704,032
Hyundai Electric Pallet Truck 15EP-XB 20EP-XB Service Manual
Brand: Hyundai
Type of Machine: Electric Pallet Truck
Type of Manual: Service Manual, Electrical and Hydraulic Diagrams
Model: Hyundai 15EP-XB 20EP-XB Electric Pallet Truck
Number of Pages: 91 Pages
1. CORRECT APPLICATION
2. DESCRIPTION OF THE PALLET TRUCK
a. Overview of the main components
b.Main technical data
c. Description of the safety devices and warning labels
d. Identification plate
3. WARNINGS, RESIDUAL RISK AND SAFETY INSTRUCTIONS
4. COMMISSIONING, TRANSPORTING, DECOMMISSIONING
a. Commissioning
b. Lifting/ transportation
c. Decommissioning
5. DAILY INSPECTION
6. OPERATING INSTRUCTIONS
a. Parking
b. Lifting
c. Lowering
d. Travelling
e. Braking
f. Malfunctions
g. Emergency
7. PIN-CODE PANEL
a. Introduction
b. Main specification parameters
c. Main control codes and functions
8. BATTERY SAFETY, CHARGING AND REPLACEMENT
a. Replacement
b. Charging
Push the plastic part with your hand and gently pull it forward. Lift the battery up directly.
9. REGULAR MAINTENANCE
a. Maintenance checklist
b. Lubricating points
c. Check and refill hydraulic oil
d. Checking electrical fuses
10. TROUBLE SHOOTING
11. WIRING/ CIRCUIT DIAGRAM
a. Electrical circuit diagram
b. Hydraulic circuit
12. Electronic Systems
a-1 Overview
b. Emergency switch
c.Controller and related devices
d. Tiller head
13.Drive/Brake System
a.Overview
b.Brake
c. Trouble shooting
14.Hydraulic System
a.Overview
b.Pump assembly
c.Lifting cylinder
d.Troubleshooting
15.Main components, disassembly and installation and description requirements
a.The whole truck composite sleeve specifications diagram
b.Disassembly of coverings
c.Chassis disassembly
d.Drive Wheel Ring Replacement
e.Disassembly and adjustment of auxiliary wheels
f.Tiller Gas Spring disassembly and Installation
g.Tiller Proximity Switch Disassembly and Installation
h. Pump station contactor disassembly and installation
i.Pump station motor disassembly and installation
j.Limit micro switch disassembly and installation
k.Torque requirement for main fixing screw
16.CURTIS Handheld programmer
17.Troubleshooting for Each Fault Code
a.15EP-XB Countermeasures of fault codes(Curtis 1212C)
b.20EP-XB Fault Code List (Curtis 1226BL)
