International Truck HX Series Interactive Schematics 0000018830 2022
Brand: International, Navistar
Type of Manual: Interactive Schematics
Model: International HX Series Truck
Built: 2021
Part Number: 0000018830
Publication Date: 2022
Number of Pages: 2517 Pages
Adaptive Cruise Control (Bendix Wingman Advanced
N/ DIU)
Adaptive Cruise Control (Bendix Wingman Advanced N/ DIU) Design 1
Adaptive Cruise Control (Bendix - Fusion W/O DIU &
N/ Safety Direct & Reg Speakers)
Adaptive Cruise Control (Bendix - Fusion W/O DIU & N/ Safety Direct & Reg
Speakers) Design 2
N/ Safety Direct & Tweeters)
Adaptive Cruise Control (Bendix - Fusion W/O DIU & N/ Safety Direct & Tweeters)
Design 4
W/ Safety Direct & Reg Speakers)
Adaptive Cruise Control (Bendix - Fusion W/O DIU & W/ Safety Direct & Reg
Speakers) Design 5
W/ Safety Direct & W/ Tweeters)
Adaptive Cruise Control (Bendix - Fusion W/O DIU & W/ Safety Direct & W/
Tweeters) Design 7
Adaptive Cruise Control (Bendix - Fusion 2.0 N/ Safety
Adaptive Cruise Control (Bendix - Fusion 2.0 N/ Safety Direct & Reg Speakers)
Design 8
Direct & Tweeters)
Adaptive Cruise Control (Bendix - Fusion 2.0 N/ Safety Direct & Tweeters)
Design 9
Adaptive Cruise Control (Bendix - Fusion 2.0 W/
Adaptive Cruise Control (Bendix - Fusion 2.0 W/ Safety Direct & W/ Tweeters)
Design 10
Adaptive Cruise Control (Bendix - Fusion 2.0 & W/
Adaptive Cruise Control (Bendix - Fusion 2.0 & W/ Safety Direct & Reg Speakers)
Design 11
Adaptive Cruise Control (Fusion 3.0 N/ DIU)
Adaptive Cruise Control (Fusion 3.0 N/ DIU) Design 12
Air Dryer (Single)
Air Dryer (Single) Design 13
Air Horn Highway With Hardwired Switch
Air Horn Highway With Hardwired Switch Design 14
Air Solenoids 4-pack (1 pack/4 solenoids)
Air Solenoids 4-pack (1 pack/4 solenoids) Design 15
Air Solenoids 4-pack (2 packs/8 solenoids)
Air Solenoids 4-pack (2 packs/8 solenoids) Design 16
iAir Solenoids 4-pack (3 packs/12 solenoids)
Air Solenoids 4-pack (3 packs/12 solenoids) Design 17
Antenna (Film Antenna, Sleeper, OTAPM, AM/FM, XM
Radio)
Antenna (Film Antenna, Sleeper, OTAPM, AM/FM, XM Radio) Design 18
Antenna (Shark Fin, AM/FM/WB only)
Antenna (Shark Fin, AM/FM/WB only) Design 20
Antenna (Shark Fin, Day Cab, OTAPM, AM/FM, XM
Radio)
Antenna (Shark Fin, Day Cab, OTAPM, AM/FM, XM Radio) Design 21
Antilock Brake System (ABS) (BENDIX 4 Channel
Implemenation - No Modulator Twist)
Antilock Brake System (ABS) (BENDIX 4 Channel Implemenation - No Modulator
Twist) Design 22
Antilock Brake System (ABS) (Bendix 6 Channel
Implementation - No Modulator Twist)
Antilock Brake System (ABS) (Bendix 6 Channel Implementation - No Modulator
Twist) Design 28
Automatic Lighting With Twilight & Not With Sunload
Automatic Lighting With Twilight & Not With Sunload Design 34
Automatic Lighting With Twilight & With Sunload
Automatic Lighting With Twilight & With Sunload Design 35
Auto Start Stop Battery & Oil Temp Mapping, Auto
Trans
Auto Start Stop Battery & Oil Temp Mapping, Auto Trans Design 36
Auto Start Stop Battery, Oil Temp Mapping, Manual
Trans
Auto Start Stop Battery, Oil Temp Mapping, Manual Trans Design 37
Auxiliary Gauges (Multiple)
Auxiliary Gauges (Multiple) Design 38
Auxiliary Gauges (Single)
Auxiliary Gauges (Single) Design 39
Auxiliary Power Source (Sleeper) - 3 APO
Auxiliary Power Source (Sleeper) - 3 APO Design 40
Auxiliary Power (40A) HSD
Auxiliary Power (40A) HSD Design 42
Auxiliary Roof Power (20A)
Auxiliary Roof Power (20A) Design 43
Auxiliary Trailer Power (BOC, ACC Bias)
Auxiliary Trailer Power (BOC, ACC Bias) Design 44
Auxiliary Trailer Power (POGO, ACC Bias)
Auxiliary Trailer Power (POGO, ACC Bias) Design 46
iiAUX Power Connector
AUX Power Connector Design 47
Aux Power (Banana Plug)
Aux Power (Banana Plug) Design 48
Aux Power (Blunt Cut)
Aux Power (Blunt Cut) Design 49
Aux Power (USB) - 1 USB
Aux Power (USB) - 1 USB Design 50
Aux Power (USB) - 2 USB
Aux Power (USB) - 2 USB Design 51
Aux Power (USB) - 3 USB
Aux Power (USB) - 3 USB Design 53
Aux Power (USB) - 4 USB
Aux Power (USB) - 4 USB Design 55
Aux Power (USB) - 5 USB
Aux Power (USB) - 5 USB Design 57
Axle Loading (Weight) (Rear)
Axle Loading (Weight) (Rear) Design 59
Axle Temperature (Tandem, Aux Gauges)
Axle Temperature (Tandem, Aux Gauges) Design 60
Axle Temperature (Tandem, Virtual Gauges)
Axle Temperature (Tandem, Virtual Gauges) Design 61
Axle Temperature (Tridem, Aux Gauges)
Axle Temperature (Tridem, Aux Gauges) Design 62
Axle Temperature (Tridem, Virtual Gauges)
Axle Temperature (Tridem, Virtual Gauges) Design 63
A26 Endurant Manual Transmission - Transmission
Power Take Off (Dual PTO W/ 42 Parameters & W/
Auto, AMT Trans)
A26 Endurant Manual Transmission - Transmission Power Take Off (Dual PTO
W/ 42 Parameters & W/ Auto, AMT Trans) Design 64
Manual Trans)
W/ 42 Parameters & W/ Manual Trans) Design 65
Power Take Off (Single PTO W/42 Parameters & W/
Auto, AMT Trans)
A26 Endurant Manual Transmission - Transmission Power Take Off (Single PTO
W/42 Parameters & W/ Auto, AMT Trans) Design 66
iiiA26 Endurant Manual Transmission - Transmission
Power Take Off (Single PTO W/ 42 Parameters & W/
Manl Trans)
W/ 42 Parameters & W/ Manl Trans) Design 67
A26 Endurant Transmission - Starter Interlocks
(Service Brake Interlock)
A26 Endurant Transmission - Starter Interlocks (Service Brake Interlock)
Design 68
A26 Endurant Transmission - Starter Interlock (BCM
LSD Controlled w/ Relay & N/ Neutral Switch)
A26 Endurant Transmission - Starter Interlock (BCM LSD Controlled w/ Relay &
N/ Neutral Switch) Design 69
LSD Controlled w/ Relay)_EATON XMSN
Relay)_EATON XMSN Design 70
A26 Endurant Transmission - Transmission Power
Take Off (Dual PTO W/ 42 Parameters & W/ Auto, AMT
Trans)
A26 Endurant Transmission - Transmission Power Take Off (Dual PTO W/ 42
Parameters & W/ Auto, AMT Trans) Design 71
Take Off (Dual PTO W/ 42 Parameters & W/ Manual
Trans)
Parameters & W/ Manual Trans) Design 72
Take Off (Single PTO W/42 Parameters & W/ Auto,
AMT Trans)
A26 Endurant Transmission - Transmission Power Take Off (Single PTO W/42
Parameters & W/ Auto, AMT Trans) Design 73
Take Off (Single PTO W/ 42 Parameters & W/ Manl
Trans)
A26 Endurant Transmission - Transmission Power Take Off (Single PTO W/ 42
Parameters & W/ Manl Trans) Design 74
A26 Endurant Transmission - Transmission Shifter
(Dual Shifter with primary being stalk)
A26 Endurant Transmission - Transmission Shifter (Dual Shifter with primary
being stalk) Design 75
(Universal Stalk Shifter - Allison)
A26 Endurant Transmission - Transmission Shifter (Universal Stalk Shifter -
Allison) Design 76
ivA26 Ultrashift Transmission - Starter Interlocks
A26 Ultrashift Transmission - Starter Interlocks (Service Brake Interlock)
Design 77
A26 Ultrashift Transmission - Starter Interlock (BCM
A26 Ultrashift Transmission - Starter Interlock (BCM LSD Controlled w/ Relay &
N/ Neutral Switch) Design 78
Relay)_EATON XMSN Design 79
A26 Ultrashift Transmission - Transmission Shifter
A26 Ultrashift Transmission - Transmission Shifter (Dual Shifter with primary
being stalk) Design 80
A26 Ultrashift Transmission - Transmission Shifter (Universal Stalk Shifter -
Allison) Design 81
A26 2017 - Coolant Level Monitoring (No CLA Module)
A26 2017 - Coolant Level Monitoring (No CLA Module) Design 82
A26 2017 - Cooling Fan Control (Fan Override)
A26 2017 - Cooling Fan Control (Fan Override) Design 83
A26 2017 - Cooling Fan Control (No Fan Override)
A26 2017 - Cooling Fan Control (No Fan Override) Design 84
A26 2021 - Coolant Level Monitoring (No CLA Module)
A26 2021 - Coolant Level Monitoring (No CLA Module) Design 85
A26 2021 - Cooling Fan Control (Fan Override)
A26 2021 - Cooling Fan Control (Fan Override) Design 86
A26 2021 - Cooling Fan Control (No Fan Override)
A26 2021 - Cooling Fan Control (No Fan Override) Design 87
A26 2021 - Selective Catalytic Reduction (SCR)
A26 2021 - Selective Catalytic Reduction (SCR) Design 88
A26 2021 - Starting Aid (Flame Start W/MD1 ECM)
A26 2021 - Starting Aid (Flame Start W/MD1 ECM) Design 90
A26 3/4000 5GEN Transmission - Transmission Power
Trans)
A26 3/4000 5GEN Transmission - Transmission Power Take Off (Dual PTO W/ 42
Parameters & W/ Auto, AMT Trans) Design 91
Trans)
vA26 3/4000 5GEN Transmission - Transmission Power Take Off (Dual PTO W/ 42
Parameters & W/ Manual Trans) Design 92
AMT Trans)
A26 3/4000 5GEN Transmission - Transmission Power Take Off (Single PTO
W/42 Parameters & W/ Auto, AMT Trans) Design 93
A26 -Backup Alarm (Switch to 5 Pin 08TKC Tailboard
to Alarm) 0008TKJ
A26 -Backup Alarm (Switch to 5 Pin 08TKC Tailboard to Alarm) 0008TKJ
Design 94
A26 - Air Filter Flow Restriction Monitoring
A26 - Air Filter Flow Restriction Monitoring Design 95
A26 - Auto Neutral (Allision without Switch and with
Confirmation Telltale)
A26 - Auto Neutral (Allision without Switch and with Confirmation Telltale)
Design 96
A26 - Auto Neutral (Allison with Multiplex Switch and
A26 - Auto Neutral (Allison with Multiplex Switch and Confirmation Telltale)
Design 97
A26 - Backup Alarm (Direct from Reverse Switch to
Alarm Conn)
A26 - Backup Alarm (Direct from Reverse Switch to Alarm Conn) Design 98
Alarm)
A26 - Backup Alarm (Direct from Reverse Switch to Alarm) Design 99
A26 - Backup Alarm (Reverse Switch to 6 Pin 08TKB
Tailboard. Backup Alarm Plugs in)
A26 - Backup Alarm (Reverse Switch to 6 Pin 08TKB Tailboard. Backup Alarm
Plugs in) Design 100
A26 - Backup Alarm (Reverse Switch to 6 Pin 08TKJ
Tailboard to Alarm Direct) with Daisy Chain
A26 - Backup Alarm (Reverse Switch to 6 Pin 08TKJ Tailboard to Alarm Direct)
with Daisy Chain Design 101
Tailboard to Alarm Direct) with 0008TKC
with 0008TKC Design 102
Tailboard to Alarm Direct) with 0008TKJ
with 0008TKJ Design 103
Tailboard. Backup Alarm Plugs In)
viA26 - Backup Alarm (Reverse Switch to 6 Pin 08TKJ Tailboard. Backup Alarm
Plugs In) Design 104
A26 - Backup Alarm (Switch to 5 Pin Daisy Chain to
Alarm) with 0008TKC
A26 - Backup Alarm (Switch to 5 Pin Daisy Chain to Alarm) with 0008TKC
Design 105
Alarm) with 0008TKJ
A26 - Backup Alarm (Switch to 5 Pin Daisy Chain to Alarm) with 0008TKJ
Design 106
Alarm)_Daisy Chain
A26 - Backup Alarm (Switch to 5 Pin Daisy Chain to Alarm)_Daisy Chain
Design 107
A26 - Backup Alarm (Switch to 5 Pin 08TKC Tailboard
to Alarm)
A26 - Backup Alarm (Switch to 5 Pin 08TKC Tailboard to Alarm) Design 108
to Alarm) 0008TKC
A26 - Backup Alarm (Switch to 5 Pin 08TKC Tailboard to Alarm) 0008TKC
Design 109
A26 - Backup Light Dual Daisy Reverse With Yukon
Trans
A26 - Backup Light Dual Daisy Reverse With Yukon Trans Design 110
A26 - Backup Light Dual Daisy with extension With
Allison Trans
A26 - Backup Light Dual Daisy with extension With Allison Trans Design 111
A26 - Backup Light Dual Daisy with extension Yukon
A26 - Backup Light Dual Daisy with extension Yukon Transmission Design 112
A26 - Backup Light Dual Reverse Light WithAllison
Trans
A26 - Backup Light Dual Reverse Light WithAllison Trans Design 113
A26 - Backup Light Dual Reverse Relay Coil Control
by TCM - 6 PIN
A26 - Backup Light Dual Reverse Relay Coil Control by TCM - 6 PIN Design 114
A26 - Backup Light Single Reverse LightWith Less
Power Module With Yukon Trans
A26 - Backup Light Single Reverse LightWith Less Power Module With Yukon
Trans Design 115
A26 - Backup Light Single Reverse Light With Less
Power Module With Allison
A26 - Backup Light Single Reverse Light With Less Power Module With Allison
Design 116
viiA26 - Backup Light Single Reverse Light Yukon
A26 - Backup Light Single Reverse Light Yukon Transmission Design 117
A26 - Battery International (3) 12V (Horizon)
A26 - Battery International (3) 12V (Horizon) Design 118
A26 - Battery International (4) 12V (Horizon)
A26 - Battery International (4) 12V (Horizon) Design 119
A26 - Body Builder Lighting - (BOC, EOF) (8HAB,
8HAE)
A26 - Body Builder Lighting - (BOC, EOF) (8HAB, 8HAE) Design 120
8HAE) (Automatic)
A26 - Body Builder Lighting - (BOC, EOF) (8HAB, 8HAE) (Automatic) Design 121
A26 - Body Builder - Altec (N/BB & W/3K4K Trans & W/
INTL Engine)
A26 - Body Builder - Altec (N/BB & W/3K4K Trans & W/ INTL Engine) Design 122
A26 - Body Builder - Altec (W/BB & W/Manual Trans &
W/ INTL Engine)
A26 - Body Builder - Altec (W/BB & W/Manual Trans & W/ INTL Engine)
Design 124
A26 - Body Builder - Altec (W/BB & W/3K4K Trans &
W/ INTL Engine)
A26 - Body Builder - Altec (W/BB & W/3K4K Trans & W/ INTL Engine) Design 129
A26 - Charging System (Delco Remy 28SI Alternator
W/ Remote Sense)
A26 - Charging System (Delco Remy 28SI Alternator W/ Remote Sense)
Design 134
A26 - Charging System (Delco Remy 36SI Alternator
W/ Remote Sense)
A26 - Charging System (Delco Remy 36SI Alternator W/ Remote Sense)
Design 135
A26 - Charging System (Delco Remy 40SI/38SI
A26 - Charging System (Delco Remy 40SI/38SI Alternator W/ Remote Sense)
Design 136
A26 - Charging System (Leece-Neville AVI160 160A W/
Remote Sense)
A26 - Charging System (Leece-Neville AVI160 160A W/ Remote Sense)
Design 137
A26 - Charging System (Leece-Neville AVI160-
160A/240A N/ Remote Sense)
A26 - Charging System (Leece-Neville AVI160-160A/240A N/ Remote Sense)
Design 138
190A/210A/240A Alternator W/ Remote Sense)
viiiA26 - Charging System (Leece-Neville AVI160-190A/210A/240A Alternator W/
Remote Sense) Design 139
A26 - Charging System (Leece-Neville 320PAH
Alternator)
A26 - Charging System (Leece-Neville 320PAH Alternator) Design 140
A26 - Charging System (Leece-Neville - LN 325A
A26 - Charging System (Leece-Neville - LN 325A Alternator W/ Remote Sense)
Design 141
A26 - Charging System (LH160_LH200)
A26 - Charging System (LH160_LH200) Design 142
A26 - Charging System (LIL165_LIL200 Alternator W/
Remote Sense)
A26 - Charging System (LIL165_LIL200 Alternator W/ Remote Sense) Design 143
A26 - Energy Storage System - International (8
Batteries) 12V
A26 - Energy Storage System - International (8 Batteries) 12V Design 144
A26 - Fuel Heater (Vehicle Powered)(Davco)
A26 - Fuel Heater (Vehicle Powered)(Davco) Design 145
A26 - Fuel Heater (Vehicle Powered)(Racor)
A26 - Fuel Heater (Vehicle Powered)(Racor) Design 146
A26 - Grounds
A26 - Grounds Design 147
A26 - Heating, Ventilation, & Air Conditioning (HVAC)
(Auto Control head W/PT Transducer, N/Low Pressure
SW)
A26 - Heating, Ventilation, & Air Conditioning (HVAC) (Auto Control head W/PT
Transducer, N/Low Pressure SW) Design 148
(Manual, W/PT Transducer, N/Low Pressure SW)
A26 - Heating, Ventilation, & Air Conditioning (HVAC) (Manual, W/PT Transducer,
N/Low Pressure SW) Design 151
A26 - Over The Air Electrical I/O (OnCommand Link /
N2 Module W/ Diagnostic Connector)
A26 - Over The Air Electrical I/O (OnCommand Link / N2 Module W/ Diagnostic
Connector) Design 153
A26 - Powertrain Body Builder Connector (N/Ultrashift
TCM)
A26 - Powertrain Body Builder Connector (N/Ultrashift TCM) Design 155
A26 - Starter Interlock (BCM HSD CTRL W/ Clutch
Switch W/ Neutral Switch)
A26 - Starter Interlock (BCM HSD CTRL W/ Clutch Switch W/ Neutral Switch)
Design 156
ixA26 - Transfer Case (NAMCO PowerTower W/ INTL
Engines & N/ TCM)
A26 - Transfer Case (NAMCO PowerTower W/ INTL Engines & N/ TCM)
Design 157
A26 - Transmissions Electrical I/O (Eaton Ultrashift)
A26 - Transmissions Electrical I/O (Eaton Ultrashift) Design 158
A26 - Transmission Electrical I/O (Endurant W/A26 &
N/ Body Builder)
A26 - Transmission Electrical I/O (Endurant W/A26 & N/ Body Builder) Design 159
Cummins N/ Body Builder)
A26 - Transmission Electrical I/O (Endurant W/ Cummins N/ Body Builder)
Design 160
A26 - Transmission I/O (Allison 4K with Body Builder)
A26 - Transmission I/O (Allison 4K with Body Builder) Design 161
A26 - Transmission I/O (Allison 4700 with Body
Builder)
A26 - Transmission I/O (Allison 4700 with Body Builder) Design 164
A26 - Transmission Oil Temperature (Manual Trans)
A26 - Transmission Oil Temperature (Manual Trans) Design 167
A26 - Transmission Oil Temperature (Manual TransHorizon W/ Aux Gauge)
A26 - Transmission Oil Temperature (Manual Trans-Horizon W/ Aux Gauge)
Design 168
A26 - Transmission Shifter (Eaton Endurant and Eaton
Procision)
A26 - Transmission Shifter (Eaton Endurant and Eaton Procision) Design 169
A26 - Transmission Shifter (Universal Stalk Shifter,
Ultrashift)
A26 - Transmission Shifter (Universal Stalk Shifter, Ultrashift) Design 170
A26 - Vehicle Speedometer System (From ECM to
Blunt Cut)
A26 - Vehicle Speedometer System (From ECM to Blunt Cut) Design 171
A26 - Vehicle Speedometer System (VSS wired
directly to ECM) Connector5771
A26 - Vehicle Speedometer System (VSS wired directly to ECM) Connector5771
Design 172
A26 - Vehicle Speedometer System (VSS wired to VIC)
Connector5771
A26 - Vehicle Speedometer System (VSS wired to VIC) Connector5771
Design 173
A26 - ZVR Splice Pack
A26 - ZVR Splice Pack Design 174
xA26/X15 - Auto Start Stop and Sleeper Auto Climate,
Cab Temp, Oil Mapping, Manual Trans
A26/X15 - Auto Start Stop and Sleeper Auto Climate, Cab Temp, Oil Mapping,
Manual Trans Design 175
A26/X15 - Auto Start Stop with Sleeper Auto Climate,
Cab Temp, Oil Mapping, Auto Trans
A26/X15 - Auto Start Stop with Sleeper Auto Climate, Cab Temp, Oil Mapping,
Auto Trans Design 176
A26/X15 - Axle Lift Controls (ELAM Module)
A26/X15 - Axle Lift Controls (ELAM Module) Design 177
A26/X15 - Axle Lift Controls (1 MUX Switch)
A26/X15 - Axle Lift Controls (1 MUX Switch) Design 178
A26/X15 - Axle Lift Controls (2 MUX Switches)
A26/X15 - Axle Lift Controls (2 MUX Switches) Design 180
A26/X15 - Axle Lift Controls (3 MUX Switches)
A26/X15 - Axle Lift Controls (3 MUX Switches) Design 182
A26/X15 - Axle Lift Pressure Monitoring (1 Aux Gauge)
A26/X15 - Axle Lift Pressure Monitoring (1 Aux Gauge) Design 184
A26/X15 - Axle Lift Pressure Monitoring (1 Virtual
Gauge)
A26/X15 - Axle Lift Pressure Monitoring (1 Virtual Gauge) Design 185
A26/X15 - Axle Lift Pressure Monitoring (2 Aux
Gauges)
A26/X15 - Axle Lift Pressure Monitoring (2 Aux Gauges) Design 186
A26/X15 - Axle Lift Pressure Monitoring (2 Virtual
Gauges)
A26/X15 - Axle Lift Pressure Monitoring (2 Virtual Gauges) Design 187
A26/X15 - Axle Lift Pressure Monitoring (3 Aux
Gauges)
A26/X15 - Axle Lift Pressure Monitoring (3 Aux Gauges) Design 188
A26/X15 - Axle Lift Pressure Monitoring (3 Virtual
Gauges)
A26/X15 - Axle Lift Pressure Monitoring (3 Virtual Gauges) Design 189
A26/X15 - Backup Alarm (Switch to 5 Pin Daisy Chain.
Backup Alarm plugs in)
A26/X15 - Backup Alarm (Switch to 5 Pin Daisy Chain. Backup Alarm plugs in)
Design 190
A26/X15 - Bendix Tractor or Towing Truck N/ Air SUSP
J1939 Driven Lamp
A26/X15 - Bendix Tractor or Towing Truck N/ Air SUSP J1939 Driven Lamp
Design 192
A26/X15 - Bendix Tractor or Towing Truck W/ Air
xiA26/X15 - Bendix Tractor or Towing Truck W/ Air SUSP J1939 Driven Lamp
Design 193
A26/X15 - Cranking (Starter) (BCM Controlled & N/
Wired Thermal Over-Crank)
A26/X15 - Cranking (Starter) (BCM Controlled & N/ Wired Thermal Over-Crank)
Design 194
A26/X15 - Cranking (Starter) (BCM Controlled & W/
Wired Thermal Overcrank)
A26/X15 - Cranking (Starter) (BCM Controlled & W/ Wired Thermal Overcrank)
Design 195
A26/X15 - Drain Valve with four (4) Heaters
A26/X15 - Drain Valve with four (4) Heaters Design 196
A26/X15 - Drain Valve with Three (3) Heaters
A26/X15 - Drain Valve with Three (3) Heaters Design 198
A26/X15 - Drain Valve with Two (2) Heaters
A26/X15 - Drain Valve with Two (2) Heaters Design 202
A26/X15 - Driver Controlled Locking Differential (Dana
- 2 Control - 2 Feedback - FR&RR)
A26/X15 - Driver Controlled Locking Differential (Dana - 2 Control - 2 Feedback -
FR&RR) Design 205
A26/X15 - Driver Controlled Locking Differential -
(Dana - 1 Control - 1 Feedback - RR)
A26/X15 - Driver Controlled Locking Differential - (Dana - 1 Control - 1 Feedback -
RR) Design 207
(Dana - 1 Control - 2 Feedback - FR&RR)
A26/X15 - Driver Controlled Locking Differential - (Dana - 1 Control - 2 Feedback -
FR&RR) Design 208
(Meritor - 1 Control - 1 Feedback - RR)
A26/X15 - Driver Controlled Locking Differential - (Meritor - 1 Control - 1
Feedback - RR) Design 210
(Meritor - 1 Control - 2 Feedback - FR&RR)
A26/X15 - Driver Controlled Locking Differential - (Meritor - 1 Control - 2
Feedback - FR&RR) Design 211
(Meritor - 1 Control - 3 Feedback - FR&CR&RR)
A26/X15 - Driver Controlled Locking Differential - (Meritor - 1 Control - 3
Feedback - FR&CR&RR) Design 214
(Meritor - 3 Control - 3 Feedback - FR&CR&RR)
A26/X15 - Driver Controlled Locking Differential - (Meritor - 3 Control - 3
Feedback - FR&CR&RR) Design 217
A26/X15 - Fuel Level Single Sensor
A26/X15 - Fuel Level Single Sensor Design 220
xiiA26/X15 - Heated Windshield
A26/X15 - Heated Windshield Design 223
A26/X15 - Hill Start Aid (HSA) (Bendix CA 2.0)
A26/X15 - Hill Start Aid (HSA) (Bendix CA 2.0) Design 224
A26/X15 - Hood Switch
A26/X15 - Hood Switch Design 225
A26/X15 - No-Idle HVAC W/Espar Airtronic &
W/Bergstrom AC
A26/X15 - No-Idle HVAC W/Espar Airtronic & W/Bergstrom AC Design 226
A26/X15 - Park Brake Controls (Non Lever Park Brake)
A26/X15 - Park Brake Controls (Non Lever Park Brake) Design 229
A26/X15 - Rear Heating, Ventilation & Air Conditioning
(HVAC) (Premium control head)
A26/X15 - Rear Heating, Ventilation & Air Conditioning (HVAC) (Premium control
head) Design 230
A26/X15 - Rear HVAC No Idle Heater Espar
A26/X15 - Rear HVAC No Idle Heater Espar Design 232
A26/X15 - Rear HVAC No Idle W/Pre-Heat Bergstrom
Heat and Cool N/2 addl Switches
A26/X15 - Rear HVAC No Idle W/Pre-Heat Bergstrom Heat and Cool N/2 addl
Switches Design 233
Heat and Cool & W/Espar Air Heat
A26/X15 - Rear HVAC No Idle W/Pre-Heat Bergstrom Heat and Cool & W/Espar
Air Heat Design 236
A26/X15 - Rear HVAC No Idle W/ Pre-Heat Bergstrom
Heat and Cool W/2 addl switches
A26/X15 - Rear HVAC No Idle W/ Pre-Heat Bergstrom Heat and Cool W/2 addl
switches Design 239
A26/X15 - Rear Suspension Pressure Monitoring
(Auxiliary Gauge)
A26/X15 - Rear Suspension Pressure Monitoring (Auxiliary Gauge) Design 242
(Virtual Gauge)
A26/X15 - Rear Suspension Pressure Monitoring (Virtual Gauge) Design 243
A26/X15 - Service Brake Pressure (Auxiliary Gauge)
A26/X15 - Service Brake Pressure (Auxiliary Gauge) Design 244
A26/X15 - Service Brake Pressure (No Gauges)
A26/X15 - Service Brake Pressure (No Gauges) Design 245
A26/X15 - Service Brake Pressure (Virtual Gauge)
A26/X15 - Service Brake Pressure (Virtual Gauge) Design 246
A26/X15 - Service Brake Switch (2 SLS/1 Transducer)
A26/X15 - Service Brake Switch (2 SLS/1 Transducer) Design 247
xiiiA26/X15 - Stability Control (Bendix Straight Truck
J1939 Driven Lamp)
A26/X15 - Stability Control (Bendix Straight Truck J1939 Driven Lamp) Design248
A26/X15 - TEM _Electric Trailer Brake Controller
Activated Stop Light
A26/X15 - TEM _Electric Trailer Brake Controller Activated Stop Light Design 249
A26/X15 - Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)
A26/X15 - Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater) Design 250
A26/X15 - Tire Pressure (TPMS) (LDL 2.0 - 2
Repeaters)
A26/X15 - Tire Pressure (TPMS) (LDL 2.0 - 2 Repeaters) Design 252
A26/X15 - Traction Control (Bendix)
A26/X15 - Traction Control (Bendix) Design 254
A26/X15 - Trailer Interface Lighting W/Combined
Turns using Blunt Cut
A26/X15 - Trailer Interface Lighting W/Combined Turns using Blunt Cut
Design 256
A26/X15 - Trailer Interface Lighting W/Separate Turns
using Blunt Cut
A26/X15 - Trailer Interface Lighting W/Separate Turns using Blunt Cut Design 257
A26/X15 - Trailer Interface (ABS) (Back of Cab Trailer
Socket)
A26/X15 - Trailer Interface (ABS) (Back of Cab Trailer Socket) Design 258
A26/X15 - Trailer Interface (ABS) (BOC and End of
Frame Trailer Socket)
A26/X15 - Trailer Interface (ABS) (BOC and End of Frame Trailer Socket)
Design 260
A26/X15 - Trailer Interface (ABS) (End of Frame Trailer
Socket)
A26/X15 - Trailer Interface (ABS) (End of Frame Trailer Socket) Design 262
A26/X15 - Trailer Interface (ABS) (POGO and End of
A26/X15 - Trailer Interface (ABS) (POGO and End of Frame Trailer Socket)
Design 263
A26/X15 - Trailer Interface (ABS) (POGO Trailer
Socket)
A26/X15 - Trailer Interface (ABS) (POGO Trailer Socket) Design 264
A26/X15 - Trailer Interface (Lighting) - Combined
Turns & Stop - End of Frame (RING GND)
A26/X15 - Trailer Interface (Lighting) - Combined Turns & Stop - End of Frame
(RING GND) Design 265
A26/X15 - Trailer Interface (Lighting) - Separate Turns
- EOF (RING GND)
A26/X15 - Trailer Interface (Lighting) - Separate Turns - EOF (RING GND)
Design 266
xivA26/X15 - Trailer Interface (Lighting) – Separate Turns
- BOC
A26/X15 - Trailer Interface (Lighting) – Separate Turns - BOC Design 268
- BOC & EOF (Ring Ground)
A26/X15 - Trailer Interface (Lighting) – Separate Turns - BOC & EOF (Ring
Ground) Design 270
- POGO
A26/X15 - Trailer Interface (Lighting) – Separate Turns - POGO Design 272
- POGO & AUX
A26/X15 - Trailer Interface (Lighting) – Separate Turns - POGO & AUX
Design 273
- POGO & EOF (Ring Ground)
A26/X15 - Trailer Interface (Lighting) – Separate Turns - POGO & EOF (Ring
Ground) Design 274
A26/X15 - Trailer Interface - ABS (ETB Feed, Blunt Cut)
A26/X15 - Trailer Interface - ABS (ETB Feed, Blunt Cut) Design 275
A26/X15 - Transmission Retarder (4K with Multiplex)
A26/X15 - Transmission Retarder (4K with Multiplex) Design 276
A26/X15 - Transmission Retarder (4700 with Multiplex)
A26/X15 - Transmission Retarder (4700 with Multiplex) Design 277
Backup Alarm (Direct from Relay to Alarm Connector)
Backup Alarm (Direct from Relay to Alarm Connector) Design 278
Backup Alarm (Direct from Relay to Alarm)
Backup Alarm (Direct from Relay to Alarm) Design 279
Backup Alarm (From Relay to 5 Pin Daisy Chain to
Backup Alarm)
Backup Alarm (From Relay to 5 Pin Daisy Chain to Backup Alarm) Design 280
Backup Alarm) with 0008TKJ
Backup Alarm (From Relay to 5 Pin Daisy Chain to Backup Alarm) with 0008TKJ
Design 281
Backup Alarm) 1
Backup Alarm (From Relay to 5 Pin Daisy Chain to Backup Alarm) 1 Design 282
Backup Alarm (From Relay to 5 Pin Daisy Chain.
Backup Alarm (From Relay to 5 Pin Daisy Chain. Backup Alarm plugs in)
Design 283
Backup Alarm (Relay to 5 Pin 08TKC Tailboard to
Alarm)
xvBackup Alarm (Relay to 5 Pin 08TKC Tailboard to Alarm) Design 284
Alarm) 0008TKC
Backup Alarm (Relay to 5 Pin 08TKC Tailboard to Alarm) 0008TKC Design 285
Alarm) 0008TKJ
Backup Alarm (Relay to 5 Pin 08TKC Tailboard to Alarm) 0008TKJ Design 286
Backup Alarm (Relay to 5 Pin 08TKC Tailboard. Alarm
Plugs In)
Backup Alarm (Relay to 5 Pin 08TKC Tailboard. Alarm Plugs In) Design 287
Plugs In) 1
Backup Alarm (Relay to 5 Pin 08TKC Tailboard. Alarm Plugs In) 1 Design 288
Backup Alarm (Relay to 6 Pin Tailboard. Backup
Alarm Plugs in)
Backup Alarm (Relay to 6 Pin Tailboard. Backup Alarm Plugs in) Design 290
Backup Alarm (Relay to 6 Pin 08TKJ Tailboard to
Alarm)
Backup Alarm (Relay to 6 Pin 08TKJ Tailboard to Alarm) Design 291
Alarm) With 0008WDG
Backup Alarm (Relay to 6 Pin 08TKJ Tailboard to Alarm) With 0008WDG
Design 292
Alarm) 0008TKJ
Backup Alarm (Relay to 6 Pin 08TKJ Tailboard to Alarm) 0008TKJ Design 293
Backup Alarm (08THB & W/ 08NAA)
Backup Alarm (08THB & W/ 08NAA) Design 294
Backup Alarm (08WDG & W/ 08NAA)
Backup Alarm (08WDG & W/ 08NAA) Design 295
Backup Lights Dual Daisy Reverse Light Eaton
Manual Trans
Backup Lights Dual Daisy Reverse Light Eaton Manual Trans Design 296
Backup Lights Dual Daisy with extension Eaton With
Manual Trans
Backup Lights Dual Daisy with extension Eaton With Manual Trans Design 297
Backup Lights Single Reverse Light With Eaton
Manual Trans
Backup Lights Single Reverse Light With Eaton Manual Trans Design 299
Backup Lights (Dual Reverse Light) Eaton/Manual
Trans
Backup Lights (Dual Reverse Light) Eaton/Manual Trans Design 300
xviBackup Light Dual Daisy Reverse With Allison
Backup Light Dual Daisy Reverse With Allison Design 301
Backup Light Single Reverse Light With Allison
Backup Light Single Reverse Light With Allison Design 302
Back of Cab Aux Work Light
Back of Cab Aux Work Light Design 303
Back of Cab Aux Work Light 2 blunt cuts
Back of Cab Aux Work Light 2 blunt cuts Design 304
Back of Cab Aux Work Light (2 blunt cuts)
Back of Cab Aux Work Light (2 blunt cuts) Design 305
Back of Cab Aux Work Light (2 blunt cuts) With Cab
0016030
Back of Cab Aux Work Light (2 blunt cuts) With Cab 0016030 Design 306
Back Up Lights Reverse With Less Power Module
Back Up Lights Reverse With Less Power Module With Eaton Manual Trans
Design 307
Battery Disconnect
Battery Disconnect Design 308
Battery Grid 1 (Non-Loadshed)
Battery Grid 1 (Non-Loadshed) Design 309
Battery Grid 2 (Loadshed)
Battery Grid 2 (Loadshed) Design 311
Battery Grid 3 (Non-Loadshed)
Battery Grid 3 (Non-Loadshed) Design 312
Beacon Strobe Light With 2 Blunt Cuts
Beacon Strobe Light With 2 Blunt Cuts Design 313
Beacon & Strobe Light - 2 Lamps Hardwired Switch
Beacon & Strobe Light - 2 Lamps Hardwired Switch Design 315
Body Builder Aux Power
Body Builder Aux Power Design 317
Body Builder Fuse Panel
Body Builder Fuse Panel Design 318
Body Builder Lighting - InCab Automatic
Body Builder Lighting - InCab Automatic Design 319
Body Builder Lighting - In Cab Manual
Body Builder Lighting - In Cab Manual Design 320
Body Builder Lighting - 8HAA Blunt Cut
Body Builder Lighting - 8HAA Blunt Cut Design 321
Body Builder Prewire (8 Wire Firewall Pass through)
Body Builder Prewire (8 Wire Firewall Pass through) Design 322
xviiBody Builder - Altec (N/BB & W/Manual XMSN & W/
INTL Engine)
Body Builder - Altec (N/BB & W/Manual XMSN & W/ INTL Engine) Design 323
CUMMINS Engine)
Body Builder - Altec (N/BB & W/3K4K Trans & W/ CUMMINS Engine) Design 325
CUMMINS Engine)
Body Builder - Altec (W/BB & W/Manual Trans & W/ CUMMINS Engine)
Design 327
CUMMINS Engine)
Body Builder - Altec (W/BB & W/3K4K Trans & W/ CUMMINS Engine) Design 332
Body Control Module
Body Control Module Design 337
Body Extra J1939 With eLam & RPM
Body Extra J1939 With eLam & RPM Design 342
Body Standard J1939
Body Standard J1939 Design 343
Cab Dome Light With Classic Trim
Cab Dome Light With Classic Trim Design 344
Cab Dome Light With Combo in Diamond Trim
Cab Dome Light With Combo in Diamond Trim Design 345
Cab Dome Light - Sleeper Cab
Cab Dome Light - Sleeper Cab Design 346
Cab Standard J1939 (All Cabs)
Cab Standard J1939 (All Cabs) Design 347
CB Radio Power Only
CB Radio Power Only Design 348
Center Chassis Grounds
Center Chassis Grounds Design 349
Center Chassis Ground Splice Packs
Center Chassis Ground Splice Packs Design 350
Center Chassis ZVR Splice Pack
Center Chassis ZVR Splice Pack Design 352
Chassis PDM
Chassis PDM Design 353
City Horn 10PIN ClockSpring Without RKA
City Horn 10PIN ClockSpring Without RKA Design 354
City Horn 10PIN ClockSpring With RKA
City Horn 10PIN ClockSpring With RKA Design 355
xviiiCity Horn 4PIN ClockSpring Without RKA
City Horn 4PIN ClockSpring Without RKA Design 356
City Horn 4PIN ClockSpring With RKA
City Horn 4PIN ClockSpring With RKA Design 357
Clearance and Identification Lights Without
SUNSHADE AMBER LENS
Clearance and Identification Lights Without SUNSHADE AMBER LENS
Design 358
Clearance and Identification Lights With SUNSHADE
AMBER LENS
Clearance and Identification Lights With SUNSHADE AMBER LENS Design 359
Clutch Monitoring (High and Low Switch to BCM)
Clutch Monitoring (High and Low Switch to BCM) Design 360
Compressed Air Supply (Primary and Secondary
Gauge)
Compressed Air Supply (Primary and Secondary Gauge) Design 361
Convenience Grid 2 (Loadshed)
Convenience Grid 2 (Loadshed) Design 362
Courtesy Step Lighting (2 Door)
Courtesy Step Lighting (2 Door) Design 363
Crank Inhibit (W/ Hood Switch)
Crank Inhibit (W/ Hood Switch) Design 364
Cruise Control (Horizon W/ One Telltale, 10 Pin)
Cruise Control (Horizon W/ One Telltale, 10 Pin) Design 365
Cruise Control (Horizon W/ One Telltale, 4 Pin)
Cruise Control (Horizon W/ One Telltale, 4 Pin) Design 366
DC/AC Inverter
DC/AC Inverter Design 367
DC/AC Inverter (with switch control)
DC/AC Inverter (with switch control) Design 368
DC/AC Inverter (1800 Watts)
DC/AC Inverter (1800 Watts) Design 369
Diagnositic 9-pin Connector
Diagnositic 9-pin Connector Design 370
Directional Signal Turn SetBack Axle With Headlights
Directional Signal Turn SetBack Axle With Headlights Design 371
And Wtih Plowlights
Directional Signal Turn SetBack Axle With Headlights And Wtih Plowlights
Design 372
Directional Signal Turn SetForward Axle With
Headlights
xixDirectional Signal Turn SetForward Axle With Headlights Design 373
Headlights With Plowlights
Directional Signal Turn SetForward Axle With Headlights With Plowlights
Design 374
DLB - I/O Expansion
DLB - I/O Expansion Design 375
DLB - Remote Power Modules (1 RPM w/ SW Pack)
DLB - Remote Power Modules (1 RPM w/ SW Pack) Design 376
DLB - Remote Power Modules (3 RPM w/SW Pack(s)
DLB - Remote Power Modules (3 RPM w/SW Pack(s) Design 377
DLB - Remote Power Module (1 RPM Blunt Cut)
DLB - Remote Power Module (1 RPM Blunt Cut) Design 378
DLB - Remote Power Module (2 RPM w/SW Pack(s)
DLB - Remote Power Module (2 RPM w/SW Pack(s) Design 379
DLB - Remote Power Module (3 RPM n/SW Pack(s)
DLB - Remote Power Module (3 RPM n/SW Pack(s) Design 380
Door Ajar Reminder (Entry/Exit)
Door Ajar Reminder (Entry/Exit) Design 381
Driver Controlled Locking Differential (Meritor - 2
Driver Controlled Locking Differential (Meritor - 2 Control - 2 Feedback - FR&RR)
Design 382
Dual Auxiliary Power with Interlock
Dual Auxiliary Power with Interlock Design 385
End of Frame One Aux Work Light (CONN) - CUST
FURNISHD
End of Frame One Aux Work Light (CONN) - CUST FURNISHD Design 386
Engine Electrical I/O (A26 Interface Connector)
Engine Electrical I/O (A26 Interface Connector) Design 387
Engine Electrical I/O (N13 Interface Connector)
Engine Electrical I/O (N13 Interface Connector) Design 389
Engine Idle Increment/Decrement (Steering Wheel
Switch - 10 Pin)
Engine Idle Increment/Decrement (Steering Wheel Switch - 10 Pin) Design 390
Switch - 4 Pin)
Engine Idle Increment/Decrement (Steering Wheel Switch - 4 Pin) Design 391
Engine Proprietary J1939
Engine Proprietary J1939 Design 392
Engine Speed Control (PTO) W/ 10-pin
Engine Speed Control (PTO) W/ 10-pin Design 393
xxEngine Speed Control(PTO) 4-pin
Engine Speed Control(PTO) 4-pin Design 394
Fan - Sleeper/Bunk
Fan - Sleeper/Bunk Design 395
Floor/Search Lighting (Sleeper 1 Light)
Floor/Search Lighting (Sleeper 1 Light) Design 397
Floor/Search Lighting (Sleeper 3 Lights)
Floor/Search Lighting (Sleeper 3 Lights) Design 398
Floor/Search Lights (DayCab)
Floor/Search Lights (DayCab) Design 399
Forward Auxiliary Power Source - 1 APO
Forward Auxiliary Power Source - 1 APO Design 400
Forward Auxiliary Power Source - 2 APO
Forward Auxiliary Power Source - 2 APO Design 401
Forward Auxiliary Power Source - 3 APO
Forward Auxiliary Power Source - 3 APO Design 402
Frame Grounds
Frame Grounds Design 403
Front Chassis Grounds
Front Chassis Grounds Design 404
Front Chassis Ground Splice Packs
Front Chassis Ground Splice Packs Design 405
Fusion Proprietary J1939 With Cab 0016AUM And
0016AUN
Fusion Proprietary J1939 With Cab 0016AUM And 0016AUN Design 406
Fusion Proprietary J1939 With Cab 0016030 And
0016AUS
Fusion Proprietary J1939 With Cab 0016030 And 0016AUS Design 407
Fusion 3.0 Proprietary J1939
Fusion 3.0 Proprietary J1939 Design 408
Grid Management (CA2 W/Load Shed, Conventional
Cab)
Grid Management (CA2 W/Load Shed, Conventional Cab) Design 409
Grid Management (CA2 W/Load Shed, Sleeper Cab)
Grid Management (CA2 W/Load Shed, Sleeper Cab) Design 410
Grid Management (CA2, N/Load Shed, Conventional
Cab)
Grid Management (CA2, N/Load Shed, Conventional Cab) Design 411
Hazard Warning
Hazard Warning Design 412
Headlights SetBack Axle
xxiHeadlights SetBack Axle Design 413
Headlights SetForward Axle
Headlights SetForward Axle Design 414
Headlights SetForward Axle With Plowlights
Headlights SetForward Axle With Plowlights Design 415
Headlight Interrupt
Headlight Interrupt Design 416
Heated Mirrors Door Pod Actuated Cab and Hood
Mounted Right Side Only
Heated Mirrors Door Pod Actuated Cab and Hood Mounted Right Side Only
Design 417
Heated Mirrors Door Pod Actuated Cab Mounted
Heated Mirrors Door Pod Actuated Cab Mounted Design 418
HMI Standard J1939
HMI Standard J1939 Design 419
HX520 - Modesty Lighting With Sleeper Cab 2 Turn
and Marker 8 Marker
HX520 - Modesty Lighting With Sleeper Cab 2 Turn and Marker 8 Marker
Design 420
HX520 - Modesty Lighting With Sleeper Cab 4 Turn
and Marker 12 Marker
HX520 - Modesty Lighting With Sleeper Cab 4 Turn and Marker 12 Marker
Design 423
and Marker 16 Marker
HX520 - Modesty Lighting With Sleeper Cab 4 Turn and Marker 16 Marker
Design 426
HX620 - Modesty Lighting With Day Cab 2 Turn and
Marker
HX620 - Modesty Lighting With Day Cab 2 Turn and Marker Design 429
Marker 6 Marker
HX620 - Modesty Lighting With Day Cab 2 Turn and Marker 6 Marker Design 430
HX620 - Modesty Lighting With Sleeper Cab 4 Turn
and Marker 14 Marker
HX620 - Modesty Lighting With Sleeper Cab 4 Turn and Marker 14 Marker
Design 431
Instrument Cluster
Instrument Cluster Design 434
Instrument Cluster - Request and Status
Instrument Cluster - Request and Status Design 435
Interior Task Lighting (Map Light) (Separate map light
from cab dome)
xxiiInterior Task Lighting (Map Light) (Separate map light from cab dome) Design 436
Interior Task Lights (Map) (Cab Dome / Map Combo)
Interior Task Lights (Map) (Cab Dome / Map Combo) Design 437
In Cab Battery Box Battery Cables
In Cab Battery Box Battery Cables Design 438
IP Grounds
IP Grounds Design 439
IP Ground Splice Packs
IP Ground Splice Packs Design 440
IP Panel Dimmer Splice Packs
IP Panel Dimmer Splice Packs Design 442
IP Underhood PDM
IP Underhood PDM Design 443
License Plate Light LED BOX LAMP Daisy Chain Tail
Light
License Plate Light LED BOX LAMP Daisy Chain Tail Light Design 444
License Plate Light LED BOX LAMP Tail Light
License Plate Light LED BOX LAMP Tail Light Design 445
License Plate Light Tail Light Single Assembly
License Plate Light Tail Light Single Assembly Design 446
License Plate Light Tail Light Single Assembly With
Less Power Module
License Plate Light Tail Light Single Assembly With Less Power Module
Design 447
License Plate Light (LED BOX LAMP Daisy Chain Tail
Light with extension)
License Plate Light (LED BOX LAMP Daisy Chain Tail Light with extension)
Design 448
Lighting Control Module
Lighting Control Module Design 449
Lighting Sleeper Dome
Lighting Sleeper Dome Design 450
Lighting Splice Packs
Lighting Splice Packs Design 451
Lighting - Cabinet Lights
Lighting - Cabinet Lights Design 452
Luggage Compartment Lights - WithOut No Idle HVAC
Luggage Compartment Lights - WithOut No Idle HVAC Design 453
Luggage Compartment Lights - With No Idle HVAC
Luggage Compartment Lights - With No Idle HVAC Design 454
Main Cab Ground
Main Cab Ground Design 455
xxiiiMarker Lighting SetBack Axle
Marker Lighting SetBack Axle Design 456
Marker Lighting SetBack Axle With Guide Posts
Marker Lighting SetBack Axle With Guide Posts Design 457
Marker Lighting SetBack Axle With Plowlight
Marker Lighting SetBack Axle With Plowlight Design 458
Marker Lighting SetBack Axle With Plowlight And
With Guide Posts
Marker Lighting SetBack Axle With Plowlight And With Guide Posts Design 459
Marker Lighting SetForward Axle
Marker Lighting SetForward Axle Design 460
Marker Lighting SetForward Axle With Guide Posts
Marker Lighting SetForward Axle With Guide Posts Design 461
Marker Lighting SetForward Axle With Plowlight
Marker Lighting SetForward Axle With Plowlight Design 462
Marker Lighting SetForward Axle With Plowlight And With Guide Posts
Marker Lighting SetForward Axle With Plowlight And With Guide Posts Design463
Mirrors Power 2 Door Pods
Mirrors Power 2 Door Pods Design 464
Mirrors (Heated) With 2 Cab and 1 Hood Mounted
Right Side Only
Mirrors (Heated) With 2 Cab and 1 Hood Mounted Right Side Only Design 465
Mirrors (Heated) With 2 Cab Mirrors
Mirrors (Heated) With 2 Cab Mirrors Design 466
Mirror Lighting Turns without Door Pods, Relay
Control
Mirror Lighting Turns without Door Pods, Relay Control Design 467
Mirror Lighting Turns with Door Pods, Relay Control
Mirror Lighting Turns with Door Pods, Relay Control Design 468
Mirror Lighting (Side Marker without Door Pods)
Mirror Lighting (Side Marker without Door Pods) Design 469
Mirror Lighting (Side Marker with Door Pods)
Mirror Lighting (Side Marker with Door Pods) Design 470
Modesty Lighting With Sleeper Design 471
10 Marker
Modesty Lighting With Sleeper Cab 4 Turn and Marker 10 Marker Design 472
Modesty Lighting With 2 Turn and Marker
Modesty Lighting With 2 Turn and Marker Design 475
xxivModesty Lighting With 2 Turn and Marker 2
Modesty Lighting With 2 Turn and Marker 2 Design 476
Modesty Lighting W/ Sleeper
Modesty Lighting W/ Sleeper Design 477
No Idle Voltage Sense
No Idle Voltage Sense Design 478
Operating Grid 1 (Non-Loadshed)
Operating Grid 1 (Non-Loadshed) Design 479
Operating Grid 2 (Loadshed)
Operating Grid 2 (Loadshed) Design 481
Operator Input (Key Switch)
Operator Input (Key Switch) Design 482
Park Lights With Marker Interrupt With 10pin
ClockSpring
Park Lights With Marker Interrupt With 10pin ClockSpring Design 483
Park Lights With Marker Interrupt 4 Pin Clockspring
Park Lights With Marker Interrupt 4 Pin Clockspring Design 484
Powertrain Aftertreatment PDM
Powertrain Aftertreatment PDM Design 485
Powertrain Standard J1939
Powertrain Standard J1939 Design 486
Powertrain Standard J1939 W/Fusion
Powertrain Standard J1939 W/Fusion Design 487
Power Door Locks (2-Door)
Power Door Locks (2-Door) Design 488
Power Windows (2-Door)
Power Windows (2-Door) Design 489
Prewire Front Fog Lights
Prewire Front Fog Lights Design 490
Radio
Radio Design 491
Radio With Bluetooth
Radio With Bluetooth Design 492
Radio With Bluetooth With Steering Wheel Pod & With
RSA
Radio With Bluetooth With Steering Wheel Pod & With RSA Design 493
Radio With Bluetooth & With Steering Wheel Pod
Radio With Bluetooth & With Steering Wheel Pod Design 494
Radio With Steering Wheel Pod
Radio With Steering Wheel Pod Design 495
Radio With Steering Wheel Pod & With RSA
Radio With Steering Wheel Pod & With RSA Design 496
xxvRear Chassis Ground Splice Packs
Rear Chassis Ground Splice Packs Design 497
Rear Interior Dimming (Accent Light)
Rear Interior Dimming (Accent Light) Design 498
Rear Lights Stop Daisy Chain With Extension Harness
Rear Lights Stop Daisy Chain With Extension Harness Design 499
Rear Lights Stop With Daisy Chain Not With Extension
Harness
Rear Lights Stop With Daisy Chain Not With Extension Harness Design 500
Rear Lights Stop - Dual Taillight Assembly
Rear Lights Stop - Dual Taillight Assembly Design 501
Rear Lights Stop - Single Taillight Assembly
Rear Lights Stop - Single Taillight Assembly Design 502
Rear Lights Stop - Single Taillight Assembly Jumper
harness
Rear Lights Stop - Single Taillight Assembly Jumper harness Design 503
Rear Light Tail Light With Daisy Chain pair of Box
Lamps
Rear Light Tail Light With Daisy Chain pair of Box Lamps Design 504
Rear Light Tail Light With Less Power Module
Rear Light Tail Light With Less Power Module Design 505
Rear Light Tail Light With 6 pin connector
Rear Light Tail Light With 6 pin connector Design 506
Rear Light With LED Box Lamp Tail Light
Rear Light With LED Box Lamp Tail Light Design 507
Rear Reading Lighting (Lower Bunk)
Rear Reading Lighting (Lower Bunk) Design 508
Rear Tail Light With Daisy Chain with extension
Rear Tail Light With Daisy Chain with extension Design 509
Refrigerator (Power and Ground Only)
Refrigerator (Power and Ground Only) Design 510
Refrigerator (Switch Control)
Refrigerator (Switch Control) Design 512
Remote Keyless Access
Remote Keyless Access Design 513
Remote Power Modules (2 RPM Blunt Cuts)
Remote Power Modules (2 RPM Blunt Cuts) Design 514
Remote Power Module Features (Gate Open and Rear
Alert W/ Auto Trans)
Remote Power Module Features (Gate Open and Rear Alert W/ Auto Trans)
Design 516
xxviRemote Power Module Features (Gate Open and Rear
Alert W/ Manual and Ulltrashift+)
Remote Power Module Features (Gate Open and Rear Alert W/ Manual and
Ulltrashift+) Design 517
Remote Start/Stop
Remote Start/Stop Design 519
Remote Start/Stop w/ Emergency Pump
Remote Start/Stop w/ Emergency Pump Design 520
Seatbelt Reminder (Warning)(Driver only)
Seatbelt Reminder (Warning)(Driver only) Design 521
Seatbelt Reminder (Warning)(Driver & Passenger in
parallel)
Seatbelt Reminder (Warning)(Driver & Passenger in parallel) Design 522
Seats (RollTek) Driver and Passenger (Hard Wired)
Seats (RollTek) Driver and Passenger (Hard Wired) Design 523
Seats (RollTek) Driver's Seat Only (Hard Wired) -
Leather
Seats (RollTek) Driver's Seat Only (Hard Wired) - Leather Design 524
Mordura
Seats (RollTek) Driver's Seat Only (Hard Wired) - Mordura Design 525
Seats (RollTek) Driver's Seat Only (Hard Wired) - Vinyl
Seats (RollTek) Driver's Seat Only (Hard Wired) - Vinyl Design 526
Seats - Climate Controlled (Drivers Heated Seat)
Seats - Climate Controlled (Drivers Heated Seat) Design 527
Seats - Climate Controlled (Driver and Passenger
Heated Seat)
Seats - Climate Controlled (Driver and Passenger Heated Seat) Design 528
Sleeper Battery Grid 4 (Loadshed)
Sleeper Battery Grid 4 (Loadshed) Design 529
Sleeper Convenience Grid 1 (Non-Loadshed)
Sleeper Convenience Grid 1 (Non-Loadshed) Design 530
Sleeper Grounds
Sleeper Grounds Design 531
Sleeper Ground Splice Packs
Sleeper Ground Splice Packs Design 532
Speakers W/Amp & N/QC
Speakers W/Amp & N/QC Design 533
Speakers:Four Speakers & N/QC
Speakers:Four Speakers & N/QC Design 535
Starting Aid (Ether Start)
Starting Aid (Ether Start) Design 537
xxviiSwitch Packs
Switch Packs Design 538
Telematics (Aftermarket W/ TMC Connector)
Telematics (Aftermarket W/ TMC Connector) Design 539
& W/ TCM)
Transfer Case (NAMCO PowerTower W/ INTL Engines & W/ TCM) Design 541
Transmission Power Take Off (Active Low Feedback)
Transmission Power Take Off (Active Low Feedback) Design 542
Transmission Power Take Off (60AKG)
Transmission Power Take Off (60AKG) Design 543
Transmission (Allison 4K)
Transmission (Allison 4K) Design 544
Ultrashift+ and FAS
Ultrashift+ and FAS Design 545
vEES-SE-L-1012-03-06_WiringDesign
vEES-SE-L-1012-03-06_WiringDesign Design 546
Vehicle Acceleration (w/ Two PWR, Two GND, & Two
STS)(Horizon)
Vehicle Acceleration (w/ Two PWR, Two GND, & Two STS)(Horizon) Design 547
Vehicle Data Recorder With Display, 2 front seats
Vehicle Data Recorder With Display, 2 front seats Design 548
Vehicle Data Recorder With Display, 3 front seats
Vehicle Data Recorder With Display, 3 front seats Design 551
Vehicle Data Recorder (N/Display, 2 front seats)
Vehicle Data Recorder (N/Display, 2 front seats) Design 554
Vehicle Data Recorder (N/VDR, N/Display, 2 front
seats)
Vehicle Data Recorder (N/VDR, N/Display, 2 front seats) Design 557
Vehicle Data Recorder (N/VDR, N/ Display, 3 seats)
Vehicle Data Recorder (N/VDR, N/ Display, 3 seats) Design 559
Vehicle Data Recorder (N/ Display, 3 front seats)
Vehicle Data Recorder (N/ Display, 3 front seats) Design 561
Vehicle Speedometer System (VSS wired to VIC) Design 564
Windshield Washer Pump And Low Fluid Sensor
Windshield Washer Pump And Low Fluid Sensor Design 565
Windshield Wipers Cruise Disable With Wipers ON
Windshield Wipers Cruise Disable With Wipers ON Design 566
Windshield Wipers Park Brake With Wiper
Windshield Wipers Park Brake With Wiper Design 567
xxviiiWindshield Wipers Standard
Windshield Wipers Standard Design 568
Windshield Wipers With Cruise Disable And Park
Brake With Wipers ON
Windshield Wipers With Cruise Disable And Park Brake With Wipers ON
Design 569
Work Lights 4 LED Bulbs With Backup Manual
Work Lights 4 LED Bulbs With Backup Manual Design 570
Work Lights - 1 Bulb With Backup Auto
Work Lights - 1 Bulb With Backup Auto Design 571
Work Lights - 1 Bulb With Backup Manual
Work Lights - 1 Bulb With Backup Manual Design 572
Work Lights - 1 Bulb With Backup With RKE Manual
Work Lights - 1 Bulb With Backup With RKE Manual Design 573
Work Lights - 1 Bulb With Backup Wtih RKE Auto
Work Lights - 1 Bulb With Backup Wtih RKE Auto Design 574
Work Lights - 2 Bulbs With Backup Auto
Work Lights - 2 Bulbs With Backup Auto Design 575
Work Lights - 2 Bulbs With Backup Manual - DayCab
Work Lights - 2 Bulbs With Backup Manual - DayCab Design 576
Work Lights - 2 Bulbs With Backup With RKE Auto
Work Lights - 2 Bulbs With Backup With RKE Auto Design 577
Work Lights - 2 Bulbs With Backup With RKE Manual -
DayCab
Work Lights - 2 Bulbs With Backup With RKE Manual - DayCab Design 578
Work Lights - 2 Bulbs With Backup (Manual)
Work Lights - 2 Bulbs With Backup (Manual) Design 579
Work Lights - 4 LED Bulbs With Backup With RKE
Manual
Work Lights - 4 LED Bulbs With Backup With RKE Manual Design 580
Work Lights- 2 Bulbs With Backup With RKE Manual
Work Lights- 2 Bulbs With Backup With RKE Manual Design 581
WORK LIGHT With Backup With RKE 2 Bulbs
Automatic Transmission
WORK LIGHT With Backup With RKE 2 Bulbs Automatic Transmission
Design 582
Automatic Transmission 2
WORK LIGHT With Backup With RKE 2 Bulbs Automatic Transmission 2
Design 583
Work Light With BackUP 2 Bulbs Auto Trans With
DayCab
Work Light With BackUP 2 Bulbs Auto Trans With DayCab Design 584
xxixWork Light With Backup 4 LED Automatic
Work Light With Backup 4 LED Automatic Transmission Design 585
WORK LIGHT With RKE 1 BULB
WORK LIGHT With RKE 1 BULB Design 586
Work Light With RKE 2 Bulbs DayCab
Work Light With RKE 2 Bulbs DayCab Design 587
Work Light With RKE 4 Led BulbSleeper
Work Light With RKE 4 Led BulbSleeper Design 588
Work Light With RKE 4 LED Light Bulbs Sleeper
Work Light With RKE 4 LED Light Bulbs Sleeper Design 589
Work light W RKE 2 Bulbs
Work light W RKE 2 Bulbs Design 590
WORK LIGHT 1 BULB
WORK LIGHT 1 BULB Design 591
Work light 2 Bulbs
Work light 2 Bulbs Design 592
WORK LIGHT 2 Bulbs DayCab
WORK LIGHT 2 Bulbs DayCab Design 593
X15 Endurant Manual Transmission - Transmission
Auto, AMT Trans)
X15 Endurant Manual Transmission - Transmission Power Take Off (Dual PTO
W/ 42 Parameters & W/ Auto, AMT Trans) Design 594
Manual Trans)
W/ 42 Parameters & W/ Manual Trans) Design 595
Auto, AMT Trans)
X15 Endurant Manual Transmission - Transmission Power Take Off (Single PTO
W/42 Parameters & W/ Auto, AMT Trans) Design 596
X15 Endurant Transmission - Starter Interlocks
X15 Endurant Transmission - Starter Interlocks (Service Brake Interlock)
Design 597
X15 Endurant Transmission - Starter Interlock (BCM
X15 Endurant Transmission - Starter Interlock (BCM LSD Controlled w/ Relay &
N/ Neutral Switch) Design 598
xxxX15 Endurant Transmission - Starter Interlock (BCM
Relay)_EATON XMSN Design 599
X15 Endurant Transmission - Transmission Power
Trans)
X15 Endurant Transmission - Transmission Power Take Off (Dual PTO W/ 42
Parameters & W/ Auto, AMT Trans) Design 600
Trans)
Parameters & W/ Manual Trans) Design 601
AMT Trans)
X15 Endurant Transmission - Transmission Power Take Off (Single PTO W/42
Parameters & W/ Auto, AMT Trans) Design 602
X15 Endurant Transmission - Transmission Shifter
X15 Endurant Transmission - Transmission Shifter (Dual Shifter with primary
being stalk) Design 603
X15 Endurant Transmission - Transmission Shifter (Universal Stalk Shifter -
Allison) Design 604
X15 Engine - Cranking (Starter) (BCM Controlled & N/
X15 Engine - Cranking (Starter) (BCM Controlled & N/ Wired Thermal OverCrank) Design 605
X15 Engine - Transmission Retarder (4K with
Multiplex)
X15 Engine - Transmission Retarder (4K with Multiplex) Design 606
X15 Engine - Transmission Retarder (4700 with
Multiplex)
X15 Engine - Transmission Retarder (4700 with Multiplex) Design 607
X15 Ultrashift Transmission - Starter Interlocks
X15 Ultrashift Transmission - Starter Interlocks (Service Brake Interlock)
Design 608
X15 Ultrashift Transmission - Starter Interlock (BCM
X15 Ultrashift Transmission - Starter Interlock (BCM LSD Controlled w/ Relay &
N/ Neutral Switch) Design 609
xxxiX15 Ultrashift Transmission - Starter Interlock (BCM
Relay)_EATON XMSN Design 610
X15 Ultrashift Transmission - Transmission Shifter
X15 Ultrashift Transmission - Transmission Shifter (Dual Shifter with primary
being stalk) Design 611
X15 Ultrashift Transmission - Transmission Shifter (Universal Stalk Shifter -
Allison) Design 612
X15 2017 - Selective Catalytic Reduction (SCR)
X15 2017 - Selective Catalytic Reduction (SCR) Design 613
X15 2017 - Starting Aid (Flame Start N/MD1 ECM)
X15 2017 - Starting Aid (Flame Start N/MD1 ECM) Design 615
X15 2021 - Cooling Fan Control (Fan Override)
X15 2021 - Cooling Fan Control (Fan Override) Design 616
X15 2021 - Cooling Fan Control (No Fan Override)
X15 2021 - Cooling Fan Control (No Fan Override) Design 617
X15 2021 - Selective Catalytic Reduction (SCR)
X15 2021 - Selective Catalytic Reduction (SCR) Design 618
X15 2021 - Transfer Case (NAMCO Powertower W/
Cummins & N/ TCM)
X15 2021 - Transfer Case (NAMCO Powertower W/ Cummins & N/ TCM)
Design 620
Cummins & W/ TCM)
X15 2021 - Transfer Case (NAMCO Powertower W/ Cummins & W/ TCM)
Design 621
X15 3/4000 5GEN Transmission - Transmission Power
Trans)
X15 3/4000 5GEN Transmission - Transmission Power Take Off (Dual PTO W/ 42
Parameters & W/ Auto, AMT Trans) Design 622
Trans)
Parameters & W/ Manual Trans) Design 623
AMT Trans)
X15 3/4000 5GEN Transmission - Transmission Power Take Off (Single PTO
W/42 Parameters & W/ Auto, AMT Trans) Design 624
xxxiiX15 3/4000 5GEN Transmission - Transmission Power
Trans)
X15 3/4000 5GEN Transmission - Transmission Power Take Off (Single PTO W/
42 Parameters & W/ Manl Trans) Design 625
X15 -Backup Alarm (Switch to 5 Pin 08TKC Tailboard
to Alarm)
X15 -Backup Alarm (Switch to 5 Pin 08TKC Tailboard to Alarm) Design 626
to Alarm)_0008TKJ
X15 -Backup Alarm (Switch to 5 Pin 08TKC Tailboard to Alarm)_0008TKJ
Design 627
X15 - Air Filter Flow Restriction Monitoring
X15 - Air Filter Flow Restriction Monitoring Design 628
X15 - Ambient Air Temperature (Mirror Sensor)
X15 - Ambient Air Temperature (Mirror Sensor) Design 629
X15 - Ambient Air Temperature (no Display, Mirror
Sensor)
X15 - Ambient Air Temperature (no Display, Mirror Sensor) Design 630
X15 - Auto Neutral (Allision without Switch and with
X15 - Auto Neutral (Allision without Switch and with Confirmation Telltale)
Design 631
X15 - Auto Neutral (Allison with Multiplex Switch and
X15 - Auto Neutral (Allison with Multiplex Switch and Confirmation Telltale)
Design 632
X15 - Auto Start/Stop Oil Temp Sensor, Auto Trans
X15 - Auto Start/Stop Oil Temp Sensor, Auto Trans Design 633
X15 - Auto Start/Stop Oil Temp Sensor, Manual Trans
X15 - Auto Start/Stop Oil Temp Sensor, Manual Trans Design 634
X15 - Auto Start/Stop with Sleeper Auto Climate, Cab
Temp, with Oil Temp Sensor, Auto Trans
X15 - Auto Start/Stop with Sleeper Auto Climate, Cab Temp, with Oil Temp
Sensor, Auto Trans Design 635
Temp, with Oil Temp Sensor, Manual Trans
Sensor, Manual Trans Design 636
X15 - Backup Alarm (Direct from Reverse Switch to
Alarm Conn)
X15 - Backup Alarm (Direct from Reverse Switch to Alarm Conn) Design 637
Alarm)
X15 - Backup Alarm (Direct from Reverse Switch to Alarm) Design 638
xxxiiiX15 - Backup Alarm (Reverse Switch to 6 Pin 08TKB
X15 - Backup Alarm (Reverse Switch to 6 Pin 08TKB Tailboard. Backup Alarm
Plugs in) Design 639
X15 - Backup Alarm (Reverse Switch to 6 Pin 08TKJ
X15 - Backup Alarm (Reverse Switch to 6 Pin 08TKJ Tailboard to Alarm Direct)
with Daisy Chain Design 640
with 0008TKC Design 641
with 0008TKJ Design 642
X15 - Backup Alarm (Reverse Switch to 6 Pin 08TKJ Tailboard. Backup Alarm
Plugs In) Design 643
X15 - Backup Alarm (Switch to 5 Pin Daisy Chain to
Alarm)_Daisy Chain
X15 - Backup Alarm (Switch to 5 Pin Daisy Chain to Alarm)_Daisy Chain
Design 644
Alarm)_0008TKC
X15 - Backup Alarm (Switch to 5 Pin Daisy Chain to Alarm)_0008TKC Design 645
Alarm)_0008TKJ
X15 - Backup Alarm (Switch to 5 Pin Daisy Chain to Alarm)_0008TKJ Design 646
X15 - Backup Alarm (Switch to 5 Pin 08TKC Tailboard
to Alarm)
X15 - Backup Alarm (Switch to 5 Pin 08TKC Tailboard to Alarm) Design 647
X15 - Backup Light Dual Daisy Reverse With Yukon
Trans
X15 - Backup Light Dual Daisy Reverse With Yukon Trans Design 648
X15 - Backup Light Dual Daisy with extension With
Allison Trans
X15 - Backup Light Dual Daisy with extension With Allison Trans Design 649
X15 - Backup Light Dual Daisy with extension Yukon
X15 - Backup Light Dual Daisy with extension Yukon Transmission Design 650
X15 - Backup Light Dual Reverse Light WithAllison
Trans
X15 - Backup Light Dual Reverse Light WithAllison Trans Design 651
xxxivX15 - Backup Light Dual Reverse Relay Coil Control
by TCM - 6 PIN
X15 - Backup Light Dual Reverse Relay Coil Control by TCM - 6 PIN Design 652
X15 - Backup Light Single Reverse LightWith Less
X15 - Backup Light Single Reverse LightWith Less Power Module With Yukon
Trans Design 653
X15 - Backup Light Single Reverse Light With Less
X15 - Backup Light Single Reverse Light With Less Power Module With Allison
Design 654
X15 - Backup Light Single Reverse Light Yukon
X15 - Backup Light Single Reverse Light Yukon Transmission Design 655
X15 - Battery International (3) 12V (Horizon)
X15 - Battery International (3) 12V (Horizon) Design 656
X15 - Battery International (4) 12V (Horizon)
X15 - Battery International (4) 12V (Horizon) Design 657
X15 - Body Builder Lighting - (BOC, EOF) (8HAB,
8HAE)
X15 - Body Builder Lighting - (BOC, EOF) (8HAB, 8HAE) Design 658
8HAE) (Automatic)
X15 - Body Builder Lighting - (BOC, EOF) (8HAB, 8HAE) (Automatic) Design 659
X15 - Body Builder - Powertrain
X15 - Body Builder - Powertrain Design 660
X15 - Charging System (Delco Remy 28SI Alternator
W/ Remote Sense)
X15 - Charging System (Delco Remy 28SI Alternator W/ Remote Sense)
Design 661
X15 - Charging System (Delco Remy 36SI Alternator
W/ Remote Sense)
X15 - Charging System (Delco Remy 36SI Alternator W/ Remote Sense)
Design 662
X15 - Charging System (Delco Remy 40SI/38SI
X15 - Charging System (Delco Remy 40SI/38SI Alternator W/ Remote Sense)
Design 663
X15 - Charging System (Leece-Neville AVI160 160A W/
Remote Sense)
X15 - Charging System (Leece-Neville AVI160 160A W/ Remote Sense)
Design 664
X15 - Charging System (Leece-Neville AVI160-
xxxvX15 - Charging System (Leece-Neville AVI160-160A/240A N/ Remote Sense)
Design 665
X15 - Charging System (Leece-Neville AVI160-190A/210A/240A Alternator W/
Remote Sense) Design 666
X15 - Charging System (Leece-Neville 320PAH
Alternator)
X15 - Charging System (Leece-Neville 320PAH Alternator) Design 667
X15 - Charging System (Leece-Neville - LN 325A
X15 - Charging System (Leece-Neville - LN 325A Alternator W/ Remote Sense)
Design 668
X15 - Charging System (LH160_LH200)
X15 - Charging System (LH160_LH200) Design 669
X15 - Charging System (LIL165_LIL200 Alternator W/
Remote Sense)
X15 - Charging System (LIL165_LIL200 Alternator W/ Remote Sense) Design 670
X15 - Energy Storage System - International (8
Batteries) 12V
X15 - Energy Storage System - International (8 Batteries) 12V Design 671
X15 - Fuel Heater (Vehicle Powered)(Davco)
X15 - Fuel Heater (Vehicle Powered)(Davco) Design 672
X15 - Fuel Heater (Vehicle Powered)(Racor)
X15 - Fuel Heater (Vehicle Powered)(Racor) Design 673
X15 - Grounds
X15 - Grounds Design 674
X15 - Heating, Ventilation, & Air Conditioning (HVAC)
SW)
X15 - Heating, Ventilation, & Air Conditioning (HVAC) (Auto Control head W/PT
Transducer, N/Low Pressure SW) Design 675
X15 - Heating, Ventilation, & Air Conditioning (HVAC) (Manual, W/PT Transducer,
N/Low Pressure SW) Design 678
X15 - Over The Air Electrical I/O (OnCommand Link /
N2 Module)
X15 - Over The Air Electrical I/O (OnCommand Link / N2 Module) Design 680
X15 - Splice Packs
X15 - Splice Packs Design 682
X15 - Starter Interlock (BCM HSD CTRL W/ Clutch
xxxviX15 - Starter Interlock (BCM HSD CTRL W/ Clutch Switch W/ Neutral Switch)
Design 683
X15 - Transfer Case (NAMCO PowerTower W/ INTL
Engines & N/ TCM)
X15 - Transfer Case (NAMCO PowerTower W/ INTL Engines & N/ TCM)
Design 684
X15 - Transmissions Electrical I/O (Eaton Ultrashift)
X15 - Transmissions Electrical I/O (Eaton Ultrashift) Design 685
X15 - Transmission Electrical I/O (Endurant W/A26 &
N/ Body Builder)
X15 - Transmission Electrical I/O (Endurant W/A26 & N/ Body Builder) Design 686
X15 - Transmission Electrical I/O (Endurant W/ Cummins N/ Body Builder)
Design 687
X15 - Transmission I/O (Allison 4K with Body Builder)
X15 - Transmission I/O (Allison 4K with Body Builder) Design 688
X15 - Transmission I/O (Allison 4700 with Body
Builder)
X15 - Transmission I/O (Allison 4700 with Body Builder) Design 691
X15 - Transmission Oil Temperature (Manual Trans)
X15 - Transmission Oil Temperature (Manual Trans) Design 694
X15 - Transmission Oil Temperature (Manual TransHorizon W/ Aux Gauge)
X15 - Transmission Oil Temperature (Manual Trans-Horizon W/ Aux Gauge)
Design 695
X15 - Transmission Shifter (Eaton Endurant and Eaton
Procision)
X15 - Transmission Shifter (Eaton Endurant and Eaton Procision) Design 696
X15 - Transmission Shifter (Universal Stalk Shifter,
Ultrashift)
X15 - Transmission Shifter (Universal Stalk Shifter, Ultrashift) Design 697
X15 - Vehicle Speedometer System (From Road Speed
SNSR to Blunt Cut)
X15 - Vehicle Speedometer System (From Road Speed SNSR to Blunt Cut)
Design 698
X15 - Vehicle Speedometer System (VSS wired
directly to ECM) Connector5770
X15 - Vehicle Speedometer System (VSS wired directly to ECM) Connector5770
Design 699
directly to ECM) Connector7023
X15 - Vehicle Speedometer System (VSS wired directly to ECM) Connector7023
Design 700
X15 - Water In Fuel (WIF) Davco N/ Heater
xxxviiX15 - Water In Fuel (WIF) Davco N/ Heater Design 701
X15 - Water In Fuel (WIF) Davco W/ Heater
X15 - Water In Fuel (WIF) Davco W/ Heater Design 702
X15 - Water In Fuel (WIF) Racor N/ Heater
X15 - Water In Fuel (WIF) Racor N/ Heater Design 703
Yukon Transmission
Yukon Transmission Design 704
ZVR Splice Pack
ZVR Splice Pack Design 705
ZVR Splice Packs
ZVR Splice Packs Design 706
2017 A26 - Ambient Air Temperature (Mirror Sensor)
2017 A26 - Ambient Air Temperature (Mirror Sensor) Design 707
2017 A26 - Ambient Air Temperature (no Display,
Mirror Sensor)
2017 A26 - Ambient Air Temperature (no Display, Mirror Sensor) Design 708
2017 A26 - Body Builder Lighting - (BOC, EOF) (8HAB,
8HAE)
2017 A26 - Body Builder Lighting - (BOC, EOF) (8HAB, 8HAE) Design 709
2017 A26 - Powertrain Body Builder Connector A26
Engine MX1 With Ultrashift TCM
2017 A26 - Powertrain Body Builder Connector A26 Engine MX1 With Ultrashift
TCM Design 710
2017 A26 - Powertrain Body Builder Connector (A26
Engine MD1 W/Ultrashift TCM)
2017 A26 - Powertrain Body Builder Connector (A26 Engine MD1 W/Ultrashift
TCM) Design 712
Engine MX1 N/Ultrashift TCM)
2017 A26 - Powertrain Body Builder Connector (A26 Engine MX1 N/Ultrashift
TCM) Design 714
(Engine MX1)
2017 A26 - Powertrain Body Builder Connector (Engine MX1) Design 715
2017 A26 - Vehicle Acceleration (w/ Two PWR, Two
2017 A26 - Vehicle Acceleration (w/ Two PWR, Two GND, & Two STS)(Horizon)
Design 719
2017 A26 - Water In Fuel (WIF) Davco N/ Heater
2017 A26 - Water In Fuel (WIF) Davco N/ Heater Design 720
2017 A26 - Water In Fuel (WIF) Davco W/ Heater
2017 A26 - Water In Fuel (WIF) Davco W/ Heater Design 721
xxxviii2017 A26 - Water In Fuel (WIF) Racor N/ Heater
2017 A26 - Water In Fuel (WIF) Racor N/ Heater Design 722
2017 X15 - ECM
2017 X15 - ECM Design 723
2021 A26 - Ambient Air Temperature (Mirror Sensor)
2021 A26 - Ambient Air Temperature (Mirror Sensor) Design 726
2021 A26 - Ambient Air Temperature (no Display,
Mirror Sensor)
2021 A26 - Ambient Air Temperature (no Display, Mirror Sensor) Design 727
2021 A26 - ECM
2021 A26 - ECM Design 728
2021 A26 - Powertrain Body Builder Connector (A26
2021 A26 - Powertrain Body Builder Connector (A26 Engine MD1 W/Ultrashift
TCM) Design 732
2021 A26 - Powertrain Body Builder Connector (A26 Engine MX1 N/Ultrashift
TCM) Design 734
Engine MX1 W/Ultrashift TCM)
2021 A26 - Powertrain Body Builder Connector (A26 Engine MX1 W/Ultrashift
TCM) Design 735
2021 A26 - Service Brake Switch (1 SLS/1 Transducer)
2021 A26 - Service Brake Switch (1 SLS/1 Transducer) Design 737
Transducer/1 RDS to ECM)
2021 A26 - Service Brake Switch (1 SLS/1 Transducer/1 RDS to ECM)
Design 738
2021 A26 - Service Brake Switch (2 SLS/ 1 Transducer/
1 RDS to ECM)
2021 A26 - Service Brake Switch (2 SLS/ 1 Transducer/ 1 RDS to ECM)
Design 739
2021 A26 - Vehicle Acceleration (w/ Two PWR, Two
2021 A26 - Vehicle Acceleration (w/ Two PWR, Two GND, & Two STS)(Horizon)
Design 740
2021 A26 - Vehicle Speedometer System (VSS wired to
VIC)
2021 A26 - Vehicle Speedometer System (VSS wired to VIC) Design 741
2021 A26 - Water In Fuel (WIF) Davco N/ Heater
2021 A26 - Water In Fuel (WIF) Davco N/ Heater Design 742
2021 A26 - Water In Fuel (WIF) Davco W/ Heater
2021 A26 - Water In Fuel (WIF) Davco W/ Heater Design 743
xxxix2021 A26 - Water In Fuel (WIF) Racor N/ Heater
2021 A26 - Water In Fuel (WIF) Racor N/ Heater Design 744
2021 X15 - Body Builder Lighting - (BOC, EOF) (8HAB,
8HAE)
2021 X15 - Body Builder Lighting - (BOC, EOF) (8HAB, 8HAE) Design 745
2021 X15 - Body Builder - Altec (N/BB & W/Manual
XMSN & W/ CUMMINS Engine)
2021 X15 - Body Builder - Altec (N/BB & W/Manual XMSN & W/ CUMMINS
Engine) Design 746
2021 X15 - Coolant Level Monitoring (No CLA Module)
2021 X15 - Coolant Level Monitoring (No CLA Module) Design 748
2-Way Radio
2-Way Radio Design 749
Connectors 752
Part Assembly List
HX_Terminal Part Number 2370
Index 2449
Brand: International, Navistar
Type of Manual: Interactive Schematics
Model: International HX Series Truck
Built: 2021
Part Number: 0000018830
Publication Date: 2022
Number of Pages: 2517 Pages
Adaptive Cruise Control (Bendix Wingman Advanced
N/ DIU)
Adaptive Cruise Control (Bendix Wingman Advanced N/ DIU) Design 1
Adaptive Cruise Control (Bendix - Fusion W/O DIU &
N/ Safety Direct & Reg Speakers)
Adaptive Cruise Control (Bendix - Fusion W/O DIU & N/ Safety Direct & Reg
Speakers) Design 2
N/ Safety Direct & Tweeters)
Adaptive Cruise Control (Bendix - Fusion W/O DIU & N/ Safety Direct & Tweeters)
Design 4
W/ Safety Direct & Reg Speakers)
Adaptive Cruise Control (Bendix - Fusion W/O DIU & W/ Safety Direct & Reg
Speakers) Design 5
W/ Safety Direct & W/ Tweeters)
Adaptive Cruise Control (Bendix - Fusion W/O DIU & W/ Safety Direct & W/
Tweeters) Design 7
Adaptive Cruise Control (Bendix - Fusion 2.0 N/ Safety
Adaptive Cruise Control (Bendix - Fusion 2.0 N/ Safety Direct & Reg Speakers)
Design 8
Direct & Tweeters)
Adaptive Cruise Control (Bendix - Fusion 2.0 N/ Safety Direct & Tweeters)
Design 9
Adaptive Cruise Control (Bendix - Fusion 2.0 W/
Adaptive Cruise Control (Bendix - Fusion 2.0 W/ Safety Direct & W/ Tweeters)
Design 10
Adaptive Cruise Control (Bendix - Fusion 2.0 & W/
Adaptive Cruise Control (Bendix - Fusion 2.0 & W/ Safety Direct & Reg Speakers)
Design 11
Adaptive Cruise Control (Fusion 3.0 N/ DIU)
Adaptive Cruise Control (Fusion 3.0 N/ DIU) Design 12
Air Dryer (Single)
Air Dryer (Single) Design 13
Air Horn Highway With Hardwired Switch
Air Horn Highway With Hardwired Switch Design 14
Air Solenoids 4-pack (1 pack/4 solenoids)
Air Solenoids 4-pack (1 pack/4 solenoids) Design 15
Air Solenoids 4-pack (2 packs/8 solenoids)
Air Solenoids 4-pack (2 packs/8 solenoids) Design 16
iAir Solenoids 4-pack (3 packs/12 solenoids)
Air Solenoids 4-pack (3 packs/12 solenoids) Design 17
Antenna (Film Antenna, Sleeper, OTAPM, AM/FM, XM
Radio)
Antenna (Film Antenna, Sleeper, OTAPM, AM/FM, XM Radio) Design 18
Antenna (Shark Fin, AM/FM/WB only)
Antenna (Shark Fin, AM/FM/WB only) Design 20
Antenna (Shark Fin, Day Cab, OTAPM, AM/FM, XM
Radio)
Antenna (Shark Fin, Day Cab, OTAPM, AM/FM, XM Radio) Design 21
Antilock Brake System (ABS) (BENDIX 4 Channel
Implemenation - No Modulator Twist)
Antilock Brake System (ABS) (BENDIX 4 Channel Implemenation - No Modulator
Twist) Design 22
Antilock Brake System (ABS) (Bendix 6 Channel
Implementation - No Modulator Twist)
Antilock Brake System (ABS) (Bendix 6 Channel Implementation - No Modulator
Twist) Design 28
Automatic Lighting With Twilight & Not With Sunload
Automatic Lighting With Twilight & Not With Sunload Design 34
Automatic Lighting With Twilight & With Sunload
Automatic Lighting With Twilight & With Sunload Design 35
Auto Start Stop Battery & Oil Temp Mapping, Auto
Trans
Auto Start Stop Battery & Oil Temp Mapping, Auto Trans Design 36
Auto Start Stop Battery, Oil Temp Mapping, Manual
Trans
Auto Start Stop Battery, Oil Temp Mapping, Manual Trans Design 37
Auxiliary Gauges (Multiple)
Auxiliary Gauges (Multiple) Design 38
Auxiliary Gauges (Single)
Auxiliary Gauges (Single) Design 39
Auxiliary Power Source (Sleeper) - 3 APO
Auxiliary Power Source (Sleeper) - 3 APO Design 40
Auxiliary Power (40A) HSD
Auxiliary Power (40A) HSD Design 42
Auxiliary Roof Power (20A)
Auxiliary Roof Power (20A) Design 43
Auxiliary Trailer Power (BOC, ACC Bias)
Auxiliary Trailer Power (BOC, ACC Bias) Design 44
Auxiliary Trailer Power (POGO, ACC Bias)
Auxiliary Trailer Power (POGO, ACC Bias) Design 46
iiAUX Power Connector
AUX Power Connector Design 47
Aux Power (Banana Plug)
Aux Power (Banana Plug) Design 48
Aux Power (Blunt Cut)
Aux Power (Blunt Cut) Design 49
Aux Power (USB) - 1 USB
Aux Power (USB) - 1 USB Design 50
Aux Power (USB) - 2 USB
Aux Power (USB) - 2 USB Design 51
Aux Power (USB) - 3 USB
Aux Power (USB) - 3 USB Design 53
Aux Power (USB) - 4 USB
Aux Power (USB) - 4 USB Design 55
Aux Power (USB) - 5 USB
Aux Power (USB) - 5 USB Design 57
Axle Loading (Weight) (Rear)
Axle Loading (Weight) (Rear) Design 59
Axle Temperature (Tandem, Aux Gauges)
Axle Temperature (Tandem, Aux Gauges) Design 60
Axle Temperature (Tandem, Virtual Gauges)
Axle Temperature (Tandem, Virtual Gauges) Design 61
Axle Temperature (Tridem, Aux Gauges)
Axle Temperature (Tridem, Aux Gauges) Design 62
Axle Temperature (Tridem, Virtual Gauges)
Axle Temperature (Tridem, Virtual Gauges) Design 63
A26 Endurant Manual Transmission - Transmission
Power Take Off (Dual PTO W/ 42 Parameters & W/
Auto, AMT Trans)
A26 Endurant Manual Transmission - Transmission Power Take Off (Dual PTO
W/ 42 Parameters & W/ Auto, AMT Trans) Design 64
Manual Trans)
W/ 42 Parameters & W/ Manual Trans) Design 65
Power Take Off (Single PTO W/42 Parameters & W/
Auto, AMT Trans)
A26 Endurant Manual Transmission - Transmission Power Take Off (Single PTO
W/42 Parameters & W/ Auto, AMT Trans) Design 66
iiiA26 Endurant Manual Transmission - Transmission
Power Take Off (Single PTO W/ 42 Parameters & W/
Manl Trans)
W/ 42 Parameters & W/ Manl Trans) Design 67
A26 Endurant Transmission - Starter Interlocks
A26 Endurant Transmission - Starter Interlocks (Service Brake Interlock)
Design 68
A26 Endurant Transmission - Starter Interlock (BCM
LSD Controlled w/ Relay & N/ Neutral Switch)
A26 Endurant Transmission - Starter Interlock (BCM LSD Controlled w/ Relay &
N/ Neutral Switch) Design 69
LSD Controlled w/ Relay)_EATON XMSN
Relay)_EATON XMSN Design 70
A26 Endurant Transmission - Transmission Power
Take Off (Dual PTO W/ 42 Parameters & W/ Auto, AMT
Trans)
A26 Endurant Transmission - Transmission Power Take Off (Dual PTO W/ 42
Parameters & W/ Auto, AMT Trans) Design 71
Take Off (Dual PTO W/ 42 Parameters & W/ Manual
Trans)
Parameters & W/ Manual Trans) Design 72
Take Off (Single PTO W/42 Parameters & W/ Auto,
AMT Trans)
A26 Endurant Transmission - Transmission Power Take Off (Single PTO W/42
Parameters & W/ Auto, AMT Trans) Design 73
Take Off (Single PTO W/ 42 Parameters & W/ Manl
Trans)
A26 Endurant Transmission - Transmission Power Take Off (Single PTO W/ 42
Parameters & W/ Manl Trans) Design 74
A26 Endurant Transmission - Transmission Shifter
(Dual Shifter with primary being stalk)
A26 Endurant Transmission - Transmission Shifter (Dual Shifter with primary
being stalk) Design 75
(Universal Stalk Shifter - Allison)
A26 Endurant Transmission - Transmission Shifter (Universal Stalk Shifter -
Allison) Design 76
ivA26 Ultrashift Transmission - Starter Interlocks
A26 Ultrashift Transmission - Starter Interlocks (Service Brake Interlock)
Design 77
A26 Ultrashift Transmission - Starter Interlock (BCM
A26 Ultrashift Transmission - Starter Interlock (BCM LSD Controlled w/ Relay &
N/ Neutral Switch) Design 78
Relay)_EATON XMSN Design 79
A26 Ultrashift Transmission - Transmission Shifter
A26 Ultrashift Transmission - Transmission Shifter (Dual Shifter with primary
being stalk) Design 80
A26 Ultrashift Transmission - Transmission Shifter (Universal Stalk Shifter -
Allison) Design 81
A26 2017 - Coolant Level Monitoring (No CLA Module)
A26 2017 - Coolant Level Monitoring (No CLA Module) Design 82
A26 2017 - Cooling Fan Control (Fan Override)
A26 2017 - Cooling Fan Control (Fan Override) Design 83
A26 2017 - Cooling Fan Control (No Fan Override)
A26 2017 - Cooling Fan Control (No Fan Override) Design 84
A26 2021 - Coolant Level Monitoring (No CLA Module)
A26 2021 - Coolant Level Monitoring (No CLA Module) Design 85
A26 2021 - Cooling Fan Control (Fan Override)
A26 2021 - Cooling Fan Control (Fan Override) Design 86
A26 2021 - Cooling Fan Control (No Fan Override)
A26 2021 - Cooling Fan Control (No Fan Override) Design 87
A26 2021 - Selective Catalytic Reduction (SCR)
A26 2021 - Selective Catalytic Reduction (SCR) Design 88
A26 2021 - Starting Aid (Flame Start W/MD1 ECM)
A26 2021 - Starting Aid (Flame Start W/MD1 ECM) Design 90
A26 3/4000 5GEN Transmission - Transmission Power
Trans)
A26 3/4000 5GEN Transmission - Transmission Power Take Off (Dual PTO W/ 42
Parameters & W/ Auto, AMT Trans) Design 91
Trans)
vA26 3/4000 5GEN Transmission - Transmission Power Take Off (Dual PTO W/ 42
Parameters & W/ Manual Trans) Design 92
AMT Trans)
A26 3/4000 5GEN Transmission - Transmission Power Take Off (Single PTO
W/42 Parameters & W/ Auto, AMT Trans) Design 93
A26 -Backup Alarm (Switch to 5 Pin 08TKC Tailboard
to Alarm) 0008TKJ
A26 -Backup Alarm (Switch to 5 Pin 08TKC Tailboard to Alarm) 0008TKJ
Design 94
A26 - Air Filter Flow Restriction Monitoring
A26 - Air Filter Flow Restriction Monitoring Design 95
A26 - Auto Neutral (Allision without Switch and with
A26 - Auto Neutral (Allision without Switch and with Confirmation Telltale)
Design 96
A26 - Auto Neutral (Allison with Multiplex Switch and
A26 - Auto Neutral (Allison with Multiplex Switch and Confirmation Telltale)
Design 97
A26 - Backup Alarm (Direct from Reverse Switch to
Alarm Conn)
A26 - Backup Alarm (Direct from Reverse Switch to Alarm Conn) Design 98
Alarm)
A26 - Backup Alarm (Direct from Reverse Switch to Alarm) Design 99
A26 - Backup Alarm (Reverse Switch to 6 Pin 08TKB
A26 - Backup Alarm (Reverse Switch to 6 Pin 08TKB Tailboard. Backup Alarm
Plugs in) Design 100
A26 - Backup Alarm (Reverse Switch to 6 Pin 08TKJ
Tailboard to Alarm Direct) with Daisy Chain
A26 - Backup Alarm (Reverse Switch to 6 Pin 08TKJ Tailboard to Alarm Direct)
with Daisy Chain Design 101
Tailboard to Alarm Direct) with 0008TKC
with 0008TKC Design 102
Tailboard to Alarm Direct) with 0008TKJ
with 0008TKJ Design 103
Tailboard. Backup Alarm Plugs In)
viA26 - Backup Alarm (Reverse Switch to 6 Pin 08TKJ Tailboard. Backup Alarm
Plugs In) Design 104
A26 - Backup Alarm (Switch to 5 Pin Daisy Chain to
Alarm) with 0008TKC
A26 - Backup Alarm (Switch to 5 Pin Daisy Chain to Alarm) with 0008TKC
Design 105
Alarm) with 0008TKJ
A26 - Backup Alarm (Switch to 5 Pin Daisy Chain to Alarm) with 0008TKJ
Design 106
Alarm)_Daisy Chain
A26 - Backup Alarm (Switch to 5 Pin Daisy Chain to Alarm)_Daisy Chain
Design 107
A26 - Backup Alarm (Switch to 5 Pin 08TKC Tailboard
to Alarm)
A26 - Backup Alarm (Switch to 5 Pin 08TKC Tailboard to Alarm) Design 108
to Alarm) 0008TKC
A26 - Backup Alarm (Switch to 5 Pin 08TKC Tailboard to Alarm) 0008TKC
Design 109
A26 - Backup Light Dual Daisy Reverse With Yukon
Trans
A26 - Backup Light Dual Daisy Reverse With Yukon Trans Design 110
A26 - Backup Light Dual Daisy with extension With
Allison Trans
A26 - Backup Light Dual Daisy with extension With Allison Trans Design 111
A26 - Backup Light Dual Daisy with extension Yukon
A26 - Backup Light Dual Daisy with extension Yukon Transmission Design 112
A26 - Backup Light Dual Reverse Light WithAllison
Trans
A26 - Backup Light Dual Reverse Light WithAllison Trans Design 113
A26 - Backup Light Dual Reverse Relay Coil Control
by TCM - 6 PIN
A26 - Backup Light Dual Reverse Relay Coil Control by TCM - 6 PIN Design 114
A26 - Backup Light Single Reverse LightWith Less
Power Module With Yukon Trans
A26 - Backup Light Single Reverse LightWith Less Power Module With Yukon
Trans Design 115
A26 - Backup Light Single Reverse Light With Less
A26 - Backup Light Single Reverse Light With Less Power Module With Allison
Design 116
viiA26 - Backup Light Single Reverse Light Yukon
A26 - Backup Light Single Reverse Light Yukon Transmission Design 117
A26 - Battery International (3) 12V (Horizon)
A26 - Battery International (3) 12V (Horizon) Design 118
A26 - Battery International (4) 12V (Horizon)
A26 - Battery International (4) 12V (Horizon) Design 119
8HAE)
A26 - Body Builder Lighting - (BOC, EOF) (8HAB, 8HAE) Design 120
8HAE) (Automatic)
A26 - Body Builder Lighting - (BOC, EOF) (8HAB, 8HAE) (Automatic) Design 121
A26 - Body Builder - Altec (N/BB & W/3K4K Trans & W/
INTL Engine)
A26 - Body Builder - Altec (N/BB & W/3K4K Trans & W/ INTL Engine) Design 122
A26 - Body Builder - Altec (W/BB & W/Manual Trans &
W/ INTL Engine)
A26 - Body Builder - Altec (W/BB & W/Manual Trans & W/ INTL Engine)
Design 124
A26 - Body Builder - Altec (W/BB & W/3K4K Trans &
W/ INTL Engine)
A26 - Body Builder - Altec (W/BB & W/3K4K Trans & W/ INTL Engine) Design 129
A26 - Charging System (Delco Remy 28SI Alternator
W/ Remote Sense)
A26 - Charging System (Delco Remy 28SI Alternator W/ Remote Sense)
Design 134
A26 - Charging System (Delco Remy 36SI Alternator
W/ Remote Sense)
A26 - Charging System (Delco Remy 36SI Alternator W/ Remote Sense)
Design 135
A26 - Charging System (Delco Remy 40SI/38SI
A26 - Charging System (Delco Remy 40SI/38SI Alternator W/ Remote Sense)
Design 136
A26 - Charging System (Leece-Neville AVI160 160A W/
Remote Sense)
A26 - Charging System (Leece-Neville AVI160 160A W/ Remote Sense)
Design 137
A26 - Charging System (Leece-Neville AVI160-
A26 - Charging System (Leece-Neville AVI160-160A/240A N/ Remote Sense)
Design 138
190A/210A/240A Alternator W/ Remote Sense)
viiiA26 - Charging System (Leece-Neville AVI160-190A/210A/240A Alternator W/
Remote Sense) Design 139
A26 - Charging System (Leece-Neville 320PAH
Alternator)
A26 - Charging System (Leece-Neville 320PAH Alternator) Design 140
A26 - Charging System (Leece-Neville - LN 325A
A26 - Charging System (Leece-Neville - LN 325A Alternator W/ Remote Sense)
Design 141
A26 - Charging System (LH160_LH200)
A26 - Charging System (LH160_LH200) Design 142
A26 - Charging System (LIL165_LIL200 Alternator W/
Remote Sense)
A26 - Charging System (LIL165_LIL200 Alternator W/ Remote Sense) Design 143
A26 - Energy Storage System - International (8
Batteries) 12V
A26 - Energy Storage System - International (8 Batteries) 12V Design 144
A26 - Fuel Heater (Vehicle Powered)(Davco)
A26 - Fuel Heater (Vehicle Powered)(Davco) Design 145
A26 - Fuel Heater (Vehicle Powered)(Racor)
A26 - Fuel Heater (Vehicle Powered)(Racor) Design 146
A26 - Grounds
A26 - Grounds Design 147
A26 - Heating, Ventilation, & Air Conditioning (HVAC)
(Auto Control head W/PT Transducer, N/Low Pressure
SW)
A26 - Heating, Ventilation, & Air Conditioning (HVAC) (Auto Control head W/PT
Transducer, N/Low Pressure SW) Design 148
(Manual, W/PT Transducer, N/Low Pressure SW)
A26 - Heating, Ventilation, & Air Conditioning (HVAC) (Manual, W/PT Transducer,
N/Low Pressure SW) Design 151
A26 - Over The Air Electrical I/O (OnCommand Link /
N2 Module W/ Diagnostic Connector)
A26 - Over The Air Electrical I/O (OnCommand Link / N2 Module W/ Diagnostic
Connector) Design 153
A26 - Powertrain Body Builder Connector (N/Ultrashift
TCM)
A26 - Powertrain Body Builder Connector (N/Ultrashift TCM) Design 155
A26 - Starter Interlock (BCM HSD CTRL W/ Clutch
A26 - Starter Interlock (BCM HSD CTRL W/ Clutch Switch W/ Neutral Switch)
Design 156
ixA26 - Transfer Case (NAMCO PowerTower W/ INTL
Engines & N/ TCM)
A26 - Transfer Case (NAMCO PowerTower W/ INTL Engines & N/ TCM)
Design 157
A26 - Transmissions Electrical I/O (Eaton Ultrashift)
A26 - Transmissions Electrical I/O (Eaton Ultrashift) Design 158
A26 - Transmission Electrical I/O (Endurant W/A26 &
N/ Body Builder)
A26 - Transmission Electrical I/O (Endurant W/A26 & N/ Body Builder) Design 159
A26 - Transmission Electrical I/O (Endurant W/ Cummins N/ Body Builder)
Design 160
A26 - Transmission I/O (Allison 4K with Body Builder)
A26 - Transmission I/O (Allison 4K with Body Builder) Design 161
A26 - Transmission I/O (Allison 4700 with Body
Builder)
A26 - Transmission I/O (Allison 4700 with Body Builder) Design 164
A26 - Transmission Oil Temperature (Manual Trans)
A26 - Transmission Oil Temperature (Manual Trans) Design 167
A26 - Transmission Oil Temperature (Manual TransHorizon W/ Aux Gauge)
A26 - Transmission Oil Temperature (Manual Trans-Horizon W/ Aux Gauge)
Design 168
A26 - Transmission Shifter (Eaton Endurant and Eaton
Procision)
A26 - Transmission Shifter (Eaton Endurant and Eaton Procision) Design 169
A26 - Transmission Shifter (Universal Stalk Shifter,
Ultrashift)
A26 - Transmission Shifter (Universal Stalk Shifter, Ultrashift) Design 170
A26 - Vehicle Speedometer System (From ECM to
Blunt Cut)
A26 - Vehicle Speedometer System (From ECM to Blunt Cut) Design 171
directly to ECM) Connector5771
A26 - Vehicle Speedometer System (VSS wired directly to ECM) Connector5771
Design 172
Connector5771
A26 - Vehicle Speedometer System (VSS wired to VIC) Connector5771
Design 173
A26 - ZVR Splice Pack
A26 - ZVR Splice Pack Design 174
xA26/X15 - Auto Start Stop and Sleeper Auto Climate,
Cab Temp, Oil Mapping, Manual Trans
A26/X15 - Auto Start Stop and Sleeper Auto Climate, Cab Temp, Oil Mapping,
Manual Trans Design 175
A26/X15 - Auto Start Stop with Sleeper Auto Climate,
Cab Temp, Oil Mapping, Auto Trans
A26/X15 - Auto Start Stop with Sleeper Auto Climate, Cab Temp, Oil Mapping,
Auto Trans Design 176
A26/X15 - Axle Lift Controls (ELAM Module)
A26/X15 - Axle Lift Controls (ELAM Module) Design 177
A26/X15 - Axle Lift Controls (1 MUX Switch)
A26/X15 - Axle Lift Controls (1 MUX Switch) Design 178
A26/X15 - Axle Lift Controls (2 MUX Switches)
A26/X15 - Axle Lift Controls (2 MUX Switches) Design 180
A26/X15 - Axle Lift Controls (3 MUX Switches)
A26/X15 - Axle Lift Controls (3 MUX Switches) Design 182
A26/X15 - Axle Lift Pressure Monitoring (1 Aux Gauge)
A26/X15 - Axle Lift Pressure Monitoring (1 Aux Gauge) Design 184
A26/X15 - Axle Lift Pressure Monitoring (1 Virtual
Gauge)
A26/X15 - Axle Lift Pressure Monitoring (1 Virtual Gauge) Design 185
A26/X15 - Axle Lift Pressure Monitoring (2 Aux
Gauges)
A26/X15 - Axle Lift Pressure Monitoring (2 Aux Gauges) Design 186
A26/X15 - Axle Lift Pressure Monitoring (2 Virtual
Gauges)
A26/X15 - Axle Lift Pressure Monitoring (2 Virtual Gauges) Design 187
A26/X15 - Axle Lift Pressure Monitoring (3 Aux
Gauges)
A26/X15 - Axle Lift Pressure Monitoring (3 Aux Gauges) Design 188
A26/X15 - Axle Lift Pressure Monitoring (3 Virtual
Gauges)
A26/X15 - Axle Lift Pressure Monitoring (3 Virtual Gauges) Design 189
A26/X15 - Backup Alarm (Switch to 5 Pin Daisy Chain.
A26/X15 - Backup Alarm (Switch to 5 Pin Daisy Chain. Backup Alarm plugs in)
Design 190
A26/X15 - Bendix Tractor or Towing Truck N/ Air SUSP
J1939 Driven Lamp
A26/X15 - Bendix Tractor or Towing Truck N/ Air SUSP J1939 Driven Lamp
Design 192
A26/X15 - Bendix Tractor or Towing Truck W/ Air
xiA26/X15 - Bendix Tractor or Towing Truck W/ Air SUSP J1939 Driven Lamp
Design 193
A26/X15 - Cranking (Starter) (BCM Controlled & N/
Wired Thermal Over-Crank)
A26/X15 - Cranking (Starter) (BCM Controlled & N/ Wired Thermal Over-Crank)
Design 194
A26/X15 - Cranking (Starter) (BCM Controlled & W/
Wired Thermal Overcrank)
A26/X15 - Cranking (Starter) (BCM Controlled & W/ Wired Thermal Overcrank)
Design 195
A26/X15 - Drain Valve with four (4) Heaters
A26/X15 - Drain Valve with four (4) Heaters Design 196
A26/X15 - Drain Valve with Three (3) Heaters
A26/X15 - Drain Valve with Three (3) Heaters Design 198
A26/X15 - Drain Valve with Two (2) Heaters
A26/X15 - Drain Valve with Two (2) Heaters Design 202
A26/X15 - Driver Controlled Locking Differential (Dana
A26/X15 - Driver Controlled Locking Differential (Dana - 2 Control - 2 Feedback -
FR&RR) Design 205
A26/X15 - Driver Controlled Locking Differential -
(Dana - 1 Control - 1 Feedback - RR)
A26/X15 - Driver Controlled Locking Differential - (Dana - 1 Control - 1 Feedback -
RR) Design 207
(Dana - 1 Control - 2 Feedback - FR&RR)
A26/X15 - Driver Controlled Locking Differential - (Dana - 1 Control - 2 Feedback -
FR&RR) Design 208
(Meritor - 1 Control - 1 Feedback - RR)
A26/X15 - Driver Controlled Locking Differential - (Meritor - 1 Control - 1
Feedback - RR) Design 210
(Meritor - 1 Control - 2 Feedback - FR&RR)
A26/X15 - Driver Controlled Locking Differential - (Meritor - 1 Control - 2
Feedback - FR&RR) Design 211
(Meritor - 1 Control - 3 Feedback - FR&CR&RR)
A26/X15 - Driver Controlled Locking Differential - (Meritor - 1 Control - 3
Feedback - FR&CR&RR) Design 214
(Meritor - 3 Control - 3 Feedback - FR&CR&RR)
A26/X15 - Driver Controlled Locking Differential - (Meritor - 3 Control - 3
Feedback - FR&CR&RR) Design 217
A26/X15 - Fuel Level Single Sensor
A26/X15 - Fuel Level Single Sensor Design 220
xiiA26/X15 - Heated Windshield
A26/X15 - Heated Windshield Design 223
A26/X15 - Hill Start Aid (HSA) (Bendix CA 2.0)
A26/X15 - Hill Start Aid (HSA) (Bendix CA 2.0) Design 224
A26/X15 - Hood Switch
A26/X15 - Hood Switch Design 225
A26/X15 - No-Idle HVAC W/Espar Airtronic &
W/Bergstrom AC
A26/X15 - No-Idle HVAC W/Espar Airtronic & W/Bergstrom AC Design 226
A26/X15 - Park Brake Controls (Non Lever Park Brake)
A26/X15 - Park Brake Controls (Non Lever Park Brake) Design 229
A26/X15 - Rear Heating, Ventilation & Air Conditioning
(HVAC) (Premium control head)
A26/X15 - Rear Heating, Ventilation & Air Conditioning (HVAC) (Premium control
head) Design 230
A26/X15 - Rear HVAC No Idle Heater Espar
A26/X15 - Rear HVAC No Idle Heater Espar Design 232
A26/X15 - Rear HVAC No Idle W/Pre-Heat Bergstrom
Heat and Cool N/2 addl Switches
A26/X15 - Rear HVAC No Idle W/Pre-Heat Bergstrom Heat and Cool N/2 addl
Switches Design 233
Heat and Cool & W/Espar Air Heat
A26/X15 - Rear HVAC No Idle W/Pre-Heat Bergstrom Heat and Cool & W/Espar
Air Heat Design 236
A26/X15 - Rear HVAC No Idle W/ Pre-Heat Bergstrom
Heat and Cool W/2 addl switches
A26/X15 - Rear HVAC No Idle W/ Pre-Heat Bergstrom Heat and Cool W/2 addl
switches Design 239
A26/X15 - Rear Suspension Pressure Monitoring
(Auxiliary Gauge)
A26/X15 - Rear Suspension Pressure Monitoring (Auxiliary Gauge) Design 242
(Virtual Gauge)
A26/X15 - Rear Suspension Pressure Monitoring (Virtual Gauge) Design 243
A26/X15 - Service Brake Pressure (Auxiliary Gauge)
A26/X15 - Service Brake Pressure (Auxiliary Gauge) Design 244
A26/X15 - Service Brake Pressure (No Gauges)
A26/X15 - Service Brake Pressure (No Gauges) Design 245
A26/X15 - Service Brake Pressure (Virtual Gauge)
A26/X15 - Service Brake Pressure (Virtual Gauge) Design 246
A26/X15 - Service Brake Switch (2 SLS/1 Transducer)
A26/X15 - Service Brake Switch (2 SLS/1 Transducer) Design 247
xiiiA26/X15 - Stability Control (Bendix Straight Truck
J1939 Driven Lamp)
A26/X15 - Stability Control (Bendix Straight Truck J1939 Driven Lamp) Design248
A26/X15 - TEM _Electric Trailer Brake Controller
Activated Stop Light
A26/X15 - TEM _Electric Trailer Brake Controller Activated Stop Light Design 249
A26/X15 - Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)
A26/X15 - Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater) Design 250
A26/X15 - Tire Pressure (TPMS) (LDL 2.0 - 2
Repeaters)
A26/X15 - Tire Pressure (TPMS) (LDL 2.0 - 2 Repeaters) Design 252
A26/X15 - Traction Control (Bendix)
A26/X15 - Traction Control (Bendix) Design 254
A26/X15 - Trailer Interface Lighting W/Combined
Turns using Blunt Cut
A26/X15 - Trailer Interface Lighting W/Combined Turns using Blunt Cut
Design 256
A26/X15 - Trailer Interface Lighting W/Separate Turns
using Blunt Cut
A26/X15 - Trailer Interface Lighting W/Separate Turns using Blunt Cut Design 257
A26/X15 - Trailer Interface (ABS) (Back of Cab Trailer
Socket)
A26/X15 - Trailer Interface (ABS) (Back of Cab Trailer Socket) Design 258
A26/X15 - Trailer Interface (ABS) (BOC and End of
Frame Trailer Socket)
A26/X15 - Trailer Interface (ABS) (BOC and End of Frame Trailer Socket)
Design 260
A26/X15 - Trailer Interface (ABS) (End of Frame Trailer
Socket)
A26/X15 - Trailer Interface (ABS) (End of Frame Trailer Socket) Design 262
A26/X15 - Trailer Interface (ABS) (POGO and End of
A26/X15 - Trailer Interface (ABS) (POGO and End of Frame Trailer Socket)
Design 263
A26/X15 - Trailer Interface (ABS) (POGO Trailer
Socket)
A26/X15 - Trailer Interface (ABS) (POGO Trailer Socket) Design 264
A26/X15 - Trailer Interface (Lighting) - Combined
Turns & Stop - End of Frame (RING GND)
A26/X15 - Trailer Interface (Lighting) - Combined Turns & Stop - End of Frame
(RING GND) Design 265
A26/X15 - Trailer Interface (Lighting) - Separate Turns
- EOF (RING GND)
A26/X15 - Trailer Interface (Lighting) - Separate Turns - EOF (RING GND)
Design 266
xivA26/X15 - Trailer Interface (Lighting) – Separate Turns
- BOC
A26/X15 - Trailer Interface (Lighting) – Separate Turns - BOC Design 268
- BOC & EOF (Ring Ground)
A26/X15 - Trailer Interface (Lighting) – Separate Turns - BOC & EOF (Ring
Ground) Design 270
- POGO
A26/X15 - Trailer Interface (Lighting) – Separate Turns - POGO Design 272
- POGO & AUX
A26/X15 - Trailer Interface (Lighting) – Separate Turns - POGO & AUX
Design 273
- POGO & EOF (Ring Ground)
A26/X15 - Trailer Interface (Lighting) – Separate Turns - POGO & EOF (Ring
Ground) Design 274
A26/X15 - Trailer Interface - ABS (ETB Feed, Blunt Cut)
A26/X15 - Trailer Interface - ABS (ETB Feed, Blunt Cut) Design 275
A26/X15 - Transmission Retarder (4K with Multiplex)
A26/X15 - Transmission Retarder (4K with Multiplex) Design 276
A26/X15 - Transmission Retarder (4700 with Multiplex)
A26/X15 - Transmission Retarder (4700 with Multiplex) Design 277
Backup Alarm (Direct from Relay to Alarm Connector)
Backup Alarm (Direct from Relay to Alarm Connector) Design 278
Backup Alarm (Direct from Relay to Alarm)
Backup Alarm (Direct from Relay to Alarm) Design 279
Backup Alarm (From Relay to 5 Pin Daisy Chain to
Backup Alarm)
Backup Alarm (From Relay to 5 Pin Daisy Chain to Backup Alarm) Design 280
Backup Alarm) with 0008TKJ
Backup Alarm (From Relay to 5 Pin Daisy Chain to Backup Alarm) with 0008TKJ
Design 281
Backup Alarm) 1
Backup Alarm (From Relay to 5 Pin Daisy Chain to Backup Alarm) 1 Design 282
Backup Alarm (From Relay to 5 Pin Daisy Chain.
Backup Alarm (From Relay to 5 Pin Daisy Chain. Backup Alarm plugs in)
Design 283
Backup Alarm (Relay to 5 Pin 08TKC Tailboard to
Alarm)
xvBackup Alarm (Relay to 5 Pin 08TKC Tailboard to Alarm) Design 284
Alarm) 0008TKC
Backup Alarm (Relay to 5 Pin 08TKC Tailboard to Alarm) 0008TKC Design 285
Alarm) 0008TKJ
Backup Alarm (Relay to 5 Pin 08TKC Tailboard to Alarm) 0008TKJ Design 286
Backup Alarm (Relay to 5 Pin 08TKC Tailboard. Alarm
Plugs In)
Backup Alarm (Relay to 5 Pin 08TKC Tailboard. Alarm Plugs In) Design 287
Plugs In) 1
Backup Alarm (Relay to 5 Pin 08TKC Tailboard. Alarm Plugs In) 1 Design 288
Backup Alarm (Relay to 6 Pin Tailboard. Backup
Alarm Plugs in)
Backup Alarm (Relay to 6 Pin Tailboard. Backup Alarm Plugs in) Design 290
Backup Alarm (Relay to 6 Pin 08TKJ Tailboard to
Alarm)
Backup Alarm (Relay to 6 Pin 08TKJ Tailboard to Alarm) Design 291
Alarm) With 0008WDG
Backup Alarm (Relay to 6 Pin 08TKJ Tailboard to Alarm) With 0008WDG
Design 292
Alarm) 0008TKJ
Backup Alarm (Relay to 6 Pin 08TKJ Tailboard to Alarm) 0008TKJ Design 293
Backup Alarm (08THB & W/ 08NAA)
Backup Alarm (08THB & W/ 08NAA) Design 294
Backup Alarm (08WDG & W/ 08NAA)
Backup Alarm (08WDG & W/ 08NAA) Design 295
Backup Lights Dual Daisy Reverse Light Eaton
Manual Trans
Backup Lights Dual Daisy Reverse Light Eaton Manual Trans Design 296
Backup Lights Dual Daisy with extension Eaton With
Manual Trans
Backup Lights Dual Daisy with extension Eaton With Manual Trans Design 297
Backup Lights Single Reverse Light With Eaton
Manual Trans
Backup Lights Single Reverse Light With Eaton Manual Trans Design 299
Backup Lights (Dual Reverse Light) Eaton/Manual
Trans
Backup Lights (Dual Reverse Light) Eaton/Manual Trans Design 300
xviBackup Light Dual Daisy Reverse With Allison
Backup Light Dual Daisy Reverse With Allison Design 301
Backup Light Single Reverse Light With Allison
Backup Light Single Reverse Light With Allison Design 302
Back of Cab Aux Work Light
Back of Cab Aux Work Light Design 303
Back of Cab Aux Work Light 2 blunt cuts
Back of Cab Aux Work Light 2 blunt cuts Design 304
Back of Cab Aux Work Light (2 blunt cuts)
Back of Cab Aux Work Light (2 blunt cuts) Design 305
Back of Cab Aux Work Light (2 blunt cuts) With Cab
0016030
Back of Cab Aux Work Light (2 blunt cuts) With Cab 0016030 Design 306
Back Up Lights Reverse With Less Power Module
Back Up Lights Reverse With Less Power Module With Eaton Manual Trans
Design 307
Battery Disconnect
Battery Disconnect Design 308
Battery Grid 1 (Non-Loadshed)
Battery Grid 1 (Non-Loadshed) Design 309
Battery Grid 2 (Loadshed)
Battery Grid 2 (Loadshed) Design 311
Battery Grid 3 (Non-Loadshed)
Battery Grid 3 (Non-Loadshed) Design 312
Beacon Strobe Light With 2 Blunt Cuts
Beacon Strobe Light With 2 Blunt Cuts Design 313
Beacon & Strobe Light - 2 Lamps Hardwired Switch
Beacon & Strobe Light - 2 Lamps Hardwired Switch Design 315
Body Builder Aux Power
Body Builder Aux Power Design 317
Body Builder Fuse Panel
Body Builder Fuse Panel Design 318
Body Builder Lighting - InCab Automatic
Body Builder Lighting - InCab Automatic Design 319
Body Builder Lighting - In Cab Manual
Body Builder Lighting - In Cab Manual Design 320
Body Builder Lighting - 8HAA Blunt Cut
Body Builder Lighting - 8HAA Blunt Cut Design 321
Body Builder Prewire (8 Wire Firewall Pass through)
Body Builder Prewire (8 Wire Firewall Pass through) Design 322
xviiBody Builder - Altec (N/BB & W/Manual XMSN & W/
INTL Engine)
Body Builder - Altec (N/BB & W/Manual XMSN & W/ INTL Engine) Design 323
CUMMINS Engine)
Body Builder - Altec (N/BB & W/3K4K Trans & W/ CUMMINS Engine) Design 325
CUMMINS Engine)
Body Builder - Altec (W/BB & W/Manual Trans & W/ CUMMINS Engine)
Design 327
CUMMINS Engine)
Body Builder - Altec (W/BB & W/3K4K Trans & W/ CUMMINS Engine) Design 332
Body Control Module
Body Control Module Design 337
Body Extra J1939 With eLam & RPM
Body Extra J1939 With eLam & RPM Design 342
Body Standard J1939
Body Standard J1939 Design 343
Cab Dome Light With Classic Trim
Cab Dome Light With Classic Trim Design 344
Cab Dome Light With Combo in Diamond Trim
Cab Dome Light With Combo in Diamond Trim Design 345
Cab Dome Light - Sleeper Cab
Cab Dome Light - Sleeper Cab Design 346
Cab Standard J1939 (All Cabs)
Cab Standard J1939 (All Cabs) Design 347
CB Radio Power Only
CB Radio Power Only Design 348
Center Chassis Grounds
Center Chassis Grounds Design 349
Center Chassis Ground Splice Packs
Center Chassis Ground Splice Packs Design 350
Center Chassis ZVR Splice Pack
Center Chassis ZVR Splice Pack Design 352
Chassis PDM
Chassis PDM Design 353
City Horn 10PIN ClockSpring Without RKA
City Horn 10PIN ClockSpring Without RKA Design 354
City Horn 10PIN ClockSpring With RKA
City Horn 10PIN ClockSpring With RKA Design 355
xviiiCity Horn 4PIN ClockSpring Without RKA
City Horn 4PIN ClockSpring Without RKA Design 356
City Horn 4PIN ClockSpring With RKA
City Horn 4PIN ClockSpring With RKA Design 357
Clearance and Identification Lights Without
SUNSHADE AMBER LENS
Clearance and Identification Lights Without SUNSHADE AMBER LENS
Design 358
Clearance and Identification Lights With SUNSHADE
AMBER LENS
Clearance and Identification Lights With SUNSHADE AMBER LENS Design 359
Clutch Monitoring (High and Low Switch to BCM)
Clutch Monitoring (High and Low Switch to BCM) Design 360
Compressed Air Supply (Primary and Secondary
Gauge)
Compressed Air Supply (Primary and Secondary Gauge) Design 361
Convenience Grid 2 (Loadshed)
Convenience Grid 2 (Loadshed) Design 362
Courtesy Step Lighting (2 Door)
Courtesy Step Lighting (2 Door) Design 363
Crank Inhibit (W/ Hood Switch)
Crank Inhibit (W/ Hood Switch) Design 364
Cruise Control (Horizon W/ One Telltale, 10 Pin)
Cruise Control (Horizon W/ One Telltale, 10 Pin) Design 365
Cruise Control (Horizon W/ One Telltale, 4 Pin)
Cruise Control (Horizon W/ One Telltale, 4 Pin) Design 366
DC/AC Inverter
DC/AC Inverter Design 367
DC/AC Inverter (with switch control)
DC/AC Inverter (with switch control) Design 368
DC/AC Inverter (1800 Watts)
DC/AC Inverter (1800 Watts) Design 369
Diagnositic 9-pin Connector
Diagnositic 9-pin Connector Design 370
Directional Signal Turn SetBack Axle With Headlights
Directional Signal Turn SetBack Axle With Headlights Design 371
And Wtih Plowlights
Directional Signal Turn SetBack Axle With Headlights And Wtih Plowlights
Design 372
Directional Signal Turn SetForward Axle With
Headlights
xixDirectional Signal Turn SetForward Axle With Headlights Design 373
Headlights With Plowlights
Directional Signal Turn SetForward Axle With Headlights With Plowlights
Design 374
DLB - I/O Expansion
DLB - I/O Expansion Design 375
DLB - Remote Power Modules (1 RPM w/ SW Pack)
DLB - Remote Power Modules (1 RPM w/ SW Pack) Design 376
DLB - Remote Power Modules (3 RPM w/SW Pack(s)
DLB - Remote Power Modules (3 RPM w/SW Pack(s) Design 377
DLB - Remote Power Module (1 RPM Blunt Cut)
DLB - Remote Power Module (1 RPM Blunt Cut) Design 378
DLB - Remote Power Module (2 RPM w/SW Pack(s)
DLB - Remote Power Module (2 RPM w/SW Pack(s) Design 379
DLB - Remote Power Module (3 RPM n/SW Pack(s)
DLB - Remote Power Module (3 RPM n/SW Pack(s) Design 380
Door Ajar Reminder (Entry/Exit)
Door Ajar Reminder (Entry/Exit) Design 381
Driver Controlled Locking Differential (Meritor - 2
Driver Controlled Locking Differential (Meritor - 2 Control - 2 Feedback - FR&RR)
Design 382
Dual Auxiliary Power with Interlock
Dual Auxiliary Power with Interlock Design 385
End of Frame One Aux Work Light (CONN) - CUST
FURNISHD
End of Frame One Aux Work Light (CONN) - CUST FURNISHD Design 386
Engine Electrical I/O (A26 Interface Connector)
Engine Electrical I/O (A26 Interface Connector) Design 387
Engine Electrical I/O (N13 Interface Connector)
Engine Electrical I/O (N13 Interface Connector) Design 389
Engine Idle Increment/Decrement (Steering Wheel
Switch - 10 Pin)
Engine Idle Increment/Decrement (Steering Wheel Switch - 10 Pin) Design 390
Switch - 4 Pin)
Engine Idle Increment/Decrement (Steering Wheel Switch - 4 Pin) Design 391
Engine Proprietary J1939
Engine Proprietary J1939 Design 392
Engine Speed Control (PTO) W/ 10-pin
Engine Speed Control (PTO) W/ 10-pin Design 393
xxEngine Speed Control(PTO) 4-pin
Engine Speed Control(PTO) 4-pin Design 394
Fan - Sleeper/Bunk
Fan - Sleeper/Bunk Design 395
Floor/Search Lighting (Sleeper 1 Light)
Floor/Search Lighting (Sleeper 1 Light) Design 397
Floor/Search Lighting (Sleeper 3 Lights)
Floor/Search Lighting (Sleeper 3 Lights) Design 398
Floor/Search Lights (DayCab)
Floor/Search Lights (DayCab) Design 399
Forward Auxiliary Power Source - 1 APO
Forward Auxiliary Power Source - 1 APO Design 400
Forward Auxiliary Power Source - 2 APO
Forward Auxiliary Power Source - 2 APO Design 401
Forward Auxiliary Power Source - 3 APO
Forward Auxiliary Power Source - 3 APO Design 402
Frame Grounds
Frame Grounds Design 403
Front Chassis Grounds
Front Chassis Grounds Design 404
Front Chassis Ground Splice Packs
Front Chassis Ground Splice Packs Design 405
Fusion Proprietary J1939 With Cab 0016AUM And
0016AUN
Fusion Proprietary J1939 With Cab 0016AUM And 0016AUN Design 406
Fusion Proprietary J1939 With Cab 0016030 And
0016AUS
Fusion Proprietary J1939 With Cab 0016030 And 0016AUS Design 407
Fusion 3.0 Proprietary J1939
Fusion 3.0 Proprietary J1939 Design 408
Grid Management (CA2 W/Load Shed, Conventional
Cab)
Grid Management (CA2 W/Load Shed, Conventional Cab) Design 409
Grid Management (CA2 W/Load Shed, Sleeper Cab)
Grid Management (CA2 W/Load Shed, Sleeper Cab) Design 410
Grid Management (CA2, N/Load Shed, Conventional
Cab)
Grid Management (CA2, N/Load Shed, Conventional Cab) Design 411
Hazard Warning
Hazard Warning Design 412
Headlights SetBack Axle
xxiHeadlights SetBack Axle Design 413
Headlights SetForward Axle
Headlights SetForward Axle Design 414
Headlights SetForward Axle With Plowlights
Headlights SetForward Axle With Plowlights Design 415
Headlight Interrupt
Headlight Interrupt Design 416
Heated Mirrors Door Pod Actuated Cab and Hood
Mounted Right Side Only
Heated Mirrors Door Pod Actuated Cab and Hood Mounted Right Side Only
Design 417
Heated Mirrors Door Pod Actuated Cab Mounted
Heated Mirrors Door Pod Actuated Cab Mounted Design 418
HMI Standard J1939
HMI Standard J1939 Design 419
HX520 - Modesty Lighting With Sleeper Cab 2 Turn
and Marker 8 Marker
HX520 - Modesty Lighting With Sleeper Cab 2 Turn and Marker 8 Marker
Design 420
HX520 - Modesty Lighting With Sleeper Cab 4 Turn
and Marker 12 Marker
HX520 - Modesty Lighting With Sleeper Cab 4 Turn and Marker 12 Marker
Design 423
and Marker 16 Marker
HX520 - Modesty Lighting With Sleeper Cab 4 Turn and Marker 16 Marker
Design 426
HX620 - Modesty Lighting With Day Cab 2 Turn and
Marker
HX620 - Modesty Lighting With Day Cab 2 Turn and Marker Design 429
Marker 6 Marker
HX620 - Modesty Lighting With Day Cab 2 Turn and Marker 6 Marker Design 430
HX620 - Modesty Lighting With Sleeper Cab 4 Turn
and Marker 14 Marker
HX620 - Modesty Lighting With Sleeper Cab 4 Turn and Marker 14 Marker
Design 431
Instrument Cluster
Instrument Cluster Design 434
Instrument Cluster - Request and Status
Instrument Cluster - Request and Status Design 435
Interior Task Lighting (Map Light) (Separate map light
from cab dome)
xxiiInterior Task Lighting (Map Light) (Separate map light from cab dome) Design 436
Interior Task Lights (Map) (Cab Dome / Map Combo)
Interior Task Lights (Map) (Cab Dome / Map Combo) Design 437
In Cab Battery Box Battery Cables
In Cab Battery Box Battery Cables Design 438
IP Grounds
IP Grounds Design 439
IP Ground Splice Packs
IP Ground Splice Packs Design 440
IP Panel Dimmer Splice Packs
IP Panel Dimmer Splice Packs Design 442
IP Underhood PDM
IP Underhood PDM Design 443
License Plate Light LED BOX LAMP Daisy Chain Tail
Light
License Plate Light LED BOX LAMP Daisy Chain Tail Light Design 444
License Plate Light LED BOX LAMP Tail Light
License Plate Light LED BOX LAMP Tail Light Design 445
License Plate Light Tail Light Single Assembly
License Plate Light Tail Light Single Assembly Design 446
License Plate Light Tail Light Single Assembly With
Less Power Module
License Plate Light Tail Light Single Assembly With Less Power Module
Design 447
License Plate Light (LED BOX LAMP Daisy Chain Tail
Light with extension)
License Plate Light (LED BOX LAMP Daisy Chain Tail Light with extension)
Design 448
Lighting Control Module
Lighting Control Module Design 449
Lighting Sleeper Dome
Lighting Sleeper Dome Design 450
Lighting Splice Packs
Lighting Splice Packs Design 451
Lighting - Cabinet Lights
Lighting - Cabinet Lights Design 452
Luggage Compartment Lights - WithOut No Idle HVAC
Luggage Compartment Lights - WithOut No Idle HVAC Design 453
Luggage Compartment Lights - With No Idle HVAC
Luggage Compartment Lights - With No Idle HVAC Design 454
Main Cab Ground
Main Cab Ground Design 455
xxiiiMarker Lighting SetBack Axle
Marker Lighting SetBack Axle Design 456
Marker Lighting SetBack Axle With Guide Posts
Marker Lighting SetBack Axle With Guide Posts Design 457
Marker Lighting SetBack Axle With Plowlight
Marker Lighting SetBack Axle With Plowlight Design 458
Marker Lighting SetBack Axle With Plowlight And
With Guide Posts
Marker Lighting SetBack Axle With Plowlight And With Guide Posts Design 459
Marker Lighting SetForward Axle
Marker Lighting SetForward Axle Design 460
Marker Lighting SetForward Axle With Guide Posts
Marker Lighting SetForward Axle With Guide Posts Design 461
Marker Lighting SetForward Axle With Plowlight
Marker Lighting SetForward Axle With Plowlight Design 462
Marker Lighting SetForward Axle With Plowlight And With Guide Posts
Marker Lighting SetForward Axle With Plowlight And With Guide Posts Design463
Mirrors Power 2 Door Pods
Mirrors Power 2 Door Pods Design 464
Mirrors (Heated) With 2 Cab and 1 Hood Mounted
Right Side Only
Mirrors (Heated) With 2 Cab and 1 Hood Mounted Right Side Only Design 465
Mirrors (Heated) With 2 Cab Mirrors
Mirrors (Heated) With 2 Cab Mirrors Design 466
Mirror Lighting Turns without Door Pods, Relay
Control
Mirror Lighting Turns without Door Pods, Relay Control Design 467
Mirror Lighting Turns with Door Pods, Relay Control
Mirror Lighting Turns with Door Pods, Relay Control Design 468
Mirror Lighting (Side Marker without Door Pods)
Mirror Lighting (Side Marker without Door Pods) Design 469
Mirror Lighting (Side Marker with Door Pods)
Mirror Lighting (Side Marker with Door Pods) Design 470
Modesty Lighting With Sleeper Design 471
10 Marker
Modesty Lighting With Sleeper Cab 4 Turn and Marker 10 Marker Design 472
Modesty Lighting With 2 Turn and Marker
Modesty Lighting With 2 Turn and Marker Design 475
xxivModesty Lighting With 2 Turn and Marker 2
Modesty Lighting With 2 Turn and Marker 2 Design 476
Modesty Lighting W/ Sleeper
Modesty Lighting W/ Sleeper Design 477
No Idle Voltage Sense
No Idle Voltage Sense Design 478
Operating Grid 1 (Non-Loadshed)
Operating Grid 1 (Non-Loadshed) Design 479
Operating Grid 2 (Loadshed)
Operating Grid 2 (Loadshed) Design 481
Operator Input (Key Switch)
Operator Input (Key Switch) Design 482
Park Lights With Marker Interrupt With 10pin
ClockSpring
Park Lights With Marker Interrupt With 10pin ClockSpring Design 483
Park Lights With Marker Interrupt 4 Pin Clockspring
Park Lights With Marker Interrupt 4 Pin Clockspring Design 484
Powertrain Aftertreatment PDM
Powertrain Aftertreatment PDM Design 485
Powertrain Standard J1939
Powertrain Standard J1939 Design 486
Powertrain Standard J1939 W/Fusion
Powertrain Standard J1939 W/Fusion Design 487
Power Door Locks (2-Door)
Power Door Locks (2-Door) Design 488
Power Windows (2-Door)
Power Windows (2-Door) Design 489
Prewire Front Fog Lights
Prewire Front Fog Lights Design 490
Radio
Radio Design 491
Radio With Bluetooth
Radio With Bluetooth Design 492
Radio With Bluetooth With Steering Wheel Pod & With
RSA
Radio With Bluetooth With Steering Wheel Pod & With RSA Design 493
Radio With Bluetooth & With Steering Wheel Pod
Radio With Bluetooth & With Steering Wheel Pod Design 494
Radio With Steering Wheel Pod
Radio With Steering Wheel Pod Design 495
Radio With Steering Wheel Pod & With RSA
Radio With Steering Wheel Pod & With RSA Design 496
xxvRear Chassis Ground Splice Packs
Rear Chassis Ground Splice Packs Design 497
Rear Interior Dimming (Accent Light)
Rear Interior Dimming (Accent Light) Design 498
Rear Lights Stop Daisy Chain With Extension Harness
Rear Lights Stop Daisy Chain With Extension Harness Design 499
Rear Lights Stop With Daisy Chain Not With Extension
Harness
Rear Lights Stop With Daisy Chain Not With Extension Harness Design 500
Rear Lights Stop - Dual Taillight Assembly
Rear Lights Stop - Dual Taillight Assembly Design 501
Rear Lights Stop - Single Taillight Assembly
Rear Lights Stop - Single Taillight Assembly Design 502
Rear Lights Stop - Single Taillight Assembly Jumper
harness
Rear Lights Stop - Single Taillight Assembly Jumper harness Design 503
Rear Light Tail Light With Daisy Chain pair of Box
Lamps
Rear Light Tail Light With Daisy Chain pair of Box Lamps Design 504
Rear Light Tail Light With Less Power Module
Rear Light Tail Light With Less Power Module Design 505
Rear Light Tail Light With 6 pin connector
Rear Light Tail Light With 6 pin connector Design 506
Rear Light With LED Box Lamp Tail Light
Rear Light With LED Box Lamp Tail Light Design 507
Rear Reading Lighting (Lower Bunk)
Rear Reading Lighting (Lower Bunk) Design 508
Rear Tail Light With Daisy Chain with extension
Rear Tail Light With Daisy Chain with extension Design 509
Refrigerator (Power and Ground Only)
Refrigerator (Power and Ground Only) Design 510
Refrigerator (Switch Control)
Refrigerator (Switch Control) Design 512
Remote Keyless Access
Remote Keyless Access Design 513
Remote Power Modules (2 RPM Blunt Cuts)
Remote Power Modules (2 RPM Blunt Cuts) Design 514
Remote Power Module Features (Gate Open and Rear
Alert W/ Auto Trans)
Remote Power Module Features (Gate Open and Rear Alert W/ Auto Trans)
Design 516
xxviRemote Power Module Features (Gate Open and Rear
Alert W/ Manual and Ulltrashift+)
Remote Power Module Features (Gate Open and Rear Alert W/ Manual and
Ulltrashift+) Design 517
Remote Start/Stop
Remote Start/Stop Design 519
Remote Start/Stop w/ Emergency Pump
Remote Start/Stop w/ Emergency Pump Design 520
Seatbelt Reminder (Warning)(Driver only)
Seatbelt Reminder (Warning)(Driver only) Design 521
Seatbelt Reminder (Warning)(Driver & Passenger in
parallel)
Seatbelt Reminder (Warning)(Driver & Passenger in parallel) Design 522
Seats (RollTek) Driver and Passenger (Hard Wired)
Seats (RollTek) Driver and Passenger (Hard Wired) Design 523
Seats (RollTek) Driver's Seat Only (Hard Wired) -
Leather
Seats (RollTek) Driver's Seat Only (Hard Wired) - Leather Design 524
Mordura
Seats (RollTek) Driver's Seat Only (Hard Wired) - Mordura Design 525
Seats (RollTek) Driver's Seat Only (Hard Wired) - Vinyl
Seats (RollTek) Driver's Seat Only (Hard Wired) - Vinyl Design 526
Seats - Climate Controlled (Drivers Heated Seat)
Seats - Climate Controlled (Drivers Heated Seat) Design 527
Seats - Climate Controlled (Driver and Passenger
Heated Seat)
Seats - Climate Controlled (Driver and Passenger Heated Seat) Design 528
Sleeper Battery Grid 4 (Loadshed)
Sleeper Battery Grid 4 (Loadshed) Design 529
Sleeper Convenience Grid 1 (Non-Loadshed)
Sleeper Convenience Grid 1 (Non-Loadshed) Design 530
Sleeper Grounds
Sleeper Grounds Design 531
Sleeper Ground Splice Packs
Sleeper Ground Splice Packs Design 532
Speakers W/Amp & N/QC
Speakers W/Amp & N/QC Design 533
Speakers:Four Speakers & N/QC
Speakers:Four Speakers & N/QC Design 535
Starting Aid (Ether Start)
Starting Aid (Ether Start) Design 537
xxviiSwitch Packs
Switch Packs Design 538
Telematics (Aftermarket W/ TMC Connector)
Telematics (Aftermarket W/ TMC Connector) Design 539
& W/ TCM)
Transfer Case (NAMCO PowerTower W/ INTL Engines & W/ TCM) Design 541
Transmission Power Take Off (Active Low Feedback)
Transmission Power Take Off (Active Low Feedback) Design 542
Transmission Power Take Off (60AKG)
Transmission Power Take Off (60AKG) Design 543
Transmission (Allison 4K)
Transmission (Allison 4K) Design 544
Ultrashift+ and FAS
Ultrashift+ and FAS Design 545
vEES-SE-L-1012-03-06_WiringDesign
vEES-SE-L-1012-03-06_WiringDesign Design 546
STS)(Horizon)
Vehicle Acceleration (w/ Two PWR, Two GND, & Two STS)(Horizon) Design 547
Vehicle Data Recorder With Display, 2 front seats
Vehicle Data Recorder With Display, 2 front seats Design 548
Vehicle Data Recorder With Display, 3 front seats
Vehicle Data Recorder With Display, 3 front seats Design 551
Vehicle Data Recorder (N/Display, 2 front seats)
Vehicle Data Recorder (N/Display, 2 front seats) Design 554
Vehicle Data Recorder (N/VDR, N/Display, 2 front
seats)
Vehicle Data Recorder (N/VDR, N/Display, 2 front seats) Design 557
Vehicle Data Recorder (N/VDR, N/ Display, 3 seats)
Vehicle Data Recorder (N/VDR, N/ Display, 3 seats) Design 559
Vehicle Data Recorder (N/ Display, 3 front seats)
Vehicle Data Recorder (N/ Display, 3 front seats) Design 561
Vehicle Speedometer System (VSS wired to VIC) Design 564
Windshield Washer Pump And Low Fluid Sensor
Windshield Washer Pump And Low Fluid Sensor Design 565
Windshield Wipers Cruise Disable With Wipers ON
Windshield Wipers Cruise Disable With Wipers ON Design 566
Windshield Wipers Park Brake With Wiper
Windshield Wipers Park Brake With Wiper Design 567
xxviiiWindshield Wipers Standard
Windshield Wipers Standard Design 568
Windshield Wipers With Cruise Disable And Park
Brake With Wipers ON
Windshield Wipers With Cruise Disable And Park Brake With Wipers ON
Design 569
Work Lights 4 LED Bulbs With Backup Manual
Work Lights 4 LED Bulbs With Backup Manual Design 570
Work Lights - 1 Bulb With Backup Auto
Work Lights - 1 Bulb With Backup Auto Design 571
Work Lights - 1 Bulb With Backup Manual
Work Lights - 1 Bulb With Backup Manual Design 572
Work Lights - 1 Bulb With Backup With RKE Manual
Work Lights - 1 Bulb With Backup With RKE Manual Design 573
Work Lights - 1 Bulb With Backup Wtih RKE Auto
Work Lights - 1 Bulb With Backup Wtih RKE Auto Design 574
Work Lights - 2 Bulbs With Backup Auto
Work Lights - 2 Bulbs With Backup Auto Design 575
Work Lights - 2 Bulbs With Backup Manual - DayCab
Work Lights - 2 Bulbs With Backup Manual - DayCab Design 576
Work Lights - 2 Bulbs With Backup With RKE Auto
Work Lights - 2 Bulbs With Backup With RKE Auto Design 577
Work Lights - 2 Bulbs With Backup With RKE Manual -
DayCab
Work Lights - 2 Bulbs With Backup With RKE Manual - DayCab Design 578
Work Lights - 2 Bulbs With Backup (Manual)
Work Lights - 2 Bulbs With Backup (Manual) Design 579
Work Lights - 4 LED Bulbs With Backup With RKE
Manual
Work Lights - 4 LED Bulbs With Backup With RKE Manual Design 580
Work Lights- 2 Bulbs With Backup With RKE Manual
Work Lights- 2 Bulbs With Backup With RKE Manual Design 581
WORK LIGHT With Backup With RKE 2 Bulbs
Automatic Transmission
WORK LIGHT With Backup With RKE 2 Bulbs Automatic Transmission
Design 582
Automatic Transmission 2
WORK LIGHT With Backup With RKE 2 Bulbs Automatic Transmission 2
Design 583
Work Light With BackUP 2 Bulbs Auto Trans With
DayCab
Work Light With BackUP 2 Bulbs Auto Trans With DayCab Design 584
xxixWork Light With Backup 4 LED Automatic
Work Light With Backup 4 LED Automatic Transmission Design 585
WORK LIGHT With RKE 1 BULB
WORK LIGHT With RKE 1 BULB Design 586
Work Light With RKE 2 Bulbs DayCab
Work Light With RKE 2 Bulbs DayCab Design 587
Work Light With RKE 4 Led BulbSleeper
Work Light With RKE 4 Led BulbSleeper Design 588
Work Light With RKE 4 LED Light Bulbs Sleeper
Work Light With RKE 4 LED Light Bulbs Sleeper Design 589
Work light W RKE 2 Bulbs
Work light W RKE 2 Bulbs Design 590
WORK LIGHT 1 BULB
WORK LIGHT 1 BULB Design 591
Work light 2 Bulbs
Work light 2 Bulbs Design 592
WORK LIGHT 2 Bulbs DayCab
WORK LIGHT 2 Bulbs DayCab Design 593
X15 Endurant Manual Transmission - Transmission
Auto, AMT Trans)
X15 Endurant Manual Transmission - Transmission Power Take Off (Dual PTO
W/ 42 Parameters & W/ Auto, AMT Trans) Design 594
Manual Trans)
W/ 42 Parameters & W/ Manual Trans) Design 595
Auto, AMT Trans)
X15 Endurant Manual Transmission - Transmission Power Take Off (Single PTO
W/42 Parameters & W/ Auto, AMT Trans) Design 596
X15 Endurant Transmission - Starter Interlocks
X15 Endurant Transmission - Starter Interlocks (Service Brake Interlock)
Design 597
X15 Endurant Transmission - Starter Interlock (BCM
X15 Endurant Transmission - Starter Interlock (BCM LSD Controlled w/ Relay &
N/ Neutral Switch) Design 598
xxxX15 Endurant Transmission - Starter Interlock (BCM
Relay)_EATON XMSN Design 599
X15 Endurant Transmission - Transmission Power
Trans)
X15 Endurant Transmission - Transmission Power Take Off (Dual PTO W/ 42
Parameters & W/ Auto, AMT Trans) Design 600
Trans)
Parameters & W/ Manual Trans) Design 601
AMT Trans)
X15 Endurant Transmission - Transmission Power Take Off (Single PTO W/42
Parameters & W/ Auto, AMT Trans) Design 602
X15 Endurant Transmission - Transmission Shifter
X15 Endurant Transmission - Transmission Shifter (Dual Shifter with primary
being stalk) Design 603
X15 Endurant Transmission - Transmission Shifter (Universal Stalk Shifter -
Allison) Design 604
X15 Engine - Cranking (Starter) (BCM Controlled & N/
X15 Engine - Cranking (Starter) (BCM Controlled & N/ Wired Thermal OverCrank) Design 605
X15 Engine - Transmission Retarder (4K with
Multiplex)
X15 Engine - Transmission Retarder (4K with Multiplex) Design 606
X15 Engine - Transmission Retarder (4700 with
Multiplex)
X15 Engine - Transmission Retarder (4700 with Multiplex) Design 607
X15 Ultrashift Transmission - Starter Interlocks
X15 Ultrashift Transmission - Starter Interlocks (Service Brake Interlock)
Design 608
X15 Ultrashift Transmission - Starter Interlock (BCM
X15 Ultrashift Transmission - Starter Interlock (BCM LSD Controlled w/ Relay &
N/ Neutral Switch) Design 609
xxxiX15 Ultrashift Transmission - Starter Interlock (BCM
Relay)_EATON XMSN Design 610
X15 Ultrashift Transmission - Transmission Shifter
X15 Ultrashift Transmission - Transmission Shifter (Dual Shifter with primary
being stalk) Design 611
X15 Ultrashift Transmission - Transmission Shifter (Universal Stalk Shifter -
Allison) Design 612
X15 2017 - Selective Catalytic Reduction (SCR)
X15 2017 - Selective Catalytic Reduction (SCR) Design 613
X15 2017 - Starting Aid (Flame Start N/MD1 ECM)
X15 2017 - Starting Aid (Flame Start N/MD1 ECM) Design 615
X15 2021 - Cooling Fan Control (Fan Override)
X15 2021 - Cooling Fan Control (Fan Override) Design 616
X15 2021 - Cooling Fan Control (No Fan Override)
X15 2021 - Cooling Fan Control (No Fan Override) Design 617
X15 2021 - Selective Catalytic Reduction (SCR)
X15 2021 - Selective Catalytic Reduction (SCR) Design 618
X15 2021 - Transfer Case (NAMCO Powertower W/
Cummins & N/ TCM)
X15 2021 - Transfer Case (NAMCO Powertower W/ Cummins & N/ TCM)
Design 620
Cummins & W/ TCM)
X15 2021 - Transfer Case (NAMCO Powertower W/ Cummins & W/ TCM)
Design 621
X15 3/4000 5GEN Transmission - Transmission Power
Trans)
X15 3/4000 5GEN Transmission - Transmission Power Take Off (Dual PTO W/ 42
Parameters & W/ Auto, AMT Trans) Design 622
Trans)
Parameters & W/ Manual Trans) Design 623
AMT Trans)
X15 3/4000 5GEN Transmission - Transmission Power Take Off (Single PTO
W/42 Parameters & W/ Auto, AMT Trans) Design 624
xxxiiX15 3/4000 5GEN Transmission - Transmission Power
Trans)
X15 3/4000 5GEN Transmission - Transmission Power Take Off (Single PTO W/
42 Parameters & W/ Manl Trans) Design 625
X15 -Backup Alarm (Switch to 5 Pin 08TKC Tailboard
to Alarm)
X15 -Backup Alarm (Switch to 5 Pin 08TKC Tailboard to Alarm) Design 626
to Alarm)_0008TKJ
X15 -Backup Alarm (Switch to 5 Pin 08TKC Tailboard to Alarm)_0008TKJ
Design 627
X15 - Air Filter Flow Restriction Monitoring
X15 - Air Filter Flow Restriction Monitoring Design 628
X15 - Ambient Air Temperature (Mirror Sensor)
X15 - Ambient Air Temperature (Mirror Sensor) Design 629
X15 - Ambient Air Temperature (no Display, Mirror
Sensor)
X15 - Ambient Air Temperature (no Display, Mirror Sensor) Design 630
X15 - Auto Neutral (Allision without Switch and with
X15 - Auto Neutral (Allision without Switch and with Confirmation Telltale)
Design 631
X15 - Auto Neutral (Allison with Multiplex Switch and
X15 - Auto Neutral (Allison with Multiplex Switch and Confirmation Telltale)
Design 632
X15 - Auto Start/Stop Oil Temp Sensor, Auto Trans
X15 - Auto Start/Stop Oil Temp Sensor, Auto Trans Design 633
X15 - Auto Start/Stop Oil Temp Sensor, Manual Trans
X15 - Auto Start/Stop Oil Temp Sensor, Manual Trans Design 634
X15 - Auto Start/Stop with Sleeper Auto Climate, Cab
Temp, with Oil Temp Sensor, Auto Trans
X15 - Auto Start/Stop with Sleeper Auto Climate, Cab Temp, with Oil Temp
Sensor, Auto Trans Design 635
Temp, with Oil Temp Sensor, Manual Trans
Sensor, Manual Trans Design 636
X15 - Backup Alarm (Direct from Reverse Switch to
Alarm Conn)
X15 - Backup Alarm (Direct from Reverse Switch to Alarm Conn) Design 637
Alarm)
X15 - Backup Alarm (Direct from Reverse Switch to Alarm) Design 638
xxxiiiX15 - Backup Alarm (Reverse Switch to 6 Pin 08TKB
X15 - Backup Alarm (Reverse Switch to 6 Pin 08TKB Tailboard. Backup Alarm
Plugs in) Design 639
X15 - Backup Alarm (Reverse Switch to 6 Pin 08TKJ
X15 - Backup Alarm (Reverse Switch to 6 Pin 08TKJ Tailboard to Alarm Direct)
with Daisy Chain Design 640
with 0008TKC Design 641
with 0008TKJ Design 642
X15 - Backup Alarm (Reverse Switch to 6 Pin 08TKJ Tailboard. Backup Alarm
Plugs In) Design 643
X15 - Backup Alarm (Switch to 5 Pin Daisy Chain to
Alarm)_Daisy Chain
X15 - Backup Alarm (Switch to 5 Pin Daisy Chain to Alarm)_Daisy Chain
Design 644
Alarm)_0008TKC
X15 - Backup Alarm (Switch to 5 Pin Daisy Chain to Alarm)_0008TKC Design 645
Alarm)_0008TKJ
X15 - Backup Alarm (Switch to 5 Pin Daisy Chain to Alarm)_0008TKJ Design 646
X15 - Backup Alarm (Switch to 5 Pin 08TKC Tailboard
to Alarm)
X15 - Backup Alarm (Switch to 5 Pin 08TKC Tailboard to Alarm) Design 647
X15 - Backup Light Dual Daisy Reverse With Yukon
Trans
X15 - Backup Light Dual Daisy Reverse With Yukon Trans Design 648
X15 - Backup Light Dual Daisy with extension With
Allison Trans
X15 - Backup Light Dual Daisy with extension With Allison Trans Design 649
X15 - Backup Light Dual Daisy with extension Yukon
X15 - Backup Light Dual Daisy with extension Yukon Transmission Design 650
X15 - Backup Light Dual Reverse Light WithAllison
Trans
X15 - Backup Light Dual Reverse Light WithAllison Trans Design 651
xxxivX15 - Backup Light Dual Reverse Relay Coil Control
by TCM - 6 PIN
X15 - Backup Light Dual Reverse Relay Coil Control by TCM - 6 PIN Design 652
X15 - Backup Light Single Reverse LightWith Less
X15 - Backup Light Single Reverse LightWith Less Power Module With Yukon
Trans Design 653
X15 - Backup Light Single Reverse Light With Less
X15 - Backup Light Single Reverse Light With Less Power Module With Allison
Design 654
X15 - Backup Light Single Reverse Light Yukon
X15 - Backup Light Single Reverse Light Yukon Transmission Design 655
X15 - Battery International (3) 12V (Horizon)
X15 - Battery International (3) 12V (Horizon) Design 656
X15 - Battery International (4) 12V (Horizon)
X15 - Battery International (4) 12V (Horizon) Design 657
8HAE)
X15 - Body Builder Lighting - (BOC, EOF) (8HAB, 8HAE) Design 658
8HAE) (Automatic)
X15 - Body Builder Lighting - (BOC, EOF) (8HAB, 8HAE) (Automatic) Design 659
X15 - Body Builder - Powertrain
X15 - Body Builder - Powertrain Design 660
X15 - Charging System (Delco Remy 28SI Alternator
W/ Remote Sense)
X15 - Charging System (Delco Remy 28SI Alternator W/ Remote Sense)
Design 661
X15 - Charging System (Delco Remy 36SI Alternator
W/ Remote Sense)
X15 - Charging System (Delco Remy 36SI Alternator W/ Remote Sense)
Design 662
X15 - Charging System (Delco Remy 40SI/38SI
X15 - Charging System (Delco Remy 40SI/38SI Alternator W/ Remote Sense)
Design 663
X15 - Charging System (Leece-Neville AVI160 160A W/
Remote Sense)
X15 - Charging System (Leece-Neville AVI160 160A W/ Remote Sense)
Design 664
X15 - Charging System (Leece-Neville AVI160-
xxxvX15 - Charging System (Leece-Neville AVI160-160A/240A N/ Remote Sense)
Design 665
X15 - Charging System (Leece-Neville AVI160-190A/210A/240A Alternator W/
Remote Sense) Design 666
X15 - Charging System (Leece-Neville 320PAH
Alternator)
X15 - Charging System (Leece-Neville 320PAH Alternator) Design 667
X15 - Charging System (Leece-Neville - LN 325A
X15 - Charging System (Leece-Neville - LN 325A Alternator W/ Remote Sense)
Design 668
X15 - Charging System (LH160_LH200)
X15 - Charging System (LH160_LH200) Design 669
X15 - Charging System (LIL165_LIL200 Alternator W/
Remote Sense)
X15 - Charging System (LIL165_LIL200 Alternator W/ Remote Sense) Design 670
X15 - Energy Storage System - International (8
Batteries) 12V
X15 - Energy Storage System - International (8 Batteries) 12V Design 671
X15 - Fuel Heater (Vehicle Powered)(Davco)
X15 - Fuel Heater (Vehicle Powered)(Davco) Design 672
X15 - Fuel Heater (Vehicle Powered)(Racor)
X15 - Fuel Heater (Vehicle Powered)(Racor) Design 673
X15 - Grounds
X15 - Grounds Design 674
X15 - Heating, Ventilation, & Air Conditioning (HVAC)
SW)
X15 - Heating, Ventilation, & Air Conditioning (HVAC) (Auto Control head W/PT
Transducer, N/Low Pressure SW) Design 675
X15 - Heating, Ventilation, & Air Conditioning (HVAC) (Manual, W/PT Transducer,
N/Low Pressure SW) Design 678
X15 - Over The Air Electrical I/O (OnCommand Link /
N2 Module)
X15 - Over The Air Electrical I/O (OnCommand Link / N2 Module) Design 680
X15 - Splice Packs
X15 - Splice Packs Design 682
X15 - Starter Interlock (BCM HSD CTRL W/ Clutch
xxxviX15 - Starter Interlock (BCM HSD CTRL W/ Clutch Switch W/ Neutral Switch)
Design 683
X15 - Transfer Case (NAMCO PowerTower W/ INTL
Engines & N/ TCM)
X15 - Transfer Case (NAMCO PowerTower W/ INTL Engines & N/ TCM)
Design 684
X15 - Transmissions Electrical I/O (Eaton Ultrashift)
X15 - Transmissions Electrical I/O (Eaton Ultrashift) Design 685
X15 - Transmission Electrical I/O (Endurant W/A26 &
N/ Body Builder)
X15 - Transmission Electrical I/O (Endurant W/A26 & N/ Body Builder) Design 686
X15 - Transmission Electrical I/O (Endurant W/ Cummins N/ Body Builder)
Design 687
X15 - Transmission I/O (Allison 4K with Body Builder)
X15 - Transmission I/O (Allison 4K with Body Builder) Design 688
X15 - Transmission I/O (Allison 4700 with Body
Builder)
X15 - Transmission I/O (Allison 4700 with Body Builder) Design 691
X15 - Transmission Oil Temperature (Manual Trans)
X15 - Transmission Oil Temperature (Manual Trans) Design 694
X15 - Transmission Oil Temperature (Manual TransHorizon W/ Aux Gauge)
X15 - Transmission Oil Temperature (Manual Trans-Horizon W/ Aux Gauge)
Design 695
X15 - Transmission Shifter (Eaton Endurant and Eaton
Procision)
X15 - Transmission Shifter (Eaton Endurant and Eaton Procision) Design 696
X15 - Transmission Shifter (Universal Stalk Shifter,
Ultrashift)
X15 - Transmission Shifter (Universal Stalk Shifter, Ultrashift) Design 697
X15 - Vehicle Speedometer System (From Road Speed
SNSR to Blunt Cut)
X15 - Vehicle Speedometer System (From Road Speed SNSR to Blunt Cut)
Design 698
X15 - Vehicle Speedometer System (VSS wired
directly to ECM) Connector5770
X15 - Vehicle Speedometer System (VSS wired directly to ECM) Connector5770
Design 699
directly to ECM) Connector7023
X15 - Vehicle Speedometer System (VSS wired directly to ECM) Connector7023
Design 700
X15 - Water In Fuel (WIF) Davco N/ Heater
xxxviiX15 - Water In Fuel (WIF) Davco N/ Heater Design 701
X15 - Water In Fuel (WIF) Davco W/ Heater
X15 - Water In Fuel (WIF) Davco W/ Heater Design 702
X15 - Water In Fuel (WIF) Racor N/ Heater
X15 - Water In Fuel (WIF) Racor N/ Heater Design 703
Yukon Transmission
Yukon Transmission Design 704
ZVR Splice Pack
ZVR Splice Pack Design 705
ZVR Splice Packs
ZVR Splice Packs Design 706
2017 A26 - Ambient Air Temperature (Mirror Sensor)
2017 A26 - Ambient Air Temperature (Mirror Sensor) Design 707
2017 A26 - Ambient Air Temperature (no Display,
Mirror Sensor)
2017 A26 - Ambient Air Temperature (no Display, Mirror Sensor) Design 708
2017 A26 - Body Builder Lighting - (BOC, EOF) (8HAB,
8HAE)
2017 A26 - Body Builder Lighting - (BOC, EOF) (8HAB, 8HAE) Design 709
2017 A26 - Powertrain Body Builder Connector A26
Engine MX1 With Ultrashift TCM
2017 A26 - Powertrain Body Builder Connector A26 Engine MX1 With Ultrashift
TCM Design 710
2017 A26 - Powertrain Body Builder Connector (A26
Engine MD1 W/Ultrashift TCM)
2017 A26 - Powertrain Body Builder Connector (A26 Engine MD1 W/Ultrashift
TCM) Design 712
Engine MX1 N/Ultrashift TCM)
2017 A26 - Powertrain Body Builder Connector (A26 Engine MX1 N/Ultrashift
TCM) Design 714
(Engine MX1)
2017 A26 - Powertrain Body Builder Connector (Engine MX1) Design 715
2017 A26 - Vehicle Acceleration (w/ Two PWR, Two
2017 A26 - Vehicle Acceleration (w/ Two PWR, Two GND, & Two STS)(Horizon)
Design 719
2017 A26 - Water In Fuel (WIF) Davco N/ Heater
2017 A26 - Water In Fuel (WIF) Davco N/ Heater Design 720
2017 A26 - Water In Fuel (WIF) Davco W/ Heater
2017 A26 - Water In Fuel (WIF) Davco W/ Heater Design 721
xxxviii2017 A26 - Water In Fuel (WIF) Racor N/ Heater
2017 A26 - Water In Fuel (WIF) Racor N/ Heater Design 722
2017 X15 - ECM
2017 X15 - ECM Design 723
2021 A26 - Ambient Air Temperature (Mirror Sensor)
2021 A26 - Ambient Air Temperature (Mirror Sensor) Design 726
2021 A26 - Ambient Air Temperature (no Display,
Mirror Sensor)
2021 A26 - Ambient Air Temperature (no Display, Mirror Sensor) Design 727
2021 A26 - ECM
2021 A26 - ECM Design 728
2021 A26 - Powertrain Body Builder Connector (A26
2021 A26 - Powertrain Body Builder Connector (A26 Engine MD1 W/Ultrashift
TCM) Design 732
2021 A26 - Powertrain Body Builder Connector (A26 Engine MX1 N/Ultrashift
TCM) Design 734
Engine MX1 W/Ultrashift TCM)
2021 A26 - Powertrain Body Builder Connector (A26 Engine MX1 W/Ultrashift
TCM) Design 735
2021 A26 - Service Brake Switch (1 SLS/1 Transducer)
2021 A26 - Service Brake Switch (1 SLS/1 Transducer) Design 737
Transducer/1 RDS to ECM)
2021 A26 - Service Brake Switch (1 SLS/1 Transducer/1 RDS to ECM)
Design 738
2021 A26 - Service Brake Switch (2 SLS/ 1 Transducer/
1 RDS to ECM)
2021 A26 - Service Brake Switch (2 SLS/ 1 Transducer/ 1 RDS to ECM)
Design 739
2021 A26 - Vehicle Acceleration (w/ Two PWR, Two
2021 A26 - Vehicle Acceleration (w/ Two PWR, Two GND, & Two STS)(Horizon)
Design 740
2021 A26 - Vehicle Speedometer System (VSS wired to
VIC)
2021 A26 - Vehicle Speedometer System (VSS wired to VIC) Design 741
2021 A26 - Water In Fuel (WIF) Davco N/ Heater
2021 A26 - Water In Fuel (WIF) Davco N/ Heater Design 742
2021 A26 - Water In Fuel (WIF) Davco W/ Heater
2021 A26 - Water In Fuel (WIF) Davco W/ Heater Design 743
xxxix2021 A26 - Water In Fuel (WIF) Racor N/ Heater
2021 A26 - Water In Fuel (WIF) Racor N/ Heater Design 744
2021 X15 - Body Builder Lighting - (BOC, EOF) (8HAB,
8HAE)
2021 X15 - Body Builder Lighting - (BOC, EOF) (8HAB, 8HAE) Design 745
2021 X15 - Body Builder - Altec (N/BB & W/Manual
XMSN & W/ CUMMINS Engine)
2021 X15 - Body Builder - Altec (N/BB & W/Manual XMSN & W/ CUMMINS
Engine) Design 746
2021 X15 - Coolant Level Monitoring (No CLA Module)
2021 X15 - Coolant Level Monitoring (No CLA Module) Design 748
2-Way Radio
2-Way Radio Design 749
Connectors 752
Part Assembly List
HX_Terminal Part Number 2370
Index 2449
- International DT466,DT570,HT570 Diesel Engine Service Manual
- International DT466E Wiring Schematic
- International 365, 444, 466, 530 Service Manuals
- Navistar Diagnostic Trouble Code Index
- SCANIA 420 DC11 - DC12 Motor
- International 9800 Electrical Schematic
- International Truck DT466E Engine Repair Manual
- International - VT365 Schematic (SPA)
- Scania Manual Transmission GRS900
- International Truck 5000i,9200i,9400i and 9900i Chassis Built Electrical Circuit Diagram
- International Trucks Body Controller Diagnostic Trouble Codes
- International Wiring Diagram
- International Truck CF500 CF600 Service Manual
- Scania Manual Transmission GR 900
- International DT466, DT530 Electronic Diagram
