Hyster Forklift H50CT B274 Parts Manual 4120805 2025
Brand: Hyster
Type of Machine: Forklift
Model: Hyster H50CT B274 Forklift
Part Number: 4120805
Publication Date: 2025
Number of Pages: 406 Pages
Frame
COUNTERWEIGHT
OVERHEAD GUARD
RAIN TOP
HOOD
SEAT NON SUSPENSION - WITH MANUAL HYDRAULIC CONTROLS
SEAT (FULL SUSPENSION) NON SWIVEL - SHEET 1 OF 4
SEAT (FULL SUSPENSION) SERVICE KITS FOR NON-SWIVEL - SHEET 2 OF 4
SEAT (FULL SUSPENSION) RECLINER AND DAMPER KITS - SHEET 3 OF 4
SEAT (FULL SUSPENSION ATTACHING PARTS) NOT INCLUDED WITH SEAT - SHEET 4 OF 4
FLOORPLATES AND COVERS
FENDER EXTENSIONS WIDE TREAD
COWL MOUNT
LOAD BACKREST EXTENSION
FORKS STANDARD
FORKS OPTIONAL
LABELS SHEET 1 OF 2
LABELS SHEET 2 OF 2
LABELS HYDRAULIC CONTROL LABELS - CONTROL LEVER
ENGINE ASSEMBLY - YANMAR
EXHAUST SYSTEM YANMAR - 2.6L DIESEL
COOLING SYSTEM YANMAR - 2.6L DIESEL
ENGINE MOUNTING YANMAR - 2.6L DIESEL
FLYWHEEL AND HOUSING YANMAR - 2.6L DIESEL
FAN ASSEMBLY YANMAR - 2.6L DIESEL
CYLINDER HEAD YANMAR - 2.6L DIESEL
CYLINDER BLOCK YANMAR - 2.6L DIESEL
INTAKE AND EXHAUST MANIFOLD YANMAR - 2.6L DIESEL
GEAR HOUSING YANMAR - 2.6L DIESEL
OIL PAN YANMAR - 2.6L DIESEL
CAMSHAFT AND DRIVE GEAR YANMAR - 2.6L DIESEL
CRANKSHAFT AND PISTONS YANMAR - 2.6L DIESEL
WATER PUMP YANMAR - 2.6L DIESEL
LUBRICATION SYSTEM YANMAR - 2.6L DIESEL
ENGINE ASSEMBLY-PSI
COUNTERWEIGHT EXHAUST SYSTEM WITH CATALYTIC CONVERTER - PSI LPG
COUNTERWEIGHT EXHAUST SYSTEM WITH CATALYTIC CONVERTER - PSI DUAL FUEL
COOLING SYSTEM 2.4L PSI ENGINE
RADIATOR ASSEMBLY PSI 2.4L LPG
ENGINE MOUNTING PSI 2.4L
AUXILIARY DRIVE 2.4L LPG and 2.4L DUAL FUEL
TRANSMISSION INTERFACE PSI 2.4L
ENGINE ELECTRICAL SYSTEM PSI 2.4L
IGNITION COIL PSI 2.4L
STARTER PSI 2.4L
ECM MOUNT PSI 2.4L
FRONT COVER AND OIL PAN PSI 2.4L
CYLINDER BLOCK PSI 2.4L
CYLINDER HEAD PSI 2.4L
CAMSHAFT AND VALVES PSI 2.4L
PISTON AND CRANKSHAFT PSI 2.4L
DIPSTICK PSI 2.4L
WATER PUMP PSI 2.4L
WATER OUTLET PSI 2.4L
INLET HOUSING PSI 2.4L
THERMOSTAT AND HOUSING PSI 2.4L
DCR COOLANT CIRCUIT PSI 2.4L
INTAKE MANIFOLD PSI 2.4L LPG
INTAKE MANIFOLD PSI 2.4L DUAL FUEL
EXHAUST MANIFOLD PSI 2.4L
EXHAUST ADAPTER PSI 2.4L
ROCKER COVER PSI 2.4L
BALANCER PSI 2.4L
OIL PUMP AND FILTER PSI 2.4L
FUEL SYSTEM
AIR INTAKE SYSTEM PSI
AIR INTAKE SYSTEM YANMAR DIESEL
AIR INTAKE SYSTEM AIR FILTER ASSEMBLY
FUEL SYSTEM PSI - WITHOUT LOW FUEL SENSOR
FUEL SYSTEM PSI-DUAL FUEL
FUEL PUMP AND SENDER PSI-DUAL FUEL
THROTTLE BODY 2.4L PSI ENGINE
FUEL REGULATING SYSTEM PSI 2.4L
LOCK-OFF VALVE 2.4L PSI ENGINE
MIXER/EPR AND PCV AIR HOSES PSI 2.4L LPG and 2.4L DUAL FUEL
FUEL RAIL PSI 2.4L DUAL FUEL
FUEL SYSTEM YANMAR DIESEL
FUEL FILTER YANMAR DIESEL
FUEL INJECTION YANMAR DIESEL
LPG FUEL TANK AND MOUNTING STEEL STRAP
THROTTLE PEDAL ASSEMBLY STANDARD PEDAL
THROTTLE CABLE MECHANICAL THROTTLE - YANMAR DIESEL
ELECTRONIC THROTTLE LINKAGE YANMAR DIESEL
ELECTRICAL SYSTEM
ELECTRICAL ARRANGEMENT
ENGINE ELECTRICAL SYSTEM YANMAR DIESEL
ALTERNATOR AND MOUNTING YANMAR DIESEL
BATTERY AND CABLES PSI - LPG/DUAL FUEL
BATTERY AND CABLES YANMAR - DIESEL
DISPLAY CLUSTER WITH STEERING WHEEL
LIGHTS STOP, TAIL, TURN, BACKUP, AND STROBE - WITH OVERHEAD GUARD
WIRE HARNESS RH CHASSIS - SHEET 1 OF 2
WIRE HARNESS RH CHASSIS - SHEET 2 OF 2
WIRE HARNESS RH CHASSIS WITH SEAT BELT SEQUENCE MODULE - SHEET 1 OF 2
WIRE HARNESS RH CHASSIS WITH SEAT BELT SEQUENCE MODULE - SHEET 2 OF 2
WIRE HARNESS LIGHTS
WIRE HARNESS ENGINE - PSI-LPG
WIRE HARNESS ENGINE - PSI-DUAL FUEL
WIRE HARNESS ENGINE - YANMAR DIESEL (POWERTRAIN)
WIRE HARNESS FUSED ALTERNATOR - YANMAR 2.6L DIESEL
TRANSMISSION
TRANSMISSION COOLING YANMAR DIESEL
TRANSMISSION COOLING PSI LPG AND DUAL FUEL
TRANSMISSION MOUNT SINGLE SPEED - ALUMINUM CHAIN DRIVE
TORQUE CONVERTER
TRANSMISSION HOUSING AND ASSEMBLY SINGLE SPEED - ALUMINUM CHAIN DRIVE
TORQUE CONVERTER HOUSING AND ATTACHING PARTS SINGLE SPEED - ALUMINUM CHAIN DRIVE
STATOR SUPPORT HOUSING
INPUT/FORWARD CLUTCH SINGLE SPEED TRANSMISSION
COUNTER/REVERSE CLUTCH SINGLE SPEED TRANSMISSION
CHARGE PUMP ASSEMBLY
Drive Axle
DRIVE AXLE ASSEMBLY
CENTER SECTION
DRIVE TIRE AND WHEEL TRELLEBORG - NARROW TREAD
DRIVE TIRE AND WHEEL MONARCH - NARROW TREAD
DRIVE TIRE AND WHEEL MONARCH - WIDE TREAD
STEERING SYSTEM
STEERING WHEEL AND COLUMN LPG - NON-ISOLATED
STEERING WHEEL AND COLUMN DIESEL - ISOLATED
STEERING COLUMN ASSEMBLY LPG - NON-ISOLATED
STEERING COLUMN ASSEMBLY DIESEL - ISOLATED
STEERING AXLE AND ATTACHING PARTS
STEERING CYLINDER
STEER TIRE AND WHEEL TRELLEBORG - NARROW TREAD
STEER TIRE AND WHEEL MONARCH - NARROW TREAD
STEERING CONTROL UNIT
BRAKE SYSTEM
BRAKE ASSEMBLY
BRAKE PEDAL LINKAGE
PARK BRAKE
HYDRAULIC SYSTEM
HYDRAULIC SUPPLY AND RETURN
HYDRAULIC HOSES STEERING
HYDRAULIC HOSES TILT, HOIST AND AUXILIARY
HYDRAULIC FILTER
GEAR PUMP ASSEMBLY
HAND LEVERS 2 AND 3 FUNCTION
HAND LEVERS 4 FUNCTION
HYDRAULIC CONTROL VALVE ASSEMBLY MANUAL CONTROL - THREE AND FOUR FUNCTION
VALVE ASSEMBLY, LIFT AND TILT MANUAL CONTROL VALVE - THREE AND FOUR FUNCTION
VALVE ASSEMBLY, AUXILIARY ONE AND TWO MANUAL CONTROL VALVE - THREE AND FOUR FUNCTION
VALVE ASSEMBLY OUTLET SECTION MANUAL CONTROL VALVE - THREE AND F0UR FUNCTION
CONTROL VALVE LOCKOUT GROUP MANUAL CONTROL VALVE
MANUAL VALVE ANTI STALL GROUP
TILT CYLINDER AND MAST INSTALLATION
TILT CYLINDER ASSEMBLY
Mast-Three Stage Full Free-Lift
MAST ASSEMBLY OUTER MAST (→ 8/2017)
MAST ASSEMBLY OUTER MAST (8/2017 →)
MAST ASSEMBLY INTERMEDIATE MAST AND MAIN LIFT (→ 8/2017)
MAST ASSEMBLY INTERMEDIATE MAST AND MAIN LIFT (8/2017 →)
MAST ASSEMBLY INNER MAST AND FREE-LIFT (→ 8/2017)
MAST ASSEMBLY INNER MAST AND FREE-LIFT (8/2017 →)
MAIN LIFT CYLINDER ASSEMBLY THREE STAGE FULL FREE LIFT
FREE LIFT CYLINDER ASSEMBLY THREE STAGE FULL FREE LIFT
HEADER HOSE AND ATTACHING PARTS 3 AND 4 FUNCTION
CARRIAGE THREE STAGE FULL FREE-LIFT
OPTIONS
MIRRORS
AUDIBLE BACKUP ALARM
FIRE EXTINGUISHER
INTEGRAL SIDE-SHIFT CARRIAGE TWO STAGE LIMITED FREE-LIFT - 1067 MM 42 IN
INTEGRAL SIDE-SHIFT CARRIAGE THREE STAGE FULL FREE-LIFT (→ 7/2016)
INTEGRAL SIDE-SHIFT CARRIAGE THREE STAGE FULL FREE-LIFT - 1067 MM 42 IN (7/2016 →)
LOWER BEARING KIT INTEGRAL SIDE-SHIFT CARRIAGE - SERVICE OPTION
KIT ISS CARRIAGE - SOLID LINK KIT
INTEGRAL SIDE-SHIFT HYDRAULIC HOSES THREE STAGE FULL FREE-LIFT
INTEGRAL SIDE-SHIFT CYLINDER ROD ASSEMBLY - 8817007
AUXILIARY EXTENSION TUBES THREE STAGE FULL FREE LIFT
NUMERICAL INDEX
Brand: Hyster
Frame
COUNTERWEIGHT
OVERHEAD GUARD
RAIN TOP
HOOD
COWL MOUNT
FORKS STANDARD
FORKS OPTIONAL
LABELS SHEET 1 OF 2
LABELS SHEET 2 OF 2
ENGINE ASSEMBLY-PSI
STARTER PSI 2.4L
ECM MOUNT PSI 2.4L
DIPSTICK PSI 2.4L
WATER PUMP PSI 2.4L
BALANCER PSI 2.4L
FUEL SYSTEM
ELECTRICAL SYSTEM
WIRE HARNESS LIGHTS
TRANSMISSION
TORQUE CONVERTER
Drive Axle
DRIVE AXLE ASSEMBLY
CENTER SECTION
STEERING SYSTEM
STEERING CYLINDER
BRAKE SYSTEM
BRAKE ASSEMBLY
BRAKE PEDAL LINKAGE
PARK BRAKE
HYDRAULIC SYSTEM
HYDRAULIC FILTER
GEAR PUMP ASSEMBLY
OPTIONS
MIRRORS
FIRE EXTINGUISHER
NUMERICAL INDEX
- Hyster Forklift Parts and Service Manual CD7
- Hyster Forklift Parts and Service Manual CD2
- Hyster Forklift Parts and Service Manual CD3
- Hyster Forklift Diagrams and Schematics
- Hyster Forklift Parts and Service Manual CD4
- Hyster Forklift Parts and Service Manual CD10
- Hyster Forklift Parts and Service Manual CD9
- HYSTER Forklift H4.0 Shop Manual
- Hyster Forklift Parts and Service Manual CD6
- Hyster THREE-SPEED POWERSHIFT TRANSMISSION REPAIR Manual
- Hyster Forklift Parts and Service Manual CD5
- Hyster Forklift Parts and Service Manual CD8
- Linde Forklift 353-02D Operator Manual , SAFETY TIPS,Electric and Hydraulic circuit diagram
- Perkins Diesel Engines 1004-42(AR) 1006-60(YG) 1006-60T(YH) Repair And Maintenance Manual
