Hyster Forklift H360XD36 H360XD48 C238 Parts Manual 4266763 2020
Brand: Hyster
Type of Machine: Forklift
Model: Hyster H360XD36 H360XD48 C238 Forklift
Parts Number: 4266763
Publication Date: 2020
Number of Pages: 688 Pages
Frame
Floorplates And Steps
Hoods And Covers
Counterweight Attaching Parts
Cab Mounting And Tilt
Cab Tilt Cylinder
Cab Tilt Pump Assembly
Cab Tilt Pump Electric
Hand Pump
Cab Group Open Cab
Cab Assembly Open Cab
Cab Sub-Assembly Open Cab - Page 1 Of 2
Cab Sub-Assembly Open Cab - Page 2 Of 2
Cab Group Closed Cab
Cab Assembly Closed Cab
Cab Sub-Assembly Closed Cab - Page 1 Of 2
Cab Sub-Assembly Closed Cab - Page 2 Of 2
Cab Noise Panels And Sound Liners Open And Closed Cabs
Cab Rear Wiper Assembly Closed Cab
Cab Heated Window Connectors Cover
Cab Door Lh - Closed Cab
Cab Door Rh - Closed Cab
Cab Window Wiper Assembly Closed Cab
Cab Single Wiper Group
Cab H-Wiper Group
Cab Exterior Mirrors
Cab Roof Panel Group
Cab Roof Mesh
Cab Sunshades
Cab Rh Rear Cover W-O Condenser
Cab Interior Open Cab
Cab Interior Closed Cab
Cab Document Clip
Cab Passenger Seat Mounting
Cab Passenger Seat Assembly
Seat Sliding Rail
Seat Base
Seat And Headrest
Seat And Headrest
Seat Armrest Lh ( Pending Per Ecn 68901-28)
Cab Floormats Open Cab
Cab Floormats Closed Cab
Cab Door Step Open Cab
Cab Door Step Closed Cab
Cab Door Stoppers
Air Conditioner Hoses, Compressor, And Attaching Parts
Condenser And Attaching Parts
Condenser Unit Assembly
Heater Hoses
Cab Heater And Air Conditioner Mounting
Cab Heater And Air Conditioner Assemblies
Labels Page 1 Of 3
Labels Page 2 Of 3
Labels Page 3 Of 3
Engine Assembly
Radiator Assembly
Exhaust System High Mount End Pipe
Exhaust System Low Mount End Pipe
Muffler-Catalytic Converter Assembly Doc
Muffler-Catalytic Converter Assembly Scr
Exhaust Pipe Drt
Engine Mounting
Auxiliary Pump Mounting
Camshaft
Coolant Plumbing
Crankcase Breather
Crankcase Breather Plumbing
Dipstick And Tube
Drive Belt Tensioner
Engine Coolant Vent
Exhaust Manifold
Exhaust Outlet
Exhaust Recirculation
Exhaust Recirculation Air Plumbing
Exhaust Recirculation Water Plumbing
Fan Drive And Mounting
Flywheel And Mounting
Flywheel Housing
Front Gear Cover
Heat Shield
Lifting Brackets
Oil Filter, Full Flow
Oil Pan
Plug, Auxiliary Cooling Plumbing
Plug, Coolant Heater Starting Aid
Plugs, Cab Heater Plumbing
Rear Gear Train Accessory Mounting
Rear Gear Housing
Rocker Levers
Starter Motor
Thermostat
Turbocharger
Turbocharger Plumbing
Valve Cover
Vibration Damper
Water Inlet Connection
Water Outlet Connection
Water Pump And Drive Belt
Fuel System
Def System Page 1 Of 4
Def System Page 2 Of 4
Def System Page 3 Of 4
Def System Page 4 Of 4
Def Tank Assembly
Def Supply Module
Air Intake And Filter Low Mount Air Cleaner
Air Intake And Filter High Mount Air Cleaner With Airco
Air Intake And Filter High Mount Air Cleaner Without Airco
Fuel Lines
Accelerator Pedal Monotrol
Accelerator Pedal Forward-Reverse Lever
Air Intake Connection
Air Intake Manifold
Air Transfer Connection
Drain Plug, Fuel Pump
Fuel Drain Plumbing
Fuel Filter Plumbing
Fuel Filter With Water Separator
Fuel Injector Plumbing
Fuel Injectors
Fuel Inlet Fitting
Electrical System Page 1 Of 2
Electrical System Page 2 Of 2
Cab Electrical Mounting
Cab Electrical Rear Wall
Cab Electrical Roof
Power Distribution
Transmission Controller
Rh Armrest And Controls
Armrest Control Box Assembly
Joystick Assembly With Forward-Neutral-Reverse
Joystick Assembly Without Forward-Neutral-Reverse
Buzzer Assembly
Horn
Beacon And Rear Work Light Mounting Without Condenser
Led Beacon W-Condenser With Beacon-Only Light Harness
Led Beacon W-Condenser With Rear And Beacon Light Harness
Led Beacon W-Condenser With Drive, Rear And Beacon Light Harness
Led Beacon W-O Condenser With Beacon-Only Light Harness
Led Beacon W-O Condenser With Rear And Beacon Light Harness
Led Beacon W-O Condenser With Drive, Rear, And Beacon Light Harness
Lights Drive
Lights Directional And Marker - Led
Lights Front Fender
Lights Mast Work
Lights Rear, With Condenser - With Rear And Beacon Light Harness
Lights Rear, With Condenser - With Drive, Rear, And Beacon Light Harness
Lights Rear, Without Condenser - With Rear And Beacon Light Harness
Lights Rear, Without Condenser - With Drive, Rear, And Beacon Light Harness
Lights Rear Blue Spotlight
Lights Tail
Cab Interior Light Group Standard
Cab Interior Light Group Deluxe
Cab Reading Light
Cab Light-Wiper Controller Group
Cab Display
Cab Door Switch
Cab Fan
Dc-Dc Converter
Second 12v Socket Option
Cab Rear View Camera Rear Mounted
Cab Rear View Camera Front Mounted
Wire Harness Beacon Light
Wire Harness Cab Display
Wire Harness Cab Display - Alternate Part
Wire Harness Cab Lights
Wire Harness Cab Lights W-Beacon
Wire Harness Cab Rear View Camera
Wire Harness Cab Rear View Camera - Alternate Part
Wire Harness Cab Rear View Camera - Front Mounted
Wire Harness Cab Rear Wall - Page 1 Of 2
Wire Harness Cab Rear Wall - Page 2 Of 2
Wire Harness Cab Rear Wall - Page 1 Of 2, Alternate Part
Wire Harness Cab Rear Wall - Page 2 Of 2, Alternate Part
Wire Harness Cab Roof With Controller
Wire Harness Cab Roof With Controller - Alternate Part
Wire Harness Cab Tilt
Wire Harness Carriage
Wire Harness Carriage, Dfssfp - Splitter
Wire Harness Carriage, Std-Ss
Wire Harness Chassis - Page 1 Of 2
Wire Harness Chassis - Page 2 Of 2
Wire Harness Closed Cab Floor
Wire Harness Closed Cab Floor - Alternate Configuration
Wire Harness Def System
Wire Harness Ecm-Eas
Wire Harness Front Lights
Wire Harness Hood Spine
Wire Harness Mast
Wire Harness Mast Light Extension
Wire Harness Mast Work Light
Wire Harness Powertrain
Wire Harness Pressure Switch Base
Wire Harness Pump Base Truck
Wire Harness Rear
Wire Harness Smart Antenna
Wire Harness Steer Column
Wire Harness Washer Pump
Alternator And Mounting
Engine Control Module
Engine Ground
Etr Control Module Wire Harness
Ambient Air Temperature Sensor
Cab Radio Group
Cab Radio Preparation Group
Cab Radio Preparation Group Alternate Configuration
Fuse Box Pdm1 W-O Circuit Breakers
Fuse Box Pdm2 W-O Circuit Breakers
Fuse Box Pdm1 W- Circuit Breakers
Fuse Box Pdm2 W- Circuit Breakers
Fuse Board Cabin W-O Circuit Breakers
Fuse Board Cabin W- Circuit Breakers
Converter
Drive Train
Pressure Oil Pump
Power Take-Off
Engine Connection
Transmission Housing Page 1 Of 2
Transmission Housing Page 2 Of 2
Pressure Filter
Transmission Sensors
Oil Dipstick Access
First Speed Clutch Assembly
Second Speed Clutch Assembly
Third Speed Clutch Assembly
Forward Clutch Assembly
Reverse Clutch Assembly
Output Flange
Control Valve Page 1 Of 4
Control Valve Page 2 Of 4
Control Valve Page 3 Of 4
Control Valve Page 4 Of 4
Pressure Regulator
Universal Shaft
Transmission Hoses And Attaching Parts
Drive Axle
Drive Axle Attaching Parts
Drive Axle Assembly Brake
Drive Axle Assembly Planetary Gear Drive
Drive Axle Assembly Hub
Drive Axle Assembly Park Brake Retainer
Drive Axle Assembly Differential And Carrier
Drive Tire And Wheel Tubeless Pneumatic
Drive Tire And Wheel Tubed Pneumatic
Steer Column And Valve
Steer Column And Valve Alternate Assembly
Steer Column Assembly Alternate Assembly
Turn Signal Lever
Gear Selection Lever
Steer Axle Assembly
Steer Cylinder
Steer Hoses
Steer Tire And Wheel Tubeless Pneumatic
Steer Tire And Wheel Tubed Pneumatic
Brake Accumulator And Attaching Parts
High Pressure Hydraulic Filter And Gear Pump And Attaching Brake Hoses
Hydraulic Control Valve And Attaching Brake Hoses
Brake Valve And Attaching Hoses
Brake Valve And Inching Pedal And Brake Pedal
Brake Valve And Inching Pedal Assembly
Brake Manifold And Attaching Hoses
Automatic Greasing System Steer Axle Greasing
Automatic Greasing System Main Lines
Automatic Greasing System Front Side And Mast - Page 1 Of 2
Automatic Greasing System Front Side And Mast - Page 2 Of 2
Block Assembly And Hoses, Twin 12-Port With Metering Unit Number 1
Block Assembly And Hoses, Twin 7-Port With Metering Units Number 3 And 8
Automatic Greasing Pump Page 1 Of 2
Automatic Greasing Pump Page 2 Of 2
Hydraulic Levers Two-Lever Control Panel
Hydraulic Levers Three-Lever Control Panel
Hydraulic Levers Four-Lever Control Panel
Hydraulic Levers Labels Kit
Hydraulic Pumps And Hoses
Hydraulic Supply And Return With Lift Accumulator
Hydraulic Supply And Return Without Lift Accumulator
Hydraulic Supply And Return Three Function
Hydraulic Supply And Return Four, Five, And Six Function
Hydraulic Tank
Main Hydraulic Control Valve Assembly
Main Hydraulic Control Valve Assembly Alternate Assembly
Hydraulic Control Valve Assembly Hic, Brake-Accumulator Block Assembly
Hydraulic Control Valve Assembly Hic, Mid-Inlet Block Assembly
Main Hydraulic Control Valve And Attaching Parts Page 1 Of 2
Main Hydraulic Control Valve And Attaching Parts Page 2 Of 2
Tilt Cylinders And Attaching Parts
Tilt Cylinder Assembly
Masts
Mast Installation
Outer Mast
Inner Mast
Header Hoses Three Function
Header Hoses Four, Five, Six, And Seven Function
Forks Pin Type
Forks Hook Type
Forks Integrated
Directional Control Valve And Attaching Parts Two-Section, Four-Function
Directional Control Valve Assembly Two-Section, Four-Function
Directional Control Valve And Attaching Parts Three-Section, Five-Function
Directional Control Valve Assembly Three-Section, Five-Function
Directional Control Valve And Attaching Parts Four-Section, Six-Function
Directional Control Valve Assembly Four-Section, Six-Function
Directional Control Valve And Attaching Parts Five-Section, Seven-Function
Directional Control Valve Assembly Five-Section, Seven-Function
Carriage Standard Pin Type - Without Fork Positioner
Carriage Standard Pin Type - With Fork Positioner
Carriage Apron Type - Without Fork Positioner
Carriage Apron Type - With Fork Positioner
Carriage (Dual Function Side-Shift Fork Positioner) Integrated And Qd Hook Type Fork - 350 Mm-13.75 In. Side-Shift With Five-Function Valve
Carriage (Dual Function Side-Shift Fork Positioner) Integrated And Qd Hook Type Fork - 468 Mm-18.40 In. Side-Shift With Five-Function Valve
Carriage (Dual Function Side-Shift Fork Positioner) Integrated And Qd Hook Type Fork - 350 Mm-13.75 In. Side-Shift With Seven-Function Valve
Carriage (Dual Function Side-Shift Fork Positioner) Integrated And Qd Hook Type Fork - 468 Mm-18.40 In. Side-Shift With Seven-Function Valve
Cylinder Assembly Side-Shift And Fork Positioner - 350 Mm-13.75 In. Side-Shift
Cylinder Assembly Side-Shift And Fork Positioner - 468 Mm-18.40 In. Side-Shift
Fork Carrier For Dual Function Side-Shift Fork Positioner Carriages With Quick Disconnect Hook Type Forks
Cylinder Assembly Fork Positioner
Cylinder Assembly Apron
Options
Back-Up Alarm
Bow-Shackles
Display Mount
Engine Block Heater Qsb 6.7 - 120v
Engine Block Heater Assembly Qsb 6.7 - 120v
Id Reader
Impact Sensor
Mud Flaps
Rear View Camera
Smart Antenna With Condenser
Smart Antenna Without Condenser
Tilt Indicator
Field Service Kits
Conversion Kits
Numerical Index
