Momed80
150
35,046
International Truck LT RH Lonestar Series Interactive Schematics 0000018822 2019
Brand: International, Navistar
Type of Manual: Interactive Schematics
Model: International LT Series, RH Series, Lonestar Series Truck
Built: Before 12/1/2016
Part Number: 0000018822
Publication Date: 2019
Number of Pages: 2624 Pages
9 Pin Diagnostic Connector 500K
9 Pin Diagnostic Connector 500K Design 1
Body Control module (BCM)
Body Control module (BCM) Design 2
Multiplexed Switch Pack (Primary Switch)
Multiplexed Switch Pack (Primary Switch) Design 10
ABS Private J1939
ABS Private J1939 Design 11
Body J1939 (250Kbps)
Body J1939 (250Kbps) Design 12
Cab J1939 (250Kbps)
Cab J1939 (250Kbps) Design 13
Diagnostic Private J1939 A26
Diagnostic Private J1939 A26 Design 14
Engine Private J1939 A26
Engine Private J1939 A26 Design 15
Engine Private J1939 X15
Engine Private J1939 X15 Design 16
Fusion Private J1939
Fusion Private J1939 Design 17
Low Speed J1939 (125Kbps)
Low Speed J1939 (125Kbps) Design 18
Powertrain J1939 (500Kbps) X15
Powertrain J1939 (500Kbps) X15 Design 19
Telematics J1708
Telematics J1708 Design 20
Eaton Ulltrashift
Eaton Ulltrashift Design 21
Endurant
Endurant Design 22
Manual Transmission
Manual Transmission Design 23
TC10 Series
TC10 Series Design 24
A26 - Engine Control Module
A26 - Engine Control Module Design 25
X15 - Engine Control Module
X15 - Engine Control Module Design 27
Auxilary Gauges (Secondary)
Auxilary Gauges (Secondary) Design 28
TABLE OF CONTENTS
iAuxiliary Gauges (Primary)
Auxiliary Gauges (Primary) Design 29
Instrument Cluster (Premium)
Instrument Cluster (Premium) Design 30
Instrument Cluster (Standard)
Instrument Cluster (Standard) Design 31
ABS Splice Packs
ABS Splice Packs Design 32
A26 - Ground Splice Packs
A26 - Ground Splice Packs Design 33
Panel Dimmer Splice Packs
Panel Dimmer Splice Packs Design 38
X15 Ground Splice Packs 3/4
X15 Ground Splice Packs 3/4 Design 39
X15 Ground Splice Packs 4/4
X15 Ground Splice Packs 4/4 Design 41
X15 - Ground Splice Packs 2/4
X15 - Ground Splice Packs 2/4 Design 42
ZVR Splice Packs
ZVR Splice Packs Design 43
Sleeper Ground Splice Packs
Sleeper Ground Splice Packs Design 44
A26 Endurant - Ground Splice Packs
A26 Endurant - Ground Splice Packs Design 46
A26 - Powertrain Ground Splice Packs
A26 - Powertrain Ground Splice Packs Design 47
A26 - Powertrain ZVR Splice Packs
A26 - Powertrain ZVR Splice Packs Design 48
X15 Endurant - Ground Splice Packs
X15 Endurant - Ground Splice Packs Design 49
X15 - Ground Splice Packs 1/4
X15 - Ground Splice Packs 1/4 Design 50
X15 - Powertrain Ground Splice Pack 1 OF 2
X15 - Powertrain Ground Splice Pack 1 OF 2 Design 51
X15 - Powertrain Ground Splice Pack 2 OF 2
X15 - Powertrain Ground Splice Pack 2 OF 2 Design 52
X15 - Powertrain ZVR Splice Packs
X15 - Powertrain ZVR Splice Packs Design 53
Center Chassis Ground Splice Packs
Center Chassis Ground Splice Packs Design 54
TABLE OF CONTENTS
iiCenter Chassis ZVR Splice Packs
Center Chassis ZVR Splice Packs Design 55
Endurant - Center Chassis Ground Splice Packs
Endurant - Center Chassis Ground Splice Packs Design 56
Forward Chassis Ground Splice Packs
Forward Chassis Ground Splice Packs Design 57
Lighting Control Module
Lighting Control Module Design 58
A26 - Powertrain Aftertreatment PDM
A26 - Powertrain Aftertreatment PDM Design 59
X15 - Powertrain Aftertreatment PDM
X15 - Powertrain Aftertreatment PDM Design 60
Grid Management CA2
Grid Management CA2 Design 61
Interior PDM Chart
Interior PDM Chart Design 62
Special Power Distribution
Special Power Distribution Design 63
A26 - Battery Feed 2
A26 - Battery Feed 2 Design 64
X15 - Battery Feed 2
X15 - Battery Feed 2 Design 65
A26 - Battery Feed 1
A26 - Battery Feed 1 Design 66
Endurant - Battery Grid 1 (Non-Loadshed)
Endurant - Battery Grid 1 (Non-Loadshed) Design 68
X15 - Battery Feed 1 - Part 1
X15 - Battery Feed 1 - Part 1 Design 69
X15 - Battery Feed 1 - Part 2
X15 - Battery Feed 1 - Part 2 Design 70
A26 - Key Switch Accessory 2
A26 - Key Switch Accessory 2 Design 71
X15 - Key Switch Accessory 2
X15 - Key Switch Accessory 2 Design 72
A26 - Key Switch Accessory 1
A26 - Key Switch Accessory 1 Design 73
X15 - Key Switch Accessory 1
X15 - Key Switch Accessory 1 Design 74
A26 - Key Switch Ignition 2
A26 - Key Switch Ignition 2 Design 75
TABLE OF CONTENTS
iiiX15 - Key Switch Ignition 2
X15 - Key Switch Ignition 2 Design 76
A26 - Key Switch Ignition 1
A26 - Key Switch Ignition 1 Design 77
X15 - Key Switch Ignition 1
X15 - Key Switch Ignition 1 Design 80
Sleeper PDM
Sleeper PDM Design 82
A26 - Underhood PDM
A26 - Underhood PDM Design 83
X15 Endurant - Underhood PDM
X15 Endurant - Underhood PDM Design 84
X15 - Underhood PDM
X15 - Underhood PDM Design 85
A26 - Fuel Heater (Vehicle Powered)(Davco)
A26 - Fuel Heater (Vehicle Powered)(Davco) Design 86
Engine Oil Fuel and Block Heaters
Engine Oil Fuel and Block Heaters Design 88
Fan - Sleeper/Bunk
Fan - Sleeper/Bunk Design 89
Power Divider Lock Control and Monitoring
Power Divider Lock Control and Monitoring Design 91
Power Windows
Power Windows Design 92
Remote Keyless Entry
Remote Keyless Entry Design 93
Theft Deterrent (Without additional relay)
Theft Deterrent (Without additional relay) Design 94
Auxiliary Air Solenoids 4-pack (1 pack/4 solenoids)
Auxiliary Air Solenoids 4-pack (1 pack/4 solenoids) Design 95
Auxiliary Air Solenoids 4-pack (2 packs/8 solenoids)
Auxiliary Air Solenoids 4-pack (2 packs/8 solenoids) Design 99
Add On:Bluetooth
Add On:Bluetooth Design 103
Radio N/ Wired Remote
Radio N/ Wired Remote Design 104
Radio W/ Wired Remote
Radio W/ Wired Remote Design 105
Speakers:Four Speakers - Daycab
Speakers:Four Speakers - Daycab Design 106
TABLE OF CONTENTS
ivSpeakers:Four Speakers - Sleeper
Speakers:Four Speakers - Sleeper Design 107
Speakers:Speakers W/ Amplifier
Speakers:Speakers W/ Amplifier Design 108
Speakers:Two Speakers
Speakers:Two Speakers Design 109
Std APO-Aux APO-Rear Std APO-Rear APO W/Cover-
12V Panel
Std APO-Aux APO-Rear Std APO-Rear APO W/Cover-12V Panel Design 110
12V Panel-Overhead APO
Std APO-Aux APO-Rear Std APO-Rear APO W/Cover-12V Panel-Overhead APO
Design 114
12V Panel-Upr Bnk APO
Std APO-Aux APO-Rear Std APO-Rear APO W/Cover-12V Panel-Upr Bnk APO
Design 118
Std APO-Aux APO-Rear Std APO-Rear APO w/Cover-
12V Panel-Upr Bnk APO-Rear Overhead APO
Std APO-Aux APO-Rear Std APO-Rear APO w/Cover-12V Panel-Upr Bnk APORear Overhead APO Design 122
Std APO-Rear Std APO-Rear APO W/Cover-12V Panel
Std APO-Rear Std APO-Rear APO W/Cover-12V Panel Design 126
Std APO-Rear Std APO-Rear APO W/Cover-12V PanelRear Overhead APO
Std APO-Rear Std APO-Rear APO W/Cover-12V Panel-Rear Overhead APO
Design 128
Std APO-Rear Std APO-Rear APO W/Cover-12V PanelUpr Bnk APO
Std APO-Rear Std APO-Rear APO W/Cover-12V Panel-Upr Bnk APO Design 130
Std APO-Rear Std APO-Rear APO w/Cover-12V PanelUpr Bnk APO-Rear Overhead APO
Std APO-Rear Std APO-Rear APO w/Cover-12V Panel-Upr Bnk APO-Rear
Overhead APO Design 132
8XBM Single Aux Switch
8XBM Single Aux Switch Design 134
8XBN Dual Aux Switch
8XBN Dual Aux Switch Design 135
Banana Plugs Receptacle
Banana Plugs Receptacle Design 136
CB Radio Power Only
CB Radio Power Only Design 137
CB Radio Power Only (Single Antenna)
CB Radio Power Only (Single Antenna) Design 138
TABLE OF CONTENTS
vCB Radio with Audio Jack for Speakers
CB Radio with Audio Jack for Speakers Design 139
Cigar Lighter- Aux APO-Rear Std APO- Rear APO
w/Cover- 12V Panel- Upr Bnk APO
Cigar Lighter- Aux APO-Rear Std APO- Rear APO w/Cover- 12V Panel- Upr Bnk
APO Design 140
Cigar Lighter- Aux APO- Rear Std APO- Rear APO
W/Cover- 12V Panel
Cigar Lighter- Aux APO- Rear Std APO- Rear APO W/Cover- 12V Panel
Design 144
w/Cover- 12V Panel- Overhead APO
Cigar Lighter- Aux APO- Rear Std APO- Rear APO w/Cover- 12V PanelOverhead APO Design 148
w/Cover- 12V Panel- Upr Bnk APO- Rear Overhead
APO
Cigar Lighter- Aux APO- Rear Std APO- Rear APO w/Cover- 12V Panel- Upr Bnk
APO- Rear Overhead APO Design 152
Cigar Lighter- Rear Std APO- APO W/Cover- 12V Panel
Cigar Lighter- Rear Std APO- APO W/Cover- 12V Panel Design 156
Cigar Lighter- Rear Std APO- Rear APO W/Cover- 12V
Panel- Overhead APO
Cigar Lighter- Rear Std APO- Rear APO W/Cover- 12V Panel- Overhead APO
Design 158
Panel- Upr Bnk APO
Cigar Lighter- Rear Std APO- Rear APO W/Cover- 12V Panel- Upr Bnk APO
Design 160
Cigar Lighter- Rear Std APO- Rear APO w/Cover- 12V
Panel- Upr Bnk APO- Rear Overhead APO
Cigar Lighter- Rear Std APO- Rear APO w/Cover- 12V Panel- Upr Bnk APORear Overhead APO Design 162
Adaptive Cruise Control w/o Display (Wabco)
Adaptive Cruise Control w/o Display (Wabco) Design 164
Adaptive Cruise Control w/o Display(Bendix)
Adaptive Cruise Control w/o Display(Bendix) Design 165
Predictive Cruise Control
Predictive Cruise Control Design 166
Vehicle Speed Control (Cruise Control) 10 - Pin
Vehicle Speed Control (Cruise Control) 10 - Pin Design 167
Vehicle Speed Control (Cruise Control) 4 - PIN
Vehicle Speed Control (Cruise Control) 4 - PIN Design 168
Driver Controlled Locking Differential -FR & RR Axle
Driver Controlled Locking Differential -FR & RR Axle Design 169
TABLE OF CONTENTS
viDriver Controlled Locking Differential -RR Axle
Driver Controlled Locking Differential -RR Axle Design 170
City Horn (N/ Radio Steering Wheel Controls)
City Horn (N/ Radio Steering Wheel Controls) Design 172
City Horn (W/ Radio Steering Wheel Controls)
City Horn (W/ Radio Steering Wheel Controls) Design 173
Door Ajar Reminder (Entry/Exit)
Door Ajar Reminder (Entry/Exit) Design 174
Power Door Locks
Power Door Locks Design 175
Cab Mounted Heated Mirrors (Door Pod Control)
Cab Mounted Heated Mirrors (Door Pod Control) Design 176
Mirrors (Power) (Door Pod Actuated)
Mirrors (Power) (Door Pod Actuated) Design 177
Cabinet Refrigerator N/Relay
Cabinet Refrigerator N/Relay Design 178
Cabinet Refrigerator Omit
Cabinet Refrigerator Omit Design 179
Underbunk Refrigerator N/Relay
Underbunk Refrigerator N/Relay Design 180
Telematics Peoplenet PMG
Telematics Peoplenet PMG Design 181
Telematics PEOPLE NET MD
Telematics PEOPLE NET MD Design 183
Telematics XATANET W/J1939
Telematics XATANET W/J1939 Design 185
Telematics (DRIVERTECH SLEEPER W/ J1939)
Telematics (DRIVERTECH SLEEPER W/ J1939) Design 186
Telematics (OMNIVISION MD)
Telematics (OMNIVISION MD) Design 188
Telematics (PEOPLE NET DAYCAB)
Telematics (PEOPLE NET DAYCAB) Design 190
Telematics (PMG w/ DVR)
Telematics (PMG w/ DVR) Design 192
Telematics (QUALCOMM IMCT DAYCAB W/ MVPC)
Telematics (QUALCOMM IMCT DAYCAB W/ MVPC) Design 193
Telematics (QUALCOMM MCP50)
Telematics (QUALCOMM MCP50) Design 194
Telematics (QUALCOMM MCT w/o Tracs)
Telematics (QUALCOMM MCT w/o Tracs) Design 195
TABLE OF CONTENTS
viiTelematics (QUALCOMM MCT)
Telematics (QUALCOMM MCT) Design 196
Telematics (QUALCOMM TMCT)
Telematics (QUALCOMM TMCT) Design 197
Telematics (TRIPMASTER DAYCAB)
Telematics (TRIPMASTER DAYCAB) Design 198
Telematics (TRIPMASTER SLEEPER)
Telematics (TRIPMASTER SLEEPER) Design 199
Hill Start Aid (Bendix)
Hill Start Aid (Bendix) Design 200
Hill Start Aid (WABCO)
Hill Start Aid (WABCO) Design 203
Two USB
Two USB Design 204
USB
USB Design 206
X15 - Selective Catalytic Reduction SCR ICT
X15 - Selective Catalytic Reduction SCR ICT Design 207
X15 - Selective Catalytic Reduction (SCR)
X15 - Selective Catalytic Reduction (SCR) Design 215
A26 - Back-Up Alarm (Manual) and UltraShift+
A26 - Back-Up Alarm (Manual) and UltraShift+ Design 223
A26 - Back-Up Alarm (Manual) (W/ Tail Light Bar Assy)
A26 - Back-Up Alarm (Manual) (W/ Tail Light Bar Assy) Design 227
Back-Up Alarm (Automatic) TC10
Back-Up Alarm (Automatic) TC10 Design 235
Back-Up Alarm (Automatic) (W/ Tail Light Bar Assy)
Back-Up Alarm (Automatic) (W/ Tail Light Bar Assy) Design 237
X15 - Back-Up Alarm Manual and UltraShift+
X15 - Back-Up Alarm Manual and UltraShift+ Design 241
X15 - Back-Up Alarm Manual W Tail Light Bar Assy
X15 - Back-Up Alarm Manual W Tail Light Bar Assy Design 243
A26 - Body Builder Powertrain
A26 - Body Builder Powertrain Design 247
8WRM TRI-PAC No Idle
8WRM TRI-PAC No Idle Design 248
Adjustable Engine Speed Control PTO 10-pin
Adjustable Engine Speed Control PTO 10-pin Design 249
Adjustable Engine Speed Control PTO 4-pin
Adjustable Engine Speed Control PTO 4-pin Design 250
TABLE OF CONTENTS
viiiAdjustable Engine Speed Control PTO -
W/OMNIVISION - W/J1939 - 1 SW
Adjustable Engine Speed Control PTO - W/OMNIVISION - W/J1939 - 1 SW
Design 251
W/OMNIVISION - W/J1939 - 2 SW
Adjustable Engine Speed Control PTO - W/OMNIVISION - W/J1939 - 2 SW
Design 252
A26 -Transmission Power Take Off Dual PTO with
Clutch Interlock
A26 -Transmission Power Take Off Dual PTO with Clutch Interlock Design 253
A26 - Transmission Power Take Off
A26 - Transmission Power Take Off Design 254
A26 - Transmission Power Take Off Dual Solenoid
A26 - Transmission Power Take Off Dual Solenoid Design 255
A26 - Transmission Power Take Off W/ Clutch
Interlock
A26 - Transmission Power Take Off W/ Clutch Interlock Design 256
X15 - Transmission Power Take Off
X15 - Transmission Power Take Off Design 257
X15 - Transmission Power Take Off Dual PTO with
Clutch Interlock
X15 - Transmission Power Take Off Dual PTO with Clutch Interlock Design 258
X15 - Transmission Power Take Off Dual Solenoid
X15 - Transmission Power Take Off Dual Solenoid Design 259
X15 - Transmission Power Take Off W/ Clutch
Interlock
X15 - Transmission Power Take Off W/ Clutch Interlock Design 260
Drain Valve Heater
Drain Valve Heater Design 261
Dual Air Dryers
Dual Air Dryers Design 262
Left Side Air Dryer-Bendix
Left Side Air Dryer-Bendix Design 264
Antilock Brake System (ABS) [Bendix 6 Channel
Implementation]
Antilock Brake System (ABS) [Bendix 6 Channel Implementation] Design 266
Antilock Brake System (ABS)-BENDIX 4 Channel
Implemenation
Antilock Brake System (ABS)-BENDIX 4 Channel Implemenation Design 269
Bendix Stability Control For Tractor or Tractors with
Trailer Tow
Bendix Stability Control For Tractor or Tractors with Trailer Tow Design 273
TABLE OF CONTENTS
ixBendix Stability Control With Rear Air Suspension No
Lift Axle
Bendix Stability Control With Rear Air Suspension No Lift Axle Design 275
Wabco Full Stability Control
Wabco Full Stability Control Design 278
Antilock Brake System (ABS)-Wabco 4 Channel
Implementation
Antilock Brake System (ABS)-Wabco 4 Channel Implementation Design 280
Antilock Brake System (ABS)-Wabco 6 Channel
Implementation
Antilock Brake System (ABS)-Wabco 6 Channel Implementation Design 284
Traction Control (Bendix Controller)
Traction Control (Bendix Controller) Design 287
Traction Control (Wabco Controller)
Traction Control (Wabco Controller) Design 289
Collision Avoidance System Warning
Collision Avoidance System Warning Design 292
Lane Departure Warning (Mobileye Per-Wire)
Lane Departure Warning (Mobileye Per-Wire) Design 293
Lane Departure Warning - (Bendix - AutoVue W/
Qualcomm Safety Direct)
Lane Departure Warning - (Bendix - AutoVue W/ Qualcomm Safety Direct)
Design 294
Lane Departure Warning - (Wabco OnLane)
Lane Departure Warning - (Wabco OnLane) Design 295
Accelerator - Interlock
Accelerator - Interlock Design 296
Adjustable Engine Speed Control PTO 10-pin n/Marker
interrupt
Adjustable Engine Speed Control PTO 10-pin n/Marker interrupt Design 297
A26 - Cooling Fan Control Two-Speed
A26 - Cooling Fan Control Two-Speed Design 298
A26 - Interface Connector
A26 - Interface Connector Design 299
A26 - Starting Aid (Flame Start)
A26 - Starting Aid (Flame Start) Design 300
Engine Brake Manual Trans MUX Switch
Engine Brake Manual Trans MUX Switch Design 301
Engine/Exhaust Brake
Engine/Exhaust Brake Design 302
Road Speed Limiter
Road Speed Limiter Design 303
TABLE OF CONTENTS
xVehicle Speed Limit Override new Datalink
Vehicle Speed Limit Override new Datalink Design 304
Water In Fuel (WIF) W/ Heater(Davco)
Water In Fuel (WIF) W/ Heater(Davco) Design 305
X15 - Acceleration Pedal
X15 - Acceleration Pedal Design 307
X15 - Accelerator Interlock W/ Park Brake Engagement
X15 - Accelerator Interlock W/ Park Brake Engagement Design 308
X15 - Cooling Fan Control ON/OFF
X15 - Cooling Fan Control ON/OFF Design 309
X15 - Starting Aid Ether Start
X15 - Starting Aid Ether Start Design 310
X15 - Water In Fuel N/ Heater
X15 - Water In Fuel N/ Heater Design 311
X15 - Water In Fuel W Heater
X15 - Water In Fuel W Heater Design 312
X15 - Water In Fuel (WIF) N/ Heater
X15 - Water In Fuel (WIF) N/ Heater Design 314
Air Shield Lighting
Air Shield Lighting Design 315
Beacon/Strobe Light
Beacon/Strobe Light Design 317
Exterior Lamp Reminder
Exterior Lamp Reminder Design 319
Service Brake Switch
Service Brake Switch Design 320
LT - Fog Lights (Halogen White Rear)
LT - Fog Lights (Halogen White Rear) Design 321
LT - Fog Lights (LED White Rear)
LT - Fog Lights (LED White Rear) Design 322
RH - Fog Lights (Halogen White)
RH - Fog Lights (Halogen White) Design 323
RH - Fog Lights (LED White)
RH - Fog Lights (LED White) Design 324
Automatic Lighting
Automatic Lighting Design 325
Day Time Running Lights (Halogen)
Day Time Running Lights (Halogen) Design 326
Day Time Running Lights (LED)
Day Time Running Lights (LED) Design 327
TABLE OF CONTENTS
xiHeadlights (Halogen) N/ Headlamp Interrupt W/
125BBC
Headlights (Halogen) N/ Headlamp Interrupt W/ 125BBC Design 328
Headlights (Halogen) W/ Headlamp Interrupt W/
125BBC
Headlights (Halogen) W/ Headlamp Interrupt W/ 125BBC Design 329
Headlights (LED) N/ Headlamp Interrupt W/ 125BBC
Headlights (LED) N/ Headlamp Interrupt W/ 125BBC Design 330
Headlights (LED) W/ Headlamp Interrupt W/ 125BBC
Headlights (LED) W/ Headlamp Interrupt W/ 125BBC Design 331
Modesty Lighting W/ Sleeper
Modesty Lighting W/ Sleeper Design 332
Skirt Light- Customer Supplied
Skirt Light- Customer Supplied Design 333
A26 - Backup Lights (Dual Reverse Light)
Eaton/Manual Trans
A26 - Backup Lights (Dual Reverse Light) Eaton/Manual Trans Design 334
A26 - Backup Lights (Single Reverse Light)
Eaton/Manual Trans
A26 - Backup Lights (Single Reverse Light) Eaton/Manual Trans Design 338
A26 - Backup Light (Endurant)
A26 - Backup Light (Endurant) Design 342
Trans
Backup Lights (Dual Reverse Light) Eaton/Manual Trans Design 343
Trans
Backup Lights (Single Reverse Light) Eaton/Manual Trans Design 345
Backup Light (Dual Reverse Light)Allison/ZF Trans
Backup Light (Dual Reverse Light)Allison/ZF Trans Design 347
Backup Light (Single Reverse Light)Allison/ZF Trans
Backup Light (Single Reverse Light)Allison/ZF Trans Design 349
Cab Mirror Turn Lights
Cab Mirror Turn Lights Design 351
Clearance and Identification Lights (N/ Sunshade)
Clearance and Identification Lights (N/ Sunshade) Design 352
Front Turn Lights W/ Halogen
Front Turn Lights W/ Halogen Design 353
Front Turn Lights W/ LED
Front Turn Lights W/ LED Design 354
Hazard Warning Lt N/Trlr Socket
Hazard Warning Lt N/Trlr Socket Design 355
TABLE OF CONTENTS
xiiLicense Plate Light (Tail Light Bar Assy.)
License Plate Light (Tail Light Bar Assy.) Design 356
License Plate Light(Weldon LED)
License Plate Light(Weldon LED) Design 358
Park Lights (Halogen/MRKR INT-STRNGWHL)
Park Lights (Halogen/MRKR INT-STRNGWHL) Design 360
Park Lights (LED)
Park Lights (LED) Design 361
Rear Lights Stop - Dual Assembly
Rear Lights Stop - Dual Assembly Design 362
Rear Lights Stop - Single Assembly
Rear Lights Stop - Single Assembly Design 364
Rear Light (Tail Light) (Light Bar ASSY)
Rear Light (Tail Light) (Light Bar ASSY) Design 366
Rear Light (Tail Light) (Light Bar ASSY/MRKR INTSTRNGWHL)
Rear Light (Tail Light) (Light Bar ASSY/MRKR INT-STRNGWHL) Design 368
Rear Light (Tail Light) (Weldon LED)
Rear Light (Tail Light) (Weldon LED) Design 370
Rear Light (Tail Light) (Weldon LED/MRKR INTSTRNGWHL)
Rear Light (Tail Light) (Weldon LED/MRKR INT-STRNGWHL) Design 372
Rear Turn Lights W/ Dual Tail Light Assembly
Rear Turn Lights W/ Dual Tail Light Assembly Design 374
Rear Turn Lights W/ Single Rear Light Assembly
Rear Turn Lights W/ Single Rear Light Assembly Design 376
X15 Backup Light (Endurant)
X15 Backup Light (Endurant) Design 378
Work Lights LED W/ Sw Pack - Day Cab
Work Lights LED W/ Sw Pack - Day Cab Design 379
Work Lights LED W/ Sw Pack - Sleeper
Work Lights LED W/ Sw Pack - Sleeper Design 380
Work Lights LED (Customer Supplied) W/ Sw Pack -
Sleeper
Work Lights LED (Customer Supplied) W/ Sw Pack - Sleeper Design 381
Work Lights (Customer Supplied) W/ Sw Pack
Work Lights (Customer Supplied) W/ Sw Pack Design 383
Fifth Wheel Slide
Fifth Wheel Slide Design 385
TABLE OF CONTENTS
xiiiJaw Monitoring
Jaw Monitoring Design 386
Jaw Unlock Control
Jaw Unlock Control Design 387
A26 - Heating Ventilation & Air Conditioning (HVAC)
A26 - Heating Ventilation & Air Conditioning (HVAC) Design 388
HVAC Assembly Actuators
HVAC Assembly Actuators Design 392
X15 - Heating Ventilation Air Conditioning (HVAC)
X15 - Heating Ventilation Air Conditioning (HVAC) Design 393
Rear HVAC (No Idle Heater) (Espar)
Rear HVAC (No Idle Heater) (Espar) Design 395
Rear HVAC (No Idle Heater) (Webasto Smartemp)
Rear HVAC (No Idle Heater) (Webasto Smartemp) Design 396
Rear HVAC (No Idle Heater) (Webasto Std N/Swift) N/
Heat Swtich
Rear HVAC (No Idle Heater) (Webasto Std N/Swift) N/ Heat Swtich Design 397
Rear HVAC (No Idle Heater) (Webasto Std W/Swift) N/
Heat Switch
Rear HVAC (No Idle Heater) (Webasto Std W/Swift) N/ Heat Switch Design 398
Rear HVAC (Sleeper W/ Deluxe)
Rear HVAC (Sleeper W/ Deluxe) Design 399
Rear HVAC (Sleeper W/ Premium)
Rear HVAC (Sleeper W/ Premium) Design 401
Driver Information Display (DID)
Driver Information Display (DID) Design 403
(Rand Mcnallly) GPS Display
(Rand Mcnallly) GPS Display Design 404
Air Application Pressure Monitoring
Air Application Pressure Monitoring Design 405
A26 - Ambient Air Temperature
A26 - Ambient Air Temperature Design 406
A26 - Vehicle Speedometer System
A26 - Vehicle Speedometer System Design 407
Coolant Temperature Monitoring
Coolant Temperature Monitoring Design 408
Engine Oil Pressure
Engine Oil Pressure Design 409
Engine Oil Temperature
Engine Oil Temperature Design 410
TABLE OF CONTENTS
xivEngine Speed (Tachometer)
Engine Speed (Tachometer) Design 411
Fuel Idle Usage (W/ Cluster Feedback)
Fuel Idle Usage (W/ Cluster Feedback) Design 412
Fuel Level (Single Tank - Left Side)
Fuel Level (Single Tank - Left Side) Design 413
Primary/Secondary Air Gauge
Primary/Secondary Air Gauge Design 419
PTO (Fuel and Hours)
PTO (Fuel and Hours) Design 420
Voltage Monitoring (Voltmeter)
Voltage Monitoring (Voltmeter) Design 421
X15 - Outside temperature monitor
X15 - Outside temperature monitor Design 422
Engine Usage Monitoring (Base)
Engine Usage Monitoring (Base) Design 423
Engine Usage Monitoring (VID Option)
Engine Usage Monitoring (VID Option) Design 424
Intake Manifold Pressure (IMP) (MX1)
Intake Manifold Pressure (IMP) (MX1) Design 425
X15 - Intake Manifold Pressure (IMP)
X15 - Intake Manifold Pressure (IMP) Design 426
X15 - Intake Manifold Pressure (IMP) W/AUX gauge
X15 - Intake Manifold Pressure (IMP) W/AUX gauge Design 427
Single Axle Temperature Monitoring
Single Axle Temperature Monitoring Design 428
Single Axle Temperature Monitoring w/Aux Gauge
Single Axle Temperature Monitoring w/Aux Gauge Design 430
Tandem Axle Temperature Monitoring
Tandem Axle Temperature Monitoring Design 432
Tandem Axle Temperature Monitoring w/Aux Gauge
Tandem Axle Temperature Monitoring w/Aux Gauge Design 434
A26 - Transmission Oil Temperature-Manual Trans
A26 - Transmission Oil Temperature-Manual Trans Design 436
Transmission Oil Temperature-Automatic Trans
Transmission Oil Temperature-Automatic Trans Design 439
Transmission Oil Temperature-Manual Trans Design 440
Air Flow Restriction Monitoring GEN IV BCM
Air Flow Restriction Monitoring GEN IV BCM Design 443
TABLE OF CONTENTS
xvAuto Neutral J1939 Based for Allison TC10/ Eaton
Ultrashift
Auto Neutral J1939 Based for Allison TC10/ Eaton Ultrashift Design 444
A26 - Air Flow Restriction Monitoring
A26 - Air Flow Restriction Monitoring Design 445
A26 - Coolant Level Monitoring
A26 - Coolant Level Monitoring Design 447
Driver Reward
Driver Reward Design 448
Engine Oil Level Monitoring (ECM)
Engine Oil Level Monitoring (ECM) Design 449
Engine Warning
Engine Warning Design 450
Odometer (via BCM/EGC)
Odometer (via BCM/EGC) Design 451
Park Brake (Monitoring)(US & Canada)
Park Brake (Monitoring)(US & Canada) Design 452
Tire Pressure (TPMS) (US & Canada)
Tire Pressure (TPMS) (US & Canada) Design 453
Up Shift Indicator
Up Shift Indicator Design 454
X15 - Coolant Level Monitoring
X15 - Coolant Level Monitoring Design 455
X15 - High Exhaust System Temperature (HEST)
Monitoring
X15 - High Exhaust System Temperature (HEST) Monitoring Design 456
A26 - Exhaust Gas Temperature – Pyrometer AUX
Gauge
A26 - Exhaust Gas Temperature – Pyrometer AUX Gauge Design 457
A26 - Exhaust Gas Temperature – Pyrometer Cluster
A26 - Exhaust Gas Temperature – Pyrometer Cluster Design 458
X15 - Exhaust Gas Temperature – Pyrometer AUX
Gauge
X15 - Exhaust Gas Temperature – Pyrometer AUX Gauge Design 459
X15 - Exhaust Gas Temperature – Pyrometer Cluster
X15 - Exhaust Gas Temperature – Pyrometer Cluster Design 460
Trip Odometer w/ECM
Trip Odometer w/ECM Design 461
Trip Odometer w/ECM & TCM
Trip Odometer w/ECM & TCM Design 462
Trip Odometer W/VID
Trip Odometer W/VID Design 463
TABLE OF CONTENTS
xviCab Dome Light (Sleeper Cab)
Cab Dome Light (Sleeper Cab) Design 464
Courtesy Light Cab
Courtesy Light Cab Design 465
Floor/Search Lights DayCab
Floor/Search Lights DayCab Design 466
Floor/Search Lights SLPR
Floor/Search Lights SLPR Design 467
Interior Task Lights (Flood) W/Upper& Lower Reading
LT - Sleeper Cab
Interior Task Lights (Flood) W/Upper& Lower Reading LT - Sleeper Cab
Design 468
Interior Task Lights (Flood) - DayCab
Interior Task Lights (Flood) - DayCab Design 469
Lighting Sleeper Dome
Lighting Sleeper Dome Design 470
Lighting - Cabinet Lights
Lighting - Cabinet Lights Design 471
Luggage Compartment Lights - N/ No Idle HVAC
Luggage Compartment Lights - N/ No Idle HVAC Design 472
Luggage Compartment Lights - W/ No Idle HVAC
Luggage Compartment Lights - W/ No Idle HVAC Design 473
Rear Interior Dimming (Accent Light)
Rear Interior Dimming (Accent Light) Design 474
Rear Interior Dimming (Accent/Mood)
Rear Interior Dimming (Accent/Mood) Design 475
Seatbelt Reminder (Warning)(Driver only)
Seatbelt Reminder (Warning)(Driver only) Design 476
Seatbelt Reminder (Warning)(Driver & Passenger in
parallel)
Seatbelt Reminder (Warning)(Driver & Passenger in parallel) Design 477
Axle Loading (Weight) Rear
Axle Loading (Weight) Rear Design 478
Height Control
Height Control Design 480
Rear Axle Load Distribution
Rear Axle Load Distribution Design 481
Auxiliary Trailer Power Cavity D
Auxiliary Trailer Power Cavity D Design 482
Trailer Interface (ABS) - BOC & EOF_NA
Trailer Interface (ABS) - BOC & EOF_NA Design 486
TABLE OF CONTENTS
xviiTrailer Interface (ABS) - BOC_NA
Trailer Interface (ABS) - BOC_NA Design 494
Trailer Interface (Lighting) – BOC & EOF
Trailer Interface (Lighting) – BOC & EOF Design 498
Trailer Interface (Lighting) – BOC_NA
Trailer Interface (Lighting) – BOC_NA Design 504
Trailer Interface (Lighting) – TRAMEC_NA
Trailer Interface (Lighting) – TRAMEC_NA Design 507
A26 - Transmission Control Module (TC10 Series A65)
A26 - Transmission Control Module (TC10 Series A65) Design 508
A26 - Transmission I/O (Endurant Pressure Sensor)
A26 - Transmission I/O (Endurant Pressure Sensor) Design 509
A26 - Transmission Shifter (Eaton Endurant and Eaton
Procision)
A26 - Transmission Shifter (Eaton Endurant and Eaton Procision) Design 510
A26 - Ultrashift+ and FAS
A26 - Ultrashift+ and FAS Design 511
Transmission Shifter Allison
Transmission Shifter Allison Design 512
Transmission Shifter Universal Shifter - Ultrashift+ &
FAS
Transmission Shifter Universal Shifter - Ultrashift+ & FAS Design 513
Transmission Ultrashift+ w/Body Builder
Transmission Ultrashift+ w/Body Builder Design 514
X15 Endurant Transmission
X15 Endurant Transmission Design 516
X15 Transmission I/O (Endurant Pressure Sensor)
X15 Transmission I/O (Endurant Pressure Sensor) Design 517
X15 - Transmission Shifter (Eaton Endurant and Eaton
Procision)
X15 - Transmission Shifter (Eaton Endurant and Eaton Procision) Design 518
X15 - Ultrashift+ and FAS
X15 - Ultrashift+ and FAS Design 519
Windshield Washer Low Fluid Sensor
Windshield Washer Low Fluid Sensor Design 520
Windshield Washer Pump
Windshield Washer Pump Design 521
Windshield Wipers
Windshield Wipers Design 522
TABLE OF CONTENTS
xviiiA26 - Battery International (4) 12V 3700CCA
A26 - Battery International (4) 12V 3700CCA Design 523
DC/AC Inverter
DC/AC Inverter Design 524
Electrical Load Control W/ Fuse
Electrical Load Control W/ Fuse Design 525
Electrical Load Control W/ Relay
Electrical Load Control W/ Relay Design 526
X15 - Battery International (4) 12V 3700CCA
X15 - Battery International (4) 12V 3700CCA Design 527
A26 - Bosch LH160 LH200 Alternator
A26 - Bosch LH160 LH200 Alternator Design 528
A26 - Bosch LIL165 LIL200 Alternator
A26 - Bosch LIL165 LIL200 Alternator Design 529
A26 - Delco Remy 28SI Alternator
A26 - Delco Remy 28SI Alternator Design 530
A26 - Delco Remy 36SI Alternator
A26 - Delco Remy 36SI Alternator Design 531
A26 - Delco Remy 40SI Alternator
A26 - Delco Remy 40SI Alternator Design 532
A26 - Leece-Neville AVI160 Alternator
A26 - Leece-Neville AVI160 Alternator Design 534
A26 - Leece-Neville AVI160-210A/240A Alternator
A26 - Leece-Neville AVI160-210A/240A Alternator Design 535
A26 - Leece-Neville 320PAH Alternator
A26 - Leece-Neville 320PAH Alternator Design 536
A26 - Leece-Neville - LN 325A Alternator
A26 - Leece-Neville - LN 325A Alternator Design 537
X15 - Bosch LH160_LH200 Alternator1
X15 - Bosch LH160_LH200 Alternator1 Design 538
X15 - Leece-Neville AVI160 Alternator
X15 - Leece-Neville AVI160 Alternator Design 539
X15 - Leece-Neville AVI160-210A/240A Alternator
X15 - Leece-Neville AVI160-210A/240A Alternator Design 540
X15 - Leece-Neville 320PAH Alternator
X15 - Leece-Neville 320PAH Alternator Design 541
Auto Start Stop Battery & Oil Temp
Auto Start Stop Battery & Oil Temp Design 542
A26 Endurant - Starter Interlocks (Service Brake
Interlock)
A26 Endurant - Starter Interlocks (Service Brake Interlock) Design 543
TABLE OF CONTENTS
xixA26 - Cranking (Starter) W/ Thermal Overcrank -
External Switch
A26 - Cranking (Starter) W/ Thermal Overcrank - External Switch Design 544
A26 - Starter Interlock (BCM HSD controlled W/ Clutch
Switch W/ Auto Start Stop)
A26 - Starter Interlock (BCM HSD controlled W/ Clutch Switch W/ Auto Start Stop)
Design 551
Clutch Monitoring (High and Low Switch to BCM)
Clutch Monitoring (High and Low Switch to BCM) Design 553
Cranking Request (w/ Key Switch w/ BCM)
Cranking Request (w/ Key Switch w/ BCM) Design 554
Cranking (Starter) GEN4 BCM W/ Thermal Overcrank -
External Switch
Cranking (Starter) GEN4 BCM W/ Thermal Overcrank - External Switch
Design 555
Cranking (Starter) W/O Thermal Overcrank Wiring
(A26)
Cranking (Starter) W/O Thermal Overcrank Wiring (A26) Design 558
Crank Inhibit (with ECM --> BCM ONLY)
Crank Inhibit (with ECM --> BCM ONLY) Design 565
Crank Inhibit (with Hood Switch) with new BCM Pin
Crank Inhibit (with Hood Switch) with new BCM Pin Design 566
Starter Interlocks (BCM controlled with input from
Allison TCM)
Starter Interlocks (BCM controlled with input from Allison TCM) Design 567
Switch N/ Auto Start Stop)
Starter Interlock (BCM HSD controlled W/ Clutch Switch N/ Auto Start Stop)
Design 568
Starter Interlock (BCM LSD Controlled w/
Relay)_EATON XMSN
Starter Interlock (BCM LSD Controlled w/ Relay)_EATON XMSN Design 569
X15 Endurant - Starter Interlocks (Service Brake
Interlock)
X15 Endurant - Starter Interlocks (Service Brake Interlock) Design 570
X15 - Starter Interlock (BCM HSD controlled W/ Clutch
X15 - Starter Interlock (BCM HSD controlled W/ Clutch Switch W/ Auto Start Stop)
Design 571
Connectors 572
Part Assembly List
Connector Assembly List 2101
Index 2583
