Momed80
150
35,046
International School Bus IC Bus RE Series Body Electrical Diagrams 0000019442 2021
Brand: International, Navistar
Type of Machine: School Bus
Type of Manual: Chassis Electrical Circuit Diagrams
Model: International IC Bus RE Series School Bus
Built: September 2017 and After
Engine Family: Cummins L9
Part Number: 0000019442
Publication Date: 2021
Number of Pages: 242 Pages
2. Instructions And Charts (Chapter 2)
2.1. Abbreviations, P. 1
2.2. Acronyms, P. 2
2.3. Circuit Diagram Instructions, P. 3
2.4. Circuit Number Identification And Color, P. 4
2.5. Circuit Number Identification And Color (Cont.), P. 5
2.6. Circuit Number Identification And Color (Cont.), P. 6
2.7. Circuit Number Identification And Color (Cont.), P. 7
2.8. Lamp Bulb Chart, P. 8
2.9. Relay Function And Wiring Guide, P. 9
2.10. Schematic Symbol Chart, P. 10
2.11. Schematic Symbol Chart (Cont.), P. 11
2.12. Schematic Symbol Chart (Cont.), P. 12
2.13. Schematic Symbol Chart (Cont.), P. 13
2.14. Schematic Symbol Chart (Cont.), P. 14
2.15. Schematic Symbol Chart (Cont.), P. 15
2.16. Schematic Symbol Chart (Cont.), P. 16
2.17. Schematic Symbol Chart (Cont.), P. 17
2.18. Schematic Symbol Chart (Cont.), P. 18
2.19. Re Bus Wiring Layout, P. 19
2.20. Electrical Fuse Panel, P. 20
2.21. Electrical Fuse Panel (Cont.), P. 21
2.22. Platform Harness Fuse Panel, P. 22
3. 12 Volt Power Distribution, Grounds, Data Bus And Electrical System
Controller (Chapter 3)
3.1. Battery Feed, P. 1
3.2. Ignition Feed, P. 2
3.3. Ignition Feed (Cont.), P. 3
3.4. Ignition Feed (Cont.), P. 4
3.5. Accessory Feed, P. 5
3.6. J1939 Data Link W/500k W/Def Gauge W/F 2017 Isl Engine, P. 6
3.7. J1939 Data Link W/500k W/Allison Transmission W/F 2017 Isl Engine, P. 7
3.8. J1939 Data Link W/500k W/Allison Transmission W/Elex Engine Gauge
W/F 2017 Isl Engine, P. 7a
3.9. Elex Engine Gauge W/Bendix Ec-80, P. 7b
3.10. Ground Platform, P. 8
3.11. Ground Platform (Cont.), P.9
3.12. Ground Platform (Cont.), P.10
3.13. Ground Chassis, P. 11
3.14. Ground Engine W/ F 2017 Isl Engine, P. 12
3.15. Ground Engine W/ F 2017 Isl Engine (Cont.), P. 13
3.16. Diagnostic Connections, P. 14
3.17. Dc Outlet, P. 15
3.18. J1939 Datalink W/Def Gauge Loc2 W/Bendix Ec-80 W/ Wingman, P. 16
3.19. J1939 Datalink W/Def Gauge Loc1 W/Bendix Ec-80 W/ Wingman, P. 17
3.20. J1939 Datalink W/Def Gauge W/Bendix Ec-80 W/ Standard, P. 18
3.21. J1939 Datalink W/Def Gauge Loc1 W/ Zonar, P. 19
4. Charging And Cranking System (Chapter 4)
4.1. Starting And Cranking W/ Allison Transmission W/F 2017 Isl Engine, P. 1.
4.2. Starting And Cranking W/ Allison Transmission W/F 2017 Isl Engine, P. 2. . . .
5. Gauges And Warning Lights (Chapter 5)
5.1. Fuel Level Gauge, P. 1
5.2. Transmission Oil Temperature Gauge, P. 2
5.3. Def Gauge W / Ammeter 300amp, P. 3
5.4. Def Gauge Without Ammeter 300amp, P. 4
5.5. Engine Oil Pressure, Speedometer, Tachometer, Water Temperature,
Voltmeter, P. 5
5.6. Park Brake Indicator Light, P. 6
5.7. Park Brake Indicator Light W / Seat Belt, P. 7
5.8. Park Brake W / Warning Alarm, P. 8
5.9. Park Brake W / Warning Alarm (Cont.), P. 9
5.10. Park Brake Interlocks, P. 10
5.11. Low Air Pressure Air Audible Alarm, P. 11
5.12. Malfunction Indicator Light (Mil) Without Bendix Ec-80, P. 12
5.13. Malfunction Indicator Light (Mil) W/ Bendix Ec-80, P. 12a
5.14. Water In Fuel Light, P. 13
5.15. Remote Voltage Sense, P. 14
5.16. Fuel Filter Cummins Standard, P. 15
5.17. Fuel Heater Front Of Fuel Tank, P. 16
6. Engine And Engine Systems (Chapter 6)
6.1. Electronics Engine Control W/ F 2017 Isl Engine, P. 1
6.2. Electronics Engine Control W/ F 2017 Isl Engine (Cont.), P. 2
6.3. Electronics Engine Control W/ F 2017 Isl Engine (Cont.), P. 3
6.4. Electronics Engine Control W/ F 2017 Isl Engine (Cont.), P. 4
6.5. Accelerator Pedal W/Bendix Ec-80, P. 4a
6.6. Def And Aftertreatment W/ F 2017 Isl Engine, P. 5
6.7. Def And Aftertreatment W/ F 2017 Isl Engine (Cont.), P. 6
6.8. Def And Aftertreatment W/ F 2017 Isl Engine (Cont.), P. 7
6.9. Def And Aftertreatment W/ F 2017 Isl Engine (Cont.), P. 8
6.10. Def And Aftertreatment W/ F 2017 Isl Engine (Cont.), P. 9
6.11. Pdm Product Graphics W/ F 2017 Isl Engine, P. 10
6.12. Power Distribution Control Module, P. 11
6.13. Power Distribution Control Module (Cont.), P. 12
6.14. Power Distribution Control Module (Cont.), P. 13
7. Chassis System (Chapter 7)
7.1. Electric Horn, P. 1
7.2. Air Dryer And Drain Valve Wiring, P. 2
7.3. Traction Aids - Traction Sanders, P. 3
7.4. Traction Aid - Spot Chain, P. 4
7.5. Standard Single Wiper Switch Wiring, P. 5
7.6. Standard Single Wiper Switch Wiring (Cont.), P. 6
7.7. Dual Wiper Switch Wiring, P. 7
8. Transmission And Transmission Systems (Chapter 8)
8.1. Allison Transmission W/ F 2017 Isl Engine, P. 1
8.2. Allison Transmission W/ F 2017 Isl Engine (Cont.), P. 2
8.3. Allison Transmission W/ F 2017 Isl Engine (Cont.), P. 3
8.4. Allison Transmission W/ F 2017 Isl Engine (Cont.), P. 4
8.5. Allison Transmission 3000 W/ Retarder W/ F 2017 Isl Engine, P. 5
8.6. Allison Transmission 3000 W/ Retarder W/ F 2017 Isl Engine (Cont.), P. 6. . . .
8.7. Allison Transmission 3000 W/ Retarder W/ F 2017 Isl Engine (Cont.), P. 6a .
9. Brake System (Chapter 9)
9.1. Bendix Air Brake Abs W / Chassis Mounted Module, P. 1
9.2. Bendix Air Brake Abs W / Chassis Mounted Module (Cont.), P. 2
9.3. Bendix Air Brake Abs W / Chassis Mounted Module (Cont.), P. 3
9.4. Cruise Control And Electronic Hand Throttle, P. 4
9.5. Exhaust Aftertreatment Control System, P. 5
9.6. Exhaust Brake, P. 6
9.7. Compression Brakes, P. 7
9.8. Bendix Air Brake Abs W/Bendix Ec-80, P. 8
9.9. Bendix Air Brake Abs Traction Control W/Bendix Ec-80, P. 9
9.10. Bendix Air Brake Abs W/Esp 45/4m W/4 Ch W/Bendix Ec-80, P. 10
9.11. Bendix Air Brake Abs W/Esp 45/4m W/4 Ch W/Bendix Ec-80 (Cont.)., P. 11
9.12. Bendix Wingman W/Bendix Ec-80, P. 12
9.13. Bendix Wingman W/Bendix Ec-80 (Cont.), P. 13
9.14. Bendix Fusion Options, P. 14
9.15. Bendix Fusion Options (Cont.), P. 15
9.16. Ignition Splice Connections, P. 16
10. Heater / Air Conditioning (Chapter 10)
10.1. Espar Coolant Heater W / White Timer, P. 1
10.2. Espar Coolant Heater W / 7 Day Timer W / Diagnostic, P. 2
10.3. 7 Day Timer W/ Espar Heater W / Bendix Ec-80, P. 3
10.4. Espar Coolant Heater W / White Timer W/ Bendix Ec-80, P. 4
11. Intentionally Left Blank (Chapter 11)
11.1. Intentionally Left Blank, P. 1
12. Connector Composites (Chapter 12)
12.1. Connector Body Composites (1), P. 1
12.2. Connector Body Composites (1), P. 2
12.3. Connector Body Composites (1c, 1f), P. 2a
12.4. Connector Body Composites (Rd1, 2a, 2f), P. 3
12.5. Connector Body Composites (2m, Rd2), P. 4
12.6. Connector Body Composites (Rd3, Rd4, Rd5, Rd7, 4m), P. 5
12.7. Connector Body Composites (8m, 9, 10, 11m), P. 6
12.8. Connector Body Composites (12m, 13m, 22m), P. 7
12.9. Connector Body Composites (23m, 35x3, 37f), P. 8
12.10. Connector Body Composites (50, 51, 52, 52a), P. 9
12.11. Connector Body Composites (78m, 79m, 162, 168), P. 10
12.12. Connector Body Composites (168a, 211m, 211n, 212m), P. 11
12.13. Connector Body Composites (288x1, 289, 290, 291, 292), P. 12
12.14. Connector Body Composites (297, 299, 350x2, 351, 352, 353, 354), P. 13
12.15. Connector Body Composites (382m, 391, 392, 500), P. 14
12.16. Connector Body Composites (523), P. 15
12.17. Connector Body Composites (600, 674), P. 15a
12.18. Connector Body Composites (674, 675, 676, 677, 678), P. 16
12.19. Connector Body Composites (679), P. 17
12.20. Connector Body Composites (680, 681, 691, 898), P. 18
12.21. Connector Body Composites (899, 922, 922a, 925), P. 19
12.22. Connector Body Composites (926, 992, 995, 996m), P. 20
12.23. Connector Body Composites (997, 998, 1003, 1004), P. 21
12.24. Connector Body Composites (1008, 1030), P. 22
12.25. Connector Body Composites (1030), P. 23
12.26. Connector Body Composites (1030p, 1031, 1032), P. 24
12.27. Connector Body Composites (1033, 1034, 1036, 1037), P. 25
12.28. Connector Body Composites (1038, 1040, 1041), P. 26
12.29. Connector Body Composites (1042a, 1042b, 1043a, 1050), P. 27
12.30. Connector Body Composites (1062, 1063, 1065), P. 28
12.31. Connector Body Composites (1100, 1111a, 1111m, 1135, 1136), P. 29
12.32. Connector Body Composites (1137, 1138, 1139, 1139a, 1139b), P. 30
12.33. Connector Body Composites (1141, 1142, 1143a, 1143b), P. 31
12.34. Connector Body Composites (1149, 1150, 1150b), P. 32
12.35. Connector Body Composites (1151, 1151a, 1153, 1205), P. 33
12.36. Connector Body Composites (1206, 1272, 1600), P. 34
12.37. Connector Body Composites (1601, 1602), P. 35
12.38. Connector Body Composites (1604, 1606, 1650), P. 36
12.39. Connector Body Composites (1700), P. 36a
12.40. Connector Body Composites (1707m, 1800m, 1850, 1908, 1952, 2233), P. 37 .
12.41. Connector Body Composites (3117, 3118, 3322), P. 38
12.42. Connector Body Composites (3344, 4009, 4433), P. 39
12.43. Connector Body Composites (4800, 5263c, 5263f, 5263m, 5556m), P. 40
12.44. Connector Body Composites (6000), P. 41
12.45. Connector Body Composites (6010, 6012, 6120, 6200), P. 42
12.46. Connector Body Composites (6308, 6316m, 6348f, 6348m), P. 43
12.47. Connector Body Composites (6400, 6402, 6500, 6665m, 6704), P. 44
12.48. Connector Body Composites (6741, 6747, 7010), P. 45
12.49. Connector Body Composites (7150), P. 46
12.50. Connector Body Composites (7205f, 7206f, 7207f), P. 47
12.51. Connector Body Composites (7250, 7306f, 7603), P. 48
12.52. Connector Body Composites (7777m, 7980), P. 48a
12.53. Connector Body Composites (7981, 7982, 7983, 8500, 8600), P. 49
12.54. Connector Body Composites (8721, 8800, 9001, 9003, 9003a, 9261), P. 50
12.55. Connector Body Composites (9550, 9850), P. 51
12.56. Connector Body Composites (9851, 9900), P. 52
12.57. Connector Body Composites (9900a, 9901, 9902, 9902a), P. 53
12.58. Connector Body Composites (9903, 9904, 9996, 9999, 9999m), P. 54
12.59. Connector Body Composites (10000), P. 55
12.60. Connector Body Composites (10003, 10003l, 10004), P. 56
12.61. Connector Body Composites (10200), P. 57
12.62. Connector Body Composites (10201, 10202), P. 58
12.63. Connector Body Composites (10203, 10204), P. 59
12.64. Connector Body Composites (10207a, 10208), P. 60
12.65. Connector Body Composites (10210), P. 61
12.66. Connector Body Composites (10212, 10213), P. 62
12.67. Connector Body Composites (10214d, 10214l, 10215, 10216), P. 63
12.68. Connector Body Composites (10217, 10218, 10219), P. 64
12.69. Connector Body Composites (10220, 10221, 10224), P. 65
12.70. Connector Body Composites (10226), P. 66
12.71. Connector Body Composites (10227, 10228), P. 67
12.72. Connector Body Composites (10229, 10230a), P. 68
12.73. Connector Body Composites (10230b, 10231a), P. 69
12.74. Connector Body Composites (10231b, 10232a, 10232b), P. 70
12.75. Connector Body Composites (10233a, 10233b, 10234a), P. 71
12.76. Connector Body Composites (10234b, 10235, 10236), P. 72
12.77. Connector Body Composites (10237, 10238, 10239), P. 73
12.78. Connector Body Composites (10240, 10241a, 10241b), P. 74
12.79. Connector Body Composites (10242, 10243, 10243b), P. 75
12.80. Connector Body Composites (10244, 10244b, 10245), P. 76
12.81. Connector Body Composites (10245b, 10246, 10246b), P. 77
12.82. Connector Body Composites (10247, 10248, 10249, 10250), P. 78
12.83. Connector Body Composites (10252, 10253, 10254, 10255), P. 79
12.84. Connector Body Composites (10256. 10257, 10259), P. 80
12.85. Connector Body Composites (10264, 10267, 10268), P. 81
12.86. Connector Body Composites (10269, 10270a, 10270b), P. 82
12.87. Connector Body Composites (10275), P. 83
12.88. Connector Body Composites (10276, 10277, 10278, 10280), P. 84
12.89. Connector Body Composites (10281, 10282, 10284, 10285), P. 85
12.90. Connector Body Composites (10286, 10290, 10291), P. 86
12.91. Connector Body Composites (10292, 10293a, 10293b, 10294), P. 87
12.92. Connector Body Composites (10295, 10297, 10299), P. 88
12.93. Connector Body Composites (10301), P. 89
12.94. Connector Body Composites (10302), P. 90
12.95. Connector Body Composites (10303), P. 91
12.96. Connector Body Composites (10304), P. 92
12.97. Connector Body Composites (10305), P. 93
12.98. Connector Body Composites (10306), P. 94
12.99. Connector Body Composites (10307), P. 95
12.100.Connector Body Composites (10308), P. 96
12.101.Connector Body Composites (10309), P. 97
12.102.Connector Body Composites (10309) (Cont.), P. 98
12.103.Connector Body Composites (10310), P. 99
12.104.Connector Body Composites (10311), P. 100
12.105.Connector Body Composites (10312, 10314), P. 101
12.106.Connector Body Composites (10315, 10316, 10317, 10318) P. 102
12.107.Connector Body Composites (10319, 10320, 10321, 10322), P. 103
12.108.Connector Body Composites (10323, 10326), P. 104
12.109.Connector Body Composites (10327, 10328), P. 105
12.110.Connector Body Composites (10329, 10330), P. 106
12.111.Connector Body Composites (10331, 10332, 10333), P. 107
12.112.Connector Body Composites (10334, 10335), P. 108
12.113.Connector Body Composites (10336, 10337), P. 109
12.114.Connector Body Composites (10340f, 10340m, 10341, 10344a), P. 110
12.115.Connector Body Composites (10344b, 10345, 10346), P. 111
12.116.Connector Body Composites (10348, 10351, 10352), P. 112
12.117.Connector Body Composites, (10353, 10354, 10358), P. 113
12.118.Connector Body Composites (10360, 10365, 10368, 10398), P. 114
12.119.Connector Body Composites (10400), P. 115
12.120.Connector Body Composites (10401), P. 116
12.121.Connector Body Composites (10513, 10751, 10751a, 10766), P. 117
12.122.Connector Body Composites (11000), P. 118
12.123.Connector Body Composites (11632, 11633), P. 119
