Espar) Option 1
Design 666
Heater) (Espar) Option 2
LT/RH/LoneStar - X15/A26 - Rear HVAC (No Idle Heater) (Espar) Option 2
Design 667
LT/RH/LoneStar A26/X15 - No-Idle HVAC (Espar
Airtronic, Berstrom AC, Front Auto Control head)
LT/RH/LoneStar A26/X15 - No-Idle HVAC (Espar Airtronic, Berstrom AC, Front
Auto Control head) Design 668
Airtronic, Berstrom AC, Front Manual Control head
xxxLT/RH/LoneStar A26/X15 - No-Idle HVAC (Espar Airtronic, Berstrom AC, Front
Manual Control head Design 671
Heater) (Webasto Smartemp)
LT/RH/LoneStar - X15/A26 - Rear HVAC (No Idle Heater) (Webasto Smartemp)
Design 674
Heater) (Webasto Std N/Swift) N/ Heat Swtich
LT/RH/LoneStar - X15/A26 - Rear HVAC (No Idle Heater) (Webasto Std N/Swift)
N/ Heat Swtich Design 675
Heater) (Webasto Std W/Swift) N/ Heat Switch
LT/RH/LoneStar - X15/A26 - Rear HVAC (No Idle Heater) (Webasto Std W/Swift)
N/ Heat Switch Design 676
LT/RH/LoneStar - X15/A26 - No Idle HVAC - TRI-PAC
Prewire
LT/RH/LoneStar - X15/A26 - No Idle HVAC - TRI-PAC Prewire Design 677
LT/RH/LoneStar - X15/A26 - Rear HVAC (Sleeper W/
Deluxe)
LT/RH/LoneStar - X15/A26 - Rear HVAC (Sleeper W/ Deluxe) Design 678
Premium)
LT/RH/LoneStar - X15/A26 - Rear HVAC (Sleeper W/ Premium) Design 680
LT/RH - A26 - Air Flow Restriction Monitoring A26
LT/RH - A26 - Air Flow Restriction Monitoring A26 Design 682
LT/RH/LoneStar - X15 - Air Flow Restriction
Monitoring
LT/RH/LoneStar - X15 - Air Flow Restriction Monitoring Design 684
LT/RH A26 - Ambient Air Temperature Option 1
LT/RH A26 - Ambient Air Temperature Option 1 Design 685
LT/RH A26 - Ambient Air Temperature Option 2
LT/RH A26 - Ambient Air Temperature Option 2 Design 686
LT/RH/LoneStar X15 - Ambient Air Temperature
Option 1
LT/RH/LoneStar X15 - Ambient Air Temperature Option 1 Design 687
Option 2
LT/RH/LoneStar X15 - Ambient Air Temperature Option 2 Design 688
LT/RH/LoneStar - X15/A26 - Auxilary Gauges
(Secondary)
LT/RH/LoneStar - X15/A26 - Auxilary Gauges (Secondary) Design 689
LT/RH/LoneStar - X15/A26 - Auxiliary Gauges
(Primary)
LT/RH/LoneStar - X15/A26 - Auxiliary Gauges (Primary) Design 690
xxxiLT/RH/LoneStar - X15/A26 - Brake Pressure (Auxiliary
Gauge)
LT/RH/LoneStar - X15/A26 - Brake Pressure (Auxiliary Gauge) Design 691
LT/RH/LoneStar - X15/A26 - Brake Pressure (Virtual
Gauge)
LT/RH/LoneStar - X15/A26 - Brake Pressure (Virtual Gauge) Design 692
LT/RH/LoneStar - X15/A26 - Compressed Air Supply
(Primary and Secondary Gauge)
LT/RH/LoneStar - X15/A26 - Compressed Air Supply (Primary and Secondary
Gauge) Design 693
LT/RH - A26 - DEF Economy Monitor (Cluster)
LT/RH - A26 - DEF Economy Monitor (Cluster) Design 694
LT/RH/LoneStar - X15 - DEF Economy Monitor (GEN IV
Cluster w/ Cummins ENG)
LT/RH/LoneStar - X15 - DEF Economy Monitor (GEN IV Cluster w/ Cummins
ENG) Design 695
LT/RH/LoneStar - X15/A26 - Engine Usage Monitoring
(Base)
LT/RH/LoneStar - X15/A26 - Engine Usage Monitoring (Base) Design 696
(VID Option)
LT/RH/LoneStar - X15/A26 - Engine Usage Monitoring (VID Option) Design 697
LT/RH - X15/A26 - Engine Oil Level Monitoring (CA2.0)
LT/RH - X15/A26 - Engine Oil Level Monitoring (CA2.0) Design 698
LT/RH/LoneStar - X15/A26 - Engine Oil Pressure
LT/RH/LoneStar - X15/A26 - Engine Oil Pressure Design 699
LT/RH/LoneStar - X15/A26 - Engine Oil Temperature
(NA MUX_AUX Gauge)
LT/RH/LoneStar - X15/A26 - Engine Oil Temperature (NA MUX_AUX Gauge)
Design 700
(NA-Mux)
LT/RH/LoneStar - X15/A26 - Engine Oil Temperature (NA-Mux) Design 701
LT/RH/LoneStar - X15/A26 - Engine Speed
(Tachometer_J1939)
LT/RH/LoneStar - X15/A26 - Engine Speed (Tachometer_J1939) Design 702
LT/RH/LoneStar - X15/A26 - Fuel Economy Monitor
LT/RH/LoneStar - X15/A26 - Fuel Economy Monitor Design 703
LT/RH/LoneStar - X15/A26 - Intake Manifold Pressure
LT/RH/LoneStar - X15/A26 - Intake Manifold Pressure Design 704
LT/RH - X15/A26 - Intake Manifold Pressure AUX
gauge
LT/RH - X15/A26 - Intake Manifold Pressure AUX gauge Design 705
xxxiiLT/RH/LoneStar - X15/A26 - Odometer (Cluster)
LT/RH/LoneStar - X15/A26 - Odometer (Cluster) Design 706
LT/RH/LoneStar - X15/A26 - Trip Odometer (Cluster)
LT/RH/LoneStar - X15/A26 - Trip Odometer (Cluster) Design 707
LT/RH/LoneStar - X15/A26 - Transmission Oil Level
(Low Level Warning)
LT/RH/LoneStar - X15/A26 - Transmission Oil Level (Low Level Warning)
Design 708
LT/RH - A26 - Transmission Oil Temperature-Manual
Trans-Horizon Option 1
LT/RH - A26 - Transmission Oil Temperature-Manual Trans-Horizon Option 1
Design 709
Trans-Horizon Option 2
LT/RH - A26 - Transmission Oil Temperature-Manual Trans-Horizon Option 2
Design 712
LT/RH/LoneStar - X15 - Transmission Oil TemperatureManual Trans-Horizon Option 1
LT/RH/LoneStar - X15 - Transmission Oil Temperature-Manual Trans-Horizon
Option 1 Design 715
LT/RH/LoneStar - X15 - Transmission Oil TemperatureManual Trans-Horizon Option 2
Option 2 Design 718
Temperature (Automatic Trans W/ Aux Gauge)
LT/RH/LoneStar - X15/A26 - Transmission Oil Temperature (Automatic Trans W/
Aux Gauge) Design 721
Temperature (Automatic Trans)
LT/RH/LoneStar - X15/A26 - Transmission Oil Temperature (Automatic Trans)
Design 722
LT/RH - A26 - VEHICLE SPEEDOMETER SYSTEM
(MANUAL XMSN)
LT/RH - A26 - VEHICLE SPEEDOMETER SYSTEM (MANUAL XMSN)
Design 723
LT/RH/LoneStar - X15 - Vehicle Speedometer System
(Manual XMSN) ISX
LT/RH/LoneStar - X15 - Vehicle Speedometer System (Manual XMSN) ISX
Design 725
LT/RH/LoneStar - X15/A26 - Vehicle Speedometer
System (W/AMT/AUTO TRANS)
LT/RH/LoneStar - X15/A26 - Vehicle Speedometer System (W/AMT/AUTO
TRANS) Design 726
xxxiiiLT/RH/LoneStar - X15/A26 - Voltage Monitoring
(Voltmeter) Option 1
LT/RH/LoneStar - X15/A26 - Voltage Monitoring (Voltmeter) Option 1 Design 727
(Voltmeter) Option 2
LT/RH/LoneStar - X15/A26 - Voltage Monitoring (Voltmeter) Option 2 Design 728
(Voltmeter) (with Aux gauge)
LT/RH/LoneStar - X15/A26 - Voltage Monitoring (Voltmeter) (with Aux gauge)
Design 729
Tire Pressure Monitoring (TPMS)(LDL Technology)
Tire Pressure Monitoring (TPMS)(LDL Technology) Design 730
LT/RH/LoneStar - X15/A26 - Engine Warning (DM1
LAMPS - MUX)
LT/RH/LoneStar - X15/A26 - Engine Warning (DM1 LAMPS - MUX) Design 733
LT/RH/LoneStar - X15/A26 - High Exhaust System
Temperature (HEST) Monitoring
LT/RH/LoneStar - X15/A26 - High Exhaust System Temperature (HEST)
Monitoring Design 734
LT/RH/LoneStar - X15/A26 - Coolant Temperature
Monitoring (J1939 Comm)
LT/RH/LoneStar - X15/A26 - Coolant Temperature Monitoring (J1939 Comm)
Design 735
LT/RH A26 - X15/A26 - Up Shift Indicator (CA 2.0)
LT/RH A26 - X15/A26 - Up Shift Indicator (CA 2.0) Design 736
LT/RH/LoneStar - X15/A26 - Transmission Range
Inhibit (J1939 Comm)
LT/RH/LoneStar - X15/A26 - Transmission Range Inhibit (J1939 Comm)
Design 737
LT/RH/LoneStar - X15/A26 - Vehicle Information
Display (VID-W/BT)
LT/RH/LoneStar - X15/A26 - Vehicle Information Display (VID-W/BT) Design 738
Display (VID-W/O BT)
LT/RH/LoneStar - X15/A26 - Vehicle Information Display (VID-W/O BT)
Design 739
LT/RH/LoneStar - X15/A26 - Lighting - Cabinet Lights
LT/RH/LoneStar - X15/A26 - Lighting - Cabinet Lights Design 740
LT/RH/LoneStar - X15/A26 - Courtesy Light Cab
LT/RH/LoneStar - X15/A26 - Courtesy Light Cab Design 741
LT/RH/LoneStar - X15/A26 - Cab Dome Light (Day Cab)
LT/RH/LoneStar - X15/A26 - Cab Dome Light (Day Cab) Design 742
LT/RH/LoneStar - X15/A26 - Cab Dome Light - (Sleeper
Cab)
LT/RH/LoneStar - X15/A26 - Cab Dome Light - (Sleeper Cab) Design 743
xxxivLT/RH/LoneStar - X15/A26 - Lighting Sleeper Dome
LT/RH/LoneStar - X15/A26 - Lighting Sleeper Dome Design 744
LT/RH/LoneStar - X15/A26 - Floor/Search Lights
DayCab
LT/RH/LoneStar - X15/A26 - Floor/Search Lights DayCab Design 745
Sleeper
LT/RH/LoneStar - X15/A26 - Floor/Search Lights Sleeper Design 746
Sleeper (1 Light)
LT/RH/LoneStar - X15/A26 - Floor/Search Lights Sleeper (1 Light) Design 747
LT/RH/LoneStar - X15/A26 - Interior Task Lights (Map)
(Cab Dome / Map Combo) - DayCab
LT/RH/LoneStar - X15/A26 - Interior Task Lights (Map) (Cab Dome / Map Combo)
- DayCab Design 748
Light-Separate map light from cab dome) - Sleeper
LT/RH/LoneStar - X15/A26 - Interior Task Lights (Map Light-Separate map light
from cab dome) - Sleeper Cab Design 749
LT/RH/LoneStar - X15/A26 - Luggage Compartment
Lights - W/O No Idle HVAC
LT/RH/LoneStar - X15/A26 - Luggage Compartment Lights - W/O No Idle HVAC
Design 750
Lights - W/ No Idle HVAC
LT/RH/LoneStar - X15/A26 - Luggage Compartment Lights - W/ No Idle HVAC
Design 751
LT/RH/LoneStar - X15/A26 - Panel Backlighting (Cabin
Dimmer) Option 1
LT/RH/LoneStar - X15/A26 - Panel Backlighting (Cabin Dimmer) Option 1
Design 752
Dimmer) Option 2
LT/RH/LoneStar - X15/A26 - Panel Backlighting (Cabin Dimmer) Option 2
Design 753
LT/RH/LoneStar - X15/A26 - Reading Lighting -
W/Lower
LT/RH/LoneStar - X15/A26 - Reading Lighting - W/Lower Design 754
W/Upper& Lower
LT/RH/LoneStar - X15/A26 - Reading Lighting - W/Upper& Lower Design 755
LT/RH/LoneStar - X15/A26 - Rear Interior Dimming
(Accent Light)
LT/RH/LoneStar - X15/A26 - Rear Interior Dimming (Accent Light) Design 756
xxxvLT/RH/LoneStar - X15/A26 - Rear Interior Dimming
(Accent/Mood)
LT/RH/LoneStar - X15/A26 - Rear Interior Dimming (Accent/Mood) Design 757
LT/RH/LoneStar - X15/A26 - Axle Loading (Weight)
Rear
LT/RH/LoneStar - X15/A26 - Axle Loading (Weight) Rear Design 758
LT/RH/LoneStar - X15/A26 - Single Axle Temperature
Monitoring
LT/RH/LoneStar - X15/A26 - Single Axle Temperature Monitoring Design 760
Monitoring w/Aux Gauge
LT/RH/LoneStar - X15/A26 - Single Axle Temperature Monitoring w/Aux Gauge
Design 761
LT/RH/LoneStar - X15/A26 - Tandem Axle Temperature
Monitoring
LT/RH/LoneStar - X15/A26 - Tandem Axle Temperature Monitoring Design 762
LT/RH/LoneStar - X15/A26 - Tandem Axle Temperature Monitoring w/Aux Gauge
Design 764
Monitoring w/ Single SNSR and AUX Gauge
LT/RH/LoneStar - X15/A26 - Tandem Axle Temperature Monitoring w/ Single
SNSR and AUX Gauge Design 766
LT/RH/LoneStar - X15/A26 - Driver Controlled Locking
Differential - FR & RR Axle (DANA)
LT/RH/LoneStar - X15/A26 - Driver Controlled Locking Differential - FR & RR Axle
(DANA) Design 767
LT/RH/LoneStar - X15/A26 - 2 Driver Controlled
Locking Differential - FR & RR Axle (DANA)
LT/RH/LoneStar - X15/A26 - 2 Driver Controlled Locking Differential - FR & RR
Axle (DANA) Design 768
Differential - RR Axle (DANA)
LT/RH/LoneStar - X15/A26 - Driver Controlled Locking Differential - RR Axle
(DANA) Design 769
Differential - FR (MERITOR)
(MERITOR) Design 771
Differential - FR & RR Axle (MERITOR)
(MERITOR) Design 772
xxxviLT/RH/LoneStar - X15/A26 - 2 Driver Controlled
Locking Differential - FR & RR Axle (MERITOR)
Axle (MERITOR) Design 773
Differential - RR Axle (MERITOR)
(MERITOR) Design 774
LT/RH/LoneStar - X15/A26 - Height Control
LT/RH/LoneStar - X15/A26 - Height Control Design 776
LT/RH/LoneStar - X15/A26 - Power Divider Lock
Control and Monitoring
LT/RH/LoneStar - X15/A26 - Power Divider Lock Control and Monitoring
Design 777
LT/RH/LoneStar - X15/A26 - Seats Climate Controlled
(Drivers Heated Seat)
LT/RH/LoneStar - X15/A26 - Seats Climate Controlled (Drivers Heated Seat)
Design 778
LT/RH/LoneStar - X15/A26 - Seats (RollTek) Driver and
Passenger (Hard Wired)
LT/RH/LoneStar - X15/A26 - Seats (RollTek) Driver and Passenger (Hard Wired)
Design 779
LT/RH/LoneStar - X15/A26 - Seats (RolTek) Drivers
Seat Only (Hard Wired) - Leather
LT/RH/LoneStar - X15/A26 - Seats (RolTek) Drivers Seat Only (Hard Wired) -
Leather Design 780
Seat Only (Hard Wired) - Mordura
Mordura Design 781
Seat Only (Hard Wired) - Vinyl
Vinyl Design 782
LT/RH/LoneStar - X15/A26 - Seatbelt Reminder
(Warning)(Driver only)
LT/RH/LoneStar - X15/A26 - Seatbelt Reminder (Warning)(Driver only) Design783
(Warning)(Driver & Passenger in parallel)
LT/RH/LoneStar - X15/A26 - Seatbelt Reminder (Warning)(Driver & Passenger in
parallel) Design 784
LT/RH/LoneStar - X15/A26 - Auxiliary Trailer Power
CAV D
LT/RH/LoneStar - X15/A26 - Auxiliary Trailer Power CAV D Design 785
xxxviiLT/RH/LoneStar - X15/A26 - Auxiliary Trailer Power W/
ISO Trailer Socket
LT/RH/LoneStar - X15/A26 - Auxiliary Trailer Power W/ ISO Trailer Socket
Design 787
LT/RH/LoneStar - X15/A26 - Mobile Communications
Sensor Wiring Effects for Trailer TRAC
LT/RH/LoneStar - X15/A26 - Mobile Communications Sensor Wiring Effects for
Trailer TRAC Design 788
LoneStar - X15 - Trailer Interface (ABS) - Center Pin
Circuit
LoneStar - X15 - Trailer Interface (ABS) - Center Pin Circuit Design 790
LT/RH - X15/A26 - Trailer Interface (ABS) - Center Pin
Circuit
LT/RH - X15/A26 - Trailer Interface (ABS) - Center Pin Circuit Design 794
LT/RH/LoneStar - X15/A26 - Trailer Interface (ABS) -
BOC & EOF_NA
LT/RH/LoneStar - X15/A26 - Trailer Interface (ABS) - BOC & EOF_NA Design 798
BOC_NA
LT/RH/LoneStar - X15/A26 - Trailer Interface (ABS) - BOC_NA Design 802
TRAMEC_NA
LT/RH/LoneStar - X15/A26 - Trailer Interface (ABS) - TRAMEC_NA Design 804
LT/RH/LoneStar - X15/A26 - Trailer Interface (Lighting)
– BOC NA
LT/RH/LoneStar - X15/A26 - Trailer Interface (Lighting) – BOC NA Design 805
– BOC & EOF_NA
LT/RH/LoneStar - X15/A26 - Trailer Interface (Lighting) – BOC & EOF_NA
Design 807
– TRAMEC_NA
LT/RH/LoneStar - X15/A26 - Trailer Interface (Lighting) – TRAMEC_NA
Design 811
LT/RH - A26 - Transmission Shifter (Eaton Endurant
and Eaton Procision)
LT/RH - A26 - Transmission Shifter (Eaton Endurant and Eaton Procision)
Design 812
LT/RH - A26 - Transmission Shifter (Universal Shifter -
Ultrashift+ & FAS)
LT/RH - A26 - Transmission Shifter (Universal Shifter - Ultrashift+ & FAS)
Design 813
LT/RH/LoneStar - X15 - Transmission Shifter (Eaton
LT/RH/LoneStar - X15 - Transmission Shifter (Eaton Endurant and Eaton
Procision) Design 814
xxxviiiLT/RH/LoneStar - X15 - Transmission Shifter
LT/RH/LoneStar - X15 - Transmission Shifter (Universal Shifter - Ultrashift+ &
FAS) Design 815
LT/RH A26 - Endurant Transmission
LT/RH A26 - Endurant Transmission Design 816
LT/RH/LoneStar X15 - Endurant Transmission
LT/RH/LoneStar X15 - Endurant Transmission Design 817
LT/RH A26 - Ultrashift Plus
LT/RH A26 - Ultrashift Plus Design 818
LT/RH/LoneStar X15 - Ultrashift Plus
LT/RH/LoneStar X15 - Ultrashift Plus Design 819
LT/RH A26 - Transmission I/O (Allison 3K with Body
Builder)
LT/RH A26 - Transmission I/O (Allison 3K with Body Builder) Design 820
LT/RH A26 - Transmission (Allison 3K/4K)
LT/RH A26 - Transmission (Allison 3K/4K) Design 823
LT/RH - A26 - Auto Neutral (Allison with Multiplex
Switch and Confirmation Telltale)
LT/RH - A26 - Auto Neutral (Allison with Multiplex Switch and Confirmation
Telltale) Design 824
LT/RH/LoneStar - X15/A26 - Auto Neutral (J1939
Comms TC10 and Ultrashift)
LT/RH/LoneStar - X15/A26 - Auto Neutral (J1939 Comms TC10 and Ultrashift)
Design 825
LT/RH A26 - TC10 Series
LT/RH A26 - TC10 Series Design 826
LT/RH/LoneStar X15 - TC10 Series
LT/RH/LoneStar X15 - TC10 Series Design 827
LT/RH A26 - Transmission (Ultrashift+ w/Body Builder)
LT/RH A26 - Transmission (Ultrashift+ w/Body Builder) Design 828
LT/RH/LoneStar X15 - Transmission (Ultrashift+
w/Body Builder)
LT/RH/LoneStar X15 - Transmission (Ultrashift+ w/Body Builder) Design 829
LT/RH/LoneStar - X15/A26 - Hill Start Aid (Bendix)
LT/RH/LoneStar - X15/A26 - Hill Start Aid (Bendix) Design 830
LT/RH/LoneStar - X15/A26 - Hill Start Aid (Wabco)
LT/RH/LoneStar - X15/A26 - Hill Start Aid (Wabco) Design 833
LT/RH/LoneStar - X15/A26 - Transmission - MODE
Selection
LT/RH/LoneStar - X15/A26 - Transmission - MODE Selection Design 834
xxxixLT/RH A26 - Transmission I/O (Endurant Pressure
Sensor)
LT/RH A26 - Transmission I/O (Endurant Pressure Sensor) Design 835
LT/RH/LoneStar X15 - Transmission I/O (Endurant
Pressure Sensor)
LT/RH/LoneStar X15 - Transmission I/O (Endurant Pressure Sensor) Design 836
LoneStar - X15 - Windshield Washer Pump
LoneStar - X15 - Windshield Washer Pump Design 837
LoneStar - X15 - Windshield Washer Pump & Low
Fluid Sensor
LoneStar - X15 - Windshield Washer Pump & Low Fluid Sensor Design 838
LT/RH - X15/A26 - Windshield Washer Pump
LT/RH - X15/A26 - Windshield Washer Pump Design 839
LT/RH - X15/A26 - Windshield Washer Pump & Low
Fluid Sensor
LT/RH - X15/A26 - Windshield Washer Pump & Low Fluid Sensor Design 840
LT/RH - X15/A26 - Windshield Wipers Cruise Disable
W/Wipers ON
LT/RH - X15/A26 - Windshield Wipers Cruise Disable W/Wipers ON Design 841
LT/RH - X15/A26 - Windshield Wipers Cruise Disable &
Park Brake W/Wipers ON
LT/RH - X15/A26 - Windshield Wipers Cruise Disable & Park Brake W/Wipers ON
Design 842
LT/RH/LoneStar - X15/A26 - Windshield Wipers Park
Brake W/Wipers ON
LT/RH/LoneStar - X15/A26 - Windshield Wipers Park Brake W/Wipers ON
Design 843
Standard
LT/RH/LoneStar - X15/A26 - Windshield Wipers Standard Design 844
LT/RH A26 - Auto Start Stop Battery & Oil Temp
Mapping Auto Trans
LT/RH A26 - Auto Start Stop Battery & Oil Temp Mapping Auto Trans Design 845
LT/RH A26 - Auto Start Stop with Sleeper Auto Climate
/ Cab Temp / Oil Mapping Auto Trans
LT/RH A26 - Auto Start Stop with Sleeper Auto Climate / Cab Temp / Oil Mapping
Auto Trans Design 846
LT/RH A26 - Auto Start Stop and Sleeper Auto Climate
/ Cab Temp / Oil Mapping Manual Trans
LT/RH A26 - Auto Start Stop and Sleeper Auto Climate / Cab Temp / Oil Mapping
Manual Trans Design 847
xlLT/RH A26 - Auto Start Stop Battery & Oil Temp Mapping Manual Trans
Design 848
LT/RH/LoneStar X15 - Auto Start Stop Oil Temp
Sensor Auto Trans
LT/RH/LoneStar X15 - Auto Start Stop Oil Temp Sensor Auto Trans Design 849
LT/RH/LoneStar X15 - Auto Start Stop with Sleeper
Auto Climate / Cab Temp with Oil Temp Sensor Auto
Trans
LT/RH/LoneStar X15 - Auto Start Stop with Sleeper Auto Climate / Cab Temp with
Oil Temp Sensor Auto Trans Design 850
Sensor Manual Trans
LT/RH/LoneStar X15 - Auto Start Stop Oil Temp Sensor Manual Trans Design851
Manual Trans
Oil Temp Sensor Manual Trans Design 852
LT/RH - X15/A26 - Battery Disconnect
LT/RH - X15/A26 - Battery Disconnect Design 853
LT/RH - A26 - Bosch LH160_LH200 Alternator
LT/RH - A26 - Bosch LH160_LH200 Alternator Design 854
LT/RH - A26 - Bosch LIL165_LIL200 Alternator W/
Remote Sense
LT/RH - A26 - Bosch LIL165_LIL200 Alternator W/ Remote Sense Design 855
LT/RH - A26 - Delco Remy 28SI Alternator W/ Remote
Sense
LT/RH - A26 - Delco Remy 28SI Alternator W/ Remote Sense Design 856
LT/RH - A26 - Delco Remy 36SI Alternator W/ Remote
Sense
LT/RH - A26 - Delco Remy 36SI Alternator W/ Remote Sense Design 857
LT/RH - A26 - Delco Remy 40SI Alternator W/ Remote
Sense Combination 1
LT/RH - A26 - Delco Remy 40SI Alternator W/ Remote Sense Combination 1
Design 858
Sense Combination 2
LT/RH - A26 - Delco Remy 40SI Alternator W/ Remote Sense Combination 2
Design 859
LT/RH - A26 - Leece-Neville AVI160 Alternator N/
Remote Sense
LT/RH - A26 - Leece-Neville AVI160 Alternator N/ Remote Sense Design 860
LT/RH - A26 - Leece-Neville AVI160-210A/240A
xliLT/RH - A26 - Leece-Neville AVI160-210A/240A Alternator W/ Remote Sense
Design 861
LT/RH - A26 - Leece-Neville 320PAH Alternator
LT/RH - A26 - Leece-Neville 320PAH Alternator Design 862
LT/RH - A26 - Leece-Neville - LN 325A Alternator W/
Remote Sense
LT/RH - A26 - Leece-Neville - LN 325A Alternator W/ Remote Sense Design 863
LT/RH/LoneStar X15 - Bosch LH160_LH200 Alternator
W/ Delco Starter
LT/RH/LoneStar X15 - Bosch LH160_LH200 Alternator W/ Delco Starter
Design 864
LT/RH/LoneStar X15 - Bosch LIL165_LIL200 Alternator
W/ Remote Sense W/ Delco Starter
LT/RH/LoneStar X15 - Bosch LIL165_LIL200 Alternator W/ Remote Sense W/
Delco Starter Design 865
LT/RH/LoneStar X15 - Delco Remy 28SI Alternator W/
LT/RH/LoneStar X15 - Delco Remy 28SI Alternator W/ Remote Sense W/ Delco
Starter Design 866
LT/RH/LoneStar X15 - Delco Remy 36SI Alternator W/
Remtoe Sense W/ Delco Starter
LT/RH/LoneStar X15 - Delco Remy 36SI Alternator W/ Remtoe Sense W/ Delco
Starter Design 868
LT/RH/LoneStar X15 - Delco Remy 40SI Alternator W/
LT/RH/LoneStar X15 - Delco Remy 40SI Alternator W/ Remote Sense W/ Delco
Starter Design 869
LT/RH/LoneStar X15 - Leece-Neville AVI160 Alternator
W/ Delco Starter
LT/RH/LoneStar X15 - Leece-Neville AVI160 Alternator W/ Delco Starter
Design 871
LT/RH/LoneStar X15 - Leece-Neville AVI160-210A/240A
Alternator W/ Remote Sense W/ Delco Starter
LT/RH/LoneStar X15 - Leece-Neville AVI160-210A/240A Alternator W/ Remote
Sense W/ Delco Starter Design 872
LT/RH/LoneStar X15 - Leece-Neville 320PAH
LT/RH/LoneStar X15 - Leece-Neville 320PAH Alternator W/ Delco Starter
Design 873
LT/RH/LoneStar X15 - Leece-Neville - LN 325A
LT/RH/LoneStar X15 - Leece-Neville - LN 325A Alternator W/ Remote Sense W/
Delco Starter Design 874
LT/RH - A26 - Bosch LH160_LH200 Alternator W/
Mitsubishi Starter
LT/RH - A26 - Bosch LH160_LH200 Alternator W/ Mitsubishi Starter Design 875
xliiLT/RH - A26 - Bosch LIL165_LIL200 Alternator W/
Remote Sense W/ Mitsubishi Starter
LT/RH - A26 - Bosch LIL165_LIL200 Alternator W/ Remote Sense W/ Mitsubishi
Starter Design 876
LT/RH - A26 - Delco Remy 28SI Alternator W/ Remote Sense W/ Mitsubishi
Starter Design 877
LT/RH - A26 - Delco Remy 36SI Alternator W/ Remote Sense W/ Mitsubishi
Starter Design 878
Sense Combination 1 W/ Mitsubishi Starter
LT/RH - A26 - Delco Remy 40SI Alternator W/ Remote Sense Combination 1 W/
Mitsubishi Starter Design 879
Sense Combination 2 W/ Mitsubishi Starter
LT/RH - A26 - Delco Remy 40SI Alternator W/ Remote Sense Combination 2 W/
Mitsubishi Starter Design 880
LT/RH - A26 - Leece-Neville AVI160 Alternator N/ Remote Sense W/ Mitsubishi
Starter Design 881
Alternator W/ Remote Sense W/ Mitsubishi Starter
LT/RH - A26 - Leece-Neville AVI160-210A/240A Alternator W/ Remote Sense W/
Mitsubishi Starter Design 882
LT/RH - A26 - Leece-Neville 320PAH Alternator W/
Mitsubishi Starter
LT/RH - A26 - Leece-Neville 320PAH Alternator W/ Mitsubishi Starter Design 883
LT/RH - A26 - Leece-Neville - LN 325A Alternator W/ Remote Sense W/
Mitsubishi Starter Design 884
LT/RH/LoneStar - X15 - Bosch LH160_LH200
LT/RH/LoneStar - X15 - Bosch LH160_LH200 Alternator W/ Mitsubishi Starter
Design 885
LT/RH/LoneStar - X15 - Bosch LIL165_LIL200
LT/RH/LoneStar - X15 - Bosch LIL165_LIL200 Alternator W/ Remote Sense W/
Mitsubishi Starter Design 886
LT/RH/LoneStar - X15 - Delco Remy 28SI Alternator W/
LT/RH/LoneStar - X15 - Delco Remy 28SI Alternator W/ Remote Sense W/
Mitsubishi Starter Design 887
xliiiLT/RH/LoneStar - X15 - Delco Remy 36SI Alternator W/
LT/RH/LoneStar - X15 - Delco Remy 36SI Alternator W/ Remote Sense W/
Mitsubishi Starter Design 889
LT/RH/LoneStar - X15 - Delco Remy 40SI Alternator W/
LT/RH/LoneStar - X15 - Delco Remy 40SI Alternator W/ Remote Sense W/
Mitsubishi Starter Design 890
LT/RH/LoneStar - X15 - Leece-Neville AVI160
LT/RH/LoneStar - X15 - Leece-Neville AVI160 Alternator W/ Mitsubishi Starter
Design 892
LT/RH/LoneStar - X15 - Leece-Neville AVI160-
210A/240A Alternator W/ Remote Sense W/ Mitsubishi
Starter
LT/RH/LoneStar - X15 - Leece-Neville AVI160-210A/240A Alternator W/ Remote
Sense W/ Mitsubishi Starter Design 893
LT/RH/LoneStar - X15 - Leece-Neville 320PAH
LT/RH/LoneStar - X15 - Leece-Neville 320PAH Alternator W/ Mitsubishi Starter
Design 894
LT/RH/LoneStar - X15 - Leece-Neville - LN 325A
LT/RH/LoneStar - X15 - Leece-Neville - LN 325A Alternator W/ Remote Sense W/
Mitsubishi Starter Design 895
LT/RH/LoneStar - X15/A26 - Cranking Request (BCM
Controlled)
LT/RH/LoneStar - X15/A26 - Cranking Request (BCM Controlled) Design 896
LT/RH/LoneStar - X15/A26 - Engine Speed Inhibit Only
LT/RH/LoneStar - X15/A26 - Engine Speed Inhibit Only Design 897
LT/RH - A26 - Cranking (Starter) GEN4 BODY
CONTROL MODULE W/O Thermal Overcrank Wiring
LT/RH - A26 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/O
Thermal Overcrank Wiring Design 898
LT/RH/LoneStar - X15 - Cranking (Starter) GEN4 BODY
LT/RH/LoneStar - X15 - Cranking (Starter) GEN4 BODY CONTROL MODULE
W/O Thermal Overcrank Wiring Design 899
CONTROL MODULE W/ Thermal Overcrank - External
Switch
LT/RH - A26 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/ Thermal
Overcrank - External Switch Design 900
Switch
xlivLT/RH/LoneStar - X15 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/
Thermal Overcrank - External Switch Design 901
LT/RH/LoneStar - X15/A26 - DC/AC Inverter
LT/RH/LoneStar - X15/A26 - DC/AC Inverter Design 902
LT/RH/LoneStar - X15/A26 - DC/AC Inverter (1200W
W/switch control)
LT/RH/LoneStar - X15/A26 - DC/AC Inverter (1200W W/switch control)
Design 903
LT/RH/LoneStar - X15/A26 - DC/AC Inverter (1800W)
LT/RH/LoneStar - X15/A26 - DC/AC Inverter (1800W) Design 904
LT/RH/LoneStar - X15/A26 - Electrical Load
Control(Load Shed)
LT/RH/LoneStar - X15/A26 - Electrical Load Control(Load Shed) Design 905
LT/RH/LoneStar - X15/A26 - JUMP START STUD
(DUAL)
LT/RH/LoneStar - X15/A26 - JUMP START STUD (DUAL) Design 906
(SINGLE)
LT/RH/LoneStar - X15/A26 - JUMP START STUD (SINGLE) Design 907
LT/RH/LoneStar - X15/A26 - Key Switch (Operator
Input)
LT/RH/LoneStar - X15/A26 - Key Switch (Operator Input) Design 908
LT/RH - A26/X15 - Maxwell 12V Ultracapacitor Engine
Start Module (ESM)
LT/RH - A26/X15 - Maxwell 12V Ultracapacitor Engine Start Module (ESM)
Design 909
LT/RH/LoneStar - X15/A26 - Clutch Monitoring (High
and Low Switch to BCM)
LT/RH/LoneStar - X15/A26 - Clutch Monitoring (High and Low Switch to BCM)
Design 910
LoneStar - X15 - Crank Inhibit with Hood Switch - with
New BODY CONTROL MODULE Pin
LoneStar - X15 - Crank Inhibit with Hood Switch - with New BODY CONTROL
MODULE Pin Design 911
LoneStar - X15 - Hood Switch
LoneStar - X15 - Hood Switch Design 913
LT/RH - X15/A26 - Hood Switch
LT/RH - X15/A26 - Hood Switch Design 914
LT/RH - X15/A26 - with Hood Switch - with New BODY
CONTROL MODULE Pin
LT/RH - X15/A26 - with Hood Switch - with New BODY CONTROL MODULE Pin
Design 915
LT/RH - A26 - Starter Interlocks A26 TC10
LT/RH - A26 - Starter Interlocks A26 TC10 Design 916
xlvLT/RH - A26 - Starter Interlocks A26 3K
LT/RH - A26 - Starter Interlocks A26 3K Design 917
LT/RH - A26 - Starter Interlocks (Service Brake
Interlock)
LT/RH - A26 - Starter Interlocks (Service Brake Interlock) Design 918
LT/RH - A26 - Starter Interlock (BCM HSD controlled
W/ Clutch Switch W/ Auto Start Stop)
LT/RH - A26 - Starter Interlock (BCM HSD controlled W/ Clutch Switch W/ Auto
Start Stop) Design 919
LT/RH - A26 - Starter Interlock (BCM LSD Controlled
w/ Relay)_EATON XMSN
LT/RH - A26 - Starter Interlock (BCM LSD Controlled w/ Relay)_EATON XMSN
Design 921
LT/RH/LoneStar - X15 - Starter Interlocks ISX TC10
LT/RH/LoneStar - X15 - Starter Interlocks ISX TC10 Design 922
LT/RH/LoneStar - X15 - Starter Interlocks (Service
Brake Interlock)
LT/RH/LoneStar - X15 - Starter Interlocks (Service Brake Interlock) Design 923
LT/RH/LoneStar - X15 - Starter Interlock (BCM HSD
controlled W/ Clutch Switch W/ Auto Start Stop)
LT/RH/LoneStar - X15 - Starter Interlock (BCM HSD controlled W/ Clutch Switch
W/ Auto Start Stop) Design 924
LT/RH/LoneStar - X15 - Starter Interlock (BCM LSD
LT/RH/LoneStar - X15 - Starter Interlock (BCM LSD Controlled w/ Relay)_EATON
XMSN Design 925
LT/RH/LoneStar - X15/A26 - Starter Interlock (BCM
HSD controlled W/ Clutch Switch N/ Auto Start Stop)
LT/RH/LoneStar - X15/A26 - Starter Interlock (BCM HSD controlled W/ Clutch
Switch N/ Auto Start Stop) Design 926
LT/RH A26 - Battery International (3) 12V
LT/RH A26 - Battery International (3) 12V Design 927
LT/RH/LoneStar X15 - Battery International (3) 12V
LT/RH/LoneStar X15 - Battery International (3) 12V Design 928
LT/RH A26 - Battery International (4) 12V
LT/RH A26 - Battery International (4) 12V Design 929
LT/RH/LoneStar X15 - Battery International (4) 12V
LT/RH/LoneStar X15 - Battery International (4) 12V Design 930
LT/RH - A26 - Battery International (8) 12V
LT/RH - A26 - Battery International (8) 12V Design 931
LT/RH/LoneStar X15 - Battery International (8) 12V
LT/RH/LoneStar X15 - Battery International (8) 12V Design 932
xlviLT/RH/LoneStar - X15/A26 - 9 Pin Diagnostic
Connector (Green)
LT/RH/LoneStar - X15/A26 - 9 Pin Diagnostic Connector (Green) Design 933
Connector (Green)(Export)
LT/RH/LoneStar - X15/A26 - 9 Pin Diagnostic Connector (Green)(Export)
Design 934
Connectors 935
Part Assembly List
Connector Assembly List 2976
Index 3092
