Momed80
150
35,046
International Truck HX Series Interactive Schematics 00000018837 2025
Brand: International, Navistar
Type of Manual: Interactive Schematics
Model: International HX Series Truck
Built: 01/01/2024 To 12/31/2025
Part Number: 00000018837
Publication Date: 2025
Number of Pages: 3031 Pages
Body Control Module (BCM)
Body Control Module (BCM) Design 1
Body Extra J1939; , W/eLAM & RPM
Body Extra J1939; , W/eLAM & RPM Design 9
Body Standard J1939
Body Standard J1939 Design 10
Cab Standard J1939 (All Cabs)
Cab Standard J1939 (All Cabs) Design 11
Low Speed (125 kbps) J1939
Low Speed (125 kbps) J1939 Design 12
9pin Diagnositic Connector
9pin Diagnositic Connector Design 13
A26/X15 - Engine Proprietary J1939
A26/X15 - Engine Proprietary J1939 Design 14
S13 - Engine Proprietary J1939
S13 - Engine Proprietary J1939 Design 15
Fusion Proprietary J1939 (Day Cab)
Fusion Proprietary J1939 (Day Cab) Design 16
Fusion Proprietary J1939 (Sleeper Cab)
Fusion Proprietary J1939 (Sleeper Cab) Design 18
Fusion 3.0 Proprietary J1939
Fusion 3.0 Proprietary J1939 Design 20
Powertrain Standard J1939
Powertrain Standard J1939 Design 21
Powertrain Standard J1939 N/Fusion (Not with
0008TPU, 0008TRM, 0008TRG )
Powertrain Standard J1939 N/Fusion (Not with 0008TPU, 0008TRM, 0008TRG )
Design 22
Powertrain Standard J1939 W/Fusion (With 0008TPU,
0008TRM, 0008TRG)
Powertrain Standard J1939 W/Fusion (With 0008TPU, 0008TRM, 0008TRG)
Design 23
2017 A26 - Engine Control Module (ECM)
2017 A26 - Engine Control Module (ECM) Design 24
2021 A26 - Engine Control Module (ECM)
2021 A26 - Engine Control Module (ECM) Design 25
2024 S13 - Engine Electrical I/O
2024 S13 - Engine Electrical I/O Design 26
2021 X15 - Engine Control Module (ECM)
2021 X15 - Engine Control Module (ECM) Design 27
2024 X15 - Engine Control Module (ECM)
2024 X15 - Engine Control Module (ECM) Design 28
TABLE OF CONTENTS
iInstrument Cluster (EGC)
Instrument Cluster (EGC) Design 31
Instrument Cluster - Request and Status
Instrument Cluster - Request and Status Design 32
Main Cab Ground
Main Cab Ground Design 33
Center Chassis Grounds
Center Chassis Grounds Design 34
Center Chassis Ground Splice Packs
Center Chassis Ground Splice Packs Design 35
Center Chassis ZVR Splice Pack
Center Chassis ZVR Splice Pack Design 37
2017/2021 A26 - Engine Grounds
2017/2021 A26 - Engine Grounds Design 38
2017/2021 A26 - 5031 & 5032 ZVR Splice Pack
2017/2021 A26 - 5031 & 5032 ZVR Splice Pack Design 39
S13 - Engine Grounds
S13 - Engine Grounds Design 40
S13 - 5035 ZVR Splice Pack
S13 - 5035 ZVR Splice Pack Design 41
2021/2024 X15 - Engine Grounds
2021/2024 X15 - Engine Grounds Design 42
2021/2024 X15 - 5030 & 5033 ZVR Splice Pack
2021/2024 X15 - 5030 & 5033 ZVR Splice Pack Design 43
Frame Grounds
Frame Grounds Design 44
Front Chassis Grounds
Front Chassis Grounds Design 45
Front Chassis Ground Splice Packs
Front Chassis Ground Splice Packs Design 46
IP Grounds
IP Grounds Design 47
IP Ground Splice Packs
IP Ground Splice Packs Design 48
IP ZVR Splice Packs
IP ZVR Splice Packs Design 50
Rear Chassis Ground Splice Packs
Rear Chassis Ground Splice Packs Design 51
Sleeper Grounds
Sleeper Grounds Design 52
TABLE OF CONTENTS
iiSleeper Ground Splice Packs
Sleeper Ground Splice Packs Design 53
LCM (Lighting Control Module)
LCM (Lighting Control Module) Design 54
S13 - Powertrain Interface Module (PIM)
S13 - Powertrain Interface Module (PIM) Design 55
2017/2021 A26 - Aftertreatment PDM
2017/2021 A26 - Aftertreatment PDM Design 56
2021/2024 X15 - Aftertreatment PDM
2021/2024 X15 - Aftertreatment PDM Design 57
A26/X15/S13 - Chassis PDM
A26/X15/S13 - Chassis PDM Design 58
IP Battery Grid 1 (Non-Loadshed)
IP Battery Grid 1 (Non-Loadshed) Design 59
IP Battery Grid 2 (Loadshed)
IP Battery Grid 2 (Loadshed) Design 61
Key Switch Accessory Grid 2 (Loadshed)(W/O TMC)
Key Switch Accessory Grid 2 (Loadshed)(W/O TMC) Design 62
Key Switch Accessory Grid 2 (Loadshed)(W/ TMC)
Key Switch Accessory Grid 2 (Loadshed)(W/ TMC) Design 63
Key Switch Ignition Grid 1 (Non-Loadshed)(W/O TMC)
Key Switch Ignition Grid 1 (Non-Loadshed)(W/O TMC) Design 64
Key Switch Ignition Grid 1 (Non-Loadshed)(W/ TMC)
Key Switch Ignition Grid 1 (Non-Loadshed)(W/ TMC) Design 66
Key Switch Ignition Grid 2 (Loadshed)(W/O TMC)
Key Switch Ignition Grid 2 (Loadshed)(W/O TMC) Design 68
Key Switch Ignition Grid 2 (Loadshed)(W/ TMC)
Key Switch Ignition Grid 2 (Loadshed)(W/ TMC) Design 69
Grid Management (CA2 W/Load Shed, Conventional
Cab)
Grid Management (CA2 W/Load Shed, Conventional Cab) Design 70
Grid Management (CA2 W/Load Shed, Sleeper Cab)
Grid Management (CA2 W/Load Shed, Sleeper Cab) Design 71
Grid Management (CA2, N/Load Shed, Conventional
Cab)
Grid Management (CA2, N/Load Shed, Conventional Cab) Design 72
Center Section N01 Lighting Splice Packs
7140/7141/7142/7143
Center Section N01 Lighting Splice Packs 7140/7141/7142/7143 Design 73
IP Panel Dimmer Splice Packs
IP Panel Dimmer Splice Packs Design 74
TABLE OF CONTENTS
iii2021/2024 X15 - 5V Splice Pack
2021/2024 X15 - 5V Splice Pack Design 75
A26/X15/S13 - Sleeper Accessory Grid 1 (NonLoadshed)
A26/X15/S13 - Sleeper Accessory Grid 1 (Non-Loadshed) Design 76
Sleeper Battery Grid 3 (Non-Loadshed)
Sleeper Battery Grid 3 (Non-Loadshed) Design 77
Sleeper Battery Grid 4 (Loadshed)
Sleeper Battery Grid 4 (Loadshed) Design 78
Junction Box Assembly
Junction Box Assembly Design 79
X15/A26 - Underhood PDM (Day Cab)
X15/A26 - Underhood PDM (Day Cab) Design 80
X15/A26 - Underhood PDM (Sleeper Cab)
X15/A26 - Underhood PDM (Sleeper Cab) Design 81
2024 S13 - Underhood PDM (Day Cab)
2024 S13 - Underhood PDM (Day Cab) Design 82
2024 S13 - Underhood PDM (Sleeper Cab)
2024 S13 - Underhood PDM (Sleeper Cab) Design 83
Air Horn (Highway) w/Hardwired Switch
Air Horn (Highway) w/Hardwired Switch Design 84
Air Solenoids 4-pack (1 pack/4 solenoids)
Air Solenoids 4-pack (1 pack/4 solenoids) Design 85
Air Solenoids 4-pack (2 packs/8 solenoids)
Air Solenoids 4-pack (2 packs/8 solenoids) Design 86
Air Solenoids 4-pack (3 packs/12 solenoids)
Air Solenoids 4-pack (3 packs/12 solenoids) Design 87
Radio
Radio Design 88
Radio W/ Bluetooth
Radio W/ Bluetooth Design 89
Radio W/ Bluetooth W/ Steering Wheel Pod & W/ RSA
Radio W/ Bluetooth W/ Steering Wheel Pod & W/ RSA Design 90
Radio W/ Bluetooth & W/ Steering Wheel Pod
Radio W/ Bluetooth & W/ Steering Wheel Pod Design 91
Radio W/ Steering Wheel Pod
Radio W/ Steering Wheel Pod Design 92
Radio W/ Steering Wheel Pod & W/ RSA
Radio W/ Steering Wheel Pod & W/ RSA Design 93
Speakers W/Amp & N/QC (LS, HRZN, HX)
Speakers W/Amp & N/QC (LS, HRZN, HX) Design 94
TABLE OF CONTENTS
ivSpeakers W/Amp & N/QC (New Amp)
Speakers W/Amp & N/QC (New Amp) Design 96
Speakers: Four Speakers & N/QC
Speakers:Four Speakers & N/QC Design 98
Auxiliary Power Source (Sleeper) - 4 APO, 1 USB
Auxiliary Power Source (Sleeper) - 4 APO, 1 USB Design 100
Auxiliary Power (Banana Plug)
Auxiliary Power (Banana Plug) Design 102
Auxiliary Power (Blunt Cut)
Auxiliary Power (Blunt Cut) Design 103
Auxiliary Power (40A) HSD
Auxiliary Power (40A) HSD Design 104
Auxiliary Roof Power (20A)
Auxiliary Roof Power (20A) Design 105
AUX Power Connector
AUX Power Connector Design 106
Dual Auxiliary Power with Interlock (HV/MV/HX)
Dual Auxiliary Power with Interlock (HV/MV/HX) Design 107
Forward Auxiliary Power Source - 2 APO (W/08XHR)
Forward Auxiliary Power Source - 2 APO (W/08XHR) Design 108
Forward Auxiliary Power Source - 2 APO (W/08XPK)
Forward Auxiliary Power Source - 2 APO (W/08XPK) Design 109
Forward Auxiliary Power Source - 3 APO (W/08XKR)
Forward Auxiliary Power Source - 3 APO (W/08XKR) Design 110
Forward Auxiliary Power Source - 3 APO (W/08XPL)
Forward Auxiliary Power Source - 3 APO (W/08XPL) Design 111
Backup Alarm (Direct from Relay to Alarm Connector)
Backup Alarm (Direct from Relay to Alarm Connector) Design 112
Backup Alarm (Direct from Relay to Alarm)
Backup Alarm (Direct from Relay to Alarm) Design 114
Backup Alarm (Direct from Reverse Switch to Alarm
Conn)
Backup Alarm (Direct from Reverse Switch to Alarm Conn) Design 116
Backup Alarm (Direct from Reverse Switch to Alarm)
Backup Alarm (Direct from Reverse Switch to Alarm) Design 120
Backup Alarm (From Relay to 5 Pin Daisy Chain to
Backup Alarm)
Backup Alarm (From Relay to 5 Pin Daisy Chain to Backup Alarm) Design 122
Backup Alarm, W/ Extension)
TABLE OF CONTENTS
vBackup Alarm (From Relay to 5 Pin Daisy Chain to Backup Alarm, W/ Extension)
Design 123
Backup Alarm (From Relay to 5 Pin Daisy Chain.
Backup Alarm Plugs in)
Backup Alarm (From Relay to 5 Pin Daisy Chain. Backup Alarm Plugs in)
Design 124
Backup Alarm Plugs in, W/ Extension)
Backup Alarm (From Relay to 5 Pin Daisy Chain. Backup Alarm Plugs in, W/
Extension) Design 125
Backup Alarm (Relay to 5 Pin 08TKC Tailboard to
Alarm)
Backup Alarm (Relay to 5 Pin 08TKC Tailboard to Alarm) Design 126
Backup Alarm (Relay to 5 Pin 08TKC Tailboard. Alarm
Plugs In) Option1
Backup Alarm (Relay to 5 Pin 08TKC Tailboard. Alarm Plugs In) Option1
Design 127
Plugs In) Option 2
Backup Alarm (Relay to 5 Pin 08TKC Tailboard. Alarm Plugs In) Option 2
Design 129
Backup Alarm (Relay to 6 Pin Tailboard. Backup
Alarm Plugs in)
Backup Alarm (Relay to 6 Pin Tailboard. Backup Alarm Plugs in) Design 130
Backup Alarm (Relay to 6 Pin 08TKJ Tailboard to
Alarm)
Backup Alarm (Relay to 6 Pin 08TKJ Tailboard to Alarm) Design 131
Backup Alarm (Reverse Switch to 6 Pin 08TKB
Backup Alarm (Reverse Switch to 6 Pin 08TKB Tailboard. Backup Alarm Plugs in)
Design 132
Backup Alarm (Reverse Switch to 6 Pin 08TKJ
Tailboard to Alarm Direct)
Backup Alarm (Reverse Switch to 6 Pin 08TKJ Tailboard to Alarm Direct)
Design 134
Tailboard. Backup Alarm Plugs In)
Backup Alarm (Reverse Switch to 6 Pin 08TKJ Tailboard. Backup Alarm Plugs In)
Design 136
Backup Alarm (Switch to 5 Pin Daisy Chain to Alarm)
Backup Alarm (Switch to 5 Pin Daisy Chain to Alarm) Design 138
Backup Alarm (Switch to 5 Pin Daisy Chain. Backup
Alarm plugs in)
Backup Alarm (Switch to 5 Pin Daisy Chain. Backup Alarm plugs in) Design 140
TABLE OF CONTENTS
viBackup Alarm (Switch to 5 Pin 08TKC Tailboard to
Alarm)
Backup Alarm (Switch to 5 Pin 08TKC Tailboard to Alarm) Design 142
CB Radio Power Only
CB Radio Power Only Design 144
Door Ajar Reminder (Entry/Exit)
Door Ajar Reminder (Entry/Exit) Design 145
Power Door Locks (2-Door)
Power Door Locks (2-Door) Design 146
Heated Mirrors (Door Pod Actuated, Cab and Hood
Mounted Right Side Only)
Heated Mirrors (Door Pod Actuated, Cab and Hood Mounted Right Side Only)
Design 147
Heated Mirrors (Door Pod Actuated, Cab Mounted)
Heated Mirrors (Door Pod Actuated, Cab Mounted) Design 148
Mirrors (Heated) (MUX Switch, 2 Cab and 1 Hood
Mirrors (Heated) (MUX Switch, 2 Cab and 1 Hood Mounted Right Side Only)
Design 149
Mirrors (Heated) (MUX Switch, 2 Cab Mirrors)
Mirrors (Heated) (MUX Switch, 2 Cab Mirrors) Design 150
Mirrors (Power) (2 Door Pods)
Mirrors (Power) (2 Door Pods) Design 151
Mirror Lighting (Side Marker without Door Pods)
Mirror Lighting (Side Marker without Door Pods) Design 152
Mirror Lighting (Side Marker with Door Pods)
Mirror Lighting (Side Marker with Door Pods) Design 153
Mirror Lighting (Turns without Door Pods, Relay
CTRL)
Mirror Lighting (Turns without Door Pods, Relay CTRL) Design 154
Mirror Lighting (Turns with Door Pods, Relay CTRL)
Mirror Lighting (Turns with Door Pods, Relay CTRL) Design 155
Power Windows (2-Door)
Power Windows (2-Door) Design 156
Electric City Horn
Electric City Horn Design 157
Fan - Sleeper/Bunk
Fan - Sleeper/Bunk Design 158
Multiplexed Switch Pack
Multiplexed Switch Pack Design 160
Refrigerator (Power and Ground Only)
Refrigerator (Power and Ground Only) Design 161
TABLE OF CONTENTS
viiRefrigerator (Switch Control)
Refrigerator (Switch Control) Design 163
Remote Keyless Access
Remote Keyless Access Design 164
Telematics (Aftermarket W/ TMC Connector & W/ ACC)
Telematics (Aftermarket W/ TMC Connector & W/ ACC) Design 165
Telematics (Aftermarket W/ TMC Connector)
Telematics (Aftermarket W/ TMC Connector) Design 166
Telematics (Aftermarket W/ 1 TMC Connector)
Telematics (Aftermarket W/ 1 TMC Connector) Design 168
Antenna (Film Antenna, Sleeper, OTAPM, AM/FM, XM
Radio)
Antenna (Film Antenna, Sleeper, OTAPM, AM/FM, XM Radio) Design 169
Antenna (Shark Fin, AM/FM/WB only)
Antenna (Shark Fin, AM/FM/WB only) Design 171
Antenna (Shark Fin, Day Cab, OTAPM, AM/FM, XM
Radio)
Antenna (Shark Fin, Day Cab, OTAPM, AM/FM, XM Radio) Design 172
A26 - Over The Air Electrical I/O (OnCommand Link /
N2 Module W/ Diagnostic Connector) (Day Cab)
A26 - Over The Air Electrical I/O (OnCommand Link / N2 Module W/ Diagnostic
Connector) (Day Cab) Design 173
N2 Module W/ Diagnostic Connector) (Sleeper Cab)
Connector) (Sleeper Cab) Design 174
S13 - Over The Air Electrical I/O (OnCommand Link /
N2 Module N/ Engine Diagnostic Connector) (Day Cab)
S13 - Over The Air Electrical I/O (OnCommand Link / N2 Module N/ Engine
Diagnostic Connector) (Day Cab) Design 175
N2 Module N/ Engine Diagnostic Connector) (Sleeper
Cab)
Diagnostic Connector) (Sleeper Cab) Design 176
N2 Module) (Sleeper Cab)
S13 - Over The Air Electrical I/O (OnCommand Link / N2 Module) (Sleeper Cab)
Design 177
N2 Module)(Day Cab)
S13 - Over The Air Electrical I/O (OnCommand Link / N2 Module)(Day Cab)
Design 178
TABLE OF CONTENTS
viii2021 X15 - Over The Air Electrical I/O (OnCommand
Link / N2 Module / 2017/2021 X15)(Day Cab)
2021 X15 - Over The Air Electrical I/O (OnCommand Link / N2 Module /
2017/2021 X15)(Day Cab) Design 179
Link / N2 Module / 2017/2021 X15)(Sleeper Cab)
2017/2021 X15)(Sleeper Cab) Design 180
2024 X15 - Over The Air Electrical I/O (OnCommand
Link / N2 Module / 2024 X15)(Day Cab)
2024 X15 - Over The Air Electrical I/O (OnCommand Link / N2 Module / 2024
X15)(Day Cab) Design 181
Link / N2 Module / 2024 X15)(Sleeper Cab)
X15)(Sleeper Cab) Design 182
Telematics Peoplenet N/Feeder Data Terminal
System(FDT)(Day Cab)
Telematics Peoplenet N/Feeder Data Terminal System(FDT)(Day Cab)
Design 183
System(FDT)(Sleeper Cab)
Telematics Peoplenet N/Feeder Data Terminal System(FDT)(Sleeper Cab)
Design 184
Steering Wheel Left and Right Pod N/Air Bag
Steering Wheel Left and Right Pod N/Air Bag Design 185
Steering Wheel Left Pod
Steering Wheel Left Pod Design 186
Television Auxiliary Power
Television Auxiliary Power Design 187
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater) Design 188
Tire Pressure (TPMS) (LDL 2.0 - 2 Repeaters)
Tire Pressure (TPMS) (LDL 2.0 - 2 Repeaters) Design 189
Aux Power (USB) - 1 USB
Aux Power (USB) - 1 USB Design 190
Aux Power (USB) - 1 USB A, 1 USB C
Aux Power (USB) - 1 USB A, 1 USB C Design 191
Aux Power (USB) - 2 USB
Aux Power (USB) - 2 USB Design 192
Aux Power (USB) - 2 USB A, 2 USB C
Aux Power (USB) - 2 USB A, 2 USB C Design 194
Aux Power (USB) - 3 USB
Aux Power (USB) - 3 USB Design 196
TABLE OF CONTENTS
ixAux Power (USB) - 3 USB A, 3 USB C
Aux Power (USB) - 3 USB A, 3 USB C Design 198
Aux Power (USB) - 4 USB
Aux Power (USB) - 4 USB Design 200
Aux Power (USB) - 5 USB
Aux Power (USB) - 5 USB Design 202
2-Way Radio
2-Way Radio Design 204
2017 A26 - Selective Catalytic Reduction (SCR)
2017 A26 - Selective Catalytic Reduction (SCR) Design 207
2021 A26 - Selective Catalytic Reduction (SCR)
2021 A26 - Selective Catalytic Reduction (SCR) Design 210
2024 S13 - Selective Catalytic Reduction (SCR)
2024 S13 - Selective Catalytic Reduction (SCR) Design 213
2021 X15 - Selective Catalytic Reduction (SCR)
2021 X15 - Selective Catalytic Reduction (SCR) Design 215
2024 X15 - Selective Catalytic Reduction (SCR)
2024 X15 - Selective Catalytic Reduction (SCR) Design 217
Airbag (Driver Seat and Passenger Seat)
Airbag (Driver Seat and Passenger Seat) Design 220
Airbag (Driver Seat Only)
Airbag (Driver Seat Only) Design 222
Body Builder Aux Power
Body Builder Aux Power Design 223
Body Builder Fuse Panel
Body Builder Fuse Panel Design 224
Body Builder Prewire (8 Wire Firewall Pass through)
Body Builder Prewire (8 Wire Firewall Pass through) Design 225
2017/2021A26 - Body Builder - Altec (N/BB & W/3K4K
Trans & W/ INTL Engine)
2017/2021A26 - Body Builder - Altec (N/BB & W/3K4K Trans & W/ INTL Engine)
Design 226
2017/2021 A26 - Body Builder - Altec (N/BB &
W/Manual XMSN & W/ INTL Engine)
2017/2021 A26 - Body Builder - Altec (N/BB & W/Manual XMSN & W/ INTL
Engine) Design 228
W/Manual XMSN & W/ INTL Engine)(Rev2)
Engine)(Rev2) Design 230
2017/2021 A26 - Body Builder - Altec (W/BB &
W/Manual Trans & W/ INTL Engine)
TABLE OF CONTENTS
x2017/2021 A26 - Body Builder - Altec (W/BB & W/Manual Trans & W/ INTL
Engine) Design 232
W/Manual Trans & W/ INTL Engine)(Rev2)
Engine)(Rev2) Design 237
2017/2021 A26 - Body Builder - Altec (W/BB & W/3K4K
2017/2021 A26 - Body Builder - Altec (W/BB & W/3K4K Trans & W/ INTL Engine)
Design 242
2024 S13 - Body Builder - Altec (N/BB & W/3K4K Trans
& W/ INTL Engine)
2024 S13 - Body Builder - Altec (N/BB & W/3K4K Trans & W/ INTL Engine)
Design 247
2024 S13 - Body Builder - Altec (W/BB & W/Manual
2024 S13 - Body Builder - Altec (W/BB & W/Manual Trans & W/ INTL Engine)
Design 249
2024 S13 - Body Builder - Altec (W/BB & W/3K4K
2024 S13 - Body Builder - Altec (W/BB & W/3K4K Trans & W/ INTL Engine)
Design 254
X15 - Body Builder - Altec (N/BB & W/Manual XMSN &
W/ CUMMINS Engine
X15 - Body Builder - Altec (N/BB & W/Manual XMSN & W/ CUMMINS Engine
Design 259
X15 - Body Builder - Altec (N/BB & W/3K4K Trans & W/
CUMMINS Engine)
X15 - Body Builder - Altec (N/BB & W/3K4K Trans & W/ CUMMINS Engine)
Design 261
X15 - Body Builder - Altec (W/BB & W/Manual Trans &
W/ CUMMINS Engine)
X15 - Body Builder - Altec (W/BB & W/Manual Trans & W/ CUMMINS Engine)
Design 263
X15 - Body Builder - Altec (W/BB & W/3K4K Trans &
W/ CUMMINS Engine)
X15 - Body Builder - Altec (W/BB & W/3K4K Trans & W/ CUMMINS Engine)
Design 268
Cab Body Builder Power Prewire
Cab Body Builder Power Prewire Design 273
DLB - I/O Expansion
DLB - I/O Expansion Design 274
Body Builder Lighting - (BOC, EOF) (8HAB, 8HAE)
(Automatic)
Body Builder Lighting - (BOC, EOF) (8HAB, 8HAE) (Automatic) Design 275
TABLE OF CONTENTS
xiBody Builder Lighting - (BOC, EOF) (8HAB, 8HAE)
(Manual)
Body Builder Lighting - (BOC, EOF) (8HAB, 8HAE) (Manual) Design 277
Body Builder Lighting - (BOC, EOF, In Cab) (8HAB,
8HAE, 8HAU) (Automatic)
Body Builder Lighting - (BOC, EOF, In Cab) (8HAB, 8HAE, 8HAU) (Automatic)
Design 279
8HAE, 8HAU) (Manual)
Body Builder Lighting - (BOC, EOF, In Cab) (8HAB, 8HAE, 8HAU) (Manual)
Design 280
Body Builder Lighting - (8HAA) (Blunt Cut)
Body Builder Lighting - (8HAA) (Blunt Cut) Design 282
A26 - Powertrain Body Builder Connector (A26 Engine
MD1 N/Ultrashift TCM)
A26 - Powertrain Body Builder Connector (A26 Engine MD1 N/Ultrashift TCM)
Design 283
Engine MD1 W/Ultrashift TCM)
A26 - Powertrain Body Builder Connector (A26 Engine MD1 W/Ultrashift TCM)
Design 284
MX1 N/Ultrashift TCM)
A26 - Powertrain Body Builder Connector (A26 Engine MX1 N/Ultrashift TCM)
Design 286
MX1 W/Ultrashift TCM)
A26 - Powertrain Body Builder Connector (A26 Engine MX1 W/Ultrashift TCM)
Design 287
S13 - Powertrain Body Builder Connector (W/ PIM)
S13 - Powertrain Body Builder Connector (W/ PIM) Design 289
A26 - Remote Power Module Features (Gate Open and
Rear Alert W/ Manual and Ulltrashift+)
A26 - Remote Power Module Features (Gate Open and Rear Alert W/ Manual and
Ulltrashift+) Design 291
DLB - Remote Power Modules (3 RPM w/SW Pack(s))
DLB - Remote Power Modules (3 RPM w/SW Pack(s)) Design 292
DLB - Remote Power Module (1 RPM Blunt Cut)
DLB - Remote Power Module (1 RPM Blunt Cut) Design 293
DLB - Remote Power Module (2 RPM w/SW Pack(s))
DLB - Remote Power Module (2 RPM w/SW Pack(s)) Design 294
DLB - Remote Power Module (3 RPM n/SW Pack(s))
DLB - Remote Power Module (3 RPM n/SW Pack(s)) Design 295
Remote Power Modules (2 RPM Blunt Cuts)
Remote Power Modules (2 RPM Blunt Cuts) Design 296
TABLE OF CONTENTS
xii2021/2024 X15 - Remote Power Module Features (Gate
Open and Rear Alert W/ Manual and Ulltrashift+)
2021/2024 X15 - Remote Power Module Features (Gate Open and Rear Alert W/
Manual and Ulltrashift+) Design 298
Remote Start/Stop w/ Emergency Pump (Horizon)
Remote Start/Stop w/ Emergency Pump (Horizon) Design 299
Remote Start/Stop (Horizon)
Remote Start/Stop (Horizon) Design 300
2021 A26 - TMC Connection - Chassis-To-Body
2021 A26 - TMC Connection - Chassis-To-Body Design 301
2021/2024 X15 - TMC Connection - Chassis-To-Body
2021/2024 X15 - TMC Connection - Chassis-To-Body Design 305
2017/2021 A26 - Transmissions Electrical I/O (Eaton
Ultrashift)
2017/2021 A26 - Transmissions Electrical I/O (Eaton Ultrashift) Design 309
2017/2021 A26 - Transmission Electrical I/O (Endurant
W/A26 & N/ Body Builder)
2017/2021 A26 - Transmission Electrical I/O (Endurant W/A26 & N/ Body Builder)
Design 310
W/ Cummins N/ Body Builder)
2017/2021 A26 - Transmission Electrical I/O (Endurant W/ Cummins N/ Body
Builder) Design 311
W/ Cummins W/ Body Builder)
2017/2021 A26 - Transmission Electrical I/O (Endurant W/ Cummins W/ Body
Builder) Design 312
2017/2021 A26 - Transmission I/O (Allison Gen 6 4K W/
Body Builder)
2017/2021 A26 - Transmission I/O (Allison Gen 6 4K W/ Body Builder) Design 313
2017/2021 A26 - Transmission I/O (Allison Gen 6 4700
W/ Body Builder)
2017/2021 A26 - Transmission I/O (Allison Gen 6 4700 W/ Body Builder)
Design 316
W/ Body Builder)A26
2017/2021 A26 - Transmission I/O (Allison Gen 6 4700 W/ Body Builder)A26
Design 319
2017/2021 A26 - Transmission I/O (Allison 4K W/ Body
Builder)
2017/2021 A26 - Transmission I/O (Allison 4K W/ Body Builder) Design 322
2017/2021 A26 - Transmission I/O (Allison 4700 W/
Body Builder)
2017/2021 A26 - Transmission I/O (Allison 4700 W/ Body Builder) Design 325
TABLE OF CONTENTS
xiii2017/2021 A26- Transmission I/O (Allison Gen 6 4K W/
Body Builder)
2017/2021 A26- Transmission I/O (Allison Gen 6 4K W/ Body Builder) Design 328
W/A26 & W/ Body Builder)
2021 A26 - Transmission Electrical I/O (Endurant W/A26 & W/ Body Builder)
Design 331
2021 - A26 - Transmission Electrical I/O (Endurant
2021 - A26 - Transmission Electrical I/O (Endurant W/A26 & W/ Body Builder)
Design 332
S13 - Transmission I/O (Allison Gen 6 4K W/ Body
Builder)
S13 - Transmission I/O (Allison Gen 6 4K W/ Body Builder) Design 333
S13 - Transmission I/O (Allison Gen 6 4700 W/ Body
Builder)
S13 - Transmission I/O (Allison Gen 6 4700 W/ Body Builder) Design 336
2021/2024 X15 - Transmissions Electrical I/O (Eaton
Ultrashift)
2021/2024 X15 - Transmissions Electrical I/O (Eaton Ultrashift) Design 339
2021/2024 X15 - Transmission Electrical I/O (Endurant
2021/2024 X15 - Transmission Electrical I/O (Endurant W/A26 & N/ Body Builder)
Design 340
2021/2024 X15 - Transmission Electrical I/O (Endurant W/ Cummins N/ Body
Builder) Design 341
W/ Cummins N/ Body Builder))
Builder)) Design 342
2021/2024 X15 - Transmission Electrical I/O (Endurant W/ Cummins W/ Body
Builder) Design 343
W/ Cummins W/ Body Builder) (0013WEW)
Builder) (0013WEW) Design 344
2021/2024 X15 - Transmission I/O (Allison Gen 6 4K
W/ Body Builder)
2021/2024 X15 - Transmission I/O (Allison Gen 6 4K W/ Body Builder) Design 345
2021/2024 X15 - Transmission I/O (Allison Gen 6 4700
W/ Body Builder)
TABLE OF CONTENTS
xiv2021/2024 X15 - Transmission I/O (Allison Gen 6 4700 W/ Body Builder)
Design 348
W/ Body Builder) X15
2021/2024 X15 - Transmission I/O (Allison Gen 6 4700 W/ Body Builder) X15
Design 351
2021/2024 X15 - Transmission I/O (Allison 4K W/ Body
Builder)
2021/2024 X15 - Transmission I/O (Allison 4K W/ Body Builder) Design 354
2021/2024 X15 - Transmission I/O (Allison 4700 W/
Body Builder)
2021/2024 X15 - Transmission I/O (Allison 4700 W/ Body Builder) Design 357
Transmission Power Take Off (60AKG)
Transmission Power Take Off (60AKG) Design 360
2017/2021 A26 - Transmission Power Take Off (Active
Low Feedback)
2017/2021 A26 - Transmission Power Take Off (Active Low Feedback)
Design 361
2017/2021 A26 - Transmission Power Take Off (Dual
PTO W/ 42 Parameters & W/ Auto, AMT Trans)
2017/2021 A26 - Transmission Power Take Off (Dual PTO W/ 42 Parameters &
W/ Auto, AMT Trans) Design 362
PTO W/ 42 Parameters & W/ Manual Trans)
W/ Manual Trans) Design 363
2017/2021 A26 - Transmission Power Take Off (Single
PTO W/42 Parameters & W/ Auto, AMT Trans)
2017/2021 A26 - Transmission Power Take Off (Single PTO W/42 Parameters &
W/ Auto, AMT Trans) Design 364
PTO W/ 42 Parameters & W/ Manl Trans)
2017/2021 A26 - Transmission Power Take Off (Single PTO W/ 42 Parameters &
W/ Manl Trans) Design 365
S13 - Transmission Power Take Off (Active Low
Feedback)
S13 - Transmission Power Take Off (Active Low Feedback) Design 366
S13 - Transmission Power Take Off (Dual PTO W/ 42
S13 - Transmission Power Take Off (Dual PTO W/ 42 Parameters & W/ Auto,
AMT Trans) Design 367
S13 - Transmission Power Take Off (Dual PTO W/ 42 Parameters & W/ Manual
Trans Design 368
TABLE OF CONTENTS
xvS13 - Transmission Power Take Off (Single PTO W/42
S13 - Transmission Power Take Off (Single PTO W/42 Parameters & W/ Auto,
AMT Trans) Design 369
S13 - Transmission Power Take Off (Single PTO W/ 42
S13 - Transmission Power Take Off (Single PTO W/ 42 Parameters & W/ Manual
Trans) Design 370
2021/2024 X15 - Transmission Power Take Off (Active
Low Feedback)
2021/2024 X15 - Transmission Power Take Off (Active Low Feedback)
Design 371
2021/2024 X15 - Transmission Power Take Off (Dual
2021/2024 X15 - Transmission Power Take Off (Dual PTO W/ 42 Parameters &
W/ Auto, AMT Trans) Design 372
W/ Manual Trans) Design 373
2021/2024 X15 - Transmission Power Take Off (Single
2021/2024 X15 - Transmission Power Take Off (Single PTO W/42 Parameters &
W/ Auto, AMT Trans) Design 374
2021/2024 X15 - Transmission Power Take Off (Single PTO W/ 42 Parameters &
W/ Manual Trans) Design 375
Service Brake Switch (1 SLS/1 Transducer)
Service Brake Switch (1 SLS/1 Transducer) Design 376
Service Brake Switch (1 SLS/1 Transducer/1 RDS to
ECM)
Service Brake Switch (1 SLS/1 Transducer/1 RDS to ECM) Design 377
Service Brake Switch (1 SLS/1 Transducer/ 1 RDS to
PIM)
Service Brake Switch (1 SLS/1 Transducer/ 1 RDS to PIM) Design 378
Service Brake Switch (2 SLS/1 Transducer)
Service Brake Switch (2 SLS/1 Transducer) Design 379
Service Brake Switch (2 SLS/ 1 Transducer/ 1 RDS to
ECM)
Service Brake Switch (2 SLS/ 1 Transducer/ 1 RDS to ECM) Design 380
PIM)
Service Brake Switch (2 SLS/ 1 Transducer/ 1 RDS to PIM) Design 381
Air Dryer (Single)
Air Dryer (Single) Design 382
TABLE OF CONTENTS
xviDrain Valve with four (4) Heaters
Drain Valve with four (4) Heaters Design 383
Drain Valve with Three (3) Heaters
Drain Valve with Three (3) Heaters Design 384
Drain Valve with Two (2) Heaters
Drain Valve with Two (2) Heaters Design 387
Antilock Brake System (ABS) (BENDIX 4 Channel
Implemenation - No Modulator Twist)
Antilock Brake System (ABS) (BENDIX 4 Channel Implemenation - No Modulator
Twist) Design 390
Antilock Brake System (ABS) (Bendix 6 Channel
Implementation - No Modulator Twist)
Antilock Brake System (ABS) (Bendix 6 Channel Implementation - No Modulator
Twist) Design 391
Brake Wear Indicator (Front & Rear, tandem axle)
Brake Wear Indicator (Front & Rear, tandem axle) Design 392
Brake Wear Indicator (Front)
Brake Wear Indicator (Front) Design 393
Brake Wear Indicator (Rear, tandem axle)
Brake Wear Indicator (Rear, tandem axle) Design 394
Park Brake Controls (Air Chassis Park Brake)
Park Brake Controls (Air Chassis Park Brake) Design 395
Park Brake Controls (Straight Truck) Intellipark
Park Brake Controls (Straight Truck) Intellipark Design 396
Park Brake Controls (Tractor) Intellipark
Park Brake Controls (Tractor) Intellipark Design 397
Bendix; Tractor or Towing Truck; N/ Air SUSP; J1939
Driven Lamp
Bendix; Tractor or Towing Truck; N/ Air SUSP; J1939 Driven Lamp Design 399
Bendix; Tractor or Towing Truck; W/ Air SUSP; J1939
Driven Lamp
Bendix; Tractor or Towing Truck; W/ Air SUSP; J1939 Driven Lamp Design 400
Stability Control (Bendix, Straight Truck, J1939 Driven
Lamp)
Stability Control (Bendix, Straight Truck, J1939 Driven Lamp) Design 401
Traction Control (Bendix)
Traction Control (Bendix) Design 402
Adaptive Cruise Control (Fusion 3.0 N/ DIU W/LDW
Audio Mute)
Adaptive Cruise Control (Fusion 3.0 N/ DIU W/LDW Audio Mute) Design 404
Adaptive Cruise Control (Fusion 3.0 N/ DIU)
Adaptive Cruise Control (Fusion 3.0 N/ DIU) Design 405
TABLE OF CONTENTS
xviiAdaptive Cruise Control (Bendix - Fusion 2.0 N/
Safety Direct Conn & W/ Reg Speakers)
Adaptive Cruise Control (Bendix - Fusion 2.0 N/ Safety Direct Conn & W/ Reg
Speakers) Design 406
Adaptive Cruise Control (Bendix - Fusion 2.0 W/
Safety Direct Conn & W/ Tweeters) Combination 1
Adaptive Cruise Control (Bendix - Fusion 2.0 W/ Safety Direct Conn & W/
Tweeters) Combination 1 Design 410
Safety Direct Conn & W/ Tweeters) Combination 2
Tweeters) Combination 2 Design 413
Adaptive Cruise Control (Bendix - Fusion 2.0 & W/
Adaptive Cruise Control (Bendix - Fusion 2.0 & W/ Safety Direct Conn & W/ Reg
Speakers) Design 416
Adaptive Cruise Control (Bendix - Fusion 2.8/2.9 N/
Safety Direct Conn W/ Reg Speakers)(W/0016AUS &
0016030)
Adaptive Cruise Control (Bendix - Fusion 2.8/2.9 N/ Safety Direct Conn W/ Reg
Speakers)(W/0016AUS & 0016030) Design 420
Safety Direct Conn W/ Tweeters)(W/0016AUS &
0016030)
Tweeters)(W/0016AUS & 0016030) Design 422
Adaptive Cruise Control (Bendix - Fusion 2.8/2.9 W/
0016030)
Adaptive Cruise Control (Bendix - Fusion 2.8/2.9 W/ Safety Direct Conn W/ Reg
Speakers)(W/0016AUS & 0016030) Design 424
0016030)
Tweeters)(W/0016AUS & 0016030) Design 426
Safety Direct Conn W/ Reg Speakers)(W/0016AUM &
0016AUN)
Speakers)(W/0016AUM & 0016AUN) Design 428
Safety Direct Conn W/ Tweeters)(W/0016AUM &
0016AUN)
Tweeters)(W/0016AUM & 0016AUN) Design 430
TABLE OF CONTENTS
xviiiAdaptive Cruise Control (Bendix - Fusion 2.8/2.9 W/
0016AUN)
Speakers)(W/0016AUM & 0016AUN) Design 431
0016AUN)
Tweeters)(W/0016AUM & 0016AUN) Design 433
Adaptive Cruise Control (Bendix Wingman Advanced
N/ DIU)
Adaptive Cruise Control (Bendix Wingman Advanced N/ DIU) Design 434
Camera Event Recorder N/Safety Direct Cable
Camera Event Recorder N/Safety Direct Cable Design 435
Camera Event Recorder W/Safety Direct Cable
Camera Event Recorder W/Safety Direct Cable Design 437
Collision Avoidance System (Warning) (Blindspotter
2.0)
Collision Avoidance System (Warning) (Blindspotter 2.0) Design 439
Collision Avoidance System (Warning) (Side Object
Detection, Left & Right Side)
Collision Avoidance System (Warning) (Side Object Detection, Left & Right Side)
Design 440
Detection, Right Side)
Collision Avoidance System (Warning) (Side Object Detection, Right Side)
Design 443
Lane Centering System
Lane Centering System Design 445
Surround View (Camera Display, 1 Camera EOF,
Prewire)
Surround View (Camera Display, 1 Camera EOF, Prewire) Design 446
2017/2021 A26 - Air Filter Flow Restriction Monitoring
2017/2021 A26 - Air Filter Flow Restriction Monitoring Design 447
2021/2024 X15 - Air Filter Flow Restriction Monitoring
2021/2024 X15 - Air Filter Flow Restriction Monitoring Design 448
2024 S13 - Air Filter Flow Restriction Monitoring
2024 S13 - Air Filter Flow Restriction Monitoring Design 449
2017 A26 - Coolant Level Monitoring (No CLA Module)
2017 A26 - Coolant Level Monitoring (No CLA Module) Design 450
2021 A26 - Coolant Level Monitoring (No CLA Module)
2021 A26 - Coolant Level Monitoring (No CLA Module) Design 451
TABLE OF CONTENTS
xix2024 S13 - Coolant Level Monitoring (W/ PIM)
2024 S13 - Coolant Level Monitoring (W/ PIM) Design 452
2021/2024 X15 - Coolant Level Monitoring (No CLA
Module)
2021/2024 X15 - Coolant Level Monitoring (No CLA Module) Design 453
2017 A26 - Cooling Fan Control (Fan Override)
2017 A26 - Cooling Fan Control (Fan Override) Design 454
2017 A26 - Cooling Fan Control (No Fan Override,
Cummins)
2017 A26 - Cooling Fan Control (No Fan Override, Cummins) Design 455
2021 A26 - Cooling Fan Control (Fan Override)
2021 A26 - Cooling Fan Control (Fan Override) Design 456
2021 A26 - Cooling Fan Control (No Fan Override,
Cummins)
2021 A26 - Cooling Fan Control (No Fan Override, Cummins) Design 457
2024 S13 - Cooling Fan Control (Fan Override)
2024 S13 - Cooling Fan Control (Fan Override) Design 458
2024 S13 - Cooling Fan Control (No Fan Override)
2024 S13 - Cooling Fan Control (No Fan Override) Design 459
2021 X15 / 2024 X15 - Cooling Fan Control (Fan
Override, Cummins)
2021 X15 / 2024 X15 - Cooling Fan Control (Fan Override, Cummins) Design 460
2021 X15 / 2024 X15 - Cooling Fan Control (No Fan
Override, Cummins)
2021 X15 / 2024 X15 - Cooling Fan Control (No Fan Override, Cummins)
Design 461
2021/2024 X15 Cooling Fan Control (No Fan Override,
Cummins)
2021/2024 X15 Cooling Fan Control (No Fan Override, Cummins) Design 462
2017 A26 - Starting Aid (Flame Start N/MD1 ECM)
2017 A26 - Starting Aid (Flame Start N/MD1 ECM) Design 463
2021 A26 - Starting Aid (Flame Start W/MD1 ECM)
2021 A26 - Starting Aid (Flame Start W/MD1 ECM) Design 464
2021/2024 X15 - Starting Aid (Ether Start)
2021/2024 X15 - Starting Aid (Ether Start) Design 465
S13 - Vehicle Acceleration (Accel Pedal wired to PIM)
S13 - Vehicle Acceleration (Accel Pedal wired to PIM) Design 466
PIM)(Rev2)
S13 - Vehicle Acceleration (Accel Pedal wired to PIM)(Rev2) Design 467
2017 A26 - Vehicle Acceleration (Wired to the ECM)
2017 A26 - Vehicle Acceleration (Wired to the ECM) Design 468
TABLE OF CONTENTS
xx2021 A26 - Vehicle Acceleration (Wired to the ECM)
2021 A26 - Vehicle Acceleration (Wired to the ECM) Design 469
2021/2024 X15 - Vehicle Acceleration (Wired to the
ECM)(REV1)
2021/2024 X15 - Vehicle Acceleration (Wired to the ECM)(REV1) Design 470
ECM)(Rev2)
2021/2024 X15 - Vehicle Acceleration (Wired to the ECM)(Rev2) Design 471
2017 A26 - Engine Electrical I/O (Interface Connector)
2017 A26 - Engine Electrical I/O (Interface Connector) Design 473
2021 A26 - Engine Electrical I/O (Interface Connector)
2021 A26 - Engine Electrical I/O (Interface Connector) Design 474
Engine Electrical I/O Design 476
Automatic Lighting W/Twilight & W/Sunload
Automatic Lighting W/Twilight & W/Sunload Design 477
2017/2021 A26 - Backup Lights (Reverse Lights)
(Crossmember Dual STT N/Back Up) Allison Trans
2017/2021 A26 - Backup Lights (Reverse Lights) (Crossmember Dual STT
N/Back Up) Allison Trans Design 478
2017/2021 A26 - Backup Light (Dual Daisy Reverse
LT)Allison/ZF Trans
2017/2021 A26 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans
Design 479
2017/2021 A26 - Backup Light (Dual Daisy with
extension)Allison/ZF Trans
2017/2021 A26 - Backup Light (Dual Daisy with extension)Allison/ZF Trans
Design 480
2017/2021 A26 - Backup Light (Dual Reverse
Light)Allison/ZF Trans
2017/2021 A26 - Backup Light (Dual Reverse Light)Allison/ZF Trans Design 481
2017/2021 A26 - Backup Light (Single Reverse Light)
W/Allison (LS,HRZN,HX)
2017/2021 A26 - Backup Light (Single Reverse Light) W/Allison (LS,HRZN,HX)
Design 482
W/Less Power Module W/ Allison
2017/2021 A26 - Backup Light (Single Reverse Light) W/Less Power Module W/
Allison Design 483
2021/2024 X15 - Backup Lights (Reverse Lights)
2021/2024 X15 - Backup Lights (Reverse Lights) (Crossmember Dual STT
N/Back Up) Allison Trans Design 484
TABLE OF CONTENTS
xxi2021/2024 X15 - Backup Light (Dual Daisy Reverse
LT)Allison/ZF Trans
2021/2024 X15 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans
Design 485
2021/2024 X15 - Backup Light (Dual Daisy with
2021/2024 X15 - Backup Light (Dual Daisy with extension)Allison/ZF Trans
Design 486
2021/2024 X15 - Backup Light (Dual Reverse
2021/2024 X15 - Backup Light (Dual Reverse Light)Allison/ZF Trans Design 487
2021/2024 X15 - Backup Light (Single Reverse Light)
2021/2024 X15 - Backup Light (Single Reverse Light) W/Allison (LS,HRZN,HX)
Design 488
2021/2024 X15 - Backup Light (Single Reverse Light) W/Less Power Module W/
Allison Design 489
Endurant/EndurantXD Trans
N/Back Up) Endurant/EndurantXD Trans Design 490
(HV, HX) Yukon AMT
2017/2021 A26 - Backup Light (Dual Daisy Reverse LT) (HV, HX) Yukon AMT
Design 491
extension)(HV, HX) Yukon AMT
2017/2021 A26 - Backup Light (Dual Daisy with extension)(HV, HX) Yukon AMT
Design 492
LT)(HRZN, HX) - Relay Coil CTRL by TCM - 6 PIN
2017/2021 A26 - Backup Light (Dual Reverse LT)(HRZN, HX) - Relay Coil CTRL
by TCM - 6 PIN Design 493
(HRZN, HX) Yukon AMT
2017/2021 A26 - Backup Light (Single Reverse Light) (HRZN, HX) Yukon AMT
Design 494
(HV, HX) W/Less Power Module W/Yukon AMT
2017/2021 A26 - Backup Light (Single Reverse Light) (HV, HX) W/Less Power
Module W/Yukon AMT Design 495
TABLE OF CONTENTS
xxii2021/2024 X15 - Backup Lights (Reverse Lights) (Crossmember Dual STT
N/Back Up) Endurant/EndurantXD Trans Design 496
(HV, HX) Yukon AMT
2021/2024 X15 - Backup Light (Dual Daisy Reverse LT) (HV, HX) Yukon AMT
Design 497
2021/2024 X15 - Backup Light (Dual Daisy with extension)(HV, HX) Yukon AMT
Design 498
2021/2024 X15 - Backup Light (Dual Reverse LT)(HRZN, HX) - Relay Coil CTRL
by TCM - 6 PIN Design 499
2021/2024 X15 - Backup Light (Single Reverse Light) (HRZN, HX) Yukon AMT
Design 500
2021/2024 X15 - Backup Light (Single Reverse Light) (HV, HX) W/Less Power
Module W/Yukon AMT Design 501
2017/2021 A26 - Backup Lights (Dual Daisy Reverse
Light) Eaton/Manual Trans
2017/2021 A26 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans
Design 502
2017/2021 A26 - Backup Lights (Dual Daisy with
extension) Eaton/Manual Trans
2017/2021 A26 - Backup Lights (Dual Daisy with extension) Eaton/Manual Trans
Design 503
2017/2021 A26 - Backup Lights (Dual Reverse Light)
Eaton/Manual Trans
2017/2021 A26 - Backup Lights (Dual Reverse Light) Eaton/Manual Trans
Design 504
(Crossmember Dual STT N/Back Up) Eaton/Manual
Trans
N/Back Up) Eaton/Manual Trans Design 505
2017/2021 A26 - Backup Lights (Single Reverse Light)
Eaton/Manual Trans (LS,HX,HRZN)
2017/2021 A26 - Backup Lights (Single Reverse Light) Eaton/Manual Trans
(LS,HX,HRZN) Design 506
2017/2021 A26 - Back Up Lights (Reverse) W/ Less
Power Module W/Eaton/ Manual
TABLE OF CONTENTS
xxiii2017/2021 A26 - Back Up Lights (Reverse) W/ Less Power Module W/Eaton/
Manual Design 507
2021/2024 X15 - Backup Lights (Dual Daisy Reverse
2021/2024 X15 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans
Design 508
2021/2024 X15 - Backup Lights (Dual Daisy with
2021/2024 X15 - Backup Lights (Dual Daisy with extension) Eaton/Manual Trans
Design 509
2021/2024 X15 - Backup Lights (Dual Reverse Light)
Eaton/Manual Trans
2021/2024 X15 - Backup Lights (Dual Reverse Light) Eaton/Manual Trans
Design 510
Trans
N/Back Up) Eaton/Manual Trans Design 511
2021/2024 X15 - Backup Lights (Single Reverse Light)
2021/2024 X15 - Backup Lights (Single Reverse Light) Eaton/Manual Trans
(LS,HX,HRZN) Design 512
2021/2024 X15 - Back Up Lights (Reverse) W/ Less
2021/2024 X15 - Back Up Lights (Reverse) W/ Less Power Module W/Eaton/
Manual Design 513
S13 - Backup Lights (Reverse Lights) (Crossmember
Dual STT N/Back Up) T14 Transmission
S13 - Backup Lights (Reverse Lights) (Crossmember Dual STT N/Back Up) T14
Transmission Design 514
S13 - Backup Light (Dual Daisy Reverse) T14
Transmission, 5 Pin
S13 - Backup Light (Dual Daisy Reverse) T14 Transmission, 5 Pin Design 515
S13 - Backup Light (Dual Daisy with extension) T14
S13 - Backup Light (Dual Daisy with extension) T14 Transmission Design 516
S13 - Backup Light (Dual Reverse) T14 Transmission,
6 Pin
S13 - Backup Light (Dual Reverse) T14 Transmission, 6 Pin Design 517
S13 - Backup Light (Single Reverse Light) T14
S13 - Backup Light (Single Reverse Light) T14 Transmission Design 518
Beacon/Strobe Light (2 Blunt Cuts, Horizon)
Beacon/Strobe Light (2 Blunt Cuts, Horizon) Design 519
TABLE OF CONTENTS
xxivBeacon/Strobe Light - 2 Lamps, Hardwired switch
Beacon/Strobe Light - 2 Lamps, Hardwired switch Design 521
Rear Lights Stop - Single Assembly jumper harness
(HV,MV, HX)
Rear Lights Stop - Single Assembly jumper harness (HV,MV, HX) Design 523
Rear Lights (Stop) (Daisy Chain N/ Extension Harness)
Rear Lights (Stop) (Daisy Chain N/ Extension Harness) Design 524
Rear Lights (Stop) (Daisy Chain W/ Extension
Harness)
Rear Lights (Stop) (Daisy Chain W/ Extension Harness) Design 526
Rear Lights (Stop) - Dual Lamp Assembly
Rear Lights (Stop) - Dual Lamp Assembly Design 528
Rear Lights (Stop) - Single Assembly (HRZN, HX, LS)
Rear Lights (Stop) - Single Assembly (HRZN, HX, LS) Design 529
Rear Lights (Tail Lights) Crossmember Dual STT
N/Back-Up
Rear Lights (Tail Lights) Crossmember Dual STT N/Back-Up Design 530
Rear Light (LED BOX LAMP Tail Light)
Rear Light (LED BOX LAMP Tail Light) Design 531
Rear Light (Stop) Crossmember Dual STT N/Back-Up
Rear Light (Stop) Crossmember Dual STT N/Back-Up Design 532
Rear Light (Tail Light) Daisy Chain W/ Extension
Rear Light (Tail Light) Daisy Chain W/ Extension Design 533
Rear Light (Tail Light) W/Daisy Chain Pair of Box
Lamps
Rear Light (Tail Light) W/Daisy Chain Pair of Box Lamps Design 534
Rear Light (Tail Light) W/Less Power Module
Rear Light (Tail Light) W/Less Power Module Design 535
Rear Light (Tail Light) W/ 6 Pin Connector
Rear Light (Tail Light) W/ 6 Pin Connector Design 536
Clearance and Identification Lights N/SUNSHADE
AMBER LENS (HX)
Clearance and Identification Lights N/SUNSHADE AMBER LENS (HX) Design537
Clearance and Identification Lights W/SUNSHADE
AMBER LENS (HX)
Clearance and Identification Lights W/SUNSHADE AMBER LENS (HX)
Design 538
Directional Signal (Turn) LED N/Plowlight (SBA, HX)
Directional Signal (Turn) LED N/Plowlight (SBA, HX) Design 539
Directional Signal (Turn) LED W/Plowlight (SBA, HX)
Directional Signal (Turn) LED W/Plowlight (SBA, HX) Design 540
Directional Signal (Turn) SBA W/HEADLIGHTS
TABLE OF CONTENTS
xxvDirectional Signal (Turn) SBA W/HEADLIGHTS Design 541
Directional Signal (Turn) SBA W/HEADLIGHTS,
W/PLOWLIGHTS
Directional Signal (Turn) SBA W/HEADLIGHTS, W/PLOWLIGHTS Design 542
Directional Signal (Turn) SFA W/HEADLIGHTS
Directional Signal (Turn) SFA W/HEADLIGHTS Design 543
Directional Signal (Turn) SFA W/HEADLIGHTS,
W/PLOWLIGHTS
Directional Signal (Turn) SFA W/HEADLIGHTS, W/PLOWLIGHTS Design 544
Front Fog Lamps
Front Fog Lamps Design 545
Prewire Front Fog Lights
Prewire Front Fog Lights Design 546
Hazard Warning (CA 2.0)(E)
Hazard Warning (CA 2.0)(E) Design 547
Headlights LED N/Plowlight (SBA)
Headlights LED N/Plowlight (SBA) Design 548
Headlights LED W/Plowlight (SBA)
Headlights LED W/Plowlight (SBA) Design 549
Headlights SBA
Headlights SBA Design 550
Headlights SBA W/Plowlights
Headlights SBA W/Plowlights Design 551
Headlights SFA
Headlights SFA Design 552
Headlights SFA W/Plowlights
Headlights SFA W/Plowlights Design 553
License Plate Light (Direct To Light)
License Plate Light (Direct To Light) Design 554
License Plate Light (LED BOX LAMP Daisy Chain Tail
Light with extension)
License Plate Light (LED BOX LAMP Daisy Chain Tail Light with extension)
Design 555
Light)
License Plate Light (LED BOX LAMP Daisy Chain Tail Light) Design 556
License Plate Light (LED BOX LAMP Tail Light)
License Plate Light (LED BOX LAMP Tail Light) Design 557
License Plate Light (Tail Light Single Assy)
License Plate Light (Tail Light Single Assy) Design 558
License Plate Light (Tail Light Single Assy.) W/Less
Power Module
TABLE OF CONTENTS
xxviLicense Plate Light (Tail Light Single Assy.) W/Less Power Module Design 559
Marker Lighting LED N/Plowlight, Guide Post (SBA)
Marker Lighting LED N/Plowlight, Guide Post (SBA) Design 560
Marker Lighting LED W/Plowlight N/Guide Post (SBA)
Marker Lighting LED W/Plowlight N/Guide Post (SBA) Design 561
Marker Lighting SBA
Marker Lighting SBA Design 562
Marker Lighting SBA W/Guide Posts
Marker Lighting SBA W/Guide Posts Design 563
Marker Lighting SBA W/Plowlight
Marker Lighting SBA W/Plowlight Design 564
Marker Lighting SBA W/Plowlight & W/Guide Posts
Marker Lighting SBA W/Plowlight & W/Guide Posts Design 565
Marker Lighting SFA
Marker Lighting SFA Design 566
Marker Lighting SFA W/Guide Posts
Marker Lighting SFA W/Guide Posts Design 567
Marker Lighting SFA W/Plowlight
Marker Lighting SFA W/Plowlight Design 568
Marker Lighting SFA W/Plowlight & W/Guide Posts
Marker Lighting SFA W/Plowlight & W/Guide Posts Design 569
Modesty Lighting W/ Day Cab 2 Turn/Marker 6 Marker
Modesty Lighting W/ Day Cab 2 Turn/Marker 6 Marker Design 570
Modesty Lighting W/ Sleeper
Modesty Lighting W/ Sleeper Design 572
Modesty Lighting W/ Sleeper Cab 2 Turn/Marker 8
Marker
Modesty Lighting W/ Sleeper Cab 2 Turn/Marker 8 Marker Design 573
Modesty Lighting W/ Sleeper Cab 4 Turn/Marker 10
Marker
Modesty Lighting W/ Sleeper Cab 4 Turn/Marker 10 Marker Design 576
Modesty Lighting W/ Sleeper Cab 4 Turn/Marker 12
Marker
Modesty Lighting W/ Sleeper Cab 4 Turn/Marker 12 Marker Design 578
Modesty Lighting W/ Sleeper Cab 4 Turn/Marker 14
Marker
Modesty Lighting W/ Sleeper Cab 4 Turn/Marker 14 Marker Design 580
Modesty Lighting W/ Sleeper Cab 4 Turn/Marker 16
Marker
Modesty Lighting W/ Sleeper Cab 4 Turn/Marker 16 Marker Design 582
Modesty Lighting W/ 2 Turn/Marker
TABLE OF CONTENTS
xxviiModesty Lighting W/ 2 Turn/Marker Design 584
Work Lights - 1 Bulb W/ Backup W/ RKE (Auto)
Work Lights - 1 Bulb W/ Backup W/ RKE (Auto) Design 585
Work Lights - 1 Bulb W/ Backup (Auto)
Work Lights - 1 Bulb W/ Backup (Auto) Design 586
Work Lights - 2 Bulbs W/ Backup W/ RKE (Auto)
Work Lights - 2 Bulbs W/ Backup W/ RKE (Auto) Design 587
Work Lights - 2 Bulbs W/ Backup (Auto)
Work Lights - 2 Bulbs W/ Backup (Auto) Design 588
Work Light W/Backup, W/RKE, 2Bulbs (Auto)
Work Light W/Backup, W/RKE, 2Bulbs (Auto) Design 589
Work Light W/Backup, W/RKE, 2 Bulbs (Auto)
Work Light W/Backup, W/RKE, 2 Bulbs (Auto) Design 590
Work Light W/Backup, 4 LED (Auto)
Work Light W/Backup, 4 LED (Auto) Design 592
Work Lights - 2 Bulbs W/ Backup W/ RKE (Manual) -
DayCab
Work Lights - 2 Bulbs W/ Backup W/ RKE (Manual) - DayCab Design 593
Work Lights - 2 Bulbs W/ Backup (Manual) - DayCab
Work Lights - 2 Bulbs W/ Backup (Manual) - DayCab Design 597
WORK LIGHT W BackUP 2 Bulbs - Auto Trans -
DayCab
WORK LIGHT W BackUP 2 Bulbs - Auto Trans - DayCab Design 601
Work Light W RKE 1 BULB
Work Light W RKE 1 BULB Design 603
WORK LIGHT W RKE 2 Bulbs - DayCab
WORK LIGHT W RKE 2 Bulbs - DayCab Design 604
Work Light 1 Bulb
Work Light 1 Bulb Design 606
WORK LIGHT 2 Bulbs DayCab
WORK LIGHT 2 Bulbs DayCab Design 607
Work Lights - 1 Bulb W/ Backup W/ RKE (Manual)
Work Lights - 1 Bulb W/ Backup W/ RKE (Manual) Design 609
Work Lights - 1 Bulb W/ Backup (Manual)
Work Lights - 1 Bulb W/ Backup (Manual) Design 611
Work Lights - 2 Bulbs W/ Backup W/ RKE (Manual) Design 613
Work Lights - 2 Bulbs W/ Backup (Manual) Design 615
TABLE OF CONTENTS
xxviiiWork Lights - 4 LED Bulbs W/ Backup W/ RKE
(Manual)
Work Lights - 4 LED Bulbs W/ Backup W/ RKE (Manual) Design 617
Work Lights - 4 LED Bulbs W/ Backup (Manual)
Work Lights - 4 LED Bulbs W/ Backup (Manual) Design 619
Work light W RKE 2 Bulbs
Work light W RKE 2 Bulbs Design 621
Work Light W/RKE 4 LED LT Bulbs Sleeper
Work Light W/RKE 4 LED LT Bulbs Sleeper Design 622
Work Light W/RKE 4 LED LT Bulbs_Sleeper- HX
Work Light W/RKE 4 LED LT Bulbs_Sleeper- HX Design 623
Work light 2 Bulbs
Work light 2 Bulbs Design 624
Back of Cab Aux Work Light (2 blunt cuts)
Back of Cab Aux Work Light (2 blunt cuts) Design 625
End of Frame Aux Work Light (CONN) - CUST
FURNISHD LT Bulb
End of Frame Aux Work Light (CONN) - CUST FURNISHD LT Bulb Design 629
2024 S13 - Fuel Delivery System (Smart Pump)
2024 S13 - Fuel Delivery System (Smart Pump) Design 630
A26 - Fuel Heater (Vehicle Powered)
A26 - Fuel Heater (Vehicle Powered) Design 631
A26 - Fuel Heater (Vehicle Powered)(Racor)(Horizon)
A26 - Fuel Heater (Vehicle Powered)(Racor)(Horizon) Design 632
S13 - Fuel Heater (Vehicle Powered)
S13 - Fuel Heater (Vehicle Powered) Design 633
S13 - Fuel Heater (Vehicle Powered)(Racor)(Horizon)
S13 - Fuel Heater (Vehicle Powered)(Racor)(Horizon) Design 634
2021/2024 X15 - Fuel Heater (Vehicle Powered)
2021/2024 X15 - Fuel Heater (Vehicle Powered) Design 635
2021/2024 X15 - Fuel Heater (Vehicle Powered)(Racor)(Horizon) Design 636
Fuel Level (Single Sensor)
Fuel Level (Single Sensor) Design 637
2017 A26 - Water In Fuel (WIF) Davco N/ Heater
2017 A26 - Water In Fuel (WIF) Davco N/ Heater Design 640
2017 A26 - Water In Fuel (WIF) Racor N/ Heater
2017 A26 - Water In Fuel (WIF) Racor N/ Heater Design 641
2017 A26 - Water In Fuel (WIF) W/ Heater
2017 A26 - Water In Fuel (WIF) W/ Heater Design 642
TABLE OF CONTENTS
xxix2021 A26 - Water In Fuel (WIF) Davco N/ Heater
2021 A26 - Water In Fuel (WIF) Davco N/ Heater Design 643
2021 A26 - Water In Fuel (WIF) Racor N/ Heater
2021 A26 - Water In Fuel (WIF) Racor N/ Heater Design 644
2021 A26 - Water In Fuel (WIF) W/ Heater
2021 A26 - Water In Fuel (WIF) W/ Heater Design 645
S13 - Water In Fuel (WIF) (WIF to PIM Davco N/ Heater)
S13 - Water In Fuel (WIF) (WIF to PIM Davco N/ Heater) Design 646
Heater)(S13)
S13 - Water In Fuel (WIF) (WIF to PIM Davco N/ Heater)(S13) Design 647
S13 - Water In Fuel (WIF) (WIF to PIM W/ Heater)
S13 - Water In Fuel (WIF) (WIF to PIM W/ Heater) Design 648
S13 - Water In Fuel (WIF) (WIF to PIM W/ Heater)(S13)
S13 - Water In Fuel (WIF) (WIF to PIM W/ Heater)(S13) Design 649
2021 X15 - Water In Fuel (WIF) Davco N/ Heater
2021 X15 - Water In Fuel (WIF) Davco N/ Heater Design 650
2021 X15 - Water In Fuel (WIF) W/ Heater
2021 X15 - Water In Fuel (WIF) W/ Heater Design 651
2021/2024 X15 - Water In Fuel (WIF) Racor N/ Heater
2021/2024 X15 - Water In Fuel (WIF) Racor N/ Heater Design 652
A26 - Heating, Ventilation, & Air Conditioning (HVAC)
(Auto Control head W/PT Transducer, N/Low Pressure
SW)
A26 - Heating, Ventilation, & Air Conditioning (HVAC) (Auto Control head W/PT
Transducer, N/Low Pressure SW) Design 653
(Manual Control Head, W/O Compressor)
A26 - Heating, Ventilation, & Air Conditioning (HVAC) (Manual Control Head, W/O
Compressor) Design 656
(Manual, W/PT Transducer, N/Low Pressure SW)
A26 - Heating, Ventilation, & Air Conditioning (HVAC) (Manual, W/PT Transducer,
N/Low Pressure SW) Design 658
S13 - Heating, Ventilation, & Air Conditioning (HVAC)
SW)-
S13 - Heating, Ventilation, & Air Conditioning (HVAC) (Auto Control head W/PT
Transducer, N/Low Pressure SW)- Design 660
(Manual, W/PT Transducer, N/Low Pressure SW)-
S13 - Heating, Ventilation, & Air Conditioning (HVAC) (Manual, W/PT Transducer,
N/Low Pressure SW)- Design 663
TABLE OF CONTENTS
xxx2021/2024 X15 - Heating, Ventilation, & Air
2021/2024 X15 - Heating, Ventilation, & Air Conditioning (HVAC) (Auto Control
head W/PT Transducer, N/Low Pressure SW) Design 665
Compressor)
2021/2024 X15 - Heating, Ventilation, & Air Conditioning (HVAC) (Manual Control
Head, W/O Compressor) Design 668
N/Low Pressure SW)
2021/2024 X15 - Heating, Ventilation, & Air Conditioning (HVAC) (Manual, W/PT
Transducer, N/Low Pressure SW) Design 670
No-Idle HVAC - W/Espar Airtronic & W/Bergstrom AC
No-Idle HVAC - W/Espar Airtronic & W/Bergstrom AC Design 672
Rear HVAC No Idle - Heater Espar
Rear HVAC No Idle - Heater Espar Design 675
Rear HVAC No Idle - W/Pre-Heat Bergstrom Heat and
Cool N/2 addl Switches
Rear HVAC No Idle - W/Pre-Heat Bergstrom Heat and Cool N/2 addl Switches
Design 676
Cool & W/Espar Air Heat
Rear HVAC No Idle - W/Pre-Heat Bergstrom Heat and Cool & W/Espar Air Heat
Design 679
Rear HVAC No Idle - W/ Pre-Heat Bergstrom Heat and
Cool W/2 addl switches
Rear HVAC No Idle - W/ Pre-Heat Bergstrom Heat and Cool W/2 addl switches
Design 682
Rear Heating, Ventilation & Air Conditioning (HVAC)
(Premium control head)
Rear Heating, Ventilation & Air Conditioning (HVAC) (Premium control head)
Design 685
2017 A26 - Ambient Temperature (Horizon-Mirror
Sensor)
2017 A26 - Ambient Temperature (Horizon-Mirror Sensor) Design 687
2017 A26 - Ambient Temperature (No Display, Mirror
Sensor)
2017 A26 - Ambient Temperature (No Display, Mirror Sensor) Design 688
2021 A26 - Ambient Temperature (Horizon-Mirror
Sensor)
2021 A26 - Ambient Temperature (Horizon-Mirror Sensor) Design 689
2021 A26 - Ambient Temperature (No Display, Mirror
Sensor)
TABLE OF CONTENTS
xxxi2021 A26 - Ambient Temperature (No Display, Mirror Sensor) Design 690
S13 - Ambient Temperature Monitoring (W/ PIM)
S13 - Ambient Temperature Monitoring (W/ PIM) Design 691
S13 - Ambient Temperature (No Display, Mirror
Sensor, W/ PIM)
S13 - Ambient Temperature (No Display, Mirror Sensor, W/ PIM) Design 692
2021/2024 X15 - Ambient Temperature (Horizon-Mirror
Sensor)
2021/2024 X15 - Ambient Temperature (Horizon-Mirror Sensor) Design 693
2021/2024 X15 - Ambient Temperature (No Display,
Mirror Sensor)
2021/2024 X15 - Ambient Temperature (No Display, Mirror Sensor) Design 694
Mirror Sensor) W/EGC
2021/2024 X15 - Ambient Temperature (No Display, Mirror Sensor) W/EGC
Design 695
Auxiliary Gauges (Multiple)
Auxiliary Gauges (Multiple) Design 696
Service Brake Pressure (Auxiliary Gauge)
Service Brake Pressure (Auxiliary Gauge) Design 697
Service Brake Pressure (No Gauges)
Service Brake Pressure (No Gauges) Design 698
Service Brake Pressure (Virtual Gauge)
Service Brake Pressure (Virtual Gauge) Design 699
Compressed Air Supply (Primary and Secondary
Gauge)
Compressed Air Supply (Primary and Secondary Gauge) Design 700
2017/2021 A26 - Transmission Oil Temperature
(Manual Trans)
2017/2021 A26 - Transmission Oil Temperature (Manual Trans) Design 701
(Manual Trans-Horizon W/ Aux Gauge)Z
2017/2021 A26 - Transmission Oil Temperature (Manual Trans-Horizon W/ Aux
Gauge)Z Design 702
2021/2024 X15 - Transmission Oil Temperature
(Manual Trans)
2021/2024 X15 - Transmission Oil Temperature (Manual Trans) Design 703
2021/2024 X15 - Transmission Oil Temperature (Manual Trans-Horizon W/ Aux
Gauge) Design 704
Vehicle Speedometer System (From PIM to Blunt Cut)
Vehicle Speedometer System (From PIM to Blunt Cut) Design 705
TABLE OF CONTENTS
xxxii2017 A26 - Vehicle Speedometer System (From ECM
to Blunt Cut)
2017 A26 - Vehicle Speedometer System (From ECM to Blunt Cut) Design 706
2017 A26 - Vehicle Speedometer System (VSS wired
directly to ECM)
2017 A26 - Vehicle Speedometer System (VSS wired directly to ECM) Design 708
2017 A26 / 2024 S13 - Vehicle Speedometer System
(From TCM to Blunt Cut)
2017 A26 / 2024 S13 - Vehicle Speedometer System (From TCM to Blunt Cut)
Design 710
2021 A26 - Vehicle Speedometer System (From A26 to
Blunt Cut)
2021 A26 - Vehicle Speedometer System (From A26 to Blunt Cut) Design 711
2021 A26 - Vehicle Speedometer System (VSS wired to
VIC)
2021 A26 - Vehicle Speedometer System (VSS wired to VIC) Design 712
2021/2024 X15 - Vehicle Speedometer System (From
Road Speed SNSR to Blunt Cut)
2021/2024 X15 - Vehicle Speedometer System (From Road Speed SNSR to
Blunt Cut) Design 714
2021/2024 X15 - Vehicle Speedometer System (VSS
2021/2024 X15 - Vehicle Speedometer System (VSS wired directly to ECM)
Design 716
Cut)(Rev2)
Vehicle Speedometer System (From TCM to Blunt Cut)(Rev2) Design 718
Courtesy Step Lighting (2 Door)
Courtesy Step Lighting (2 Door) Design 719
Cab Dome Light W/Classic Trim (MV, HV, HX)
Cab Dome Light W/Classic Trim (MV, HV, HX) Design 720
Cab Dome Light W/ Combo in Diamond
Trim(HRZN,LS,MV,HV,HX)
Cab Dome Light W/ Combo in Diamond Trim(HRZN,LS,MV,HV,HX) Design 721
Cab Dome Light - Sleeper Cab
Cab Dome Light - Sleeper Cab Design 722
Lighting Sleeper Dome (Horizon)
Lighting Sleeper Dome (Horizon) Design 723
Floor/Search Lighting (Sleeper 1 Light)
Floor/Search Lighting (Sleeper 1 Light) Design 724
Floor/Search Lighting (Sleeper 3 Lights)
Floor/Search Lighting (Sleeper 3 Lights) Design 725
Floor/Search Lights (DayCab)
TABLE OF CONTENTS
xxxiiiFloor/Search Lights (DayCab) Design 726
Interior Task Lighting (Map Light) (Separate map light
from cab dome)
Interior Task Lighting (Map Light) (Separate map light from cab dome) Design 727
Interior Task Lights (Map) (Cab Dome / Map Combo)
Interior Task Lights (Map) (Cab Dome / Map Combo) Design 728
Luggage Compartment Lights - W/O No Idle HVAC
(Horizon, HX)
Luggage Compartment Lights - W/O No Idle HVAC (Horizon, HX) Design 729
Luggage Compartment Lights - W/ No Idle HVAC
(Horizon, HX)
Luggage Compartment Lights - W/ No Idle HVAC (Horizon, HX) Design 730
Rear Interior Dimming (Accent
Light)(Horizon)(ProStar)
Rear Interior Dimming (Accent Light)(Horizon)(ProStar) Design 731
Rear Reading Lighting (Lower Bunk)
Rear Reading Lighting (Lower Bunk) Design 732
Axle Lift Controls (Customer Installed SPIF Controls)
Axle Lift Controls (Customer Installed SPIF Controls) Design 733
Axle Lift Controls (ELAM Module)
Axle Lift Controls (ELAM Module) Design 734
Axle Lift Controls (1 MUX Switch)
Axle Lift Controls (1 MUX Switch) Design 735
Axle Lift Controls (2 MUX Switches)
Axle Lift Controls (2 MUX Switches) Design 737
Axle Lift Controls (2 MUX Switches)(Post)
Axle Lift Controls (2 MUX Switches)(Post) Design 739
Axle Lift Controls (3 MUX Switches)
Axle Lift Controls (3 MUX Switches) Design 741
Axle Lift Pressure Monitoring (2 Virtual Gauges)
Axle Lift Pressure Monitoring (2 Virtual Gauges) Design 743
Axle Lift Pressure Monitoring (3 Virtual Gauges)
Axle Lift Pressure Monitoring (3 Virtual Gauges) Design 744
Axle Loading (Weight) (Rear, Horizon)
Axle Loading (Weight) (Rear, Horizon) Design 745
Axle Temperature (Tandem, Aux Gauges)
Axle Temperature (Tandem, Aux Gauges) Design 746
Axle Temperature (Tandem, Virtual Gauges)
Axle Temperature (Tandem, Virtual Gauges) Design 747
Axle Temperature (Tridem, Aux Gauges)
Axle Temperature (Tridem, Aux Gauges) Design 748
TABLE OF CONTENTS
xxxivAxle Temperature (Tridem, Virtual Gauges)
Axle Temperature (Tridem, Virtual Gauges) Design 750
Driver Controlled Locking Differential (Dana - 2
Control - 2 Feedback - FR&RR)
Driver Controlled Locking Differential (Dana - 2 Control - 2 Feedback - FR&RR)
Design 752
Driver Controlled Locking Differential (Meritor - 2
Control - 2 Feedback - FR&RR) Option 1
Driver Controlled Locking Differential (Meritor - 2 Control - 2 Feedback - FR&RR)
Option 1 Design 754
Control - 2 Feedback - FR&RR) Option 2
Option 2 Design 756
Driver Controlled Locking Differential - (Dana - 1
Control - 1 Feedback - RR)
Driver Controlled Locking Differential - (Dana - 1 Control - 1 Feedback - RR)
Design 758
Driver Controlled Locking Differential - (Dana - 1 Control - 2 Feedback - FR&RR)
Design 759
Driver Controlled Locking Differential - (Meritor - 1
Control - 1 Feedback - FR)
Driver Controlled Locking Differential - (Meritor - 1 Control - 1 Feedback - FR)
Design 761
Driver Controlled Locking Differential - (Meritor - 1 Control - 1 Feedback - RR)
Design 762
Driver Controlled Locking Differential - (Meritor - 1 Control - 2 Feedback -
FR&RR) Design 763
Control - 3 Feedback - FR&CR&RR)
Driver Controlled Locking Differential - (Meritor - 1 Control - 3 Feedback -
FR&CR&RR) Design 765
Driver Controlled Locking Differential - (Meritor - 3
Driver Controlled Locking Differential - (Meritor - 3 Control - 3 Feedback -
FR&CR&RR) Design 768
Seats - Climate Controlled (Drivers Heated Seat)
Seats - Climate Controlled (Drivers Heated Seat) Design 769
TABLE OF CONTENTS
xxxvSeats - Climate Controlled (Driver and Passenger
Heated Seat)
Seats - Climate Controlled (Driver and Passenger Heated Seat) Design 770
Seatbelt Reminder (Warning)(Driver only)(Horizon)
Seatbelt Reminder (Warning)(Driver only)(Horizon) Design 771
Seatbelt Reminder (Warning)(Driver & Passenger in
parallel)(Horizon)
Seatbelt Reminder (Warning)(Driver & Passenger in parallel)(Horizon) Design 772
Vehicle Data Recorder (N/Display, 2 front seats)
Vehicle Data Recorder (N/Display, 2 front seats) Design 773
Vehicle Data Recorder (N/VDR, N/Display, 2 front
seats)
Vehicle Data Recorder (N/VDR, N/Display, 2 front seats) Design 775
Vehicle Data Recorder (N/VDR, N/ Display, 3 seats)
Vehicle Data Recorder (N/VDR, N/ Display, 3 seats) Design 776
Vehicle Data Recorder (N/ Display, 3 front seats)
Vehicle Data Recorder (N/ Display, 3 front seats) Design 777
Vehicle Data Recorder (W/Display, 2 front seats)
Vehicle Data Recorder (W/Display, 2 front seats) Design 779
Vehicle Data Recorder (W/ Display, 3 front seats)
Vehicle Data Recorder (W/ Display, 3 front seats) Design 781
Auxiliary Trailer Power (BOC, ACC Bias)
Auxiliary Trailer Power (BOC, ACC Bias) Design 783
Auxiliary Trailer Power (POGO, ACC Bias)
Auxiliary Trailer Power (POGO, ACC Bias) Design 785
Auxiliary Trailer Power (w/ Park Brake) - POGO
Auxiliary Trailer Power (w/ Park Brake) - POGO Design 786
TEM _Electric Trailer Brake Controller Activated Stop
LT
TEM _Electric Trailer Brake Controller Activated Stop LT Design 787
Trailer Interface Lighting W/Combined Turns using
Blunt Cut
Trailer Interface Lighting W/Combined Turns using Blunt Cut Design 788
Trailer Interface Lighting W/Separate Turns using
Blunt Cut
Trailer Interface Lighting W/Separate Turns using Blunt Cut Design 789
Trailer Interface (ABS) (BOC and EOF TRLR Socket)
Trailer Interface (ABS) (BOC and EOF TRLR Socket) Design 790
Trailer Interface (ABS) (BOC TRLR Socket)
Trailer Interface (ABS) (BOC TRLR Socket) Design 792
Trailer Interface (ABS) (EOF TRLR Socket)
Trailer Interface (ABS) (EOF TRLR Socket) Design 794
TABLE OF CONTENTS
xxxviTrailer Interface (ABS) (POGO and EOF TRLR Socket)
Trailer Interface (ABS) (POGO and EOF TRLR Socket) Design 795
Trailer Interface (ABS) (POGO TRLR Socket)
Trailer Interface (ABS) (POGO TRLR Socket) Design 796
Trailer Interface (Lighting) - Combined Turns & Stop -
EOF (RING GND)
Trailer Interface (Lighting) - Combined Turns & Stop - EOF (RING GND)
Design 797
( Blunt Cut / EOF, RING GND)
Trailer Interface (Lighting) - Combined Turns & Stop - ( Blunt Cut / EOF, RING
GND) Design 798
Trailer Interface (Lighting) - Separate Turns - EOF
(RING GND)
Trailer Interface (Lighting) - Separate Turns - EOF (RING GND) Design 799
Trailer Interface (Lighting) – Separate Turns - BOC
Trailer Interface (Lighting) – Separate Turns - BOC Design 800
Trailer Interface (Lighting) – Separate Turns - BOC &
EOF (Ring Ground)
Trailer Interface (Lighting) – Separate Turns - BOC & EOF (Ring Ground)
Design 802
Trailer Interface (Lighting) – Separate Turns - POGO
Trailer Interface (Lighting) – Separate Turns - POGO Design 804
Trailer Interface (Lighting) – Separate Turns - POGO &
AUX
Trailer Interface (Lighting) – Separate Turns - POGO & AUX Design 805
EOF (Ring Ground)
Trailer Interface (Lighting) – Separate Turns - POGO & EOF (Ring Ground)
Design 806
Trailer Interface - ABS (ETB Feed, Blunt Cut)
Trailer Interface - ABS (ETB Feed, Blunt Cut) Design 807
Trailer Interface - (ABS) (ETB Feed, Blunt Cut / EOF
TRLR Socket)
Trailer Interface - (ABS) (ETB Feed, Blunt Cut / EOF TRLR Socket) Design 808
S13 - Auto Neutral (Allision N/ Switch & W/
Confirmation Telltale)
S13 - Auto Neutral (Allision N/ Switch & W/ Confirmation Telltale) Design 809
S13 - Auto Neutral (Allison W/ Multiplex Switch &
S13 - Auto Neutral (Allison W/ Multiplex Switch & Confirmation Telltale)
Design 810
Hill Start Aid (HSA)
Hill Start Aid (HSA) Design 811
TABLE OF CONTENTS
xxxvii2017 2021 A26- Transmission (Allison 3K/4K, 24-Volt)
2017 2021 A26- Transmission (Allison 3K/4K, 24-Volt) Design 812
2017/2021 A26 - Endurant Transmission
2017/2021 A26 - Endurant Transmission Design 813
2017/2021 A26 - Transmission (Allison 4K)
2017/2021 A26 - Transmission (Allison 4K) Design 814
2017/2021 A26 - Transmission (Ultrashift+ and FAS)
2017/2021 A26 - Transmission (Ultrashift+ and FAS) Design 815
2024 S13 - Transmission Electrical I/O(T14 TRANS)
2024 S13 - Transmission Electrical I/O(T14 TRANS) Design 816
2024 S13 - Transmission (Allison 3K/4K, 24-Volt)
2024 S13 - Transmission (Allison 3K/4K, 24-Volt) Design 817
2024 S13 - Transmission (Allison 4K)
2024 S13 - Transmission (Allison 4K) Design 818
2021 2024 X15 - Transmission (Allison 3K/4K, 24-Volt)
2021 2024 X15 - Transmission (Allison 3K/4K, 24-Volt) Design 819
2021/2024 X15 - Endurant Transmission
2021/2024 X15 - Endurant Transmission Design 820
2021/2024 X15 - Transmission (Allison 4K)
2021/2024 X15 - Transmission (Allison 4K) Design 821
2021/2024 X15 - Transmission (Ultrashift+ and FAS)
2021/2024 X15 - Transmission (Ultrashift+ and FAS) Design 822
S13 - Transmission Retarder (4K, Gen 6, W/ Multiplex)
S13 - Transmission Retarder (4K, Gen 6, W/ Multiplex) Design 823
S13 - Transmission Retarder (4700 W/ Multiplex)
S13 - Transmission Retarder (4700 W/ Multiplex) Design 824
S13 - Transmission Retarder (4700, Gen 6, W/
Multiplex)
S13 - Transmission Retarder (4700, Gen 6, W/ Multiplex) Design 825
Multiplex))
S13 - Transmission Retarder (4700, Gen 6, W/ Multiplex)) Design 826
2017/2021 A26 - Transmission Retarder (4K with
Multiplex)
2017/2021 A26 - Transmission Retarder (4K with Multiplex) Design 827
2017/2021 A26 - Transmission Retarder (4K, Gen 6, W/
Multiplex))
2017/2021 A26 - Transmission Retarder (4K, Gen 6, W/ Multiplex)) Design 828
2017/2021 A26 - Transmission Retarder (4700 W/
Multiplex)
2017/2021 A26 - Transmission Retarder (4700 W/ Multiplex) Design 829
TABLE OF CONTENTS
xxxviii2017/2021 A26 - Transmission Retarder (4700, Gen 6,
W/ Multiplex))
2017/2021 A26 - Transmission Retarder (4700, Gen 6, W/ Multiplex)) Design 830
2021/2024 X15 - Transmission Retarder (4K with
Multiplex)
2021/2024 X15 - Transmission Retarder (4K with Multiplex) Design 831
2021/2024 X15 - Transmission Retarder (4K, Gen 6, W/
Multiplex)
2021/2024 X15 - Transmission Retarder (4K, Gen 6, W/ Multiplex) Design 832
2021/2024 X15 - Transmission Retarder (4700 W/
Multiplex)
2021/2024 X15 - Transmission Retarder (4700 W/ Multiplex) Design 833
2021/2024 X15 - Transmission Retarder (4700, Gen 6,
W/ Multiplex)
2021/2024 X15 - Transmission Retarder (4700, Gen 6, W/ Multiplex) Design 834
2017/2021 A26 - Transfer Case (NAMCO PowerTower
W/ INTL Engines & N/ TCM)
2017/2021 A26 - Transfer Case (NAMCO PowerTower W/ INTL Engines & N/
TCM) Design 835
W/ INTL Engines & W/ TCM)
2017/2021 A26 - Transfer Case (NAMCO PowerTower W/ INTL Engines & W/
TCM) Design 836
2021/2024 X15 - Transfer Case (NAMCO Powertower
W/ Cummins & N/ TCM)
2021/2024 X15 - Transfer Case (NAMCO Powertower W/ Cummins & N/ TCM)
Design 837
W/ Cummins & W/ TCM)
2021/2024 X15 - Transfer Case (NAMCO Powertower W/ Cummins & W/ TCM)
Design 838
Transmission Shifter (INTL Transmission)(W/0013WET
& T14 TRANS)
Transmission Shifter (INTL Transmission)(W/0013WET & T14 TRANS)
Design 839
X15/A26 - Transmission Shifter (Dual Shifter with
primary being stalk)
X15/A26 - Transmission Shifter (Dual Shifter with primary being stalk) Design 840
2017/2021 A26 - Transmission Shifter (Stalk Shifter,
Eaton Endurant)
2017/2021 A26 - Transmission Shifter (Stalk Shifter, Eaton Endurant) Design 841
2017/2021 A26 - Transmission Shifter (Universal Stalk
Shifter - Allison 3K/4K)
2017/2021 A26 - Transmission Shifter (Universal Stalk Shifter - Allison 3K/4K)
Design 842
TABLE OF CONTENTS
xxxix2017/2021 A26 - Transmission Shifter (Universal Stalk
Shifter, Ultrashift)
2017/2021 A26 - Transmission Shifter (Universal Stalk Shifter, Ultrashift)
Design 843
2021/2024 X15 - Transmission Shifter (Stalk Shifter,
Eaton Endurant)
2021/2024 X15 - Transmission Shifter (Stalk Shifter, Eaton Endurant) Design 844
2021/2024 X15 - Transmission Shifter (Universal Stalk
2021/2024 X15 - Transmission Shifter (Universal Stalk Shifter - Allison 3K/4K)
Design 845
2021/2024 X15 - Transmission Shifter (Universal Stalk Shifter, Ultrashift)
Design 846
Windshield Washer Pump & Low Fluid Sensor
Windshield Washer Pump & Low Fluid Sensor Design 847
Heated Windshield
Heated Windshield Design 848
Heated Windshield (W/ DS Heating Grid)
Heated Windshield (W/ DS Heating Grid) Design 849
A26/X15 - Windshield Wipers
A26/X15 - Windshield Wipers Design 850
S13 - Windshield Wipers
S13 - Windshield Wipers Design 851
A26/S13 - Auto Start Stop and Sleeper Auto Climate,
Cab Temp, Oil Mapping, Manual Trans
A26/S13 - Auto Start Stop and Sleeper Auto Climate, Cab Temp, Oil Mapping,
Manual Trans Design 852
Cab Temp, Oil Mapping, Manual Transmission
Manual Transmission Design 853
A26/S13 - Auto Start Stop Battery & Oil Temp
Mapping, Auto Trans
A26/S13 - Auto Start Stop Battery & Oil Temp Mapping, Auto Trans Design 854
A26/S13 - Auto Start Stop with Sleeper Auto Climate,
Cab Temp, Oil Mapping, Auto Trans
A26/S13 - Auto Start Stop with Sleeper Auto Climate, Cab Temp, Oil Mapping,
Auto Trans Design 855
Cab Temp, Oil Mapping, Auto Transmission_
Auto Transmission_ Design 856
TABLE OF CONTENTS
xlA26/S13 - Auto Start Stop (Horizon) Battery, Oil Temp
A26/S13 - Auto Start Stop (Horizon) Battery, Oil Temp Mapping, Manual Trans
Design 857
X15 - Auto Start/Stop with Sleeper Auto Climate, Cab
Temp, X15 with Oil Temp Sensor, Auto Trans
X15 - Auto Start/Stop with Sleeper Auto Climate, Cab Temp, X15 with Oil Temp
Sensor, Auto Trans Design 858
Temp, X15 with Oil Temp Sensor, Auto Transmission
Sensor, Auto Transmission Design 859
Temp, X15 with Oil Temp Sensor, Manual Trans
Sensor, Manual Trans Design 860
Sensor, Manual Transmission Design 861
X15 - Auto Start/Stop (Horizon) Oil Temp Sensor, Auto
Trans
X15 - Auto Start/Stop (Horizon) Oil Temp Sensor, Auto Trans Design 862
X15 - Auto Start/Stop (Horizon) Oil Temp Sensor, X15,
Auto Trans
X15 - Auto Start/Stop (Horizon) Oil Temp Sensor, X15, Auto Trans Design 863
Manual Trans
X15 - Auto Start/Stop (Horizon) Oil Temp Sensor, X15, Manual Trans Design 864
Manual Transmission
X15 - Auto Start/Stop (Horizon) Oil Temp Sensor, X15, Manual Transmission
Design 865
Battery Disconnect
Battery Disconnect Design 866
Battery Management System (12/24V 3 or 4 Battery
System)
Battery Management System (12/24V 3 or 4 Battery System) Design 867
Battery Management System (12/24V 8-Battery
System)
Battery Management System (12/24V 8-Battery System) Design 868
A26 - Charging System (Delco Remy 36SI Alternator
W/ Remote Sense)
A26 - Charging System (Delco Remy 36SI Alternator W/ Remote Sense)
Design 869
TABLE OF CONTENTS
xliA26 - Charging System (Delco Remy 40SI/38SI
A26 - Charging System (Delco Remy 40SI/38SI Alternator W/ Remote Sense)
Design 870
A26 - Charging System (Delco Remy & Mitsubishi
A26 - Charging System (Delco Remy & Mitsubishi Alternator W/ Remote Sense)
Design 871
A26 - Charging System (Leece-Neville AVI160 160A W/
Remote Sense)
A26 - Charging System (Leece-Neville AVI160 160A W/ Remote Sense)
Design 872
A26 - Charging System (Leece-Neville AVI160-
160A/240A N/ Remote Sense)
A26 - Charging System (Leece-Neville AVI160-160A/240A N/ Remote Sense)
Design 873
190A/210A/240A Alternator W/ Remote Sense)
A26 - Charging System (Leece-Neville AVI160-190A/210A/240A Alternator W/
Remote Sense) Design 874
A26 - Charging System (Leece-Neville 320PAH
Alternator)
A26 - Charging System (Leece-Neville 320PAH Alternator) Design 875
A26 - Charging System (Leece-Neville - LN 325A
A26 - Charging System (Leece-Neville - LN 325A Alternator W/ Remote Sense)
Design 876
A26 - Charging System (LH160_LH200)
A26 - Charging System (LH160_LH200) Design 877
A26 - Charging System (LIL165_LIL200 Alternator W/
Remote Sense)
A26 - Charging System (LIL165_LIL200 Alternator W/ Remote Sense) Design 878
Charging System (Leece-Neville AVI160-160A W/
Skelstart & N/ Remote Sense)
Charging System (Leece-Neville AVI160-160A W/ Skelstart & N/ Remote Sense)
Design 879
S13 - Charging System (Delco Remy & Mitsubishi
S13 - Charging System (Delco Remy & Mitsubishi Alternator W/ Remote Sense)
Design 881
2021/2024 X15 - Charging System (Delco Remy 36SI
2021/2024 X15 - Charging System (Delco Remy 36SI Alternator W/ Remote
Sense) Design 882
TABLE OF CONTENTS
xlii2021/2024 X15 - Charging System (Delco Remy 40SI/38SI Alternator W/ Remote
Sense) Design 883
2021/2024 X15 - Charging System (Delco Remy &
2021/2024 X15 - Charging System (Delco Remy & Mitsubishi Alternator W/
Remote Sense) Design 884
2021/2024 X15 - Charging System (Leece-Neville
2021/2024 X15 - Charging System (Leece-Neville AVI160 160A W/ Remote
Sense) Design 885
2021/2024 X15 - Charging System (Leece-Neville AVI160-160A/240A N/ Remote
Sense) Design 886
AVI160-190A/210A/240A Alternator W/ Remote Sense)
2021/2024 X15 - Charging System (Leece-Neville AVI160-190A/210A/240A
Alternator W/ Remote Sense) Design 887
320PAH Alternator)
2021/2024 X15 - Charging System (Leece-Neville 320PAH Alternator) Design 888
2021/2024 X15 - Charging System (Leece-Neville - LN
2021/2024 X15 - Charging System (Leece-Neville - LN 325A Alternator W/
Remote Sense) Design 889
2021/2024 X15 - Charging System (LH160_LH200)
2021/2024 X15 - Charging System (LH160_LH200) Design 890
2021/2024 X15 - Charging System (LIL165_LIL200
2021/2024 X15 - Charging System (LIL165_LIL200 Alternator W/ Remote Sense)
Design 891
A26 - Cranking (Starter) (BCM Controlled & N/ Wired
Thermal Overcrank)
A26 - Cranking (Starter) (BCM Controlled & N/ Wired Thermal Overcrank)
Design 892
Thermal Over-Crank)
A26 - Cranking (Starter) (BCM Controlled & N/ Wired Thermal Over-Crank)
Design 893
A26 - Cranking (Starter) (BCM Controlled & W/ Wired
Thermal Overcrank)
A26 - Cranking (Starter) (BCM Controlled & W/ Wired Thermal Overcrank)
Design 894
Thermal Overcrank)
Design 895
TABLE OF CONTENTS
xliiiA26 - Cranking (Starter) (BCM Controlled & W/ Wired
Thermal Overcrank, Skelstart)
A26 - Cranking (Starter) (BCM Controlled & W/ Wired Thermal Overcrank,
Skelstart) Design 896
Cranking (Starter) (Mitsubishi 90P, 24V)
Cranking (Starter) (Mitsubishi 90P, 24V) Design 897
S13 - Cranking (Starter) (BCM Controlled & N/ Wired
Thermal Overcrank)
S13 - Cranking (Starter) (BCM Controlled & N/ Wired Thermal Overcrank)
Design 898
2021/2024 X15 - Cranking (Starter) (BCM Controlled &
2021/2024 X15 - Cranking (Starter) (BCM Controlled & N/ Wired Thermal
Overcrank) Design 899
2021/2024 X15 - Cranking (Starter) (BCM Controlled & N/ Wired Thermal OverCrank) Design 900
2021/2024 X15 - Cranking (Starter) (BCM Controlled & W/ Wired Thermal
Overcrank) Design 901
Overcrank) Design 902
W/ Wired Thermal Overcrank, Skelstart)
Overcrank, Skelstart) Design 903
DC/AC Inverter (with switch control)
DC/AC Inverter (with switch control) Design 904
DC/AC Inverter (1800/2000 Watts)
DC/AC Inverter (1800/2000 Watts) Design 905
Operator Input (Key Switch)
Operator Input (Key Switch) Design 906
A26 - Starter Interlocks (Service Brake Interlock)
A26 - Starter Interlocks (Service Brake Interlock) Design 907
A26 - Starter Interlock (BCM LSD Controlled w/ Relay
& N/ Neutral Switch)
A26 - Starter Interlock (BCM LSD Controlled w/ Relay & N/ Neutral Switch)
Design 908
Relay)_EATON XMSN
TABLE OF CONTENTS
xlivA26 - Starter Interlock (BCM LSD Controlled w/ Relay)_EATON XMSN Design909
2021/2024 X15 - Starter Interlocks (Service Brake
Interlock)
2021/2024 X15 - Starter Interlocks (Service Brake Interlock) Design 910
2021/2024 X15 - Starter Interlock (BCM LSD
2021/2024 X15 - Starter Interlock (BCM LSD Controlled w/ Relay & N/ Neutral
Switch) Design 911
2021/2024 X15 - Starter Interlock (BCM LSD Controlled w/ Relay)_EATON XMSN
Design 912
Clutch Monitoring (High and Low Switch to BCM)
Clutch Monitoring (High and Low Switch to BCM) Design 913
Crank Inhibit (W/ Hood Switch)
Crank Inhibit (W/ Hood Switch) Design 914
Hood Switch
Hood Switch Design 915
A26 - Starter Interlock (BCM HSD CTRL W/ Clutch
Switch W/ Neutral Switch)
A26 - Starter Interlock (BCM HSD CTRL W/ Clutch Switch W/ Neutral Switch)
Design 916
2021/2024 X15 - Starter Interlock (BCM HSD CTRL W/
2021/2024 X15 - Starter Interlock (BCM HSD CTRL W/ Clutch Switch W/ Neutral
Switch) Design 917
Battery International (3) 12V
Battery International (3) 12V Design 918
Battery International (4) 12V
Battery International (4) 12V Design 919
Battery International (8) 12V
Battery International (8) 12V Design 920
Connectors 921
Index 295
