estemar1979
12
5,723
Hyster Reachs Tacker RS45-27CH to RS46-41LS C222 Parts Manual 4038588 2024
Brand: Hyster
Type of Machine: Reachs Tacker
Model: Hyster C222 Reachstacker
RS45-27CH , RS45-31CH,
RS46-36CH, RS46-41L
RS46-41S, RS46-41LS - AMERICAS
Part Number: 4038588
Publication Date: 2024
Number of Pages: 904 Pages
Frame
FLOORPLATES AND STEPS WITH RH STAIRS
FLOORPLATES AND STEPS WITHOUT RH STAIRS
STORAGE COMPARTMENT AND RUNNING BOARDS
HANDRAILS WITH POWER SLIDING CAB
HANDRAILS WITHOUT POWER SLIDING CAB
CAB MOUNTING POWERED SLIDING CAB
CAB MOUNTING NON-POWERED SLIDING CAB
CAB MOUNTING NON-POWERED SLIDING CAB - ALTERNATE CONFIGURATION
COVERS TIER III ENGINE
COVERS TIER IV INTERIM ENGINE
FENDERS
CAB PAGE 1 OF 3
CAB PAGE 2 OF 3
CAB PAGE 3 OF 3
CAB FLOORMATS
CAB DOOR LEFT HAND
CAB DOOR RIGHT HAND
MAIN WINDOW ASSEMBLY
WINDOW WIPER SYSTEM WASHER BOTTLE KIT
WINDOW WIPER SYSTEM REAR AND ROOF WIPER KITS - AND FRONT WIPER OPTIONS
AIR HORN
CAB RECIRCULATING FAN
CONSOLE INDICATOR DISPLAY AND CONTROLS
HEATER AND AIR DUCT WITH TWO-FAN CONDENSER SYSTEM
HEATER SYSTEM WITH TWO-FAN CONDENSER SYSTEM
AIR DUCT ASSEMBLY HEATER - WITH TWO-FAN CONDENSER SYSTEM
HEATER ASSEMBLY WITH TWO-FAN CONDENSER SYSTEM
CONTROL PANEL ASSEMBLY HEATER
AIR CONDITIONER SYSTEM CLIMATE CONTROL CAB
AIR CONDITIONER CLIMATE CONTROL CAB
AIR CONDITIONER SYSTEM WITH TWO-FAN CONDENSER SYSTEM
AIR CONDITIONER ASSEMBLY WITH TWO-FAN CONDENSER SYSTEM (→ 12/2012)
AIR CONDITIONER ASSEMBLY WITH TWO-FAN CONDENSER SYSTEM (12/2012 →)
CONTROL PANEL ASSEMBLY WITH TWO-FAN CONDENSER SYSTEM (→ 12/2012)
CONTROL PANEL ASSEMBLY WITH TWO-FAN CONDENSER SYSTEM (12/2012 →)
CLIMATE CONTROL SYSTEM
CONDENSER ASSEMBLY WITH TWO-FAN CONDENSER SYSTEM
AIR CONDITIONER SYSTEM CLOSED CAB WITH AIRCO
AIR DUCT ASSEMBLY AIR CONDITIONING - WITH TWO-FAN CONDENSER SYSTEM
DASH AND AIR DUCT ASSEMBLY CAB
AIR CONDITIONER FILTER AND COVER ASSEMBLY
SEAT ASSEMBLY DELUXE SUSPENSION
SUSPENSION KIT ASSEMBLY
SEAT ASSEMBLY CLIMATE CONTROL CAB
SEAT ASSEMBLY SUSPENSION (→ 3/2010)
SEAT ASSEMBLY SUSPENSION (3/2010 →)
SEAT BACKREST EXTENSION OPTIONAL
SEAT ASSEMBLY MECHANICAL AND AIR SUSPENSION
SEAT ASSEMBLY MECHANICAL SUSPENSION
SEAT ASSEMBLY AIR SUSPENSION
PIVOT ARM ASSEMBLY
ARMREST ASSEMBLY
COUNTERWEIGHT RS46-41S
COUNTERWEIGHT RS46-41L/LS
COUNTERWEIGHT RS45-27/31, RS46-36
MIRRORS FRONT FENDER - WITHOUT FULL STROKE POWER SLIDING CAB
MIRRORS FRONT FENDER - WITH FULL STROKE POWER SLIDING CAB
HEATER HOSES TIER III ENGINE
HEATER HOSES TIER IV INTERIM ENGINE
AIR CONDITIONING HOSES TIER III ENGINE
AIR CONDITIONING HOSES TIER IV INTERIM ENGINE
COMPRESSOR ASSEMBLY TIER IV INTERIM ENGINE
LABELS SWITCHES
LABELS
RADIO CONSOLE AND ATTACHING PARTS
CONDENSER ASSEMBLY 24V
ENGINE ASSEMBLY - TIER III ENGINE
ENGINE MOUNTING
EXHAUST SYSTEM
COOLING SYSTEM
COOLER ASSEMBLY
ACCESSORY DRIVE PULLEY
AIR CLEANER PLUMBING
AIR TRANSFER CONNECTION
BREATHER PLUMBING
CAM FOLLOWER LEVER
CAMSHAFT
COMPRESSOR MOUNTING
COOLANT HEATER STARTING AID
CORROSION RESISTOR
CRANKSHAFT
CRANKSHAFT AND MAIN BEARINGS
CYLINDER BLOCK
CYLINDER BLOCK PLUMBING
CYLINDER HEAD
CYLINDER LINER
EXHAUST MANIFOLD
EXHAUST OUTLET CONNECTION
FAN DRIVE AND SPACER
FLYWHEEL
FLYWHEEL HOUSING
FRONT DRIVE TRAIN
FRONT ENGINE SUPPORT
FRONT GEAR COVER
GEAR HOUSING
IDLER GEAR
INTAKE CONNECTOR AIR COMPRESSOR
INTAKE MANIFOLD
LIFTING BRACKETS
NOISE PANEL
OIL COOLER WATER PLUMBING
OIL FILL
OIL FILLER
OIL FILTER
OIL FILTER AND COOLER HEAD
OIL LEVEL GAUGE
OIL PAN
OIL PUMP AND ATTACHING PARTS
PISTON AND CONNECTING ROD
PISTON COOLING NOZZLE
RADIATOR PLUMBING
RADIATOR PLUMBING ENGINE WITH AIRCO (10/2013 →)
ROCKER LEVERS
THERMOSTAT
THERMOSTAT HOUSING
TURBOCHARGER
TURBOCHARGER ENGINE WITH AIRCO (10/2013 →)
TURBOCHARGER PLUMBING
TURBOCHARGER PLUMBING ENGINE WITH AIRCO (10/2013 →)
VALVE COVER
VIBRATION DAMPER
WATER PUMP
ENGINE ASSEMBLY - TIER IV INTERIM ENGINE
ENGINE MOUNTING
EXHAUST SYSTEM
DIESEL PARTICULATE FILTER AFTERTREATMEANT MODULE DEVICE
COOLING SYSTEM
COOLER ASSEMBLY
AIR INTAKE CONNECTION
AIR INTAKE HOSE
BELT TENSIONER
BREATHER PLUMBING
COMPRESSOR MOUNTING
CONNECTING ROD AND PISTON
COOLANT PLUMBING
CRANKSHAFT AND BEARINGS
CYLINDER BLOCK
CYLINDER HEAD
CYLINDER HEAD PLUMBING
ENGINE SUPPORT
EXHAUST MANIFOLD
EXHAUST PLUMBING AIR RECIRCULATION
EXHAUST PLUMBING WATER RECIRCULATION
EXHAUST RECIRCULATION
FAN DRIVE AND MOUNTING
FLYWHEEL
FLYWHEEL HOUSING
FRONT GEAR COVER
FRONT GEAR TRAIN ACCESSORY MOUNTING
GEAR HOUSING
HEAT SHIELD
INTAKE MANIFOLD
LIFTING BRACKETS
OIL COOLER
OIL FILL CYLINDER BLOCK
OIL FILL FRONT GEAR COVER
OIL FILTER ELEMENT
OIL LEVEL GAUGE
OIL PAN
OIL PUMP
PLUG, CABIN HEATER PLUMBING
PLUG, COOLANT HEATER STARTING AID
PLUG, TORQUE CONVERTER OIL COOLER
ROCKER LEVER HOUSING
THERMOSTAT
TURBOCHARGER
TURBOCHARGER WATER PLUMBING
VALVE COVER
VIBRATION DAMPER
WATER PUMP AND CONNECTIONS
FUEL SYSTEM - TIER III ENGINE
AIR INTAKE SYSTEM
AIR FILTER ASSEMBLY
FUEL SYSTEM
FUEL PUMP ASSEMBLY
FUEL PUMP COUPLING
FUEL PUMP DRIVE
FUEL PUMP INTAKE FITTING
FUEL PUMP PLUMBING
FUEL FILTER
FUEL FILTER PLUMBING
FUEL INJECTORS
THROTTLE AND INCHING SENSORS
THROTTLE PEDAL AND ATTACHING PARTS
FUEL SYSTEM - TIER IV INTERIM ENGINE
AIR INTAKE SYSTEM
FUEL SYSTEM
FUEL DRAIN PLUMBING
FUEL PUMP MOUNTING
FUEL PUMP
FUEL FILTERS
FUEL INJECTORS
FUEL INJECTOR PLUMBING
FUEL TRANSFER PUMP
ELECTRICAL SYSTEM
ELECTRICAL SYSTEM PAGE 1 OF 4
ELECTRICAL SYSTEM PAGE 2 OF 4
ELECTRICAL SYSTEM PAGE 3 OF 4
ELECTRICAL SYSTEM PAGE 4 OF 4
CAB ELECTRICAL AND SHIFT LEVER
WIRE HARNESS ARMREST (→ S/N C222E01608K EXC. 01601)
WIRE HARNESS ARMREST (S/N C222E01609K → INC. 01601)
WIRE HARNESS ATTACHMENT SIGNALS - CAB TO FRAME
WIRE HARNESS BOOM EXTENSION - INTERMODAL HANDLER
WIRE HARNESS BOOM EXTENSION - STANDARD SPREADER 2
WIRE HARNESS BOOM EXTENSION - STANDARD SPREADER 1
WIRE HARNESS BOOM LIGHTS
WIRE HARNESS BOOM LIGHTS, INNER AND OUTER
WIRE HARNESS BOOM VALVES (→ 5/2014)
WIRE HARNESS CAB SIDE CONSOLE - PAGE 1 OF 3 (→ S/N C222E01608K EXC. 01601)
WIRE HARNESS CAB SIDE CONSOLE - PAGE 2 OF 3 (→ S/N C222E01608K EXC. 01601)
WIRE HARNESS CAB SIDE CONSOLE - PAGE 3 OF 3 (→ S/N C222E01608K EXC. 01601)
RELAYS AND FUSES
WIRE HARNESS CAB SIDE CONSOLE - PAGE 1 OF 3 (S/N C222E01609K → INC. 01601)
WIRE HARNESS CAB SIDE CONSOLE - PAGE 2 OF 3 (S/N C222E01609K → INC. 01601)
WIRE HARNESS CAB SIDE CONSOLE - PAGE 3 OF 3 (S/N C222E01609K → INC. 01601)
RELAYS AND FUSES
WIRE HARNESS CAB UNDERFLOOR
WIRE HARNESS CHASSIS - PAGE 1 OF 2 (→ S/N C222E01608K EXC. 01601)
WIRE HARNESS CHASSIS - PAGE 2 OF 2 (→ S/N C222E01608K EXC. 01601)
WIRE HARNESS CHASSIS - PAGE 1 OF 2 (S/N C222E01609K ↔ S/N C222E01871M INC. 01601)
WIRE HARNESS CHASSIS - PAGE 2 OF 2 (S/N C222E01609K ↔ S/N C222E01871M INC. 01601)
WIRE HARNESS CHASSIS - PAGE 1 OF 2 (S/N C222E01872M →)
WIRE HARNESS CHASSIS - PAGE 2 OF 2 (S/N C222E01872M →)
WIRE HARNESS CLOSED CAB
WIRE HARNESS COOLANT LEVEL SWITCH - TIER III ENGINE
WIRE HARNESS COOLANT LEVEL SWITCH - TIER IV INTERIM ENGINE
WIRE HARNESS ENGINE COMPARTMENT LIGHT
WIRE HARNESS ENGINE ECM ADAPTER - TIER III ENGINE
WIRE HARNESS ENGINE ECM ADAPTER - TIER IV INTERIM ENGINE
WIRE HARNESS ENGINE POWER - CAB TO FRAME
WIRE HARNESS FRONT LIGHTS
WIRE HARNESS LMI CAN CONNECTION - CAB TO FRAME
WIRE HARNESS LMI COLOR DISPLAY
WIRE HARNESS LMI COLOR DISPLAY - OPTIONAL
WIRE HARNESS LMI MONOCHROME DISPLAY (→ S/N C222E01608K EXC. 01601)
WIRE HARNESS LMI MONOCHROME DISPLAY (S/N C222E01609K → INC. 01601)
WIRE HARNESS LMI MONOCHROME DISPLAY - OPTIONAL
WIRE HARNESS POWERTRAIN CAN CONNECTION - CAB TO FRAME
WIRE HARNESS POWERTRAIN - FULL FLOW
WIRE HARNESS POWERTRAIN SIGNAL 1 - CAB TO FRAME
WIRE HARNESS POWERTRAIN SIGNAL 2 - CAB TO FRAME
WIRE HARNESS REAR
WIRE HARNESS REAR CAB
WIRE HARNESS SLIDING CAB
WIRE HARNESS STEER COLUMN
WIRE HARNESS STOP BUTTON, FRONT - POWERED SLIDING CAB
WIRE HARNESS STOP BUTTON, REAR - POWERED SLIDING CAB
WIRE HARNESS WINDOW WASH PUMPS
EMERGENCY STOP SWITCH CAB WITH AIRCO
EMERGENCY STOP SWITCH CAB WITH HEATER
LIGHT BAR AND MOUNT TWISTLOCK MODULE - LOAD MOMENT INDICATOR (→ S/N C222E01608K EXC. 01601)
LIGHT SWITCHES
LIGHTS ENGINE COMPARTMENT
LIGHTS TAIL AND BACKUP ALARM
LIGHTS FRONT
LIGHTS STROBE
LIGHTS WORK
LOAD LIMITER COLOR DISPLAY
LOAD LIMITER MONOCHROME
SENSOR ASSEMBLY BOOM ANGLE AND EXTENSION (→ S/N C222E01608K EXC. 01601)
SENSOR ASSEMBLY BOOM ANGLE AND EXTENSION (S/N C222E01609K → INC. 01601)
PROXIMITY SWITCH ASSEMBLY CAB MOUNTING
PROXIMITY SWITCH ASSEMBLY REAR HARNESS
ENGINE CONTROL SYSTEM TIER III ENGINE
ELECTRICAL ACCESSORIES TIER III ENGINE
WIRING ACCESSORIES ELECTRONIC CONTROL MODULE - TIER III ENGINES
STARTER MOTOR TIER III ENGINE
ENGINE CONTROL MODULE AND SENSORS TIER IV INTERIM ENGINE
ALTERNATOR TIER III ENGINE (→ 10/2013)
ALTERNATOR TIER III AND IV INTERIM ENGINE (10/2013 → (Tier III Engine))
ALTERNATOR MOUNTING TIER III ENGINE
ALTERNATOR MOUNTING TIER IV INTERIM ENGINE
STARTER TIER IV INTERIM ENGINE
WIRE HARNESS BACK-UP ALARM
WIRE HARNESS TWIST MODULE AND LMI DISPLAY
WIRE HARNESS STABILIZER (→ S/N C222E01608K EXC. 01601)
WIRE HARNESS STABILIZER (S/N C222E01609K → INC. 01601)
WIRE HARNESS ETR CONTROL MODULE - TIER IV INTERIM ENGINE
WIRE HARNESS WIF SENSOR
WIRE HARNESS STABILIZER VALVE
CONTROL PANEL ASSEMBLY CLIMATE CONTROL
TRANSMISSION
TRANSMISSION TORQUE CONVERTER HOUSING
TRANSMISSION CASE AND REAR COVER
TRANSMISSION TURBINE SHAFT, STATOR SUPPORT, OIL BAFFLE
TRANSMISSION INPUT DRIVE GEARS
TRANSMISSION PUMP DRIVE
TRANSMISSION TORQUE CONVERTER AND DRIVE PLATE
TRANSMISSION FORWARD, REVERSE AND SECOND, - AND THIRD OR FOURTH CLUTCH SHAFTS
TRANSMISSION FIRST SPEED GEARS
TRANSMISSION FORWARD CLUTCH SHAFT
TRANSMISSION THIRD SPEED CLUTCH SHAFT
TRANSMISSION THIRD SPEED GEARS
TRANSMISSION REVERSE AND SECOND CLUTCH SHAFT
TRANSMISSION FIRST SPEED CLUTCH SHAFT
TRANSMISSION FOURTH SPEED CLUTCH SHAFT
TRANSMISSION FIRST SPEED SHAFT AND IDLER GEAR
TRANSMISSION OUTPUT SHAFT
TRANSMISSION REGULATOR VALVE AND HYDRAULIC PUMP
TRANSMISSION REGULATOR VALVE ASSEMBLY
TRANSMISSION REMOTE FILTER AND ADAPTER
TRANSMISSION CONTROL VALVE
DRIVE SHAFT
DRIVE SHAFT
TRANSMISSION MOUNTING
TRANSMISSION LINES AND ATTACHING PARTS
Drive Axle
DRIVE AXLE HOUSING (→ S/N C222E01556K INC. 01558-01559, 01561-01562)
DRIVE AXLE DIFFERENTIAL AND CARRIER (→ S/N C222E01556K INC. 01558-01559, 01561-01562)
DRIVE AXLE HUB AND SHAFT (→ S/N C222E01556K INC. 01558-01559, 01561-01562)
BRAKE ASSEMBLY PARK BRAKE (→ S/N C222E01556K INC. 01558-01559, 01561-01562)
BRAKE ASSEMBLY SERVICE BRAKES (→ S/N C222E01556K INC. 01558-01559, 01561-01562)
DRIVE AXLE MOUNTING
HUB ASSEMBLY
SERVICE BRAKE ASSEMBLY
PARK BRAKE ASSEMBLY
PARK BRAKE RETAINER
DRIVE WHEELS AND TIRES 18.00 X 25 (→ 4/2015)
DRIVE WHEELS AND TIRES 18.00 X 25 (4/2015 →)
DRIVE WHEELS AND TIRES 18.00 X 33
DRIVE WHEELS AND TIRES 18.00 X 33 - FOR TRUCKS WITH KESSLER DRIVE AXLE ONLY (S/N C222E01557K → EXC. 01558-01559, 01561-01562)
STEERING SYSTEM
STEER COLUMN ASSEMBLY
STEER COLUMN ASSEMBLY ALTERNATE CONFIGURATION
STEERING COLUMN
STEERING COLUMN AND ATTACHING PARTS
STEERING CONTROL UNIT
STEERING CONTROL VALVE
STEER AXLE AND ATTACHING PARTS
STEER AXLE ASSEMBLY
STEER AXLE ASSEMBLY PAGE 1 OF 2 (S/N C222E01786L →)
STEER AXLE ASSEMBLY PAGE 2 OF 2 (S/N C222E01786L →)
STEERING HOSES
STEER CYLINDER
STEER CYLINDER
STEER TIRES AND WHEELS 18.00 X 25 (→ 4/2015)
STEER TIRES AND WHEELS 18.00 X 25 (4/2015 →)
STEER TIRES AND WHEELS 18.00 X 33
STEER TIRES AND WHEELS 18.00 X 33 - FOR TRUCKS WITH KESSLER DRIVE AXLE ONLY
BRAKE SYSTEM
BRAKE PEDAL LINKAGE
BRAKE PEDAL ASSEMBLY
MAIN MANIFOLD AND ATTACHING BRAKE HOSES
BRAKE ACCUMULATOR AND MOUNTING HARDWARE
HYDRAULIC FILTER AND ATTACHING BRAKE HOSES
HIGH PRESSURE HYDRAULIC FILTER AND ATTACHING BRAKE HOSES
HYDRAULIC PUMP AND ATTACHING BRAKE HOSES
HYDRAULIC TANK AND ATTACHING BRAKE HOSES
DRIVE AXLE AND ATTACHING BRAKE HOSES
COOLER AND ATTACHING BRAKE HOSES
BRAKE VALVE AND ATTACHING BRAKE HOSES
BRAKE MANIFOLD AND ATTACHING BRAKE HOSES
HYDRAULIC SYSTEM
HYDRAULIC SYSTEM PAGE 1 OF 2
HYDRAULIC SYSTEM PAGE 2 OF 2
HYDRAULIC TANK
HYDRAULIC CONTROLS JOYSTICK - CONTAINER HANDLER
HYDRAULIC CONTROLS JOYSTICK - INTERMODAL HANDLER
JOYSTICK ASSEMBLY
HYDRAULIC PUMPS AND ATTACHING PARTS
HYDRAULIC MOTOR POWERED SLIDING CAB
HYDRAULIC CONTROL VALVES MOUNTING
CONTROL VALVES HYDRAULICS
MAIN CONTROL VALVE ATTACHING PARTS
MAIN CONTROL VALVE ASSEMBLY
COMBINATION MANIFOLD ATTACHING PARTS
COMBINATION MANIFOLD ASSEMBLY PAGE 1 OF 2 (→ S/N C222E01671L)
COMBINATION MANIFOLD ASSEMBLY PAGE 2 OF 2 (→ S/N C222E01671L)
COMBINATION MANIFOLD ASSEMBLY PAGE 1 OF 2 (S/N C222E01672L →)
COMBINATION MANIFOLD ASSEMBLY PAGE 2 OF 2 (S/N C222E01672L →)
FLOW AMPLIFIER ATTACHING PARTS
AUTOMATIC GREASING SYSTEM PAGE 1 OF 2
AUTOMATIC GREASING SYSTEM PAGE 2 OF 2
AUTOMATIC GREASING PUMP
STABILZER HYDRAULICS
STABILIZER CYLINDER
STABILIZER VALVE
BLOCK ASSY AND HOSES, TWIN 12-PORT WITH METERING UNIT NUMBERS 9 AND 10 - BASE TRUCK
BLOCK ASSY AND HOSES, TWIN 7-PORT WITH METERING UNIT NUMBERS 9 AND 10 - BOOM FRONT
BLOCK ASSY AND HOSES, TWIN 4-PORT WITH METERING UNIT NUMBER 3 - BOOM REAR
BLOCK ASSY AND HOSES, TWIN 4-PORT WITH METERING UNIT NUMBERS 9 AND 10 - BOOM REAR
Boom
BOOM PAGE 1 OF 4
BOOM PAGE 2 OF 4
BOOM PAGE 3 OF 4
BOOM PAGE 4 OF 4
BOOM MOUNTING
BUMPERS
BUMPERS INSET
BOOM DERRICKING CYLINDER MOUNTING
BOOM HYDRAULIC SYSTEM
EXTENSION CYLINDER BOOM
BOOM DERRICKING CYLINDER ASSEMBLY
LOWERING CONTROL VALVE LOAD HOLDING VALVE - DERRICKING
LOWERING CONTROL VALVE LOAD HOLDING VALVE - TELESCOPING
OPTIONS
OPTIONAL MOUNTING EQUIPMENT (HANDLE)
OPTIONAL MOUNTING EQUIPMENT (HANDLE) ALTERNATE ASSEMBLY
MAP READING LIGHT
TRAINING SEAT
DC-DC CONVERTER AND ATTACHING PARTS
SECOND 12V SOCKET OPTION
HEATED TOP WINDOW
CAB SUNSHADE TOP
CAB SUNSHADE REAR
INSULATION MATS AND AIR DUCT CLOSED CAB WITH AIRCO OR CLIMATE CONTROL
AIR DUCT ASSEMBLY LOUVER SYSTEM
EMPTY SEAT ENGINE SHUTDOWN
SOUND REDUCTION TIER III ENGINE
SOUND REDUCTION TIER IV INTERIM ENGINE
THREE-POINT SEAT BELT
BUMPERS
DIAGNOSTICS INTERFACE CABLE
START AID
ENGINE BLOCK HEATER 240V QSL
ENGINE BLOCK HEATER 240V QSM
FIELD CONVERSION KITS
WATER COOLED TURBOCHARGER
LOUVER - HEAVY DUTY AIRCO
TELEMETRY KITS
PARK BRAKE KIT
ADD-ON OPTION KITS
NUMERICAL INDEX
