International Truck HV Series Interactive Schematics 00000018833 2025
Brand: International, Navistar
Type of Manual: Interactive Schematics
Model: International HV Series Truck
Built: 12/10/2021 To 12/31/2025
Part Number: 00000018833
Publication Date: 2025
Number of Pages: 4959 Pages
A26/B6.7/L9 - BCM (Body Control Module)
A26/B6.7/L9 - BODY CONTROL MODULE (Body Control Module) Design 1
A26 - ABS Private J1939
A26 - ABS Private J1939 Design 9
A26 - Cab J1939 (250Kbps)
A26 - Cab J1939 (250Kbps) Design 10
A26 - Low Speed J1939 (125Kbps)
A26 - Low Speed J1939 (125Kbps) Design 11
A26 - N2 Proprietary J1939
A26 - N2 Proprietary J1939 Design 12
A26 - Telematics J1708 (9.6kbps)
A26 - Telematics J1708 (9.6kbps) Design 13
A26 - 2017 Body Standard J1939 (250kbps) - 5/26/2025
and Newer Models
A26 - 2017 Body Standard J1939 (250kbps) - 5/26/2025 and Newer Models
Design 14
Diagnostic Proprietary J1939
Diagnostic Proprietary J1939 Design 15
Engine Proprietary J1939 (250kbps)
Engine Proprietary J1939 (250kbps) Design 16
Powertrain Standard J1939 (500kbps)
Powertrain Standard J1939 (500kbps) Design 17
B6.7 - ABS Private J1939
B6.7 - ABS Private J1939 Design 18
B6.7 - Cab J1939 (250kbps)
B6.7 - Cab J1939 (250kbps) Design 19
B6.7 - Engine Private J1939 (250kbps)
B6.7 - Engine Private J1939 (250kbps) Design 20
B6.7 - Low Speed J1939 (125kbps)
B6.7 - Low Speed J1939 (125kbps) Design 21
B6.7 - Telematics J1708 (9.6kbps)
B6.7 - Telematics J1708 (9.6kbps) Design 22
B6.7 - 2017-2024 Body Standard J1939 (250kbps) -
12/10/2021 - 5/25/2025
B6.7 - 2017-2024 Body Standard J1939 (250kbps) - 12/10/2021 - 5/25/2025
Design 23
B6.7 - 2017-2024 N2 Proprietary J1939
B6.7 - 2017-2024 N2 Proprietary J1939 Design 24
B6.7 - 2024-2027 Body Standard J1939 (250kbps) -
05/26/2025 and Newer Models
B6.7 - 2024-2027 Body Standard J1939 (250kbps) - 05/26/2025 and Newer
Models Design 25
iB6.7 - 2024-2027 N2 Proprietary J1939
B6.7 - 2024-2027 N2 Proprietary J1939 Design 26
B6.7 - Powertrain J1939 Allison 1k/2k
B6.7 - Powertrain J1939 Allison 1k/2k Design 27
B6.7 - Powertrain J1939 Allison 3k/4k
B6.7 - Powertrain J1939 Allison 3k/4k Design 28
B6.7 - Powertrain J1939 Manual Transmission
B6.7 - Powertrain J1939 Manual Transmission Design 29
CBE1 - 2024-2027 Body Standard J1939 (250kbps) -
CBE1 - 2024-2027 Body Standard J1939 (250kbps) - 05/26/2025 and Newer
Models Design 30
CBE1 - 2024-2027 N2 Proprietary J1939
CBE1 - 2024-2027 N2 Proprietary J1939 Design 31
L9 - ABS Private J1939
L9 - ABS Private J1939 Design 32
L9 - Body J1939 (250kbps)
L9 - Body J1939 (250kbps) Design 33
L9 - Cab J1939 (250kbps)
L9 - Cab J1939 (250kbps) Design 34
L9 - Engine Private J1939 (250kbps)
L9 - Engine Private J1939 (250kbps) Design 35
L9 - Low Speed J1939 (125kbps)
L9 - Low Speed J1939 (125kbps) Design 36
L9 - Telematics J1708 (9.6kbps)
L9 - Telematics J1708 (9.6kbps) Design 37
L9 - 2017-2024 Body Standard J1939 (250kbps) -
L9 - 2017-2024 Body Standard J1939 (250kbps) - 12/10/2021 - 5/25/2025
Design 38
L9 - 2017-2024 N2 Proprietary J1939
L9 - 2017-2024 N2 Proprietary J1939 Design 39
L9 - 2024-2027 Body Standard J1939 (250kbps) -
L9 - 2024-2027 Body Standard J1939 (250kbps) - 05/26/2025 and Newer Models
Design 40
L9 - 2024-2027 N2 Proprietary J1939
L9 - 2024-2027 N2 Proprietary J1939 Design 41
L9 - Powertrain J1939 Allison 3k/4k
L9 - Powertrain J1939 Allison 3k/4k Design 42
L9 - Powertrain J1939 Eaton
L9 - Powertrain J1939 Eaton Design 43
iiL9 - Powertrain J1939 Manual Transmission
L9 - Powertrain J1939 Manual Transmission Design 44
A26 - ECM Navistar A26
A26 - ECM Navistar A26 Design 45
B6.7 - ECM Cummins CM2350A
B6.7 - ECM Cummins CM2350A Design 49
L9 - ECM Cummins CM2350A
L9 - ECM Cummins CM2350A Design 50
A26/B6.7/L9 - Instrument Cluster (Premium)
A26/B6.7/L9 - Instrument Cluster (Premium) Design 51
A26/B6.7/L9 - Instrument Cluster (Standard)
A26/B6.7/L9 - Instrument Cluster (Standard) Design 53
A26/B6.7/L9 - Instrument Cluster - Bulb Check
A26/B6.7/L9 - Instrument Cluster - Bulb Check Design 55
A26/B6.7/L9 - Instrument Cluster - Request and Status
A26/B6.7/L9 - Instrument Cluster - Request and Status Design 56
A26/B6.7/L9/S13 - Ground Splice Pack 1022 & 1023
A26/B6.7/L9/S13 - Ground Splice Pack 1022 & 1023 Design 57
A26/B6.7/L9/S13 - Ground Splice Pack 1027
A26/B6.7/L9/S13 - Ground Splice Pack 1027 Design 58
A26/B6.7/L9/S13 - Interior Dual Post Ground StudCowl Wall
A26/B6.7/L9/S13 - Interior Dual Post Ground Stud-Cowl Wall Design 59
A26/B6.7/L9/S13 - ZVR Splice Pack - 1620
A26/B6.7/L9/S13 - ZVR Splice Pack - 1620 Design 60
A26 - Center Chassis Ground Splice Packs
A26 - Center Chassis Ground Splice Packs Design 61
B6.7 - Center Chassis Ground Splice Packs
B6.7 - Center Chassis Ground Splice Packs Design 62
L9/S13 - Center Chassis Ground Splice Packs
L9/S13 - Center Chassis Ground Splice Packs Design 63
A26 - Forward Chassis Ground Splice Packs 8800
A26 - Forward Chassis Ground Splice Packs 8800 Design 64
B6.7 - Forward Chassis Ground Splice Packs 8800
B6.7 - Forward Chassis Ground Splice Packs 8800 Design 65
L9 - Forward Chassis Ground Splice Packs 8800
L9 - Forward Chassis Ground Splice Packs 8800 Design 66
A26 - Powertrain Ground Splice Packs - 6704
A26 - Powertrain Ground Splice Packs - 6704 Design 67
A26 - Powertrain ZVR Splice Packs 6702
A26 - Powertrain ZVR Splice Packs 6702 Design 68
iiiB6.7 - Engine Ground Distribution - Ring Terminals
B6.7 - Engine Ground Distribution - Ring Terminals Design 69
B6.7 - Engine Ground Distribution - Splice Packs
B6.7 - Engine Ground Distribution - Splice Packs Design 70
B6.7 - Powertrain Splice Pack 6704
B6.7 - Powertrain Splice Pack 6704 Design 71
B6.7 - ZVR Splice Pack - 6747
B6.7 - ZVR Splice Pack - 6747 Design 72
L9 - Powertrain Splice Pack 6704 & 6704B
L9 - Powertrain Splice Pack 6704 & 6704B Design 73
L9 - ZVR Splice Pack - 6747
L9 - ZVR Splice Pack - 6747 Design 74
A26/B6.7/L9/S13 - Lighting Control Module
A26/B6.7/L9/S13 - Lighting Control Module Design 75
A26 - Aftertreatment PDM
A26 - Aftertreatment PDM Design 77
B6.7 - Aftertreatment PDM
B6.7 - Aftertreatment PDM Design 78
L9 - Aftertreatment PDM
L9 - Aftertreatment PDM Design 79
A26 - Auxiliary Power Fuse
A26 - Auxiliary Power Fuse Design 80
B6.7 - Auxiliary Power Fuse
B6.7 - Auxiliary Power Fuse Design 81
L9 - Auxiliary Power Fuse
L9 - Auxiliary Power Fuse Design 82
A26 - Chassis PDM
A26 - Chassis PDM Design 83
B6.7/L9 - Chassis PDM
B6.7/L9 - Chassis PDM Design 84
A26/B6.7/L9/S13 - Battery Feed
A26/B6.7/L9/S13 - Battery Feed Design 85
A26/B6.7/L9/S13 - Interior PDM Chart
A26/B6.7/L9/S13 - Interior PDM Chart Design 86
A26/B6.7/L9/S13 - Key Switch Accessory
A26/B6.7/L9/S13 - Key Switch Accessory Design 87
A26/B6.7/L9/S13 - Key Switch Ignition
A26/B6.7/L9/S13 - Key Switch Ignition Design 88
A26 - Relays
A26 - Relays Design 89
ivB6.7 - Relays
B6.7 - Relays Design 90
L9 - Relays
L9 - Relays Design 91
A26/B6.7/L9/S13 - ABS CAN Splice Pack - 1410
A26/B6.7/L9/S13 - ABS CAN Splice Pack - 1410 Design 92
A26/B6.7/L9/S13 - Panel Light Dimmer Splice Pack -
1021
A26/B6.7/L9/S13 - Panel Light Dimmer Splice Pack - 1021 Design 93
A26/B6.7/L9/S13 - Park / Turn Lights Splice Packs
1623/1625/400
A26/B6.7/L9/S13 - Park / Turn Lights Splice Packs 1623/1625/400 Design 94
A26 - Underhood PDM
A26 - Underhood PDM Design 95
B6.7/L9 - Underhood PDM
B6.7/L9 - Underhood PDM Design 96
A26/B6.7/L9 - Air Horn (Highway) W/Hardwired Switch
A26/B6.7/L9 - Air Horn (Highway) W/Hardwired Switch Design 97
A26/B6.7/L9 - Radio
A26/B6.7/L9 - Radio Design 98
A26/B6.7/L9 - Radio w/Bluetooth
A26/B6.7/L9 - Radio w/Bluetooth Design 99
A26/B6.7/L9 - Radio w/Bluetooth without Steering
Wheel Pod
A26/B6.7/L9 - Radio w/Bluetooth without Steering Wheel Pod Design 101
A26/B6.7/L9 - Radio w/Steering Wheel Pod
A26/B6.7/L9 - Radio w/Steering Wheel Pod Design 102
A26/B6.7/L9 - Four Speakers Daycab BT n/QC
A26/B6.7/L9 - Four Speakers Daycab BT n/QC Design 104
A26/B6.7/L9 - Four Speakers Daycab n/BT n/QC
A26/B6.7/L9 - Four Speakers Daycab n/BT n/QC Design 105
A26/B6.7/L9 - Two Speakers Daycab BT n/QC
A26/B6.7/L9 - Two Speakers Daycab BT n/QC Design 106
A26/B6.7/L9 - Two Speakers Daycab n/BT n/QC
A26/B6.7/L9 - Two Speakers Daycab n/BT n/QC Design 107
B6.7 - Speakers: Four Speakers Daycab n/BT w/QC
B6.7 - Speakers:Four Speakers Daycab n/BT w/QC Design 108
B6.7 - Speakers: Two Speakers n/BT w/QC
B6.7 - Speakers:Two Speakers n/BT w/QC Design 109
B6.7 - Speakers: Two Speakers w/BT w/QC
B6.7 - Speakers:Two Speakers w/BT w/QC Design 110
vB6.7 - Speaker: Four Speakers Daycab w/BT w/QC
B6.7 - Speaker:Four Speakers Daycab w/BT w/QC Design 111
L9 - Speakers: Four Speakers Daycab n/BT w/QC
L9 - Speakers:Four Speakers Daycab n/BT w/QC Design 112
L9 - Speakers: Two Speakers n/BT w/QC
L9 - Speakers:Two Speakers n/BT w/QC Design 113
L9 - Speakers: Two Speakers w/BT w/QC
L9 - Speakers:Two Speakers w/BT w/QC Design 114
L9 - Speaker: Four Speakers Daycab w/BT w/QC
L9 - Speaker:Four Speakers Daycab w/BT w/QC Design 115
A26/B6.7/L9 - Auxiliary Power (40A) HSD
A26/B6.7/L9 - Auxiliary Power (40A) HSD Design 116
B6.7 - Dual Auxiliary Power with Interlock
B6.7 - Dual Auxiliary Power with Interlock Design 117
A26 - Backup Alarm (Relay to 5 Pin 08TKC Tailboard
Alarm Plugs In)
A26 - Backup Alarm (Relay to 5 Pin 08TKC Tailboard Alarm Plugs In) Design 118
to Alarm)
A26 - Backup Alarm (Relay to 5 Pin 08TKC Tailboard to Alarm) Design 119
A26 - Backup Alarm (Relay to 5 Pin 08TKC Tailboard.
Alarm Plugs In)
A26 - Backup Alarm (Relay to 5 Pin 08TKC Tailboard. Alarm Plugs In) Design 120
A26 - Backup Alarm (Switch to 5 Pin 08TKC Tailboard
to Alarm)
A26 - Backup Alarm (Switch to 5 Pin 08TKC Tailboard to Alarm) Design 121
A26 - Backup Alarm (08THB & W/ 08NAA)
A26 - Backup Alarm (08THB & W/ 08NAA) Design 122
A26 - Backup Alarm (08WDG & W/ 08NAA)
A26 - Backup Alarm (08WDG & W/ 08NAA) Design 123
A26 - Back-Up Alarm (Automatic) W/O Tailboard
A26 - Back-Up Alarm (Automatic) W/O Tailboard Design 124
A26 - Back-Up Alarm (Automatic) W/ Tailboard)
A26 - Back-Up Alarm (Automatic) W/ Tailboard) Design 125
A26 - Back-Up Alarm (Manual) W/O Tailboard
A26 - Back-Up Alarm (Manual) W/O Tailboard Design 126
A26 - Back-Up Alarm (Manual) W/ Tailboard)
A26 - Back-Up Alarm (Manual) W/ Tailboard) Design 127
A26/B6.7/L9 - Backup Alarm (From Relay to 5 Pin
Daisy Chain to Backup Alarm)
viA26/B6.7/L9 - Backup Alarm (From Relay to 5 Pin Daisy Chain to Backup Alarm)
Design 128
Daisy Chain to Backup Alarm, W/ Extension)
A26/B6.7/L9 - Backup Alarm (From Relay to 5 Pin Daisy Chain to Backup Alarm,
W/ Extension) Design 129
Daisy Chain. Backup Alarm Plugs in)
A26/B6.7/L9 - Backup Alarm (From Relay to 5 Pin Daisy Chain. Backup Alarm
Plugs in) Design 130
Daisy Chain. Backup Alarm Plugs in, W/ Extension)
Plugs in, W/ Extension) Design 131
A26/B6.7/L9 - Back-Up Alarm (Automatic) W/O
Tailboard
A26/B6.7/L9 - Back-Up Alarm (Automatic) W/O Tailboard Design 132
B6.7 - Back-Up Alarm (Automatic) W/O Tailboard
B6.7 - Back-Up Alarm (Automatic) W/O Tailboard Design 133
B6.7 - Back-Up Alarm (Automatic) W/ Tailboard
B6.7 - Back-Up Alarm (Automatic) W/ Tailboard Design 134
B6.7 - Back-Up Alarm (Manual) W/O Tailboard
B6.7 - Back-Up Alarm (Manual) W/O Tailboard Design 135
B6.7 - Back-Up Alarm (Manual) W/ Tailboard
B6.7 - Back-Up Alarm (Manual) W/ Tailboard Design 136
L9 - Back-Up Alarm (Automatic) W/O Tailboard Design 137
L9 - Back-Up Alarm (Automatic) W/ Tailboard
L9 - Back-Up Alarm (Automatic) W/ Tailboard Design 138
L9 - Back-Up Alarm (Manual) W/O Tailboard
L9 - Back-Up Alarm (Manual) W/O Tailboard Design 139
L9 - Back-Up Alarm (Manual) W/ Tailboard
L9 - Back-Up Alarm (Manual) W/ Tailboard Design 141
A26/B6.7/L9 - Banana Plugs Receptacle
A26/B6.7/L9 - Banana Plugs Receptacle Design 143
A26/B6.7/L9 - Surround View (Camera Display, 1
Camera EOF, Prewire)
A26/B6.7/L9 - Surround View (Camera Display, 1 Camera EOF, Prewire)
Design 144
A26/B6.7/L9 - CB Radio - Power Only
A26/B6.7/L9 - CB Radio - Power Only Design 145
A26/B6.7/L9 - CB Radio - Power Only (Single Antenna)
A26/B6.7/L9 - CB Radio - Power Only (Single Antenna) Design 146
A26/B6.7/L9 - Cigar Lighter
viiA26/B6.7/L9 - Cigar Lighter Design 147
A26/B6.7/L9 - Cigar Lighter Aux APO
A26/B6.7/L9 - Cigar Lighter Aux APO Design 148
A26/B6.7/L9 - Forward Auxiliary Power Source (1 APO)
A26/B6.7/L9 - Forward Auxiliary Power Source (1 APO) Design 151
A26/B6.7/L9 - Forward Auxiliary Power Source (2 APO)
A26/B6.7/L9 - Forward Auxiliary Power Source (2 APO) Design 155
A26/B6.7/L9 - Forward Auxiliary Power Source (3 APO)
A26/B6.7/L9 - Forward Auxiliary Power Source (3 APO) Design 161
A26/B6.7/L9 - Forward Auxiliary Power Source (4 APO)
A26/B6.7/L9 - Forward Auxiliary Power Source (4 APO) Design 165
A26/B6.7/L9 - Standard APO
A26/B6.7/L9 - Standard APO Design 166
A26/B6.7/L9 - Standard APO Aux APO
A26/B6.7/L9 - Standard APO Aux APO Design 167
A26/B6.7/L9 - Vehicle Speed Control (Cruise Control)
Multiplex Switch & N/PIM
A26/B6.7/L9 - Vehicle Speed Control (Cruise Control) Multiplex Switch & N/PIM
Design 170
A26/B6.7/L9 - Cruise Control (W/ One Telltale 10 Pin)
A26/B6.7/L9 - Cruise Control (W/ One Telltale 10 Pin) Design 171
A26/B6.7/L9 - Cruise Control (W/ One Telltale 4 Pin)
A26/B6.7/L9 - Cruise Control (W/ One Telltale 4 Pin) Design 173
Multiplex Switch & W/PIM
A26/B6.7/L9 - Vehicle Speed Control (Cruise Control) Multiplex Switch & W/PIM
Design 175
10 Pin
A26/B6.7/L9 - Vehicle Speed Control (Cruise Control) 10 Pin Design 176
A26/B6.7/L9 - Vehicle Speed Control (Cruise Control) 4
Pin
A26/B6.7/L9 - Vehicle Speed Control (Cruise Control) 4 Pin Design 177
(Steering Wheel Controls, No PIM)
A26/B6.7/L9 - Vehicle Speed Control (Cruise Control) (Steering Wheel Controls,
No PIM) Design 178
(Steering Wheel Controls, W/PIM)
W/PIM) Design 179
A26/B6.7/L9 - Door Ajar Reminder (Entry /Exit): 4 Door
A26/B6.7/L9 - Door Ajar Reminder (Entry /Exit):4 Door Design 180
viiiA26/B6.7/L9 - Door Ajar Reminder (Entry/Exit) 2 Door
A26/B6.7/L9 - Door Ajar Reminder (Entry/Exit) 2 Door Design 181
A26/B6.7/L9 - Door Pod Module (2 Door)
A26/B6.7/L9 - Door Pod Module (2 Door) Design 182
A26/B6.7/L9 - Door Pod Module (4 Door)
A26/B6.7/L9 - Door Pod Module (4 Door) Design 183
A26/B6.7/L9 - Mirrors (Heated)
A26/B6.7/L9 - Mirrors (Heated) Design 184
A26/B6.7/L9 - Mirrors (Heat) Switch Pack Actuated
Relay Driven
A26/B6.7/L9 - Mirrors (Heat) Switch Pack Actuated Relay Driven Design 185
A26 - Heated Mirrors (Hood with Door Pods)
A26 - Heated Mirrors (Hood with Door Pods) Design 186
A26 - Heated Mirrors (RT Hood with Door Pods)
A26 - Heated Mirrors (RT Hood with Door Pods) Design 187
A26 - Mirrors (Heat) Switch Pack Actuated includes
Hood Mirrors
A26 - Mirrors (Heat) Switch Pack Actuated includes Hood Mirrors Design 188
A26 - Mirrors (Heat) Switch Pack Actuated includes RT
Hood Mirror
A26 - Mirrors (Heat) Switch Pack Actuated includes RT Hood Mirror Design 189
B6.7 - Heated Mirrors (Hood with Door Pods)
B6.7 - Heated Mirrors (Hood with Door Pods) Design 190
B6.7 - Heated Mirrors (RT Hood with Door Pods)
B6.7 - Heated Mirrors (RT Hood with Door Pods) Design 192
B6.7 - Mirrors (Heat) Switch Pack Actuated includes
Hood Mirrors
B6.7 - Mirrors (Heat) Switch Pack Actuated includes Hood Mirrors Design 196
RT Hood Mirror
B6.7 - Mirrors (Heat) Switch Pack Actuated includes RT Hood Mirror Design 198
L9 - Heated Mirrors (Hood with Door Pods)
L9 - Heated Mirrors (Hood with Door Pods) Design 202
L9 - Heated Mirrors (RT Hood with Door Pods)
L9 - Heated Mirrors (RT Hood with Door Pods) Design 206
L9 - Mirrors (Heat) Switch Pack Actuated includes
Hood Mirrors
L9 - Mirrors (Heat) Switch Pack Actuated includes Hood Mirrors Design 210
L9 - Mirrors (Heat) Switch Pack Actuated includes RT
Hood Mirror
L9 - Mirrors (Heat) Switch Pack Actuated includes RT Hood Mirror Design 214
A26/B6.7/L9 - Power Mirrors (Control Switch Actuated)
ixA26/B6.7/L9 - Power Mirrors (Control Switch Actuated) Design 218
A26 - City Horn (W/ 10PIN Park Brake)
A26 - City Horn (W/ 10PIN Park Brake) Design 220
A26 - City Horn (W/ 10PIN)
A26 - City Horn (W/ 10PIN) Design 222
A26 - City Horn (W/ 4PIN Park Brake)
A26 - City Horn (W/ 4PIN Park Brake) Design 224
A26 - City Horn (W/ 4PIN)
A26 - City Horn (W/ 4PIN) Design 228
B6.7 - City Horn (W/ 10PIN CLK & Park Brake)
B6.7 - City Horn (W/ 10PIN CLK & Park Brake) Design 232
B6.7 - City Horn (W/ 10PIN CLK)
B6.7 - City Horn (W/ 10PIN CLK) Design 235
B6.7 - City Horn (W/ 4PIN CLK & Park Brake)
B6.7 - City Horn (W/ 4PIN CLK & Park Brake) Design 238
B6.7 - City Horn (W/ 4PIN CLK)
B6.7 - City Horn (W/ 4PIN CLK) Design 244
L9 - City Horn (W/ 10PIN CLK & Park Brake)
L9 - City Horn (W/ 10PIN CLK & Park Brake) Design 250
L9 - City Horn (W/ 10PIN CLK)
L9 - City Horn (W/ 10PIN CLK) Design 252
L9 - City Horn (W/ 4PIN CLK & Park Brake)
L9 - City Horn (W/ 4PIN CLK & Park Brake) Design 254
L9 - City Horn (W/ 4PIN CLK)
L9 - City Horn (W/ 4PIN CLK) Design 258
A26 - (Rand Mcnallly) GPS Display
A26 - (Rand Mcnallly) GPS Display Design 262
A26/B6.7/L9 - Heated Windshield
A26/B6.7/L9 - Heated Windshield Design 263
A26/B6.7/L9 - Heated Windshield (W/ DS Heating Grid)
A26/B6.7/L9 - Heated Windshield (W/ DS Heating Grid) Design 264
A26/B6.7/L9 - Multiplexed Switch Pack (Primary
Switch)
A26/B6.7/L9 - Multiplexed Switch Pack (Primary Switch) Design 265
A26/B6.7/L9 - Real Time Clock (RTC) (BCM Controlled)
A26/B6.7/L9 - Real Time Clock (RTC) (BCM Controlled) Design 266
A26 - Remote Keyless Access
A26 - Remote Keyless Access Design 267
B6.7 - Remote Keyless Access
B6.7 - Remote Keyless Access Design 268
xL9 - Remote Keyless Access
L9 - Remote Keyless Access Design 269
A26 - Over The Air Electrical I/O (OnCommand Link /
N2 Module W/ Diagnostic Connector)
A26 - Over The Air Electrical I/O (OnCommand Link / N2 Module W/ Diagnostic
Connector) Design 270
B6.7 - Over The Air Electrical I/O (OnCommand Link /
N2 Module)
B6.7 - Over The Air Electrical I/O (OnCommand Link / N2 Module) Design 271
N2 Module)(2017-2024 B6.7)
B6.7 - Over The Air Electrical I/O (OnCommand Link / N2 Module)(2017-2024
B6.7) Design 272
N2 Module)(2024-2027 B6.7)
B6.7 - Over The Air Electrical I/O (OnCommand Link / N2 Module)(2024-2027
B6.7) Design 273
B6.7/L9 - Over The Air Electrical I/O (OnCommand
Link / N2 Module W/ Diagnostic Connector)
B6.7/L9 - Over The Air Electrical I/O (OnCommand Link / N2 Module W/
Diagnostic Connector) Design 274
Module)
L9 - Over The Air Electrical I/O (OnCommand Link / N2 Module) Design 275
Module)(2017-2024 L9)
L9 - Over The Air Electrical I/O (OnCommand Link / N2 Module)(2017-2024 L9)
Design 276
Module)(2024-2027 L9)
L9 - Over The Air Electrical I/O (OnCommand Link / N2 Module)(2024-2027 L9)
Design 277
A26 - Telematics (PEOPLE NET, DAYCAB)
A26 - Telematics (PEOPLE NET, DAYCAB) Design 278
L9 - Telematics (PEOPLE NET DAYCAB)
L9 - Telematics (PEOPLE NET DAYCAB) Design 279
A26/B6.7/L9 - Theft Deterrent (Grid Controlled)
A26/B6.7/L9 - Theft Deterrent (Grid Controlled) Design 280
A26/B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 - 1
Repeater)
A26/B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater) Design 281
A26/B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 - 2
Repeaters)
A26/B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 - 2 Repeaters) Design 285
xiTire Pressure (TPMS) (LDL 2.0 AutoLocate - 1
Repeater)(2017 A26)
Tire Pressure (TPMS) (LDL 2.0 AutoLocate - 1 Repeater)(2017 A26) Design 287
Repeater)(2017-2024 L9)
Tire Pressure (TPMS) (LDL 2.0 AutoLocate - 1 Repeater)(2017-2024 L9)
Design 295
Repeater)(2024 B6.7)
Tire Pressure (TPMS) (LDL 2.0 AutoLocate - 1 Repeater)(2024 B6.7) Design 303
Repeater)(2024 L9)
Tire Pressure (TPMS) (LDL 2.0 AutoLocate - 1 Repeater)(2024 L9) Design 311
Repeater)(2024-2027 B6.7)
Tire Pressure (TPMS) (LDL 2.0 AutoLocate - 1 Repeater)(2024-2027 B6.7)
Design 315
Repeater)(2024-2027 L9/S13)
Tire Pressure (TPMS) (LDL 2.0 AutoLocate - 1 Repeater)(2024-2027 L9/S13)
Design 323
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(2017 A26)
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(2017 A26) Design 331
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(2024
B6.7)
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(2024 B6.7) Design 335
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(2024 L9)
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(2024 L9) Design 343
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(2024 S13)
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(2024 S13) Design 347
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(2024-2027
B6.7)
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(2024-2027 B6.7) Design 351
Tire Pressure (TPMS) (LDL 2.0 - 2 Repeaters)(2017
A26)
Tire Pressure (TPMS) (LDL 2.0 - 2 Repeaters)(2017 A26) Design 355
Tire Pressure (TPMS) (LDL 2.0 - 2 Repeaters)(2024-
2027 S13)
Tire Pressure (TPMS) (LDL 2.0 - 2 Repeaters)(2024-2027 S13) Design 357
TMC 8 PIN - 08XNL
TMC 8 PIN - 08XNL Design 359
A26/B6.7/L9 - Aux Power (USB) - 1 USB A, 1 USB C
A26/B6.7/L9 - Aux Power (USB) - 1 USB A, 1 USB C Design 360
A26/B6.7/L9 - Aux Power (USB) - 2 USB A, 2 USB C
xiiA26/B6.7/L9 - Aux Power (USB) - 2 USB A, 2 USB C Design 365
A26/B6.7/L9 - Aux Power (USB) - 3 USB A, 3 USB C
A26/B6.7/L9 - Aux Power (USB) - 3 USB A, 3 USB C Design 375
A26/B6.7/L9 - One USB
A26/B6.7/L9 - One USB Design 384
A26/B6.7/L9 - Two USB
A26/B6.7/L9 - Two USB Design 385
A26/B6.7/L9 - Vehicle Sleep Mode
A26/B6.7/L9 - Vehicle Sleep Mode Design 387
A26 - 2-Way Radio
A26 - 2-Way Radio Design 388
B6.7 - 2-Way Radio
B6.7 - 2-Way Radio Design 390
L9 - 2-Way Radio
L9 - 2-Way Radio Design 392
B6.7/L9 - DPF Regen Switch Only
B6.7/L9 - DPF Regen Switch Only Design 394
B6.7/L9 - DPF With Bistable Inhibit Switch
B6.7/L9 - DPF With Bistable Inhibit Switch Design 395
B6.7/L9 - DPF With Monostable Inhibit Switch
B6.7/L9 - DPF With Monostable Inhibit Switch Design 396
A26 - Diesel Particulate Filter (DPF) (Regen Switch
Only)
A26 - Diesel Particulate Filter (DPF) (Regen Switch Only) Design 397
A26 - Diesel Particulate Filter (DPF) (With Monostable
Inhibit SW)
A26 - Diesel Particulate Filter (DPF) (With Monostable Inhibit SW) Design 398
A26 - Diesel Particulate Filter (DPF) (W/ Bi-Stable
Inhibit SW)
A26 - Diesel Particulate Filter (DPF) (W/ Bi-Stable Inhibit SW) Design 399
A26 - Selective Catalytic Reduction (SCR)
A26 - Selective Catalytic Reduction (SCR) Design 400
B6.7 - Selective Catalytic Reduction (SCR)
B6.7 - Selective Catalytic Reduction (SCR) Design 407
B6.7 - Selective Catalytic Reduction (SCR): 2024 and
newer models
B6.7 - Selective Catalytic Reduction (SCR):2024 and newer models Design 409
L9 - Selective Catalytic Reduction (SCR)
L9 - Selective Catalytic Reduction (SCR) Design 411
L9 - Selective Catalytic Reduction (SCR): 2024 and
newer models
xiiiL9 - Selective Catalytic Reduction (SCR):2024 and newer models Design 413
A26/B6.7/L9 - Adjustable Engine Speed Control (PTO)
10-pin
A26/B6.7/L9 - Adjustable Engine Speed Control (PTO) 10-pin Design 415
4-pin
A26/B6.7/L9 - Adjustable Engine Speed Control (PTO) 4-pin Design 417
A26/B6.7/L9 - Engine Idle Increment/Decrement
(Steering Wheel Controls)
A26/B6.7/L9 - Engine Idle Increment/Decrement (Steering Wheel Controls)
Design 418
(W/MUX Switch)
A26/B6.7/L9 - Engine Idle Increment/Decrement (W/MUX Switch) Design 419
A26/B6.7/L9 - Engine Speed Control (PTO) W/MUX
Switch
A26/B6.7/L9 - Engine Speed Control (PTO) W/MUX Switch Design 420
A26/B6.7/L9 - Engine Speed Control (PTO) (Steering
Wheel Controls)
A26/B6.7/L9 - Engine Speed Control (PTO) (Steering Wheel Controls) Design 421
A26/B6.7/L9 - Steering Wheel Controls (Body Builder)
A26/B6.7/L9 - Steering Wheel Controls (Body Builder) Design 422
A26 - Auxiliary Air Solenoids Normally Closed
A26 - Auxiliary Air Solenoids Normally Closed Design 423
A26 - Auxillary Air Solenoids Normally Open
A26 - Auxillary Air Solenoids Normally Open Design 424
B6.7 - Auxiliary Air Solenoids (1 Normally Closed)
Option 1
B6.7 - Auxiliary Air Solenoids (1 Normally Closed) Option 1 Design 430
Option 2
B6.7 - Auxiliary Air Solenoids (1 Normally Closed) Option 2 Design 431
Option 3
B6.7 - Auxiliary Air Solenoids (1 Normally Closed) Option 3 Design 434
L9 - Auxiliary Air Solenoids (1 Normally Closed)
L9 - Auxiliary Air Solenoids (1 Normally Closed) Design 437
L9 - Auxillary Air Solenoids Normally Closed
L9 - Auxillary Air Solenoids Normally Closed Design 438
L9 - Four Auxillary Air Solenoids
L9 - Four Auxillary Air Solenoids Design 444
L9 - Three Auxillary Air Solenoids
L9 - Three Auxillary Air Solenoids Design 445
xivA26 - Body Builder - Altec (N/BB & W/Manual XMSN &
W/ INTL Engine)
A26 - Body Builder - Altec (N/BB & W/Manual XMSN & W/ INTL Engine)
Design 448
A26 - Body Builder - Altec (N/BB & W/1K2K Trans)
A26 - Body Builder - Altec (N/BB & W/1K2K Trans) Design 450
A26 - Body Builder - Altec (N/BB & W/3K4K Trans & W/
INTL Engine)
A26 - Body Builder - Altec (N/BB & W/3K4K Trans & W/ INTL Engine) Design 452
A26 - Body Builder - Altec (W/BB & W/Manual Trans &
W/ INTL Engine)
A26 - Body Builder - Altec (W/BB & W/Manual Trans & W/ INTL Engine)
Design 454
A26 - Body Builder - Altec (W/BB & W/1K2K Trans)
A26 - Body Builder - Altec (W/BB & W/1K2K Trans) Design 460
A26 - Body Builder - Altec (W/BB & W/3K4K Trans &
W/ INTL Engine)
A26 - Body Builder - Altec (W/BB & W/3K4K Trans & W/ INTL Engine) Design 466
B6.7 - Body Builder - Altec (N/BB & W/Manual XMSN &
W/ CUMMINS Engine)
B6.7 - Body Builder - Altec (N/BB & W/Manual XMSN & W/ CUMMINS Engine)
Design 472
B6.7 - Body Builder - Altec (N/BB & W/1K2K Trans)
B6.7 - Body Builder - Altec (N/BB & W/1K2K Trans) Design 475
B6.7 - Body Builder - Altec (N/BB & W/3K4K Trans &
W/ CUMMINS Engine)
B6.7 - Body Builder - Altec (N/BB & W/3K4K Trans & W/ CUMMINS Engine)
Design 478
B6.7 - Body Builder - Altec (W/BB & W/Manual Trans &
W/ CUMMINS Engine)
B6.7 - Body Builder - Altec (W/BB & W/Manual Trans & W/ CUMMINS Engine)
Design 481
B6.7 - Body Builder - Altec (W/BB & W/1K2K Trans)
B6.7 - Body Builder - Altec (W/BB & W/1K2K Trans) Design 487
B6.7 - Body Builder - Altec (W/BB & W/3K4K Trans &
W/ CUMMINS Engine)
B6.7 - Body Builder - Altec (W/BB & W/3K4K Trans & W/ CUMMINS Engine)
Design 493
B6.7/L9 - Body Builder - Altec (N/BB & W/3K4K Trans
& W/ INTL Engine)
B6.7/L9 - Body Builder - Altec (N/BB & W/3K4K Trans & W/ INTL Engine)
Design 499
B6.7/L9 - Body Builder - Altec (W/BB & W/3K4K Trans
& W/ INTL Engine)
xvB6.7/L9 - Body Builder - Altec (W/BB & W/3K4K Trans & W/ INTL Engine)
Design 501
L9 - Body Builder - Altec (N/BB & W/Manual XMSN &
W/ CUMMINS Engine)
L9 - Body Builder - Altec (N/BB & W/Manual XMSN & W/ CUMMINS Engine)
Design 506
L9 - Body Builder - Altec (N/BB & W/1K2K Trans)
L9 - Body Builder - Altec (N/BB & W/1K2K Trans) Design 509
L9 - Body Builder - Altec (W/BB & W/Manual Trans &
W/ CUMMINS Engine)
L9 - Body Builder - Altec (W/BB & W/Manual Trans & W/ CUMMINS Engine)
Design 512
L9 - Body Builder - Altec (W/BB & W/1K2K Trans)
L9 - Body Builder - Altec (W/BB & W/1K2K Trans) Design 518
CUMMINS Engine)
L9 - Body Builder - Altec (W/BB & W/3K4K Trans & W/ CUMMINS Engine)
Design 524
L9- Body Builder - Altec (N/BB & W/3K4K Trans & W/
CUMMINS Engine)
L9- Body Builder - Altec (N/BB & W/3K4K Trans & W/ CUMMINS Engine)
Design 530
A26/B6.7/L9 - Body Builder Aux Power (In Cab, BOC,
or EOF)
A26/B6.7/L9 - Body Builder Aux Power (In Cab, BOC, or EOF) Design 533
A26 - Body Builder Lighting - BOC, 08HBX, Automatic
A26 - Body Builder Lighting - BOC, 08HBX, Automatic Design 536
A26 - Body Builder Lighting - BOC, 08HBX, Manual
A26 - Body Builder Lighting - BOC, 08HBX, Manual Design 537
A26 - Body Builder Lighting - (BOC, EOF, In Cab)
(8HAB, 8HAE, 8HAU) (Automatic)
A26 - Body Builder Lighting - (BOC, EOF, In Cab) (8HAB, 8HAE, 8HAU)
(Automatic) Design 538
(8HAB, 8HAE, 8HAU) (Automatic)(Option2)
(Automatic)(Option2) Design 539
(8HAB, 8HAE, 8HAU) (Manual)
A26 - Body Builder Lighting - (BOC, EOF, In Cab) (8HAB, 8HAE, 8HAU) (Manual)
Design 540
A26 - Body Builder Lighting - (8HAA) (Blunt Cut)
A26 - Body Builder Lighting - (8HAA) (Blunt Cut) Design 541
xviB6.7 - Body Builder Lighting - Combined Turn and
Stop Lamps (Automatic)
B6.7 - Body Builder Lighting - Combined Turn and Stop Lamps (Automatic)
Design 542
Stop Lamps (Manual)
B6.7 - Body Builder Lighting - Combined Turn and Stop Lamps (Manual)
Design 545
B6.7 - Body Builder Lighting - Separate Turn and Stop
Lamps (Blunt Cut) Option 1
B6.7 - Body Builder Lighting - Separate Turn and Stop Lamps (Blunt Cut) Option
1 Design 548
Lamps (Blunt Cut) Option 2
2 Design 549
L9 - Body Builder Lighting - Combined Turn and Stop
Lamps (Automatic)
L9 - Body Builder Lighting - Combined Turn and Stop Lamps (Automatic)
Design 550
Lamps (Manual)
L9 - Body Builder Lighting - Combined Turn and Stop Lamps (Manual) Design 553
L9 - Body Builder Lighting - Separate Turn and Stop
L9 - Body Builder Lighting - Separate Turn and Stop Lamps (Blunt Cut) Option 1
Design 559
L9 - Body Builder Lighting - Separate Turn and Stop Lamps (Blunt Cut) Option 2
Design 560
A26 - I/O Expansion
A26 - I/O Expansion Design 561
B6.7 - I/O Expansion
B6.7 - I/O Expansion Design 562
L9 - I/O Expansion
L9 - I/O Expansion Design 563
A26 - Powertrain Body Builder Connector (A26 Engine
MD1 N/Ultrashift TCM)
A26 - Powertrain Body Builder Connector (A26 Engine MD1 N/Ultrashift TCM)
Design 564
MD1 W/Ultrashift TCM)
A26 - Powertrain Body Builder Connector (A26 Engine MD1 W/Ultrashift TCM)
Design 565
xviiB6.7 - Powertrain Body Builder Connector (12XBM)
B6.7 - Powertrain Body Builder Connector (12XBM) Design 567
L9 - Powertrain Body Builder Connector (12XBM)
L9 - Powertrain Body Builder Connector (12XBM) Design 568
A26 - Power Lift Gate
A26 - Power Lift Gate Design 569
B6.7 - Power Lift Gate
B6.7 - Power Lift Gate Design 570
L9 - Power Lift Gate
L9 - Power Lift Gate Design 571
A26 - Remote Power Module Features (Boom and
Outrigger Alert)
A26 - Remote Power Module Features (Boom and Outrigger Alert) Design 572
A26 - Remote Power Module Features (Gate Open and
Body UP)
A26 - Remote Power Module Features (Gate Open and Body UP) Design 573
Rear Alert W/ Auto Trans and Procision)
A26 - Remote Power Module Features (Gate Open and Rear Alert W/ Auto Trans
and Procision) Design 574
Rear Alert W/ Auto Trans)
A26 - Remote Power Module Features (Gate Open and Rear Alert W/ Auto Trans)
Design 575
Rear Alert W/ Manual and Ulltrashift+)
A26 - Remote Power Module Features (Gate Open and Rear Alert W/ Manual and
Ulltrashift+) Design 576
A26 - DLB - Remote Power Modules (1 RPM n/ Switch
Packs)
A26 - DLB - Remote Power Modules (1 RPM n/ Switch Packs) Design 577
A26 - DLB - Remote Power Modules (1 RPM w/ Switch
Packs)
A26 - DLB - Remote Power Modules (1 RPM w/ Switch Packs) Design 580
A26 - DLB - Remote Power Modules (2 RPM n/ Switch
Pack)
A26 - DLB - Remote Power Modules (2 RPM n/ Switch Pack) Design 583
Pack)Option2
A26 - DLB - Remote Power Modules (2 RPM n/ Switch Pack)Option2 Design 586
A26 - DLB - Remote Power Modules (2 RPM w/ Switch
Packs)
A26 - DLB - Remote Power Modules (2 RPM w/ Switch Packs) Design 587
xviiiA26 - DLB - Remote Power Modules (2 RPM w/ Switch
Packs)Option2
A26 - DLB - Remote Power Modules (2 RPM w/ Switch Packs)Option2 Design588
A26 - DLB - Remote Power Modules (3 RPM w/ Swtich
Packs)
A26 - DLB - Remote Power Modules (3 RPM w/ Swtich Packs) Design 591
Packs)Option2
A26 - DLB - Remote Power Modules (3 RPM w/ Swtich Packs)Option2 Design592
A26 - DLB - Remote Power Module (3 RPM n/Switch
Pack)
A26 - DLB - Remote Power Module (3 RPM n/Switch Pack) Design 594
Pack)Option2
A26 - DLB - Remote Power Module (3 RPM n/Switch Pack)Option2 Design 595
B6.7 - DLB - Remote Power Modules (1 RPM n/ Switch
Packs)
B6.7 - DLB - Remote Power Modules (1 RPM n/ Switch Packs) Design 597
B6.7 - DLB - Remote Power Modules (1 RPM w/ Switch
Packs)
B6.7 - DLB - Remote Power Modules (1 RPM w/ Switch Packs) Design 600
B6.7 - DLB - Remote Power Modules (2 RPM n/ Switch
Pack)
B6.7 - DLB - Remote Power Modules (2 RPM n/ Switch Pack) Design 603
B6.7 - DLB - Remote Power Modules (2 RPM w/ Switch
Packs)
B6.7 - DLB - Remote Power Modules (2 RPM w/ Switch Packs) Design 607
B6.7 - DLB - Remote Power Modules (3 RPM w/ Swtich
Packs)
B6.7 - DLB - Remote Power Modules (3 RPM w/ Swtich Packs) Design 611
B6.7 - DLB - Remote Power Module (3 RPM n/Switch
Pack)
B6.7 - DLB - Remote Power Module (3 RPM n/Switch Pack) Design 612
L9 - DLB - Remote Power Modules (1 RPM n/ Switch
Packs)
L9 - DLB - Remote Power Modules (1 RPM n/ Switch Packs) Design 613
L9 - DLB - Remote Power Modules (1 RPM w/ Switch
Packs)
L9 - DLB - Remote Power Modules (1 RPM w/ Switch Packs) Design 616
L9 - DLB - Remote Power Modules (2 RPM n/ Switch
Pack)
L9 - DLB - Remote Power Modules (2 RPM n/ Switch Pack) Design 619
xixL9 - DLB - Remote Power Modules (2 RPM w/ Switch
Packs)
L9 - DLB - Remote Power Modules (2 RPM w/ Switch Packs) Design 623
L9 - DLB - Remote Power Modules (3 RPM w/ Swtich
Packs)
L9 - DLB - Remote Power Modules (3 RPM w/ Swtich Packs) Design 627
L9 - DLB - Remote Power Module (3 RPM n/Switch
Pack)
L9 - DLB - Remote Power Module (3 RPM n/Switch Pack) Design 628
A26 - Remote Start/Stop
A26 - Remote Start/Stop Design 629
B6.7 - Remote Start/Stop
B6.7 - Remote Start/Stop Design 630
B6.7 - Remote Start/Stop w/ Emergency Pump
B6.7 - Remote Start/Stop w/ Emergency Pump Design 631
L9 - Remote Start/Stop
L9 - Remote Start/Stop Design 632
L9 - Remote Start/Stop w/ Emergency Pump
L9 - Remote Start/Stop w/ Emergency Pump Design 633
A26 -Transmissions Electrical I/O (Eaton Ultrashift)
A26 -Transmissions Electrical I/O (Eaton Ultrashift) Design 634
A26 - Transmission I/O (Allison 3K with Body Builder)
A26 - Transmission I/O (Allison 3K with Body Builder) Design 635
A26 - Transmission I/O (Allison 4K with Body Builder)
A26 - Transmission I/O (Allison 4K with Body Builder) Design 638
A26 - Transmission I/O (Allison 4700 with Body
Builder)
A26 - Transmission I/O (Allison 4700 with Body Builder) Design 641
B6.7 - Transmission I/O (Allison Gen 6 1K/2K W/ Body
Builder)
B6.7 - Transmission I/O (Allison Gen 6 1K/2K W/ Body Builder) Design 644
B6.7 - Transmission I/O (Allison Gen 6 3K W/ Body
Builder)
B6.7 - Transmission I/O (Allison Gen 6 3K W/ Body Builder) Design 648
L9 - Transmission I/O (Allison Gen 6 4K W/ Body
Builder)
L9 - Transmission I/O (Allison Gen 6 4K W/ Body Builder) Design 654
L9 - Transmission I/O (Allison Gen 6 4700 W/ Body
Builder)
L9 - Transmission I/O (Allison Gen 6 4700 W/ Body Builder) Design 663
L9 - Transmission I/O (Allison 3K with Body Builder) -
13WUC
L9 - Transmission I/O (Allison 3K with Body Builder) - 13WUC Design 672
xxL9 - Transmission I/O (Allison 4700 W/ Body Builder)
L9 - Transmission I/O (Allison 4700 W/ Body Builder) Design 673
A26 - Transmission Power Take Off (Active Low
Feedback)
A26 - Transmission Power Take Off (Active Low Feedback) Design 682
A26 - Transmission Power Take Off (Dual PTO W/ 42
Parameters & W/ Auto, AMT Trans)
A26 - Transmission Power Take Off (Dual PTO W/ 42 Parameters & W/ Auto,
AMT Trans) Design 683
Parameters & W/ Manual Trans)
A26 - Transmission Power Take Off (Dual PTO W/ 42 Parameters & W/ Manual
Trans) Design 684
A26 - Transmission Power Take Off (Single PTO W/42
A26 - Transmission Power Take Off (Single PTO W/42 Parameters & W/ Auto,
AMT Trans) Design 685
Parameters & W/ Auto, AMT Trans)(Option2)
AMT Trans)(Option2) Design 686
RPM W/AUTO TRANS,AMT)
A26 - Transmission Power Take Off (Single PTO W/ RPM W/AUTO TRANS,AMT)
Design 687
RPM W/AUTO TRANS,AMT)(Option2)
TRANS,AMT)(Option2) Design 688
RPM & W/ MANL TRANS)
A26 - Transmission Power Take Off (Single PTO W/ RPM & W/ MANL TRANS)
Design 689
A26 - Transmission Power Take Off (Single PTO W/ 42
Parameters & W/ Manl Trans)
A26 - Transmission Power Take Off (Single PTO W/ 42 Parameters & W/ Manl
Trans) Design 690
A26 - Transmission Power Take Off (XFER PTO
W/Auto Trans )
A26 - Transmission Power Take Off (XFER PTO W/Auto Trans ) Design 691
W/Auto Trans )(Option2)
A26 - Transmission Power Take Off (XFER PTO W/Auto Trans )(Option2)
Design 692
Manual Trans )
xxiA26 - Transmission Power Take Off (XFER PTO W/ Manual Trans ) Design 693
A26 - Transmission Power Take Off (60AKG)
A26 - Transmission Power Take Off (60AKG) Design 694
B6.7 - Transmission Power Take Off 60AKG
B6.7 - Transmission Power Take Off 60AKG Design 695
B6.7 - Transmission Power Take Off (Auto Trans
Single PTO w/21 Parameters)
B6.7 - Transmission Power Take Off (Auto Trans Single PTO w/21 Parameters)
Design 696
B6.7 - Transmission Power Take Off (Manual Trans
B6.7 - Transmission Power Take Off (Manual Trans Single PTO w/21
Parameters) Design 697
B6.7 - Transmission Power Take Off (Single Input
configurable pull up or pull down)
B6.7 - Transmission Power Take Off (Single Input configurable pull up or pull
down) Design 698
L9 - Transmission Power Take Off (Auto Trans Single
L9 - Transmission Power Take Off (Auto Trans Single PTO w/21 Parameters)
Design 699
L9 - Transmission Power Take Off (Auto Trans with
Lectradrive)
L9 - Transmission Power Take Off (Auto Trans with Lectradrive) Design 700
L9 - Transmission Power Take Off (Lectrashift PTO
with Manual Trans)
L9 - Transmission Power Take Off (Lectrashift PTO with Manual Trans)
Design 701
L9 - Transmission Power Take Off (Manual Trans
L9 - Transmission Power Take Off (Manual Trans Single PTO w/21 Parameters)
Design 702
L9 - Transmission Power Take Off (Single Input
L9 - Transmission Power Take Off (Single Input configurable pull up or pull down)
Design 703
L9 - Transmission Power Take Off (Single PTO W/
RPM and Auto Trans)
L9 - Transmission Power Take Off (Single PTO W/ RPM and Auto Trans)
Design 704
RPM and Manual Trans)
L9 - Transmission Power Take Off (Single PTO W/ RPM and Manual Trans)
Design 705
xxiiB6.7 - Brake Switch
B6.7 - Brake Switch Design 706
L9 - Brake Switch
L9 - Brake Switch Design 707
A26 - Service Brake Switch (Multiple Service Brake
Switch W/ Redundant Switch)
A26 - Service Brake Switch (Multiple Service Brake Switch W/ Redundant Switch)
Design 708
A26 - Service Brake Switch(Multiple Brake Switch
N/Redundant Brake Switch)
A26 - Service Brake Switch(Multiple Brake Switch N/Redundant Brake Switch)
Design 709
A26 - Rightside Air Dryer
A26 - Rightside Air Dryer Design 710
A26/B6.7/L9 - Air Dryer (Single)
A26/B6.7/L9 - Air Dryer (Single) Design 721
B6.7 - RIGHTSIDE AIR DRYER
B6.7 - RIGHTSIDE AIR DRYER Design 736
L9 - RIGHTSIDE AIR DRYER
L9 - RIGHTSIDE AIR DRYER Design 742
A26 - Drain Valve Heater
A26 - Drain Valve Heater Design 753
B6.7 - Drain Valve Heater
B6.7 - Drain Valve Heater Design 763
L9 - Drain Valve Heater
L9 - Drain Valve Heater Design 770
A26 - Antilock Brake System (ABS) Bendix
A26 - Antilock Brake System (ABS) Bendix Design 779
A26 - Antilock Brake System (ABS)-Wabco 4 Channel
Implementation
A26 - Antilock Brake System (ABS)-Wabco 4 Channel Implementation Design 782
B6.7 - Antilock Brake System (ABS) BENDIX 4
Channel Implemenation
B6.7 - Antilock Brake System (ABS) BENDIX 4 Channel Implemenation
Design 783
L9 - Antilock Brake System (ABS) BENDIX 4 Channel
Implemenation
L9 - Antilock Brake System (ABS) BENDIX 4 Channel Implemenation Design 786
L9 - Antilock Brake System (ABS) Bendix 6 Channel
Implementation
L9 - Antilock Brake System (ABS) Bendix 6 Channel Implementation Design 787
L9 - Antilock Brake System (ABS) Wabco 4 Channel
Implementation
L9 - Antilock Brake System (ABS) Wabco 4 Channel Implementation Design 796
xxiiiA26 - Park Brake Control (Monitoring)(GEN IV BCM)
A26 - Park Brake Control (Monitoring)(GEN IV BCM) Design 797
A26/B6.7/L9 - Park Brake Controls (Air Chassis Park
Brake)
A26/B6.7/L9 - Park Brake Controls (Air Chassis Park Brake) Design 798
A26/B6.7/L9 - Park Brake Controls (Straight Truck)
Intellipark
A26/B6.7/L9 - Park Brake Controls (Straight Truck) Intellipark Design 799
A26/B6.7/L9 - Park Brake Controls (Tractor) Intellipark
A26/B6.7/L9 - Park Brake Controls (Tractor) Intellipark Design 800
B6.7 - Park Brake Controls (Monitoring) (Door Switch
City Horn)
B6.7 - Park Brake Controls (Monitoring) (Door Switch City Horn) Design 802
L9 - Park Brake Controls (Monitoring) (Door Switch
City Horn)
L9 - Park Brake Controls (Monitoring) (Door Switch City Horn) Design 803
L9 - Park Brake Control (Monitoring)(GEN IV BCM)
L9 - Park Brake Control (Monitoring)(GEN IV BCM) Design 804
A26 - Bendix Tractor or Towing Truck N/ Air SUSP
J1939 Driven Lamp
A26 - Bendix Tractor or Towing Truck N/ Air SUSP J1939 Driven Lamp
Design 805
A26 - Bendix Tractor or Towing Truck W/ Air SUSP
J1939 Driven Lamp
A26 - Bendix Tractor or Towing Truck W/ Air SUSP J1939 Driven Lamp
Design 809
A26 - Stability Control (Bendix Straight Truck J1939
Driven Lamp)
A26 - Stability Control (Bendix Straight Truck J1939 Driven Lamp) Design 813
B6.7 - Stability Control (Bendix Straight Truck J1939
Driven Lamp)
B6.7 - Stability Control (Bendix Straight Truck J1939 Driven Lamp) Design 817
L9 - Bendix Tractor or Towing Truck W/ Air SUSP
J1939 Driven Lamp
L9 - Bendix Tractor or Towing Truck W/ Air SUSP J1939 Driven Lamp Design 821
L9 - Stability Control (Bendix Straight Truck J1939
Driven Lamp)
L9 - Stability Control (Bendix Straight Truck J1939 Driven Lamp) Design 823
A26 - Traction Control (Bendix)
A26 - Traction Control (Bendix) Design 827
B6.7 - Traction Control (Bendix)
B6.7 - Traction Control (Bendix) Design 829
L9 - Traction Control (Bendix)
L9 - Traction Control (Bendix) Design 831
xxivA26/B6.7/L9 - Adaptive Cruise Control (Bendix -
Fusion 2.0 N/ Safety Direct Conn & W/ Reg Speakers)
A26/B6.7/L9 - Adaptive Cruise Control (Bendix - Fusion 2.0 N/ Safety Direct Conn
& W/ Reg Speakers) Design 832
Fusion 2.0 & N/ Safety Direct & Reg Speakers)
A26/B6.7/L9 - Adaptive Cruise Control (Bendix - Fusion 2.0 & N/ Safety Direct &
Reg Speakers) Design 834
A26/B6.7/L9 - A26 - Adaptive Cruise Control w/o
Display (Bendix)
A26/B6.7/L9 - A26 - Adaptive Cruise Control w/o Display (Bendix) Design 835
B6.7/L9 - Oncoming Detection (Fusion 3.0)
B6.7/L9 - Oncoming Detection (Fusion 3.0) Design 836
A26/B6.7/L9 - Camera Event Recorder N/Safety Direct
Cable
A26/B6.7/L9 - Camera Event Recorder N/Safety Direct Cable Design 837
A26 - Air Filter Flow Restriction Monitoring
A26 - Air Filter Flow Restriction Monitoring Design 838
A26/B6.7/L9 - Engine Block Heater
A26/B6.7/L9 - Engine Block Heater Design 839
A26/B6.7/L9 - Engine Fuel and Block Heaters
(Purchased Assembly)
A26/B6.7/L9 - Engine Fuel and Block Heaters (Purchased Assembly) Design 840
A26/B6.7/L9 - Engine Oil and Block Heaters
A26/B6.7/L9 - Engine Oil and Block Heaters (Purchased Assembly) Design 841
A26/B6.7/L9 - Engine Oil Fuel and Block Heaters
A26/B6.7/L9 - Engine Oil Fuel and Block Heaters Design 842
A26 - Engine Brake Mux Switch
A26 - Engine Brake Mux Switch Design 843
A26 - Engine Brake W/ Stalk Shifter
A26 - Engine Brake W/ Stalk Shifter Design 844
B6.7/L9 - Engine Brake Mux Switch
B6.7/L9 - Engine Brake Mux Switch Design 845
B6.7/L9 - Engine Brake W/ Stalk Shifter
B6.7/L9 - Engine Brake W/ Stalk Shifter Design 846
A26 - Coolant Level Monitoring (No CLA Module)
A26 - Coolant Level Monitoring (No CLA Module) Design 847
B6.7 - Coolant Level Monitoring (No CLA Module)
B6.7 - Coolant Level Monitoring (No CLA Module) Design 848
(2024 & Newer Models)
xxvB6.7 - Coolant Level Monitoring (No CLA Module) (2024 & Newer Models)
Design 849
B6.7 - Coolant Level Monitoring (No Coolant Module)
B6.7 - Coolant Level Monitoring (No Coolant Module) Design 850
L9 - Coolant Level Monitoring (No CLA Module)
L9 - Coolant Level Monitoring (No CLA Module) Design 851
L9 - Coolant Level Monitoring (No CLA Module) (2024
& Newer Models)
L9 - Coolant Level Monitoring (No CLA Module) (2024 & Newer Models)
Design 852
L9 - Coolant Level Monitoring (No Coolant Module)
L9 - Coolant Level Monitoring (No Coolant Module) Design 853
B6.7 - Coolant Level Monitoring (With Coolant Module)
B6.7 - Coolant Level Monitoring (With Coolant Module) Design 854
L9 - Coolant Level Monitoring (With Coolant Module)
L9 - Coolant Level Monitoring (With Coolant Module) Design 855
A26 - Cooling Fan Control (Fan Override,
International)
A26 - Cooling Fan Control (Fan Override, International) Design 856
A26 - Cooling Fan Control (No Fan Override,
International)
A26 - Cooling Fan Control (No Fan Override, International) Design 857
A26 _ Cooling Fan Control (Fan Override,
International)
A26 _ Cooling Fan Control (Fan Override, International) Design 858
B6.7 - Cooling Fan Control (Fan Override, Cummins)
B6.7 - Cooling Fan Control (Fan Override, Cummins) Design 859
B6.7 - Cooling Fan Control (Fan Override, Cummins):
B6.7 - Cooling Fan Control (Fan Override, Cummins):2024 and newer models
Design 860
B6.7 - Cooling Fan Control (No Fan Override,
Cummins)
B6.7 - Cooling Fan Control (No Fan Override, Cummins) Design 861
Cummins): 2024 and newer models
B6.7 - Cooling Fan Control (No Fan Override, Cummins):2024 and newer models
Design 862
L9 - Cooling Fan Control (Fan Override, Cummins)
L9 - Cooling Fan Control (Fan Override, Cummins) Design 863
L9 - Cooling Fan Control (Fan Override, Cummins):
L9 - Cooling Fan Control (Fan Override, Cummins):2024 and newer models
Design 864
xxviL9 - Cooling Fan Control (No Fan Override, Cummins)
L9 - Cooling Fan Control (No Fan Override, Cummins) Design 865
L9 - Cooling Fan Control (No Fan Override, Cummins):
L9 - Cooling Fan Control (No Fan Override, Cummins):2024 and newer models
Design 866
A26 - Engine Ramp Up (60AJA W/ A26 Engine W/
Automatic Transmission, AMT)
A26 - Engine Ramp Up (60AJA W/ A26 Engine W/ Automatic Transmission, AMT)
Design 867
A26 - Engine Ramp Up (60AJA W/ Cummins W/
AUTO,AMT)
A26 - Engine Ramp Up (60AJA W/ Cummins W/ AUTO,AMT) Design 868
A26 - Engine Ramp Up (60AJE,60AJJ W/A26 W/
AUTO,AMT)
A26 - Engine Ramp Up (60AJE,60AJJ W/A26 W/ AUTO,AMT) Design 869
A26 - Engine Ramp Up (60AJE,60AJJ W/ CUMMINS W/
AUTO, AMT)
A26 - Engine Ramp Up (60AJE,60AJJ W/ CUMMINS W/ AUTO, AMT) Design 870
A26 - Engine Ramp Up (60AJG W/A26 W/ AUTO OR
AMT)
A26 - Engine Ramp Up (60AJG W/A26 W/ AUTO OR AMT) Design 871
A26 - Engine Ramp Up (60AJG W/CUMMINS W/ AUTO,
AMT)
A26 - Engine Ramp Up (60AJG W/CUMMINS W/ AUTO, AMT) Design 872
A26 - Engine Ramp Up (60AJH W/ AUTO,AMT)
A26 - Engine Ramp Up (60AJH W/ AUTO,AMT) Design 873
B6.7/L9 - Engine Ramp UP (60AJA W/Cummins W/
Manual Trans)
B6.7/L9 - Engine Ramp UP (60AJA W/Cummins W/ Manual Trans) Design 874
B6.7/L9 - ENGINE RAMP UP (60AJE,60AJJ W/
CUMMINS W/ MANUAL)
B6.7/L9 - ENGINE RAMP UP (60AJE,60AJJ W/ CUMMINS W/ MANUAL)
Design 875
B6.7/L9 - ENGINE RAMP UP (60AJG W/CUMMINS W/
MANUAL)
B6.7/L9 - ENGINE RAMP UP (60AJG W/CUMMINS W/ MANUAL) Design 876
A26 - Exhaust Brake
A26 - Exhaust Brake Design 877
B6.7/L9 - Exhaust Brake (Cummins)
B6.7/L9 - Exhaust Brake (Cummins) Design 878
A26 - Snow Valve Control
A26 - Snow Valve Control Design 879
xxviiA26/B6.7/L9 - Snow Valve Control
A26/B6.7/L9 - Snow Valve Control Design 881
B6.7 - Snow Valve Control
B6.7 - Snow Valve Control Design 882
L9 - Snow Valve Control Design 884
A26 - Starting Aid (Flame Start W/MD1 ECM)
A26 - Starting Aid (Flame Start W/MD1 ECM) Design 886
B6.7 - Starting Aid (Grid Heater)
B6.7 - Starting Aid (Grid Heater) Design 887
B6.7 - Starting Aid (Grid Heater) - 2024 and Newer
Models
B6.7 - Starting Aid (Grid Heater) - 2024 and Newer Models Design 888
L9 - Starting Aid (Grid Heater)
L9 - Starting Aid (Grid Heater) Design 889
L9 - Starting Aid (Grid Heater) - 2024 and Newer
Models
L9 - Starting Aid (Grid Heater) - 2024 and Newer Models Design 890
A26- Vehicle Acceleration (Wired to the ECM)
A26- Vehicle Acceleration (Wired to the ECM) Design 892
B6.7 - Vehicle Acceleration (w/ Two PWR Two GND &
Two STS)
B6.7 - Vehicle Acceleration (w/ Two PWR Two GND & Two STS) Design 893
L9 - Vehicle Acceleration (w/ Two PWR Two GND &
Two STS)
L9 - Vehicle Acceleration (w/ Two PWR Two GND & Two STS) Design 894
A26 - Engine Electrical I/O (24-Pin/3-Pin Vehicle
Interface Connector)
A26 - Engine Electrical I/O (24-Pin/3-Pin Vehicle Interface Connector) Design 895
A26/B6.7/L9 - Alternate Flashing (Wig Wag) - Park
Brake disables High Beams
A26/B6.7/L9 - Alternate Flashing (Wig Wag) - Park Brake disables High Beams
Design 897
Brake disables Wig Wag
A26/B6.7/L9 - Alternate Flashing (Wig Wag) - Park Brake disables Wig Wag
Design 898
A26/B6.7/L9 - Automatic Lighting - Dual Sensor
Twilight/Solar
A26/B6.7/L9 - Automatic Lighting - Dual Sensor Twilight/Solar Design 899
A26/B6.7/L9 - Automatic Lighting - Single Sensor
Twilight
A26/B6.7/L9 - Automatic Lighting - Single Sensor Twilight Design 901
xxviiiA26 - Backup Lights (Dual Daisy Reverse Light)
Eaton/Manual Trans
A26 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans Design 903
Eaton/Manual Trans -
A26 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans - Design 904
A26 - Backup Lights (Dual Daisy with extension)
Eaton/Manual Trans
A26 - Backup Lights (Dual Daisy with extension) Eaton/Manual Trans Design 905
Eaton/Manual TransA26 - Backup Lights (Dual Daisy with extension) Eaton/Manual Trans- Design 906
A26 - Backup Lights (Dual Reverse Light)
Eaton/Manual Trans
A26 - Backup Lights (Dual Reverse Light) Eaton/Manual Trans Design 907
A26 - Backup Light (Dual Daisy Reverse LT)Allison/ZF
Trans
A26 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans Design 908
TransA26 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans- Design 909
A26 - Backup Light (Dual Daisy Reverse LT) Yukon
AMT
A26 - Backup Light (Dual Daisy Reverse LT) Yukon AMT Design 911
A26 - Backup Light (Dual Daisy with
extension)Allison/ZF Trans
A26 - Backup Light (Dual Daisy with extension)Allison/ZF Trans Design 912
extension)Allison/ZF TransA26 - Backup Light (Dual Daisy with extension)Allison/ZF Trans- Design 913
A26 - Backup Light (Dual Daisy with extension)(HV,
HX) Yukon AMT
A26 - Backup Light (Dual Daisy with extension)(HV, HX) Yukon AMT Design 914
A26 - Backup Light (Dual Reverse Light with
extension) (HV) Yukon AMT
A26 - Backup Light (Dual Reverse Light with extension) (HV) Yukon AMT
Design 915
A26 - Backup Light (Dual Reverse Light)Allison/ZF
Trans
A26 - Backup Light (Dual Reverse Light)Allison/ZF Trans Design 916
A26 - Backup Light (Dual Reverse Light) (HV) Yukon
AMT
A26 - Backup Light (Dual Reverse Light) (HV) Yukon AMT Design 917
xxixA26/B6.7/L9 - Backup Light (Dual Daisy with
extension) Yukon AMT
A26/B6.7/L9 - Backup Light (Dual Daisy with extension) Yukon AMT Design 918
B6.7 - Backup Lights (Dual Daisy Reverse Light)
Eaton/Manual Trans
B6.7 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans Design 919
Eaton/Manual TransB6.7 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans- Design 920
B6.7 - Backup Lights (Dual Daisy with extension)
Eaton/Manual Trans
B6.7 - Backup Lights (Dual Daisy with extension) Eaton/Manual Trans Design 921
B6.7 - Backup Lights (Dual Reverse Light)
Eaton/Manual Trans
B6.7 - Backup Lights (Dual Reverse Light) Eaton/Manual Trans Design 922
B6.7 - Backup Light (Dual Daisy Reverse LT)Allison/ZF
Trans
B6.7 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans Design 923
Trans 1K/2K
B6.7 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans 1K/2K Design 925
Trans 3K/4K
B6.7 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans 3K/4K Design 926
B6.7 - Backup Light (Dual Daisy with
B6.7 - Backup Light (Dual Daisy with extension)Allison/ZF Trans Design 928
B6.7 - Backup Light (Dual Reverse Light)Allison/ZF
Trans 1K/2K
B6.7 - Backup Light (Dual Reverse Light)Allison/ZF Trans 1K/2K Design 929
Trans 3K/4K
B6.7 - Backup Light (Dual Reverse Light)Allison/ZF Trans 3K/4K Design 930
L9 - Backup Lights (Dual Daisy Reverse Light)
Eaton/Manual Trans
L9 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans Design 932
Eaton/Manual TransL9 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans- Design 934
L9 - Backup Lights (Dual Daisy with extension)
Eaton/Manual Trans
L9 - Backup Lights (Dual Daisy with extension) Eaton/Manual Trans Design 935
xxxL9 - Backup Lights (Dual Reverse Light) Eaton/Manual
Trans
L9 - Backup Lights (Dual Reverse Light) Eaton/Manual Trans Design 936
L9 - Backup Light (Dual Daisy Reverse
L9 - Backup Light (Dual Daisy Reverse Light)Allison/ZF Trans 3K/4K Design 938
L9 - Backup Light (Dual Daisy Reverse LT)Allison/ZF
Trans
L9 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans Design 940
L9 - Backup Light (Dual Daisy with extension)Allison/ZF Trans Design 942
A26 - Backup Lights (Reverse Lights) (Crossmember
Dual STT N/Back Up) Allison Trans
A26 - Backup Lights (Reverse Lights) (Crossmember Dual STT N/Back Up)
Allison Trans Design 943
Dual STT N/Back Up) Eaton/Manual Trans
Eaton/Manual Trans Design 944
Dual STT N/Back Up) Endurant/EndurantXD Trans
Endurant/EndurantXD Trans Design 945
A26 - Backup Lights (Single Reverse Lights)
Eaton/Manual Trans
A26 - Backup Lights (Single Reverse Lights) Eaton/Manual Trans Design 946
Eaton/Manual Transmission
A26 - Backup Lights (Single Reverse Lights) Eaton/Manual Transmission
Design 947
A26 - Backup Light (Single Reverse Light)Allison
A26 - Backup Light (Single Reverse Light)Allison Design 948
A26 - Backup Light (Single Reverse Light) W/Less
Power Module W/ Allison
A26 - Backup Light (Single Reverse Light) W/Less Power Module W/ Allison
Design 949
Power Module W/ AllisonA26 - Backup Light (Single Reverse Light) W/Less Power Module W/ AllisonDesign 950
A26 - Backup Light (Single Reverse Light) (HV)
W/Less Power Module W/Yukon AMT
A26 - Backup Light (Single Reverse Light) (HV) W/Less Power Module W/Yukon
AMT Design 951
xxxiA26 - Backup Light (Single Reverse Light) (HV) Yukon
AMT (Option 1)
A26 - Backup Light (Single Reverse Light) (HV) Yukon AMT (Option 1) Design952
AMT (Option 2)
A26 - Backup Light (Single Reverse Light) (HV) Yukon AMT (Option 2) Design953
A26 - Back Up Lights (Reverse) W/ Less Power
Module W/Eaton/ Manual
A26 - Back Up Lights (Reverse) W/ Less Power Module W/Eaton/ Manual
Design 954
Module W/Eaton/ ManualA26 - Back Up Lights (Reverse) W/ Less Power Module W/Eaton/ ManualDesign 955
A26/B6.7/L9 - Backup Lights (Reverse Lights)
A26/B6.7/L9 - Backup Lights (Reverse Lights) (Crossmember Dual STT N/Back
Up) Endurant/EndurantXD Trans Design 956
A26/B6.7/L9 - Backup Light (Single Reverse Light)
A26/B6.7/L9 - Backup Light (Single Reverse Light) W/Less Power Module
W/Yukon AMT Design 957
B6.7 - Backup Lights (Reverse Lights) (Crossmember
B6.7 - Backup Lights (Reverse Lights) (Crossmember Dual STT N/Back Up)
Allison Trans Design 958
Eaton/Manual Trans Design 959
B6.7 - Backup Lights (Single Reverse Lights)
Eaton/Manual Trans Option 1
B6.7 - Backup Lights (Single Reverse Lights) Eaton/Manual Trans Option 1
Design 960
Eaton/Manual Trans Option 2
B6.7 - Backup Lights (Single Reverse Lights) Eaton/Manual Trans Option 2
Design 961
B6.7 - Backup Lights (Single Reverse Light)
Eaton/Manual Trans
B6.7 - Backup Lights (Single Reverse Light) Eaton/Manual Trans Design 962
B6.7 - Backup Light (Single Reverse Light) Allison
1K/2K Option 1
B6.7 - Backup Light (Single Reverse Light) Allison 1K/2K Option 1 Design 963
xxxiiB6.7 - Backup Light (Single Reverse Light) Allison
1K/2K Option 2
B6.7 - Backup Light (Single Reverse Light) Allison 1K/2K Option 2 Design 964
1K/2K Option 3
B6.7 - Backup Light (Single Reverse Light) Allison 1K/2K Option 3 Design 965
3K/4K Option 1
B6.7 - Backup Light (Single Reverse Light) Allison 3K/4K Option 1 Design 966
3K/4K Option 2
B6.7 - Backup Light (Single Reverse Light) Allison 3K/4K Option 2 Design 968
3K/4K Option 3
B6.7 - Backup Light (Single Reverse Light) Allison 3K/4K Option 3 Design 970
B6.7 - Backup Light (Single Reverse Light) W/Less
B6.7 - Backup Light (Single Reverse Light) W/Less Power Module W/ Allison
Design 972
B6.7 - Back Up Lights (Reverse) W/ Less Power
B6.7 - Back Up Lights (Reverse) W/ Less Power Module W/Eaton/ Manual
Design 973
L9 - Backup Lights (Reverse Lights) (Crossmember Dual STT N/Back Up) Allison
Trans Design 974
Eaton/Manual Trans Design 975
L9 - Backup Lights (Single Reverse Light)
L9 - Backup Lights (Single Reverse Light) Eaton/Manual Trans Option 1
Design 976
L9 - Backup Lights (Single Reverse Light) Eaton/Manual Trans Option 2
Design 978
Eaton/Manual Trans Option 3
L9 - Backup Lights (Single Reverse Light) Eaton/Manual Trans Option 3
Design 980
Eaton/Manual Trans Option 4
L9 - Backup Lights (Single Reverse Light) Eaton/Manual Trans Option 4
Design 982
xxxiiiL9 - Backup Light (Single Reverse Light)Allison
L9 - Backup Light (Single Reverse Light)Allison Design 984
L9 - Backup Light (Single Reverse Light) Allison
3K/4K Option 1
L9 - Backup Light (Single Reverse Light) Allison 3K/4K Option 1 Design 986
3K/4K Option 2
L9 - Backup Light (Single Reverse Light) Allison 3K/4K Option 2 Design 988
3K/4K Option 3
L9 - Backup Light (Single Reverse Light) Allison 3K/4K Option 3 Design 990
L9 - Backup Light (Single Reverse Light) W/Less Power Module W/ Allison
Design 992
L9 - Back Up Lights (Reverse) W/ Less Power Module
W/Eaton/ Manual
L9 - Back Up Lights (Reverse) W/ Less Power Module W/Eaton/ Manual
Design 993
A26 - Rear Lights Stop - Daisy Chain
A26 - Rear Lights Stop - Daisy Chain Design 994
A26 - Rear Lights Stop - Dual Assembly
A26 - Rear Lights Stop - Dual Assembly Design 995
A26 - Rear Lights Stop - Single Assemby
A26 - Rear Lights Stop - Single Assemby Design 996
A26 - Rear Lights Stop - Single Assemby Jumper
Harness W/08TKC, 08THM
A26 - Rear Lights Stop - Single Assemby Jumper Harness W/08TKC, 08THM
Design 997
A26 - Rear Lights Stop - Single Assemby W/08TKJ
A26 - Rear Lights Stop - Single Assemby W/08TKJ Design 998
A26 - Separate Rear Lights (Stop) W/08TVH
A26 - Separate Rear Lights (Stop) W/08TVH Design 999
A26/B6.7/L9 - Rear Lights Stop - Single Assembly
jumper harness
A26/B6.7/L9 - Rear Lights Stop - Single Assembly jumper harness Design 1000
A26/B6.7/L9 - Rear Lights (Stop) (Daisy Chain N/
Extension Harness)
A26/B6.7/L9 - Rear Lights (Stop) (Daisy Chain N/ Extension Harness)
Design 1001
A26/B6.7/L9 - Rear Lights (Stop) (Daisy Chain W/
Extension Harness)
A26/B6.7/L9 - Rear Lights (Stop) (Daisy Chain W/ Extension Harness)
Design 1002
xxxivA26/B6.7/L9 - Rear Light (Stop) Crossmember Dual
STT N/Back-Up
A26/B6.7/L9 - Rear Light (Stop) Crossmember Dual STT N/Back-Up Design 1003
B6.7 - Rear Lights Stop - Daisy Chain
B6.7 - Rear Lights Stop - Daisy Chain Design 1004
B6.7 - Rear Lights Stop - Dual Assembly
B6.7 - Rear Lights Stop - Dual Assembly Design 1005
B6.7 - Rear Lights Stop - Single Assemby
B6.7 - Rear Lights Stop - Single Assemby Design 1006
L9 - Rear Lights Stop - Daisy Chain
L9 - Rear Lights Stop - Daisy Chain Design 1007
L9 - Rear Lights Stop - Dual Assembly
L9 - Rear Lights Stop - Dual Assembly Design 1008
L9 - Rear Lights Stop - Single Assemby
L9 - Rear Lights Stop - Single Assemby Design 1009
A26/B6.7/L9 - Clearance and Identification Lights
A26/B6.7/L9 - Clearance and Identification Lights Design 1010
A26/B6.7/L9 - Daytime Running Lights N/CAN
Headlamps
A26/B6.7/L9 - Daytime Running Lights N/CAN Headlamps Design 1011
A26/B6.7/L9 - Daytime Running Lights (Output to Plow
Lights)
A26/B6.7/L9 - Daytime Running Lights (Output to Plow Lights) Design 1012
A26 - Directional Signal (Turn) W/ Daisy Chain Box
Lamps
A26 - Directional Signal (Turn) W/ Daisy Chain Box Lamps Design 1013
A26 - Directional Signal (Turn) W/ LED BOX LAMPS
A26 - Directional Signal (Turn) W/ LED BOX LAMPS Design 1014
A26 - Directional Signal (Turn) W/ Less Power Module
Tail Board, W/Hazard SW
A26 - Directional Signal (Turn) W/ Less Power Module Tail Board, W/Hazard SW
Design 1015
A26 - Directional Signal (Turn) W/ Single Tail Board
W/Hazard SW
A26 - Directional Signal (Turn) W/ Single Tail Board W/Hazard SW Design 1016
A26/B6.7/L9 - Directional Signal (Turn) W/ Daisy Chain
Box Lamps
A26/B6.7/L9 - Directional Signal (Turn) W/ Daisy Chain Box Lamps Design 1017
A26/B6.7/L9 - Directional Signal (Turn) W/ Less Power
Module Tail Board , W/Hazard SW
A26/B6.7/L9 - Directional Signal (Turn) W/ Less Power Module Tail Board ,
W/Hazard SW Design 1018
xxxvB6.7 - Directional Signal (Turn) W/ DAISY CHAIN BOX
LAMPS
B6.7 - Directional Signal (Turn) W/ DAISY CHAIN BOX LAMPS Design 1019
B6.7 - Directional Signal (Turn) W/ LED BOX LAMPS
B6.7 - Directional Signal (Turn) W/ LED BOX LAMPS Design 1021
B6.7 - Directional Signal (Turn) W/ Less Power Module
B6.7 - Directional Signal (Turn) W/ Less Power Module Tail Board W/Hazard SW
Design 1023
B6.7 - Directional Signal (Turn) W/ Single Tail Board
W/Hazard SW
B6.7 - Directional Signal (Turn) W/ Single Tail Board W/Hazard SW Design 1025
L9 - Directional Signal (Turn) W/ DAISY CHAIN BOX
LAMPS
L9 - Directional Signal (Turn) W/ DAISY CHAIN BOX LAMPS Design 1027
L9 - Directional Signal (Turn) W/ Less Power Module Tail Board W/Hazard SW
Design 1029
L9 - Directional Signal (Turn) W/ Single Tail Board
W/Hazard SW
L9 - Directional Signal (Turn) W/ Single Tail Board W/Hazard SW Design 1031
Lamps, W/Plow Lights
A26 - Directional Signal (Turn) W/ Daisy Chain Box Lamps, W/Plow Lights
Design 1033
A26 - Directional Signal (Turn) W/ LED BOX LAMPS,
W/Plow Lights
A26 - Directional Signal (Turn) W/ LED BOX LAMPS, W/Plow Lights Design 1035
Tail Board, W/Hazard SW, W/Plow Lights
A26 - Directional Signal (Turn) W/ Less Power Module Tail Board, W/Hazard SW,
W/Plow Lights Design 1037
A26 - Directional Signal (Turn) W/ Single Tail Board,
A26 - Directional Signal (Turn) W/ Single Tail Board, W/Hazard SW, W/Plow
Lights Design 1039
A26/B6.7/L9 - Directional Signal (Turn) W/ Daisy Chain Box Lamps, W/Plow
Lights Design 1041
Module Tail Board , W/Hazard SW , W/PLOW LIGHTS
W/Hazard SW , W/PLOW LIGHTS Design 1043
xxxviB6.7 - Directional Signal (Turn) W/ Daisy Chain Box
Lamps W/Plow Lights
B6.7 - Directional Signal (Turn) W/ Daisy Chain Box Lamps W/Plow Lights
Design 1045
W/Plow Lights
B6.7 - Directional Signal (Turn) W/ LED BOX LAMPS W/Plow Lights Design 1049
Module Tail Board W/Hazard SW W/PLOW LIGHTS
W/PLOW LIGHTS Design 1053
W/Plow Lights
B6.7 - Directional Signal (Turn) W/ Single Tail Board W/Plow Lights Design 1057
Lamps W/Plow Lights
L9 - Directional Signal (Turn) W/ Daisy Chain Box Lamps W/Plow Lights
Design 1061
L9 - Directional Signal (Turn) W/ LED BOX LAMPS
L9 - Directional Signal (Turn) W/ LED BOX LAMPS Design 1065
W/Plow Lights
L9 - Directional Signal (Turn) W/ LED BOX LAMPS W/Plow Lights Design 1067
W/PLOW LIGHTS Design 1071
W/Plow Lights
L9 - Directional Signal (Turn) W/ Single Tail Board W/Plow Lights Design 1075
A26/B6.7/L9 - Exterior Lamp Check
A26/B6.7/L9 - Exterior Lamp Check Design 1079
A26/B6.7/L9 - Exterior Lamp Reminder
A26/B6.7/L9 - Exterior Lamp Reminder Design 1080
A26 - Front Fog Lamps LED
A26 - Front Fog Lamps LED Design 1081
A26 - Front Fog Lights W CONNECTOR Halogen
A26 - Front Fog Lights W CONNECTOR Halogen Design 1083
B6.7 - Fog Lights (Halogen White)
B6.7 - Fog Lights (Halogen White) Design 1085
B6.7 - Fog Lights (LED White)
B6.7 - Fog Lights (LED White) Design 1088
B6.7 - Front Fog Lamps
B6.7 - Front Fog Lamps Design 1091
xxxviiB6.7 - Front Fog Lights W CONNECTOR
B6.7 - Front Fog Lights W CONNECTOR Design 1094
L9 - Fog Lights (Halogen White)
L9 - Fog Lights (Halogen White) Design 1096
L9 - Fog Lights (LED White)
L9 - Fog Lights (LED White) Design 1098
L9 - Front Fog Lights W CONNECTOR
L9 - Front Fog Lights W CONNECTOR Design 1100
A26 - Front Marker Lights
A26 - Front Marker Lights Design 1102
A26 - Front Marker Lights W/Plow Lights
A26 - Front Marker Lights W/Plow Lights Design 1103
B6.7 - Front Marker Lights - Without Snow Plow Lights
B6.7 - Front Marker Lights - Without Snow Plow Lights Design 1105
B6.7 - Front Marker Lights - With Plow Lights
B6.7 - Front Marker Lights - With Plow Lights Design 1107
L9 - Front Marker Lights - Without Snow Plow Lights
L9 - Front Marker Lights - Without Snow Plow Lights Design 1111
L9 - Front Marker Lights - With Plow Lights
L9 - Front Marker Lights - With Plow Lights Design 1113
A26 - Hazard Warning Light N/Trlr Socket
A26 - Hazard Warning Light N/Trlr Socket Design 1117
L9 - Hazard Warning Light N/Trlr Socket
L9 - Hazard Warning Light N/Trlr Socket Design 1119
A26 - Headlights W/LOWW, W/O Interrupt
A26 - Headlights W/LOWW, W/O Interrupt Design 1121
A26 - Headlights W/O LOWW, W/O Interrupt
A26 - Headlights W/O LOWW, W/O Interrupt Design 1123
A26 - Headlights W/LOWW, W/Interrupt - 10 PIN CLK
A26 - Headlights W/LOWW, W/Interrupt - 10 PIN CLK Design 1125
A26 - Headlights W/O LOWW, W/Interrupt - 10 PIN CLK
A26 - Headlights W/O LOWW, W/Interrupt - 10 PIN CLK Design 1127
A26 - Headlight W/Plowlights, W/LOWW, W/O Interrupt
A26 - Headlight W/Plowlights, W/LOWW, W/O Interrupt Design 1129
A26 - Headlight W/Plowlights, W/O LOWW, W/O
Interrupt
A26 - Headlight W/Plowlights, W/O LOWW, W/O Interrupt Design 1133
A26 - Headlights W/PlowLights, W/LOWW, W/Interrupt
- 10 PIN CLK
A26 - Headlights W/PlowLights, W/LOWW, W/Interrupt - 10 PIN CLK Design 1137
xxxviiiA26 - Headlights W/PlowLights, W/O LOWW,
A26 - Headlights W/PlowLights, W/O LOWW, W/Interrupt - 10 PIN CLK
Design 1141
B6.7 - Headlights W/O Lights ON With Wipers (LOWW)
W/O Headlights Interrupt
B6.7 - Headlights W/O Lights ON With Wipers (LOWW) W/O Headlights Interrupt
Design 1145
B6.7 - Headlights W/O Lights ON with wipers (LOWW)
W/ Headlights Interrupt
B6.7 - Headlights W/O Lights ON with wipers (LOWW) W/ Headlights Interrupt
Design 1149
B6.7 - Headlights W 10PIN CLK W/LOWW W/O
Interrupt
B6.7 - Headlights W 10PIN CLK W/LOWW W/O Interrupt Design 1153
B6.7 - Headlights W 10PIN CLK W/LOWW W/Interrupt
B6.7 - Headlights W 10PIN CLK W/LOWW W/Interrupt Design 1157
B6.7 - Headlights W/Plowlights W/O Lights ON With
B6.7 - Headlights W/Plowlights W/O Lights ON With Wipers (LOWW) W/O
Headlights Interrupt Design 1161
B6.7 - Headlight W/Plowlights W/LOWW W/O
Headlight Interrupt -10 PIN CLK
B6.7 - Headlight W/Plowlights W/LOWW W/O Headlight Interrupt -10 PIN CLK
Design 1169
B6.7 - Headlights W/PlowLights W/Headlight Interrupt
-10PIN CLK W/LOWW W/Interrupt
B6.7 - Headlights W/PlowLights W/Headlight Interrupt -10PIN CLK W/LOWW
W/Interrupt Design 1177
B6.7 - Headlights W/PlowLights W/O Lights ON with
B6.7 - Headlights W/PlowLights W/O Lights ON with wipers (LOWW) W/
Headlights Interrupt Design 1185
L9 - Headlights W/O Lights ON With Wipers (LOWW)
L9 - Headlights W/O Lights ON With Wipers (LOWW) W/O Headlights Interrupt
Design 1193
L9 - Headlights W/O Lights ON with wipers (LOWW)
L9 - Headlights W/O Lights ON with wipers (LOWW) W/ Headlights Interrupt
Design 1197
L9 - Headlights W 10PIN CLK W/LOWW W/O Interrupt
L9 - Headlights W 10PIN CLK W/LOWW W/O Interrupt Design 1201
L9 - Headlights W 10PIN CLK W/LOWW W/Interrupt
L9 - Headlights W 10PIN CLK W/LOWW W/Interrupt Design 1205
xxxixL9 - Headlights W/Plowlights W/O Lights ON With
L9 - Headlights W/Plowlights W/O Lights ON With Wipers (LOWW) W/O
Headlights Interrupt Design 1209
L9 - Headlight W/Plowlights W/LOWW W/O Headlight
L9 - Headlight W/Plowlights W/LOWW W/O Headlight Interrupt -10 PIN CLK
Design 1217
L9 - Headlights W/PlowLights W/Headlight Interrupt -
L9 - Headlights W/PlowLights W/Headlight Interrupt -10PIN CLK W/LOWW
W/Interrupt Design 1225
L9 - Headlights W/PlowLights W/O Lights ON with
L9 - Headlights W/PlowLights W/O Lights ON with wipers (LOWW) W/ Headlights
Interrupt Design 1233
A26 - License Plate Light (LED BOX LAMP Daisy
Chain Tail Light)
A26 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light) Design 1241
A26 - License Plate Light (LED BOX LAMP Tail Light)
A26 - License Plate Light (LED BOX LAMP Tail Light) Design 1242
A26 - License Plate Light (Tail Light Single Assembly)
A26 - License Plate Light (Tail Light Single Assembly) Design 1243
Assembly)Option2
A26 - License Plate Light (Tail Light Single Assembly)Option2 Design 1244
Assembly)Option3
A26 - License Plate Light (Tail Light Single Assembly)Option3 Design 1245
A26 - License Plate Light (Tail Light Single Assy.)
W/Less Power Module (W/08TKC, 08THM)
A26 - License Plate Light (Tail Light Single Assy.) W/Less Power Module
(W/08TKC, 08THM) Design 1246
A26/B6.7/L9 - License Plate Light (Direct To Light)
A26/B6.7/L9 - License Plate Light (Direct To Light) Design 1247
A26/B6.7/L9 - License Plate Light (LED BOX LAMP
Daisy Chain Tail Light with extension)
A26/B6.7/L9 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light with
extension) Design 1248
A26/B6.7/L9 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light)
Design 1249
A26/B6.7/L9 - License Plate Light (Tail Light Single
xlA26/B6.7/L9 - License Plate Light (Tail Light Single Assy.) W/Less Power Module
Design 1250
B6.7 - License Plate Light (LED BOX LAMP Daisy
Chain Tail Light)
B6.7 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light) Design 1251
B6.7 - License Plate Light (LED BOX LAMP Tail Light)
B6.7 - License Plate Light (LED BOX LAMP Tail Light) Design 1252
B6.7 - License Plate Light (Tail Light Single Assy)
Option 1
B6.7 - License Plate Light (Tail Light Single Assy) Option 1 Design 1253
Option 2
B6.7 - License Plate Light (Tail Light Single Assy) Option 2 Design 1254
Option 3
B6.7 - License Plate Light (Tail Light Single Assy) Option 3 Design 1255
Option 4
B6.7 - License Plate Light (Tail Light Single Assy) Option 4 Design 1256
W/Less Power Module
B6.7 - License Plate Light (Tail Light Single Assy) W/Less Power Module
Design 1257
Tail Light)
L9 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light) Design 1258
L9 - License Plate Light (LED BOX LAMP Tail Light)
L9 - License Plate Light (LED BOX LAMP Tail Light) Design 1259
L9 - License Plate Light (Tail Light Single Assy)
Option 1
L9 - License Plate Light (Tail Light Single Assy) Option 1 Design 1260
Option 2
L9 - License Plate Light (Tail Light Single Assy) Option 2 Design 1261
Option 3
L9 - License Plate Light (Tail Light Single Assy) Option 3 Design 1262
Option 4
L9 - License Plate Light (Tail Light Single Assy) Option 4 Design 1263
A26/B6.7/L9 - PARK LIGHTS - N/Marker Interrupt
A26/B6.7/L9 - PARK LIGHTS - N/Marker Interrupt Design 1264
xliA26/B6.7/L9 - PARK LIGHTS - W/Marker Interrupt
10pin CLCKSPRING
A26/B6.7/L9 - PARK LIGHTS - W/Marker Interrupt 10pin CLCKSPRING
Design 1266
A26/B6.7/L9 - PARK LIGHTS - W/Marker Interrupt 4 pin
clockspring
A26/B6.7/L9 - PARK LIGHTS - W/Marker Interrupt 4 pin clockspring Design 1268
A26/B6.7/L9 - Snow Plow Lights
A26/B6.7/L9 - Snow Plow Lights Design 1270
A26 - Rear Light (LED BOX LAMP Tail Light) W/08TPS,
08TPR
A26 - Rear Light (LED BOX LAMP Tail Light) W/08TPS, 08TPR Design 1271
A26 - Rear Light (Tail Light) W/Less Power Module
(W/08TKC, 08THM)
A26 - Rear Light (Tail Light) W/Less Power Module (W/08TKC, 08THM)
Design 1272
A26 - Rear Light (Tail Light) W/08THK
A26 - Rear Light (Tail Light) W/08THK Design 1273
A26 - Rear Light (Tail Light) W/08TKB
A26 - Rear Light (Tail Light) W/08TKB Design 1274
A26 - Rear Light (Tail Light) W/08TKJ
A26 - Rear Light (Tail Light) W/08TKJ Design 1275
A26 - Rear Light (Tail Light) W_Daisy Chain pair of
Box Lamps W/08TRS
A26 - Rear Light (Tail Light) W_Daisy Chain pair of Box Lamps W/08TRS
Design 1276
A26/B6.7/L9 - Rear Lights (Tail Lights) Crossmember
Dual STT N/Back-Up
A26/B6.7/L9 - Rear Lights (Tail Lights) Crossmember Dual STT N/Back-Up
Design 1277
A26/B6.7/L9 - Rear Lights (Tail Lights) (W/Separate
Stop/Turn Assembly)
A26/B6.7/L9 - Rear Lights (Tail Lights) (W/Separate Stop/Turn Assembly)
Design 1278
A26/B6.7/L9 - Rear Light (Tail Light) Daisy Chain W/
Extension
A26/B6.7/L9 - Rear Light (Tail Light) Daisy Chain W/ Extension Design 1279
A26/B6.7/L9 - Rear Light (Tail Light) W/Daisy Chain
Pair of Box Lamps
A26/B6.7/L9 - Rear Light (Tail Light) W/Daisy Chain Pair of Box Lamps
Design 1280
A26/B6.7/L9 - Rear Light (Tail Light) W/Less Power
Module
A26/B6.7/L9 - Rear Light (Tail Light) W/Less Power Module Design 1281
B6.7 - Rear Light (LED BOX LAMP Tail Light)
xliiB6.7 - Rear Light (LED BOX LAMP Tail Light) Design 1282
B6.7 - Rear Light (Tail Light) Option 1
B6.7 - Rear Light (Tail Light) Option 1 Design 1283
B6.7 - Rear Light (Tail Light) Option 2
B6.7 - Rear Light (Tail Light) Option 2 Design 1284
B6.7 - Rear Light (Tail Light) Option 3
B6.7 - Rear Light (Tail Light) Option 3 Design 1285
B6.7 - Rear Light (Tail Light) Option 4
B6.7 - Rear Light (Tail Light) Option 4 Design 1286
B6.7 - Rear Light (Tail Light) W_Daisy Chain pair of
Box Lamps
B6.7 - Rear Light (Tail Light) W_Daisy Chain pair of Box Lamps Design 1287
L9 - Rear Light (LED BOX LAMP Tail Light)
L9 - Rear Light (LED BOX LAMP Tail Light) Design 1288
L9 - Rear Light (Tail Light) Design 1289
L9 - Rear Light (Tail Light) W Daisy Chain pair of Box
Lamps
L9 - Rear Light (Tail Light) W Daisy Chain pair of Box Lamps Design 1290
A26 - WORK LIGHT W BackUP 1 BULB_AUTOMATIC
TRANSMISSION
A26 - WORK LIGHT W BackUP 1 BULB_AUTOMATIC TRANSMISSION
Design 1291
A26 - WORK LIGHT W BackUP 1 BULB_MANUAL
TRANSMISSION
A26 - WORK LIGHT W BackUP 1 BULB_MANUAL TRANSMISSION Design 1292
A26 - WORK LIGHT W RKE W BackUP 1 BULB
(Manual)
A26 - WORK LIGHT W RKE W BackUP 1 BULB (Manual) Design 1293
A26 - WORK LIGHT W RKE 1 BULB1
A26 - WORK LIGHT W RKE 1 BULB1 Design 1294
A26 - WORK LIGHT W/Backup W/RKE 1 Bulb
A26 - WORK LIGHT W/Backup W/RKE 1 Bulb Automatic Transmission
Design 1295
A26 - WORK LIGHT 1 BULB 1
A26 - WORK LIGHT 1 BULB 1 Design 1296
B6.7 - Work Lights LED W/ Sw Pack - Day Cab
B6.7 - Work Lights LED W/ Sw Pack - Day Cab Design 1297
B6.7 - WORK LIGHT W BackUP 1 BULB
B6.7 - WORK LIGHT W BackUP 1 BULB Design 1298
xliiiB6.7 - WORK LIGHT W RKE 1 BULB
B6.7 - WORK LIGHT W RKE 1 BULB Design 1299
B6.7 - WORK LIGHT 1 BULB
B6.7 - WORK LIGHT 1 BULB Design 1300
L9 - Work Lights LED W/ Sw Pack - Day Cab
L9 - Work Lights LED W/ Sw Pack - Day Cab Design 1301
L9 - WORK LIGHT W BackUP 1 BULB Option 1
L9 - WORK LIGHT W BackUP 1 BULB Option 1 Design 1303
L9 - WORK LIGHT W BackUP 1 BULB Option 2
L9 - WORK LIGHT W BackUP 1 BULB Option 2 Design 1307
L9 - WORK LIGHT W RKE 1 BULB
L9 - WORK LIGHT W RKE 1 BULB Design 1309
L9 - WORK LIGHT 1 BULB
L9 - WORK LIGHT 1 BULB Design 1311
A26/B6.7/L9 - Fifth Wheel Slide
A26/B6.7/L9 - Fifth Wheel Slide Design 1313
A26/B6.7/L9 - Jaw Unlock Control
A26/B6.7/L9 - Jaw Unlock Control Design 1314
A26/B6.7/L9 - Jaw Unlock Control W/ SOLENOIDS
W/SWITCH PACKS
A26/B6.7/L9 - Jaw Unlock Control W/ SOLENOIDS W/SWITCH PACKS
Design 1315
A26 - Fuel Heater (Vehicle Powered)(Davco) 1
A26 - Fuel Heater (Vehicle Powered)(Davco) 1 Design 1316
A26 - Fuel Heater (Vehicle Powered)(Racor)
A26 - Fuel Heater (Vehicle Powered)(Racor) Design 1317
B6.7 - Fuel Heater (Vehicle Powered)(Davco)
B6.7 - Fuel Heater (Vehicle Powered)(Davco) Design 1318
B6.7 - Fuel Heater (Vehicle Powered)(Racor)
B6.7 - Fuel Heater (Vehicle Powered)(Racor) Design 1325
L9 - Fuel Heater (Vehicle Powered)(Davco)
L9 - Fuel Heater (Vehicle Powered)(Davco) Design 1332
L9 - Fuel Heater (Vehicle Powered)(Racor)
L9 - Fuel Heater (Vehicle Powered)(Racor) Design 1347
A26 - 26" Fuel Tank
A26 - 26" Fuel Tank Design 1355
A26 - 26" Fuel Tank - Secondary
A26 - 26" Fuel Tank - Secondary Design 1360
B6.7 - 26 inch Fuel Tank
B6.7 - 26 inch Fuel Tank Design 1367
xlivB6.7 - 26 inch Fuel Tank - Secondary
B6.7 - 26 inch Fuel Tank - Secondary Design 1370
2017-2024 B6.7 - Fuel Level (Single Sensor)
2017-2024 B6.7 - Fuel Level (Single Sensor) Design 1371
L9 - 26 inch Fuel Tank
L9 - 26 inch Fuel Tank Design 1377
L9 - 26 inch Fuel Tank - Secondary
L9 - 26 inch Fuel Tank - Secondary Design 1383
2017-2024 L9 - Fuel Level (Single Sensor)
2017-2024 L9 - Fuel Level (Single Sensor) Design 1390
A26 - Water In Fuel (WIF) Racor N/ Heater
A26 - Water In Fuel (WIF) Racor N/ Heater Design 1398
B6.7 - Water In Fuel (WIF) Racor N/ Heater
B6.7 - Water In Fuel (WIF) Racor N/ Heater Design 1400
B6.7 - Water In Fuel (WIF) Racor W/ Heater
B6.7 - Water In Fuel (WIF) Racor W/ Heater Design 1407
L9 - Water In Fuel (WIF) Davco N/ Heater
L9 - Water In Fuel (WIF) Davco N/ Heater Design 1414
L9 - Water In Fuel (WIF) Davco W/ Heater
L9 - Water In Fuel (WIF) Davco W/ Heater Design 1423
HVAC Actuators
HVAC Actuators Design 1432
A26 - Heating, Ventilation & Air Conditioning (HVAC)
(Auto Control head W/PT Transducer N/Low Pressure
SW)
A26 - Heating, Ventilation & Air Conditioning (HVAC) (Auto Control head W/PT
Transducer N/Low Pressure SW) Design 1433
B6.7 - Heating Ventilation & Air Conditioning (HVAC)
Auto Temp Control
B6.7 - Heating Ventilation & Air Conditioning (HVAC) Auto Temp Control
Design 1436
L9 - Heating Ventilation & Air Conditioning (HVAC)
Auto Temp Control
L9 - Heating Ventilation & Air Conditioning (HVAC) Auto Temp Control
Design 1439
(Manual W/PT Transducer N/Low Pressure SW)
A26 - Heating, Ventilation & Air Conditioning (HVAC) (Manual W/PT Transducer
N/Low Pressure SW) Design 1442
A26/B6.7/L9 - HVAC Assembly Actuators
A26/B6.7/L9 - HVAC Assembly Actuators Design 1444
B6.7 - Heating Ventilation & Air Conditioning (HVAC) Design 1445
xlvL9 - Heating Ventilation & Air Conditioning (HVAC)
L9 - Heating Ventilation & Air Conditioning (HVAC) Design 1446
A26 - Ambient Temperature (Mirror Sensor)
A26 - Ambient Temperature (Mirror Sensor) Design 1447
A26 - Ambient Temperature (No Display Mirror
Sensor)
A26 - Ambient Temperature (No Display Mirror Sensor) Design 1448
B6.7 - Ambient Temperature (Horizon-Mirror Sensor)
B6.7 - Ambient Temperature (Horizon-Mirror Sensor) Design 1449
B6.7 - Ambient Temperature (No Display, Mirror
Sensor)
B6.7 - Ambient Temperature (No Display, Mirror Sensor) Design 1450
L9 - Ambient Temperature (Horizon-Mirror Sensor)
L9 - Ambient Temperature (Horizon-Mirror Sensor) Design 1451
L9 - Ambient Temperature (No Display, Mirror Sensor)
L9 - Ambient Temperature (No Display, Mirror Sensor) Design 1452
2021 L9 - Ambient Air Temperature
2021 L9 - Ambient Air Temperature Design 1453
B6.7 - Current Monitoring (Ammeter)
B6.7 - Current Monitoring (Ammeter) Design 1454
A26 - Brake Pressure (Auxiliary Gauge)
A26 - Brake Pressure (Auxiliary Gauge) Design 1456
A26 - Brake Pressure (Virtual Gauge)
A26 - Brake Pressure (Virtual Gauge) Design 1457
B6.7 - Brake Pressure (Auxiliary Gauge)
B6.7 - Brake Pressure (Auxiliary Gauge) Design 1458
B6.7 - Brake Pressure (Virtual Gauge)
B6.7 - Brake Pressure (Virtual Gauge) Design 1459
L9 - Brake Pressure (Auxiliary Gauge)
L9 - Brake Pressure (Auxiliary Gauge) Design 1460
L9 - Brake Pressure (Virtual Gauge)
L9 - Brake Pressure (Virtual Gauge) Design 1461
A26/B6.7/L9 - Compressed Air Supply
A26/B6.7/L9 - Compressed Air Supply Design 1462
A26 - DEF Economy Monitor (GEN IV)
A26 - DEF Economy Monitor (GEN IV) Design 1463
B6.7/L9 - DEF Economy Monitor (GEN IV Cluster w/
Cummins ENG)
B6.7/L9 - DEF Economy Monitor (GEN IV Cluster w/ Cummins ENG) Design 1464
L9 - Coolant Temperature Monitoring (J1939 Comm)
L9 - Coolant Temperature Monitoring (J1939 Comm) Design 1465
xlviA26/B6.7/L9 - Engine Usage Monitoring (Base) NA
A26/B6.7/L9 - Engine Usage Monitoring (Base) NA Design 1466
A26/B6.7/L9 - Engine Usage Monitoring (VID Option)
A26/B6.7/L9 - Engine Usage Monitoring (VID Option) Design 1467
A26 - Transmission Oil Level (Low Level Warning)
A26 - Transmission Oil Level (Low Level Warning) Design 1468
A26/B6.7/L9 - Engine Oil Level Monitoring
A26/B6.7/L9 - Engine Oil Level Monitoring Design 1469
A26/B6.7/L9 - Engine Oil Pressure
A26/B6.7/L9 - Engine Oil Pressure Design 1470
A26/B6.7/L9 - Engine Oil Temperature (NA Mux)
A26/B6.7/L9 - Engine Oil Temperature (NA Mux) Design 1471
A26/B6.7/L9 - Engine Oil Temperature(NA MUX AUX
Gauge)
A26/B6.7/L9 - Engine Oil Temperature(NA MUX AUX Gauge) Design 1472
A26 - Engine Speed (Tachometer)
A26 - Engine Speed (Tachometer) Design 1473
B6.7 & L9 - Engine Speed (Tachometer)
B6.7 & L9 - Engine Speed (Tachometer) Design 1474
A26/B6.7/L9 - Fuel Economy Monitor
A26/B6.7/L9 - Fuel Economy Monitor Design 1475
A26/B6.7/L9 - Odometer (via BCM/EGC)
A26/B6.7/L9 - Odometer (via BCM/EGC) Design 1476
A26/B6.7/L9 - Trip Odometer w/VID
A26/B6.7/L9 - Trip Odometer w/VID Design 1477
A26/B6.7/L9 - Trip Odometer (Gen 4 Cluster)
A26/B6.7/L9 - Trip Odometer (Gen 4 Cluster) Design 1478
A26/B6.7/L9 - Trip Odometer ( w/ECM & TCM)
A26/B6.7/L9 - Trip Odometer ( w/ECM & TCM) Design 1479
A26/B6.7/L9 - PTO Hour Meter
A26/B6.7/L9 - PTO Hour Meter Design 1480
A26 - Transmission Oil Temperature (Automatic Trans
W/ Aux Gauge)
A26 - Transmission Oil Temperature (Automatic Trans W/ Aux Gauge)
Design 1481
Trans)
A26 - Transmission Oil Temperature (Automatic Trans) Design 1482
A26 - Transmission Oil Temperature (Manual Trans W/
Aux Gauge)Z
A26 - Transmission Oil Temperature (Manual Trans W/ Aux Gauge)Z Design1483
A26 - Transmission Oil Temperature (Manual Trans)
xlviiA26 - Transmission Oil Temperature (Manual Trans) Design 1484
B6.7 - Transmission Oil Temperature-Manual Trans
B6.7 - Transmission Oil Temperature-Manual Trans Design 1485
(w/Aux Gauge)
B6.7 - Transmission Oil Temperature-Manual Trans (w/Aux Gauge) Design 1486
L9 - Transmission Oil Temperature-Automatic Trans
L9 - Transmission Oil Temperature-Automatic Trans Design 1487
w/Aux Gauge
L9 - Transmission Oil Temperature-Automatic Trans w/Aux Gauge Design 1488
L9 - Transmission Oil Temperature-Manual
L9 - Transmission Oil Temperature-Manual Transmission Design 1489
w/Aux Gauge
L9 - Transmission Oil Temperature-Manual Trans w/Aux Gauge Design 1490
B6.7 - Vehicle Speedometer System (Manual XMSN)
B6.7 - Vehicle Speedometer System (Manual XMSN) Design 1491
B6.7/L9 - Vehicle Speedometer System (Automatic
XMSN J1939)
B6.7/L9 - Vehicle Speedometer System (Automatic XMSN J1939) Design 1492
L9 - Auxilary Tranmission XMSN (W/13607)
L9 - Auxilary Tranmission XMSN (W/13607) Design 1493
L9 - Vehicle Speedometer System (From Road Speed
SNSR to Blunt Cut)
L9 - Vehicle Speedometer System (From Road Speed SNSR to Blunt Cut)
Design 1494
L9 - Vehicle Speedometer System (Manual XMSN)
L9 - Vehicle Speedometer System (Manual XMSN) Design 1496
A26 - Vehicle Speedometer System (J1939 Message
from TCM to ECM)
A26 - Vehicle Speedometer System (J1939 Message from TCM to ECM)
Design 1497
from TCM to ECM)(Option2)
ECM)(Option2) Design 1498
A26 - Vehicle Speedometer System (VSS wired to VIC)
A26 - Vehicle Speedometer System (VSS wired to VIC) Design 1499
A26/B6.7/L9 - Vehicle Speed Limit Override
A26/B6.7/L9 - Vehicle Speed Limit Override Design 1500
A26/B6.7/L9 - Voltage Monitoring (Voltmeter)
xlviiiA26/B6.7/L9 - Voltage Monitoring (Voltmeter) Design 1501
A26/B6.7/L9 - Voltage Monitoring (Voltmeter) (with
Aux gauge)
A26/B6.7/L9 - Voltage Monitoring (Voltmeter) (with Aux gauge) Design 1502
A26/B6.7/L9 - Engine Warning_MUX
A26/B6.7/L9 - Engine Warning_MUX Design 1503
A26 - High Exhaust System Temperature (HEST)
Monitoring
A26 - High Exhaust System Temperature (HEST) Monitoring Design 1504
B6.7/L9 - High Exhaust System Temperature (HEST)
Monitoring
B6.7/L9 - High Exhaust System Temperature (HEST) Monitoring Design 1505
A26 - Up Shift Indicator (CA 2.0)
A26 - Up Shift Indicator (CA 2.0) Design 1506
A26/B6.7/L9 - Up Shift Indicator
A26/B6.7/L9 - Up Shift Indicator Design 1507
A26 - Range Inhibit with Seatbelt
A26 - Range Inhibit with Seatbelt Design 1508
A26/B6.7/L9 - Trans Range Inhibit (J1939 Comm)
A26/B6.7/L9 - Trans Range Inhibit (J1939 Comm) Design 1509
B6.7 - Range Inhibit (sixth gear inhibit switch)
B6.7 - Range Inhibit (sixth gear inhibit switch) Design 1510
B6.7 - Range Inhibit (Sixth Gear Inhibit Switch))
B6.7 - Range Inhibit (Sixth Gear Inhibit Switch)) Design 1511
B6.7/L9 - Trans Range Inhibit (J1939 Comm) Design 1513
A26/B6.7/L9 - Vehicle Information Display Premium w/
Wi-Fi (VID)
A26/B6.7/L9 - Vehicle Information Display Premium w/ Wi-Fi (VID) Design 1514
A26/B6.7/L9 - Vehicle Information Display (Without
Bluetooth)
A26/B6.7/L9 - Vehicle Information Display (Without Bluetooth) Design 1515
Bluetooth)
A26/B6.7/L9 - Vehicle Information Display (With Bluetooth) Design 1516
A26/B6.7/L9 - Cab Dome Light W/Classic Trim
A26/B6.7/L9 - Cab Dome Light W/Classic Trim Design 1517
A26/B6.7/L9 - Cab Dome Light W/ Combo in Diamond
Trim
A26/B6.7/L9 - Cab Dome Light W/ Combo in Diamond Trim Design 1518
xlixA26/B6.7/L9 - Interior Task Lights (Map) - Dome
Combo
A26/B6.7/L9 - Interior Task Lights (Map) - Dome Combo Design 1519
A26/B6.7/L9 - Courtesy Light Cab 2 door
A26/B6.7/L9 - Courtesy Light Cab 2 door Design 1520
A26/B6.7/L9 - Courtesy Light 4 Door
A26/B6.7/L9 - Courtesy Light 4 Door Design 1521
A26/B6.7/L9 - Panel Backlighting (Cabin Dimmer)
A26/B6.7/L9 - Panel Backlighting (Cabin Dimmer) Design 1522
A26/B6.7/L9 - Axle Lift Controls
A26/B6.7/L9 - Axle Lift Controls Design 1523
A26 - Axle Lift Controls
A26 - Axle Lift Controls Design 1527
A26 - Lift Axle Controls (Center Pedestal Controls f/ 1
lift axle)
A26 - Lift Axle Controls (Center Pedestal Controls f/ 1 lift axle) Design 1529
A26 - Lift Axle Controls (Center Pedestal Controls f/ 2
Lift Axles)
A26 - Lift Axle Controls (Center Pedestal Controls f/ 2 Lift Axles) Design 1531
A26 - Lift Axle Controls (Center Pedestal Controls f/ 3
lift axles)
A26 - Lift Axle Controls (Center Pedestal Controls f/ 3 lift axles) Design 1532
L9 - Axle Lift Controls Option 2
L9 - Axle Lift Controls Option 2 Design 1533
L9 - Lift Axle Controls (Center Pedestal Controls f/ 1
lift axle)
L9 - Lift Axle Controls (Center Pedestal Controls f/ 1 lift axle) Design 1535
L9 - Lift Axle Controls (Center Pedestal Controls f/ 2
Lift Axles)
L9 - Lift Axle Controls (Center Pedestal Controls f/ 2 Lift Axles) Design 1537
L9 - Lift Axle Controls (Center Pedestal Controls f/ 3
lift axles)
L9 - Lift Axle Controls (Center Pedestal Controls f/ 3 lift axles) Design 1538
A26 - Axle Loading (Weight) (Rear, Horizon)
A26 - Axle Loading (Weight) (Rear, Horizon) Design 1539
B6.7 - Axle Loading (Weight) Rear
B6.7 - Axle Loading (Weight) Rear Design 1545
B6.7 - Axle Loading (Weight) (Rear, Horizon)
B6.7 - Axle Loading (Weight) (Rear, Horizon) Design 1547
L9 - Axle Loading (Weight) Rear
L9 - Axle Loading (Weight) Rear Design 1551
lL9 - Axle Loading (Weight) (Rear, Horizon)
L9 - Axle Loading (Weight) (Rear, Horizon) Design 1553
A26 - Axle Temperature Monitoring (Single Rear Aux
Gauge)
A26 - Axle Temperature Monitoring (Single Rear Aux Gauge) Design 1557
Virtual Gauge)
A26 - Axle Temperature Monitoring (Single Rear Virtual Gauge) Design 1558
A26 - Axle Temperature Monitoring (Tandem Rear Aux
Gauge)
A26 - Axle Temperature Monitoring (Tandem Rear Aux Gauge) Design 1559
Virtual Gauge)
A26 - Axle Temperature Monitoring (Tandem Rear Virtual Gauge) Design 1560
B6.7 - Axle Temperature Monitoring (Single Rear Aux
Gauge)
B6.7 - Axle Temperature Monitoring (Single Rear Aux Gauge) Design 1561
Virtual Gauge)
B6.7 - Axle Temperature Monitoring (Single Rear Virtual Gauge) Design 1562
L9 - Axle Temperature Monitoring (Tandem Rear Aux
Gauge) Option 1
L9 - Axle Temperature Monitoring (Tandem Rear Aux Gauge) Option 1
Design 1563
Gauge) Option 2
L9 - Axle Temperature Monitoring (Tandem Rear Aux Gauge) Option 2
Design 1564
Virtual Gauge) Option 1
L9 - Axle Temperature Monitoring (Tandem Rear Virtual Gauge) Option 1
Design 1565
Virtual Gauge) Option 2
L9 - Axle Temperature Monitoring (Tandem Rear Virtual Gauge) Option 2
Design 1566
A26 - Driver Controlled Locking Differential FR and RR
Axles (Dana w/ two sw)
A26 - Driver Controlled Locking Differential FR and RR Axles (Dana w/ two sw)
Design 1567
Axle (Dana w/ one switch)
A26 - Driver Controlled Locking Differential FR and RR Axle (Dana w/ one switch)
Design 1568
liA26 - Driver Controlled Locking Differential RR Axle
(Dana w/ one sw)
A26 - Driver Controlled Locking Differential RR Axle (Dana w/ one sw)
Design 1569
Axles (Meritor w/ two sw)
A26 - Driver Controlled Locking Differential FR and RR Axles (Meritor w/ two sw)
Design 1570
Axle (Meritor w/ one sw)
A26 - Driver Controlled Locking Differential FR and RR Axle (Meritor w/ one sw)
Design 1571
(Meritor w/ one sw)
A26 - Driver Controlled Locking Differential RR Axle (Meritor w/ one sw)
Design 1572
B6.7 - Driver Controlled Locking Differential - RR Axle
(Dana w/ one sw)
B6.7 - Driver Controlled Locking Differential - RR Axle (Dana w/ one sw)
Design 1573
(Meritor w/ one sw)
B6.7 - Driver Controlled Locking Differential - RR Axle (Meritor w/ one sw)
Design 1574
L9 - Driver Controlled Locking Differential - FR and RR
L9 - Driver Controlled Locking Differential - FR and RR Axles (Dana w/ two sw)
Design 1575
L9 - Driver Controlled Locking Differential - FR and RR Axle (Dana w/ one sw)
Design 1576
L9 - Driver Controlled Locking Differential - RR Axle
(Dana w/ one sw)
L9 - Driver Controlled Locking Differential - RR Axle (Dana w/ one sw)
Design 1577
L9 - Driver Controlled Locking Differential - FR and RR Axles (Meritor w/ two sw)
Design 1578
L9 - Driver Controlled Locking Differential - FR and RR Axle (Meritor w/ one sw)
Design 1579
(Meritor w/ one sw)
L9 - Driver Controlled Locking Differential - RR Axle (Meritor w/ one sw)
Design 1580
liiA26/B6.7/L9 - Height Control
A26/B6.7/L9 - Height Control Design 1581
A26/B6.7/L9 - Power Divider Lock Control and
Monitoring
A26/B6.7/L9 - Power Divider Lock Control and Monitoring Design 1582
L9 - Rear Axle Load Distribution
L9 - Rear Axle Load Distribution Design 1583
A26/B6.7/L9 - Rear Suspension Pressure Monitoring
(Auxiliary Gauge)
A26/B6.7/L9 - Rear Suspension Pressure Monitoring (Auxiliary Gauge)
Design 1584
(Virtual Gauge)
A26/B6.7/L9 - Rear Suspension Pressure Monitoring (Virtual Gauge) Design 1586
A26 - Two Speed Axle (Multiplex SW on Dash)
A26 - Two Speed Axle (Multiplex SW on Dash) Design 1588
Dash)(Option2)
A26 - Two Speed Axle (Multiplex SW on Dash)(Option2) Design 1589
B6.7 - Two Speed Axle (AirShift on Shifter)
B6.7 - Two Speed Axle (AirShift on Shifter) Design 1590
L9 - Two Speed Axle (AirShift on Shifter)
L9 - Two Speed Axle (AirShift on Shifter) Design 1591
L9 - Two Speed Axle (Multiplex SW on Dash)
L9 - Two Speed Axle (Multiplex SW on Dash) Design 1592
A26/B6.7/L9 - Driver and Passenger Seats - RollTek
(Hard Wired)
A26/B6.7/L9 - Driver and Passenger Seats - RollTek (Hard Wired) Design 1593
A26/B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard
Wired) - Leather
A26/B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard Wired) - Leather
Design 1594
Wired) - Mordular
A26/B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard Wired) - Mordular
Design 1595
Wired) - Vinyl
A26/B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard Wired) - Vinyl Design 1596
A26/B6.7/L9 - Seatbelt Reminder 6 Seats
A26/B6.7/L9 - Seatbelt Reminder 6 Seats Design 1597
A26/B6.7/L9 - Seatbelt Reminder (Warning)(Driver
only)
liiiA26/B6.7/L9 - Seatbelt Reminder (Warning)(Driver only) Design 1598
A26/B6.7/L9 - Seatbelt Reminder (Warning)(Driver &
Passenger in parallel)
A26/B6.7/L9 - Seatbelt Reminder (Warning)(Driver & Passenger in parallel)
Design 1599
Vehicle Data Recorder (No Display)
Vehicle Data Recorder (No Display) Design 1600
Vehicle Data Recorder (W/ Display)
Vehicle Data Recorder (W/ Display) Design 1602
L9 - TEM Electric Trailer Brake Controller Activated
Stop LT
L9 - TEM Electric Trailer Brake Controller Activated Stop LT Design 1604
A26 - TEM Electric Trailer Brake Controller Activated
Stop LT
A26 - TEM Electric Trailer Brake Controller Activated Stop LT Design 1605
Stop LT (Option2)
A26 - TEM Electric Trailer Brake Controller Activated Stop LT (Option2)
Design 1606
B6.7 - TEM Electric Trailer Brake Controller Activated
Stop LT Option 2
B6.7 - TEM Electric Trailer Brake Controller Activated Stop LT Option 2
Design 1607
B6.7 - TEM _Electric Trailer Brake Controller Activated
Stop LT Option 1
B6.7 - TEM _Electric Trailer Brake Controller Activated Stop LT Option 1
Design 1608
L9 - Trailer Interface - ABS (ETB Feed, Blunt Cut)
L9 - Trailer Interface - ABS (ETB Feed, Blunt Cut) Design 1609
B6.7 - Trailer Interface (Lighting) – BLUNT CUT (Part
of Electric Trailer Brakes) Option 1
B6.7 - Trailer Interface (Lighting) – BLUNT CUT (Part of Electric Trailer Brakes)
Option 1 Design 1610
of Electric Trailer Brakes) Option 2
Option 2 Design 1611
L9 - Trailer Interface (Lighting) – BLUNT CUT (Part of
L9 - Trailer Interface (Lighting) – BLUNT CUT (Part of Electric Trailer Brakes)
Option 1 Design 1612
Option 2 Design 1613
livA26 - Auto Neutral (Allison with Multiplex Switch and
Confirmation Telltale)
A26 - Auto Neutral (Allison with Multiplex Switch and Confirmation Telltale)
Design 1614
B6.7 - Auto Neutral HS Output W/ J1939 SW N/Relay
B6.7 - Auto Neutral HS Output W/ J1939 SW N/Relay Design 1615
B6.7 - Auto Neutral (Allision N/ Switch & W/
B6.7 - Auto Neutral (Allision N/ Switch & W/ Confirmation Telltale) Design 1617
B6.7 - Auto Neutral (HS Drive N/ SW N/ Relay)
B6.7 - Auto Neutral (HS Drive N/ SW N/ Relay) Design 1619
L9 - Auto Neutral (Allision N/ Switch & W/
L9 - Auto Neutral (Allision N/ Switch & W/ Confirmation Telltale) Design 1621
L9 - Auto Neutral (Allison without Multiplex Switch
L9 - Auto Neutral (Allison without Multiplex Switch and Confirmation Telltale)
Design 1624
L9 - Auto Neutral (Allison with Multiplex Switch and
L9 - Auto Neutral (Allison with Multiplex Switch and Confirmation Telltale)
Design 1626
A26 - Rock Free Transmission
A26 - Rock Free Transmission Design 1628
B6.7/L9 - Transmission Shifter (T-Handle for Allison,
N/ Park Position)
B6.7/L9 - Transmission Shifter (T-Handle for Allison, N/ Park Position)
Design 1629
A26 - Transmission Shifter (Stalk Shifter, Eaton
Endurant)
A26 - Transmission Shifter (Stalk Shifter, Eaton Endurant) Design 1630
A26 - Transmission Shifter (Universal Stalk Shifter -
Allison 3K/4K
A26 - Transmission Shifter (Universal Stalk Shifter - Allison 3K/4K Design 1631
Ultrashift)
A26 - Transmission Shifter (Universal Stalk Shifter - Ultrashift) Design 1632
B6.7 - Transmission Shifter Allison 5th Gen Push
Button(SURHD)
B6.7 - Transmission Shifter Allison 5th Gen Push Button(SURHD) Design 1633
B6.7 - Transmission Shifter (Push Button Shifter -
Allison 3K/4K)
B6.7 - Transmission Shifter (Push Button Shifter - Allison 3K/4K) Design 1635
B6.7 - Transmission Shifter (Stalk Shifter Allison)
lvB6.7 - Transmission Shifter (Stalk Shifter Allison) Design 1637
B6.7 - Transmission Shifter (Universal Stalk Shifter -
Allison 3K/4K)
B6.7 - Transmission Shifter (Universal Stalk Shifter - Allison 3K/4K) Design 1639
B6.7 - Transmission Shifter (T-Handle for Allison With
Park Position)
B6.7 - Transmission Shifter (T-Handle for Allison With Park Position) Design 1641
B6.7 - T-Handle for Allison Without Park Position
B6.7 - T-Handle for Allison Without Park Position Design 1643
L9 - Transmission Shifter Allison 5th Gen Push
Button(SURHD)
L9 - Transmission Shifter Allison 5th Gen Push Button(SURHD) Design 1645
L9 - Transmission Shifter (Push Button Shifter -
Allison 3K/4K)
L9 - Transmission Shifter (Push Button Shifter - Allison 3K/4K) Design 1646
L9 - Transmission Shifter (Stalk Shifter Allison)
L9 - Transmission Shifter (Stalk Shifter Allison) Design 1648
L9 - Transmission Shifter (Universal Stalk Shifter -
Allison 3K/4K)
L9 - Transmission Shifter (Universal Stalk Shifter - Allison 3K/4K) Design 1650
A26/B6.7/L9 - Transfer Case - High/Low Air Sol
A26/B6.7/L9 - Transfer Case - High/Low Air Sol Design 1653
A26/B6.7/L9 - Transfer Case - High/Neu/Low Air Sol
A26/B6.7/L9 - Transfer Case - High/Neu/Low Air Sol Design 1654
A26 - Transmission (Ultrashift + FAS)
A26 - Transmission (Ultrashift + FAS) Design 1655
L9 - Ultrashift Plus
L9 - Ultrashift Plus Design 1656
A26 - Transmission (Allison 3K/4K) 1
A26 - Transmission (Allison 3K/4K) 1 Design 1657
B6.7 - Transmission (Allison 1K/2K)
B6.7 - Transmission (Allison 1K/2K) Design 1658
B6.7 - Transmission (Allison 3K/4K)
B6.7 - Transmission (Allison 3K/4K) Design 1659
L9 - Transmission (Allison 3K/4K)
L9 - Transmission (Allison 3K/4K) Design 1661
A26 - Endurant Transmission
A26 - Endurant Transmission Design 1663
A26 - Transmissions Electrical I/O (Eaton Ultrashift)
A26 - Transmissions Electrical I/O (Eaton Ultrashift) Design 1664
lviA26 - Transmission Electrical I/O (Endurant W/A26 &
N/ Body Builder)
A26 - Transmission Electrical I/O (Endurant W/A26 & N/ Body Builder)
Design 1665
W/ Body Builder)
A26 - Transmission Electrical I/O (Endurant W/A26 & W/ Body Builder)
Design 1666
L9 - Transmissions Electrical I/O (Eaton Ultrashift)
L9 - Transmissions Electrical I/O (Eaton Ultrashift) Design 1667
A26 - Hill Start Aid (Bendix)
A26 - Hill Start Aid (Bendix) Design 1668
A26 - Hill Start Aid (HSA) (Bendix CA 2.0)
A26 - Hill Start Aid (HSA) (Bendix CA 2.0) Design 1670
L9 - Hill Start Aid (Bendix)
L9 - Hill Start Aid (Bendix) Design 1671
L9 - Hill Start Aid (WABCO)
L9 - Hill Start Aid (WABCO) Design 1673
A26 - Transmission Retarder (3K)
A26 - Transmission Retarder (3K) Design 1674
A26 - Transmission Retarder (4K Hardwire Switch)
A26 - Transmission Retarder (4K Hardwire Switch) Design 1675
L9 - Transmission Retarder (3K, Gen 6)
L9 - Transmission Retarder (3K, Gen 6) Design 1676
L9 - Transmission Retarder (4K, Gen 6, Hardwire
Switch)
L9 - Transmission Retarder (4K, Gen 6, Hardwire Switch) Design 1678
L9 - Transmission Retarder (4K, Gen 6, W/ Multiplex)
L9 - Transmission Retarder (4K, Gen 6, W/ Multiplex) Design 1680
L9 - Transmission Retarder (4700 W/ Multiplex)
L9 - Transmission Retarder (4700 W/ Multiplex) Design 1682
L9 - Transmission Retarder (4700, Gen 6, W/ Multiplex)
L9 - Transmission Retarder (4700, Gen 6, W/ Multiplex) Design 1684
A26/B6.7/L9 - Transmission - MODE Selection
A26/B6.7/L9 - Transmission - MODE Selection Design 1686
B6.7/L9 - Transmission Mode Button (1K/2K)
B6.7/L9 - Transmission Mode Button (1K/2K) Design 1687
B6.7/L9 - Transmission - MODE Selection Design 1688
B6.7 - Windshield Washer Pump
B6.7 - Windshield Washer Pump Design 1689
B6.7 - Windshield Washer Pump & Low Fluid Sensor
B6.7 - Windshield Washer Pump & Low Fluid Sensor Design 1690
lviiL9 - Windshield Washer Pump & Low Fluid Sensor
L9 - Windshield Washer Pump & Low Fluid Sensor Design 1691
A26 - Windshield Wipers
A26 - Windshield Wipers Design 1693
B6.7 - Windshield Wipers
B6.7 - Windshield Wipers Design 1694
L9 - Windshield Wipers
L9 - Windshield Wipers Design 1695
B6.7/L9 - Battery Disconnect (W/Switch and
W/Solenoid)
B6.7/L9 - Battery Disconnect (W/Switch and W/Solenoid) Design 1696
A26 - Charging System (Delco Remy 28SI Alternator
W/ Remote Sense)
A26 - Charging System (Delco Remy 28SI Alternator W/ Remote Sense)
Design 1697
A26 - Charging System (Delco Remy 36SI Alternator
W/ Remote Sense)
A26 - Charging System (Delco Remy 36SI Alternator W/ Remote Sense)
Design 1699
A26 - Charging System (Delco Remy 40SI/38SI
A26 - Charging System (Delco Remy 40SI/38SI Alternator W/ Remote Sense)
Design 1701
A26 - Charging System (Leece-Neville AVI160-
160A/210A/240A N/ Remote Sense)
A26 - Charging System (Leece-Neville AVI160-160A/210A/240A N/ Remote
Sense) Design 1703
190A/210A/240A Alternator W/ Remote Sense)
A26 - Charging System (Leece-Neville AVI160-190A/210A/240A Alternator W/
Remote Sense) Design 1705
14931PAH_14923PAH Alternator)
A26 - Charging System (Leece-Neville 14931PAH_14923PAH Alternator)
Design 1707
A26 - Charging System (Leece-Neville - LN 325A
A26 - Charging System (Leece-Neville - LN 325A Alternator W/ Remote Sense)
Design 1709
A26 - Charging System (LH160_LH200)
A26 - Charging System (LH160_LH200) Design 1711
A26 - Charging System (LIL165_LIL200 Alternator W/
Remote Sense)
A26 - Charging System (LIL165_LIL200 Alternator W/ Remote Sense)
Design 1713
lviiiB6.7 - Bosch LH160_LH200 Alternator
B6.7 - Bosch LH160_LH200 Alternator Design 1715
B6.7 - Delco Remy 28SI Alternator W/Sensor Option 1
B6.7 - Delco Remy 28SI Alternator W/Sensor Option 1 Design 1717
B6.7 - Delco Remy 28SI Alternator W/Sensor Option 2
B6.7 - Delco Remy 28SI Alternator W/Sensor Option 2 Design 1718
B6.7 - Delco Remy 36SI Alternator W/Sensor
B6.7 - Delco Remy 36SI Alternator W/Sensor Design 1719
B6.7 - Delco Remy 40SI Alternator W/Sensor
B6.7 - Delco Remy 40SI Alternator W/Sensor Design 1720
B6.7 - Leece-Neville AVI160 Alternator
B6.7 - Leece-Neville AVI160 Alternator Design 1721
B6.7 - Leece-Neville AVI160-210A/240A Alternator
W/Sensor
B6.7 - Leece-Neville AVI160-210A/240A Alternator W/Sensor Design 1722
B6.7 - Leece-Neville 320PAH Alternator
B6.7 - Leece-Neville 320PAH Alternator Design 1723
B6.7 - Leece-Neville - LN 325A Alternator W/Sensor
B6.7 - Leece-Neville - LN 325A Alternator W/Sensor Design 1724
L9 - Bosch LH160_LH200 Alternator
L9 - Bosch LH160_LH200 Alternator Design 1725
L9 - Delco Remy 28SI Alternator W/Sensor
L9 - Delco Remy 28SI Alternator W/Sensor Design 1726
L9 - Delco Remy 36SI Alternator W/Sensor
L9 - Delco Remy 36SI Alternator W/Sensor Design 1727
L9 - Delco Remy 40SI Alternator W/Sensor
L9 - Delco Remy 40SI Alternator W/Sensor Design 1728
L9 - Leece-Neville AVI160 Alternator
L9 - Leece-Neville AVI160 Alternator Design 1729
L9 - Leece-Neville AVI160-210A/240A Alternator
W/Sensor
L9 - Leece-Neville AVI160-210A/240A Alternator W/Sensor Design 1730
L9 - Leece-Neville - LN 325A Alternator W/Sensor
L9 - Leece-Neville - LN 325A Alternator W/Sensor Design 1731
A26 - Cranking (Starter) (BCM Controlled & N/ Wired
Thermal Overcrank)
A26 - Cranking (Starter) (BCM Controlled & N/ Wired Thermal Overcrank)
Design 1732
Thermal Over-Crank 2)
A26 - Cranking (Starter) (BCM Controlled & N/ Wired Thermal Over-Crank 2)
Design 1733
lixA26 - Cranking (Starter) (BCM Controlled & N/ Wired
Thermal Over-Crank)
A26 - Cranking (Starter) (BCM Controlled & N/ Wired Thermal Over-Crank)
Design 1734
A26 - Cranking (Starter) (BCM Controlled & W/ Wired
Thermal Overcrank 2)
A26 - Cranking (Starter) (BCM Controlled & W/ Wired Thermal Overcrank 2)
Design 1735
Thermal Overcrank)
A26 - Cranking (Starter) (BCM Controlled & W/ Wired Thermal Overcrank)
Design 1736
B6.7 - Cranking (Starter) GEN4 BCM W/O Thermal
Overcrank
B6.7 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/O Thermal
Overcrank Design 1737
L9 - Cranking (Starter) GEN4 BCM W/O Thermal
Overcrank
L9 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/O Thermal
Overcrank Design 1738
L9 - Cranking (Starter) GEN4 BCM W/ Thermal
Overcrank - External Switch
L9 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/ Thermal Overcrank
- External Switch Design 1739
A26 - Cranking Request (w/ Key Switch w/ BCM)
A26 - Cranking Request (w/ Key Switch w/ BCM) Design 1740
A26/B6.7/L9 - Key Switch (Operator Input)
A26/B6.7/L9 - Key Switch (Operator Input) Design 1742
B6.7 - Cranking Request (w/ Key Switch w/ BCM)
B6.7 - Cranking Request (w/ Key Switch w/ BCM) Design 1744
L9 - Cranking Request (w/ Key Switch w/ BCM)
L9 - Cranking Request (w/ Key Switch w/ BCM) Design 1746
A26 - Starter Interlocks (BCM controlled with input
from Allison TCM)
A26 - Starter Interlocks (BCM controlled with input from Allison TCM) Design 1747
A26 - Starter Interlocks (Service Brake Interlock)
A26 - Starter Interlocks (Service Brake Interlock) Design 1748
A26 - Starter Interlock (BCM HSD controlled W/ Clutch
SW & N/ (Neutral Switch)
A26 - Starter Interlock (BCM HSD controlled W/ Clutch SW & N/ (Neutral Switch)
Design 1749
A26 - Starter Interlock (BCM HSD Controlled w/ Relay
& N/ Neutral Switch)
A26 - Starter Interlock (BCM HSD Controlled w/ Relay & N/ Neutral Switch)
Design 1750
lxB6.7 - Clutch Switch/Monitoring (High and Low Switch
to BCM)
B6.7 - Clutch Switch/Monitoring (High and Low Switch to BCM) Design 1751
B6.7 - Starter Interlocks (BCM Controlled with Input
from Allison 1K/2K TCM)
B6.7 - Starter Interlocks (BCM Controlled with Input from Allison 1K/2K TCM)
Design 1752
from Allison 3K/4K TCM)
B6.7 - Starter Interlocks (BCM Controlled with Input from Allison 3K/4K TCM)
Design 1753
L9 - Clutch Switch/Monitoring (High and Low Switch
to BCM)
L9 - Clutch Switch/Monitoring (High and Low Switch to BCM) Design 1755
L9 - Starter Interlocks (BCM Controlled with Input
L9 - Starter Interlocks (BCM Controlled with Input from Allison 3K/4K TCM)
Design 1756
L9 - Starter Interlock (BCM HSD controlled W/ Clutch
SW & N/Auto SS)
L9 - Starter Interlock (BCM HSD controlled W/ Clutch SW & N/Auto SS)
Design 1758
L9 - Starter Interlock (BCM LSD Controlled w/ Relay &
N/ Auto SS)_EATON XMSN
L9 - Starter Interlock (BCM LSD Controlled w/ Relay & N/ Auto SS)_EATON
XMSN Design 1759
B6.7 - Battery International (4) 12V
B6.7 - Battery International (4) 12V Design 1760
L9 - Battery International (4) 12V
L9 - Battery International (4) 12V Design 1761
A26 - Battery International (3) 12V
A26 - Battery International (3) 12V Design 1762
A26 - Battery International (4) 12V
A26 - Battery International (4) 12V Design 1763
Connectors 1764
Index 485
Brand: International, Navistar
Type of Manual: Interactive Schematics
Model: International HV Series Truck
Built: 12/10/2021 To 12/31/2025
Part Number: 00000018833
Publication Date: 2025
Number of Pages: 4959 Pages
A26/B6.7/L9 - BCM (Body Control Module)
A26/B6.7/L9 - BODY CONTROL MODULE (Body Control Module) Design 1
A26 - ABS Private J1939
A26 - ABS Private J1939 Design 9
A26 - Cab J1939 (250Kbps)
A26 - Cab J1939 (250Kbps) Design 10
A26 - Low Speed J1939 (125Kbps)
A26 - Low Speed J1939 (125Kbps) Design 11
A26 - N2 Proprietary J1939
A26 - N2 Proprietary J1939 Design 12
A26 - Telematics J1708 (9.6kbps)
A26 - Telematics J1708 (9.6kbps) Design 13
A26 - 2017 Body Standard J1939 (250kbps) - 5/26/2025
and Newer Models
A26 - 2017 Body Standard J1939 (250kbps) - 5/26/2025 and Newer Models
Design 14
Diagnostic Proprietary J1939
Diagnostic Proprietary J1939 Design 15
Engine Proprietary J1939 (250kbps)
Engine Proprietary J1939 (250kbps) Design 16
Powertrain Standard J1939 (500kbps)
Powertrain Standard J1939 (500kbps) Design 17
B6.7 - ABS Private J1939
B6.7 - ABS Private J1939 Design 18
B6.7 - Cab J1939 (250kbps)
B6.7 - Cab J1939 (250kbps) Design 19
B6.7 - Engine Private J1939 (250kbps)
B6.7 - Engine Private J1939 (250kbps) Design 20
B6.7 - Low Speed J1939 (125kbps)
B6.7 - Low Speed J1939 (125kbps) Design 21
B6.7 - Telematics J1708 (9.6kbps)
B6.7 - Telematics J1708 (9.6kbps) Design 22
B6.7 - 2017-2024 Body Standard J1939 (250kbps) -
12/10/2021 - 5/25/2025
B6.7 - 2017-2024 Body Standard J1939 (250kbps) - 12/10/2021 - 5/25/2025
Design 23
B6.7 - 2017-2024 N2 Proprietary J1939
B6.7 - 2017-2024 N2 Proprietary J1939 Design 24
B6.7 - 2024-2027 Body Standard J1939 (250kbps) -
05/26/2025 and Newer Models
B6.7 - 2024-2027 Body Standard J1939 (250kbps) - 05/26/2025 and Newer
Models Design 25
iB6.7 - 2024-2027 N2 Proprietary J1939
B6.7 - 2024-2027 N2 Proprietary J1939 Design 26
B6.7 - Powertrain J1939 Allison 1k/2k
B6.7 - Powertrain J1939 Allison 1k/2k Design 27
B6.7 - Powertrain J1939 Allison 3k/4k
B6.7 - Powertrain J1939 Allison 3k/4k Design 28
B6.7 - Powertrain J1939 Manual Transmission
B6.7 - Powertrain J1939 Manual Transmission Design 29
CBE1 - 2024-2027 Body Standard J1939 (250kbps) -
CBE1 - 2024-2027 Body Standard J1939 (250kbps) - 05/26/2025 and Newer
Models Design 30
CBE1 - 2024-2027 N2 Proprietary J1939
CBE1 - 2024-2027 N2 Proprietary J1939 Design 31
L9 - ABS Private J1939
L9 - ABS Private J1939 Design 32
L9 - Body J1939 (250kbps)
L9 - Body J1939 (250kbps) Design 33
L9 - Cab J1939 (250kbps)
L9 - Cab J1939 (250kbps) Design 34
L9 - Engine Private J1939 (250kbps)
L9 - Engine Private J1939 (250kbps) Design 35
L9 - Low Speed J1939 (125kbps)
L9 - Low Speed J1939 (125kbps) Design 36
L9 - Telematics J1708 (9.6kbps)
L9 - Telematics J1708 (9.6kbps) Design 37
L9 - 2017-2024 Body Standard J1939 (250kbps) -
L9 - 2017-2024 Body Standard J1939 (250kbps) - 12/10/2021 - 5/25/2025
Design 38
L9 - 2017-2024 N2 Proprietary J1939
L9 - 2017-2024 N2 Proprietary J1939 Design 39
L9 - 2024-2027 Body Standard J1939 (250kbps) -
L9 - 2024-2027 Body Standard J1939 (250kbps) - 05/26/2025 and Newer Models
Design 40
L9 - 2024-2027 N2 Proprietary J1939
L9 - 2024-2027 N2 Proprietary J1939 Design 41
L9 - Powertrain J1939 Allison 3k/4k
L9 - Powertrain J1939 Allison 3k/4k Design 42
L9 - Powertrain J1939 Eaton
L9 - Powertrain J1939 Eaton Design 43
iiL9 - Powertrain J1939 Manual Transmission
L9 - Powertrain J1939 Manual Transmission Design 44
A26 - ECM Navistar A26
A26 - ECM Navistar A26 Design 45
B6.7 - ECM Cummins CM2350A
B6.7 - ECM Cummins CM2350A Design 49
L9 - ECM Cummins CM2350A
L9 - ECM Cummins CM2350A Design 50
A26/B6.7/L9 - Instrument Cluster (Premium)
A26/B6.7/L9 - Instrument Cluster (Premium) Design 51
A26/B6.7/L9 - Instrument Cluster (Standard)
A26/B6.7/L9 - Instrument Cluster (Standard) Design 53
A26/B6.7/L9 - Instrument Cluster - Bulb Check
A26/B6.7/L9 - Instrument Cluster - Bulb Check Design 55
A26/B6.7/L9 - Instrument Cluster - Request and Status
A26/B6.7/L9 - Instrument Cluster - Request and Status Design 56
A26/B6.7/L9/S13 - Ground Splice Pack 1022 & 1023
A26/B6.7/L9/S13 - Ground Splice Pack 1022 & 1023 Design 57
A26/B6.7/L9/S13 - Ground Splice Pack 1027
A26/B6.7/L9/S13 - Ground Splice Pack 1027 Design 58
A26/B6.7/L9/S13 - Interior Dual Post Ground StudCowl Wall
A26/B6.7/L9/S13 - Interior Dual Post Ground Stud-Cowl Wall Design 59
A26/B6.7/L9/S13 - ZVR Splice Pack - 1620
A26/B6.7/L9/S13 - ZVR Splice Pack - 1620 Design 60
A26 - Center Chassis Ground Splice Packs
A26 - Center Chassis Ground Splice Packs Design 61
B6.7 - Center Chassis Ground Splice Packs
B6.7 - Center Chassis Ground Splice Packs Design 62
L9/S13 - Center Chassis Ground Splice Packs
L9/S13 - Center Chassis Ground Splice Packs Design 63
A26 - Forward Chassis Ground Splice Packs 8800
A26 - Forward Chassis Ground Splice Packs 8800 Design 64
B6.7 - Forward Chassis Ground Splice Packs 8800
B6.7 - Forward Chassis Ground Splice Packs 8800 Design 65
L9 - Forward Chassis Ground Splice Packs 8800
L9 - Forward Chassis Ground Splice Packs 8800 Design 66
A26 - Powertrain Ground Splice Packs - 6704
A26 - Powertrain Ground Splice Packs - 6704 Design 67
A26 - Powertrain ZVR Splice Packs 6702
A26 - Powertrain ZVR Splice Packs 6702 Design 68
iiiB6.7 - Engine Ground Distribution - Ring Terminals
B6.7 - Engine Ground Distribution - Ring Terminals Design 69
B6.7 - Engine Ground Distribution - Splice Packs
B6.7 - Engine Ground Distribution - Splice Packs Design 70
B6.7 - Powertrain Splice Pack 6704
B6.7 - Powertrain Splice Pack 6704 Design 71
B6.7 - ZVR Splice Pack - 6747
B6.7 - ZVR Splice Pack - 6747 Design 72
L9 - Powertrain Splice Pack 6704 & 6704B
L9 - Powertrain Splice Pack 6704 & 6704B Design 73
L9 - ZVR Splice Pack - 6747
L9 - ZVR Splice Pack - 6747 Design 74
A26/B6.7/L9/S13 - Lighting Control Module
A26/B6.7/L9/S13 - Lighting Control Module Design 75
A26 - Aftertreatment PDM
A26 - Aftertreatment PDM Design 77
B6.7 - Aftertreatment PDM
B6.7 - Aftertreatment PDM Design 78
L9 - Aftertreatment PDM
L9 - Aftertreatment PDM Design 79
A26 - Auxiliary Power Fuse
A26 - Auxiliary Power Fuse Design 80
B6.7 - Auxiliary Power Fuse
B6.7 - Auxiliary Power Fuse Design 81
L9 - Auxiliary Power Fuse
L9 - Auxiliary Power Fuse Design 82
A26 - Chassis PDM
A26 - Chassis PDM Design 83
B6.7/L9 - Chassis PDM
B6.7/L9 - Chassis PDM Design 84
A26/B6.7/L9/S13 - Battery Feed
A26/B6.7/L9/S13 - Battery Feed Design 85
A26/B6.7/L9/S13 - Interior PDM Chart
A26/B6.7/L9/S13 - Interior PDM Chart Design 86
A26/B6.7/L9/S13 - Key Switch Accessory
A26/B6.7/L9/S13 - Key Switch Accessory Design 87
A26/B6.7/L9/S13 - Key Switch Ignition
A26/B6.7/L9/S13 - Key Switch Ignition Design 88
A26 - Relays
A26 - Relays Design 89
ivB6.7 - Relays
B6.7 - Relays Design 90
L9 - Relays
L9 - Relays Design 91
A26/B6.7/L9/S13 - ABS CAN Splice Pack - 1410
A26/B6.7/L9/S13 - ABS CAN Splice Pack - 1410 Design 92
A26/B6.7/L9/S13 - Panel Light Dimmer Splice Pack -
1021
A26/B6.7/L9/S13 - Panel Light Dimmer Splice Pack - 1021 Design 93
A26/B6.7/L9/S13 - Park / Turn Lights Splice Packs
1623/1625/400
A26/B6.7/L9/S13 - Park / Turn Lights Splice Packs 1623/1625/400 Design 94
A26 - Underhood PDM
A26 - Underhood PDM Design 95
B6.7/L9 - Underhood PDM
B6.7/L9 - Underhood PDM Design 96
A26/B6.7/L9 - Air Horn (Highway) W/Hardwired Switch
A26/B6.7/L9 - Air Horn (Highway) W/Hardwired Switch Design 97
A26/B6.7/L9 - Radio
A26/B6.7/L9 - Radio Design 98
A26/B6.7/L9 - Radio w/Bluetooth
A26/B6.7/L9 - Radio w/Bluetooth Design 99
A26/B6.7/L9 - Radio w/Bluetooth without Steering
Wheel Pod
A26/B6.7/L9 - Radio w/Bluetooth without Steering Wheel Pod Design 101
A26/B6.7/L9 - Radio w/Steering Wheel Pod
A26/B6.7/L9 - Radio w/Steering Wheel Pod Design 102
A26/B6.7/L9 - Four Speakers Daycab BT n/QC
A26/B6.7/L9 - Four Speakers Daycab BT n/QC Design 104
A26/B6.7/L9 - Four Speakers Daycab n/BT n/QC
A26/B6.7/L9 - Four Speakers Daycab n/BT n/QC Design 105
A26/B6.7/L9 - Two Speakers Daycab BT n/QC
A26/B6.7/L9 - Two Speakers Daycab BT n/QC Design 106
A26/B6.7/L9 - Two Speakers Daycab n/BT n/QC
A26/B6.7/L9 - Two Speakers Daycab n/BT n/QC Design 107
B6.7 - Speakers: Four Speakers Daycab n/BT w/QC
B6.7 - Speakers:Four Speakers Daycab n/BT w/QC Design 108
B6.7 - Speakers: Two Speakers n/BT w/QC
B6.7 - Speakers:Two Speakers n/BT w/QC Design 109
B6.7 - Speakers: Two Speakers w/BT w/QC
B6.7 - Speakers:Two Speakers w/BT w/QC Design 110
vB6.7 - Speaker: Four Speakers Daycab w/BT w/QC
B6.7 - Speaker:Four Speakers Daycab w/BT w/QC Design 111
L9 - Speakers: Four Speakers Daycab n/BT w/QC
L9 - Speakers:Four Speakers Daycab n/BT w/QC Design 112
L9 - Speakers: Two Speakers n/BT w/QC
L9 - Speakers:Two Speakers n/BT w/QC Design 113
L9 - Speakers: Two Speakers w/BT w/QC
L9 - Speakers:Two Speakers w/BT w/QC Design 114
L9 - Speaker: Four Speakers Daycab w/BT w/QC
L9 - Speaker:Four Speakers Daycab w/BT w/QC Design 115
A26/B6.7/L9 - Auxiliary Power (40A) HSD
A26/B6.7/L9 - Auxiliary Power (40A) HSD Design 116
B6.7 - Dual Auxiliary Power with Interlock
B6.7 - Dual Auxiliary Power with Interlock Design 117
A26 - Backup Alarm (Relay to 5 Pin 08TKC Tailboard
Alarm Plugs In)
A26 - Backup Alarm (Relay to 5 Pin 08TKC Tailboard Alarm Plugs In) Design 118
to Alarm)
A26 - Backup Alarm (Relay to 5 Pin 08TKC Tailboard to Alarm) Design 119
A26 - Backup Alarm (Relay to 5 Pin 08TKC Tailboard.
Alarm Plugs In)
A26 - Backup Alarm (Relay to 5 Pin 08TKC Tailboard. Alarm Plugs In) Design 120
A26 - Backup Alarm (Switch to 5 Pin 08TKC Tailboard
to Alarm)
A26 - Backup Alarm (Switch to 5 Pin 08TKC Tailboard to Alarm) Design 121
A26 - Backup Alarm (08THB & W/ 08NAA)
A26 - Backup Alarm (08THB & W/ 08NAA) Design 122
A26 - Backup Alarm (08WDG & W/ 08NAA)
A26 - Backup Alarm (08WDG & W/ 08NAA) Design 123
A26 - Back-Up Alarm (Automatic) W/O Tailboard
A26 - Back-Up Alarm (Automatic) W/O Tailboard Design 124
A26 - Back-Up Alarm (Automatic) W/ Tailboard)
A26 - Back-Up Alarm (Automatic) W/ Tailboard) Design 125
A26 - Back-Up Alarm (Manual) W/O Tailboard
A26 - Back-Up Alarm (Manual) W/O Tailboard Design 126
A26 - Back-Up Alarm (Manual) W/ Tailboard)
A26 - Back-Up Alarm (Manual) W/ Tailboard) Design 127
A26/B6.7/L9 - Backup Alarm (From Relay to 5 Pin
Daisy Chain to Backup Alarm)
viA26/B6.7/L9 - Backup Alarm (From Relay to 5 Pin Daisy Chain to Backup Alarm)
Design 128
Daisy Chain to Backup Alarm, W/ Extension)
A26/B6.7/L9 - Backup Alarm (From Relay to 5 Pin Daisy Chain to Backup Alarm,
W/ Extension) Design 129
Daisy Chain. Backup Alarm Plugs in)
A26/B6.7/L9 - Backup Alarm (From Relay to 5 Pin Daisy Chain. Backup Alarm
Plugs in) Design 130
Daisy Chain. Backup Alarm Plugs in, W/ Extension)
Plugs in, W/ Extension) Design 131
A26/B6.7/L9 - Back-Up Alarm (Automatic) W/O
Tailboard
A26/B6.7/L9 - Back-Up Alarm (Automatic) W/O Tailboard Design 132
B6.7 - Back-Up Alarm (Automatic) W/O Tailboard
B6.7 - Back-Up Alarm (Automatic) W/O Tailboard Design 133
B6.7 - Back-Up Alarm (Automatic) W/ Tailboard
B6.7 - Back-Up Alarm (Automatic) W/ Tailboard Design 134
B6.7 - Back-Up Alarm (Manual) W/O Tailboard
B6.7 - Back-Up Alarm (Manual) W/O Tailboard Design 135
B6.7 - Back-Up Alarm (Manual) W/ Tailboard
B6.7 - Back-Up Alarm (Manual) W/ Tailboard Design 136
L9 - Back-Up Alarm (Automatic) W/O Tailboard Design 137
L9 - Back-Up Alarm (Automatic) W/ Tailboard
L9 - Back-Up Alarm (Automatic) W/ Tailboard Design 138
L9 - Back-Up Alarm (Manual) W/O Tailboard
L9 - Back-Up Alarm (Manual) W/O Tailboard Design 139
L9 - Back-Up Alarm (Manual) W/ Tailboard
L9 - Back-Up Alarm (Manual) W/ Tailboard Design 141
A26/B6.7/L9 - Banana Plugs Receptacle
A26/B6.7/L9 - Banana Plugs Receptacle Design 143
A26/B6.7/L9 - Surround View (Camera Display, 1
Camera EOF, Prewire)
A26/B6.7/L9 - Surround View (Camera Display, 1 Camera EOF, Prewire)
Design 144
A26/B6.7/L9 - CB Radio - Power Only
A26/B6.7/L9 - CB Radio - Power Only Design 145
A26/B6.7/L9 - CB Radio - Power Only (Single Antenna)
A26/B6.7/L9 - CB Radio - Power Only (Single Antenna) Design 146
A26/B6.7/L9 - Cigar Lighter
viiA26/B6.7/L9 - Cigar Lighter Design 147
A26/B6.7/L9 - Cigar Lighter Aux APO
A26/B6.7/L9 - Cigar Lighter Aux APO Design 148
A26/B6.7/L9 - Forward Auxiliary Power Source (1 APO)
A26/B6.7/L9 - Forward Auxiliary Power Source (1 APO) Design 151
A26/B6.7/L9 - Forward Auxiliary Power Source (2 APO)
A26/B6.7/L9 - Forward Auxiliary Power Source (2 APO) Design 155
A26/B6.7/L9 - Forward Auxiliary Power Source (3 APO)
A26/B6.7/L9 - Forward Auxiliary Power Source (3 APO) Design 161
A26/B6.7/L9 - Forward Auxiliary Power Source (4 APO)
A26/B6.7/L9 - Forward Auxiliary Power Source (4 APO) Design 165
A26/B6.7/L9 - Standard APO
A26/B6.7/L9 - Standard APO Design 166
A26/B6.7/L9 - Standard APO Aux APO
A26/B6.7/L9 - Standard APO Aux APO Design 167
A26/B6.7/L9 - Vehicle Speed Control (Cruise Control)
Multiplex Switch & N/PIM
A26/B6.7/L9 - Vehicle Speed Control (Cruise Control) Multiplex Switch & N/PIM
Design 170
A26/B6.7/L9 - Cruise Control (W/ One Telltale 10 Pin)
A26/B6.7/L9 - Cruise Control (W/ One Telltale 10 Pin) Design 171
A26/B6.7/L9 - Cruise Control (W/ One Telltale 4 Pin)
A26/B6.7/L9 - Cruise Control (W/ One Telltale 4 Pin) Design 173
Multiplex Switch & W/PIM
A26/B6.7/L9 - Vehicle Speed Control (Cruise Control) Multiplex Switch & W/PIM
Design 175
10 Pin
A26/B6.7/L9 - Vehicle Speed Control (Cruise Control) 10 Pin Design 176
A26/B6.7/L9 - Vehicle Speed Control (Cruise Control) 4
Pin
A26/B6.7/L9 - Vehicle Speed Control (Cruise Control) 4 Pin Design 177
(Steering Wheel Controls, No PIM)
A26/B6.7/L9 - Vehicle Speed Control (Cruise Control) (Steering Wheel Controls,
No PIM) Design 178
(Steering Wheel Controls, W/PIM)
W/PIM) Design 179
A26/B6.7/L9 - Door Ajar Reminder (Entry /Exit): 4 Door
A26/B6.7/L9 - Door Ajar Reminder (Entry /Exit):4 Door Design 180
viiiA26/B6.7/L9 - Door Ajar Reminder (Entry/Exit) 2 Door
A26/B6.7/L9 - Door Ajar Reminder (Entry/Exit) 2 Door Design 181
A26/B6.7/L9 - Door Pod Module (2 Door)
A26/B6.7/L9 - Door Pod Module (2 Door) Design 182
A26/B6.7/L9 - Door Pod Module (4 Door)
A26/B6.7/L9 - Door Pod Module (4 Door) Design 183
A26/B6.7/L9 - Mirrors (Heated)
A26/B6.7/L9 - Mirrors (Heated) Design 184
A26/B6.7/L9 - Mirrors (Heat) Switch Pack Actuated
Relay Driven
A26/B6.7/L9 - Mirrors (Heat) Switch Pack Actuated Relay Driven Design 185
A26 - Heated Mirrors (Hood with Door Pods)
A26 - Heated Mirrors (Hood with Door Pods) Design 186
A26 - Heated Mirrors (RT Hood with Door Pods)
A26 - Heated Mirrors (RT Hood with Door Pods) Design 187
A26 - Mirrors (Heat) Switch Pack Actuated includes
Hood Mirrors
A26 - Mirrors (Heat) Switch Pack Actuated includes Hood Mirrors Design 188
A26 - Mirrors (Heat) Switch Pack Actuated includes RT
Hood Mirror
A26 - Mirrors (Heat) Switch Pack Actuated includes RT Hood Mirror Design 189
B6.7 - Heated Mirrors (Hood with Door Pods)
B6.7 - Heated Mirrors (Hood with Door Pods) Design 190
B6.7 - Heated Mirrors (RT Hood with Door Pods)
B6.7 - Heated Mirrors (RT Hood with Door Pods) Design 192
B6.7 - Mirrors (Heat) Switch Pack Actuated includes
Hood Mirrors
B6.7 - Mirrors (Heat) Switch Pack Actuated includes Hood Mirrors Design 196
RT Hood Mirror
B6.7 - Mirrors (Heat) Switch Pack Actuated includes RT Hood Mirror Design 198
L9 - Heated Mirrors (Hood with Door Pods)
L9 - Heated Mirrors (Hood with Door Pods) Design 202
L9 - Heated Mirrors (RT Hood with Door Pods)
L9 - Heated Mirrors (RT Hood with Door Pods) Design 206
L9 - Mirrors (Heat) Switch Pack Actuated includes
Hood Mirrors
L9 - Mirrors (Heat) Switch Pack Actuated includes Hood Mirrors Design 210
L9 - Mirrors (Heat) Switch Pack Actuated includes RT
Hood Mirror
L9 - Mirrors (Heat) Switch Pack Actuated includes RT Hood Mirror Design 214
A26/B6.7/L9 - Power Mirrors (Control Switch Actuated)
ixA26/B6.7/L9 - Power Mirrors (Control Switch Actuated) Design 218
A26 - City Horn (W/ 10PIN Park Brake)
A26 - City Horn (W/ 10PIN Park Brake) Design 220
A26 - City Horn (W/ 10PIN)
A26 - City Horn (W/ 10PIN) Design 222
A26 - City Horn (W/ 4PIN Park Brake)
A26 - City Horn (W/ 4PIN Park Brake) Design 224
A26 - City Horn (W/ 4PIN)
A26 - City Horn (W/ 4PIN) Design 228
B6.7 - City Horn (W/ 10PIN CLK & Park Brake)
B6.7 - City Horn (W/ 10PIN CLK & Park Brake) Design 232
B6.7 - City Horn (W/ 10PIN CLK)
B6.7 - City Horn (W/ 10PIN CLK) Design 235
B6.7 - City Horn (W/ 4PIN CLK & Park Brake)
B6.7 - City Horn (W/ 4PIN CLK & Park Brake) Design 238
B6.7 - City Horn (W/ 4PIN CLK)
B6.7 - City Horn (W/ 4PIN CLK) Design 244
L9 - City Horn (W/ 10PIN CLK & Park Brake)
L9 - City Horn (W/ 10PIN CLK & Park Brake) Design 250
L9 - City Horn (W/ 10PIN CLK)
L9 - City Horn (W/ 10PIN CLK) Design 252
L9 - City Horn (W/ 4PIN CLK & Park Brake)
L9 - City Horn (W/ 4PIN CLK & Park Brake) Design 254
L9 - City Horn (W/ 4PIN CLK)
L9 - City Horn (W/ 4PIN CLK) Design 258
A26 - (Rand Mcnallly) GPS Display
A26 - (Rand Mcnallly) GPS Display Design 262
A26/B6.7/L9 - Heated Windshield
A26/B6.7/L9 - Heated Windshield Design 263
A26/B6.7/L9 - Heated Windshield (W/ DS Heating Grid)
A26/B6.7/L9 - Heated Windshield (W/ DS Heating Grid) Design 264
A26/B6.7/L9 - Multiplexed Switch Pack (Primary
Switch)
A26/B6.7/L9 - Multiplexed Switch Pack (Primary Switch) Design 265
A26/B6.7/L9 - Real Time Clock (RTC) (BCM Controlled)
A26/B6.7/L9 - Real Time Clock (RTC) (BCM Controlled) Design 266
A26 - Remote Keyless Access
A26 - Remote Keyless Access Design 267
B6.7 - Remote Keyless Access
B6.7 - Remote Keyless Access Design 268
xL9 - Remote Keyless Access
L9 - Remote Keyless Access Design 269
A26 - Over The Air Electrical I/O (OnCommand Link /
N2 Module W/ Diagnostic Connector)
A26 - Over The Air Electrical I/O (OnCommand Link / N2 Module W/ Diagnostic
Connector) Design 270
B6.7 - Over The Air Electrical I/O (OnCommand Link /
N2 Module)
B6.7 - Over The Air Electrical I/O (OnCommand Link / N2 Module) Design 271
N2 Module)(2017-2024 B6.7)
B6.7 - Over The Air Electrical I/O (OnCommand Link / N2 Module)(2017-2024
B6.7) Design 272
N2 Module)(2024-2027 B6.7)
B6.7 - Over The Air Electrical I/O (OnCommand Link / N2 Module)(2024-2027
B6.7) Design 273
B6.7/L9 - Over The Air Electrical I/O (OnCommand
Link / N2 Module W/ Diagnostic Connector)
B6.7/L9 - Over The Air Electrical I/O (OnCommand Link / N2 Module W/
Diagnostic Connector) Design 274
Module)
L9 - Over The Air Electrical I/O (OnCommand Link / N2 Module) Design 275
Module)(2017-2024 L9)
L9 - Over The Air Electrical I/O (OnCommand Link / N2 Module)(2017-2024 L9)
Design 276
Module)(2024-2027 L9)
L9 - Over The Air Electrical I/O (OnCommand Link / N2 Module)(2024-2027 L9)
Design 277
A26 - Telematics (PEOPLE NET, DAYCAB)
A26 - Telematics (PEOPLE NET, DAYCAB) Design 278
L9 - Telematics (PEOPLE NET DAYCAB)
L9 - Telematics (PEOPLE NET DAYCAB) Design 279
A26/B6.7/L9 - Theft Deterrent (Grid Controlled)
A26/B6.7/L9 - Theft Deterrent (Grid Controlled) Design 280
A26/B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 - 1
Repeater)
A26/B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater) Design 281
A26/B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 - 2
Repeaters)
A26/B6.7/L9 - Tire Pressure (TPMS) (LDL 2.0 - 2 Repeaters) Design 285
xiTire Pressure (TPMS) (LDL 2.0 AutoLocate - 1
Repeater)(2017 A26)
Tire Pressure (TPMS) (LDL 2.0 AutoLocate - 1 Repeater)(2017 A26) Design 287
Repeater)(2017-2024 L9)
Tire Pressure (TPMS) (LDL 2.0 AutoLocate - 1 Repeater)(2017-2024 L9)
Design 295
Repeater)(2024 B6.7)
Tire Pressure (TPMS) (LDL 2.0 AutoLocate - 1 Repeater)(2024 B6.7) Design 303
Repeater)(2024 L9)
Tire Pressure (TPMS) (LDL 2.0 AutoLocate - 1 Repeater)(2024 L9) Design 311
Repeater)(2024-2027 B6.7)
Tire Pressure (TPMS) (LDL 2.0 AutoLocate - 1 Repeater)(2024-2027 B6.7)
Design 315
Repeater)(2024-2027 L9/S13)
Tire Pressure (TPMS) (LDL 2.0 AutoLocate - 1 Repeater)(2024-2027 L9/S13)
Design 323
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(2017 A26)
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(2017 A26) Design 331
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(2024
B6.7)
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(2024 B6.7) Design 335
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(2024 L9)
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(2024 L9) Design 343
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(2024 S13)
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(2024 S13) Design 347
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(2024-2027
B6.7)
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)(2024-2027 B6.7) Design 351
Tire Pressure (TPMS) (LDL 2.0 - 2 Repeaters)(2017
A26)
Tire Pressure (TPMS) (LDL 2.0 - 2 Repeaters)(2017 A26) Design 355
Tire Pressure (TPMS) (LDL 2.0 - 2 Repeaters)(2024-
2027 S13)
Tire Pressure (TPMS) (LDL 2.0 - 2 Repeaters)(2024-2027 S13) Design 357
TMC 8 PIN - 08XNL
TMC 8 PIN - 08XNL Design 359
A26/B6.7/L9 - Aux Power (USB) - 1 USB A, 1 USB C
A26/B6.7/L9 - Aux Power (USB) - 1 USB A, 1 USB C Design 360
A26/B6.7/L9 - Aux Power (USB) - 2 USB A, 2 USB C
xiiA26/B6.7/L9 - Aux Power (USB) - 2 USB A, 2 USB C Design 365
A26/B6.7/L9 - Aux Power (USB) - 3 USB A, 3 USB C
A26/B6.7/L9 - Aux Power (USB) - 3 USB A, 3 USB C Design 375
A26/B6.7/L9 - One USB
A26/B6.7/L9 - One USB Design 384
A26/B6.7/L9 - Two USB
A26/B6.7/L9 - Two USB Design 385
A26/B6.7/L9 - Vehicle Sleep Mode
A26/B6.7/L9 - Vehicle Sleep Mode Design 387
A26 - 2-Way Radio
A26 - 2-Way Radio Design 388
B6.7 - 2-Way Radio
B6.7 - 2-Way Radio Design 390
L9 - 2-Way Radio
L9 - 2-Way Radio Design 392
B6.7/L9 - DPF Regen Switch Only
B6.7/L9 - DPF Regen Switch Only Design 394
B6.7/L9 - DPF With Bistable Inhibit Switch
B6.7/L9 - DPF With Bistable Inhibit Switch Design 395
B6.7/L9 - DPF With Monostable Inhibit Switch
B6.7/L9 - DPF With Monostable Inhibit Switch Design 396
A26 - Diesel Particulate Filter (DPF) (Regen Switch
Only)
A26 - Diesel Particulate Filter (DPF) (Regen Switch Only) Design 397
A26 - Diesel Particulate Filter (DPF) (With Monostable
Inhibit SW)
A26 - Diesel Particulate Filter (DPF) (With Monostable Inhibit SW) Design 398
A26 - Diesel Particulate Filter (DPF) (W/ Bi-Stable
Inhibit SW)
A26 - Diesel Particulate Filter (DPF) (W/ Bi-Stable Inhibit SW) Design 399
A26 - Selective Catalytic Reduction (SCR)
A26 - Selective Catalytic Reduction (SCR) Design 400
B6.7 - Selective Catalytic Reduction (SCR)
B6.7 - Selective Catalytic Reduction (SCR) Design 407
B6.7 - Selective Catalytic Reduction (SCR): 2024 and
newer models
B6.7 - Selective Catalytic Reduction (SCR):2024 and newer models Design 409
L9 - Selective Catalytic Reduction (SCR)
L9 - Selective Catalytic Reduction (SCR) Design 411
L9 - Selective Catalytic Reduction (SCR): 2024 and
newer models
xiiiL9 - Selective Catalytic Reduction (SCR):2024 and newer models Design 413
A26/B6.7/L9 - Adjustable Engine Speed Control (PTO)
10-pin
A26/B6.7/L9 - Adjustable Engine Speed Control (PTO) 10-pin Design 415
4-pin
A26/B6.7/L9 - Adjustable Engine Speed Control (PTO) 4-pin Design 417
A26/B6.7/L9 - Engine Idle Increment/Decrement
(Steering Wheel Controls)
A26/B6.7/L9 - Engine Idle Increment/Decrement (Steering Wheel Controls)
Design 418
(W/MUX Switch)
A26/B6.7/L9 - Engine Idle Increment/Decrement (W/MUX Switch) Design 419
A26/B6.7/L9 - Engine Speed Control (PTO) W/MUX
Switch
A26/B6.7/L9 - Engine Speed Control (PTO) W/MUX Switch Design 420
A26/B6.7/L9 - Engine Speed Control (PTO) (Steering
Wheel Controls)
A26/B6.7/L9 - Engine Speed Control (PTO) (Steering Wheel Controls) Design 421
A26/B6.7/L9 - Steering Wheel Controls (Body Builder)
A26/B6.7/L9 - Steering Wheel Controls (Body Builder) Design 422
A26 - Auxiliary Air Solenoids Normally Closed
A26 - Auxiliary Air Solenoids Normally Closed Design 423
A26 - Auxillary Air Solenoids Normally Open
A26 - Auxillary Air Solenoids Normally Open Design 424
B6.7 - Auxiliary Air Solenoids (1 Normally Closed)
Option 1
B6.7 - Auxiliary Air Solenoids (1 Normally Closed) Option 1 Design 430
Option 2
B6.7 - Auxiliary Air Solenoids (1 Normally Closed) Option 2 Design 431
Option 3
B6.7 - Auxiliary Air Solenoids (1 Normally Closed) Option 3 Design 434
L9 - Auxiliary Air Solenoids (1 Normally Closed)
L9 - Auxiliary Air Solenoids (1 Normally Closed) Design 437
L9 - Auxillary Air Solenoids Normally Closed
L9 - Auxillary Air Solenoids Normally Closed Design 438
L9 - Four Auxillary Air Solenoids
L9 - Four Auxillary Air Solenoids Design 444
L9 - Three Auxillary Air Solenoids
L9 - Three Auxillary Air Solenoids Design 445
xivA26 - Body Builder - Altec (N/BB & W/Manual XMSN &
W/ INTL Engine)
A26 - Body Builder - Altec (N/BB & W/Manual XMSN & W/ INTL Engine)
Design 448
A26 - Body Builder - Altec (N/BB & W/1K2K Trans)
A26 - Body Builder - Altec (N/BB & W/1K2K Trans) Design 450
A26 - Body Builder - Altec (N/BB & W/3K4K Trans & W/
INTL Engine)
A26 - Body Builder - Altec (N/BB & W/3K4K Trans & W/ INTL Engine) Design 452
A26 - Body Builder - Altec (W/BB & W/Manual Trans &
W/ INTL Engine)
A26 - Body Builder - Altec (W/BB & W/Manual Trans & W/ INTL Engine)
Design 454
A26 - Body Builder - Altec (W/BB & W/1K2K Trans)
A26 - Body Builder - Altec (W/BB & W/1K2K Trans) Design 460
A26 - Body Builder - Altec (W/BB & W/3K4K Trans &
W/ INTL Engine)
A26 - Body Builder - Altec (W/BB & W/3K4K Trans & W/ INTL Engine) Design 466
B6.7 - Body Builder - Altec (N/BB & W/Manual XMSN &
W/ CUMMINS Engine)
B6.7 - Body Builder - Altec (N/BB & W/Manual XMSN & W/ CUMMINS Engine)
Design 472
B6.7 - Body Builder - Altec (N/BB & W/1K2K Trans)
B6.7 - Body Builder - Altec (N/BB & W/1K2K Trans) Design 475
B6.7 - Body Builder - Altec (N/BB & W/3K4K Trans &
W/ CUMMINS Engine)
B6.7 - Body Builder - Altec (N/BB & W/3K4K Trans & W/ CUMMINS Engine)
Design 478
B6.7 - Body Builder - Altec (W/BB & W/Manual Trans &
W/ CUMMINS Engine)
B6.7 - Body Builder - Altec (W/BB & W/Manual Trans & W/ CUMMINS Engine)
Design 481
B6.7 - Body Builder - Altec (W/BB & W/1K2K Trans)
B6.7 - Body Builder - Altec (W/BB & W/1K2K Trans) Design 487
B6.7 - Body Builder - Altec (W/BB & W/3K4K Trans &
W/ CUMMINS Engine)
B6.7 - Body Builder - Altec (W/BB & W/3K4K Trans & W/ CUMMINS Engine)
Design 493
B6.7/L9 - Body Builder - Altec (N/BB & W/3K4K Trans
& W/ INTL Engine)
B6.7/L9 - Body Builder - Altec (N/BB & W/3K4K Trans & W/ INTL Engine)
Design 499
B6.7/L9 - Body Builder - Altec (W/BB & W/3K4K Trans
& W/ INTL Engine)
xvB6.7/L9 - Body Builder - Altec (W/BB & W/3K4K Trans & W/ INTL Engine)
Design 501
L9 - Body Builder - Altec (N/BB & W/Manual XMSN &
W/ CUMMINS Engine)
L9 - Body Builder - Altec (N/BB & W/Manual XMSN & W/ CUMMINS Engine)
Design 506
L9 - Body Builder - Altec (N/BB & W/1K2K Trans)
L9 - Body Builder - Altec (N/BB & W/1K2K Trans) Design 509
L9 - Body Builder - Altec (W/BB & W/Manual Trans &
W/ CUMMINS Engine)
L9 - Body Builder - Altec (W/BB & W/Manual Trans & W/ CUMMINS Engine)
Design 512
L9 - Body Builder - Altec (W/BB & W/1K2K Trans)
L9 - Body Builder - Altec (W/BB & W/1K2K Trans) Design 518
CUMMINS Engine)
L9 - Body Builder - Altec (W/BB & W/3K4K Trans & W/ CUMMINS Engine)
Design 524
L9- Body Builder - Altec (N/BB & W/3K4K Trans & W/
CUMMINS Engine)
L9- Body Builder - Altec (N/BB & W/3K4K Trans & W/ CUMMINS Engine)
Design 530
A26/B6.7/L9 - Body Builder Aux Power (In Cab, BOC,
or EOF)
A26/B6.7/L9 - Body Builder Aux Power (In Cab, BOC, or EOF) Design 533
A26 - Body Builder Lighting - BOC, 08HBX, Automatic
A26 - Body Builder Lighting - BOC, 08HBX, Automatic Design 536
A26 - Body Builder Lighting - BOC, 08HBX, Manual
A26 - Body Builder Lighting - BOC, 08HBX, Manual Design 537
A26 - Body Builder Lighting - (BOC, EOF, In Cab)
(8HAB, 8HAE, 8HAU) (Automatic)
A26 - Body Builder Lighting - (BOC, EOF, In Cab) (8HAB, 8HAE, 8HAU)
(Automatic) Design 538
(8HAB, 8HAE, 8HAU) (Automatic)(Option2)
(Automatic)(Option2) Design 539
(8HAB, 8HAE, 8HAU) (Manual)
A26 - Body Builder Lighting - (BOC, EOF, In Cab) (8HAB, 8HAE, 8HAU) (Manual)
Design 540
A26 - Body Builder Lighting - (8HAA) (Blunt Cut)
A26 - Body Builder Lighting - (8HAA) (Blunt Cut) Design 541
xviB6.7 - Body Builder Lighting - Combined Turn and
Stop Lamps (Automatic)
B6.7 - Body Builder Lighting - Combined Turn and Stop Lamps (Automatic)
Design 542
Stop Lamps (Manual)
B6.7 - Body Builder Lighting - Combined Turn and Stop Lamps (Manual)
Design 545
B6.7 - Body Builder Lighting - Separate Turn and Stop
Lamps (Blunt Cut) Option 1
B6.7 - Body Builder Lighting - Separate Turn and Stop Lamps (Blunt Cut) Option
1 Design 548
Lamps (Blunt Cut) Option 2
2 Design 549
L9 - Body Builder Lighting - Combined Turn and Stop
Lamps (Automatic)
L9 - Body Builder Lighting - Combined Turn and Stop Lamps (Automatic)
Design 550
Lamps (Manual)
L9 - Body Builder Lighting - Combined Turn and Stop Lamps (Manual) Design 553
L9 - Body Builder Lighting - Separate Turn and Stop
L9 - Body Builder Lighting - Separate Turn and Stop Lamps (Blunt Cut) Option 1
Design 559
L9 - Body Builder Lighting - Separate Turn and Stop Lamps (Blunt Cut) Option 2
Design 560
A26 - I/O Expansion
A26 - I/O Expansion Design 561
B6.7 - I/O Expansion
B6.7 - I/O Expansion Design 562
L9 - I/O Expansion
L9 - I/O Expansion Design 563
A26 - Powertrain Body Builder Connector (A26 Engine
MD1 N/Ultrashift TCM)
A26 - Powertrain Body Builder Connector (A26 Engine MD1 N/Ultrashift TCM)
Design 564
MD1 W/Ultrashift TCM)
A26 - Powertrain Body Builder Connector (A26 Engine MD1 W/Ultrashift TCM)
Design 565
xviiB6.7 - Powertrain Body Builder Connector (12XBM)
B6.7 - Powertrain Body Builder Connector (12XBM) Design 567
L9 - Powertrain Body Builder Connector (12XBM)
L9 - Powertrain Body Builder Connector (12XBM) Design 568
A26 - Power Lift Gate
A26 - Power Lift Gate Design 569
B6.7 - Power Lift Gate
B6.7 - Power Lift Gate Design 570
L9 - Power Lift Gate
L9 - Power Lift Gate Design 571
A26 - Remote Power Module Features (Boom and
Outrigger Alert)
A26 - Remote Power Module Features (Boom and Outrigger Alert) Design 572
A26 - Remote Power Module Features (Gate Open and
Body UP)
A26 - Remote Power Module Features (Gate Open and Body UP) Design 573
Rear Alert W/ Auto Trans and Procision)
A26 - Remote Power Module Features (Gate Open and Rear Alert W/ Auto Trans
and Procision) Design 574
Rear Alert W/ Auto Trans)
A26 - Remote Power Module Features (Gate Open and Rear Alert W/ Auto Trans)
Design 575
Rear Alert W/ Manual and Ulltrashift+)
A26 - Remote Power Module Features (Gate Open and Rear Alert W/ Manual and
Ulltrashift+) Design 576
A26 - DLB - Remote Power Modules (1 RPM n/ Switch
Packs)
A26 - DLB - Remote Power Modules (1 RPM n/ Switch Packs) Design 577
A26 - DLB - Remote Power Modules (1 RPM w/ Switch
Packs)
A26 - DLB - Remote Power Modules (1 RPM w/ Switch Packs) Design 580
A26 - DLB - Remote Power Modules (2 RPM n/ Switch
Pack)
A26 - DLB - Remote Power Modules (2 RPM n/ Switch Pack) Design 583
Pack)Option2
A26 - DLB - Remote Power Modules (2 RPM n/ Switch Pack)Option2 Design 586
A26 - DLB - Remote Power Modules (2 RPM w/ Switch
Packs)
A26 - DLB - Remote Power Modules (2 RPM w/ Switch Packs) Design 587
xviiiA26 - DLB - Remote Power Modules (2 RPM w/ Switch
Packs)Option2
A26 - DLB - Remote Power Modules (2 RPM w/ Switch Packs)Option2 Design588
A26 - DLB - Remote Power Modules (3 RPM w/ Swtich
Packs)
A26 - DLB - Remote Power Modules (3 RPM w/ Swtich Packs) Design 591
Packs)Option2
A26 - DLB - Remote Power Modules (3 RPM w/ Swtich Packs)Option2 Design592
A26 - DLB - Remote Power Module (3 RPM n/Switch
Pack)
A26 - DLB - Remote Power Module (3 RPM n/Switch Pack) Design 594
Pack)Option2
A26 - DLB - Remote Power Module (3 RPM n/Switch Pack)Option2 Design 595
B6.7 - DLB - Remote Power Modules (1 RPM n/ Switch
Packs)
B6.7 - DLB - Remote Power Modules (1 RPM n/ Switch Packs) Design 597
B6.7 - DLB - Remote Power Modules (1 RPM w/ Switch
Packs)
B6.7 - DLB - Remote Power Modules (1 RPM w/ Switch Packs) Design 600
B6.7 - DLB - Remote Power Modules (2 RPM n/ Switch
Pack)
B6.7 - DLB - Remote Power Modules (2 RPM n/ Switch Pack) Design 603
B6.7 - DLB - Remote Power Modules (2 RPM w/ Switch
Packs)
B6.7 - DLB - Remote Power Modules (2 RPM w/ Switch Packs) Design 607
B6.7 - DLB - Remote Power Modules (3 RPM w/ Swtich
Packs)
B6.7 - DLB - Remote Power Modules (3 RPM w/ Swtich Packs) Design 611
B6.7 - DLB - Remote Power Module (3 RPM n/Switch
Pack)
B6.7 - DLB - Remote Power Module (3 RPM n/Switch Pack) Design 612
L9 - DLB - Remote Power Modules (1 RPM n/ Switch
Packs)
L9 - DLB - Remote Power Modules (1 RPM n/ Switch Packs) Design 613
L9 - DLB - Remote Power Modules (1 RPM w/ Switch
Packs)
L9 - DLB - Remote Power Modules (1 RPM w/ Switch Packs) Design 616
L9 - DLB - Remote Power Modules (2 RPM n/ Switch
Pack)
L9 - DLB - Remote Power Modules (2 RPM n/ Switch Pack) Design 619
xixL9 - DLB - Remote Power Modules (2 RPM w/ Switch
Packs)
L9 - DLB - Remote Power Modules (2 RPM w/ Switch Packs) Design 623
L9 - DLB - Remote Power Modules (3 RPM w/ Swtich
Packs)
L9 - DLB - Remote Power Modules (3 RPM w/ Swtich Packs) Design 627
L9 - DLB - Remote Power Module (3 RPM n/Switch
Pack)
L9 - DLB - Remote Power Module (3 RPM n/Switch Pack) Design 628
A26 - Remote Start/Stop
A26 - Remote Start/Stop Design 629
B6.7 - Remote Start/Stop
B6.7 - Remote Start/Stop Design 630
B6.7 - Remote Start/Stop w/ Emergency Pump
B6.7 - Remote Start/Stop w/ Emergency Pump Design 631
L9 - Remote Start/Stop
L9 - Remote Start/Stop Design 632
L9 - Remote Start/Stop w/ Emergency Pump
L9 - Remote Start/Stop w/ Emergency Pump Design 633
A26 -Transmissions Electrical I/O (Eaton Ultrashift)
A26 -Transmissions Electrical I/O (Eaton Ultrashift) Design 634
A26 - Transmission I/O (Allison 3K with Body Builder)
A26 - Transmission I/O (Allison 3K with Body Builder) Design 635
A26 - Transmission I/O (Allison 4K with Body Builder)
A26 - Transmission I/O (Allison 4K with Body Builder) Design 638
A26 - Transmission I/O (Allison 4700 with Body
Builder)
A26 - Transmission I/O (Allison 4700 with Body Builder) Design 641
B6.7 - Transmission I/O (Allison Gen 6 1K/2K W/ Body
Builder)
B6.7 - Transmission I/O (Allison Gen 6 1K/2K W/ Body Builder) Design 644
B6.7 - Transmission I/O (Allison Gen 6 3K W/ Body
Builder)
B6.7 - Transmission I/O (Allison Gen 6 3K W/ Body Builder) Design 648
L9 - Transmission I/O (Allison Gen 6 4K W/ Body
Builder)
L9 - Transmission I/O (Allison Gen 6 4K W/ Body Builder) Design 654
L9 - Transmission I/O (Allison Gen 6 4700 W/ Body
Builder)
L9 - Transmission I/O (Allison Gen 6 4700 W/ Body Builder) Design 663
L9 - Transmission I/O (Allison 3K with Body Builder) -
13WUC
L9 - Transmission I/O (Allison 3K with Body Builder) - 13WUC Design 672
xxL9 - Transmission I/O (Allison 4700 W/ Body Builder)
L9 - Transmission I/O (Allison 4700 W/ Body Builder) Design 673
A26 - Transmission Power Take Off (Active Low
Feedback)
A26 - Transmission Power Take Off (Active Low Feedback) Design 682
A26 - Transmission Power Take Off (Dual PTO W/ 42
Parameters & W/ Auto, AMT Trans)
A26 - Transmission Power Take Off (Dual PTO W/ 42 Parameters & W/ Auto,
AMT Trans) Design 683
Parameters & W/ Manual Trans)
A26 - Transmission Power Take Off (Dual PTO W/ 42 Parameters & W/ Manual
Trans) Design 684
A26 - Transmission Power Take Off (Single PTO W/42
A26 - Transmission Power Take Off (Single PTO W/42 Parameters & W/ Auto,
AMT Trans) Design 685
Parameters & W/ Auto, AMT Trans)(Option2)
AMT Trans)(Option2) Design 686
RPM W/AUTO TRANS,AMT)
A26 - Transmission Power Take Off (Single PTO W/ RPM W/AUTO TRANS,AMT)
Design 687
RPM W/AUTO TRANS,AMT)(Option2)
TRANS,AMT)(Option2) Design 688
RPM & W/ MANL TRANS)
A26 - Transmission Power Take Off (Single PTO W/ RPM & W/ MANL TRANS)
Design 689
A26 - Transmission Power Take Off (Single PTO W/ 42
Parameters & W/ Manl Trans)
A26 - Transmission Power Take Off (Single PTO W/ 42 Parameters & W/ Manl
Trans) Design 690
A26 - Transmission Power Take Off (XFER PTO
W/Auto Trans )
A26 - Transmission Power Take Off (XFER PTO W/Auto Trans ) Design 691
W/Auto Trans )(Option2)
A26 - Transmission Power Take Off (XFER PTO W/Auto Trans )(Option2)
Design 692
Manual Trans )
xxiA26 - Transmission Power Take Off (XFER PTO W/ Manual Trans ) Design 693
A26 - Transmission Power Take Off (60AKG)
A26 - Transmission Power Take Off (60AKG) Design 694
B6.7 - Transmission Power Take Off 60AKG
B6.7 - Transmission Power Take Off 60AKG Design 695
B6.7 - Transmission Power Take Off (Auto Trans
Single PTO w/21 Parameters)
B6.7 - Transmission Power Take Off (Auto Trans Single PTO w/21 Parameters)
Design 696
B6.7 - Transmission Power Take Off (Manual Trans
B6.7 - Transmission Power Take Off (Manual Trans Single PTO w/21
Parameters) Design 697
B6.7 - Transmission Power Take Off (Single Input
configurable pull up or pull down)
B6.7 - Transmission Power Take Off (Single Input configurable pull up or pull
down) Design 698
L9 - Transmission Power Take Off (Auto Trans Single
L9 - Transmission Power Take Off (Auto Trans Single PTO w/21 Parameters)
Design 699
L9 - Transmission Power Take Off (Auto Trans with
Lectradrive)
L9 - Transmission Power Take Off (Auto Trans with Lectradrive) Design 700
L9 - Transmission Power Take Off (Lectrashift PTO
with Manual Trans)
L9 - Transmission Power Take Off (Lectrashift PTO with Manual Trans)
Design 701
L9 - Transmission Power Take Off (Manual Trans
L9 - Transmission Power Take Off (Manual Trans Single PTO w/21 Parameters)
Design 702
L9 - Transmission Power Take Off (Single Input
L9 - Transmission Power Take Off (Single Input configurable pull up or pull down)
Design 703
L9 - Transmission Power Take Off (Single PTO W/
RPM and Auto Trans)
L9 - Transmission Power Take Off (Single PTO W/ RPM and Auto Trans)
Design 704
RPM and Manual Trans)
L9 - Transmission Power Take Off (Single PTO W/ RPM and Manual Trans)
Design 705
xxiiB6.7 - Brake Switch
B6.7 - Brake Switch Design 706
L9 - Brake Switch
L9 - Brake Switch Design 707
A26 - Service Brake Switch (Multiple Service Brake
Switch W/ Redundant Switch)
A26 - Service Brake Switch (Multiple Service Brake Switch W/ Redundant Switch)
Design 708
A26 - Service Brake Switch(Multiple Brake Switch
N/Redundant Brake Switch)
A26 - Service Brake Switch(Multiple Brake Switch N/Redundant Brake Switch)
Design 709
A26 - Rightside Air Dryer
A26 - Rightside Air Dryer Design 710
A26/B6.7/L9 - Air Dryer (Single)
A26/B6.7/L9 - Air Dryer (Single) Design 721
B6.7 - RIGHTSIDE AIR DRYER
B6.7 - RIGHTSIDE AIR DRYER Design 736
L9 - RIGHTSIDE AIR DRYER
L9 - RIGHTSIDE AIR DRYER Design 742
A26 - Drain Valve Heater
A26 - Drain Valve Heater Design 753
B6.7 - Drain Valve Heater
B6.7 - Drain Valve Heater Design 763
L9 - Drain Valve Heater
L9 - Drain Valve Heater Design 770
A26 - Antilock Brake System (ABS) Bendix
A26 - Antilock Brake System (ABS) Bendix Design 779
A26 - Antilock Brake System (ABS)-Wabco 4 Channel
Implementation
A26 - Antilock Brake System (ABS)-Wabco 4 Channel Implementation Design 782
B6.7 - Antilock Brake System (ABS) BENDIX 4
Channel Implemenation
B6.7 - Antilock Brake System (ABS) BENDIX 4 Channel Implemenation
Design 783
L9 - Antilock Brake System (ABS) BENDIX 4 Channel
Implemenation
L9 - Antilock Brake System (ABS) BENDIX 4 Channel Implemenation Design 786
L9 - Antilock Brake System (ABS) Bendix 6 Channel
Implementation
L9 - Antilock Brake System (ABS) Bendix 6 Channel Implementation Design 787
L9 - Antilock Brake System (ABS) Wabco 4 Channel
Implementation
L9 - Antilock Brake System (ABS) Wabco 4 Channel Implementation Design 796
xxiiiA26 - Park Brake Control (Monitoring)(GEN IV BCM)
A26 - Park Brake Control (Monitoring)(GEN IV BCM) Design 797
A26/B6.7/L9 - Park Brake Controls (Air Chassis Park
Brake)
A26/B6.7/L9 - Park Brake Controls (Air Chassis Park Brake) Design 798
A26/B6.7/L9 - Park Brake Controls (Straight Truck)
Intellipark
A26/B6.7/L9 - Park Brake Controls (Straight Truck) Intellipark Design 799
A26/B6.7/L9 - Park Brake Controls (Tractor) Intellipark
A26/B6.7/L9 - Park Brake Controls (Tractor) Intellipark Design 800
B6.7 - Park Brake Controls (Monitoring) (Door Switch
City Horn)
B6.7 - Park Brake Controls (Monitoring) (Door Switch City Horn) Design 802
L9 - Park Brake Controls (Monitoring) (Door Switch
City Horn)
L9 - Park Brake Controls (Monitoring) (Door Switch City Horn) Design 803
L9 - Park Brake Control (Monitoring)(GEN IV BCM)
L9 - Park Brake Control (Monitoring)(GEN IV BCM) Design 804
A26 - Bendix Tractor or Towing Truck N/ Air SUSP
J1939 Driven Lamp
A26 - Bendix Tractor or Towing Truck N/ Air SUSP J1939 Driven Lamp
Design 805
A26 - Bendix Tractor or Towing Truck W/ Air SUSP
J1939 Driven Lamp
A26 - Bendix Tractor or Towing Truck W/ Air SUSP J1939 Driven Lamp
Design 809
A26 - Stability Control (Bendix Straight Truck J1939
Driven Lamp)
A26 - Stability Control (Bendix Straight Truck J1939 Driven Lamp) Design 813
B6.7 - Stability Control (Bendix Straight Truck J1939
Driven Lamp)
B6.7 - Stability Control (Bendix Straight Truck J1939 Driven Lamp) Design 817
L9 - Bendix Tractor or Towing Truck W/ Air SUSP
J1939 Driven Lamp
L9 - Bendix Tractor or Towing Truck W/ Air SUSP J1939 Driven Lamp Design 821
L9 - Stability Control (Bendix Straight Truck J1939
Driven Lamp)
L9 - Stability Control (Bendix Straight Truck J1939 Driven Lamp) Design 823
A26 - Traction Control (Bendix)
A26 - Traction Control (Bendix) Design 827
B6.7 - Traction Control (Bendix)
B6.7 - Traction Control (Bendix) Design 829
L9 - Traction Control (Bendix)
L9 - Traction Control (Bendix) Design 831
xxivA26/B6.7/L9 - Adaptive Cruise Control (Bendix -
Fusion 2.0 N/ Safety Direct Conn & W/ Reg Speakers)
A26/B6.7/L9 - Adaptive Cruise Control (Bendix - Fusion 2.0 N/ Safety Direct Conn
& W/ Reg Speakers) Design 832
Fusion 2.0 & N/ Safety Direct & Reg Speakers)
A26/B6.7/L9 - Adaptive Cruise Control (Bendix - Fusion 2.0 & N/ Safety Direct &
Reg Speakers) Design 834
A26/B6.7/L9 - A26 - Adaptive Cruise Control w/o
Display (Bendix)
A26/B6.7/L9 - A26 - Adaptive Cruise Control w/o Display (Bendix) Design 835
B6.7/L9 - Oncoming Detection (Fusion 3.0)
B6.7/L9 - Oncoming Detection (Fusion 3.0) Design 836
A26/B6.7/L9 - Camera Event Recorder N/Safety Direct
Cable
A26/B6.7/L9 - Camera Event Recorder N/Safety Direct Cable Design 837
A26 - Air Filter Flow Restriction Monitoring
A26 - Air Filter Flow Restriction Monitoring Design 838
A26/B6.7/L9 - Engine Block Heater
A26/B6.7/L9 - Engine Block Heater Design 839
A26/B6.7/L9 - Engine Fuel and Block Heaters
(Purchased Assembly)
A26/B6.7/L9 - Engine Fuel and Block Heaters (Purchased Assembly) Design 840
A26/B6.7/L9 - Engine Oil and Block Heaters
A26/B6.7/L9 - Engine Oil and Block Heaters (Purchased Assembly) Design 841
A26/B6.7/L9 - Engine Oil Fuel and Block Heaters
A26/B6.7/L9 - Engine Oil Fuel and Block Heaters Design 842
A26 - Engine Brake Mux Switch
A26 - Engine Brake Mux Switch Design 843
A26 - Engine Brake W/ Stalk Shifter
A26 - Engine Brake W/ Stalk Shifter Design 844
B6.7/L9 - Engine Brake Mux Switch
B6.7/L9 - Engine Brake Mux Switch Design 845
B6.7/L9 - Engine Brake W/ Stalk Shifter
B6.7/L9 - Engine Brake W/ Stalk Shifter Design 846
A26 - Coolant Level Monitoring (No CLA Module)
A26 - Coolant Level Monitoring (No CLA Module) Design 847
B6.7 - Coolant Level Monitoring (No CLA Module)
B6.7 - Coolant Level Monitoring (No CLA Module) Design 848
(2024 & Newer Models)
xxvB6.7 - Coolant Level Monitoring (No CLA Module) (2024 & Newer Models)
Design 849
B6.7 - Coolant Level Monitoring (No Coolant Module)
B6.7 - Coolant Level Monitoring (No Coolant Module) Design 850
L9 - Coolant Level Monitoring (No CLA Module)
L9 - Coolant Level Monitoring (No CLA Module) Design 851
L9 - Coolant Level Monitoring (No CLA Module) (2024
& Newer Models)
L9 - Coolant Level Monitoring (No CLA Module) (2024 & Newer Models)
Design 852
L9 - Coolant Level Monitoring (No Coolant Module)
L9 - Coolant Level Monitoring (No Coolant Module) Design 853
B6.7 - Coolant Level Monitoring (With Coolant Module)
B6.7 - Coolant Level Monitoring (With Coolant Module) Design 854
L9 - Coolant Level Monitoring (With Coolant Module)
L9 - Coolant Level Monitoring (With Coolant Module) Design 855
A26 - Cooling Fan Control (Fan Override,
International)
A26 - Cooling Fan Control (Fan Override, International) Design 856
A26 - Cooling Fan Control (No Fan Override,
International)
A26 - Cooling Fan Control (No Fan Override, International) Design 857
A26 _ Cooling Fan Control (Fan Override,
International)
A26 _ Cooling Fan Control (Fan Override, International) Design 858
B6.7 - Cooling Fan Control (Fan Override, Cummins)
B6.7 - Cooling Fan Control (Fan Override, Cummins) Design 859
B6.7 - Cooling Fan Control (Fan Override, Cummins):
B6.7 - Cooling Fan Control (Fan Override, Cummins):2024 and newer models
Design 860
B6.7 - Cooling Fan Control (No Fan Override,
Cummins)
B6.7 - Cooling Fan Control (No Fan Override, Cummins) Design 861
Cummins): 2024 and newer models
B6.7 - Cooling Fan Control (No Fan Override, Cummins):2024 and newer models
Design 862
L9 - Cooling Fan Control (Fan Override, Cummins)
L9 - Cooling Fan Control (Fan Override, Cummins) Design 863
L9 - Cooling Fan Control (Fan Override, Cummins):
L9 - Cooling Fan Control (Fan Override, Cummins):2024 and newer models
Design 864
xxviL9 - Cooling Fan Control (No Fan Override, Cummins)
L9 - Cooling Fan Control (No Fan Override, Cummins) Design 865
L9 - Cooling Fan Control (No Fan Override, Cummins):
L9 - Cooling Fan Control (No Fan Override, Cummins):2024 and newer models
Design 866
A26 - Engine Ramp Up (60AJA W/ A26 Engine W/
Automatic Transmission, AMT)
A26 - Engine Ramp Up (60AJA W/ A26 Engine W/ Automatic Transmission, AMT)
Design 867
A26 - Engine Ramp Up (60AJA W/ Cummins W/
AUTO,AMT)
A26 - Engine Ramp Up (60AJA W/ Cummins W/ AUTO,AMT) Design 868
A26 - Engine Ramp Up (60AJE,60AJJ W/A26 W/
AUTO,AMT)
A26 - Engine Ramp Up (60AJE,60AJJ W/A26 W/ AUTO,AMT) Design 869
A26 - Engine Ramp Up (60AJE,60AJJ W/ CUMMINS W/
AUTO, AMT)
A26 - Engine Ramp Up (60AJE,60AJJ W/ CUMMINS W/ AUTO, AMT) Design 870
A26 - Engine Ramp Up (60AJG W/A26 W/ AUTO OR
AMT)
A26 - Engine Ramp Up (60AJG W/A26 W/ AUTO OR AMT) Design 871
A26 - Engine Ramp Up (60AJG W/CUMMINS W/ AUTO,
AMT)
A26 - Engine Ramp Up (60AJG W/CUMMINS W/ AUTO, AMT) Design 872
A26 - Engine Ramp Up (60AJH W/ AUTO,AMT)
A26 - Engine Ramp Up (60AJH W/ AUTO,AMT) Design 873
B6.7/L9 - Engine Ramp UP (60AJA W/Cummins W/
Manual Trans)
B6.7/L9 - Engine Ramp UP (60AJA W/Cummins W/ Manual Trans) Design 874
B6.7/L9 - ENGINE RAMP UP (60AJE,60AJJ W/
CUMMINS W/ MANUAL)
B6.7/L9 - ENGINE RAMP UP (60AJE,60AJJ W/ CUMMINS W/ MANUAL)
Design 875
B6.7/L9 - ENGINE RAMP UP (60AJG W/CUMMINS W/
MANUAL)
B6.7/L9 - ENGINE RAMP UP (60AJG W/CUMMINS W/ MANUAL) Design 876
A26 - Exhaust Brake
A26 - Exhaust Brake Design 877
B6.7/L9 - Exhaust Brake (Cummins)
B6.7/L9 - Exhaust Brake (Cummins) Design 878
A26 - Snow Valve Control
A26 - Snow Valve Control Design 879
xxviiA26/B6.7/L9 - Snow Valve Control
A26/B6.7/L9 - Snow Valve Control Design 881
B6.7 - Snow Valve Control
B6.7 - Snow Valve Control Design 882
L9 - Snow Valve Control Design 884
A26 - Starting Aid (Flame Start W/MD1 ECM)
A26 - Starting Aid (Flame Start W/MD1 ECM) Design 886
B6.7 - Starting Aid (Grid Heater)
B6.7 - Starting Aid (Grid Heater) Design 887
B6.7 - Starting Aid (Grid Heater) - 2024 and Newer
Models
B6.7 - Starting Aid (Grid Heater) - 2024 and Newer Models Design 888
L9 - Starting Aid (Grid Heater)
L9 - Starting Aid (Grid Heater) Design 889
L9 - Starting Aid (Grid Heater) - 2024 and Newer
Models
L9 - Starting Aid (Grid Heater) - 2024 and Newer Models Design 890
A26- Vehicle Acceleration (Wired to the ECM)
A26- Vehicle Acceleration (Wired to the ECM) Design 892
B6.7 - Vehicle Acceleration (w/ Two PWR Two GND &
Two STS)
B6.7 - Vehicle Acceleration (w/ Two PWR Two GND & Two STS) Design 893
L9 - Vehicle Acceleration (w/ Two PWR Two GND &
Two STS)
L9 - Vehicle Acceleration (w/ Two PWR Two GND & Two STS) Design 894
A26 - Engine Electrical I/O (24-Pin/3-Pin Vehicle
Interface Connector)
A26 - Engine Electrical I/O (24-Pin/3-Pin Vehicle Interface Connector) Design 895
A26/B6.7/L9 - Alternate Flashing (Wig Wag) - Park
Brake disables High Beams
A26/B6.7/L9 - Alternate Flashing (Wig Wag) - Park Brake disables High Beams
Design 897
Brake disables Wig Wag
A26/B6.7/L9 - Alternate Flashing (Wig Wag) - Park Brake disables Wig Wag
Design 898
A26/B6.7/L9 - Automatic Lighting - Dual Sensor
Twilight/Solar
A26/B6.7/L9 - Automatic Lighting - Dual Sensor Twilight/Solar Design 899
A26/B6.7/L9 - Automatic Lighting - Single Sensor
Twilight
A26/B6.7/L9 - Automatic Lighting - Single Sensor Twilight Design 901
xxviiiA26 - Backup Lights (Dual Daisy Reverse Light)
Eaton/Manual Trans
A26 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans Design 903
Eaton/Manual Trans -
A26 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans - Design 904
A26 - Backup Lights (Dual Daisy with extension)
Eaton/Manual Trans
A26 - Backup Lights (Dual Daisy with extension) Eaton/Manual Trans Design 905
Eaton/Manual TransA26 - Backup Lights (Dual Daisy with extension) Eaton/Manual Trans- Design 906
A26 - Backup Lights (Dual Reverse Light)
Eaton/Manual Trans
A26 - Backup Lights (Dual Reverse Light) Eaton/Manual Trans Design 907
A26 - Backup Light (Dual Daisy Reverse LT)Allison/ZF
Trans
A26 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans Design 908
TransA26 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans- Design 909
A26 - Backup Light (Dual Daisy Reverse LT) Yukon
AMT
A26 - Backup Light (Dual Daisy Reverse LT) Yukon AMT Design 911
A26 - Backup Light (Dual Daisy with
extension)Allison/ZF Trans
A26 - Backup Light (Dual Daisy with extension)Allison/ZF Trans Design 912
extension)Allison/ZF TransA26 - Backup Light (Dual Daisy with extension)Allison/ZF Trans- Design 913
A26 - Backup Light (Dual Daisy with extension)(HV,
HX) Yukon AMT
A26 - Backup Light (Dual Daisy with extension)(HV, HX) Yukon AMT Design 914
A26 - Backup Light (Dual Reverse Light with
extension) (HV) Yukon AMT
A26 - Backup Light (Dual Reverse Light with extension) (HV) Yukon AMT
Design 915
A26 - Backup Light (Dual Reverse Light)Allison/ZF
Trans
A26 - Backup Light (Dual Reverse Light)Allison/ZF Trans Design 916
A26 - Backup Light (Dual Reverse Light) (HV) Yukon
AMT
A26 - Backup Light (Dual Reverse Light) (HV) Yukon AMT Design 917
xxixA26/B6.7/L9 - Backup Light (Dual Daisy with
extension) Yukon AMT
A26/B6.7/L9 - Backup Light (Dual Daisy with extension) Yukon AMT Design 918
B6.7 - Backup Lights (Dual Daisy Reverse Light)
Eaton/Manual Trans
B6.7 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans Design 919
Eaton/Manual TransB6.7 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans- Design 920
B6.7 - Backup Lights (Dual Daisy with extension)
Eaton/Manual Trans
B6.7 - Backup Lights (Dual Daisy with extension) Eaton/Manual Trans Design 921
B6.7 - Backup Lights (Dual Reverse Light)
Eaton/Manual Trans
B6.7 - Backup Lights (Dual Reverse Light) Eaton/Manual Trans Design 922
B6.7 - Backup Light (Dual Daisy Reverse LT)Allison/ZF
Trans
B6.7 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans Design 923
Trans 1K/2K
B6.7 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans 1K/2K Design 925
Trans 3K/4K
B6.7 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans 3K/4K Design 926
B6.7 - Backup Light (Dual Daisy with
B6.7 - Backup Light (Dual Daisy with extension)Allison/ZF Trans Design 928
B6.7 - Backup Light (Dual Reverse Light)Allison/ZF
Trans 1K/2K
B6.7 - Backup Light (Dual Reverse Light)Allison/ZF Trans 1K/2K Design 929
Trans 3K/4K
B6.7 - Backup Light (Dual Reverse Light)Allison/ZF Trans 3K/4K Design 930
L9 - Backup Lights (Dual Daisy Reverse Light)
Eaton/Manual Trans
L9 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans Design 932
Eaton/Manual TransL9 - Backup Lights (Dual Daisy Reverse Light) Eaton/Manual Trans- Design 934
L9 - Backup Lights (Dual Daisy with extension)
Eaton/Manual Trans
L9 - Backup Lights (Dual Daisy with extension) Eaton/Manual Trans Design 935
xxxL9 - Backup Lights (Dual Reverse Light) Eaton/Manual
Trans
L9 - Backup Lights (Dual Reverse Light) Eaton/Manual Trans Design 936
L9 - Backup Light (Dual Daisy Reverse
L9 - Backup Light (Dual Daisy Reverse Light)Allison/ZF Trans 3K/4K Design 938
L9 - Backup Light (Dual Daisy Reverse LT)Allison/ZF
Trans
L9 - Backup Light (Dual Daisy Reverse LT)Allison/ZF Trans Design 940
L9 - Backup Light (Dual Daisy with extension)Allison/ZF Trans Design 942
A26 - Backup Lights (Reverse Lights) (Crossmember
Dual STT N/Back Up) Allison Trans
A26 - Backup Lights (Reverse Lights) (Crossmember Dual STT N/Back Up)
Allison Trans Design 943
Dual STT N/Back Up) Eaton/Manual Trans
Eaton/Manual Trans Design 944
Dual STT N/Back Up) Endurant/EndurantXD Trans
Endurant/EndurantXD Trans Design 945
A26 - Backup Lights (Single Reverse Lights)
Eaton/Manual Trans
A26 - Backup Lights (Single Reverse Lights) Eaton/Manual Trans Design 946
Eaton/Manual Transmission
A26 - Backup Lights (Single Reverse Lights) Eaton/Manual Transmission
Design 947
A26 - Backup Light (Single Reverse Light)Allison
A26 - Backup Light (Single Reverse Light)Allison Design 948
A26 - Backup Light (Single Reverse Light) W/Less
Power Module W/ Allison
A26 - Backup Light (Single Reverse Light) W/Less Power Module W/ Allison
Design 949
Power Module W/ AllisonA26 - Backup Light (Single Reverse Light) W/Less Power Module W/ AllisonDesign 950
A26 - Backup Light (Single Reverse Light) (HV)
W/Less Power Module W/Yukon AMT
A26 - Backup Light (Single Reverse Light) (HV) W/Less Power Module W/Yukon
AMT Design 951
xxxiA26 - Backup Light (Single Reverse Light) (HV) Yukon
AMT (Option 1)
A26 - Backup Light (Single Reverse Light) (HV) Yukon AMT (Option 1) Design952
AMT (Option 2)
A26 - Backup Light (Single Reverse Light) (HV) Yukon AMT (Option 2) Design953
A26 - Back Up Lights (Reverse) W/ Less Power
Module W/Eaton/ Manual
A26 - Back Up Lights (Reverse) W/ Less Power Module W/Eaton/ Manual
Design 954
Module W/Eaton/ ManualA26 - Back Up Lights (Reverse) W/ Less Power Module W/Eaton/ ManualDesign 955
A26/B6.7/L9 - Backup Lights (Reverse Lights)
A26/B6.7/L9 - Backup Lights (Reverse Lights) (Crossmember Dual STT N/Back
Up) Endurant/EndurantXD Trans Design 956
A26/B6.7/L9 - Backup Light (Single Reverse Light)
A26/B6.7/L9 - Backup Light (Single Reverse Light) W/Less Power Module
W/Yukon AMT Design 957
B6.7 - Backup Lights (Reverse Lights) (Crossmember
B6.7 - Backup Lights (Reverse Lights) (Crossmember Dual STT N/Back Up)
Allison Trans Design 958
Eaton/Manual Trans Design 959
B6.7 - Backup Lights (Single Reverse Lights)
Eaton/Manual Trans Option 1
B6.7 - Backup Lights (Single Reverse Lights) Eaton/Manual Trans Option 1
Design 960
Eaton/Manual Trans Option 2
B6.7 - Backup Lights (Single Reverse Lights) Eaton/Manual Trans Option 2
Design 961
B6.7 - Backup Lights (Single Reverse Light)
Eaton/Manual Trans
B6.7 - Backup Lights (Single Reverse Light) Eaton/Manual Trans Design 962
B6.7 - Backup Light (Single Reverse Light) Allison
1K/2K Option 1
B6.7 - Backup Light (Single Reverse Light) Allison 1K/2K Option 1 Design 963
xxxiiB6.7 - Backup Light (Single Reverse Light) Allison
1K/2K Option 2
B6.7 - Backup Light (Single Reverse Light) Allison 1K/2K Option 2 Design 964
1K/2K Option 3
B6.7 - Backup Light (Single Reverse Light) Allison 1K/2K Option 3 Design 965
3K/4K Option 1
B6.7 - Backup Light (Single Reverse Light) Allison 3K/4K Option 1 Design 966
3K/4K Option 2
B6.7 - Backup Light (Single Reverse Light) Allison 3K/4K Option 2 Design 968
3K/4K Option 3
B6.7 - Backup Light (Single Reverse Light) Allison 3K/4K Option 3 Design 970
B6.7 - Backup Light (Single Reverse Light) W/Less
B6.7 - Backup Light (Single Reverse Light) W/Less Power Module W/ Allison
Design 972
B6.7 - Back Up Lights (Reverse) W/ Less Power
B6.7 - Back Up Lights (Reverse) W/ Less Power Module W/Eaton/ Manual
Design 973
L9 - Backup Lights (Reverse Lights) (Crossmember Dual STT N/Back Up) Allison
Trans Design 974
Eaton/Manual Trans Design 975
L9 - Backup Lights (Single Reverse Light)
L9 - Backup Lights (Single Reverse Light) Eaton/Manual Trans Option 1
Design 976
L9 - Backup Lights (Single Reverse Light) Eaton/Manual Trans Option 2
Design 978
Eaton/Manual Trans Option 3
L9 - Backup Lights (Single Reverse Light) Eaton/Manual Trans Option 3
Design 980
Eaton/Manual Trans Option 4
L9 - Backup Lights (Single Reverse Light) Eaton/Manual Trans Option 4
Design 982
xxxiiiL9 - Backup Light (Single Reverse Light)Allison
L9 - Backup Light (Single Reverse Light)Allison Design 984
L9 - Backup Light (Single Reverse Light) Allison
3K/4K Option 1
L9 - Backup Light (Single Reverse Light) Allison 3K/4K Option 1 Design 986
3K/4K Option 2
L9 - Backup Light (Single Reverse Light) Allison 3K/4K Option 2 Design 988
3K/4K Option 3
L9 - Backup Light (Single Reverse Light) Allison 3K/4K Option 3 Design 990
L9 - Backup Light (Single Reverse Light) W/Less Power Module W/ Allison
Design 992
L9 - Back Up Lights (Reverse) W/ Less Power Module
W/Eaton/ Manual
L9 - Back Up Lights (Reverse) W/ Less Power Module W/Eaton/ Manual
Design 993
A26 - Rear Lights Stop - Daisy Chain
A26 - Rear Lights Stop - Daisy Chain Design 994
A26 - Rear Lights Stop - Dual Assembly
A26 - Rear Lights Stop - Dual Assembly Design 995
A26 - Rear Lights Stop - Single Assemby
A26 - Rear Lights Stop - Single Assemby Design 996
A26 - Rear Lights Stop - Single Assemby Jumper
Harness W/08TKC, 08THM
A26 - Rear Lights Stop - Single Assemby Jumper Harness W/08TKC, 08THM
Design 997
A26 - Rear Lights Stop - Single Assemby W/08TKJ
A26 - Rear Lights Stop - Single Assemby W/08TKJ Design 998
A26 - Separate Rear Lights (Stop) W/08TVH
A26 - Separate Rear Lights (Stop) W/08TVH Design 999
A26/B6.7/L9 - Rear Lights Stop - Single Assembly
jumper harness
A26/B6.7/L9 - Rear Lights Stop - Single Assembly jumper harness Design 1000
A26/B6.7/L9 - Rear Lights (Stop) (Daisy Chain N/
Extension Harness)
A26/B6.7/L9 - Rear Lights (Stop) (Daisy Chain N/ Extension Harness)
Design 1001
A26/B6.7/L9 - Rear Lights (Stop) (Daisy Chain W/
Extension Harness)
A26/B6.7/L9 - Rear Lights (Stop) (Daisy Chain W/ Extension Harness)
Design 1002
xxxivA26/B6.7/L9 - Rear Light (Stop) Crossmember Dual
STT N/Back-Up
A26/B6.7/L9 - Rear Light (Stop) Crossmember Dual STT N/Back-Up Design 1003
B6.7 - Rear Lights Stop - Daisy Chain
B6.7 - Rear Lights Stop - Daisy Chain Design 1004
B6.7 - Rear Lights Stop - Dual Assembly
B6.7 - Rear Lights Stop - Dual Assembly Design 1005
B6.7 - Rear Lights Stop - Single Assemby
B6.7 - Rear Lights Stop - Single Assemby Design 1006
L9 - Rear Lights Stop - Daisy Chain
L9 - Rear Lights Stop - Daisy Chain Design 1007
L9 - Rear Lights Stop - Dual Assembly
L9 - Rear Lights Stop - Dual Assembly Design 1008
L9 - Rear Lights Stop - Single Assemby
L9 - Rear Lights Stop - Single Assemby Design 1009
A26/B6.7/L9 - Clearance and Identification Lights
A26/B6.7/L9 - Clearance and Identification Lights Design 1010
A26/B6.7/L9 - Daytime Running Lights N/CAN
Headlamps
A26/B6.7/L9 - Daytime Running Lights N/CAN Headlamps Design 1011
A26/B6.7/L9 - Daytime Running Lights (Output to Plow
Lights)
A26/B6.7/L9 - Daytime Running Lights (Output to Plow Lights) Design 1012
A26 - Directional Signal (Turn) W/ Daisy Chain Box
Lamps
A26 - Directional Signal (Turn) W/ Daisy Chain Box Lamps Design 1013
A26 - Directional Signal (Turn) W/ LED BOX LAMPS
A26 - Directional Signal (Turn) W/ LED BOX LAMPS Design 1014
A26 - Directional Signal (Turn) W/ Less Power Module
Tail Board, W/Hazard SW
A26 - Directional Signal (Turn) W/ Less Power Module Tail Board, W/Hazard SW
Design 1015
A26 - Directional Signal (Turn) W/ Single Tail Board
W/Hazard SW
A26 - Directional Signal (Turn) W/ Single Tail Board W/Hazard SW Design 1016
A26/B6.7/L9 - Directional Signal (Turn) W/ Daisy Chain
Box Lamps
A26/B6.7/L9 - Directional Signal (Turn) W/ Daisy Chain Box Lamps Design 1017
A26/B6.7/L9 - Directional Signal (Turn) W/ Less Power
Module Tail Board , W/Hazard SW
A26/B6.7/L9 - Directional Signal (Turn) W/ Less Power Module Tail Board ,
W/Hazard SW Design 1018
xxxvB6.7 - Directional Signal (Turn) W/ DAISY CHAIN BOX
LAMPS
B6.7 - Directional Signal (Turn) W/ DAISY CHAIN BOX LAMPS Design 1019
B6.7 - Directional Signal (Turn) W/ LED BOX LAMPS
B6.7 - Directional Signal (Turn) W/ LED BOX LAMPS Design 1021
B6.7 - Directional Signal (Turn) W/ Less Power Module
B6.7 - Directional Signal (Turn) W/ Less Power Module Tail Board W/Hazard SW
Design 1023
B6.7 - Directional Signal (Turn) W/ Single Tail Board
W/Hazard SW
B6.7 - Directional Signal (Turn) W/ Single Tail Board W/Hazard SW Design 1025
L9 - Directional Signal (Turn) W/ DAISY CHAIN BOX
LAMPS
L9 - Directional Signal (Turn) W/ DAISY CHAIN BOX LAMPS Design 1027
L9 - Directional Signal (Turn) W/ Less Power Module Tail Board W/Hazard SW
Design 1029
L9 - Directional Signal (Turn) W/ Single Tail Board
W/Hazard SW
L9 - Directional Signal (Turn) W/ Single Tail Board W/Hazard SW Design 1031
Lamps, W/Plow Lights
A26 - Directional Signal (Turn) W/ Daisy Chain Box Lamps, W/Plow Lights
Design 1033
A26 - Directional Signal (Turn) W/ LED BOX LAMPS,
W/Plow Lights
A26 - Directional Signal (Turn) W/ LED BOX LAMPS, W/Plow Lights Design 1035
Tail Board, W/Hazard SW, W/Plow Lights
A26 - Directional Signal (Turn) W/ Less Power Module Tail Board, W/Hazard SW,
W/Plow Lights Design 1037
A26 - Directional Signal (Turn) W/ Single Tail Board,
A26 - Directional Signal (Turn) W/ Single Tail Board, W/Hazard SW, W/Plow
Lights Design 1039
A26/B6.7/L9 - Directional Signal (Turn) W/ Daisy Chain Box Lamps, W/Plow
Lights Design 1041
Module Tail Board , W/Hazard SW , W/PLOW LIGHTS
W/Hazard SW , W/PLOW LIGHTS Design 1043
xxxviB6.7 - Directional Signal (Turn) W/ Daisy Chain Box
Lamps W/Plow Lights
B6.7 - Directional Signal (Turn) W/ Daisy Chain Box Lamps W/Plow Lights
Design 1045
W/Plow Lights
B6.7 - Directional Signal (Turn) W/ LED BOX LAMPS W/Plow Lights Design 1049
Module Tail Board W/Hazard SW W/PLOW LIGHTS
W/PLOW LIGHTS Design 1053
W/Plow Lights
B6.7 - Directional Signal (Turn) W/ Single Tail Board W/Plow Lights Design 1057
Lamps W/Plow Lights
L9 - Directional Signal (Turn) W/ Daisy Chain Box Lamps W/Plow Lights
Design 1061
L9 - Directional Signal (Turn) W/ LED BOX LAMPS
L9 - Directional Signal (Turn) W/ LED BOX LAMPS Design 1065
W/Plow Lights
L9 - Directional Signal (Turn) W/ LED BOX LAMPS W/Plow Lights Design 1067
W/PLOW LIGHTS Design 1071
W/Plow Lights
L9 - Directional Signal (Turn) W/ Single Tail Board W/Plow Lights Design 1075
A26/B6.7/L9 - Exterior Lamp Check
A26/B6.7/L9 - Exterior Lamp Check Design 1079
A26/B6.7/L9 - Exterior Lamp Reminder
A26/B6.7/L9 - Exterior Lamp Reminder Design 1080
A26 - Front Fog Lamps LED
A26 - Front Fog Lamps LED Design 1081
A26 - Front Fog Lights W CONNECTOR Halogen
A26 - Front Fog Lights W CONNECTOR Halogen Design 1083
B6.7 - Fog Lights (Halogen White)
B6.7 - Fog Lights (Halogen White) Design 1085
B6.7 - Fog Lights (LED White)
B6.7 - Fog Lights (LED White) Design 1088
B6.7 - Front Fog Lamps
B6.7 - Front Fog Lamps Design 1091
xxxviiB6.7 - Front Fog Lights W CONNECTOR
B6.7 - Front Fog Lights W CONNECTOR Design 1094
L9 - Fog Lights (Halogen White)
L9 - Fog Lights (Halogen White) Design 1096
L9 - Fog Lights (LED White)
L9 - Fog Lights (LED White) Design 1098
L9 - Front Fog Lights W CONNECTOR
L9 - Front Fog Lights W CONNECTOR Design 1100
A26 - Front Marker Lights
A26 - Front Marker Lights Design 1102
A26 - Front Marker Lights W/Plow Lights
A26 - Front Marker Lights W/Plow Lights Design 1103
B6.7 - Front Marker Lights - Without Snow Plow Lights
B6.7 - Front Marker Lights - Without Snow Plow Lights Design 1105
B6.7 - Front Marker Lights - With Plow Lights
B6.7 - Front Marker Lights - With Plow Lights Design 1107
L9 - Front Marker Lights - Without Snow Plow Lights
L9 - Front Marker Lights - Without Snow Plow Lights Design 1111
L9 - Front Marker Lights - With Plow Lights
L9 - Front Marker Lights - With Plow Lights Design 1113
A26 - Hazard Warning Light N/Trlr Socket
A26 - Hazard Warning Light N/Trlr Socket Design 1117
L9 - Hazard Warning Light N/Trlr Socket
L9 - Hazard Warning Light N/Trlr Socket Design 1119
A26 - Headlights W/LOWW, W/O Interrupt
A26 - Headlights W/LOWW, W/O Interrupt Design 1121
A26 - Headlights W/O LOWW, W/O Interrupt
A26 - Headlights W/O LOWW, W/O Interrupt Design 1123
A26 - Headlights W/LOWW, W/Interrupt - 10 PIN CLK
A26 - Headlights W/LOWW, W/Interrupt - 10 PIN CLK Design 1125
A26 - Headlights W/O LOWW, W/Interrupt - 10 PIN CLK
A26 - Headlights W/O LOWW, W/Interrupt - 10 PIN CLK Design 1127
A26 - Headlight W/Plowlights, W/LOWW, W/O Interrupt
A26 - Headlight W/Plowlights, W/LOWW, W/O Interrupt Design 1129
A26 - Headlight W/Plowlights, W/O LOWW, W/O
Interrupt
A26 - Headlight W/Plowlights, W/O LOWW, W/O Interrupt Design 1133
A26 - Headlights W/PlowLights, W/LOWW, W/Interrupt
- 10 PIN CLK
A26 - Headlights W/PlowLights, W/LOWW, W/Interrupt - 10 PIN CLK Design 1137
xxxviiiA26 - Headlights W/PlowLights, W/O LOWW,
A26 - Headlights W/PlowLights, W/O LOWW, W/Interrupt - 10 PIN CLK
Design 1141
B6.7 - Headlights W/O Lights ON With Wipers (LOWW)
W/O Headlights Interrupt
B6.7 - Headlights W/O Lights ON With Wipers (LOWW) W/O Headlights Interrupt
Design 1145
B6.7 - Headlights W/O Lights ON with wipers (LOWW)
W/ Headlights Interrupt
B6.7 - Headlights W/O Lights ON with wipers (LOWW) W/ Headlights Interrupt
Design 1149
B6.7 - Headlights W 10PIN CLK W/LOWW W/O
Interrupt
B6.7 - Headlights W 10PIN CLK W/LOWW W/O Interrupt Design 1153
B6.7 - Headlights W 10PIN CLK W/LOWW W/Interrupt
B6.7 - Headlights W 10PIN CLK W/LOWW W/Interrupt Design 1157
B6.7 - Headlights W/Plowlights W/O Lights ON With
B6.7 - Headlights W/Plowlights W/O Lights ON With Wipers (LOWW) W/O
Headlights Interrupt Design 1161
B6.7 - Headlight W/Plowlights W/LOWW W/O
Headlight Interrupt -10 PIN CLK
B6.7 - Headlight W/Plowlights W/LOWW W/O Headlight Interrupt -10 PIN CLK
Design 1169
B6.7 - Headlights W/PlowLights W/Headlight Interrupt
-10PIN CLK W/LOWW W/Interrupt
B6.7 - Headlights W/PlowLights W/Headlight Interrupt -10PIN CLK W/LOWW
W/Interrupt Design 1177
B6.7 - Headlights W/PlowLights W/O Lights ON with
B6.7 - Headlights W/PlowLights W/O Lights ON with wipers (LOWW) W/
Headlights Interrupt Design 1185
L9 - Headlights W/O Lights ON With Wipers (LOWW)
L9 - Headlights W/O Lights ON With Wipers (LOWW) W/O Headlights Interrupt
Design 1193
L9 - Headlights W/O Lights ON with wipers (LOWW)
L9 - Headlights W/O Lights ON with wipers (LOWW) W/ Headlights Interrupt
Design 1197
L9 - Headlights W 10PIN CLK W/LOWW W/O Interrupt
L9 - Headlights W 10PIN CLK W/LOWW W/O Interrupt Design 1201
L9 - Headlights W 10PIN CLK W/LOWW W/Interrupt
L9 - Headlights W 10PIN CLK W/LOWW W/Interrupt Design 1205
xxxixL9 - Headlights W/Plowlights W/O Lights ON With
L9 - Headlights W/Plowlights W/O Lights ON With Wipers (LOWW) W/O
Headlights Interrupt Design 1209
L9 - Headlight W/Plowlights W/LOWW W/O Headlight
L9 - Headlight W/Plowlights W/LOWW W/O Headlight Interrupt -10 PIN CLK
Design 1217
L9 - Headlights W/PlowLights W/Headlight Interrupt -
L9 - Headlights W/PlowLights W/Headlight Interrupt -10PIN CLK W/LOWW
W/Interrupt Design 1225
L9 - Headlights W/PlowLights W/O Lights ON with
L9 - Headlights W/PlowLights W/O Lights ON with wipers (LOWW) W/ Headlights
Interrupt Design 1233
A26 - License Plate Light (LED BOX LAMP Daisy
Chain Tail Light)
A26 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light) Design 1241
A26 - License Plate Light (LED BOX LAMP Tail Light)
A26 - License Plate Light (LED BOX LAMP Tail Light) Design 1242
A26 - License Plate Light (Tail Light Single Assembly)
A26 - License Plate Light (Tail Light Single Assembly) Design 1243
Assembly)Option2
A26 - License Plate Light (Tail Light Single Assembly)Option2 Design 1244
Assembly)Option3
A26 - License Plate Light (Tail Light Single Assembly)Option3 Design 1245
A26 - License Plate Light (Tail Light Single Assy.)
W/Less Power Module (W/08TKC, 08THM)
A26 - License Plate Light (Tail Light Single Assy.) W/Less Power Module
(W/08TKC, 08THM) Design 1246
A26/B6.7/L9 - License Plate Light (Direct To Light)
A26/B6.7/L9 - License Plate Light (Direct To Light) Design 1247
A26/B6.7/L9 - License Plate Light (LED BOX LAMP
Daisy Chain Tail Light with extension)
A26/B6.7/L9 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light with
extension) Design 1248
A26/B6.7/L9 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light)
Design 1249
A26/B6.7/L9 - License Plate Light (Tail Light Single
xlA26/B6.7/L9 - License Plate Light (Tail Light Single Assy.) W/Less Power Module
Design 1250
B6.7 - License Plate Light (LED BOX LAMP Daisy
Chain Tail Light)
B6.7 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light) Design 1251
B6.7 - License Plate Light (LED BOX LAMP Tail Light)
B6.7 - License Plate Light (LED BOX LAMP Tail Light) Design 1252
B6.7 - License Plate Light (Tail Light Single Assy)
Option 1
B6.7 - License Plate Light (Tail Light Single Assy) Option 1 Design 1253
Option 2
B6.7 - License Plate Light (Tail Light Single Assy) Option 2 Design 1254
Option 3
B6.7 - License Plate Light (Tail Light Single Assy) Option 3 Design 1255
Option 4
B6.7 - License Plate Light (Tail Light Single Assy) Option 4 Design 1256
W/Less Power Module
B6.7 - License Plate Light (Tail Light Single Assy) W/Less Power Module
Design 1257
Tail Light)
L9 - License Plate Light (LED BOX LAMP Daisy Chain Tail Light) Design 1258
L9 - License Plate Light (LED BOX LAMP Tail Light)
L9 - License Plate Light (LED BOX LAMP Tail Light) Design 1259
L9 - License Plate Light (Tail Light Single Assy)
Option 1
L9 - License Plate Light (Tail Light Single Assy) Option 1 Design 1260
Option 2
L9 - License Plate Light (Tail Light Single Assy) Option 2 Design 1261
Option 3
L9 - License Plate Light (Tail Light Single Assy) Option 3 Design 1262
Option 4
L9 - License Plate Light (Tail Light Single Assy) Option 4 Design 1263
A26/B6.7/L9 - PARK LIGHTS - N/Marker Interrupt
A26/B6.7/L9 - PARK LIGHTS - N/Marker Interrupt Design 1264
xliA26/B6.7/L9 - PARK LIGHTS - W/Marker Interrupt
10pin CLCKSPRING
A26/B6.7/L9 - PARK LIGHTS - W/Marker Interrupt 10pin CLCKSPRING
Design 1266
A26/B6.7/L9 - PARK LIGHTS - W/Marker Interrupt 4 pin
clockspring
A26/B6.7/L9 - PARK LIGHTS - W/Marker Interrupt 4 pin clockspring Design 1268
A26/B6.7/L9 - Snow Plow Lights
A26/B6.7/L9 - Snow Plow Lights Design 1270
A26 - Rear Light (LED BOX LAMP Tail Light) W/08TPS,
08TPR
A26 - Rear Light (LED BOX LAMP Tail Light) W/08TPS, 08TPR Design 1271
A26 - Rear Light (Tail Light) W/Less Power Module
(W/08TKC, 08THM)
A26 - Rear Light (Tail Light) W/Less Power Module (W/08TKC, 08THM)
Design 1272
A26 - Rear Light (Tail Light) W/08THK
A26 - Rear Light (Tail Light) W/08THK Design 1273
A26 - Rear Light (Tail Light) W/08TKB
A26 - Rear Light (Tail Light) W/08TKB Design 1274
A26 - Rear Light (Tail Light) W/08TKJ
A26 - Rear Light (Tail Light) W/08TKJ Design 1275
A26 - Rear Light (Tail Light) W_Daisy Chain pair of
Box Lamps W/08TRS
A26 - Rear Light (Tail Light) W_Daisy Chain pair of Box Lamps W/08TRS
Design 1276
A26/B6.7/L9 - Rear Lights (Tail Lights) Crossmember
Dual STT N/Back-Up
A26/B6.7/L9 - Rear Lights (Tail Lights) Crossmember Dual STT N/Back-Up
Design 1277
A26/B6.7/L9 - Rear Lights (Tail Lights) (W/Separate
Stop/Turn Assembly)
A26/B6.7/L9 - Rear Lights (Tail Lights) (W/Separate Stop/Turn Assembly)
Design 1278
A26/B6.7/L9 - Rear Light (Tail Light) Daisy Chain W/
Extension
A26/B6.7/L9 - Rear Light (Tail Light) Daisy Chain W/ Extension Design 1279
A26/B6.7/L9 - Rear Light (Tail Light) W/Daisy Chain
Pair of Box Lamps
A26/B6.7/L9 - Rear Light (Tail Light) W/Daisy Chain Pair of Box Lamps
Design 1280
A26/B6.7/L9 - Rear Light (Tail Light) W/Less Power
Module
A26/B6.7/L9 - Rear Light (Tail Light) W/Less Power Module Design 1281
B6.7 - Rear Light (LED BOX LAMP Tail Light)
xliiB6.7 - Rear Light (LED BOX LAMP Tail Light) Design 1282
B6.7 - Rear Light (Tail Light) Option 1
B6.7 - Rear Light (Tail Light) Option 1 Design 1283
B6.7 - Rear Light (Tail Light) Option 2
B6.7 - Rear Light (Tail Light) Option 2 Design 1284
B6.7 - Rear Light (Tail Light) Option 3
B6.7 - Rear Light (Tail Light) Option 3 Design 1285
B6.7 - Rear Light (Tail Light) Option 4
B6.7 - Rear Light (Tail Light) Option 4 Design 1286
B6.7 - Rear Light (Tail Light) W_Daisy Chain pair of
Box Lamps
B6.7 - Rear Light (Tail Light) W_Daisy Chain pair of Box Lamps Design 1287
L9 - Rear Light (LED BOX LAMP Tail Light)
L9 - Rear Light (LED BOX LAMP Tail Light) Design 1288
L9 - Rear Light (Tail Light) Design 1289
L9 - Rear Light (Tail Light) W Daisy Chain pair of Box
Lamps
L9 - Rear Light (Tail Light) W Daisy Chain pair of Box Lamps Design 1290
A26 - WORK LIGHT W BackUP 1 BULB_AUTOMATIC
TRANSMISSION
A26 - WORK LIGHT W BackUP 1 BULB_AUTOMATIC TRANSMISSION
Design 1291
A26 - WORK LIGHT W BackUP 1 BULB_MANUAL
TRANSMISSION
A26 - WORK LIGHT W BackUP 1 BULB_MANUAL TRANSMISSION Design 1292
A26 - WORK LIGHT W RKE W BackUP 1 BULB
(Manual)
A26 - WORK LIGHT W RKE W BackUP 1 BULB (Manual) Design 1293
A26 - WORK LIGHT W RKE 1 BULB1
A26 - WORK LIGHT W RKE 1 BULB1 Design 1294
A26 - WORK LIGHT W/Backup W/RKE 1 Bulb
A26 - WORK LIGHT W/Backup W/RKE 1 Bulb Automatic Transmission
Design 1295
A26 - WORK LIGHT 1 BULB 1
A26 - WORK LIGHT 1 BULB 1 Design 1296
B6.7 - Work Lights LED W/ Sw Pack - Day Cab
B6.7 - Work Lights LED W/ Sw Pack - Day Cab Design 1297
B6.7 - WORK LIGHT W BackUP 1 BULB
B6.7 - WORK LIGHT W BackUP 1 BULB Design 1298
xliiiB6.7 - WORK LIGHT W RKE 1 BULB
B6.7 - WORK LIGHT W RKE 1 BULB Design 1299
B6.7 - WORK LIGHT 1 BULB
B6.7 - WORK LIGHT 1 BULB Design 1300
L9 - Work Lights LED W/ Sw Pack - Day Cab
L9 - Work Lights LED W/ Sw Pack - Day Cab Design 1301
L9 - WORK LIGHT W BackUP 1 BULB Option 1
L9 - WORK LIGHT W BackUP 1 BULB Option 1 Design 1303
L9 - WORK LIGHT W BackUP 1 BULB Option 2
L9 - WORK LIGHT W BackUP 1 BULB Option 2 Design 1307
L9 - WORK LIGHT W RKE 1 BULB
L9 - WORK LIGHT W RKE 1 BULB Design 1309
L9 - WORK LIGHT 1 BULB
L9 - WORK LIGHT 1 BULB Design 1311
A26/B6.7/L9 - Fifth Wheel Slide
A26/B6.7/L9 - Fifth Wheel Slide Design 1313
A26/B6.7/L9 - Jaw Unlock Control
A26/B6.7/L9 - Jaw Unlock Control Design 1314
A26/B6.7/L9 - Jaw Unlock Control W/ SOLENOIDS
W/SWITCH PACKS
A26/B6.7/L9 - Jaw Unlock Control W/ SOLENOIDS W/SWITCH PACKS
Design 1315
A26 - Fuel Heater (Vehicle Powered)(Davco) 1
A26 - Fuel Heater (Vehicle Powered)(Davco) 1 Design 1316
A26 - Fuel Heater (Vehicle Powered)(Racor)
A26 - Fuel Heater (Vehicle Powered)(Racor) Design 1317
B6.7 - Fuel Heater (Vehicle Powered)(Davco)
B6.7 - Fuel Heater (Vehicle Powered)(Davco) Design 1318
B6.7 - Fuel Heater (Vehicle Powered)(Racor)
B6.7 - Fuel Heater (Vehicle Powered)(Racor) Design 1325
L9 - Fuel Heater (Vehicle Powered)(Davco)
L9 - Fuel Heater (Vehicle Powered)(Davco) Design 1332
L9 - Fuel Heater (Vehicle Powered)(Racor)
L9 - Fuel Heater (Vehicle Powered)(Racor) Design 1347
A26 - 26" Fuel Tank
A26 - 26" Fuel Tank Design 1355
A26 - 26" Fuel Tank - Secondary
A26 - 26" Fuel Tank - Secondary Design 1360
B6.7 - 26 inch Fuel Tank
B6.7 - 26 inch Fuel Tank Design 1367
xlivB6.7 - 26 inch Fuel Tank - Secondary
B6.7 - 26 inch Fuel Tank - Secondary Design 1370
2017-2024 B6.7 - Fuel Level (Single Sensor)
2017-2024 B6.7 - Fuel Level (Single Sensor) Design 1371
L9 - 26 inch Fuel Tank
L9 - 26 inch Fuel Tank Design 1377
L9 - 26 inch Fuel Tank - Secondary
L9 - 26 inch Fuel Tank - Secondary Design 1383
2017-2024 L9 - Fuel Level (Single Sensor)
2017-2024 L9 - Fuel Level (Single Sensor) Design 1390
A26 - Water In Fuel (WIF) Racor N/ Heater
A26 - Water In Fuel (WIF) Racor N/ Heater Design 1398
B6.7 - Water In Fuel (WIF) Racor N/ Heater
B6.7 - Water In Fuel (WIF) Racor N/ Heater Design 1400
B6.7 - Water In Fuel (WIF) Racor W/ Heater
B6.7 - Water In Fuel (WIF) Racor W/ Heater Design 1407
L9 - Water In Fuel (WIF) Davco N/ Heater
L9 - Water In Fuel (WIF) Davco N/ Heater Design 1414
L9 - Water In Fuel (WIF) Davco W/ Heater
L9 - Water In Fuel (WIF) Davco W/ Heater Design 1423
HVAC Actuators
HVAC Actuators Design 1432
A26 - Heating, Ventilation & Air Conditioning (HVAC)
(Auto Control head W/PT Transducer N/Low Pressure
SW)
A26 - Heating, Ventilation & Air Conditioning (HVAC) (Auto Control head W/PT
Transducer N/Low Pressure SW) Design 1433
B6.7 - Heating Ventilation & Air Conditioning (HVAC)
Auto Temp Control
B6.7 - Heating Ventilation & Air Conditioning (HVAC) Auto Temp Control
Design 1436
L9 - Heating Ventilation & Air Conditioning (HVAC)
Auto Temp Control
L9 - Heating Ventilation & Air Conditioning (HVAC) Auto Temp Control
Design 1439
(Manual W/PT Transducer N/Low Pressure SW)
A26 - Heating, Ventilation & Air Conditioning (HVAC) (Manual W/PT Transducer
N/Low Pressure SW) Design 1442
A26/B6.7/L9 - HVAC Assembly Actuators
A26/B6.7/L9 - HVAC Assembly Actuators Design 1444
B6.7 - Heating Ventilation & Air Conditioning (HVAC) Design 1445
xlvL9 - Heating Ventilation & Air Conditioning (HVAC)
L9 - Heating Ventilation & Air Conditioning (HVAC) Design 1446
A26 - Ambient Temperature (Mirror Sensor)
A26 - Ambient Temperature (Mirror Sensor) Design 1447
A26 - Ambient Temperature (No Display Mirror
Sensor)
A26 - Ambient Temperature (No Display Mirror Sensor) Design 1448
B6.7 - Ambient Temperature (Horizon-Mirror Sensor)
B6.7 - Ambient Temperature (Horizon-Mirror Sensor) Design 1449
B6.7 - Ambient Temperature (No Display, Mirror
Sensor)
B6.7 - Ambient Temperature (No Display, Mirror Sensor) Design 1450
L9 - Ambient Temperature (Horizon-Mirror Sensor)
L9 - Ambient Temperature (Horizon-Mirror Sensor) Design 1451
L9 - Ambient Temperature (No Display, Mirror Sensor)
L9 - Ambient Temperature (No Display, Mirror Sensor) Design 1452
2021 L9 - Ambient Air Temperature
2021 L9 - Ambient Air Temperature Design 1453
B6.7 - Current Monitoring (Ammeter)
B6.7 - Current Monitoring (Ammeter) Design 1454
A26 - Brake Pressure (Auxiliary Gauge)
A26 - Brake Pressure (Auxiliary Gauge) Design 1456
A26 - Brake Pressure (Virtual Gauge)
A26 - Brake Pressure (Virtual Gauge) Design 1457
B6.7 - Brake Pressure (Auxiliary Gauge)
B6.7 - Brake Pressure (Auxiliary Gauge) Design 1458
B6.7 - Brake Pressure (Virtual Gauge)
B6.7 - Brake Pressure (Virtual Gauge) Design 1459
L9 - Brake Pressure (Auxiliary Gauge)
L9 - Brake Pressure (Auxiliary Gauge) Design 1460
L9 - Brake Pressure (Virtual Gauge)
L9 - Brake Pressure (Virtual Gauge) Design 1461
A26/B6.7/L9 - Compressed Air Supply
A26/B6.7/L9 - Compressed Air Supply Design 1462
A26 - DEF Economy Monitor (GEN IV)
A26 - DEF Economy Monitor (GEN IV) Design 1463
B6.7/L9 - DEF Economy Monitor (GEN IV Cluster w/
Cummins ENG)
B6.7/L9 - DEF Economy Monitor (GEN IV Cluster w/ Cummins ENG) Design 1464
L9 - Coolant Temperature Monitoring (J1939 Comm)
L9 - Coolant Temperature Monitoring (J1939 Comm) Design 1465
xlviA26/B6.7/L9 - Engine Usage Monitoring (Base) NA
A26/B6.7/L9 - Engine Usage Monitoring (Base) NA Design 1466
A26/B6.7/L9 - Engine Usage Monitoring (VID Option)
A26/B6.7/L9 - Engine Usage Monitoring (VID Option) Design 1467
A26 - Transmission Oil Level (Low Level Warning)
A26 - Transmission Oil Level (Low Level Warning) Design 1468
A26/B6.7/L9 - Engine Oil Level Monitoring
A26/B6.7/L9 - Engine Oil Level Monitoring Design 1469
A26/B6.7/L9 - Engine Oil Pressure
A26/B6.7/L9 - Engine Oil Pressure Design 1470
A26/B6.7/L9 - Engine Oil Temperature (NA Mux)
A26/B6.7/L9 - Engine Oil Temperature (NA Mux) Design 1471
A26/B6.7/L9 - Engine Oil Temperature(NA MUX AUX
Gauge)
A26/B6.7/L9 - Engine Oil Temperature(NA MUX AUX Gauge) Design 1472
A26 - Engine Speed (Tachometer)
A26 - Engine Speed (Tachometer) Design 1473
B6.7 & L9 - Engine Speed (Tachometer)
B6.7 & L9 - Engine Speed (Tachometer) Design 1474
A26/B6.7/L9 - Fuel Economy Monitor
A26/B6.7/L9 - Fuel Economy Monitor Design 1475
A26/B6.7/L9 - Odometer (via BCM/EGC)
A26/B6.7/L9 - Odometer (via BCM/EGC) Design 1476
A26/B6.7/L9 - Trip Odometer w/VID
A26/B6.7/L9 - Trip Odometer w/VID Design 1477
A26/B6.7/L9 - Trip Odometer (Gen 4 Cluster)
A26/B6.7/L9 - Trip Odometer (Gen 4 Cluster) Design 1478
A26/B6.7/L9 - Trip Odometer ( w/ECM & TCM)
A26/B6.7/L9 - Trip Odometer ( w/ECM & TCM) Design 1479
A26/B6.7/L9 - PTO Hour Meter
A26/B6.7/L9 - PTO Hour Meter Design 1480
A26 - Transmission Oil Temperature (Automatic Trans
W/ Aux Gauge)
A26 - Transmission Oil Temperature (Automatic Trans W/ Aux Gauge)
Design 1481
Trans)
A26 - Transmission Oil Temperature (Automatic Trans) Design 1482
A26 - Transmission Oil Temperature (Manual Trans W/
Aux Gauge)Z
A26 - Transmission Oil Temperature (Manual Trans W/ Aux Gauge)Z Design1483
A26 - Transmission Oil Temperature (Manual Trans)
xlviiA26 - Transmission Oil Temperature (Manual Trans) Design 1484
B6.7 - Transmission Oil Temperature-Manual Trans
B6.7 - Transmission Oil Temperature-Manual Trans Design 1485
(w/Aux Gauge)
B6.7 - Transmission Oil Temperature-Manual Trans (w/Aux Gauge) Design 1486
L9 - Transmission Oil Temperature-Automatic Trans
L9 - Transmission Oil Temperature-Automatic Trans Design 1487
w/Aux Gauge
L9 - Transmission Oil Temperature-Automatic Trans w/Aux Gauge Design 1488
L9 - Transmission Oil Temperature-Manual
L9 - Transmission Oil Temperature-Manual Transmission Design 1489
w/Aux Gauge
L9 - Transmission Oil Temperature-Manual Trans w/Aux Gauge Design 1490
B6.7 - Vehicle Speedometer System (Manual XMSN)
B6.7 - Vehicle Speedometer System (Manual XMSN) Design 1491
B6.7/L9 - Vehicle Speedometer System (Automatic
XMSN J1939)
B6.7/L9 - Vehicle Speedometer System (Automatic XMSN J1939) Design 1492
L9 - Auxilary Tranmission XMSN (W/13607)
L9 - Auxilary Tranmission XMSN (W/13607) Design 1493
L9 - Vehicle Speedometer System (From Road Speed
SNSR to Blunt Cut)
L9 - Vehicle Speedometer System (From Road Speed SNSR to Blunt Cut)
Design 1494
L9 - Vehicle Speedometer System (Manual XMSN)
L9 - Vehicle Speedometer System (Manual XMSN) Design 1496
A26 - Vehicle Speedometer System (J1939 Message
from TCM to ECM)
A26 - Vehicle Speedometer System (J1939 Message from TCM to ECM)
Design 1497
from TCM to ECM)(Option2)
ECM)(Option2) Design 1498
A26 - Vehicle Speedometer System (VSS wired to VIC)
A26 - Vehicle Speedometer System (VSS wired to VIC) Design 1499
A26/B6.7/L9 - Vehicle Speed Limit Override
A26/B6.7/L9 - Vehicle Speed Limit Override Design 1500
A26/B6.7/L9 - Voltage Monitoring (Voltmeter)
xlviiiA26/B6.7/L9 - Voltage Monitoring (Voltmeter) Design 1501
A26/B6.7/L9 - Voltage Monitoring (Voltmeter) (with
Aux gauge)
A26/B6.7/L9 - Voltage Monitoring (Voltmeter) (with Aux gauge) Design 1502
A26/B6.7/L9 - Engine Warning_MUX
A26/B6.7/L9 - Engine Warning_MUX Design 1503
A26 - High Exhaust System Temperature (HEST)
Monitoring
A26 - High Exhaust System Temperature (HEST) Monitoring Design 1504
B6.7/L9 - High Exhaust System Temperature (HEST)
Monitoring
B6.7/L9 - High Exhaust System Temperature (HEST) Monitoring Design 1505
A26 - Up Shift Indicator (CA 2.0)
A26 - Up Shift Indicator (CA 2.0) Design 1506
A26/B6.7/L9 - Up Shift Indicator
A26/B6.7/L9 - Up Shift Indicator Design 1507
A26 - Range Inhibit with Seatbelt
A26 - Range Inhibit with Seatbelt Design 1508
A26/B6.7/L9 - Trans Range Inhibit (J1939 Comm)
A26/B6.7/L9 - Trans Range Inhibit (J1939 Comm) Design 1509
B6.7 - Range Inhibit (sixth gear inhibit switch)
B6.7 - Range Inhibit (sixth gear inhibit switch) Design 1510
B6.7 - Range Inhibit (Sixth Gear Inhibit Switch))
B6.7 - Range Inhibit (Sixth Gear Inhibit Switch)) Design 1511
B6.7/L9 - Trans Range Inhibit (J1939 Comm) Design 1513
A26/B6.7/L9 - Vehicle Information Display Premium w/
Wi-Fi (VID)
A26/B6.7/L9 - Vehicle Information Display Premium w/ Wi-Fi (VID) Design 1514
A26/B6.7/L9 - Vehicle Information Display (Without
Bluetooth)
A26/B6.7/L9 - Vehicle Information Display (Without Bluetooth) Design 1515
Bluetooth)
A26/B6.7/L9 - Vehicle Information Display (With Bluetooth) Design 1516
A26/B6.7/L9 - Cab Dome Light W/Classic Trim
A26/B6.7/L9 - Cab Dome Light W/Classic Trim Design 1517
A26/B6.7/L9 - Cab Dome Light W/ Combo in Diamond
Trim
A26/B6.7/L9 - Cab Dome Light W/ Combo in Diamond Trim Design 1518
xlixA26/B6.7/L9 - Interior Task Lights (Map) - Dome
Combo
A26/B6.7/L9 - Interior Task Lights (Map) - Dome Combo Design 1519
A26/B6.7/L9 - Courtesy Light Cab 2 door
A26/B6.7/L9 - Courtesy Light Cab 2 door Design 1520
A26/B6.7/L9 - Courtesy Light 4 Door
A26/B6.7/L9 - Courtesy Light 4 Door Design 1521
A26/B6.7/L9 - Panel Backlighting (Cabin Dimmer)
A26/B6.7/L9 - Panel Backlighting (Cabin Dimmer) Design 1522
A26/B6.7/L9 - Axle Lift Controls
A26/B6.7/L9 - Axle Lift Controls Design 1523
A26 - Axle Lift Controls
A26 - Axle Lift Controls Design 1527
A26 - Lift Axle Controls (Center Pedestal Controls f/ 1
lift axle)
A26 - Lift Axle Controls (Center Pedestal Controls f/ 1 lift axle) Design 1529
A26 - Lift Axle Controls (Center Pedestal Controls f/ 2
Lift Axles)
A26 - Lift Axle Controls (Center Pedestal Controls f/ 2 Lift Axles) Design 1531
A26 - Lift Axle Controls (Center Pedestal Controls f/ 3
lift axles)
A26 - Lift Axle Controls (Center Pedestal Controls f/ 3 lift axles) Design 1532
L9 - Axle Lift Controls Option 2
L9 - Axle Lift Controls Option 2 Design 1533
L9 - Lift Axle Controls (Center Pedestal Controls f/ 1
lift axle)
L9 - Lift Axle Controls (Center Pedestal Controls f/ 1 lift axle) Design 1535
L9 - Lift Axle Controls (Center Pedestal Controls f/ 2
Lift Axles)
L9 - Lift Axle Controls (Center Pedestal Controls f/ 2 Lift Axles) Design 1537
L9 - Lift Axle Controls (Center Pedestal Controls f/ 3
lift axles)
L9 - Lift Axle Controls (Center Pedestal Controls f/ 3 lift axles) Design 1538
A26 - Axle Loading (Weight) (Rear, Horizon)
A26 - Axle Loading (Weight) (Rear, Horizon) Design 1539
B6.7 - Axle Loading (Weight) Rear
B6.7 - Axle Loading (Weight) Rear Design 1545
B6.7 - Axle Loading (Weight) (Rear, Horizon)
B6.7 - Axle Loading (Weight) (Rear, Horizon) Design 1547
L9 - Axle Loading (Weight) Rear
L9 - Axle Loading (Weight) Rear Design 1551
lL9 - Axle Loading (Weight) (Rear, Horizon)
L9 - Axle Loading (Weight) (Rear, Horizon) Design 1553
A26 - Axle Temperature Monitoring (Single Rear Aux
Gauge)
A26 - Axle Temperature Monitoring (Single Rear Aux Gauge) Design 1557
Virtual Gauge)
A26 - Axle Temperature Monitoring (Single Rear Virtual Gauge) Design 1558
A26 - Axle Temperature Monitoring (Tandem Rear Aux
Gauge)
A26 - Axle Temperature Monitoring (Tandem Rear Aux Gauge) Design 1559
Virtual Gauge)
A26 - Axle Temperature Monitoring (Tandem Rear Virtual Gauge) Design 1560
B6.7 - Axle Temperature Monitoring (Single Rear Aux
Gauge)
B6.7 - Axle Temperature Monitoring (Single Rear Aux Gauge) Design 1561
Virtual Gauge)
B6.7 - Axle Temperature Monitoring (Single Rear Virtual Gauge) Design 1562
L9 - Axle Temperature Monitoring (Tandem Rear Aux
Gauge) Option 1
L9 - Axle Temperature Monitoring (Tandem Rear Aux Gauge) Option 1
Design 1563
Gauge) Option 2
L9 - Axle Temperature Monitoring (Tandem Rear Aux Gauge) Option 2
Design 1564
Virtual Gauge) Option 1
L9 - Axle Temperature Monitoring (Tandem Rear Virtual Gauge) Option 1
Design 1565
Virtual Gauge) Option 2
L9 - Axle Temperature Monitoring (Tandem Rear Virtual Gauge) Option 2
Design 1566
A26 - Driver Controlled Locking Differential FR and RR
Axles (Dana w/ two sw)
A26 - Driver Controlled Locking Differential FR and RR Axles (Dana w/ two sw)
Design 1567
Axle (Dana w/ one switch)
A26 - Driver Controlled Locking Differential FR and RR Axle (Dana w/ one switch)
Design 1568
liA26 - Driver Controlled Locking Differential RR Axle
(Dana w/ one sw)
A26 - Driver Controlled Locking Differential RR Axle (Dana w/ one sw)
Design 1569
Axles (Meritor w/ two sw)
A26 - Driver Controlled Locking Differential FR and RR Axles (Meritor w/ two sw)
Design 1570
Axle (Meritor w/ one sw)
A26 - Driver Controlled Locking Differential FR and RR Axle (Meritor w/ one sw)
Design 1571
(Meritor w/ one sw)
A26 - Driver Controlled Locking Differential RR Axle (Meritor w/ one sw)
Design 1572
B6.7 - Driver Controlled Locking Differential - RR Axle
(Dana w/ one sw)
B6.7 - Driver Controlled Locking Differential - RR Axle (Dana w/ one sw)
Design 1573
(Meritor w/ one sw)
B6.7 - Driver Controlled Locking Differential - RR Axle (Meritor w/ one sw)
Design 1574
L9 - Driver Controlled Locking Differential - FR and RR
L9 - Driver Controlled Locking Differential - FR and RR Axles (Dana w/ two sw)
Design 1575
L9 - Driver Controlled Locking Differential - FR and RR Axle (Dana w/ one sw)
Design 1576
L9 - Driver Controlled Locking Differential - RR Axle
(Dana w/ one sw)
L9 - Driver Controlled Locking Differential - RR Axle (Dana w/ one sw)
Design 1577
L9 - Driver Controlled Locking Differential - FR and RR Axles (Meritor w/ two sw)
Design 1578
L9 - Driver Controlled Locking Differential - FR and RR Axle (Meritor w/ one sw)
Design 1579
(Meritor w/ one sw)
L9 - Driver Controlled Locking Differential - RR Axle (Meritor w/ one sw)
Design 1580
liiA26/B6.7/L9 - Height Control
A26/B6.7/L9 - Height Control Design 1581
A26/B6.7/L9 - Power Divider Lock Control and
Monitoring
A26/B6.7/L9 - Power Divider Lock Control and Monitoring Design 1582
L9 - Rear Axle Load Distribution
L9 - Rear Axle Load Distribution Design 1583
A26/B6.7/L9 - Rear Suspension Pressure Monitoring
(Auxiliary Gauge)
A26/B6.7/L9 - Rear Suspension Pressure Monitoring (Auxiliary Gauge)
Design 1584
(Virtual Gauge)
A26/B6.7/L9 - Rear Suspension Pressure Monitoring (Virtual Gauge) Design 1586
A26 - Two Speed Axle (Multiplex SW on Dash)
A26 - Two Speed Axle (Multiplex SW on Dash) Design 1588
Dash)(Option2)
A26 - Two Speed Axle (Multiplex SW on Dash)(Option2) Design 1589
B6.7 - Two Speed Axle (AirShift on Shifter)
B6.7 - Two Speed Axle (AirShift on Shifter) Design 1590
L9 - Two Speed Axle (AirShift on Shifter)
L9 - Two Speed Axle (AirShift on Shifter) Design 1591
L9 - Two Speed Axle (Multiplex SW on Dash)
L9 - Two Speed Axle (Multiplex SW on Dash) Design 1592
A26/B6.7/L9 - Driver and Passenger Seats - RollTek
(Hard Wired)
A26/B6.7/L9 - Driver and Passenger Seats - RollTek (Hard Wired) Design 1593
A26/B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard
Wired) - Leather
A26/B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard Wired) - Leather
Design 1594
Wired) - Mordular
A26/B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard Wired) - Mordular
Design 1595
Wired) - Vinyl
A26/B6.7/L9 - Seats (RollTek) Drivers Seat Only (Hard Wired) - Vinyl Design 1596
A26/B6.7/L9 - Seatbelt Reminder 6 Seats
A26/B6.7/L9 - Seatbelt Reminder 6 Seats Design 1597
A26/B6.7/L9 - Seatbelt Reminder (Warning)(Driver
only)
liiiA26/B6.7/L9 - Seatbelt Reminder (Warning)(Driver only) Design 1598
A26/B6.7/L9 - Seatbelt Reminder (Warning)(Driver &
Passenger in parallel)
A26/B6.7/L9 - Seatbelt Reminder (Warning)(Driver & Passenger in parallel)
Design 1599
Vehicle Data Recorder (No Display)
Vehicle Data Recorder (No Display) Design 1600
Vehicle Data Recorder (W/ Display)
Vehicle Data Recorder (W/ Display) Design 1602
L9 - TEM Electric Trailer Brake Controller Activated
Stop LT
L9 - TEM Electric Trailer Brake Controller Activated Stop LT Design 1604
A26 - TEM Electric Trailer Brake Controller Activated
Stop LT
A26 - TEM Electric Trailer Brake Controller Activated Stop LT Design 1605
Stop LT (Option2)
A26 - TEM Electric Trailer Brake Controller Activated Stop LT (Option2)
Design 1606
B6.7 - TEM Electric Trailer Brake Controller Activated
Stop LT Option 2
B6.7 - TEM Electric Trailer Brake Controller Activated Stop LT Option 2
Design 1607
B6.7 - TEM _Electric Trailer Brake Controller Activated
Stop LT Option 1
B6.7 - TEM _Electric Trailer Brake Controller Activated Stop LT Option 1
Design 1608
L9 - Trailer Interface - ABS (ETB Feed, Blunt Cut)
L9 - Trailer Interface - ABS (ETB Feed, Blunt Cut) Design 1609
B6.7 - Trailer Interface (Lighting) – BLUNT CUT (Part
of Electric Trailer Brakes) Option 1
B6.7 - Trailer Interface (Lighting) – BLUNT CUT (Part of Electric Trailer Brakes)
Option 1 Design 1610
of Electric Trailer Brakes) Option 2
Option 2 Design 1611
L9 - Trailer Interface (Lighting) – BLUNT CUT (Part of
L9 - Trailer Interface (Lighting) – BLUNT CUT (Part of Electric Trailer Brakes)
Option 1 Design 1612
Option 2 Design 1613
livA26 - Auto Neutral (Allison with Multiplex Switch and
Confirmation Telltale)
A26 - Auto Neutral (Allison with Multiplex Switch and Confirmation Telltale)
Design 1614
B6.7 - Auto Neutral HS Output W/ J1939 SW N/Relay
B6.7 - Auto Neutral HS Output W/ J1939 SW N/Relay Design 1615
B6.7 - Auto Neutral (Allision N/ Switch & W/
B6.7 - Auto Neutral (Allision N/ Switch & W/ Confirmation Telltale) Design 1617
B6.7 - Auto Neutral (HS Drive N/ SW N/ Relay)
B6.7 - Auto Neutral (HS Drive N/ SW N/ Relay) Design 1619
L9 - Auto Neutral (Allision N/ Switch & W/
L9 - Auto Neutral (Allision N/ Switch & W/ Confirmation Telltale) Design 1621
L9 - Auto Neutral (Allison without Multiplex Switch
L9 - Auto Neutral (Allison without Multiplex Switch and Confirmation Telltale)
Design 1624
L9 - Auto Neutral (Allison with Multiplex Switch and
L9 - Auto Neutral (Allison with Multiplex Switch and Confirmation Telltale)
Design 1626
A26 - Rock Free Transmission
A26 - Rock Free Transmission Design 1628
B6.7/L9 - Transmission Shifter (T-Handle for Allison,
N/ Park Position)
B6.7/L9 - Transmission Shifter (T-Handle for Allison, N/ Park Position)
Design 1629
A26 - Transmission Shifter (Stalk Shifter, Eaton
Endurant)
A26 - Transmission Shifter (Stalk Shifter, Eaton Endurant) Design 1630
A26 - Transmission Shifter (Universal Stalk Shifter -
Allison 3K/4K
A26 - Transmission Shifter (Universal Stalk Shifter - Allison 3K/4K Design 1631
Ultrashift)
A26 - Transmission Shifter (Universal Stalk Shifter - Ultrashift) Design 1632
B6.7 - Transmission Shifter Allison 5th Gen Push
Button(SURHD)
B6.7 - Transmission Shifter Allison 5th Gen Push Button(SURHD) Design 1633
B6.7 - Transmission Shifter (Push Button Shifter -
Allison 3K/4K)
B6.7 - Transmission Shifter (Push Button Shifter - Allison 3K/4K) Design 1635
B6.7 - Transmission Shifter (Stalk Shifter Allison)
lvB6.7 - Transmission Shifter (Stalk Shifter Allison) Design 1637
B6.7 - Transmission Shifter (Universal Stalk Shifter -
Allison 3K/4K)
B6.7 - Transmission Shifter (Universal Stalk Shifter - Allison 3K/4K) Design 1639
B6.7 - Transmission Shifter (T-Handle for Allison With
Park Position)
B6.7 - Transmission Shifter (T-Handle for Allison With Park Position) Design 1641
B6.7 - T-Handle for Allison Without Park Position
B6.7 - T-Handle for Allison Without Park Position Design 1643
L9 - Transmission Shifter Allison 5th Gen Push
Button(SURHD)
L9 - Transmission Shifter Allison 5th Gen Push Button(SURHD) Design 1645
L9 - Transmission Shifter (Push Button Shifter -
Allison 3K/4K)
L9 - Transmission Shifter (Push Button Shifter - Allison 3K/4K) Design 1646
L9 - Transmission Shifter (Stalk Shifter Allison)
L9 - Transmission Shifter (Stalk Shifter Allison) Design 1648
L9 - Transmission Shifter (Universal Stalk Shifter -
Allison 3K/4K)
L9 - Transmission Shifter (Universal Stalk Shifter - Allison 3K/4K) Design 1650
A26/B6.7/L9 - Transfer Case - High/Low Air Sol
A26/B6.7/L9 - Transfer Case - High/Low Air Sol Design 1653
A26/B6.7/L9 - Transfer Case - High/Neu/Low Air Sol
A26/B6.7/L9 - Transfer Case - High/Neu/Low Air Sol Design 1654
A26 - Transmission (Ultrashift + FAS)
A26 - Transmission (Ultrashift + FAS) Design 1655
L9 - Ultrashift Plus
L9 - Ultrashift Plus Design 1656
A26 - Transmission (Allison 3K/4K) 1
A26 - Transmission (Allison 3K/4K) 1 Design 1657
B6.7 - Transmission (Allison 1K/2K)
B6.7 - Transmission (Allison 1K/2K) Design 1658
B6.7 - Transmission (Allison 3K/4K)
B6.7 - Transmission (Allison 3K/4K) Design 1659
L9 - Transmission (Allison 3K/4K)
L9 - Transmission (Allison 3K/4K) Design 1661
A26 - Endurant Transmission
A26 - Endurant Transmission Design 1663
A26 - Transmissions Electrical I/O (Eaton Ultrashift)
A26 - Transmissions Electrical I/O (Eaton Ultrashift) Design 1664
lviA26 - Transmission Electrical I/O (Endurant W/A26 &
N/ Body Builder)
A26 - Transmission Electrical I/O (Endurant W/A26 & N/ Body Builder)
Design 1665
W/ Body Builder)
A26 - Transmission Electrical I/O (Endurant W/A26 & W/ Body Builder)
Design 1666
L9 - Transmissions Electrical I/O (Eaton Ultrashift)
L9 - Transmissions Electrical I/O (Eaton Ultrashift) Design 1667
A26 - Hill Start Aid (Bendix)
A26 - Hill Start Aid (Bendix) Design 1668
A26 - Hill Start Aid (HSA) (Bendix CA 2.0)
A26 - Hill Start Aid (HSA) (Bendix CA 2.0) Design 1670
L9 - Hill Start Aid (Bendix)
L9 - Hill Start Aid (Bendix) Design 1671
L9 - Hill Start Aid (WABCO)
L9 - Hill Start Aid (WABCO) Design 1673
A26 - Transmission Retarder (3K)
A26 - Transmission Retarder (3K) Design 1674
A26 - Transmission Retarder (4K Hardwire Switch)
A26 - Transmission Retarder (4K Hardwire Switch) Design 1675
L9 - Transmission Retarder (3K, Gen 6)
L9 - Transmission Retarder (3K, Gen 6) Design 1676
L9 - Transmission Retarder (4K, Gen 6, Hardwire
Switch)
L9 - Transmission Retarder (4K, Gen 6, Hardwire Switch) Design 1678
L9 - Transmission Retarder (4K, Gen 6, W/ Multiplex)
L9 - Transmission Retarder (4K, Gen 6, W/ Multiplex) Design 1680
L9 - Transmission Retarder (4700 W/ Multiplex)
L9 - Transmission Retarder (4700 W/ Multiplex) Design 1682
L9 - Transmission Retarder (4700, Gen 6, W/ Multiplex)
L9 - Transmission Retarder (4700, Gen 6, W/ Multiplex) Design 1684
A26/B6.7/L9 - Transmission - MODE Selection
A26/B6.7/L9 - Transmission - MODE Selection Design 1686
B6.7/L9 - Transmission Mode Button (1K/2K)
B6.7/L9 - Transmission Mode Button (1K/2K) Design 1687
B6.7/L9 - Transmission - MODE Selection Design 1688
B6.7 - Windshield Washer Pump
B6.7 - Windshield Washer Pump Design 1689
B6.7 - Windshield Washer Pump & Low Fluid Sensor
B6.7 - Windshield Washer Pump & Low Fluid Sensor Design 1690
lviiL9 - Windshield Washer Pump & Low Fluid Sensor
L9 - Windshield Washer Pump & Low Fluid Sensor Design 1691
A26 - Windshield Wipers
A26 - Windshield Wipers Design 1693
B6.7 - Windshield Wipers
B6.7 - Windshield Wipers Design 1694
L9 - Windshield Wipers
L9 - Windshield Wipers Design 1695
B6.7/L9 - Battery Disconnect (W/Switch and
W/Solenoid)
B6.7/L9 - Battery Disconnect (W/Switch and W/Solenoid) Design 1696
A26 - Charging System (Delco Remy 28SI Alternator
W/ Remote Sense)
A26 - Charging System (Delco Remy 28SI Alternator W/ Remote Sense)
Design 1697
A26 - Charging System (Delco Remy 36SI Alternator
W/ Remote Sense)
A26 - Charging System (Delco Remy 36SI Alternator W/ Remote Sense)
Design 1699
A26 - Charging System (Delco Remy 40SI/38SI
A26 - Charging System (Delco Remy 40SI/38SI Alternator W/ Remote Sense)
Design 1701
A26 - Charging System (Leece-Neville AVI160-
160A/210A/240A N/ Remote Sense)
A26 - Charging System (Leece-Neville AVI160-160A/210A/240A N/ Remote
Sense) Design 1703
190A/210A/240A Alternator W/ Remote Sense)
A26 - Charging System (Leece-Neville AVI160-190A/210A/240A Alternator W/
Remote Sense) Design 1705
14931PAH_14923PAH Alternator)
A26 - Charging System (Leece-Neville 14931PAH_14923PAH Alternator)
Design 1707
A26 - Charging System (Leece-Neville - LN 325A
A26 - Charging System (Leece-Neville - LN 325A Alternator W/ Remote Sense)
Design 1709
A26 - Charging System (LH160_LH200)
A26 - Charging System (LH160_LH200) Design 1711
A26 - Charging System (LIL165_LIL200 Alternator W/
Remote Sense)
A26 - Charging System (LIL165_LIL200 Alternator W/ Remote Sense)
Design 1713
lviiiB6.7 - Bosch LH160_LH200 Alternator
B6.7 - Bosch LH160_LH200 Alternator Design 1715
B6.7 - Delco Remy 28SI Alternator W/Sensor Option 1
B6.7 - Delco Remy 28SI Alternator W/Sensor Option 1 Design 1717
B6.7 - Delco Remy 28SI Alternator W/Sensor Option 2
B6.7 - Delco Remy 28SI Alternator W/Sensor Option 2 Design 1718
B6.7 - Delco Remy 36SI Alternator W/Sensor
B6.7 - Delco Remy 36SI Alternator W/Sensor Design 1719
B6.7 - Delco Remy 40SI Alternator W/Sensor
B6.7 - Delco Remy 40SI Alternator W/Sensor Design 1720
B6.7 - Leece-Neville AVI160 Alternator
B6.7 - Leece-Neville AVI160 Alternator Design 1721
B6.7 - Leece-Neville AVI160-210A/240A Alternator
W/Sensor
B6.7 - Leece-Neville AVI160-210A/240A Alternator W/Sensor Design 1722
B6.7 - Leece-Neville 320PAH Alternator
B6.7 - Leece-Neville 320PAH Alternator Design 1723
B6.7 - Leece-Neville - LN 325A Alternator W/Sensor
B6.7 - Leece-Neville - LN 325A Alternator W/Sensor Design 1724
L9 - Bosch LH160_LH200 Alternator
L9 - Bosch LH160_LH200 Alternator Design 1725
L9 - Delco Remy 28SI Alternator W/Sensor
L9 - Delco Remy 28SI Alternator W/Sensor Design 1726
L9 - Delco Remy 36SI Alternator W/Sensor
L9 - Delco Remy 36SI Alternator W/Sensor Design 1727
L9 - Delco Remy 40SI Alternator W/Sensor
L9 - Delco Remy 40SI Alternator W/Sensor Design 1728
L9 - Leece-Neville AVI160 Alternator
L9 - Leece-Neville AVI160 Alternator Design 1729
L9 - Leece-Neville AVI160-210A/240A Alternator
W/Sensor
L9 - Leece-Neville AVI160-210A/240A Alternator W/Sensor Design 1730
L9 - Leece-Neville - LN 325A Alternator W/Sensor
L9 - Leece-Neville - LN 325A Alternator W/Sensor Design 1731
A26 - Cranking (Starter) (BCM Controlled & N/ Wired
Thermal Overcrank)
A26 - Cranking (Starter) (BCM Controlled & N/ Wired Thermal Overcrank)
Design 1732
Thermal Over-Crank 2)
A26 - Cranking (Starter) (BCM Controlled & N/ Wired Thermal Over-Crank 2)
Design 1733
lixA26 - Cranking (Starter) (BCM Controlled & N/ Wired
Thermal Over-Crank)
A26 - Cranking (Starter) (BCM Controlled & N/ Wired Thermal Over-Crank)
Design 1734
A26 - Cranking (Starter) (BCM Controlled & W/ Wired
Thermal Overcrank 2)
A26 - Cranking (Starter) (BCM Controlled & W/ Wired Thermal Overcrank 2)
Design 1735
Thermal Overcrank)
A26 - Cranking (Starter) (BCM Controlled & W/ Wired Thermal Overcrank)
Design 1736
B6.7 - Cranking (Starter) GEN4 BCM W/O Thermal
Overcrank
B6.7 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/O Thermal
Overcrank Design 1737
L9 - Cranking (Starter) GEN4 BCM W/O Thermal
Overcrank
L9 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/O Thermal
Overcrank Design 1738
L9 - Cranking (Starter) GEN4 BCM W/ Thermal
Overcrank - External Switch
L9 - Cranking (Starter) GEN4 BODY CONTROL MODULE W/ Thermal Overcrank
- External Switch Design 1739
A26 - Cranking Request (w/ Key Switch w/ BCM)
A26 - Cranking Request (w/ Key Switch w/ BCM) Design 1740
A26/B6.7/L9 - Key Switch (Operator Input)
A26/B6.7/L9 - Key Switch (Operator Input) Design 1742
B6.7 - Cranking Request (w/ Key Switch w/ BCM)
B6.7 - Cranking Request (w/ Key Switch w/ BCM) Design 1744
L9 - Cranking Request (w/ Key Switch w/ BCM)
L9 - Cranking Request (w/ Key Switch w/ BCM) Design 1746
A26 - Starter Interlocks (BCM controlled with input
from Allison TCM)
A26 - Starter Interlocks (BCM controlled with input from Allison TCM) Design 1747
A26 - Starter Interlocks (Service Brake Interlock)
A26 - Starter Interlocks (Service Brake Interlock) Design 1748
A26 - Starter Interlock (BCM HSD controlled W/ Clutch
SW & N/ (Neutral Switch)
A26 - Starter Interlock (BCM HSD controlled W/ Clutch SW & N/ (Neutral Switch)
Design 1749
A26 - Starter Interlock (BCM HSD Controlled w/ Relay
& N/ Neutral Switch)
A26 - Starter Interlock (BCM HSD Controlled w/ Relay & N/ Neutral Switch)
Design 1750
lxB6.7 - Clutch Switch/Monitoring (High and Low Switch
to BCM)
B6.7 - Clutch Switch/Monitoring (High and Low Switch to BCM) Design 1751
B6.7 - Starter Interlocks (BCM Controlled with Input
from Allison 1K/2K TCM)
B6.7 - Starter Interlocks (BCM Controlled with Input from Allison 1K/2K TCM)
Design 1752
from Allison 3K/4K TCM)
B6.7 - Starter Interlocks (BCM Controlled with Input from Allison 3K/4K TCM)
Design 1753
L9 - Clutch Switch/Monitoring (High and Low Switch
to BCM)
L9 - Clutch Switch/Monitoring (High and Low Switch to BCM) Design 1755
L9 - Starter Interlocks (BCM Controlled with Input
L9 - Starter Interlocks (BCM Controlled with Input from Allison 3K/4K TCM)
Design 1756
L9 - Starter Interlock (BCM HSD controlled W/ Clutch
SW & N/Auto SS)
L9 - Starter Interlock (BCM HSD controlled W/ Clutch SW & N/Auto SS)
Design 1758
L9 - Starter Interlock (BCM LSD Controlled w/ Relay &
N/ Auto SS)_EATON XMSN
L9 - Starter Interlock (BCM LSD Controlled w/ Relay & N/ Auto SS)_EATON
XMSN Design 1759
B6.7 - Battery International (4) 12V
B6.7 - Battery International (4) 12V Design 1760
L9 - Battery International (4) 12V
L9 - Battery International (4) 12V Design 1761
A26 - Battery International (3) 12V
A26 - Battery International (3) 12V Design 1762
A26 - Battery International (4) 12V
A26 - Battery International (4) 12V Design 1763
Connectors 1764
Index 485
- International DT466,DT570,HT570 Diesel Engine Service Manual
- International DT466E Wiring Schematic
- International 365, 444, 466, 530 Service Manuals
- Navistar Diagnostic Trouble Code Index
- SCANIA 420 DC11 - DC12 Motor
- International 9800 Electrical Schematic
- International Truck DT466E Engine Repair Manual
- International - VT365 Schematic (SPA)
- Scania Manual Transmission GRS900
- International Truck 5000i,9200i,9400i and 9900i Chassis Built Electrical Circuit Diagram
- International Trucks Body Controller Diagnostic Trouble Codes
- International Wiring Diagram
- International Truck CF500 CF600 Service Manual
- Scania Manual Transmission GR 900
- International DT466, DT530 Electronic Diagram
