Momed80
150
35,046
International School Bus IC Bus BE CE Series Electrical Diagrams 0000020182 2021
Brand: International, Navistar
Type of Machine: Bus
Type of Manual: Electrical Diagram, Circuit Diagram
Model: International 2016 - 2021 IC Bus BE CE Series
Part Number: 0000020182
Publication Date: 2021
Number of Pages: 1523 Pages
Chapter 1 - Table Of Contents
Chapter 2 (Ae08090653) - Instructions And Charts
Abbreviations
Acronyms
Circuit Diagram Instructions
Circuit Number Identification And Color
Circuit Number Identification And Color (Cont.)
Circuit Name Composition
Circuit/Insulation Color
Lamp Bulb Chart
Relay Function And Wiring Guide
Schematic Symbol Chart
Schematic Symbol Chart (Cont.)
Ce Bus Layout
Ce Bus Layout (Cont.)
Fuse Graphic-Platform And Electrical Panel - 4214351c1
Fuse Graphic-Platform And Electrical Panel - 4214351c1 (Cont.)
Product Graphic-Bus Body Electrical Panel Harness
Product Graphic-Fuse Block Platform Harness
Terminal/Heat Shrink(Hst) Information
Acronyms Electric Vehicles
Terminal/Heat Shrink(Hst) Information (Cont.)
Chapter 3 (Ae08090654) - 12 Volt Power Distribution And Datalink
Battery Feed - Platform
Battery Feed – Platform (Cont.)
Accessory Feed - Platform
Ignition Feed - Platform
Ignition Feed - Platform (Cont.)
Battery Feed - Electrical Panel
Battery Feed - Electrical Panel (Cont.)
Accessory Feed - Electrical Panel
Accessory Feed - Electrical Panel (Cont.)
Ignition Feed - Electrical Panel
Ignition Feed - Electrical Panel (Cont.)
Body Circuit - Noise Suppression
Body Circuit - Noise Suppression (Cont.)
Body Circuit - Master Disconnect
Body Circuit - Master Disconnect (Cont.)
N2 Communications Module Effects W/Cummins Connectivity
N2 Communications Module Effects W/2017-Isb-Diesel & F-2018 Propane/Gas Engine .
Ignition Splice Pack (5 Amp Max)
Ignition Splice Pack W/2017-Isb-Diesel & F-2018 Propane/Gas Engine
Accessory Splice Relay Coils
Accessory Splice Relay Coils (Cont.)
Body Ground – Platform
Body Ground – Platform (Cont.)
Body Ground – Electrical Panel
Body Ground – Electrical Panel (Cont.)
Body Ground – Front Cap
Body Ground – Front Cap (Cont.)
Body Ground – Rear Cap
Body Ground – Rear Cap (Cont.)
Body Ground – Sealed Engine
Body Ground – Sealed Engine (Cont.)
Body Ground – Chassis W/2017 Isb /2021 B6.7 Diesel Engine
Body Ground – Chassis W/F-2018 Propane / Gas Engine
Body Ground – Right Body
Body Ground – Right Body (Cont.)
Body Ground – Left Body
Body Ground – Left Body (Cont.)
Zero Volt Reference Splice
Zero Volt Reference Splice (Cont.)
Engine Ground – W/2017 Isb /2021 B6.7 Diesel Engine
Engine Ground – W/F-2018 Propane Engine
Engine Ground – W/F-2018 Gas Engine
Battery Ecm Positive/Negative Conn W/2017 Isb /2021 B6.7 Diesel Engine
Battery Ecm Positive/Negative Conn W/F-2018 Propane Engine
Battery Ecm Positive/Negative Conn W/F-2018 Gas Engine
Dc Power Effects
Dc Power Effects W/2017 Isb Diesel Engine
Battery Isolator
J1939 Datalink W/500k W/Lct/Wtec Xmsn W/2017 Isb /2021 B6.7 Diesel Engine &
J1939 Datalink W/500k W/Lct/Bendix Abs-8 W/2017 Isb /2021 B6.7 Diesel &
J1939 Datalink W/500k W/Lct/Abs-8/Zonar W/2017 Isb /2021 B6.7 Diesel &
J1939 Datalink W/500k W/Lct/Wingman/Zonar W/2017 Isb /2021 B6.7 Diesel &
J1939 Datalink W/500k W/Lct/Bendix Fusion W/2017 Isb /2021 B6.7 Diesel &
J1939 Datalink W/500k W/Lct/Bendix Wingman W/2017 Isb /2021 B6.7 Diesel &
J1939 Datalink W/500k W/Lct/Fusion/Zonar W/2017 Isb /2021 B6.7 Diesel &
J1939 Datalink W/500k W/Lct Or E-Pro W/2017 Isb /2021 B6.7 Diesel &
J1939 Datalink W/500k W/Lct Or E-Pro W/Zonar W/2017 Isb /2021 B6.7 Diesel &
J1939 Datalink W/500k W/Wtec W/2017 Isb / 2021 B6.7 Diesel Engine
J1939 Datalink W/500k W/Wtec W/Zonar W/2017 Isb / 2021 B6.7 Diesel Engine
J1939 Datalink W/500k W/Wtec W/Bendix Abs-8 W/2017 Isb / 2021 B6.7 Diesel Engine
J1939 Datalink W/500k W/Wtec W/Bendix Wingman W/2017 Isb / 2021 B6.7 Diesel Engine
J1939 Datalink W/500k W/Wtec W/Bendix Abs-8 W/Zonar W/2017 Isb / 2021 B6.7 Diesel Engine .
J1939 Datalink W/500k W/Wtec W/Bendix Wingman W/Zonar W/2017 Isb /
J1939 Datalink W/500k W/Wtec W/Bendix Fusion W/Zonar W/2017 Isb /
J1939 Datalink W/500k W/Wtec W/Bendix Fusion W/2017 Isb / 2021 B6.7 Diesel Engine
J1939 Datalink W/500k W/Allison Xmsn W/2017 Isb / 2021 B6.7 Diesel Engine
J1939 Datalink W/500k W/Allison Xmsn W/Pto W/2017 Isb / 2021 B6.7 Diesel Engine
J1939 Datalink W/500k W/Eaton Procision Xmsn W/2017 Isb / 2021 B6.7 Diesel Engine
J1939 Datalink W/Public Can N/Enhanced Vcm Function W/F-2018 Propane Engine
J1939 Datalink W/Public Can W/Enhanced Vcm Function W/F-2018 Propane Engine
J1939 Datalink W/Public Can N/Pam W/F-2018-Gas Engine
J1939 Datalink W/500k W/Enhanced Vcm Functions W/2017 Isb /2021 B6.7 Diesel &
Driver Interface Unit W/2017 Isb /2021 B6.7 Diesel & W/F-2018 Propane/Gas Engine
Battery Feed – Platform W/2017-Isb-Diesel & F-2018 Propane/Gas Engine
Accessory Feed – Platform W/2017-Isb-Diesel & F-2018 Propane/Gas Engine
Ignition Feed – Platform W/2017-Isb-Diesel & F-2018 Propane/Gas Engine
Ignition Feed – Platform W/2017-Isb-Diesel & F-2018 Propane/Gas Engine (Cont.)
Body Circuit – Battery Feed Electrical Panel
Circuit -Battery Feed Electrical Panel (Cont.)
Body Circuit -Battery Feed Electrical Panel (Cont.)
Body Circuit - Battery Feed Electrical Panel (Cont.)
Body Circuit - Acc And Ign Feed Electrical Panel
Body Circuit - Noise Suppression(Cont.)
Body Ground - Platform
Body Ground - Platform (Cont.)
Body Ground - Electrical Panel
Body Ground - Electrical Panel (Cont.)
J1708 Datalink Complete W/Wtec Xmsn W/Body Controller W/2017-Isb-Diesel Engine
J1708 Datalink Complete W/Wtec Xmsn W/Body Controller W/2017-Isb-Diesel Engine (Cont.)
J1939 Data Link Complete W/Body Controller W/2017-Isb-Diesel Engine
J1939 Datalink Basic W/Lct Or Eaton Xmsn W/Body Controller W/2017-Isb-Diesel Engine
J1939 Datalink Basic W/Wtec Xmsn W/Body Controller W/2017-Isb-Diesel Engine
J1939 Datalink Basic W/Lct Or Eaton & W/Wtec Xmsn W/Body Controller W/
J1939 Datalink W/500k W/2017-Isb-Diesel Engine
J1939 Datalink W/500k W/Lct Xmsn Or E-Pro W/2017-Isb-Diesel-Engine
J1939 Datalink W/500k W/Lct Xmsn Or E-Pro & W/Zonar W/2017-Isb-Diesel Engine
J1939 Datalink W/500k W/Lct Xmsn W/Bendix Wingman W/2017-Isb-Diesel Engine
J1939 Datalink W/500k W/Lct Xmsn W/Bendix Wingman & Zonar W/2017-Isb-Diesel Engine
J1939 Datalink W/500k W/Lct Xmsn & Abs-8 W/2017-Isb-Diesel Engine
J1939 Datalink W/500k W/Lct Xmsn & Abs-8 & Zonar W/2017-Isb-Diesel Engine
J1939 Datalink W/500k W/Lct Xmsn & Bendix Fusion W/2017-Isb-Diesel Engine
J1939 Datalink W/500k W/Wtec Xmsn W/Bendix Wingman W/2017-Isb-Diesel Engine
J1939 Datalink W/500k W/Wtec Xmsn W/Bendix Wingman & Zonar W/2017-Isb-Diesel Engine
J1939 Datalink W/500k W/Wtec Xmsn & Abs-8 W/2017-Isb-Diesel Engine
J1939 Datalink W/500k W/Wtec Xmsn & Abs-8 & Zonar W/2017-Isb-Diesel Engine
J1939 Datalink W/500k W/Wtec Xmsn W/2017-Isb-Diesel Engine
J1939 Datalink W/500k W/Wtec Xmsn & W/Zonar W/2017-Isb-Diesel Engine
J1939 Datalink W/500k W/Wtec Xmsn Fusion & Zonar W/2017-Isb-Diesel Engine
J1939 Datalink W/500k W/Allison Xmsn W/2017-Isb-Diesel Engine
J1939 Datalink W/500k W/Eaton Procision Xmsn W/2017-Isb-Diesel Engine
J1939 Datalink W/500k W/Enhanced Vcm Features W/2017-Isb-Diesel Engine
J1939 Datalink W/250k W/Lct Xmsn W/2017-Isb-Diesel & F-2018-Propane/Gas-Engine
J1939 Datalink W/250k W/Lct Xmsn W/F-2018-Propane/Gas-Engine
J1939 Datalink W/250k W/Lct Xmsn W/F-2018-Propane-Engine
J1939 Datalink W/250k W/Lct Xmsn W/F-2018-Gas-Engine
J1939 Datalink W/500k W/Lct Xmsn W/Bendix Fusion W/F-2018-Propane/Gas-Engine
J1939 Datalink W/500k W/Lct Xmsn W/Bendix Fusion & Zonar W/F-2018-Propane/Gas-Engine
J1939 Datalink W/500k W/Lct Xmsn W/Bendix Wingman W/F-2018-Propane/Gas-Engine
J1939 Datalink W/500k W/Lct Xmsn W/Bendix Wingman & Zonar W/F-2018-Propane/Gas-Engine
J1939 Datalink W/500k W/Lct Xmsn W/Bendix Abs-8 W/F-2018-Propane/Gas-Engine
J1939 Datalink W/500k W/Lct Xmsn W/Bendix Abs-8 & Zonar W/F-2018-Propane/Gas-Engine
J1939 Datalink W/500k W/Lct Xmsn W/Bendix Abs-6 W/F-2018-Propane/Gas-Engine
J1939 Datalink W/500k W/Lct Xmsn W/Bendix Abs-6 & Zonar W/F-2018-Propane/Gas-Engine
Chapter 4 (Ae08090655) - Charging And Cranking System
Charging And Cranking - W/Enhanced Vcm Function W/2017 Isb /2021 B6.7 Diesel Engine
Charging And Cranking - W/F-2018-Propane-Engine
Charging And Cranking - W/F-2018-Propane-Engine (Cont.)
Charging And Cranking - W/F-2018-Gas-Engine
Grid Heater Connections W/2017 Isb /2021 B6.7 Diesel Engine
Cab Feed And Frame Ground Connections W/F-2018-Propane/Gas-Engine
Charging And Cranking - W/2017-Isb-Diesel Engine
Charging And Cranking - W/F-2018-Propane/Gas-Engine
Chapter 5 (Ae08090656) - Gauges And Warning Lights
Instrument Gauge Cluster W/2017 Isb /2021 B6.7 Diesel & F-2018-Propane/Gas-Engine
Fuel Gauges W/2017 Isb /2021 B6.7 Diesel Engine
Fuel Gauges W/F-2018-Propane/Gas-Engine
Engine Compartment Temp Indicator
Engine Compartment Temp Indicator (Cont.)
Lift Door Indicator Effects
Temperature Display
Body Builder Connections
Pam Module And Ammeter Connections W/2017 Isb /2021 B6.7 Diesel Engine
Crossing Gate And Ammeter Connections W/F-2018-Propane/Gas-Engine
Ammeter Connection W/400a W/2017 Isb /2021 B6.7 Diesel Engine
Pam Module Connections W/2017-Isb-Diesel Engine
Seat Belt Alarm Effects W/2017 Isb /2021 B6.7 Diesel & F-2018-Propane/Gas-Engine
Seat Belt Alarm Effects W/2017 Isb /2021 B6.7 Diesel & F-2018-Propane/Gas-Engine (Cont.)
Seat Belt Alarm Effects W/2017-Isb-Diesel & F-2018-Propane/Gas-Engine
Gasoline Fuel Tank With Air And Hydraulic Brakes W/F-2018-Gas-Engine
Gasoline Fuel Tank With Air And Hydraulic Brakes W/F-2018-Gas-Engine (Cont.)
Propane Fuel Tank With Air And Hydraulic Brakes W/F-2018-Propane-Engine
Propane Fuel Tank With Air And Hydraulic Brakes W/F-2018-Propane-Engine (Cont)
Chapter 6 (Ae08090657) - Pupil Warning Light Activation
Pupil Warning Light Controls W/Red Light
Pupil Warning Light Controls W/Amber Light
Pupil Warning Light W/8 Lamp Light Monitor
Pupil Warning Light W/8 Lamp Light Monitor (Cont)
Pupil Warning Light Controls N/Light Monitor
Pupil Warning Light Controls N/Light Monitor (Cont)
Pupil Warning Light Controls N/Light Monitor W/Additional Warning Light
Pupil Warning Light W/Rear Lights
Pupil Warning Light W/Red And Blue Light W/9
Pupil Warning Light Indicators W/Right Light
Pupil Warning Lights W/Switch Panel Indicator Monitor
Pupil Warning Lights W/Switch Panel Indicator Monitor (Cont)
Pupil Warning Light W/Driver Alert Sign W/Above Bumper
Flasher System Master Switch Effects
Flasher System Master Switch Effects (Cont)
Left Mounted Master Switch Effects
Master Flasher Switch W/Momentary Cancel W/Omit
Right Side Master Flasher Switch Effects
Flasher Start Switch Effects
Left Panel Mounted Override Switch Effects
Red Override Switch Effects
Left Mounted Master Switch W/Single Cycle Cancel
Left Mounted Master Switch W/Warn & Rrx Cancel W/3 Position Switch
Chapter 7 (Ae08090658) - External Lights
Backup Lights
Backup Lights (Cont)
Backup Lights Activated By Rear Emergency Exit
Backup Lights With Additional Lights
Destination Sign Front And Rear W/Dual Switch
Destination Sign Front And Rear W/Single Switch
Destination Sign Activated By Clearance Lights
Strobe Light Activated W/Ignition
Strobe Light Activated W/Switch
Strobe Light Activated W/Switch Or Sarm
Strobe Light Activated W/Switch Or Sarm W/9
Strobe Light Activated W/Switch Or Pupil Warning Light
Strobe Light Activated W/Mom Switch
Double Strobe Light N/7 Window
Double Strobe Light W/7 Window
Strobe Light Indicator
Stop/Tail/Directional Lights
Stop / Tail / Directional / License Plate Light
Stop/Tail/Turn Lights W/Check N/Child Check Mate W/9
Stop/Tail/Turn Lights W/Check W/Child Check Mate W/9
Stop/Tail/Turn Lights W/Video Light Monitor W/9
Stop/Tail/Turn Lights W/Check W/Theft Mate W/9
Stop/Tail/Turn Lights W/Check W/Video W/Theft Mate W/9
Stop/Tail/Turn Lights W/Seon W/Additional Power W/9
Stop/Tail/Turn Lights N/Check N/Child Check Mate W/9
Stop/Tail/Turn Lights N/Check W/Child Check Mate W/9
Stop/Tail/Turn Lights W/Video Prewire W/9
Stop/Tail/Turn Lights N/Check W/Theft Mate W/9
Stop/Tail/Turn Lights N/Video W/Theft Mate W/9
Stop/Tail/Turn Lights W/Video & Ccm & Snooze W/9
Stop/Tail/Turn Lights W/Check W/Snooze W/9
Stop/Tail/Turn Lights W/Video W/Lt Monitor W/9
Stop/Tail/Turn Lights W/Video Ccm & Snooze W/9
Left Side Directional Lights
Left Side Directional Lights (Cont.)
Right Side Directional Lights
Right Side Directional Lights (Cont.)
Combination Light After Entrance Door And Forward Or Rear Wheel Pocket W/R Body
Marker Light After Entrance Door And After Rear Wheel Pocket W/R Body
Combination Light After Entrance Door And Forward Or Rear Wheel Pocket W/L Body
Marker Light After Entrance Door And After Rear Wheel Pocket W/L Body
Directional Lights N/Cowl Mounted
Directional Lights W/Cowl Mounted
Directional And Marker Combination Lights W/Cowl Mounted W/2017 Isb /
2021 B6.7 Diesel & W/F-2018-Propane/Gas-Engine
Directional Lights N/Cowl Mounted W/2017 Isb Diesel & W/F-2018-Propane/Gas-Engine
Corner Marker Lights
Clearance/Identification Lights (Standard)
Clearance/Identification Lights Activated By Emergency Exit Light
Clearance/Identification Lights/Dual Corner/Activated By Emergency Exit Light
Clearance/Identification Lights/Dual Corner/Ceiling Mounted Rear Emergency Exit Light .
Clearance/Identification Lights & Ceiling Mounted Rear Emergency Exit Light &
Right Rear Marker Light
Intermediate/Side Marker Light/3 Inch Light Over Kick Out Window W/L Body
Intermediate/Side Marker Light/3 Inch Light Over Kick Out Window W/R Body
Directional/Clearance Light Splice
Directional/Clearance Light Splice (Cont.)
Head Lights W/2017 Isb /2021 B6.7 Diesel Engine
Head Lights W/Pedestal Mount W/2017 Isb /2021 B6.7 Diesel Engine
Head Lights N/Pedestal Mount W/2017 Isb /2021 B6.7 Diesel Engine
Head Lights W/F-2018-Propane/Gas-Engine
Head Lights W/Child Reminder System
Fog Lights
Fog Lights W/Diesel & W/F-2018-Propane/Gas-Engine
Pedestrian Lights
Pedestrian Lights
Switch Illumination Splice
Luggage Compartment Light W/Panel Mounted Switch
Lower Panel Mounted Hazard Switch W/ Steering Column Switch
Clearance Light Connection
Sed Landing Light
Sed Landing Light
Full/Rear View Camera W/Standalone Display W/Diesel & W/F-2018-Propane/Gas-Engine
Full/Rear View Camera W/Mirror Display W/Diesel & W/F-2018-Propane/Gas-Engine
Brake Monitoring Effects
Chapter 8 (Ae08090659) - Internal Lights
Guard Dome Light
Activity Dome Light
Engine Compartment Lights
Electrical Compartment Lights
Front Amber Cluster Lights
Rear Door Splice Connections
Dome Light Rheostat
Rear Row Dome Lights
Rear Row Dome Lights (Cont.)
Dome Lights W/Ignition Feed W/Rheostat
Drivers Dome Lights Activated By Step Light
Drivers Dome Lights W/1 Inch/Red
Dome Light W/Single Switch
Dome Light W/Single Switch (Cont.)
Dome Light W/Split Switch
Dome Light W/Split Switch (Cont.)
Dome Light Activated By Timer W/2min
Dome Light Activated By Timer W/2min W/Rear Row
Dome Light Activated By Timer W/2 Min W/Rear Row W/Emergency Exit
Dome Light Activated By Emergency Exit
Dome Light Activated By Emergency Exit W/Rear Row
Dome Light Activated By Entrance Door
Dome Light Activated By Entrance Door W/Rear Row
Dome Light W/2 Min W/Rear Row W/Emergency Exit
Step Well Lights
Step Well Lights (Cont.)
Primary Switch Illumination
Panel Lights
Panel Lights (Cont.)
Switch Panel Illumination
Switch Panel Illumination (Cont.)
Dome Light Feed
Dome Light Feed (Cont.)
Standard Stagger Dome Light W/Rear Row
Standard Stagger Switched Dome Light Front And Rear W/Rear Row
Standard Stagger Switched Dome Light Front And Rear W/Rear Row W/6 Window
Double Dome Light W/Rear Row W/L Body
Double Dome Light W/Rear Row W/R Body
Double Dome Light W/Rear Row W/12-13 Window W/R Body
Double Dome Light W/Rear Row W/6 Window W/R Body
Double Switched Dome Light Front And Rear W/L Body
Double Switched Dome Light Front And Rear W/R Body
Double Switched Dome Light Front And Rear W/Rear Row W/5-10 Window W/L Body
Double Switched Dome Light Front And Rear W/Rear Row W/11-13 Window W/L Body
Double Switched Dome Light Front And Rear W/Rear Row W/5-13 Window W/R Body
Dome Light Above Each Seat W/L Body
Dome Light Above Each Seat W/R Body
Lighted Steering Wheel Switches W/2017 Isb /2021 B6.7 Diesel &
N/Lighted Steering Wheel Switches W/2017 Isb /2021 B6.7 Diesel &
Switch Pack W/2017 Isb /2021 B6.7 Diesel & W/F-2018-Propane/Gas-Engine
Dome Light 10 Led
Dome Light 12 Led
Dome Light Activated By Lift Door
Chapter 9 (Ae08090660) - Stop Arm / Crossing Gate
Front And Rear Or Rear Only Stop Arm
Front And Rear Or Rear Only Stop Arm (Cont.)
Stop Arm Extend
Air/Electric Stop Arm/Xgt Cancel Switch
Right Stop Arm/Crossing Gate Cancel Switch
Stop Arm And Xgt Valve W/Xgt Cancel
Air Stop Arm Valve
Crossing Gate Valve
Crossing Gate W/2017 Isb /2021 B6.7 Diesel Engine
Crossing Gate W/300a W/F-2018-Propane/Gas-Engine
Crossing Gate W/150a W/2017 Isb /2021 B6.7 Diesel Engine
Sarm Strobe Hi/Lo Intensity Switch
Chapter 10 (Ae08090661) - Mirror System
Heated And Motorized Mirror
Heated And Motorized Mirror (Cont.)
Motorized Mirror
Heated Mirror - Left And Right Overhead
Heated Crossview Mirrors
Heated And Motorized Mirror W/Lower Mount
Chapter 11 (Ae08090662) - Engine And Engine System
Electronic Engine Control W/2017 Isb /2021 B6.7 Diesel Engine
Electronic Engine Control W/2017 Isb /2021 B6.7 Diesel Engine (Cont.)
Def And Aftertreatment W/2017 Isb /2021 B6.7 Diesel Engine
Def And Aftertreatment W/2017 Isb /2021 B6.7 Diesel Engine (Cont.)
Fan Wiring W/2017 Isb /2021 B6.7 Diesel Engine
Freon Compressor Wiring W/2017 Isb /2021 B6.7 Diesel Engine
Electronic Engine Control W/F-2018-Propane-Engine
Electronic Engine Control W/F-2018-Propane-Engine (Cont.)
Freon Compressor Wiring W/F-2018-Propane-Engine
Electronic Engine Control W/F-2018-Gas-Engine
Electronic Engine Control W/F-2018-Gas-Engine (Cont.)
Freon Compressor Wiring W/F-2018-Gas-Engine
Chapter 12 (Ae08090663) - Transmission And Transmission System
Economy Mode Relay Connections
Economy Mode Relay Connections (Cont)
Shift Inhibit Relay Connections
Shift Inhibit Relay
Shift Selector Connections
Shifter Interlock Effects
Shifter Interlock Effects (Cont.)
1/2000 Allison Xmsn Gen5 (Lct) W/Bcm Gen4 W/2017 Isb /2021 B6.7 Diesel Engine
1/2000 Allison Xmsn Gen5 (Lct) W/Bcm Gen4 W/2017 Isb /2021 B6.7 Diesel Engine (Cont.)
Allison Xmsn Lct W/2017 Isb Diesel Engine
3000 Allison Xmsn Gen5 (Wtec) W/Bcm Gen4 W/2017 Isb /2021 B6.7 Diesel Engine
3000 Allison Xmsn Gen5 (Wtec) W/Bcm Gen4 W/2017 Isb /2021 B6.7 Diesel Engine (Cont.)
1/2/3000 Allison Xmsn Gen5 (Wtec/Lct) W/Bcm Gen4 W/2017 Isb /2021 B6.7 Diesel Engine .
1/2/3000 Allison Xmsn Gen5 (Wtec/Lct) W/Bcm Gen4 W/2017 Isb Diesel Engine
3000 Allison Xmsn Gen5 W/Pto W/Bcm Gen4 W/2017 Isb /2021 B6.7 Diesel Engine
3000 Allison Xmsn Gen5 W/Pto W/Bcm Gen4 W/2017 Isb /2021 B6.7 Diesel Engine (Cont.)
Eaton Procision Xmsn W/2017 Isb /2021 B6.7 Diesel Engine
Eaton Procision Xmsn W/2017 Isb /2021 B6.7 Diesel Engine (Cont.)
Eaton Procision Xmsn W/Push Button & W/T-Handle Trs W/2017 Isb Diesel Engine
Eaton Procision Xmsn W/ Push Button & W/T-Handle Trs W/2017 Isb Diesel Engine (Cont)
J1939 Eaton Procision Xmsn W/250k
J1939 W/500k Eaton Procision Xmsn W/4100
Eaton Procision Transmission W/Push Button W/F-2017-Isb-Engine
1/2000 Allison Xmsn Gen 4/5 (Lct) W/F-2018-Propane-Engine
1/2000 Allison Xmsn Gen 4/5 (Lct) W/F-2018-Propane-Engine (Cont.)
1/2000 Allison Xmsn Gen 4/5 (Lct) W/F-2018-Gas-Engine
1/2000 Allison Xmsn Gen 4/5 (Lct) W/F-2018-Gas-Engine (Cont.)
1/2000 W/Gen 4/5 Allison Lct Xmsn W/F-2018-Propane/Gas-Engine
1/2000 W/Gen 4/5 Allison Lct Xmsn W/F-2018-Propane/Gas-Engine (Cont)
Allison Lct Gen5 W/ Arens Shifter
Chapter 13 (Ae08090664) - Chassis System
Air Dryer And Drain Valve System W/2017 Isb /2021 B6.7 Diesel &
Automatic Drain Valve Effects W/Haldex Drain Valve
Automatic Drain Valve Effects W/Haldex Drain Valve (Cont.)
Air Compressor On Hydraulic Chassis W/2017 Isb /2021 B6.7 Diesel &
Park Brake Signal W/2017 Isb /2021 B6.7 Diesel & W/F-2018-Propane/Gas-Engine
Park Brake Signal W/2017-Isb-Diesel & W/F-2018-Propane/Gas-Engine
Air Solenoid Effects W/4 Pack W/2017 Isb /2021 B6.7 Diesel & W/F-2018-Propane/Gas-Engine.
Windshield Wiper Effects W/Ce Bus Wiper Motor Wiring
Windshield Wiper Effects W/Ce Bus Wiper Motor Wiring (Cont.)
Remote Hazard Switch Effects W/Tilting & Telescoping
Windshield Wiper Effects W/Wiper Motor Wiring W/2017-Isb-Diesel &
W/F-2018-Propane/Gas-Engine (Cont.)
Remote Hazard Switch Effects W/Tilting & Telescoping W/2017-Isb-Diesel &
Air Horn Effects W/2017 Isb /2021 B6.7 Diesel & W/F-2018-Propane/Gas-Engine
Air Horn Effects W/2017-Isb-Diesel & W/F-2018-Propane/Gas-Engine
Traction Aids Effects W/Traction Chain
Tire Winch Effects
Fire Suppression System W/Jomarr Vts12 W/Pressure Switch
Fire Suppression W/Indicator N/Buzzer W/2017-Isb-Diesel Engine
Fire Suppression System W/12 And 13 Window Bus
Passenger Pull Cord System
Liquid Spring Suspension Effects
Liquid Spring Suspension Effects (Cont.)
Fuel Heater System W/2017 Isb /2021 B6.7 Diesel Engine
Regen Switch Effects W/Relocated W/2017 Isb /2021 B6.7 Diesel Engine
Mgm E-Stroke Brake Monitor W/2017 Isb /2021 B6.7 Diesel Engine
Mgm E-Stroke Brake Monitor W/2017-Isb-Diesel Engine
Air Brake W/Abs6 W/Gen4 Bc W/Atc W/2017 Isb /2021 B6.7 Diesel Engine
Air Brake W/Abs6 W/Gen4 Bc W/Atc W/2017 Isb /2021 B6.7 Diesel Engine (Cont.)
Air Brake W/Abs6 W/L Mega Bracket W/2017 Isb /2021 B6.7 Diesel Engine
Wabco Air Abs W/2017 Isb /2021 B6.7 Diesel Engine
Wabco Air Abs W/2017 Isb /2021 B6.7 Diesel Engine (Cont.)
Wabco Air Abs W/L Mega Bracket W/2017 Isb /2021 B6.7 Diesel Engine
Bendix Abs-8 W/Ec 80 W/Gen 4 Bc N/Atc W/2017 Isb /2021 B6.7 Diesel Engine
Bendix Abs-8 W/Ec 80 W/Gen 4 Bc W/Atc W/2017 Isb /2021 B6.7 Diesel Engine
Bendix Abs-8 W/Ec 80 W/Gen 4 Bc W/Stability Control W/2017 Isb /2021 B6.7 Diesel Engine
Bendix Abs-8 W/Ec 80 W/Gen 4 Bc W/Fusion & Wingman W/2017 Isb /2021 B6.7 Diesel Engine
Hydraulic Brake W/2017 Isb /2021 B6.7 Diesel Engine
Hydraulic Brake W/2017 Isb /2021 B6.7 Diesel Engine (Cont.)
Hydraulic Brake W/Air Compressor V8 W/L Mega Bracket W/2017 Isb /
Hydromax Hydraulic Brakes W/Manual Park Brake W/2017 Isb /
Hydromax Hydraulic Brakes W/Wabco Mk25 W/Stability Control W/2017 Isb /
Hydromax Hydraulic Brakes W/Wabco Mk25 W/Stability Control W/2017-Isb-Diesel Engine
Bendix Abs-6 N/Atc W/F-2018-Propane/Gas-Engine
Bendix Abs-6 W/Atc W/F-2018-Propane/Gas-Engine
Bendix Abs-6 W/Park Brake Buzzer W/F-2018-Propane/Gas-Engine
Bendix Abs-8 W/Ec 80 W/Gen 4 Bc W/Atc W/F-2018-Propane/Gas-Engine
Bendix Abs-8 W/Ec 80 W/Gen 4 Bc N/Atc W/F-2018-Propane/Gas-Engine
Bendix Abs-8 W/Ec 80 W/Gen 4 Bc W/Stability Control W/F-2018-Propane/Gas-Engine
Hydromax Hydraulic Brakes W/F-2018-Propane/Gas-Engine
Hydromax Hydraulic Brakes Wabco Mk25 W/Bendix Air Compressor
Hydromax Hydraulic Brakes Wabco Mk25 W/Stability Control
Hydromax Hydraulic Brakes Wabco Mk25 W/Stability Control W/
Collision Avoidance Effects W/F-2018-Propane/Gas-Engine
Bendix Abs 6/8 W/2017 Isb /2021 B6.7 Diesel W/F-2018-Propane/Gas-Engine
Bendix Abs 6/8 W/2017 Isb /2021 B6.7 Diesel W/F-2018-Propane/Gas-Engine (Cont.)
Bendix Abs 6/8 W/2017-Isb-Diesel & W/F-2018-Propane/Gas-Engine
Bendix Abs 6 W/2017-Isb-Diesel & W/F-2018-Propane/Gas-Engine
Bendix Abs 6 W/2017-Isb-Diesel & W/F-2018-Propane/Gas-Engine (Cont.)
Bendix Abs 6/Wabco W/Park Brake W/2017 Isb /2021 B6.7 Diesel &
Bendix Abs 6/Wabco W/Park Brake W/2017-Isb-Diesel & W/F-2018-Propane/Gas-Engine
Bendix Abs-8 W/Wingman Fusion Options W/2017 Isb /2021 B6.7 Diesel &
Bendix Abs-8 W/Wingman Fusion Options W/2017-Isb-Diesel &
Bendix Abs-8 & Hydraulic Brake W/Cluster Warn Lt W/2017 Isb /2021 B6.7 Diesel & W/
Hydraulic Brakes W/Manual Park Brake W/2017 Isb /2021 B6.7 Diesel & W/
Wheelchair Lift W/Park Brake Interlock W/Lct/Wtec Xmsn W/2017 Isb /2021 B6.7 Diesel &
Wheelchair Lift W/Park Brake Interlock W/Lct/Wtec Xmsn W/2017-Isb-Diesel &
Air Brakes W/Esp W/2010 Engine
Air Brakes W/Adjustable Pedal & N/Esp & W/2007/2010 Engine
Heated Wiper Blade W/2017-Isb-Diesel Engine
Datalink Basic W/Lct/Wtec For Hydraulic Brakes (4100) W/2017-Isb-Engine
Air Park Brake Intlk W/Hydraulic Brakes W/F-2018-Propane/Gas-Engine
Chapter 14(Ae08090665) - Emergency Exit System
Emergency Exit Buzzer Effects
Emergency Exit Buzzer Effects (Cont)
Emergency Exit Relay
Emergency Exit Relay (Cont)
Kick Out Window N/Light Sect 1 To 8 W/L Body
Kick Out Window N/Light Sect 9 To 13 W/L Body
Kick Out Window W/Light Sect 1 To 4 W/L Body
Kick Out Window W/Light Sect 5 To 8 W/L Body
Kick Out Window W/Light Sect 9 To 13 W/L Body
Kick Out Window N/3 In Red Light Sect 1 To 6 W/R Body
Kick Out Window N/3 In Red Light Sect 7 To 13 W/R Body
Kick Out Window W/3 In Red Light Sect 1 To 6 W/R Body
Kick Out Window W/3 In Red Light Sect 7 To 13 W/R Body
Kick Out Windows-Any Sect 4-6 W/L Body
Kick Out Windows-Any Sect 7-9 W/L Body
Kick Out Windows-Any Sect 10-12 W/L Body
Roof Hatches W/Alarm Section 1 To 11 W/L Body
Roof Hatches W/Alarm Section 11 To 13 W/L Body
Roof Hatches W/Alarm W/Starter Interlock Sect 1 To 4 And 9 To 12 W/L Body
Roof Hatches W/Alarm W/Starter Interlock Sect 5 To 8 And 13 W/L Body
Left Side Emergency Door
Left Side Emergency Door (Cont)
Right Side Emergency Exit Door W/Accessory Feed
Right Side Emergency Exit Door W/Accessory Feed (Cont.)
Right Side Emergency Exit Door (Cont)
Right Side Emergency Door W/3 In Red Lt Tide To Cl Lt N/ Kick Out Window
Right Side Emergency Door W/3 In Red Lt Tide To Cl Lt W/ Kick Out Window
Right Side Emergency Door W/3in Red Light Tied To Igition Sect 7 To 8
Emergency Exit Indicator Light In Cluster
Starter Interlock
City Horn W/2017/2021 Isb/B6.7 Diesel & W/F-2018-Prop/Gas-Eng
Chapter 15 (Ae08090666) - Wheel Chair Lift Door System
Lift W/Air Brake W/Key On/Off W/2017 Isb /2021 B6.7 Diesel Engine
Lift W/Air Brake W/Key On/Off W/Ind Lt W/2017 Isb /2021 B6.7 Diesel Engine
Lift Switch Effects W/Air And Hydraulic Brake
Lift W/Hydraulic Brake W/Key On/Off W/2017 Isb /2021 B6.7 Diesel Engine
Lift W/Hydraulic Brake W/Key On/Off W/Ind Lt W/2017 Isb /2021 B6.7 Diesel Engine
Lift W/Hydraulic Brake W/Key On W/F-2018-Propane/Gas-Engine
Lift W/Hydraulic Brake W/Key On W/Ind Lt W/F-2018-Propane/Gas-Engine
Wheelchair Lift Interlock W/Air Park Brake W/Key Off W/ Lct & Eaton Xmsn
Wheelchair Lift Interlock W/Air Park Brake W/Lct & Wtec Xmsn
Intentially Left Blank
Wheelchair Lift Interlock W/Air Park & Hyd Brake W/Lct Xmsn W/F-2018-Propane/Gas-Engine
Single Lift Door Interlock To Brake And Xmsn In Section 1 To 2, 3 To 4
Single Lift Door Interlock To Brake And Xmsn In Section 2 To 3
Single Lift Door Interlock To Brake And Xmsn In Section 4 To 5
Single Lift Door Interlock To Brake And Xmsn In Section 4 To 5, 5 To 6
Single Lift Door Interlock To Brake And Xmsn In Section 6 To 7
Single Lift Door Interlock To Brake And Xmsn In Section 7 To 8
Single Lift Door Interlock To Brake And Xmsn In Section 8 To 9
Single Lift Door Interlock To Brake And Xmsn In Section 9 To 10
Single Lift Door Interlock To Brake And Xmsn In Section 10 To 11
Single Lift Door Interlock To Brake And Xmsn In Section 11 To 12
Single Lift Door Interlock To Brake And Xmsn In Section 12 To 13
48 Inch Alternate Entrance Door Interlock To Brake And Xmsn In Section 7 To 8, 8 To 9
Pupil Warning Lights Activated By Lift Door Open
Lift Door With Starter Interlock
Lift Door Switch Connection
Lift Exterior Light
Lift Interior Light
Lift Door Indicator
Drivers Dome Light
Lift W/ Air Brake And Hyd Brake W/ Key On
Lift W/ Air Brake And Hyd Brake W/ Key On (Cont)
Wheelchair Lift Interlock W/Air Park & W/Hydraulic Brake W/Lct Xmsn
Wheelchair Lift W/Air Brake W/Key On/Off W/Diesel & W/F-2018-Propane/Gas-Engine
Wheelchair Lift W/Hydraulic Brake W/Key On/Off W/Diesel & W/F-2018-Propane/Gas-Engine
Lift Exterior Light
Lift Door Indicator
Chapter 16(Ae08090667) - Entry Door
Panel Mounted Door Controls - W/Left W/2 And 3 Position Rotary Switch
Panel Mounted Door Controls - W/Right W/2 And 3 Position Rotary Switch
Panel Mounted Door Controls - W/Left W/3 Position Toggle Switch
Panel Mounted Door Controls - W/3 Position Toggle Switch W/Amber Cancel
Panel Mounted Door Controls - W/2 Position Toggle Switch W/Amber Cancel
W/Rrx, Master Switch
Panel Mounted Door Controls - W/Left Side Redundant Door
Panel Mounted Door Controls - W/Right Side Redundant Door
Front Entrance Door - W/Manual Door Control N/Air/Electric Door
Front Entrance Door - W/Air Door
Front Entrance Door- W/Air Door (Cont)
Front Entrance Door - W/Air Door W/Low Side Driver
Front Entrance Door- W/Air Door W/Low Side Driver (Cont)
Front Entrance Door - W/Air Door N/Step-Well Lt Relay
Front Entrance Door - W/Electric Door
Front Entrance Door- W/Electric Door (Cont)
Front Entrance Door - W/Electric Door W/Low Side Driver
Front Entrance Door - W/Electric Door W/Key Off Switch
Front Entrance Door - W/Electric Door W/Key Off Switch (Cont.)
Front Entrance Door - W/Electric Door W/Release Starter Interlock
Front Entrance Door - W/Electric Door W/Single Cycle Flasher Cancel
Vandal Locks On Right W/Air Door W/Zonar
Vandal Locks On Right W/Electric Door W/Zonar
Vandal Locks On Right W/Manual Door
Alternate Entrance Door W/Right W/Vandal Lock Key Switch
Alternate Entrance Door W/Left & Right W/Air W/Dump Valve
Alternate Entrance Door W/Left W/Electric W/Master Switch W/9
Dump Valve Effects - W/Alternate Entrance Door W/Air/Electric
Dump Valve Effects - W/Air Door W/Interior And Exterior
Rear Door Activated Option
Rear Door Activated Option (Cont)
Right Entrance Door W/Manual Door
Panel Mounted Door Controls - W/3 Position Toggle Switch W/Amber Cancel (Cont)
Right Alternate Entrance Door Vandal Lock Key Switch
Right Alternate Entrance Door Vandal Lock Key Switch (Cont)
Vandal Lock For Electric Entrance Door
Left Alternate Entrance Door-Electric N/Master Switch
Left Enterance Door-Electric W/Master Sw
Alternate Entrance Door Air W/Dump Valve
3-Position Toggle Switch
Chapter 17(Ae08090668) - Radio / Pa / Cellular - Gps
Radio Wiring W/Dash Mounted 2 Channel Radio
Radio Wiring W/Overhead Mounted 2 Channel Radio
Radio Wiring W/Pa Horn System
Radio Wiring W/Dash/Overhead Mounted W/Front Speaker
Radio Wiring W/Dash/Overhead Mounted W/Front Speaker (Cont.)
Right/Left Speaker Wiring For Quantity 2
Right/Left Speaker Wiring For Quantity 4
Left Speaker Wiring For Quantity 6
Right Speaker Wiring For Quantity 6
Left Speaker Wiring For Quantity 8
Right Speaker Wiring For Quantity 8
Left Speaker Wiring For Quantity 10
Right Speaker Wiring For Quantity 10
Left Speaker Wiring For Quantity 12
Right Speaker Wiring For Quantity 12
Left Speaker Wiring For 2 - 140 In Behind Stanchion
Left Speaker Wiring For 4 - 140 In Behind Stanchion
Left Speaker Wiring For 6 - 140 In Behind Stanchion
Left Speaker Wiring For 8 - 140 In Behind Stanchion
Left Speaker Wiring For 4 - Aft Of Third Row Of Seats
Right Speaker Wiring For 2 - 140 In Behind Stanchion
Right Speaker Wiring For 4 - 140 In Behind Stanchion
Right Speaker Wiring For 6 - 140 In Behind Stanchion
Right Speaker Wiring For 6 - 140 In Behind Stanchion (Cont.)
Right Speaker Wiring For 8 - 140 In Behind Stanchion
Right Speaker Wiring For 4 - Aft Of Third Row Of Seats
Audio And Video Prewire Effects
Audio And Video Prewire Effects (Cont.)
Telematic Effects W/Zonar V3 Prewire
Telematic Effects W/Zonar V3 Prewire (Cont.)
Front Camera Effects W/2017 Isb /2021 B6.7 Eng, W/F-2018-Propane/Gas-Engine
Dash Mounted 4-Channel Radio-Pa
Two Way Radio And Video Effects
Gps Pre-Wire And Video Power Effects
Accessory Power Strip And Access Feed
Dvr Prewire
Telematic Zonar V3 Prewire N/Door Signal
Chapter 18(Ae08090669) - Child Reminder System
Child Monitor System
Child Monitor System (Cont.)
Theft Mate Prewire System
Theft Mate Prewire System (Cont.)
Theft Mate Prewire System W/Snooze
Theft Mate Prewire System W/Snooze (Cont.)
Child Check Mate System
Child Check Mate System (Cont.)
Child Check Mate System W/Pti Deactivation Switch In Lt Bar
Child Check Mate System W/Snooze W/Emergency Exit Act W/Lift
Child Check Mate System W/Snooze W/Emergency Exit Act W/Lift (Cont.)
Checkmate W/Snooze W/Emer Act W/Lift
Child Check Mate System W/Snooze W/Emergency Exit Act N/ Lift
Child Check Mate System W/Snooze W/Emergency Exit Act N/ Lift (Cont.)
Checkmate W/Snooze W/Emer Act N/Lift (Cont)
Child Checkmate System W/Entrance Door W/Emergency Exit Act
Child Checkmate System W/Entrance Door W/Emergency Exit Act (Cont.)
Child Checkmate/Theft Mate System W/Snooze W/Lift
Child Checkmate/Theft Mate System W/Snooze W/Lift (Cont.)
Child Checkmate/Theft Mate System W/Snoozew/Lift (Cont.)
Child Checkmate/Theft Mate System W/Emergency Exit Act W/Dome Lt
Child Checkmate/Theft Mate System W/Emergency Exit Act W/Dome Lt (Cont.)
Leave No Student Behind W/Battery Feed Buzz
Leave No Student Behind (Cont.)
Post Trip Inspection Effects N/Crs
Post Trip Inspection Effects N/Crs (Cont.)
Post Trip Inspection Effects W/Snooze
Child Safety Alarm
Child Safety Alarm (Cont.)
Bus Scan
Bus Scan W/Pti Deactivation Sw In Bulkhead
Chapter 19 (Ae08090670) - Heaters / Air Conditioning / Accessories
Booster Pump W/Espar Heater W/Timer
Booster Pump W/Fr Mounted Heater W/Timer In Electrical Panel Or Overhead Driver Compt
Booster Pump W/Fr Mounted Heater W/Smart Timer
Booster Pump W/Fr Mounted Heater W/Timer R Driver
Booster Pump W/Fr Mounted Heater W/White Timer
Booster Pump W/Activated By Heater Switch
Booster Pump W/Coolant Heater Wired Separately W/Timer
Booster Pump W/Coolant Heater W/Timer And Low Voltage Disc
Booster Pump W/Espar Heater W/Timer Prewire
Booster Pump W/2010 High Output W/Be/Ce Bus
Booster Pump Activated By Driver Heater Switch
Espar Coolant Heater W/Espar 7-Day Timer/White Timer W/Diesel
Espar Coolant Heater W/Espar W/ Multimax Timer W/Diesel
Espar Coolant Heater W/Rsm Tank And W/12 Kw Rsm Tank
Espar Coolant Heater W/Af And Rsm Fuel Tank
Coolant Heater Effects
Coolant Heater Effects (Cont.)
Left Front Passenger Heater
Left Rear Passenger Heater
Right Front Passenger Heater
Right Rear Passenger Heater
Booster Pump Relay Splice
Defog Fan Effects
Defog Fan Effects (Cont.)
Defog Fan Switch W/Driver S Fan And Blowers
Defog Fan Left Switch Output
Defog Fan Left Switch Output (Cont.)
Defog Fan Right Switch Output
Defog Fan Right Switch Output (Cont.)
Step Tread Heater Effects
Convection Heater Effects
Stepwell Heater Effects
Heated Air Seat Effects
Air Compressor Effects
Engine Speed Control W/ Air Conditioning
Engine Speed Control W/ Air Conditioning (Cont.)
Overhead Locking Compartment
Power Vent Fr And Rr W/Alarm W/Roof Hatch
Booster Pump W/17k Front Heater W/Smartemp Timer In Electrical Panel Or Overhead
Booster Pump W/17k Front Heater W/Smartemp Timer Mounted Right Of Driver
Booster Pump W/Front Mounted Heater W/White Timer
Booster Pump
Coolant Heater With Timer And Low Voltage Disc
Step Tread Heater 1st/Step Warmer
Defog Fan Switch W/Drivers Fan
Ac Compressor Disable In Low Accl
Air Compressor
Engine Speed Control W/Air Conditioning W/Diesel & W/F-2018-Propane/Gas-Engine
Engine Speed Control W/Air Conditioning W/Diesel & W/F-2018-Propane/Gas-Engine (Cont) .
Heated Air Seat
Espar Coolant Heater W/Espar W/Multimax Timer
Webasto Scholastic Coolant Heater W/Webasto 7-Day Timer
Fuel Fired Heater Smartemp Timer Right Of Driver
Coolant Heater Effects (Cont)
Freon Compressor Connections
Webasto 45k Fuel Fired Heater
Webasto 45k Fuel Fired Heater (Cont)
Webasto 45k Fuel Fired Heater (Cont) With Smartemp Timer
Booster Pump W/ Front Heater W/Timer Overhead Driver Compartment
Chapter 20 (Ae08090671) - Connector Composite (52-2505)
Chapter 21 (Ae08090672) - Connector Composite (2512-8903)
Chapter 22 (Ae08090673) - Connector Composite (9001-9996)
Chapter 23 (Ae08090674) - Connector Composite (10000-10300)
Chapter 24 (Ae08090675) - Connector Composite (10301-10440)
Chapter 25 (Ae08090676) - Connector Composite (10441-10740)
Chapter 26 (Ae08090677) - Connector Composite (10741-84331)
Chapter 27 (Ae08093713) - Electric Vehicle ( Ev ) Systems
Battery Feed
Battery Feed Pdm1
Battery Feed Pdm2
Ignition Feed
J1939 Powertrain W/ 500k
J1939 Can_Hvctrls Network
J1939 Can_Hvpwr Network
J1939 Can_Bms-C Network
J1939 Can_0 Diagnostic Network
Clean Ground
Ev Diagnostic Connector
Body Ground
Body Ground - Ev Systems
High Voltage Distribution Unit (Hvdu)
On-Board Chargers
High Voltage Distribution Module (Hvdm)
Battery Management System S-Box
Bms Hv Battery Vendor Supplied Cables
Dc/Dc Converters
12v Disconnect Of Hv System
Vcu Hvil
Onboard Charging Interface Module (Oci)
Charge Port Inlet 12v Signals
Diesel Fuel Gauge W/ Aux Heater
Head/Park Lamp Switch
Vcu Backup Lights Signal
Panel Lights Switch
Vehicle Control Unit (Vcu)
Supervisory Control Unit (Scu)
Global Power A Relay
Global Power B Relay
Fan Control Module
Battery Thermal Management System (Btms)
Vcu Ambient Temp Sensor
Coolant Temp Sensors
Surge Tank Sensors
Medium Temp (Mt) Coolant Pump
Traction Power Inverter Module (Tpim)
Tpim Vendor Motor Control Cable
Accelerator Position Sensor
Ev Shift Selector ( Rndl Pushbutton Type )
2-In-1 Inverter
2-In-1 Inverter Vendor Supplied Cables
Air Dryer
Hv Air Compressor Purge Valve
Air Park Brake Interlock
Vcu Stop Light Pressure Switches
Hv Electric Water Heater
Hv Cabin Heat Enable
Hv Cabin Heat Enable (Continued)
Ev Booster (Cabin Heat) Pump
Ev Booster Pump (Continued)
Aux Heater
Abs Forward/Rear Chassis Interconnect
Hv Dc Fast Battery Charge
Hv Ac Battery Charge
Hv Battery Charge Distribution
Hv Battery Bms Switch Box
Hv Dc/Dc Converters
Hv 2-In-1 Inverter
Hv Battery Thermal Management System
Hv Tpim Drive Motor
Hvdu Hvil Circuit
Hvdm Hvil Circuit
Body Air Conditioning Enable
Body Air Conditioning Hmi
Body Air Conditioning 12v Power Feed
Adjustable Pedals
Ev Noise Generator
Hv Body Air Conditioning
Chapter 28 (Ae08093712) - Connector Composite (1100f-14159)
