International Truck eMV Series Interactive Schematics 0000018831 2025
Brand: International, Navistar
Type of Manual: Interactive Schematics
Model: International eMV Series Truck
Built: 8/3/2021 To 12/31/2025
Part Number: 0000018831
Publication Date: 2025
Number of Pages: 813 Pages
Body Standard J1939 (250Kbps)
Body Standard J1939 (250Kbps) Design 1
Cab Standard J1939 (250Kbps)
Cab Standard J1939 (250Kbps) Design 2
HV Controls J1939 with InMotion DC/DC 0008WUM
HV Controls J1939 with InMotion DC/DC 0008WUM Design 3
HV Controls J1939 (500Kbps) with Power Solutions
DC/DC 0008WUC
HV Controls J1939 (500Kbps) with Power Solutions DC/DC 0008WUC Design 4
HV Power J1939 (500Kbps)
HV Power J1939 (500Kbps) Design 5
Low Speed J1939 (125Kbps)
Low Speed J1939 (125Kbps) Design 6
Powertrain Standard J1939 (500Kbps)
Powertrain Standard J1939 (500Kbps) Design 7
Diagnostic Mode (Horizon)
Diagnostic Mode (Horizon) Design 8
Instrument Cluster (EGC) EV
Instrument Cluster (EGC) EV Design 9
Instrument Cluster - Bulb Check
Instrument Cluster - Bulb Check Design 10
Vehicle Control Unit (VCU)
Vehicle Control Unit (VCU) Design 11
Center Chassis Ground Splice Pack 8809
Center Chassis Ground Splice Pack 8809 Design 13
Forward Chassis Ground Splice Pack 8800
Forward Chassis Ground Splice Pack 8800 Design 14
Interior Dual Post Ground Stud-Cowl Wall
Interior Dual Post Ground Stud-Cowl Wall Design 15
IP Ground Splice Packs 1022/1023 and 1027 Option 1
IP Ground Splice Packs 1022/1023 and 1027 Option 1 Design 16
IP Ground Splice Packs 1022/1023 and 1027 Option 2
IP Ground Splice Packs 1022/1023 and 1027 Option 2 Design 17
Powertrain Ground Distribution
Powertrain Ground Distribution Design 18
ZVR Splice Packs 1620
ZVR Splice Packs 1620 Design 19
Battery Feed
Battery Feed Design 20
Interior PDM Chart
Interior PDM Chart Design 21
iKey Switch Accessory
Key Switch Accessory Design 22
Key Switch Ignition
Key Switch Ignition Design 23
Relays - Grid Management
Relays - Grid Management Design 24
Battery Box Optional PDM for Lift Gate - W/08VBA &
N/510244
Battery Box Optional PDM for Lift Gate - W/08VBA & N/510244 Design 25
Battery Box Optional PDM for Lift Gate - 08VBA &
08VVM
Battery Box Optional PDM for Lift Gate - 08VBA & 08VVM Design 26
ABS CAN Splice Pack - 1410
ABS CAN Splice Pack - 1410 Design 27
Panel Light Dimmer Splice Pack - 1021
Panel Light Dimmer Splice Pack - 1021 Design 28
Park / Turn Lights Splice Packs 1623/1625/400
Park / Turn Lights Splice Packs 1623/1625/400 Design 29
VCU PDM and Underhood PDM
VCU PDM and Underhood PDM Design 30
(PDM 1) VCU PDM and (PDM 2) Underhood PDM (Rev
2)
(PDM 1) VCU PDM and (PDM 2) Underhood PDM (Rev 2) Design 31
Air Governor Control
Air Governor Control Design 32
Antenna (Shark Fin, AM/FM/WB only)
Antenna (Shark Fin, AM/FM/WB only) Design 33
Antenna (Shark Fin, Day Cab, OTAPM, AM/FM, XM
Radio)
Antenna (Shark Fin, Day Cab, OTAPM, AM/FM, XM Radio) Design 34
Radio W/ Bluetooth
Radio W/ Bluetooth Design 35
Radio W/ Bluetooth & W/ Steering Wheel Pod
Radio W/ Bluetooth & W/ Steering Wheel Pod Design 36
Speakers: Four Speakers & N/QC
Speakers:Four Speakers & N/QC Design 37
Aux Power (Blunt Cut)
Aux Power (Blunt Cut) Design 38
Forward Auxiliary Power Source (1 APO)(Option 1)
Forward Auxiliary Power Source (1 APO)(Option 1) Design 39
iiForward Auxiliary Power Source (1 APO)(Option 2)
Forward Auxiliary Power Source (1 APO)(Option 2) Design 42
Forward Auxiliary Power Source (2 APO)(Option 1)
Forward Auxiliary Power Source (2 APO)(Option 1) Design 46
Forward Auxiliary Power Source (2 APO)(Option 2)
Forward Auxiliary Power Source (2 APO)(Option 2) Design 49
Forward Auxiliary Power Source (3 APO)(Option 1)
Forward Auxiliary Power Source (3 APO)(Option 1) Design 55
Forward Auxiliary Power Source (3 APO)(Option 2)
Forward Auxiliary Power Source (3 APO)(Option 2) Design 56
Backup Alarm (From Relay to 5 Pin Daisy Chain.
Backup Alarm Plugs in)
Backup Alarm (From Relay to 5 Pin Daisy Chain. Backup Alarm Plugs in)
Design 60
CB Radio Power Only
CB Radio Power Only Design 61
Door Ajar Reminder (Entry/Exit) (2 Doors)
Door Ajar Reminder (Entry/Exit) (2 Doors) Design 62
Mirrors (Heated) (Door Pod Actuated 2 Cab and 1
Hood Mirror Left Side Only)
Mirrors (Heated) (Door Pod Actuated 2 Cab and 1 Hood Mirror Left Side Only)
Design 63
Mirrors (Heated) (Door Pod Actuated, Cab Mounted, 1-
Door)
Mirrors (Heated) (Door Pod Actuated, Cab Mounted, 1-Door) Design 64
Mirrors (Heated) (Door Pod Actuated, 2 Cab and 2
Hood Mirrors)
Mirrors (Heated) (Door Pod Actuated, 2 Cab and 2 Hood Mirrors) Design 65
Mirrors (Heated) (MUX Switch, 2 Cab and 1 Hood
Mirrors (Heated) (MUX Switch, 2 Cab and 1 Hood Mirror Left Side Only) Design66
Mirrors (Power) (2 Door Pods)
Mirrors (Power) (2 Door Pods) Design 67
Power Door Locks (2-Door)
Power Door Locks (2-Door) Design 68
City Horn
City Horn Design 69
Electronic Logging Device (ELD) Indicator (J1939
Switchpack Indicator)
Electronic Logging Device (ELD) Indicator (J1939 Switchpack Indicator) Design70
Power Windows (2-Door)
Power Windows (2-Door) Design 71
Real Time Clock (RTC) (Standard)
iiiReal Time Clock (RTC) (Standard) Design 72
Remote Keyless Access
Remote Keyless Access Design 73
Over The Air Electrical I/O (OnCommand Link / N2
Module N/ Engine Diagnostic Connector)
Over The Air Electrical I/O (OnCommand Link / N2 Module N/ Engine Diagnostic
Connector) Design 74
Over the Air Programming (OnCommand Link / N2
Module)
Over the Air Programming (OnCommand Link / N2 Module) Design 75
Theft Deterrent (Standard, J1939 Mux SW, W/VCU)
Theft Deterrent (Standard, J1939 Mux SW, W/VCU) Design 76
Aux Power (USB) - 1 USB A, 1 USB C
Aux Power (USB) - 1 USB A, 1 USB C Design 77
Aux Power (USB) - 1 USB A, 1 USB C (Rev 2)
Aux Power (USB) - 1 USB A, 1 USB C (Rev 2) Design 81
Aux Power (USB) - 2 USB A, 2 USB C
Aux Power (USB) - 2 USB A, 2 USB C Design 84
Aux Power (USB) - 2 USB A, 2 USB C (Rev 2)
Aux Power (USB) - 2 USB A, 2 USB C (Rev 2) Design 90
Aux Power (USB) - 3 USB A, 3 USB C
Aux Power (USB) - 3 USB A, 3 USB C Design 93
Aux Power (USB) - 3 USB A, 3 USB C (Rev 2)
Aux Power (USB) - 3 USB A, 3 USB C (Rev 2) Design 97
Vehicle Alarm System (Standard)
Vehicle Alarm System (Standard) Design 98
Vehicle Sleep Mode
Vehicle Sleep Mode Design 99
Vehicle Sound Generator
Vehicle Sound Generator Design 100
Camera (LYTX Prewire) W/Event Recording Button
Camera (LYTX Prewire) W/Event Recording Button Design 101
Battery Management System (Post 05-2022) Option 1
Battery Management System (Post 05-2022) Option 1 Design 103
Battery Management System (Post 05-2022) Option 2
Battery Management System (Post 05-2022) Option 2 Design 105
Battery Management System (Pre 05-2022)
Battery Management System (Pre 05-2022) Design 107
Battery Thermal Management System (BTMS) Internal
Components
Battery Thermal Management System (BTMS) Internal Components Design 109
ivBattery Thermal Management (W/VCU) BTMS
Battery Thermal Management (W/VCU) BTMS Design 110
Auxiliary Air Solenoids (Normally Closed)
Auxiliary Air Solenoids (Normally Closed) Design 111
Body Builder Aux Power (IGN Power, EOF, Blunt Cut)
Body Builder Aux Power (IGN Power, EOF, Blunt Cut) Design 112
Body Builder Lighting - (8HAA) (Blunt Cut)
Body Builder Lighting - (8HAA) (Blunt Cut) Design 113
Body Builder Power Prewire (ePower Prewire)
Body Builder Power Prewire (ePower Prewire) Design 114
Power Lift Gate
Power Lift Gate Design 115
Antilock Brake System (ABS) (BENDIX 4 Channel
Implemenation - No Modulator Twist)
Antilock Brake System (ABS) (BENDIX 4 Channel Implemenation - No Modulator
Twist) Design 116
Park Brake Controls (W/VCU)
Park Brake Controls (W/VCU) Design 117
Park Brake Reminder (Stationary) (CA2.0)
Park Brake Reminder (Stationary) (CA2.0) Design 118
Service Brake Switch (2 SLS/ 1 Transducer/ 2 RDS to
VCU)
Service Brake Switch (2 SLS/ 1 Transducer/ 2 RDS to VCU) Design 119
Stability Control (Bendix, Straight Truck, J1939 Driven
Lamp)
Stability Control (Bendix, Straight Truck, J1939 Driven Lamp) Design 120
Traction Control (Bendix, VCU)
Traction Control (Bendix, VCU) Design 121
Drive Mode Selector I/O (W/VCU)
Drive Mode Selector I/O (W/VCU) Design 122
Hybrid Auxiliary Power Generator for HEV (DC/AC
Inverter).
Hybrid Auxiliary Power Generator for HEV (DC/AC Inverter). Design 123
Regenerative Braking (W/VCU)
Regenerative Braking (W/VCU) Design 125
Vehicle Acceleration (Wired to VCU)
Vehicle Acceleration (Wired to VCU) Design 126
Coolant Level Monitoring (W/VCU)
Coolant Level Monitoring (W/VCU) Design 127
Coolant Temperature Monitoring (J1939 Comm,
W/VCU)
vCoolant Temperature Monitoring (J1939 Comm, W/VCU) Design 128
Power Electronics Coolant Temperature Monitoring
Power Electronics Coolant Temperature Monitoring Design 129
Propulsion Coolant Temperature Monitoring (W/VCU)
Propulsion Coolant Temperature Monitoring (W/VCU) Design 130
Inverter)
Hybrid Auxiliary Power Generator for HEV (DC/AC Inverter) Design 131
Engine Speed Control (ePTO)
Engine Speed Control (ePTO) Design 132
Automatic Lighting W/Twilight & W/Sunload
Automatic Lighting W/Twilight & W/Sunload Design 135
Backup Light (W/VCU) Dual Daisy Reverse Light
Backup Light (W/VCU) Dual Daisy Reverse Light Design 136
Rear Lights (Stop) (W/VCU) W/Daisy Chain
Rear Lights (Stop) (W/VCU) W/Daisy Chain Design 137
Clearance and Identification Lights N/SUNSHADE
AMBER LENS
Clearance and Identification Lights N/SUNSHADE AMBER LENS Design 138
Daytime Running Lights W/CAN Headlamps
Daytime Running Lights W/CAN Headlamps Design 139
Directional Signals (Turn) (LED CAN) W/O Plow
Lights, W/O Fender Lights
Directional Signals (Turn) (LED CAN) W/O Plow Lights, W/O Fender Lights
Design 140
Exterior Lamp Check (Horizon)
Exterior Lamp Check (Horizon) Design 141
Exterior Lighting On Reminder
Exterior Lighting On Reminder Design 142
Front Fog Lamps
Front Fog Lamps Design 143
Marker Lighting (LED CAN Headlamp) N/Plow Lts,
N/Fender Lts, N/Guide Posts
Marker Lighting (LED CAN Headlamp) N/Plow Lts, N/Fender Lts, N/Guide Posts
Design 144
Hazard Warning (CA 2.0)
Hazard Warning (CA 2.0) Design 145
Headlights (LED CAN) W/O Plow Lights
Headlights (LED CAN) W/O Plow Lights Design 146
License Plate Light (LED BOX LAMP Daisy Chain Tail Light)
License Plate Light (LED BOX LAMP Daisy Chain Tail Light) Design 147
viMirror Lighting (Turns N/ Door Pods)
Mirror Lighting (Turns N/ Door Pods) Design 148
Mirror Lighting (Turns W/ Door Pods)
Mirror Lighting (Turns W/ Door Pods) Design 149
Park Lights (W/Marker Interrupt)
Park Lights (W/Marker Interrupt) Design 150
Park Lights - N/Marker Interrupt
Park Lights - N/Marker Interrupt Design 151
End of Frame Aux Work Light (One Light N/Relay)
End of Frame Aux Work Light (One Light N/Relay) Design 152
Jaw Unlock Control W/ SOLENOIDS W/SWITCH
PACKS
Jaw Unlock Control W/ SOLENOIDS W/SWITCH PACKS Design 153
Heating Ventilation & Air Conditioning (HVAC)
(W/VCU)
Heating Ventilation & Air Conditioning (HVAC) (W/VCU) Design 154
Heating, Ventilation, & Air Conditioning (HVAC) (W/VCU) (Rev 2)
Heating, Ventilation, & Air Conditioning (HVAC) (W/VCU) (Rev 2) Design 157
HVAC Actuators
HVAC Actuators Design 160
High-Voltage Interlock
High-Voltage Interlock Design 161
Charge Port Monitoring OCI System
Charge Port Monitoring OCI System Design 162
Charge Port Monitoring OCI System (Rev 2)
Charge Port Monitoring OCI System (Rev 2) Design 163
Charging System (W/VCU) Dual DC/DC Converter W/
Power Solutions 0008WUC
Charging System (W/VCU) Dual DC/DC Converter W/ Power Solutions 0008WUC
Design 164
Charging System (W/VCU) Dual DC/DC Converter 12V
W/ InMotion 0008WUM
Charging System (W/VCU) Dual DC/DC Converter 12V W/ InMotion 0008WUM
Design 165
eVehicle Charging (W/VCU) Onboard Charging
Modules
eVehicle Charging (W/VCU) Onboard Charging Modules Design 167
High-Voltage Battery System
High-Voltage Battery System Design 168
High-Voltage Distribution Module (HVDM)
High-Voltage Distribution Module (HVDM) Design 169
viiHigh-Voltage Distribution Unit (HVDU)
High-Voltage Distribution Unit (HVDU) Design 170
High-Voltage Monitor
High-Voltage Monitor Design 171
High-Voltage Power Distribution System
High-Voltage Power Distribution System Design 172
Ambient Temperature (No Display, Mirror Sensor,
VCU)
Ambient Temperature (No Display, Mirror Sensor, VCU) Design 173
Compressed Air Supply (Primary & Secondary Gauge)
(Dual Air Brake System)
Compressed Air Supply (Primary & Secondary Gauge) (Dual Air Brake System)
Design 174
Gauge)(W/2 in 1 Inverter)
Compressed Air Supply (Primary & Secondary Gauge)(W/2 in 1 Inverter)
Design 175
Engine Speed (Tachometer, W/VCU)
Engine Speed (Tachometer, W/VCU) Design 176
Odometer (W/VCU)
Odometer (W/VCU) Design 177
Trip Odometer (W/VCU)
Trip Odometer (W/VCU) Design 178
Voltage Monitoring (Voltmeter) (Horizon)
Voltage Monitoring (Voltmeter) (Horizon) Design 179
Engine Warning (DM1 LAMPS - MUX)
Engine Warning (DM1 LAMPS - MUX) Design 180
Vehicle Speed Control (Cruise Control) (Steering
Wheel Controls, W/VCU)
Vehicle Speed Control (Cruise Control) (Steering Wheel Controls, W/VCU)
Design 181
Cab Dome Lights (CA 2.0 Standard Cab/Low Rise
Sleeper)
Cab Dome Lights (CA 2.0 Standard Cab/Low Rise Sleeper) Design 182
Cab Dome Light W/Classic Trim (MV, HV, HX)
Cab Dome Light W/Classic Trim (MV, HV, HX) Design 183
Courtesy Step Lighting (2 Door)
Courtesy Step Lighting (2 Door) Design 184
Interior Task Lighting (Map Light) (CA 2.0 Standard
Interior Task Lighting (Map Light) (CA 2.0 Standard Cab/Low Rise Sleeper)
Design 185
viiiPanel Backlighting (Cabin Dimmer)
Panel Backlighting (Cabin Dimmer) Design 186
Height Control (W/VCU)
Height Control (W/VCU) Design 187
Seatbelt Reminder (Warning)(Driver only)
Seatbelt Reminder (Warning)(Driver only) Design 188
Windshield Washer Pump W/O Low Fluid Sensor
Windshield Washer Pump W/O Low Fluid Sensor Design 189
Windshield Washer Pump & Low Fluid Sensor (MV,
CE)
Windshield Washer Pump & Low Fluid Sensor (MV, CE) Design 190
Windshield Wipers
Windshield Wipers Design 191
Cranking Request (BCM Controlled)
Cranking Request (BCM Controlled) Design 192
Cranking (W/VCU)
Cranking (W/VCU) Design 193
Operator Input (Key Switch)
Operator Input (Key Switch) Design 194
Battery International (2) 12V (Horizon)
Battery International (2) 12V (Horizon) Design 195
12v Battery Disconnect (Switch Only)
12v Battery Disconnect (Switch Only) Design 196
Connectors 197
Index 792
DC/DC 0008WUC
Battery Feed
Interior PDM Chart
Key Switch Ignition
N/510244
08VVM
2)
Radio)
Radio W/ Bluetooth
Design 60
CB Radio Power Only
Design 63
Door)
Hood Mirrors)
City Horn
City Horn Design 69
Module)
Vehicle Sleep Mode
Components
Power Lift Gate
Twist) Design 116
VCU)
Lamp)
Inverter).
W/VCU)
Inverter)
AMBER LENS
Design 140
Front Fog Lamps
Design 144
PACKS
(W/VCU)
HVAC Actuators
Design 164
W/ InMotion 0008WUM
Design 165
Modules
VCU)
Design 174
Design 175
Odometer (W/VCU)
Design 181
Sleeper)
Design 185
CE)
Windshield Wipers
Cranking (W/VCU)
Connectors 197
Index 792
- International DT466,DT570,HT570 Diesel Engine Service Manual
- International DT466E Wiring Schematic
- International 365, 444, 466, 530 Service Manuals
- Navistar Diagnostic Trouble Code Index
- SCANIA 420 DC11 - DC12 Motor
- International 9800 Electrical Schematic
- International Truck DT466E Engine Repair Manual
- International - VT365 Schematic (SPA)
- Scania Manual Transmission GRS900
- International Truck 5000i,9200i,9400i and 9900i Chassis Built Electrical Circuit Diagram
- International Trucks Body Controller Diagnostic Trouble Codes
- International Wiring Diagram
- International Truck CF500 CF600 Service Manual
- Scania Manual Transmission GR 900
- International DT466, DT530 Electronic Diagram
