Hyundai Crawler Excavator R480LC-9S Spare Parts Catalog
Brand: Hyundai
Type of Machine: Crawler Excavator
Model: Hyundai R480LC-9S Crawler Excavator
Number of Pages: 689 Pages
Engine Mounting
Air Intake System
Air Intake System(Oil Bath, #0257-)
Exhaust Group
Radiator Assy(-#0173)
Radiator Assy (#0174-)
Fuel System
Aircon & Heater Group
Air Conditioner Bottom Sub
Air Conditioner & Heater Unit
Air Conditioner Mounting
Air Conditioner Unit(Semi Auto)
Heater Mounting
Heater Unit(Semi Auto)
Pre Heating Group
Rh Electric (Cluster Type 1)
Lh Electric(Cluster Type 1)
Rh Electric (Cluster Type 2)
Lh Electric(Cluster Type 2)
Boom Electric
Air Compressor Electric
Engine Electric
Electric Box(-#0445)
Electric Box(#0446-)
Cab Electric 1
Cab Electric 2
Cab Electric 3
Cluster (Type 1)
Cluster(Type 2)
Bottom Electric
Fuel Filler Pump
Fuse Box
Pump Mounting
Hydraulic Tank
Upper Hydraulic Piping(Base 1)
Upper Hydraulic Piping (Base 2)
Upper Hydraulic Piping(Attach)
Upper Hydraulic Piping (Travel)
Upper Hyd Piping (Travel, S_M Type 2)
Pilot Hydraulic Piping (Control 1)
Pilot Hydraulic Piping (Control 2)
Pilot Hydraulic Piping (Control 3)
Pilot Hyd Piping (Base 1, Cluster Type 1)
Pilot Hyd Piping (Base 2, Cluster Type 1)
Pilot Hyd Pip (Base 3, Cluster 1, -#0753)
Pilot Hyd Pip (Base 3, Cluster 1, -#0754)
Pilot Hyd Piping (Base 1, Cluster Type 2)
Pilot Hyd Piping (Base 2, Cluster Type 2)
Pilot Hyd Pip (Base 3, Cluster 2, -#0753)
Pilot Hyd Pip (Base 3, Cluster 2, #0754-)
Travel Hydraulic Piping
Travel Hyd Piping (T_Motor Type 3)
Boom Hyd Piping (7.06m, Std)
Boom Hyd Piping (6.55m, S_Short)
Boom Hyd Piping (9.0m, S_Long)
Boom Hyd Piping (10.0m, #0149-)
Boom Grease Lub Sys(7.06m, Std)
Boom Grease Lub Sys(6.55m, S_Short)
Boom Grease Lub Sys(9.0m, S_Long)
Boom Grease Lub Sys(10.0m, #0149-)
Boom Safety Lock System(-#0178)
Boom Safety Lock System(#0179-)
Quick Clamp Hyd Piping
Quick Clamp(Hook Type, -#0255)
Quick Clamp(Close Type, -#0255)
Quick Clamp(Hook Type 1, #0256-)
Quick Clamp(Close Type 1, #0256-)
Quick Clamp(Hook Type 2, #0372-)
Quick Clamp(Close Type 2, #0372-)
Arm Hyd Piping (3.38m, Std)
Arm Hyd Piping (2.4m, Short)
Arm Hyd Piping (2.9m, Short)
Arm Hyd Piping (4.0m)
Arm Hyd Piping (5.85m, S_Long)
Arm Safety Lock System
Double Acting Main Piping Kit(1_2)
Double Acting Main Piping Kit(2_2)
Attach Piping Kit (S & D_Acting)
Single Pedal(Double Acting)
Single Acting Main Piping Kit
Semi Auto Grease Lub Sys
Main Pump (-#0753)
Main Pump (#0754-)
Regulator (Front)
Regulator (Rear)
Gear Pump
Main Control Valve(1_3)
Main Control Valve(1_3, Type 2,3)
Main Control Valve(2_3)
Main Control Valve(2_3, Type 2,3)
Main Control Valve(3_3)
Main Control Valve(3_3, Type 2,3)
Swing Motor(Lh)
Swing Motor(Rh)
Swing Motor(Type 2)
Swing Reduction Gear
Swing Reduction Gear(Type 2)
Travel Motor(1_2, Type 1)
Travel Motor(1_2, Type 2)
Travel Motor (1_2, Type 3, 4)
Travel Motor(2_2, Type 1)
Travel Motor(2_2, Type 2)
Travel Motor (2_2, Type 3, 4)
Travel Reduction Gear(Type 1)
Travel Reduction Gear(Type 2)
Travel Reduction Gear(Type 3)
Remote Control Lever (Type L1, -#0677)
Isoview 3 Document (109)
Remote Control Lever (Type L2)
Isoview 3 Document (111)
Remote Control Lever (Type L4, #067
Remote Control Lever (Type 2)
Remote Control Lever (Type L7, -#0677)
Remote Control Lever (Type 3)
Remote Control Pedal
Turning Joint
Boom Cylinder
Arm Cylinder
Bucket Cylinder
Solenoid Valve(Cluster Type 1, -#0002)
Solenoid V_V(Cluster Type1, #0003-#0266)
Solenoid Valve(Cluster Type 1, #0267-)
Solenoid Valve(Cluster Type 2, -#0001)
Solenoid Valve(Cluster Type 2, #0002-)
Breaker Assy(1_3)
Breaker Assy(2_3)
Breaker Assy(3_3)
Breaker Auto Grease Unit(Opt)
Breaker Central Grease Supply Unit(Opt)
Undercarriage Mounting
Lower Roller(-#0625)
Lower Roller(#0626-)
Upper Roller(-#0625)
Upper Roller(#0626-)
Idler
Track Chain
Adjust Component
Cab Mounting
Cab Assy(1_4)
Cab Assy(2_4)
Cab Assy(3_4)
Cab Assy (4_4, Door)
Cab Interior 1
Cab Interior 2
Cab Interior 3
Console Box 1(Lh)
Console Box 2(Lh)
Console Box 3(Rh)
Seat Base Assy
Seat(Std)
Seat(Suspension, Heated)
Storage Box Assy
Bottom Plate Mounting
Cowling 1
Cowling 2
Side Cowl Assy(Lh)
Side Cover Assy(Lh)
Side Cowl Assy(Rh)
Engine Hood Assy
Under Cover
Tool Box Mounting
Tool Box
Grommet Group(-#0210)
Grommet Group(#0211-)
Upper Frame & Counterweight
Lower Frame & Cover
Swing Ring Grease Lub System
Boom Mounting
Boom(7.06m, Std, -#0326)
Boom (7.06m, Heavy Duty)
Boom (6.55m)
Boom (9.0m, Long Reach)
Arm(3.38m, Std)
Arm (3.38m, Std)
Arm(3.38m, Heavy Duty)
Arm(2.4m)
Arm (2.4m)
Arm(2.9m)
Arm (2.9m)
Arm(4.0m)
Arm (4.0m)
Arm(5.85m, Long Reach)
Bucket Control Group
Bucket(5 Teeth, -#0303)
Bucket(5 Teeth, #0304-)
Bucket(5 Teeth, Casting, -#0303)
Bucket(4 Teeth)
Bucket(6 Teeth, #0304-)
Bucket(7 Teeth, -#0303)
Bucket(5 Teeth, Heavy Duty)
Bucket(5 Teeth, Rock)
Bucket(5 Teeth, Rock)_1
Bucket(3 Teeth)
Bucket(6 Teeth, Rock, -#0303)
Bucket(6 Teeth, Rock, #0304-)
Bucket(6 Teeth, Heavy Duty, #0304-)
Tools
Hce-Dt Kit
Manuals
Accessory Drive Pulley
Air Heater Starting Aid
Dataplate
Cylinder Block Plumbing
Cam Follower Lever
Main Bearings
Coolant Heater Starting Aid
Air Compressor Inlet Connection
Vibration Damper
Front Gear Train Accessory Drive
Fuel Pump Drive
Engine Brake Control
Idler Gears
Gear Housing
Breather Plumbing
Alternator Mounting Alternator Mounting
Thermostat
Alternator Drive Pulley
Front Engine Support
Fan Drive
Fuel Pump Inlet Fitting
Flywheel Housing
Fuel Pump
Fuel Pump Mounting
Fuel System Primer Plumbing
Flywheel & Ring Gear
Front Gear Cover
Air Intake Connection
Lifting Bracket
Lubricating Oil Cooler
Engine Oil Filter
Level Gauge
Lubricating Oil Pump
Oil Filter Arrangement
Oil Pan
Electronic Control Cooler
Injectors
Cylinder Head Mounting
Camshaft
Engine Piston Kit
Connecting Rod
Piston Cooling Nozzle
Turbocharger
Exhaust Manifold
Rocker Lever
Radiator Plumbing
Start Motor And Mounting
Fan Pilot Spacer
Air Intake Manifold
Thermostat And Housing
Turbocharger Plumbing
Valve Cover
Corrosion Resistor
Heat Shield
Wiring Accessories
Exhaust Connection
Wiring Harness
Brand: Hyundai
Engine Mounting
Air Intake System
Exhaust Group
Fuel System
Heater Mounting
Pre Heating Group
Boom Electric
Engine Electric
Cab Electric 1
Cab Electric 2
Cab Electric 3
Cluster (Type 1)
Cluster(Type 2)
Bottom Electric
Fuel Filler Pump
Fuse Box
Pump Mounting
Hydraulic Tank
Main Pump (-#0753)
Main Pump (#0754-)
Regulator (Front)
Regulator (Rear)
Gear Pump
Swing Motor(Lh)
Swing Motor(Rh)
Swing Motor(Type 2)
Turning Joint
Boom Cylinder
Arm Cylinder
Bucket Cylinder
Breaker Assy(1_3)
Breaker Assy(2_3)
Breaker Assy(3_3)
Idler
Track Chain
Adjust Component
Cab Mounting
Cab Assy(1_4)
Cab Assy(2_4)
Cab Assy(3_4)
Cab Interior 1
Cab Interior 2
Cab Interior 3
Console Box 1(Lh)
Console Box 2(Lh)
Console Box 3(Rh)
Seat Base Assy
Seat(Std)
Storage Box Assy
Cowling 1
Cowling 2
Side Cowl Assy(Lh)
Side Cover Assy(Lh)
Side Cowl Assy(Rh)
Engine Hood Assy
Under Cover
Tool Box Mounting
Tool Box
Lower Frame & Cover
Boom Mounting
Boom (6.55m)
Arm(3.38m, Std)
Arm (3.38m, Std)
Arm(2.4m)
Arm (2.4m)
Arm(2.9m)
Arm (2.9m)
Arm(4.0m)
Arm (4.0m)
Bucket(4 Teeth)
Bucket(3 Teeth)
Tools
Hce-Dt Kit
Manuals
Dataplate
Cam Follower Lever
Main Bearings
Vibration Damper
Fuel Pump Drive
Idler Gears
Gear Housing
Breather Plumbing
Thermostat
Fan Drive
Flywheel Housing
Fuel Pump
Fuel Pump Mounting
Front Gear Cover
Lifting Bracket
Engine Oil Filter
Level Gauge
Oil Pan
Injectors
Camshaft
Engine Piston Kit
Connecting Rod
Turbocharger
Exhaust Manifold
Rocker Lever
Radiator Plumbing
Fan Pilot Spacer
Air Intake Manifold
Valve Cover
Corrosion Resistor
Heat Shield
Wiring Accessories
Exhaust Connection
Wiring Harness
- Hyundai Excavaror Robex R200LC-3 R210LC-3 Service Manual and Diagram
- SANKO MST 542-544 SERVICE MANUAL FULL
- Hyundai Crawler Excavator R210LC-7H R220LC-7H Service Manual
- Hyundai Wheel Loader [HL770-7A] Service Manual
- Hyundai Crawler Excavator R290LC-7 Service Manual
- Hyundai Wheel Excavator R210W-9S Service Manual
- Hyundai Robex 2013 Full Cracked
- Hyundai Backhoe Loader H930S/H940S Workshop Manual
- [Hyundai Mini Excavator] Rolex 75-7 Service Manual
- Hyundai Backhoe Loader H930C/H940C Workshop Manual
- [Hyundai Mini Excavator] Rolex 16-7 Service Manual
- Wirtgen Widos 2014 FULL DOCUMENT
- Hyundai Crawler Excavator R320LC-9 Service Manual
- Hyundai Crawler Excavator R220LC-9S Service Manual
- Hyundai Wheel Loader [HL760-7A] Service Manual
