Momed80
150
35,046
International Truck LT RH LoneStar Series Interactive Schematics 00000018832 2025
Brand: International, Navistar
Type of Manual: Interactive Schematics
Model: International LT Series, RH Series, LoneStar Series Truck
Built: 12/10/2021 To 12/31/2025
Part Number: 00000018832
Publication Date: 2025
Number of Pages: 3819 Pages
LT/RH/LoneStar - X15/A26 - BCM (Body Control
Module)
LT/RH/LoneStar - X15/A26 - BODY CONTROL MODULE (Body Control Module)
Design 1
ABS Private J1939
ABS Private J1939 Design 9
Body Standard J1939 (250kbps) - 03/2023 and Newer
Models
Body Standard J1939 (250kbps) - 03/2023 and Newer Models Design 10
Cab J1939 (250Kbps)
Cab J1939 (250Kbps) Design 11
Diagnostic Proprietary J1939 A26
Diagnostic Proprietary J1939 A26 Design 12
Engine Private J1939 A26
Engine Private J1939 A26 Design 13
Engine Private J1939 X15
Engine Private J1939 X15 Design 14
Fusion Private J1939 - Pre 03/2023 Models
Fusion Private J1939 - Pre 03/2023 Models Design 15
Fusion Proprietary J1939 - 03/2023 and Newer Models
Fusion Proprietary J1939 - 03/2023 and Newer Models Design 16
Low Speed J1939 (125Kbps)
Low Speed J1939 (125Kbps) Design 17
Powertrain Standard J1939 A26 - 08/2023 and Newer
Models
Powertrain Standard J1939 A26 - 08/2023 and Newer Models Design 18
Powertrain Standard J1939 X15 - 04/2024 and Newer
Models
Powertrain Standard J1939 X15 - 04/2024 and Newer Models Design 19
Telematics J1708
Telematics J1708 Design 20
Body J1939 (250Kbps) Splice Pack 1024
Body J1939 (250Kbps) Splice Pack 1024 Design 21
Body J1939 (250Kbps) Splice Pack 1025
Body J1939 (250Kbps) Splice Pack 1025 Design 22
Body J1939 (250Kbps) Splice Pack 1029
Body J1939 (250Kbps) Splice Pack 1029 Design 23
Body J1939 (250Kbps) W/3 Splice Packs
Body J1939 (250Kbps) W/3 Splice Packs Design 24
Powertrain J1939 (500Kbps) A26 - Pre 08/2023 Models
Powertrain J1939 (500Kbps) A26 - Pre 08/2023 Models Design 25
TABLE OF CONTENTS
iPowertrain J1939 (500Kbps) Eaton Ultrashift+
Transmission X15
Powertrain J1939 (500Kbps) Eaton Ultrashift+ Transmission X15 Design 26
Powertrain J1939 (500Kbps) Endurant Transmission
X15
Powertrain J1939 (500Kbps) Endurant Transmission X15 Design 27
Powertrain J1939 (500Kbps) Manual Transmission X15
Powertrain J1939 (500Kbps) Manual Transmission X15 Design 28
Powertrain J1939 (500Kbps) TC10 Transmission X15
Powertrain J1939 (500Kbps) TC10 Transmission X15 Design 29
LT/RH/LoneStar - X15/A26 - 9 Pin Diagnostic
Connector (Green)
LT/RH/LoneStar - X15/A26 - 9 Pin Diagnostic Connector (Green) Design 30
Connector (Green)(Export)
LT/RH/LoneStar - X15/A26 - 9 Pin Diagnostic Connector (Green)(Export)
Design 31
LT/RH - Navistar A26 ECM
LT/RH - Navistar A26 ECM Design 32
LT/RH/LoneStar - Cummins X15 ECM
LT/RH/LoneStar - Cummins X15 ECM Design 33
LT/RH/LoneStar - X15/A26 - Instrument Cluster
(Premium)
LT/RH/LoneStar - X15/A26 - Instrument Cluster (Premium) Design 34
(Standard)
LT/RH/LoneStar - X15/A26 - Instrument Cluster (Standard) Design 35
LT/RH/LoneStar - X15/A26 - Instrument Cluster - Bulb
Check
LT/RH/LoneStar - X15/A26 - Instrument Cluster - Bulb Check Design 36
Request and Status
LT/RH/LoneStar - X15/A26 - Instrument Cluster - Request and Status Design 37
LT/RH/LoneStar - X15/A26 - Cab Ground Studs
LT/RH/LoneStar - X15/A26 - Cab Ground Studs Design 38
LT/RH/LoneStar - X15/A26 - Ground Splice Packs -
1022 & 1023
LT/RH/LoneStar - X15/A26 - Ground Splice Packs - 1022 & 1023 Design 39
1027
LT/RH/LoneStar - X15/A26 - Ground Splice Packs - 1027 Design 40
LT/RH/LoneStar - X15/A26 - Ground Splice Pack 1620
LT/RH/LoneStar - X15/A26 - Ground Splice Pack 1620 Design 41
TABLE OF CONTENTS
iiLT/RH/LoneStar - X15/A26 - Sleeper Ground Splice
Packs - 5007
LT/RH/LoneStar - X15/A26 - Sleeper Ground Splice Packs - 5007 Design 42
LT/RH/LoneStar - X15/A26 - Center Chassis Ground
Splice Packs - 8803 & 8804
LT/RH/LoneStar - X15/A26 - Center Chassis Ground Splice Packs - 8803 & 8804
Design 43
LT/RH/LoneStar - X15/A26 - Center Chassis ZVR
Splice Packs - 8802
LT/RH/LoneStar - X15/A26 - Center Chassis ZVR Splice Packs - 8802 Design 44
LT/RH/LoneStar - X15/A26 - Forward Chassis Ground
Splice Packs - 8800
LT/RH/LoneStar - X15/A26 - Forward Chassis Ground Splice Packs - 8800
Design 45
LT/RH - A26 - Powertrain Ground Splice Pack 6704
LT/RH - A26 - Powertrain Ground Splice Pack 6704 Design 47
LT/RH - A26 - Powertrain ZVR Splice Pack 6702
LT/RH - A26 - Powertrain ZVR Splice Pack 6702 Design 48
LT/RH/LoneStar X15 - Powertrain Ground Splice
Packs - 6704 & 6704A
LT/RH/LoneStar X15 - Powertrain Ground Splice Packs - 6704 & 6704A Design49
LT/RH/LoneStar X15 - ZVR Splice Packs - 6702 & 6703
LT/RH/LoneStar X15 - ZVR Splice Packs - 6702 & 6703 Design 50
LT/RH/LoneStar - X15/A26 - Lighting Control Module
LT/RH/LoneStar - X15/A26 - Lighting Control Module Design 51
LT/RH A26 - Aftertreatment PDM
LT/RH A26 - Aftertreatment PDM Design 52
LT/RH/LoneStar X15 - Aftertreatment PDM
LT/RH/LoneStar X15 - Aftertreatment PDM Design 53
Battery Feed
Battery Feed Design 54
Interior PDM Chart
Interior PDM Chart Design 55
Key Switch Accessory
Key Switch Accessory Design 56
Key Switch Ignition
Key Switch Ignition Design 57
Relays - Grid Management (N/Load Shed Day Cab)
Relays - Grid Management (N/Load Shed Day Cab) Design 58
Relays - Grid Management (W/Load Shed Day Cab)
Relays - Grid Management (W/Load Shed Day Cab) Design 59
Relays - Grid Management (W/Load Shed Sleeper Cab)
TABLE OF CONTENTS
iiiRelays - Grid Management (W/Load Shed Sleeper Cab) Design 60
LT/RH/LoneStar - X15/A26 - ABS CAN Splice Pack -
1410
LT/RH/LoneStar - X15/A26 - ABS CAN Splice Pack - 1410 Design 61
LT/RH/LoneStar - X15/A26 - Front Turn Signal & BackUp Light Splice Packs - 1030 & 1040
LT/RH/LoneStar - X15/A26 - Front Turn Signal & Back-Up Light Splice Packs -
1030 & 1040 Design 62
LT/RH/LoneStar - X15/A26 - Marker/Park Lights Splice
Pack - 1028
LT/RH/LoneStar - X15/A26 - Marker/Park Lights Splice Pack - 1028 Design 63
LT/RH/LoneStar - X15/A26 - Panel Dimmer Splice Pack
- 1021
LT/RH/LoneStar - X15/A26 - Panel Dimmer Splice Pack - 1021 Design 64
LT/RH/LoneStar - X15/A26 - Sleeper PDM
LT/RH/LoneStar - X15/A26 - Sleeper PDM Design 65
LT/RH/LoneStar - X15/A26 - Special Power Distribution
LT/RH/LoneStar - X15/A26 - Special Power Distribution Design 66
LT/RH - A26 - Underhood PDM
LT/RH - A26 - Underhood PDM Design 67
LT/RH/LoneStar X15 - IP Underhood PDM
LT/RH/LoneStar X15 - IP Underhood PDM Design 68
LT/RH/LoneStar - X15/A26 - Auxiliary Air Solenoids 4-
pack (1 pack/4 solenoids)
LT/RH/LoneStar - X15/A26 - Auxiliary Air Solenoids 4-pack (1 pack/4 solenoids)
Design 69
pack (2 packs/8 solenoids)
LT/RH/LoneStar - X15/A26 - Auxiliary Air Solenoids 4-pack (2 packs/8 solenoids)
Design 74
LT/RH - X15/A26 - Radio N/ Sterring Wheel Pod N/
Remote
LT/RH - X15/A26 - Radio N/ Sterring Wheel Pod N/ Remote Design 79
LT/RH - X15/A26 - Radio W/Steering Wheel Pod N/
Remote
LT/RH - X15/A26 - Radio W/Steering Wheel Pod N/ Remote Design 80
LT/RH/LoneStar - X15/A26 - Radio N/ Steering Wheel
Pod W/Remote
LT/RH/LoneStar - X15/A26 - Radio N/ Steering Wheel Pod W/Remote Design 81
LT/RH/LoneStar - X15/A26 - Radio W/Steering Wheel
Pod W/Remote
LT/RH/LoneStar - X15/A26 - Radio W/Steering Wheel Pod W/Remote Design 82
TABLE OF CONTENTS
ivLT/RH/LoneStar - X15/A26 - Radio (Bluetooth)
W/Steering Wheel Pod N/ Remote W/MIC
LT/RH/LoneStar - X15/A26 - Radio (Bluetooth) W/Steering Wheel Pod N/ Remote
W/MIC Design 83
LT/RH/LoneStar - X15/A26 - Radio(Bluetooth)
W/Steering Wheel W/Remote W/MIC
LT/RH/LoneStar - X15/A26 - Radio(Bluetooth) W/Steering Wheel W/Remote
W/MIC Design 84
LT/RH LoneStar - X15/A26 - Speakers: Four Speakers
N/BT N/QC
LT/RH LoneStar - X15/A26 - Speakers:Four Speakers N/BT N/QC Design 85
N/BT W/QC
LT/RH LoneStar - X15/A26 - Speakers:Four Speakers N/BT W/QC Design 87
LT/RH LoneStar - X15/A26 - Speakers: Speakers N/BT
W/AMP N/QC
LT/RH LoneStar - X15/A26 - Speakers:Speakers N/BT W/AMP N/QC Design 89
W/BT N/QC
LT/RH LoneStar - X15/A26 - Speakers:Four Speakers W/BT N/QC Design 90
W/BT W/QC
LT/RH LoneStar - X15/A26 - Speakers:Four Speakers W/BT W/QC Design 92
LT/RH LoneStar - X15/A26 - Speakers: Speakers W/BT
W/AMP N/QC
LT/RH LoneStar - X15/A26 - Speakers:Speakers W/BT W/AMP N/QC Design 94
LT/RH/LoneStar - X15/A26 - Dual Aux Switch
LT/RH/LoneStar - X15/A26 - Dual Aux Switch Design 95
LT/RH/LoneStar - X15/A26 - Single Aux Switch
LT/RH/LoneStar - X15/A26 - Single Aux Switch Design 96
LT/RH/LoneStar - X15/A26 - Back-Up Alarm
(Automatic) (W/ Tail Light Bar Assy)
LT/RH/LoneStar - X15/A26 - Back-Up Alarm (Automatic) (W/ Tail Light Bar Assy)
Design 98
LT/RH - A26/X15 - Backup Alarm (Direct from Relay to
Alarm Connector)
LT/RH - A26/X15 - Backup Alarm (Direct from Relay to Alarm Connector)
Design 100
LT/RH - A26/X15 - Backup Alarm (Relay to 6 Pin
Tailboard Backup Alarm Plugs in)
LT/RH - A26/X15 - Backup Alarm (Relay to 6 Pin Tailboard Backup Alarm Plugs
in) Design 105
LT/RH A26 - Back-Up Alarm (Manual) and UltraShift+
LT/RH A26 - Back-Up Alarm (Manual) and UltraShift+ Design 107
TABLE OF CONTENTS
vLT/RH A26 - Back-Up Alarm (Manual) (W/ Tail Light
Bar Assy)
LT/RH A26 - Back-Up Alarm (Manual) (W/ Tail Light Bar Assy) Design 115
LT/RH - A26 - Back-Up Alarm (Manual) W/ Tailboard
LT/RH - A26 - Back-Up Alarm (Manual) W/ Tailboard Design 119
LT/RH/LoneStar X15 - Back-Up Alarm (Manual) and
UltraShift+
LT/RH/LoneStar X15 - Back-Up Alarm (Manual) and UltraShift+ Design 121
LT/RH/LoneStar X15 - Back-Up Alarm (Manual) (W/ Tail
Light Bar Assy)
LT/RH/LoneStar X15 - Back-Up Alarm (Manual) (W/ Tail Light Bar Assy)
Design 125
LT/RH/LoneStar - X15/A26 - Banana Plugs Receptacle
LT/RH/LoneStar - X15/A26 - Banana Plugs Receptacle Design 127
Camera (LYTX Prewire) W/Event Recording Button
Camera (LYTX Prewire) W/Event Recording Button Design 128
LT/RH/LoneStar - X15/A26 - CB Radio Power Only
LT/RH/LoneStar - X15/A26 - CB Radio Power Only Design 130
LT/RH - X15/A26 - Auxiliary Power Source (Sleeper) - 4
APO, 1 USB
LT/RH - X15/A26 - Auxiliary Power Source (Sleeper) - 4 APO, 1 USB Design 131
LT/RH - X15/A26 - Auxiliary Power Source (Sleeper) - 5
APO, 1 USB
LT/RH - X15/A26 - Auxiliary Power Source (Sleeper) - 5 APO, 1 USB Design 134
LT/RH - X15/A26 - Forward Auxiliary Power Source (1
APO)
LT/RH - X15/A26 - Forward Auxiliary Power Source (1 APO) Design 135
LT/RH - X15/A26 - Forward Auxiliary Power Source (2
APO)
LT/RH - X15/A26 - Forward Auxiliary Power Source (2 APO) Design 138
LT/RH/LoneStar - X15/A26 - Cigar Lighter
LT/RH/LoneStar - X15/A26 - Cigar Lighter Design 141
LT/RH/LoneStar - X15/A26 - Cigar Lighter Aux APO
LT/RH/LoneStar - X15/A26 - Cigar Lighter Aux APO Design 142
Overhead APO
LT/RH/LoneStar - X15/A26 - Cigar Lighter Aux APO Overhead APO Design 144
Rear Std APO Rear APO W/Cover 12V Panel
LT/RH/LoneStar - X15/A26 - Cigar Lighter Aux APO Rear Std APO Rear APO
W/Cover 12V Panel Design 146
TABLE OF CONTENTS
viLT/RH/LoneStar - X15/A26 - Cigar Lighter Aux APO
Rear Std APO Rear APO w/Cover 12V Panel Overhead
APO
w/Cover 12V Panel Overhead APO Design 150
Rear Std APO Rear APO w/Cover 12V Panel Upr Bnk
APO
w/Cover 12V Panel Upr Bnk APO Design 154
APO Rear Overhead APO
w/Cover 12V Panel Upr Bnk APO Rear Overhead APO Design 158
LT/RH/LoneStar - X15/A26 - Cigar Lighter Overhead
APO
LT/RH/LoneStar - X15/A26 - Cigar Lighter Overhead APO Design 162
LT/RH/LoneStar - X15/A26 - Cigar Lighter Rear Std
APO APO W/Cover 12V Panel
LT/RH/LoneStar - X15/A26 - Cigar Lighter Rear Std APO APO W/Cover 12V
Panel Design 163
APO Rear APO W/Cover 12V Panel Overhead APO
LT/RH/LoneStar - X15/A26 - Cigar Lighter Rear Std APO Rear APO W/Cover 12V
Panel Overhead APO Design 165
APO Rear APO W/Cover 12V Panel Upr Bnk APO
Panel Upr Bnk APO Design 167
APO Rear APO w/Cover 12V Panel Upr Bnk APO Rear
Overhead APO
LT/RH/LoneStar - X15/A26 - Cigar Lighter Rear Std APO Rear APO w/Cover 12V
Panel Upr Bnk APO Rear Overhead APO Design 169
LT/RH/LoneStar - X15/A26 - Forward Auxiliary Power
Source (3 APO)
LT/RH/LoneStar - X15/A26 - Forward Auxiliary Power Source (3 APO) Design 171
LT/RH/LoneStar - X15/A26 - Standard APO
LT/RH/LoneStar - X15/A26 - Standard APO Design 172
LT/RH/LoneStar - X15/A26 - Standard APO Aux APO
LT/RH/LoneStar - X15/A26 - Standard APO Aux APO Design 173
Overhead APO
LT/RH/LoneStar - X15/A26 - Standard APO Aux APO Overhead APO Design 175
TABLE OF CONTENTS
viiLT/RH/LoneStar - X15/A26 - Standard APO Overhead
APO
LT/RH/LoneStar - X15/A26 - Standard APO Overhead APO Design 177
LT/RH/LoneStar - X15/A26 - Std APO Aux APO Rear
LT/RH/LoneStar - X15/A26 - Std APO Aux APO Rear Std APO Rear APO
W/Cover 12V Panel Design 178
Std APO Rear APO W/Cover 12V Panel Overhead APO
W/Cover 12V Panel Overhead APO Design 182
Std APO Rear APO W/Cover 12V Panel Upr Bnk APO
W/Cover 12V Panel Upr Bnk APO Design 186
Std APO Rear APO w/Cover 12V Panel Upr Bnk APO
Rear Overhead APO
w/Cover 12V Panel Upr Bnk APO Rear Overhead APO Design 190
LT/RH/LoneStar - X15/A26 - Std APO Rear Std APO
LT/RH/LoneStar - X15/A26 - Std APO Rear Std APO Rear APO W/Cover 12V
Panel Design 194
Rear APO W/Cover 12V Panel Rear Overhead APO
Panel Rear Overhead APO Design 196
Panel Upr Bnk APO Design 198
Overhead APO
LT/RH/LoneStar - X15/A26 - Std APO Rear Std APO Rear APO w/Cover 12V
Panel Upr Bnk APO Rear Overhead APO Design 200
LT/RH - A26/X15 - Vehicle Speed Control (Cruise
Control) (Steering Wheel Controls, No PIM)
LT/RH - A26/X15 - Vehicle Speed Control (Cruise Control) (Steering Wheel
Controls, No PIM) Design 202
Control) (Steering Wheel Controls, W/PIM)
Controls, W/PIM) Design 203
LT/RH - X15/A26 - 10 PIN ClockSpring
LT/RH - X15/A26 - 10 PIN ClockSpring Design 204
TABLE OF CONTENTS
viiiLT/RH/LoneStar - X15/A26 - Vehicle Speed Control
(Cruise Control) 4 - PIN
LT/RH/LoneStar - X15/A26 - Vehicle Speed Control (Cruise Control) 4 - PIN
Design 205
LT/RH/LoneStar - X15/A26 - Door Ajar Reminder
(Entry/Exit)
LT/RH/LoneStar - X15/A26 - Door Ajar Reminder (Entry/Exit) Design 206
LT/RH/LoneStar - X15/A26 - Power Door Locks
LT/RH/LoneStar - X15/A26 - Power Door Locks Design 207
LT/RH - X15/A26 - Mirrors (Heat) [Switch Pack
Actuated Relay Driven]
LT/RH - X15/A26 - Mirrors (Heat) [Switch Pack Actuated Relay Driven] Design208
LT/RH/LoneStar - X15/A26 - Heated Mirrors (Door Pod
Actuated Cab and Hood Mounted)
LT/RH/LoneStar - X15/A26 - Heated Mirrors (Door Pod Actuated Cab and Hood
Mounted) Design 209
Actuated Cab Mounted)
LT/RH/LoneStar - X15/A26 - Heated Mirrors (Door Pod Actuated Cab Mounted)
Design 210
LT/RH/LoneStar - X15/A26 - Mirrors (Power) [Door Pod
Actuated]
LT/RH/LoneStar - X15/A26 - Mirrors (Power) [Door Pod Actuated] Design 211
LT/RH/LoneStar - X15/A26 - Mirror Lighting (Turns
without Door Pods)
LT/RH/LoneStar - X15/A26 - Mirror Lighting (Turns without Door Pods) Design212
with Door Pods)
LT/RH/LoneStar - X15/A26 - Mirror Lighting (Turns with Door Pods) Design 213
LT/RH/LoneStar - X15/A26 - Power Windows
LT/RH/LoneStar - X15/A26 - Power Windows Design 214
LoneStar - X15 - City Horn W/ 10PIN CLK W/O RKA
LoneStar - X15 - City Horn W/ 10PIN CLK W/O RKA Design 215
LoneStar - X15 - City Horn W/ 10PIN CLK W/RKA
LoneStar - X15 - City Horn W/ 10PIN CLK W/RKA Design 216
LoneStar - X15 - City Horn W/ 4PIN CLK W/O RKA
LoneStar - X15 - City Horn W/ 4PIN CLK W/O RKA Design 217
LoneStar - X15 - City Horn W/ 4PIN CLK W/RKA
LoneStar - X15 - City Horn W/ 4PIN CLK W/RKA Design 218
LT/RH - X15/A26 - City Horn W/ 10PIN CLK W/O RKA
LT/RH - X15/A26 - City Horn W/ 10PIN CLK W/O RKA Design 219
LT/RH - X15/A26 - City Horn W/ 10PIN CLK W/RKA
LT/RH - X15/A26 - City Horn W/ 10PIN CLK W/RKA Design 220
TABLE OF CONTENTS
ixLT/RH - X15/A26 - City Horn W/ 4PIN CLK W/O RKA
LT/RH - X15/A26 - City Horn W/ 4PIN CLK W/O RKA Design 221
LT/RH - X15/A26 - City Horn W/ 4PIN CLK W/RKA
LT/RH - X15/A26 - City Horn W/ 4PIN CLK W/RKA Design 222
LT/RH LoneStar - X15/A26 - Fan - Sleeper/Bunk
LT/RH LoneStar - X15/A26 - Fan - Sleeper/Bunk Design 223
LT/RH/LoneStar - X15/A26 - (Rand Mcnallly) GPS
Display
LT/RH/LoneStar - X15/A26 - (Rand Mcnallly) GPS Display Design 224
LT A26/X15 Hadley Smart Valve - 14WCS
LT A26/X15 Hadley Smart Valve - 14WCS Design 225
LT/RH/LoneStar - X15/A26 - Multiplexed Switch Pack
(Primary Switch)
LT/RH/LoneStar - X15/A26 - Multiplexed Switch Pack (Primary Switch) Design226
LT/RH/LoneStar - X15/A26 - Real Time Clock (RTC)
(Standard)
LT/RH/LoneStar - X15/A26 - Real Time Clock (RTC) (Standard) Design 227
LT/RH/LoneStar - X15/A26 - Cabinet Refrigerator
N/Relay
LT/RH/LoneStar - X15/A26 - Cabinet Refrigerator N/Relay Design 228
W/Relay
LT/RH/LoneStar - X15/A26 - Cabinet Refrigerator W/Relay Design 229
LT/RH/LoneStar - X15/A26 - Refrigerator (Power and
Ground Only)
LT/RH/LoneStar - X15/A26 - Refrigerator (Power and Ground Only) Design 230
LT/RH/LoneStar - X15/A26 - Refrigerator (Switch
Control)
LT/RH/LoneStar - X15/A26 - Refrigerator (Switch Control) Design 231
LT/RH/LoneStar - X15/A26 - Underbunk Refrigerator
N/Relay
LT/RH/LoneStar - X15/A26 - Underbunk Refrigerator N/Relay Design 232
LT/RH/LoneStar - X15/A26 - Remote Keyless Access
LT/RH/LoneStar - X15/A26 - Remote Keyless Access Design 233
LT/RH - X15/A26 - Rock Free Transmission
LT/RH - X15/A26 - Rock Free Transmission Design 234
LT/RH/LoneStar - X15/A26 - Telematics (DRIVERTECH
DAYCAB W/ J1939)
LT/RH/LoneStar - X15/A26 - Telematics (DRIVERTECH DAYCAB W/ J1939)
Design 235
SLEEPER W/ J1939)
TABLE OF CONTENTS
xLT/RH/LoneStar - X15/A26 - Telematics (DRIVERTECH SLEEPER W/ J1939)
Design 236
LT/RH/LoneStar - X15/A26 - Antenna (Film Antenna
Sleeper Cab OTAPM and Radio)
LT/RH/LoneStar - X15/A26 - Antenna (Film Antenna Sleeper Cab OTAPM and
Radio) Design 237
LT/RH/LoneStar - X15/A26 - Antenna (Shark Fin Day
LT/RH/LoneStar - X15/A26 - Antenna (Shark Fin Day Cab OTAPM and Radio)
Design 238
LT/RH/LoneStar - X15/A26 - Navistar Telematics
Module - Programming
LT/RH/LoneStar - X15/A26 - Navistar Telematics Module - Programming
Design 239
Module - Wiring
LT/RH/LoneStar - X15/A26 - Navistar Telematics Module - Wiring Design 240
LT/RH/LoneStar - X15/A26 - Telematics (OMNIVISION
MD)
LT/RH/LoneStar - X15/A26 - Telematics (OMNIVISION MD) Design 241
W/ J1939 & PANIC BUTTON)
LT/RH/LoneStar - X15/A26 - Telematics (OMNIVISION W/ J1939 & PANIC
BUTTON) Design 243
LT/RH/LoneStar - X15/A26 - Telematics: OnCommand
Telematics Module
LT/RH/LoneStar - X15/A26 - Telematics:OnCommand Telematics Module
Design 245
LT/RH/LoneStar - X15/A26 - Telematics (PEOPLE NET
DAYCAB)
LT/RH/LoneStar - X15/A26 - Telematics (PEOPLE NET DAYCAB) Design 246
SLEEPER)
LT/RH/LoneStar - X15/A26 - Telematics (PEOPLE NET SLEEPER) Design 247
LT/RH/LoneStar - X15/A26 - Telematics QUALCOMM
IMCT DAYCAB With MVPC
LT/RH/LoneStar - X15/A26 - Telematics QUALCOMM IMCT DAYCAB With
MVPC Design 248
IMCT DAYCAB With MVPC & PANIC BUTTON
MVPC & PANIC BUTTON Design 249
IMCT DAYCAB With PANIC BUTTON
TABLE OF CONTENTS
xiLT/RH/LoneStar - X15/A26 - Telematics QUALCOMM IMCT DAYCAB With
PANIC BUTTON Design 250
IMCT MD
LT/RH/LoneStar - X15/A26 - Telematics QUALCOMM IMCT MD Design 252
TMCT
LT/RH/LoneStar - X15/A26 - Telematics QUALCOMM TMCT Design 254
TMCT With PANIC BUTTON
LT/RH/LoneStar - X15/A26 - Telematics QUALCOMM TMCT With PANIC
BUTTON Design 255
LT/RH/LoneStar - X15/A26 - Telematics (QUALCOMM
MCP50)
LT/RH/LoneStar - X15/A26 - Telematics (QUALCOMM MCP50) Design 256
MCT w/o Tracs)
LT/RH/LoneStar - X15/A26 - Telematics (QUALCOMM MCT w/o Tracs)
Design 257
MCT w/ TRACS)
LT/RH/LoneStar - X15/A26 - Telematics (QUALCOMM MCT w/ TRACS)
Design 258
LT/RH/LoneStar - X15/A26 - Telematics (TRIPMASTER
DAYCAB)
LT/RH/LoneStar - X15/A26 - Telematics (TRIPMASTER DAYCAB) Design 259
SLEEPER)
LT/RH/LoneStar - X15/A26 - Telematics (TRIPMASTER SLEEPER) Design 260
LT/RH/LoneStar - X15/A26 - Theft Deterrent (Standard
J1939 Mux SW)
LT/RH/LoneStar - X15/A26 - Theft Deterrent (Standard J1939 Mux SW)
Design 261
LoneStar - X15 - Tire Pressure (TPMS) (US & Canada)
LoneStar - X15 - Tire Pressure (TPMS) (US & Canada) Design 262
LT/RH - X15/A26 - Tire Pressure Monitoring
(TPMS)(LDL Technology)
LT/RH - X15/A26 - Tire Pressure Monitoring (TPMS)(LDL Technology) Design263
LT/RH - X15/A26 - Tire Pressure (TPMS) (LDL 2.0 - 1
Repeater)
LT/RH - X15/A26 - Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater) Design 266
LT/RH - X15/A26 - Tire Pressure (TPMS) (US &
Canada)
LT/RH - X15/A26 - Tire Pressure (TPMS) (US & Canada) Design 269
TABLE OF CONTENTS
xiiLT/RH - X15/A26 - Aux Power (USB) - 1 USB A, 1 USB
C
LT/RH - X15/A26 - Aux Power (USB) - 1 USB A, 1 USB C Design 270
LT/RH - X15/A26 - Aux Power (USB) - 2 USB A, 2 USB
C
LT/RH - X15/A26 - Aux Power (USB) - 2 USB A, 2 USB C Design 273
LT/RH - X15/A26 - Aux Power (USB) - 3 USB A, 3 USB
C
LT/RH - X15/A26 - Aux Power (USB) - 3 USB A, 3 USB C Design 276
LT/RH/LoneStar - X15/A26 - 1 USB
LT/RH/LoneStar - X15/A26 - 1 USB Design 277
LT/RH/LoneStar - X15/A26 - 2 USB
LT/RH/LoneStar - X15/A26 - 2 USB Design 278
LT/RH/LoneStar - Vehicle Accessory Connector -
0008XMB
LT/RH/LoneStar - Vehicle Accessory Connector - 0008XMB Design 280
LT/RH/LoneStar - X15/A26 - Vehicle Sleep Mode
LT/RH/LoneStar - X15/A26 - Vehicle Sleep Mode Design 281
LT/RH - A26 - DPF Regen Switch Only
LT/RH - A26 - DPF Regen Switch Only Design 282
LT/RH - A26 - DPF With Monostable Inhibit Switch
LT/RH - A26 - DPF With Monostable Inhibit Switch Design 283
LT/RH - A26 - DPF With/ Bi-Stable Inhibit Switch
LT/RH - A26 - DPF With/ Bi-Stable Inhibit Switch Design 284
LT/RH/LoneStar - X15 - DPF Regen Switch Only
LT/RH/LoneStar - X15 - DPF Regen Switch Only Design 285
LT/RH/LoneStar - X15 - DPF With Monostable Inhibit
Switch
LT/RH/LoneStar - X15 - DPF With Monostable Inhibit Switch Design 286
LT/RH/LoneStar - X15 - DPF With/ Bi-Stable Inhibit
Switch
LT/RH/LoneStar - X15 - DPF With/ Bi-Stable Inhibit Switch Design 287
LT/RH - A26 - Selective Catalytic Reduction (SCR) -
(Built 11/01/2021-12/10/2021)
LT/RH - A26 - Selective Catalytic Reduction (SCR) - (Built 11/01/2021-
12/10/2021) Design 288
(Built 12/10/2021 and Newer Models)
LT/RH - A26 - Selective Catalytic Reduction (SCR) - (Built 12/10/2021 and Newer
Models) Design 290
LT/RH/LoneStar - X15 - Selective Catalytic Reduction
(SCR)
LT/RH/LoneStar - X15 - Selective Catalytic Reduction (SCR) Design 295
TABLE OF CONTENTS
xiiiLT/RH - X15/A26 - Airbag (Driver Seat and Passenger
Seat)
LT/RH - X15/A26 - Airbag (Driver Seat and Passenger Seat) Design 300
LT/RH - X15/A26 - Airbag (Driver Seat Only)
LT/RH - X15/A26 - Airbag (Driver Seat Only) Design 302
LT/RH - X15/A26 - Airbag (Driver Seat, Passenger
Seat, and Steering Wheel)
LT/RH - X15/A26 - Airbag (Driver Seat, Passenger Seat, and Steering Wheel)
Design 303
LT/RH - X15/A26 - Airbag (Steering Wheel and Driver
Seat)
LT/RH - X15/A26 - Airbag (Steering Wheel and Driver Seat) Design 305
LT/RH - X15/A26 - Airbag (Steering Wheel Only)
LT/RH - X15/A26 - Airbag (Steering Wheel Only) Design 306
LT/RH - X15/A26 - Steering Wheel W/Air Bag
LT/RH - X15/A26 - Steering Wheel W/Air Bag Design 307
LT/RH/LoneStar - X15/A26 - Seats (RollTek) Driver and
Passenger (Hard Wired)
LT/RH/LoneStar - X15/A26 - Seats (RollTek) Driver and Passenger (Hard Wired)
Design 308
LT/RH/LoneStar - X15/A26 - Seats (RolTek) Drivers
Seat Only (Hard Wired) - Leather
LT/RH/LoneStar - X15/A26 - Seats (RolTek) Drivers Seat Only (Hard Wired) -
Leather Design 309
Seat Only (Hard Wired) - Mordura
Mordura Design 310
Seat Only (Hard Wired) - Vinyl
Vinyl Design 311
LT/RH - A26/X15 - Engine Speed Control (PTO)
(Steering Wheel Controls)
LT/RH - A26/X15 - Engine Speed Control (PTO) (Steering Wheel Controls)
Design 312
LT/RH/LoneStar - X15/A26 - Adjustable Engine Speed
Control (PTO) 10-PIN ClockSpring
LT/RH/LoneStar - X15/A26 - Adjustable Engine Speed Control (PTO) 10-PIN
ClockSpring Design 313
Control (PTO) 4-pin Clockspring
LT/RH/LoneStar - X15/A26 - Adjustable Engine Speed Control (PTO) 4-pin
Clockspring Design 314
TABLE OF CONTENTS
xivLoneStar - X15 - Body Builder Lighting - (BOC EOF In
Cab) (8HAB 8HAE 8HAU) (Automatic)
LoneStar - X15 - Body Builder Lighting - (BOC EOF In Cab) (8HAB 8HAE 8HAU)
(Automatic) Design 315
LT/RH A26/X15 - Body Builder Lighting - (BOC, EOF,
In Cab) (8HAB, 8HAE, 8HAU) (Automatic)
LT/RH A26/X15 - Body Builder Lighting - (BOC, EOF, In Cab) (8HAB, 8HAE,
8HAU) (Automatic) Design 317
LT/RH - X15/A26 - Body Builder Lighting - (BOC EOF
In Cab) (8HAB 8HAE 8HAU) (Automatic)
LT/RH - X15/A26 - Body Builder Lighting - (BOC EOF In Cab) (8HAB 8HAE
8HAU) (Automatic) Design 319
LT/RH/LoneStar - X15/A26 - Body Builder Lighting -
(Blunt Cut)
LT/RH/LoneStar - X15/A26 - Body Builder Lighting - (Blunt Cut) Design 321
Cab) (8HAB 8HAE 8HAU) (Manual)
(Manual) Design 323
LT/RH - A26 - Body Builder Lighting - (BOC EOF In
LT/RH - A26 - Body Builder Lighting - (BOC EOF In Cab) (8HAB 8HAE 8HAU)
(Manual) Design 325
LT/RH - X15 - Body Builder Lighting - (BOC EOF In
LT/RH - X15 - Body Builder Lighting - (BOC EOF In Cab) (8HAB 8HAE 8HAU)
(Manual) Design 327
LT/RH - A26 - Powertrain Body Builder Connector
(A26 Engine MD1 N/Ultrashift TCM)
LT/RH - A26 - Powertrain Body Builder Connector (A26 Engine MD1 N/Ultrashift
TCM) Design 329
LT/RH/LoneStar - X15/A26 - DLB - Remote Power
Module (2 RPM w/ Switch Packs)
LT/RH/LoneStar - X15/A26 - DLB - Remote Power Module (2 RPM w/ Switch
Packs) Design 330
LT/RH/LoneStar X15 - Transmission (TC10 Series A65
w/Body Builder)
LT/RH/LoneStar X15 - Transmission (TC10 Series A65 w/Body Builder)
Design 331
LT/RH - A26 - Transmissions Electrical I/O (Eaton
Ultrashift)
LT/RH - A26 - Transmissions Electrical I/O (Eaton Ultrashift) Design 332
LT/RH - A26 - Transmission Electrical I/O (Endurant
W/A26 & N/ Body Builder)
LT/RH - A26 - Transmission Electrical I/O (Endurant W/A26 & N/ Body Builder)
Design 333
TABLE OF CONTENTS
xvLT/RH - A26 - Transmission Electrical I/O (Endurant
W/A26 & W/ Body Builder)
LT/RH - A26 - Transmission Electrical I/O (Endurant W/A26 & W/ Body Builder)
Design 334
LT/RH - A26 - Transmission I/O (Allison 3K with Body
Builder)
LT/RH - A26 - Transmission I/O (Allison 3K with Body Builder) Design 335
LT/RH - A26/X15 - Transmission I/O (Allison Gen 6 3K
W/ Body Builder)
LT/RH - A26/X15 - Transmission I/O (Allison Gen 6 3K W/ Body Builder)
Design 338
LT/RH - X15 - Transmission Electrical I/O (Endurant W/
Cummins N/ Body Builder)
LT/RH - X15 - Transmission Electrical I/O (Endurant W/ Cummins N/ Body
Builder) Design 341
Cummins W/ Body Builder)
LT/RH - X15 - Transmission Electrical I/O (Endurant W/ Cummins W/ Body
Builder) Design 342
LT/RH - A26 - Transmission Power Take Off (Active
Low Feedback)
LT/RH - A26 - Transmission Power Take Off (Active Low Feedback) Design 343
LT/RH - A26 - Transmission Power Take Off (Dual PTO
W/ 42 Parameters & W/ Auto, AMT Trans)
LT/RH - A26 - Transmission Power Take Off (Dual PTO W/ 42 Parameters & W/
Auto, AMT Trans) Design 344
W/ 42 Parameters & W/ Auto, AMT Trans)(Rev2)
Auto, AMT Trans)(Rev2) Design 346
W/ 42 Parameters & W/ Manual Trans)
Manual Trans) Design 347
LT/RH - A26 - Transmission Power Take Off (Single
PTO W/42 Parameters & W/ Auto, AMT Trans)
LT/RH - A26 - Transmission Power Take Off (Single PTO W/42 Parameters & W/
Auto, AMT Trans) Design 348
PTO W/42 Parameters & W/ Auto, AMT Trans)(Rev2)
Auto, AMT Trans)(Rev2) Design 350
PTO W/ 42 Parameters & W/ Manl Trans)
LT/RH - A26 - Transmission Power Take Off (Single PTO W/ 42 Parameters & W/
Manl Trans) Design 351
TABLE OF CONTENTS
xviLT/RH - X15 - Transmission Power Take Off (Dual PTO
LT/RH - X15 - Transmission Power Take Off (Dual PTO W/ 42 Parameters & W/
Auto, AMT Trans) Design 352
LT/RH - X15 - Transmission Power Take Off (Single
PTO W/ 42 Parameters & W/ Auto, AMT Trans)
LT/RH - X15 - Transmission Power Take Off (Single PTO W/ 42 Parameters & W/
Auto, AMT Trans) Design 353
LT/RH/LoneStar - X15 - Transmission Power Take Off
LT/RH/LoneStar - X15 - Transmission Power Take Off Design 354
Dual PTO with Clutch Interlock MANUAL
LT/RH/LoneStar - X15 - Transmission Power Take Off Dual PTO with Clutch
Interlock MANUAL Design 355
Dual Solenoid AUTO
LT/RH/LoneStar - X15 - Transmission Power Take Off Dual Solenoid AUTO
Design 356
W/ Clutch Interlock
LT/RH/LoneStar - X15 - Transmission Power Take Off W/ Clutch Interlock
Design 357
LT/RH/LoneStar - X15 - Transmission SINGLE Power
Take Off MANUAL
LT/RH/LoneStar - X15 - Transmission SINGLE Power Take Off MANUAL
Design 358
LT/RH - A26 - Service Brake Switch (Multiple Service
Brake Switch W/ Redundant Switch)
LT/RH - A26 - Service Brake Switch (Multiple Service Brake Switch W/
Redundant Switch) Design 359
LT/RH - A26 - Service Brake Switch(Multiple Brake
Switch N/Redundant Brake Switch)
LT/RH - A26 - Service Brake Switch(Multiple Brake Switch N/Redundant Brake
Switch) Design 360
LT/RH/LoneStar - X15/A26 - Brake Switch
LT/RH/LoneStar - X15/A26 - Brake Switch Design 361
Air Dryer (Dual)
Air Dryer (Dual) Design 362
Air Dryer (Single)
Air Dryer (Single) Design 368
LT/RH - X15/A26 -Air Dryer (Intelligent Air Governor)
LT/RH - X15/A26 -Air Dryer (Intelligent Air Governor) Design 372
LT/RH - A26 - Air Governor Control (Intelligent Air
Governor)
TABLE OF CONTENTS
xviiLT/RH - A26 - Air Governor Control (Intelligent Air Governor) Design 373
LT/RH - X15 - Air Governor Control (Intelligent Air
Governor)
LT/RH - X15 - Air Governor Control (Intelligent Air Governor) Design 375
LT/RH/LoneStar - X15/A26 - Drain Valve Heater
LT/RH/LoneStar - X15/A26 - Drain Valve Heater Design 376
LoneStar - X15 - Antilock Brake System (ABS) [Bendix
6 Channel Implementation]
LoneStar - X15 - Antilock Brake System (ABS) [Bendix 6 Channel
Implementation] Design 377
LoneStar - X15 - Antilock Brake System (ABS)-BENDIX
4 Channel Implemenation
LoneStar - X15 - Antilock Brake System (ABS)-BENDIX 4 Channel Implemenation
Design 380
LT/RH - X15/A26 - Antilock Brake System (ABS)
LT/RH - X15/A26 - Antilock Brake System (ABS) BENDIX 4 Channel
Implemenation Design 384
Bendix 6 Channel Implementation
LT/RH - X15/A26 - Antilock Brake System (ABS) Bendix 6 Channel
Implementation Design 388
LoneStar - X15 - Antilock Brake System (ABS) -
Wabco 4 Channel Implementation
LoneStar - X15 - Antilock Brake System (ABS) - Wabco 4 Channel
Implementation Design 391
LoneStar - X15 - Antilock Brake System - Wabco ABS
LoneStar - X15 - Antilock Brake System - Wabco ABS 6 Channel Implementation
Design 395
LT/RH - X15/A26 - Antilock Brake System (ABS) -
LT/RH - X15/A26 - Antilock Brake System (ABS) - Wabco 4 Channel
Implementation Design 398
LT/RH - X15/A26 - Antilock Brake System - Wabco
LT/RH - X15/A26 - Antilock Brake System - Wabco ABS 6 Channel
Implementation Design 402
LT/RH - X15/A26 - Park Brake Control (Monitoring)
(W/Vehicle Speed)
LT/RH - X15/A26 - Park Brake Control (Monitoring) (W/Vehicle Speed) Design405
(Monitoring)(GEN IV BCM)
LT/RH - X15/A26 - Park Brake Control (Monitoring)(GEN IV BCM) Design 406
TABLE OF CONTENTS
xviiiLT/RH/LoneStar - X15/A26 - Park Brake Controls (Non
Lever Park Brake)
LT/RH/LoneStar - X15/A26 - Park Brake Controls (Non Lever Park Brake)
Design 407
LT/RH/LoneStar - X15/A26 - Park Brake Controls (with
Alarm IGN ON/OFF)
LT/RH/LoneStar - X15/A26 - Park Brake Controls (with Alarm IGN ON/OFF)
Design 408
LT/RH/LoneStar - X15/A26 - Park Brake Reminder
(Non-Stationary) (CA2.0)
LT/RH/LoneStar - X15/A26 - Park Brake Reminder (Non-Stationary) (CA2.0)
Design 409
(Stationary) (CA2.0)
LT/RH/LoneStar - X15/A26 - Park Brake Reminder (Stationary) (CA2.0)
Design 410
Park Brake Controls (Air Chassis Park Brake)
Park Brake Controls (Air Chassis Park Brake) Design 411
Park Brake Controls (Tractor) Intellipark
Park Brake Controls (Tractor) Intellipark Design 412
LT/RH - X15/A26 - Bendix Stability Control For Tractor
or Tractors with Trailer Tow
LT/RH - X15/A26 - Bendix Stability Control For Tractor or Tractors with Trailer
Tow Design 414
LT/RH - X15/A26 - Bendix; Tractor or Towing Truck; W/
Air SUSP; J1939 Driven Lamp
LT/RH - X15/A26 - Bendix; Tractor or Towing Truck; W/ Air SUSP; J1939 Driven
Lamp Design 416
LT/RH - X15/A26 - Wabco Full Stability Control
LT/RH - X15/A26 - Wabco Full Stability Control Design 418
LT/RH/LoneStar - X15/A26 - Traction Control (Bendix
Controller)
LT/RH/LoneStar - X15/A26 - Traction Control (Bendix Controller) Design 420
Controller) With ABS Trailer
LT/RH/LoneStar - X15/A26 - Traction Control (Bendix Controller) With ABS Trailer
Design 422
LT/RH/LoneStar - X15/A26 - Traction Control (Wabco
Controller)
LT/RH/LoneStar - X15/A26 - Traction Control (Wabco Controller) Design 424
LoneStar - X15 - Adaptive Cruise Control w/o Display
(Bendix)
LoneStar - X15 - Adaptive Cruise Control w/o Display (Bendix) Design 427
TABLE OF CONTENTS
xixLoneStar - X15 - Adaptive Cruise Control (Bendix -
Fusion W/O DIU & N/ Safety Direct & Tweeters)
LoneStar - X15 - Adaptive Cruise Control (Bendix - Fusion W/O DIU & N/ Safety
Direct & Tweeters) Design 428
Fusion W/O DIU & W/ Safety Direct & Reg Speakers)
Option 1
LoneStar - X15 - Adaptive Cruise Control (Bendix - Fusion W/O DIU & W/ Safety
Direct & Reg Speakers) Option 1 Design 429
Option 2
Direct & Reg Speakers) Option 2 Design 430
Fusion W/O DIU & W/ Safety Direct & W/ Tweeters)
Direct & W/ Tweeters) Design 431
LT/RH - A26/X15 - ACC Following Mode Selection
(Bendix Wingman Fusion 3.0)
LT/RH - A26/X15 - ACC Following Mode Selection (Bendix Wingman Fusion 3.0)
Design 432
LT/RH - A26/X15 - Adaptive Cruise Control w/o Display
(Bendix)
LT/RH - A26/X15 - Adaptive Cruise Control w/o Display (Bendix) Design 433
LT/RH - A26/X15 - Adaptive Cruise Control (Bendix -
Fusion W/O DIU & N/ Safety Direct & Reg Speakers)
LT/RH - A26/X15 - Adaptive Cruise Control (Bendix - Fusion W/O DIU & N/ Safety
Direct & Reg Speakers) Design 434
Direct & Tweeters) Design 435
LT/RH - A26/X15 - Adaptive Cruise Control (Bendix - Fusion W/O DIU & W/
Safety Direct & Reg Speakers) Design 436
Safety Direct & W/ Tweeters) Design 437
Fusion 2.0 N/ Safety Direct Conn & W/ Reg Speakers)
LT/RH - A26/X15 - Adaptive Cruise Control (Bendix - Fusion 2.0 N/ Safety Direct
Conn & W/ Reg Speakers) Design 438
Fusion 2.0 N/ Safety Direct Conn & W/ Tweeters)
TABLE OF CONTENTS
xxLT/RH - A26/X15 - Adaptive Cruise Control (Bendix - Fusion 2.0 N/ Safety Direct
Conn & W/ Tweeters) Design 442
Fusion 2.0 W/ Safety Direct Conn & W/ Tweeters
LT/RH - A26/X15 - Adaptive Cruise Control (Bendix - Fusion 2.0 W/ Safety Direct
Conn & W/ Tweeters Design 444
Fusion 2.0 & W/ Safety Direct Conn & W/ Reg
Speakers)
LT/RH - A26/X15 - Adaptive Cruise Control (Bendix - Fusion 2.0 & W/ Safety
Direct Conn & W/ Reg Speakers) Design 446
Fusion 2.8/2.9 N/ Safety Direct Conn W/ Reg Speakers)
LT/RH - A26/X15 - Adaptive Cruise Control (Bendix - Fusion 2.8/2.9 N/ Safety
Direct Conn W/ Reg Speakers) Design 450
Fusion 2.8/2.9 N/ Safety Direct Conn W/ Tweeters)
Direct Conn W/ Tweeters) Design 454
Fusion 2.8/2.9 W/ Safety Direct Conn W/ Reg
Speakers)
LT/RH - A26/X15 - Adaptive Cruise Control (Bendix - Fusion 2.8/2.9 W/ Safety
Direct Conn W/ Reg Speakers) Design 456
Fusion 2.8/2.9 W/ Safety Direct Conn W/ Tweeters)
Direct Conn W/ Tweeters) Design 460
LT/RH - A26/X15 - Adaptive Cruise Control (Fusion 3.0
N/ DIU W/LDW Audio Mute)
LT/RH - A26/X15 - Adaptive Cruise Control (Fusion 3.0 N/ DIU W/LDW Audio
Mute) Design 462
N/ DIU)
LT/RH - A26/X15 - Adaptive Cruise Control (Fusion 3.0 N/ DIU) Design 463
LT/RH - X15/A26 - Adaptive Cruise Control (OnGuard
Max N/ DIU W/LDW Audio Mute)
LT/RH - X15/A26 - Adaptive Cruise Control (OnGuard Max N/ DIU W/LDW Audio
Mute) Design 464
Max N/ DIU)
LT/RH - X15/A26 - Adaptive Cruise Control (OnGuard Max N/ DIU) Design 465
(Wabco)
LoneStar - X15 - Adaptive Cruise Control w/o Display (Wabco) Design 466
LT/RH - X15/A26 - Adaptive Cruise Control w/o Display
(Wabco)
TABLE OF CONTENTS
xxiLT/RH - X15/A26 - Adaptive Cruise Control w/o Display (Wabco) Design 467
LT/RH/LoneStar - X15/A26 - Analytic Cruise Control
LT/RH/LoneStar - X15/A26 - Analytic Cruise Control Design 468
Oncoming Detection (Fusion 3.0)
Oncoming Detection (Fusion 3.0) Design 469
LT/RH/LoneStar - X15/A26 - Collision Avoidance
System (Warning)
LT/RH/LoneStar - X15/A26 - Collision Avoidance System (Warning) Design 470
LT/RH - A26/X15 - Camera Event Recorder N/Safety
Direct Cable Option 1
LT/RH - A26/X15 - Camera Event Recorder N/Safety Direct Cable Option 1
Design 471
Direct Cable Option 2
LT/RH - A26/X15 - Camera Event Recorder N/Safety Direct Cable Option 2
Design 472
LT/RH - A26/X15 - Camera event Recorder W/Safety
LT/RH - A26/X15 - Camera event Recorder W/Safety Direct Cable Option 1
Design 473
LT/RH - A26/X15 - Camera Event Recorder W/Safety
LT/RH - A26/X15 - Camera Event Recorder W/Safety Direct Cable Option 2
Design 475
LT/RH - A26/X15 - Camera (LYTX Prewire) N/Event
Recording Button
LT/RH - A26/X15 - Camera (LYTX Prewire) N/Event Recording Button Design 477
LoneStar - X15 - Lane Departure Warning - (Bendix
Fusion W/Safety Direct))(US & Canada)
LoneStar - X15 - Lane Departure Warning - (Bendix Fusion W/Safety Direct))(US
& Canada) Design 478
Fusion W/Safety Direct))(US & Canada)-
& Canada)- Design 479
LT/RH - X15/A26 - Lane Departure Warning - Bendix
LT/RH - X15/A26 - Lane Departure Warning - Bendix Design 480
LT/RH - X15/A26 - Lane Departure Warning - (Bendix
LT/RH - X15/A26 - Lane Departure Warning - (Bendix Fusion W/Safety
Direct))(US & Canada) Design 481
LT/RH - X15/A26 - Lane Departure Warning - (Bendix -
AutoVue N/ Qualcomm Safety Direct)
LT/RH - X15/A26 - Lane Departure Warning - (Bendix - AutoVue N/ Qualcomm
Safety Direct) Design 482
TABLE OF CONTENTS
xxiiLT/RH - X15/A26 - Lane Departure Warning - (Bendix -
AutoVue W/ Qualcomm Safety Direct)
LT/RH - X15/A26 - Lane Departure Warning - (Bendix - AutoVue W/ Qualcomm
Safety Direct) Design 483
LT/RH - X15/A26 - Lane Departure Warning (Mobileye
Per-Wire)
LT/RH - X15/A26 - Lane Departure Warning (Mobileye Per-Wire) Design 484
LT/RH - X15/A26 - Lane Departure Warning - (Wabco
OnLane 2.0 w/ roof speakers)
LT/RH - X15/A26 - Lane Departure Warning - (Wabco OnLane 2.0 w/ roof
speakers) Design 485
OnLane 2.0 w/ tweeter)
LT/RH - X15/A26 - Lane Departure Warning - (Wabco OnLane 2.0 w/ tweeter)
Design 486
OnLane)
LT/RH - X15/A26 - Lane Departure Warning - (Wabco OnLane) Design 487
LT/RH - X15/A26 - Lane Keep AssistLT/RH - X15/A26 - Lane Keep Assist- Design 488
LT/RH - X15/A26 - ACC Following Mode Selection
(Wabco OnGuard Max)
LT/RH - X15/A26 - ACC Following Mode Selection (Wabco OnGuard Max)
Design 489
LT/RH - X15/A26 - Oncoming Detection (Wabco
OnGuard Max)
LT/RH - X15/A26 - Oncoming Detection (Wabco OnGuard Max) Design 490
LT/RH - X15 - Accelerator Interlock W/ Park Brake
Controls
LT/RH - X15 - Accelerator Interlock W/ Park Brake Controls Design 491
LT/RH - A26 - Air Filter Flow Restriction Monitoring
LT/RH - A26 - Air Filter Flow Restriction Monitoring Design 492
(LED Indicator)
LT/RH - A26 - Air Filter Flow Restriction Monitoring (LED Indicator) Design 493
LT/RH/LoneStar - X15 - Air Flow Restriction
Monitoring
LT/RH/LoneStar - X15 - Air Flow Restriction Monitoring Design 494
LT/RH/LoneStar - X15/A26 - Engine Brake (CA2.0; Mux
Switch)
LT/RH/LoneStar - X15/A26 - Engine Brake (CA2.0; Mux Switch) Design 495
Stalk Shifter)
LT/RH/LoneStar - X15/A26 - Engine Brake (CA2.0; Stalk Shifter) Design 496
TABLE OF CONTENTS
xxiiiLT/RH/LoneStar - X15/A26 - Engine/Exhaust Brake
LT/RH/LoneStar - X15/A26 - Engine/Exhaust Brake Design 497
LT/RH X15 - Coolant Level Monitoring
LT/RH X15 - Coolant Level Monitoring Design 498
LT/RH - A26 - Coolant Level Monitoring (No CLA
Module)
LT/RH - A26 - Coolant Level Monitoring (No CLA Module) Design 499
LT/RH/LoneStar - X15 - Coolant Level Monitoring
LT/RH/LoneStar - X15 - Coolant Level Monitoring Design 500
LT/RH - A26 - Cooling Fan Control (Fan Override)
LT/RH - A26 - Cooling Fan Control (Fan Override) Design 501
LT/RH - A26 - Cooling Fan Control (No Fan Override)
LT/RH - A26 - Cooling Fan Control (No Fan Override) Design 502
LT/RH - X15 - Cooling Fan Control (No Fan Override,
Cummins)
LT/RH - X15 - Cooling Fan Control (No Fan Override, Cummins) Design 503
LT/RH/LoneStar - X15 - Cooling Fan Control (Fan
Override, Cummins)
LT/RH/LoneStar - X15 - Cooling Fan Control (Fan Override, Cummins) Design504
LT/RH/LoneStar - X15/A26 - Engine Diagnostic
Connector
LT/RH/LoneStar - X15/A26 - Engine Diagnostic Connector Design 505
LT/RH - A26/X15 - Engine Idle Increment/Decrement
LT/RH - A26/X15 - Engine Idle Increment/Decrement (Steering Wheel Controls)
Design 506
LT/RH/LoneStar - X15/A26 - Engine Idle
Increment/Decrement (Steering Wheel Switch - 10 Pin)
LT/RH/LoneStar - X15/A26 - Engine Idle Increment/Decrement (Steering Wheel
Switch - 10 Pin) Design 507
Increment/Decrement (Steering Wheel Switch - 4 Pin)
Switch - 4 Pin) Design 508
LT/RH - X15/A26 - Engine Block Heater (Purchased
Assembly)
LT/RH - X15/A26 - Engine Block Heater (Purchased Assembly) Design 509
LT/RH - X15/A26 - Engine Fuel and Block Heaters
LT/RH - X15/A26 - Engine Fuel and Block Heaters (Purchased Assembly)
Design 510
LT/RH - X15/A26 - Engine Oil and Block Heaters
TABLE OF CONTENTS
xxivLT/RH - X15/A26 - Engine Oil and Block Heaters (Purchased Assembly)
Design 511
LT/RH - X15/A26 - Engine Oil, Fuel, and Block Heaters
LT/RH - X15/A26 - Engine Oil, Fuel, and Block Heaters (Purchased Assembly)
Design 512
LT/RH - A26 - Starting Aid (Flame Start W/MD1 ECM)
LT/RH - A26 - Starting Aid (Flame Start W/MD1 ECM) Design 513
LT/RH/LoneStar - X15 - Starting Aid (Ether Start)
LT/RH/LoneStar - X15 - Starting Aid (Ether Start) Design 514
LT/RH 2021 A26 - Vehicle Acceleration (Wired to the
ECM)
LT/RH 2021 A26 - Vehicle Acceleration (Wired to the ECM) Design 515
LT/RH/LoneStar - X15 - Vehicle Acceleration (w/ Two
PWR Two GND & Two STS)
LT/RH/LoneStar - X15 - Vehicle Acceleration (w/ Two PWR Two GND & Two
STS) Design 516
LT/RH/LoneStar - X15/A26 - Vehicle Speed Limit
Override
LT/RH/LoneStar - X15/A26 - Vehicle Speed Limit Override Design 517
LT/RH - A26 - Engine Electrical I/O (24-Pin Vehicle
Interface Connector)
LT/RH - A26 - Engine Electrical I/O (24-Pin Vehicle Interface Connector)
Design 518
LT/RH/LoneStar - X15/A26 - Air Shield Lighting w/ One
Light
LT/RH/LoneStar - X15/A26 - Air Shield Lighting w/ One Light Design 520
LT/RH/LoneStar - X15/A26 - Automatic Lighting (Dual
Sensor Solar/Twilight)
LT/RH/LoneStar - X15/A26 - Automatic Lighting (Dual Sensor Solar/Twilight)
Design 522
(Single Sensor Twilight)
LT/RH/LoneStar - X15/A26 - Automatic Lighting (Single Sensor Twilight)
Design 523
LT/RH X15 - Backup Light (Dual Reverse Light)
Allison-TC10
LT/RH X15 - Backup Light (Dual Reverse Light) Allison-TC10 Design 524
LT/RH X15 - Backup Light (Reverse Light ) Allison
TC10
LT/RH X15 - Backup Light (Reverse Light ) Allison TC10 Design 526
LT/RH X15 - Backup Light (Single Reverse Light)
Allison TC10
LT/RH X15 - Backup Light (Single Reverse Light) Allison TC10 Design 528
TABLE OF CONTENTS
xxvLT/RH/LoneStar X15 - Backup Light (Single Reverse
Light) W/Allison TC10
LT/RH/LoneStar X15 - Backup Light (Single Reverse Light) W/Allison TC10
Design 530
LT/RH - A26 - Backup Lights (Reverse Lights)
(Crossmember Dual STT N/Back Up) Allison Trans
LT/RH - A26 - Backup Lights (Reverse Lights) (Crossmember Dual STT N/Back
Up) Allison Trans Design 532
LT/RH - A26 - Backup Lights (W/ BB TRLR
SKT)Allison/ZF Trans
LT/RH - A26 - Backup Lights (W/ BB TRLR SKT)Allison/ZF Trans Design 533
LT/RH - A26 - Backup Light (Dual Reverse
Light)Allison/ZF Trans
LT/RH - A26 - Backup Light (Dual Reverse Light)Allison/ZF Trans Design 534
Light)Allison/ZF TransLT/RH - A26 - Backup Light (Dual Reverse Light)Allison/ZF Trans- Design 536
LT/RH - A26 - Backup Light (Reverse Light ) Allison/ZF
Trans
LT/RH - A26 - Backup Light (Reverse Light ) Allison/ZF Trans Design 538
LT/RH - A26 - Backup Light (Single Reverse Light)
W/Allison
LT/RH - A26 - Backup Light (Single Reverse Light) W/Allison Design 539
W/AllisonLT/RH - A26 - Backup Light (Single Reverse Light) W/Allison- Design 540
LT/RH - A26 - Back Up Lights (Reverse Lights)
(Tailboard Dual STT W/Back Up) Allison Trans
LT/RH - A26 - Back Up Lights (Reverse Lights) (Tailboard Dual STT W/Back Up)
Allison Trans Design 542
LT/RH X15 - Backup Lights (Dual Reverse Light)
Eaton/Manual Trans
LT/RH X15 - Backup Lights (Dual Reverse Light) Eaton/Manual Trans Design 544
LT/RH X15 - Backup Lights (Reverse Lights)
Eaton/Manual Trans
LT/RH X15 - Backup Lights (Reverse Lights) Eaton/Manual Trans Design 546
LT/RH X15 - Backup Lights (Reverse Light)
Eaton/Manual Trans
LT/RH X15 - Backup Lights (Reverse Light) Eaton/Manual Trans Design 548
LT/RH X15 - Backup Lights (Single Reverse Light)
Eaton/Manual Trans
LT/RH X15 - Backup Lights (Single Reverse Light) Eaton/Manual Trans
Design 550
LT/RH - A26 - Backup Lights (Dual Reverse Light)
Eaton/Manual Trans
TABLE OF CONTENTS
xxviLT/RH - A26 - Backup Lights (Dual Reverse Light) Eaton/Manual Trans
Design 552
(Crossmember Dual STT N/Back Up) Eaton/Manual
Trans
Up) Eaton/Manual Trans Design 554
LT/RH - A26 - Backup Lights (Single Reverse Light)
Eaton/Manual Trans
LT/RH - A26 - Backup Lights (Single Reverse Light) Eaton/Manual Trans
Design 555
Eaton/Manual Trans-Option2
LT/RH - A26 - Backup Lights (Single Reverse Light) Eaton/Manual Trans-Option2
Design 557
Eaton/Manual Trans-Option 1
LT/RH - A26 - Backup Lights (Single Reverse Light) Eaton/Manual Trans-Option 1
Design 558
LT/RH - A26 - Backup Lights ( Reverse Light )
Eaton/Manual Trans
LT/RH - A26 - Backup Lights ( Reverse Light ) Eaton/Manual Trans Design 560
(Tailboard Dual STT W/Back Up) Eaton/Manual Trans
Eaton/Manual Trans Design 561
LT/RH - X15 - Backup Lights (Reverse Lights)
Trans
LT/RH - X15 - Backup Lights (Reverse Lights) (Crossmember Dual STT N/Back
Up) Eaton/Manual Trans Design 563
LT/RH - X15 - Backup Lights (Single Reverse Light)
Eaton/Manual Trans
LT/RH - X15 - Backup Lights (Single Reverse Light) Eaton/Manual Trans
Design 564
LT/RH - X15 - Back Up Lights (Reverse Lights)
LT/RH - X15 - Back Up Lights (Reverse Lights) (Tailboard Dual STT W/Back Up)
Eaton/Manual Trans Design 566
LT/RH/LoneStar X15 - Backup Lights (Single Reverse
LT/RH/LoneStar X15 - Backup Lights (Single Reverse Light) Eaton/Manual Trans
Design 568
LT/RH A26 - Backup Lights (Reverse Lights)
Endurant/EndurantXD Trans
TABLE OF CONTENTS
xxviiLT/RH A26 - Backup Lights (Reverse Lights) (Crossmember Dual STT N/Back
Up) Endurant/EndurantXD Trans Design 570
LT/RH A26 - Backup Light (Dual Reverse LT)(HRZN,
HX) - Relay Coil CTRL by TCM - 6 PIN: A26
LT/RH A26 - Backup Light (Dual Reverse LT)(HRZN, HX) - Relay Coil CTRL by
TCM - 6 PIN:A26 Design 572
LT/RH A26 - Backup Light (Single Reverse Light)
Endurant/EndurantXD
LT/RH A26 - Backup Light (Single Reverse Light) Endurant/EndurantXD
Design 574
(HRZN, HX) Yukon AMT
LT/RH A26 - Backup Light (Single Reverse Light) (HRZN, HX) Yukon AMT
Design 576
LT/RH A26 - Back Up Lights (Reverse Lights)
LT/RH A26 - Back Up Lights (Reverse Lights) (Tailboard Dual STT W/Back Up)
Endurant/EndurantXD Trans Design 578
Up) Endurant/EndurantXD Trans Design 580
LT/RH - A26 - Backup Light (Dual Reverse LT) Relay
LT/RH - A26 - Backup Light (Dual Reverse LT) Relay Coil CTRL by TCM - 6 PIN
Design 581
LT/RH - A26 - Backup Light (Dual Reverse LT) - Relay
LT/RH - A26 - Backup Light (Dual Reverse LT) - Relay Coil CTRL by TCM - 6 PIN
Design 583
Light)Yukon AMT
LT/RH - A26 - Backup Light (Single Reverse Light)Yukon AMT Design 585
Procision, Endurant
LT/RH - A26 - Backup Light (Single Reverse Light) Procision, Endurant
Design 586
Endurant/EndurantXD Trans Design 587
TABLE OF CONTENTS
xxviiiLT/RH X15 - Backup Lights (Reverse Lights) (Crossmember Dual STT N/Back
Up) Endurant/EndurantXD Trans Design 589
LT/RH X15 - Backup Light (Dual Reverse LT)
Procosion/Endurant
LT/RH X15 - Backup Light (Dual Reverse LT) Procosion/Endurant Design 591
LT/RH X15 - Backup Light (Dual Reverse LT)(HRZN,
LT/RH X15 - Backup Light (Dual Reverse LT)(HRZN, HX) - Relay Coil CTRL by
TCM - 6 PIN Design 593
Endurant
LT/RH X15 - Backup Light (Single Reverse Light) Endurant Design 595
Endurant/EndurantXD
LT/RH X15 - Backup Light (Single Reverse Light) Endurant/EndurantXD
Design 597
LT/RH X15 - Backup Light (Single Reverse Light) (HRZN, HX) Yukon AMT
Design 599
LT/RH X15 - Back Up Lights (Reverse Lights)
LT/RH X15 - Back Up Lights (Reverse Lights) (Tailboard Dual STT W/Back Up)
Endurant/EndurantXD Trans Design 601
Up) Endurant/EndurantXD Trans Design 603
LT/RH - X15 - Backup Light (Dual Reverse LT)(HX) -
LT/RH - X15 - Backup Light (Dual Reverse LT)(HX) - Relay Coil CTRL by TCM - 6
PIN Design 605
Endurant/EndurantXD Trans Design 609
LT/RH/LoneStar X15 - Backup Light Endurant
LT/RH/LoneStar X15 - Backup Light Endurant Design 613
Light) Endurant
LT/RH/LoneStar X15 - Backup Light (Single Reverse Light) Endurant Design 615
LT/RH/LoneStar - X15/A26 - Beacon/Strobe Light
LT/RH/LoneStar - X15/A26 - Beacon/Strobe Light Design 617
TABLE OF CONTENTS
xxixLT/RH/LoneStar - X15/A26 - Clearance and
Identification Lights (W/ Sunshade)
LT/RH/LoneStar - X15/A26 - Clearance and Identification Lights (W/ Sunshade)
Design 619
LT/RH - A26/X15 - Daytime Running Lights N/CAN
Headlamps
LT/RH - A26/X15 - Daytime Running Lights N/CAN Headlamps Design 620
LT/RH/LoneStar - X15/A26 - Daytime Running Lights
LT/RH/LoneStar - X15/A26 - Daytime Running Lights Design 621
LT/RH - X15/A26 - Directional Signal (Turn) With
HEADLIGHTS
LT/RH - X15/A26 - Directional Signal (Turn) With HEADLIGHTS Design 622
HEADLIGHTS (HAL-125)
LT/RH - X15/A26 - Directional Signal (Turn) With HEADLIGHTS (HAL-125)
Design 623
W/HEADLIGHTS
RH - X15/A26 - Directional Signal (Turn) W/HEADLIGHTS Design 624
LT/RH - A26/X15 - Directional Signals (Turn) (LED
125BBC)
LT/RH - A26/X15 - Directional Signals (Turn) (LED 125BBC) Design 625
HEADLIGHTS Option2
LT/RH - X15/A26 - Directional Signal (Turn) With HEADLIGHTS Option2
Design 626
HEADLIGHTS (LED-125)
LT/RH - X15/A26 - Directional Signal (Turn) With HEADLIGHTS (LED-125)
Design 627
LT/RH/LoneStar - X15/A26 - Exterior Lamp Check
LT/RH/LoneStar - X15/A26 - Exterior Lamp Check Design 628
LT/RH/LoneStar - X15/A26 - Exterior Lamp Reminder
LT/RH/LoneStar - X15/A26 - Exterior Lamp Reminder Design 629
LoneStar - X15/A26 - Front Fog Lamps
LoneStar - X15/A26 - Front Fog Lamps Design 630
LT/RH - X15/A26 - Fog Lights Lamps
LT/RH - X15/A26 - Fog Lights Lamps Design 631
LT/RH/LoneStar - X15/A26 - Hazard Warning (CA 2.0)
LT/RH/LoneStar - X15/A26 - Hazard Warning (CA 2.0) Design 632
LoneStar - X15 - Headlights Halogen N/INT N/LOWW
LoneStar - X15 - Headlights Halogen N/INT N/LOWW Design 633
LoneStar - X15 - Headlights Halogen N/INT W/LOWW
LoneStar - X15 - Headlights Halogen N/INT W/LOWW Design 634
TABLE OF CONTENTS
xxxLoneStar - X15 - Headlights Halogen W/INT N/LOWW
LoneStar - X15 - Headlights Halogen W/INT N/LOWW Design 635
LoneStar - X15 - Headlights Halogen W/INT W/LOWW
LoneStar - X15 - Headlights Halogen W/INT W/LOWW Design 636
LT - X15/A26 - Headlights Halogen N/INT N/LOWW
LT - X15/A26 - Headlights Halogen N/INT N/LOWW Design 637
LT - X15/A26 - Headlights Halogen N/INT W/LOWW
LT - X15/A26 - Headlights Halogen N/INT W/LOWW Design 638
LT - X15/A26 - Headlights Halogen W/INT N/LOWW
LT - X15/A26 - Headlights Halogen W/INT N/LOWW Design 639
LT - X15/A26 - Headlights Halogen W/INT W/LOWW
LT - X15/A26 - Headlights Halogen W/INT W/LOWW Design 640
LT - X15/A26 - Headlights (Halogen 113 BBC)
LT - X15/A26 - Headlights (Halogen 113 BBC) Design 641
LT - X15/A26 - Headlights (Halogen 125BBC) W/LOWW
LT - X15/A26 - Headlights (Halogen 125BBC) W/LOWW Design 642
LT - X15/A26 - Headlights (Halogen 125BBC) W/O
LOWW
LT - X15/A26 - Headlights (Halogen 125BBC) W/O LOWW Design 643
LT - A26/X15 - Headlights (LED 113 BBC)
LT - A26/X15 - Headlights (LED 113 BBC) Design 644
LT - X15/A26 - Headlights LED N/ INT N/LOWW
LT - X15/A26 - Headlights LED N/ INT N/LOWW Design 645
LT - X15/A26 - Headlights LED N/ INT W/LOWW
LT - X15/A26 - Headlights LED N/ INT W/LOWW Design 646
LT - X15/A26 - Headlights LED W/INT N/LOWW
LT - X15/A26 - Headlights LED W/INT N/LOWW Design 647
LT - X15/A26 - Headlights LED W/INT W/LOWW
LT - X15/A26 - Headlights LED W/INT W/LOWW Design 648
LT - X15/A26 - Headlights (LED 125 BBC) N/LOWW
LT - X15/A26 - Headlights (LED 125 BBC) N/LOWW Design 649
LT - X15/A26 - Headlights (LED 125 BBC) W/LOWW
LT - X15/A26 - Headlights (LED 125 BBC) W/LOWW Design 650
RH - X15/A26 - Headlights Halogen N/INT N/LOWW
RH - X15/A26 - Headlights Halogen N/INT N/LOWW Design 651
RH - X15/A26 - Headlights Halogen N/INT W/LOWW
RH - X15/A26 - Headlights Halogen N/INT W/LOWW Design 652
RH - X15/A26 - Headlights Halogen W/INT N/LOWW
RH - X15/A26 - Headlights Halogen W/INT N/LOWW Design 653
RH - X15/A26 - Headlights Halogen W/INT W/LOWW
RH - X15/A26 - Headlights Halogen W/INT W/LOWW Design 654
TABLE OF CONTENTS
xxxiRH - A26/X15 - Headlights (LED 113 BBC)
RH - A26/X15 - Headlights (LED 113 BBC) Design 655
RH - X15/A26 - Headlights LED N/INT N/LOWW LT
RH - X15/A26 - Headlights LED N/INT N/LOWW LT Design 656
RH - X15/A26 - Headlights LED N/INT W/LOWW LT
RH - X15/A26 - Headlights LED N/INT W/LOWW LT Design 657
RH - X15/A26 - Headlights LED W/INT N/LOWW LT
RH - X15/A26 - Headlights LED W/INT N/LOWW LT Design 658
RH - X15/A26 - Headlights LED W/INT W/LOWW LT
RH - X15/A26 - Headlights LED W/INT W/LOWW LT Design 659
LT/RH - A26/X15 - Rear Lights (Tail Lights)
Crossmember Dual STT N/Back-Up
LT/RH - A26/X15 - Rear Lights (Tail Lights) Crossmember Dual STT N/Back-Up
Design 660
LT/RH - A26/X15 - Rear Lights (Tail Lights) (Tailboard
Dual STT W/Back Up)
LT/RH - A26/X15 - Rear Lights (Tail Lights) (Tailboard Dual STT W/Back Up)
Design 661
LT/RH - X15/A26 - License Plate Light (Dual LED Lamp
Tail Light) Option 1
LT/RH - X15/A26 - License Plate Light (Dual LED Lamp Tail Light) Option 1
Design 663
Tail Light) Option 2
LT/RH - X15/A26 - License Plate Light (Dual LED Lamp Tail Light) Option 2
Design 665
LT/RH - A26/X15 - License Plate Light (Direct To Light)
LT/RH - A26/X15 - License Plate Light (Direct To Light) Design 667
LT/RH - A26/X15 - License Plate Light (Tail Light
Single Assy)
LT/RH - A26/X15 - License Plate Light (Tail Light Single Assy) Design 670
LT/RH - A26/X15 - Rear Light (Tail Light) W/ 6 Pin
Connector
LT/RH - A26/X15 - Rear Light (Tail Light) W/ 6 Pin Connector Design 672
LT/RH - X15/A26 - License Plate Light (Tail Light
Single Assy.)Option 2
LT/RH - X15/A26 - License Plate Light (Tail Light Single Assy.)Option 2
Design 674
Single Assy.) Option 1
LT/RH - X15/A26 - License Plate Light (Tail Light Single Assy.) Option 1
Design 676
LT/RH/LoneStar - X15/A26 - License Plate Light (Tail
TABLE OF CONTENTS
xxxiiLT/RH/LoneStar - X15/A26 - License Plate Light (Tail Light Single Assy.) Option 1
Design 678
Light Single Assy.) Option 2
LT/RH/LoneStar - X15/A26 - License Plate Light (Tail Light Single Assy.) Option 2
Design 680
LoneStar - X15/A26 - Marker Lights (Halogen)
LoneStar - X15/A26 - Marker Lights (Halogen) Design 682
LT/RH - X15/A26 - Marker Lights (With 113 Halogen)
LT/RH - X15/A26 - Marker Lights (With 113 Halogen) Design 683
LT/RH - X15/A26 - Marker Lights (With 125 Halogen)
LT/RH - X15/A26 - Marker Lights (With 125 Halogen) Design 684
LT/RH - A26/X15 - Marker Lighting (LED 125BBC)
LT/RH - A26/X15 - Marker Lighting (LED 125BBC) Design 685
LT/RH - X15/A26 - Marker Lights (With113 LED)
LT/RH - X15/A26 - Marker Lights (With113 LED) Design 686
LT/RH - X15/A26 - Marker Lights (With 125 LED)
LT/RH - X15/A26 - Marker Lights (With 125 LED) Design 687
LT/RH/LoneStar - X15/A26 - MARKER/PARK LIGHTS -
W/Marker Interrupt 10pin CLCKSPRING
LT/RH/LoneStar - X15/A26 - MARKER/PARK LIGHTS - W/Marker Interrupt 10pin
CLCKSPRING Design 688
LT/RH/LoneStar - X15/A26 - PARK LIGHTS - W/Marker
Interrupt 4 pin clockspring
LT/RH/LoneStar - X15/A26 - PARK LIGHTS - W/Marker Interrupt 4 pin
clockspring Design 689
LoneStar - X15 - Modesty Lighting W/ Day Cab W/ 2
Turn /0 Marker
LoneStar - X15 - Modesty Lighting W/ Day Cab W/ 2 Turn /0 Marker Design 690
LoneStar - X15 - Modesty Lighting W/ Sleeper W/ 4
Side Turns / 0 Marker
LoneStar - X15 - Modesty Lighting W/ Sleeper W/ 4 Side Turns / 0 Marker
Design 691
LT/RH - X15/A26 - Modesty Lighting W/ Day Cab W/ 2
Turn /0 Marker
LT/RH - X15/A26 - Modesty Lighting W/ Day Cab W/ 2 Turn /0 Marker Design 692
LT/RH - X15/A26 - Modesty Lighting W/ Sleeper W/ 4
LT/RH - X15/A26 - Modesty Lighting W/ Sleeper W/ 4 Side Turns / 0 Marker
Design 693
LT/RH - X15/A26 - Panic Switch (Sleeper)
LT/RH - X15/A26 - Panic Switch (Sleeper) Design 694
LT/RH - X15/A26 - Skirt Light Customer Supplied
LT/RH - X15/A26 - Skirt Light Customer Supplied Design 695
TABLE OF CONTENTS
xxxiiiLT/RH - A26/X15 - Rear Lights (Stop) (Tailboard Dual
STT W/Back Up)
LT/RH - A26/X15 - Rear Lights (Stop) (Tailboard Dual STT W/Back Up)
Design 696
LT/RH - A26/X15 - Rear Lights (Stop) - Dual Lamp
Assembly
LT/RH - A26/X15 - Rear Lights (Stop) - Dual Lamp Assembly Design 698
LT/RH - A26/X15 - Rear Lights (Stop) - Single
Assembly
LT/RH - A26/X15 - Rear Lights (Stop) - Single Assembly Design 700
LT/RH - A26/X15 - Rear Light (Stop) Crossmember
Dual STT N/Back-Up
LT/RH - A26/X15 - Rear Light (Stop) Crossmember Dual STT N/Back-Up
Design 702
LT/RH/LoneStar - X15/A26 - Rear Lights Stop - Dual
Assembly
LT/RH/LoneStar - X15/A26 - Rear Lights Stop - Dual Assembly Design 703
LT/RH/LoneStar - X15/A26 - Rear Lights Stop - Single
Assembly Option 1
LT/RH/LoneStar - X15/A26 - Rear Lights Stop - Single Assembly Option 1
Design 705
Assembly Option 2
LT/RH/LoneStar - X15/A26 - Rear Lights Stop - Single Assembly Option 2
Design 707
LT/RH/LoneStar - X15/A26 - Work Lights W/ Sw Pack -
Customer Supplied W/O RKE W/AUTO REV
LT/RH/LoneStar - X15/A26 - Work Lights W/ Sw Pack - Customer Supplied W/O
RKE W/AUTO REV Design 709
Customer Supplied W/ RKE W/AUTO REV
RKE W/AUTO REV Design 711
LT/RH - A26 - Work Lights W/ Sw Pack - Customer
Supplied W/O RKE W/MAN REV
LT/RH - A26 - Work Lights W/ Sw Pack - Customer Supplied W/O RKE W/MAN
REV Design 713
Supplied W/ RKE W/MAN REV
LT/RH - A26 - Work Lights W/ Sw Pack - Customer Supplied W/ RKE W/MAN
REV Design 717
LT/RH/LoneStar X15 - Work Lights LED W/ Sw Pack -
Day Cab W/O RKE W/MAN REV
LT/RH/LoneStar X15 - Work Lights LED W/ Sw Pack - Day Cab W/O RKE
W/MAN REV Design 721
TABLE OF CONTENTS
xxxivLT/RH - X15/A26 - Work Lights W/ Sw Pack - Customer
Supplied
LT/RH - X15/A26 - Work Lights W/ Sw Pack - Customer Supplied Design 722
LT/RH/LoneStar - X15 - Work Lights W/ Sw Pack -
Customer Supplied W/O RKE W/MAN REV
LT/RH/LoneStar - X15 - Work Lights W/ Sw Pack - Customer Supplied W/O RKE
W/MAN REV Design 724
Customer Supplied W/ RKE W/MAN REV
LT/RH/LoneStar - X15 - Work Lights W/ Sw Pack - Customer Supplied W/ RKE
W/MAN REV Design 726
Customer Supplied
Design 728
LT/RH/LoneStar - X15/A26 - Work Lights - LED W/ Sw
Pack - Customer Supplied - Sleeper W/O RKE W/AUTO
REV
LT/RH/LoneStar - X15/A26 - Work Lights - LED W/ Sw Pack - Customer Supplied
- Sleeper W/O RKE W/AUTO REV Design 730
Pack - Customer Supplied - Sleeper W/ RKE W/AUTO
REV
- Sleeper W/ RKE W/AUTO REV Design 732
LT/RH - A26 - Work Lights - LED W/ Sw Pack -
Customer Supplied - Sleeper W/O RKE W/MAN REV
LT/RH - A26 - Work Lights - LED W/ Sw Pack - Customer Supplied - Sleeper W/O
RKE W/MAN REV Design 734
Customer Supplied - Sleeper W/ RKE W/MAN REV
RKE W/MAN REV Design 738
LT/RH/LoneStar - X15 - Work Lights - LED W/ Sw Pack
- Customer Supplied - Sleeper W/O RKE W/MAN REV
LT/RH/LoneStar - X15 - Work Lights - LED W/ Sw Pack - Customer Supplied -
Sleeper W/O RKE W/MAN REV Design 742
- Customer Supplied - Sleeper W/ RKE W/MAN REV
Sleeper W/ RKE W/MAN REV Design 744
W/Endurant (Schneider)
- Sleeper W/O RKE W/Endurant (Schneider) Design 746
TABLE OF CONTENTS
xxxvLT/RH/LoneStar - X15/A26 - Work Lights - LED W/ Sw
- Sleeper Design 748
- Sleeper W/O RKE Design 750
LT/RH/LoneStar - X15/A26 - Work Lights LED W/ Sw
Pack - Day Cab W/O RKE W/AUTO REV
LT/RH/LoneStar - X15/A26 - Work Lights LED W/ Sw Pack - Day Cab W/O RKE
W/AUTO REV Design 752
Pack - Day Cab W/ RKE W/AUTO REV
LT/RH/LoneStar - X15/A26 - Work Lights LED W/ Sw Pack - Day Cab W/ RKE
W/AUTO REV Design 753
LT/RH/LoneStar - X15/A26 - Work Lights (2 Blunt Cuts
Only W/O Relay) W/Backup W/Auto Trans (Allison and
Endurant)
LT/RH/LoneStar - X15/A26 - Work Lights (2 Blunt Cuts Only W/O Relay)
W/Backup W/Auto Trans (Allison and Endurant) Design 754
LT/RH - A26 - Work Lights LED W/ Sw Pack - Day Cab
W/O RKE W/MAN REV
LT/RH - A26 - Work Lights LED W/ Sw Pack - Day Cab W/O RKE W/MAN REV
Design 756
W/ RKE W/MAN REV
LT/RH - A26 - Work Lights LED W/ Sw Pack - Day Cab W/ RKE W/MAN REV
Design 758
LT/RH - A26 - Work Lights (2 Blunt Cuts Only W/O
Relay) W/Backup W/Manual Trans Day Cab
LT/RH - A26 - Work Lights (2 Blunt Cuts Only W/O Relay) W/Backup W/Manual
Trans Day Cab Design 760
LT/RH/LoneStar - X15 - Work Lights (2 Blunt Cuts Only
W/O Relay) W/Backup W/Manual Trans
LT/RH/LoneStar - X15 - Work Lights (2 Blunt Cuts Only W/O Relay) W/Backup
W/Manual Trans Design 764
LT/RH/LoneStar X15 - Work Lights LED W/ Sw Pack - Day Cab W/ RKE W/MAN
REV Design 766
Pack - Day Cab
LT/RH/LoneStar - X15/A26 - Work Lights LED W/ Sw Pack - Day Cab Design 767
TABLE OF CONTENTS
xxxviLT/RH/LoneStar - X15/A26 - Work Lights LED W/ Sw Pack - Day Cab W/O RKE
Design 768
Only W/O Relay)
Design 769
LT/RH/LoneStar - X15/A26 - Work Lights -LED W/ Sw
Pack - Sleeper W/O RKE W/AUTO REV
LT/RH/LoneStar - X15/A26 - Work Lights -LED W/ Sw Pack - Sleeper W/O RKE
W/AUTO REV Design 771
Pack - Sleeper W/ RKE W/AUTO REV
LT/RH/LoneStar - X15/A26 - Work Lights -LED W/ Sw Pack - Sleeper W/ RKE
W/AUTO REV Design 772
LT/RH - A26 - Work Lights -LED W/ Sw Pack - Sleeper
W/O RKE W/MAN REV
LT/RH - A26 - Work Lights -LED W/ Sw Pack - Sleeper W/O RKE W/MAN REV
Design 773
W/ RKE W/MAN REV
LT/RH - A26 - Work Lights -LED W/ Sw Pack - Sleeper W/ RKE W/MAN REV
Design 775
LT/RH/LoneStar - X15 - Work Lights -LED W/ Sw Pack
LT/RH/LoneStar - X15 - Work Lights -LED W/ Sw Pack - Sleeper W/O RKE
W/MAN REV Design 777
LT/RH/LoneStar - X15 - Work Lights -LED W/ Sw Pack - Sleeper W/ RKE W/MAN
REV Design 778
Pack - Sleeper
LT/RH/LoneStar - X15/A26 - Work Lights -LED W/ Sw Pack - Sleeper Design 779
Design 780
LT/RH - A26 - Back of Cab Aux Work Light (2 blunt
cuts without relay) (Backup with Manual Trans- not
Endurant)
LT/RH - A26 - Back of Cab Aux Work Light (2 blunt cuts without relay) (Backup
with Manual Trans- not Endurant) Design 781
LT/RH/LoneStar - X15/A26 - Fifth Wheel Slide
LT/RH/LoneStar - X15/A26 - Fifth Wheel Slide Design 783
TABLE OF CONTENTS
xxxviiLT/RH/LoneStar - Jaw Monitoring (Jost Sensor & In
Cab Display)
LT/RH/LoneStar - Jaw Monitoring (Jost Sensor & In Cab Display) Design 784
LT/RH/LoneStar - X15/A26 - Jaw Monitoring
LT/RH/LoneStar - X15/A26 - Jaw Monitoring Design 787
LT/RH/LoneStar - X15/A26 - Jaw Unlock Control W/
SOLENOIDS W/SWITCH PACKS
LT/RH/LoneStar - X15/A26 - Jaw Unlock Control W/ SOLENOIDS W/SWITCH
PACKS Design 788
(Standard)
LT/RH/LoneStar - X15/A26 - Jaw Unlock Control (Standard) Design 789
LoneStar - X15 - Fuel Heater (Vehicle Powered)
(Davco)
LoneStar - X15 - Fuel Heater (Vehicle Powered) (Davco) Design 790
LT/RH - A26 - Fuel Heater (Vehicle Powered)(Davco)
LT/RH - A26 - Fuel Heater (Vehicle Powered)(Davco) Design 791
LT/RH - X15 - Fuel Heater (Vehicle Powered) (Davco)
LT/RH - X15 - Fuel Heater (Vehicle Powered) (Davco) Design 792
(RAVCOR)
LT/RH - X15 - Fuel Heater (Vehicle Powered) (RAVCOR) Design 794
LT/RH/LoneStar - X15/A26 - Fuel Level (Single Tank -
Left Side)
LT/RH/LoneStar - X15/A26 - Fuel Level (Single Tank - Left Side) Design 795
LT/RH - A26 - Water In Fuel (WIF) Davco W/ Heater
LT/RH - A26 - Water In Fuel (WIF) Davco W/ Heater Design 801
LT/RH - A26 - Water In Fuel (WIF) Racor N/ Heater
LT/RH - A26 - Water In Fuel (WIF) Racor N/ Heater Design 802
LT/RH/LoneStar - X15 - Water In Fuel (WIF) DAVCO N/
Heater
LT/RH/LoneStar - X15 - Water In Fuel (WIF) DAVCO N/ Heater Design 803
LT/RH/LoneStar - X15 - Water In Fuel (WIF) DAVCO W/
Heater
LT/RH/LoneStar - X15 - Water In Fuel (WIF) DAVCO W/ Heater Design 805
LT/RH/LoneStar - X15 - Water In Fuel (WIF) RACOR N/
Heater
LT/RH/LoneStar - X15 - Water In Fuel (WIF) RACOR N/ Heater Design 807
HVAC Actuators
HVAC Actuators Design 808
LT/RH - A26 - Heating Ventilation & Air Conditioning
(HVAC) (Auto Control head W/PT Transducer N/Low
Pressure SW)
TABLE OF CONTENTS
xxxviiiLT/RH - A26 - Heating Ventilation & Air Conditioning (HVAC) (Auto Control head
W/PT Transducer N/Low Pressure SW) Design 809
(HVAC) (Manual W/PT Transduce N/Low Pressure SW)
LT/RH - A26 - Heating Ventilation & Air Conditioning (HVAC) (Manual W/PT
Transduce N/Low Pressure SW) Design 811
LT/RH/LoneStar X15 - Heating Ventilation & Air
Conditioning (HVAC) Auto Temp Control
LT/RH/LoneStar X15 - Heating Ventilation & Air Conditioning (HVAC) Auto Temp
Control Design 812
Conditioning (HVAC) Manual
LT/RH/LoneStar X15 - Heating Ventilation & Air Conditioning (HVAC) Manual
Design 814
LT/RH/LoneStar - X15/A26 - Rear AUTO HVAC (No
Idle) W/ Pre-Heat (Bergstrom Heat and Cool w/
Condensation) 2 SWITCHES
LT/RH/LoneStar - X15/A26 - Rear AUTO HVAC (No Idle) W/ Pre-Heat (Bergstrom
Heat and Cool w/ Condensation) 2 SWITCHES Design 815
LT/RH/LoneStar - X15/A26 - Rear HVAC (No Idle) W/
Pre-Heat (Bergstrom Heat and Cool w/ Condensation)
2 SWITCHES Option 1
LT/RH/LoneStar - X15/A26 - Rear HVAC (No Idle) W/ Pre-Heat (Bergstrom Heat
and Cool w/ Condensation) 2 SWITCHES Option 1 Design 818
2 SWITCHES Option 2
and Cool w/ Condensation) 2 SWITCHES Option 2 Design 820
4 SWITCHES Option 1
and Cool w/ Condensation) 4 SWITCHES Option 1 Design 822
4 SWITCHES Option 2
and Cool w/ Condensation) 4 SWITCHES Option 2 Design 824
LT/RH/LoneStar - X15/A26 - Rear Manual HVAC (No
LT/RH/LoneStar - X15/A26 - Rear Manual HVAC (No Idle) W/ Pre-Heat
(Bergstrom Heat and Cool w/ Condensation) 2 SWITCHES Design 826
Heater) (Espar) Option 1
LT/RH/LoneStar - X15/A26 - Rear HVAC (No Idle Heater) (Espar) Option 1
Design 829
TABLE OF CONTENTS
xxxixLT/RH/LoneStar - X15/A26 - Rear HVAC (No Idle
Heater) (Espar) Option 2
LT/RH/LoneStar - X15/A26 - Rear HVAC (No Idle Heater) (Espar) Option 2
Design 830
LT/RH/LoneStar A26/X15 - No-Idle HVAC (Espar
Airtronic, Berstrom AC, Front Auto Control head)
LT/RH/LoneStar A26/X15 - No-Idle HVAC (Espar Airtronic, Berstrom AC, Front
Auto Control head) Design 831
Airtronic, Berstrom AC, Front Manual Control head
Manual Control head Design 834
Heater) (Webasto Smartemp)
LT/RH/LoneStar - X15/A26 - Rear HVAC (No Idle Heater) (Webasto Smartemp)
Design 837
Heater) (Webasto Std N/Swift) N/ Heat Swtich
LT/RH/LoneStar - X15/A26 - Rear HVAC (No Idle Heater) (Webasto Std N/Swift)
N/ Heat Swtich Design 838
Heater) (Webasto Std W/Swift) N/ Heat Switch
LT/RH/LoneStar - X15/A26 - Rear HVAC (No Idle Heater) (Webasto Std W/Swift)
N/ Heat Switch Design 839
LT/RH/LoneStar - X15/A26 - No Idle HVAC - TRI-PAC
Prewire
LT/RH/LoneStar - X15/A26 - No Idle HVAC - TRI-PAC Prewire Design 840
LT/RH/LoneStar - X15/A26 - Rear HVAC (Sleeper W/
Deluxe)
LT/RH/LoneStar - X15/A26 - Rear HVAC (Sleeper W/ Deluxe) Design 841
Premium)
LT/RH/LoneStar - X15/A26 - Rear HVAC (Sleeper W/ Premium) Design 843
LT/RH - A26 - Ambient Temperature (Mirror Sensor)
LT/RH - A26 - Ambient Temperature (Mirror Sensor) Design 845
LT/RH/LoneStar X15 - Ambient Air Temperature
Option 1
LT/RH/LoneStar X15 - Ambient Air Temperature Option 1 Design 846
Option 2
LT/RH/LoneStar X15 - Ambient Air Temperature Option 2 Design 847
LT/RH/LoneStar - X15/A26 - Auxilary Gauges
(Secondary)
LT/RH/LoneStar - X15/A26 - Auxilary Gauges (Secondary) Design 848
LT/RH/LoneStar - X15/A26 - Auxiliary Gauges
(Primary)
TABLE OF CONTENTS
xlLT/RH/LoneStar - X15/A26 - Auxiliary Gauges (Primary) Design 849
LT/RH/LoneStar - X15/A26 - Brake Pressure (Auxiliary
Gauge)
LT/RH/LoneStar - X15/A26 - Brake Pressure (Auxiliary Gauge) Design 850
LT/RH/LoneStar - X15/A26 - Brake Pressure (Virtual
Gauge)
LT/RH/LoneStar - X15/A26 - Brake Pressure (Virtual Gauge) Design 851
LT/RH/LoneStar - X15/A26 - Compressed Air Supply
(Primary and Secondary Gauge)
LT/RH/LoneStar - X15/A26 - Compressed Air Supply (Primary and Secondary
Gauge) Design 852
LT/RH - A26 - DEF Economy Monitor (Cluster)
LT/RH - A26 - DEF Economy Monitor (Cluster) Design 853
LT/RH/LoneStar - X15 - DEF Economy Monitor (GEN IV
Cluster w/ Cummins ENG)
LT/RH/LoneStar - X15 - DEF Economy Monitor (GEN IV Cluster w/ Cummins
ENG) Design 854
LT/RH/LoneStar - X15/A26 - Engine Usage Monitoring
(Base)
LT/RH/LoneStar - X15/A26 - Engine Usage Monitoring (Base) Design 855
(VID Option)
LT/RH/LoneStar - X15/A26 - Engine Usage Monitoring (VID Option) Design 856
LT/RH - X15/A26 - Engine Oil Level Monitoring (CA2.0)
LT/RH - X15/A26 - Engine Oil Level Monitoring (CA2.0) Design 857
LT/RH/LoneStar - X15/A26 - Engine Oil Pressure
LT/RH/LoneStar - X15/A26 - Engine Oil Pressure Design 858
LT/RH/LoneStar - X15/A26 - Engine Oil Temperature
(NA MUX_AUX Gauge)
LT/RH/LoneStar - X15/A26 - Engine Oil Temperature (NA MUX_AUX Gauge)
Design 859
(NA-Mux)
LT/RH/LoneStar - X15/A26 - Engine Oil Temperature (NA-Mux) Design 860
LT/RH/LoneStar - X15/A26 - Engine Speed
(Tachometer_J1939)
LT/RH/LoneStar - X15/A26 - Engine Speed (Tachometer_J1939) Design 861
LT/RH/LoneStar - X15/A26 - Fuel Economy Monitor
LT/RH/LoneStar - X15/A26 - Fuel Economy Monitor Design 862
LT/RH/LoneStar - X15/A26 - Intake Manifold Pressure
LT/RH/LoneStar - X15/A26 - Intake Manifold Pressure Design 863
LT/RH - X15/A26 - Intake Manifold Pressure AUX
gauge
TABLE OF CONTENTS
xliLT/RH - X15/A26 - Intake Manifold Pressure AUX gauge Design 864
LT/RH/LoneStar - X15/A26 - Odometer (Cluster)
LT/RH/LoneStar - X15/A26 - Odometer (Cluster) Design 865
LT/RH/LoneStar - X15/A26 - Trip Odometer (Cluster)
LT/RH/LoneStar - X15/A26 - Trip Odometer (Cluster) Design 866
LT/RH - X15/A26 - Transmission Oil Level (Low Level
Warning)
LT/RH - X15/A26 - Transmission Oil Level (Low Level Warning) Design 867
LT/RH/LoneStar - X15/A26 - Transmission Oil Level
(Low Level Warning)
LT/RH/LoneStar - X15/A26 - Transmission Oil Level (Low Level Warning)
Design 868
LT/RH - A26 - Transmission Oil Temperature
(Automatic Trans W/ Aux Gauge)
LT/RH - A26 - Transmission Oil Temperature (Automatic Trans W/ Aux Gauge)
Design 869
(Automatic Trans)
LT/RH - A26 - Transmission Oil Temperature (Automatic Trans) Design 870
LT/RH - A26 - Transmission Oil Temperature (Manual
Trans W/ Aux Gauge)
LT/RH - A26 - Transmission Oil Temperature (Manual Trans W/ Aux Gauge)
Design 871
Trans)
LT/RH - A26 - Transmission Oil Temperature (Manual Trans) Design 872
LT/RH/LoneStar - X15 - Transmission Oil Temperature
LT/RH/LoneStar - X15 - Transmission Oil Temperature (Automatic Trans W/ Aux
Gauge) Design 873
(Automatic Trans)
LT/RH/LoneStar - X15 - Transmission Oil Temperature (Automatic Trans)
Design 874
LT/RH/LoneStar - X15 - Transmission Oil TemperatureManual Trans-Horizon Option 1
LT/RH/LoneStar - X15 - Transmission Oil Temperature-Manual Trans-Horizon
Option 1 Design 875
LT/RH/LoneStar - X15 - Transmission Oil TemperatureManual Trans-Horizon Option 2
Option 2 Design 878
LT/RH - A26 - Vehicle Speedometer System (VSS
wired to VIC)
TABLE OF CONTENTS
xliiLT/RH - A26 - Vehicle Speedometer System (VSS wired to VIC) Design 881
LT/RH - A26/X15 - Vehicle Speedometer System
(J1939 Message from TCM to ECM)
LT/RH - A26/X15 - Vehicle Speedometer System (J1939 Message from TCM to
ECM) Design 882
LT/RH/LoneStar - X15 - Vehicle Speedometer System
(Manual XMSN)
LT/RH/LoneStar - X15 - Vehicle Speedometer System (Manual XMSN)
Design 883
(W/AMT/AUTO TRANS)
LT/RH/LoneStar - X15 - Vehicle Speedometer System (W/AMT/AUTO TRANS)
Design 884
LT/RH/LoneStar - X15/A26 - Voltage Monitoring
(Voltmeter) Option 1
LT/RH/LoneStar - X15/A26 - Voltage Monitoring (Voltmeter) Option 1 Design 885
(Voltmeter) Option 2
LT/RH/LoneStar - X15/A26 - Voltage Monitoring (Voltmeter) Option 2 Design 886
(Voltmeter) (with Aux gauge)
LT/RH/LoneStar - X15/A26 - Voltage Monitoring (Voltmeter) (with Aux gauge)
Design 887
LT/RH/LoneStar - X15/A26 - Engine Warning (DM1
LAMPS - MUX)
LT/RH/LoneStar - X15/A26 - Engine Warning (DM1 LAMPS - MUX) Design 888
LT/RH - A26 - High Exhaust System Temperature
(HEST) Monitoring
LT/RH - A26 - High Exhaust System Temperature (HEST) Monitoring Design 889
LT/RH/LoneStar - X15 - High Exhaust System
LT/RH/LoneStar - X15 - High Exhaust System Temperature (HEST) Monitoring
Design 890
LT/RH/LoneStar - X15/A26 - Coolant Temperature
Monitoring (J1939 Comm)
LT/RH/LoneStar - X15/A26 - Coolant Temperature Monitoring (J1939 Comm)
Design 891
LT/RH - A26/X15 - Transmission - MODE Selection
LT/RH - A26/X15 - Transmission - MODE Selection Design 892
LT/RH - A26/X15 - Trans Range Inhibit (J1939 Comm)
LT/RH - A26/X15 - Trans Range Inhibit (J1939 Comm) Design 893
LT/RH A26 - X15/A26 - Up Shift Indicator (CA 2.0)
LT/RH A26 - X15/A26 - Up Shift Indicator (CA 2.0) Design 894
LT/RH/LoneStar - X15/A26 - Transmission Range
TABLE OF CONTENTS
xliiiLT/RH/LoneStar - X15/A26 - Transmission Range Inhibit (J1939 Comm)
Design 895
LT/RH/LoneStar - X15/A26 - Vehicle Information
Display (VID-W/BT)
LT/RH/LoneStar - X15/A26 - Vehicle Information Display (VID-W/BT) Design 896
Display (VID-W/O BT)
LT/RH/LoneStar - X15/A26 - Vehicle Information Display (VID-W/O BT)
Design 897
LT/RH/LoneStar - X15/A26 - Lighting - Cabinet Lights
LT/RH/LoneStar - X15/A26 - Lighting - Cabinet Lights Design 898
LT/RH/LoneStar - X15/A26 - Courtesy Light Cab
LT/RH/LoneStar - X15/A26 - Courtesy Light Cab Design 899
LT/RH/LoneStar - X15/A26 - Cab Dome Light (Day Cab)
LT/RH/LoneStar - X15/A26 - Cab Dome Light (Day Cab) Design 900
LT/RH/LoneStar - X15/A26 - Cab Dome Light - (Sleeper
Cab)
LT/RH/LoneStar - X15/A26 - Cab Dome Light - (Sleeper Cab) Design 901
LT/RH/LoneStar - X15/A26 - Lighting Sleeper Dome
LT/RH/LoneStar - X15/A26 - Lighting Sleeper Dome Design 902
LT/RH/LoneStar - X15/A26 - Floor/Search Lights
DayCab
LT/RH/LoneStar - X15/A26 - Floor/Search Lights DayCab Design 903
Sleeper
LT/RH/LoneStar - X15/A26 - Floor/Search Lights Sleeper Design 904
Sleeper (1 Light)
LT/RH/LoneStar - X15/A26 - Floor/Search Lights Sleeper (1 Light) Design 905
LT/RH/LoneStar - X15/A26 - Interior Task Lights (Map)
(Cab Dome / Map Combo) - DayCab
LT/RH/LoneStar - X15/A26 - Interior Task Lights (Map) (Cab Dome / Map Combo)
- DayCab Design 906
Light-Separate map light from cab dome) - Sleeper
LT/RH/LoneStar - X15/A26 - Interior Task Lights (Map Light-Separate map light
from cab dome) - Sleeper Cab Design 907
LT/RH/LoneStar - X15/A26 - Luggage Compartment
Lights - W/O No Idle HVAC
LT/RH/LoneStar - X15/A26 - Luggage Compartment Lights - W/O No Idle HVAC
Design 908
TABLE OF CONTENTS
xlivLT/RH/LoneStar - X15/A26 - Luggage Compartment
Lights - W/ No Idle HVAC
LT/RH/LoneStar - X15/A26 - Luggage Compartment Lights - W/ No Idle HVAC
Design 909
LT/RH/LoneStar - X15/A26 - Panel Backlighting (Cabin
Dimmer) Option 1
LT/RH/LoneStar - X15/A26 - Panel Backlighting (Cabin Dimmer) Option 1
Design 910
Dimmer) Option 2
LT/RH/LoneStar - X15/A26 - Panel Backlighting (Cabin Dimmer) Option 2
Design 911
LT/RH/LoneStar - X15/A26 - Reading Lighting -
W/Lower
LT/RH/LoneStar - X15/A26 - Reading Lighting - W/Lower Design 912
W/Upper& Lower
LT/RH/LoneStar - X15/A26 - Reading Lighting - W/Upper& Lower Design 913
LT/RH/LoneStar - X15/A26 - Rear Interior Dimming
(Accent Light)
LT/RH/LoneStar - X15/A26 - Rear Interior Dimming (Accent Light) Design 914
(Accent/Mood)
LT/RH/LoneStar - X15/A26 - Rear Interior Dimming (Accent/Mood) Design 915
LT/RH - A26/X15 - Axle Loading (Weight) (Rear,
Horizon)
LT/RH - A26/X15 - Axle Loading (Weight) (Rear, Horizon) Design 916
LT/RH/LoneStar - X15/A26 - Axle Loading (Weight)
Rear
LT/RH/LoneStar - X15/A26 - Axle Loading (Weight) Rear Design 918
LT/RH/LoneStar - X15/A26 - Single Axle Temperature
Monitoring
LT/RH/LoneStar - X15/A26 - Single Axle Temperature Monitoring Design 920
Monitoring w/Aux Gauge
LT/RH/LoneStar - X15/A26 - Single Axle Temperature Monitoring w/Aux Gauge
Design 921
LT/RH/LoneStar - X15/A26 - Tandem Axle Temperature
Monitoring
LT/RH/LoneStar - X15/A26 - Tandem Axle Temperature Monitoring Design 922
LT/RH/LoneStar - X15/A26 - Tandem Axle Temperature Monitoring w/Aux Gauge
Design 924
TABLE OF CONTENTS
xlvLT/RH/LoneStar - X15/A26 - Tandem Axle Temperature
Monitoring w/ Single SNSR and AUX Gauge
LT/RH/LoneStar - X15/A26 - Tandem Axle Temperature Monitoring w/ Single
SNSR and AUX Gauge Design 926
LT/RH/LoneStar - X15/A26 - Driver Controlled Locking
Differential - FR & RR Axle (DANA)
LT/RH/LoneStar - X15/A26 - Driver Controlled Locking Differential - FR & RR Axle
(DANA) Design 927
LT/RH/LoneStar - X15/A26 - 2 Driver Controlled
Locking Differential - FR & RR Axle (DANA)
LT/RH/LoneStar - X15/A26 - 2 Driver Controlled Locking Differential - FR & RR
Axle (DANA) Design 928
Differential - RR Axle (DANA)
LT/RH/LoneStar - X15/A26 - Driver Controlled Locking Differential - RR Axle
(DANA) Design 929
Differential - FR (MERITOR)
(MERITOR) Design 931
Differential - FR & RR Axle (MERITOR)
(MERITOR) Design 932
Locking Differential - FR & RR Axle (MERITOR)
Axle (MERITOR) Design 933
Differential - RR Axle (MERITOR)
(MERITOR) Design 934
LT/RH/LoneStar - X15/A26 - Height Control
LT/RH/LoneStar - X15/A26 - Height Control Design 936
LT/RH/LoneStar - X15/A26 - Power Divider Lock
Control and Monitoring
LT/RH/LoneStar - X15/A26 - Power Divider Lock Control and Monitoring
Design 937
LT/RH/LoneStar - X15/A26 - Seats Climate Controlled
(Drivers Heated Seat)
LT/RH/LoneStar - X15/A26 - Seats Climate Controlled (Drivers Heated Seat)
Design 938
LT/RH/LoneStar - X15/A26 - Seatbelt Reminder
(Warning)(Driver only)
LT/RH/LoneStar - X15/A26 - Seatbelt Reminder (Warning)(Driver only) Design939
(Warning)(Driver & Passenger in parallel)
TABLE OF CONTENTS
xlviLT/RH/LoneStar - X15/A26 - Seatbelt Reminder (Warning)(Driver & Passenger in
parallel) Design 940
LT/RH - X15/A26 - Auxiliary Trailer Power (W/ Park
Brake)
LT/RH - X15/A26 - Auxiliary Trailer Power (W/ Park Brake) Design 941
LT/RH/LoneStar - X15/A26 - Auxiliary Trailer Power
CAV D
LT/RH/LoneStar - X15/A26 - Auxiliary Trailer Power CAV D Design 943
LT/RH/LoneStar - X15/A26 - Auxiliary Trailer Power W/
ISO Trailer Socket
LT/RH/LoneStar - X15/A26 - Auxiliary Trailer Power W/ ISO Trailer Socket
Design 945
LT/RH/LoneStar - X15/A26 - Mobile Communications
Sensor Wiring Effects for Trailer TRAC
LT/RH/LoneStar - X15/A26 - Mobile Communications Sensor Wiring Effects for
Trailer TRAC Design 946
LoneStar - X15 - Trailer Interface (ABS) - Center Pin
Circuit
LoneStar - X15 - Trailer Interface (ABS) - Center Pin Circuit Design 948
LT/RH - X15/A26 - Trailer Interface (ABS) - Center Pin
Circuit
LT/RH - X15/A26 - Trailer Interface (ABS) - Center Pin Circuit Design 952
LT/RH/LoneStar - X15/A26 - Trailer Interface (ABS) -
BOC & EOF_NA
LT/RH/LoneStar - X15/A26 - Trailer Interface (ABS) - BOC & EOF_NA Design 956
BOC_NA
LT/RH/LoneStar - X15/A26 - Trailer Interface (ABS) - BOC_NA Design 960
TRAMEC_NA
LT/RH/LoneStar - X15/A26 - Trailer Interface (ABS) - TRAMEC_NA Design 962
LT/RH/LoneStar - X15/A26 - Trailer Interface (Lighting)
– BOC NA
LT/RH/LoneStar - X15/A26 - Trailer Interface (Lighting) – BOC NA Design 963
– BOC & EOF_NA
LT/RH/LoneStar - X15/A26 - Trailer Interface (Lighting) – BOC & EOF_NA
Design 965
– TRAMEC_NA
LT/RH/LoneStar - X15/A26 - Trailer Interface (Lighting) – TRAMEC_NA
Design 969
LT/RH - A26 - Transmission Shifter (Eaton Endurant
and Eaton Procision)
TABLE OF CONTENTS
xlviiLT/RH - A26 - Transmission Shifter (Eaton Endurant and Eaton Procision)
Design 970
LT/RH - A26 - Transmission Shifter (Stalk Shifter,
Eaton Endurant)
LT/RH - A26 - Transmission Shifter (Stalk Shifter, Eaton Endurant) Design 971
LT/RH - A26 - Transmission Shifter (Universal Stalk
Shifter - Allison 3K/4K)
LT/RH - A26 - Transmission Shifter (Universal Stalk Shifter - Allison 3K/4K)
Design 972
Shifter, Ultrashift)
LT/RH - A26 - Transmission Shifter (Universal Stalk Shifter, Ultrashift) Design 973
LT/RH - A26/X15 - Transmission Shifter (Universal
LT/RH - A26/X15 - Transmission Shifter (Universal Stalk Shifter - Allison 3K/4K)
Design 974
LT/RH - X15 - Transmission Shifter (Stalk Shifter,
Eaton Endurant)
LT/RH - X15 - Transmission Shifter (Stalk Shifter, Eaton Endurant) Design 975
LT/RH/LoneStar - X15 - Transmission Shifter (Eaton
LT/RH/LoneStar - X15 - Transmission Shifter (Eaton Endurant and Eaton
Procision) Design 976
(Universal Shifter - Ultrashift+ & FAS)
LT/RH/LoneStar - X15 - Transmission Shifter (Universal Shifter - Ultrashift+ &
FAS) Design 977
LT/RH - A26 - Transmission (Endurant)
LT/RH - A26 - Transmission (Endurant) Design 978
LT/RH/LoneStar X15 - Endurant Transmission
LT/RH/LoneStar X15 - Endurant Transmission Design 979
LT/RH - A26 - Transmission (Ultrashift + FAS)
LT/RH - A26 - Transmission (Ultrashift + FAS) Design 980
LT/RH/LoneStar X15 - Ultrashift Plus
LT/RH/LoneStar X15 - Ultrashift Plus Design 981
LT/RH - A26 - Transmission (Allison 3K)
LT/RH - A26 - Transmission (Allison 3K) Design 982
LT/RH - A26 - Auto Neutral (Allison with Multiplex
Switch and Confirmation Telltale)
LT/RH - A26 - Auto Neutral (Allison with Multiplex Switch and Confirmation
Telltale) Design 983
LT/RH/LoneStar - X15 - Auto Neutral (J1939 Comms
TC10 and Ultrashift)
LT/RH/LoneStar - X15 - Auto Neutral (J1939 Comms TC10 and Ultrashift)
Design 984
TABLE OF CONTENTS
xlviiiLT/RH A26 - Endurant Transmission
LT/RH A26 - Endurant Transmission Design 985
LT/RH X15 - Endurant Transmission
LT/RH X15 - Endurant Transmission Design 986
LT/RH/LoneStar X15 - TC10 Series
LT/RH/LoneStar X15 - TC10 Series Design 987
LT/RH A26 - Transmission (Ultrashift+ w/Body Builder)
LT/RH A26 - Transmission (Ultrashift+ w/Body Builder) Design 988
LT/RH/LoneStar X15 - Transmission (Ultrashift+
w/Body Builder)
LT/RH/LoneStar X15 - Transmission (Ultrashift+ w/Body Builder) Design 989
LT/RH - X15/A26 - Hill Start Aid (HSA) (Bendix CA 2.0)
Option 1
LT/RH - X15/A26 - Hill Start Aid (HSA) (Bendix CA 2.0) Option 1 Design 990
Option 2
LT/RH - X15/A26 - Hill Start Aid (HSA) (Bendix CA 2.0) Option 2 Design 993
LT/RH - X15/A26 - Hill Start Aid (HSA) (Wabco)
LT/RH - X15/A26 - Hill Start Aid (HSA) (Wabco) Design 996
LT/RH/LoneStar - X15/A26 - Hill Start Aid (Bendix)
LT/RH/LoneStar - X15/A26 - Hill Start Aid (Bendix) Design 997
LT/RH/LoneStar - X15/A26 - Hill Start Aid (Wabco)
LT/RH/LoneStar - X15/A26 - Hill Start Aid (Wabco) Design 1000
LT/RH/LoneStar - X15/A26 - Transmission - MODE
Selection
LT/RH/LoneStar - X15/A26 - Transmission - MODE Selection Design 1001
LT/RH A26 - Transmission I/O (Endurant Pressure
Sensor)
LT/RH A26 - Transmission I/O (Endurant Pressure Sensor) Design 1002
LT/RH/LoneStar X15 - Transmission I/O (Endurant
Pressure Sensor)
LT/RH/LoneStar X15 - Transmission I/O (Endurant Pressure Sensor) Design 1003
LT/RH - A26/X15 - Heated Windshield (W/ DS Heating
Grid)
LT/RH - A26/X15 - Heated Windshield (W/ DS Heating Grid) Design 1004
LoneStar - X15 - Windshield Washer Pump
LoneStar - X15 - Windshield Washer Pump Design 1005
LoneStar - X15 - Windshield Washer Pump & Low
Fluid Sensor
LoneStar - X15 - Windshield Washer Pump & Low Fluid Sensor Design 1006
LT/RH - X15/A26 - Windshield Washer Pump
LT/RH - X15/A26 - Windshield Washer Pump Design 1007
TABLE OF CONTENTS
xlixLT/RH - X15/A26 - Windshield Washer Pump & Low
Fluid Sensor
LT/RH - X15/A26 - Windshield Washer Pump & Low Fluid Sensor Design 1008
LT/RH - X15/A26 - Windshield Wipers Cruise Disable
W/Wipers ON
LT/RH - X15/A26 - Windshield Wipers Cruise Disable W/Wipers ON Design 1009
LT/RH - X15/A26 - Windshield Wipers Cruise Disable &
Park Brake W/Wipers ON
LT/RH - X15/A26 - Windshield Wipers Cruise Disable & Park Brake W/Wipers ON
Design 1010
LT/RH/LoneStar - X15/A26 - Windshield Wipers Park
Brake W/Wipers ON
LT/RH/LoneStar - X15/A26 - Windshield Wipers Park Brake W/Wipers ON
Design 1011
Standard
LT/RH/LoneStar - X15/A26 - Windshield Wipers Standard Design 1012
LT/RH A26/X15 - Auto Start Stop with Sleeper Auto
Climate, Cab Temp, Oil Mapping, Auto Trans
LT/RH A26/X15 - Auto Start Stop with Sleeper Auto Climate, Cab Temp, Oil
Mapping, Auto Trans Design 1013
LT/RH A26/X15 - Auto Start Stop (Horizon) Battery &
Oil Temp Mapping, Auto Trans
LT/RH A26/X15 - Auto Start Stop (Horizon) Battery & Oil Temp Mapping, Auto
Trans Design 1014
LT/RH - A26 - Auto Start Stop with Sleeper Auto
Climate Cab Temp Oil Mapping (Auto Trans)
LT/RH - A26 - Auto Start Stop with Sleeper Auto Climate Cab Temp Oil Mapping
(Auto Trans) Design 1015
LT/RH - A26 - Auto Start Stop and Sleeper Auto
Climate Cab Temp Oil Mapping ( Manual Trans)
LT/RH - A26 - Auto Start Stop and Sleeper Auto Climate Cab Temp Oil Mapping (
Manual Trans) Design 1016
LT/RH - A26 - Auto Start Stop Battery Oil Temp
Mapping Manual Trans
LT/RH - A26 - Auto Start Stop Battery Oil Temp Mapping Manual Trans
Design 1017
LT/RH X15 - Auto Start/Stop with Sleeper Auto
Climate, Cab Temp, with Oil Temp Sensor, Auto Trans
LT/RH X15 - Auto Start/Stop with Sleeper Auto Climate, Cab Temp, with Oil Temp
Sensor, Auto Trans Design 1018
LT/RH X15 - Auto Start/Stop (Horizon) Oil Temp
Sensor, Auto Trans
LT/RH X15 - Auto Start/Stop (Horizon) Oil Temp Sensor, Auto Trans Design 1019
LT/RH/LoneStar X15 - Auto Start Stop Oil Temp
Sensor Auto Trans
TABLE OF CONTENTS
lLT/RH/LoneStar X15 - Auto Start Stop Oil Temp Sensor Auto Trans Design 1020
LT/RH/LoneStar X15 - Auto Start Stop with Sleeper
Auto Climate / Cab Temp with Oil Temp Sensor Auto
Trans
LT/RH/LoneStar X15 - Auto Start Stop with Sleeper Auto Climate / Cab Temp with
Oil Temp Sensor Auto Trans Design 1021
Sensor Manual Trans
LT/RH/LoneStar X15 - Auto Start Stop Oil Temp Sensor Manual Trans
Design 1022
Manual Trans
Oil Temp Sensor Manual Trans Design 1023
LT/RH - X15/A26 - Battery Disconnect
LT/RH - X15/A26 - Battery Disconnect Design 1024
LT/RH - A26 - Charging System (Bosch LH160_LH200
Alternator)
LT/RH - A26 - Charging System (Bosch LH160_LH200 Alternator) Design 1025
LT/RH - A26 - Charging System (Bosch LIL165_LIL200
Alternator W/ Remote Sense)
LT/RH - A26 - Charging System (Bosch LIL165_LIL200 Alternator W/ Remote
Sense) Design 1028
LT/RH/LoneStar - X15 - Bosch LH160_LH200
Alternator W/ Delco Starter
LT/RH/LoneStar - X15 - Bosch LH160_LH200 Alternator W/ Delco Starter
Design 1031
Alternator W/ Mitsubishi Starter
LT/RH/LoneStar - X15 - Bosch LH160_LH200 Alternator W/ Mitsubishi Starter
Design 1032
LT/RH/LoneStar - X15 - Bosch LIL165_LIL200
Alternator W/ Remote Sense W/ Delco Starter
LT/RH/LoneStar - X15 - Bosch LIL165_LIL200 Alternator W/ Remote Sense W/
Delco Starter Design 1033
Alternator W/ Remote Sense W/ Mitsubishi Starter
Mitsubishi Starter Design 1034
LT/RH - A26 - Charging System (Delco Remy 28SI
LT/RH - A26 - Charging System (Delco Remy 28SI Alternator W/ Remote Sense)
Design 1035
TABLE OF CONTENTS
liLT/RH - A26 - Charging System (Delco Remy 36SI
LT/RH - A26 - Charging System (Delco Remy 36SI Alternator W/ Remote Sense)
Design 1038
LT/RH - A26 - Charging System (Delco Remy 40SI/38SI
LT/RH - A26 - Charging System (Delco Remy 40SI/38SI Alternator W/ Remote
Sense) Design 1041
LT/RH/LoneStar - X15 - Delco Remy 28SI Alternator W/
LT/RH/LoneStar - X15 - Delco Remy 28SI Alternator W/ Remote Sense W/ Delco
Starter Design 1044
Mitsubishi Starter Design 1046
LT/RH/LoneStar - X15 - Delco Remy 36SI Alternator W/
LT/RH/LoneStar - X15 - Delco Remy 36SI Alternator W/ Remote Sense W/
Mitsubishi Starter Design 1048
Remtoe Sense W/ Delco Starter
LT/RH/LoneStar - X15 - Delco Remy 36SI Alternator W/ Remtoe Sense W/ Delco
Starter Design 1049
LT/RH/LoneStar - X15 - Delco Remy 40SI Alternator W/
LT/RH/LoneStar - X15 - Delco Remy 40SI Alternator W/ Remote Sense W/ Delco
Starter Design 1050
Mitsubishi Starter Design 1052
LT/RH - A26 - Charging System (Leece-Neville AVI160-
160A/210A/240A N/ Remote Sense)
LT/RH - A26 - Charging System (Leece-Neville AVI160-160A/210A/240A N/
Remote Sense) Design 1054
190A/210A/240A Alternator W/ Remote Sense)
LT/RH - A26 - Charging System (Leece-Neville AVI160-190A/210A/240A
Alternator W/ Remote Sense) Design 1057
14931PAH_14923PAH Alternator)
LT/RH - A26 - Charging System (Leece-Neville 14931PAH_14923PAH Alternator)
Design 1060
LT/RH - A26 - Charging System (Leece-Neville - LN
325A Alternator W/ Remote Sense)
LT/RH - A26 - Charging System (Leece-Neville - LN 325A Alternator W/ Remote
Sense) Design 1063
TABLE OF CONTENTS
liiLT/RH/LoneStar - X15 - Leece-Neville AVI160
LT/RH/LoneStar - X15 - Leece-Neville AVI160 Alternator W/ Delco Starter
Design 1066
LT/RH/LoneStar - X15 - Leece-Neville AVI160 Alternator W/ Mitsubishi Starter
Design 1067
LT/RH/LoneStar - X15 - Leece-Neville AVI160-
210A/240A Alternator W/ Remote Sense W/ Delco
Starter
LT/RH/LoneStar - X15 - Leece-Neville AVI160-210A/240A Alternator W/ Remote
Sense W/ Delco Starter Design 1068
210A/240A Alternator W/ Remote Sense W/ Mitsubishi
Starter
Sense W/ Mitsubishi Starter Design 1069
LT/RH/LoneStar - X15 - Leece-Neville 320PAH
LT/RH/LoneStar - X15 - Leece-Neville 320PAH Alternator W/ Delco Starter
Design 1070
LT/RH/LoneStar - X15 - Leece-Neville 320PAH Alternator W/ Mitsubishi Starter
Design 1071
LT/RH/LoneStar - X15 - Leece-Neville - LN 325A
LT/RH/LoneStar - X15 - Leece-Neville - LN 325A Alternator W/ Remote Sense W/
Delco Starter Design 1072
Mitsubishi Starter Design 1073
LT/RH/LoneStar - X15/A26 - Cranking Request (BCM
Controlled)
LT/RH/LoneStar - X15/A26 - Cranking Request (BCM Controlled) Design 1074
LT/RH/LoneStar - X15/A26 - Engine Speed Inhibit Only
LT/RH/LoneStar - X15/A26 - Engine Speed Inhibit Only Design 1075
LT/RH - A26 - Cranking (Starter) (BCM Controlled & N/
Wired Thermal Overcrank)
LT/RH - A26 - Cranking (Starter) (BCM Controlled & N/ Wired Thermal
Overcrank) Design 1076
Wired Thermal Over-Crank)
LT/RH - A26 - Cranking (Starter) (BCM Controlled & N/ Wired Thermal OverCrank) Design 1077
TABLE OF CONTENTS
liiiLT/RH/LoneStar - X15 - Cranking (Starter) GEN4 BCM
W/O Thermal Overcrank Wiring
LT/RH/LoneStar - X15 - Cranking (Starter) GEN4 BODY CONTROL MODULE
W/O Thermal Overcrank Wiring Design 1078
LT/RH - A26 - Cranking (Starter) (BCM Controlled & W/
LT/RH - A26 - Cranking (Starter) (BCM Controlled & W/ Wired Thermal
Overcrank) Design 1079
Wired Thermal Over-crank)
LT/RH - A26 - Cranking (Starter) (BCM Controlled & W/ Wired Thermal Overcrank) Design 1080
W/ Thermal Overcrank - External Switch
LT/RH/LoneStar - X15 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/
Thermal Overcrank - External Switch Design 1081
LT/RH/LoneStar - X15/A26 - DC/AC Inverter
LT/RH/LoneStar - X15/A26 - DC/AC Inverter Design 1082
LT/RH/LoneStar - X15/A26 - DC/AC Inverter (1200W
W/switch control)
LT/RH/LoneStar - X15/A26 - DC/AC Inverter (1200W W/switch control)
Design 1083
LT/RH/LoneStar - X15/A26 - DC/AC Inverter (1800W)
LT/RH/LoneStar - X15/A26 - DC/AC Inverter (1800W) Design 1084
LT/RH/LoneStar - X15/A26 - Electrical Load
Control(Load Shed)
LT/RH/LoneStar - X15/A26 - Electrical Load Control(Load Shed) Design 1085
LT/RH/LoneStar - X15/A26 - JUMP START STUD
(DUAL)
LT/RH/LoneStar - X15/A26 - JUMP START STUD (DUAL) Design 1086
(SINGLE)
LT/RH/LoneStar - X15/A26 - JUMP START STUD (SINGLE) Design 1087
LT/RH/LoneStar - X15/A26 - Key Switch (Operator
Input)
LT/RH/LoneStar - X15/A26 - Key Switch (Operator Input) Design 1088
LT/RH - A26/X15 - Maxwell 12V Ultracapacitor Engine
Start Module (ESM)
LT/RH - A26/X15 - Maxwell 12V Ultracapacitor Engine Start Module (ESM)
Design 1089
LT/RH/LoneStar - X15/A26 - Clutch Monitoring (High
and Low Switch to BCM)
LT/RH/LoneStar - X15/A26 - Clutch Monitoring (High and Low Switch to BCM)
Design 1090
TABLE OF CONTENTS
livLoneStar - X15 - Crank Inhibit with Hood Switch - with
new BCM Pin
LoneStar - X15 - Crank Inhibit with Hood Switch - with New BODY CONTROL
MODULE Pin Design 1091
LoneStar - X15 - Hood Switch
LoneStar - X15 - Hood Switch Design 1093
LT/RH - X15/A26 - Hood Switch
LT/RH - X15/A26 - Hood Switch Design 1094
LT/RH - X15/A26 - with Hood Switch - with new BCM
Pin
LT/RH - X15/A26 - with Hood Switch - with New BODY CONTROL MODULE Pin
Design 1095
LT/RH - A26 - Starter Interlocks (BCM controlled with
input from Allison TCM
LT/RH - A26 - Starter Interlocks (BCM controlled with input from Allison TCM
Design 1096
LT/RH - A26 - Starter Interlocks (Service Brake
Interlock)
LT/RH - A26 - Starter Interlocks (Service Brake Interlock) Design 1097
Interlock)(Rev2)
LT/RH - A26 - Starter Interlocks (Service Brake Interlock)(Rev2) Design 1098
LT/RH - A26 - Starter Interlock (BCM HSD Controlled
w/ Relay & N/ Neutral Switch)
LT/RH - A26 - Starter Interlock (BCM HSD Controlled w/ Relay & N/ Neutral
Switch) Design 1099
W/ Relay & W/ Neutral Switch)
LT/RH - A26 - Starter Interlock (BCM HSD Controlled W/ Relay & W/ Neutral
Switch) Design 1100
LT/RH - A26 - Starter Interlock (BCM HSD CTRL W/
Clutch Switch W/ Neutral Switch)
LT/RH - A26 - Starter Interlock (BCM HSD CTRL W/ Clutch Switch W/ Neutral
Switch) Design 1101
LT/RH - X15 - Starter Interlocks (Service Brake
Interlock)
LT/RH - X15 - Starter Interlocks (Service Brake Interlock) Design 1102
LT/RH/LoneStar - X15 - Starter Interlocks ISX TC10
LT/RH/LoneStar - X15 - Starter Interlocks ISX TC10 Design 1103
LT/RH/LoneStar - X15 - Starter Interlocks (Service
Brake Interlock)
LT/RH/LoneStar - X15 - Starter Interlocks (Service Brake Interlock) Design 1104
LT/RH/LoneStar - X15 - Starter Interlock (BCM HSD
controlled W/ Clutch Switch N/ Auto Start Stop)
TABLE OF CONTENTS
lvLT/RH/LoneStar - X15 - Starter Interlock (BCM HSD controlled W/ Clutch Switch
N/ Auto Start Stop) Design 1105
controlled W/ Clutch Switch W/ Auto Start Stop)
W/ Auto Start Stop) Design 1106
LT/RH/LoneStar - X15 - Starter Interlock (BCM LSD
Controlled w/ Relay)_EATON XMSN
LT/RH/LoneStar - X15 - Starter Interlock (BCM LSD Controlled w/ Relay)_EATON
XMSN Design 1107
LT/RH A26 - Battery International (3) 12V
LT/RH A26 - Battery International (3) 12V Design 1108
LT/RH/LoneStar X15 - Battery International (3) 12V
LT/RH/LoneStar X15 - Battery International (3) 12V Design 1109
LT/RH A26 - Battery International (4) 12V
LT/RH A26 - Battery International (4) 12V Design 1110
LT/RH/LoneStar X15 - Battery International (4) 12V
LT/RH/LoneStar X15 - Battery International (4) 12V Design 1111
LT/RH - A26 - Battery International (8) 12V
LT/RH - A26 - Battery International (8) 12V Design 1112
LT/RH/LoneStar X15 - Battery International (8) 12V
LT/RH/LoneStar X15 - Battery International (8) 12V Design 1113
Connectors 1114
Index 3721
