International School Bus IC Bus RE Series Chassis Electrical Diagrams 0000019443 2019
Brand: International, Navistar
Type of Machine: School Bus
Type of Manual: Body Electrical Circuit Diagrams
Model: International IC Bus RE Series School Bus
Built: September 2017 and After
Engine Family: Cummins L9
Part Number: 0000019443
Publication Date: 2019
Number of Pages: 647 Pages
3. Instructions And Charts (Chapter 2)
3.1. Abbreviations, P. 1
3.2. Acronyms, P. 2
3.3. Circuit Diagram Instructions, P. 3
3.4. Circuit Number Identification And Color, P. 4
3.5. Circuit Number Identification And Color (Cont.), P. 5
3.6. Circuit Number Identification And Color (Cont.), P. 6
3.7. Circuit Number Identification And Color (Cont.), P. 7
3.8. Lamp Bulb Chart, P. 8
3.9. Relay Function And Wiring Guide, P. 9
3.10. Schematic Symbol Chart, P. 10
3.11. Schematic Symbol Chart (Cont.), P. 11
3.12. Schematic Symbol Chart (Cont.), P. 12
3.13. Schematic Symbol Chart (Cont.), P. 13
3.14. Schematic Symbol Chart (Cont.), P. 14
3.15. Schematic Symbol Chart (Cont.), P. 15
3.16. Schematic Symbol Chart (Cont.), P. 16
3.17. Schematic Symbol Chart (Cont.), P. 17
3.18. Schematic Symbol Chart (Cont.), P. 18
3.19. Re Bus Wiring Layout, P. 19
3.20. Electrical Fuse Panel Ñ Product Graphics, P. 20
3.21. Electrical Fuse Panel Ñ Product Graphics (Cont.), P. 21
3.22. Platform Harness Fuse Panel Ñ Product Graphics, P. 22
4. 12 Volt Power Distribution, Grounds, Data Bus And Electrical System
Controller (Chapter 3)
4.1. Battery Feed, P. 1
4.2. Ignition Feed, P. 2
4.3. Accessory Feed, P. 3
4.4. Body Circuit Ñ Fuse Block, P. 4
4.5. Body Circuit Ñ Fuse Block (Cont.), P. 5
4.6. Body Circuit Ñ Fuse Block (Cont.), P. 6
4.7. Body Circuit Ñ Fuse Block (Cont.), P. 7
4.8. Body Circuit Ñ Fuse Block (Cont.), P. 8
4.9. Body Circuit Ñ Fuse Block (Cont.), P. 9
4.10. Body Circuit Ñ Fuse Block (Cont.), P. 10
4.11. Body Circuit Ñ Fuse Block (Cont.), P. 11
4.12. Body Circuit Ñ Accessory & Ignition Feed, P. 12
4.13. Body Circuit Ñ Master Disconnect, P. 13
4.14. Body Circuit Ñ Noise Suppression, P. 14
4.15. Body Circuit Ñ Accessory Splice, P. 15
4.16. Body Circuit Ñ Reference Splice, P. 16
4.17. Body Circuit Ñ Battery Isolator, P. 17
4.18. Body Ground Ñ Platform, P. 18
4.19. Body Ground Ñ Platform (Cont.), P. 19
4.20. Body Ground Ñ Platform (Cont.), P. 20
4.21. Body Ground Ñ Electrical Panel, P. 21
4.22. Body Ground Ñ Electrical Panel (Cont.), P. 22
4.23. Body Ground Ñ Electrical Panel (Cont.), P. 23
4.24. Body Ground Ñ Electrical Panel (Cont.), P. 24
4.25. Body Ground Ñ Electrical Panel (Cont.), P. 25
4.26. Body Ground Ñ Electrical Panel (Cont.), P. 26
4.27. Body Ground Ñ Front Cap, P. 27
4.28. Body Ground Ñ Front Cap (Cont.), P. 28
4.29. Body Ground Ñ Front End, P. 29
4.30. Body Ground Ñ Front End (Cont.), P. 30
4.31. Body Ground Ñ Rear Cap, P. 31
4.32. Body Ground Ñ Rear Cap (Cont.), P. 32
4.33. Body Ground Ñ Left Body, P. 33
4.34. Body Ground Ñ Left Body (Cont.), P. 34
4.35. Body Ground Ñ Left Body (Cont.), P. 35
4.36. Body Ground Ñ Right Body, P. 36
4.37. Zonar Power And Signal, P. 38
5. 12 Volt Charging And Cranking System (Chapter 4)
5.1. Starter Interlock / Vandal Lock, P. 1
6. Gauges And Warning Lights (Chapter 5)
6.1. Turn Signals With Audible Flasher System, P. 1
6.2. Turn Signals Without Aux Flasher Switch, P. 2
6.3. Turn Signals With Aux Flasher Switch, P. 3
6.4. Temp Sensor In Engine Compartment, P. 4
6.5. Temp Sensor In Engine Compartment And Electrical Panel, P. 5
6.6. Stop Light Switch, P. 6
6.7. Abs Brake & With Stop Light, P. 6a
6.8. Fire Suppression, P. 7
6.9. Rear Cap Fire Suppression & With Engine Compartment Temp Sensor, P. 8
6.10. Locking Compartment With Alarm With Starter Interlock With Mech
Buzzer, P. 9
6.11. Heated Wiper Blades, P. 10
6.12. Camera System - Mirror Display, P. 11
6.13. Camera System - Standalone Display, P. 12
7. Pupil Warning Light Activation (Chapter 6)
7.1. Pupil Warning Lights Without Light Monitor, P. 1
7.2. Pupil Warning Lights Without Light Monitor (Cont.), P. 2
7.3. Pupil Warning Lights Without Light Monitor (Cont.), P. 3
7.4. Pupil Warning Lights Without Light Monitor (Cont.), P. 4
7.5. Pupil Warning Lights Without Light Monitor With Driver Alert Sign, P. 5. .
7.6. Pupil Warning Lights With Light Monitor, P. 6
7.7. Pupil Warning Lights With Light Monitor (Cont.), P. 7
7.8. Pupil Warning Lights With Light Monitor (Cont.), P. 8
7.9. Pupil Warning Lights With Light Monitor With Driver Alert Sign, P. 9
7.10. Pupil Warning Lights With 16 Lamp Light Monitor, P. 10
7.11. Pupil Warning Lights With 8 Lamp Light Monitor, P. 11
7.12. Tell-Tail Lights Connections, P. 12
7.13. Stop Arm Splice Signal, P. 13
7.14. Sequential Pupil Warning Light System With V Battery, P. 14
7.15. Sequential Pupil Warning Light System With V Battery (Cont.), P. 15
7.16. Non-Sequential Pupil Warning Light System With V Battery, P. 16
7.17. Non-Sequential Pupil Warning Light System With V Battery (Cont.), P. 17. . .
7.18. Non-Sequential Pupil Warning Light System With Right Rotary Door
Switch, P. 18
7.19. Non-Sequential Pupil Warning Light System With Right Rotary Door
Switch (Cont.), P. 19
7.20. Florida Pupil, Warning Light System, P. 20
7.21. Florida Pupil, Warning Light System (Cont.), P. 21
7.22. Standard Right Flasher Switches With Maryland, P. 22
7.23. Standard Right Flasher Switches With Maryland (Cont.), P. 23
7.24. Flasher Control Cancel Switch Connections, P. 24
8. External Lights (Chapter 7)
8.1. Back-Up Lights Without Read Exit Options, P. 1
8.2. Back-Up Light With Light Monitor And With Ree, P. 2
8.3. Destination Sign Front And Rear Lights, P. 3
8.4. Fog Lights / Auxiliary Driving Lights, P. 4
8.5. Strobe Light Mounted On Left Switch Panel, P. 5
8.6. Strobe Light Activated By Warning Lights W / Overhead Switch, P. 6
8.7. Strobe Light Activated By Stop Arm With Overhead Switch, P. 7
8.8. Strobe Light Activated By Mom Switch With Overhead Switch, P. 8
8.9. Strobe Light Activated By Ignition, P. 9
8.10. Strobe Light Splice Pack, P. 10
8.11. Left Side Turn Lights, P. 11
8.12. Left Side Turn Lights (Cont.), P. 12
8.13. Left Side Turn Lights (Cont.), P. 13
8.14. Right Side Turn Lights, P. 14
8.15. Right Side Turn Lights (Cont.), P. 15
8.16. Right Side Turn Lights (Cont.), P. 16
8.17. Direction Lights Not Cowl Mounted, P. 17
8.18. Directional Lights On Cowl Without Park Lights, P. 18
8.19. Directional Lights On Cowl With Park Lights, P. 19
8.20. Clearance Lights, P. 20
8.21. Front Cap Ñ Clearance / Identification Lights, P. 21
8.22. Rear Cap Ñ Clearance / Identification Lights (Standard), P. 22
8.23. Rear Cap Ñ Clearance / Identification Lights And Act Emergency Exit
Light, P. 23
8.24. Rear Cap Ñ Dual Corner Marker Light, P. 24
8.25. Rear Cap Emergency Exit And Dual Marker Light, P. 25
8.26. Rear Cap Emergency Exit And Dual Marker Light (Cont), P. 26
8.27. Rear Cap Bulkhead And Clearance Lights, P. 26a
8.28. Rear Cap Bulkhead And Double Clearance Lights, P. 26b
8.29. Extra Marker Light In Skirt, P. 27
8.30. Grill Lights Without Light Monitor, P. 28
8.31. Grill Lights With Light Monitor, P. 29
8.32. Rear Lights Without Options, P. 29a
8.33. Left And Right Grill Lights, P. 30
8.34. Left Rear End Lights, P. 31
8.35. Right Rear End Lights, P. 32
8.36. Luggage Box / Compartment Lights, P. 33
8.37. Pedestrian Lights, P. 34
8.38. Hazard Light Switch In Left Switch Panel, P. 35
8.39. Headlight Wiring, P. 36
8.40. Headlight Wiring With Standard, P. 37
8.41. Headlight Wiring With Special Drl, P. 38
8.42. Headlight Wiring With Headlights Always On, P. 39
8.43. Headlight Wiring With Full Time Running Lights, P. 40
8.44. Headlight Wiring With Warning Buzzer, P. 41
8.45. Turn Signal Splice, P. 42
8.46. Stop And Tail Signal Splice, P. 43
9. Interior Lights (Chapter 8)
9.1. Stepwell Lights With Dual And Skirt Light, P. 1
9.2. Panel Light With Single Dimmer Control, P. 2
9.3. Panel Light With Dual Dimmer Control, P. 3
9.4. Panel Light Adapter, P. 4
9.5. Switch Illumination, P. 5
9.6. Switch Illumination (Cont.), P. 6
9.7. Switch Illumination (Cont.), P. 7
9.8. Switch Illumination (Cont.), P. 8
9.9. Switch Illumination (Cont.), P. 9
9.10. Switch Illumination (Cont.), P. 10
9.11. Switch Illumination (Cont.), P. 11
9.12. Dome Light Single Switch, P. 12
9.13. Dome Light Single Switch (Cont.), P. 13
9.14. Dome Light Deluxe Single Switch With V Ignition Overhead, P. 14
9.15. Dome Light Split Switch, P. 15
9.16. Dome Light Split Switch (Cont.), P. 16
9.17. Driverís Dome Light, P. 17
9.18. Activity Dome Light, P. 18
9.19. Dome Lights Activated By Emergency Exits, P. 19
9.20. Dome Lights Activated By Entrance Door, P. 20
9.21. Dome Light Split Switch With Wired To Headlights, P. 21
9.22. Dome Light Split Switch With Ignition Overhead With Crs, P. 22
9.23. Engine Compartment Light, P. 23
9.24. Rear Row / Last Dome Light, P. 24
9.25. Guard Dome Light, P. 25
9.26. Double Dome Light With Rear Row 15 Window Sect L Body, P. 26
9.27. Double Dome Light With Rear Row 15 Window Sect R Body, P. 27
9.28. Double Dome Light With Rear Row 13 / 14 Window Sect L Body, P. 28
9.29. Double Dome Light With Rear Row 13 / 14 Window Sect R Body, P. 29
9.30. Double Dome Light With Rear Row 12 Window Sect L Body, P. 30
9.31. Double Dome Light With Rear Row 12 Window Sect R Body, P. 31
9.32. Dome Light Deluxe Switch With Fr And Rr 14 Window L Body, P. 32
9.33. Dome Light Deluxe Switch With Fr And Rr 14 Window R Body, P. 33
9.34. Dome Light Deluxe Switch With 14 Window R Body, P. 34
9.35. Double Dome Lt With Separate Sw For Fr And Rr, With Rear Row 15
Window Sect L Body, P. 35
9.36. Double Dome Lt With Separate Sw For Fr And Rr, With Rear Row 15
Window Sect R Body, P. 36
9.37. Double Dome Lt With Separate Sw For Fr And Rr, With Rear Row 13 / 14
Window Sect L Body, P. 37
9.38. Double Dome Lt With Separate Sw For Fr And Rr, With Rear Row 13 / 14
Window Sect R Body, P. 38
9.39. Double Dome Lt With Separate Sw For Fr And Rr, With Rear Row 12
Window Sect L Body, P. 39
9.40. Double Dome Lt With Separate Sw For Fr And Rr, With Rear Row 12
Window Sect R Body, P. 40
9.41. Standard Stagger Dome Lt With Rear Row 15 Window Sect L And R
Body, P. 41
9.42. Standard Stagger Dome Lt With Rear Row 13 / 14 Window Sect L And R
Body, P. 42
9.43. Standard Stagger Dome Lt With Rear Row 12 Window Sect L And R
Body, P. 43
9.44. Standard Stagger Dome Lt Fr And Rr, With Rear Row 15 Window Sect
L Body, P. 44
9.45. Standard Stagger Dome Lt Fr And Rr, With Rear Row 15 Window Sect
R Body, P. 45
9.46. Standard Stagger Dome Lt Fr And Rr, With Rear Row 13 / 14 Window
Sect L And R Body, P. 46
9.47. Standard Stagger Dome Lt Fr And Rr, With Rear Row 12 Window Sect
L And R Body, P. 47
9.48. Dome Lt Above Each Seat With Fr And Rr 14 Window R Body, P. 48
9.49. Dome Lt Above Each Seat With Fr And Rr 14 Window R Body, P. 49
9.50. Dome Lt Above Each Seat With Fr And Rr 14 Window L Body, P. 50
9.51. Dome Lt Above Each Seat With Fr And Rr 14 Window L Body (Cont.), P. 51.
9.52. Dome Lt Last Row Sect Overhead And Left Panel Switch, P. 52
9.53. Compartment Light, P. 53
9.54. Emergency Door Light Ñ Overhead Locking Compartment, P. 54
10. Stop Arm / Crossing Gate (Chapter 9)
10.1. Stop Arm / Crossing Gate Without Cancel, P. 1
10.2. Stop Arm / Crossing Gate With Air Xgt Cancel, P. 2
10.3. Stop Arm / Crossing Gate With Electrical Xgt Cancel, P. 3
10.4. Stop Arm / Crossing Gate With Stop Arm Cancel Overhead, P. 4
10.5. Stop Arm / Crossing Gate With Stop Arm Cancel L Switch Panel, P. 5
10.6. Stop Arm / Crossing Gate Florida, P. 6
10.7. Crossing Gate, P. 7
10.8. Stop Arm Strobe Hi / Lo Intensity Switch L Switch Panel, P. 8
10.9. Stop Arm Strobe Hi / Lo Intensity Switch L Switch Panel With Rear, P. 9
10.10. Stop Arm Strobe Hi / Lo Intensity Switch L Switch Panel With Flasher
System, P. 10
10.11. Stop Arm Strobe Hi / Lo Intensity Switch L Switch Panel With Flasher
System With Rear, P. 11
10.12. Stop Arm / Crossing Gate Without Cancel With Zonar, P. 12
10.13. Stop Arm / Crossing Gate With Air Xgt Cancel With Zonar, P. 13
10.14. Electric Stop Arm / Crossing Gate With Stop Arm Cancel Overhead,
P. 14
11. Mirror Systems (Chapter 10)
11.1. Heated Mirror Overhead Switch, P. 1
11.2. Heated Mirrors L Switch Panel, P. 2
11.3. Motorized Mirror, P. 3
11.4. Heated Motorized Mirror With Left Panel And Overhead Switch, P. 4 .
11.5. Heated / Motorized Mirror With 20 Minute Timer, P. 5
11.6. Heated And Motorized Mirror Control Switch (Iku), P. 6
11.7. Driver Side Heated And Motorized Mirror Control Switch (Iku), P. 7. .
11.8. Passenger Side Heated And Motorized Mirror Control Switch (Iku), P. 8
11.9. Heated And Motorized Mirror Control Switch (Ngv), P. 9
11.10. Driver Side Heated And Motorized Mirror Control Switch (Ngv), P. 10
11.11. Passenger Side Heated And Motorized Mirror Control Switch (Ngv),
P. 11
11.12. Heated Cross View Mirror And Rear View Mirror, P. 12
11.13. Heated Air Seat, P. 13
12. Emergency Exit System (Chapter 11)
12.1. Alarm Switched Ground Adapter, P. 1
12.2. Kick Out Window Sect 1 To 8 L Body, P. 2
12.3. Kick Out Window Sect 9 To 15 L Body, P. 3
12.4. Kick Out Window Sect 1 To 6 R Body, P. 4
12.5. Kick Out Window Sect 7 To 12 R Body, P. 5
12.6. Kick Out Window Sect 13 To 15 R Body, P. 6
12.7. 3 Inch Red Lt Over Kick Out Window Sect 1 To 4 L Body, P. 7
12.8. 3 Inch Red Lt Over Kick Out Window Sect 6 To 8 L Body, P. 8
12.9. 3 Inch Red Lt Over Kick Out Window Sect 8 To 12 L Body, P. 9
12.10. 3 Inch Red Lt Over Kick Out Window Sect 13 To 15 L Body, P. 10
12.11. 3 Inch Red Lt Over Kick Out Window Sect 1 To 6 R Body, P. 11
12.12. 3 Inch Red Lt Over Kick Out Window Sect 7 To 12 R Body, P. 12
12.13. 3 Inch Red Lt Over Kick Out Window Sect 13 To 15 R Body, P. 13
12.14. 3 Inch Red Lt Over Right Side Emergency Door Without Kick Out Light,
P. 14
12.15. 3 Inch Red Lt Over Right Side Emergency Door With Kick Out Light, P. 15. .
12.16. 3 Inch Red Lt Over Right Side Emergency Door With Kick Out Light
(Cont.), P. 16
12.17. 3 Inch Red Lt To Ignition Feed Over Side Sect 7 To 8 R Body, P. 17
12.18. Roof Hatch Sect 1 To 10 L Body, P. 18
12.19. Roof Hatch Sect 11 To 15 L Body, P. 19
12.20. Roof Hatch With Starter Interlock For Sect 1 To 4 And 9 To 12 L Body,
P. 20
12.21. Roof Hatch With Starter Interlock For Sect 5 To 8 And 13 To 15 L
Body, P. 21
12.22. Roof Hatch With Front And With Alarm Power Vent Sect 2 And 3 L
Body, P. 22
12.23. Roof Hatch With Front And With Alarm Power Vent Sect 8 And 12 L
Body, P. 23
12.24. Roof Hatch With Front Power Vent Sect 2 And 4 L Body, P. 24
12.25. Roof Hatch With Front Power Vent Sect 7 And 12 L Body, P. 25
12.26. Roof Hatch With Front Power Vent Sect 12 And 14 L Body, P. 26
12.27. Roof Hatch With Rear Power Vent Sect 2 And 7 L Body, P. 27
12.28. Roof Hatch With Fr And Rr Power Vent L Body, P. 28
12.29. Left Side Emergency Door, P. 29
12.30. Right Side Emergency Door, P. 30
12.31. Right Side Emergency Door (Cont.), P. 31
12.32. Right Side Emergency Door With Starter Interlock, P. 32
12.33. Front Kick Out Window Connections L Body, P. 33
12.34. Rear Kick Out Window (Hehr) L Body, P. 34
12.35. Rear Kick Out Window Connections L Body, P. 35
12.36. Rear Kick Out Window Connections L Body (Cont.), P. 36
12.37. Emergency Exit Indicator Light In Cluster, P. 37
13. Lift Door System (Chapter 12)
13.1. Lift Interlock Key On, P. 1
13.2. Lift Interlock Key On (Cont.), P. 2
13.3. Lift Interlock Key On / Off, P. 3
13.4. Lift Interlock Key On / Off With Aed Interlock, P. 4
13.5. Lift Door Switch Connection, P. 5
13.6. Lift Door With Exterior Lights, P. 6
13.7. Lift Door With Exterior Lights (Cont.), P. 7
13.8. Lift Door With Interior Lights, P. 8
13.9. Lift Door With Starter Interrupt / Vandal Lock, P. 9
13.10. Lift Door Buzzer Connection, P. 10
13.11. Lift Door Connections With R Body, P. 11
13.12. Lift Door Connections With R Body (Cont.), P. 12
13.13. Lift Door Connections With R Body (Cont.), P. 13
13.14. Lift Door Connections With R Body (Cont.), P. 14
14. Entry Door (Chapter 13)
14.1. Air Door Rotary Switch And Rocker Switch, P. 1
14.2. Air Door Rotary Switch Wired To Headlights, P. 2
14.3. Air Door Rotary Switch Right Hand, P. 3
14.4. Electrical Door Rotary Switch, P. 4
14.5. Electrical Door Rotary Switch (Cont.), P. 5
14.6. Electrical Door Toggle Switch, P. 6
14.7. Electrical Door Toggle Switch (Cont.), P. 7
14.8. Electrical Door Toggle Switch With Momentary, P. 8
14.9. Electrical Door Toggle Switch With Momentary (Cont.), P. 9
14.10. Electrical Door Toggle Switch With Breaker, P. 10
14.11. Electrical Door Toggle Switch With Breaker (Cont.), P. 11
14.12. Air Alternate Entrance Door With Vandal Lock With Fr, P. 12
14.13. Air Alternate Entrance Door Harness, P. 13
14.14. Alternate Entrance Door 12 / 13 Window Sect L Body, P. 14
14.15. Alternate Entrance Door Control 48 Inch With Vandal Lock, P. 15
14.16. Additional Air Alternate Entrance Door, P. 16
14.17. Additional Air Alternate Entrance Door (Cont.), P. 17
14.18. Electric Sedan Door, P. 18
14.19. Dump Valve, P. 19
14.20. Alternate Entrance Door Alarm, P. 20
14.21. Door Option Splice, P. 21
15. Radio / Pa / Cellular Gps (Chapter 14)
15.1. Radio / Pa System, P. 1
15.2. Speaker Wiring For Qty 6 L And R Body, P. 2
15.3. Speaker Wiring For Qty 4 L And R Body, P. 3
15.4. Speaker Wiring For Qty 6 L And R Body, P. 4
15.5. Speaker Wiring For Qty 8 L Body, P. 5
15.6. Speaker Wiring For Qty 8 R Body, P. 6
15.7. Speaker Wiring For Qty 10 L Body, P. 7
15.8. Speaker Wiring For Qty 10 R Body, P. 8
15.9. Speaker Wiring For Qty 12 L Body, P. 9
15.10. Speaker Wiring For Qty 12 R Body, P. 10
15.11. Speaker Wiring For 2-140 In Behind Stanchion L And R Body, P. 11
15.12. Speaker Wiring For 4-140 In Behind Stanchion L And R Body, P. 12
15.13. Speaker Wiring For 6-140 In Behind Stanchion L Body, P. 13
15.14. Speaker Wiring For 6-140 In Behind Stanchion R Body, P. 14
15.15. Speaker Wiring For 6-140 In Behind Stanchion R Body (Cont.), P. 15
15.16. Speaker Wiring For 8-140 In Behind Stanchion L Body, P. 16
15.17. Speaker Wiring For 8-140 In Behind Stanchion L Body (Cont.), P. 17
15.18. Speaker Wiring For 8-140 In Behind Stanchion R Body, P. 18
15.19. Speaker Wiring For 8-140 In Behind Stanchion R Body (Cont.), P. 19
15.20. Speaker Wiring For 4-After Third Row Of Seats L Body, P. 20
15.21. Speaker Wiring For 4-After Third Row Of Seats R Body, P. 21
15.22. 12 Speaker Wiring Sect 3 / 5 / 7 / 9 / 12 / 14 With 14 Window L Body, P. 22
15.23. 12 Speaker Wiring Sect 1 / 3 / 6 / 9 / 11 / 13 With 14 Window L Body, P. 23
15.24. 12 Speaker Wiring Sect 1 / 3 / 6 / 9 / 11 / 13 With 14 Window R Body, P. 24
15.25. 8 Speaker Wiring With 48 Aed & 1st Located 1st R Window L Body, P. 25
15.26. 2 Speaker Wiring 1st Window Sect L & R Body, P. 26
15.27. Two Way Radio Term Strip, P. 27
15.28. Dual Radio Speakers In Bulkhead, P. 28
15.29. Video System, P. 29
15.30. Video System Term Strip, P. 30
15.31. Seon Video Prewire, P. 31
16. Child Reminder System (Chapter 15)
16.1. Electric Horn, P. 1
16.2. Air Horn, P. 2
16.3. Air Horn (Cont.), P. 3
16.4. Post Trip Inspection With Alternate Relay Location, P. 4
16.5. Post Trip Inspection With Alternate Relay Location (Cont.), P. 4a
16.6. Post Trip Inspection With Snooze, P. 5
16.7. Post Trip Inspection With Snooze (Cont.), P. 5a
16.8. Post Trip Inspection With Snooze (Cont.), P. 5b
16.9. Post Trip Inspection With Snooze (Cont.), P. 5c
16.10. Child Checkmate Post Trip Inspection, P. 6
16.11. Post Trip Inspection Without Snooze, P. 7
16.12. Post Trip Inspection Without Snooze (Cont.), P. 8
16.13. Post Trip Inspection Without Snooze (Cont.), P. 8a
16.14. Tire Carrier Winch Type, P. 9
16.15. Dome Light Post Trip Inspection Without Split Switch, P. 10
16.16. Dome Light Post Trip Inspection Without Split Switch (Cont.), P. 11
17. Heater / Air Conditioning (Chapter 16)
17.1. Booster Pump, P. 1
17.2. Booster Pump With Espar Heater With White Timer, P. 2
17.3. Booster Pump With Espar Heater With 7 Day Timer, P. 3
17.4. Booster Pump With Espar Heater With 7 Day Timer (Cont.), P. 4
17.5. Webasto Heater With 7 Day Timer, P. 5
17.6. Webasto Heater With Timer, P. 6
17.7. Webasto Heater With Smarttemp Timer, P. 7
17.8. Passenger Heater Left Front Midship With Single & Split Switch, P. 8
17.9. Passenger Heater Right Front Midship With Single & Split Switch, P. 9
17.10. Passenger Heater Left Rear Midship With Single & Split Switch, P. 10
17.11. Passenger Heater Right Rear Midship With Single & Split Switch, P. 11. .
17.12. Additional Driverís Heater, P. 12
17.13. Convection Passenger Heater, P. 13
17.14. Driverís Blower, P. 14
17.15. Heated Step, P. 15
17.16. Stepwell Heater Fan, P. 16
17.17. Step Defrost Heater, P. 17
17.18. Defog Fan, Dual Switch Front Bulkhead, P. 18
17.19. Defog Fan, Single Fan Or Center Blower Left Switch, P. 19
17.20. Defog Fan, Single Fan Right Switch, P. 20
17.21. Defog Fan, Dual Switch With Driver Fan Left Switch, P. 21
17.22. Defog Fan, Dual Switch With Driver Fan Right Switch, P. 22
17.23. Defog Fan Left Switch Output, P. 23
17.24. Defog Fan Right Switch Output, P. 24
17.25. Defog Fan Right Switch Output (Cont.), P. 25
17.26. Defog Fan, Drivers Defog Fan, P. 26
17.27. Idle Up With Ac, P. 27
17.28. Booster Pump With Espar Timer With Overhead Switch Panel, P. 28
18. Connector Body Composites (Chapter 17)
18.1. Connector Composites (1), P. 1
18.2. Connector Composites (1), P. 2
18.3. Connector Composites (2m), P. 3
18.4. Connector Composites (4m, 8m, 9, 10, 11m), P. 4
18.5. Connector Composites (12m, 13m, 14m), P. 5
18.6. Connector Composites (017wt, 018wt), P. 5a
18.7. Connector Composites (22m, 23m, 30wt, 31wt), P. 6
18.8. Connector Composites (32wt, 33wt, 34wt, 35wt, 36wt), P. 7
18.9. Connector Composites (37wt, 38wt, 39wt, 40wt, 41wt), P. 8
18.10. Connector Composites (46wt, 47wt, 50, 51, 52), P. 9
18.11. Connector Composites (52a, 53, 74m, 75m, 78m), P. 10
18.12. Connector Composites (78m, 79m, 80m, 81m), P. 10a
18.13. Connector Composites (100, 101, 162, 168), P. 11
18.14. Connector Composites (168a, 211m, 211n, 212m), P. 12
18.15. Connector Composites (220, 221), P. 12a
18.16. Connector Composites (240, 250, 297, 299), P. 13
18.17. Connector Composites (382m, 391, 392), P. 14
18.18. Connector Composites (491m, 674), P. 14a
18.19. Connector Composites (675, 676, 677, 678), P. 15
18.20. Connector Composites (680, 681, 691, 898), P. 16
18.21. Connector Composites (899, 922, 922a, 925), P. 17
18.22. Connector Composites (926, 992, 995, 996m), P. 18
18.23. Connector Composites (997, 998, 1003, 1004), P. 19
18.24. Connector Composites (1008, 1030), P. 20
18.25. Connector Composites (1030), P. 21
18.26. Connector Composites (1030p, 1031, 1032), P. 22
18.27. Connector Composites (1033, 1033b, 1034, 1036, 1337), P. 23
18.28. Connector Composites (1038, 1040, 1041), P. 24
18.29. Connector Composites (1042a, 1042b, 1043a, 1050), P. 25
18.30. Connector Composites (1062, 1063, 1065), P. 26
18.31. Connector Composites (1100, 1135, 1136), P. 27
18.32. Connector Composites (1137, 1138, 1139, 1139a, 1139b), P. 28
18.33. Connector Composites (1141, 1142, 1143a, 1143b), P. 29
18.34. Connector Composites (1149, 1150, 1150b), P. 30
18.35. Connector Composites (1151, 1151a, 1153, 1153a, 1205), P. 31
18.36. Connector Composites (1206, 1349, 1350, 1351, 1400), P. 32
18.37. Connector Composites (1401, 1402, 1403), P. 32a
18.38. Connector Composites (1410, 1600), P. 32b
18.39. Connector Composites (1601, 1602), P. 33
18.40. Connector Composites (1604, 1606, 1650, 1700), P. 34
18.41. Connector Composites (1700), P. 34a
18.42. Connector Composites (1707m, 1800m, 1908, 2233), P. 35
18.43. Connector Composites (3117, 3118, 3322), P. 36
18.44. Connector Composites (3344, 4433), P. 36a
18.45. Connector Composites (4800, 4801, 5263c, 5263f, 5263m), P. 37
18.46. Connector Composites (6200, 6348f, 6348m), P. 38
18.47. Connector Composites (8721, 8787, 8787b, 9003a, 9900), P. 39
18.48. Connector Composites (9900a, 9901, 9902, 9902a), P. 40
18.49. Connector Composites (9903, 9904, 9996, 9999), P. 41
18.50. Connector Composites (10000), P. 42
18.51. Connector Composites (10000), P. 43
18.52. Connector Composites (10001), P. 44
18.53. Connector Composites (10003, 10003l, 10004), P. 45
18.54. Connector Composites (10004, 10009, 10010), P. 46
18.55. Connector Composites (10011, 10012, 10013), P. 47
18.56. Connector Composites (10014, 10014a, 10015, 10016), P. 48
18.57. Connector Composites (10017, 10018, 10019, 10020, 10021, 10022), P. 49
18.58. Connector Composites (10023, 10024, 10025a, 10025b), P. 50
18.59. Connector Composites (10025c, 10025d, 10026a), P. 51
18.60. Connector Composites (10026b, 10026c, 10026d), P. 52
18.61. Connector Composites (10026d, 10027, 10028, 10028a), P. 53
18.62. Connector Composites (10029, 10029a, 10030, 10030a), P. 54
18.63. Connector Composites (10031, 10031a, 10032a), P. 55
18.64. Connector Composites (10032b, 10033a, 10034, 10035), P. 56
18.65. Connector Composites (10036, 10038, 10039, 10041, 10042), P. 57
18.66. Connector Composites (10043, 10046, 10046a, 10047), P. 58
18.67. Connector Composites (10047, 10048), P. 59
18.68. Connector Composites (10049, 10050, 10051, 10052), P. 60
18.69. Connector Composites (10052, 10053, 10054, 10057a, 10059), P. 61
18.70. Connector Composites (10060, 10061, 10070, 10072), P. 62
18.71. Connector Composites (10075, 10076, 10077, 10078, 10083), P. 63
18.72. Connector Composites (10084, 10085, 10086), P. 63a
18.73. Connector Composites (10100, 10101, 10102), P. 64
18.74. Connector Composites (10103, 10104, 10105, 10106, 10107), P. 65
18.75. Connector Composites (10108, 10109, 10110, 10112, 10113), P. 66
18.76. Connector Composites (10114, 10115, 10116, 10117, 10118), P. 67
18.77. Connector Composites (10119, 10120, 10121, 10122, 10123), P. 68
18.78. Connector Composites (10124, 10125, 10127, 10127a, 10128), P. 69
18.79. Connector Composites (10129, 10130, 10133, 10135, 10136), P. 70
18.80. Connector Composites (10137, 10138, 10139, 10140, 10141), P. 71
18.81. Connector Composites (10142, 10143, 10144, 1046, 10147, 10153), P. 72 .
18.82. Connector Composites (10154, 10155a, 10155b, 10156, 10157), P. 73
18.83. Connector Composites (10160, 10161), P. 74
18.84. Connector Composites (10176, 10181, 10182), P. 75
18.85. Connector Composites (10200), P. 76
18.86. Connector Composites (10201, 10202), P. 77
18.87. Connector Composites (10203, 10204), P. 78
18.88. Connector Composites (10207a, 10208), P. 79
18.89. Connector Composites (10210), P. 80
18.90. Connector Composites (10212, 10213), P. 81
18.91. Connector Composites (10214d, 10214l, 10215, 10216), P. 82
18.92. Connector Composites (10217, 10218, 10219), P. 83
18.93. Connector Composites (10220, 10221, 10224), P. 84
18.94. Connector Composites (10225, 10226), P. 85
18.95. Connector Composites (10227, 10228), P. 86
18.96. Connector Composites (10229, 10230a), P. 87
18.97. Connector Composites (10230b, 10231a), P. 88
18.98. Connector Composites (10231b, 10232a, 10232b), P. 89
18.99. Connector Composites (10233a, 10233b, 10234a), P. 90
18.100.Connector Composites (10234b, 10235, 10236), P. 91
18.101.Connector Composites (10237, 10238, 10239), P. 92
18.102.Connector Composites (10240, 10241a, 10241b), P. 93
18.103.Connector Composites (10242, 10243, 10243b), P. 94
18.104.Connector Composites (10244, 10244b, 10245), P. 95
18.105.Connector Composites (10245b, 10246, 10246b), P. 96
18.106.Connector Composites (10247, 10247a, 10248), P. 97
18.107.Connector Composites (10248a, 10249, 10250), P. 98
18.108.Connector Composites (10252, 10253, 10254, 10255), P. 99
18.109.Connector Composites (10256, 10257, 10259), P. 100
18.110.Connector Composites (10264, 10267, 10268), P. 101
18.111.Connector Composites (10269, 10270a, 10270b), P. 102
18.112.Connector Composites (10275), P. 103
18.113.Connector Composites (10276, 10277, 10278, 10280), P. 104
18.114.Connector Composites (10281, 10282, 10284, 10285), P. 105
18.115.Connector Composites (10286, 10290, 10291), P. 106
18.116.Connector Composites (10292, 10293a / 10293b, 10294), P. 107
18.117.Connector Composites (10295, 10297, 10299), P. 108
18.118.Connector Composites (10301), P. 109
18.119.Connector Composites (10302), P. 110
18.120.Connector Composites (10303), P. 111
18.121.Connector Composites (10304), P. 112
18.122.Connector Composites (10305), P. 113
18.123.Connector Composites (10306), P. 114
18.124.Connector Composites (10307), P. 115
18.125.Connector Composites (10308), P. 116
18.126.Connector Composites (10309), P. 117
18.127.Connector Composites (10309) (Cont.), P. 118
18.128.Connector Composites (10310), P. 119
18.129.Connector Composites (10311) , P. 120
18.130.Connector Composites (10312, 10314), P. 121
18.131.Connector Composites (10315, 10316, 10317, 10318), P. 122
18.132.Connector Composites (10319, 10320, 10321, 10322), P. 123
18.133.Connector Composites (10323, 10326), P. 124
18.134.Connector Composites (10327, 10328), P. 125
18.135.Connector Composites (10329, 10330), P. 126
18.136.Connector Composites (10331, 10332, 10333), P. 127
18.137.Connector Composites (10334, 10335), P. 128
18.138.Connector Composites (10336, 10337), P. 129
18.139.Connector Composites (10340f, 10340m, 10341, 10344a), P. 130
19. Connector Composites (Chapter 18)
19.1. Connector Composites (10344b, 10345, 10346), P. 1
19.2. Connector Composites (10348, 10351, 10352), P. 2
19.3. Connector Composites (10353, 10354, 10355), P. 3
19.4. Connector Composites (10356, 10358), P. 3a
19.5. Connector Composites (10360, 10365), P. 4
19.6. Connector Composites (10368, 10386, 10389, 10398), P. 5
19.7. Connector Composites (10400), P. 6
19.8. Connector Composites (10400) (Cont.), P. 7
19.9. Connector Composites (10401), P. 8
19.10. Connector Composites (10401) (Cont.), P. 9
19.11. Connector Composites (10401) (Cont.), P. 10
19.12. Connector Composites (10405) (Cont.), P. 10a
19.13. Connector Composites (10405), P. 11
19.14. Connector Composites (10406), P. 12
19.15. Connector Composites (10406) (Cont.), P. 13
19.16. Connector Composites (10410, 10411, 10412), P. 14
19.17. Connector Composites (10413, 10414, 10416), P. 15
19.18. Connector Composites (10417, 10417a, 10418), P. 16
19.19. Connector Composites (10419, 10420), P. 17
19.20. Connector Composites (10421), P. 18
19.21. Connector Composites (10422), P. 19
19.22. Connector Composites (10423), P. 20
19.23. Connector Composites (10426, 10427, 10428, 10430, 10431), P. 21
19.24. Connector Composites (10432, 10433, 10434, 10435, 10436, 10437), P. 22
19.25. Connector Composites (10438, 10439, 10440, 10441, 10442, 10443), P. 23
19.26. Connector Composites (10444, 10445, 10446, 10447, 10448, 10449), P. 24
19.27. Connector Composites (10450, 10451, 10452, 10453, 10454a, 10454b), P. 25.
19.28. Connector Composites (10454c, 10454d, 10454e, 10454f), P. 26
19.29. Connector Composites (10454g, 10454j, 10454k, 10455a, 10455b), P. 27
19.30. Connector Composites (10455c, 10455d, 10455e, 10455f, 10455g), P. 28
19.31. Connector Composites (10455h, 10455j, 10455k, 10456a, 10456b), P. 29
19.32. Connector Composites (10456c, 10456d, 10456e, 10456f, 10456g), P. 30
19.33. Connector Composites (10456h, 10456j, 10456k, 10457), P. 31
19.34. Connector Composites (10457a / 10457b, 10458, 10459), P. 32
19.35. Connector Composites (10460, 10461, 10462), P. 33
19.36. Connector Composites (10463, 10463a, 10464), P. 34
19.37. Connector Composites (10465, 10466, 10467), P. 35
19.38. Connector Composites (10468, 10468a, 10469), P. 36
19.39. Connector Composites (10470, 10471), P. 37
19.40. Connector Composites (10472), P. 38
19.41. Connector Composites (10473, 10474a / 10474b, 10474c, 10474d / 10474e /
10474f / 10474g / 10474h / 10474j / 10474k / 10474l / 10474m / 10474n), P. 39
19.42. Connector Composites (10474p, 10474r, 10475 / 10476, 10479), P. 40
19.43. Connector Composites (10482, 10483, 10483a), P. 41
19.44. Connector Composites (10484, 10484a, 10485, 10485a), P. 42
19.45. Connector Composites (10486, 10486a, 10487), P. 43
19.46. Connector Composites (10487a, 10488, 10489), P. 44
19.47. Connector Composites (10489a, 10490, 10491a, 10491b), P. 45
19.48. Connector Composites (10492, 10513), P. 46
19.49. Connector Composites (10513, 10514, 10515), P. 47
19.50. Connector Composites (10516, 10517, 10518), P. 48
19.51. Connector Composites (10519, 10520a, 10521a, 10522a), P. 49
19.52. Connector Composites (10523a, 10524a, 10555a, 10555b, 10555e), P. 50
19.53. Connector Composites (10555f, 10556c, 10556d, 10558a), P. 50a
19.54. Connector Composites (10558b, 10558c, 10558d), P. 50b
19.55. Connector Composites (10700), P. 51
19.56. Connector Composites (10700) (Cont.), P. 52
19.57. Connector Composites (10700) (Cont.), P. 53
19.58. Connector Composites (10700) (Cont.), P. 54
19.59. Connector Composites (10701), P. 55
19.60. Connector Composites (10702, 10703), P. 56
19.61. Connector Composites (10704), P. 57
19.62. Connector Composites (10705, 10706, 10706a), P. 58
19.63. Connector Composites (10706b, 10707 / 10707a, 10707b, 10708), P. 59
19.64. Connector Composites (10708a, 10708b, 10709, 10709b, 10710), P. 60
19.65. Connector Composites (10710a, 10711, 10712), P. 61
19.66. Connector Composites (10713), P. 62
19.67. Connector Composites (10714), P. 63
19.68. Connector Composites (10715, 10716, 10717, 10718), P. 64
19.69. Connector Composites (10719, 10720, 10721, 10722), P. 65
19.70. Connector Composites (10723, 10724, 10725, 10726), P. 66
19.71. Connector Composites (10727, 10728, 10729, 10730, 10731), P. 67
19.72. Connector Composites (10732, 10733, 10734, 10735), P. 68
19.73. Connector Composites (10736, 10737, 10738, 10739), P. 69
19.74. Connector Composites (10740, 10741, 10742, 10743, 10744), P. 70
19.75. Connector Composites (10751, 10751a, 10757, 10757a, 10758), P. 71
19.76. Connector Composites (10758a, 10759, 10759a, 10760), P. 72
19.77. Connector Composites (10760a, 10761, 10761a, 10762), P. 73
19.78. Connector Composites (10763, 10763a, 10764, 10765a, 10766), P. 74
19.79. Connector Composites (10767, 10768, 10769), P. 75
19.80. Connector Composites (*10769, 10769c, 10769d), P. 75a
19.81. Connector Composites (10769e, 10769f, 10769h), P. 76
19.82. Connector Composites (10769j, 10770, 10770c, 10770d, 10770e), P. 77
19.83. Connector Composites (10770f, 10770h, 10770j), P. 78
19.84. Connector Composites (10771, 10771a, 10771b, 10771c), P. 79
19.85. Connector Composites (10771d, 10771e, 10771f, 10771g, 10771h, 10771j,
10771k, 10771l), P. 80
19.86. Connector Composites (10772a, 10772b, 10772c), P. 81
19.87. Connector Composites (10772d, 10772e, 10772f, 10772g), P. 82
19.88. Connector Composites (10772h, 10772j, 10772k, 10772l), P. 83
19.89. Connector Composites (10773a, 10773b), P. 84
19.90. Connector Composites (10773c, 10773d, 10773e, 10773f), P. 85
19.91. Connector Composites (10773g, 10773h, 10773j), P. 86
19.92. Connector Composites (10773k, 10773l), P. 87
19.93. Connector Composites (10774, 10774a), P. 88
19.94. Connector Composites (10774b, 10774c, 10774d, 10774e), P. 89
19.95. Connector Composites (10774f, 10774g, 10774h, 10774j), P. 90
19.96. Connector Composites (10774k, 10774l, 10774n, 10774p), P. 91
19.97. Connector Composites (10778 / 10778c / 10778d / 10778e, 10778f, 10778h /
10778j), P. 92
19.98. Connector Composites (10780, 10781), P. 93
19.99. Connector Composites (10781a, 10784, 10785, 10786a), P. 94
19.100.Connector Composites (10786b, 10787, 10788a, 10788b), P. 95
19.101.Connector Composites (10789, 10795, 10796a, 10796b), P. 96
19.102.Connector Composites (10807a / 10807b / 10807c, 10831, 10832, *10832,
10833, *10833), P. 97
19.103.Connector Composites (10833a, 10837, 10838, 10840), P. 98
19.104.Connector Composites (10841, 10845, 10848a), P. 98a
19.105.Connector Composites (10849a, 10850a, 10851a, 10852a), P. 99
19.106.Connector Composites (11000), P. 100
19.107.Connector Composites (11000) (Cont.), P. 101
19.108.Connector Composites (11001, 11003, 11003a, 11004l), P. 102
19.109.Connector Composites (11004r, 11005l, 11005r, 11006l), P. 103
19.110.Connector Composites (11006r, 11009l, 11009r, 11010l), P. 104
19.111.Connector Composites (11010r, 11011l, 11011r), P. 105
19.112.Connector Composites (11012, 11016, 11017, 11018), P. 106
19.113.Connector Composites (11019, 11020, 11021, 11022), P. 107
19.114.Connector Composites (11023, 11024, 11025, 11025a), P. 108
19.115.Connector Composites (11025a, 11025b, 11025c), P. 109
19.116.Connector Composites (11025d, 11026, *11026, 11027, *11027, 11028), P. 110
19.117.Connector Composites (11029, 11033, 11037), P. 111
19.118.Connector Composites (11038, 11044, 11045, 11100), P. 112
19.119.Connector Composites (11101, 11102, 11200, 11201, 11202, 11203, 11204), P. 113
19.120.Connector Composites (11205, 11206, 11207, 11234, 11337, 11632), P. 114
19.121.Connector Composites (11633, 11643, 11644, 11647, 11648), P. 115
3.2. Acronyms, P. 2
Buzzer, P. 9
Switch, P. 18
Light, P. 23
Body, P. 41
Body, P. 42
Body, P. 43
L Body, P. 44
R Body, P. 45
L And R Body, P. 47
System, P. 10
P. 14
P. 11
P. 14
(Cont.), P. 16
P. 20
Body, P. 21
Body, P. 22
Body, P. 23
10778j), P. 92
- International DT466,DT570,HT570 Diesel Engine Service Manual
- International DT466E Wiring Schematic
- International 365, 444, 466, 530 Service Manuals
- Navistar Diagnostic Trouble Code Index
- SCANIA 420 DC11 - DC12 Motor
- International 9800 Electrical Schematic
- International Truck DT466E Engine Repair Manual
- International - VT365 Schematic (SPA)
- Scania Manual Transmission GRS900
- International Truck 5000i,9200i,9400i and 9900i Chassis Built Electrical Circuit Diagram
- International Trucks Body Controller Diagnostic Trouble Codes
- International Wiring Diagram
- International Truck CF500 CF600 Service Manual
- Scania Manual Transmission GR 900
- International DT466, DT530 Electronic Diagram
