International Truck HV Series Interactive Schematics 0000018823 2022
Brand: International, Navistar
Type of Manual: Interactive Schematics
Model: International HV Series Truck
Built: 1/1/2018 To 12/10/2021
Part Number: 0000018823
Publication Date: 2022
Number of Pages: 3701 Pages
A26/B6.7/L9 - BODY CONTROL MODULE (Body
Control Module)
A26/B6.7/L9 - BODY CONTROL MODULE (Body Control Module) Design 1
A26 - ABS Private J1939
A26 - ABS Private J1939 Design 9
A26 - Body J1939 (250kbps)
A26 - Body J1939 (250kbps) Design 10
A26 - Cab J1939 (250Kbps)
A26 - Cab J1939 (250Kbps) Design 11
A26 - Diagnostic Private J1939
A26 - Diagnostic Private J1939 Design 12
A26 - Engine Private J1939 (250kbps)
A26 - Engine Private J1939 (250kbps) Design 13
A26 - Low Speed J1939 (125Kbps)
A26 - Low Speed J1939 (125Kbps) Design 14
A26 - Telematics J1708 (9.6kbps)
A26 - Telematics J1708 (9.6kbps) Design 15
A26 - Powertrain J1939 Allison 3k/4k
A26 - Powertrain J1939 Allison 3k/4k Design 16
A26 - Powertrain J1939 UltraShift Transmission
A26 - Powertrain J1939 UltraShift Transmission Design 17
B6.7 - ABS Private J1939
B6.7 - ABS Private J1939 Design 18
B6.7 - Body J1939 (250kbps)
B6.7 - Body J1939 (250kbps) Design 19
B6.7 - Cab J1939 (250kbps)
B6.7 - Cab J1939 (250kbps) Design 20
B6.7 - Engine Private J1939 (250kbps)
B6.7 - Engine Private J1939 (250kbps) Design 21
B6.7 - Low Speed J1939 (125kbps)
B6.7 - Low Speed J1939 (125kbps) Design 22
B6.7 - Telematics J1708 (9.6kbps)
B6.7 - Telematics J1708 (9.6kbps) Design 23
B6.7 - Powertrain J1939 Allison 1k/2k
B6.7 - Powertrain J1939 Allison 1k/2k Design 24
B6.7 - Powertrain J1939 Allison 3k/4k
B6.7 - Powertrain J1939 Allison 3k/4k Design 25
B6.7 - Powertrain J1939 Manual Transmission
B6.7 - Powertrain J1939 Manual Transmission Design 26
L9 - ABS Private J1939
L9 - ABS Private J1939 Design 27
TABLE OF CONTENTS
iL9 - Body J1939 (250kbps)
L9 - Body J1939 (250kbps) Design 28
L9 - Cab J1939 (250kbps)
L9 - Cab J1939 (250kbps) Design 29
L9 - Engine Private J1939 (250kbps)
L9 - Engine Private J1939 (250kbps) Design 30
L9 - Low Speed J1939 (125kbps)
L9 - Low Speed J1939 (125kbps) Design 31
L9 - Telematics J1708 (9.6kbps)
L9 - Telematics J1708 (9.6kbps) Design 32
L9 - Powertrain J1939 Allison 3k/4k
L9 - Powertrain J1939 Allison 3k/4k Design 33
L9 - Powertrain J1939 Eaton
L9 - Powertrain J1939 Eaton Design 34
L9 - Powertrain J1939 Manual Transmission
L9 - Powertrain J1939 Manual Transmission Design 35
A26 - Navistar ECM
A26 - Navistar ECM Design 36
B6.7 - ECM Cummins CM2350A
B6.7 - ECM Cummins CM2350A Design 37
L9 - ECM Cummins CM2350A
L9 - ECM Cummins CM2350A Design 38
A26/B6.7/L9 - Instrument Cluster (Premium)
A26/B6.7/L9 - Instrument Cluster (Premium) Design 39
A26/B6.7/L9 - Instrument Cluster (Standard)
A26/B6.7/L9 - Instrument Cluster (Standard) Design 41
A26/B6.7/L9 - Instrument Cluster - Bulb Check
A26/B6.7/L9 - Instrument Cluster - Bulb Check Design 43
A26/B6.7/L9 - Instrument Cluster - Request and Status
A26/B6.7/L9 - Instrument Cluster - Request and Status Design 44
A26/B6.7/L9 - Ground Splice Pack 1022 & 1023
A26/B6.7/L9 - Ground Splice Pack 1022 & 1023 Design 45
A26/B6.7/L9 - Ground Splice Pack 1027
A26/B6.7/L9 - Ground Splice Pack 1027 Design 46
A26/B6.7/L9 - Interior Dual Post Ground Stud-Cowl
Wall
A26/B6.7/L9 - Interior Dual Post Ground Stud-Cowl Wall Design 47
A26/B6.7/L9 - ZVR Splice Pack - 1620
A26/B6.7/L9 - ZVR Splice Pack - 1620 Design 48
A26 - Center Chassis Ground Splice Packs
A26 - Center Chassis Ground Splice Packs Design 49
TABLE OF CONTENTS
iiB6.7 - Center Chassis Ground Splice Packs
B6.7 - Center Chassis Ground Splice Packs Design 50
L9 - Center Chassis Ground Splice Packs
L9 - Center Chassis Ground Splice Packs Design 51
A26 - Forward Chassis Ground Splice Packs 8800
A26 - Forward Chassis Ground Splice Packs 8800 Design 52
B6.7 - Forward Chassis Ground Splice Packs 8800
B6.7 - Forward Chassis Ground Splice Packs 8800 Design 53
L9 - Forward Chassis Ground Splice Packs 8800
L9 - Forward Chassis Ground Splice Packs 8800 Design 54
A26 - Powertrain Splice Pack 6704
A26 - Powertrain Splice Pack 6704 Design 55
A26 - ZVR Splice Packs 6702 & 6704B
A26 - ZVR Splice Packs 6702 & 6704B Design 56
B6.7 - Powertrain Splice Pack 6704
B6.7 - Powertrain Splice Pack 6704 Design 57
B6.7 - ZVR Splice Pack - 6747
B6.7 - ZVR Splice Pack - 6747 Design 58
L9 - Powertrain Splice Pack 6704 & 6704B
L9 - Powertrain Splice Pack 6704 & 6704B Design 59
L9 - ZVR Splice Pack - 6747
L9 - ZVR Splice Pack - 6747 Design 60
A26/B6.7/L9 - Lighting Control Module
A26/B6.7/L9 - Lighting Control Module Design 61
A26 - Aftertreatment PDM
A26 - Aftertreatment PDM Design 63
B6.7 - Aftertreatment PDM
B6.7 - Aftertreatment PDM Design 64
L9 - Aftertreatment PDM
L9 - Aftertreatment PDM Design 65
A26 - Auxilary Power Fuse
A26 - Auxilary Power Fuse Design 66
B6.7 - Auxilary Power Fuse
B6.7 - Auxilary Power Fuse Design 67
L9 - Auxilary Power Fuse
L9 - Auxilary Power Fuse Design 68
A26 - Chassis PDM
A26 - Chassis PDM Design 69
B6.7/L9 - Chassis PDM
B6.7/L9 - Chassis PDM Design 70
TABLE OF CONTENTS
iiiA26/B6.7/L9 - Battery Feed
A26/B6.7/L9 - Battery Feed Design 71
A26/B6.7/L9 - Interior PDM Chart
A26/B6.7/L9 - Interior PDM Chart Design 72
A26/B6.7/L9 - Key Switch Accessory
A26/B6.7/L9 - Key Switch Accessory Design 73
A26/B6.7/L9 - Key Switch Ignition
A26/B6.7/L9 - Key Switch Ignition Design 74
A26 - Relays
A26 - Relays Design 75
B6.7 - Relays
B6.7 - Relays Design 76
L9 - Relays
L9 - Relays Design 77
A26/B6.7/L9 - ABS CAN Splice Pack - 1410
A26/B6.7/L9 - ABS CAN Splice Pack - 1410 Design 78
A26/B6.7/L9 - Panel Light Dimmer Splice Pack - 1021
A26/B6.7/L9 - Panel Light Dimmer Splice Pack - 1021 Design 79
A26/B6.7/L9 - Park / Turn Lights Splice Packs
1623/1625/400
A26/B6.7/L9 - Park / Turn Lights Splice Packs 1623/1625/400 Design 80
A26 - Underhood PDM
A26 - Underhood PDM Design 81
B6.7/L9 - Underhood PDM
B6.7/L9 - Underhood PDM Design 82
A26/B6.7/L9 - Radio
A26/B6.7/L9 - Radio Design 83
A26/B6.7/L9 - Radio w/Bluetooth
A26/B6.7/L9 - Radio w/Bluetooth Design 84
A26/B6.7/L9 - Radio w/Bluetooth without Steering
Wheel Pod
A26/B6.7/L9 - Radio w/Bluetooth without Steering Wheel Pod Design 86
A26/B6.7/L9 - Radio w/Steering Wheel Pod
A26/B6.7/L9 - Radio w/Steering Wheel Pod Design 87
A26/B6.7/L9 - Four Speakers Daycab BT n/QC
A26/B6.7/L9 - Four Speakers Daycab BT n/QC Design 89
A26/B6.7/L9 - Four Speakers Daycab n/BT n/QC
A26/B6.7/L9 - Four Speakers Daycab n/BT n/QC Design 90
A26/B6.7/L9 - Two Speakers Daycab BT n/QC
A26/B6.7/L9 - Two Speakers Daycab BT n/QC Design 91
A26/B6.7/L9 - Two Speakers Daycab n/BT n/QC
A26/B6.7/L9 - Two Speakers Daycab n/BT n/QC Design 92
TABLE OF CONTENTS
ivB6.7 - Speakers:Four Speakers Daycab n/BT w/QC
B6.7 - Speakers:Four Speakers Daycab n/BT w/QC Design 93
B6.7 - Speakers:Two Speakers n/BT w/QC
B6.7 - Speakers:Two Speakers n/BT w/QC Design 94
B6.7 - Speakers:Two Speakers w/BT w/QC
B6.7 - Speakers:Two Speakers w/BT w/QC Design 95
B6.7 - Speaker:Four Speakers Daycab w/BT w/QC
B6.7 - Speaker:Four Speakers Daycab w/BT w/QC Design 96
L9 - Speakers:Four Speakers Daycab n/BT w/QC
L9 - Speakers:Four Speakers Daycab n/BT w/QC Design 97
L9 - Speakers:Two Speakers n/BT w/QC
L9 - Speakers:Two Speakers n/BT w/QC Design 98
L9 - Speakers:Two Speakers w/BT w/QC
L9 - Speakers:Two Speakers w/BT w/QC Design 99
L9 - Speaker:Four Speakers Daycab w/BT w/QC
L9 - Speaker:Four Speakers Daycab w/BT w/QC Design 100
A26/B6.7/L9 - Auxiliary Power (40A) HSD
A26/B6.7/L9 - Auxiliary Power (40A) HSD Design 101
B6.7 - Dual Auxiliary Power with Interlock
B6.7 - Dual Auxiliary Power with Interlock Design 102
A26 - Back-Up Alarm (Automatic) W/O Tailboard
A26 - Back-Up Alarm (Automatic) W/O Tailboard Design 103
A26 - Back-Up Alarm (Automatic) W/ Tailboard
A26 - Back-Up Alarm (Automatic) W/ Tailboard Design 104
A26 - Back-Up Alarm (Relay to 5 Pin 08TKC Tailboard
to Alarm) (Automatic)
A26 - Back-Up Alarm (Relay to 5 Pin 08TKC Tailboard to Alarm) (Automatic)
Design 105
A26 - Back-Up Alarm (Relay to 5 Pin 08TKC Tailboard.
Alarm Plugs In) (Automatic)
A26 - Back-Up Alarm (Relay to 5 Pin 08TKC Tailboard. Alarm Plugs In)
(Automatic) Design 106
A26 - Backup Alarm (Switch to 5 Pin 08TKC Tailboard
to Alarm) (Manual)
A26 - Backup Alarm (Switch to 5 Pin 08TKC Tailboard to Alarm) (Manual)
Design 107
A26 - Backup Alarm (Switch to 5 Pin 08TKC Tailboard.
Alarm Plugs In) (Manual)
A26 - Backup Alarm (Switch to 5 Pin 08TKC Tailboard. Alarm Plugs In) (Manual)
Design 108
A26 - Back-Up Alarm (Manual) W/O Tailboard
A26 - Back-Up Alarm (Manual) W/O Tailboard Design 109
TABLE OF CONTENTS
vA26 - Back-Up Alarm (Manual) W/ Tailboard
A26 - Back-Up Alarm (Manual) W/ Tailboard Design 110
B6.7 - Back-Up Alarm (Automatic) W/O Tailboard
B6.7 - Back-Up Alarm (Automatic) W/O Tailboard Design 111
B6.7 - Back-Up Alarm (Automatic) W/ Tailboard
B6.7 - Back-Up Alarm (Automatic) W/ Tailboard Design 112
B6.7 - Back-Up Alarm (Manual) W/O Tailboard
B6.7 - Back-Up Alarm (Manual) W/O Tailboard Design 113
B6.7 - Back-Up Alarm (Manual) W/ Tailboard
B6.7 - Back-Up Alarm (Manual) W/ Tailboard Design 114
L9 - Back-Up Alarm (Automatic) W/O Tailboard
L9 - Back-Up Alarm (Automatic) W/O Tailboard Design 115
L9 - Back-Up Alarm (Automatic) W/ Tailboard
L9 - Back-Up Alarm (Automatic) W/ Tailboard Design 116
L9 - Back-Up Alarm (Manual) W/O Tailboard
L9 - Back-Up Alarm (Manual) W/O Tailboard Design 117
L9 - Back-Up Alarm (Manual) W/ Tailboard
L9 - Back-Up Alarm (Manual) W/ Tailboard Design 119
A26/B6.7/L9 - Banana Plugs Receptacle
A26/B6.7/L9 - Banana Plugs Receptacle Design 121
A26/B6.7/L9 - CB Radio - Power Only
A26/B6.7/L9 - CB Radio - Power Only Design 122
A26/B6.7/L9 - CB Radio - Power Only (Single Antenna)
A26/B6.7/L9 - CB Radio - Power Only (Single Antenna) Design 123
A26/B6.7/L9 - Cigar Lighter
A26/B6.7/L9 - Cigar Lighter Design 124
A26/B6.7/L9 - Cigar Lighter Aux APO
A26/B6.7/L9 - Cigar Lighter Aux APO Design 125
A26/B6.7/L9 - Standard APO
A26/B6.7/L9 - Standard APO Design 128
A26/B6.7/L9 - Standard APO Aux APO
A26/B6.7/L9 - Standard APO Aux APO Design 129
A26/B6.7/L9 - Cruise Control (W/ One Telltale 10 Pin)
A26/B6.7/L9 - Cruise Control (W/ One Telltale 10 Pin) Design 132
A26/B6.7/L9 - Vehicle Speed Control (Cruise Control)
10 Pin
A26/B6.7/L9 - Vehicle Speed Control (Cruise Control) 10 Pin Design 134
A26/B6.7/L9 - Cruise Control (W/ One Telltale 4 Pin)
A26/B6.7/L9 - Cruise Control (W/ One Telltale 4 Pin) Design 135
TABLE OF CONTENTS
viA26/B6.7/L9 - Vehicle Speed Control (Cruise Control) 4
Pin
A26/B6.7/L9 - Vehicle Speed Control (Cruise Control) 4 Pin Design 137
A26/B6.7/L9 - Door Ajar Reminder (Entry /Exit):4 Door
A26/B6.7/L9 - Door Ajar Reminder (Entry /Exit):4 Door Design 138
A26/B6.7/L9 - Door Ajar Reminder (Entry/Exit) 2 Door
A26/B6.7/L9 - Door Ajar Reminder (Entry/Exit) 2 Door Design 139
A26/B6.7/L9 - Door Pod Module (2 Door)
A26/B6.7/L9 - Door Pod Module (2 Door) Design 140
A26/B6.7/L9 - Door Pod Module (4 Door)
A26/B6.7/L9 - Door Pod Module (4 Door) Design 141
A26/B6.7/L9 - Mirrors (Heated)
A26/B6.7/L9 - Mirrors (Heated) Design 142
A26/B6.7/L9 - Mirrors (Heat) Switch Pack Actuated
Relay Driven
A26/B6.7/L9 - Mirrors (Heat) Switch Pack Actuated Relay Driven Design 143
A26 - Heated Mirrors (Hood with Door Pods)
A26 - Heated Mirrors (Hood with Door Pods) Design 144
A26 - Heated Mirrors (RT Hood with Door Pods)
A26 - Heated Mirrors (RT Hood with Door Pods) Design 145
A26 - Mirrors (Heat) Switch Pack Actuated includes
Hood Mirrors
A26 - Mirrors (Heat) Switch Pack Actuated includes Hood Mirrors Design 146
A26 - Mirrors (Heat) Switch Pack Actuated includes RT
Hood Mirror
A26 - Mirrors (Heat) Switch Pack Actuated includes RT Hood Mirror Design 147
B6.7 - Heated Mirrors (Hood with Door Pods)
B6.7 - Heated Mirrors (Hood with Door Pods) Design 148
B6.7 - Heated Mirrors (RT Hood with Door Pods)
B6.7 - Heated Mirrors (RT Hood with Door Pods) Design 150
B6.7 - Mirrors (Heat) Switch Pack Actuated includes
Hood Mirrors
B6.7 - Mirrors (Heat) Switch Pack Actuated includes Hood Mirrors Design 154
RT Hood Mirror
B6.7 - Mirrors (Heat) Switch Pack Actuated includes RT Hood Mirror Design 156
L9 - Heated Mirrors (Hood with Door Pods)
L9 - Heated Mirrors (Hood with Door Pods) Design 160
L9 - Heated Mirrors (RT Hood with Door Pods)
L9 - Heated Mirrors (RT Hood with Door Pods) Design 164
TABLE OF CONTENTS
viiL9 - Mirrors (Heat) Switch Pack Actuated includes
Hood Mirrors
L9 - Mirrors (Heat) Switch Pack Actuated includes Hood Mirrors Design 168
L9 - Mirrors (Heat) Switch Pack Actuated includes RT
Hood Mirror
L9 - Mirrors (Heat) Switch Pack Actuated includes RT Hood Mirror Design 172
A26/B6.7/L9 - Power Mirrors (Control Switch Actuated)
A26/B6.7/L9 - Power Mirrors (Control Switch Actuated) Design 176
A26 - City Horn (W/ 10PIN Park Brake)
A26 - City Horn (W/ 10PIN Park Brake) Design 178
A26 - City Horn (W/ 10PIN)
A26 - City Horn (W/ 10PIN) Design 180
A26 - City Horn (W/ 4PIN Park Brake)
A26 - City Horn (W/ 4PIN Park Brake) Design 182
A26 - City Horn (W/ 4PIN)
A26 - City Horn (W/ 4PIN) Design 186
B6.7 - City Horn (W/ 10PIN CLK & Park Brake)
B6.7 - City Horn (W/ 10PIN CLK & Park Brake) Design 190
B6.7 - City Horn (W/ 10PIN CLK)
B6.7 - City Horn (W/ 10PIN CLK) Design 193
B6.7 - City Horn (W/ 4PIN CLK & Park Brake)
B6.7 - City Horn (W/ 4PIN CLK & Park Brake) Design 196
B6.7 - City Horn (W/ 4PIN CLK)
B6.7 - City Horn (W/ 4PIN CLK) Design 202
L9 - City Horn (W/ 10PIN CLK & Park Brake)
L9 - City Horn (W/ 10PIN CLK & Park Brake) Design 208
L9 - City Horn (W/ 10PIN CLK)
L9 - City Horn (W/ 10PIN CLK) Design 210
L9 - City Horn (W/ 4PIN CLK & Park Brake)
L9 - City Horn (W/ 4PIN CLK & Park Brake) Design 212
L9 - City Horn (W/ 4PIN CLK)
L9 - City Horn (W/ 4PIN CLK) Design 216
A26 - (Rand Mcnallly) GPS Display
A26 - (Rand Mcnallly) GPS Display Design 220
A26/B6.7/L9 - Heated Windshield
A26/B6.7/L9 - Heated Windshield Design 221
A26/B6.7/L9 - Multiplexed Switch Pack (Primary
Switch)
A26/B6.7/L9 - Multiplexed Switch Pack (Primary Switch) Design 222
A26/B6.7/L9 - Real Time Clock (RTC) (BCM Controlled)
A26/B6.7/L9 - Real Time Clock (RTC) (BCM Controlled) Design 223
TABLE OF CONTENTS
viiiA26 - Remote Keyless Access
A26 - Remote Keyless Access Design 224
B6.7 - Remote Keyless Access
B6.7 - Remote Keyless Access Design 225
L9 - Remote Keyless Access
L9 - Remote Keyless Access Design 226
A26/B6.7/L9 - Over The Air Electrical I/O (OnCommand
Link / N2 Module)
A26/B6.7/L9 - Over The Air Electrical I/O (OnCommand Link / N2 Module)
Design 227
A26/B6.7/L9 - Over the Air Programming
A26/B6.7/L9 - Over the Air Programming (OnCommand Link / N2 Module)
Design 228
A26 - Telematics (PEOPLE NET, DAYCAB)
A26 - Telematics (PEOPLE NET, DAYCAB) Design 229
L9 - Telematics (PEOPLE NET DAYCAB)
L9 - Telematics (PEOPLE NET DAYCAB) Design 230
A26/B6.7/L9 - Theft Deterrent (Grid Controlled)
A26/B6.7/L9 - Theft Deterrent (Grid Controlled) Design 231
A26/B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 - 1
Repeater)
A26/B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater) Design 232
A26/B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 - 2
Repeaters)
A26/B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 - 2 Repeaters) Design 236
TMC 8 PIN - 08XNL
TMC 8 PIN - 08XNL Design 238
A26/B6.7/L9 - One USB
A26/B6.7/L9 - One USB Design 239
A26/B6.7/L9 - Two USB
A26/B6.7/L9 - Two USB Design 240
A26/B6.7/L9 - Vehicle Sleep Mode
A26/B6.7/L9 - Vehicle Sleep Mode Design 242
A26 - 2-Way Radio
A26 - 2-Way Radio Design 243
B6.7 - 2-Way Radio
B6.7 - 2-Way Radio Design 245
L9 - 2-Way Radio
L9 - 2-Way Radio Design 247
TABLE OF CONTENTS
ixA26/B6.7/L9 - DPF Regen Switch Only
A26/B6.7/L9 - DPF Regen Switch Only Design 249
A26/B6.7/L9 - DPF With Bistable Inhibit Switch
A26/B6.7/L9 - DPF With Bistable Inhibit Switch Design 250
A26/B6.7/L9 - DPF With Monostable Inhibit Switch
A26/B6.7/L9 - DPF With Monostable Inhibit Switch Design 251
A26 - Selective Catalytic Reduction (SCR)
A26 - Selective Catalytic Reduction (SCR) Design 252
B6.7 - Selective Catalytic Reduction (SCR)
B6.7 - Selective Catalytic Reduction (SCR) Design 256
L9 - Selective Catalytic Reduction (SCR)
L9 - Selective Catalytic Reduction (SCR) Design 258
A26/B6.7/L9 - Adjustable Engine Speed Control (PTO)
10-pin
A26/B6.7/L9 - Adjustable Engine Speed Control (PTO) 10-pin Design 260
4-pin
A26/B6.7/L9 - Adjustable Engine Speed Control (PTO) 4-pin Design 262
A26 - Auxiliary Air Solenoids Normally Closed
A26 - Auxiliary Air Solenoids Normally Closed Design 263
A26 - Auxillary Air Solenoids Normally Open
A26 - Auxillary Air Solenoids Normally Open Design 264
B6.7 - Auxiliary Air Solenoids (1 Normally Closed)
Option 1
B6.7 - Auxiliary Air Solenoids (1 Normally Closed) Option 1 Design 270
Option 2
B6.7 - Auxiliary Air Solenoids (1 Normally Closed) Option 2 Design 271
Option 3
B6.7 - Auxiliary Air Solenoids (1 Normally Closed) Option 3 Design 274
L9 - Auxiliary Air Solenoids (1 Normally Closed)
L9 - Auxiliary Air Solenoids (1 Normally Closed) Design 277
L9 - Auxillary Air Solenoids Normally Closed
L9 - Auxillary Air Solenoids Normally Closed Design 278
L9 - Four Auxillary Air Solenoids
L9 - Four Auxillary Air Solenoids Design 284
L9 - Three Auxillary Air Solenoids
L9 - Three Auxillary Air Solenoids Design 285
A26/B6.7/L9 - Body Builder Aux Power (In Cab, BOC,
or EOF)
TABLE OF CONTENTS
xA26/B6.7/L9 - Body Builder Aux Power (In Cab, BOC, or EOF) Design 288
A26 - Body Builder Lighting - BOC, 08HBX (Automatic)
A26 - Body Builder Lighting - BOC, 08HBX (Automatic) Design 291
A26 - Body Builder Lighting - BOC, 08HBX (Manual)
A26 - Body Builder Lighting - BOC, 08HBX (Manual) Design 292
A26 - Body Builder Lighting - Combined Turn and
Stop Lamps (Automatic)
A26 - Body Builder Lighting - Combined Turn and Stop Lamps (Automatic)
Design 293
Stop Lamps (Manual)
A26 - Body Builder Lighting - Combined Turn and Stop Lamps (Manual)
Design 296
A26 - Body Builder Lighting - Separate Turn and Stop
Lamps (Blunt Cut) - Option 1
A26 - Body Builder Lighting - Separate Turn and Stop Lamps (Blunt Cut) - Option
1 Design 299
Lamps (Blunt Cut) - Option 2
2 Design 300
B6.7 - Body Builder Lighting - Combined Turn and
B6.7 - Body Builder Lighting - Combined Turn and Stop Lamps (Automatic)
Design 301
Stop Lamps (Manual)
B6.7 - Body Builder Lighting - Combined Turn and Stop Lamps (Manual)
Design 304
B6.7 - Body Builder Lighting - Separate Turn and Stop
Lamps (Blunt Cut) Option 1
B6.7 - Body Builder Lighting - Separate Turn and Stop Lamps (Blunt Cut) Option
1 Design 307
Lamps (Blunt Cut) Option 2
2 Design 308
L9 - Body Builder Lighting - Combined Turn and Stop
Lamps (Automatic)
L9 - Body Builder Lighting - Combined Turn and Stop Lamps (Automatic)
Design 309
Lamps (Manual)
L9 - Body Builder Lighting - Combined Turn and Stop Lamps (Manual) Design 312
TABLE OF CONTENTS
xiL9 - Body Builder Lighting - Separate Turn and Stop
L9 - Body Builder Lighting - Separate Turn and Stop Lamps (Blunt Cut) Option 1
Design 318
L9 - Body Builder Lighting - Separate Turn and Stop Lamps (Blunt Cut) Option 2
Design 319
A26 - I/O Expansion
A26 - I/O Expansion Design 320
B6.7 - I/O Expansion
B6.7 - I/O Expansion Design 321
L9 - I/O Expansion
L9 - I/O Expansion Design 322
A26 - Body Builder - Powertrain
A26 - Body Builder - Powertrain Design 323
A26 - Power Lift Gate
A26 - Power Lift Gate Design 324
B6.7 - Power Lift Gate
B6.7 - Power Lift Gate Design 325
L9 - Power Lift Gate
L9 - Power Lift Gate Design 326
A26 - DLB - Remote Power Modules (1 RPM n/ Switch
Packs)
A26 - DLB - Remote Power Modules (1 RPM n/ Switch Packs) Design 327
A26 - DLB - Remote Power Modules (1 RPM w/ Switch
Packs)
A26 - DLB - Remote Power Modules (1 RPM w/ Switch Packs) Design 330
A26 - DLB - Remote Power Modules (2 RPM n/ Switch
Pack)
A26 - DLB - Remote Power Modules (2 RPM n/ Switch Pack) Design 333
Pack)Option2
A26 - DLB - Remote Power Modules (2 RPM n/ Switch Pack)Option2 Design 336
A26 - DLB - Remote Power Modules (2 RPM w/ Switch
Packs)
A26 - DLB - Remote Power Modules (2 RPM w/ Switch Packs) Design 337
Packs)Option2
A26 - DLB - Remote Power Modules (2 RPM w/ Switch Packs)Option2 Design338
A26 - DLB - Remote Power Modules (3 RPM w/ Swtich
Packs)
A26 - DLB - Remote Power Modules (3 RPM w/ Swtich Packs) Design 341
TABLE OF CONTENTS
xiiA26 - DLB - Remote Power Modules (3 RPM w/ Swtich
Packs)Option2
A26 - DLB - Remote Power Modules (3 RPM w/ Swtich Packs)Option2 Design342
A26 - DLB - Remote Power Module (3 RPM n/Switch
Pack)
A26 - DLB - Remote Power Module (3 RPM n/Switch Pack) Design 344
Pack)Option2
A26 - DLB - Remote Power Module (3 RPM n/Switch Pack)Option2 Design 345
B6.7 - DLB - Remote Power Modules (1 RPM n/ Switch
Packs)
B6.7 - DLB - Remote Power Modules (1 RPM n/ Switch Packs) Design 347
B6.7 - DLB - Remote Power Modules (1 RPM w/ Switch
Packs)
B6.7 - DLB - Remote Power Modules (1 RPM w/ Switch Packs) Design 350
B6.7 - DLB - Remote Power Modules (2 RPM n/ Switch
Pack)
B6.7 - DLB - Remote Power Modules (2 RPM n/ Switch Pack) Design 353
B6.7 - DLB - Remote Power Modules (2 RPM w/ Switch
Packs)
B6.7 - DLB - Remote Power Modules (2 RPM w/ Switch Packs) Design 357
B6.7 - DLB - Remote Power Modules (3 RPM w/ Swtich
Packs)
B6.7 - DLB - Remote Power Modules (3 RPM w/ Swtich Packs) Design 361
B6.7 - DLB - Remote Power Module (3 RPM n/Switch
Pack)
B6.7 - DLB - Remote Power Module (3 RPM n/Switch Pack) Design 362
L9 - DLB - Remote Power Modules (1 RPM n/ Switch
Packs)
L9 - DLB - Remote Power Modules (1 RPM n/ Switch Packs) Design 363
L9 - DLB - Remote Power Modules (1 RPM w/ Switch
Packs)
L9 - DLB - Remote Power Modules (1 RPM w/ Switch Packs) Design 366
L9 - DLB - Remote Power Modules (2 RPM n/ Switch
Pack)
L9 - DLB - Remote Power Modules (2 RPM n/ Switch Pack) Design 369
L9 - DLB - Remote Power Modules (2 RPM w/ Switch
Packs)
L9 - DLB - Remote Power Modules (2 RPM w/ Switch Packs) Design 373
L9 - DLB - Remote Power Modules (3 RPM w/ Swtich
Packs)
L9 - DLB - Remote Power Modules (3 RPM w/ Swtich Packs) Design 377
TABLE OF CONTENTS
xiiiL9 - DLB - Remote Power Module (3 RPM n/Switch
Pack)
L9 - DLB - Remote Power Module (3 RPM n/Switch Pack) Design 378
A26 - Remote Start/Stop
A26 - Remote Start/Stop Design 379
B6.7 - Remote Start/Stop
B6.7 - Remote Start/Stop Design 380
B6.7 - Remote Start/Stop w/ Emergency Pump
B6.7 - Remote Start/Stop w/ Emergency Pump Design 381
L9 - Remote Start/Stop
L9 - Remote Start/Stop Design 382
L9 - Remote Start/Stop w/ Emergency Pump
L9 - Remote Start/Stop w/ Emergency Pump Design 383
A26 - Transmission Power Take Off (Auto Trans Dual
PTO W/ 42 Parameters)
A26 - Transmission Power Take Off (Auto Trans Dual PTO W/ 42 Parameters)
Design 384
A26 - Transmission Power Take Off (Manual Trans
A26 - Transmission Power Take Off (Manual Trans Dual PTO W/ 42 Parameters)
Design 385
Single PTO w/21 Parameters)
A26 - Transmission Power Take Off (Auto Trans Single PTO w/21 Parameters)
Design 386
Single PTO w/ 21 Parameters)
A26 - Transmission Power Take Off (Manual Trans Single PTO w/ 21
Parameters) Design 387
A26 - Transmission Power Take Off (Single Input
Configurable pull up or pull down)
A26 - Transmission Power Take Off (Single Input Configurable pull up or pull
down) Design 388
B6.7 - Transmission Power Take Off 60AKG
B6.7 - Transmission Power Take Off 60AKG Design 389
B6.7 - Transmission Power Take Off (Auto Trans
B6.7 - Transmission Power Take Off (Auto Trans Single PTO w/21 Parameters)
Design 390
B6.7 - Transmission Power Take Off (Manual Trans
B6.7 - Transmission Power Take Off (Manual Trans Single PTO w/21
Parameters) Design 391
TABLE OF CONTENTS
xivB6.7 - Transmission Power Take Off (Single Input
configurable pull up or pull down)
B6.7 - Transmission Power Take Off (Single Input configurable pull up or pull
down) Design 392
L9 - Transmission Power Take Off (Auto Trans Single
L9 - Transmission Power Take Off (Auto Trans Single PTO w/21 Parameters)
Design 393
L9 - Transmission Power Take Off (Auto Trans with
Lectradrive)
L9 - Transmission Power Take Off (Auto Trans with Lectradrive) Design 394
L9 - Transmission Power Take Off (Lectrashift PTO
with Manual Trans)
L9 - Transmission Power Take Off (Lectrashift PTO with Manual Trans)
Design 395
L9 - Transmission Power Take Off (Manual Trans
L9 - Transmission Power Take Off (Manual Trans Single PTO w/21 Parameters)
Design 396
L9 - Transmission Power Take Off (Single Input
L9 - Transmission Power Take Off (Single Input configurable pull up or pull down)
Design 397
L9 - Transmission Power Take Off (Single PTO W/
RPM and Auto Trans)
L9 - Transmission Power Take Off (Single PTO W/ RPM and Auto Trans)
Design 398
RPM and Manual Trans)
L9 - Transmission Power Take Off (Single PTO W/ RPM and Manual Trans)
Design 399
A26 - Brake Switch
A26 - Brake Switch Design 400
B6.7 - Brake Switch
B6.7 - Brake Switch Design 401
L9 - Brake Switch
L9 - Brake Switch Design 402
A26 - Rightside Air Dryer
A26 - Rightside Air Dryer Design 403
B6.7 - RIGHTSIDE AIR DRYER
B6.7 - RIGHTSIDE AIR DRYER Design 414
L9 - RIGHTSIDE AIR DRYER
L9 - RIGHTSIDE AIR DRYER Design 420
A26 - Drain Valve Heater
A26 - Drain Valve Heater Design 431
TABLE OF CONTENTS
xvB6.7 - Drain Valve Heater
B6.7 - Drain Valve Heater Design 441
L9 - Drain Valve Heater
L9 - Drain Valve Heater Design 448
A26 - Antilock Brake System (ABS) Bendix
A26 - Antilock Brake System (ABS) Bendix Design 457
A26 - Antilock Brake System (ABS)-Wabco 4 Channel
Implementation
A26 - Antilock Brake System (ABS)-Wabco 4 Channel Implementation Design 460
B6.7 - Antilock Brake System (ABS) BENDIX 4
Channel Implemenation
B6.7 - Antilock Brake System (ABS) BENDIX 4 Channel Implemenation
Design 461
L9 - Antilock Brake System (ABS) BENDIX 4 Channel
Implemenation
L9 - Antilock Brake System (ABS) BENDIX 4 Channel Implemenation Design 464
L9 - Antilock Brake System (ABS) Bendix 6 Channel
Implementation
L9 - Antilock Brake System (ABS) Bendix 6 Channel Implementation Design 465
L9 - Antilock Brake System (ABS) Wabco 4 Channel
Implementation
L9 - Antilock Brake System (ABS) Wabco 4 Channel Implementation Design 474
A26 - Park Brake Control (Monitoring)(GEN IV BCM)
A26 - Park Brake Control (Monitoring)(GEN IV BCM) Design 475
B6.7 - Park Brake Controls (Monitoring) (Door Switch
City Horn)
B6.7 - Park Brake Controls (Monitoring) (Door Switch City Horn) Design 476
L9 - Park Brake Controls (Monitoring) (Door Switch
City Horn)
L9 - Park Brake Controls (Monitoring) (Door Switch City Horn) Design 477
L9 - Park Brake Control (Monitoring)(GEN IV BCM)
L9 - Park Brake Control (Monitoring)(GEN IV BCM) Design 478
A26 - Bendix Tractor or Towing Truck N/ Air SUSP
J1939 Driven Lamp
A26 - Bendix Tractor or Towing Truck N/ Air SUSP J1939 Driven Lamp
Design 479
A26 - Bendix Tractor or Towing Truck W/ Air SUSP
J1939 Driven Lamp
A26 - Bendix Tractor or Towing Truck W/ Air SUSP J1939 Driven Lamp
Design 483
A26 - Stability Control (Bendix Straight Truck J1939
Driven Lamp)
A26 - Stability Control (Bendix Straight Truck J1939 Driven Lamp) Design 487
TABLE OF CONTENTS
xviB6.7 - Stability Control (Bendix Straight Truck J1939
Driven Lamp)
B6.7 - Stability Control (Bendix Straight Truck J1939 Driven Lamp) Design 491
L9 - Bendix Tractor or Towing Truck W/ Air SUSP
J1939 Driven Lamp
L9 - Bendix Tractor or Towing Truck W/ Air SUSP J1939 Driven Lamp Design 495
L9 - Stability Control (Bendix Straight Truck J1939
Driven Lamp)
L9 - Stability Control (Bendix Straight Truck J1939 Driven Lamp) Design 497
A26 - Traction Control (Bendix)
A26 - Traction Control (Bendix) Design 501
B6.7 - Traction Control (Bendix)
B6.7 - Traction Control (Bendix) Design 503
L9 - Traction Control (Bendix)
L9 - Traction Control (Bendix) Design 505
A26/B6.7/L9 - Adaptive Cruise Control (Bendix -
Fusion 2.0 & N/ Safety Direct & Reg Speakers)
A26/B6.7/L9 - Adaptive Cruise Control (Bendix - Fusion 2.0 & N/ Safety Direct &
Reg Speakers) Design 506
A26/B6.7/L9 - A26 - Adaptive Cruise Control w/o
Display (Bendix)
A26/B6.7/L9 - A26 - Adaptive Cruise Control w/o Display (Bendix) Design 507
A26 - Coolant Level Monitoring (No Coolant Module)
A26 - Coolant Level Monitoring (No Coolant Module) Design 508
B6.7 - Coolant Level Monitoring (No Coolant Module)
B6.7 - Coolant Level Monitoring (No Coolant Module) Design 509
L9 - Coolant Level Monitoring (No Coolant Module)
L9 - Coolant Level Monitoring (No Coolant Module) Design 510
HV B6.7 - Coolant Level Monitoring (With Coolant
Module)
HV B6.7 - Coolant Level Monitoring (With Coolant Module) Design 511
HV L9 - Coolant Level Monitoring (With Coolant
Module)
HV L9 - Coolant Level Monitoring (With Coolant Module) Design 512
A26 - Cooling Fan Control Two-Speed
A26 - Cooling Fan Control Two-Speed Design 513
B6.7 - Cooling Fan Control Two-Speed
B6.7 - Cooling Fan Control Two-Speed Design 514
A26/B6.7/L9 - Engine Block Heater
A26/B6.7/L9 - Engine Block Heater Design 516
A26/B6.7/L9 - Engine Fuel and Block Heaters
(Purchased Assembly)
A26/B6.7/L9 - Engine Fuel and Block Heaters (Purchased Assembly) Design 517
TABLE OF CONTENTS
xviiA26/B6.7/L9 - Engine Oil and Block Heaters
A26/B6.7/L9 - Engine Oil and Block Heaters (Purchased Assembly) Design 518
A26/B6.7/L9 - Engine Oil Fuel and Block Heaters
A26/B6.7/L9 - Engine Oil Fuel and Block Heaters Design 519
A26 - Engine Brake Mux Switch
A26 - Engine Brake Mux Switch Design 520
A26 - Engine Brake W/ Stalk Shifter
A26 - Engine Brake W/ Stalk Shifter Design 521
B6.7/L9 - Engine Brake Mux Switch
B6.7/L9 - Engine Brake Mux Switch Design 522
B6.7/L9 - Engine Brake W/ Stalk Shifter
B6.7/L9 - Engine Brake W/ Stalk Shifter Design 523
A26 - Exhaust Brake
A26 - Exhaust Brake Design 524
B6.7 - Exhaust Brake (Cummins)
B6.7 - Exhaust Brake (Cummins) Design 525
L9 - Exhaust Brake (Cummins)
L9 - Exhaust Brake (Cummins) Design 526
A26 - Snow Valve Control
A26 - Snow Valve Control Design 527
A26/B6.7/L9 - Snow Valve Control
A26/B6.7/L9 - Snow Valve Control Design 529
B6.7 - Snow Valve Control
B6.7 - Snow Valve Control Design 530
L9 - Snow Valve Control Design 532
A26 - Starting Aid (Flame Start)
A26 - Starting Aid (Flame Start) Design 534
B6.7 - Starting Aid (Grid Heater)
B6.7 - Starting Aid (Grid Heater) Design 535
L9 - Starting Aid (Grid Heater)
L9 - Starting Aid (Grid Heater) Design 536
A26 - Vehicle Acceleration (w/ Two PWR Two GND &
Two STS)
A26 - Vehicle Acceleration (w/ Two PWR Two GND & Two STS) Design 537
B6.7 - Vehicle Acceleration (w/ Two PWR Two GND &
Two STS)
B6.7 - Vehicle Acceleration (w/ Two PWR Two GND & Two STS) Design 538
L9 - Vehicle Acceleration (w/ Two PWR Two GND &
Two STS)
L9 - Vehicle Acceleration (w/ Two PWR Two GND & Two STS) Design 539
TABLE OF CONTENTS
xviiiA26/B6.7/L9 - Alternate Flashing (Wig Wag) - Park
Brake disables High Beams
A26/B6.7/L9 - Alternate Flashing (Wig Wag) - Park Brake disables High Beams
Design 540
Brake disables Wig Wag
A26/B6.7/L9 - Alternate Flashing (Wig Wag) - Park Brake disables Wig Wag
Design 541
A26/B6.7/L9 - Automatic Lighting - Dual Sensor
Twilight/Solar
A26/B6.7/L9 - Automatic Lighting - Dual Sensor Twilight/Solar Design 542
A26/B6.7/L9 - Automatic Lighting - Single Sensor
Twilight
A26/B6.7/L9 - Automatic Lighting - Single Sensor Twilight Design 544
A26 - Backup Light (Dual Daisy Reverse LT)Allison/ZF
Trans 3K/4K
A26 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans 3K/4K Design 546
A26 - Backup Light (Dual Reverse Light)Allison/ZF
Trans 3K/4K
A26 - Backup Light (Dual Reverse Light)Allison/ZF Trans 3K/4K Design 548
A26 - Backup Lights (Dual Daisy Reverse Light)
Eaton/Manual Trans
A26 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans Design 550
A26 - Backup Lights (Dual Reverse Light)
Eaton/Manual Trans
A26 - Backup Lights (Dual Reverse Light) Eaton/Manual Trans Design 551
A26 - Backup Light (Single Reverse Light)Allison
3K/4K
A26 - Backup Light (Single Reverse Light)Allison 3K/4K Design 552
A26 - Backup Light (Single Reverse Light) Allison
3K/4K
A26 - Backup Light (Single Reverse Light) Allison 3K/4K Design 554
3K/4K Option2
A26 - Backup Light (Single Reverse Light) Allison 3K/4K Option2 Design 556
A26 - Backup Light (Single Reverse Light) W/Less
Power Module Allison 3K/4K
A26 - Backup Light (Single Reverse Light) W/Less Power Module Allison 3K/4K
Design 558
A26 - Backup Lights (Reverse) W/Less Power Module
Eaton/Manual Trans
A26 - Backup Lights (Reverse) W/Less Power Module Eaton/Manual Trans
Design 560
A26 - Backup Lights (Single Reverse Lights)
Eaton/Manual Trans
A26 - Backup Lights (Single Reverse Lights) Eaton/Manual Trans Design 561
TABLE OF CONTENTS
xixA26 - Backup Lights (Single Reverse Lights)
Eaton/Manual Transmission
A26 - Backup Lights (Single Reverse Lights) Eaton/Manual Transmission
Design 562
Eaton/Manual Trans Option2
A26 - Backup Lights (Single Reverse Lights) Eaton/Manual Trans Option2
Design 563
A26 - Backup Lights (Single Reverse Light)
Eaton/Manual Trans
A26 - Backup Lights (Single Reverse Light) Eaton/Manual Trans Design 564
B6.7 - Backup Light (Dual Daisy Reverse LT)Allison/ZF
Trans 1K/2K
B6.7 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans 1K/2K Design 565
Trans 3K/4K
B6.7 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans 3K/4K Design 566
B6.7 - Backup Light (Dual Reverse Light)Allison/ZF
Trans 1K/2K
B6.7 - Backup Light (Dual Reverse Light)Allison/ZF Trans 1K/2K Design 568
Trans 3K/4K
B6.7 - Backup Light (Dual Reverse Light)Allison/ZF Trans 3K/4K Design 569
B6.7 - Backup Lights (Dual Daisy Reverse Light)
Eaton/Manual Trans
B6.7 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans Design 571
B6.7 - Backup Lights (Dual Reverse Light)
Eaton/Manual Trans
B6.7 - Backup Lights (Dual Reverse Light) Eaton/Manual Trans Design 572
B6.7 - Backup Light (Single Reverse Light) Allison
1K/2K Option 1
B6.7 - Backup Light (Single Reverse Light) Allison 1K/2K Option 1 Design 573
1K/2K Option 2
B6.7 - Backup Light (Single Reverse Light) Allison 1K/2K Option 2 Design 574
1K/2K Option 3
B6.7 - Backup Light (Single Reverse Light) Allison 1K/2K Option 3 Design 575
3K/4K Option 1
B6.7 - Backup Light (Single Reverse Light) Allison 3K/4K Option 1 Design 576
3K/4K Option 2
B6.7 - Backup Light (Single Reverse Light) Allison 3K/4K Option 2 Design 578
TABLE OF CONTENTS
xxB6.7 - Backup Light (Single Reverse Light) Allison
3K/4K Option 3
B6.7 - Backup Light (Single Reverse Light) Allison 3K/4K Option 3 Design 580
B6.7 - Backup Lights (Single Reverse Lights)
Eaton/Manual Trans Option 1
B6.7 - Backup Lights (Single Reverse Lights) Eaton/Manual Trans Option 1
Design 582
Eaton/Manual Trans Option 2
B6.7 - Backup Lights (Single Reverse Lights) Eaton/Manual Trans Option 2
Design 583
B6.7 - Backup Lights (Single Reverse Light)
Eaton/Manual Trans
B6.7 - Backup Lights (Single Reverse Light) Eaton/Manual Trans Design 584
L9 - Backup Light (Dual Daisy Reverse
L9 - Backup Light (Dual Daisy Reverse Light)Allison/ZF Trans 3K/4K Design 585
L9 - Backup Lights (Dual Daisy Reverse Light)
Eaton/Manual Trans
L9 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans Design 587
L9 - Backup Lights (Dual Reverse Light) Eaton/Manual
Trans
L9 - Backup Lights (Dual Reverse Light) Eaton/Manual Trans Design 589
L9 - Backup Light (Single Reverse Light)Allison
L9 - Backup Light (Single Reverse Light)Allison Design 591
L9 - Backup Light (Single Reverse Light) Allison
3K/4K Option 1
L9 - Backup Light (Single Reverse Light) Allison 3K/4K Option 1 Design 593
3K/4K Option 2
L9 - Backup Light (Single Reverse Light) Allison 3K/4K Option 2 Design 595
3K/4K Option 3
L9 - Backup Light (Single Reverse Light) Allison 3K/4K Option 3 Design 597
L9 - Backup Lights (Single Reverse Light)
L9 - Backup Lights (Single Reverse Light) Eaton/Manual Trans Option 1
Design 599
L9 - Backup Lights (Single Reverse Light) Eaton/Manual Trans Option 2
Design 601
Eaton/Manual Trans Option 3
L9 - Backup Lights (Single Reverse Light) Eaton/Manual Trans Option 3
Design 603
TABLE OF CONTENTS
xxiL9 - Backup Lights (Single Reverse Light)
Eaton/Manual Trans Option 4
L9 - Backup Lights (Single Reverse Light) Eaton/Manual Trans Option 4
Design 605
A26 - Rear Lights Stop - Daisy Chain
A26 - Rear Lights Stop - Daisy Chain Design 607
A26 - Rear Lights Stop - Dual Assembly
A26 - Rear Lights Stop - Dual Assembly Design 608
A26 - Rear Lights Stop - Single Assemby
A26 - Rear Lights Stop - Single Assemby Design 609
A26 - Rear Lights Stop - Single Assemby Jumper
Harness W/08TKC, 08THM
A26 - Rear Lights Stop - Single Assemby Jumper Harness W/08TKC, 08THM
Design 610
A26 - Rear Lights Stop - Single Assemby W/08TKJ
A26 - Rear Lights Stop - Single Assemby W/08TKJ Design 611
A26 - Separate Rear Lights (Stop) W/08TVH
A26 - Separate Rear Lights (Stop) W/08TVH Design 612
B6.7 - Rear Lights Stop - Daisy Chain
B6.7 - Rear Lights Stop - Daisy Chain Design 613
B6.7 - Rear Lights Stop - Dual Assembly
B6.7 - Rear Lights Stop - Dual Assembly Design 614
B6.7 - Rear Lights Stop - Single Assemby
B6.7 - Rear Lights Stop - Single Assemby Design 615
L9 - Rear Lights Stop - Daisy Chain
L9 - Rear Lights Stop - Daisy Chain Design 616
L9 - Rear Lights Stop - Dual Assembly
L9 - Rear Lights Stop - Dual Assembly Design 617
L9 - Rear Lights Stop - Single Assemby
L9 - Rear Lights Stop - Single Assemby Design 618
A26/B6.7/L9 - Clearance and Identification Lights
A26/B6.7/L9 - Clearance and Identification Lights Design 619
A26/B6.7/L9 - Daytime Running Lights (Output to Plow
Lights)
A26/B6.7/L9 - Daytime Running Lights (Output to Plow Lights) Design 620
A26 - Directional Signal (Turn) W/ Daisy Chain Box
Lamps
A26 - Directional Signal (Turn) W/ Daisy Chain Box Lamps Design 621
A26 - Directional Signal (Turn) W/ LED BOX LAMPS
A26 - Directional Signal (Turn) W/ LED BOX LAMPS Design 622
A26 - Directional Signal (Turn) W/ Less Power Module
Tail Board, W/Hazard SW
TABLE OF CONTENTS
xxiiA26 - Directional Signal (Turn) W/ Less Power Module Tail Board, W/Hazard SW
Design 623
A26 - Directional Signal (Turn) W/ Single Tail Board
W/Hazard SW
A26 - Directional Signal (Turn) W/ Single Tail Board W/Hazard SW Design 624
Lamps, W/Plow Lights
A26 - Directional Signal (Turn) W/ Daisy Chain Box Lamps, W/Plow Lights
Design 625
A26 - Directional Signal (Turn) W/ LED BOX LAMPS,
W/Plow Lights
A26 - Directional Signal (Turn) W/ LED BOX LAMPS, W/Plow Lights Design 627
Tail Board, W/Hazard SW, W/Plow Lights
A26 - Directional Signal (Turn) W/ Less Power Module Tail Board, W/Hazard SW,
W/Plow Lights Design 629
A26 - Directional Signal (Turn) W/ Single Tail Board,
A26 - Directional Signal (Turn) W/ Single Tail Board, W/Hazard SW, W/Plow
Lights Design 631
B6.7 - Directional Signal (Turn) W/ DAISY CHAIN BOX
LAMPS
B6.7 - Directional Signal (Turn) W/ DAISY CHAIN BOX LAMPS Design 633
B6.7 - Directional Signal (Turn) W/ LED BOX LAMPS
B6.7 - Directional Signal (Turn) W/ LED BOX LAMPS Design 635
B6.7 - Directional Signal (Turn) W/ Less Power Module
B6.7 - Directional Signal (Turn) W/ Less Power Module Tail Board W/Hazard SW
Design 637
B6.7 - Directional Signal (Turn) W/ Single Tail Board
W/Hazard SW
B6.7 - Directional Signal (Turn) W/ Single Tail Board W/Hazard SW Design 639
B6.7 - Directional Signal (Turn) W/ Daisy Chain Box
Lamps W/Plow Lights
B6.7 - Directional Signal (Turn) W/ Daisy Chain Box Lamps W/Plow Lights
Design 641
W/Plow Lights
B6.7 - Directional Signal (Turn) W/ LED BOX LAMPS W/Plow Lights Design 645
Tail Board W/Hazard SW W/PLOW LIGHTS
W/PLOW LIGHTS Design 649
W/Plow Lights
B6.7 - Directional Signal (Turn) W/ Single Tail Board W/Plow Lights Design 653
TABLE OF CONTENTS
xxiiiL9 - Directional Signal (Turn) W/ DAISY CHAIN BOX
LAMPS
L9 - Directional Signal (Turn) W/ DAISY CHAIN BOX LAMPS Design 657
L9 - Directional Signal (Turn) W/ LED BOX LAMPS
L9 - Directional Signal (Turn) W/ LED BOX LAMPS Design 659
L9 - Directional Signal (Turn) W/ Less Power Module
L9 - Directional Signal (Turn) W/ Less Power Module Tail Board W/Hazard SW
Design 661
L9 - Directional Signal (Turn) W/ Single Tail Board
W/Hazard SW
L9 - Directional Signal (Turn) W/ Single Tail Board W/Hazard SW Design 663
L9 - Directional Signal (Turn) W/ Daisy Chain Box
Lamps W/Plow Lights
L9 - Directional Signal (Turn) W/ Daisy Chain Box Lamps W/Plow Lights
Design 665
W/Plow Lights
L9 - Directional Signal (Turn) W/ LED BOX LAMPS W/Plow Lights Design 669
W/PLOW LIGHTS Design 673
W/Plow Lights
L9 - Directional Signal (Turn) W/ Single Tail Board W/Plow Lights Design 677
A26/B6.7/L9 - Exterior Lamp Check
A26/B6.7/L9 - Exterior Lamp Check Design 681
A26/B6.7/L9 - Exterior Lamp Reminder
A26/B6.7/L9 - Exterior Lamp Reminder Design 682
A26 - Front Fog Lamps LED
A26 - Front Fog Lamps LED Design 683
A26 - Front Fog Lights W CONNECTOR Halogen
A26 - Front Fog Lights W CONNECTOR Halogen Design 685
B6.7 - Fog Lights (Halogen White)
B6.7 - Fog Lights (Halogen White) Design 687
B6.7 - Fog Lights (LED White)
B6.7 - Fog Lights (LED White) Design 690
B6.7 - Front Fog Lamps
B6.7 - Front Fog Lamps Design 693
B6.7 - Front Fog Lights W CONNECTOR
B6.7 - Front Fog Lights W CONNECTOR Design 696
L9 - Fog Lights (Halogen White)
L9 - Fog Lights (Halogen White) Design 698
TABLE OF CONTENTS
xxivL9 - Fog Lights (LED White)
L9 - Fog Lights (LED White) Design 700
L9 - Front Fog Lights W CONNECTOR
L9 - Front Fog Lights W CONNECTOR Design 702
A26 - Front Marker Lights
A26 - Front Marker Lights Design 704
A26 - Front Marker Lights W/Plow Lights
A26 - Front Marker Lights W/Plow Lights Design 705
B6.7 - Front Marker Lights - Without Snow Plow Lights
B6.7 - Front Marker Lights - Without Snow Plow Lights Design 707
B6.7 - Front Marker Lights - With Plow Lights
B6.7 - Front Marker Lights - With Plow Lights Design 709
L9 - Front Marker Lights - Without Snow Plow Lights
L9 - Front Marker Lights - Without Snow Plow Lights Design 713
L9 - Front Marker Lights - With Plow Lights
L9 - Front Marker Lights - With Plow Lights Design 715
A26 - Hazard Warning Light N/Trlr Socket
A26 - Hazard Warning Light N/Trlr Socket Design 719
L9 - Hazard Warning Light N/Trlr Socket
L9 - Hazard Warning Light N/Trlr Socket Design 721
A26 - Headlights W/LOWW, W/O Interrupt
A26 - Headlights W/LOWW, W/O Interrupt Design 723
A26 - Headlights W/O LOWW, W/O Interrupt
A26 - Headlights W/O LOWW, W/O Interrupt Design 725
A26 - Headlights W/LOWW, W/Interrupt - 10 PIN CLK
A26 - Headlights W/LOWW, W/Interrupt - 10 PIN CLK Design 727
A26 - Headlights W/O LOWW, W/Interrupt - 10 PIN CLK
A26 - Headlights W/O LOWW, W/Interrupt - 10 PIN CLK Design 729
A26 - Headlight W/Plowlights, W/LOWW, W/O Interrupt
A26 - Headlight W/Plowlights, W/LOWW, W/O Interrupt Design 731
A26 - Headlight W/Plowlights, W/O LOWW, W/O
Interrupt
A26 - Headlight W/Plowlights, W/O LOWW, W/O Interrupt Design 735
A26 - Headlights W/PlowLights, W/LOWW, W/Interrupt
- 10 PIN CLK
A26 - Headlights W/PlowLights, W/LOWW, W/Interrupt - 10 PIN CLK Design 739
A26 - Headlights W/PlowLights, W/O LOWW,
A26 - Headlights W/PlowLights, W/O LOWW, W/Interrupt - 10 PIN CLK
Design 743
TABLE OF CONTENTS
xxvB6.7 - Headlights W/O Lights ON With Wipers (LOWW)
W/O Headlights Interrupt
B6.7 - Headlights W/O Lights ON With Wipers (LOWW) W/O Headlights Interrupt
Design 747
B6.7 - Headlights W/O Lights ON with wipers (LOWW)
W/ Headlights Interrupt
B6.7 - Headlights W/O Lights ON with wipers (LOWW) W/ Headlights Interrupt
Design 751
B6.7 - Headlights W 10PIN CLK W/LOWW W/O
Interrupt
B6.7 - Headlights W 10PIN CLK W/LOWW W/O Interrupt Design 755
B6.7 - Headlights W 10PIN CLK W/LOWW W/Interrupt
B6.7 - Headlights W 10PIN CLK W/LOWW W/Interrupt Design 759
B6.7 - Headlights W/Plowlights W/O Lights ON With
B6.7 - Headlights W/Plowlights W/O Lights ON With Wipers (LOWW) W/O
Headlights Interrupt Design 763
B6.7 - Headlight W/Plowlights W/LOWW W/O
Headlight Interrupt -10 PIN CLK
B6.7 - Headlight W/Plowlights W/LOWW W/O Headlight Interrupt -10 PIN CLK
Design 771
B6.7 - Headlights W/PlowLights W/Headlight Interrupt
-10PIN CLK W/LOWW W/Interrupt
B6.7 - Headlights W/PlowLights W/Headlight Interrupt -10PIN CLK W/LOWW
W/Interrupt Design 779
B6.7 - Headlights W/PlowLights W/O Lights ON with
B6.7 - Headlights W/PlowLights W/O Lights ON with wipers (LOWW) W/
Headlights Interrupt Design 787
L9 - Headlights W/O Lights ON With Wipers (LOWW)
L9 - Headlights W/O Lights ON With Wipers (LOWW) W/O Headlights Interrupt
Design 795
L9 - Headlights W/O Lights ON with wipers (LOWW)
L9 - Headlights W/O Lights ON with wipers (LOWW) W/ Headlights Interrupt
Design 799
L9 - Headlights W 10PIN CLK W/LOWW W/O Interrupt
L9 - Headlights W 10PIN CLK W/LOWW W/O Interrupt Design 803
L9 - Headlights W 10PIN CLK W/LOWW W/Interrupt
L9 - Headlights W 10PIN CLK W/LOWW W/Interrupt Design 807
L9 - Headlights W/Plowlights W/O Lights ON With
L9 - Headlights W/Plowlights W/O Lights ON With Wipers (LOWW) W/O
Headlights Interrupt Design 811
TABLE OF CONTENTS
xxviL9 - Headlight W/Plowlights W/LOWW W/O Headlight
L9 - Headlight W/Plowlights W/LOWW W/O Headlight Interrupt -10 PIN CLK
Design 819
L9 - Headlights W/PlowLights W/Headlight Interrupt -
L9 - Headlights W/PlowLights W/Headlight Interrupt -10PIN CLK W/LOWW
W/Interrupt Design 827
L9 - Headlights W/PlowLights W/O Lights ON with
L9 - Headlights W/PlowLights W/O Lights ON with wipers (LOWW) W/ Headlights
Interrupt Design 835
A26 - License Plate Light (LED BOX LAMP Daisy
Chain Tail Light)
A26 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light) Design 843
A26 - License Plate Light (LED BOX LAMP Tail Light)
A26 - License Plate Light (LED BOX LAMP Tail Light) Design 844
A26 - License Plate Light (Tail Light Single Assembly)
A26 - License Plate Light (Tail Light Single Assembly) Design 845
Assembly)Option2
A26 - License Plate Light (Tail Light Single Assembly)Option2 Design 846
Assembly)Option3
A26 - License Plate Light (Tail Light Single Assembly)Option3 Design 847
A26 - License Plate Light (Tail Light Single Assy.)
W/Less Power Module (W/08TKC, 08THM)
A26 - License Plate Light (Tail Light Single Assy.) W/Less Power Module
(W/08TKC, 08THM) Design 848
B6.7 - License Plate Light (LED BOX LAMP Daisy
Chain Tail Light)
B6.7 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light) Design 849
B6.7 - License Plate Light (LED BOX LAMP Tail Light)
B6.7 - License Plate Light (LED BOX LAMP Tail Light) Design 850
B6.7 - License Plate Light (Tail Light Single Assy)
Option 1
B6.7 - License Plate Light (Tail Light Single Assy) Option 1 Design 851
Option 2
B6.7 - License Plate Light (Tail Light Single Assy) Option 2 Design 852
Option 3
B6.7 - License Plate Light (Tail Light Single Assy) Option 3 Design 853
TABLE OF CONTENTS
xxviiB6.7 - License Plate Light (Tail Light Single Assy)
Option 4
B6.7 - License Plate Light (Tail Light Single Assy) Option 4 Design 854
W/Less Power Module
B6.7 - License Plate Light (Tail Light Single Assy) W/Less Power Module
Design 855
L9 - License Plate Light (LED BOX LAMP Daisy Chain
Tail Light)
L9 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light) Design 856
L9 - License Plate Light (LED BOX LAMP Tail Light)
L9 - License Plate Light (LED BOX LAMP Tail Light) Design 857
L9 - License Plate Light (Tail Light Single Assy)
Option 1
L9 - License Plate Light (Tail Light Single Assy) Option 1 Design 858
Option 2
L9 - License Plate Light (Tail Light Single Assy) Option 2 Design 859
Option 3
L9 - License Plate Light (Tail Light Single Assy) Option 3 Design 860
Option 4
L9 - License Plate Light (Tail Light Single Assy) Option 4 Design 861
A26/B6.7/L9 - PARK LIGHTS - N/Marker Interrupt
A26/B6.7/L9 - PARK LIGHTS - N/Marker Interrupt Design 862
A26/B6.7/L9 - PARK LIGHTS - W/Marker Interrupt
10pin CLCKSPRING
A26/B6.7/L9 - PARK LIGHTS - W/Marker Interrupt 10pin CLCKSPRING
Design 864
A26/B6.7/L9 - PARK LIGHTS - W/Marker Interrupt 4 pin
clockspring
A26/B6.7/L9 - PARK LIGHTS - W/Marker Interrupt 4 pin clockspring Design 866
A26/B6.7/L9 - Snow Plow Lights
A26/B6.7/L9 - Snow Plow Lights Design 868
A26 - Rear Light (LED BOX LAMP Tail Light) W/08TPS,
08TPR
A26 - Rear Light (LED BOX LAMP Tail Light) W/08TPS, 08TPR Design 869
A26 - Rear Light (Tail Light) W/Less Power Module
(W/08TKC, 08THM)
A26 - Rear Light (Tail Light) W/Less Power Module (W/08TKC, 08THM)
Design 870
A26 - Rear Light (Tail Light) W/08THK
TABLE OF CONTENTS
xxviiiA26 - Rear Light (Tail Light) W/08THK Design 871
A26 - Rear Light (Tail Light) W/08TKB
A26 - Rear Light (Tail Light) W/08TKB Design 872
A26 - Rear Light (Tail Light) W/08TKJ
A26 - Rear Light (Tail Light) W/08TKJ Design 873
A26 - Rear Light (Tail Light) W_Daisy Chain pair of
Box Lamps W/08TRS
A26 - Rear Light (Tail Light) W_Daisy Chain pair of Box Lamps W/08TRS
Design 874
B6.7 - Rear Light (LED BOX LAMP Tail Light)
B6.7 - Rear Light (LED BOX LAMP Tail Light) Design 875
B6.7 - Rear Light (Tail Light) Option 1
B6.7 - Rear Light (Tail Light) Option 1 Design 876
B6.7 - Rear Light (Tail Light) Option 2
B6.7 - Rear Light (Tail Light) Option 2 Design 877
B6.7 - Rear Light (Tail Light) Option 3
B6.7 - Rear Light (Tail Light) Option 3 Design 878
B6.7 - Rear Light (Tail Light) Option 4
B6.7 - Rear Light (Tail Light) Option 4 Design 879
B6.7 - Rear Light (Tail Light) W_Daisy Chain pair of
Box Lamps
B6.7 - Rear Light (Tail Light) W_Daisy Chain pair of Box Lamps Design 880
L9 - Rear Light (LED BOX LAMP Tail Light)
L9 - Rear Light (LED BOX LAMP Tail Light) Design 881
L9 - Rear Light (Tail Light)
L9 - Rear Light (Tail Light) Design 882
L9 - Rear Light (Tail Light) W Daisy Chain pair of Box
Lamps
L9 - Rear Light (Tail Light) W Daisy Chain pair of Box Lamps Design 883
A26 - Work Lights LED W/ Sw Pack - Day Cab
A26 - Work Lights LED W/ Sw Pack - Day Cab Design 884
A26 - WORK LIGHT W Backup 1 Bulb
A26 - WORK LIGHT W Backup 1 Bulb Design 886
A26 - WORK LIGHT W BackUP 1 BULB
A26 - WORK LIGHT W BackUP 1 BULB Design 888
A26 - WORK LIGHT W RKE 1 BULB
A26 - WORK LIGHT W RKE 1 BULB Design 890
A26 - Work Light W/ Backup 1 Bulb W/Automatic W/
RKE
A26 - Work Light W/ Backup 1 Bulb W/Automatic W/ RKE Design 892
A26 - Work Light W/ Backup 1 Bulb W/Manual W/ RKE
A26 - Work Light W/ Backup 1 Bulb W/Manual W/ RKE Design 894
TABLE OF CONTENTS
xxixA26 - WORK LIGHT 1 BULB
A26 - WORK LIGHT 1 BULB Design 896
B6.7 - Work Lights LED W/ Sw Pack - Day Cab
B6.7 - Work Lights LED W/ Sw Pack - Day Cab Design 898
B6.7 - WORK LIGHT W BackUP 1 BULB
B6.7 - WORK LIGHT W BackUP 1 BULB Design 899
B6.7 - WORK LIGHT W RKE 1 BULB
B6.7 - WORK LIGHT W RKE 1 BULB Design 900
B6.7 - WORK LIGHT 1 BULB
B6.7 - WORK LIGHT 1 BULB Design 901
L9 - Work Lights LED W/ Sw Pack - Day Cab
L9 - Work Lights LED W/ Sw Pack - Day Cab Design 902
L9 - WORK LIGHT W BackUP 1 BULB Option 1
L9 - WORK LIGHT W BackUP 1 BULB Option 1 Design 904
L9 - WORK LIGHT W BackUP 1 BULB Option 2
L9 - WORK LIGHT W BackUP 1 BULB Option 2 Design 908
L9 - WORK LIGHT W RKE 1 BULB
L9 - WORK LIGHT W RKE 1 BULB Design 910
L9 - WORK LIGHT 1 BULB
L9 - WORK LIGHT 1 BULB Design 912
A26/B6.7/L9 - Fifth Wheel Slide
A26/B6.7/L9 - Fifth Wheel Slide Design 914
A26/B6.7/L9 - Jaw Unlock Control
A26/B6.7/L9 - Jaw Unlock Control Design 915
A26/B6.7/L9 - Jaw Unlock Control W/ SOLENOIDS
W/SWITCH PACKS
A26/B6.7/L9 - Jaw Unlock Control W/ SOLENOIDS W/SWITCH PACKS
Design 916
A26 - Fuel Heater (Vehicle Powered)(Davco)
A26 - Fuel Heater (Vehicle Powered)(Davco) Design 917
B6.7 - Fuel Heater (Vehicle Powered)(Davco)
B6.7 - Fuel Heater (Vehicle Powered)(Davco) Design 926
B6.7 - Fuel Heater (Vehicle Powered)(Racor)
B6.7 - Fuel Heater (Vehicle Powered)(Racor) Design 933
L9 - Fuel Heater (Vehicle Powered)(Davco)
L9 - Fuel Heater (Vehicle Powered)(Davco) Design 940
L9 - Fuel Heater (Vehicle Powered)(Racor)
L9 - Fuel Heater (Vehicle Powered)(Racor) Design 955
A26 - 26" Fuel Tank
A26 - 26" Fuel Tank Design 963
A26 - 26" Fuel Tank - Secondary
TABLE OF CONTENTS
xxxA26 - 26" Fuel Tank - Secondary Design 968
B6.7 - 26 inch Fuel Tank
B6.7 - 26 inch Fuel Tank Design 975
B6.7 - 26 inch Fuel Tank - Secondary
B6.7 - 26 inch Fuel Tank - Secondary Design 978
L9 - 26 inch Fuel Tank
L9 - 26 inch Fuel Tank Design 979
L9 - 26 inch Fuel Tank - Secondary
L9 - 26 inch Fuel Tank - Secondary Design 985
A26 - Water In Fuel (WIF) Davco N/ Heater
A26 - Water In Fuel (WIF) Davco N/ Heater Design 992
A26 - Water In Fuel (WIF) Davco W/ Heater
A26 - Water In Fuel (WIF) Davco W/ Heater Design 1001
B6.7 - Water In Fuel (WIF) Racor N/ Heater
B6.7 - Water In Fuel (WIF) Racor N/ Heater Design 1010
B6.7 - Water In Fuel (WIF) Racor W/ Heater
B6.7 - Water In Fuel (WIF) Racor W/ Heater Design 1017
L9 - Water In Fuel (WIF) Davco N/ Heater
L9 - Water In Fuel (WIF) Davco N/ Heater Design 1024
L9 - Water In Fuel (WIF) Davco W/ Heater
L9 - Water In Fuel (WIF) Davco W/ Heater Design 1033
A26 - Heating Ventilation & Air Conditioning (HVAC)
Auto Temp Control
A26 - Heating Ventilation & Air Conditioning (HVAC) Auto Temp Control
Design 1042
B6.7 - Heating Ventilation & Air Conditioning (HVAC)
Auto Temp Control
B6.7 - Heating Ventilation & Air Conditioning (HVAC) Auto Temp Control
Design 1045
L9 - Heating Ventilation & Air Conditioning (HVAC)
Auto Temp Control
L9 - Heating Ventilation & Air Conditioning (HVAC) Auto Temp Control
Design 1048
A26 - Heating Ventilation & Air Conditioning (HVAC) Design 1051
A26/B6.7/L9 - HVAC Assembly Actuators
A26/B6.7/L9 - HVAC Assembly Actuators Design 1052
B6.7 - Heating Ventilation & Air Conditioning (HVAC) Design 1053
L9 - Heating Ventilation & Air Conditioning (HVAC) Design 1054
A26 - Ambient Air Temperature
TABLE OF CONTENTS
xxxiA26 - Ambient Air Temperature Design 1055
A26 - Ambient Temperature Monitoring
A26 - Ambient Temperature Monitoring Design 1056
L9 - Ambient Air Temperature
L9 - Ambient Air Temperature Design 1057
B6.7 - Current Monitoring (Ammeter)
B6.7 - Current Monitoring (Ammeter) Design 1058
A26 - Brake Pressure (Auxiliary Gauge)
A26 - Brake Pressure (Auxiliary Gauge) Design 1060
A26 - Brake Pressure (Virtual Gauge)
A26 - Brake Pressure (Virtual Gauge) Design 1061
B6.7 - Brake Pressure (Auxiliary Gauge)
B6.7 - Brake Pressure (Auxiliary Gauge) Design 1062
B6.7 - Brake Pressure (Virtual Gauge)
B6.7 - Brake Pressure (Virtual Gauge) Design 1063
L9 - Brake Pressure (Auxiliary Gauge)
L9 - Brake Pressure (Auxiliary Gauge) Design 1064
L9 - Brake Pressure (Virtual Gauge)
L9 - Brake Pressure (Virtual Gauge) Design 1065
A26/B6.7/L9 - Compressed Air Supply
A26/B6.7/L9 - Compressed Air Supply Design 1066
A26/B6.7/L9 - DEF Economy Monitor (GEN IV)
A26/B6.7/L9 - DEF Economy Monitor (GEN IV) Design 1067
L9 - Coolant Temperature Monitoring (J1939 Comm)
L9 - Coolant Temperature Monitoring (J1939 Comm) Design 1068
A26/B6.7/L9 - Engine Usage Monitoring (Base) NA
A26/B6.7/L9 - Engine Usage Monitoring (Base) NA Design 1069
A26/B6.7/L9 - Engine Usage Monitoring (VID Option)
A26/B6.7/L9 - Engine Usage Monitoring (VID Option) Design 1070
A26/B6.7/L9 - Engine Oil Level Monitoring
A26/B6.7/L9 - Engine Oil Level Monitoring Design 1071
A26/B6.7/L9 - Engine Oil Pressure
A26/B6.7/L9 - Engine Oil Pressure Design 1072
A26/B6.7/L9 - Engine Oil Temperature (NA Mux)
A26/B6.7/L9 - Engine Oil Temperature (NA Mux) Design 1073
A26/B6.7/L9 - Engine Oil Temperature(NA MUX AUX
Gauge)
A26/B6.7/L9 - Engine Oil Temperature(NA MUX AUX Gauge) Design 1074
A26 - Engine Speed (Tachometer)
A26 - Engine Speed (Tachometer) Design 1075
TABLE OF CONTENTS
xxxiiB6.7 & L9 - Engine Speed (Tachometer)
B6.7 & L9 - Engine Speed (Tachometer) Design 1076
A26/B6.7/L9 - Fuel Economy Monitor
A26/B6.7/L9 - Fuel Economy Monitor Design 1077
A26/B6.7/L9 - Odometer (via BCM/EGC)
A26/B6.7/L9 - Odometer (via BCM/EGC) Design 1078
A26/B6.7/L9 - Trip Odometer w/VID
A26/B6.7/L9 - Trip Odometer w/VID Design 1079
A26/B6.7/L9 - Trip Odometer (Gen 4 Cluster)
A26/B6.7/L9 - Trip Odometer (Gen 4 Cluster) Design 1080
A26/B6.7/L9 - Trip Odometer ( w/ECM & TCM)
A26/B6.7/L9 - Trip Odometer ( w/ECM & TCM) Design 1081
A26/B6.7/L9 - PTO Hour Meter
A26/B6.7/L9 - PTO Hour Meter Design 1082
A26 - Transmission Oil Temperature-Manual Trans
A26 - Transmission Oil Temperature-Manual Trans Design 1083
w/Aux Gauge
A26 - Transmission Oil Temperature-Manual Trans w/Aux Gauge Design 1085
B6.7 - Transmission Oil Temperature-Manual Trans
B6.7 - Transmission Oil Temperature-Manual Trans Design 1087
(w/Aux Gauge)
B6.7 - Transmission Oil Temperature-Manual Trans (w/Aux Gauge) Design 1088
L9 - Transmission Oil Temperature-Automatic Trans
L9 - Transmission Oil Temperature-Automatic Trans Design 1089
w/Aux Gauge
L9 - Transmission Oil Temperature-Automatic Trans w/Aux Gauge Design 1090
L9 - Transmission Oil Temperature-Manual
L9 - Transmission Oil Temperature-Manual Transmission Design 1091
w/Aux Gauge
L9 - Transmission Oil Temperature-Manual Trans w/Aux Gauge Design 1092
A26/B6.7/L9 - Vehicle Speedometer System
(Automatic XMSN)
A26/B6.7/L9 - Vehicle Speedometer System (Automatic XMSN) Design 1093
A26 - Vehicle Speedometer System (Manual XMSN)
A26 - Vehicle Speedometer System (Manual XMSN) Design 1094
B6.7 - Vehicle Speedometer System (Manual XMSN)
B6.7 - Vehicle Speedometer System (Manual XMSN) Design 1095
TABLE OF CONTENTS
xxxiiiL9 - Vehicle Speedometer System (Manual XMSN)
L9 - Vehicle Speedometer System (Manual XMSN) Design 1096
A26/B6.7/L9 - Vehicle Speed Limit Override
A26/B6.7/L9 - Vehicle Speed Limit Override Design 1097
A26/B6.7/L9 - Voltage Monitoring (Voltmeter)
A26/B6.7/L9 - Voltage Monitoring (Voltmeter) Design 1098
A26/B6.7/L9 - Voltage Monitoring (Voltmeter) (with
Aux gauge)
A26/B6.7/L9 - Voltage Monitoring (Voltmeter) (with Aux gauge) Design 1099
A26/B6.7/L9 - Engine Warning_MUX
A26/B6.7/L9 - Engine Warning_MUX Design 1100
A26/B6.7/L9 - High Exhaust System Temperature
(HEST) Monitoring
A26/B6.7/L9 - High Exhaust System Temperature (HEST) Monitoring Design 1101
A26/B6.7/L9 - Up Shift Indicator
A26/B6.7/L9 - Up Shift Indicator Design 1102
A26 - Range Inhibit with Seatbelt
A26 - Range Inhibit with Seatbelt Design 1103
A26/B6.7/L9 - Trans Range Inhibit (J1939 Comm)
A26/B6.7/L9 - Trans Range Inhibit (J1939 Comm) Design 1104
B6.7 - Range Inhibit (sixth gear inhibit switch)
B6.7 - Range Inhibit (sixth gear inhibit switch) Design 1105
A26/B6.7/L9 - Vehicle Information Display Premium w/
Wi-Fi (VID)
A26/B6.7/L9 - Vehicle Information Display Premium w/ Wi-Fi (VID) Design 1106
A26/B6.7/L9 - Vehicle Information Display (Without
Bluetooth)
A26/B6.7/L9 - Vehicle Information Display (Without Bluetooth) Design 1107
Bluetooth)
A26/B6.7/L9 - Vehicle Information Display (With Bluetooth) Design 1108
A26/B6.7/L9 - Cab Dome Light W/Classic Trim
A26/B6.7/L9 - Cab Dome Light W/Classic Trim Design 1109
A26/B6.7/L9 - Cab Dome Light W/ Combo in Diamond
Trim
A26/B6.7/L9 - Cab Dome Light W/ Combo in Diamond Trim Design 1110
A26/B6.7/L9 - Interior Task Lights (Map) - Dome
Combo
A26/B6.7/L9 - Interior Task Lights (Map) - Dome Combo Design 1111
A26/B6.7/L9 - Courtesy Light Cab 2 door
A26/B6.7/L9 - Courtesy Light Cab 2 door Design 1112
TABLE OF CONTENTS
xxxivA26/B6.7/L9 - Courtesy Light 4 Door
A26/B6.7/L9 - Courtesy Light 4 Door Design 1113
A26/B6.7/L9 - Panel Backlighting (Cabin Dimmer)
A26/B6.7/L9 - Panel Backlighting (Cabin Dimmer) Design 1114
A26/B6.7/L9 - Axle Lift Controls
A26/B6.7/L9 - Axle Lift Controls Design 1115
A26 - Axle Lift Controls
A26 - Axle Lift Controls Design 1119
A26 - Lift Axle Controls (Center Pedestal Controls f/ 1
lift axle)
A26 - Lift Axle Controls (Center Pedestal Controls f/ 1 lift axle) Design 1121
A26 - Lift Axle Controls (Center Pedestal Controls f/ 2
Lift Axles)
A26 - Lift Axle Controls (Center Pedestal Controls f/ 2 Lift Axles) Design 1123
A26 - Lift Axle Controls (Center Pedestal Controls f/ 3
lift axles)
A26 - Lift Axle Controls (Center Pedestal Controls f/ 3 lift axles) Design 1124
L9 - Axle Lift Controls Option 2
L9 - Axle Lift Controls Option 2 Design 1125
L9 - Lift Axle Controls (Center Pedestal Controls f/ 1
lift axle)
L9 - Lift Axle Controls (Center Pedestal Controls f/ 1 lift axle) Design 1127
L9 - Lift Axle Controls (Center Pedestal Controls f/ 2
Lift Axles)
L9 - Lift Axle Controls (Center Pedestal Controls f/ 2 Lift Axles) Design 1129
L9 - Lift Axle Controls (Center Pedestal Controls f/ 3
lift axles)
L9 - Lift Axle Controls (Center Pedestal Controls f/ 3 lift axles) Design 1130
B6.7 - Axle Loading (Weight) Rear
B6.7 - Axle Loading (Weight) Rear Design 1131
L9 - Axle Loading (Weight) Rear
L9 - Axle Loading (Weight) Rear Design 1133
A26 - Axle Temperature Monitoring (Single Rear Aux
Gauge)
A26 - Axle Temperature Monitoring (Single Rear Aux Gauge) Design 1135
Virtual Gauge)
A26 - Axle Temperature Monitoring (Single Rear Virtual Gauge) Design 1136
A26 - Axle Temperature Monitoring (Tandem Rear Aux
Gauge)
A26 - Axle Temperature Monitoring (Tandem Rear Aux Gauge) Design 1137
TABLE OF CONTENTS
xxxvA26 - Axle Temperature Monitoring (Tandem Rear
Virtual Gauge)
A26 - Axle Temperature Monitoring (Tandem Rear Virtual Gauge) Design 1138
B6.7 - Axle Temperature Monitoring (Single Rear Aux
Gauge)
B6.7 - Axle Temperature Monitoring (Single Rear Aux Gauge) Design 1139
Virtual Gauge)
B6.7 - Axle Temperature Monitoring (Single Rear Virtual Gauge) Design 1140
L9 - Axle Temperature Monitoring (Tandem Rear Aux
Gauge) Option 1
L9 - Axle Temperature Monitoring (Tandem Rear Aux Gauge) Option 1
Design 1141
Gauge) Option 2
L9 - Axle Temperature Monitoring (Tandem Rear Aux Gauge) Option 2
Design 1142
Virtual Gauge) Option 1
L9 - Axle Temperature Monitoring (Tandem Rear Virtual Gauge) Option 1
Design 1143
Virtual Gauge) Option 2
L9 - Axle Temperature Monitoring (Tandem Rear Virtual Gauge) Option 2
Design 1144
A26 - Driver Controlled Locking Differential FR and RR
Axles (Dana w/ two sw)
A26 - Driver Controlled Locking Differential FR and RR Axles (Dana w/ two sw)
Design 1145
Axle (Dana w/ one switch)
A26 - Driver Controlled Locking Differential FR and RR Axle (Dana w/ one switch)
Design 1146
A26 - Driver Controlled Locking Differential RR Axle
(Dana w/ one sw)
A26 - Driver Controlled Locking Differential RR Axle (Dana w/ one sw)
Design 1147
Axles (Meritor w/ two sw)
A26 - Driver Controlled Locking Differential FR and RR Axles (Meritor w/ two sw)
Design 1148
Axle (Meritor w/ one sw)
A26 - Driver Controlled Locking Differential FR and RR Axle (Meritor w/ one sw)
Design 1149
TABLE OF CONTENTS
xxxviA26 - Driver Controlled Locking Differential RR Axle
(Meritor w/ one sw)
A26 - Driver Controlled Locking Differential RR Axle (Meritor w/ one sw)
Design 1150
B6.7 - Driver Controlled Locking Differential - RR Axle
(Dana w/ one sw)
B6.7 - Driver Controlled Locking Differential - RR Axle (Dana w/ one sw)
Design 1151
(Meritor w/ one sw)
B6.7 - Driver Controlled Locking Differential - RR Axle (Meritor w/ one sw)
Design 1152
L9 - Driver Controlled Locking Differential - FR and RR
L9 - Driver Controlled Locking Differential - FR and RR Axles (Dana w/ two sw)
Design 1153
L9 - Driver Controlled Locking Differential - FR and RR Axle (Dana w/ one sw)
Design 1154
L9 - Driver Controlled Locking Differential - RR Axle
(Dana w/ one sw)
L9 - Driver Controlled Locking Differential - RR Axle (Dana w/ one sw)
Design 1155
L9 - Driver Controlled Locking Differential - FR and RR Axles (Meritor w/ two sw)
Design 1156
L9 - Driver Controlled Locking Differential - FR and RR Axle (Meritor w/ one sw)
Design 1157
(Meritor w/ one sw)
L9 - Driver Controlled Locking Differential - RR Axle (Meritor w/ one sw)
Design 1158
A26/B6.7/L9 - Height Control
A26/B6.7/L9 - Height Control Design 1159
A26/B6.7/L9 - Power Divider Lock Control and
Monitoring
A26/B6.7/L9 - Power Divider Lock Control and Monitoring Design 1160
L9 - Rear Axle Load Distribution
L9 - Rear Axle Load Distribution Design 1161
A26/B6.7/L9 - Rear Suspension Pressure Monitoring
(Auxiliary Gauge)
A26/B6.7/L9 - Rear Suspension Pressure Monitoring (Auxiliary Gauge)
Design 1162
TABLE OF CONTENTS
xxxviiA26/B6.7/L9 - Rear Suspension Pressure Monitoring
(Virtual Gauge)
A26/B6.7/L9 - Rear Suspension Pressure Monitoring (Virtual Gauge) Design 1164
A26 - Two Speed Axle (Multiplex SW on Dash)
A26 - Two Speed Axle (Multiplex SW on Dash) Design 1166
B6.7 - Two Speed Axle (AirShift on Shifter)
B6.7 - Two Speed Axle (AirShift on Shifter) Design 1167
L9 - Two Speed Axle (AirShift on Shifter)
L9 - Two Speed Axle (AirShift on Shifter) Design 1168
L9 - Two Speed Axle (Multiplex SW on Dash)
L9 - Two Speed Axle (Multiplex SW on Dash) Design 1169
A26/B6.7/L9 - Driver and Passenger Seats - RollTek
(Hard Wired)
A26/B6.7/L9 - Driver and Passenger Seats - RollTek (Hard Wired) Design 1170
A26/B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard
Wired) - Leather
A26/B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard Wired) - Leather
Design 1171
Wired) - Mordular
A26/B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard Wired) - Mordular
Design 1172
Wired) - Vinyl
A26/B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard Wired) - Vinyl Design 1173
A26/B6.7/L9 - Seatbelt Reminder 6 Seats
A26/B6.7/L9 - Seatbelt Reminder 6 Seats Design 1174
A26/B6.7/L9 - Seatbelt Reminder (Warning)(Driver
only)
A26/B6.7/L9 - Seatbelt Reminder (Warning)(Driver only) Design 1175
A26/B6.7/L9 - Seatbelt Reminder (Warning)(Driver &
Passenger in parallel)
A26/B6.7/L9 - Seatbelt Reminder (Warning)(Driver & Passenger in parallel)
Design 1176
Vehicle Data Recorder (No Display)
Vehicle Data Recorder (No Display) Design 1177
Vehicle Data Recorder (W/ Display)
Vehicle Data Recorder (W/ Display) Design 1179
L9 - TEM Electric Trailer Brake Controller Activated
Stop LT
L9 - TEM Electric Trailer Brake Controller Activated Stop LT Design 1181
A26 - TEM Electric Trailer Brake Controller Activated
Stop LT
A26 - TEM Electric Trailer Brake Controller Activated Stop LT Design 1182
TABLE OF CONTENTS
xxxviiiA26 - TEM Electric Trailer Brake Controller Activated
Stop LT (Option2)
A26 - TEM Electric Trailer Brake Controller Activated Stop LT (Option2)
Design 1183
B6.7 - TEM Electric Trailer Brake Controller Activated
Stop LT Option 2
B6.7 - TEM Electric Trailer Brake Controller Activated Stop LT Option 2
Design 1184
B6.7 - TEM _Electric Trailer Brake Controller Activated
Stop LT Option 1
B6.7 - TEM _Electric Trailer Brake Controller Activated Stop LT Option 1
Design 1185
L9 - Trailer Interface - ABS (ETB Feed, Blunt Cut)
L9 - Trailer Interface - ABS (ETB Feed, Blunt Cut) Design 1186
B6.7 - Trailer Interface (Lighting) – BLUNT CUT (Part
of Electric Trailer Brakes) Option 1
B6.7 - Trailer Interface (Lighting) – BLUNT CUT (Part of Electric Trailer Brakes)
Option 1 Design 1187
of Electric Trailer Brakes) Option 2
Option 2 Design 1188
L9 - Trailer Interface (Lighting) – BLUNT CUT (Part of
L9 - Trailer Interface (Lighting) – BLUNT CUT (Part of Electric Trailer Brakes)
Option 1 Design 1189
Option 2 Design 1190
A26 - Transmission Shifter (Stalk Shifter Allison)
A26 - Transmission Shifter (Stalk Shifter Allison) Design 1191
B6.7 - Transmission Shifter (Stalk Shifter Allison)
B6.7 - Transmission Shifter (Stalk Shifter Allison) Design 1193
B6.7 - Transmission Shifter (T-Handle for Allison With
Park Position)
B6.7 - Transmission Shifter (T-Handle for Allison With Park Position) Design 1195
B6.7 - T-Handle for Allison Without Park Position
B6.7 - T-Handle for Allison Without Park Position Design 1197
B6.7 - Transmission Shifter Allison 5th Gen Push
Button(SURHD)
B6.7 - Transmission Shifter Allison 5th Gen Push Button(SURHD) Design 1199
L9 - Transmission Shifter Allison 5th Gen Push
Button(SURHD)
TABLE OF CONTENTS
xxxixL9 - Transmission Shifter Allison 5th Gen Push Button(SURHD) Design 1201
L9 - Transmission Shifter (Stalk Shifter Allison)
L9 - Transmission Shifter (Stalk Shifter Allison) Design 1202
A26/B6.7/L9 - Transfer Case - High/Low Air Sol
A26/B6.7/L9 - Transfer Case - High/Low Air Sol Design 1204
A26/B6.7/L9 - Transfer Case - High/Neu/Low Air Sol
A26/B6.7/L9 - Transfer Case - High/Neu/Low Air Sol Design 1205
A26 - Ultrashift Plus
A26 - Ultrashift Plus Design 1206
L9 - Ultrashift Plus
L9 - Ultrashift Plus Design 1207
A26 - Transmission (Allison 3K/4K)
A26 - Transmission (Allison 3K/4K) Design 1208
L9 - Auto Neutral (Allison without Multiplex Switch
and Confirmation Telltale)
L9 - Auto Neutral (Allison without Multiplex Switch and Confirmation Telltale)
Design 1210
L9 - Auto Neutral (Allison with Multiplex Switch and
L9 - Auto Neutral (Allison with Multiplex Switch and Confirmation Telltale)
Design 1212
B6.7 - Transmission (Allison 1K/2K)
B6.7 - Transmission (Allison 1K/2K) Design 1214
B6.7 - Transmission (Allison 3K/4K)
B6.7 - Transmission (Allison 3K/4K) Design 1215
L9 - Transmission I/O (Allison 3K with Body Builder) -
13WUC
L9 - Transmission I/O (Allison 3K with Body Builder) - 13WUC Design 1217
L9 - Transmission (Allison 3K/4K)
L9 - Transmission (Allison 3K/4K) Design 1218
A26 - Transmissions Electrical I/O (Eaton Ultrashift)
A26 - Transmissions Electrical I/O (Eaton Ultrashift) Design 1220
L9 - Transmissions Electrical I/O (Eaton Ultrashift)
L9 - Transmissions Electrical I/O (Eaton Ultrashift) Design 1221
A26 - Hill Start Aid (Bendix)
A26 - Hill Start Aid (Bendix) Design 1222
L9 - Hill Start Aid (Bendix)
L9 - Hill Start Aid (Bendix) Design 1224
L9 - Hill Start Aid (WABCO)
L9 - Hill Start Aid (WABCO) Design 1226
A26/B6.7/L9 - Transmission - MODE Selection
A26/B6.7/L9 - Transmission - MODE Selection Design 1227
TABLE OF CONTENTS
xlB6.7 - Windshield Washer Pump
B6.7 - Windshield Washer Pump Design 1228
B6.7 - Windshield Washer Pump & Low Fluid Sensor
B6.7 - Windshield Washer Pump & Low Fluid Sensor Design 1229
L9 - Windshield Washer Pump & Low Fluid Sensor
L9 - Windshield Washer Pump & Low Fluid Sensor Design 1230
A26 - Windshield Wipers
A26 - Windshield Wipers Design 1232
B6.7 - Windshield Wipers
B6.7 - Windshield Wipers Design 1233
L9 - Windshield Wipers
L9 - Windshield Wipers Design 1234
B6.7/L9 - Battery Disconnect (W/Switch and
W/Solenoid)
B6.7/L9 - Battery Disconnect (W/Switch and W/Solenoid) Design 1235
A26 - Bosch LIL165 LIL200 Alternator W/Sensor
A26 - Bosch LIL165 LIL200 Alternator W/Sensor Design 1236
A26 - Delco Remy 28SI Alternator W/Sensor
A26 - Delco Remy 28SI Alternator W/Sensor Design 1238
A26 - Delco Remy 36SI Alternator W/Sensor
A26 - Delco Remy 36SI Alternator W/Sensor Design 1240
A26 - Delco Remy 40SI Alternator W/Sensor
A26 - Delco Remy 40SI Alternator W/Sensor Design 1242
A26 - Leece-Neville AVI160 Alternator
A26 - Leece-Neville AVI160 Alternator Design 1244
A26 - Leece-Neville AVI160-210A/240A Alternator
W/Sensor
A26 - Leece-Neville AVI160-210A/240A Alternator W/Sensor Design 1245
A26 - Leece-Neville 320PAH Alternator
A26 - Leece-Neville 320PAH Alternator Design 1247
A26 - Leece-Neville - LN 325A Alternator W/Sensor
A26 - Leece-Neville - LN 325A Alternator W/Sensor Design 1248
A26- Bosch LH160 LH200 Alternator
A26- Bosch LH160 LH200 Alternator Design 1250
B6.7 - Bosch LH160_LH200 Alternator
B6.7 - Bosch LH160_LH200 Alternator Design 1251
B6.7 - Delco Remy 28SI Alternator W/Sensor Option 1
B6.7 - Delco Remy 28SI Alternator W/Sensor Option 1 Design 1253
B6.7 - Delco Remy 28SI Alternator W/Sensor Option 2
B6.7 - Delco Remy 28SI Alternator W/Sensor Option 2 Design 1254
B6.7 - Delco Remy 36SI Alternator W/Sensor
B6.7 - Delco Remy 36SI Alternator W/Sensor Design 1255
TABLE OF CONTENTS
xliB6.7 - Delco Remy 40SI Alternator W/Sensor
B6.7 - Delco Remy 40SI Alternator W/Sensor Design 1256
B6.7 - Leece-Neville AVI160 Alternator
B6.7 - Leece-Neville AVI160 Alternator Design 1257
B6.7 - Leece-Neville AVI160-210A/240A Alternator
W/Sensor
B6.7 - Leece-Neville AVI160-210A/240A Alternator W/Sensor Design 1258
B6.7 - Leece-Neville 320PAH Alternator
B6.7 - Leece-Neville 320PAH Alternator Design 1259
B6.7 - Leece-Neville - LN 325A Alternator W/Sensor
B6.7 - Leece-Neville - LN 325A Alternator W/Sensor Design 1260
L9 - Bosch LH160_LH200 Alternator
L9 - Bosch LH160_LH200 Alternator Design 1261
L9 - Delco Remy 28SI Alternator W/Sensor
L9 - Delco Remy 28SI Alternator W/Sensor Design 1262
L9 - Delco Remy 36SI Alternator W/Sensor
L9 - Delco Remy 36SI Alternator W/Sensor Design 1263
L9 - Delco Remy 40SI Alternator W/Sensor
L9 - Delco Remy 40SI Alternator W/Sensor Design 1264
L9 - Leece-Neville AVI160 Alternator
L9 - Leece-Neville AVI160 Alternator Design 1265
L9 - Leece-Neville AVI160-210A/240A Alternator
W/Sensor
L9 - Leece-Neville AVI160-210A/240A Alternator W/Sensor Design 1266
L9 - Leece-Neville - LN 325A Alternator W/Sensor
L9 - Leece-Neville - LN 325A Alternator W/Sensor Design 1267
A26/B6.7/L9 - Crank Inhibit (Engine Speed Inhibit
Only)
A26/B6.7/L9 - Crank Inhibit (Engine Speed Inhibit Only) Design 1268
A26 - Cranking (Starter) GEN4 BODY CONTROL
MODULE W/O Thermal Overcrank
A26 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/O Thermal
Overcrank Design 1269
MODULE W/ Thermal Overcrank
A26 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/ Thermal
Overcrank Design 1275
B6.7 - Cranking (Starter) GEN4 BODY CONTROL
B6.7 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/O Thermal
Overcrank Design 1281
L9 - Cranking (Starter) GEN4 BODY CONTROL
TABLE OF CONTENTS
xliiL9 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/O Thermal
Overcrank Design 1282
MODULE W/ Thermal Overcrank - External Switch
L9 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/ Thermal Overcrank
- External Switch Design 1283
A26 - Cranking Request (w/ Key Switch w/ BCM)
A26 - Cranking Request (w/ Key Switch w/ BCM) Design 1284
A26/B6.7/L9 - Key Switch (Operator Input)
A26/B6.7/L9 - Key Switch (Operator Input) Design 1286
B6.7 - Cranking Request (w/ Key Switch w/ BCM)
B6.7 - Cranking Request (w/ Key Switch w/ BCM) Design 1288
L9 - Cranking Request (w/ Key Switch w/ BCM)
L9 - Cranking Request (w/ Key Switch w/ BCM) Design 1290
A26 - Clutch Switch/Monitoring (High and Low Switch
to BCM)
A26 - Clutch Switch/Monitoring (High and Low Switch to BCM) Design 1291
A26 - Starter Interlock (BCM Controlled with Input
from Allison 3K/4K TCM)
A26 - Starter Interlock (BCM Controlled with Input from Allison 3K/4K TCM)
Design 1292
A26 - Starter Interlock (BCM LSD Controlled w/ Relay
& N/ Auto SS)
A26 - Starter Interlock (BCM LSD Controlled w/ Relay & N/ Auto SS) Design 1294
B6.7 - Clutch Switch/Monitoring (High and Low Switch
to BCM)
B6.7 - Clutch Switch/Monitoring (High and Low Switch to BCM) Design 1295
B6.7 - Starter Interlocks (BCM Controlled with Input
from Allison 1K/2K TCM)
B6.7 - Starter Interlocks (BCM Controlled with Input from Allison 1K/2K TCM)
Design 1296
B6.7 - Starter Interlocks (BCM Controlled with Input from Allison 3K/4K TCM)
Design 1297
L9 - Clutch Switch/Monitoring (High and Low Switch
to BCM)
L9 - Clutch Switch/Monitoring (High and Low Switch to BCM) Design 1299
L9 - Starter Interlocks (BCM Controlled with Input
L9 - Starter Interlocks (BCM Controlled with Input from Allison 3K/4K TCM)
Design 1300
L9 - Starter Interlock (BCM HSD controlled W/ Clutch
SW & N/Auto SS)
TABLE OF CONTENTS
xliiiL9 - Starter Interlock (BCM HSD controlled W/ Clutch SW & N/Auto SS)
Design 1302
L9 - Starter Interlock (BCM LSD Controlled w/ Relay &
N/ Auto SS)_EATON XMSN
L9 - Starter Interlock (BCM LSD Controlled w/ Relay & N/ Auto SS)_EATON
XMSN Design 1303
A26 - Battery International (4) 12V
A26 - Battery International (4) 12V Design 1304
B6.7 - Battery International (4) 12V
B6.7 - Battery International (4) 12V Design 1305
L9 - Battery International (4) 12V
L9 - Battery International (4) 12V Design 1306
Connectors 1307
Part Assembly List
Connector Assembly List HV 3419
Index 36
Brand: International, Navistar
Type of Manual: Interactive Schematics
Model: International HV Series Truck
Built: 1/1/2018 To 12/10/2021
Part Number: 0000018823
Publication Date: 2022
Number of Pages: 3701 Pages
A26/B6.7/L9 - BODY CONTROL MODULE (Body
Control Module)
A26/B6.7/L9 - BODY CONTROL MODULE (Body Control Module) Design 1
A26 - ABS Private J1939
A26 - ABS Private J1939 Design 9
A26 - Body J1939 (250kbps)
A26 - Body J1939 (250kbps) Design 10
A26 - Cab J1939 (250Kbps)
A26 - Cab J1939 (250Kbps) Design 11
A26 - Diagnostic Private J1939
A26 - Diagnostic Private J1939 Design 12
A26 - Engine Private J1939 (250kbps)
A26 - Engine Private J1939 (250kbps) Design 13
A26 - Low Speed J1939 (125Kbps)
A26 - Low Speed J1939 (125Kbps) Design 14
A26 - Telematics J1708 (9.6kbps)
A26 - Telematics J1708 (9.6kbps) Design 15
A26 - Powertrain J1939 Allison 3k/4k
A26 - Powertrain J1939 Allison 3k/4k Design 16
A26 - Powertrain J1939 UltraShift Transmission
A26 - Powertrain J1939 UltraShift Transmission Design 17
B6.7 - ABS Private J1939
B6.7 - ABS Private J1939 Design 18
B6.7 - Body J1939 (250kbps)
B6.7 - Body J1939 (250kbps) Design 19
B6.7 - Cab J1939 (250kbps)
B6.7 - Cab J1939 (250kbps) Design 20
B6.7 - Engine Private J1939 (250kbps)
B6.7 - Engine Private J1939 (250kbps) Design 21
B6.7 - Low Speed J1939 (125kbps)
B6.7 - Low Speed J1939 (125kbps) Design 22
B6.7 - Telematics J1708 (9.6kbps)
B6.7 - Telematics J1708 (9.6kbps) Design 23
B6.7 - Powertrain J1939 Allison 1k/2k
B6.7 - Powertrain J1939 Allison 1k/2k Design 24
B6.7 - Powertrain J1939 Allison 3k/4k
B6.7 - Powertrain J1939 Allison 3k/4k Design 25
B6.7 - Powertrain J1939 Manual Transmission
B6.7 - Powertrain J1939 Manual Transmission Design 26
L9 - ABS Private J1939
L9 - ABS Private J1939 Design 27
TABLE OF CONTENTS
iL9 - Body J1939 (250kbps)
L9 - Body J1939 (250kbps) Design 28
L9 - Cab J1939 (250kbps)
L9 - Cab J1939 (250kbps) Design 29
L9 - Engine Private J1939 (250kbps)
L9 - Engine Private J1939 (250kbps) Design 30
L9 - Low Speed J1939 (125kbps)
L9 - Low Speed J1939 (125kbps) Design 31
L9 - Telematics J1708 (9.6kbps)
L9 - Telematics J1708 (9.6kbps) Design 32
L9 - Powertrain J1939 Allison 3k/4k
L9 - Powertrain J1939 Allison 3k/4k Design 33
L9 - Powertrain J1939 Eaton
L9 - Powertrain J1939 Eaton Design 34
L9 - Powertrain J1939 Manual Transmission
L9 - Powertrain J1939 Manual Transmission Design 35
A26 - Navistar ECM
A26 - Navistar ECM Design 36
B6.7 - ECM Cummins CM2350A
B6.7 - ECM Cummins CM2350A Design 37
L9 - ECM Cummins CM2350A
L9 - ECM Cummins CM2350A Design 38
A26/B6.7/L9 - Instrument Cluster (Premium)
A26/B6.7/L9 - Instrument Cluster (Premium) Design 39
A26/B6.7/L9 - Instrument Cluster (Standard)
A26/B6.7/L9 - Instrument Cluster (Standard) Design 41
A26/B6.7/L9 - Instrument Cluster - Bulb Check
A26/B6.7/L9 - Instrument Cluster - Bulb Check Design 43
A26/B6.7/L9 - Instrument Cluster - Request and Status
A26/B6.7/L9 - Instrument Cluster - Request and Status Design 44
A26/B6.7/L9 - Ground Splice Pack 1022 & 1023
A26/B6.7/L9 - Ground Splice Pack 1022 & 1023 Design 45
A26/B6.7/L9 - Ground Splice Pack 1027
A26/B6.7/L9 - Ground Splice Pack 1027 Design 46
A26/B6.7/L9 - Interior Dual Post Ground Stud-Cowl
Wall
A26/B6.7/L9 - Interior Dual Post Ground Stud-Cowl Wall Design 47
A26/B6.7/L9 - ZVR Splice Pack - 1620
A26/B6.7/L9 - ZVR Splice Pack - 1620 Design 48
A26 - Center Chassis Ground Splice Packs
A26 - Center Chassis Ground Splice Packs Design 49
TABLE OF CONTENTS
iiB6.7 - Center Chassis Ground Splice Packs
B6.7 - Center Chassis Ground Splice Packs Design 50
L9 - Center Chassis Ground Splice Packs
L9 - Center Chassis Ground Splice Packs Design 51
A26 - Forward Chassis Ground Splice Packs 8800
A26 - Forward Chassis Ground Splice Packs 8800 Design 52
B6.7 - Forward Chassis Ground Splice Packs 8800
B6.7 - Forward Chassis Ground Splice Packs 8800 Design 53
L9 - Forward Chassis Ground Splice Packs 8800
L9 - Forward Chassis Ground Splice Packs 8800 Design 54
A26 - Powertrain Splice Pack 6704
A26 - Powertrain Splice Pack 6704 Design 55
A26 - ZVR Splice Packs 6702 & 6704B
A26 - ZVR Splice Packs 6702 & 6704B Design 56
B6.7 - Powertrain Splice Pack 6704
B6.7 - Powertrain Splice Pack 6704 Design 57
B6.7 - ZVR Splice Pack - 6747
B6.7 - ZVR Splice Pack - 6747 Design 58
L9 - Powertrain Splice Pack 6704 & 6704B
L9 - Powertrain Splice Pack 6704 & 6704B Design 59
L9 - ZVR Splice Pack - 6747
L9 - ZVR Splice Pack - 6747 Design 60
A26/B6.7/L9 - Lighting Control Module
A26/B6.7/L9 - Lighting Control Module Design 61
A26 - Aftertreatment PDM
A26 - Aftertreatment PDM Design 63
B6.7 - Aftertreatment PDM
B6.7 - Aftertreatment PDM Design 64
L9 - Aftertreatment PDM
L9 - Aftertreatment PDM Design 65
A26 - Auxilary Power Fuse
A26 - Auxilary Power Fuse Design 66
B6.7 - Auxilary Power Fuse
B6.7 - Auxilary Power Fuse Design 67
L9 - Auxilary Power Fuse
L9 - Auxilary Power Fuse Design 68
A26 - Chassis PDM
A26 - Chassis PDM Design 69
B6.7/L9 - Chassis PDM
B6.7/L9 - Chassis PDM Design 70
TABLE OF CONTENTS
iiiA26/B6.7/L9 - Battery Feed
A26/B6.7/L9 - Battery Feed Design 71
A26/B6.7/L9 - Interior PDM Chart
A26/B6.7/L9 - Interior PDM Chart Design 72
A26/B6.7/L9 - Key Switch Accessory
A26/B6.7/L9 - Key Switch Accessory Design 73
A26/B6.7/L9 - Key Switch Ignition
A26/B6.7/L9 - Key Switch Ignition Design 74
A26 - Relays
A26 - Relays Design 75
B6.7 - Relays
B6.7 - Relays Design 76
L9 - Relays
L9 - Relays Design 77
A26/B6.7/L9 - ABS CAN Splice Pack - 1410
A26/B6.7/L9 - ABS CAN Splice Pack - 1410 Design 78
A26/B6.7/L9 - Panel Light Dimmer Splice Pack - 1021
A26/B6.7/L9 - Panel Light Dimmer Splice Pack - 1021 Design 79
A26/B6.7/L9 - Park / Turn Lights Splice Packs
1623/1625/400
A26/B6.7/L9 - Park / Turn Lights Splice Packs 1623/1625/400 Design 80
A26 - Underhood PDM
A26 - Underhood PDM Design 81
B6.7/L9 - Underhood PDM
B6.7/L9 - Underhood PDM Design 82
A26/B6.7/L9 - Radio
A26/B6.7/L9 - Radio Design 83
A26/B6.7/L9 - Radio w/Bluetooth
A26/B6.7/L9 - Radio w/Bluetooth Design 84
A26/B6.7/L9 - Radio w/Bluetooth without Steering
Wheel Pod
A26/B6.7/L9 - Radio w/Bluetooth without Steering Wheel Pod Design 86
A26/B6.7/L9 - Radio w/Steering Wheel Pod
A26/B6.7/L9 - Radio w/Steering Wheel Pod Design 87
A26/B6.7/L9 - Four Speakers Daycab BT n/QC
A26/B6.7/L9 - Four Speakers Daycab BT n/QC Design 89
A26/B6.7/L9 - Four Speakers Daycab n/BT n/QC
A26/B6.7/L9 - Four Speakers Daycab n/BT n/QC Design 90
A26/B6.7/L9 - Two Speakers Daycab BT n/QC
A26/B6.7/L9 - Two Speakers Daycab BT n/QC Design 91
A26/B6.7/L9 - Two Speakers Daycab n/BT n/QC
A26/B6.7/L9 - Two Speakers Daycab n/BT n/QC Design 92
TABLE OF CONTENTS
ivB6.7 - Speakers:Four Speakers Daycab n/BT w/QC
B6.7 - Speakers:Four Speakers Daycab n/BT w/QC Design 93
B6.7 - Speakers:Two Speakers n/BT w/QC
B6.7 - Speakers:Two Speakers n/BT w/QC Design 94
B6.7 - Speakers:Two Speakers w/BT w/QC
B6.7 - Speakers:Two Speakers w/BT w/QC Design 95
B6.7 - Speaker:Four Speakers Daycab w/BT w/QC
B6.7 - Speaker:Four Speakers Daycab w/BT w/QC Design 96
L9 - Speakers:Four Speakers Daycab n/BT w/QC
L9 - Speakers:Four Speakers Daycab n/BT w/QC Design 97
L9 - Speakers:Two Speakers n/BT w/QC
L9 - Speakers:Two Speakers n/BT w/QC Design 98
L9 - Speakers:Two Speakers w/BT w/QC
L9 - Speakers:Two Speakers w/BT w/QC Design 99
L9 - Speaker:Four Speakers Daycab w/BT w/QC
L9 - Speaker:Four Speakers Daycab w/BT w/QC Design 100
A26/B6.7/L9 - Auxiliary Power (40A) HSD
A26/B6.7/L9 - Auxiliary Power (40A) HSD Design 101
B6.7 - Dual Auxiliary Power with Interlock
B6.7 - Dual Auxiliary Power with Interlock Design 102
A26 - Back-Up Alarm (Automatic) W/O Tailboard
A26 - Back-Up Alarm (Automatic) W/O Tailboard Design 103
A26 - Back-Up Alarm (Automatic) W/ Tailboard
A26 - Back-Up Alarm (Automatic) W/ Tailboard Design 104
A26 - Back-Up Alarm (Relay to 5 Pin 08TKC Tailboard
to Alarm) (Automatic)
A26 - Back-Up Alarm (Relay to 5 Pin 08TKC Tailboard to Alarm) (Automatic)
Design 105
A26 - Back-Up Alarm (Relay to 5 Pin 08TKC Tailboard.
Alarm Plugs In) (Automatic)
A26 - Back-Up Alarm (Relay to 5 Pin 08TKC Tailboard. Alarm Plugs In)
(Automatic) Design 106
A26 - Backup Alarm (Switch to 5 Pin 08TKC Tailboard
to Alarm) (Manual)
A26 - Backup Alarm (Switch to 5 Pin 08TKC Tailboard to Alarm) (Manual)
Design 107
A26 - Backup Alarm (Switch to 5 Pin 08TKC Tailboard.
Alarm Plugs In) (Manual)
A26 - Backup Alarm (Switch to 5 Pin 08TKC Tailboard. Alarm Plugs In) (Manual)
Design 108
A26 - Back-Up Alarm (Manual) W/O Tailboard
A26 - Back-Up Alarm (Manual) W/O Tailboard Design 109
TABLE OF CONTENTS
vA26 - Back-Up Alarm (Manual) W/ Tailboard
A26 - Back-Up Alarm (Manual) W/ Tailboard Design 110
B6.7 - Back-Up Alarm (Automatic) W/O Tailboard
B6.7 - Back-Up Alarm (Automatic) W/O Tailboard Design 111
B6.7 - Back-Up Alarm (Automatic) W/ Tailboard
B6.7 - Back-Up Alarm (Automatic) W/ Tailboard Design 112
B6.7 - Back-Up Alarm (Manual) W/O Tailboard
B6.7 - Back-Up Alarm (Manual) W/O Tailboard Design 113
B6.7 - Back-Up Alarm (Manual) W/ Tailboard
B6.7 - Back-Up Alarm (Manual) W/ Tailboard Design 114
L9 - Back-Up Alarm (Automatic) W/O Tailboard
L9 - Back-Up Alarm (Automatic) W/O Tailboard Design 115
L9 - Back-Up Alarm (Automatic) W/ Tailboard
L9 - Back-Up Alarm (Automatic) W/ Tailboard Design 116
L9 - Back-Up Alarm (Manual) W/O Tailboard
L9 - Back-Up Alarm (Manual) W/O Tailboard Design 117
L9 - Back-Up Alarm (Manual) W/ Tailboard
L9 - Back-Up Alarm (Manual) W/ Tailboard Design 119
A26/B6.7/L9 - Banana Plugs Receptacle
A26/B6.7/L9 - Banana Plugs Receptacle Design 121
A26/B6.7/L9 - CB Radio - Power Only
A26/B6.7/L9 - CB Radio - Power Only Design 122
A26/B6.7/L9 - CB Radio - Power Only (Single Antenna)
A26/B6.7/L9 - CB Radio - Power Only (Single Antenna) Design 123
A26/B6.7/L9 - Cigar Lighter
A26/B6.7/L9 - Cigar Lighter Design 124
A26/B6.7/L9 - Cigar Lighter Aux APO
A26/B6.7/L9 - Cigar Lighter Aux APO Design 125
A26/B6.7/L9 - Standard APO
A26/B6.7/L9 - Standard APO Design 128
A26/B6.7/L9 - Standard APO Aux APO
A26/B6.7/L9 - Standard APO Aux APO Design 129
A26/B6.7/L9 - Cruise Control (W/ One Telltale 10 Pin)
A26/B6.7/L9 - Cruise Control (W/ One Telltale 10 Pin) Design 132
A26/B6.7/L9 - Vehicle Speed Control (Cruise Control)
10 Pin
A26/B6.7/L9 - Vehicle Speed Control (Cruise Control) 10 Pin Design 134
A26/B6.7/L9 - Cruise Control (W/ One Telltale 4 Pin)
A26/B6.7/L9 - Cruise Control (W/ One Telltale 4 Pin) Design 135
TABLE OF CONTENTS
viA26/B6.7/L9 - Vehicle Speed Control (Cruise Control) 4
Pin
A26/B6.7/L9 - Vehicle Speed Control (Cruise Control) 4 Pin Design 137
A26/B6.7/L9 - Door Ajar Reminder (Entry /Exit):4 Door
A26/B6.7/L9 - Door Ajar Reminder (Entry /Exit):4 Door Design 138
A26/B6.7/L9 - Door Ajar Reminder (Entry/Exit) 2 Door
A26/B6.7/L9 - Door Ajar Reminder (Entry/Exit) 2 Door Design 139
A26/B6.7/L9 - Door Pod Module (2 Door)
A26/B6.7/L9 - Door Pod Module (2 Door) Design 140
A26/B6.7/L9 - Door Pod Module (4 Door)
A26/B6.7/L9 - Door Pod Module (4 Door) Design 141
A26/B6.7/L9 - Mirrors (Heated)
A26/B6.7/L9 - Mirrors (Heated) Design 142
A26/B6.7/L9 - Mirrors (Heat) Switch Pack Actuated
Relay Driven
A26/B6.7/L9 - Mirrors (Heat) Switch Pack Actuated Relay Driven Design 143
A26 - Heated Mirrors (Hood with Door Pods)
A26 - Heated Mirrors (Hood with Door Pods) Design 144
A26 - Heated Mirrors (RT Hood with Door Pods)
A26 - Heated Mirrors (RT Hood with Door Pods) Design 145
A26 - Mirrors (Heat) Switch Pack Actuated includes
Hood Mirrors
A26 - Mirrors (Heat) Switch Pack Actuated includes Hood Mirrors Design 146
A26 - Mirrors (Heat) Switch Pack Actuated includes RT
Hood Mirror
A26 - Mirrors (Heat) Switch Pack Actuated includes RT Hood Mirror Design 147
B6.7 - Heated Mirrors (Hood with Door Pods)
B6.7 - Heated Mirrors (Hood with Door Pods) Design 148
B6.7 - Heated Mirrors (RT Hood with Door Pods)
B6.7 - Heated Mirrors (RT Hood with Door Pods) Design 150
B6.7 - Mirrors (Heat) Switch Pack Actuated includes
Hood Mirrors
B6.7 - Mirrors (Heat) Switch Pack Actuated includes Hood Mirrors Design 154
RT Hood Mirror
B6.7 - Mirrors (Heat) Switch Pack Actuated includes RT Hood Mirror Design 156
L9 - Heated Mirrors (Hood with Door Pods)
L9 - Heated Mirrors (Hood with Door Pods) Design 160
L9 - Heated Mirrors (RT Hood with Door Pods)
L9 - Heated Mirrors (RT Hood with Door Pods) Design 164
TABLE OF CONTENTS
viiL9 - Mirrors (Heat) Switch Pack Actuated includes
Hood Mirrors
L9 - Mirrors (Heat) Switch Pack Actuated includes Hood Mirrors Design 168
L9 - Mirrors (Heat) Switch Pack Actuated includes RT
Hood Mirror
L9 - Mirrors (Heat) Switch Pack Actuated includes RT Hood Mirror Design 172
A26/B6.7/L9 - Power Mirrors (Control Switch Actuated)
A26/B6.7/L9 - Power Mirrors (Control Switch Actuated) Design 176
A26 - City Horn (W/ 10PIN Park Brake)
A26 - City Horn (W/ 10PIN Park Brake) Design 178
A26 - City Horn (W/ 10PIN)
A26 - City Horn (W/ 10PIN) Design 180
A26 - City Horn (W/ 4PIN Park Brake)
A26 - City Horn (W/ 4PIN Park Brake) Design 182
A26 - City Horn (W/ 4PIN)
A26 - City Horn (W/ 4PIN) Design 186
B6.7 - City Horn (W/ 10PIN CLK & Park Brake)
B6.7 - City Horn (W/ 10PIN CLK & Park Brake) Design 190
B6.7 - City Horn (W/ 10PIN CLK)
B6.7 - City Horn (W/ 10PIN CLK) Design 193
B6.7 - City Horn (W/ 4PIN CLK & Park Brake)
B6.7 - City Horn (W/ 4PIN CLK & Park Brake) Design 196
B6.7 - City Horn (W/ 4PIN CLK)
B6.7 - City Horn (W/ 4PIN CLK) Design 202
L9 - City Horn (W/ 10PIN CLK & Park Brake)
L9 - City Horn (W/ 10PIN CLK & Park Brake) Design 208
L9 - City Horn (W/ 10PIN CLK)
L9 - City Horn (W/ 10PIN CLK) Design 210
L9 - City Horn (W/ 4PIN CLK & Park Brake)
L9 - City Horn (W/ 4PIN CLK & Park Brake) Design 212
L9 - City Horn (W/ 4PIN CLK)
L9 - City Horn (W/ 4PIN CLK) Design 216
A26 - (Rand Mcnallly) GPS Display
A26 - (Rand Mcnallly) GPS Display Design 220
A26/B6.7/L9 - Heated Windshield
A26/B6.7/L9 - Heated Windshield Design 221
A26/B6.7/L9 - Multiplexed Switch Pack (Primary
Switch)
A26/B6.7/L9 - Multiplexed Switch Pack (Primary Switch) Design 222
A26/B6.7/L9 - Real Time Clock (RTC) (BCM Controlled)
A26/B6.7/L9 - Real Time Clock (RTC) (BCM Controlled) Design 223
TABLE OF CONTENTS
viiiA26 - Remote Keyless Access
A26 - Remote Keyless Access Design 224
B6.7 - Remote Keyless Access
B6.7 - Remote Keyless Access Design 225
L9 - Remote Keyless Access
L9 - Remote Keyless Access Design 226
A26/B6.7/L9 - Over The Air Electrical I/O (OnCommand
Link / N2 Module)
A26/B6.7/L9 - Over The Air Electrical I/O (OnCommand Link / N2 Module)
Design 227
A26/B6.7/L9 - Over the Air Programming
A26/B6.7/L9 - Over the Air Programming (OnCommand Link / N2 Module)
Design 228
A26 - Telematics (PEOPLE NET, DAYCAB)
A26 - Telematics (PEOPLE NET, DAYCAB) Design 229
L9 - Telematics (PEOPLE NET DAYCAB)
L9 - Telematics (PEOPLE NET DAYCAB) Design 230
A26/B6.7/L9 - Theft Deterrent (Grid Controlled)
A26/B6.7/L9 - Theft Deterrent (Grid Controlled) Design 231
A26/B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 - 1
Repeater)
A26/B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater) Design 232
A26/B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 - 2
Repeaters)
A26/B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 - 2 Repeaters) Design 236
TMC 8 PIN - 08XNL
TMC 8 PIN - 08XNL Design 238
A26/B6.7/L9 - One USB
A26/B6.7/L9 - One USB Design 239
A26/B6.7/L9 - Two USB
A26/B6.7/L9 - Two USB Design 240
A26/B6.7/L9 - Vehicle Sleep Mode
A26/B6.7/L9 - Vehicle Sleep Mode Design 242
A26 - 2-Way Radio
A26 - 2-Way Radio Design 243
B6.7 - 2-Way Radio
B6.7 - 2-Way Radio Design 245
L9 - 2-Way Radio
L9 - 2-Way Radio Design 247
TABLE OF CONTENTS
ixA26/B6.7/L9 - DPF Regen Switch Only
A26/B6.7/L9 - DPF Regen Switch Only Design 249
A26/B6.7/L9 - DPF With Bistable Inhibit Switch
A26/B6.7/L9 - DPF With Bistable Inhibit Switch Design 250
A26/B6.7/L9 - DPF With Monostable Inhibit Switch
A26/B6.7/L9 - DPF With Monostable Inhibit Switch Design 251
A26 - Selective Catalytic Reduction (SCR)
A26 - Selective Catalytic Reduction (SCR) Design 252
B6.7 - Selective Catalytic Reduction (SCR)
B6.7 - Selective Catalytic Reduction (SCR) Design 256
L9 - Selective Catalytic Reduction (SCR)
L9 - Selective Catalytic Reduction (SCR) Design 258
A26/B6.7/L9 - Adjustable Engine Speed Control (PTO)
10-pin
A26/B6.7/L9 - Adjustable Engine Speed Control (PTO) 10-pin Design 260
4-pin
A26/B6.7/L9 - Adjustable Engine Speed Control (PTO) 4-pin Design 262
A26 - Auxiliary Air Solenoids Normally Closed
A26 - Auxiliary Air Solenoids Normally Closed Design 263
A26 - Auxillary Air Solenoids Normally Open
A26 - Auxillary Air Solenoids Normally Open Design 264
B6.7 - Auxiliary Air Solenoids (1 Normally Closed)
Option 1
B6.7 - Auxiliary Air Solenoids (1 Normally Closed) Option 1 Design 270
Option 2
B6.7 - Auxiliary Air Solenoids (1 Normally Closed) Option 2 Design 271
Option 3
B6.7 - Auxiliary Air Solenoids (1 Normally Closed) Option 3 Design 274
L9 - Auxiliary Air Solenoids (1 Normally Closed)
L9 - Auxiliary Air Solenoids (1 Normally Closed) Design 277
L9 - Auxillary Air Solenoids Normally Closed
L9 - Auxillary Air Solenoids Normally Closed Design 278
L9 - Four Auxillary Air Solenoids
L9 - Four Auxillary Air Solenoids Design 284
L9 - Three Auxillary Air Solenoids
L9 - Three Auxillary Air Solenoids Design 285
A26/B6.7/L9 - Body Builder Aux Power (In Cab, BOC,
or EOF)
TABLE OF CONTENTS
xA26/B6.7/L9 - Body Builder Aux Power (In Cab, BOC, or EOF) Design 288
A26 - Body Builder Lighting - BOC, 08HBX (Automatic)
A26 - Body Builder Lighting - BOC, 08HBX (Automatic) Design 291
A26 - Body Builder Lighting - BOC, 08HBX (Manual)
A26 - Body Builder Lighting - BOC, 08HBX (Manual) Design 292
A26 - Body Builder Lighting - Combined Turn and
Stop Lamps (Automatic)
A26 - Body Builder Lighting - Combined Turn and Stop Lamps (Automatic)
Design 293
Stop Lamps (Manual)
A26 - Body Builder Lighting - Combined Turn and Stop Lamps (Manual)
Design 296
A26 - Body Builder Lighting - Separate Turn and Stop
Lamps (Blunt Cut) - Option 1
A26 - Body Builder Lighting - Separate Turn and Stop Lamps (Blunt Cut) - Option
1 Design 299
Lamps (Blunt Cut) - Option 2
2 Design 300
B6.7 - Body Builder Lighting - Combined Turn and
B6.7 - Body Builder Lighting - Combined Turn and Stop Lamps (Automatic)
Design 301
Stop Lamps (Manual)
B6.7 - Body Builder Lighting - Combined Turn and Stop Lamps (Manual)
Design 304
B6.7 - Body Builder Lighting - Separate Turn and Stop
Lamps (Blunt Cut) Option 1
B6.7 - Body Builder Lighting - Separate Turn and Stop Lamps (Blunt Cut) Option
1 Design 307
Lamps (Blunt Cut) Option 2
2 Design 308
L9 - Body Builder Lighting - Combined Turn and Stop
Lamps (Automatic)
L9 - Body Builder Lighting - Combined Turn and Stop Lamps (Automatic)
Design 309
Lamps (Manual)
L9 - Body Builder Lighting - Combined Turn and Stop Lamps (Manual) Design 312
TABLE OF CONTENTS
xiL9 - Body Builder Lighting - Separate Turn and Stop
L9 - Body Builder Lighting - Separate Turn and Stop Lamps (Blunt Cut) Option 1
Design 318
L9 - Body Builder Lighting - Separate Turn and Stop Lamps (Blunt Cut) Option 2
Design 319
A26 - I/O Expansion
A26 - I/O Expansion Design 320
B6.7 - I/O Expansion
B6.7 - I/O Expansion Design 321
L9 - I/O Expansion
L9 - I/O Expansion Design 322
A26 - Body Builder - Powertrain
A26 - Body Builder - Powertrain Design 323
A26 - Power Lift Gate
A26 - Power Lift Gate Design 324
B6.7 - Power Lift Gate
B6.7 - Power Lift Gate Design 325
L9 - Power Lift Gate
L9 - Power Lift Gate Design 326
A26 - DLB - Remote Power Modules (1 RPM n/ Switch
Packs)
A26 - DLB - Remote Power Modules (1 RPM n/ Switch Packs) Design 327
A26 - DLB - Remote Power Modules (1 RPM w/ Switch
Packs)
A26 - DLB - Remote Power Modules (1 RPM w/ Switch Packs) Design 330
A26 - DLB - Remote Power Modules (2 RPM n/ Switch
Pack)
A26 - DLB - Remote Power Modules (2 RPM n/ Switch Pack) Design 333
Pack)Option2
A26 - DLB - Remote Power Modules (2 RPM n/ Switch Pack)Option2 Design 336
A26 - DLB - Remote Power Modules (2 RPM w/ Switch
Packs)
A26 - DLB - Remote Power Modules (2 RPM w/ Switch Packs) Design 337
Packs)Option2
A26 - DLB - Remote Power Modules (2 RPM w/ Switch Packs)Option2 Design338
A26 - DLB - Remote Power Modules (3 RPM w/ Swtich
Packs)
A26 - DLB - Remote Power Modules (3 RPM w/ Swtich Packs) Design 341
TABLE OF CONTENTS
xiiA26 - DLB - Remote Power Modules (3 RPM w/ Swtich
Packs)Option2
A26 - DLB - Remote Power Modules (3 RPM w/ Swtich Packs)Option2 Design342
A26 - DLB - Remote Power Module (3 RPM n/Switch
Pack)
A26 - DLB - Remote Power Module (3 RPM n/Switch Pack) Design 344
Pack)Option2
A26 - DLB - Remote Power Module (3 RPM n/Switch Pack)Option2 Design 345
B6.7 - DLB - Remote Power Modules (1 RPM n/ Switch
Packs)
B6.7 - DLB - Remote Power Modules (1 RPM n/ Switch Packs) Design 347
B6.7 - DLB - Remote Power Modules (1 RPM w/ Switch
Packs)
B6.7 - DLB - Remote Power Modules (1 RPM w/ Switch Packs) Design 350
B6.7 - DLB - Remote Power Modules (2 RPM n/ Switch
Pack)
B6.7 - DLB - Remote Power Modules (2 RPM n/ Switch Pack) Design 353
B6.7 - DLB - Remote Power Modules (2 RPM w/ Switch
Packs)
B6.7 - DLB - Remote Power Modules (2 RPM w/ Switch Packs) Design 357
B6.7 - DLB - Remote Power Modules (3 RPM w/ Swtich
Packs)
B6.7 - DLB - Remote Power Modules (3 RPM w/ Swtich Packs) Design 361
B6.7 - DLB - Remote Power Module (3 RPM n/Switch
Pack)
B6.7 - DLB - Remote Power Module (3 RPM n/Switch Pack) Design 362
L9 - DLB - Remote Power Modules (1 RPM n/ Switch
Packs)
L9 - DLB - Remote Power Modules (1 RPM n/ Switch Packs) Design 363
L9 - DLB - Remote Power Modules (1 RPM w/ Switch
Packs)
L9 - DLB - Remote Power Modules (1 RPM w/ Switch Packs) Design 366
L9 - DLB - Remote Power Modules (2 RPM n/ Switch
Pack)
L9 - DLB - Remote Power Modules (2 RPM n/ Switch Pack) Design 369
L9 - DLB - Remote Power Modules (2 RPM w/ Switch
Packs)
L9 - DLB - Remote Power Modules (2 RPM w/ Switch Packs) Design 373
L9 - DLB - Remote Power Modules (3 RPM w/ Swtich
Packs)
L9 - DLB - Remote Power Modules (3 RPM w/ Swtich Packs) Design 377
TABLE OF CONTENTS
xiiiL9 - DLB - Remote Power Module (3 RPM n/Switch
Pack)
L9 - DLB - Remote Power Module (3 RPM n/Switch Pack) Design 378
A26 - Remote Start/Stop
A26 - Remote Start/Stop Design 379
B6.7 - Remote Start/Stop
B6.7 - Remote Start/Stop Design 380
B6.7 - Remote Start/Stop w/ Emergency Pump
B6.7 - Remote Start/Stop w/ Emergency Pump Design 381
L9 - Remote Start/Stop
L9 - Remote Start/Stop Design 382
L9 - Remote Start/Stop w/ Emergency Pump
L9 - Remote Start/Stop w/ Emergency Pump Design 383
A26 - Transmission Power Take Off (Auto Trans Dual
PTO W/ 42 Parameters)
A26 - Transmission Power Take Off (Auto Trans Dual PTO W/ 42 Parameters)
Design 384
A26 - Transmission Power Take Off (Manual Trans
A26 - Transmission Power Take Off (Manual Trans Dual PTO W/ 42 Parameters)
Design 385
Single PTO w/21 Parameters)
A26 - Transmission Power Take Off (Auto Trans Single PTO w/21 Parameters)
Design 386
Single PTO w/ 21 Parameters)
A26 - Transmission Power Take Off (Manual Trans Single PTO w/ 21
Parameters) Design 387
A26 - Transmission Power Take Off (Single Input
Configurable pull up or pull down)
A26 - Transmission Power Take Off (Single Input Configurable pull up or pull
down) Design 388
B6.7 - Transmission Power Take Off 60AKG
B6.7 - Transmission Power Take Off 60AKG Design 389
B6.7 - Transmission Power Take Off (Auto Trans
B6.7 - Transmission Power Take Off (Auto Trans Single PTO w/21 Parameters)
Design 390
B6.7 - Transmission Power Take Off (Manual Trans
B6.7 - Transmission Power Take Off (Manual Trans Single PTO w/21
Parameters) Design 391
TABLE OF CONTENTS
xivB6.7 - Transmission Power Take Off (Single Input
configurable pull up or pull down)
B6.7 - Transmission Power Take Off (Single Input configurable pull up or pull
down) Design 392
L9 - Transmission Power Take Off (Auto Trans Single
L9 - Transmission Power Take Off (Auto Trans Single PTO w/21 Parameters)
Design 393
L9 - Transmission Power Take Off (Auto Trans with
Lectradrive)
L9 - Transmission Power Take Off (Auto Trans with Lectradrive) Design 394
L9 - Transmission Power Take Off (Lectrashift PTO
with Manual Trans)
L9 - Transmission Power Take Off (Lectrashift PTO with Manual Trans)
Design 395
L9 - Transmission Power Take Off (Manual Trans
L9 - Transmission Power Take Off (Manual Trans Single PTO w/21 Parameters)
Design 396
L9 - Transmission Power Take Off (Single Input
L9 - Transmission Power Take Off (Single Input configurable pull up or pull down)
Design 397
L9 - Transmission Power Take Off (Single PTO W/
RPM and Auto Trans)
L9 - Transmission Power Take Off (Single PTO W/ RPM and Auto Trans)
Design 398
RPM and Manual Trans)
L9 - Transmission Power Take Off (Single PTO W/ RPM and Manual Trans)
Design 399
A26 - Brake Switch
A26 - Brake Switch Design 400
B6.7 - Brake Switch
B6.7 - Brake Switch Design 401
L9 - Brake Switch
L9 - Brake Switch Design 402
A26 - Rightside Air Dryer
A26 - Rightside Air Dryer Design 403
B6.7 - RIGHTSIDE AIR DRYER
B6.7 - RIGHTSIDE AIR DRYER Design 414
L9 - RIGHTSIDE AIR DRYER
L9 - RIGHTSIDE AIR DRYER Design 420
A26 - Drain Valve Heater
A26 - Drain Valve Heater Design 431
TABLE OF CONTENTS
xvB6.7 - Drain Valve Heater
B6.7 - Drain Valve Heater Design 441
L9 - Drain Valve Heater
L9 - Drain Valve Heater Design 448
A26 - Antilock Brake System (ABS) Bendix
A26 - Antilock Brake System (ABS) Bendix Design 457
A26 - Antilock Brake System (ABS)-Wabco 4 Channel
Implementation
A26 - Antilock Brake System (ABS)-Wabco 4 Channel Implementation Design 460
B6.7 - Antilock Brake System (ABS) BENDIX 4
Channel Implemenation
B6.7 - Antilock Brake System (ABS) BENDIX 4 Channel Implemenation
Design 461
L9 - Antilock Brake System (ABS) BENDIX 4 Channel
Implemenation
L9 - Antilock Brake System (ABS) BENDIX 4 Channel Implemenation Design 464
L9 - Antilock Brake System (ABS) Bendix 6 Channel
Implementation
L9 - Antilock Brake System (ABS) Bendix 6 Channel Implementation Design 465
L9 - Antilock Brake System (ABS) Wabco 4 Channel
Implementation
L9 - Antilock Brake System (ABS) Wabco 4 Channel Implementation Design 474
A26 - Park Brake Control (Monitoring)(GEN IV BCM)
A26 - Park Brake Control (Monitoring)(GEN IV BCM) Design 475
B6.7 - Park Brake Controls (Monitoring) (Door Switch
City Horn)
B6.7 - Park Brake Controls (Monitoring) (Door Switch City Horn) Design 476
L9 - Park Brake Controls (Monitoring) (Door Switch
City Horn)
L9 - Park Brake Controls (Monitoring) (Door Switch City Horn) Design 477
L9 - Park Brake Control (Monitoring)(GEN IV BCM)
L9 - Park Brake Control (Monitoring)(GEN IV BCM) Design 478
A26 - Bendix Tractor or Towing Truck N/ Air SUSP
J1939 Driven Lamp
A26 - Bendix Tractor or Towing Truck N/ Air SUSP J1939 Driven Lamp
Design 479
A26 - Bendix Tractor or Towing Truck W/ Air SUSP
J1939 Driven Lamp
A26 - Bendix Tractor or Towing Truck W/ Air SUSP J1939 Driven Lamp
Design 483
A26 - Stability Control (Bendix Straight Truck J1939
Driven Lamp)
A26 - Stability Control (Bendix Straight Truck J1939 Driven Lamp) Design 487
TABLE OF CONTENTS
xviB6.7 - Stability Control (Bendix Straight Truck J1939
Driven Lamp)
B6.7 - Stability Control (Bendix Straight Truck J1939 Driven Lamp) Design 491
L9 - Bendix Tractor or Towing Truck W/ Air SUSP
J1939 Driven Lamp
L9 - Bendix Tractor or Towing Truck W/ Air SUSP J1939 Driven Lamp Design 495
L9 - Stability Control (Bendix Straight Truck J1939
Driven Lamp)
L9 - Stability Control (Bendix Straight Truck J1939 Driven Lamp) Design 497
A26 - Traction Control (Bendix)
A26 - Traction Control (Bendix) Design 501
B6.7 - Traction Control (Bendix)
B6.7 - Traction Control (Bendix) Design 503
L9 - Traction Control (Bendix)
L9 - Traction Control (Bendix) Design 505
A26/B6.7/L9 - Adaptive Cruise Control (Bendix -
Fusion 2.0 & N/ Safety Direct & Reg Speakers)
A26/B6.7/L9 - Adaptive Cruise Control (Bendix - Fusion 2.0 & N/ Safety Direct &
Reg Speakers) Design 506
A26/B6.7/L9 - A26 - Adaptive Cruise Control w/o
Display (Bendix)
A26/B6.7/L9 - A26 - Adaptive Cruise Control w/o Display (Bendix) Design 507
A26 - Coolant Level Monitoring (No Coolant Module)
A26 - Coolant Level Monitoring (No Coolant Module) Design 508
B6.7 - Coolant Level Monitoring (No Coolant Module)
B6.7 - Coolant Level Monitoring (No Coolant Module) Design 509
L9 - Coolant Level Monitoring (No Coolant Module)
L9 - Coolant Level Monitoring (No Coolant Module) Design 510
HV B6.7 - Coolant Level Monitoring (With Coolant
Module)
HV B6.7 - Coolant Level Monitoring (With Coolant Module) Design 511
HV L9 - Coolant Level Monitoring (With Coolant
Module)
HV L9 - Coolant Level Monitoring (With Coolant Module) Design 512
A26 - Cooling Fan Control Two-Speed
A26 - Cooling Fan Control Two-Speed Design 513
B6.7 - Cooling Fan Control Two-Speed
B6.7 - Cooling Fan Control Two-Speed Design 514
A26/B6.7/L9 - Engine Block Heater
A26/B6.7/L9 - Engine Block Heater Design 516
A26/B6.7/L9 - Engine Fuel and Block Heaters
(Purchased Assembly)
A26/B6.7/L9 - Engine Fuel and Block Heaters (Purchased Assembly) Design 517
TABLE OF CONTENTS
xviiA26/B6.7/L9 - Engine Oil and Block Heaters
A26/B6.7/L9 - Engine Oil and Block Heaters (Purchased Assembly) Design 518
A26/B6.7/L9 - Engine Oil Fuel and Block Heaters
A26/B6.7/L9 - Engine Oil Fuel and Block Heaters Design 519
A26 - Engine Brake Mux Switch
A26 - Engine Brake Mux Switch Design 520
A26 - Engine Brake W/ Stalk Shifter
A26 - Engine Brake W/ Stalk Shifter Design 521
B6.7/L9 - Engine Brake Mux Switch
B6.7/L9 - Engine Brake Mux Switch Design 522
B6.7/L9 - Engine Brake W/ Stalk Shifter
B6.7/L9 - Engine Brake W/ Stalk Shifter Design 523
A26 - Exhaust Brake
A26 - Exhaust Brake Design 524
B6.7 - Exhaust Brake (Cummins)
B6.7 - Exhaust Brake (Cummins) Design 525
L9 - Exhaust Brake (Cummins)
L9 - Exhaust Brake (Cummins) Design 526
A26 - Snow Valve Control
A26 - Snow Valve Control Design 527
A26/B6.7/L9 - Snow Valve Control
A26/B6.7/L9 - Snow Valve Control Design 529
B6.7 - Snow Valve Control
B6.7 - Snow Valve Control Design 530
L9 - Snow Valve Control Design 532
A26 - Starting Aid (Flame Start)
A26 - Starting Aid (Flame Start) Design 534
B6.7 - Starting Aid (Grid Heater)
B6.7 - Starting Aid (Grid Heater) Design 535
L9 - Starting Aid (Grid Heater)
L9 - Starting Aid (Grid Heater) Design 536
A26 - Vehicle Acceleration (w/ Two PWR Two GND &
Two STS)
A26 - Vehicle Acceleration (w/ Two PWR Two GND & Two STS) Design 537
B6.7 - Vehicle Acceleration (w/ Two PWR Two GND &
Two STS)
B6.7 - Vehicle Acceleration (w/ Two PWR Two GND & Two STS) Design 538
L9 - Vehicle Acceleration (w/ Two PWR Two GND &
Two STS)
L9 - Vehicle Acceleration (w/ Two PWR Two GND & Two STS) Design 539
TABLE OF CONTENTS
xviiiA26/B6.7/L9 - Alternate Flashing (Wig Wag) - Park
Brake disables High Beams
A26/B6.7/L9 - Alternate Flashing (Wig Wag) - Park Brake disables High Beams
Design 540
Brake disables Wig Wag
A26/B6.7/L9 - Alternate Flashing (Wig Wag) - Park Brake disables Wig Wag
Design 541
A26/B6.7/L9 - Automatic Lighting - Dual Sensor
Twilight/Solar
A26/B6.7/L9 - Automatic Lighting - Dual Sensor Twilight/Solar Design 542
A26/B6.7/L9 - Automatic Lighting - Single Sensor
Twilight
A26/B6.7/L9 - Automatic Lighting - Single Sensor Twilight Design 544
A26 - Backup Light (Dual Daisy Reverse LT)Allison/ZF
Trans 3K/4K
A26 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans 3K/4K Design 546
A26 - Backup Light (Dual Reverse Light)Allison/ZF
Trans 3K/4K
A26 - Backup Light (Dual Reverse Light)Allison/ZF Trans 3K/4K Design 548
A26 - Backup Lights (Dual Daisy Reverse Light)
Eaton/Manual Trans
A26 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans Design 550
A26 - Backup Lights (Dual Reverse Light)
Eaton/Manual Trans
A26 - Backup Lights (Dual Reverse Light) Eaton/Manual Trans Design 551
A26 - Backup Light (Single Reverse Light)Allison
3K/4K
A26 - Backup Light (Single Reverse Light)Allison 3K/4K Design 552
A26 - Backup Light (Single Reverse Light) Allison
3K/4K
A26 - Backup Light (Single Reverse Light) Allison 3K/4K Design 554
3K/4K Option2
A26 - Backup Light (Single Reverse Light) Allison 3K/4K Option2 Design 556
A26 - Backup Light (Single Reverse Light) W/Less
Power Module Allison 3K/4K
A26 - Backup Light (Single Reverse Light) W/Less Power Module Allison 3K/4K
Design 558
A26 - Backup Lights (Reverse) W/Less Power Module
Eaton/Manual Trans
A26 - Backup Lights (Reverse) W/Less Power Module Eaton/Manual Trans
Design 560
A26 - Backup Lights (Single Reverse Lights)
Eaton/Manual Trans
A26 - Backup Lights (Single Reverse Lights) Eaton/Manual Trans Design 561
TABLE OF CONTENTS
xixA26 - Backup Lights (Single Reverse Lights)
Eaton/Manual Transmission
A26 - Backup Lights (Single Reverse Lights) Eaton/Manual Transmission
Design 562
Eaton/Manual Trans Option2
A26 - Backup Lights (Single Reverse Lights) Eaton/Manual Trans Option2
Design 563
A26 - Backup Lights (Single Reverse Light)
Eaton/Manual Trans
A26 - Backup Lights (Single Reverse Light) Eaton/Manual Trans Design 564
B6.7 - Backup Light (Dual Daisy Reverse LT)Allison/ZF
Trans 1K/2K
B6.7 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans 1K/2K Design 565
Trans 3K/4K
B6.7 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans 3K/4K Design 566
B6.7 - Backup Light (Dual Reverse Light)Allison/ZF
Trans 1K/2K
B6.7 - Backup Light (Dual Reverse Light)Allison/ZF Trans 1K/2K Design 568
Trans 3K/4K
B6.7 - Backup Light (Dual Reverse Light)Allison/ZF Trans 3K/4K Design 569
B6.7 - Backup Lights (Dual Daisy Reverse Light)
Eaton/Manual Trans
B6.7 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans Design 571
B6.7 - Backup Lights (Dual Reverse Light)
Eaton/Manual Trans
B6.7 - Backup Lights (Dual Reverse Light) Eaton/Manual Trans Design 572
B6.7 - Backup Light (Single Reverse Light) Allison
1K/2K Option 1
B6.7 - Backup Light (Single Reverse Light) Allison 1K/2K Option 1 Design 573
1K/2K Option 2
B6.7 - Backup Light (Single Reverse Light) Allison 1K/2K Option 2 Design 574
1K/2K Option 3
B6.7 - Backup Light (Single Reverse Light) Allison 1K/2K Option 3 Design 575
3K/4K Option 1
B6.7 - Backup Light (Single Reverse Light) Allison 3K/4K Option 1 Design 576
3K/4K Option 2
B6.7 - Backup Light (Single Reverse Light) Allison 3K/4K Option 2 Design 578
TABLE OF CONTENTS
xxB6.7 - Backup Light (Single Reverse Light) Allison
3K/4K Option 3
B6.7 - Backup Light (Single Reverse Light) Allison 3K/4K Option 3 Design 580
B6.7 - Backup Lights (Single Reverse Lights)
Eaton/Manual Trans Option 1
B6.7 - Backup Lights (Single Reverse Lights) Eaton/Manual Trans Option 1
Design 582
Eaton/Manual Trans Option 2
B6.7 - Backup Lights (Single Reverse Lights) Eaton/Manual Trans Option 2
Design 583
B6.7 - Backup Lights (Single Reverse Light)
Eaton/Manual Trans
B6.7 - Backup Lights (Single Reverse Light) Eaton/Manual Trans Design 584
L9 - Backup Light (Dual Daisy Reverse
L9 - Backup Light (Dual Daisy Reverse Light)Allison/ZF Trans 3K/4K Design 585
L9 - Backup Lights (Dual Daisy Reverse Light)
Eaton/Manual Trans
L9 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans Design 587
L9 - Backup Lights (Dual Reverse Light) Eaton/Manual
Trans
L9 - Backup Lights (Dual Reverse Light) Eaton/Manual Trans Design 589
L9 - Backup Light (Single Reverse Light)Allison
L9 - Backup Light (Single Reverse Light)Allison Design 591
L9 - Backup Light (Single Reverse Light) Allison
3K/4K Option 1
L9 - Backup Light (Single Reverse Light) Allison 3K/4K Option 1 Design 593
3K/4K Option 2
L9 - Backup Light (Single Reverse Light) Allison 3K/4K Option 2 Design 595
3K/4K Option 3
L9 - Backup Light (Single Reverse Light) Allison 3K/4K Option 3 Design 597
L9 - Backup Lights (Single Reverse Light)
L9 - Backup Lights (Single Reverse Light) Eaton/Manual Trans Option 1
Design 599
L9 - Backup Lights (Single Reverse Light) Eaton/Manual Trans Option 2
Design 601
Eaton/Manual Trans Option 3
L9 - Backup Lights (Single Reverse Light) Eaton/Manual Trans Option 3
Design 603
TABLE OF CONTENTS
xxiL9 - Backup Lights (Single Reverse Light)
Eaton/Manual Trans Option 4
L9 - Backup Lights (Single Reverse Light) Eaton/Manual Trans Option 4
Design 605
A26 - Rear Lights Stop - Daisy Chain
A26 - Rear Lights Stop - Daisy Chain Design 607
A26 - Rear Lights Stop - Dual Assembly
A26 - Rear Lights Stop - Dual Assembly Design 608
A26 - Rear Lights Stop - Single Assemby
A26 - Rear Lights Stop - Single Assemby Design 609
A26 - Rear Lights Stop - Single Assemby Jumper
Harness W/08TKC, 08THM
A26 - Rear Lights Stop - Single Assemby Jumper Harness W/08TKC, 08THM
Design 610
A26 - Rear Lights Stop - Single Assemby W/08TKJ
A26 - Rear Lights Stop - Single Assemby W/08TKJ Design 611
A26 - Separate Rear Lights (Stop) W/08TVH
A26 - Separate Rear Lights (Stop) W/08TVH Design 612
B6.7 - Rear Lights Stop - Daisy Chain
B6.7 - Rear Lights Stop - Daisy Chain Design 613
B6.7 - Rear Lights Stop - Dual Assembly
B6.7 - Rear Lights Stop - Dual Assembly Design 614
B6.7 - Rear Lights Stop - Single Assemby
B6.7 - Rear Lights Stop - Single Assemby Design 615
L9 - Rear Lights Stop - Daisy Chain
L9 - Rear Lights Stop - Daisy Chain Design 616
L9 - Rear Lights Stop - Dual Assembly
L9 - Rear Lights Stop - Dual Assembly Design 617
L9 - Rear Lights Stop - Single Assemby
L9 - Rear Lights Stop - Single Assemby Design 618
A26/B6.7/L9 - Clearance and Identification Lights
A26/B6.7/L9 - Clearance and Identification Lights Design 619
A26/B6.7/L9 - Daytime Running Lights (Output to Plow
Lights)
A26/B6.7/L9 - Daytime Running Lights (Output to Plow Lights) Design 620
A26 - Directional Signal (Turn) W/ Daisy Chain Box
Lamps
A26 - Directional Signal (Turn) W/ Daisy Chain Box Lamps Design 621
A26 - Directional Signal (Turn) W/ LED BOX LAMPS
A26 - Directional Signal (Turn) W/ LED BOX LAMPS Design 622
A26 - Directional Signal (Turn) W/ Less Power Module
Tail Board, W/Hazard SW
TABLE OF CONTENTS
xxiiA26 - Directional Signal (Turn) W/ Less Power Module Tail Board, W/Hazard SW
Design 623
A26 - Directional Signal (Turn) W/ Single Tail Board
W/Hazard SW
A26 - Directional Signal (Turn) W/ Single Tail Board W/Hazard SW Design 624
Lamps, W/Plow Lights
A26 - Directional Signal (Turn) W/ Daisy Chain Box Lamps, W/Plow Lights
Design 625
A26 - Directional Signal (Turn) W/ LED BOX LAMPS,
W/Plow Lights
A26 - Directional Signal (Turn) W/ LED BOX LAMPS, W/Plow Lights Design 627
Tail Board, W/Hazard SW, W/Plow Lights
A26 - Directional Signal (Turn) W/ Less Power Module Tail Board, W/Hazard SW,
W/Plow Lights Design 629
A26 - Directional Signal (Turn) W/ Single Tail Board,
A26 - Directional Signal (Turn) W/ Single Tail Board, W/Hazard SW, W/Plow
Lights Design 631
B6.7 - Directional Signal (Turn) W/ DAISY CHAIN BOX
LAMPS
B6.7 - Directional Signal (Turn) W/ DAISY CHAIN BOX LAMPS Design 633
B6.7 - Directional Signal (Turn) W/ LED BOX LAMPS
B6.7 - Directional Signal (Turn) W/ LED BOX LAMPS Design 635
B6.7 - Directional Signal (Turn) W/ Less Power Module
B6.7 - Directional Signal (Turn) W/ Less Power Module Tail Board W/Hazard SW
Design 637
B6.7 - Directional Signal (Turn) W/ Single Tail Board
W/Hazard SW
B6.7 - Directional Signal (Turn) W/ Single Tail Board W/Hazard SW Design 639
B6.7 - Directional Signal (Turn) W/ Daisy Chain Box
Lamps W/Plow Lights
B6.7 - Directional Signal (Turn) W/ Daisy Chain Box Lamps W/Plow Lights
Design 641
W/Plow Lights
B6.7 - Directional Signal (Turn) W/ LED BOX LAMPS W/Plow Lights Design 645
Tail Board W/Hazard SW W/PLOW LIGHTS
W/PLOW LIGHTS Design 649
W/Plow Lights
B6.7 - Directional Signal (Turn) W/ Single Tail Board W/Plow Lights Design 653
TABLE OF CONTENTS
xxiiiL9 - Directional Signal (Turn) W/ DAISY CHAIN BOX
LAMPS
L9 - Directional Signal (Turn) W/ DAISY CHAIN BOX LAMPS Design 657
L9 - Directional Signal (Turn) W/ LED BOX LAMPS
L9 - Directional Signal (Turn) W/ LED BOX LAMPS Design 659
L9 - Directional Signal (Turn) W/ Less Power Module
L9 - Directional Signal (Turn) W/ Less Power Module Tail Board W/Hazard SW
Design 661
L9 - Directional Signal (Turn) W/ Single Tail Board
W/Hazard SW
L9 - Directional Signal (Turn) W/ Single Tail Board W/Hazard SW Design 663
L9 - Directional Signal (Turn) W/ Daisy Chain Box
Lamps W/Plow Lights
L9 - Directional Signal (Turn) W/ Daisy Chain Box Lamps W/Plow Lights
Design 665
W/Plow Lights
L9 - Directional Signal (Turn) W/ LED BOX LAMPS W/Plow Lights Design 669
W/PLOW LIGHTS Design 673
W/Plow Lights
L9 - Directional Signal (Turn) W/ Single Tail Board W/Plow Lights Design 677
A26/B6.7/L9 - Exterior Lamp Check
A26/B6.7/L9 - Exterior Lamp Check Design 681
A26/B6.7/L9 - Exterior Lamp Reminder
A26/B6.7/L9 - Exterior Lamp Reminder Design 682
A26 - Front Fog Lamps LED
A26 - Front Fog Lamps LED Design 683
A26 - Front Fog Lights W CONNECTOR Halogen
A26 - Front Fog Lights W CONNECTOR Halogen Design 685
B6.7 - Fog Lights (Halogen White)
B6.7 - Fog Lights (Halogen White) Design 687
B6.7 - Fog Lights (LED White)
B6.7 - Fog Lights (LED White) Design 690
B6.7 - Front Fog Lamps
B6.7 - Front Fog Lamps Design 693
B6.7 - Front Fog Lights W CONNECTOR
B6.7 - Front Fog Lights W CONNECTOR Design 696
L9 - Fog Lights (Halogen White)
L9 - Fog Lights (Halogen White) Design 698
TABLE OF CONTENTS
xxivL9 - Fog Lights (LED White)
L9 - Fog Lights (LED White) Design 700
L9 - Front Fog Lights W CONNECTOR
L9 - Front Fog Lights W CONNECTOR Design 702
A26 - Front Marker Lights
A26 - Front Marker Lights Design 704
A26 - Front Marker Lights W/Plow Lights
A26 - Front Marker Lights W/Plow Lights Design 705
B6.7 - Front Marker Lights - Without Snow Plow Lights
B6.7 - Front Marker Lights - Without Snow Plow Lights Design 707
B6.7 - Front Marker Lights - With Plow Lights
B6.7 - Front Marker Lights - With Plow Lights Design 709
L9 - Front Marker Lights - Without Snow Plow Lights
L9 - Front Marker Lights - Without Snow Plow Lights Design 713
L9 - Front Marker Lights - With Plow Lights
L9 - Front Marker Lights - With Plow Lights Design 715
A26 - Hazard Warning Light N/Trlr Socket
A26 - Hazard Warning Light N/Trlr Socket Design 719
L9 - Hazard Warning Light N/Trlr Socket
L9 - Hazard Warning Light N/Trlr Socket Design 721
A26 - Headlights W/LOWW, W/O Interrupt
A26 - Headlights W/LOWW, W/O Interrupt Design 723
A26 - Headlights W/O LOWW, W/O Interrupt
A26 - Headlights W/O LOWW, W/O Interrupt Design 725
A26 - Headlights W/LOWW, W/Interrupt - 10 PIN CLK
A26 - Headlights W/LOWW, W/Interrupt - 10 PIN CLK Design 727
A26 - Headlights W/O LOWW, W/Interrupt - 10 PIN CLK
A26 - Headlights W/O LOWW, W/Interrupt - 10 PIN CLK Design 729
A26 - Headlight W/Plowlights, W/LOWW, W/O Interrupt
A26 - Headlight W/Plowlights, W/LOWW, W/O Interrupt Design 731
A26 - Headlight W/Plowlights, W/O LOWW, W/O
Interrupt
A26 - Headlight W/Plowlights, W/O LOWW, W/O Interrupt Design 735
A26 - Headlights W/PlowLights, W/LOWW, W/Interrupt
- 10 PIN CLK
A26 - Headlights W/PlowLights, W/LOWW, W/Interrupt - 10 PIN CLK Design 739
A26 - Headlights W/PlowLights, W/O LOWW,
A26 - Headlights W/PlowLights, W/O LOWW, W/Interrupt - 10 PIN CLK
Design 743
TABLE OF CONTENTS
xxvB6.7 - Headlights W/O Lights ON With Wipers (LOWW)
W/O Headlights Interrupt
B6.7 - Headlights W/O Lights ON With Wipers (LOWW) W/O Headlights Interrupt
Design 747
B6.7 - Headlights W/O Lights ON with wipers (LOWW)
W/ Headlights Interrupt
B6.7 - Headlights W/O Lights ON with wipers (LOWW) W/ Headlights Interrupt
Design 751
B6.7 - Headlights W 10PIN CLK W/LOWW W/O
Interrupt
B6.7 - Headlights W 10PIN CLK W/LOWW W/O Interrupt Design 755
B6.7 - Headlights W 10PIN CLK W/LOWW W/Interrupt
B6.7 - Headlights W 10PIN CLK W/LOWW W/Interrupt Design 759
B6.7 - Headlights W/Plowlights W/O Lights ON With
B6.7 - Headlights W/Plowlights W/O Lights ON With Wipers (LOWW) W/O
Headlights Interrupt Design 763
B6.7 - Headlight W/Plowlights W/LOWW W/O
Headlight Interrupt -10 PIN CLK
B6.7 - Headlight W/Plowlights W/LOWW W/O Headlight Interrupt -10 PIN CLK
Design 771
B6.7 - Headlights W/PlowLights W/Headlight Interrupt
-10PIN CLK W/LOWW W/Interrupt
B6.7 - Headlights W/PlowLights W/Headlight Interrupt -10PIN CLK W/LOWW
W/Interrupt Design 779
B6.7 - Headlights W/PlowLights W/O Lights ON with
B6.7 - Headlights W/PlowLights W/O Lights ON with wipers (LOWW) W/
Headlights Interrupt Design 787
L9 - Headlights W/O Lights ON With Wipers (LOWW)
L9 - Headlights W/O Lights ON With Wipers (LOWW) W/O Headlights Interrupt
Design 795
L9 - Headlights W/O Lights ON with wipers (LOWW)
L9 - Headlights W/O Lights ON with wipers (LOWW) W/ Headlights Interrupt
Design 799
L9 - Headlights W 10PIN CLK W/LOWW W/O Interrupt
L9 - Headlights W 10PIN CLK W/LOWW W/O Interrupt Design 803
L9 - Headlights W 10PIN CLK W/LOWW W/Interrupt
L9 - Headlights W 10PIN CLK W/LOWW W/Interrupt Design 807
L9 - Headlights W/Plowlights W/O Lights ON With
L9 - Headlights W/Plowlights W/O Lights ON With Wipers (LOWW) W/O
Headlights Interrupt Design 811
TABLE OF CONTENTS
xxviL9 - Headlight W/Plowlights W/LOWW W/O Headlight
L9 - Headlight W/Plowlights W/LOWW W/O Headlight Interrupt -10 PIN CLK
Design 819
L9 - Headlights W/PlowLights W/Headlight Interrupt -
L9 - Headlights W/PlowLights W/Headlight Interrupt -10PIN CLK W/LOWW
W/Interrupt Design 827
L9 - Headlights W/PlowLights W/O Lights ON with
L9 - Headlights W/PlowLights W/O Lights ON with wipers (LOWW) W/ Headlights
Interrupt Design 835
A26 - License Plate Light (LED BOX LAMP Daisy
Chain Tail Light)
A26 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light) Design 843
A26 - License Plate Light (LED BOX LAMP Tail Light)
A26 - License Plate Light (LED BOX LAMP Tail Light) Design 844
A26 - License Plate Light (Tail Light Single Assembly)
A26 - License Plate Light (Tail Light Single Assembly) Design 845
Assembly)Option2
A26 - License Plate Light (Tail Light Single Assembly)Option2 Design 846
Assembly)Option3
A26 - License Plate Light (Tail Light Single Assembly)Option3 Design 847
A26 - License Plate Light (Tail Light Single Assy.)
W/Less Power Module (W/08TKC, 08THM)
A26 - License Plate Light (Tail Light Single Assy.) W/Less Power Module
(W/08TKC, 08THM) Design 848
B6.7 - License Plate Light (LED BOX LAMP Daisy
Chain Tail Light)
B6.7 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light) Design 849
B6.7 - License Plate Light (LED BOX LAMP Tail Light)
B6.7 - License Plate Light (LED BOX LAMP Tail Light) Design 850
B6.7 - License Plate Light (Tail Light Single Assy)
Option 1
B6.7 - License Plate Light (Tail Light Single Assy) Option 1 Design 851
Option 2
B6.7 - License Plate Light (Tail Light Single Assy) Option 2 Design 852
Option 3
B6.7 - License Plate Light (Tail Light Single Assy) Option 3 Design 853
TABLE OF CONTENTS
xxviiB6.7 - License Plate Light (Tail Light Single Assy)
Option 4
B6.7 - License Plate Light (Tail Light Single Assy) Option 4 Design 854
W/Less Power Module
B6.7 - License Plate Light (Tail Light Single Assy) W/Less Power Module
Design 855
L9 - License Plate Light (LED BOX LAMP Daisy Chain
Tail Light)
L9 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light) Design 856
L9 - License Plate Light (LED BOX LAMP Tail Light)
L9 - License Plate Light (LED BOX LAMP Tail Light) Design 857
L9 - License Plate Light (Tail Light Single Assy)
Option 1
L9 - License Plate Light (Tail Light Single Assy) Option 1 Design 858
Option 2
L9 - License Plate Light (Tail Light Single Assy) Option 2 Design 859
Option 3
L9 - License Plate Light (Tail Light Single Assy) Option 3 Design 860
Option 4
L9 - License Plate Light (Tail Light Single Assy) Option 4 Design 861
A26/B6.7/L9 - PARK LIGHTS - N/Marker Interrupt
A26/B6.7/L9 - PARK LIGHTS - N/Marker Interrupt Design 862
A26/B6.7/L9 - PARK LIGHTS - W/Marker Interrupt
10pin CLCKSPRING
A26/B6.7/L9 - PARK LIGHTS - W/Marker Interrupt 10pin CLCKSPRING
Design 864
A26/B6.7/L9 - PARK LIGHTS - W/Marker Interrupt 4 pin
clockspring
A26/B6.7/L9 - PARK LIGHTS - W/Marker Interrupt 4 pin clockspring Design 866
A26/B6.7/L9 - Snow Plow Lights
A26/B6.7/L9 - Snow Plow Lights Design 868
A26 - Rear Light (LED BOX LAMP Tail Light) W/08TPS,
08TPR
A26 - Rear Light (LED BOX LAMP Tail Light) W/08TPS, 08TPR Design 869
A26 - Rear Light (Tail Light) W/Less Power Module
(W/08TKC, 08THM)
A26 - Rear Light (Tail Light) W/Less Power Module (W/08TKC, 08THM)
Design 870
A26 - Rear Light (Tail Light) W/08THK
TABLE OF CONTENTS
xxviiiA26 - Rear Light (Tail Light) W/08THK Design 871
A26 - Rear Light (Tail Light) W/08TKB
A26 - Rear Light (Tail Light) W/08TKB Design 872
A26 - Rear Light (Tail Light) W/08TKJ
A26 - Rear Light (Tail Light) W/08TKJ Design 873
A26 - Rear Light (Tail Light) W_Daisy Chain pair of
Box Lamps W/08TRS
A26 - Rear Light (Tail Light) W_Daisy Chain pair of Box Lamps W/08TRS
Design 874
B6.7 - Rear Light (LED BOX LAMP Tail Light)
B6.7 - Rear Light (LED BOX LAMP Tail Light) Design 875
B6.7 - Rear Light (Tail Light) Option 1
B6.7 - Rear Light (Tail Light) Option 1 Design 876
B6.7 - Rear Light (Tail Light) Option 2
B6.7 - Rear Light (Tail Light) Option 2 Design 877
B6.7 - Rear Light (Tail Light) Option 3
B6.7 - Rear Light (Tail Light) Option 3 Design 878
B6.7 - Rear Light (Tail Light) Option 4
B6.7 - Rear Light (Tail Light) Option 4 Design 879
B6.7 - Rear Light (Tail Light) W_Daisy Chain pair of
Box Lamps
B6.7 - Rear Light (Tail Light) W_Daisy Chain pair of Box Lamps Design 880
L9 - Rear Light (LED BOX LAMP Tail Light)
L9 - Rear Light (LED BOX LAMP Tail Light) Design 881
L9 - Rear Light (Tail Light)
L9 - Rear Light (Tail Light) Design 882
L9 - Rear Light (Tail Light) W Daisy Chain pair of Box
Lamps
L9 - Rear Light (Tail Light) W Daisy Chain pair of Box Lamps Design 883
A26 - Work Lights LED W/ Sw Pack - Day Cab
A26 - Work Lights LED W/ Sw Pack - Day Cab Design 884
A26 - WORK LIGHT W Backup 1 Bulb
A26 - WORK LIGHT W Backup 1 Bulb Design 886
A26 - WORK LIGHT W BackUP 1 BULB
A26 - WORK LIGHT W BackUP 1 BULB Design 888
A26 - WORK LIGHT W RKE 1 BULB
A26 - WORK LIGHT W RKE 1 BULB Design 890
A26 - Work Light W/ Backup 1 Bulb W/Automatic W/
RKE
A26 - Work Light W/ Backup 1 Bulb W/Automatic W/ RKE Design 892
A26 - Work Light W/ Backup 1 Bulb W/Manual W/ RKE
A26 - Work Light W/ Backup 1 Bulb W/Manual W/ RKE Design 894
TABLE OF CONTENTS
xxixA26 - WORK LIGHT 1 BULB
A26 - WORK LIGHT 1 BULB Design 896
B6.7 - Work Lights LED W/ Sw Pack - Day Cab
B6.7 - Work Lights LED W/ Sw Pack - Day Cab Design 898
B6.7 - WORK LIGHT W BackUP 1 BULB
B6.7 - WORK LIGHT W BackUP 1 BULB Design 899
B6.7 - WORK LIGHT W RKE 1 BULB
B6.7 - WORK LIGHT W RKE 1 BULB Design 900
B6.7 - WORK LIGHT 1 BULB
B6.7 - WORK LIGHT 1 BULB Design 901
L9 - Work Lights LED W/ Sw Pack - Day Cab
L9 - Work Lights LED W/ Sw Pack - Day Cab Design 902
L9 - WORK LIGHT W BackUP 1 BULB Option 1
L9 - WORK LIGHT W BackUP 1 BULB Option 1 Design 904
L9 - WORK LIGHT W BackUP 1 BULB Option 2
L9 - WORK LIGHT W BackUP 1 BULB Option 2 Design 908
L9 - WORK LIGHT W RKE 1 BULB
L9 - WORK LIGHT W RKE 1 BULB Design 910
L9 - WORK LIGHT 1 BULB
L9 - WORK LIGHT 1 BULB Design 912
A26/B6.7/L9 - Fifth Wheel Slide
A26/B6.7/L9 - Fifth Wheel Slide Design 914
A26/B6.7/L9 - Jaw Unlock Control
A26/B6.7/L9 - Jaw Unlock Control Design 915
A26/B6.7/L9 - Jaw Unlock Control W/ SOLENOIDS
W/SWITCH PACKS
A26/B6.7/L9 - Jaw Unlock Control W/ SOLENOIDS W/SWITCH PACKS
Design 916
A26 - Fuel Heater (Vehicle Powered)(Davco)
A26 - Fuel Heater (Vehicle Powered)(Davco) Design 917
B6.7 - Fuel Heater (Vehicle Powered)(Davco)
B6.7 - Fuel Heater (Vehicle Powered)(Davco) Design 926
B6.7 - Fuel Heater (Vehicle Powered)(Racor)
B6.7 - Fuel Heater (Vehicle Powered)(Racor) Design 933
L9 - Fuel Heater (Vehicle Powered)(Davco)
L9 - Fuel Heater (Vehicle Powered)(Davco) Design 940
L9 - Fuel Heater (Vehicle Powered)(Racor)
L9 - Fuel Heater (Vehicle Powered)(Racor) Design 955
A26 - 26" Fuel Tank
A26 - 26" Fuel Tank Design 963
A26 - 26" Fuel Tank - Secondary
TABLE OF CONTENTS
xxxA26 - 26" Fuel Tank - Secondary Design 968
B6.7 - 26 inch Fuel Tank
B6.7 - 26 inch Fuel Tank Design 975
B6.7 - 26 inch Fuel Tank - Secondary
B6.7 - 26 inch Fuel Tank - Secondary Design 978
L9 - 26 inch Fuel Tank
L9 - 26 inch Fuel Tank Design 979
L9 - 26 inch Fuel Tank - Secondary
L9 - 26 inch Fuel Tank - Secondary Design 985
A26 - Water In Fuel (WIF) Davco N/ Heater
A26 - Water In Fuel (WIF) Davco N/ Heater Design 992
A26 - Water In Fuel (WIF) Davco W/ Heater
A26 - Water In Fuel (WIF) Davco W/ Heater Design 1001
B6.7 - Water In Fuel (WIF) Racor N/ Heater
B6.7 - Water In Fuel (WIF) Racor N/ Heater Design 1010
B6.7 - Water In Fuel (WIF) Racor W/ Heater
B6.7 - Water In Fuel (WIF) Racor W/ Heater Design 1017
L9 - Water In Fuel (WIF) Davco N/ Heater
L9 - Water In Fuel (WIF) Davco N/ Heater Design 1024
L9 - Water In Fuel (WIF) Davco W/ Heater
L9 - Water In Fuel (WIF) Davco W/ Heater Design 1033
A26 - Heating Ventilation & Air Conditioning (HVAC)
Auto Temp Control
A26 - Heating Ventilation & Air Conditioning (HVAC) Auto Temp Control
Design 1042
B6.7 - Heating Ventilation & Air Conditioning (HVAC)
Auto Temp Control
B6.7 - Heating Ventilation & Air Conditioning (HVAC) Auto Temp Control
Design 1045
L9 - Heating Ventilation & Air Conditioning (HVAC)
Auto Temp Control
L9 - Heating Ventilation & Air Conditioning (HVAC) Auto Temp Control
Design 1048
A26 - Heating Ventilation & Air Conditioning (HVAC) Design 1051
A26/B6.7/L9 - HVAC Assembly Actuators
A26/B6.7/L9 - HVAC Assembly Actuators Design 1052
B6.7 - Heating Ventilation & Air Conditioning (HVAC) Design 1053
L9 - Heating Ventilation & Air Conditioning (HVAC) Design 1054
A26 - Ambient Air Temperature
TABLE OF CONTENTS
xxxiA26 - Ambient Air Temperature Design 1055
A26 - Ambient Temperature Monitoring
A26 - Ambient Temperature Monitoring Design 1056
L9 - Ambient Air Temperature
L9 - Ambient Air Temperature Design 1057
B6.7 - Current Monitoring (Ammeter)
B6.7 - Current Monitoring (Ammeter) Design 1058
A26 - Brake Pressure (Auxiliary Gauge)
A26 - Brake Pressure (Auxiliary Gauge) Design 1060
A26 - Brake Pressure (Virtual Gauge)
A26 - Brake Pressure (Virtual Gauge) Design 1061
B6.7 - Brake Pressure (Auxiliary Gauge)
B6.7 - Brake Pressure (Auxiliary Gauge) Design 1062
B6.7 - Brake Pressure (Virtual Gauge)
B6.7 - Brake Pressure (Virtual Gauge) Design 1063
L9 - Brake Pressure (Auxiliary Gauge)
L9 - Brake Pressure (Auxiliary Gauge) Design 1064
L9 - Brake Pressure (Virtual Gauge)
L9 - Brake Pressure (Virtual Gauge) Design 1065
A26/B6.7/L9 - Compressed Air Supply
A26/B6.7/L9 - Compressed Air Supply Design 1066
A26/B6.7/L9 - DEF Economy Monitor (GEN IV)
A26/B6.7/L9 - DEF Economy Monitor (GEN IV) Design 1067
L9 - Coolant Temperature Monitoring (J1939 Comm)
L9 - Coolant Temperature Monitoring (J1939 Comm) Design 1068
A26/B6.7/L9 - Engine Usage Monitoring (Base) NA
A26/B6.7/L9 - Engine Usage Monitoring (Base) NA Design 1069
A26/B6.7/L9 - Engine Usage Monitoring (VID Option)
A26/B6.7/L9 - Engine Usage Monitoring (VID Option) Design 1070
A26/B6.7/L9 - Engine Oil Level Monitoring
A26/B6.7/L9 - Engine Oil Level Monitoring Design 1071
A26/B6.7/L9 - Engine Oil Pressure
A26/B6.7/L9 - Engine Oil Pressure Design 1072
A26/B6.7/L9 - Engine Oil Temperature (NA Mux)
A26/B6.7/L9 - Engine Oil Temperature (NA Mux) Design 1073
A26/B6.7/L9 - Engine Oil Temperature(NA MUX AUX
Gauge)
A26/B6.7/L9 - Engine Oil Temperature(NA MUX AUX Gauge) Design 1074
A26 - Engine Speed (Tachometer)
A26 - Engine Speed (Tachometer) Design 1075
TABLE OF CONTENTS
xxxiiB6.7 & L9 - Engine Speed (Tachometer)
B6.7 & L9 - Engine Speed (Tachometer) Design 1076
A26/B6.7/L9 - Fuel Economy Monitor
A26/B6.7/L9 - Fuel Economy Monitor Design 1077
A26/B6.7/L9 - Odometer (via BCM/EGC)
A26/B6.7/L9 - Odometer (via BCM/EGC) Design 1078
A26/B6.7/L9 - Trip Odometer w/VID
A26/B6.7/L9 - Trip Odometer w/VID Design 1079
A26/B6.7/L9 - Trip Odometer (Gen 4 Cluster)
A26/B6.7/L9 - Trip Odometer (Gen 4 Cluster) Design 1080
A26/B6.7/L9 - Trip Odometer ( w/ECM & TCM)
A26/B6.7/L9 - Trip Odometer ( w/ECM & TCM) Design 1081
A26/B6.7/L9 - PTO Hour Meter
A26/B6.7/L9 - PTO Hour Meter Design 1082
A26 - Transmission Oil Temperature-Manual Trans
A26 - Transmission Oil Temperature-Manual Trans Design 1083
w/Aux Gauge
A26 - Transmission Oil Temperature-Manual Trans w/Aux Gauge Design 1085
B6.7 - Transmission Oil Temperature-Manual Trans
B6.7 - Transmission Oil Temperature-Manual Trans Design 1087
(w/Aux Gauge)
B6.7 - Transmission Oil Temperature-Manual Trans (w/Aux Gauge) Design 1088
L9 - Transmission Oil Temperature-Automatic Trans
L9 - Transmission Oil Temperature-Automatic Trans Design 1089
w/Aux Gauge
L9 - Transmission Oil Temperature-Automatic Trans w/Aux Gauge Design 1090
L9 - Transmission Oil Temperature-Manual
L9 - Transmission Oil Temperature-Manual Transmission Design 1091
w/Aux Gauge
L9 - Transmission Oil Temperature-Manual Trans w/Aux Gauge Design 1092
A26/B6.7/L9 - Vehicle Speedometer System
(Automatic XMSN)
A26/B6.7/L9 - Vehicle Speedometer System (Automatic XMSN) Design 1093
A26 - Vehicle Speedometer System (Manual XMSN)
A26 - Vehicle Speedometer System (Manual XMSN) Design 1094
B6.7 - Vehicle Speedometer System (Manual XMSN)
B6.7 - Vehicle Speedometer System (Manual XMSN) Design 1095
TABLE OF CONTENTS
xxxiiiL9 - Vehicle Speedometer System (Manual XMSN)
L9 - Vehicle Speedometer System (Manual XMSN) Design 1096
A26/B6.7/L9 - Vehicle Speed Limit Override
A26/B6.7/L9 - Vehicle Speed Limit Override Design 1097
A26/B6.7/L9 - Voltage Monitoring (Voltmeter)
A26/B6.7/L9 - Voltage Monitoring (Voltmeter) Design 1098
A26/B6.7/L9 - Voltage Monitoring (Voltmeter) (with
Aux gauge)
A26/B6.7/L9 - Voltage Monitoring (Voltmeter) (with Aux gauge) Design 1099
A26/B6.7/L9 - Engine Warning_MUX
A26/B6.7/L9 - Engine Warning_MUX Design 1100
A26/B6.7/L9 - High Exhaust System Temperature
(HEST) Monitoring
A26/B6.7/L9 - High Exhaust System Temperature (HEST) Monitoring Design 1101
A26/B6.7/L9 - Up Shift Indicator
A26/B6.7/L9 - Up Shift Indicator Design 1102
A26 - Range Inhibit with Seatbelt
A26 - Range Inhibit with Seatbelt Design 1103
A26/B6.7/L9 - Trans Range Inhibit (J1939 Comm)
A26/B6.7/L9 - Trans Range Inhibit (J1939 Comm) Design 1104
B6.7 - Range Inhibit (sixth gear inhibit switch)
B6.7 - Range Inhibit (sixth gear inhibit switch) Design 1105
A26/B6.7/L9 - Vehicle Information Display Premium w/
Wi-Fi (VID)
A26/B6.7/L9 - Vehicle Information Display Premium w/ Wi-Fi (VID) Design 1106
A26/B6.7/L9 - Vehicle Information Display (Without
Bluetooth)
A26/B6.7/L9 - Vehicle Information Display (Without Bluetooth) Design 1107
Bluetooth)
A26/B6.7/L9 - Vehicle Information Display (With Bluetooth) Design 1108
A26/B6.7/L9 - Cab Dome Light W/Classic Trim
A26/B6.7/L9 - Cab Dome Light W/Classic Trim Design 1109
A26/B6.7/L9 - Cab Dome Light W/ Combo in Diamond
Trim
A26/B6.7/L9 - Cab Dome Light W/ Combo in Diamond Trim Design 1110
A26/B6.7/L9 - Interior Task Lights (Map) - Dome
Combo
A26/B6.7/L9 - Interior Task Lights (Map) - Dome Combo Design 1111
A26/B6.7/L9 - Courtesy Light Cab 2 door
A26/B6.7/L9 - Courtesy Light Cab 2 door Design 1112
TABLE OF CONTENTS
xxxivA26/B6.7/L9 - Courtesy Light 4 Door
A26/B6.7/L9 - Courtesy Light 4 Door Design 1113
A26/B6.7/L9 - Panel Backlighting (Cabin Dimmer)
A26/B6.7/L9 - Panel Backlighting (Cabin Dimmer) Design 1114
A26/B6.7/L9 - Axle Lift Controls
A26/B6.7/L9 - Axle Lift Controls Design 1115
A26 - Axle Lift Controls
A26 - Axle Lift Controls Design 1119
A26 - Lift Axle Controls (Center Pedestal Controls f/ 1
lift axle)
A26 - Lift Axle Controls (Center Pedestal Controls f/ 1 lift axle) Design 1121
A26 - Lift Axle Controls (Center Pedestal Controls f/ 2
Lift Axles)
A26 - Lift Axle Controls (Center Pedestal Controls f/ 2 Lift Axles) Design 1123
A26 - Lift Axle Controls (Center Pedestal Controls f/ 3
lift axles)
A26 - Lift Axle Controls (Center Pedestal Controls f/ 3 lift axles) Design 1124
L9 - Axle Lift Controls Option 2
L9 - Axle Lift Controls Option 2 Design 1125
L9 - Lift Axle Controls (Center Pedestal Controls f/ 1
lift axle)
L9 - Lift Axle Controls (Center Pedestal Controls f/ 1 lift axle) Design 1127
L9 - Lift Axle Controls (Center Pedestal Controls f/ 2
Lift Axles)
L9 - Lift Axle Controls (Center Pedestal Controls f/ 2 Lift Axles) Design 1129
L9 - Lift Axle Controls (Center Pedestal Controls f/ 3
lift axles)
L9 - Lift Axle Controls (Center Pedestal Controls f/ 3 lift axles) Design 1130
B6.7 - Axle Loading (Weight) Rear
B6.7 - Axle Loading (Weight) Rear Design 1131
L9 - Axle Loading (Weight) Rear
L9 - Axle Loading (Weight) Rear Design 1133
A26 - Axle Temperature Monitoring (Single Rear Aux
Gauge)
A26 - Axle Temperature Monitoring (Single Rear Aux Gauge) Design 1135
Virtual Gauge)
A26 - Axle Temperature Monitoring (Single Rear Virtual Gauge) Design 1136
A26 - Axle Temperature Monitoring (Tandem Rear Aux
Gauge)
A26 - Axle Temperature Monitoring (Tandem Rear Aux Gauge) Design 1137
TABLE OF CONTENTS
xxxvA26 - Axle Temperature Monitoring (Tandem Rear
Virtual Gauge)
A26 - Axle Temperature Monitoring (Tandem Rear Virtual Gauge) Design 1138
B6.7 - Axle Temperature Monitoring (Single Rear Aux
Gauge)
B6.7 - Axle Temperature Monitoring (Single Rear Aux Gauge) Design 1139
Virtual Gauge)
B6.7 - Axle Temperature Monitoring (Single Rear Virtual Gauge) Design 1140
L9 - Axle Temperature Monitoring (Tandem Rear Aux
Gauge) Option 1
L9 - Axle Temperature Monitoring (Tandem Rear Aux Gauge) Option 1
Design 1141
Gauge) Option 2
L9 - Axle Temperature Monitoring (Tandem Rear Aux Gauge) Option 2
Design 1142
Virtual Gauge) Option 1
L9 - Axle Temperature Monitoring (Tandem Rear Virtual Gauge) Option 1
Design 1143
Virtual Gauge) Option 2
L9 - Axle Temperature Monitoring (Tandem Rear Virtual Gauge) Option 2
Design 1144
A26 - Driver Controlled Locking Differential FR and RR
Axles (Dana w/ two sw)
A26 - Driver Controlled Locking Differential FR and RR Axles (Dana w/ two sw)
Design 1145
Axle (Dana w/ one switch)
A26 - Driver Controlled Locking Differential FR and RR Axle (Dana w/ one switch)
Design 1146
A26 - Driver Controlled Locking Differential RR Axle
(Dana w/ one sw)
A26 - Driver Controlled Locking Differential RR Axle (Dana w/ one sw)
Design 1147
Axles (Meritor w/ two sw)
A26 - Driver Controlled Locking Differential FR and RR Axles (Meritor w/ two sw)
Design 1148
Axle (Meritor w/ one sw)
A26 - Driver Controlled Locking Differential FR and RR Axle (Meritor w/ one sw)
Design 1149
TABLE OF CONTENTS
xxxviA26 - Driver Controlled Locking Differential RR Axle
(Meritor w/ one sw)
A26 - Driver Controlled Locking Differential RR Axle (Meritor w/ one sw)
Design 1150
B6.7 - Driver Controlled Locking Differential - RR Axle
(Dana w/ one sw)
B6.7 - Driver Controlled Locking Differential - RR Axle (Dana w/ one sw)
Design 1151
(Meritor w/ one sw)
B6.7 - Driver Controlled Locking Differential - RR Axle (Meritor w/ one sw)
Design 1152
L9 - Driver Controlled Locking Differential - FR and RR
L9 - Driver Controlled Locking Differential - FR and RR Axles (Dana w/ two sw)
Design 1153
L9 - Driver Controlled Locking Differential - FR and RR Axle (Dana w/ one sw)
Design 1154
L9 - Driver Controlled Locking Differential - RR Axle
(Dana w/ one sw)
L9 - Driver Controlled Locking Differential - RR Axle (Dana w/ one sw)
Design 1155
L9 - Driver Controlled Locking Differential - FR and RR Axles (Meritor w/ two sw)
Design 1156
L9 - Driver Controlled Locking Differential - FR and RR Axle (Meritor w/ one sw)
Design 1157
(Meritor w/ one sw)
L9 - Driver Controlled Locking Differential - RR Axle (Meritor w/ one sw)
Design 1158
A26/B6.7/L9 - Height Control
A26/B6.7/L9 - Height Control Design 1159
A26/B6.7/L9 - Power Divider Lock Control and
Monitoring
A26/B6.7/L9 - Power Divider Lock Control and Monitoring Design 1160
L9 - Rear Axle Load Distribution
L9 - Rear Axle Load Distribution Design 1161
A26/B6.7/L9 - Rear Suspension Pressure Monitoring
(Auxiliary Gauge)
A26/B6.7/L9 - Rear Suspension Pressure Monitoring (Auxiliary Gauge)
Design 1162
TABLE OF CONTENTS
xxxviiA26/B6.7/L9 - Rear Suspension Pressure Monitoring
(Virtual Gauge)
A26/B6.7/L9 - Rear Suspension Pressure Monitoring (Virtual Gauge) Design 1164
A26 - Two Speed Axle (Multiplex SW on Dash)
A26 - Two Speed Axle (Multiplex SW on Dash) Design 1166
B6.7 - Two Speed Axle (AirShift on Shifter)
B6.7 - Two Speed Axle (AirShift on Shifter) Design 1167
L9 - Two Speed Axle (AirShift on Shifter)
L9 - Two Speed Axle (AirShift on Shifter) Design 1168
L9 - Two Speed Axle (Multiplex SW on Dash)
L9 - Two Speed Axle (Multiplex SW on Dash) Design 1169
A26/B6.7/L9 - Driver and Passenger Seats - RollTek
(Hard Wired)
A26/B6.7/L9 - Driver and Passenger Seats - RollTek (Hard Wired) Design 1170
A26/B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard
Wired) - Leather
A26/B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard Wired) - Leather
Design 1171
Wired) - Mordular
A26/B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard Wired) - Mordular
Design 1172
Wired) - Vinyl
A26/B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard Wired) - Vinyl Design 1173
A26/B6.7/L9 - Seatbelt Reminder 6 Seats
A26/B6.7/L9 - Seatbelt Reminder 6 Seats Design 1174
A26/B6.7/L9 - Seatbelt Reminder (Warning)(Driver
only)
A26/B6.7/L9 - Seatbelt Reminder (Warning)(Driver only) Design 1175
A26/B6.7/L9 - Seatbelt Reminder (Warning)(Driver &
Passenger in parallel)
A26/B6.7/L9 - Seatbelt Reminder (Warning)(Driver & Passenger in parallel)
Design 1176
Vehicle Data Recorder (No Display)
Vehicle Data Recorder (No Display) Design 1177
Vehicle Data Recorder (W/ Display)
Vehicle Data Recorder (W/ Display) Design 1179
L9 - TEM Electric Trailer Brake Controller Activated
Stop LT
L9 - TEM Electric Trailer Brake Controller Activated Stop LT Design 1181
A26 - TEM Electric Trailer Brake Controller Activated
Stop LT
A26 - TEM Electric Trailer Brake Controller Activated Stop LT Design 1182
TABLE OF CONTENTS
xxxviiiA26 - TEM Electric Trailer Brake Controller Activated
Stop LT (Option2)
A26 - TEM Electric Trailer Brake Controller Activated Stop LT (Option2)
Design 1183
B6.7 - TEM Electric Trailer Brake Controller Activated
Stop LT Option 2
B6.7 - TEM Electric Trailer Brake Controller Activated Stop LT Option 2
Design 1184
B6.7 - TEM _Electric Trailer Brake Controller Activated
Stop LT Option 1
B6.7 - TEM _Electric Trailer Brake Controller Activated Stop LT Option 1
Design 1185
L9 - Trailer Interface - ABS (ETB Feed, Blunt Cut)
L9 - Trailer Interface - ABS (ETB Feed, Blunt Cut) Design 1186
B6.7 - Trailer Interface (Lighting) – BLUNT CUT (Part
of Electric Trailer Brakes) Option 1
B6.7 - Trailer Interface (Lighting) – BLUNT CUT (Part of Electric Trailer Brakes)
Option 1 Design 1187
of Electric Trailer Brakes) Option 2
Option 2 Design 1188
L9 - Trailer Interface (Lighting) – BLUNT CUT (Part of
L9 - Trailer Interface (Lighting) – BLUNT CUT (Part of Electric Trailer Brakes)
Option 1 Design 1189
Option 2 Design 1190
A26 - Transmission Shifter (Stalk Shifter Allison)
A26 - Transmission Shifter (Stalk Shifter Allison) Design 1191
B6.7 - Transmission Shifter (Stalk Shifter Allison)
B6.7 - Transmission Shifter (Stalk Shifter Allison) Design 1193
B6.7 - Transmission Shifter (T-Handle for Allison With
Park Position)
B6.7 - Transmission Shifter (T-Handle for Allison With Park Position) Design 1195
B6.7 - T-Handle for Allison Without Park Position
B6.7 - T-Handle for Allison Without Park Position Design 1197
B6.7 - Transmission Shifter Allison 5th Gen Push
Button(SURHD)
B6.7 - Transmission Shifter Allison 5th Gen Push Button(SURHD) Design 1199
L9 - Transmission Shifter Allison 5th Gen Push
Button(SURHD)
TABLE OF CONTENTS
xxxixL9 - Transmission Shifter Allison 5th Gen Push Button(SURHD) Design 1201
L9 - Transmission Shifter (Stalk Shifter Allison)
L9 - Transmission Shifter (Stalk Shifter Allison) Design 1202
A26/B6.7/L9 - Transfer Case - High/Low Air Sol
A26/B6.7/L9 - Transfer Case - High/Low Air Sol Design 1204
A26/B6.7/L9 - Transfer Case - High/Neu/Low Air Sol
A26/B6.7/L9 - Transfer Case - High/Neu/Low Air Sol Design 1205
A26 - Ultrashift Plus
A26 - Ultrashift Plus Design 1206
L9 - Ultrashift Plus
L9 - Ultrashift Plus Design 1207
A26 - Transmission (Allison 3K/4K)
A26 - Transmission (Allison 3K/4K) Design 1208
L9 - Auto Neutral (Allison without Multiplex Switch
and Confirmation Telltale)
L9 - Auto Neutral (Allison without Multiplex Switch and Confirmation Telltale)
Design 1210
L9 - Auto Neutral (Allison with Multiplex Switch and
L9 - Auto Neutral (Allison with Multiplex Switch and Confirmation Telltale)
Design 1212
B6.7 - Transmission (Allison 1K/2K)
B6.7 - Transmission (Allison 1K/2K) Design 1214
B6.7 - Transmission (Allison 3K/4K)
B6.7 - Transmission (Allison 3K/4K) Design 1215
L9 - Transmission I/O (Allison 3K with Body Builder) -
13WUC
L9 - Transmission I/O (Allison 3K with Body Builder) - 13WUC Design 1217
L9 - Transmission (Allison 3K/4K)
L9 - Transmission (Allison 3K/4K) Design 1218
A26 - Transmissions Electrical I/O (Eaton Ultrashift)
A26 - Transmissions Electrical I/O (Eaton Ultrashift) Design 1220
L9 - Transmissions Electrical I/O (Eaton Ultrashift)
L9 - Transmissions Electrical I/O (Eaton Ultrashift) Design 1221
A26 - Hill Start Aid (Bendix)
A26 - Hill Start Aid (Bendix) Design 1222
L9 - Hill Start Aid (Bendix)
L9 - Hill Start Aid (Bendix) Design 1224
L9 - Hill Start Aid (WABCO)
L9 - Hill Start Aid (WABCO) Design 1226
A26/B6.7/L9 - Transmission - MODE Selection
A26/B6.7/L9 - Transmission - MODE Selection Design 1227
TABLE OF CONTENTS
xlB6.7 - Windshield Washer Pump
B6.7 - Windshield Washer Pump Design 1228
B6.7 - Windshield Washer Pump & Low Fluid Sensor
B6.7 - Windshield Washer Pump & Low Fluid Sensor Design 1229
L9 - Windshield Washer Pump & Low Fluid Sensor
L9 - Windshield Washer Pump & Low Fluid Sensor Design 1230
A26 - Windshield Wipers
A26 - Windshield Wipers Design 1232
B6.7 - Windshield Wipers
B6.7 - Windshield Wipers Design 1233
L9 - Windshield Wipers
L9 - Windshield Wipers Design 1234
B6.7/L9 - Battery Disconnect (W/Switch and
W/Solenoid)
B6.7/L9 - Battery Disconnect (W/Switch and W/Solenoid) Design 1235
A26 - Bosch LIL165 LIL200 Alternator W/Sensor
A26 - Bosch LIL165 LIL200 Alternator W/Sensor Design 1236
A26 - Delco Remy 28SI Alternator W/Sensor
A26 - Delco Remy 28SI Alternator W/Sensor Design 1238
A26 - Delco Remy 36SI Alternator W/Sensor
A26 - Delco Remy 36SI Alternator W/Sensor Design 1240
A26 - Delco Remy 40SI Alternator W/Sensor
A26 - Delco Remy 40SI Alternator W/Sensor Design 1242
A26 - Leece-Neville AVI160 Alternator
A26 - Leece-Neville AVI160 Alternator Design 1244
A26 - Leece-Neville AVI160-210A/240A Alternator
W/Sensor
A26 - Leece-Neville AVI160-210A/240A Alternator W/Sensor Design 1245
A26 - Leece-Neville 320PAH Alternator
A26 - Leece-Neville 320PAH Alternator Design 1247
A26 - Leece-Neville - LN 325A Alternator W/Sensor
A26 - Leece-Neville - LN 325A Alternator W/Sensor Design 1248
A26- Bosch LH160 LH200 Alternator
A26- Bosch LH160 LH200 Alternator Design 1250
B6.7 - Bosch LH160_LH200 Alternator
B6.7 - Bosch LH160_LH200 Alternator Design 1251
B6.7 - Delco Remy 28SI Alternator W/Sensor Option 1
B6.7 - Delco Remy 28SI Alternator W/Sensor Option 1 Design 1253
B6.7 - Delco Remy 28SI Alternator W/Sensor Option 2
B6.7 - Delco Remy 28SI Alternator W/Sensor Option 2 Design 1254
B6.7 - Delco Remy 36SI Alternator W/Sensor
B6.7 - Delco Remy 36SI Alternator W/Sensor Design 1255
TABLE OF CONTENTS
xliB6.7 - Delco Remy 40SI Alternator W/Sensor
B6.7 - Delco Remy 40SI Alternator W/Sensor Design 1256
B6.7 - Leece-Neville AVI160 Alternator
B6.7 - Leece-Neville AVI160 Alternator Design 1257
B6.7 - Leece-Neville AVI160-210A/240A Alternator
W/Sensor
B6.7 - Leece-Neville AVI160-210A/240A Alternator W/Sensor Design 1258
B6.7 - Leece-Neville 320PAH Alternator
B6.7 - Leece-Neville 320PAH Alternator Design 1259
B6.7 - Leece-Neville - LN 325A Alternator W/Sensor
B6.7 - Leece-Neville - LN 325A Alternator W/Sensor Design 1260
L9 - Bosch LH160_LH200 Alternator
L9 - Bosch LH160_LH200 Alternator Design 1261
L9 - Delco Remy 28SI Alternator W/Sensor
L9 - Delco Remy 28SI Alternator W/Sensor Design 1262
L9 - Delco Remy 36SI Alternator W/Sensor
L9 - Delco Remy 36SI Alternator W/Sensor Design 1263
L9 - Delco Remy 40SI Alternator W/Sensor
L9 - Delco Remy 40SI Alternator W/Sensor Design 1264
L9 - Leece-Neville AVI160 Alternator
L9 - Leece-Neville AVI160 Alternator Design 1265
L9 - Leece-Neville AVI160-210A/240A Alternator
W/Sensor
L9 - Leece-Neville AVI160-210A/240A Alternator W/Sensor Design 1266
L9 - Leece-Neville - LN 325A Alternator W/Sensor
L9 - Leece-Neville - LN 325A Alternator W/Sensor Design 1267
A26/B6.7/L9 - Crank Inhibit (Engine Speed Inhibit
Only)
A26/B6.7/L9 - Crank Inhibit (Engine Speed Inhibit Only) Design 1268
A26 - Cranking (Starter) GEN4 BODY CONTROL
MODULE W/O Thermal Overcrank
A26 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/O Thermal
Overcrank Design 1269
MODULE W/ Thermal Overcrank
A26 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/ Thermal
Overcrank Design 1275
B6.7 - Cranking (Starter) GEN4 BODY CONTROL
B6.7 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/O Thermal
Overcrank Design 1281
L9 - Cranking (Starter) GEN4 BODY CONTROL
TABLE OF CONTENTS
xliiL9 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/O Thermal
Overcrank Design 1282
MODULE W/ Thermal Overcrank - External Switch
L9 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/ Thermal Overcrank
- External Switch Design 1283
A26 - Cranking Request (w/ Key Switch w/ BCM)
A26 - Cranking Request (w/ Key Switch w/ BCM) Design 1284
A26/B6.7/L9 - Key Switch (Operator Input)
A26/B6.7/L9 - Key Switch (Operator Input) Design 1286
B6.7 - Cranking Request (w/ Key Switch w/ BCM)
B6.7 - Cranking Request (w/ Key Switch w/ BCM) Design 1288
L9 - Cranking Request (w/ Key Switch w/ BCM)
L9 - Cranking Request (w/ Key Switch w/ BCM) Design 1290
A26 - Clutch Switch/Monitoring (High and Low Switch
to BCM)
A26 - Clutch Switch/Monitoring (High and Low Switch to BCM) Design 1291
A26 - Starter Interlock (BCM Controlled with Input
from Allison 3K/4K TCM)
A26 - Starter Interlock (BCM Controlled with Input from Allison 3K/4K TCM)
Design 1292
A26 - Starter Interlock (BCM LSD Controlled w/ Relay
& N/ Auto SS)
A26 - Starter Interlock (BCM LSD Controlled w/ Relay & N/ Auto SS) Design 1294
B6.7 - Clutch Switch/Monitoring (High and Low Switch
to BCM)
B6.7 - Clutch Switch/Monitoring (High and Low Switch to BCM) Design 1295
B6.7 - Starter Interlocks (BCM Controlled with Input
from Allison 1K/2K TCM)
B6.7 - Starter Interlocks (BCM Controlled with Input from Allison 1K/2K TCM)
Design 1296
B6.7 - Starter Interlocks (BCM Controlled with Input from Allison 3K/4K TCM)
Design 1297
L9 - Clutch Switch/Monitoring (High and Low Switch
to BCM)
L9 - Clutch Switch/Monitoring (High and Low Switch to BCM) Design 1299
L9 - Starter Interlocks (BCM Controlled with Input
L9 - Starter Interlocks (BCM Controlled with Input from Allison 3K/4K TCM)
Design 1300
L9 - Starter Interlock (BCM HSD controlled W/ Clutch
SW & N/Auto SS)
TABLE OF CONTENTS
xliiiL9 - Starter Interlock (BCM HSD controlled W/ Clutch SW & N/Auto SS)
Design 1302
L9 - Starter Interlock (BCM LSD Controlled w/ Relay &
N/ Auto SS)_EATON XMSN
L9 - Starter Interlock (BCM LSD Controlled w/ Relay & N/ Auto SS)_EATON
XMSN Design 1303
A26 - Battery International (4) 12V
A26 - Battery International (4) 12V Design 1304
B6.7 - Battery International (4) 12V
B6.7 - Battery International (4) 12V Design 1305
L9 - Battery International (4) 12V
L9 - Battery International (4) 12V Design 1306
Connectors 1307
Part Assembly List
Connector Assembly List HV 3419
Index 36
- International DT466,DT570,HT570 Diesel Engine Service Manual
- International DT466E Wiring Schematic
- International 365, 444, 466, 530 Service Manuals
- Navistar Diagnostic Trouble Code Index
- SCANIA 420 DC11 - DC12 Motor
- International 9800 Electrical Schematic
- International Truck DT466E Engine Repair Manual
- International - VT365 Schematic (SPA)
- Scania Manual Transmission GRS900
- International Truck 5000i,9200i,9400i and 9900i Chassis Built Electrical Circuit Diagram
- International Trucks Body Controller Diagnostic Trouble Codes
- International Wiring Diagram
- International Truck CF500 CF600 Service Manual
- Scania Manual Transmission GR 900
- International DT466, DT530 Electronic Diagram
