International School Bus IC Bus CE Series Interactive Schematics 00000018836 2025
Brand: International, Navistar
Type of Machine: School Bus
Type of Manual: Interactive Schematics
Model: International CE Series School Bus
Built: 1/1/2024 To 12/31/2025
Part Number: 00000018836
Publication Date: 2025
Number of Pages: 3697 Pages
Body Control Module (BCM)
Body Control Module (BCM) Design 1
Body Standard J1939 (250kbps)
Body Standard J1939 (250kbps) Design 9
Cab Standard J1939 (250kbps)
Cab Standard J1939 (250kbps) Design 10
Engine Private J1939 (250kbps)
Engine Private J1939 (250kbps) Design 11
Fusion Proprietary J1939
Fusion Proprietary J1939 Design 12
Low Speed (125 kbps) J1939
Low Speed (125 kbps) J1939 Design 13
Powertrain J1939 (500kbps)
Powertrain J1939 (500kbps) Design 14
9pin Diagnositic Connector
9pin Diagnositic Connector Design 15
B6.7 - Engine Control Module (ECM)
B6.7 - Engine Control Module (ECM) Design 16
Instrument Cluster (EGC)
Instrument Cluster (EGC) Design 17
Instrument Cluster (EGC) - Request and Status
Instrument Cluster (EGC) - Request and Status Design 18
Rear Cap Ground Splice Packs
Rear Cap Ground Splice Packs Design 19
Left Body Ground Splice Packs
Left Body Ground Splice Packs Design 20
Right Body Ground Splice Packs
Right Body Ground Splice Packs Design 22
Electrical Panel Grounds
Electrical Panel Grounds Design 24
Electrical Panel Ground Splice Packs
Electrical Panel Ground Splice Packs Design 25
Electrical Panel ZVR Splice Pack
Electrical Panel ZVR Splice Pack Design 27
IP Grounds
IP Grounds Design 28
IP Ground Splice Packs
IP Ground Splice Packs Design 29
IP ZVR Splice Packs
IP ZVR Splice Packs Design 31
TABLE OF CONTENTS
iCenter Chassis Grounds
Center Chassis Grounds Design 32
Center Chassis Ground Splice Packs
Center Chassis Ground Splice Packs Design 33
Center Chassis ZVR Splice Pack
Center Chassis ZVR Splice Pack Design 34
Front Cap Ground Splice Packs
Front Cap Ground Splice Packs Design 35
Front Chassis Grounds
Front Chassis Grounds Design 36
Front Chassis Ground Splice Packs
Front Chassis Ground Splice Packs Design 37
B6.7 Powertrain Grounds
B6.7 Powertrain Grounds Design 39
B6.7 Powertrain Ground Splice Packs
B6.7 Powertrain Ground Splice Packs Design 40
B6.7 ZVR Splice Packs
B6.7 ZVR Splice Packs Design 41
Rear Chassis Grounds
Rear Chassis Grounds Design 42
Rear Chassis Ground Splice Pack
Rear Chassis Ground Splice Pack Design 44
LCM
LCM Design 45
Aftertreatment PDM
Aftertreatment PDM Design 46
Miscellaneous Power Distribution
Miscellaneous Power Distribution Design 47
Bus Body Fuse Block #C3 #C4 #D4
Bus Body Fuse Block #C3 #C4 #D4 Design 48
Bus Body Fuse Block #C6
Bus Body Fuse Block #C6 Design 51
Bus Body Fuse Block #C9
Bus Body Fuse Block #C9 Design 52
Bus Body Fuse Block #D1
Bus Body Fuse Block #D1 Design 54
Bus Body Fuse Block #D2
Bus Body Fuse Block #D2 Design 55
Chassis PDM
Chassis PDM Design 56
TABLE OF CONTENTS
iiOptional Chassis PDM
Optional Chassis PDM Design 57
Battery Grid 1
Battery Grid 1 Design 58
Battery Grid 2
Battery Grid 2 Design 60
CE Bus Interior PDM Chart
CE Bus Interior PDM Chart Design 61
Key Switch Accessory Grid 2
Key Switch Accessory Grid 2 Design 62
Key Switch Ignition Grid 1
Key Switch Ignition Grid 1 Design 63
Key Switch Ignition Grid 2
Key Switch Ignition Grid 2 Design 65
Grid Management (CA2, N/Load Shed, Bus N/Noise
Suppression)
Grid Management (CA2, N/Load Shed, Bus N/Noise Suppression) Design 66
Grid Management (CA2, N/Load Shed, Bus W/ Noise
Suppression)
Grid Management (CA2, N/Load Shed, Bus W/ Noise Suppression) Design 68
Grid Management (CA2, N/Load Shed, Conventional
Cab)
Grid Management (CA2, N/Load Shed, Conventional Cab) Design 70
Center Chassis N01 Lighting Splice Packs
Center Chassis N01 Lighting Splice Packs Design 71
Electrical Panel Light Splice Pack
Electrical Panel Light Splice Pack Design 72
IP Panel Dimmer Splice Packs
IP Panel Dimmer Splice Packs Design 73
IP Turn Signal Splice Packs
IP Turn Signal Splice Packs Design 74
Park/Turn Light Splice Packs 7110/4110/1590/6810
Park/Turn Light Splice Packs 7110/4110/1590/6810 Design 75
Powertrain B6.7 5V Splice Packs
Powertrain B6.7 5V Splice Packs Design 76
IP Underhood PDM
IP Underhood PDM Design 77
Power Adjustable Pedals (CE)
Power Adjustable Pedals (CE) Design 78
Back Up Alarm (CE) W/O Reverse Motion Sensor
Back Up Alarm (CE) W/O Reverse Motion Sensor Design 79
TABLE OF CONTENTS
iiiBack Up Alarm (CE) W/ Reverse Motion Sensor
Back Up Alarm (CE) W/ Reverse Motion Sensor Design 80
Bus Post Trip Inspection (Bus, eBus, No Student Left
Behind W/O Snooze, ACC Buzzer)
Bus Post Trip Inspection (Bus, eBus, No Student Left Behind W/O Snooze, ACC
Buzzer) Design 81
Behind W/ Snooze, ACC Buzzer)
Bus Post Trip Inspection (Bus, eBus, No Student Left Behind W/ Snooze, ACC
Buzzer) Design 83
Bus Post Trip Inspection (CE) Leave No Student
Behind (47KEC, ACC Buzzer)
Bus Post Trip Inspection (CE) Leave No Student Behind (47KEC, ACC Buzzer)
Design 85
Behind (47KEC, BAT Buzzer)
Bus Post Trip Inspection (CE) Leave No Student Behind (47KEC, BATTERY
Buzzer) Design 87
Behind (47KED, ACC Buzzer)
Bus Post Trip Inspection (CE) Leave No Student Behind (47KED, ACC Buzzer)
Design 89
Behind (47KED, BAT Buzzer)
Bus Post Trip Inspection (CE) Leave No Student Behind (47KED, BATTERY
Buzzer) Design 91
Behind (47KEE, ACC Buzzer)
Bus Post Trip Inspection (CE) Leave No Student Behind (47KEE, ACC Buzzer)
Design 93
Behind (47KEE, BAT Buzzer)
Bus Post Trip Inspection (CE) Leave No Student Behind (47KEE, BATTERY
Buzzer) Design 95
Behind (47KEG, ACC Buzzer)
Bus Post Trip Inspection (CE) Leave No Student Behind (47KEG, ACC Buzzer)
Design 97
Behind (47KEG, BAT Buzzer)
Bus Post Trip Inspection (CE) Leave No Student Behind (47KEG, BATTERY
Buzzer) Design 99
Bus Post Trip Inspection (CE) No Student Left Behind
W/O Snooze, BAT Buzzer
Bus Post Trip Inspection (CE) No Student Left Behind W/O Snooze, BATTERY
Buzzer Design 101
TABLE OF CONTENTS
ivBus Post Trip Inspection (CE) No Student Left Behind
W/ Snooze Button, BAT Buzzer
Bus Post Trip Inspection (CE) No Student Left Behind W/ Snooze Button,
BATTERY Buzzer Design 103
Bus Post Trip Inspection (Child Check Mate 47KDY
Pre-Wire)
Bus Post Trip Inspection (Child Check Mate 47KDY Pre-Wire) Design 105
Bus Post Trip Inspection (Child Check Mate 47KEA
Pre-Wire N/ Lift & N/Rear Dr Options)
Bus Post Trip Inspection (Child Check Mate 47KEA Pre-Wire N/ Lift & N/Rear Dr
Options) Design 107
Pre-Wire N/ Lift & W/Rear Dr Option)
Bus Post Trip Inspection (Child Check Mate 47KEA Pre-Wire N/ Lift & W/Rear Dr
Option) Design 109
Pre-Wire W/ Lift & N/Rear Dr Options)
Bus Post Trip Inspection (Child Check Mate 47KEA Pre-Wire W/ Lift & N/Rear Dr
Options) Design 111
Pre-Wire W/ Lift & W/Rear Dr Option)
Bus Post Trip Inspection (Child Check Mate 47KEA Pre-Wire W/ Lift & W/Rear Dr
Option) Design 113
Emergency Exit Door (Bus) Rear Only W/Piezo Alarm
ACC Power N/Rear Dr Option
Emergency Exit Door (Bus) Rear Only W/Piezo Alarm ACC Power N/Rear Dr
Option Design 115
ACC Power W/Rear Dr Option
Emergency Exit Door (Bus) Rear Only W/Piezo Alarm ACC Power W/Rear Dr
Option Design 116
BAT Power N/Rear Dr Option
Emergency Exit Door (Bus) Rear Only W/Piezo Alarm BATTERY Power N/Rear
Dr Option Design 117
BAT Power W/Rear Dr Option
Emergency Exit Door (Bus) Rear Only W/Piezo Alarm BATTERY Power W/Rear
Dr Option Design 118
Emergency Exit Door (Bus) Rear/Left W/Piezo Alarm
Emergency Exit Door (Bus) Rear/Left W/Piezo Alarm ACC Power N/Rear Dr
Option Design 119
Emergency Exit Door (Bus) Rear/Left W/Piezo Alarm ACC Power W/Rear Dr
Option Design 121
TABLE OF CONTENTS
vEmergency Exit Door (Bus) Rear/Left W/Piezo Alarm
Emergency Exit Door (Bus) Rear/Left W/Piezo Alarm BATTERY Power N/Rear Dr
Option Design 123
Emergency Exit Door (Bus) Rear/Left W/Piezo Alarm BATTERY Power W/Rear
Dr Option Design 125
Emergency Exit Door (Bus) Rear/Left/Right W/Piezo
Alarm ACC Power N/Rear Dr Option
Emergency Exit Door (Bus) Rear/Left/Right W/Piezo Alarm ACC Power N/Rear Dr
Option Design 127
Alarm ACC Power W/Rear Dr Option
Emergency Exit Door (Bus) Rear/Left/Right W/Piezo Alarm ACC Power W/Rear
Dr Option Design 129
Alarm BAT Power N/Rear Dr Option
Emergency Exit Door (Bus) Rear/Left/Right W/Piezo Alarm BATTERY Power
N/Rear Dr Option Design 131
Alarm BAT Power W/Rear Dr Option
W/Rear Dr Option Design 133
Emergency Exit Door (CE) Rear Only, ACC Power
W/Mechl Buzzer N/ Rear Dr Option
Emergency Exit Door (CE) Rear Only, ACC Power W/Mechl Buzzer N/ Rear Dr
Option Design 135
W/Mechl Buzzer W/Rear Dr Option
Emergency Exit Door (CE) Rear Only, ACC Power W/Mechl Buzzer W/Rear Dr
Option Design 136
Infotainment System (Radio) (Bus, N/LDW Speakers,
W/Mux Switches)
Infotainment System (Radio) (Bus, N/LDW Speakers, W/Mux Switches)
Design 137
Infotainment System (Radio) (Bus, W/ LDW Speakers,
W/Mux Switches)
Infotainment System (Radio) (Bus, W/ LDW Speakers, W/Mux Switches)
Design 138
Infotainment System (Radio) (CE Wiring Only)
Infotainment System (Radio) (CE Wiring Only) Design 139
Radio
Radio Design 140
Radio W/ Bluetooth
Radio W/ Bluetooth Design 141
TABLE OF CONTENTS
viRadio W/ Bluetooth & W/ Steering Wheel Pod
Radio W/ Bluetooth & W/ Steering Wheel Pod Design 142
Radio W/ Steering Wheel Pod
Radio W/ Steering Wheel Pod Design 143
Speakers (Bus, Eight Speakers W/ External PA
Speaker)
Speakers (Bus, Eight Speakers W/ External PA Speaker) Design 144
Speakers (Bus, Eight Speakers)
Speakers (Bus, Eight Speakers) Design 146
Speakers (Bus, Four Speakers W/ External PA
Speaker)
Speakers (Bus, Four Speakers W/ External PA Speaker) Design 148
Speakers (Bus, Four Speakers)
Speakers (Bus, Four Speakers) Design 150
Speakers (Bus, Two Speakers W/ External PA
Speaker)
Speakers (Bus, Two Speakers W/ External PA Speaker) Design 152
Speakers (Bus, Two Speakers)
Speakers (Bus, Two Speakers) Design 153
Speakers (Bus, 2 Speakers in Bulkhead W/ External
PA Speaker)
Speakers (Bus, 2 Speakers in Bulkhead W/ External PA Speaker) Design 154
Speakers (Bus, 2 Speakers in Bulkhead)
Speakers (Bus, 2 Speakers in Bulkhead) Design 155
Version 1 of E02 Speaker Splice Packs
Version 1 of E02 Speaker Splice Packs Design 156
Version 1 of F02 Speaker Splice Packs
Version 1 of F02 Speaker Splice Packs Design 157
Steering Wheel Left and Right Pod N/Air Bag
Steering Wheel Left and Right Pod N/Air Bag Design 158
Steering Wheel Left Pod
Steering Wheel Left Pod Design 159
Steering Wheel Right Pod
Steering Wheel Right Pod Design 160
Auxiliary Power (40A) HSD
Auxiliary Power (40A) HSD Design 161
AUX Power Connector (2 BAT, 2 ACC 20A Fused
Connectors)
AUX Power Connector (2 BAT, 2 ACC 20A Fused Connectors) Design 162
AUX Power Connector (2 BAT, 4 ACC 20A Fused
Connectors)
AUX Power Connector (2 BAT, 4 ACC 20A Fused Connectors) Design 163
TABLE OF CONTENTS
viiAUX Power Connector (4 ACC 20A Fused Connectors)
AUX Power Connector (4 ACC 20A Fused Connectors) Design 164
Aux Power (Blunt Cut)
Aux Power (Blunt Cut) Design 165
Forward Auxiliary Power Source (1 APO)
Forward Auxiliary Power Source (1 APO) Design 166
Forward Auxiliary Power Source (2 APO)
Forward Auxiliary Power Source (2 APO) Design 168
Forward Auxiliary Power Source (3 APO)
Forward Auxiliary Power Source (3 APO) Design 170
Aux Power (Banana Plug)
Aux Power (Banana Plug) Design 172
Booster Pump (Bus, Controlled by Aux Heater Switch)
Booster Pump (Bus, Controlled by Aux Heater Switch) Design 173
Booster Pump (Bus, High Output, Controlled by Aux
Heater Switch)
Booster Pump (Bus, High Output, Controlled by Aux Heater Switch) Design 174
Booster Pump (CE N/Coolant Heater)
Booster Pump (CE N/Coolant Heater) Design 175
Booster Pump (CE W/Coolant Heater Timer)
Booster Pump (CE W/Coolant Heater Timer) Design 176
Booster Pump (High Output, N/Coolant Heater)
Booster Pump (High Output, N/Coolant Heater) Design 177
Booster Pump (High Output, W/Coolant Heater)
Booster Pump (High Output, W/Coolant Heater) Design 178
Bus Crossing Gate (CE) Air Crossing Gate
Bus Crossing Gate (CE) Air Crossing Gate Design 179
Bus Crossing Gate (CE) Air Crossing Gate W/LH
Cross Gate Interrupt
Bus Crossing Gate (CE) Air Crossing Gate W/LH Cross Gate Interrupt Design 180
Bus Crossing Gate (CE) Air Crossing Gate W/RH
Bus Crossing Gate (CE) Air Crossing Gate W/RH Cross Gate Interrupt Design181
Override
Bus Crossing Gate (CE) Air Crossing Gate W/ Override Design 182
Bus Crossing Gate (CE) Electric Crossing Gate
Bus Crossing Gate (CE) Electric Crossing Gate Design 183
Bus Crossing Gate (CE) Electric Crossing Gate W/LH
Bus Crossing Gate (CE) Electric Crossing Gate W/LH Cross Gate Interrupt
Design 184
TABLE OF CONTENTS
viiiBus Crossing Gate (CE) Electric Crossing Gate W/RH
Bus Crossing Gate (CE) Electric Crossing Gate W/RH Cross Gate Interrupt
Design 185
Bus Alternate Entrance Door (Left Side Electric Door,
Omit Master Switch)
Bus Alternate Entrance Door (Left Side Electric Door, Omit Master Switch)
Design 186
W/ LH Master Switch)
Bus Alternate Entrance Door (Left Side Electric Door, W/ LH Master Switch)
Design 187
W/ RH Master Switch)
Bus Alternate Entrance Door (Left Side Electric Door, W/ RH Master Switch)
Design 188
Bus Alternate Entrance Door (Right Side Air Door)
Bus Alternate Entrance Door (Right Side Air Door) Design 189
Bus Entrance Door Operation (Air Door N/ Sensitive
Edge)
Bus Entrance Door Operation (Air Door N/ Sensitive Edge) Design 193
Bus Entrance Door Operation (Air Door W/ Sensitive
Edge)
Bus Entrance Door Operation (Air Door W/ Sensitive Edge) Design 194
Bus Entrance Door Operation (Air Door, W/ Knob
Wakeup)(Post 3/24)
Bus Entrance Door Operation (Air Door, W/ Knob Wakeup)(Post 3/24) Design 196
Wakeup)(Pre 3/24)
Bus Entrance Door Operation (Air Door, W/ Knob Wakeup)(Pre 3/24) Design 198
Wakeup, W/ Sensitive Edge)
Bus Entrance Door Operation (Air Door, W/ Knob Wakeup, W/ Sensitive Edge)
Design 200
Bus Entrance Door Operation (CAN Electric Motor
W/Knob Wakeup, W/ Sensitive Edge)
Bus Entrance Door Operation (CAN Electric Motor W/Knob Wakeup, W/ Sensitive
Edge) Design 202
Bus Entrance Door Operation (CAN Electric Motor, W/
Knob Wakeup)
Bus Entrance Door Operation (CAN Electric Motor, W/ Knob Wakeup) Design 204
Bus Entrance Door Request and Status (CE) 2
Position Rotary Switch
Bus Entrance Door Request and Status (CE) 2 Position Rotary Switch Design 206
TABLE OF CONTENTS
ixBus Entrance Door Request and Status (CE) 3
Bus Entrance Door Request and Status (CE) 3 Position Rotary Switch Design 208
Bus Entrance Door Request and Status (Steering
Wheel Controls W/Left Side Redundant Switch)
Bus Entrance Door Request and Status (Steering Wheel Controls W/Left Side
Redundant Switch) Design 210
Wheel Controls W/Right Side
Bus Entrance Door Request and Status (Steering Wheel Controls W/Right Side
Design 211
Bus Entrance Door Request and Status (3-Position
Paddle Switch)
Bus Entrance Door Request and Status (3-Position Paddle Switch) Design 212
Version 1 of B06 Stop Arm Splice Packs
Version 1 of B06 Stop Arm Splice Packs Design 213
Bus Stop Arm (Air, Front and Rear W/Left Side Stop
Arm Interrupt Switch)
Bus Stop Arm (Air, Front and Rear W/Left Side Stop Arm Interrupt Switch)
Design 214
Bus Stop Arm (Air, Front and Rear)
Bus Stop Arm (Air, Front and Rear) Design 222
Bus Stop Arm (Air, Front or Rear W/Left Side Stop
Bus Stop Arm (Air, Front or Rear W/Left Side Stop Arm Interrupt Switch)
Design 230
Bus Stop Arm (Air, Front or Rear)
Bus Stop Arm (Air, Front or Rear) Design 239
Bus Stop Arm (CE) Front and Rear Air Stop Arm
W/Right Side Stop Arm Interrupt Switch
Bus Stop Arm (CE) Front and Rear Air Stop Arm W/Right Side Stop Arm Interrupt
Switch Design 248
Bus Stop Arm (CE) Front or Rear Air Stop Arm
Bus Stop Arm (CE) Front or Rear Air Stop Arm W/Right Side Stop Arm Interrupt
Switch Design 256
Bus Stop Arm (Electric, Front and Rear W/Left Side
Bus Stop Arm (Electric, Front and Rear W/Left Side Stop Arm Interrupt Switch)
Design 265
Bus Stop Arm (Electric, Front and Rear W/Right Side
Bus Stop Arm (Electric, Front and Rear W/Right Side Stop Arm Interrupt Switch)
Design 273
Bus Stop Arm (Electric, Front and Rear)
TABLE OF CONTENTS
xBus Stop Arm (Electric, Front and Rear) Design 281
Bus Stop Arm (Electric, Front or Rear W/Left Side
Bus Stop Arm (Electric, Front or Rear W/Left Side Stop Arm Interrupt Switch)
Design 289
Bus Stop Arm (Electric, Front or Rear W/Right Side
Bus Stop Arm (Electric, Front or Rear W/Right Side Stop Arm Interrupt Switch)
Design 298
Bus Stop Arm (Electric, Front or Rear)
Bus Stop Arm (Electric, Front or Rear) Design 307
Camera (CE, Bat Ign & Gnd for Video Wiring, W/ Lytx
Video)
Camera (CE, Bat Ign & Gnd for Video Wiring, W/ Lytx Video) Design 316
Camera (CE, eBus) Pwr & Gnd for Video Wiring, W/O
Lytx Video
Camera (CE, eBus) Pwr & Gnd for Video Wiring, W/O Lytx Video Design 317
Camera (CE, Pwr & Gnd for Video Wiring Mounted
Above Driver)
Camera (CE, Pwr & Gnd for Video Wiring Mounted Above Driver) Design 318
Camera (CE, Seon TL4 DVR Prewire, w/ Seon Signals)
Camera (CE, Seon TL4 DVR Prewire, w/ Seon Signals) Design 319
Surround View (Camera Display, 1 Camera EOF,
Prewire)
Surround View (Camera Display, 1 Camera EOF, Prewire) Design 321
Compartment Vandal Lock (Bus, Driver Compt Only
W/Mechanical Buzzer)
Compartment Vandal Lock (Bus, Driver Compt Only W/Mechanical Buzzer)
Design 322
W/Std Buzzer)
Compartment Vandal Lock (Bus, Driver Compt Only W/Std Buzzer) Design 323
Compartment Vandal Lock (Bus, N/Interlock
W/Mechanical Buzzer N/Driver Compt)
Compartment Vandal Lock (Bus, N/Interlock W/Mechanical Buzzer N/Driver
Compt) Design 324
W/Mechanical Buzzer W/Driver Compt)
Compartment Vandal Lock (Bus, N/Interlock W/Mechanical Buzzer W/Driver
Compt) Design 325
Compartment Vandal Lock (Bus, N/Interlock W/Std
Compartment Vandal Lock (Bus, N/Interlock W/Std Buzzer N/Driver Compt)
Design 326
TABLE OF CONTENTS
xiCompartment Vandal Lock (Bus, N/Interlock W/Std
Compartment Vandal Lock (Bus, N/Interlock W/Std Buzzer W/Driver Compt)
Design 327
Compartment Vandal Lock (Bus, W/Interlock
Compartment Vandal Lock (Bus, W/Interlock W/Mechanical Buzzer N/Driver
Compt) Design 328
Compartment Vandal Lock (Bus, W/Interlock W/Mechanical Buzzer W/Driver
Compt) Design 329
Compartment Vandal Lock (Bus, W/Interlock W/Std
Buzzer N/ Driver Compt)
Compartment Vandal Lock (Bus, W/Interlock W/Std Buzzer N/ Driver Compt)
Design 330
Compartment Vandal Lock (Bus, W/Interlock W/Std Buzzer W/Driver Compt)
Design 331
Version 1 of B02 Vandal Lock Splice Packs
Version 1 of B02 Vandal Lock Splice Packs Design 332
Destination Sign (Type 1 LED)
Destination Sign (Type 1 LED) Design 333
Destination Sign (Type 2 LED)
Destination Sign (Type 2 LED) Design 334
Destination Sign (Type 3 LED)
Destination Sign (Type 3 LED) Design 336
Driver Alert Sign (CE)
Driver Alert Sign (CE) Design 338
Emergency Exit Splice Packs
Emergency Exit Splice Packs Design 339
Emergency Exit Vandal Lock (CE) Rear Door Only
Emergency Exit Vandal Lock (CE) Rear Door Only Design 340
Emergency Exit Vandal Lock (CE) Rear & Left Side
Emergency Exit Vandal Lock (CE) Rear & Left Side Design 342
Emergency Exit Vandal Lock (CE) Rear, Left & Right
Side
Emergency Exit Vandal Lock (CE) Rear, Left & Right Side Design 344
Emergency Exit Windows (CE) 1 Window each side
Emergency Exit Windows (CE) 1 Window each side Design 346
Emergency Exit Windows (CE) 2 Windows each side
Emergency Exit Windows (CE) 2 Windows each side Design 348
TABLE OF CONTENTS
xiiEmergency Exit Windows (CE) 3 Windows each side
Emergency Exit Windows (CE) 3 Windows each side Design 350
Emergency Exit Windows (CE) 4 Windows each side
Emergency Exit Windows (CE) 4 Windows each side Design 352
Hazard Warning (CE W/ Redundant Panel Switch)
Hazard Warning (CE W/ Redundant Panel Switch) Design 354
Hazard Warning (CE, W/O Redundant Switch)
Hazard Warning (CE, W/O Redundant Switch) Design 355
Hood Switch
Hood Switch Design 356
Hood Switch (W/ Underhood Work Light)
Hood Switch (W/ Underhood Work Light) Design 357
Air Horn (Highway) W/Hardwired Switch
Air Horn (Highway) W/Hardwired Switch Design 358
City Horn
City Horn Design 359
Mirrors (Heated) (CE, Crossview Heat N/ Rear View
Heat)
Mirrors (Heated) (CE, Crossview Heat N/ Rear View Heat) Design 360
Mirrors (Heated) (CE, Crossview & Rear View Heated,
Motorized)
Mirrors (Heated) (CE, Crossview & Rear View Heated, Motorized) Design 361
Non-Motorized)
Mirrors (Heated) (CE, Crossview & Rear View Heated, Non-Motorized) Design362
Mirrors (Heated) (CE, Rear View Heat, Motorized N/
Crossview Heat)
Mirrors (Heated) (CE, Rear View Heat, Motorized N/ Crossview Heat) Design 363
Mirrors (Heated) (CE, Rear View Heat, Non-Motorized,
N/ Crossview)
Mirrors (Heated) (CE, Rear View Heat, Non-Motorized, N/ Crossview) Design 364
Mirrors (Power) (CE, Dual Ctrl Switch, L/R W/
Upper/Lower Mirrors)
Mirrors (Power) (CE, Dual Ctrl Switch, L/R W/ Upper/Lower Mirrors) Design 365
Switch Packs
Switch Packs Design 366
Noise Suppression Switch (CE) No A/C Noise
Abatement
Noise Suppression Switch (CE) No A/C Noise Abatement Design 367
Noise Suppression Switch (CE) W/ 1 Abatement
Adaptor
TABLE OF CONTENTS
xiiiNoise Suppression Switch (CE) W/ 1 Abatement Adaptor Design 368
Noise Suppression Switch (CE) W/ 2 Abatement
Adapters
Noise Suppression Switch (CE) W/ 2 Abatement Adapters Design 369
Pupil Warning Master Flasher Switch (Left Side)
Pupil Warning Master Flasher Switch (Left Side) Design 370
Pupil Warning Master Flasher Switch (Left Side, W/
Lift Door Relay)
Pupil Warning Master Flasher Switch (Left Side, W/ Lift Door Relay) Design 371
Pupil Warning Master Flasher Switch (Right Side)
Pupil Warning Master Flasher Switch (Right Side) Design 372
Pupil Warning Master Flasher Switch (Right Side, W/
Lift Door Relay)
Pupil Warning Master Flasher Switch (Right Side, W/ Lift Door Relay) Design 373
Pupil Warning Master Flasher Switch (W/Amber
Cancel)
Pupil Warning Master Flasher Switch (W/Amber Cancel) Design 374
Pupil Warning Red Override Switch (Left Side)
Pupil Warning Red Override Switch (Left Side) Design 375
Pupil Warning Red Override Switch (Left Side, Always
Hot)
Pupil Warning Red Override Switch (Left Side, Always Hot) Design 376
Hot, Lift Door Activated)
Pupil Warning Red Override Switch (Left Side, Always Hot, Lift Door Activated)
Design 377
Hot, Lift Door Activated, W/ Master Sw)
Pupil Warning Red Override Switch (Left Side, Always Hot, Lift Door Activated, W/
Master Sw) Design 378
Pupil Warning Red Override Switch (Omit Switch, Lift
Door Activated)
Pupil Warning Red Override Switch (Omit Switch, Lift Door Activated) Design 379
Pupil Warning Red Override Switch (Omit, Lift Door
Pupil Warning Red Override Switch (Omit, Lift Door Activated, W/ Master Sw)
Design 380
Pupil Warning Red Override Switch (Right Side)
Pupil Warning Red Override Switch (Right Side) Design 381
Pupil Warning Red Override Switch (Right Side,
Always Hot)
Pupil Warning Red Override Switch (Right Side, Always Hot) Design 382
TABLE OF CONTENTS
xivPupil Warning Red Override Switch (Right Side,
Pupil Warning Red Override Switch (Right Side, Always Hot, Lift Door Activated)
Design 383
Always Hot, Lift Door Activated, W/ Master SW)
Pupil Warning Red Override Switch (Right Side, Always Hot, Lift Door Activated,
W/ Master SW) Design 384
Roof Hatch Emergency Exit (CE) Front Hatch Only
Roof Hatch Emergency Exit (CE) Front Hatch Only Design 385
Roof Hatch Emergency Exit (CE) Front & Rear Hatch
Roof Hatch Emergency Exit (CE) Front & Rear Hatch Design 392
Roof Hatch Emergency Exit (CE) Front, Rear & Center
Hatch
Roof Hatch Emergency Exit (CE) Front, Rear & Center Hatch Design 394
Roof Hatch Power Vent (CE) Front & Rear
Roof Hatch Power Vent (CE) Front & Rear Design 396
Roof Hatch Power Vent (CE, Front Vent Only)
Roof Hatch Power Vent (CE, Front Vent Only) Design 398
Roof Hatch Power Vent (CE, Rear Vent Only)
Roof Hatch Power Vent (CE, Rear Vent Only) Design 400
Roof Hatch Vandal Lock (Bus) W/Starter Interlock,
Front Only
Roof Hatch Vandal Lock (Bus) W/Starter Interlock, Front Only Design 402
Front & Rear
Roof Hatch Vandal Lock (Bus) W/Starter Interlock, Front & Rear Design 404
Over The Air Electrical I/O (OnCommand Link / N2
Module/ ISB)
Over The Air Electrical I/O (OnCommand Link / N2 Module/ ISB) Design 406
Telematics (Bus) Zonar Pre-Wire
Telematics (Bus) Zonar Pre-Wire Design 407
Telematics (CE) Zonar Pre-Wire
Telematics (CE) Zonar Pre-Wire Design 409
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater) Design 411
Traction Aids (Traction Chains, CE Bus)
Traction Aids (Traction Chains, CE Bus) Design 412
Aux Power (USB) - 1 USB
Aux Power (USB) - 1 USB Design 413
Aux Power (USB) - 1 USB A, 1 USB C
Aux Power (USB) - 1 USB A, 1 USB C Design 415
TABLE OF CONTENTS
xvAux Power (USB) - 2 USB
Aux Power (USB) - 2 USB Design 417
Aux Power (USB) - 2 USB A, 2 USB C
Aux Power (USB) - 2 USB A, 2 USB C Design 419
Aux Power (USB) - 3 USB
Aux Power (USB) - 3 USB Design 421
Aux Power (USB) - 3 USB A, 3 USB C
Aux Power (USB) - 3 USB A, 3 USB C Design 423
Aux Power (USB) - 4 USB
Aux Power (USB) - 4 USB Design 425
Bus Aux Power (USB) (CE) Single USB A, USB C
Bus Aux Power (USB) (CE) Single USB A, USB C Design 427
Bus Door Vandal Lock (W/ Starter Interrupt)
Bus Door Vandal Lock (W/ Starter Interrupt) Design 428
Wheelchair Lift Interlock (Key OFF/ON, Air Brakes,
Dash Switch)
Wheelchair Lift Interlock (Key OFF/ON, Air Brakes, Dash Switch) Design 429
Door Switch)
Wheelchair Lift Interlock (Key OFF/ON, Air Brakes, Door Switch) Design 431
Wheelchair Lift Interlock (Key OFF/ON, Air Brakes, No
Switch)
Wheelchair Lift Interlock (Key OFF/ON, Air Brakes, No Switch) Design 433
Wheelchair Lift Interlock (Key OFF/ON, Hydraulic
W/Foot Park Brake, No Switch)ke, No Switch)
Wheelchair Lift Interlock (Key OFF/ON, Hydraulic W/Foot Park Brake, No
Switch)ke, No Switch) Design 435
W/SAAR, No Switch)
Wheelchair Lift Interlock (Key OFF/ON, Hydraulic W/SAAR, No Switch)
Design 437
W/SAAR, W/ Dash Switch)
Wheelchair Lift Interlock (Key OFF/ON, Hydraulic W/SAAR, W/ Dash Switch)
Design 439
Foot Brake, Dash Switch)
Wheelchair Lift Interlock (Key OFF/ON, Hydraulic W/ Foot Brake, Dash Switch)
Design 441
Wheelchair Lift Interlock (Key ON, No Switch)
Wheelchair Lift Interlock (Key ON, No Switch) Design 443
Wheelchair Lift Interlock (Key ON, W/ Dash Switch &
Door Switch)
TABLE OF CONTENTS
xviWheelchair Lift Interlock (Key ON, W/ Dash Switch & Door Switch) Design 445
Wheelchair Lift Interlock (Key ON, W/ Dash Switch)
Wheelchair Lift Interlock (Key ON, W/ Dash Switch) Design 447
Wheelchair Lift Interlock (Key ON, W/ Door Switch)
Wheelchair Lift Interlock (Key ON, W/ Door Switch) Design 449
Wheelchair Lift Lighting (CE, Interior Light Only)
Wheelchair Lift Lighting (CE, Interior Light Only) Design 451
Wheelchair Lift Lighting (CE, Single Exterior, N/
Interior)
Wheelchair Lift Lighting (CE, Single Exterior, N/ Interior) Design 452
Wheelchair Lift Lighting (CE, Single Exterior, W/
Interior)
Wheelchair Lift Lighting (CE, Single Exterior, W/ Interior) Design 454
Wheelchair Lift Lighting (CE, Three Exterior, N/
Interior)
Wheelchair Lift Lighting (CE, Three Exterior, N/ Interior) Design 456
Wheelchair Lift Lighting (CE, Three Exterior, W/
Interior)
Wheelchair Lift Lighting (CE, Three Exterior, W/ Interior) Design 458
Wheelchair Lift Vandal Lock (CE)
Wheelchair Lift Vandal Lock (CE) Design 460
Wheelchair Warning (No Indicator, Buzzer On W/ Lift
Door Open)
Wheelchair Warning (No Indicator, Buzzer On W/ Lift Door Open) Design 461
Door Open, Shuts Off When 4" Open)
Wheelchair Warning (No Indicator, Buzzer On W/ Lift Door Open, Shuts Off When
4" Open) Design 462
Wheelchair Warning (No Indicator, Mechanical Buzzer
On W/ Lift Door Open, Shuts Off When 4" Open)
Wheelchair Warning (No Indicator, Mechanical Buzzer On W/ Lift Door Open,
Shuts Off When 4" Open) Design 463
Wheelchair Warning (2" Flashing Indicator, Buzzer On
W/ Lift Door Open)
Wheelchair Warning (2" Flashing Indicator, Buzzer On W/ Lift Door Open)
Design 464
Mechanical Buzzer On W/ Lift Door Open, Off W/ Lift
Door 4" Open)
Wheelchair Warning (2" Flashing Indicator, Mechanical Buzzer On W/ Lift Door
Open, Off W/ Lift Door 4" Open) Design 465
Wheelchair Warning (2" Flashing Indicator, No Buzzer)
Wheelchair Warning (2" Flashing Indicator, No Buzzer) Design 466
TABLE OF CONTENTS
xviiWheelchair Warning (2" Flashing Indicator, Piezo
Buzzer On W/ Lift Door Open, Off W/ Lift Door 4"
Open)
Wheelchair Warning (2" Flashing Indicator, Piezo Buzzer On W/ Lift Door Open,
Off W/ Lift Door 4" Open) Design 467
Wheelchair Warning (3" Indicator in Bulkhead, Buzzer
Wheelchair Warning (3" Indicator in Bulkhead, Buzzer On W/ Lift Door Open)
Design 468
On W/ Lift Door Open, Shuts off when 4" open)
Wheelchair Warning (3" Indicator in Bulkhead, Buzzer On W/ Lift Door Open,
Shuts off when 4" open) Design 469
Mechanical Buzzer On W/ Lift Door Open, Shuts Off
When 4" Open)
Wheelchair Warning (3" Indicator in Bulkhead, Mechanical Buzzer On W/ Lift
Door Open, Shuts Off When 4" Open) Design 470
Wheelchair Warning (3" Indicator in Bulkhead, No
Buzzer)
Wheelchair Warning (3" Indicator in Bulkhead, No Buzzer) Design 471
2-Way Radio
2-Way Radio Design 472
Diesel Particulate Filter (DPF) (W/ Regen Switch -
Relocated)
Diesel Particulate Filter (DPF) (W/ Regen Switch - Relocated) Design 473
Selective Catalytic Reduction (SCR)
Selective Catalytic Reduction (SCR) Design 474
Transmission I/O (Allison Gen 6 1K/2K N/ Body
Builder)
Transmission I/O (Allison Gen 6 1K/2K N/ Body Builder) Design 476
Transmission I/O (Allison Gen 6 3K N/ Body Builder)
Transmission I/O (Allison Gen 6 3K N/ Body Builder) Design 478
Air Dryer (Single)
Air Dryer (Single) Design 480
Air Solenoids 4-pack (1 pack/4 solenoids)
Air Solenoids 4-pack (1 pack/4 solenoids) Design 481
Antilock Brake Systems (ABS) (Wabco Hydraulic 4
Channel N/ Stability)
Antilock Brake Systems (ABS) (Wabco Hydraulic 4 Channel N/ Stability)
Design 482
Channel W/ Stability)
Antilock Brake Systems (ABS) (Wabco Hydraulic 4 Channel W/ Stability)
Design 483
TABLE OF CONTENTS
xviiiAntilock Brake System (ABS) (BENDIX 4 Channel
Implemenation - No Modulator Twist)
Antilock Brake System (ABS) (BENDIX 4 Channel Implemenation - No Modulator
Twist) Design 484
Service Brake Switch (Single Switch, N/Redundant
Switch, Hydraulic Brakes)
Service Brake Switch (Single Switch, N/Redundant Switch, Hydraulic Brakes)
Design 485
Service Brake Switch (1 SLS/1 Transducer)
Service Brake Switch (1 SLS/1 Transducer) Design 486
Drain Valve (1) One Heater
Drain Valve (1) One Heater Design 487
Service Brake (Hydraulic)
Service Brake (Hydraulic) Design 488
Auto Park Brake (T-Handle Shifter, Auto Park Brake)
Auto Park Brake (T-Handle Shifter, Auto Park Brake) Design 489
Park Brake Controls (Bus) Intellipark
Park Brake Controls (Bus) Intellipark Design 490
Park Brake Controls (Hydraulic SAAR Park Brake)
Park Brake Controls (Hydraulic SAAR Park Brake) Design 491
Park Brake Controls (Park Brake W/ Interlock, N/ Lift,
Air Chassis)
Park Brake Controls (Park Brake W/ Interlock, N/ Lift, Air Chassis) Design 492
Air Chassis, W/ Park Brake Buzzer)
Park Brake Controls (Park Brake W/ Interlock, N/ Lift, Air Chassis, W/ Park Brake
Buzzer) Design 493
W/SAAR)
Park Brake Controls (Park Brake W/ Interlock, N/ Lift, W/SAAR) Design 494
Park Brake Controls (Park Brake W/ Interlock, W/ Lift,
Air Chassis)
Park Brake Controls (Park Brake W/ Interlock, W/ Lift, Air Chassis) Design 495
Park Brake Controls (Park Brake W/ Interlock, W/ Lift, Air Chassis, W/ Park Brake
Buzzer) Design 496
SAAR)
Park Brake Controls (Park Brake W/ Interlock, W/ Lift, SAAR) Design 497
Park Brake Controls (W/ Inhibit Solenoid)
Park Brake Controls (W/ Inhibit Solenoid) Design 498
TABLE OF CONTENTS
xixPark Brake Reminder (Stationary) (Bus, W/ Hardwired
Buzzer)
Park Brake Reminder (Stationary) (Bus, W/ Hardwired Buzzer) Design 499
Stability Control (Bendix, Straight Truck, J1939 Driven
Lamp)
Stability Control (Bendix, Straight Truck, J1939 Driven Lamp) Design 500
Stability Control; Wabco Hydraulic W/ J1939 Driven
Lamp
Stability Control; Wabco Hydraulic W/ J1939 Driven Lamp Design 501
Traction Control (Bendix, ECM)
Traction Control (Bendix, ECM) Design 502
Adaptive Cruise Control (Bendix Wingman Advanced
N/ DIU)
Adaptive Cruise Control (Bendix Wingman Advanced N/ DIU) Design 503
Adaptive Cruise Control (Bendix - Fusion 2.8 &
N/Safety Direct Conn & W/Bus Bulkhead Speakers)
Adaptive Cruise Control (Bendix - Fusion 2.8 & N/Safety Direct Conn & W/Bus
Bulkhead Speakers) Design 504
W/Safety Direct Conn & W/Bus Bulkhead Speakers)
Adaptive Cruise Control (Bendix - Fusion 2.8 & W/Safety Direct Conn & W/Bus
Bulkhead Speakers) Design 506
Adaptive Cruise Control (Fusion 3.0 N/ DIU W/LDW
Audio Mute)
Adaptive Cruise Control (Fusion 3.0 N/ DIU W/LDW Audio Mute) Design 508
Adaptive Cruise Control (Fusion 3.0 N/ DIU)
Adaptive Cruise Control (Fusion 3.0 N/ DIU) Design 509
Camera Event Recorder N/Safety Direct Cable
Camera Event Recorder N/Safety Direct Cable Design 510
Engine Coolant Level Monitoring (No CLA Module)
Engine Coolant Level Monitoring (No CLA Module) Design 511
Cooling Fan Control (CE) Warner Electric
Cooling Fan Control (CE) Warner Electric Design 512
Cooling Fan Control (No Fan Override Cummins No
Radiator)
Cooling Fan Control (No Fan Override Cummins No Radiator) Design 513
Engine Idle Ramp Up (W/ A/C On)
Engine Idle Ramp Up (W/ A/C On) Design 514
Starting Aid (Grid Heater)
Starting Aid (Grid Heater) Design 515
Vehicle Acceleration with Adjustable pedal
Vehicle Acceleration with Adjustable pedal Design 516
TABLE OF CONTENTS
xxAutomatic Lighting W/Twilight & N/Sunload
Automatic Lighting W/Twilight & N/Sunload Design 517
Back Up Lights (Reverse Lights) (CE) (2) W/Light
Monitor N/ Exit Activated
Back Up Lights (Reverse Lights) (CE) (2) W/Light Monitor N/ Exit Activated
Design 518
Monitor & W/ E/E Activated
Back Up Lights (Reverse Lights) (CE) (2) W/Light Monitor & W/ E/E Activated
Design 519
Back Up Lights (Reverse Lights) (CE) (4) W/Light
Back Up Lights (Reverse Lights) (CE) (4) W/Light Monitor N/ Exit Activated
Design 520
Back Up Lights (Reverse Lights) (CE) (4) W/Light Monitor & W/ E/E Activated
Design 521
Beacon/Strobe Light (CE) Dual On with Ignition
Beacon/Strobe Light (CE) Dual On with Ignition Design 522
Beacon/Strobe Light (CE) Dual On W/ Stop Arm or
Switch
Beacon/Strobe Light (CE) Dual On W/ Stop Arm or Switch Design 535
Beacon/Strobe Light (CE) Dual W/Switch
Beacon/Strobe Light (CE) Dual W/Switch Design 548
Beacon/Strobe Light (CE) Dual W/Switch or W/PWL
Beacon/Strobe Light (CE) Dual W/Switch or W/PWL Design 561
Beacon/Strobe Light (CE) Dual W/ Momentary Switch
Beacon/Strobe Light (CE) Dual W/ Momentary Switch Design 574
Beacon/Strobe Light (CE) Single On with Ignition
Beacon/Strobe Light (CE) Single On with Ignition Design 587
Beacon/Strobe Light (CE) Single On W/ Stop Arm or
Switch
Beacon/Strobe Light (CE) Single On W/ Stop Arm or Switch Design 600
Beacon/Strobe Light (CE) Single W/Momentary Switch
Beacon/Strobe Light (CE) Single W/Momentary Switch Design 613
Beacon/Strobe Light (CE) Single W/Switch or W/PWL
Beacon/Strobe Light (CE) Single W/Switch or W/PWL Design 626
Beacon/Strobe Light (CE) Single W/Switch(Post 3/24)
Beacon/Strobe Light (CE) Single W/Switch(Post 3/24) Design 639
Beacon/Strobe Light (CE) Single W/Switch(Pre 3/24)
Beacon/Strobe Light (CE) Single W/Switch(Pre 3/24) Design 640
Bus Door Stepwell Lighting (Wired to ACC, N/ AED Lt)
Bus Door Stepwell Lighting (Wired to ACC, N/ AED Lt) Design 653
TABLE OF CONTENTS
xxiBus Door Stepwell Lighting (Wired to ACC, W/ AED Lt)
Bus Door Stepwell Lighting (Wired to ACC, W/ AED Lt) Design 654
Bus Door Stepwell Lighting (Wired to Clearance, N/
AED Lt)
Bus Door Stepwell Lighting (Wired to Clearance, N/ AED Lt) Design 655
Bus Door Stepwell Lighting (Wired to Clearance, W/
AED Lt)
Bus Door Stepwell Lighting (Wired to Clearance, W/ AED Lt) Design 656
Bus Door Stepwell Lighting (Wired to Dome Lts, N/
AED Lt)
Bus Door Stepwell Lighting (Wired to Dome Lts, N/ AED Lt) Design 657
Bus Door Stepwell Lighting (Wired to Dome Lts, W/
AED Lt)
Bus Door Stepwell Lighting (Wired to Dome Lts, W/ AED Lt) Design 658
Bus Door Stepwell Lighting (Wired to Ignition, N/ AED
Lt)
Bus Door Stepwell Lighting (Wired to Ignition, N/ AED Lt) Design 659
Bus Door Stepwell Lighting (Wired to IGN, W/ AED
Light)
Bus Door Stepwell Lighting (Wired to IGN, W/ AED Light) Design 660
Bus Light Monitor
Bus Light Monitor Design 661
Clearance and Identification Lights (CE, Front ID to
Ignition)
Clearance and Identification Lights (CE, Front ID to Ignition) Design 662
Directional Signals (Turn) (BUS CAN LED) N/Fender
Lts W/Light Monitor
Directional Signals (Turn) (BUS CAN LED) N/Fender Lts W/Light Monitor
Design 663
Directional Signals (Turn) (BUS CAN LED) W/Fender
Lts W/Light Monitor
Directional Signals (Turn) (BUS CAN LED) W/Fender Lts W/Light Monitor
Design 664
Directional Signals (Turn) (CE) Halogen N/Fender Lts
W/Light Monitor
Directional Signals (Turn) (CE) Halogen N/Fender Lts W/Light Monitor Design 665
Directional Signals (Turn) (CE) Halogen W/Fender Lts
W/Light Monitor
Directional Signals (Turn) (CE) Halogen W/Fender Lts W/Light Monitor Design666
Front Fog Lamps W/Relay
Front Fog Lamps W/Relay Design 667
Front Fog Lamps (Bus, W/ Relay)(Post 12/22)
Front Fog Lamps (Bus, W/ Relay)(Post 12/22) Design 668
Front Fog Lamps (Bus, W/ Relay)(Pre 12/22)
TABLE OF CONTENTS
xxiiFront Fog Lamps (Bus, W/ Relay)(Pre 12/22) Design 669
Marker Lighting (Halogen Headlights) N/Plowlights,
W/Fender, N/Guide Posts
Marker Lighting (Halogen Headlights) N/Plowlights, W/Fender, N/Guide Posts
Design 670
Marker Lighting (Halogen Headlights) N/Plowlight,
N/Fender, N/Guide Posts
Marker Lighting (Halogen Headlights) N/Plowlight, N/Fender, N/Guide Posts
Design 671
Marker Lighting (LED CAN Headlamp) N/Plow Lts,
N/Fender Lts, N/Guide Posts
Marker Lighting (LED CAN Headlamp) N/Plow Lts, N/Fender Lts, N/Guide Posts
Design 672
W/Fender Lts, N/Guide Posts
Marker Lighting (LED CAN Headlamp) N/Plow Lts, W/Fender Lts, N/Guide Posts
Design 673
Headlights (Bus Halogen)
Headlights (Bus Halogen) Design 674
Headlights (Bus LED CAN)
Headlights (Bus LED CAN) Design 675
License Plate Light (CE) W/Dual License Plate Lights
License Plate Light (CE) W/Dual License Plate Lights Design 676
License Plate Light (CE) W/Single License Plate Light
License Plate Light (CE) W/Single License Plate Light Design 677
License Plate Light (CE) W/Stop/Tail/License Light,
Monitored
License Plate Light (CE) W/Stop/Tail/License Light, Monitored Design 678
Not Monitored
License Plate Light (CE) W/Stop/Tail/License Light, Not Monitored Design 679
Mirror Lighting (Bus, Dual Crossview Lookdown
Light)
Mirror Lighting (Bus, Dual Crossview Lookdown Light) Design 680
Pupil Warning Lights (Steering Wheel, NonSequential, W/ Panel Flasher Switch)
Pupil Warning Lights (Steering Wheel, Non-Sequential, W/ Panel Flasher Switch)
Design 681
Pupil Warning Lights (W/ 3-Position Flasher Switch)
Pupil Warning Lights (W/ 3-Position Flasher Switch) Design 682
Pupil Warning Lights (W/ 3-Position Flasher Switch,
Always Hot)
Pupil Warning Lights (W/ 3-Position Flasher Switch, Always Hot) Design 683
Pupil Warning Lights (Left Side 2-Position, NonSequential)
TABLE OF CONTENTS
xxiiiPupil Warning Lights (Left Side 2-Position, Non-Sequential) Design 684
Pupil Warning Lights (Left Side 3-Position, NonSequential, No Master)(Post 3/24)
Pupil Warning Lights (Left Side 3-Position, Non-Sequential, No Master)(Post 3/24)
Design 685
Pupil Warning Lights (Left Side 3-Position, NonSequential, No Master)(Pre 3/24)
Pupil Warning Lights (Left Side 3-Position, Non-Sequential, No Master)(Pre 3/24)
Design 686
Pupil Warning Lights (Left Side 3-Position, NonSequential, No Master, Always Hot)
Pupil Warning Lights (Left Side 3-Position, Non-Sequential, No Master, Always
Hot) Design 688
Pupil Warning Lights (Left Side 3-Position, NonSequential, W/ Master)
Pupil Warning Lights (Left Side 3-Position, Non-Sequential, W/ Master)
Design 690
Pupil Warning Lights (Left Side 3-Position, NonSequential, W/ Master)(Post 3/24)
Pupil Warning Lights (Left Side 3-Position, Non-Sequential, W/ Master)(Post 3/24)
Design 692
Pupil Warning Lights (Left Side 3-Position, NonSequential, W/ Master)(Pre 3/24)
Pupil Warning Lights (Left Side 3-Position, Non-Sequential, W/ Master)(Pre 3/24)
Design 694
Pupil Warning Lights (Left Side 3-Position, NonSequential, W/ Master, Always Hot)
Pupil Warning Lights (Left Side 3-Position, Non-Sequential, W/ Master, Always
Hot) Design 696
Pupil Warning Lights (Left Side 3-Position, NonSequential, W/ Master, Always Hot)(Post 3/24)
Hot)(Post 3/24) Design 698
Pupil Warning Lights (Left Side 3-Position, NonSequential, W/ Master, Always Hot)(Pre 3/24)
Hot)(Pre 3/24) Design 699
Pupil Warning Lights (Left Side 3-Position, Sequential)
Pupil Warning Lights (Left Side 3-Position, Sequential) Design 701
Pupil Warning Lights (Left Side, Sequential)
Pupil Warning Lights (Left Side, Sequential) Design 703
Pupil Warning Lights (Left Side, 3-Position, NonSequential, No Master)
Pupil Warning Lights (Left Side, 3-Position, Non-Sequential, No Master)
Design 704
TABLE OF CONTENTS
xxivPupil Warning Lights (Left Side, 3-Position, NonSequential, No Master, Always Hot)
Pupil Warning Lights (Left Side, 3-Position, Non-Sequential, No Master, Always
Hot) Design 706
Pupil Warning Lights (Right Side 2-Position, NonSequential)
Pupil Warning Lights (Right Side 2-Position, Non-Sequential) Design 708
Pupil Warning Lights (Right Side 3-Position, NonSequential, Omit Master)
Pupil Warning Lights (Right Side 3-Position, Non-Sequential, Omit Master)
Design 709
Pupil Warning Lights (Right Side 3-Position, NonSequential, Omit Master, Always Hot)
Pupil Warning Lights (Right Side 3-Position, Non-Sequential, Omit Master, Always
Hot) Design 711
Pupil Warning Lights (Right Side 3-Position, NonSequential, W/ Master)
Pupil Warning Lights (Right Side 3-Position, Non-Sequential, W/ Master)
Design 713
Pupil Warning Lights (Right Side 3-Position, NonSequential, W/ Master, Always Hot)
Pupil Warning Lights (Right Side 3-Position, Non-Sequential, W/ Master, Always
Hot) Design 715
Sequential)
Pupil Warning Lights (Right Side 3-Position, Sequential) Design 717
Pupil Warning Lights (Right Side, Sequential)
Pupil Warning Lights (Right Side, Sequential) Design 719
Pupil Warning Lights (3-Position Paddle, NonSequential)
Pupil Warning Lights (3-Position Paddle, Non-Sequential) Design 720
Pupil Warning Lights (3-Position Paddle, NonSequential, Always Hot)
Pupil Warning Lights (3-Position Paddle, Non-Sequential, Always Hot) Design 721
Pupil Warning Light Interrupt (Hold to Cancel)
Pupil Warning Light Interrupt (Hold to Cancel) Design 722
Pupil Warning Light Interrupt (Master and RRX Cancel
W/Amber Cancel, No 3-Pos Switch)(Post 3/24)
Pupil Warning Light Interrupt (Master and RRX Cancel W/Amber Cancel, No 3-
Pos Switch)(Post 3/24) Design 723
W/Amber Cancel, No 3-Pos Switch)(Pre 3/24)
Pos Switch)(Pre 3/24) Design 724
TABLE OF CONTENTS
xxvPupil Warning Light Interrupt (Master and RRX
Cancel, W/Amber Cancel, W/3-Pos Paddle Sw)
Pupil Warning Light Interrupt (Master and RRX Cancel, W/Amber Cancel, W/3-
Pos Paddle Sw) Design 725
Pupil Warning Light Interrupt (Single Cycle Master &
RRX Cancel Switch)
Pupil Warning Light Interrupt (Single Cycle Master & RRX Cancel Switch)
Design 726
Pupil Warning Lights Outputs (With 16-Lamp Light
Monitor)
Pupil Warning Lights Outputs (With 16-Lamp Light Monitor) Design 727
Rear Lights (Stop) (CE) (2) N/Extra Lts W/Light
Monitor
Rear Lights (Stop) (CE) (2) N/Extra Lts W/Light Monitor Design 729
Rear Lights (Stop) (CE) (4) W/Add'l Stop/Tail Light
W/Light Monitor
Rear Lights (Stop) (CE) (4) W/Add'l Stop/Tail Light W/Light Monitor Design 730
Rear Lights (Stop) (CE) (4) W/Stop/Tail/License
W/Light Monitor
Rear Lights (Stop) (CE) (4) W/Stop/Tail/License W/Light Monitor Design 731
Rear Lights (Stop) (CE) (6) W/Stop/Tail/License &
W/Add'l S/T W/ Light Monitor
Rear Lights (Stop) (CE) (6) W/Stop/Tail/License & W/Add'l S/T W/ Light Monitor
Design 732
Rear Lights (Tail Lights) (CE) (2) W/License W/Omit
Std Wiring W/Lt Monitor
Rear Lights (Tail Lights) (CE) (2) W/License W/Omit Std Wiring W/Lt Monitor
Design 733
Rear Lights (Tail Lights) (CE) (4) W/Add'l Stop/Tail Lt
W/Lt Monitor
Rear Lights (Tail Lights) (CE) (4) W/Add'l Stop/Tail Lt W/Lt Monitor Design 734
Rear Lights (Tail Lights) (CE) (4) W/Stop/Tail/License
W/Lt Monitor
Rear Lights (Tail Lights) (CE) (4) W/Stop/Tail/License W/Lt Monitor Design 735
Rear Lights (Tail Lights) (CE) (6) W/License &
Additional W/Lt Monitor
Rear Lights (Tail Lights) (CE) (6) W/License & Additional W/Lt Monitor Design 736
Side Marker Lighting W/Side Marker/Turn
Combination Light (CE)
Side Marker Lighting W/Side Marker/Turn Combination Light (CE) Design 737
Side Marker Lighting (Bus, W/ Extra Markers only)
Side Marker Lighting (Bus, W/ Extra Markers only) Design 738
Side Marker Lighting (Bus, W/ Intermediate Lt &
Marker/Turn Lt)
TABLE OF CONTENTS
xxviSide Marker Lighting (Bus, W/ Intermediate Lt & Marker/Turn Lt) Design 740
Side Marker Lighting (Bus, W/ Intermediate Markers
only)
Side Marker Lighting (Bus, W/ Intermediate Markers only) Design 742
Side Marker Lighting (Bus, W/ Intermediate & Extra
Side Markers)
Side Marker Lighting (Bus, W/ Intermediate & Extra Side Markers) Design 746
SideTurn Lighting W/Side Marker/Turn Combination
Light & W/4 Side Turn (CE)
SideTurn Lighting W/Side Marker/Turn Combination Light & W/4 Side Turn (CE)
Design 748
Side Turn Lighting W/Marker/Turn Combination Light
(CE, eBus)
Side Turn Lighting W/Marker/Turn Combination Light (CE, eBus) Design 750
Side Turrn Lighting W/Marker/Turn Combination Light
& W/2 Side Turn (CE) (Aft Wheel))
Side Turrn Lighting W/Marker/Turn Combination Light & W/2 Side Turn (CE) (Aft
Wheel)) Design 751
& W/2 Side Turn (CE) (Before Wheel))
(Before Wheel)) Design 759
& W/2 Side Turn (CE) (Midship)
(Midship) Design 764
& W/2 Side Turn (CE) (Over Wheel))
(Over Wheel)) Design 768
Side Turn Lighting W/ 2 Side Turn (CE) (Aft Entrance
Door)
Side Turn Lighting W/ 2 Side Turn (CE) (Aft Entrance Door) Design 773
Side Turn Lighting W/ 2 Side Turn (CE) (Aft Rear
Wheel)
Side Turn Lighting W/ 2 Side Turn (CE) (Aft Rear Wheel) Design 774
Side Turn Lighting W/ 2 Side Turn (CE) (Before Rear
Wheel)
Side Turn Lighting W/ 2 Side Turn (CE) (Before Rear Wheel) Design 782
Side Turn Lighting W/ 2 Side Turn (CE) (Midship)
Side Turn Lighting W/ 2 Side Turn (CE) (Midship) Design 787
Side Turn Lighting W/ 2 Side Turn (CE) (Over Rear
Wheel)
Side Turn Lighting W/ 2 Side Turn (CE) (Over Rear Wheel) Design 791
TABLE OF CONTENTS
xxviiSide Turn Lighting W/ 4 Side Turn (CE) (Aft Entrance
and Aft Wheel)
Side Turn Lighting W/ 4 Side Turn (CE) (Aft Entrance and Aft Wheel) Design 796
and Before Wheel)
Side Turn Lighting W/ 4 Side Turn (CE) (Aft Entrance and Before Wheel)
Design 804
and Midship)
Side Turn Lighting W/ 4 Side Turn (CE) (Aft Entrance and Midship) Design 809
and Over Wheel)
Side Turn Lighting W/ 4 Side Turn (CE) (Aft Entrance and Over Wheel)
Design 813
Side Turn Lighting W/ 4 Side Turn (CE) (Midship and
Aft Wheel)
Side Turn Lighting W/ 4 Side Turn (CE) (Midship and Aft Wheel) Design 818
Skirt Light (CE, Rear Tire Illumination Light)
Skirt Light (CE, Rear Tire Illumination Light) Design 820
Under Hood Lighting (MV, CE) BCM Controlled
Timeout W/Hood Switch
Under Hood Lighting (MV, CE) BODY CONTROL MODULE Controlled Timeout
W/Hood Switch Design 821
Fuel Heater (Vehicle Powered) Davco 245
Fuel Heater (Vehicle Powered) Davco 245 Design 822
Fuel Heater (Vehicle Powered) (Racor 400 Series)
Fuel Heater (Vehicle Powered) (Racor 400 Series) Design 823
Fuel Level (Single Sensor)
Fuel Level (Single Sensor) Design 824
Water In Fuel (WIF) Davco 245 W/ Heater
Water In Fuel (WIF) Davco 245 W/ Heater Design 825
Water In Fuel (WIF) Racor W/ Heater
Water In Fuel (WIF) Racor W/ Heater Design 826
Current Monitoring (Ammeter) (PAM Module)
Current Monitoring (Ammeter) (PAM Module) Design 827
Auxiliary Defog Fans (CE, 1 Fan, Center Blower)
Auxiliary Defog Fans (CE, 1 Fan, Center Blower) Design 828
Auxiliary Defog Fans (CE, 1 Fan, Center Left)
Auxiliary Defog Fans (CE, 1 Fan, Center Left) Design 829
Auxiliary Defog Fans (CE, 1 Fan, Center Right)
Auxiliary Defog Fans (CE, 1 Fan, Center Right) Design 830
Auxiliary Defog Fans (CE, 1 Fan, Far Left)
Auxiliary Defog Fans (CE, 1 Fan, Far Left) Design 831
TABLE OF CONTENTS
xxviiiAuxiliary Defog Fans (CE, 1 Fan, Far Right)
Auxiliary Defog Fans (CE, 1 Fan, Far Right) Design 833
Auxiliary Defog Fans (CE, 2 Fans, Center Blower, Far
Right)
Auxiliary Defog Fans (CE, 2 Fans, Center Blower, Far Right) Design 834
Auxiliary Defog Fans (CE, 2 Fans, Center Left, Center
Right)
Auxiliary Defog Fans (CE, 2 Fans, Center Left, Center Right) Design 835
Auxiliary Defog Fans (CE, 2 Fans, Center Left, Far
Right)
Auxiliary Defog Fans (CE, 2 Fans, Center Left, Far Right) Design 836
Auxiliary Defog Fans (CE, 2 Fans, Center Right, Far
Right)
Auxiliary Defog Fans (CE, 2 Fans, Center Right, Far Right) Design 837
Auxiliary Defog Fans (CE, 2 Fans, Far Left, Center
Blower)
Auxiliary Defog Fans (CE, 2 Fans, Far Left, Center Blower) Design 838
Right)
Auxiliary Defog Fans (CE, 2 Fans, Far Left, Center Right) Design 840
Auxiliary Defog Fans (CE, 2 Fans, Far Left, Far Right)
Auxiliary Defog Fans (CE, 2 Fans, Far Left, Far Right) Design 842
Auxiliary Defog Fans (CE, 3 Fans, Center Left, Center
Right, Far Right)
Auxiliary Defog Fans (CE, 3 Fans, Center Left, Center Right, Far Right)
Design 844
Auxiliary Defog Fans (CE, 3 Fans, Far Left, Center
Right, Far Right)
Auxiliary Defog Fans (CE, 3 Fans, Far Left, Center Right, Far Right) Design 845
Heating Ventilation & Air Conditioning (HVAC)
(Manual W/PT Transducer N/Low Pressure SW)
Heating Ventilation & Air Conditioning (HVAC) (Manual W/PT Transducer N/Low
Pressure SW) Design 847
Heating Ventilation & Air Conditioning (HVAC)-
Manual Heater Only
Heating Ventilation & Air Conditioning (HVAC)- Manual Heater Only Design 849
Heated Steps (Stepwell Heater, Switch)
Heated Steps (Stepwell Heater, Switch) Design 851
Bus Passenger Air Conditioning (Body A/C Dual
Compressors W/ Noise Abatement)
Bus Passenger Air Conditioning (Body A/C Dual Compressors W/ Noise
Abatement) Design 852
Compressors)
Bus Passenger Air Conditioning (Body A/C Dual Compressors) Design 854
TABLE OF CONTENTS
xxixBus Passenger Air Conditioning (Body A/C Single
Compressor W/ Noise Abatement)
Bus Passenger Air Conditioning (Body A/C Single Compressor W/ Noise
Abatement) Design 856
Compressor)
Bus Passenger Air Conditioning (Body A/C Single Compressor) Design 857
Left Front Bus Passenger Heater (50K/84.5K BTU
Single Switch Activates Booster)
Left Front Bus Passenger Heater (50K/84.5K BTU Single Switch Activates
Booster) Design 858
Left Front Bus Passenger Heater (84.5K BTU Dual
Left Front Bus Passenger Heater (84.5K BTU Dual Switch Activates Booster)
Design 859
Switch)
Left Front Bus Passenger Heater (84.5K BTU Dual Switch) Design 860
Left Front Bus Passenger Heater (84.5K BTU Single
Switch)
Left Front Bus Passenger Heater (84.5K BTU Single Switch) Design 861
Left Rear Bus Passenger Heater (50/84.5K BTU Single
Left Rear Bus Passenger Heater (50/84.5K BTU Single Switch Activates Booster)
Design 862
Left Rear Bus Passenger Heater (84.5K BTU Dual
Left Rear Bus Passenger Heater (84.5K BTU Dual Switch Activates Booster)
Design 863
Switch)
Left Rear Bus Passenger Heater (84.5K BTU Dual Switch) Design 864
Left Rear Bus Passenger Heater (84.5K BTU Single
Switch)
Left Rear Bus Passenger Heater (84.5K BTU Single Switch) Design 865
Right Front Bus Passenger Heater (50K/84.5K BTU
Right Front Bus Passenger Heater (50K/84.5K BTU Single Switch Activates
Booster) Design 866
Right Front Bus Passenger Heater (84.5K BTU Dual
Right Front Bus Passenger Heater (84.5K BTU Dual Switch Activates Booster)
Design 867
Switch)
Right Front Bus Passenger Heater (84.5K BTU Dual Switch) Design 868
TABLE OF CONTENTS
xxxRight Front Bus Passenger Heater (84.5K BTU Single
Switch)
Right Front Bus Passenger Heater (84.5K BTU Single Switch) Design 869
Right Rear Bus Passenger Heater (50K/84.5K BTU
Right Rear Bus Passenger Heater (50K/84.5K BTU Single Switch Activates
Booster) Design 870
Right Rear Bus Passenger Heater (80K Wall Mount
Activates Booster)
Right Rear Bus Passenger Heater (80K Wall Mount Activates Booster) Design871
Right Rear Bus Passenger Heater (80K Wall Mount)
Right Rear Bus Passenger Heater (80K Wall Mount) Design 872
Right Rear Bus Passenger Heater (84.5K BTU Dual
Right Rear Bus Passenger Heater (84.5K BTU Dual Switch Activates Booster)
Design 873
Switch)
Right Rear Bus Passenger Heater (84.5K BTU Dual Switch) Design 874
Right Rear Bus Passenger Heater (84.5K BTU Single
Switch)
Right Rear Bus Passenger Heater (84.5K BTU Single Switch) Design 875
Rear AUX Heating Ventilation & Air Conditioning
(HVAC) (Convection Heater)
Rear AUX Heating Ventilation & Air Conditioning (HVAC) (Convection Heater)
Design 876
Rear No-Idle HVAC (Espar W/ Timer)
Rear No-Idle HVAC (Espar W/ Timer) Design 877
Rear No-Idle HVAC (17K Webasto W/ Timer)
Rear No-Idle HVAC (17K Webasto W/ Timer) Design 879
Rear No-Idle HVAC (45k Webasto Scholastic W/ Timer)
Rear No-Idle HVAC (45k Webasto Scholastic W/ Timer) Design 880
Ambient Temperature Monitoring Mirror Sensor ( W/
Heated Non-Motorized Mirror N/ Display)
Ambient Temperature Monitoring Mirror Sensor ( W/ Heated Non-Motorized Mirror
N/ Display) Design 881
Heated Non-Motorized Mirror )
) Design 882
Motor Mirror N/ Display )
Ambient Temperature Monitoring Mirror Sensor ( W/ Motor Mirror N/ Display )
Design 883
TABLE OF CONTENTS
xxxiAmbient Temperature Monitoring Mirror Sensor ( W/
Motor Mirror )
Ambient Temperature Monitoring Mirror Sensor ( W/ Motor Mirror ) Design 884
Non-Heated Non-Motorized Mirror N/ Display)
Ambient Temperature Monitoring Mirror Sensor ( W/ Non-Heated Non-Motorized
Mirror N/ Display) Design 885
Non-Heated Non-Motorized Mirror )
Mirror ) Design 886
LT Series Version 0 Auxiliary Gauges (Single)
LT Series Version 0 Auxiliary Gauges (Single) Design 887
LT Series Version 1 Auxiliary Gauges (Multiple)
LT Series Version 1 Auxiliary Gauges (Multiple) Design 888
Compartment Temperature (Bus, Engine/Electrical
Compartment Temp Warning)
Compartment Temperature (Bus, Engine/Electrical Compartment Temp Warning)
Design 889
Compressed Air Supply (Bus) (Aux Air Pressure
Gauge, Hydraulic Chassis)
Compressed Air Supply (Bus) (Aux Air Pressure Gauge, Hydraulic Chassis)
Design 890
Compressed Air Supply (Bus, eBus) (Primary &
Secondary Gauge, Dual Air Brake System)
Compressed Air Supply (Bus, eBus) (Primary & Secondary Gauge, Dual Air
Brake System) Design 892
Current Monitoring (Ammeter) (Bus, 400 Amp)
Current Monitoring (Ammeter) (Bus, 400 Amp) Design 893
White LED Clock
White LED Clock Design 894
Wheelchair Warning (MUX Indicator, Buzzer On W/Lift
Door Open)
Wheelchair Warning (MUX Indicator, Buzzer On W/Lift Door Open) Design 895
Wheelchair Warning (MUX Indicator, Mechanical
Buzzer, On W/Lift Door Open, Shuts Off When 4"
Open)
Wheelchair Warning (MUX Indicator, Mechanical Buzzer, On W/Lift Door Open,
Shuts Off When 4" Open) Design 896
Wheelchair Warning (MUX Indicator, Piezo Buzzer On
W/Lift Door Open, Shuts Off When 4" Open)
Wheelchair Warning (MUX Indicator, Piezo Buzzer On W/Lift Door Open, Shuts
Off When 4" Open) Design 897
Cab Dome Lights (CE, Driver Dome,Left/Right w/
Switch)
Cab Dome Lights (CE, Driver Dome,Left/Right w/ Switch) Design 898
TABLE OF CONTENTS
xxxiiCab Dome Lights (CE, Driver Dome, Single)
Cab Dome Lights (CE, Driver Dome, Single) Design 899
Cab Dome Lights (CE, Driver Dome, Single, W/ Switch,
Plus Red Driver Dome)
Cab Dome Lights (CE, Driver Dome, Single, W/ Switch, Plus Red Driver Dome)
Design 900
Cab Dome Lights (CE, Driver Dome, Three, W/ Switch)
Cab Dome Lights (CE, Driver Dome, Three, W/ Switch) Design 901
Cab Dome Lights (W/ Switch, Red Driver Dome)
Cab Dome Lights (W/ Switch, Red Driver Dome) Design 902
Courtesy Step Lighting (CE, Entry Dr Skirt Lt,
Activated by Step Lt, W/ AED Light)
Courtesy Step Lighting (CE, Entry Dr Skirt Lt, Activated by Step Lt, W/ AED Light)
Design 903
Courtesy Step Lighting (CE, Entry Dr Skirt Lt, Activtd
by Step Lt, No AED Lt)
Courtesy Step Lighting (CE, Entry Dr Skirt Lt, Activtd by Step Lt, No AED Lt)
Design 904
Courtesy Step Lighting (CE, N/ Entry Dr Skirt Lt,
Courtesy Step Lighting (CE, N/ Entry Dr Skirt Lt, Activated by Step Lt, W/ AED
Light) Design 905
Electrical Compartment Light (CE)
Electrical Compartment Light (CE) Design 906
Emergency Exit Interior Lighting (Clearance, Left
Door, No Windows)
Emergency Exit Interior Lighting (Clearance, Left Door, No Windows) Design 907
Door, 2 Windows)
Emergency Exit Interior Lighting (Clearance, Left Door, 2 Windows) Design 909
Door, 4 Windows)
Emergency Exit Interior Lighting (Clearance, Left Door, 4 Windows) Design 911
Emergency Exit Interior Lighting (Clearance, Left &
Right Doors, No Windows)
Emergency Exit Interior Lighting (Clearance, Left & Right Doors, No Windows)
Design 913
Right Doors, 2 Windows)
Emergency Exit Interior Lighting (Clearance, Left & Right Doors, 2 Windows)
Design 915
Right Doors, 4 Windows)
Emergency Exit Interior Lighting (Clearance, Left & Right Doors, 4 Windows)
Design 917
TABLE OF CONTENTS
xxxiiiEmergency Exit Interior Lighting (Clearance, No
Doors, 2 Windows)
Emergency Exit Interior Lighting (Clearance, No Doors, 2 Windows) Design 919
Doors, 4 Windows)
Emergency Exit Interior Lighting (Clearance, No Doors, 4 Windows) Design 921
Emergency Exit Interior Lighting (Clearance, Rear
Door, No Windows)
Emergency Exit Interior Lighting (Clearance, Rear Door, No Windows) Design 923
Door, 2 Windows)
Emergency Exit Interior Lighting (Clearance, Rear Door, 2 Windows) Design 925
Door, 4 Windows)
Emergency Exit Interior Lighting (Clearance, Rear Door, 4 Windows) Design 927
Emergency Exit Interior Lighting (Clearance, Rear &
Left Doors, No Windows)
Emergency Exit Interior Lighting (Clearance, Rear & Left Doors, No Windows)
Design 929
Left Doors, 2 Windows)
Emergency Exit Interior Lighting (Clearance, Rear & Left Doors, 2 Windows)
Design 931
Left Doors, 4 Windows)
Emergency Exit Interior Lighting (Clearance, Rear & Left Doors, 4 Windows)
Design 933
Emergency Exit Interior Lighting (Clearance, Rear & Right Doors, No Windows)
Design 935
Emergency Exit Interior Lighting (Clearance, Rear & Right Doors, 2 Windows)
Design 937
Emergency Exit Interior Lighting (Clearance, Rear & Right Doors, 4 Windows)
Design 939
Emergency Exit Interior Lighting (Clearance, Rear,
Emergency Exit Interior Lighting (Clearance, Rear, Left & Right Doors, No
Windows) Design 941
Left, Right Doors, 2 Windows)
Emergency Exit Interior Lighting (Clearance, Rear, Left, Right Doors, 2 Windows)
Design 943
TABLE OF CONTENTS
xxxivEmergency Exit Interior Lighting (Clearance, Rear,
Left, Right Doors, 4 Windows)
Emergency Exit Interior Lighting (Clearance, Rear, Left, Right Doors, 4 Windows)
Design 945
Emergency Exit Interior Lighting (Clearance, Right
Door, No Windows)
Emergency Exit Interior Lighting (Clearance, Right Door, No Windows) Design947
Door, 2 Windows)
Emergency Exit Interior Lighting (Clearance, Right Door, 2 Windows) Design 949
Door, 4 Windows)
Emergency Exit Interior Lighting (Clearance, Right Door, 4 Windows) Design 951
Emergency Exit Interior Lighting (Ignition, Rear Door
Only)
Emergency Exit Interior Lighting (Ignition, Rear Door Only) Design 953
Entrance Door Lighting (CE PWL Activated, W/5s
Timer)
Entrance Door Lighting (CE PWL Activated, W/5s Timer) Design 955
Entrance Door Lighting (CE, Step Lt Activated W/ 5s
Timer)
Entrance Door Lighting (CE, Step Lt Activated W/ 5s Timer) Design 956
Entrance Door Lighting (CE, Stop Arm Activated, W/
5s Timer)
Entrance Door Lighting (CE, Stop Arm Activated, W/ 5s Timer) Design 957
Bus Passenger Dome Lights (CE, Single Switch, Two
Full Rows, 10 Lights)
Bus Passenger Dome Lights (CE, Single Switch, Two Full Rows, 10 Lights)
Design 958
Full Rows, 12 Lights)
Bus Passenger Dome Lights (CE, Single Switch, Two Full Rows, 12 Lights)
Design 962
Full Rows, 14 Lights)
Bus Passenger Dome Lights (CE, Single Switch, Two Full Rows, 14 Lights)
Design 966
Full Rows, 6 Lights)
Bus Passenger Dome Lights (CE, Single Switch, Two Full Rows, 6 Lights)
Design 970
Full Rows, 8 Lights)
Bus Passenger Dome Lights (CE, Single Switch, Two Full Rows, 8 Lights)
Design 972
TABLE OF CONTENTS
xxxvStorage Compartment (Luggage) (Bus, 6 Luggage
Compartment Lights)
Storage Compartment (Luggage) (Bus, 6 Luggage Compartment Lights)
Design 976
Height Control (LiquidSpring)
Height Control (LiquidSpring) Design 978
Seats - Climate Controlled (Drivers Heated Seat W/ Air
Compressor)
Seats - Climate Controlled (Drivers Heated Seat W/ Air Compressor) Design 981
Seats - Climate Controlled (Drivers Heated Seat)
Seats - Climate Controlled (Drivers Heated Seat) Design 982
Seats - Electrical Power (CE Self-Contained Air Seat)
Seats - Electrical Power (CE Self-Contained Air Seat) Design 983
Seats - Electrical Power (CE Self-Contained Heated Air
Seat)
Seats - Electrical Power (CE Self-Contained Heated Air Seat) Design 984
Seatbelt Reminder (Warning) (Bus, No Park Brake
Buzzer)
Seatbelt Reminder (Warning) (Bus, No Park Brake Buzzer) Design 985
Seatbelt Reminder (Warning) (Bus, W/ Park Brake
Buzzer)
Seatbelt Reminder (Warning) (Bus, W/ Park Brake Buzzer) Design 986
Transmission (Allison 1K/2K)
Transmission (Allison 1K/2K) Design 987
Transmission (Allison 3K/4K)
Transmission (Allison 3K/4K) Design 988
Hill Start Aid (HSA) (Bendix CA 2.0)
Hill Start Aid (HSA) (Bendix CA 2.0) Design 989
Transmission Shifter (T-Handle for Allison W/ Park
Position)
Transmission Shifter (T-Handle for Allison W/ Park Position) Design 990
Transmission Shifter (Universal Stalk Shifter - Allison
1K/2K N/Park Position)
Transmission Shifter (Universal Stalk Shifter - Allison 1K/2K N/Park Position)
Design 991
1K/2K W/Park Position)
Transmission Shifter (Universal Stalk Shifter - Allison 1K/2K W/Park Position)
Design 992
3K/4K)
Transmission Shifter (Universal Stalk Shifter - Allison 3K/4K) Design 993
Windshield Washer Pump W/O Low Fluid Sensor
Windshield Washer Pump W/O Low Fluid Sensor Design 994
TABLE OF CONTENTS
xxxviWindshield Washer Pump & Low Fluid Sensor (MV,
CE)
Windshield Washer Pump & Low Fluid Sensor (MV, CE) Design 995
Windshield Wipers
Windshield Wipers Design 996
Battery Disconnect (Switch Only)
Battery Disconnect (Switch Only) Design 997
Battery Isolator
Battery Isolator Design 998
Charging System (Delco Remy 28SI Alternator N/
Remote Sense)
Charging System (Delco Remy 28SI Alternator N/ Remote Sense) Design 999
Charging System (Delco Remy & Mitsubishi Alternator
W/ Remote Sense)
Charging System (Delco Remy & Mitsubishi Alternator W/ Remote Sense)
Design 1000
Charging System (Leece-Neville AVI160-
160A/210A/240A N/ Remote Sense, Skelstart)
Charging System (Leece-Neville AVI160-160A/210A/240A N/ Remote Sense,
Skelstart) Design 1001
Charging System (Leece-Neville - LN 325A Alternator
W/ Remote Sense)
Charging System (Leece-Neville - LN 325A Alternator W/ Remote Sense)
Design 1002
Charging System (LH160_LH200)
Charging System (LH160_LH200) Design 1003
Cranking (Starter) (BCM Controlled & N/ Wired
Thermal Overcrank, Skelstart)
Cranking (Starter) (BCM Controlled & N/ Wired Thermal Overcrank, Skelstart)
Design 1004
Thermal Overcrank, W/ Disconnect)
Cranking (Starter) (BCM Controlled & N/ Wired Thermal Overcrank, W/
Disconnect) Design 1005
Operator Input (Key Switch) (W/ Starter Interrupt)
Operator Input (Key Switch) (W/ Starter Interrupt) Design 1006
Battery International (3) 12V
Battery International (3) 12V Design 1007
Connectors 1008
Index 3626
Brand: International, Navistar
Type of Machine: School Bus
Type of Manual: Interactive Schematics
Model: International CE Series School Bus
Built: 1/1/2024 To 12/31/2025
Part Number: 00000018836
Publication Date: 2025
Number of Pages: 3697 Pages
Body Control Module (BCM)
Body Control Module (BCM) Design 1
Body Standard J1939 (250kbps)
Body Standard J1939 (250kbps) Design 9
Cab Standard J1939 (250kbps)
Cab Standard J1939 (250kbps) Design 10
Engine Private J1939 (250kbps)
Engine Private J1939 (250kbps) Design 11
Fusion Proprietary J1939
Fusion Proprietary J1939 Design 12
Low Speed (125 kbps) J1939
Low Speed (125 kbps) J1939 Design 13
Powertrain J1939 (500kbps)
Powertrain J1939 (500kbps) Design 14
9pin Diagnositic Connector
9pin Diagnositic Connector Design 15
B6.7 - Engine Control Module (ECM)
B6.7 - Engine Control Module (ECM) Design 16
Instrument Cluster (EGC)
Instrument Cluster (EGC) Design 17
Instrument Cluster (EGC) - Request and Status
Instrument Cluster (EGC) - Request and Status Design 18
Rear Cap Ground Splice Packs
Rear Cap Ground Splice Packs Design 19
Left Body Ground Splice Packs
Left Body Ground Splice Packs Design 20
Right Body Ground Splice Packs
Right Body Ground Splice Packs Design 22
Electrical Panel Grounds
Electrical Panel Grounds Design 24
Electrical Panel Ground Splice Packs
Electrical Panel Ground Splice Packs Design 25
Electrical Panel ZVR Splice Pack
Electrical Panel ZVR Splice Pack Design 27
IP Grounds
IP Grounds Design 28
IP Ground Splice Packs
IP Ground Splice Packs Design 29
IP ZVR Splice Packs
IP ZVR Splice Packs Design 31
TABLE OF CONTENTS
iCenter Chassis Grounds
Center Chassis Grounds Design 32
Center Chassis Ground Splice Packs
Center Chassis Ground Splice Packs Design 33
Center Chassis ZVR Splice Pack
Center Chassis ZVR Splice Pack Design 34
Front Cap Ground Splice Packs
Front Cap Ground Splice Packs Design 35
Front Chassis Grounds
Front Chassis Grounds Design 36
Front Chassis Ground Splice Packs
Front Chassis Ground Splice Packs Design 37
B6.7 Powertrain Grounds
B6.7 Powertrain Grounds Design 39
B6.7 Powertrain Ground Splice Packs
B6.7 Powertrain Ground Splice Packs Design 40
B6.7 ZVR Splice Packs
B6.7 ZVR Splice Packs Design 41
Rear Chassis Grounds
Rear Chassis Grounds Design 42
Rear Chassis Ground Splice Pack
Rear Chassis Ground Splice Pack Design 44
LCM
LCM Design 45
Aftertreatment PDM
Aftertreatment PDM Design 46
Miscellaneous Power Distribution
Miscellaneous Power Distribution Design 47
Bus Body Fuse Block #C3 #C4 #D4
Bus Body Fuse Block #C3 #C4 #D4 Design 48
Bus Body Fuse Block #C6
Bus Body Fuse Block #C6 Design 51
Bus Body Fuse Block #C9
Bus Body Fuse Block #C9 Design 52
Bus Body Fuse Block #D1
Bus Body Fuse Block #D1 Design 54
Bus Body Fuse Block #D2
Bus Body Fuse Block #D2 Design 55
Chassis PDM
Chassis PDM Design 56
TABLE OF CONTENTS
iiOptional Chassis PDM
Optional Chassis PDM Design 57
Battery Grid 1
Battery Grid 1 Design 58
Battery Grid 2
Battery Grid 2 Design 60
CE Bus Interior PDM Chart
CE Bus Interior PDM Chart Design 61
Key Switch Accessory Grid 2
Key Switch Accessory Grid 2 Design 62
Key Switch Ignition Grid 1
Key Switch Ignition Grid 1 Design 63
Key Switch Ignition Grid 2
Key Switch Ignition Grid 2 Design 65
Grid Management (CA2, N/Load Shed, Bus N/Noise
Suppression)
Grid Management (CA2, N/Load Shed, Bus N/Noise Suppression) Design 66
Grid Management (CA2, N/Load Shed, Bus W/ Noise
Suppression)
Grid Management (CA2, N/Load Shed, Bus W/ Noise Suppression) Design 68
Grid Management (CA2, N/Load Shed, Conventional
Cab)
Grid Management (CA2, N/Load Shed, Conventional Cab) Design 70
Center Chassis N01 Lighting Splice Packs
Center Chassis N01 Lighting Splice Packs Design 71
Electrical Panel Light Splice Pack
Electrical Panel Light Splice Pack Design 72
IP Panel Dimmer Splice Packs
IP Panel Dimmer Splice Packs Design 73
IP Turn Signal Splice Packs
IP Turn Signal Splice Packs Design 74
Park/Turn Light Splice Packs 7110/4110/1590/6810
Park/Turn Light Splice Packs 7110/4110/1590/6810 Design 75
Powertrain B6.7 5V Splice Packs
Powertrain B6.7 5V Splice Packs Design 76
IP Underhood PDM
IP Underhood PDM Design 77
Power Adjustable Pedals (CE)
Power Adjustable Pedals (CE) Design 78
Back Up Alarm (CE) W/O Reverse Motion Sensor
Back Up Alarm (CE) W/O Reverse Motion Sensor Design 79
TABLE OF CONTENTS
iiiBack Up Alarm (CE) W/ Reverse Motion Sensor
Back Up Alarm (CE) W/ Reverse Motion Sensor Design 80
Bus Post Trip Inspection (Bus, eBus, No Student Left
Behind W/O Snooze, ACC Buzzer)
Bus Post Trip Inspection (Bus, eBus, No Student Left Behind W/O Snooze, ACC
Buzzer) Design 81
Behind W/ Snooze, ACC Buzzer)
Bus Post Trip Inspection (Bus, eBus, No Student Left Behind W/ Snooze, ACC
Buzzer) Design 83
Bus Post Trip Inspection (CE) Leave No Student
Behind (47KEC, ACC Buzzer)
Bus Post Trip Inspection (CE) Leave No Student Behind (47KEC, ACC Buzzer)
Design 85
Behind (47KEC, BAT Buzzer)
Bus Post Trip Inspection (CE) Leave No Student Behind (47KEC, BATTERY
Buzzer) Design 87
Behind (47KED, ACC Buzzer)
Bus Post Trip Inspection (CE) Leave No Student Behind (47KED, ACC Buzzer)
Design 89
Behind (47KED, BAT Buzzer)
Bus Post Trip Inspection (CE) Leave No Student Behind (47KED, BATTERY
Buzzer) Design 91
Behind (47KEE, ACC Buzzer)
Bus Post Trip Inspection (CE) Leave No Student Behind (47KEE, ACC Buzzer)
Design 93
Behind (47KEE, BAT Buzzer)
Bus Post Trip Inspection (CE) Leave No Student Behind (47KEE, BATTERY
Buzzer) Design 95
Behind (47KEG, ACC Buzzer)
Bus Post Trip Inspection (CE) Leave No Student Behind (47KEG, ACC Buzzer)
Design 97
Behind (47KEG, BAT Buzzer)
Bus Post Trip Inspection (CE) Leave No Student Behind (47KEG, BATTERY
Buzzer) Design 99
Bus Post Trip Inspection (CE) No Student Left Behind
W/O Snooze, BAT Buzzer
Bus Post Trip Inspection (CE) No Student Left Behind W/O Snooze, BATTERY
Buzzer Design 101
TABLE OF CONTENTS
ivBus Post Trip Inspection (CE) No Student Left Behind
W/ Snooze Button, BAT Buzzer
Bus Post Trip Inspection (CE) No Student Left Behind W/ Snooze Button,
BATTERY Buzzer Design 103
Bus Post Trip Inspection (Child Check Mate 47KDY
Pre-Wire)
Bus Post Trip Inspection (Child Check Mate 47KDY Pre-Wire) Design 105
Bus Post Trip Inspection (Child Check Mate 47KEA
Pre-Wire N/ Lift & N/Rear Dr Options)
Bus Post Trip Inspection (Child Check Mate 47KEA Pre-Wire N/ Lift & N/Rear Dr
Options) Design 107
Pre-Wire N/ Lift & W/Rear Dr Option)
Bus Post Trip Inspection (Child Check Mate 47KEA Pre-Wire N/ Lift & W/Rear Dr
Option) Design 109
Pre-Wire W/ Lift & N/Rear Dr Options)
Bus Post Trip Inspection (Child Check Mate 47KEA Pre-Wire W/ Lift & N/Rear Dr
Options) Design 111
Pre-Wire W/ Lift & W/Rear Dr Option)
Bus Post Trip Inspection (Child Check Mate 47KEA Pre-Wire W/ Lift & W/Rear Dr
Option) Design 113
Emergency Exit Door (Bus) Rear Only W/Piezo Alarm
ACC Power N/Rear Dr Option
Emergency Exit Door (Bus) Rear Only W/Piezo Alarm ACC Power N/Rear Dr
Option Design 115
ACC Power W/Rear Dr Option
Emergency Exit Door (Bus) Rear Only W/Piezo Alarm ACC Power W/Rear Dr
Option Design 116
BAT Power N/Rear Dr Option
Emergency Exit Door (Bus) Rear Only W/Piezo Alarm BATTERY Power N/Rear
Dr Option Design 117
BAT Power W/Rear Dr Option
Emergency Exit Door (Bus) Rear Only W/Piezo Alarm BATTERY Power W/Rear
Dr Option Design 118
Emergency Exit Door (Bus) Rear/Left W/Piezo Alarm
Emergency Exit Door (Bus) Rear/Left W/Piezo Alarm ACC Power N/Rear Dr
Option Design 119
Emergency Exit Door (Bus) Rear/Left W/Piezo Alarm ACC Power W/Rear Dr
Option Design 121
TABLE OF CONTENTS
vEmergency Exit Door (Bus) Rear/Left W/Piezo Alarm
Emergency Exit Door (Bus) Rear/Left W/Piezo Alarm BATTERY Power N/Rear Dr
Option Design 123
Emergency Exit Door (Bus) Rear/Left W/Piezo Alarm BATTERY Power W/Rear
Dr Option Design 125
Emergency Exit Door (Bus) Rear/Left/Right W/Piezo
Alarm ACC Power N/Rear Dr Option
Emergency Exit Door (Bus) Rear/Left/Right W/Piezo Alarm ACC Power N/Rear Dr
Option Design 127
Alarm ACC Power W/Rear Dr Option
Emergency Exit Door (Bus) Rear/Left/Right W/Piezo Alarm ACC Power W/Rear
Dr Option Design 129
Alarm BAT Power N/Rear Dr Option
Emergency Exit Door (Bus) Rear/Left/Right W/Piezo Alarm BATTERY Power
N/Rear Dr Option Design 131
Alarm BAT Power W/Rear Dr Option
W/Rear Dr Option Design 133
Emergency Exit Door (CE) Rear Only, ACC Power
W/Mechl Buzzer N/ Rear Dr Option
Emergency Exit Door (CE) Rear Only, ACC Power W/Mechl Buzzer N/ Rear Dr
Option Design 135
W/Mechl Buzzer W/Rear Dr Option
Emergency Exit Door (CE) Rear Only, ACC Power W/Mechl Buzzer W/Rear Dr
Option Design 136
Infotainment System (Radio) (Bus, N/LDW Speakers,
W/Mux Switches)
Infotainment System (Radio) (Bus, N/LDW Speakers, W/Mux Switches)
Design 137
Infotainment System (Radio) (Bus, W/ LDW Speakers,
W/Mux Switches)
Infotainment System (Radio) (Bus, W/ LDW Speakers, W/Mux Switches)
Design 138
Infotainment System (Radio) (CE Wiring Only)
Infotainment System (Radio) (CE Wiring Only) Design 139
Radio
Radio Design 140
Radio W/ Bluetooth
Radio W/ Bluetooth Design 141
TABLE OF CONTENTS
viRadio W/ Bluetooth & W/ Steering Wheel Pod
Radio W/ Bluetooth & W/ Steering Wheel Pod Design 142
Radio W/ Steering Wheel Pod
Radio W/ Steering Wheel Pod Design 143
Speakers (Bus, Eight Speakers W/ External PA
Speaker)
Speakers (Bus, Eight Speakers W/ External PA Speaker) Design 144
Speakers (Bus, Eight Speakers)
Speakers (Bus, Eight Speakers) Design 146
Speakers (Bus, Four Speakers W/ External PA
Speaker)
Speakers (Bus, Four Speakers W/ External PA Speaker) Design 148
Speakers (Bus, Four Speakers)
Speakers (Bus, Four Speakers) Design 150
Speakers (Bus, Two Speakers W/ External PA
Speaker)
Speakers (Bus, Two Speakers W/ External PA Speaker) Design 152
Speakers (Bus, Two Speakers)
Speakers (Bus, Two Speakers) Design 153
Speakers (Bus, 2 Speakers in Bulkhead W/ External
PA Speaker)
Speakers (Bus, 2 Speakers in Bulkhead W/ External PA Speaker) Design 154
Speakers (Bus, 2 Speakers in Bulkhead)
Speakers (Bus, 2 Speakers in Bulkhead) Design 155
Version 1 of E02 Speaker Splice Packs
Version 1 of E02 Speaker Splice Packs Design 156
Version 1 of F02 Speaker Splice Packs
Version 1 of F02 Speaker Splice Packs Design 157
Steering Wheel Left and Right Pod N/Air Bag
Steering Wheel Left and Right Pod N/Air Bag Design 158
Steering Wheel Left Pod
Steering Wheel Left Pod Design 159
Steering Wheel Right Pod
Steering Wheel Right Pod Design 160
Auxiliary Power (40A) HSD
Auxiliary Power (40A) HSD Design 161
AUX Power Connector (2 BAT, 2 ACC 20A Fused
Connectors)
AUX Power Connector (2 BAT, 2 ACC 20A Fused Connectors) Design 162
AUX Power Connector (2 BAT, 4 ACC 20A Fused
Connectors)
AUX Power Connector (2 BAT, 4 ACC 20A Fused Connectors) Design 163
TABLE OF CONTENTS
viiAUX Power Connector (4 ACC 20A Fused Connectors)
AUX Power Connector (4 ACC 20A Fused Connectors) Design 164
Aux Power (Blunt Cut)
Aux Power (Blunt Cut) Design 165
Forward Auxiliary Power Source (1 APO)
Forward Auxiliary Power Source (1 APO) Design 166
Forward Auxiliary Power Source (2 APO)
Forward Auxiliary Power Source (2 APO) Design 168
Forward Auxiliary Power Source (3 APO)
Forward Auxiliary Power Source (3 APO) Design 170
Aux Power (Banana Plug)
Aux Power (Banana Plug) Design 172
Booster Pump (Bus, Controlled by Aux Heater Switch)
Booster Pump (Bus, Controlled by Aux Heater Switch) Design 173
Booster Pump (Bus, High Output, Controlled by Aux
Heater Switch)
Booster Pump (Bus, High Output, Controlled by Aux Heater Switch) Design 174
Booster Pump (CE N/Coolant Heater)
Booster Pump (CE N/Coolant Heater) Design 175
Booster Pump (CE W/Coolant Heater Timer)
Booster Pump (CE W/Coolant Heater Timer) Design 176
Booster Pump (High Output, N/Coolant Heater)
Booster Pump (High Output, N/Coolant Heater) Design 177
Booster Pump (High Output, W/Coolant Heater)
Booster Pump (High Output, W/Coolant Heater) Design 178
Bus Crossing Gate (CE) Air Crossing Gate
Bus Crossing Gate (CE) Air Crossing Gate Design 179
Bus Crossing Gate (CE) Air Crossing Gate W/LH
Cross Gate Interrupt
Bus Crossing Gate (CE) Air Crossing Gate W/LH Cross Gate Interrupt Design 180
Bus Crossing Gate (CE) Air Crossing Gate W/RH
Bus Crossing Gate (CE) Air Crossing Gate W/RH Cross Gate Interrupt Design181
Override
Bus Crossing Gate (CE) Air Crossing Gate W/ Override Design 182
Bus Crossing Gate (CE) Electric Crossing Gate
Bus Crossing Gate (CE) Electric Crossing Gate Design 183
Bus Crossing Gate (CE) Electric Crossing Gate W/LH
Bus Crossing Gate (CE) Electric Crossing Gate W/LH Cross Gate Interrupt
Design 184
TABLE OF CONTENTS
viiiBus Crossing Gate (CE) Electric Crossing Gate W/RH
Bus Crossing Gate (CE) Electric Crossing Gate W/RH Cross Gate Interrupt
Design 185
Bus Alternate Entrance Door (Left Side Electric Door,
Omit Master Switch)
Bus Alternate Entrance Door (Left Side Electric Door, Omit Master Switch)
Design 186
W/ LH Master Switch)
Bus Alternate Entrance Door (Left Side Electric Door, W/ LH Master Switch)
Design 187
W/ RH Master Switch)
Bus Alternate Entrance Door (Left Side Electric Door, W/ RH Master Switch)
Design 188
Bus Alternate Entrance Door (Right Side Air Door)
Bus Alternate Entrance Door (Right Side Air Door) Design 189
Bus Entrance Door Operation (Air Door N/ Sensitive
Edge)
Bus Entrance Door Operation (Air Door N/ Sensitive Edge) Design 193
Bus Entrance Door Operation (Air Door W/ Sensitive
Edge)
Bus Entrance Door Operation (Air Door W/ Sensitive Edge) Design 194
Bus Entrance Door Operation (Air Door, W/ Knob
Wakeup)(Post 3/24)
Bus Entrance Door Operation (Air Door, W/ Knob Wakeup)(Post 3/24) Design 196
Wakeup)(Pre 3/24)
Bus Entrance Door Operation (Air Door, W/ Knob Wakeup)(Pre 3/24) Design 198
Wakeup, W/ Sensitive Edge)
Bus Entrance Door Operation (Air Door, W/ Knob Wakeup, W/ Sensitive Edge)
Design 200
Bus Entrance Door Operation (CAN Electric Motor
W/Knob Wakeup, W/ Sensitive Edge)
Bus Entrance Door Operation (CAN Electric Motor W/Knob Wakeup, W/ Sensitive
Edge) Design 202
Bus Entrance Door Operation (CAN Electric Motor, W/
Knob Wakeup)
Bus Entrance Door Operation (CAN Electric Motor, W/ Knob Wakeup) Design 204
Bus Entrance Door Request and Status (CE) 2
Position Rotary Switch
Bus Entrance Door Request and Status (CE) 2 Position Rotary Switch Design 206
TABLE OF CONTENTS
ixBus Entrance Door Request and Status (CE) 3
Bus Entrance Door Request and Status (CE) 3 Position Rotary Switch Design 208
Bus Entrance Door Request and Status (Steering
Wheel Controls W/Left Side Redundant Switch)
Bus Entrance Door Request and Status (Steering Wheel Controls W/Left Side
Redundant Switch) Design 210
Wheel Controls W/Right Side
Bus Entrance Door Request and Status (Steering Wheel Controls W/Right Side
Design 211
Bus Entrance Door Request and Status (3-Position
Paddle Switch)
Bus Entrance Door Request and Status (3-Position Paddle Switch) Design 212
Version 1 of B06 Stop Arm Splice Packs
Version 1 of B06 Stop Arm Splice Packs Design 213
Bus Stop Arm (Air, Front and Rear W/Left Side Stop
Arm Interrupt Switch)
Bus Stop Arm (Air, Front and Rear W/Left Side Stop Arm Interrupt Switch)
Design 214
Bus Stop Arm (Air, Front and Rear)
Bus Stop Arm (Air, Front and Rear) Design 222
Bus Stop Arm (Air, Front or Rear W/Left Side Stop
Bus Stop Arm (Air, Front or Rear W/Left Side Stop Arm Interrupt Switch)
Design 230
Bus Stop Arm (Air, Front or Rear)
Bus Stop Arm (Air, Front or Rear) Design 239
Bus Stop Arm (CE) Front and Rear Air Stop Arm
W/Right Side Stop Arm Interrupt Switch
Bus Stop Arm (CE) Front and Rear Air Stop Arm W/Right Side Stop Arm Interrupt
Switch Design 248
Bus Stop Arm (CE) Front or Rear Air Stop Arm
Bus Stop Arm (CE) Front or Rear Air Stop Arm W/Right Side Stop Arm Interrupt
Switch Design 256
Bus Stop Arm (Electric, Front and Rear W/Left Side
Bus Stop Arm (Electric, Front and Rear W/Left Side Stop Arm Interrupt Switch)
Design 265
Bus Stop Arm (Electric, Front and Rear W/Right Side
Bus Stop Arm (Electric, Front and Rear W/Right Side Stop Arm Interrupt Switch)
Design 273
Bus Stop Arm (Electric, Front and Rear)
TABLE OF CONTENTS
xBus Stop Arm (Electric, Front and Rear) Design 281
Bus Stop Arm (Electric, Front or Rear W/Left Side
Bus Stop Arm (Electric, Front or Rear W/Left Side Stop Arm Interrupt Switch)
Design 289
Bus Stop Arm (Electric, Front or Rear W/Right Side
Bus Stop Arm (Electric, Front or Rear W/Right Side Stop Arm Interrupt Switch)
Design 298
Bus Stop Arm (Electric, Front or Rear)
Bus Stop Arm (Electric, Front or Rear) Design 307
Camera (CE, Bat Ign & Gnd for Video Wiring, W/ Lytx
Video)
Camera (CE, Bat Ign & Gnd for Video Wiring, W/ Lytx Video) Design 316
Camera (CE, eBus) Pwr & Gnd for Video Wiring, W/O
Lytx Video
Camera (CE, eBus) Pwr & Gnd for Video Wiring, W/O Lytx Video Design 317
Camera (CE, Pwr & Gnd for Video Wiring Mounted
Above Driver)
Camera (CE, Pwr & Gnd for Video Wiring Mounted Above Driver) Design 318
Camera (CE, Seon TL4 DVR Prewire, w/ Seon Signals)
Camera (CE, Seon TL4 DVR Prewire, w/ Seon Signals) Design 319
Surround View (Camera Display, 1 Camera EOF,
Prewire)
Surround View (Camera Display, 1 Camera EOF, Prewire) Design 321
Compartment Vandal Lock (Bus, Driver Compt Only
W/Mechanical Buzzer)
Compartment Vandal Lock (Bus, Driver Compt Only W/Mechanical Buzzer)
Design 322
W/Std Buzzer)
Compartment Vandal Lock (Bus, Driver Compt Only W/Std Buzzer) Design 323
Compartment Vandal Lock (Bus, N/Interlock
W/Mechanical Buzzer N/Driver Compt)
Compartment Vandal Lock (Bus, N/Interlock W/Mechanical Buzzer N/Driver
Compt) Design 324
W/Mechanical Buzzer W/Driver Compt)
Compartment Vandal Lock (Bus, N/Interlock W/Mechanical Buzzer W/Driver
Compt) Design 325
Compartment Vandal Lock (Bus, N/Interlock W/Std
Compartment Vandal Lock (Bus, N/Interlock W/Std Buzzer N/Driver Compt)
Design 326
TABLE OF CONTENTS
xiCompartment Vandal Lock (Bus, N/Interlock W/Std
Compartment Vandal Lock (Bus, N/Interlock W/Std Buzzer W/Driver Compt)
Design 327
Compartment Vandal Lock (Bus, W/Interlock
Compartment Vandal Lock (Bus, W/Interlock W/Mechanical Buzzer N/Driver
Compt) Design 328
Compartment Vandal Lock (Bus, W/Interlock W/Mechanical Buzzer W/Driver
Compt) Design 329
Compartment Vandal Lock (Bus, W/Interlock W/Std
Buzzer N/ Driver Compt)
Compartment Vandal Lock (Bus, W/Interlock W/Std Buzzer N/ Driver Compt)
Design 330
Compartment Vandal Lock (Bus, W/Interlock W/Std Buzzer W/Driver Compt)
Design 331
Version 1 of B02 Vandal Lock Splice Packs
Version 1 of B02 Vandal Lock Splice Packs Design 332
Destination Sign (Type 1 LED)
Destination Sign (Type 1 LED) Design 333
Destination Sign (Type 2 LED)
Destination Sign (Type 2 LED) Design 334
Destination Sign (Type 3 LED)
Destination Sign (Type 3 LED) Design 336
Driver Alert Sign (CE)
Driver Alert Sign (CE) Design 338
Emergency Exit Splice Packs
Emergency Exit Splice Packs Design 339
Emergency Exit Vandal Lock (CE) Rear Door Only
Emergency Exit Vandal Lock (CE) Rear Door Only Design 340
Emergency Exit Vandal Lock (CE) Rear & Left Side
Emergency Exit Vandal Lock (CE) Rear & Left Side Design 342
Emergency Exit Vandal Lock (CE) Rear, Left & Right
Side
Emergency Exit Vandal Lock (CE) Rear, Left & Right Side Design 344
Emergency Exit Windows (CE) 1 Window each side
Emergency Exit Windows (CE) 1 Window each side Design 346
Emergency Exit Windows (CE) 2 Windows each side
Emergency Exit Windows (CE) 2 Windows each side Design 348
TABLE OF CONTENTS
xiiEmergency Exit Windows (CE) 3 Windows each side
Emergency Exit Windows (CE) 3 Windows each side Design 350
Emergency Exit Windows (CE) 4 Windows each side
Emergency Exit Windows (CE) 4 Windows each side Design 352
Hazard Warning (CE W/ Redundant Panel Switch)
Hazard Warning (CE W/ Redundant Panel Switch) Design 354
Hazard Warning (CE, W/O Redundant Switch)
Hazard Warning (CE, W/O Redundant Switch) Design 355
Hood Switch
Hood Switch Design 356
Hood Switch (W/ Underhood Work Light)
Hood Switch (W/ Underhood Work Light) Design 357
Air Horn (Highway) W/Hardwired Switch
Air Horn (Highway) W/Hardwired Switch Design 358
City Horn
City Horn Design 359
Mirrors (Heated) (CE, Crossview Heat N/ Rear View
Heat)
Mirrors (Heated) (CE, Crossview Heat N/ Rear View Heat) Design 360
Mirrors (Heated) (CE, Crossview & Rear View Heated,
Motorized)
Mirrors (Heated) (CE, Crossview & Rear View Heated, Motorized) Design 361
Non-Motorized)
Mirrors (Heated) (CE, Crossview & Rear View Heated, Non-Motorized) Design362
Mirrors (Heated) (CE, Rear View Heat, Motorized N/
Crossview Heat)
Mirrors (Heated) (CE, Rear View Heat, Motorized N/ Crossview Heat) Design 363
Mirrors (Heated) (CE, Rear View Heat, Non-Motorized,
N/ Crossview)
Mirrors (Heated) (CE, Rear View Heat, Non-Motorized, N/ Crossview) Design 364
Mirrors (Power) (CE, Dual Ctrl Switch, L/R W/
Upper/Lower Mirrors)
Mirrors (Power) (CE, Dual Ctrl Switch, L/R W/ Upper/Lower Mirrors) Design 365
Switch Packs
Switch Packs Design 366
Noise Suppression Switch (CE) No A/C Noise
Abatement
Noise Suppression Switch (CE) No A/C Noise Abatement Design 367
Noise Suppression Switch (CE) W/ 1 Abatement
Adaptor
TABLE OF CONTENTS
xiiiNoise Suppression Switch (CE) W/ 1 Abatement Adaptor Design 368
Noise Suppression Switch (CE) W/ 2 Abatement
Adapters
Noise Suppression Switch (CE) W/ 2 Abatement Adapters Design 369
Pupil Warning Master Flasher Switch (Left Side)
Pupil Warning Master Flasher Switch (Left Side) Design 370
Pupil Warning Master Flasher Switch (Left Side, W/
Lift Door Relay)
Pupil Warning Master Flasher Switch (Left Side, W/ Lift Door Relay) Design 371
Pupil Warning Master Flasher Switch (Right Side)
Pupil Warning Master Flasher Switch (Right Side) Design 372
Pupil Warning Master Flasher Switch (Right Side, W/
Lift Door Relay)
Pupil Warning Master Flasher Switch (Right Side, W/ Lift Door Relay) Design 373
Pupil Warning Master Flasher Switch (W/Amber
Cancel)
Pupil Warning Master Flasher Switch (W/Amber Cancel) Design 374
Pupil Warning Red Override Switch (Left Side)
Pupil Warning Red Override Switch (Left Side) Design 375
Pupil Warning Red Override Switch (Left Side, Always
Hot)
Pupil Warning Red Override Switch (Left Side, Always Hot) Design 376
Hot, Lift Door Activated)
Pupil Warning Red Override Switch (Left Side, Always Hot, Lift Door Activated)
Design 377
Hot, Lift Door Activated, W/ Master Sw)
Pupil Warning Red Override Switch (Left Side, Always Hot, Lift Door Activated, W/
Master Sw) Design 378
Pupil Warning Red Override Switch (Omit Switch, Lift
Door Activated)
Pupil Warning Red Override Switch (Omit Switch, Lift Door Activated) Design 379
Pupil Warning Red Override Switch (Omit, Lift Door
Pupil Warning Red Override Switch (Omit, Lift Door Activated, W/ Master Sw)
Design 380
Pupil Warning Red Override Switch (Right Side)
Pupil Warning Red Override Switch (Right Side) Design 381
Pupil Warning Red Override Switch (Right Side,
Always Hot)
Pupil Warning Red Override Switch (Right Side, Always Hot) Design 382
TABLE OF CONTENTS
xivPupil Warning Red Override Switch (Right Side,
Pupil Warning Red Override Switch (Right Side, Always Hot, Lift Door Activated)
Design 383
Always Hot, Lift Door Activated, W/ Master SW)
Pupil Warning Red Override Switch (Right Side, Always Hot, Lift Door Activated,
W/ Master SW) Design 384
Roof Hatch Emergency Exit (CE) Front Hatch Only
Roof Hatch Emergency Exit (CE) Front Hatch Only Design 385
Roof Hatch Emergency Exit (CE) Front & Rear Hatch
Roof Hatch Emergency Exit (CE) Front & Rear Hatch Design 392
Roof Hatch Emergency Exit (CE) Front, Rear & Center
Hatch
Roof Hatch Emergency Exit (CE) Front, Rear & Center Hatch Design 394
Roof Hatch Power Vent (CE) Front & Rear
Roof Hatch Power Vent (CE) Front & Rear Design 396
Roof Hatch Power Vent (CE, Front Vent Only)
Roof Hatch Power Vent (CE, Front Vent Only) Design 398
Roof Hatch Power Vent (CE, Rear Vent Only)
Roof Hatch Power Vent (CE, Rear Vent Only) Design 400
Roof Hatch Vandal Lock (Bus) W/Starter Interlock,
Front Only
Roof Hatch Vandal Lock (Bus) W/Starter Interlock, Front Only Design 402
Front & Rear
Roof Hatch Vandal Lock (Bus) W/Starter Interlock, Front & Rear Design 404
Over The Air Electrical I/O (OnCommand Link / N2
Module/ ISB)
Over The Air Electrical I/O (OnCommand Link / N2 Module/ ISB) Design 406
Telematics (Bus) Zonar Pre-Wire
Telematics (Bus) Zonar Pre-Wire Design 407
Telematics (CE) Zonar Pre-Wire
Telematics (CE) Zonar Pre-Wire Design 409
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater)
Tire Pressure (TPMS) (LDL 2.0 - 1 Repeater) Design 411
Traction Aids (Traction Chains, CE Bus)
Traction Aids (Traction Chains, CE Bus) Design 412
Aux Power (USB) - 1 USB
Aux Power (USB) - 1 USB Design 413
Aux Power (USB) - 1 USB A, 1 USB C
Aux Power (USB) - 1 USB A, 1 USB C Design 415
TABLE OF CONTENTS
xvAux Power (USB) - 2 USB
Aux Power (USB) - 2 USB Design 417
Aux Power (USB) - 2 USB A, 2 USB C
Aux Power (USB) - 2 USB A, 2 USB C Design 419
Aux Power (USB) - 3 USB
Aux Power (USB) - 3 USB Design 421
Aux Power (USB) - 3 USB A, 3 USB C
Aux Power (USB) - 3 USB A, 3 USB C Design 423
Aux Power (USB) - 4 USB
Aux Power (USB) - 4 USB Design 425
Bus Aux Power (USB) (CE) Single USB A, USB C
Bus Aux Power (USB) (CE) Single USB A, USB C Design 427
Bus Door Vandal Lock (W/ Starter Interrupt)
Bus Door Vandal Lock (W/ Starter Interrupt) Design 428
Wheelchair Lift Interlock (Key OFF/ON, Air Brakes,
Dash Switch)
Wheelchair Lift Interlock (Key OFF/ON, Air Brakes, Dash Switch) Design 429
Door Switch)
Wheelchair Lift Interlock (Key OFF/ON, Air Brakes, Door Switch) Design 431
Wheelchair Lift Interlock (Key OFF/ON, Air Brakes, No
Switch)
Wheelchair Lift Interlock (Key OFF/ON, Air Brakes, No Switch) Design 433
Wheelchair Lift Interlock (Key OFF/ON, Hydraulic
W/Foot Park Brake, No Switch)ke, No Switch)
Wheelchair Lift Interlock (Key OFF/ON, Hydraulic W/Foot Park Brake, No
Switch)ke, No Switch) Design 435
W/SAAR, No Switch)
Wheelchair Lift Interlock (Key OFF/ON, Hydraulic W/SAAR, No Switch)
Design 437
W/SAAR, W/ Dash Switch)
Wheelchair Lift Interlock (Key OFF/ON, Hydraulic W/SAAR, W/ Dash Switch)
Design 439
Foot Brake, Dash Switch)
Wheelchair Lift Interlock (Key OFF/ON, Hydraulic W/ Foot Brake, Dash Switch)
Design 441
Wheelchair Lift Interlock (Key ON, No Switch)
Wheelchair Lift Interlock (Key ON, No Switch) Design 443
Wheelchair Lift Interlock (Key ON, W/ Dash Switch &
Door Switch)
TABLE OF CONTENTS
xviWheelchair Lift Interlock (Key ON, W/ Dash Switch & Door Switch) Design 445
Wheelchair Lift Interlock (Key ON, W/ Dash Switch)
Wheelchair Lift Interlock (Key ON, W/ Dash Switch) Design 447
Wheelchair Lift Interlock (Key ON, W/ Door Switch)
Wheelchair Lift Interlock (Key ON, W/ Door Switch) Design 449
Wheelchair Lift Lighting (CE, Interior Light Only)
Wheelchair Lift Lighting (CE, Interior Light Only) Design 451
Wheelchair Lift Lighting (CE, Single Exterior, N/
Interior)
Wheelchair Lift Lighting (CE, Single Exterior, N/ Interior) Design 452
Wheelchair Lift Lighting (CE, Single Exterior, W/
Interior)
Wheelchair Lift Lighting (CE, Single Exterior, W/ Interior) Design 454
Wheelchair Lift Lighting (CE, Three Exterior, N/
Interior)
Wheelchair Lift Lighting (CE, Three Exterior, N/ Interior) Design 456
Wheelchair Lift Lighting (CE, Three Exterior, W/
Interior)
Wheelchair Lift Lighting (CE, Three Exterior, W/ Interior) Design 458
Wheelchair Lift Vandal Lock (CE)
Wheelchair Lift Vandal Lock (CE) Design 460
Wheelchair Warning (No Indicator, Buzzer On W/ Lift
Door Open)
Wheelchair Warning (No Indicator, Buzzer On W/ Lift Door Open) Design 461
Wheelchair Warning (No Indicator, Buzzer On W/ Lift Door Open, Shuts Off When
4" Open) Design 462
Wheelchair Warning (No Indicator, Mechanical Buzzer
On W/ Lift Door Open, Shuts Off When 4" Open)
Wheelchair Warning (No Indicator, Mechanical Buzzer On W/ Lift Door Open,
Shuts Off When 4" Open) Design 463
Wheelchair Warning (2" Flashing Indicator, Buzzer On
W/ Lift Door Open)
Wheelchair Warning (2" Flashing Indicator, Buzzer On W/ Lift Door Open)
Design 464
Mechanical Buzzer On W/ Lift Door Open, Off W/ Lift
Door 4" Open)
Wheelchair Warning (2" Flashing Indicator, Mechanical Buzzer On W/ Lift Door
Open, Off W/ Lift Door 4" Open) Design 465
Wheelchair Warning (2" Flashing Indicator, No Buzzer)
Wheelchair Warning (2" Flashing Indicator, No Buzzer) Design 466
TABLE OF CONTENTS
xviiWheelchair Warning (2" Flashing Indicator, Piezo
Buzzer On W/ Lift Door Open, Off W/ Lift Door 4"
Open)
Wheelchair Warning (2" Flashing Indicator, Piezo Buzzer On W/ Lift Door Open,
Off W/ Lift Door 4" Open) Design 467
Wheelchair Warning (3" Indicator in Bulkhead, Buzzer
Wheelchair Warning (3" Indicator in Bulkhead, Buzzer On W/ Lift Door Open)
Design 468
On W/ Lift Door Open, Shuts off when 4" open)
Wheelchair Warning (3" Indicator in Bulkhead, Buzzer On W/ Lift Door Open,
Shuts off when 4" open) Design 469
Mechanical Buzzer On W/ Lift Door Open, Shuts Off
When 4" Open)
Wheelchair Warning (3" Indicator in Bulkhead, Mechanical Buzzer On W/ Lift
Door Open, Shuts Off When 4" Open) Design 470
Wheelchair Warning (3" Indicator in Bulkhead, No
Buzzer)
Wheelchair Warning (3" Indicator in Bulkhead, No Buzzer) Design 471
2-Way Radio
2-Way Radio Design 472
Diesel Particulate Filter (DPF) (W/ Regen Switch -
Relocated)
Diesel Particulate Filter (DPF) (W/ Regen Switch - Relocated) Design 473
Selective Catalytic Reduction (SCR)
Selective Catalytic Reduction (SCR) Design 474
Transmission I/O (Allison Gen 6 1K/2K N/ Body
Builder)
Transmission I/O (Allison Gen 6 1K/2K N/ Body Builder) Design 476
Transmission I/O (Allison Gen 6 3K N/ Body Builder)
Transmission I/O (Allison Gen 6 3K N/ Body Builder) Design 478
Air Dryer (Single)
Air Dryer (Single) Design 480
Air Solenoids 4-pack (1 pack/4 solenoids)
Air Solenoids 4-pack (1 pack/4 solenoids) Design 481
Antilock Brake Systems (ABS) (Wabco Hydraulic 4
Channel N/ Stability)
Antilock Brake Systems (ABS) (Wabco Hydraulic 4 Channel N/ Stability)
Design 482
Channel W/ Stability)
Antilock Brake Systems (ABS) (Wabco Hydraulic 4 Channel W/ Stability)
Design 483
TABLE OF CONTENTS
xviiiAntilock Brake System (ABS) (BENDIX 4 Channel
Implemenation - No Modulator Twist)
Antilock Brake System (ABS) (BENDIX 4 Channel Implemenation - No Modulator
Twist) Design 484
Service Brake Switch (Single Switch, N/Redundant
Switch, Hydraulic Brakes)
Service Brake Switch (Single Switch, N/Redundant Switch, Hydraulic Brakes)
Design 485
Service Brake Switch (1 SLS/1 Transducer)
Service Brake Switch (1 SLS/1 Transducer) Design 486
Drain Valve (1) One Heater
Drain Valve (1) One Heater Design 487
Service Brake (Hydraulic)
Service Brake (Hydraulic) Design 488
Auto Park Brake (T-Handle Shifter, Auto Park Brake)
Auto Park Brake (T-Handle Shifter, Auto Park Brake) Design 489
Park Brake Controls (Bus) Intellipark
Park Brake Controls (Bus) Intellipark Design 490
Park Brake Controls (Hydraulic SAAR Park Brake)
Park Brake Controls (Hydraulic SAAR Park Brake) Design 491
Park Brake Controls (Park Brake W/ Interlock, N/ Lift,
Air Chassis)
Park Brake Controls (Park Brake W/ Interlock, N/ Lift, Air Chassis) Design 492
Air Chassis, W/ Park Brake Buzzer)
Park Brake Controls (Park Brake W/ Interlock, N/ Lift, Air Chassis, W/ Park Brake
Buzzer) Design 493
W/SAAR)
Park Brake Controls (Park Brake W/ Interlock, N/ Lift, W/SAAR) Design 494
Park Brake Controls (Park Brake W/ Interlock, W/ Lift,
Air Chassis)
Park Brake Controls (Park Brake W/ Interlock, W/ Lift, Air Chassis) Design 495
Park Brake Controls (Park Brake W/ Interlock, W/ Lift, Air Chassis, W/ Park Brake
Buzzer) Design 496
SAAR)
Park Brake Controls (Park Brake W/ Interlock, W/ Lift, SAAR) Design 497
Park Brake Controls (W/ Inhibit Solenoid)
Park Brake Controls (W/ Inhibit Solenoid) Design 498
TABLE OF CONTENTS
xixPark Brake Reminder (Stationary) (Bus, W/ Hardwired
Buzzer)
Park Brake Reminder (Stationary) (Bus, W/ Hardwired Buzzer) Design 499
Stability Control (Bendix, Straight Truck, J1939 Driven
Lamp)
Stability Control (Bendix, Straight Truck, J1939 Driven Lamp) Design 500
Stability Control; Wabco Hydraulic W/ J1939 Driven
Lamp
Stability Control; Wabco Hydraulic W/ J1939 Driven Lamp Design 501
Traction Control (Bendix, ECM)
Traction Control (Bendix, ECM) Design 502
Adaptive Cruise Control (Bendix Wingman Advanced
N/ DIU)
Adaptive Cruise Control (Bendix Wingman Advanced N/ DIU) Design 503
Adaptive Cruise Control (Bendix - Fusion 2.8 &
N/Safety Direct Conn & W/Bus Bulkhead Speakers)
Adaptive Cruise Control (Bendix - Fusion 2.8 & N/Safety Direct Conn & W/Bus
Bulkhead Speakers) Design 504
W/Safety Direct Conn & W/Bus Bulkhead Speakers)
Adaptive Cruise Control (Bendix - Fusion 2.8 & W/Safety Direct Conn & W/Bus
Bulkhead Speakers) Design 506
Adaptive Cruise Control (Fusion 3.0 N/ DIU W/LDW
Audio Mute)
Adaptive Cruise Control (Fusion 3.0 N/ DIU W/LDW Audio Mute) Design 508
Adaptive Cruise Control (Fusion 3.0 N/ DIU)
Adaptive Cruise Control (Fusion 3.0 N/ DIU) Design 509
Camera Event Recorder N/Safety Direct Cable
Camera Event Recorder N/Safety Direct Cable Design 510
Engine Coolant Level Monitoring (No CLA Module)
Engine Coolant Level Monitoring (No CLA Module) Design 511
Cooling Fan Control (CE) Warner Electric
Cooling Fan Control (CE) Warner Electric Design 512
Cooling Fan Control (No Fan Override Cummins No
Radiator)
Cooling Fan Control (No Fan Override Cummins No Radiator) Design 513
Engine Idle Ramp Up (W/ A/C On)
Engine Idle Ramp Up (W/ A/C On) Design 514
Starting Aid (Grid Heater)
Starting Aid (Grid Heater) Design 515
Vehicle Acceleration with Adjustable pedal
Vehicle Acceleration with Adjustable pedal Design 516
TABLE OF CONTENTS
xxAutomatic Lighting W/Twilight & N/Sunload
Automatic Lighting W/Twilight & N/Sunload Design 517
Back Up Lights (Reverse Lights) (CE) (2) W/Light
Monitor N/ Exit Activated
Back Up Lights (Reverse Lights) (CE) (2) W/Light Monitor N/ Exit Activated
Design 518
Monitor & W/ E/E Activated
Back Up Lights (Reverse Lights) (CE) (2) W/Light Monitor & W/ E/E Activated
Design 519
Back Up Lights (Reverse Lights) (CE) (4) W/Light
Back Up Lights (Reverse Lights) (CE) (4) W/Light Monitor N/ Exit Activated
Design 520
Back Up Lights (Reverse Lights) (CE) (4) W/Light Monitor & W/ E/E Activated
Design 521
Beacon/Strobe Light (CE) Dual On with Ignition
Beacon/Strobe Light (CE) Dual On with Ignition Design 522
Beacon/Strobe Light (CE) Dual On W/ Stop Arm or
Switch
Beacon/Strobe Light (CE) Dual On W/ Stop Arm or Switch Design 535
Beacon/Strobe Light (CE) Dual W/Switch
Beacon/Strobe Light (CE) Dual W/Switch Design 548
Beacon/Strobe Light (CE) Dual W/Switch or W/PWL
Beacon/Strobe Light (CE) Dual W/Switch or W/PWL Design 561
Beacon/Strobe Light (CE) Dual W/ Momentary Switch
Beacon/Strobe Light (CE) Dual W/ Momentary Switch Design 574
Beacon/Strobe Light (CE) Single On with Ignition
Beacon/Strobe Light (CE) Single On with Ignition Design 587
Beacon/Strobe Light (CE) Single On W/ Stop Arm or
Switch
Beacon/Strobe Light (CE) Single On W/ Stop Arm or Switch Design 600
Beacon/Strobe Light (CE) Single W/Momentary Switch
Beacon/Strobe Light (CE) Single W/Momentary Switch Design 613
Beacon/Strobe Light (CE) Single W/Switch or W/PWL
Beacon/Strobe Light (CE) Single W/Switch or W/PWL Design 626
Beacon/Strobe Light (CE) Single W/Switch(Post 3/24)
Beacon/Strobe Light (CE) Single W/Switch(Post 3/24) Design 639
Beacon/Strobe Light (CE) Single W/Switch(Pre 3/24)
Beacon/Strobe Light (CE) Single W/Switch(Pre 3/24) Design 640
Bus Door Stepwell Lighting (Wired to ACC, N/ AED Lt)
Bus Door Stepwell Lighting (Wired to ACC, N/ AED Lt) Design 653
TABLE OF CONTENTS
xxiBus Door Stepwell Lighting (Wired to ACC, W/ AED Lt)
Bus Door Stepwell Lighting (Wired to ACC, W/ AED Lt) Design 654
Bus Door Stepwell Lighting (Wired to Clearance, N/
AED Lt)
Bus Door Stepwell Lighting (Wired to Clearance, N/ AED Lt) Design 655
Bus Door Stepwell Lighting (Wired to Clearance, W/
AED Lt)
Bus Door Stepwell Lighting (Wired to Clearance, W/ AED Lt) Design 656
Bus Door Stepwell Lighting (Wired to Dome Lts, N/
AED Lt)
Bus Door Stepwell Lighting (Wired to Dome Lts, N/ AED Lt) Design 657
Bus Door Stepwell Lighting (Wired to Dome Lts, W/
AED Lt)
Bus Door Stepwell Lighting (Wired to Dome Lts, W/ AED Lt) Design 658
Bus Door Stepwell Lighting (Wired to Ignition, N/ AED
Lt)
Bus Door Stepwell Lighting (Wired to Ignition, N/ AED Lt) Design 659
Bus Door Stepwell Lighting (Wired to IGN, W/ AED
Light)
Bus Door Stepwell Lighting (Wired to IGN, W/ AED Light) Design 660
Bus Light Monitor
Bus Light Monitor Design 661
Clearance and Identification Lights (CE, Front ID to
Ignition)
Clearance and Identification Lights (CE, Front ID to Ignition) Design 662
Directional Signals (Turn) (BUS CAN LED) N/Fender
Lts W/Light Monitor
Directional Signals (Turn) (BUS CAN LED) N/Fender Lts W/Light Monitor
Design 663
Directional Signals (Turn) (BUS CAN LED) W/Fender
Lts W/Light Monitor
Directional Signals (Turn) (BUS CAN LED) W/Fender Lts W/Light Monitor
Design 664
Directional Signals (Turn) (CE) Halogen N/Fender Lts
W/Light Monitor
Directional Signals (Turn) (CE) Halogen N/Fender Lts W/Light Monitor Design 665
Directional Signals (Turn) (CE) Halogen W/Fender Lts
W/Light Monitor
Directional Signals (Turn) (CE) Halogen W/Fender Lts W/Light Monitor Design666
Front Fog Lamps W/Relay
Front Fog Lamps W/Relay Design 667
Front Fog Lamps (Bus, W/ Relay)(Post 12/22)
Front Fog Lamps (Bus, W/ Relay)(Post 12/22) Design 668
Front Fog Lamps (Bus, W/ Relay)(Pre 12/22)
TABLE OF CONTENTS
xxiiFront Fog Lamps (Bus, W/ Relay)(Pre 12/22) Design 669
Marker Lighting (Halogen Headlights) N/Plowlights,
W/Fender, N/Guide Posts
Marker Lighting (Halogen Headlights) N/Plowlights, W/Fender, N/Guide Posts
Design 670
Marker Lighting (Halogen Headlights) N/Plowlight,
N/Fender, N/Guide Posts
Marker Lighting (Halogen Headlights) N/Plowlight, N/Fender, N/Guide Posts
Design 671
Marker Lighting (LED CAN Headlamp) N/Plow Lts,
N/Fender Lts, N/Guide Posts
Marker Lighting (LED CAN Headlamp) N/Plow Lts, N/Fender Lts, N/Guide Posts
Design 672
W/Fender Lts, N/Guide Posts
Marker Lighting (LED CAN Headlamp) N/Plow Lts, W/Fender Lts, N/Guide Posts
Design 673
Headlights (Bus Halogen)
Headlights (Bus Halogen) Design 674
Headlights (Bus LED CAN)
Headlights (Bus LED CAN) Design 675
License Plate Light (CE) W/Dual License Plate Lights
License Plate Light (CE) W/Dual License Plate Lights Design 676
License Plate Light (CE) W/Single License Plate Light
License Plate Light (CE) W/Single License Plate Light Design 677
License Plate Light (CE) W/Stop/Tail/License Light,
Monitored
License Plate Light (CE) W/Stop/Tail/License Light, Monitored Design 678
Not Monitored
License Plate Light (CE) W/Stop/Tail/License Light, Not Monitored Design 679
Mirror Lighting (Bus, Dual Crossview Lookdown
Light)
Mirror Lighting (Bus, Dual Crossview Lookdown Light) Design 680
Pupil Warning Lights (Steering Wheel, NonSequential, W/ Panel Flasher Switch)
Pupil Warning Lights (Steering Wheel, Non-Sequential, W/ Panel Flasher Switch)
Design 681
Pupil Warning Lights (W/ 3-Position Flasher Switch)
Pupil Warning Lights (W/ 3-Position Flasher Switch) Design 682
Pupil Warning Lights (W/ 3-Position Flasher Switch,
Always Hot)
Pupil Warning Lights (W/ 3-Position Flasher Switch, Always Hot) Design 683
Pupil Warning Lights (Left Side 2-Position, NonSequential)
TABLE OF CONTENTS
xxiiiPupil Warning Lights (Left Side 2-Position, Non-Sequential) Design 684
Pupil Warning Lights (Left Side 3-Position, NonSequential, No Master)(Post 3/24)
Pupil Warning Lights (Left Side 3-Position, Non-Sequential, No Master)(Post 3/24)
Design 685
Pupil Warning Lights (Left Side 3-Position, NonSequential, No Master)(Pre 3/24)
Pupil Warning Lights (Left Side 3-Position, Non-Sequential, No Master)(Pre 3/24)
Design 686
Pupil Warning Lights (Left Side 3-Position, NonSequential, No Master, Always Hot)
Pupil Warning Lights (Left Side 3-Position, Non-Sequential, No Master, Always
Hot) Design 688
Pupil Warning Lights (Left Side 3-Position, NonSequential, W/ Master)
Pupil Warning Lights (Left Side 3-Position, Non-Sequential, W/ Master)
Design 690
Pupil Warning Lights (Left Side 3-Position, NonSequential, W/ Master)(Post 3/24)
Pupil Warning Lights (Left Side 3-Position, Non-Sequential, W/ Master)(Post 3/24)
Design 692
Pupil Warning Lights (Left Side 3-Position, NonSequential, W/ Master)(Pre 3/24)
Pupil Warning Lights (Left Side 3-Position, Non-Sequential, W/ Master)(Pre 3/24)
Design 694
Pupil Warning Lights (Left Side 3-Position, NonSequential, W/ Master, Always Hot)
Pupil Warning Lights (Left Side 3-Position, Non-Sequential, W/ Master, Always
Hot) Design 696
Pupil Warning Lights (Left Side 3-Position, NonSequential, W/ Master, Always Hot)(Post 3/24)
Hot)(Post 3/24) Design 698
Pupil Warning Lights (Left Side 3-Position, NonSequential, W/ Master, Always Hot)(Pre 3/24)
Hot)(Pre 3/24) Design 699
Pupil Warning Lights (Left Side 3-Position, Sequential)
Pupil Warning Lights (Left Side 3-Position, Sequential) Design 701
Pupil Warning Lights (Left Side, Sequential)
Pupil Warning Lights (Left Side, Sequential) Design 703
Pupil Warning Lights (Left Side, 3-Position, NonSequential, No Master)
Pupil Warning Lights (Left Side, 3-Position, Non-Sequential, No Master)
Design 704
TABLE OF CONTENTS
xxivPupil Warning Lights (Left Side, 3-Position, NonSequential, No Master, Always Hot)
Pupil Warning Lights (Left Side, 3-Position, Non-Sequential, No Master, Always
Hot) Design 706
Pupil Warning Lights (Right Side 2-Position, NonSequential)
Pupil Warning Lights (Right Side 2-Position, Non-Sequential) Design 708
Pupil Warning Lights (Right Side 3-Position, NonSequential, Omit Master)
Pupil Warning Lights (Right Side 3-Position, Non-Sequential, Omit Master)
Design 709
Pupil Warning Lights (Right Side 3-Position, NonSequential, Omit Master, Always Hot)
Pupil Warning Lights (Right Side 3-Position, Non-Sequential, Omit Master, Always
Hot) Design 711
Pupil Warning Lights (Right Side 3-Position, NonSequential, W/ Master)
Pupil Warning Lights (Right Side 3-Position, Non-Sequential, W/ Master)
Design 713
Pupil Warning Lights (Right Side 3-Position, NonSequential, W/ Master, Always Hot)
Pupil Warning Lights (Right Side 3-Position, Non-Sequential, W/ Master, Always
Hot) Design 715
Sequential)
Pupil Warning Lights (Right Side 3-Position, Sequential) Design 717
Pupil Warning Lights (Right Side, Sequential)
Pupil Warning Lights (Right Side, Sequential) Design 719
Pupil Warning Lights (3-Position Paddle, NonSequential)
Pupil Warning Lights (3-Position Paddle, Non-Sequential) Design 720
Pupil Warning Lights (3-Position Paddle, NonSequential, Always Hot)
Pupil Warning Lights (3-Position Paddle, Non-Sequential, Always Hot) Design 721
Pupil Warning Light Interrupt (Hold to Cancel)
Pupil Warning Light Interrupt (Hold to Cancel) Design 722
Pupil Warning Light Interrupt (Master and RRX Cancel
W/Amber Cancel, No 3-Pos Switch)(Post 3/24)
Pupil Warning Light Interrupt (Master and RRX Cancel W/Amber Cancel, No 3-
Pos Switch)(Post 3/24) Design 723
W/Amber Cancel, No 3-Pos Switch)(Pre 3/24)
Pos Switch)(Pre 3/24) Design 724
TABLE OF CONTENTS
xxvPupil Warning Light Interrupt (Master and RRX
Cancel, W/Amber Cancel, W/3-Pos Paddle Sw)
Pupil Warning Light Interrupt (Master and RRX Cancel, W/Amber Cancel, W/3-
Pos Paddle Sw) Design 725
Pupil Warning Light Interrupt (Single Cycle Master &
RRX Cancel Switch)
Pupil Warning Light Interrupt (Single Cycle Master & RRX Cancel Switch)
Design 726
Pupil Warning Lights Outputs (With 16-Lamp Light
Monitor)
Pupil Warning Lights Outputs (With 16-Lamp Light Monitor) Design 727
Rear Lights (Stop) (CE) (2) N/Extra Lts W/Light
Monitor
Rear Lights (Stop) (CE) (2) N/Extra Lts W/Light Monitor Design 729
Rear Lights (Stop) (CE) (4) W/Add'l Stop/Tail Light
W/Light Monitor
Rear Lights (Stop) (CE) (4) W/Add'l Stop/Tail Light W/Light Monitor Design 730
Rear Lights (Stop) (CE) (4) W/Stop/Tail/License
W/Light Monitor
Rear Lights (Stop) (CE) (4) W/Stop/Tail/License W/Light Monitor Design 731
Rear Lights (Stop) (CE) (6) W/Stop/Tail/License &
W/Add'l S/T W/ Light Monitor
Rear Lights (Stop) (CE) (6) W/Stop/Tail/License & W/Add'l S/T W/ Light Monitor
Design 732
Rear Lights (Tail Lights) (CE) (2) W/License W/Omit
Std Wiring W/Lt Monitor
Rear Lights (Tail Lights) (CE) (2) W/License W/Omit Std Wiring W/Lt Monitor
Design 733
Rear Lights (Tail Lights) (CE) (4) W/Add'l Stop/Tail Lt
W/Lt Monitor
Rear Lights (Tail Lights) (CE) (4) W/Add'l Stop/Tail Lt W/Lt Monitor Design 734
Rear Lights (Tail Lights) (CE) (4) W/Stop/Tail/License
W/Lt Monitor
Rear Lights (Tail Lights) (CE) (4) W/Stop/Tail/License W/Lt Monitor Design 735
Rear Lights (Tail Lights) (CE) (6) W/License &
Additional W/Lt Monitor
Rear Lights (Tail Lights) (CE) (6) W/License & Additional W/Lt Monitor Design 736
Side Marker Lighting W/Side Marker/Turn
Combination Light (CE)
Side Marker Lighting W/Side Marker/Turn Combination Light (CE) Design 737
Side Marker Lighting (Bus, W/ Extra Markers only)
Side Marker Lighting (Bus, W/ Extra Markers only) Design 738
Side Marker Lighting (Bus, W/ Intermediate Lt &
Marker/Turn Lt)
TABLE OF CONTENTS
xxviSide Marker Lighting (Bus, W/ Intermediate Lt & Marker/Turn Lt) Design 740
Side Marker Lighting (Bus, W/ Intermediate Markers
only)
Side Marker Lighting (Bus, W/ Intermediate Markers only) Design 742
Side Marker Lighting (Bus, W/ Intermediate & Extra
Side Markers)
Side Marker Lighting (Bus, W/ Intermediate & Extra Side Markers) Design 746
SideTurn Lighting W/Side Marker/Turn Combination
Light & W/4 Side Turn (CE)
SideTurn Lighting W/Side Marker/Turn Combination Light & W/4 Side Turn (CE)
Design 748
Side Turn Lighting W/Marker/Turn Combination Light
(CE, eBus)
Side Turn Lighting W/Marker/Turn Combination Light (CE, eBus) Design 750
Side Turrn Lighting W/Marker/Turn Combination Light
& W/2 Side Turn (CE) (Aft Wheel))
Side Turrn Lighting W/Marker/Turn Combination Light & W/2 Side Turn (CE) (Aft
Wheel)) Design 751
& W/2 Side Turn (CE) (Before Wheel))
(Before Wheel)) Design 759
& W/2 Side Turn (CE) (Midship)
(Midship) Design 764
& W/2 Side Turn (CE) (Over Wheel))
(Over Wheel)) Design 768
Side Turn Lighting W/ 2 Side Turn (CE) (Aft Entrance
Door)
Side Turn Lighting W/ 2 Side Turn (CE) (Aft Entrance Door) Design 773
Side Turn Lighting W/ 2 Side Turn (CE) (Aft Rear
Wheel)
Side Turn Lighting W/ 2 Side Turn (CE) (Aft Rear Wheel) Design 774
Side Turn Lighting W/ 2 Side Turn (CE) (Before Rear
Wheel)
Side Turn Lighting W/ 2 Side Turn (CE) (Before Rear Wheel) Design 782
Side Turn Lighting W/ 2 Side Turn (CE) (Midship)
Side Turn Lighting W/ 2 Side Turn (CE) (Midship) Design 787
Side Turn Lighting W/ 2 Side Turn (CE) (Over Rear
Wheel)
Side Turn Lighting W/ 2 Side Turn (CE) (Over Rear Wheel) Design 791
TABLE OF CONTENTS
xxviiSide Turn Lighting W/ 4 Side Turn (CE) (Aft Entrance
and Aft Wheel)
Side Turn Lighting W/ 4 Side Turn (CE) (Aft Entrance and Aft Wheel) Design 796
and Before Wheel)
Side Turn Lighting W/ 4 Side Turn (CE) (Aft Entrance and Before Wheel)
Design 804
and Midship)
Side Turn Lighting W/ 4 Side Turn (CE) (Aft Entrance and Midship) Design 809
and Over Wheel)
Side Turn Lighting W/ 4 Side Turn (CE) (Aft Entrance and Over Wheel)
Design 813
Side Turn Lighting W/ 4 Side Turn (CE) (Midship and
Aft Wheel)
Side Turn Lighting W/ 4 Side Turn (CE) (Midship and Aft Wheel) Design 818
Skirt Light (CE, Rear Tire Illumination Light)
Skirt Light (CE, Rear Tire Illumination Light) Design 820
Under Hood Lighting (MV, CE) BCM Controlled
Timeout W/Hood Switch
Under Hood Lighting (MV, CE) BODY CONTROL MODULE Controlled Timeout
W/Hood Switch Design 821
Fuel Heater (Vehicle Powered) Davco 245
Fuel Heater (Vehicle Powered) Davco 245 Design 822
Fuel Heater (Vehicle Powered) (Racor 400 Series)
Fuel Heater (Vehicle Powered) (Racor 400 Series) Design 823
Fuel Level (Single Sensor)
Fuel Level (Single Sensor) Design 824
Water In Fuel (WIF) Davco 245 W/ Heater
Water In Fuel (WIF) Davco 245 W/ Heater Design 825
Water In Fuel (WIF) Racor W/ Heater
Water In Fuel (WIF) Racor W/ Heater Design 826
Current Monitoring (Ammeter) (PAM Module)
Current Monitoring (Ammeter) (PAM Module) Design 827
Auxiliary Defog Fans (CE, 1 Fan, Center Blower)
Auxiliary Defog Fans (CE, 1 Fan, Center Blower) Design 828
Auxiliary Defog Fans (CE, 1 Fan, Center Left)
Auxiliary Defog Fans (CE, 1 Fan, Center Left) Design 829
Auxiliary Defog Fans (CE, 1 Fan, Center Right)
Auxiliary Defog Fans (CE, 1 Fan, Center Right) Design 830
Auxiliary Defog Fans (CE, 1 Fan, Far Left)
Auxiliary Defog Fans (CE, 1 Fan, Far Left) Design 831
TABLE OF CONTENTS
xxviiiAuxiliary Defog Fans (CE, 1 Fan, Far Right)
Auxiliary Defog Fans (CE, 1 Fan, Far Right) Design 833
Auxiliary Defog Fans (CE, 2 Fans, Center Blower, Far
Right)
Auxiliary Defog Fans (CE, 2 Fans, Center Blower, Far Right) Design 834
Auxiliary Defog Fans (CE, 2 Fans, Center Left, Center
Right)
Auxiliary Defog Fans (CE, 2 Fans, Center Left, Center Right) Design 835
Auxiliary Defog Fans (CE, 2 Fans, Center Left, Far
Right)
Auxiliary Defog Fans (CE, 2 Fans, Center Left, Far Right) Design 836
Auxiliary Defog Fans (CE, 2 Fans, Center Right, Far
Right)
Auxiliary Defog Fans (CE, 2 Fans, Center Right, Far Right) Design 837
Auxiliary Defog Fans (CE, 2 Fans, Far Left, Center
Blower)
Auxiliary Defog Fans (CE, 2 Fans, Far Left, Center Blower) Design 838
Right)
Auxiliary Defog Fans (CE, 2 Fans, Far Left, Center Right) Design 840
Auxiliary Defog Fans (CE, 2 Fans, Far Left, Far Right)
Auxiliary Defog Fans (CE, 2 Fans, Far Left, Far Right) Design 842
Auxiliary Defog Fans (CE, 3 Fans, Center Left, Center
Right, Far Right)
Auxiliary Defog Fans (CE, 3 Fans, Center Left, Center Right, Far Right)
Design 844
Auxiliary Defog Fans (CE, 3 Fans, Far Left, Center
Right, Far Right)
Auxiliary Defog Fans (CE, 3 Fans, Far Left, Center Right, Far Right) Design 845
Heating Ventilation & Air Conditioning (HVAC)
(Manual W/PT Transducer N/Low Pressure SW)
Heating Ventilation & Air Conditioning (HVAC) (Manual W/PT Transducer N/Low
Pressure SW) Design 847
Heating Ventilation & Air Conditioning (HVAC)-
Manual Heater Only
Heating Ventilation & Air Conditioning (HVAC)- Manual Heater Only Design 849
Heated Steps (Stepwell Heater, Switch)
Heated Steps (Stepwell Heater, Switch) Design 851
Bus Passenger Air Conditioning (Body A/C Dual
Compressors W/ Noise Abatement)
Bus Passenger Air Conditioning (Body A/C Dual Compressors W/ Noise
Abatement) Design 852
Compressors)
Bus Passenger Air Conditioning (Body A/C Dual Compressors) Design 854
TABLE OF CONTENTS
xxixBus Passenger Air Conditioning (Body A/C Single
Compressor W/ Noise Abatement)
Bus Passenger Air Conditioning (Body A/C Single Compressor W/ Noise
Abatement) Design 856
Compressor)
Bus Passenger Air Conditioning (Body A/C Single Compressor) Design 857
Left Front Bus Passenger Heater (50K/84.5K BTU
Single Switch Activates Booster)
Left Front Bus Passenger Heater (50K/84.5K BTU Single Switch Activates
Booster) Design 858
Left Front Bus Passenger Heater (84.5K BTU Dual
Left Front Bus Passenger Heater (84.5K BTU Dual Switch Activates Booster)
Design 859
Switch)
Left Front Bus Passenger Heater (84.5K BTU Dual Switch) Design 860
Left Front Bus Passenger Heater (84.5K BTU Single
Switch)
Left Front Bus Passenger Heater (84.5K BTU Single Switch) Design 861
Left Rear Bus Passenger Heater (50/84.5K BTU Single
Left Rear Bus Passenger Heater (50/84.5K BTU Single Switch Activates Booster)
Design 862
Left Rear Bus Passenger Heater (84.5K BTU Dual
Left Rear Bus Passenger Heater (84.5K BTU Dual Switch Activates Booster)
Design 863
Switch)
Left Rear Bus Passenger Heater (84.5K BTU Dual Switch) Design 864
Left Rear Bus Passenger Heater (84.5K BTU Single
Switch)
Left Rear Bus Passenger Heater (84.5K BTU Single Switch) Design 865
Right Front Bus Passenger Heater (50K/84.5K BTU
Right Front Bus Passenger Heater (50K/84.5K BTU Single Switch Activates
Booster) Design 866
Right Front Bus Passenger Heater (84.5K BTU Dual
Right Front Bus Passenger Heater (84.5K BTU Dual Switch Activates Booster)
Design 867
Switch)
Right Front Bus Passenger Heater (84.5K BTU Dual Switch) Design 868
TABLE OF CONTENTS
xxxRight Front Bus Passenger Heater (84.5K BTU Single
Switch)
Right Front Bus Passenger Heater (84.5K BTU Single Switch) Design 869
Right Rear Bus Passenger Heater (50K/84.5K BTU
Right Rear Bus Passenger Heater (50K/84.5K BTU Single Switch Activates
Booster) Design 870
Right Rear Bus Passenger Heater (80K Wall Mount
Activates Booster)
Right Rear Bus Passenger Heater (80K Wall Mount Activates Booster) Design871
Right Rear Bus Passenger Heater (80K Wall Mount)
Right Rear Bus Passenger Heater (80K Wall Mount) Design 872
Right Rear Bus Passenger Heater (84.5K BTU Dual
Right Rear Bus Passenger Heater (84.5K BTU Dual Switch Activates Booster)
Design 873
Switch)
Right Rear Bus Passenger Heater (84.5K BTU Dual Switch) Design 874
Right Rear Bus Passenger Heater (84.5K BTU Single
Switch)
Right Rear Bus Passenger Heater (84.5K BTU Single Switch) Design 875
Rear AUX Heating Ventilation & Air Conditioning
(HVAC) (Convection Heater)
Rear AUX Heating Ventilation & Air Conditioning (HVAC) (Convection Heater)
Design 876
Rear No-Idle HVAC (Espar W/ Timer)
Rear No-Idle HVAC (Espar W/ Timer) Design 877
Rear No-Idle HVAC (17K Webasto W/ Timer)
Rear No-Idle HVAC (17K Webasto W/ Timer) Design 879
Rear No-Idle HVAC (45k Webasto Scholastic W/ Timer)
Rear No-Idle HVAC (45k Webasto Scholastic W/ Timer) Design 880
Ambient Temperature Monitoring Mirror Sensor ( W/
Heated Non-Motorized Mirror N/ Display)
Ambient Temperature Monitoring Mirror Sensor ( W/ Heated Non-Motorized Mirror
N/ Display) Design 881
Heated Non-Motorized Mirror )
) Design 882
Motor Mirror N/ Display )
Ambient Temperature Monitoring Mirror Sensor ( W/ Motor Mirror N/ Display )
Design 883
TABLE OF CONTENTS
xxxiAmbient Temperature Monitoring Mirror Sensor ( W/
Motor Mirror )
Ambient Temperature Monitoring Mirror Sensor ( W/ Motor Mirror ) Design 884
Non-Heated Non-Motorized Mirror N/ Display)
Ambient Temperature Monitoring Mirror Sensor ( W/ Non-Heated Non-Motorized
Mirror N/ Display) Design 885
Non-Heated Non-Motorized Mirror )
Mirror ) Design 886
LT Series Version 0 Auxiliary Gauges (Single)
LT Series Version 0 Auxiliary Gauges (Single) Design 887
LT Series Version 1 Auxiliary Gauges (Multiple)
LT Series Version 1 Auxiliary Gauges (Multiple) Design 888
Compartment Temperature (Bus, Engine/Electrical
Compartment Temp Warning)
Compartment Temperature (Bus, Engine/Electrical Compartment Temp Warning)
Design 889
Compressed Air Supply (Bus) (Aux Air Pressure
Gauge, Hydraulic Chassis)
Compressed Air Supply (Bus) (Aux Air Pressure Gauge, Hydraulic Chassis)
Design 890
Compressed Air Supply (Bus, eBus) (Primary &
Secondary Gauge, Dual Air Brake System)
Compressed Air Supply (Bus, eBus) (Primary & Secondary Gauge, Dual Air
Brake System) Design 892
Current Monitoring (Ammeter) (Bus, 400 Amp)
Current Monitoring (Ammeter) (Bus, 400 Amp) Design 893
White LED Clock
White LED Clock Design 894
Wheelchair Warning (MUX Indicator, Buzzer On W/Lift
Door Open)
Wheelchair Warning (MUX Indicator, Buzzer On W/Lift Door Open) Design 895
Wheelchair Warning (MUX Indicator, Mechanical
Buzzer, On W/Lift Door Open, Shuts Off When 4"
Open)
Wheelchair Warning (MUX Indicator, Mechanical Buzzer, On W/Lift Door Open,
Shuts Off When 4" Open) Design 896
Wheelchair Warning (MUX Indicator, Piezo Buzzer On
W/Lift Door Open, Shuts Off When 4" Open)
Wheelchair Warning (MUX Indicator, Piezo Buzzer On W/Lift Door Open, Shuts
Off When 4" Open) Design 897
Cab Dome Lights (CE, Driver Dome,Left/Right w/
Switch)
Cab Dome Lights (CE, Driver Dome,Left/Right w/ Switch) Design 898
TABLE OF CONTENTS
xxxiiCab Dome Lights (CE, Driver Dome, Single)
Cab Dome Lights (CE, Driver Dome, Single) Design 899
Cab Dome Lights (CE, Driver Dome, Single, W/ Switch,
Plus Red Driver Dome)
Cab Dome Lights (CE, Driver Dome, Single, W/ Switch, Plus Red Driver Dome)
Design 900
Cab Dome Lights (CE, Driver Dome, Three, W/ Switch)
Cab Dome Lights (CE, Driver Dome, Three, W/ Switch) Design 901
Cab Dome Lights (W/ Switch, Red Driver Dome)
Cab Dome Lights (W/ Switch, Red Driver Dome) Design 902
Courtesy Step Lighting (CE, Entry Dr Skirt Lt,
Activated by Step Lt, W/ AED Light)
Courtesy Step Lighting (CE, Entry Dr Skirt Lt, Activated by Step Lt, W/ AED Light)
Design 903
Courtesy Step Lighting (CE, Entry Dr Skirt Lt, Activtd
by Step Lt, No AED Lt)
Courtesy Step Lighting (CE, Entry Dr Skirt Lt, Activtd by Step Lt, No AED Lt)
Design 904
Courtesy Step Lighting (CE, N/ Entry Dr Skirt Lt,
Courtesy Step Lighting (CE, N/ Entry Dr Skirt Lt, Activated by Step Lt, W/ AED
Light) Design 905
Electrical Compartment Light (CE)
Electrical Compartment Light (CE) Design 906
Emergency Exit Interior Lighting (Clearance, Left
Door, No Windows)
Emergency Exit Interior Lighting (Clearance, Left Door, No Windows) Design 907
Door, 2 Windows)
Emergency Exit Interior Lighting (Clearance, Left Door, 2 Windows) Design 909
Door, 4 Windows)
Emergency Exit Interior Lighting (Clearance, Left Door, 4 Windows) Design 911
Emergency Exit Interior Lighting (Clearance, Left &
Right Doors, No Windows)
Emergency Exit Interior Lighting (Clearance, Left & Right Doors, No Windows)
Design 913
Right Doors, 2 Windows)
Emergency Exit Interior Lighting (Clearance, Left & Right Doors, 2 Windows)
Design 915
Right Doors, 4 Windows)
Emergency Exit Interior Lighting (Clearance, Left & Right Doors, 4 Windows)
Design 917
TABLE OF CONTENTS
xxxiiiEmergency Exit Interior Lighting (Clearance, No
Doors, 2 Windows)
Emergency Exit Interior Lighting (Clearance, No Doors, 2 Windows) Design 919
Doors, 4 Windows)
Emergency Exit Interior Lighting (Clearance, No Doors, 4 Windows) Design 921
Emergency Exit Interior Lighting (Clearance, Rear
Door, No Windows)
Emergency Exit Interior Lighting (Clearance, Rear Door, No Windows) Design 923
Door, 2 Windows)
Emergency Exit Interior Lighting (Clearance, Rear Door, 2 Windows) Design 925
Door, 4 Windows)
Emergency Exit Interior Lighting (Clearance, Rear Door, 4 Windows) Design 927
Emergency Exit Interior Lighting (Clearance, Rear &
Left Doors, No Windows)
Emergency Exit Interior Lighting (Clearance, Rear & Left Doors, No Windows)
Design 929
Left Doors, 2 Windows)
Emergency Exit Interior Lighting (Clearance, Rear & Left Doors, 2 Windows)
Design 931
Left Doors, 4 Windows)
Emergency Exit Interior Lighting (Clearance, Rear & Left Doors, 4 Windows)
Design 933
Emergency Exit Interior Lighting (Clearance, Rear & Right Doors, No Windows)
Design 935
Emergency Exit Interior Lighting (Clearance, Rear & Right Doors, 2 Windows)
Design 937
Emergency Exit Interior Lighting (Clearance, Rear & Right Doors, 4 Windows)
Design 939
Emergency Exit Interior Lighting (Clearance, Rear,
Emergency Exit Interior Lighting (Clearance, Rear, Left & Right Doors, No
Windows) Design 941
Left, Right Doors, 2 Windows)
Emergency Exit Interior Lighting (Clearance, Rear, Left, Right Doors, 2 Windows)
Design 943
TABLE OF CONTENTS
xxxivEmergency Exit Interior Lighting (Clearance, Rear,
Left, Right Doors, 4 Windows)
Emergency Exit Interior Lighting (Clearance, Rear, Left, Right Doors, 4 Windows)
Design 945
Emergency Exit Interior Lighting (Clearance, Right
Door, No Windows)
Emergency Exit Interior Lighting (Clearance, Right Door, No Windows) Design947
Door, 2 Windows)
Emergency Exit Interior Lighting (Clearance, Right Door, 2 Windows) Design 949
Door, 4 Windows)
Emergency Exit Interior Lighting (Clearance, Right Door, 4 Windows) Design 951
Emergency Exit Interior Lighting (Ignition, Rear Door
Only)
Emergency Exit Interior Lighting (Ignition, Rear Door Only) Design 953
Entrance Door Lighting (CE PWL Activated, W/5s
Timer)
Entrance Door Lighting (CE PWL Activated, W/5s Timer) Design 955
Entrance Door Lighting (CE, Step Lt Activated W/ 5s
Timer)
Entrance Door Lighting (CE, Step Lt Activated W/ 5s Timer) Design 956
Entrance Door Lighting (CE, Stop Arm Activated, W/
5s Timer)
Entrance Door Lighting (CE, Stop Arm Activated, W/ 5s Timer) Design 957
Bus Passenger Dome Lights (CE, Single Switch, Two
Full Rows, 10 Lights)
Bus Passenger Dome Lights (CE, Single Switch, Two Full Rows, 10 Lights)
Design 958
Full Rows, 12 Lights)
Bus Passenger Dome Lights (CE, Single Switch, Two Full Rows, 12 Lights)
Design 962
Full Rows, 14 Lights)
Bus Passenger Dome Lights (CE, Single Switch, Two Full Rows, 14 Lights)
Design 966
Full Rows, 6 Lights)
Bus Passenger Dome Lights (CE, Single Switch, Two Full Rows, 6 Lights)
Design 970
Full Rows, 8 Lights)
Bus Passenger Dome Lights (CE, Single Switch, Two Full Rows, 8 Lights)
Design 972
TABLE OF CONTENTS
xxxvStorage Compartment (Luggage) (Bus, 6 Luggage
Compartment Lights)
Storage Compartment (Luggage) (Bus, 6 Luggage Compartment Lights)
Design 976
Height Control (LiquidSpring)
Height Control (LiquidSpring) Design 978
Seats - Climate Controlled (Drivers Heated Seat W/ Air
Compressor)
Seats - Climate Controlled (Drivers Heated Seat W/ Air Compressor) Design 981
Seats - Climate Controlled (Drivers Heated Seat)
Seats - Climate Controlled (Drivers Heated Seat) Design 982
Seats - Electrical Power (CE Self-Contained Air Seat)
Seats - Electrical Power (CE Self-Contained Air Seat) Design 983
Seats - Electrical Power (CE Self-Contained Heated Air
Seat)
Seats - Electrical Power (CE Self-Contained Heated Air Seat) Design 984
Seatbelt Reminder (Warning) (Bus, No Park Brake
Buzzer)
Seatbelt Reminder (Warning) (Bus, No Park Brake Buzzer) Design 985
Seatbelt Reminder (Warning) (Bus, W/ Park Brake
Buzzer)
Seatbelt Reminder (Warning) (Bus, W/ Park Brake Buzzer) Design 986
Transmission (Allison 1K/2K)
Transmission (Allison 1K/2K) Design 987
Transmission (Allison 3K/4K)
Transmission (Allison 3K/4K) Design 988
Hill Start Aid (HSA) (Bendix CA 2.0)
Hill Start Aid (HSA) (Bendix CA 2.0) Design 989
Transmission Shifter (T-Handle for Allison W/ Park
Position)
Transmission Shifter (T-Handle for Allison W/ Park Position) Design 990
Transmission Shifter (Universal Stalk Shifter - Allison
1K/2K N/Park Position)
Transmission Shifter (Universal Stalk Shifter - Allison 1K/2K N/Park Position)
Design 991
1K/2K W/Park Position)
Transmission Shifter (Universal Stalk Shifter - Allison 1K/2K W/Park Position)
Design 992
3K/4K)
Transmission Shifter (Universal Stalk Shifter - Allison 3K/4K) Design 993
Windshield Washer Pump W/O Low Fluid Sensor
Windshield Washer Pump W/O Low Fluid Sensor Design 994
TABLE OF CONTENTS
xxxviWindshield Washer Pump & Low Fluid Sensor (MV,
CE)
Windshield Washer Pump & Low Fluid Sensor (MV, CE) Design 995
Windshield Wipers
Windshield Wipers Design 996
Battery Disconnect (Switch Only)
Battery Disconnect (Switch Only) Design 997
Battery Isolator
Battery Isolator Design 998
Charging System (Delco Remy 28SI Alternator N/
Remote Sense)
Charging System (Delco Remy 28SI Alternator N/ Remote Sense) Design 999
Charging System (Delco Remy & Mitsubishi Alternator
W/ Remote Sense)
Charging System (Delco Remy & Mitsubishi Alternator W/ Remote Sense)
Design 1000
Charging System (Leece-Neville AVI160-
160A/210A/240A N/ Remote Sense, Skelstart)
Charging System (Leece-Neville AVI160-160A/210A/240A N/ Remote Sense,
Skelstart) Design 1001
Charging System (Leece-Neville - LN 325A Alternator
W/ Remote Sense)
Charging System (Leece-Neville - LN 325A Alternator W/ Remote Sense)
Design 1002
Charging System (LH160_LH200)
Charging System (LH160_LH200) Design 1003
Cranking (Starter) (BCM Controlled & N/ Wired
Thermal Overcrank, Skelstart)
Cranking (Starter) (BCM Controlled & N/ Wired Thermal Overcrank, Skelstart)
Design 1004
Thermal Overcrank, W/ Disconnect)
Cranking (Starter) (BCM Controlled & N/ Wired Thermal Overcrank, W/
Disconnect) Design 1005
Operator Input (Key Switch) (W/ Starter Interrupt)
Operator Input (Key Switch) (W/ Starter Interrupt) Design 1006
Battery International (3) 12V
Battery International (3) 12V Design 1007
Connectors 1008
Index 3626
- International DT466,DT570,HT570 Diesel Engine Service Manual
- International DT466E Wiring Schematic
- International 365, 444, 466, 530 Service Manuals
- Navistar Diagnostic Trouble Code Index
- SCANIA 420 DC11 - DC12 Motor
- International 9800 Electrical Schematic
- International Truck DT466E Engine Repair Manual
- International - VT365 Schematic (SPA)
- Scania Manual Transmission GRS900
- International Truck 5000i,9200i,9400i and 9900i Chassis Built Electrical Circuit Diagram
- International Trucks Body Controller Diagnostic Trouble Codes
- International Wiring Diagram
- International Truck CF500 CF600 Service Manual
- Scania Manual Transmission GR 900
- International DT466, DT530 Electronic Diagram
