Momed80
150
35,046
International Truck LT RH Lonestar Series Interactive Schematics 0000018825 2021
Brand: International, Navistar
Type of Manual: Interactive Schematics
Model: International LT Series, RH Series, Lonestar Series Truck
Built: 12/1/2016 To 1/14/2019
Part Number: 0000018825
Publication Date: 2021
Number of Pages: 3013 Pages
LT/RH/LoneStar - X15/A26 - Body Control Module
(BCM)
LT/RH/LoneStar - X15/A26 - Body Control Module (BCM) Design 1
ABS Private
ABS Private Design 9
Cab J1939 (250Kbps)
Cab J1939 (250Kbps) Design 10
Engine Private J1939 A26
Engine Private J1939 A26 Design 11
Engine Private J1939 X15
Engine Private J1939 X15 Design 12
Fusion Private J1939
Fusion Private J1939 Design 13
Low Speed J1939 (125Kbps)
Low Speed J1939 (125Kbps) Design 14
Telematics J1708
Telematics J1708 Design 15
Body J1939 (250Kbps) Splice Pack 1024
Body J1939 (250Kbps) Splice Pack 1024 Design 16
Body J1939 (250Kbps) Splice Pack 1025
Body J1939 (250Kbps) Splice Pack 1025 Design 17
Body J1939 (250Kbps) Splice Pack 1029
Body J1939 (250Kbps) Splice Pack 1029 Design 18
Body J1939 (250Kbps) W/ 3 Splice Packs
Body J1939 (250Kbps) W/ 3 Splice Packs Design 19
Powertrain J1939 (500Kbps) Allison 3K Transmission
A26
Powertrain J1939 (500Kbps) Allison 3K Transmission A26 Design 20
Powertrain J1939 (500Kbps) Eaton Ultrashift+
Transmission A26
Powertrain J1939 (500Kbps) Eaton Ultrashift+ Transmission A26 Design 21
Powertrain J1939 (500Kbps) Endurant Transmission
A26
Powertrain J1939 (500Kbps) Endurant Transmission A26 Design 22
Powertrain J1939 (500Kbps) Manual Transmission
A26
Powertrain J1939 (500Kbps) Manual Transmission A26 Design 23
Powertrain J1939 (500Kbps) TC10 Transmission A26
Powertrain J1939 (500Kbps) TC10 Transmission A26 Design 24
Transmission X15
Powertrain J1939 (500Kbps) Eaton Ultrashift+ Transmission X15 Design 25
iPowertrain J1939 (500Kbps) Endurant Transmission
X15
Powertrain J1939 (500Kbps) Endurant Transmission X15 Design 26
Powertrain J1939 (500Kbps) Manual Transmission X15
Powertrain J1939 (500Kbps) Manual Transmission X15 Design 27
Powertrain J1939 (500Kbps) TC10 Transmission X15
Powertrain J1939 (500Kbps) TC10 Transmission X15 Design 28
LT/RH - A26 - ECM
LT/RH - A26 - ECM Design 29
LT/RH/LoneStar - X15 - ECM
LT/RH/LoneStar - X15 - ECM Design 31
LT/RH/LoneStar - X15/A26 - Instrument Cluster
(Premium)
LT/RH/LoneStar - X15/A26 - Instrument Cluster (Premium) Design 32
(Standard)
LT/RH/LoneStar - X15/A26 - Instrument Cluster (Standard) Design 33
LT/RH/LoneStar - X15/A26 - Instrument Cluster - Bulb
Check
LT/RH/LoneStar - X15/A26 - Instrument Cluster - Bulb Check Design 34
Request and Status
LT/RH/LoneStar - X15/A26 - Instrument Cluster - Request and Status Design 35
LT/RH - A26 - Ground Splice Packs - 1022 & 1023
LT/RH - A26 - Ground Splice Packs - 1022 & 1023 Design 36
LT/RH/LoneStar - X15 - Ground Splice Packs - 1022 &
1023
LT/RH/LoneStar - X15 - Ground Splice Packs - 1022 & 1023 Design 37
LT/RH/LoneStar - X15/A26 - Ground Splice Pack - 1027
LT/RH/LoneStar - X15/A26 - Ground Splice Pack - 1027 Design 38
LT/RH/LoneStar - X15/A26 - Interior Dual Post Ground
Stud-Cowl Wall
LT/RH/LoneStar - X15/A26 - Interior Dual Post Ground Stud-Cowl Wall Design 39
LT/RH/LoneStar - X15/A26 - Splice Pack - 1620
LT/RH/LoneStar - X15/A26 - Splice Pack - 1620 Design 40
LoneStar - X15 - Forward Chassis Splice Packs - 8800
LoneStar - X15 - Forward Chassis Splice Packs - 8800 Design 41
LT/RH - X15/A26 - Forward Chassis Splice Packs -
8800
LT/RH - X15/A26 - Forward Chassis Splice Packs - 8800 Design 42
iiLT/RH/LoneStar - X15/A26 - Rear Chassis Splice
Packs - 8802
LT/RH/LoneStar - X15/A26 - Rear Chassis Splice Packs - 8802 Design 43
Packs - 8803 & 8804
LT/RH/LoneStar - X15/A26 - Rear Chassis Splice Packs - 8803 & 8804 Design 44
LT/RH - A26 - Powertrain Ground Splice Packs - 6704
LT/RH - A26 - Powertrain Ground Splice Packs - 6704 Design 45
LT/RH - A26 - Powertrain ZVR Splice Packs 6702 &
6704B
LT/RH - A26 - Powertrain ZVR Splice Packs 6702 & 6704B Design 46
LT/RH/LoneStar - X15 - Powertrain Ground Splice
Packs - 6704
LT/RH/LoneStar - X15 - Powertrain Ground Splice Packs - 6704 Design 47
LT/RH/LoneStar - X15 - Powertrain Splice Packs - 6702
& 6703
LT/RH/LoneStar - X15 - Powertrain Splice Packs - 6702 & 6703 Design 48
LT/RH/LoneStar - X15/A26 - Sleeper Ground Splice
Packs - 5007
LT/RH/LoneStar - X15/A26 - Sleeper Ground Splice Packs - 5007 Design 49
LT/RH/LoneStar - X15/A26 - Lighting Control Module
LT/RH/LoneStar - X15/A26 - Lighting Control Module Design 50
LT/RH - A26 - Aftertreatment PDM
LT/RH - A26 - Aftertreatment PDM Design 51
LT/RH/LoneStar - X15 - Aftertreatment PDM
LT/RH/LoneStar - X15 - Aftertreatment PDM Design 52
LT/RH/LoneStar - X15/A26 - Battery Feed
LT/RH/LoneStar - X15/A26 - Battery Feed Design 53
LT/RH/LoneStar - X15/A26 - Interior PDM Chart
LT/RH/LoneStar - X15/A26 - Interior PDM Chart Design 54
LT/RH/LoneStar - X15/A26 - Key Switch Accessory
LT/RH/LoneStar - X15/A26 - Key Switch Accessory Design 55
LT/RH/LoneStar - X15/A26 - Key Switch Ignition
LT/RH/LoneStar - X15/A26 - Key Switch Ignition Design 56
LT/RH/LoneStar - X15/A26 - Relays - Grid Management
LT/RH/LoneStar - X15/A26 - Relays - Grid Management Design 57
LT/RH/LoneStar - X15/A26 - ABS Splice Pack - 1410
LT/RH/LoneStar - X15/A26 - ABS Splice Pack - 1410 Design 58
LT/RH/LoneStar - X15/A26 - Panel Dimmer Splice Pack
1021
LT/RH/LoneStar - X15/A26 - Panel Dimmer Splice Pack 1021 Design 59
Park / Turn Light Splice Packs - 1028
Park / Turn Light Splice Packs - 1028 Design 60
iiiLT/RH/LoneStar - X15/A26 - Sleeper PDM
LT/RH/LoneStar - X15/A26 - Sleeper PDM Design 61
LT/RH - A26 - Underhood PDM
LT/RH - A26 - Underhood PDM Design 62
LT/RH/LoneStar - X15 - Underhood PDM
LT/RH/LoneStar - X15 - Underhood PDM Design 63
LT/RH/LoneStar - X15/A26 - Auxiliary Air Solenoids 4-
pack (1 pack/4 solenoids)
LT/RH/LoneStar - X15/A26 - Auxiliary Air Solenoids 4-pack (1 pack/4 solenoids)
Design 64
pack (1 pack/4 solenoids) 2
LT/RH/LoneStar - X15/A26 - Auxiliary Air Solenoids 4-pack (1 pack/4 solenoids) 2
Design 68
pack (2 packs/8 solenoids)
LT/RH/LoneStar - X15/A26 - Auxiliary Air Solenoids 4-pack (2 packs/8 solenoids)
Design 69
pack (2 packs/8 solenoids) 2
2 Design 73
LT/RH/LoneStar - X15/A26 - Radio BlueTooth
W/Steering Wheel W/Remote W/MIC
LT/RH/LoneStar - X15/A26 - Radio BlueTooth W/Steering Wheel W/Remote
W/MIC Design 74
LT/RH/LoneStar - X15/A26 - Radio N/ Steering Wheel
Pod W/Remote
LT/RH/LoneStar - X15/A26 - Radio N/ Steering Wheel Pod W/Remote Design 75
LT/RH/LoneStar - X15/A26 - Radio W/Steering Wheel
Pod N/ Remote
LT/RH/LoneStar - X15/A26 - Radio W/Steering Wheel Pod N/ Remote Design 76
Pod W/Remote
LT/RH/LoneStar - X15/A26 - Radio W/Steering Wheel Pod W/Remote Design 77
LT/RH/LoneStar - X15/A26 - Speakers:Four Speakers
N/BT N/QC
LT/RH/LoneStar - X15/A26 - Speakers:Four Speakers N/BT N/QC Design 78
N/BT W/QC
LT/RH/LoneStar - X15/A26 - Speakers:Four Speakers N/BT W/QC Design 80
LT/RH/LoneStar - X15/A26 - Speakers:Speakers N/BT
W/ Amplifier
LT/RH/LoneStar - X15/A26 - Speakers:Speakers N/BT W/ Amplifier Design 82
ivLT/RH/LoneStar - X15/A26 - Speakers:Four Speakers
W/BT N/QC
LT/RH/LoneStar - X15/A26 - Speakers:Four Speakers W/BT N/QC Design 83
W/BT W/QC
LT/RH/LoneStar - X15/A26 - Speakers:Four Speakers W/BT W/QC Design 85
LT/RH/LoneStar - X15/A26 - Speakers:Speakers W/ BT
W/ AmplifieR
LT/RH/LoneStar - X15/A26 - Speakers:Speakers W/ BT W/ AmplifieR Design 87
LT/RH/LoneStar - X15/A26 - Dual Aux Switch
LT/RH/LoneStar - X15/A26 - Dual Aux Switch Design 88
LT/RH/LoneStar - X15/A26 - Single Aux Switch
LT/RH/LoneStar - X15/A26 - Single Aux Switch Design 89
LT/RH/LoneStar - X15/A26 - Standard APO Aux APO
Rear Std APO Rear APO W/Cover 12V Panel
LT/RH/LoneStar - X15/A26 - Standard APO Aux APO Rear Std APO Rear APO
W/Cover 12V Panel Design 91
LT/RH/LoneStar - X15/A26 - Standard APO Rear
Standard APO Rear APO W/Cover 12V Panel
LT/RH/LoneStar - X15/A26 - Standard APO Rear Standard APO Rear APO
W/Cover 12V Panel Design 95
Standard APO Rear APO W/Cover 12V Panel Rear
Overhead APO
W/Cover 12V Panel Rear Overhead APO Design 97
LT/RH/LoneStar - X15/A26 - Standard Auxiliary Power
Outlet
LT/RH/LoneStar - X15/A26 - Standard Auxiliary Power Outlet Design 99
Outlet AUX Auxiliary Power Outlet
LT/RH/LoneStar - X15/A26 - Standard Auxiliary Power Outlet AUX Auxiliary
Power Outlet Design 100
Outlet Aux Auxiliary Power Outlet Overhead Auxiliary
Power Outlet
LT/RH/LoneStar - X15/A26 - Standard Auxiliary Power Outlet Aux Auxiliary Power
Outlet Overhead Auxiliary Power Outlet Design 102
Outlet Aux Auxiliary Power Outlet Rear Standard
Auxiliary Power Outlet Rear Auxiliary Power Outlet
W/Cover 12V Panel Overhead Auxiliary Power Outlet
Outlet Rear Standard Auxiliary Power Outlet Rear Auxiliary Power Outlet W/Cover
12V Panel Overhead Auxiliary Power Outlet Design 104
vLT/RH/LoneStar - X15/A26 - Standard Auxiliary Power
W/Cover 12V Panel Upper Bank Auxiliary Power Outlet
12V Panel Upper Bank Auxiliary Power Outlet Design 108
Rear Overhead Auxiliary Power Outlet
12V Panel Upper Bank Auxiliary Power Outlet Rear Overhead Auxiliary Power
Outlet Design 112
LT/RH/LoneStar - X15/A26 - Standard Auxiliary Power Outlet Overhead Auxiliary
Power Outlet Design 116
Auxiliary Power Outlet W/Cover 12V Panel Upper Bank
LT/RH/LoneStar - X15/A26 - Standard Auxiliary Power Outlet Rear Standard
Auxiliary Power Outlet Rear Auxiliary Power Outlet W/Cover 12V Panel Upper
Bank Auxiliary Power Outlet Design 117
Outlet
Bank Auxiliary Power Outlet Rear Overhead Auxiliary Power Outlet Design 119
LT/RH - A26 - Back-Up Alarm Manual and UltraShift+
LT/RH - A26 - Back-Up Alarm Manual and UltraShift+ Design 121
LT/RH - A26 - Back-Up Alarm (Automatic)TC10
LT/RH - A26 - Back-Up Alarm (Automatic)TC10 Design 125
LT/RH/LoneStar - X15 - Back-Up Alarm (Manual) and
UltraShift+
LT/RH/LoneStar - X15 - Back-Up Alarm (Manual) and UltraShift+ Design 127
LT/RH/LoneStar - X15/A26 - Banana Plugs Receptacle
LT/RH/LoneStar - X15/A26 - Banana Plugs Receptacle Design 129
LT/RH/LoneStar - X15/A26 - CB Radio Power Only
LT/RH/LoneStar - X15/A26 - CB Radio Power Only Design 130
viLT/RH/LoneStar - X15/A26 - Cigar Lighter
LT/RH/LoneStar - X15/A26 - Cigar Lighter Design 131
LT/RH/LoneStar - X15/A26 - Cigar Lighter Auxiliary
Power Outlet
LT/RH/LoneStar - X15/A26 - Cigar Lighter Auxiliary Power Outlet Design 132
LT/RH/LoneStar - X15/A26 - Cigar Lighter Aux APO
Rear Standard APO Rear APO W/Cover 12V Panel
LT/RH/LoneStar - X15/A26 - Cigar Lighter Aux APO Rear Standard APO Rear
APO W/Cover 12V Panel Design 134
Auxiliary Power Outlet Overhead Auxiliary Power
Outlet
LT/RH/LoneStar - X15/A26 - Cigar Lighter Aux Auxiliary Power Outlet Overhead
Auxiliary Power Outlet Design 138
Auxiliary Power Outlet Rear Santdard Auxiliary Power
Overhead APO
LT/RH/LoneStar - X15/A26 - Cigar Lighter Aux Auxiliary Power Outlet Rear
Santdard Auxiliary Power Outlet Rear Auxiliary Power Outlet W/Cover 12V Panel
Overhead APO Design 140
Auxiliary Power Outlet Rear Standard Auxiliary Power
Standard Auxiliary Power Outlet Rear Auxiliary Power Outlet W/Cover 12V Panel
Upper Bank Auxiliary Power Outlet Design 144
Upper Bank Auxiliary Power Outlet Rear Overhead Auxiliary Power Outlet
Design 148
LT/RH/LoneStar - X15/A26 - Cigar Lighter Overhead
LT/RH/LoneStar - X15/A26 - Cigar Lighter Overhead Auxiliary Power Outlet
Design 152
LT/RH/LoneStar - X15/A26 - Cigar Lighter Rear
Outlet W/Cover 12V Panel Overhead Auxiliary Power
Outlet
viiLT/RH/LoneStar - X15/A26 - Cigar Lighter Rear Standard Auxiliary Power Outlet
Rear Auxiliary Power Outlet W/Cover 12V Panel Overhead Auxiliary Power Outlet
Design 153
Outlet W/Cover 12V Panel Upper Bank Auxiliary Power
Outlet
Rear Auxiliary Power Outlet W/Cover 12V Panel Upper Bank Auxiliary Power
Outlet Design 155
Outlet Rear Overhead Auxiliary Power Outlet Design 157
LT/RH/LoneStar - X15/A26 - Cigar Lighter Rear Std
APO APO W/Cover 12V Panel
LT/RH/LoneStar - X15/A26 - Cigar Lighter Rear Std APO APO W/Cover 12V
Panel Design 159
LT/RH/LoneStar - X15/A26 - LoneStar - Adaptive
Cruise Control w/o Display (Wabco)
LT/RH/LoneStar - X15/A26 - LoneStar - Adaptive Cruise Control w/o Display
(Wabco) Design 161
Cruise Control w/o Display(Bendix)
Display(Bendix) Design 162
LT/RH/LoneStar - X15/A26 - Analytic Cruise Control
LT/RH/LoneStar - X15/A26 - Analytic Cruise Control Design 163
LT/RH/LoneStar - X15/A26 - Vehicle Speed Control
(Cruise Control) 10 - Pin
LT/RH/LoneStar - X15/A26 - Vehicle Speed Control (Cruise Control) 10 - Pin
Design 164
(Cruise Control) 4 - PIN
LT/RH/LoneStar - X15/A26 - Vehicle Speed Control (Cruise Control) 4 - PIN
Design 165
LoneStar - X15 - City Horn (W/ 10PIN CLK)
LoneStar - X15 - City Horn (W/ 10PIN CLK) Design 166
LoneStar - X15 - City Horn (W/ 10PIN CLK) (Horizon)
LoneStar - X15 - City Horn (W/ 10PIN CLK) (Horizon) Design 167
LT/RH - A26/X15 - City Horn (W/ 10PIN CLK)
LT/RH - A26/X15 - City Horn (W/ 10PIN CLK) Design 168
LT/RH - A26/X15 - City Horn (W/ 10PIN CLK) (Horizon)
LT/RH - A26/X15 - City Horn (W/ 10PIN CLK) (Horizon) Design 169
viiiLoneStar - X15 - City Horn (W/ 4PIN CLK)
LoneStar - X15 - City Horn (W/ 4PIN CLK) Design 170
LoneStar - X15 - City Horn (W/ 4PIN CLK) (Horizon)
LoneStar - X15 - City Horn (W/ 4PIN CLK) (Horizon) Design 171
LT/RH - A26/X15 - City Horn (W/ 4PIN CLK)
LT/RH - A26/X15 - City Horn (W/ 4PIN CLK) Design 172
LT/RH - A26/X15 - City Horn (W/ 4PIN CLK)-
LT/RH - A26/X15 - City Horn (W/ 4PIN CLK)- Design 173
LT/RH/LoneStar - X15/A26 - Fan - Sleeper/Bunk
LT/RH/LoneStar - X15/A26 - Fan - Sleeper/Bunk Design 174
LT/RH/LoneStar - X15/A26 - Rand Mcnallly GPS
Display
LT/RH/LoneStar - X15/A26 - Rand Mcnallly GPS Display Design 176
LT/RH/LoneStar - X15/A26 - Multiplexed Switch Pack
(Primary Switch)
LT/RH/LoneStar - X15/A26 - Multiplexed Switch Pack (Primary Switch) Design177
LT/RH/LoneStar - X15/A26 - Door Ajar Reminder
Entry/Exit
LT/RH/LoneStar - X15/A26 - Door Ajar Reminder Entry/Exit Design 178
LT/RH/LoneStar - X15/A26 - Power Door Locks
LT/RH/LoneStar - X15/A26 - Power Door Locks Design 179
LT/RH/LoneStar - X15/A26 - Heated Mirrors (Door Pod
Actuated Cab Mounted)
LT/RH/LoneStar - X15/A26 - Heated Mirrors (Door Pod Actuated Cab Mounted)
Design 180
LT/RH/LoneStar - X15/A26 - Mirrors (Power) Door Pod
Actuated
LT/RH/LoneStar - X15/A26 - Mirrors (Power) Door Pod Actuated Design 181
LT/RH/LoneStar - X15/A26 - Mirror Lighting Turns with
Door Pods
LT/RH/LoneStar - X15/A26 - Mirror Lighting Turns with Door Pods Design 182
LT/RH/LoneStar - X15/A26 - Power Windows
LT/RH/LoneStar - X15/A26 - Power Windows Design 183
LT/RH/LoneStar - X15/A26 - Cabinet Refrigerator
N/Relay
LT/RH/LoneStar - X15/A26 - Cabinet Refrigerator N/Relay Design 184
W/Relay
LT/RH/LoneStar - X15/A26 - Cabinet Refrigerator W/Relay Design 185
LT/RH/LoneStar - X15/A26 - Underbunk Refrigerator
N/Relay
LT/RH/LoneStar - X15/A26 - Underbunk Refrigerator N/Relay Design 186
ixLT/RH/LoneStar - X15/A26 - REMOTE KEYLESS
ACCESS
LT/RH/LoneStar - X15/A26 - REMOTE KEYLESS ACCESS Design 187
LT/RH/LoneStar - X15/A26 - Telematics (DRIVERTECH
DAYCAB W/ J1939)
LT/RH/LoneStar - X15/A26 - Telematics (DRIVERTECH DAYCAB W/ J1939)
Design 188
SLEEPER W/ J1939)
LT/RH/LoneStar - X15/A26 - Telematics (DRIVERTECH SLEEPER W/ J1939)
Design 189
LT/RH/LoneStar - X15/A26 - OCC Telematics
LT/RH/LoneStar - X15/A26 - OCC Telematics Design 190
LT/RH/LoneStar - X15/A26 - Telematics (OMNIVISION
MD)
LT/RH/LoneStar - X15/A26 - Telematics (OMNIVISION MD) Design 191
W/ J1939 & PANIC BUTTON)
LT/RH/LoneStar - X15/A26 - Telematics (OMNIVISION W/ J1939 & PANIC
BUTTON) Design 193
LT/RH/LoneStar - X15/A26 - Telematics (Peoplenet
PMG)
LT/RH/LoneStar - X15/A26 - Telematics (Peoplenet PMG) Design 194
LT/RH/LoneStar - X15/A26 - Telematics (PEOPLE NET
DAYCAB)
LT/RH/LoneStar - X15/A26 - Telematics (PEOPLE NET DAYCAB) Design 196
LT/RH/LoneStar - X15/A26 - Telematics (PMG W/ DVR)
LT/RH/LoneStar - X15/A26 - Telematics (PMG W/ DVR) Design 198
LT/RH/LoneStar - X15/A26 - Telematics QUALCOMM
IMCT DAYCAB W/ MVPC & PANIC BUTTON
LT/RH/LoneStar - X15/A26 - Telematics QUALCOMM IMCT DAYCAB W/ MVPC
& PANIC BUTTON Design 199
IMCT DAYCAB W/ PANIC BUTTON
LT/RH/LoneStar - X15/A26 - Telematics QUALCOMM IMCT DAYCAB W/ PANIC
BUTTON Design 200
IMCT MD
LT/RH/LoneStar - X15/A26 - Telematics QUALCOMM IMCT MD Design 202
TMCT
LT/RH/LoneStar - X15/A26 - Telematics QUALCOMM TMCT Design 204
TMCT W/ PANIC BUTTON
LT/RH/LoneStar - X15/A26 - Telematics QUALCOMM TMCT W/ PANIC BUTTON
Design 205
xLT/RH/LoneStar - X15/A26 - Telematics (QUALCOMM
IMCT DAYCAB W/ MVPC)
LT/RH/LoneStar - X15/A26 - Telematics (QUALCOMM IMCT DAYCAB W/ MVPC)
Design 206
MCP50)
LT/RH/LoneStar - X15/A26 - Telematics (QUALCOMM MCP50) Design 207
MCT W/O Tracs)
LT/RH/LoneStar - X15/A26 - Telematics (QUALCOMM MCT W/O Tracs)
Design 208
MCT W/ TRACS)
LT/RH/LoneStar - X15/A26 - Telematics (QUALCOMM MCT W/ TRACS)
Design 209
LT/RH/LoneStar - X15/A26 - Telematics (TRIPMASTER
DAYCAB)
LT/RH/LoneStar - X15/A26 - Telematics (TRIPMASTER DAYCAB) Design 210
SLEEPER)
LT/RH/LoneStar - X15/A26 - Telematics (TRIPMASTER SLEEPER) Design 211
LT/RH/LoneStar - X15/A26 - Telematics XATANET
W/J1708
LT/RH/LoneStar - X15/A26 - Telematics XATANET W/J1708 Design 212
W/J1939
LT/RH/LoneStar - X15/A26 - Telematics XATANET W/J1939 Design 213
LT/RH/LoneStar - X15/A26 - Theft Deterrent (Standard
J1939 Mux Switch)
LT/RH/LoneStar - X15/A26 - Theft Deterrent (Standard J1939 Mux Switch)
Design 214
LoneStar - X15 - Tire Pressure TPMS
LoneStar - X15 - Tire Pressure TPMS Design 215
LT/RH/LoneStar - X15/A26 - Tire Pressure (TPMS) (US
& Canada)
LT/RH/LoneStar - X15/A26 - Tire Pressure (TPMS) (US & Canada) Design 216
LT/RH/LoneStar - X15/A26 - Two USB
LT/RH/LoneStar - X15/A26 - Two USB Design 217
LT/RH/LoneStar - X15/A26 - USB
LT/RH/LoneStar - X15/A26 - USB Design 219
LT/RH/LoneStar - X15/A26 - Vehicle Alarm System
(Standard)
LT/RH/LoneStar - X15/A26 - Vehicle Alarm System (Standard) Design 220
LT/RH/LoneStar - X15/A26 - Regen Switch Only
xiLT/RH/LoneStar - X15/A26 - Regen Switch Only Design 221
LT/RH/LoneStar - X15/A26 - With Monostable Inhibit
Switch
LT/RH/LoneStar - X15/A26 - With Monostable Inhibit Switch Design 222
LT/RH/LoneStar - X15/A26 - With/ Bi-Stable Inhibit
Switch
LT/RH/LoneStar - X15/A26 - With/ Bi-Stable Inhibit Switch Design 223
LT/RH - A26 - Selective Catalytic Reduction (SCR) ICT
LT/RH - A26 - Selective Catalytic Reduction (SCR) ICT Design 224
LT/RH/LoneStar - X15 - Selective Catalytic Reduction
(SCR)
LT/RH/LoneStar - X15 - Selective Catalytic Reduction (SCR) Design 230
LT/RH/LoneStar - X15/A26 - Adjustable Engine Speed
Control (PTO) 10-pin
LT/RH/LoneStar - X15/A26 - Adjustable Engine Speed Control (PTO) 10-pin
Design 236
Control(PTO) 4-pin
LT/RH/LoneStar - X15/A26 - Adjustable Engine Speed Control(PTO) 4-pin
Design 237
LT/RH/LoneStar - X15/A26 - BODY BUILDER LIGHTING
BLUNT CUTS
LT/RH/LoneStar - X15/A26 - BODY BUILDER LIGHTING BLUNT CUTS
Design 238
LT/RH - A26 - Body Builder Powertrain
LT/RH - A26 - Body Builder Powertrain Design 240
LT/RH/LoneStar - X15/A26 - DLB - Remote Power
Module (2 RPM w/ Switch Packs)
LT/RH/LoneStar - X15/A26 - DLB - Remote Power Module (2 RPM w/ Switch
Packs) Design 241
LT/RH - A26 - Transmission Power Take Off
LT/RH - A26 - Transmission Power Take Off Design 242
LT/RH - A26 - Transmission Power Take Off Dual PTO
with Clutch Interlock
LT/RH - A26 - Transmission Power Take Off Dual PTO with Clutch Interlock
Design 243
Solenoid AUTO
LT/RH - A26 - Transmission Power Take Off Dual Solenoid AUTO Design 244
LT/RH - A26 - Transmission Power Take Off W/ Clutch
Interlock
LT/RH - A26 - Transmission Power Take Off W/ Clutch Interlock Design 245
LT/RH/LoneStar - X15 - Transmission Power Take Off
Dual PTO with Clutch Interlock MANUAL
xiiLT/RH/LoneStar - X15 - Transmission Power Take Off Dual PTO with Clutch
Interlock MANUAL Design 246
Dual Solenoid AUTO
LT/RH/LoneStar - X15 - Transmission Power Take Off Dual Solenoid AUTO
Design 247
W/ Clutch Interlock
LT/RH/LoneStar - X15 - Transmission Power Take Off W/ Clutch Interlock
Design 248
LT/RH/LoneStar - X15 - Transmission SINGLE Power
Take Off MANUAL
LT/RH/LoneStar - X15 - Transmission SINGLE Power Take Off MANUAL
Design 249
LT/RH/LoneStar - X15/A26 - Service Brake Pressure
Without Auxiliary Guage Module
LT/RH/LoneStar - X15/A26 - Service Brake Pressure Without Auxiliary Guage
Module Design 250
With Auxiliary Guage Module
LT/RH/LoneStar - X15/A26 - Service Brake Pressure With Auxiliary Guage
Module Design 251
LT/RH/LoneStar - X15/A26 - Service Brake Switch
LT/RH/LoneStar - X15/A26 - Service Brake Switch Design 252
LT/RH/LoneStar - X15/A26 - Dual Air Dryers
LT/RH/LoneStar - X15/A26 - Dual Air Dryers Design 253
LT/RH/LoneStar - X15/A26 - Left Side Air Dryer-Bendix
LT/RH/LoneStar - X15/A26 - Left Side Air Dryer-Bendix Design 255
LT/RH/LoneStar - X15/A26 - Drain Valve Heater
LT/RH/LoneStar - X15/A26 - Drain Valve Heater Design 257
LoneStar - X15 - Antilock Brake System (ABS) [Bendix
6 Channel Implementation]
LoneStar - X15 - Antilock Brake System (ABS) [Bendix 6 Channel
Implementation] Design 258
Lonestar - X15 - Antilock Brake System (ABS)-BENDIX
4 Channel Implemenation
Lonestar - X15 - Antilock Brake System (ABS)-BENDIX 4 Channel Implemenation
Design 261
LT/RH - X15/A26 - Antilock Brake System (ABS)
LT/RH - X15/A26 - Antilock Brake System (ABS) BENDIX 4 Channel
Implemenation Design 265
Bendix 6 Channel Implementation
LT/RH - X15/A26 - Antilock Brake System (ABS) Bendix 6 Channel
Implementation Design 269
xiiiLoneStar - X15 - Antilock Brake System (ABS) -
Wabco 4 Channel Implementation
LoneStar - X15 - Antilock Brake System (ABS) - Wabco 4 Channel
Implementation Design 272
LoneStar - X15 - Antilock Brake System - Wabco ABS
LoneStar - X15 - Antilock Brake System - Wabco ABS 6 Channel Implementation
Design 276
LT/RH - X15/A26 - Antilock Brake System (ABS) -
LT/RH - X15/A26 - Antilock Brake System (ABS) - Wabco 4 Channel
Implementation Design 279
LT/RH - X15/A26 - Antilock Brake System - Wabco
LT/RH - X15/A26 - Antilock Brake System - Wabco ABS 6 Channel
Implementation Design 283
LT/RH/LoneStar - X15/A26 - Park Brake Controls
Without ECM
LT/RH/LoneStar - X15/A26 - Park Brake Controls Without ECM Design 286
ECM
LT/RH/LoneStar - X15/A26 - Park Brake Controls With ECM Design 287
Gauge Control
LT/RH/LoneStar - X15/A26 - Park Brake Controls With Gauge Control Design 288
LT/RH/LoneStar - X15/A26 - Bendix Tractor or Towing
LT/RH/LoneStar - X15/A26 - Bendix Tractor or Towing Truck Design 289
Truck With/ Air Suspension J1939 Driven Lamp
LT/RH/LoneStar - X15/A26 - Bendix Tractor or Towing Truck With/ Air
Suspension J1939 Driven Lamp Design 291
LT/RH/LoneStar - X15/A26 - Wabco Full Stability
Control
LT/RH/LoneStar - X15/A26 - Wabco Full Stability Control Design 293
LT/RH/LoneStar - X15/A26 - Traction Control (Bendix
Controller) WIthout Electronic Brake
LT/RH/LoneStar - X15/A26 - Traction Control (Bendix Controller) WIthout
Electronic Brake Design 295
Controller) With Electronic Brake
LT/RH/LoneStar - X15/A26 - Traction Control (Bendix Controller) With Electronic
Brake Design 297
LT/RH/LoneStar - X15/A26 - Traction Control (Wabco
Controller)
xivLT/RH/LoneStar - X15/A26 - Traction Control (Wabco Controller) Design 299
LT/RH/LoneStar - X15/A26 - Collision Avoidance
System (Warning)
LT/RH/LoneStar - X15/A26 - Collision Avoidance System (Warning) Design 302
LoneStar - A26 - Lane Departure Warning - (Bendix
Fusion W/Safety Direct))(US & Canada)
LoneStar - A26 - Lane Departure Warning - (Bendix Fusion W/Safety Direct))(US
& Canada) Design 303
LoneStar - X15 - Lane Departure Warning - (Bendix
LoneStar - X15 - Lane Departure Warning - (Bendix Fusion W/Safety Direct))(US
& Canada) Design 304
LT/RH/LoneStar - X15/A26 - Land Departure Warning -
(Bendix - AutoVue W/ Qualcomm Safety Direct)
LT/RH/LoneStar - X15/A26 - Land Departure Warning - (Bendix - AutoVue W/
Qualcomm Safety Direct) Design 305
LT/RH/LoneStar - X15/A26 - Lane Departure Warning -
LT/RH/LoneStar - X15/A26 - Lane Departure Warning - Bendix Fusion W/Safety
Direct Design 306
LT/RH/LoneStar - X15/A26 - Lane Departure Warning - (Bendix Fusion W/Safety
Direct) Design 307
(Bendix - AutoVue N/ Qualcomm Safety Direct)
LT/RH/LoneStar - X15/A26 - Lane Departure Warning - (Bendix - AutoVue N/
Qualcomm Safety Direct) Design 308
(Mobileye Pre-Wire)
LT/RH/LoneStar - X15/A26 - Lane Departure Warning (Mobileye Pre-Wire)
Design 309
(Wabco OnLane)
LT/RH/LoneStar - X15/A26 - Lane Departure Warning - (Wabco OnLane)
Design 310
LT/RH/LoneStar - X15/A26 - Accelerator - Interlock
LT/RH/LoneStar - X15/A26 - Accelerator - Interlock Design 311
LT/RH - A26 - Coolant Level Monitoring
LT/RH - A26 - Coolant Level Monitoring Design 312
LT/RH/Lonestar - X15 - Coolant Level Monitoring
LT/RH/Lonestar - X15 - Coolant Level Monitoring Design 313
LT/RH - A26 - Cooling Fan Control Without Switch
LT/RH - A26 - Cooling Fan Control Without Switch Design 314
xvLT/RH - A26 - Cooling Fan Control With Switch
LT/RH - A26 - Cooling Fan Control With Switch Design 315
LoneStar - X15 -Cooling Fan Control Without Switch
LoneStar - X15 -Cooling Fan Control Without Switch Design 316
LoneStar - X15 - Cooling Fan Control With Switch
LoneStar - X15 - Cooling Fan Control With Switch Design 317
LT/RH - X15 - Cooling Fan Control Without Switch
LT/RH - X15 - Cooling Fan Control Without Switch Design 318
LT/RH - X15 - Cooling Fan Control With Switch
LT/RH - X15 - Cooling Fan Control With Switch Design 319
LT/RH - A26 - Egine Diagnostic Connector
LT/RH - A26 - Egine Diagnostic Connector Design 320
LT/RH - A26 - Engine Diagnostic Connector
LT/RH - A26 - Engine Diagnostic Connector Design 321
LT/RH/LoneStar - X15/A26 - ENGINE IDLE
INCREMENT/DECREMENT 10-pin
LT/RH/LoneStar - X15/A26 - ENGINE IDLE INCREMENT/DECREMENT 10-pin
Design 322
LT/RH/LoneStar - X15/A26 - Engine Idle
Increment/Decrement 4-pin
LT/RH/LoneStar - X15/A26 - Engine Idle Increment/Decrement 4-pin Design 323
LT/RH/LoneStar - X15/A26 - Engine Block Heater
LT/RH/LoneStar - X15/A26 - Engine Block Heater Design 324
LT/RH/LoneStar - X15/A26 - Engine Fuel and Block
Heaters (Purchased Assembly)
LT/RH/LoneStar - X15/A26 - Engine Fuel and Block Heaters (Purchased
Assembly) Design 325
LT/RH/LoneStar - X15/A26 - Engine Oil and Block
LT/RH/LoneStar - X15/A26 - Engine Oil and Block Heaters (Purchased Assembly)
Design 326
LT/RH/LoneStar - X15/A26 - Engine Oil and Fuel and
Block Heaters
LT/RH/LoneStar - X15/A26 - Engine Oil and Fuel and Block Heaters Design 327
LT/RH/LoneStar - X15/A26 - Engine/Exhaust Brake
LT/RH/LoneStar - X15/A26 - Engine/Exhaust Brake Design 328
LT/RH - A26 - Interface Connector
LT/RH - A26 - Interface Connector Design 329
LT/RH - A26 - Starting Aid Flame Start
LT/RH - A26 - Starting Aid Flame Start Design 330
LT/RH/LoneStar - X15 - Starting Aid (Ether Start)
LT/RH/LoneStar - X15 - Starting Aid (Ether Start) Design 331
xviLT/RH - A26 - Vehicle Acceleration (w/ Two PWR Two
GND & Two STS)
LT/RH - A26 - Vehicle Acceleration (w/ Two PWR Two GND & Two STS)
Design 332
LT/RH/LoneStar - X15 - Accelerator Interlock W/ Park
Brake Controls
LT/RH/LoneStar - X15 - Accelerator Interlock W/ Park Brake Controls Design 333
LT/RH/LoneStar - X15 - Vehicle Acceleration w/ Two
PWR Two GND Two STATUS
LT/RH/LoneStar - X15 - Vehicle Acceleration w/ Two PWR Two GND Two
STATUS Design 334
LT/RH/LoneStar - X15/A26 - Vehicle Speed Limit
Override
LT/RH/LoneStar - X15/A26 - Vehicle Speed Limit Override Design 335
LT/RH/LoneStar - X15/A26 - Air Shield Lighting w/ One
Light
LT/RH/LoneStar - X15/A26 - Air Shield Lighting w/ One Light Design 336
LT/RH/LoneStar - X15/A26 - Automatic Lighting - Dual
Sensor Twilight/Solar
LT/RH/LoneStar - X15/A26 - Automatic Lighting - Dual Sensor Twilight/Solar
Design 338
Single Sensor Twilight
LT/RH/LoneStar - X15/A26 - Automatic Lighting - Single Sensor Twilight
Design 339
LT/RH - A26 - Backup Light
LT/RH - A26 - Backup Light Design 340
LT/RH - A26 - Backup LightLT/RH - A26 - Backup Light- Design 342
LT/RH - A26 - Backup Lights (Single Reverse Light)
Eaton/Manual
LT/RH - A26 - Backup Lights (Single Reverse Light) Eaton/Manual Design 344
Eaton/Manual Trans
LT/RH - A26 - Backup Lights (Single Reverse Light) Eaton/Manual Trans
Design 348
Eaton/Manual TransLT/RH - A26 - Backup Lights (Single Reverse Light) Eaton/Manual TransDesign 352
LT/RH - A26 - Backup Light (Single Reverse Light)
W/Allison
LT/RH - A26 - Backup Light (Single Reverse Light) W/Allison Design 356
W/Allison Trans
xviiLT/RH - A26 - Backup Light (Single Reverse Light) W/Allison Trans Design 358
W/AllisonLT/RH - A26 - Backup Light (Single Reverse Light) W/Allison- Design 360
LT/RH - A26/X15 - Backup Lights (Single Reverse
Light) Eaton/Manual Trans Option 1
LT/RH - A26/X15 - Backup Lights (Single Reverse Light) Eaton/Manual Trans
Option 1 Design 362
Light) Eaton/Manual Trans Option 2
Option 2 Design 364
LT/RH - X15 - Backup Light
LT/RH - X15 - Backup Light Design 366
LT/RH - X15 - Backup LightLT/RH - X15 - Backup Light- Design 368
LT/RH/LONESTAR - X15 - Backup Light
LT/RH/LONESTAR - X15 - Backup Light Design 370
LT/RH/LONESTAR - X15 - Backup Lights (Single
LT/RH/LONESTAR - X15 - Backup Lights (Single Reverse Light) Eaton/Manual
Trans Design 372
LT/RH/LoneStar - X15/A26 - Beacon/Strobe Light
LT/RH/LoneStar - X15/A26 - Beacon/Strobe Light Design 374
LT/RH - A26/X15 - Clearance and Identification Lights
(W/ Sunshade)
LT/RH - A26/X15 - Clearance and Identification Lights (W/ Sunshade) Design 376
Lonestar - A26 - Directional Signal (Turn)
W/HEADLIGHTS (HAL-113)
Lonestar - A26 - Directional Signal (Turn) W/HEADLIGHTS (HAL-113) Design 377
LT - X15/A26 - Directional Signal (Turn)
W/HEADLIGHTS (HAL-125)
LT - X15/A26 - Directional Signal (Turn) W/HEADLIGHTS (HAL-125) Design 378
W/HEADLIGHTS (LED-125)
LT - X15/A26 - Directional Signal (Turn) W/HEADLIGHTS (LED-125) Design 379
RH - X15/A26 - Directional Signal (Turn)
RH - X15/A26 - Directional Signal (Turn) W/HEADLIGHTS (HAL-113) Design 380
W/HEADLIGHTS (LED-113)
RH - X15/A26 - Directional Signal (Turn) W/HEADLIGHTS (LED-113) Design 381
LT/RH/LoneStar - X15/A26 - Exterior Lamp Check
LT/RH/LoneStar - X15/A26 - Exterior Lamp Check Design 382
xviiiLT/RH/LoneStar - X15/A26 - Exterior Lighting On
Reminder
LT/RH/LoneStar - X15/A26 - Exterior Lighting On Reminder Design 383
LoneStar - X15 - Front Fog Lamps
LoneStar - X15 - Front Fog Lamps Design 384
LT/RH - A26/X15 - Fog Lights (LED White)
LT/RH - A26/X15 - Fog Lights (LED White) Design 385
LT/RH/LoneStar - X15/A26 - Hazard Warning N/Trailer
Socket
LT/RH/LoneStar - X15/A26 - Hazard Warning N/Trailer Socket Design 386
LoneStar - X15 - Headlights Halogen N/INT N/LOWW
LoneStar - X15 - Headlights Halogen N/INT N/LOWW Design 387
LoneStar - X15 - Headlights Halogen N/INT W/LOWW
LoneStar - X15 - Headlights Halogen N/INT W/LOWW Design 388
LoneStar - X15 - Headlights Halogen W/INT N/LOWW
LoneStar - X15 - Headlights Halogen W/INT N/LOWW Design 389
LoneStar - X15 - Headlights Halogen W/INT W/LOWW
LoneStar - X15 - Headlights Halogen W/INT W/LOWW Design 390
LT - A26/X15 - Headlights(HAL-125) N/INT N/LOWW
LT - A26/X15 - Headlights(HAL-125) N/INT N/LOWW Design 391
LT - A26/X15 - Headlights(HAL-125) N/INT W/LOWW
LT - A26/X15 - Headlights(HAL-125) N/INT W/LOWW Design 392
LT - A26/X15 - Headlights(HAL-125) W/INT N/LOWW
LT - A26/X15 - Headlights(HAL-125) W/INT N/LOWW Design 393
LT - A26/X15 - Headlights(HAL-125) W/INT W/LOWW
LT - A26/X15 - Headlights(HAL-125) W/INT W/LOWW Design 394
RH - A26/X15 - Headlights (HAL-113) N/INT N/LOWW
RH - A26/X15 - Headlights (HAL-113) N/INT N/LOWW Design 395
RH - A26/X15 - Headlights (HAL-113) N/INT W/LOWW
RH - A26/X15 - Headlights (HAL-113) N/INT W/LOWW Design 396
RH - A26/X15 - Headlights (HAL-113) W/INT N/LOWW
RH - A26/X15 - Headlights (HAL-113) W/INT N/LOWW Design 397
RH - A26/X15 - Headlights (HAL-113) W/INT W/LOWW
RH - A26/X15 - Headlights (HAL-113) W/INT W/LOWW Design 398
LT - A26/X15 - Headlights(LED-125) N/ INT N/LOWW
LT - A26/X15 - Headlights(LED-125) N/ INT N/LOWW Design 399
LT - A26/X15 - Headlights(LED-125) N/ INT W/LOWW
LT - A26/X15 - Headlights(LED-125) N/ INT W/LOWW Design 400
LT - A26/X15 - Headlights(LED-125) W/INT N/LOWW
LT - A26/X15 - Headlights(LED-125) W/INT N/LOWW Design 401
xixLT - A26/X15 - Headlights(LED-125) W/INT W/LOWW
LT - A26/X15 - Headlights(LED-125) W/INT W/LOWW Design 402
RH - A26/X15 - Headlights (LED-113) N/INT N/LOWW
RH - A26/X15 - Headlights (LED-113) N/INT N/LOWW Design 403
RH - A26/X15 - Headlights (LED-113) N/INT W/LOWW
RH - A26/X15 - Headlights (LED-113) N/INT W/LOWW Design 404
RH - A26/X15 - Headlights (LED-113) W/INT N/LOWW
RH - A26/X15 - Headlights (LED-113) W/INT N/LOWW Design 405
RH - A26/X15 - Headlights (LED-113) W/INT W/LOWW
RH - A26/X15 - Headlights (LED-113) W/INT W/LOWW Design 406
LT/RH - A26/X15 - License Plate Light Tail Light Single
Assy
LT/RH - A26/X15 - License Plate Light Tail Light Single Assy Design 407
LT/RH - X15 - License Plate Light (Dual LED Lamp Tail
Light)
LT/RH - X15 - License Plate Light (Dual LED Lamp Tail Light) Design 409
LT/RH/LoneStar - X15/A26 - License Plate Light Tail
Light Single Assy
LT/RH/LoneStar - X15/A26 - License Plate Light Tail Light Single Assy Design411
LoneStar - X15 - Marker Lights W/113 Halogen
LoneStar - X15 - Marker Lights W/113 Halogen Design 413
LT - A26/X15 - Marker Lights (W/125 Halogen)
LT - A26/X15 - Marker Lights (W/125 Halogen) Design 414
LT- A26/X15 - Marker Lights (W/125 LED)
LT- A26/X15 - Marker Lights (W/125 LED) Design 415
RH - A26/X15 - Marker Lights (W/113 LED)
RH - A26/X15 - Marker Lights (W/113 LED) Design 416
LoneStar - X15 - Modesty Lighting W/ Day Cab
LoneStar - X15 - Modesty Lighting W/ Day Cab Design 417
LoneStar - X15 - Modesty Lighting W/ Sleeper
LoneStar - X15 - Modesty Lighting W/ Sleeper Design 418
LT/RH - A26/X15 - Modesty Lighting W/ Day Cab
LT/RH - A26/X15 - Modesty Lighting W/ Day Cab Design 419
LT/RH - A26/X15 - Modesty Lighting W/ Sleeper
LT/RH - A26/X15 - Modesty Lighting W/ Sleeper Design 420
LT/RH/LoneStar - X15/A26 - PARK LIGHTS - W/Marker
Interrupt 10pin CLCKSPRING
LT/RH/LoneStar - X15/A26 - PARK LIGHTS - W/Marker Interrupt 10pin
CLCKSPRING Design 421
Interrupt 4 pin clockspring
LT/RH/LoneStar - X15/A26 - PARK LIGHTS - W/Marker Interrupt 4 pin
clockspring Design 422
xxLT/RH - A26/X15 - Skirt Light Customer Supplied
LT/RH - A26/X15 - Skirt Light Customer Supplied Design 423
LT/RH - A26/X15 - Rear Lights Stop - Single Assembly
LT/RH - A26/X15 - Rear Lights Stop - Single Assembly Design 424
LT/RH- X15 - Rear Lights Stop - Dual Assembly
LT/RH- X15 - Rear Lights Stop - Dual Assembly Design 426
LT/RH/LoneStar - X15/A26 - Rear Lights Stop - Single
Assembly
LT/RH/LoneStar - X15/A26 - Rear Lights Stop - Single Assembly Design 428
LT/RH- X15 - Work Lights - LED W/ Sw Pack -
Customer Supplied
LT/RH- X15 - Work Lights - LED W/ Sw Pack - Customer Supplied Design 430
LT/RH - A26 - Work Lights LED W/ Switch Pack - Day
Cab N/ Remote Key W/Manual Reverse
LT/RH - A26 - Work Lights LED W/ Switch Pack - Day Cab N/ Remote Key
W/Manual Reverse Design 432
Cab W/ Remote Key W/Manual Reverse
LT/RH - A26 - Work Lights LED W/ Switch Pack - Day Cab W/ Remote Key
W/Manual Reverse Design 434
LT/RH/LoneStar - X15 - Work Lights LED W/ Switch
Pack - Day Cab N/ Remote Key Entry W/Manual
Reverse
LT/RH/LoneStar - X15 - Work Lights LED W/ Switch Pack - Day Cab N/ Remote
Key Entry W/Manual Reverse Design 436
Pack - Day Cab W/ Remote Key Entry W/Manual
Reverse
LT/RH/LoneStar - X15 - Work Lights LED W/ Switch Pack - Day Cab W/ Remote
Key Entry W/Manual Reverse Design 437
LT/RH/LoneStar - X15/A26 - Work Lights LED W/
LT/RH/LoneStar - X15/A26 - Work Lights LED W/ Switch Pack - Day Cab
Design 438
Switch Pack - Day Cab N/ Remote Key Entry W/Auto
Reverse
LT/RH/LoneStar - X15/A26 - Work Lights LED W/ Switch Pack - Day Cab N/
Remote Key Entry W/Auto Reverse Design 439
Switch Pack - Day Cab W/ Remote Key Entry
LT/RH/LoneStar - X15/A26 - Work Lights LED W/ Switch Pack - Day Cab W/
Remote Key Entry Design 440
xxiLT/RH/LoneStar - X15/A26 - Work Lights LED W/
Switch Pack - Day Cab W/ Remote Key Entry W/Auto
Reverse
Remote Key Entry W/Auto Reverse Design 441
Sleeper W/ Remote Key W/Manual Reverse
LT/RH - A26 - Work Lights LED W/ Switch Pack - Sleeper W/ Remote Key
W/Manual Reverse Design 442
LT/RH - A26 - Work Lights -LED W/ Switch Pack -
Sleeper N/ Remote Key W/Manual Reverse
LT/RH - A26 - Work Lights -LED W/ Switch Pack - Sleeper N/ Remote Key
W/Manual Reverse Design 444
LT/RH - A26 - Work Lights - LED W/ Switch Pack -
Customer Supplied - Sleeper N/ Remote Key
W/Manual Reverse
LT/RH - A26 - Work Lights - LED W/ Switch Pack - Customer Supplied - Sleeper
N/ Remote Key W/Manual Reverse Design 446
Customer Supplied - Sleeper W/ Remote Key
W/Manual Reverse
W/ Remote Key W/Manual Reverse Design 450
Pack - Sleeper N/ Remote Key Entry W/Manual
Reverse
LT/RH/LoneStar - X15 - Work Lights LED W/ Switch Pack - Sleeper N/ Remote
Key Entry W/Manual Reverse Design 454
Pack - Sleeper W/ Remote Key Entry W/Manual
Reverse
LT/RH/LoneStar - X15 - Work Lights LED W/ Switch Pack - Sleeper W/ Remote
Key Entry W/Manual Reverse Design 455
LT/RH/LoneStar - X15 - Work Lights - LED W/ Switch
Pack - Customer Supplied - Sleeper N/ Remote Key
LT/RH/LoneStar - X15 - Work Lights - LED W/ Switch Pack - Customer Supplied -
Sleeper N/ Remote Key Entry W/Manual Reverse Design 456
Pack - Customer Supplied - Sleeper W/ Remote Key
Sleeper W/ Remote Key Entry W/Manual Reverse Design 458
Switch Pack - Sleeper W/ Remote Key Entry W/Auto
Reverse
LT/RH/LoneStar - X15/A26 - Work Lights LED W/ Switch Pack - Sleeper W/
Remote Key Entry W/Auto Reverse Design 460
xxiiLT/RH/LoneStar - X15/A26 - Work Lights -LED W/
LT/RH/LoneStar - X15/A26 - Work Lights -LED W/ Switch Pack - Sleeper
Design 461
Switch Pack - Sleeper N/ Remote Key Entry W/Auto
Reverse
LT/RH/LoneStar - X15/A26 - Work Lights -LED W/ Switch Pack - Sleeper N/
Remote Key Entry W/Auto Reverse Design 462
LT/RH/LoneStar - X15/A26 - Work Lights -LED W/ Switch Pack - Sleeper W/
Remote Key Entry Design 463
LT/RH/LoneStar - X15/A26 - Work Lights - LED W/
Switch Pack - Customer Supplied - Sleeper N/ Remote
Key ENtry W/Auto Reverse
LT/RH/LoneStar - X15/A26 - Work Lights - LED W/ Switch Pack - Customer
Supplied - Sleeper N/ Remote Key ENtry W/Auto Reverse Design 464
Switch Pack - Customer Supplied - Sleeper W/ Remote
Key Entry
Supplied - Sleeper W/ Remote Key Entry Design 466
Supplied - Sleeper W/ Remote Key Entry W/Auto Reverse Design 468
LT/RH - A26 - Work Lights W/ Switch Pack - Customer
Supplied N/ Remote Key W/Manual Reverse
LT/RH - A26 - Work Lights W/ Switch Pack - Customer Supplied N/ Remote Key
W/Manual Reverse Design 470
Supplied W/ Remote Key W/Manual Reverse
LT/RH - A26 - Work Lights W/ Switch Pack - Customer Supplied W/ Remote Key
W/Manual Reverse Design 474
LT/RH/LoneStar - X15 - Work Lights W/ Switch Pack -
Customer Supplied N/ Remote Key Entry W/Manual
Reverse
LT/RH/LoneStar - X15 - Work Lights W/ Switch Pack - Customer Supplied N/
Remote Key Entry W/Manual Reverse Design 478
Customer Supplied W/ Remote Key Entry W/Manual
Reverse
LT/RH/LoneStar - X15 - Work Lights W/ Switch Pack - Customer Supplied W/
Remote Key Entry W/Manual Reverse Design 480
xxiiiLT/RH/LoneStar - X15/A26 - Work Lights W/ Switch
LT/RH/LoneStar - X15/A26 - Work Lights W/ Switch Pack - Customer Supplied
Design 482
Pack - Customer Supplied N/ Remote Key Entry
W/Auto Reverse
LT/RH/LoneStar - X15/A26 - Work Lights W/ Switch Pack - Customer Supplied N/
Remote Key Entry W/Auto Reverse Design 484
Pack - Customer Supplied W/ Remote Key Entry
LT/RH/LoneStar - X15/A26 - Work Lights W/ Switch Pack - Customer Supplied W/
Remote Key Entry Design 486
W/Auto Reverse
Remote Key Entry W/Auto Reverse Design 488
LT/RH/LoneStar - X15/A26 - Fifth Wheel Slide
LT/RH/LoneStar - X15/A26 - Fifth Wheel Slide Design 490
LT/RH/LoneStar - X15/A26 - Jaw Monitoring
LT/RH/LoneStar - X15/A26 - Jaw Monitoring Design 491
LT/RH/LoneStar - X15/A26 - Jaw Unlock Control W/
SOLENOIDS W/SWITCH PACKS
LT/RH/LoneStar - X15/A26 - Jaw Unlock Control W/ SOLENOIDS W/SWITCH
PACKS Design 492
(Standard)
LT/RH/LoneStar - X15/A26 - Jaw Unlock Control (Standard) Design 493
LoneStar - X15 - Fuel Heater (Vehicle Powered)(Davco)
LoneStar - X15 - Fuel Heater (Vehicle Powered)(Davco) Design 494
LT/RH/LoneStar - X15/A26 - Fuel Level (Single Tank -
Left Side)
LT/RH/LoneStar - X15/A26 - Fuel Level (Single Tank - Left Side) Design 495
LT/RH - A26 - Water In Fuel DAVCO N/ Heater
LT/RH - A26 - Water In Fuel DAVCO N/ Heater Design 501
LT/RH - A26 - Water In Fuel Davco W/Heater
LT/RH - A26 - Water In Fuel Davco W/Heater Design 503
LT/RH - A26 - Water In Fuel RACOR N/ Heater
LT/RH - A26 - Water In Fuel RACOR N/ Heater Design 505
LT/RH/LoneStar - X15 - Water In Fuel (WIF) DAVCO N/
Heater
LT/RH/LoneStar - X15 - Water In Fuel (WIF) DAVCO N/ Heater Design 506
xxivLT/RH/LoneStar - X15 - Water In Fuel (WIF) Davco
W/Heater
LT/RH/LoneStar - X15 - Water In Fuel (WIF) Davco W/Heater Design 508
LT/RH/LoneStar - X15 - Water In Fuel (WIF) DAVCO W/
Heater
LT/RH/LoneStar - X15 - Water In Fuel (WIF) DAVCO W/ Heater Design 510
LT/RH/LoneStar - X15 - Water In Fuel (WIF) RACOR N/
Heater
LT/RH/LoneStar - X15 - Water In Fuel (WIF) RACOR N/ Heater Design 512
LT/RH - A26 - Heating Ventilation & Air Conditioning
(HVAC) Auto Temp Control
LT/RH - A26 - Heating Ventilation & Air Conditioning (HVAC) Auto Temp Control
Design 513
LT/RH/LoneStar - X15 - Heating Ventilation & Air
LT/RH/LoneStar - X15 - Heating Ventilation & Air Conditioning (HVAC) Auto
Temp Control Design 517
(HVAC)
LT/RH - A26 - Heating Ventilation & Air Conditioning (HVAC) Design 520
Conditioning (HVAC)
LT/RH/LoneStar - X15 - Heating Ventilation & Air Conditioning (HVAC) Design524
LT/RH/LoneStar - X15/A26 - Rear HVAC (No Idle) W/
Pre-Heat (Bergstrom Heat and Cool w/ Condensation)
2 Switch
LT/RH/LoneStar - X15/A26 - Rear HVAC (No Idle) W/ Pre-Heat (Bergstrom Heat
and Cool w/ Condensation) 2 Switch Design 526
4 Switch
and Cool w/ Condensation) 4 Switch Design 528
Heater) (Espar)
LT/RH/LoneStar - X15/A26 - Rear HVAC (No Idle Heater) (Espar) Design 530
LT/RH/LoneStar - X15/A26 - TRI-PAC No Idle APU
LT/RH/LoneStar - X15/A26 - TRI-PAC No Idle APU Design 531
Heater) (Webasto Smartemp)
LT/RH/LoneStar - X15/A26 - Rear HVAC (No Idle Heater) (Webasto Smartemp)
Design 532
Heater) (Webasto Std N/Swift) N/ Heat Swtich
LT/RH/LoneStar - X15/A26 - Rear HVAC (No Idle Heater) (Webasto Std N/Swift)
N/ Heat Swtich Design 533
xxvLT/RH/LoneStar - X15/A26 - Rear HVAC (No Idle
Heater) (Webasto Std W/Swift) N/ Heat Switch
LT/RH/LoneStar - X15/A26 - Rear HVAC (No Idle Heater) (Webasto Std W/Swift)
N/ Heat Switch Design 534
LT/RH/LoneStar - X15/A26 - Rear HVAC (Sleeper W/
Deluxe)
LT/RH/LoneStar - X15/A26 - Rear HVAC (Sleeper W/ Deluxe) Design 535
Premium)
LT/RH/LoneStar - X15/A26 - Rear HVAC (Sleeper W/ Premium) Design 537
LT/RH - A26 - Air Flow Restriction Monitoring
LT/RH - A26 - Air Flow Restriction Monitoring Design 539
LT/RH/LoneStar - X15 - Air Flow Restriction
Monitoring
LT/RH/LoneStar - X15 - Air Flow Restriction Monitoring Design 541
LT/RH - A26 - Ambient Air Temperature OPTION 1
LT/RH - A26 - Ambient Air Temperature OPTION 1 Design 542
LT/RH - A26 - Ambient Air Temperature OPTION 2
LT/RH - A26 - Ambient Air Temperature OPTION 2 Design 543
LT/RH/LoneStar - X15 - Ambient Air Temperature
Option 1
LT/RH/LoneStar - X15 - Ambient Air Temperature Option 1 Design 544
Option 2
LT/RH/LoneStar - X15 - Ambient Air Temperature Option 2 Design 545
LT/RH/LoneStar - X15/A26 - Auxilary Gauges
(Secondary)
LT/RH/LoneStar - X15/A26 - Auxilary Gauges (Secondary) Design 546
LT/RH/LoneStar - X15/A26 - Auxiliary Gauges
(Primary)
LT/RH/LoneStar - X15/A26 - Auxiliary Gauges (Primary) Design 547
LT/RH/LoneStar - X15/A26 - Compressed Air Supply
LT/RH/LoneStar - X15/A26 - Compressed Air Supply Design 548
(Primary and Secondary Gauge)
LT/RH/LoneStar - X15/A26 - Compressed Air Supply (Primary and Secondary
Gauge) Design 549
LT/RH - A26 - DEF Economy Monitor
LT/RH - A26 - DEF Economy Monitor Design 550
LT/RH/LoneStar - X15 - DEF Economy Monitor
LT/RH/LoneStar - X15 - DEF Economy Monitor Design 551
LT/RH/LoneStar - X15/A26 - Engine Usage Monitoring
(Base)
LT/RH/LoneStar - X15/A26 - Engine Usage Monitoring (Base) Design 552
xxviLT/RH/LoneStar - X15/A26 - Engine Usage Monitoring
(VID Option)
LT/RH/LoneStar - X15/A26 - Engine Usage Monitoring (VID Option) Design 553
LT/RH/LoneStar - X15/A26 - Engine Oil Level
Monitoring
LT/RH/LoneStar - X15/A26 - Engine Oil Level Monitoring Design 554
LT/RH/LoneStar - X15/A26 - Engine Oil Pressure
LT/RH/LoneStar - X15/A26 - Engine Oil Pressure Design 555
LT/RH/LoneStar - X15/A26 - Engine Oil Temperature
(NA-Mux)
LT/RH/LoneStar - X15/A26 - Engine Oil Temperature (NA-Mux) Design 556
Temperature(NA MUX_AUX Gauge)
LT/RH/LoneStar - X15/A26 - Engine Oil Temperature(NA MUX_AUX Gauge)
Design 557
LT/RH/LoneStar - X15/A26 - Engine Speed
(Tachometer J1939)
LT/RH/LoneStar - X15/A26 - Engine Speed (Tachometer J1939) Design 558
LT/RH/LoneStar - X15/A26 - Fuel Economy Monitor
LT/RH/LoneStar - X15/A26 - Fuel Economy Monitor Design 559
LT/RH/LoneStar - X15/A26 - Fuel Idle Usage (W/
Cluster Feedback)
LT/RH/LoneStar - X15/A26 - Fuel Idle Usage (W/ Cluster Feedback) Design 560
LT/RH/LoneStar - X15/A26 - PTO - Fuel and Hours
(Multiplexed)
LT/RH/LoneStar - X15/A26 - PTO - Fuel and Hours (Multiplexed) Design 561
LT/RH/LoneStar - X15/A26 - Transmission Oil Level
(Low Level Warning)
LT/RH/LoneStar - X15/A26 - Transmission Oil Level (Low Level Warning)
Design 562
Temperature (Automatic Trans W/ Aux Gauge)
LT/RH/LoneStar - X15/A26 - Transmission Oil Temperature (Automatic Trans W/
Aux Gauge) Design 563
Temperature (Automatic Trans)
LT/RH/LoneStar - X15/A26 - Transmission Oil Temperature (Automatic Trans)
Design 564
LT/RH - A26 - Transmission Oil Temperature-Manual
Trans OPTION 1
LT/RH - A26 - Transmission Oil Temperature-Manual Trans OPTION 1
Design 565
Trans OPTION 2
xxviiLT/RH - A26 - Transmission Oil Temperature-Manual Trans OPTION 2
Design 568
LT/RH/LoneStar - X15 - Transmission Oil Temperature
Manual Trans Combination 1
LT/RH/LoneStar - X15 - Transmission Oil Temperature Manual Trans
Combination 1 Design 571
Manual Trans Combination 2
Combination 2 Design 574
LT/RH/LoneStar - X15/A26 - Trip Odometer
LT/RH/LoneStar - X15/A26 - Trip Odometer Design 577
LT/RH/LoneStar - X15/A26 - Trip Odometer With/VID
LT/RH/LoneStar - X15/A26 - Trip Odometer With/VID Design 578
LT/RH - A26 - VEHICLE SPEEDOMETER SYSTEM
LT/RH - A26 - VEHICLE SPEEDOMETER SYSTEM Design 579
LT/RH/LoneStar - X15 - Vehicle Speedometer System
LT/RH/LoneStar - X15 - Vehicle Speedometer System Design 581
LT/RH/LoneStar - X15/A26 - Vehicle Speedometer
System (With/ AMT/AUTO TRANS)
LT/RH/LoneStar - X15/A26 - Vehicle Speedometer System (With/ AMT/AUTO
TRANS) Design 582
LT/RH/LoneStar - X15/A26 - Voltage Monitoring
Voltmeter
LT/RH/LoneStar - X15/A26 - Voltage Monitoring Voltmeter Design 583
Voltmeter with Aux gauge
LT/RH/LoneStar - X15/A26 - Voltage Monitoring Voltmeter with Aux gauge
Design 584
LT/RH/LoneStar - X15/A26 - High Exhaust System
Temperature (HEST) Monitoring
LT/RH/LoneStar - X15/A26 - High Exhaust System Temperature (HEST)
Monitoring Design 585
LT/RH/LoneStar - X15/A26 - Power Divider Lock
Control and Monitoring
LT/RH/LoneStar - X15/A26 - Power Divider Lock Control and Monitoring
Design 586
LT/RH/LoneStar - X15/A26 - Up Shift Indicator
LT/RH/LoneStar - X15/A26 - Up Shift Indicator Design 587
LT/RH/LoneStar - X15/A26 - Transmission Range
Inhibit (J1939 Comm)
LT/RH/LoneStar - X15/A26 - Transmission Range Inhibit (J1939 Comm)
Design 588
LT/RH/LoneStar - X15/A26 - Vehicle Information
Display BlueTooth VID
xxviiiLT/RH/LoneStar - X15/A26 - Vehicle Information Display BlueTooth VID
Design 589
Display VID
LT/RH/LoneStar - X15/A26 - Vehicle Information Display VID Design 590
LT/RH/LoneStar - X15/A26 - Cabinet Lights
LT/RH/LoneStar - X15/A26 - Cabinet Lights Design 591
LT/RH/LoneStar - X15/A26 - Courtesy Light Cab
LT/RH/LoneStar - X15/A26 - Courtesy Light Cab Design 592
LT/RH/LoneStar - X15/A26 - Cab Dome Light - Day Cab
LT/RH/LoneStar - X15/A26 - Cab Dome Light - Day Cab Design 593
LT/RH/LoneStar - X15/A26 - Cab Dome Light - Sleeper
LT/RH/LoneStar - X15/A26 - Cab Dome Light - Sleeper Cab Design 594
LT/RH/LoneStar - X15/A26 - Lighting Sleeper Dome
LT/RH/LoneStar - X15/A26 - Lighting Sleeper Dome Design 595
LT/RH/LoneStar - X15/A26 - Floor/Search Lights
DayCab
LT/RH/LoneStar - X15/A26 - Floor/Search Lights DayCab Design 596
Sleeper W/ DOME Switch (1 Light)
LT/RH/LoneStar - X15/A26 - Floor/Search Lights Sleeper W/ DOME Switch (1
Light) Design 597
Sleeper (3 Lights)
LT/RH/LoneStar - X15/A26 - Floor/Search Lights Sleeper (3 Lights) Design 598
LT/RH/LoneStar - X15/A26 - Interior Task Lights Flood
W/Upper& Lower Reading - Sleeper Cab
LT/RH/LoneStar - X15/A26 - Interior Task Lights Flood W/Upper& Lower Reading
- Sleeper Cab Design 599
- DayCab
LT/RH/LoneStar - X15/A26 - Interior Task Lights Flood - DayCab Design 600
LT/RH/LoneStar - X15/A26 - Luggage Compartment
Lights - N/ No Idle HVAC
LT/RH/LoneStar - X15/A26 - Luggage Compartment Lights - N/ No Idle HVAC
Design 601
Lights - W/ No Idle HVAC
LT/RH/LoneStar - X15/A26 - Luggage Compartment Lights - W/ No Idle HVAC
Design 602
LT/RH/LoneStar - X15/A26 - Panel Backlighting (Cabin
Dimmer)
LT/RH/LoneStar - X15/A26 - Panel Backlighting (Cabin Dimmer) Design 603
xxixLT/RH/LoneStar - X15/A26 - Reading Lighting -
W/Lower
LT/RH/LoneStar - X15/A26 - Reading Lighting - W/Lower Design 604
W/Upper& Lower
LT/RH/LoneStar - X15/A26 - Reading Lighting - W/Upper& Lower Design 605
LT/RH/LoneStar - X15/A26 - Rear Interior Dimming
Accent Light
LT/RH/LoneStar - X15/A26 - Rear Interior Dimming Accent Light Design 606
Accent/Mood
LT/RH/LoneStar - X15/A26 - Rear Interior Dimming Accent/Mood Design 607
LT/RH/LoneStar - X15/A26 - Axle Loading (Weight)
Rear
LT/RH/LoneStar - X15/A26 - Axle Loading (Weight) Rear Design 608
LT/RH/LoneStar - X15/A26 - Single Axle Temperature
Monitoring
LT/RH/LoneStar - X15/A26 - Single Axle Temperature Monitoring Design 610
Monitoring w/Aux Gauge
LT/RH/LoneStar - X15/A26 - Single Axle Temperature Monitoring w/Aux Gauge
Design 612
LT/RH/LoneStar - X15/A26 - Tandem Axle Temperature
Monitoring
LT/RH/LoneStar - X15/A26 - Tandem Axle Temperature Monitoring Design 614
LT/RH/LoneStar - X15/A26 - Tandem Axle Temperature Monitoring w/Aux Gauge
Design 616
LT/RH/LoneStar - X15/A26 - Driver Controlled Locking
Differential -FR & RR Axle (DANA)
LT/RH/LoneStar - X15/A26 - Driver Controlled Locking Differential -FR & RR Axle
(DANA) Design 618
Differential -RR Axle (DANA)
LT/RH/LoneStar - X15/A26 - Driver Controlled Locking Differential -RR Axle
(DANA) Design 619
Differential -FR & RR Axle (MERITOR)
(MERITOR) Design 621
Differential -RR Axle (MERITOR)
(MERITOR) Design 622
xxxLT/RH/LoneStar - X15/A26 - Height Control
LT/RH/LoneStar - X15/A26 - Height Control Design 625
LT/RH/LoneStar - X15/A26 - Rear Axle Load
Distribution
LT/RH/LoneStar - X15/A26 - Rear Axle Load Distribution Design 626
LT/RH/LoneStar - X15/A26 - Seats - Climate Controlled
Drivers Heated Seat
LT/RH/LoneStar - X15/A26 - Seats - Climate Controlled Drivers Heated Seat
Design 627
LT/RH/LoneStar - X15/A26 - Seats (RolTek) Drivers
Seat Only Hard Wired With Vinyl Boxing/ Leather
Insert
LT/RH/LoneStar - X15/A26 - Seats (RolTek) Drivers Seat Only Hard Wired With
Vinyl Boxing/ Leather Insert Design 628
Seat Only (Hard Wired) With Mordura
LT/RH/LoneStar - X15/A26 - Seats (RolTek) Drivers Seat Only (Hard Wired) With
Mordura Design 629
Seat Only (Hard Wired) With Vinyl
Vinyl Design 630
LT/RH/LoneStar - X15/A26 - Seatbelt Reminder
Warning Driver only
LT/RH/LoneStar - X15/A26 - Seatbelt Reminder Warning Driver only Design 631
Warning Driver & Passenger in parallel
LT/RH/LoneStar - X15/A26 - Seatbelt Reminder Warning Driver & Passenger in
parallel Design 632
LT/RH/LoneStar - X15/A26 - Auxiliary Trailer Power
Cavity D
LT/RH/LoneStar - X15/A26 - Auxiliary Trailer Power Cavity D Design 633
LT/RH/LoneStar - X15/A26 - Auxiliary Trailer Power W/
ISO Trailer Socket
LT/RH/LoneStar - X15/A26 - Auxiliary Trailer Power W/ ISO Trailer Socket
Design 636
LT/RH/LoneStar - X15/A26 - Mobile Communications
Sensor Wiring Effects for Trailer TRAC 8RHR
LT/RH/LoneStar - X15/A26 - Mobile Communications Sensor Wiring Effects for
Trailer TRAC 8RHR Design 637
LoneStar - X15 - Trailer Interface (ABS) - Center Pin
Circuit
LoneStar - X15 - Trailer Interface (ABS) - Center Pin Circuit Design 639
LT/RH/LoneStar - X15/A26 - Trailer Interface (ABS) -
BOC & EOF_NA
xxxiLT/RH/LoneStar - X15/A26 - Trailer Interface (ABS) - BOC & EOF_NA Design 645
BOC_NA
LT/RH/LoneStar - X15/A26 - Trailer Interface (ABS) - BOC_NA Design 653
Center Pin Circuit
LT/RH/LoneStar - X15/A26 - Trailer Interface (ABS) - Center Pin Circuit
Design 657
TRAMEC_NA
LT/RH/LoneStar - X15/A26 - Trailer Interface (ABS) - TRAMEC_NA Design 663
LT/RH/LoneStar - X15/A26 - Trailer Interface (Lighting)
– BOC_NA
LT/RH/LoneStar - X15/A26 - Trailer Interface (Lighting) – BOC_NA Design 664
– TRAMEC_NA
LT/RH/LoneStar - X15/A26 - Trailer Interface (Lighting) – TRAMEC_NA
Design 667
LT/RH - A26 - Transmission Shifter (Eaton Endurant
and Eaton Procision)
LT/RH - A26 - Transmission Shifter (Eaton Endurant and Eaton Procision)
Design 668
LT/RH - A26 - Transmission Shifter (Universal Shifter -
Ultrashift+ & FAS)
LT/RH - A26 - Transmission Shifter (Universal Shifter - Ultrashift+ & FAS)
Design 669
LT/RH/LoneStar - X15 - Transmission Shifter (Eaton
LT/RH/LoneStar - X15 - Transmission Shifter (Eaton Endurant and Eaton
Procision) Design 670
LT/RH/LoneStar - X15 - Transmission Shifter (Universal Shifter - Ultrashift+ &
FAS) Design 671
LT/RH - A26 - Endurant Transmission
LT/RH - A26 - Endurant Transmission Design 672
LT/RH/LoneStar - X15 - Endurant Transnission
LT/RH/LoneStar - X15 - Endurant Transnission Design 673
LT/RH - A26 - Transmission (Ultrashift+ w/Body
Builder)
LT/RH - A26 - Transmission (Ultrashift+ w/Body Builder) Design 674
LT/RH - A26 - Ultrashift+ and FAS A26
LT/RH - A26 - Ultrashift+ and FAS A26 Design 675
xxxiiLT/RH/LoneStar - X15 - Transmission Ultrashift+
w/Body Builder
LT/RH/LoneStar - X15 - Transmission Ultrashift+ w/Body Builder Design 676
LT/RH/LoneStar - X15 - Ultrashift+ and FAS
LT/RH/LoneStar - X15 - Ultrashift+ and FAS Design 677
LT/RH/LoneStar - X15/A26 - Auto Neutral (J1939
Comms TC10 and Ultrashift)
LT/RH/LoneStar - X15/A26 - Auto Neutral (J1939 Comms TC10 and Ultrashift)
Design 678
LT/RH - A26 - TC10 Series
LT/RH - A26 - TC10 Series Design 679
LT/RH - A26 - Transmission (TC10 Series A65 w/Body
Builder)
LT/RH - A26 - Transmission (TC10 Series A65 w/Body Builder) Design 680
LT/RH/LoneStar - X15/A26 - Hill Start Aid (Bendix)
LT/RH/LoneStar - X15/A26 - Hill Start Aid (Bendix) Design 681
LT/RH/LoneStar - X15/A26 - Hill Start Aid (Wabco)
LT/RH/LoneStar - X15/A26 - Hill Start Aid (Wabco) Design 684
LT/RH/LoneStar - X15/A26 - Transmission - MODE
Selection
LT/RH/LoneStar - X15/A26 - Transmission - MODE Selection Design 685
LT/RH - A26 - Transmission I/O (Endurant Pressure
Sensor)
LT/RH - A26 - Transmission I/O (Endurant Pressure Sensor) Design 686
LT/RH/LoneStar - X15 - Transmission I/O Endurant
Pressure Sensor
LT/RH/LoneStar - X15 - Transmission I/O Endurant Pressure Sensor Design 687
LoneStar - X15 - Windshield Washer Pump
LoneStar - X15 - Windshield Washer Pump Design 688
LoneStar - X15 - Windshield Washer Pump & Low
Fluid Sensor
LoneStar - X15 - Windshield Washer Pump & Low Fluid Sensor Design 689
LT/RH - A26/X15 - Windshield Washer Pump
LT/RH - A26/X15 - Windshield Washer Pump Design 690
LT/RH - A26/X15 - Windshield Washer Pump & Low
Fluid Sensor
LT/RH - A26/X15 - Windshield Washer Pump & Low Fluid Sensor Design 691
LT/RH/LoneStar - X15/A26 - Windshield Wipers
LT/RH/LoneStar - X15/A26 - Windshield Wipers Design 692
LT/RH/LoneStar - X15 - Auto Start Stop AUTO Trans
Cruise Control Message
LT/RH/LoneStar - X15 - Auto Start Stop AUTO Trans Cruise Control Message
Design 693
xxxiiiLT/RH/LoneStar - X15/A26 - Auto Start Stop Auto
Trans and Cruise Control Message
LT/RH/LoneStar - X15/A26 - Auto Start Stop Auto Trans and Cruise Control
Message Design 694
LT/RH/LoneStar - X15 - Auto Start Stop Manual Trans
Cruise Control
LT/RH/LoneStar - X15 - Auto Start Stop Manual Trans Cruise Control Design 695
LT/RH/LoneStar - X15 - Auto Start Stop Manual Trans Cruise Control Message
Design 696
LT/RH/LoneStar - X15/A26 - Auto Start Stop Manual
LT/RH/LoneStar - X15/A26 - Auto Start Stop Manual Trans and Cruise Control
Message Design 697
LT/RH - A26 - Auto Start Stop AUTO TRANS
LT/RH - A26 - Auto Start Stop AUTO TRANS Design 698
LT/RH - A26 - Auto Start Stop Battery & Oil Temp
LT/RH - A26 - Auto Start Stop Battery & Oil Temp Design 699
LT/RH/Lonestar - X15 - Auto Start Stop AUTO Trans
LT/RH/Lonestar - X15 - Auto Start Stop AUTO Trans Design 700
LT/RH/LoneStar - X15/A26 - Battery Disconnect
LT/RH/LoneStar - X15/A26 - Battery Disconnect Design 701
LT/RH - A26 - Bosch LH160 LH200 Alternator DELCO
LT/RH - A26 - Bosch LH160 LH200 Alternator DELCO Design 702
MITSUBISHI
LT/RH - A26 - Bosch LH160 LH200 Alternator MITSUBISHI Design 703
LT/RH - A26 - Bosch LIL165 LIL200 Alternator A26
DEL
LT/RH - A26 - Bosch LIL165 LIL200 Alternator A26 DEL Design 704
MITSUBISHI
LT/RH - A26 - Bosch LIL165 LIL200 Alternator A26 MITSUBISHI Design 705
LT/RH/LoneStar - X15 - Bosch LH160_LH200
LT/RH/LoneStar - X15 - Bosch LH160_LH200 Alternator Design 706
Alternator ISX MITS
LT/RH/LoneStar - X15 - Bosch LH160_LH200 Alternator ISX MITS Design 707
LT/RH/LoneStar - X15 - Bosch LIL165_LIL200
Alternator ISX DEL
LT/RH/LoneStar - X15 - Bosch LIL165_LIL200 Alternator ISX DEL Design 708
xxxivLT/RH/LoneStar - X15 - Bosch LIL165_LIL200
Alternator ISX MITS
LT/RH/LoneStar - X15 - Bosch LIL165_LIL200 Alternator ISX MITS Design 709
LT/RH - A26 - Delco Remy 28SI Alternator
LT/RH - A26 - Delco Remy 28SI Alternator Design 710
LT/RH - A26 - Delco Remy 28SI Alternator MITSUBISHI
LT/RH - A26 - Delco Remy 28SI Alternator MITSUBISHI Design 711
LT/RH - A26 - Delco Remy 36SI Alternator DELCO
LT/RH - A26 - Delco Remy 36SI Alternator DELCO Design 712
LT/RH - A26 - Delco Remy 36SI Alternator MITSUBISHI
LT/RH - A26 - Delco Remy 36SI Alternator MITSUBISHI Design 713
LT/RH - A26 - Delco Remy 40SI Alternator DELCO
OPTION 1
LT/RH - A26 - Delco Remy 40SI Alternator DELCO OPTION 1 Design 714
OPTION 2
LT/RH - A26 - Delco Remy 40SI Alternator DELCO OPTION 2 Design 715
LT/RH - A26 - Delco Remy 40SI Alternator MITSUBISHI
OPTION 1
LT/RH - A26 - Delco Remy 40SI Alternator MITSUBISHI OPTION 1 Design 716
OPTION 2
LT/RH - A26 - Delco Remy 40SI Alternator MITSUBISHI OPTION 2 Design 717
LT/RH/LoneStar - X15 - Delco Remy 28SI Alternator
ISX DEL COMB1
LT/RH/LoneStar - X15 - Delco Remy 28SI Alternator ISX DEL COMB1 Design718
ISX DEL COMB2
LT/RH/LoneStar - X15 - Delco Remy 28SI Alternator ISX DEL COMB2 Design719
ISX MITS COMB1
LT/RH/LoneStar - X15 - Delco Remy 28SI Alternator ISX MITS COMB1
Design 720
ISX MITS COMB2
LT/RH/LoneStar - X15 - Delco Remy 28SI Alternator ISX MITS COMB2
Design 721
LT/RH/LoneStar - X15 - Delco Remy 36SI Alternator
ISX DEL
LT/RH/LoneStar - X15 - Delco Remy 36SI Alternator ISX DEL Design 722
ISX MITS
LT/RH/LoneStar - X15 - Delco Remy 36SI Alternator ISX MITS Design 723
xxxvLT/RH/LoneStar - X15 - Delco Remy 40SI Alternator
ISX DEL COMB1
LT/RH/LoneStar - X15 - Delco Remy 40SI Alternator ISX DEL COMB1 Design724
ISX DEL COMB2
LT/RH/LoneStar - X15 - Delco Remy 40SI Alternator ISX DEL COMB2 Design725
ISX MITS COMB1
LT/RH/LoneStar - X15 - Delco Remy 40SI Alternator ISX MITS COMB1
Design 726
ISX MITS COMB2
LT/RH/LoneStar - X15 - Delco Remy 40SI Alternator ISX MITS COMB2
Design 727
LT/RH - A26 - Leece-Neville AVI160 Alternator DELCO
LT/RH - A26 - Leece-Neville AVI160 Alternator DELCO Design 728
MITSUBISHI
LT/RH - A26 - Leece-Neville AVI160 Alternator MITSUBISHI Design 729
LT/RH - A26 - Leece-Neville AVI160-210A/240A
Alternator A26 DELCO
LT/RH - A26 - Leece-Neville AVI160-210A/240A Alternator A26 DELCO
Design 730
Alternator A26 MITIBISHU
LT/RH - A26 - Leece-Neville AVI160-210A/240A Alternator A26 MITIBISHU
Design 731
LT/RH - A26 - Leece-Neville 320PAH Alternator DELCO
LT/RH - A26 - Leece-Neville 320PAH Alternator DELCO Design 732
MITSUBISHI
LT/RH - A26 - Leece-Neville 320PAH Alternator MITSUBISHI Design 733
LT/RH - A26 - Leece-Neville - LN 325A Alternator A26
DELCO
LT/RH - A26 - Leece-Neville - LN 325A Alternator A26 DELCO Design 734
MITSUBISHI
LT/RH - A26 - Leece-Neville - LN 325A Alternator MITSUBISHI Design 735
LT/RH/LoneStar - X15 - Leece-Neville AVI160
LT/RH/LoneStar - X15 - Leece-Neville AVI160 Alternator Design 736
Alternator ISX MITS
LT/RH/LoneStar - X15 - Leece-Neville AVI160 Alternator ISX MITS Design 737
xxxviLT/RH/LoneStar - X15 - Leece-Neville AVI160-
210A/240A Alternator ISX DEL
LT/RH/LoneStar - X15 - Leece-Neville AVI160-210A/240A Alternator ISX DEL
Design 738
210A/240A Alternator ISX MITS
LT/RH/LoneStar - X15 - Leece-Neville AVI160-210A/240A Alternator ISX MITS
Design 739
LT/RH/LoneStar - X15 - Leece-Neville 320PAH
LT/RH/LoneStar - X15 - Leece-Neville 320PAH Alternator Design 740
Alternator ISX MITS
LT/RH/LoneStar - X15 - Leece-Neville 320PAH Alternator ISX MITS Design 741
LT/RH/LoneStar - X15 - Leece-Neville - LN 325A
Alternator ISX DEL
LT/RH/LoneStar - X15 - Leece-Neville - LN 325A Alternator ISX DEL Design 742
Alternator ISX MITS
LT/RH/LoneStar - X15 - Leece-Neville - LN 325A Alternator ISX MITS Design 743
LoneStar - X15 - Crank Inhibit (with Hood Switch) with
New BODY CONTROL MODULE Pin
LoneStar - X15 - Crank Inhibit (with Hood Switch) with New BODY CONTROL
MODULE Pin Design 744
LT/RH/LoneStar - X15/A26 - Cranking Request BODY
CONTROL MODULE Controlled
LT/RH/LoneStar - X15/A26 - Cranking Request BODY CONTROL MODULE
Controlled Design 745
LT/RH/LoneStar - X15/A26 - Crank Inhibit (Engine
Speed Inhibit Only)
LT/RH/LoneStar - X15/A26 - Crank Inhibit (Engine Speed Inhibit Only) Design 746
LT/RH/LoneStar - X15/A26 - Crank Inhibit (with Hood
Switch) with New BODY CONTROL MODULE Pin
LT/RH/LoneStar - X15/A26 - Crank Inhibit (with Hood Switch) with New BODY
CONTROL MODULE Pin Design 747
LT/RH/LoneStar - A26 - Cranking (Starter) GEN4 BODY
CONTROL MODULE W/O Thermal Overcrank Wiring
LT/RH/LoneStar - A26 - Cranking (Starter) GEN4 BODY CONTROL MODULE
W/O Thermal Overcrank Wiring Design 748
LT/RH/LoneStar - X15 - Cranking (Starter) GEN4 BODY
LT/RH/LoneStar - X15 - Cranking (Starter) GEN4 BODY CONTROL MODULE
W/O Thermal Overcrank Wiring Design 749
xxxviiLT/RH/LoneStar - A26 - Cranking (Starter) GEN4 BODY
CONTROL MODULE W/ Thermal Overcrank - External
Switch
LT/RH/LoneStar - A26 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/
Thermal Overcrank - External Switch Design 750
Switch
LT/RH/LoneStar - X15 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/
Thermal Overcrank - External Switch Design 751
LT/RH/LoneStar - X15/A26 - DC/AC Inverter
LT/RH/LoneStar - X15/A26 - DC/AC Inverter Design 752
LT/RH/LoneStar - X15/A26 - Operator Input
LT/RH/LoneStar - X15/A26 - Operator Input Design 753
LT/RH/LoneStar - X15/A26 - Clutch Monitoring (High
and Low Switch to BCM)
LT/RH/LoneStar - X15/A26 - Clutch Monitoring (High and Low Switch to BCM)
Design 754
LT/RH/LoneStar - X15/A26 - Starter Interlock (BCM
HSD controlled W/ Clutch Switch N/ Auto Start Stop)
LT/RH/LoneStar - X15/A26 - Starter Interlock (BCM HSD controlled W/ Clutch
Switch N/ Auto Start Stop) Design 755
LT/RH - A26 - Starter Interlocks Service Brake
Interlock
LT/RH - A26 - Starter Interlocks Service Brake Interlock Design 756
LT/RH - A26 - Starter Interlocks (BCM controlled with
input from Allison TCM)
LT/RH - A26 - Starter Interlocks (BCM controlled with input from Allison TCM)
Design 757
LT/RH - A26 - Starter Interlock BODY CONTROL
MODULE HSD controlled W/ Clutch Switch W/ Auto
Start Stop
LT/RH - A26 - Starter Interlock BODY CONTROL MODULE HSD controlled W/
Clutch Switch W/ Auto Start Stop Design 758
MODULE LSD Controlled w/ Relay
LT/RH - A26 - Starter Interlock BODY CONTROL MODULE LSD Controlled w/
Relay Design 760
LT/RH/LoneStar - X15 - Starter Interlocks (Service
Brake Interlock)
LT/RH/LoneStar - X15 - Starter Interlocks (Service Brake Interlock) Design 761
LT/RH/LoneStar - X15 - Starter Interlock (BCM HSD
controlled W/ Clutch Switch W/ Auto Start Stop)
LT/RH/LoneStar - X15 - Starter Interlock (BCM HSD controlled W/ Clutch Switch
W/ Auto Start Stop) Design 762
xxxviiiLT/RH/LoneStar - X15 - Starter Interlock (BCM LSD
Controlled w/ Relay) EATON
LT/RH/LoneStar - X15 - Starter Interlock (BCM LSD Controlled w/ Relay) EATON
Design 763
LT/RH/LoneStar - A26 - Battery International 12V
3700CCA
LT/RH/LoneStar - A26 - Battery International 12V 3700CCA Design 764
LT/RH/LoneStar - X15 - Battery International (4) 12V
3700CCA
LT/RH/LoneStar - X15 - Battery International (4) 12V 3700CCA Design 765
LT/RH/LoneStar - X15/A26 - 9 Pin Diagnostic
Connector Green
LT/RH/LoneStar - X15/A26 - 9 Pin Diagnostic Connector Green Design 766
Connector Green Export
LT/RH/LoneStar - X15/A26 - 9 Pin Diagnostic Connector Green Export Design767
Connectors 768
Part Assembly List
Connector Assembly List LT 2648
Index 2945
