International Truck 3200 to RXT Electrical Diagram S08315 2009
Brand: International, Navistar
Type of Manual: Electrical Diagram, Circuit Diagram
Model: 3200 Start Date: 10/01/2005 End Date: 02/28/2007; 4100 Start Date: 10/01/2005 End Date: 02/28/2007
4200 Start Date: 10/01/2005 End Date: 02/28/2007; 4300 Start Date: 10/01/2005 End Date: 02/28/2007
4400 Start Date: 10/01/2005 End Date: 02/28/2007; 7300 Start Date: 10/01/2005 End Date: 02/28/2007
7400 Start Date: 10/01/2005 End Date: 02/28/2007; 7500 Start Date: 10/01/2005 End Date: 02/28/2007
7600 Start Date: 10/01/2005 End Date: 02/28/2007; 7700 Start Date: 10/01/2005 End Date: 02/28/2007
8500 Start Date: 10/01/2005 End Date: 02/28/2007; 8600 Start Date: 10/01/2005 End Date: 02/28/2007
MXT Start Date: 07/06/2006 End Date: 02/28/2007; RXT Start Date: 07/06/2006 End Date: 02/28/2007
Part Number: S08315
Publication Date: 05/01/2009
Number of Pages: 289 Pages
1. Instructions And Charts (Chapter 1)
1.1. Circuit Number Identification And Location Chart, P. 1
1.2. Circuit Number Identification And Location Chart, P. 2
1.3. Circuit Number Identification And Location Chart, P. 3
1.4. Circuit Number Identification And Location Chart, P. 4
1.5. Circuit Number Identification And Location Chart, P. 5
1.6. Navpak/Ecm I6 Engine Controller Connector Pin Number Identification, P.
6
1.7. Circuit Diagram Instructions, P. 7
1.8. Circuit Diagram Instructions, P. 8
1.9. Schematic Symbol Chart, P. 9
1.10. Relay Functions, P. 10
1.11. Lamp Bulb Chart, P. 11
1.12. International V8 And I6 Ecm Controller Connectors Pin Number
Identification, P.12
2. 12 Volt Power Distribution Circuit Diagrams (Chapter 2)
2.1. Accessory, P. 1
2.2. Battery Feeds, Cab, P. 2
2.3. Battery, P. 3
2.4. 1708 Data Link-Chassis, P. 4
2.5. J–1708 Data Link-Cab, P. 4a
2.6. Switch Data Link, P. 5
2.7. Drivetrain 1939 Data Link (Cab), P. 6
2.8. Drivetrain 1939 Data Link (Chassis), P. 7
2.9. J1939 Data Link — Mxt, P. 7a
2.10. Grounds, Chassis, P. 8
2.11. Grounds, Chassis, P. 9
2.12. Grounds, Ip, P. 10
2.13. Grounds, Ip, P. 11
2.14. Ignition Cab With Theft Deterrent, P. 12
2.15. Ignition Cab, P. 13
2.16. Ignition Feeds, Chassis, P. 14
2.17. Start, P. 15
3. Cab Accessories (Chapter 3)
3.1. Cigar Lighter And Power Feeds, P. 1
3.2. Cb Power, P. 2
3.3. Compass And Temperature Display, P. 3
3.4. Front Doors Windows And Locks (Power), P. 4
3.5. Crew Doors Windows And Locks (Power), P. 5
3.6. Horn, Dual Electric, P. 6
3.7. Mirrors (Heated, Lighted And Power), P. 7
3.8. Radio (Entertainment), Speakers, P. 8
3.9. Windshield Wiper And Washer Pump, P. 9
3.10. 2–Way Radio, P. 10
3.11. Switch Pack, Optional Gauge Pack, P. 11
S08315ii 3200, 4100, 4200, 4300, 4400, 7300, 7400, 7500, 7600, 7700, 8500, 8600, Mxt, Rxt
Models Built Oct. 1, 2005 To Feb. 28, 2007 — Electrical Circuit Diagrams
3.12. Lighted Air Shield, P. 12
3.13. Roof Aux. Load, P. 13
3.14. Satellite Communication Qualcomm-Mct And Imct Systems, P. 14
3.15. Self Contained Air Seat, P. 15
3.16. Digital Clock Ptc, P. 16
3.17. Transmission Allison Lct Column Shifter, P. 17
3.18. Heated Seats For 7700 Models Only, P. 18
3.19. Backup Camera, P. 19
3.20. Xata Computer, P. 20
3.21. Keyless Ignition System, P. 21
3.22. Telematics System, P. 22
3.23. Eaton Vorad Collision Avoidance System, P. 23
3.24. Eaton Vorad Collision Avoidance System, P. 24
3.25. Eaton Vorad Collision Avoidance System, P. 25
3.26. Xata Data System, P. 26
3.27. Cadec Gps System, P. 27
3.28. Trip Master, P. 28
3.29. Entertainment System — Rxt, P. 29
3.30. Entertainment System — Rxt, P. 30
3.31. Entertainment System — Rxt, P. 31
3.32. Entertainment System — Rxt, P. 32
3.33. Rxt — Apo_1 And Apo_2 Auxiliary Power Socket, P. 33
3.34. Tachograph, P. 34
3.35. Communications System, Aware, P. 35
3.36. Communications System, Aware, P. 36
4. 12v Charging + Cranking System (Chapter 4)
4.1. I6 Egr Engines, P. 1
4.2. V8 Avnt Engines, P. 2
4.3. Caterpillar, Cummins Ism Engines, P. 3
4.4. I6 Heui Engines, P. 4
4.5. Caterpillar Engines, Cummins Ism And With Eaton Ultrashift/Dm2, P. 5.
4.6. I6 Egr Engines With Air Start, P. 6
4.7. I6 Egr And Power Pack 3kw, P. 7
5. Fans And Engine Accessories (Chapter 5)
5.1. Fan Wiring, International Engines, P. 1
5.2. Ether Start, P. 2
5.3. Snow Valve, P. 3
5.4. Fan Wiring, Caterpillar And Cummins, P. 4
5.5. Engine Fan, Mwm Engine, P. 5
5.6. Exhaust Brake, Mwm Engine, P. 6
6. Electronic Engines (Chapter 6)
6.1. Electronic Engine Controls, I6–Egr Engines, P. 1
6.2. Electronic Engine Controls, I6–Egr Engine Cruise Control And Body
Builder Connections, P. 2
6.3. Electronic Engine Controls, (V8–Avnt) Engines, P. 3
6.4. Electronic Engine Controls, V8–Avnt Engine Cruise Control And Body
Builder Connections, P. 4
6.5. Caterpillar C10, C11, C12, And C13 Engines, P. 5
6.6. Cummins Ism Engine, P. 6
6.7. I6 Heui Engine, P. 7
S083153200, 4100, 4200, 4300, 4400, 7300, 7400, 7500, 7600, 7700, 8500, 8600, Mxt, Rxt
6.8. I6 Heui Engine Cruise Control And Body Builder Connections With Manual
Transmission, P. 8
6.9. Road Speed Signal, P. 9
6.10. Mwm Engine — Multiplexed Monitoring Unit, P. 10
7. Gauges With And Without Integral Warning Light (Chapter 7)
7.1. Ip/Gauge List, P. 1
7.2. Warning Light List, P. 2
7.3. Warning Lights Controlled By Engine, Transmission, Abs Controller, P.
3
7.4. Engine Oil Pressure And Temp, Speedometer, Tach, Voltmeter And Water
Temp Gauge Circuits, P. 4
7.5. Ip/Gauges And Warning Lights — Gauge Cluster, P. 5
7.6. Air Pressure Input Circuit, P. 6
7.7. Axle Temperature, Fwd Rear And Rear Axles, Gauge Input Circuit, P. 7.
7.8. Fuel Gauge Input Circuit (Single Tank) Differential Lock Warning Lamps,
8
7.9. Gauges And Warning Lights — Fuel Filter Heater And Water In Fuel Lights,
P. 9
7.10. Gauges And Warning Lights — Park Brake Light And Transmission Oil Temp.
Gauge, P. 10
7.11. Gauges And Warning Lights — Ammeter, P. 11
7.12. Engine Oil Temperature Gauge With Caterpillar, P. 12
7.13. Front Axle Engagement Warning Lamp, P. 13
8. Lights (Chapter 8)
8.1. Backup Lights, P. 1
8.2. Light Systems — Clearance, Marker, And Park, P. 2
8.3. Light Systems — Clearance, Marker, Park, Tail, Turn And Stop Lamps, P.
3
8.4. Light Systems — Turn Signal And Stop Switches, P. 4
8.5. Dome Light, Map Light, P. 5
8.6. Dome Light, Map Light (Cont.), P. 6
8.7. Fog Light And Work Light, P. 7
8.8. Headlights, P. 8
8.9. Aux. Headlights, Aux. Park, Aux Turn, P. 9
8.10. Panel Lights, P. 10
8.11. Rxt Exterior Lighting, P. 11
8.12. Tail, Turn, And Stop Lamps, P. 12
8.13. Mxt — Exterior Lighting, P. 13
9. Chassis Accessories (Chapter 9)
9.1. Air Dryer And Heated Drain Valve, P. 1
9.2. Antilock Brake System (Abs), Air, P. 2
9.3. Antilock Brake System (Abs), Air, Traction Control, P. 3
9.4. Antilock Brake System (Abs), Hydraulic, P. 4
9.5. Antilock Brake System (Abs), Hydraulic (Cont.), P. 5
9.6. Antilock Brake System (Abs), Hydraulic (Cont.), P. 6
9.7. Two Speed Axle Switch With Manual Transmission And I6 Heui Fuel Heater
N/Warn Lights, P. 7
9.8. Brake System, Hydraulic, P. 8
9.9. Fuel Transfer Pump, P. 9
9.10. Back Of Cab Body Builder And Trailer Stop, Tail, Marker, P. 10
S08315iv 3200, 4100, 4200, 4300, 4400, 7300, 7400, 7500, 7600, 7700, 8500, 8600, Mxt,
9.11. Back Of Cab Body Builder And Trailer Stop, Tail, Marker, P. 10a
9.12. Body Builder And Trailer Turns, Center Pin Abs, Center Pin Aux, P. 11
9.13. Body Builder And 7–Way Trailer Socket Back Of Cab Socket, P. 12
9.14. Body Builder And Trailer Socket End Of Frame (Eof) Socket And Body
Builder, P. 13
9.15. Air Solenoid 4–Way Pack, P. 14
9.16. Remote Power Units, Solenoid Packs, Remote Engine Speed Controller,
15
9.17. Chassis Accessories, P. 16
9.18. Air Suspension, P. 17
9.19. Aux. Trailer, Acc Controlled, P. 18
9.20. Aux. Trailer, Btry Controlled, P. 19
9.21. Lift Axles (Non-Steerable), P. 20
9.22. Lift Axles (Steerable), P. 21
9.23. Air Actuated Park Brake, P. 22
9.24. Antilock Brake System, Wabco Air, P. 23
9.25. Antilock Brake System, Wabco Air, P. 24
9.26. Lift Axles, With Non—Steerable For Ss Models, P. 25
9.27. Fuel / Water Separator With 12vdc Fuel Preheater, P. 26
9.28. Electronic Trailer Brake Accommodation, P. 27
9.29. Lectrashift Accommodation, P. 28
9.30. Auxiliary 40 Amp Circuit, P. 29
9.31. Hourmeter, Customer Mounted Pto, P. 30
9.32. Remote Start/ Stop, P. 31
9.33. Lift Axle With 14rar, P. 32
9.34. Lift Gate, P. 33
9.35. Lift Axle Multiplex, P. 34
9.36. Body Builder Wheelchair Lift Interlock Electrical Connection, P. 35.
9.37. Air Park Brake Interlock, P. 36
9.38. Hydraulic Abs — Wabco Full Power, P. 37
9.39. Center Pin Circuit, P. 38
9.40. Fifth Wheel Circuit, P. 39
9.41. Hydraulic Power Brake With Sahr Park Brakes, P. 40
9.42. Air Compressor, P. 41
9.43. Electric Air Compressor, P. 42
10. Transmissions (Chapter 10)
10.1. Allison Gen4 Lct Transmission Or Allison 1000, 2000, 2400, P. 1
10.2. Allison Gen4 Lct Transmission Or Allison 1000, 2000, 2400, P. 1a
10.3. Transmission, Lct With V8, P. 1b
10.4. Allison Md Transmission, P. 2
10.5. Allison Gen4 Md Transmission (Wtec), P. 3
10.6. Allison Md Transmission (Cont.), P. 4
10.7. Transmission, Wtec Md W/Auto Neutral, P. 5
10.8. Transmission, Wtec With V8, P. 5a
10.9. Transmission, Wtec With V8, P. 5b
10.10. Eaton Autoshift Transmission, P. 6
10.11. Eaton Autoshift Transmission (Cont.), P. 7
10.12. Eaton Lightning Transmission, P. 8
10.13. Allison Hd Transmission, P. 9
10.14. Allison Hd Transmission, P. 10
10.15. Allison Hd Transmission, P. 11
10.16. Allison Hd Transmission With Auto Neutral, P. 12
10.17. Allison Hd Transmission With Auto Neutral — Gen4, P. 13
10.18. Allison Lct Transmission (Allison 1000, 2000, 2400) With I6 Heui, P. 14
10.19. Transmission Retarder Control Wiring With Md Xmsn, Hard Wired
Effects, P. 15
10.20. Transmission Retarder Control Wiring With Md Xmsn, Hard Wired
Effects, P. 16
10.21. Eaton Ultrashift/Dm2, P. 17
10.22. Eaton Ultrashift/Dm2 (Cont.), P. 18
10.23. Wtec Md Transmission With Auto Neutral, P. 19
10.24. Wtec Md Transmission With Auto Neutral And With 0013wua, P. 19a
10.25. Eaton Autoshift/Ultrashift Transmission (Gen 3), P. 20
10.26. Eaton Hybrid Transmission, P. 21
10.27. Eaton Hybrid Transmission, P. 22
10.28. Eaton Hybrid Transmission, P. 23
10.29. Eaton Hybrid Transmission, P. 24
10.30. Eaton Hybrid Transmission, P. 25
10.31. Eaton Hybrid Transmission, P. 26
10.32. Transfer Case — With Mxt, P. 27
10.33. Transfer Case — With Mxt, P. 28
11. Air Conditioning (Chapter 11)
11.1. Hvac Systems, P. 1
11.2. Air Conditioning, P. 2
11.3. Autotherm Systems, P. 3
12. Connector Composites (Chapter 12)
12.1. Connector Composites (10m), (71), (72), (345f), P. 1
12.2. Connector Composites (420f), (421f), (422m), (520), (521), (522), (523), (524),
2
12.3. Connector Composites (734m), (1002), (1003), P. 3
12.4. Connector Composites (1005), (1006), (1008), (1009), P. 3a
12.5. Connector Composites (1007), (1008), (1010), P. 3b
12.6. Connector Composite (1011), P. 4
12.7. Connector Composite (1012), P. 5
12.8. Connector Composite (1013), P. 6
12.9. Connector Composite (1014), P. 7
12.10. Connector Composites (1016), (1018), (1019), (1019f), (1019m), (1020m), P. 8.
12.11. Connector Composites (1020), (1021m), (1022m), P. 8a
12.12. Connector Composites (1027m, F), (1040), (1100), (1101a), (1101), (1102), P. 9
12.13. Connector Composites (1104), (1105m), (1106), (1200), (1210), (1240), P. 10
12.14. Connector Composites (1300), (1301), (1400), (1402), (1410), (1500), (1510),
11
12.15. Connector Composites (1553), (1554f), (1555), (1600), (1601), (1650), P. 12
12.16. Connector Composites (1652), (1657), (1657m), (1657m2), (1657n), (1657y), (1658),
(1659), (1660), (1661), P. 13
12.17. Connector Composites (1650), (1701), P. 13a
12.18. Connector Composite (1701), P. 13b
12.19. Connector Composites (1703), (1800), (1804), (1807), (1808), (1809), (1810), (1811),
(1812), (1813), (1814), (1815), P. 14
12.20. Connector Composites (1820), (1822), (1823), (1824), (1828), (1852), (1860),
15
12.21. Connector Composites (1861), (1901m), (1905), (1906), (1915), P. 15a
S08315vi 3200, 4100, 4200, 4300, 4400, 7300, 7400, 7500, 7600, 7700, 8500, 8600, Mxt, Rxt
12.22. Connector Composites (1918), (1935), (1920), (2000), (2002m), (2003m), (2004m),
(2005m), P. 16
12.23. Connector Composites (2006m), (2007f), (2021f), (2021m), (2111m), (2112m),
(2113m), (2114m), (2115m), (2116m), (2117m), (2301m), (2302m), (2303m), P. 17
12.24. Connector Composites (2304m), (2305m), (2306m), (2307f), (2308f), (2502f),
(2502m), (2503f, M), (2600f, M), P. 18
12.25. Connector Composites (2601m, F), (2602m, F), (3000m), (3000f), (3002m), (3003),
(3100m), (3200f, M), (3201m), (3202), (3203m), P. 19
12.26. Connector Composites (3204m, F), (3209), (3210m), (3211m), (4000), P. 20
12.27. Connector Composite (4001), P. 21
12.28. Connector Composite (4002), P. 22
12.29. Connector Composite (4003), P. 23
12.30. Connector Composites (4004), (4007), (4008), P. 24
12.31. Connector Composite (4014), P. 25
12.32. Connector Composite (4014/1700), P. 26
12.33. Connector Composites (4015), (4017), (4018), (4019), (4020), (4021), (4022), (4023),
27
12.34. Connector Composites (4024), (4030), (4031), (4032), (4033), (4037), (4038), (4040),
(4041), (4070), (4071), P. 28
12.35. Connector Composites (4087), (4088), (4100), (4101), (4109), (4112), P. 29
12.36. Connector Composite (4103), P. 30
12.37. Connector Composite (4103), P. 30a
12.38. Connector Composites (4105), (4111), (4120), (4301), P. 31
12.39. Connector Composites (4305), (4410), (4410b), (4410c), (4410d), (4410e), (4410h),
(4410m), (4411), P. 32
12.40. Connector Composites (4411a), (4411b), (4412), (4415), (4450), (4450a), (4460a),
(4460), P. 33
12.41. Connector Composite (4705), P. 34
12.42. Connector Composites (4705f32), (4705f3), (4712f), (4713f), (4810), (4820), (4830),
P. 35
12.43. Connector Composites (4840), (4850), (4900), (4906), (4910), P. 36
12.44. Connector Composites (4921), (4922), (4950), (4953), (4954), P. 36a
12.45. Connector Composites (6007), (6011), P. 37
12.46. Connector Composites (6013m), (6014), (6015), P. 38
12.47. Connector Composites (6020), (6021), (6200), (6316), (6323), P. 39
12.48. Connector Composites (6020), P. 39a
12.49. Connector Composites (6331f), (6332), (6333), (6334), (6400), (6401m), (6401),
(6406), (6407), (6407d), (6409), (6500), (6502), (6550), P. 40
12.50. Connector Composites (6703), (6704), (6708), (6900a), (7103), (7104), (7104a),
(7105), (7106), (7107), P. 41
12.51. Connector Composites (7111), (7150), P. 42
12.52. Connector Composite (7151), P. 42a
12.53. Connector Composites (7200), (7202), (7203), P. 42b
12.54. Connector Composites (7204), (7205), (7206), (7208), (7211), (7212), (7213),
43
12.55. Connector Composites (7214), (7250), (7251), P. 44
12.56. Connector Composites (7300), (7301), P. 44a
12.57. Connector Composites (7302), (7304), (7305), (7306), (7350), P. 45
12.58. Connector Composites (7500), (7502), (7503), (7600), (7601), P. 45a
12.59. Connector Composites (7600m), (7603), (7604), (7604m), (7605), (7606), (7607),
(7607m), (7608), (7609), (7610), (7611), (7612), (7613), (7615), (7700), (7702), (7703), (7703a),
P. 46
12.60. Connector Composites (7800), (7801m), (7801r), (7803), (7899), P. 47
12.61. Connector Composites (7900), (7901), (7905), (7906), P. 48
12.62. Connector Composites (7909), (8000), (8001), (8102), (8150), (8151), (8200),
49
12.63. Connector Composites (8201), (8301), (8310), (8311), (8312), (8400), (8500), (8501),
(8502), (8502a), P. 50
12.64. Connector Composites (8503), (8503a), (8505), (8506), (8507), (8508), (8509), (8600),
(8601), (8602), P. 51
12.65. Connector Composites (8700), (8701), (8800), (8801), (8802), (8803), (8805),
52
12.66. Connector Composites (9001), (9002), (9100), (9101), (9102), (9103), (9104), (9254),
(9255), P. 53
12.67. Connector Composites (9260), (9261), (9262), (9263), P. 54
12.68. Connector Composites , (9264), (9265), (9303a), (9405), (9501), (9502), (9503), (9504),
(9505), (9506), (9506/9911), P. 55
12.69. Connector Composites (9507), (9508), (9509), (9510), (9511), (9512), (9513), (9514),
(9515), P. 56
12.70. Connector Composites (9516), (9517), (9518), (9519), (9520e), (9520f), (9521), (9528),
P. 57
12.71. Connector Composite (9700), P. 58
12.72. Connector Composite (9700), P. 59
12.73. Connector Composites (9715/9780), (9715a), (9715b), P. 60
12.74. Connector Composites (9716/9779), (9716a), (9716b), P. 61
12.75. Connector Composites (9717a), (9717b), P. 62
12.76. Connector Composites (9718), (9719), (9720), (9722), (9733), (9734), (9736), (9739),
(9740), (9741), P. 63
12.77. Connector Composites (9742), (9743), (9745), (9754), (9762), (9763), (9765), (9766),
(9767), P. 64
12.78. Connector Composites (9777), (9778), P. 65
12.79. Connector Composites (9870), (9871), (9811), (9812), (9814), (9815), (9830), (9850),
(9860), (9865m), (9900), (9900a), (9913a), P. 66
12.80. Connector Composites (9913b), (9914), (9994), (9999), P. 67
12.81. Connector Composites (1j), (2j), P. 67a
12.82. Connector Composites (9988), (9989), (9990), (9991), (9992), (9993), (9995), (9996),
12.83. Connector Composites (1936), (1937), (1938), (1940), P. 69
12.84. Connector Composites (1943), (1944), (1949), (1997), P. 70
12.85. Connector Composite (9998), P. 71
12.86. Connector Composites (C1), (C15), (C40), (C50), (C60), (C70), (C80), P. 72.
Part Number: S08315
6
2.3. Battery, P. 3
2.17. Start, P. 15
3.2. Cb Power, P. 2
Transmission, P. 8
3
8
P. 9
Gauge, P. 10
3
N/Warn Lights, P. 7
Builder, P. 13
15
Effects, P. 15
Effects, P. 16
2
11
15
(2005m), P. 16
27
(4460), P. 33
P. 35
43
P. 46
49
52
(9255), P. 53
(9515), P. 56
P. 57
(9767), P. 64
- International DT466,DT570,HT570 Diesel Engine Service Manual
- International DT466E Wiring Schematic
- International 365, 444, 466, 530 Service Manuals
- Navistar Diagnostic Trouble Code Index
- SCANIA 420 DC11 - DC12 Motor
- International 9800 Electrical Schematic
- International Truck DT466E Engine Repair Manual
- International - VT365 Schematic (SPA)
- Scania Manual Transmission GRS900
- International Truck 5000i,9200i,9400i and 9900i Chassis Built Electrical Circuit Diagram
- International Trucks Body Controller Diagnostic Trouble Codes
- International Wiring Diagram
- International Truck CF500 CF600 Service Manual
- Scania Manual Transmission GR 900
- International DT466, DT530 Electronic Diagram
