Hyundai HCE-DT Master Diagnostic [2016]
PASS: HCE-DT2016
Diagnostic Software for Hyundai Robex - excavators, Forklifts, WheelLoaders above 7, 8 tons.
M-H-01-00-0007 (UNLIMITED UPDATES)
Region: Europe
Languages: English (Multilanguage)
Type: Diagnostic Software
Version: M-H-01-00-0007
OS:WinXP, Vista, Windows7, WIN8
Quantity of CD: 1 DVD
Year: 2016
Date of Update: 2016 (UNLIMITED UPDATES)
Hyundai Robex Diagnostic Tool (HRDT) is a Self-Diagnosis program, allowing plug&play machine monitoring. The software pack reads all error codes and records engine brake down logs, maintenance logs and operation logs.
This program communicates with the main controller (MCU) of the excavator and allows the user to check various settings like driving mode, fuel efficiency and coolant temperature. It also provides inspection procedures for the engine and electronic parts.
Also, a more efficient management of the excavator is possible since it automatically informs the user of replacement cycles of various oils and filters as well as showing operation data such as engine speed, in real time. This program can be used on all -7 excavators above 8 tons. The ease-of-use of the program allows every operator to diagnose his Hyundai excavator on the spot.
Requirements:
- communiaction cable MCU-to-PC, RS232
- RS232-to-USB adapter
For Hyundai Excavator Forklift WheelLoader
M-H-01-00-0000 Version - With Online Update to M-H-01-00-0007
HCE-DT Distinctive Features
HCE-DT has some of the following distinctive features.
Coupling information and diagnosis: HCE-DT Information Terminal is a computerized system. It is possible to store large amounts of information. In addition, it can show the diagnosis results and related information on one screen, in contrast to existing scanners limitations in output due to their limited screen size.
This feature saves time and increases diagnostic effectiveness.
Quick Support through internet updates: If new data is introduced or if an error has generated in the HCE-DT System, data update or system fix can be made through a real time Internet update.
ECU reprogramming support: reprogramming step-up transformer, unlimited reprogramming events.
Support for powerful flight recording functions.
Wireless network support between VCI and Information Terminal: Reduces need for cable connections between machine and Information Terminal.
Work with Excavator 9 Series and 7 Series, Forklift All, WheelLoader 9 Series
Hyundai HCE-DT Master [2016] install Guide
1. Mount the DISK and Install the program (RUN Setup.exe) .
2. Post your Hardware ID in the topic to get your Registration key .
3. Continue the installation untill finish
4. Reboot your PC .
5. Run the program from the desktop shortcut .
6. Apply the Updates if you need ( Unlimited Updates)
7. DONE , ENJOY !! NOW Hyundai HCE-DT Master [2016] is FULL activated and updated .
