International Truck 3200 to 8600 Electrical Diagram 0000017581 2015
Brand: International, Navistar
Type of Manual: Electrical Diagram, Circuit Diagram
Model: International 3200, 4100, 4200, 4300, 4400, 7300, 7500, 7400, 7600, 8500, 8600 Truck
Start Date: 03/11/2004
End Date: 09/30/2005
Part Number: 0000017581
Publication Date: 2015
Number of Pages: 215 Pages
INSTRUCTIONS AND CHARTS (Chapter 1)
2.1. Circuit Number Identification and Location Chart, p. 1
2.2. Circuit Number Identification and Location Chart, p. 2
2.3. Circuit Number Identification and Location Chart, p. 3
2.4. Circuit Number Identification and Location Chart, p. 4
2.5. Circuit Number Identification and Location Chart, p. 5
2.6. NAVPAK/ECM I6 Engine Controller Connector Pin Number Identi
2.7. Circuit Diagram Instructions, p. 7
2.8. Circuit Diagram Instructions, p. 8
2.9. Schematic Symbol Chart, p. 9
2.10. Relay Functions, p. 10
2.11. Lamp Bulb Chart, p. 11
2.12. International V8 and I6 ECM Controller Connectors Pin Numb
12 VOLT POWER DISTRIBUTION CIRCUIT DIAGRAMS (Chapter 2)
3.1. Accessory, p. 1
3.2. Battery Feeds, Cab, p. 2
3.3. Battery, p. 3
3.4. 1708 Data Link Chassis, p. 4
3.5. Switch Data Link, p. 5
3.6. Drivetrain 1939 Data Link (Cab), p. 6
3.7. Drivetrain 1939 Data Link (Chassis), p. 7
3.8. Grounds Chassis, p. 8
3.9. Grounds Chassis, p. 9
3.10. Grounds IP, p. 10
3.11. Grounds IP, p. 11
3.12. Ignition Cab, p. 12
3.13. Ignition Cab, p. 13
3.14. Ignition Feeds, Chassis, p. 14
3.15. Start, p. 15
CAB ACCESSORIES (Chapter 3)
4.1. Cigar Lighter and Power Feeds, p. 1
4.2. CB Power, p. 2
4.3. Compass and Temperature Display, p. 3
4.4. Front Doors Windows and Locks (Power), p. 4
4.5. Crew Doors Windows and Locks (Power), p. 5
4.6. Horn, Dual Electric, p. 6
4.7. Mirrors (Heated, Lighted and Power), p. 7
4.8. Radio (Entertainment), Speakers, p. 8
4.9. Windshield Wiper and Washer Pump, p. 9
4.10. 2–Way Radio, p. 10
4.11. Switch Pack, Optional Gauge Pack, p. 11
4.12. Lighted Air Shield, p. 12
4.13. Roof Aux. Load, p. 13
4.14. Satellite Communication Qualcomm-MCT and IMCT Systems, p.
4.15. Self Contained Air Seat, p. 15
4.16. Digital Clock PTC, p. 16
4.17. Transmission Allison LCT Column Shifter, p. 17
4.18. Heated Seats for 7700 Models Only, p. 18
4.19. Backup Camera, p. 19
4.20. XATA Computer, p. 20
4.21. Keyless Ignition System, p. 21
12V CHARGING + CRANKING SYSTEM (Chapter 4)
5.1. I6 EGR Engines, p. 1
5.2. V8 AVNT Engines, p. 2
5.3. Caterpillar, Cummins ISM Engines, p. 3
5.4. I6 HEUI Engines, p. 4
5.5. Caterpillar Engines, Cummins ISM and with Eaton Ultrashift/
5.6. I6 EGR Engines with Air Start, p. 6
FANS AND ENGINE ACCESSORIES (Chapter 5)
6.1. Fan Wiring, p. 1
6.2. Ether Start, p. 2
6.3. Snow Valve, p. 3
6.4. Fan Wiring, Caterpillar and Cummins, p. 4
ELECTRONIC ENGINES (Chapter 6)
7.1. Electronic Engine Controls, I6–EGR Engines, p. 1
7.2. Electronic Engine Controls, I6-EGR Engine Cruise Control an
7.3. Electronic Engine Controls, (V8–AVNT) Engines, p. 3
7.4. Electronic Engine Controls, V8–AVNT Engine Cruise Control a
7.5. Caterpillar C10, C11, C12, and C13 Engines, p. 5
7.6. Cummins ISM Engine, p. 6
7.7. I6 HEUI Engine, p. 7
7.8. I6 HEUI Engine Cruise Control and Body Builder Connections
GAUGES WITH AND WITHOUT INTEGRAL WARNING LIGHT (Chapter 7)
8.1. IP/Gauge List, p. 1
8.2. Warning Light List, p. 2
8.3. Warning Lights Controlled by Engine, Transmission, ABS Cont
8.4. Engine Oil Pressure and Temp, Speedometer, Tach, Voltmeter
8.5. IP/Gauges and Warning Lights — Gauge Cluster, p. 5
8.6. Air Pressure Input Circuit, p. 6
8.7. Axle Temperature, FWD Rear and Rear Axles, Gauge Input Circ
8.8. Fuel Gauge Input Circuit (Single Tank) Differential Lock Wa
8.9. Gauges and Warning Lights — Fuel Filter Restriction and Wat
8.10. Gauges and Warning Lights — Park Brake Light and Transmiss
8.11. Gauges and Warning Lights — Ammeter, p. 11
8.12. Engine Oil Temperature Gauge With Caterpillar, p. 12
8.13. Front Axle Engagement Lamp, p. 13
LIGHTS (Chapter 8)
9.1. Back Up Lights, p. 1
9.2. Light Systems — Clearance, Marker, Park, Tail, Turn and Sto
9.3. Light Systems — Clearance, Marker, Park, Tail, Turn and Sto
9.4. Light Systems — Turn Signal and Stop Switches, p. 4
9.5. Dome Light, Map Light, p. 5
9.6. Dome Light, Map Light (Cont.), p. 6
9.7. Fog Light and Work Light, p. 7
9.8. Headlights, p. 8
9.9. Aux. Headlights, Aux. Park, Aux. Turn, p. 9
9.10. Panel Lights, p. 10
CHASSIS ACCESSORIES (Chapter 9)
10.1. Air Dryer and Heated Drain Valve, p. 1
10.2. Antilock Brake System (ABS), Air, p. 2
10.3. Antilock Brake System (ABS), Air, Traction Control, p. 3
10.4. Antilock Brake System (ABS), Hydraulic, p. 4
10.5. Antilock Brake System (ABS), Hydraulic (Cont.), p. 5
10.6. Antilock Brake System (ABS), Hydraulic (Cont.), p. 6
10.7. Two Speed Axle Switch With Manual Transmission and I6 HEUI
10.8. Brake System, Hydraulic, p. 8
10.9. Fuel Transfer Pump, p. 9
10.10. Back of Cab Body Builder and Trailer Stop, Tail, Marker,
10.11. Body Builder and Trailer Turns, Center Pin ABS, Center Pi
10.12. Body Builder and Trailer Socket Back of Cab Sockets, p. 1
10.13. Body Builder and Trailer Socket End of Frame (EOF) Socket
10.14. Air Solenoid 4–Way Pack, p. 14
10.15. Remote Power Units, Solenoid Packs, Remote Engine Speed C
10.16. HYD Power Park, p. 16
10.17. Air Suspension, p. 17
10.18. Aux. Trailer, Acc Controlled, p. 18
10.19. Aux. Trailer, Battery Controlled, p. 19
10.20. Lift Axles (Non-Steerable), p. 20
10.21. Lift Axles (Steerable), p. 21
10.22. Air Actuated Park Brake, p. 22
10.23. Antilock Brake System, WABCO Air, p. 23
10.24. Antilock Brake System, WABCO Air, p. 24
10.25. Lift Axles, With Non-Steerable for SS Models, p. 25
10.26. Fuel / Water Separator With 12VDC Fuel Preheater, p. 26
10.27. Electronic Trailer Brake Accommodation, p. 27
10.28. Lectrashift Accommodation, p. 28
10.29. Auxiliary 40 Amp Circuit, p. 29
10.30. Hourmeter, Customer Mounted PTO, p. 30
10.31. Remote Start/ Stop, p. 31
10.32. Lift Axle with 14RAR, p. 32
10.33. Lift Gate, p. 33
10.34. Lift Axle Multiplex, p. 34
TRANSMISSIONS (Chapter 10)
11.1. Allison LCT Transmission or Allison 1000, 2000, 2400, p. 1
11.2. Allison MD Transmission, p. 2
11.3. Allison MD Transmission (WTEC), p. 3
11.4. Allison MD Transmission (Cont.), p. 4
11.5. Transmission, WTEC MD W/Auto Neutral, p. 5
11.6. Eaton Autoshift Transmission, p. 6
11.7. Eaton Autoshift Transmission (Cont.), p. 7
11.8. Eaton Lightning Transmission, p. 8
11.9. Allison HD Transmission, p. 9
11.10. Allison HD Transmission, p. 10
11.11. Allison HD Transmission, p. 11
11.12. Allison HD Transmission With Auto Neutral, p. 12
11.13. Allison HD Transmission With Auto Neutral and with 0013WU
11.14. Allison LCT Transmission (Allison 1000, 2000, 2400) with
11.15. Transmission Retarder Control Wiring with MD Xmsn, Hard W
11.16. Transmission Retarder Control Wiring with MD Xmsn, Hard W
AIR CONDITIONING (Chapter 11)
12.1. HVAC Systems, p. 1
12.2. Air Conditioning (Only), p. 2
12.3. Autotherm Systems, p. 3
CONNECTOR COMPOSITES (Chapter 12)
13.1. Connector Composites (10M), (71), (72), (345F), p. 1
13.2. Connector Composites (420F), (420M), (520), (521), (522),
13.3. Connector Composites (1002), (1003), (1010), p. 3
13.4. Connector Composite (1011), p. 4
13.5. Connector Composite (1012), p. 5
13.6. Connector Composite (1013), p. 6
13.7. Connector Composite (1014), p. 7
13.8. Connector Composites (1018), (1019M), (1020M), (1021M), (1
13.9. Connector Composites (1027M, F), (1100), (1101A), (1101),
13.10. Connector Composites (1104), (1106), (1200), (1210), p. 1
13.11. Connector Composites (1300), (1301), (1400), (1402), (141
13.12. Connector Composites (1553), (1554F), (1555), (1600), (16
13.13. Connector Composites (1652), (1657M), (1658), (1659), (18
13.14. Connector Composites (1804), (1807), (1808), (1809), (181
13.15. Connector Composites (1820), (1822), (1823), (1824), (182
13.16. Connector Composites (1918), (1935), (1920), (2000), (200
13.17. Connector Composites (2006M), (2007F), (2021F), (2021M),
13.18. Connector Composites (2304M), (2305M), (2306M), (2307F),
13.19. Connector Composites (2601M, F), (2602M, F), (3000M), (30
13.20. Connector Composites (3204M, F), (3209), (3210M), (3211M)
13.21. Connector Composite (4001), p. 21
13.22. Connector Composite (4002), p. 22
13.23. Connector Composite (4003), p. 23
13.24. Connector Composites (4004), (4007), (4008), p. 24
13.25. Connector Composite (4014), p. 25
13.26. Connector Composite (4014/1700), p. 26
13.27. Connector Composites (4015), (4017), (4018), (4019), (402
13.28. Connector Composites (4024), (4030), (4031), (4032), (403
13.29. Connector Composites (4070), (4071), (4087), (4098), (410
13.30. Connector Composite (4103), p. 30
13.31. Connector Composites (4105), (4111), (4120), (4301), p. 3
13.32. Connector Composites (4305), (4410), (4410B), (4410C), (4
13.33. Connector Composites (4411A), (4411B), (4412), (4415), (4
13.34. Connector Composite (4705), p. 34
13.35. Connector Composites (4810), (4712F), (4820), (4713F), (4
13.36. Connector Composites (4900), (4910), (4950), (4951), p. 3
13.37. Connector Composites (6007), (6011), p. 37
13.38. Connector Composites (6013M), (6014), p. 38
13.39. Connector Composites (6015), (6020), (6021), p. 39
13.40. Connector Composites (6200), (6316), (6323), (6332), (633
13.41. Connector Composites (6550), (6703), (6704), (6708), (710
13.42. Connector Composites (7200), (7202), (7203), p. 42
13.43. Connector Composites (7204), (7205), (7206), (7211), (72
13.44. Connector Composites (7214), (7300), (7301), p. 44
13.45. Connector Composites (7302), (7304), (7305), (7306), (750
13.46. Connector Composites (7603), (7604), (7605), (7606), (760
13.47. Connector Composites (7800), (7801M), (7803), (7900), (79
13.48. Connector Composites (7905), (7906), (8000), (8001), (810
13.49. Connector Composites (8201), (8301), (8310), (8311), (831
13.50. Connector Composites (8503), (8503A), (8505), (8506), (85
13.51. Connector Composites (8700), (8701), (8800), (8801), (880
13.52. Connector Composites (9001), (9002), (9100), (9101), (910
13.53. Connector Composites (9260), (9261), (9262), (9263), (926
13.54. Connector Composites (9405), (9501), (9502), (9503), (950
13.55. Connector Composites (9507), (9508), (9509), (9510), (951
13.56. Connector Composites (9516), (9517), (9518), (9519), p. 5
13.57. Connector Composite (9700), p. 57
13.58. Connector Composite (9700), p. 58
13.59. Connector Composites (9715), (9715A), (9715B), p. 59
13.60. Connector Composites (9716), (9716A), (9716B), p. 60
13.61. Connector Composites (9717A), (9717B), p. 61
13.62. Connector Composites (9718), (9719), (9720), (9733), (973
13.63. Connector Composites (9777), (9778), (9800), p. 63
13.64. Connector Composites (9870), (9871), (9811), (9812), (981
13.65. Connector Composites (9913B), (9914), (4100), (4109), (41
3.3. Battery, p. 3
3.15. Start, p. 15
4.2. CB Power, p. 2
LIGHTS (Chapter 8)
- International DT466,DT570,HT570 Diesel Engine Service Manual
- International DT466E Wiring Schematic
- International 365, 444, 466, 530 Service Manuals
- Navistar Diagnostic Trouble Code Index
- SCANIA 420 DC11 - DC12 Motor
- International 9800 Electrical Schematic
- International Truck DT466E Engine Repair Manual
- International - VT365 Schematic (SPA)
- Scania Manual Transmission GRS900
- International Truck 5000i,9200i,9400i and 9900i Chassis Built Electrical Circuit Diagram
- International Trucks Body Controller Diagnostic Trouble Codes
- International Wiring Diagram
- International Truck CF500 CF600 Service Manual
- Scania Manual Transmission GR 900
- International DT466, DT530 Electronic Diagram
