International Truck HX Series Electrical Diagrams 0000018081 2021
Brand: International, Navistar
Type of Manual: Electrical Circuit Diagrams
Model: International HX Series Truck
Engine Family: International A26, 2013 N13, Cummins 2013 / 2017 ISX, Cummins, X15 Engines
Part Number: 0000018081
Publication Date: 2021
Number of Pages: 498 Pages
2. Instructions And Charts (Chapter 2)
2.1. Abbreviations, P. 1
2.2. Acronyms, P. 2
2.3. Circuit Diagram Instructions, P. 3
2.4. Circuit Number Identification And Color, P. 4
2.5. Circuit Number Identification And Color (Cont.), P. 5
2.6. Circuit Number Identification And Color (Cont.), P. 6
2.7. Circuit Number Identification And Color (Cont.), P. 6a
2.8. Circuit Number Identification And Color (Cont.), P. 6b
2.9. Circuit Number Identification And Color (Cont.), P. 6c
2.10. Lamp Bulb Chart, P. 7
2.11. Relay Function And Wiring Guide, P. 8
2.12. Schematic Symbol Chart, P. 9
2.13. Schematic Symbol Chart (Cont.), P. 10
2.14. Schematic Symbol Chart (Cont.), P. 11
2.15. Schematic Symbol Chart (Cont.), P. 12
2.16. Switches And Product Graphic Information, P. 13
2.17. Switches And Product Graphic Information (Cont.), P. 13a
2.18. Product Graphic, Fuse Panel, Upper (4134361c1), P. 14
2.19. Product Graphic, Fuse Panel, Lower (4123214c3), P. 15
2.20. Pto Switches (3881412c1), P. 16
3. 12 Volt Power Distribution (Chapter 3)
3.1. Battery Feed, P. 1
3.2. Battery Feed (Cont.), P. 2
3.3. Battery Feed (Cont.), P. 3
3.4. Battery Feed (Cont.), P. 4
3.5. Battery Feed (Cont.), P. 5
3.6. Accessory Feed, P. 6
3.7. Ignition Feed, P. 7
3.8. Ignition Feed (Cont.), P. 8
3.9. Ignition Feed (Cont.), P. 9
3.10. Ignition Feed (Cont.), P. 10
3.11. Ignition Feed (Cont.), P. 11
3.12. J1939 Wiring With 500k Baud Rate, P. 12
3.13. J1939 Wiring With 500k Baud Rate (Cont.), P. 13
3.14. J1939 Data Link Wiring With 250k, P. 14
3.15. J1939 Wiring With Bendix Abs With 500k Baud Rate, P. 15
3.16. J1939 Wiring With Allison Transmission, P. 16
3.17. Five And Zero Volt Source Splice Pack, P. 17
3.18. Ground Ñ Ip, P. 18
3.19. Ground Ñ Ip (Cont.), P. 19
3.20. Ground Ñ Ip (Cont.), P. 20
3.21. Ground Ñ Ip (Cont.), P. 20a
3.22. Ground Ñ Ip (Cont.), P. 21
3.23. Ground Ñ Ip (Cont.), P. 22
3.24. Ground Ñ Ip (Cont.), P. 23
3.25. Ground Ñ Ip (Cont.), P. 24
3.26. Ground Ñ Ip (Cont.), P. 25
3.27. Ground Ñ Ip (Cont.), P. 26
3.28. Ground Ñ Ip (Cont.), P. 27
3.29. Ground Ñ Ip (Cont.), P. 28
3.30. Ground Ñ Ip (Cont.), P. 29
3.31. Ground Ñ Ip (Cont.), P. 30
3.32. Panel Light Adapter, P. 31
3.33. Panel Light Adapter (Cont.), P. 32
3.34. Panel Light Adapter (Cont.), P. 33
3.35. Panel Light Adapter (Cont.), P. 33a
3.36. Ignition Splice Pack, P. 34
3.37. Ignition Splice Pack (Cont.), P. 35
3.38. Start Feed Adapter, P. 36
3.39. Ground Ñ Chassis, P. 37
3.40. Ground Ñ Chassis (Cont.), P. 38
3.41. Ground Ñ Chassis (Cont.), P. 39
3.42. Ground Ñ Chassis (Cont.), P. 40
3.43. Ground Ñ Chassis (Cont.), P. 41
3.44. Ground Ñ Chassis (Cont.), P. 42
3.45. Ecm 5v And Ov Splice With 2013 N13 Engine, P. 43
3.46. Power Ignition Splice, P. 44
3.47. Ground Ñ Engine With 2013 N13 Engine, P. 45
3.48. Ground Ñ Engine With F-2013 Isx Engine, P. 46
3.49. Ground Ñ Engine With F-2013 Isx Engine (Cont.), P. 47
3.50. Engine Cab Power, P. 48
3.51. Ground Ñ Engine With 2017 Isx Eng, P. 49
3.52. Ground Ñ Sleeper Box, P. 50
3.53. Ecm 0v & 5v Splice With A26 Engine, P. 51
3.54. Ground Engine A26 Engine, P. 52
3.55. Ground Engine A26 Engine (Cont.), P. 53
3.56. Effects Of Auxiliary Switches W / 10 With Accessory, P. 54
3.57. Effects Of Auxiliary Switches W / 10 With Accessory (Cont.), P. 55
4. Cab Accessories (Chapter 4)
4.1. Cigar Lighter Connection, P. 1
4.2. Receptacle And 2 Post Power Source, P. 2
4.3. Electric Window Ñ Right And Left, P. 3
4.4. Keyless Entry With Horn Wiring, P. 4
4.5. Electric Lock Ñ Right And Left With Power Window, P. 5
4.6. Electric Lock Ñ Right And Left With Power Window With Remote
Keyless Entry, P. 6
4.7. Heated, Power With Mirrors Light, P. 7
4.8. Heated, Power With Mirrors Light (Cont.), P. 8
4.9. Heated, Power With Mirrors Light With Ambient Air Temperature
(Aat), P. 9
4.10. Heated, Power With Mirrors Light, P. 10
4.11. Heated Driver And Passenger Seat, P. 11
4.12. Windshield Wiper Motor And Washer Pump Wiring, P. 12
4.13. Cb Radio Power, P. 13
4.14. 2 Way Radio Connection, P. 14
4.15. Radio Day Cab Speaker Wiring, P. 15
4.16. Sleeper Box With Speaker Wiring With Volume Control, P. 15a
4.17. Secondary Display Connections With Bluetooth, P. 16
4.18. Day Cab With Qualcomm Speaker Wiring, P. 16a
4.19. Peoplenet Communication Wiring, P. 17
4.20. Sleeper Box With Remote Radio, P. 18
4.21. Qualcomm Omnivision, P. 19
4.22. Sleeper Box With Auxiliary Radio Control With Did, P. 20
4.23. Radio Can Bus With Auxiliary Radio Control, P. 20a
4.24. Standard Apo, P. 21
4.25. Sleeper Box With Auxiliary Power And Tv / Vcr, P. 22
4.26. Rolltek Seating Wiring, P. 23
4.27. Data Recorder Wiring, P. 24
4.28. Data Recorder Wiring (Cont.), P. 24a
4.29. Rolltek Seat, P. 25
4.30. Rsm Heated Hood Mirror, P. 26
4.31. Rsm And Lsm Heated Hood Mirror, P. 27
4.32. Rsm And Lsm Heated Hood Mirror (Cont.), P. 28
5. Charging And Cranking (Chapter 5)
5.1. Starting And Cranking With Ultrashift Transmission With F-2013-Isx
Engine, P. 1
5.2. Starting And Cranking With Manual Transmission With F-2013-Isx
Engine, P. 2
5.3. Starting And Cranking With Allison Transmission With F-2013-Isx
Engine, P. 3
5.4. Starting And Cranking With 2013 N13 Engine With Ultrashift
Transmission Without Thermal Overcrank, P. 4
5.5. Starting And Cranking With 2013 N13 Engine With Manual Transmission
With Thermal Overcrank, P. 5
5.6. Starting And Cranking With 2013 N13 Engine With Allison Transmission
Without Thermal Overcrank, P. 6
5.7. Starting And Cranking With Ultrashift Transmission With F-2017 Isx
Engine, P. 7
5.8. Starting And Cranking With Manual Transmission With F-2017 Isx
Engine, P. 8
5.9. Starting And Cranking With Allison Transmission With F-2017 Isx
Engine, P. 9
5.10. Starting And Cranking With Manual Transmission With Thermal
Overcrank A26 Engine, P. 10
5.11. Starting And Cranking With Ultrashift Transmission Without
Thermal Overcrank A26 Engine, P. 11
5.12. Starting And Cranking With Allison Transmission Without Thermal
Overcrank A26 Engine, P. 12
6. Fan Wiring (Chapter 6)
6.1. Fan Wiring Without A/C With F-2013, 2017 Isx Engine, P. 1
6.2. Fan Wiring With A/C, Fan Override Switch Without Air Conditioning
Protection And Diagnostic System (Apads) With F-2013, 2017 Isx Engine,
P. 2
6.3. Fan Wiring With A/C With Apads With F-2013, 2017 Isx Engine, P. 3
6.4. Fan Wiring With Two Speed With 2013 N13 Engine, P. 4
6.5. Fan Wiring With A/C, Fan Override With F-2010 Scr 13l Engine, P. 5
6.6. Fan Wiring Without A/C, With F-2010 Scr 13l Engine, P. 5a
6.7. Fan Wiring With Apads With 2013 N13 Engine, P. 6
6.8. Fan Wiring With Override Switch, P. 7
6.9. Sleeper Box With Auxiliary Fan Connections, P. 8
6.10. Fan Wiring With A/C Apads With A26 Engine, P. 9
6.11. Fan Wiring With Two Speed A26 Engine, P. 10
6.12. Fan Wiring With Defroster A26 Engine, P. 11
7. Engine Systems (Chapter 7)
7.1. Cruise Control With F-2013 Isx Engine, P. 1
7.2. Cruise Control With F-2013 Isx Engine (Cont.), P. 2
7.3. Cruise Control With F-2013 Isx Engine (Cont.), P. 3
7.4. Accelerator Wiring With F-2013 Isx Engine, P. 4
7.5. Diesel Exhaust Fluid (Def) And Aftertreatment With F-2013 Isx Engine,
P. 5
7.6. Def And Aftertreatment With F-2013 Isx Engine (Cont.), P. 6
7.7. Def And Aftertreatment With F-2013 Isx Engine (Cont.), P. 7
7.8. Def And Aftertreatment With F-2013 Isx Engine (Cont.), P. 8
7.9. Def And Aftertreatment With F-2013-Isx Engine (Cont.), P. 9
7.10. Def And Aftertreatment With F-2013-Isx Engine (Cont.), P. 10
7.11. Power Distribution Module (Pdm) Product Graphics With F-2013-Isx
Engine, P. 11
7.12. Cruise Control With 2013 N13 Engine, P. 12
7.13. Power Take Off (Pto) Remote Control With 2013 N13 Engine, P. 13
7.14. Accelerator Wiring With 2013 N13 Engine, P. 14
7.15. Electronic Control Module With 2013 N13 Engine, P. 15
7.16. Def And Aftertreatment With 2013 N13 Engine, P. 16
7.17. Def And Aftertreatment With 2013 N13 Engine (Cont.), P. 17
7.18. Def And Aftertreatment With 2013 N13 Engine (Cont.), P. 18
7.19. Def And Aftertreatment With 2013 N13 Engine (Cont.), P. 19
7.20. Def And Aftertreatment With 2013 N13 Engine (Cont.), P. 20
7.21. Pdm Product Graphics With 2013 N13 Engine, P. 21
7.22. J1939 Connection With 250k With 2013 N13 Engine, P. 22
7.23. J1939 Connection With 500k With 2013 N13 Engine, P. 23
7.24. Starting Aid With Flame Start 2010 N13 Engines, P. 24
7.25. Transfer Case With 2013 N13 Engine, P. 25
7.26. Engine Brake Wiring, P. 26
7.27. Transmission Control Wiring, P. 27
7.28. Aftertreatment Park And Inhibit Switch Wiring, P. 28
7.29. Remote Voltage Sensor, P. 29
7.30. Cruise Control With F-2017 Isx Engine, P. 30
7.31. Cruise Control With F-2017 Isx Engine (Cont.), P. 31
7.32. Accelerator Wiring With F-2017 Isx Engine, P. 32
7.33. Diesel Exhaust Fluid (Def) And Aftertreatment With F-2017 Isx Engine,
P. 33
7.34. Def And Aftertreatment With F-2017 Isx Engine (Cont.), P. 34
7.35. Def And Aftertreatment With F-2017 Isx Engine (Cont.), P. 35
7.36. Def And Aftertreatment With F-2017 Isx Engine (Cont.), P. 36
7.37. Power Distribution Module (Pdm) Product Graphics With F-2017 Isx
Engine, P. 37
7.38. Underhood Pdm With F-2017 Isx Engine, P. 38
7.39. Underhood Pdm With F-2017 Isx Engine (Cont.), P. 39
7.40. Intentionally Left Blank, P. 40
7.41. Cruise Control With Remote Cruise Control F 2017 Isx Engine, P. 41
7.42. Cruise Control With Remote Cruise Control A26 Engine, P. 41a
7.43. Cruise Control Without Remote Cruise Control A26 Engine, P. 42
7.44. Pto Remote Control With A26 Engine, P. 43
7.45. Electronic Control Module With A26 Engine, P. 44
7.46. Electronic Control Module With A26 Engine (Cont.), P. 45
7.47. Def And Aftertreatment With A26 Engine, P. 46
7.48. Def And Aftertreatment With A26 Engine (Cont.), P. 47
7.49. Def And Aftertreatment With A26 Engine (Cont.), P. 48
7.50. Aftertreatment Horizontal Exhaust With A26 Engine, P. 49
7.51. Pdm Product Graphics With A26 Engine, P. 50
7.52. Underhood Pdm With A26 Engine, P. 51
7.53. Underhood Pdm Product Graphic With A26 Engine, P. 52
7.54. Starting Air With Flame Start With A26 Engine, P. 53
8. Gauges And Warning Lights (Chapter 8)
8.1. Gauges Ñ Cluster Connector, P. 1
8.2. Brake Application Gauge Wiring, P. 2
8.3. Suspension Gauge With Tridem, P. 3
8.4. Rear Axle Temperature Gauge With Tridem, P. 4
8.5. Two Speed Axle, P. 5
8.6. Power Divider Lock, P. 6
8.7. Fuel Heater, P. 7
8.8. Fuel And Temperature Senders, P. 8
8.9. Air Filter Restriction Gauge Warning, P. 9
8.10. Fuel Water Separator With F-2013, 2017-Isx Engine, P. 10
8.11. Transmission Oil Temperature And With Advantage Series
Transmission With F-2013, 2017-Isx Engine, P. 11
8.12. Fuel Water Separator With 2013 N13 Engine, P. 12
8.13. Two Speed Axle, P. 13
8.14. Transmission Oil Temperature & Advantage Transmission A26 Engine,
P. 14
8.15. Fuel / Water Separator Davco & Racor A26 Engine, P. 15
9. Lighting System (Chapter 9)
9.1. Backup Light With Allison And Ultrashift Transmission With Isx 2013,
2017 Engine Or A26 Engine, P. 1
9.2. Headlight, Auxiliary Light, And Panel Light Switch, P. 2
9.3. Headlight Wiring With Auxiliary Lights, P. 3
9.4. Headlight Wiring Without Auxiliary Lights, P. 4
9.5. Headlight Wiring With Set Back Axle, P. 5
9.6. Headlight Wiring With Set Back Axle (Cont.), P. 6
9.7. Headlight Wiring With Set Front Axle, P. 7
9.8. Headlight Wiring With Set Front Axle (Cont.), P. 8
9.9. Fog Lights, P. 9
9.10. Courtesy Lights, P. 10
9.11. Day Cab Work Lights, P. 11
9.12. Sleeper Box With Work Lights, P. 11a
9.13. Cargo Lights And Work Lights, P. 11b
9.14. Modesty Lights And Sunshade Clearance Lights, P. 12
9.15. Beacon Lights, P. 13
9.16. Dome Lights, P. 14
9.17. Tail, Turn, And Stop Lights, P. 15
9.18. Turn Lights, P. 16
9.19. Turn Signal Wiring And Hazard Light Switch, P. 17
9.20. Left And Right Turn Relay Splice Pack, P. 18
9.21. Lights Ñ Cluster Connectors, P. 19
9.22. Tail / Clearance Splice Pack, P. 20
9.23. Tail / Clearance Splice Pack (Cont.), P. 20a
9.24. Marker Interrupt And Exterior Lamp Check Switch, P. 21
9.25. Switched Power Feed, P. 22
9.26. Switched Power Feed (Cont.), P. 22a
9.27. Customer Defined Auxiliary Switch, P. 23
9.28. Customer Defined Auxiliary Switch (Cont.), P. 24
9.29. Customer Defined Auxiliary Switch (Cont.), P. 25
9.30. Customer Defined Auxiliary Switch (Cont.), P. 25a
9.31. Customer Defined Auxiliary Switch (Cont.), P. 25b
9.32. Sleeper Box With Skirt Light Connections, P. 26
9.33. Sleeper Box With Luggage Lights Connections, P. 27
9.34. Sleeper Box With Luggage Lights Connections (Cont.), P. 28
9.35. Sleeper Box With Dome And Reading Light, P. 29
9.36. Sleeper Box With Dome And Reading Light (Cont.), P. 30
9.37. Sleeper Box With Turn And Marker Lights A26 Engine, P. 31
9.38. Customer Supplied Worklight, P. 32
9.39. Customer Supplied Worklight (Cont.), P. 33
9.40. Back Up Light With Customer Worklight, P. 34
10. Chassis Accessories (Chapter 10)
10.1. Air Dryer And Heated Drain Valve, P. 1
10.2. Differential Warning Lights, P. 2
10.3. Differential Warning Lights (Cont.), P. 3
10.4. Air Switches, P. 4
10.5. Brake Wiring, P. 5
10.6. Bendix Electronic Stability Program (Esp) Wiring With Tractor
Brakes With Ultrashift Transmission, P. 6
10.7. Bendix Esp Wiring With Tractor Brakes With Ultrashift Transmission
(Cont.), P. 7
10.8. Bendix Esp Wiring With Tractor Brakes With Ultrashift Transmission
(Cont.), P. 8
10.9. Bendix Esp Wiring With Tractor Brakes With Ultrashift Transmission
(Cont.), P. 9
10.10. Bendix Esp Wiring With Tractor Brakes With Ultrashift Transmission
(Cont.), P. 10
10.11. Bendix Esp Wiring With Tractor Brakes With Ultrashift Transmission
(Cont.), P. 11
10.12. Bendix Esp Wiring With Tractor Brakes With Ultrashift Transmission
(Cont.), P. 12
10.13. Hill Start Aid Switch, P. 13
10.14. Lift Axle Latch And Reverse Relay, P. 14
10.15. Lift Axle Wiring With One Axle, P. 15
10.16. Lift Axle Wiring With Two Axles, P. 16
10.17. Lift Axle Wiring With Three Axles, P. 17
10.18. Tag Axle Wiring, P. 18
10.19. Pusher Axle Wiring, P. 19
10.20. Body Builder Lighting Wiring, P. 20
10.21. Body Builder Lighting Wiring (Cont.), P. 21
10.22. Body Builder Lighting Wiring (Cont.), P. 22
10.23. Body Builder Lighting Wiring (Cont.), P. 23
10.24. Auxiliary Trailer Socket Wiring, P. 24
10.25. Standard Back Of Cab (Boc) Trailer Socket Wiring, P. 25
10.26. End Of Frame (Eof) Trailer Socket Wiring, P. 26
10.27. Standard Boc And Eof Trailer Socket Wiring, P. 27
10.28. Trailer Socket Ground, P. 28
10.29. Trailer Stop And Abs Trailer Relay, P. 29
10.30. Bendix Wingman Advanced Wiring, P. 30
10.31. Sleeper Box With Trailer Socket, P. 31
10.32. Sleeper Box With Trailer Socket (Cont.), P. 32
10.33. Trailer Socket With Auxiliary 7 Way, P. 33
10.34. Trailer Socket With Etb, P. 33a
10.35. Bendix Fusion Wiring With Day Cab And Sleeper Cab, P. 34
10.36. Bendix Fusion Wiring With Day Cab And Sleeper Cab (Cont.), P. 35
10.37. Bendix Fusion Wiring (Cont), P. 36
10.38. J1939 Wiring With Allison Transmission With Bendix Fusion Display
Relocate, P. 37
10.39. J1939 Wiring With Allison Transmission With Bendix Fusion, P. 37a
10.40. Bendix Fusion Power & Ground To Diu, P. 38
10.41. Lift Axle Wiring, With Auto Raise In Reverse, P. 39
10.42. Lift Axle Wiring, With 2 Axles And Auto Raise In Reverse, P. 40
10.43. J1939 Wiring With Eaton Transmission With Bendix Fusion 500k, P. 41.
10.44. J1939 Wiring With Eaton Transmission With Bendix Fusion 250k, P. 42.
10.45. Customer Supplied Worklight, P. 43
10.46. Customer Supplied Worklight (Cont.), P. 44
10.47. Electric Trailer Brake Wiring Without Auxiliary Circuit, P. 45
11. Transmission Control Module (Chapter 11)
11.1. Allison Transmission, P. 1
11.2. Allison Transmission (Cont.), P. 2
11.3. Allison Transmission (Cont.), P. 3
11.4. Allison Transmission (Cont.), P. 4
11.5. Allison Transmission With 500k With Eof Shifter With F-2013-Isx
Engine, P. 5
11.6. Allison Transmission With 500k With Retarder With Eof Shifter With
F-2013-Isx Engine, P. 6
11.7. Allison Transmission With 500k With Retarder Without Eof Shifter
With F-2013-Isx Engine, P. 7
11.8. Ultrashift Transmission With 500k With F-2013-Isx Engine, P. 8
11.9. Manual Transmission With F-2013-Isx Engine, P. 9
11.10. Allison Transmission With 2013 N13 Engine, P. 10
11.11. Allison Transmission With 2013 N13 Engine (Cont.), P. 11
11.12. Ultrashift Transmission With 2013 N13 Engine, P. 12
11.13. Allison Transmission With 500k With F-2017 Isx Engine, P. 13
11.14. Allison Transmission With 500k With F-2017 Isx Engine (Cont.), P. 14
11.15. Allison Transmission With 500k With F-2017 Isx Engine (Cont.), P. 15
11.16. Ultrashift Transmission With 500k With F-2017 Isx Engine, P. 16
11.17. Manual Transmission With 500k With F-2017 Isx Engine, P. 17
11.18. Manual Transmission With A26 Engine, P. 18
11.19. Allison Transmission With 4k &4700 With A26 Engine, P. 19
11.20. Allison Transmission I / O Spare With A26 Engine, P. 20
11.21. Allison Transmission I / O Spare With A26 Engine (Cont.), P. 21
11.22. Allison 4700 Transmission With 500k With A26 Engine, P. 22
11.23. Allison Transmission With Retarder A26 Engine, P. 23
11.24. Ultrashift Vocational Performance A26 Engine, P. 24
11.25. Ultrashift Vocational Performance A26 Engine (Cont.), P. 25
11.26. Allison I/O With Transmission Pto Switch, P. 26
11.27. Road Speed W / 2017 Isx Eng, P. 27
12. Hvac (Chapter 12)
12.1. Hvac Wiring Ñ Cab With Cummins Isx, 2013 N13 And A26 Engine, P. 1
12.2. Hvac Wiring Ñ Heater Cab, P. 2
12.3. Hvac Wiring Ñ Heater Cab (Cont.), P. 3
12.4. Hvac Wiring Ñ With Air Conditioning Protection And Diagnostic
System (Apads) With Cummins Isx, 2013 N13 And A26 Engine, P. 4
12.5. Sleeper Box With Hvac Connection, P. 5
12.6. Sleeper Box With Hvac Connection (Cont.), P. 6
13. Connector Composites (Chapter 13)
13.1. Connector Composites (1), P. 1
13.2. Connector Composites (1m / 2), P. 2
13.3. Connector Composites (2), P. 2a
13.4. Connector Composites (2) (Cont.), P. 2b
13.5. Connector Composites (2m), P. 3
13.6. Connector Composites (3 / 3m / 4m / 8a / 9m), P. 4
13.7. Connector Composites (4m, 8a, 9m, 16b), P. 4a
13.8. Connector Composites (18m / 20 / 40m / 48 / 49 / 71), P. 5
13.9. Connector Composites (72 / 76m / 90m), P. 5a
13.10. Connector Composites (101 / 100m3 ), P. 6
13.11. Connector Composites (105f), P. 6a
13.12. Connector Composites (105m), P. 7
13.13. Connector Composites (105m), P. 7a
13.14. Connector Composites (110 / 110a), P. 8
13.15. Connector Composites (110a / 110b / 110c / 112 / 115), P. 8a
13.16. Connector Composites (116 / 117 / 118 / 141f / 161m / 162f), P. 8b
13.17. Connector Composites (190), P. 9
13.18. Connector Composites (190) (Cont.), P. 9a
13.19. Connector Composites (190m / 203 / 204 / 205), P. 10
13.20. Connector Composites (227 / *228 / %228 / *236 / 254m / 267m / *275), P. 11
13.21. Connector Composites (289f / 289f2 / 289f3 / 290f / 291f / 292f / 292f1 /
294a / 294f), P. 12
13.22. Connector Composites (303m / 344 / 345f/ 369 / 371 / 372m), P. 13
13.23. Connector Composites (374m / 400 / 401 / 417 / 418), P. 14
13.24. Connector Composites (421m / 422m / 425m), P. 15
13.25. Connector Composites (426), P. 15a
13.26. Connector Composites (427 / 428 / 428f), P. 16
13.27. Connector Composites (429 / *430), P. 17
13.28. Connector Composites (430 / 433m / 434m), P. 18
13.29. Connector Composites (435m / 436m / 438m / 439m / 440m), P. 19
13.30. Connector Composites (441m / 443 / 443m / 444m / 445m), P. 20
13.31. Connector Composites (448m / 449m / 450m / 451m), P. 21
13.32. Connector Composites (452m / 453m / 454m), P. 22
13.33. Connector Composites (455m / 456m / 457m / 458m), P. 23
13.34. Connector Composites (459m / 460m / 461m / 465m), P. 24
13.35. Connector Composites (467 / 471 / 480m / 481m / 482m / 483m / 484m), P. 25
13.36. Connector Composites (485m / 490m / 491 / 491m), P. 26
13.37. Connector Composites (492 / 493 / 494 / 503m), P. 26a
13.38. Connector Composites (504m / 505m / 506m / 506n), P. 27
13.39. Connector Composites (507m / 509m / 527 / 528 / 529 / 530), P. 28
13.40. Connector Composites (531 / 540 / 541 / 562 / 562a / 563m), P. 29
13.41. Connector Composites (564m / 565m / 566 / 567m / 568 / 569m), P. 30
13.42. Connector Composites (575 / 576 / 577 / 578 / 579), P. 30a
13.43. Connector Composites (583 / 587 / 592 / 593 / 594 / 607), P. 30b
13.44. Connector Composites (608 / 640 / 641 / 642 / 643 / 659 / 670), P. 31
13.45. Connector Composites (670 / 670a / 671 / *670a), P. 32
13.46. Connector Composites (671a / 672 / 673), P. 33
13.47. Connector Composites (674), P. 34
13.48. Connector Composites (674 / *674), P. 34a
13.49. Connector Composites (*674d / 675 / 676), P. 35
13.50. Connector Composites (677 / 678), P. 36
13.51. Connector Composites (679), P. 37
13.52. Connector Composites (679), P. 38
13.53. Connector Composites (679f / 680 / *680 / 680f), P. 39
13.54. Connector Composites (*681 / 685), P. 40
13.55. Connector Composites (686 / 687 / 687a), P. 41
13.56. Connector Composites (690), P. 42
13.57. Connector Composites (690 / *690 / 691 / 789 / 800), P. 42a
13.58. Connector Composites (#800f / 878f / 879m / 884f / 885f / 905m), P. 43
13.59. Connector Composites (906f / 906m), P. 43a
13.60. Connector Composites (907m / 922m / 923f / 923h / 923j), P. 43b
13.61. Connector Composites (935f / 936f / 937f / 942f / 942m / 945a), P. 44
13.62. Connector Composites (*946 / 958f / 974f / 975f / 979f), P. 44a
13.63. Connector Composites (980m / 981f / 982m), P. 44b
13.64. Connector Composites (992 / 994 / 964m), P. 44c
13.65. Connector Composites (1001), P. 45
13.66. Connector Composites (1001), P. 46
13.67. Connector Composites (1002), P. 47
13.68. Connector Composites (1002), P. 48
13.69. Connector Composites (1003), P. 49
13.70. Connector Composites (1003), P. 50
13.71. Connector Composites (1004), P. 51
13.72. Connector Composites (1004), P. 52
13.73. Connector Composites (1015 / 1015a / 1020 / 1021 / 1023a), P. 53
13.74. Connector Composites (1023b / 1023c / 1025 / 1026), P. 54
13.75. Connector Composites (1027 / 1028), P. 55
13.76. Connector Composites (1034a / 1034b / 1034af), P. 55a
13.77. Connector Composites (1034bf / 1039 / 1040 / 1042), P. 56
13.78. Connector Composites (1043 / 1044 / 1045 / 1046 / 1047), P. 57
13.79. Connector Composites (1049a / 1049b / 1049af / 1049bf), P. 58
13.80. Connector Composites (1051f / 1054f / 1054fp / 1056m), P. 59
13.81. Connector Composites (1057 / 1058m / 1059m / 1060m), P. 60
13.82. Connector Composites (1090f / 1090m / 1095f / 1108 / 1109m), P. 61
13.83. Connector Composites (1125 / 1126 / 1128m / 1129m / 1130m), P. 62
13.84. Connector Composites (1131m / 1132m / 1133m / 1134m), P. 63
13.85. Connector Composites (1135 / 1135m / 1136m / 1137m / 1138m), P. 64
13.86. Connector Composites (1140 / 1187 / 1244f / 1245m / 1246f / 1247m), P. 64a .
13.87. Connector Composites (1286 / 1287 / 1288 / 1304 / 1305 / 1306 / 1322a), P. 65
13.88. Connector Composites (1322f / 1322m / 1348 / 1349), P. 65a
13.89. Connector Composites (1350 / 1360 / 1361 / 1365), P. 66
13.90. Connector Composites (1366 / 1368f / 1369), P. 67
13.91. Connector Composites (1378 / 1386 / 1402 / 1403), P. 68
13.92. Connector Composites (1404m / 1408m / 1414 / 1414p), P. 69
13.93. Connector Composites (1450 / 1451 / 1600 / 1601), P. 70
13.94. Connector Composites (1602 / 1603), P. 71
13.95. Connector Composites (1604 / 1605 / 1606), P. 72
13.96. Connector Composites (1701), P. 73
13.97. Connector Composites (1701f), P. 74
13.98. Connector Composites (1805 / 1811), P. 75
13.99. Connector Composites (1812 / 1813 / 1814 / 1815 / 1874a), P. 76
13.100. Connector Composites (*1874b / 1874c / 1938m / 1939 / 1939m), P. 77
13.101. Connector Composites (1916 / 1917 / 1918a / 1919a), P. 77a
13.102. Connector Composites (1937n / 1943n /1943m / 1978 / 1979), P. 77b
13.103. Connector Composites (1979a / 2000n / 2224 / 2225), P. 77c
13.104. Connector Composites (2996 / 2997 / 2998 / 2999), P. 77d
13.105. Connector Composites (3000), P. 78
13.106. Connector Composites (3005), P. 79
13.107. Connector Composites (3010), P. 80
13.108. Connector Composites (3020), P. 80a
13.109. Connector Composites (3045 / 3050 / 4327 / 4327l), P. 81
13.110. Connector Composites (4327r / *4328 / 4450m / 4450am), P. 82
13.111. Connector Composites (4450bm / 4450bf / 4460m / 4460bm), P. 83
13.112. Connector Composites (4705 / 4706 / 4950 / 4950a), P. 84
13.113. Connector Composites (5001), P. 84a
13.114. Connector Composites (5002 / 5007 / 5118), P. 84b
13.115. Connector Composites (6000), P. 85
13.116. Connector Composites (6000), P. 85a
13.117. Connector Composites (6001 / 6018), P. 86
13.118. Connector Composites (6018), P. 86a
13.119. Connector Composites (6019), P. 87
13.120. Connector Composites (6019), P. 87a
13.121. Connector Composites (*6033 / 6033 / *6104 / 6200 / %6200), P. 88
13.122. Connector Composites (6260a / 6260f / 6260fp), P. 89
13.123. Connector Composites (*6260h / *6260vn / *6316m), P. 90
13.124. Connector Composites (*6400 / *6401 / *6407 / *6550 / *6566), P. 91
13.125. Connector Composites (6567 / 6587 / 6704 / 6704b), P. 92
13.126. Connector Composites (6704d / 6704f / 6705b), P. 93
13.127. Connector Composites (6706 / 6707 / 6748 / *7100 / *7104f), P. 94
13.128. Connector Composites (7105 / *7110 / %7110aa / 7110b), P. 95
13.129. Connector Composites (7110b / 7205f / 7206m / 7110b / *7211 / 7211a), P. 96
13.130. Connector Composites (*7212 / *7213 / #7213a / &7250), P. 96a
13.131. Connector Composites (7250 / *7303c / *7500w), P. 96b
13.132. Connector Composites (7501 / 7600 / 7603 / 7603c / *7608 / 7608a / *7615 /
7615a / 7700k / *7700l), P. 97
13.133. Connector Composites (7704 / 8000 / 8102 / 8165), P. 98
13.134. Connector Composites (8165 / 8200 / 8200a / 8201 / 8410 / 8500), P. 99
13.135. Connector Composites (8702 / 8802/ 8806 / 8807 / 8809), P. 99a
13.136. Connector Composites (8702b / 8702c / 8702d / 8881 / 8882), P. 99b
13.137. Connector Composites (8996), P. 99c
13.138. Intentionally Left Blank, P. 100
13.139. Connector Composites (8810 / 8903 / 8956 / 9000 / 9001), P. 101
13.140. Connector Composites (9002 / 9314a / 9314b), P. 102
13.141. Connector Composites (9109a / 9303a / 9314a / 9314b / 9501a / 9501b /
9501c / 9501d), P. 103
13.142. Connector Composites (9501k / 9501l / 9501p / 9501r), P. 104
13.143. Connector Composites (9501t / 9501v / 9502 / 9502a), P. 105
13.144. Connector Composites (9502b / 9502c / 9502d / 9502l), P. 106
13.145. Connector Composites (9502p / 9502r / 9502t / 9502v), P. 107
13.146. Connector Composites (9503a / 9503b / 9503c / 9503d / 9503e), P. 108
13.147. Connector Composites (9503f / 9503k / 9503l / 9503p / 9503r), P. 109
13.148. Connector Composites (9503t / 9503v / 9503w / 9503x / 9510a), P. 110
13.149. Connector Composites (9511 / 9512c / 9514 / 9514c), P. 111
13.150. Connector Composites (9514f / 9520 / 9521 / 9521a), P. 112
13.151. Connector Composites (9522 / 9522b / 9522c / 9522d), P. 113
13.152. Connector Composites (9522l / 9522p / 9522r / 9522t), P. 114
13.153. Connector Composites (9522v / 9522w / 9522x / 9531 / 9715f), P. 115
13.154. Connector Composites (9715m / 9716f / 9716m / 9717f), P. 116
13.155. Connector Composites (9717m / 9725f / 9725m / 9726f / 9726m), P. 117
13.156. Connector Composites (9727f / 9727m / 9762 / 9763), P. 118
13.157. Connector Composites (9764 / 9778f / 9778fb / 9779f), P. 119
13.158. Connector Composites (9779fb / 9780m / 9781m / 9782f), P. 120
13.159. Connector Composites (9783f / 9784 / 9790mb / 9800), P. 121
13.160. Connector Composites (9800f / 9802 / 9812), P. 122
13.161. Connector Composites (9813 / 9814a / 9814b / 9814c), P. 123
13.162. Connector Composites (9814d / 9815 / 9822 / 9824 / 9900a), P. 124
2.2. Acronyms, P. 2
Keyless Entry, P. 6
(Aat), P. 9
Engine, P. 1
Engine, P. 2
Engine, P. 3
Engine, P. 7
Engine, P. 8
Engine, P. 9
P. 2
P. 5
Engine, P. 11
P. 33
Engine, P. 37
P. 14
(Cont.), P. 7
(Cont.), P. 8
(Cont.), P. 9
(Cont.), P. 10
(Cont.), P. 11
(Cont.), P. 12
Relocate, P. 37
Engine, P. 5
294a / 294f), P. 12
- International DT466,DT570,HT570 Diesel Engine Service Manual
- International DT466E Wiring Schematic
- International 365, 444, 466, 530 Service Manuals
- Navistar Diagnostic Trouble Code Index
- SCANIA 420 DC11 - DC12 Motor
- International 9800 Electrical Schematic
- International Truck DT466E Engine Repair Manual
- International - VT365 Schematic (SPA)
- Scania Manual Transmission GRS900
- International Truck 5000i,9200i,9400i and 9900i Chassis Built Electrical Circuit Diagram
- International Trucks Body Controller Diagnostic Trouble Codes
- International Wiring Diagram
- International Truck CF500 CF600 Service Manual
- Scania Manual Transmission GR 900
- International DT466, DT530 Electronic Diagram
