Momed80
150
35,046
International Truck 3200 to RXT Electrical Diagram 0000002842 2019
Brand: International, Navistar
Type of Manual: Electrical Diagram, Circuit Diagram
Model: International 3200
DuraStar - 4100 / 4300 / 4400
WorkStar - 7300 / 7400 / 7500 / 7600 / 7700
TranStar - 8500 / 8600 and RXT Models Built March 19, 2008 to May 16, 2010
Part Number: 0000002842
Publication Date: 2019
Number of Pages: 408 Pages
2. Instructions And Charts (Chapter 2)
2.1. Abbreviations, P. 1
2.2. Acronyms, P. 2
2.3. Circuit Diagram Instructions, P. 3
2.4. Circuit Number Identification And Color, P. 4
2.5. Circuit Number Identification And Color, P. 5
2.6. Circuit Number Identification And Color, P. 6
2.7. Lamp Bulb Chart, P. 7
2.8. Relay Function And Wiring Guide, P. 8
2.9. Schematic Symbol Chart, P. 9
2.10. Schematic Symbol Chart, P. 10
2.11. Schematic Symbol Chart, P. 11
2.12. Schematic Symbol Chart, P.12
3. 12 Volt Power Distribution, Grounds, Data Bus And Electrical System
Controller (Chapter 3)
3.1. Battery Feed, Dual, P. 1
3.2. Battery Feed, Dual (Cont.), P. 2
3.3. Battery Feed, Dual (Cont.), P. 3
3.4. Accessory Feed, P. 4
3.5. Ignition Feed Ñ Standard, Theft Deterrent, Remote Start / Stop, P. 5
3.6. Ignition Feed Relay 1, P. 6
3.7. Ignition Feed Relay 2, P. 7
3.8. Ignition Feed Relay 3, P. 8
3.9. J1708 Data Link Ñ Public Effects, P. 9
3.10. J1708 Data Link Ñ Public Effects (Cont.), P. 10
3.11. J1708 Data Link Ñ Private With Power Window And Lock, P. 11
3.12. J1939 Data Link, P. 12
3.13. J1939 Data Link With Options, P. 13
3.14. J1939 Data Link With Options (Cont.), P. 14
3.15. J1939 Data Link Ñ Ism 2007 / Euro Iv Engine, P. 15
3.16. J1939 Data Link Ñ I6 2007 Engine, P. 16
3.17. J1939 Data Link Ñ C11 / C13 2007 Engine, P. 17
3.18. Ground Ñ Ip, P. 18
3.19. Ground Ñ Ip (Cont.), P. 19
3.20. Ground Ñip (Cont.), P. 20
3.21. Ground Ñ Ip(Cont.) , P. 21
3.22. Engine Ground, P. 22
3.23. Engine Ground Cat C11ñc13 2007 Engine, P. 23
3.24. Ground Ñ Chassis, P. 24
3.25. Ground Ñ Chassis With Heavy Duty Diesel, P. 25
3.26. Ground Ñ Chassis, P. 26
3.27. Ground Ñ Chassis (Cont.), P. 27
3.28. Zero Volt Reference, P. 28
3.29. Ground Ñ Chassis, P. 29
3.30. J1939 Data Link With V8 Engine, P. 30
3.31. Engine Ground Ñ Ibb Engine, P. 31
3.32. J1939 Data Link Ñ Ibb Engine (Cont.), P. 32
3.33. J1939 Data Link Ñ Ibb Engine (Cont.), P. 33
3.34. Battery Feed, Single, P. 34
3.35. Battery Feed, Single (Cont.), P. 35
5.4. Starting And Cranking Cat, Cummins And Ibb Engine With Allison
Transmission, P. 4
5.5. Starting And Cranking I6 Engine With Autoshift, Ultrashift And
Eaton Hybrid Transmission, P. 5
5.6. Starting And Cranking Cat, Euro Iv Ism, And Ibb Engines With
Autoshift And Ultrashift Transmission, P. 6
5.7. I6 Power Pack, P. 7
5.8. Rocker Start, P. 8
6. Fans And Engine Accessories (Chapter 6)
6.1. Fan Wiring, I6 / V8 2007 Engines, P. 1
6.2. Fan Wiring, Ism, C11ñc13 2007 Engines, P. 2
6.3. Starting Aid Ñ Ether Start, P. 3
6.4. Snow Valve, P. 4
6.5. Snow Valve With Ibb Engine, P. 4a
6.6. Starting Aid Ñ Cold Start Assist (Ibb Engine), P. 5
6.7. Fan Wiring Ñ Ibb Engine, P. 6
7. Electronic Engines (Chapter 7)
7.1. Electronic Engine Controls, Cat Engines, P. 1
7.2. Electronic Engine Controls, Cat Engines (Cont.), P. 2
7.3. Engine Body Builder Ñ Remote Engine Control (Cat Engine), P. 3
7.4. Electronic Engine Controls (Ism 2007 / Euro Iv Engine), P. 4
7.5. Electronic Engine Controls, Euro Iv Ism Engine (Cont.), P. 5
7.6. Electronic Engine Controls, Ism 2007 & Euro Iv Ism Engines (Cont.), P. 6 .
7.7. Electronic Engine Controls (Euro Iv Ism Engine), P. 6a
7.8. Electronic Engine Controls (Euro Iv Ism Engine) (Cont.), P. 6ab
7.9. Electronic Engine Controls, I6 Engines, P. 7
7.10. Electronic Engine Controls, I6 Engines (Cont.), P. 8
7.11. Electronic Engine Controls, I6 Engines (Cont.), P. 9
7.12. Electronic Engine Controls, I6 Engines (Cont.), P. 10
7.13. Electronic Engine Controls, I6 Engines, P. 11
7.14. Electronic Engine Controls Ñ V8 Engines, P. 12
7.15. Electronic Engine Controls Ñ V8 Engines (Cont.), P. 13
7.16. Electronic Engine Controls Ñ V8 Engines (Cont.), P. 14
7.17. Cruise Control, P. 15
7.18. Electronic Engine Controls (Ibb Engine), P. 16
7.19. Electronic Engine Controls (Ibb Engine) (Cont.), P. 17
7.20. Electronic Engine Controls (Ibb Engine) (Cont.), P. 17a
7.21. Electronic Engine Controls (Ibb Engine) (Cont.), P. 18
7.22. Electronic Engine Controls (Ibb Engine) (Cont.), P. 19
7.23. Electronic Engine Controls (Ibb Engine) (Cont.), P. 20
7.24. Aftertreatment (Ibb Engine), P. 21
7.25. Aftertreatment (Cat Engine), P. 22
7.26. Aftertreatment (Ism 2007 & Euro Iv Ism Engine), P. 22a
7.27. Aftertreatment (Ism 2007 & Euro Iv Ism Engine), P. 22b
8. Gauges With And Without Internal Warning Light (Chapter 8)
8.1. Ip / Gauges, P. 1
8.2. Warning Light List, P. 2
8.3. Warning Lights Controlled By Engine, Transmission, Abs
Controller, P. 3
8.4. Engine Oil Pressure And Temp, Speedometer, Tachometer, Voltmeter
And Water Temp Gauge Circuits, P. 4
8.5. Ip Gauges And Warning Lights Ñ Gauge Cluster, P. 5
8.6. Air Pressure Input Circuit, P. 6
8.7. Axle Temperature, Gauge Input Circuit, P. 7
8.8. Fuel Gauge Circuitry (Single Tank), P. 8
8.9. Differential Lock Warning Lamps, P. 9
8.10. Park Brake Switch Hydraulic, P. 9a
8.11. Air Park Brake And Manual Transmission Oil Temp Gauge, P. 10
8.12. Freedomline Transmission Oil Temp Gauge And Surge Pump, P. 10a
8.13. Gauges And Warning Lights Ñ Ammeter, P. 11
8.14. Engine Oil Temperature Gauge With Caterpillar, P. 12
8.15. Front Axle Engagement Lamp, P. 13
8.16. Warning Lights Ñ Right Bank Ñ Optional, P. 14
8.17. Warning Lights Ó Left Bank Ó Optional, P. 15
8.18. Load Monitoring, P. 16
9. Lights (Chapter 9)
9.1. Back-Up Lights Without Allison Transmission, P. 1
9.2. Back-Up Lights With Allison Transmission, P. 2
9.3. Light Systems Ñ Clearance, Marker, Park, Tail, Turn And Stop Lights,
P. 3
9.4. Light Systems Ñ Clearance, Marker, Park, Tail, Turn And Stop Lights
(Cont.), P. 4
9.5. Light Systems Ñ Clearance, Marker, Park, Tail, Turn And Stop Lights
(Cont.), P. 5
9.6. Light Systems Ñ Clearance, Marker, Park, Tail, Turn And Stop Lights
(Cont.), P. 6
9.7. Light Systems Ñ Turn Signal And Stop Switches, P. 7
9.8. Dome Light, Map Light, P. 8
9.9. Dome Light, Map Light (Cont.), P. 9
9.10. Dome Light, Map Light (Cont.), P. 10
9.11. Fog Light, P. 11
9.12. Headlights, P. 12
9.13. Aux. Headlights, Snow Plow Lights, P. 13
9.14. Aux. Headlights, Snow Plow Lights (Cont), P. 14
9.15. Panel Lights, P. 15
9.16. Work Light, P. 16
10. Chassis Accessories (Chapter 10)
10.1. Abs Ñ Bendix Air, P. 1
10.2. Abs Ñ Bendix Air, P. 2
10.3. Abs Ñ Bendix Air (Cont.), P. 3
10.4. Abs Ñ Wabco Air (8000 Models), P. 4
10.5. Abs Ñ Wabco Air (4000 / 7000 Models), P. 4a
10.6. Abs Ñ Wabco Air (8000 Models) (Cont.), P. 5
10.7. Abs Ñ Wabco Air (4000 / 7000 Models) (Cont.), P. 5a
10.8. Abs Ñ Wabco Air (4000 / 7000 Models) (Cont.), P. 5b
10.9. Wabco Full Power Brakes, P. 6
11.7. Transmission, Allison Md / Hd (Wtec) With I6 And With V8 Engine (Cont.),
P. 7
11.8. Transmission, Allison Md (Wtec), P. 8
11.9. Transmission, Allison Md (Wtec) (Cont.), P. 8a
11.10. Transmission, Allison Md (Wtec) (Ism Engine), P. 9
11.11. Transmission, Allison Md (Wtec) (Ism Engine), P. 10
11.12. Transmission, Eaton Ultrashift (Ism Euro Iv Engine), P. 10a
11.13. Eaton Autoshift Transmission With I6 Engine, P. 11
11.14. Eaton Autoshift Transmission, P. 12
11.15. Eaton Autoshift Transmission (Cont.), P. 12a
11.16. Transmission Allison Md (Wtec) With Cat Engine, P. 13
11.17. Transmission Allison Md (Wtec) With Cat Engine (Cont.), P. 14
11.18. Transmission Retarder Controls Wiring With Md Transmission Hard
Wired Effects, P. 15
11.19. Eaton Auto And Ultrashift Gen 3 Transmission With Cat And With Ism
Engine, P. 16
11.20. Allison Transmission 3 / 4000 Gen 4 With Auto Neutral, P. 17
11.21. Eaton Ultrashift Gen 3 / Meritor G Ñ Manual Transmission, P. 18
11.22. Eaton Hybrid Transmission, P. 19
11.23. Eaton Hybrid Transmission (Cont.), P. 20
11.24. Eaton Hybrid Transmission (Cont.), P. 21
11.25. Eaton Hybrid Transmission (Cont.), P. 22
11.26. Eaton Hybrid Transmission (Cont.), P. 23
11.27. Eaton Hybrid Transmission (Cont.), P. 23a
11.28. Transmission Allison Md (Wtec) With Cat Engine, P. 24
11.29. Freedomline Transmission With Cat And Ism Engine, P. 25
11.30. Eaton Auto And Ultrashift Gen 3 Transmission With Ibb Engine, P. 26 .
11.31. Transmission Allison With Ibb Engine, P. 27
11.32. Transmission Allison With Ibb Engine, P. 28
11.33. Transmission Allison With Ibb Engine, P. 29
11.34. Transmission Allison With Ibb Engine, P. 30
12. Air Conditioning (Chapter 12)
12.1. Air Conditioning, P. 1
12.2. Air Conditioning, P. 2
12.3. Hvac System, P. 3
12.4. Hvac System (Cont.), P. 4
12.5. Hvac System (Cont.), P. 5
12.6. Autotherm System, P. 6
13. Connector Composites (Chapter 13)
13.1. Connector Composites (1j), (2j), (71), P. 1
13.2. Connector Composites (72), (254f), (254m), (345), (400), P. 2
13.3. Connector Composites (421), (422), (422f), (423), (424), (425), P. 3
13.4. Connector Composites (520), (521), (522), (523), (524), (670a), P. 4
13.5. Connector Composites (672m), (674), (674m), (675), (675m), (677), P. 4a
13.6. Connector Composites (677f), (678), (679), (680), P. 4b
13.7. Connector Composites (682), (827), P. 4c
13.8. Connector Composites (830), (1002), (1003), (1006), P. 5
13.9. Connector Composites (1008), (1009), P. 6
13.10. Connector Composite (1010), P. 7
13.11. Connector Composite (1011), P. 8
13.12. Connector Composite (1012), P. 9
13.13. Connector Composite (1013), P. 10
13.14. Connector Composite (1014), P. 11
13.15. Connector Composite (1015), P. 12
13.16. Connector Composite (1016), P. 13
13.17. Connector Composite (1017), P. 14
13.18. Connector Composite (1018), P. 15
13.19. Connector Composite (1019), P. 16
13.20. Connector Composite (1019) (Cont.), P. 16a
13.21. Connector Composites (1020), P. 17
13.22. Connector Composites (1021), (1022), (1023a), (1023b), P. 18
13.23. Connector Composites (1023c), (1023d), (1024), (1025), P. 18a
13.24. Connector Composites (1025), (1026), (1029), (1069), P. 19
13.25. Connector Composites (1100), (1100ma), (1101), (1101a), P. 20
13.26. Connector Composites (1105), (1106), (1107), (1108), P. 21
13.27. Connector Composites (1109), (1110), (1200), P. 22
13.28. Connector Composites (1210), (1227), (1227m), (1228), P. 23
13.29. Connector Composites (1229), (1230f), (1231), (1240f), P. 24
13.30. Connector Composites (1242), (1243), (1300), (1301), (1338), P. 25
13.31. Connector Composites (1378), (1400), (1401), (1402), P. 26
13.32. Connector Composites (1403), (1410), P. 26a
13.33. Connector Composites (1420), (1421), (1500), P. 27
13.34. Connector Composites (1501), (1510), (1511), (1512), P. 28
13.35. Connector Composites (1556), (1557), (1558), (1600), P. 29
13.36. Connector Composite (1601), P. 30
13.37. Connector Composite (1602), P. 31
13.38. Connector Composites (1603), (1604), (1620), (1623), P. 32
13.39. Connector Composites (1625), (1626), (1650), (1657), P. 33
13.40. Connector Composites (1660), (1661), P. 34
13.41. Connector Composite (1700), P. 35
13.42. Connector Composite (1700), P. 36
13.43. Connector Composite (1700), P. 37
13.44. Connector Composite (1701), P. 38
13.45. Connector Composite (1701), P. 39
13.46. Connector Composite (1701), P. 40
13.47. Connector Composite (1702), P. 41
13.48. Connector Composite (1702), P. 41a
13.49. Connector Composite (1702), P. 42
13.50. Connector Composite (1702), P. 43
13.51. Connector Composite (1809), (1810), (1811), (1812), (1813), (1814), P. 44
13.52. Connector Composites (1800), P. 45
13.53. Connector Composites (1804), (1807), (1808), P. 46
13.54. Connector Composites (1809), (1810), (1811), (1812), (1813), (1815), (1822), P. 47. . .
13.55. Connector Composites (1820), (1821), P. 47a
13.56. Connector Composites (1823), (1824), (1825), (1826), (1827), P. 48
13.57. Connector Composites (1828), (1852), (1860), P. 48a
13.58. Connector Composites (1861), (1872), (1873), (1874), (1875), (1900), P. 49
13.59. Connector Composites (1901), (1902), (1910), (1912), (1916), P. 50
13.60. Connector Composites (1918), (1927), (1929), (1935), (2000), P. 51
13.61. Connector Composites (2000), (2002), (2003), (2004), (2005), (2006), P. 52
13.62. Connector Composites (2020), (2021), (2022), (2115), (2116), (2116m), (2117),
(2117m), P. 53
13.63. Connector Composites (2301), (2302), (2303), (2304), (2305), (2502), P. 54
13.64. Connector Composites (2503), (2600), (2601), (2602), P. 55
13.65. Connector Composites (2700), (2700m), P. 56
13.66. Connector Composites (2701), (2701f), (2701g), (2702), P. 57
13.67. Connector Composites (2990), (2991), (2992), (2993), (2994), (2995), (2996),
(2997), (2998), (2999), (3000), (3001), P. 57a
13.68. Connector Composites (2703), (3000), (3002), (3003), P. 58
13.69. Connector Composites (3100), (3200), (3201), P. 59
13.70. Connector Composites (3202), (3203), (3204), (3208), P. 60
13.71. Connector Composites (3209), (3210), (3211), (3400), (4003), (4004), P. 61
13.72. Connector Composites (4017), (4018), (4019), (4021), (4022), (4037), (4038),
(4070), (4071), P. 62
13.73. Connector Composites (4087 / 4087a), (4111m), (4120), P. 63
13.74. Connector Composites (4328), (4410d), (4410e), P. 64
13.75. Connector Composites (4410f), (4410h), (4410k), (4410l), (4410m), P. 65
13.76. Connector Composites (4450am), (4450bm), (4450m), (4460am), (4460bf), P. 66
13.77. Connector Composites (4460bm / 4450bf), (4460m), (4500), (4705), P. 67
13.78. Connector Composites (4706), (4905), (4906), (4950), (4951), (5117), P. 68
13.79. Connector Composites (6000), (6001), P. 69
13.80. Connector Composites (6010), (6011), P. 70
13.81. Connector Composites (6018), (6019), (6020), P. 70a
13.82. Connector Composites (6020m), P. 71
13.83. Connector Composites (6020m), P. 72
13.84. Connector Composites (6021), (6022), (6023), (6033), P. 73
13.85. Connector Composites (6200), (6201), (6259), P. 74
13.86. Connector Composites (6261), (6262), (6263), (6304), (6316m), (6323), P. 75
13.87. Connector Composites (6323), (6334), (6400), (6401), P. 76
13.88. Connector Composites (6401), (6401 / 6407), (6402), (6403), P. 77
13.89. Connector Composites (6406a), (6407m), (6420), (6550), (6561), (6650), (6701),
P. 77a
13.90. Connector Composites (6702), (6703a), (6703), (6704), P. 78
13.91. Connector Composites (6704a), (6704m), (6706), (6707), (6708 / 6709), (6712),
P. 78a
13.92. Connector Composites (6713), (6714), (6716), (6716a), (6720 / 6721), (6725), P. 79 .
13.93. Connector Composites (6730), (6731), P. 79a
13.94. Connector Composites (6732), (6747), P. 79b
13.95. Connector Composites (6900), (6901), (7103), (7103m), (7104), P. 80
13.96. Connector Composites (7104), (7104 / &7104f), (7105), P. 81
13.97. Connector Composites (7106), (7110 / &&7110a), (7111), P. 82
13.98. Connector Composites (7150), (7152), P. 83
13.99. Connector Composites (7150), (7150f / 7150f2), (7150 / 7151), P. 84
13.100.Connector Composites (7151), P. 85
13.101.Connector Composites (7205m / @7205), (7205m), (7206f / @7206), (7206f),
P. 86
13.102.Connector Composites (7211), (7212), (7213), P. 87
13.103.Connector Composites (7250), (7251), (7350), P. 88
13.104.Connector Composites (7500), (7500w), (7502m / &7500a), (7501), (7600),
(7600 / &7600a), (7601), (7601m), P. 89
13.105.Connector Composites (7602), (7603), (7604), (7605), (7607), (7608), (7609),
(7611), P. 90
13.106.Connector Composites (7615), (7616), (7617), (7700), (7700 / @7700k), P. 91
13.107.Connector Composites (7702), (7703), (7801f), P. 91a
13.108.Connector Composites (7801m), (7802), (7803), (7804), (7900), (7901), P. 92
13.109.Connector Composites (7905), (7909), P. 93
13.110.Connector Composites (7910), (7911), P. 93a
13.111.Connector Composites (8000), (8001), (8102), (8103), (8150), (8151), P. 94
13.112.Connector Composites (8200), (8201), (8301), (8303), (8305), (8310), (8311), P. 95
13.113.Connector Composites (8312), (8410), (8500), (8501), P. 96
13.114.Connector Composites (8502), (8502a), P. 96a
13.115.Connector Composites (8503), (8503a), (8505), (8506), (8506a), (8507),
(8507a), (8508), P. 97
13.116.Connector Composites (8508a), (8509a), (8520a), (8521), (8601),\, P. 97a
13.117.Connector Composites (8800), (8801), (8802), (8803), P. 98
13.118.Connector Composites (8805), (8806), P. 99
13.119.Connector Composites (8995), (8996), (8997), (8998), (8999), P. 99a
13.120.Connector Composites (8807), (8809), (8900), (9001), P. 100
13.121.Connector Composites (9100), (9101), (9102a / 9102), (9103), (9108), (9255),
(9260), (9261), (9280), P. 101
13.122.Connector Composites (9300), (9303), P. 102
13.123.Connector Composites (9310), (9311), (9315), (9316), (9501), (9502), (9503),
(9504), P. 103
13.124.Connector Composites (9505), (9506), (9510), (9510a), (9510b), (9510f),
(9510m), P. 104
13.125.Connector Composite (9511), P. 105
13.126.Connector Composites (9512), (9513), (9514), (9516), (9516a), (9517), (9517a),
P. 106
13.127.Connector Composites (9516), (9517), (9518), (9519), (9519a), (9520), (9521),
(9522), (9523), (9524), P. 107
13.128.Connector Composites (9524), (9530), P. 108
13.129.Connector Composites (9715), (9716), P. 109
13.130.Connector Composites (9718), (9719m), (9720), (9736), (9737), P. 110
13.131.Connector Composites (9738), (9739), (9740 / 9740a / 9740b / 9740c), P. 111
13.132.Connector Composites (9740), (9745), (9746), (9747), (9748), P. 112
13.133.Connector Composites (9751), (9752), (9753), (9753a), (9754), P. 113
13.134.Connector Composites (9758), (9759), (9760), P. 114
13.135.Connector Composite (9761), P. 115
13.136.Connector Composites (9761f), (9762), (9763), (9764), (9765), (9766), P. 116
13.137.Connector Composites (9775), (9777), (9777a), (9777m), (9778), P. 117
13.138.Connector Composites (9779f), (9780m), (9781m), (9782f), P. 118
13.139.Connector Composites (9800), P. 119
13.140.Connector Composites (9811), (9812), (9814), (9815), (9820m), P. 120
13.141.Connector Composites (9830), (9832), (9900), (9900e), P. 121
13.142.Connector Composites (9913b), (9915), (9920), (9921), (9994), (9999), P. 122
