Hyster Forklift J4.0XTLG J4.5XTLG J5.0XTLG J5.0XTLGS6 XTLG Service Manual 4387607 2024
Brand: Hyster
Type of Machine: Forklift
Model: Hyster J4.0XTLG J4.5XTLG J5.0XTLG J5.0XTLGS6 XTLG Forklift
Part Number: 4387607
Publication Date: 2024
Number of Pages: 132 Pages
Introduction
Forword
Safety Precautions Maintenance and Repair
Main technical parameters of forklift
Structure, principle, adjustment and maintenance of forklift
Lithium battery and installation
Overview
Structure of lithium battery
Specifications of the lithium battery and charger
Storage of lithium batteries
Application of lithium battery
Maintenance of lithium battery
General precautions
Definition of lithium battery profile and interface
Definition of discharge port pin
Definition of charge port pin
Definition of DC interface connector
Definition of communication port pin
Electrical diagram for battery system
Propel motor and transmission system
Overview
Drive axle
Repair of drive axle
Front tire and rim models
Brake
Automatic clearance adjusting mechanism
Brake disassembly and assembly, adjustment essentials
Reduction gearbox and differential device
Propel motor
Lifting motor
Model and specifications
Use environment
Electrical system
Overview
Precautions for safe operation of high-voltage components
The matters needing attention for the maintenance of each high-voltage component
Electric control characteristics of permanent magnet motor
USB port
Common fault codes for TERCEL AC power control
Vehicle identification device (TSG81)
Steering device and its installation
Overview
Check after the steering system is reinstalled
Troubleshooting
Steering axle and its installation
Overview
Repair
Disassemble
Clean
Inspect
Re-assemble
Reinstall
Steering Cylinder Repair
Remove and Disassemble
Clean and Inspect
Assemble and Install
Foot Brake Operation
Overview
Foot Brake Pedal
Brake Master Pump
Hydraulic assisted braking
Fault Diagnosis
Hydraulic oil tank and its installation
Overview
Hydraulic oil tank
Hydraulic system
Overview
Main oil pump
Multi-way valve
Full hydraulic orbitrol
Speed limit valve
Hydraulic pipeline
Lifting cylinder
Tilting cylinder
Mast system
Overview
Masts
Fork carriage
Lifting chain
Adjustment of lifting system
Adjustment of lifting cylinder
Periodic maintenance schedule
List of Vulnerable Parts
Some vulnerable parts
Combination seal ring
Driving, operating and daily maintenance of forklift truck
Transport
Storage
Pre-use preparation
Operation
Precautions for the use of the cooling system
Environmental requirements for use
Truck oil
Main load-bearing structural parts diagrams
Brand: Hyster
Introduction
Forword
Overview
General precautions
Overview
Drive axle
Brake
Propel motor
Lifting motor
Use environment
Electrical system
Overview
USB port
Overview
Troubleshooting
Overview
Repair
Disassemble
Clean
Inspect
Re-assemble
Reinstall
Clean and Inspect
Overview
Foot Brake Pedal
Brake Master Pump
Fault Diagnosis
Overview
Hydraulic oil tank
Hydraulic system
Overview
Main oil pump
Multi-way valve
Speed limit valve
Hydraulic pipeline
Lifting cylinder
Tilting cylinder
Mast system
Overview
Masts
Fork carriage
Lifting chain
Transport
Storage
Pre-use preparation
Operation
Truck oil
- Hyster Forklift Parts and Service Manual CD7
- Hyster Forklift Parts and Service Manual CD2
- Hyster Forklift Parts and Service Manual CD3
- Hyster Forklift Diagrams and Schematics
- Hyster Forklift Parts and Service Manual CD4
- Hyster Forklift Parts and Service Manual CD10
- Hyster Forklift Parts and Service Manual CD9
- HYSTER Forklift H4.0 Shop Manual
- Hyster Forklift Parts and Service Manual CD6
- Hyster THREE-SPEED POWERSHIFT TRANSMISSION REPAIR Manual
- Hyster Forklift Parts and Service Manual CD5
- Hyster Forklift Parts and Service Manual CD8
- Linde Forklift 353-02D Operator Manual , SAFETY TIPS,Electric and Hydraulic circuit diagram
- Perkins Diesel Engines 1004-42(AR) 1006-60(YG) 1006-60T(YH) Repair And Maintenance Manual
