704,032
Hyster Forklift H1050HD-16CH H1150HD-16CH J117 Parts Manual 4222753 2020
Brand: Hyster
Type of Machine: Forklift
Model: Hyster H1050HD-16CH H1150HD-16CH J117 Forklift
Parts Number: 4222753
Publication Date: 2020
Number of Pages: 910 Pages
Frame
Seat Assembly, Mechanical Suspension
Seat Assembly, Air Suspension
Seat Assembly, Air Suspension Deluxe
Seat Assembly, Air Suspension Deluxe Cover W- 3 Point Belts
Suspension Kit Assembly
Seat Assembly Suspension
Seat Backrest Extension
Mirrors Front Fender
Counterweight
Dash Assembly
Dash Assembly With Telemetry
Armrest Assembly
Pivot Arm Assembly
Cab Door Right Hand
Cab Door Left Hand
Cab Main Door Window Right And Left Hand
Cab Attaching Parts Page 1 Of 4
Cab Attaching Parts Page 2 Of 4
Cab Attaching Parts Page 3 Of 4
Cab Attaching Parts Page 4 Of 4
Air Horn
Cab Floormats
Cab Windows Installation
Window Wiper System Washer Bottle Kit
Window Wiper System Rear And Roof Wiper Kits And Front Wiper Options - Closed Cab Only
Buzzer And Cover
Cab Sound Reduction
Cab Platform Without Automatic Tip-Up
Cab Platform With Automatic Tip-Up
Covers Tier 3 Engine Configuration
Covers Tier 4(F) Engine Configuration
Floorplates, Steps, And Rails Page 1 Of 3
Floorplates, Steps, And Rails Page 2 Of 3
Floorplates, Steps, And Rails Page 3 Of 3
Heater Hoses Tier 3 Engine
Heater Hoses Tier 4(F) Engine
Air Compressor And Hoses Tier 3 Engine
Air Compressor And Hoses Tier 4(F) Engine
Compressor Assembly Tier 4(F) Engine
Heater And Air Duct
Air Duct Assembly Heater
Heater And Control Panel Assembly
Heater Assembly 24v
Air Conditioner System Assembly Cab With Airco
Condenser Cab With Airco Or With Climate Control
Air Duct Assembly Air Conditioning - Cab With Airco Or With Climate Control
Air Conditioner And Control Panel Assembly Manual 24v
Air Conditioner Assembly Manual 24v
Climate Control System Condenser
Air Conditioner And Control Panel Assembly Climate Control Cab
Air Conditioner Assembly 24v - Climate Control
Labels Page 1 Of 3
Labels Page 2 Of 3
Labels Page 3 Of 3
Engine Assembly - Tier 3 Engine
Exhaust System
Cooler Assembly
Expansion Tank And Hoses
Engine Mounting And Charge Air Cooler Tubes
Accessory Drive Pulley
Air Cleaner Plumbing
Breather Plumbing
Cam Follower Levers
Camshaft
Compressor Mounting
Coolant Heater Starting Aid
Corrosion Resistor
Crankshaft Main Bearings
Cylinder Block Plumbing
Engine Oil Fill
Exhaust Manifold
Exhaust Outlet Connection
Fan Drive And Spacer
Flywheel Housing
Flywheel
Front Drive Train
Front Engine Support
Front Gear Cover
Gear Housing
Idler Gear
Intake Connector Air Compressor
Lifting Bracket
Oil Cooler Water Plumbing
Oil Level Gauge
Oil Filler
Oil Filter
Oil Cooler And Filter Head Adapter
Oil Pan
Oil Pump And Attaching Parts
Radiator Plumbing
Thermostat
Thermostat Housing
Turbocharger
Turbocharger Plumbing
Valve Cover
Vibration Damper
Engine Assembly - Tier 4(F) Engine
Exhaust System
Exhaust Pipe Drt
Muffler-Catalytic Converter Assembly Scr
Muffler-Catalytic Converter Assembly Doc
Cooler Assembly
Remote Oil Filter, Hoses, And Attaching Parts
Air Transfer Connection
Belt Tensioner
Breather Plumbing
Cabin Heater Plumbing
Camshaft And Timing Gear
Connecting Rods And Pistons
Crankshaft And Bearings
Cylinder Block Cover
Engine Coolant Plumbing
Engine Support
Exhaust Manifold
Exhaust Recirculation
Exhaust Recirculation Water Plumbing
Exhaust Recirculation Air Plumbing
Fan Drive And Mounting
Flywheel Housing
Flywheel
Front Gear Cover
Front Gear Train Accessory Mounting
Gear Housing
Heat Shield
Intake Manifold
Lifting Brackets
Oil Level Gauge
Oil Filter
Oil Pan
Oil Pump
Plug, Coolant Heater Starting Aid
Plug, Torque Converter Oil Cooler
Rocker Levers
Thermostat
Turbocharger
Turbocharger Water Plumbing
Valve Cover
Vibration Damper
Water Pump And Outlet
Valve Tappet
Fuel System - Tier 3 Engine
Fuel System
Air Intake System
Air Filter Assembly
Pedal Linkage Forward-Reverse Lever
Throttle And Inching Sensors
Air Intake Connection
Air Intake Hose
Air Intake Manifold
Fuel Pump Assembly
Fuel Pump Coupling
Fuel Pump Drive
Fuel Pump Intake Fitting
Fuel Pump Plumbing
Fuel Filter Plumbing
Fuel System - Tier 4(F) Engine
Air Intake System
Fuel System
Def System
Def Supply Module
Def Tank Assembly
Def Tank Assembly
Def Hoses
Def Hoses
Air Intake Hose
Fuel Drain Plumbing
Fuel Filters
Fuel Injectors
Fuel Injector Plumbing
Fuel Pump
Fuel Pump Mounting
Fuel Supply Plumbing
Fuel Transfer Pump
Electrical System Tier 3 Engine - Page 1 Of 2
Electrical System Tier 3 Engine - Page 2 Of 2
Electrical System Tier 4(F) Engine - Page 1 Of 2
Electrical System Tier 4(F) Engine - Page 2 Of 2
Cab Side Console
Cab Hydraulic Controller
Color Display
Buzzer Assembly Telemetry
Proximity Switch
Wire Harness Armrest
Wire Harness Cab Lights
Wire Harness Cab Side Console - Page 1 Of 5
Wire Harness Cab Side Console - Page 2 Of 5
Wire Harness Cab Side Console - Page 3 Of 5
Wire Harness Cab Side Console - Page 4 Of 5
Wire Harness Cab Side Console - Page 5 Of 5
Wire Harness Cab Side Console - Page 1 Of 5, Alternate Part
Wire Harness Cab Side Console - Page 2 Of 5, Alternate Part
Wire Harness Cab Side Console - Page 3 Of 5, Alternate Part
Wire Harness Cab Side Console - Page 4 Of 5, Alternate Part
Wire Harness Cab Side Console - Page 5 Of 5, Alternate Part
Wire Harness Cab Tip-Up Lift Proximity Switch
Wire Harness Cab Underfloor
Wire Harness Can Display
Wire Harness Chassis - Page 1 Of 2
Wire Harness Chassis - Page 2 Of 2
Wire Harness Chassis - Page 1 Of 2, Alternate Part
Wire Harness Chassis - Page 2 Of 2, Alternate Part
Wire Harness Closed Cab
Wire Harness Coolant Level Switch - Tier 3 Engine
Wire Harness Coolant Level Switch - Tier 4(F) Engine
Wire Harness Eas-Ecm - Tier 4(F) Engine
Wire Harness Ecm Adapter - Tier 3 Engine
Wire Harness Eco-Elo-Hip
Wire Harness Engine
Wire Harness Engine Compartment Light
Wire Harness Front Lights, Lh
Wire Harness Front Lights, Rh
Wire Harness Grid Heater
Wire Harness Manifold
Wire Harness Mast
Wire Harness Pdm
Wire Harness Power Pile Slope
Wire Harness Pressure Switch Base
Wire Harness Proximity Switch, Lift And Tilt
Wire Harness Pump Base Truck
Wire Harness Rear
Wire Harness Rear View Camera
Wire Harness Rear Wiper Extension
Wire Harness Steer Column
Wire Harness Telemetry - Fm2a
Wire Harness Telemetry - Fm1b
Wire Harness Telemetry - Fm1a
Wire Harness Transmission
Wire Harness Wif Sensor
Wire Harness Window Wash Pumps
Lights Engine Compartment - Halogen
Lights Engine Compartment - Led
Lights Front Fender
Lights Tail
Lights Strobe, With Condenser
Lights Strobe, Without Condenser
Lights Work - Without Condenser
Lights Work - With Condenser
Back-Up Alarm
Alternator Tier 3 And Tier 4(F) Engine
Alternator Mounting Tier 3 Engine
Alternator Drive Pulley Tier 3 Engine
Engine Control System Tier 3 Engine
Starter Motor And Mounting Tier 3 Engine
Wiring Accessories Electronic Control Module - Tier 3 Engine
Alternator Mounting Tier 4(F) Engine
Engine Control Module Tier 4(F) Engine
Etr Control Module Wire Harness Tier 4(F) Engine
Starter Tier 4(F) Engine
Control Panel Assembly Heater
Control Panel Assembly Heater And Air Conditioner
Inductive Sensor Assembly
Cab Tip Up Electrical
Indicator Display And Controls
Drive Shaft
Transmission Mounting
Transmission Attaching Parts
Transmission Torque Converter Housing
Transmission Case And Rear Cover
Transmission Turbine Shaft, Stator Support, Oil Baffle
Transmission Input Drive Gears
Transmission Pump Drive
Transmission Torque Converter And Drive Plate
Transmission Forward, Reverse And Second, - And Third Or Fourth Clutch Shafts
Transmission First Speed Gears
Transmission Forward Clutch Shaft
Transmission Third Speed Clutch Shaft
Transmission Third Speed Gears
Transmission Reverse And Second Clutch Shaft
Transmission First Speed Clutch Shaft
Transmission Fourth Speed Clutch Shaft
Transmission First Speed Shaft And Idler Gear
Transmission Output Shaft
Transmission Regulator Valve And Hydraulic Pump
Transmission Remote Filter And Adapter
Transmission Control Valve
Transmission Control Valve Attaching Parts
Transmission Regulator Valve Assembly
Drive Axle
Drive Axle Mounting
Differential And Carrier Assembly
Hub Assembly Standard Track Drive Axle
Hub Assembly Wide Track Axle
Service Brake Assembly
Park Brake Retainer
Park Brake Assembly
Drive Wheels And Tires 18.00 X 25
Drive Wheels And Tires 18.00 X 33
Steer Axle And Attaching Parts
Steer Axle Assembly Page 1 Of 2
Steer Axle Assembly Page 2 Of 2
Steer Cylinder
Steering Hoses
Steer Column Assembly
Steering Column
Steering Control Unit
Steering Control Valve
Steer Tires And Wheels 18.00 X 25
Steer Tires And Wheels 18.00 X 33
Brake Pedal Assembly
Brake Pedal Linkage
High Pressure Hydraulic Filter And Attaching Brake Hoses
Brake Manifold And Attaching Brake Hoses
Brake Accumulator And Mounting Hardware
Drive Axle And Attaching Brake Hoses
Hydraulic Tank And Attaching Brake Hoses
Main Manifold And Attaching Brake Hoses
Hydraulic Pump And Attaching Brake Hoses
Cooler And Attaching Brake Hoses
Brake Valve And Attaching Brake Hoses
Hydraulic Tank
Tilt Hydraulics
Lift-Tilt Manifold And Attaching Hydraulic Hoses
Manifold Assembly Lift And Tilt
Tilt Cylinders And Attaching Parts
Tilt Cylinder Assembly 6 Deg. Fwd., 10 Deg. Back
Hydraulic Controls Joystick
Joystick Assembly
Lift Accumulator And Attaching Parts
Hydraulic Pumps
Hydraulic Gear Pump Fixed Displacement
Control Valves Mounting
Main Manifold And Attaching Hydraulic Hoses
Manifold Assembly Main
Flow Amplifier And Attaching Hydraulic Hoses
Main Hydraulic Control Valve And Attaching Hydraulic Hoses
Control Valve Assembly Auxiliary
Control Valve Assembly Lift
Control Valve Assembly Lift And Tilt
Control Valve Assembly Cap And Support Kit
Automatic Greasing System Page 1 Of 4
Automatic Greasing System Page 2 Of 4
Automatic Greasing System Page 3 Of 4
Automatic Greasing System Page 4 Of 4
Automatic Greasing Pump
Block Assembly And Hoses, Twin 7-Port With Metering Unit Numbers 4 And 8 - Mast Mounting Lubrication
Block Assembly And Hoses, Twin 12-Port With Metering Unit Numbers 3, 8, And 10 - Steer Axle Lubrication
Mast With Container Handler
Mast Installation
Mast Assembly
Lift Cylinder 7010 Mm (275.9 In.), And 9754 Mm (384.0 In.) Lift Height
Lift Cylinder 12650 Mm (498.0 In.) Lift Height
Lift Cylinder 15550 Mm (612.2 In.) Lift Height
Header Hoses
Dedicated Carriage
Gantry Carriage Installation
Chain Anchor Protection Option
Elme Attachment - Model 750 - Gantry Carriage Mechanical Parts - Gantry Assembly
Elme Attachment - Model 750 - Gantry Carriage Hydraulic Parts - Cylinder Assembly, Power Pile Slope
Elme Attachment - Model 750 - Gantry Carriage Hydraulic Parts - Valve Assembly
Elme Attachment - Model 750 - Gantry Carriage Additional Parts - Hose Clamps - Single, Rubber
Elme Attachment - Model 750 - Gantry Carriage Additional Parts - Hose Clamps - Single, Standard
Elme Attachment - Model 750 - Gantry Carriage Additional Parts - Hose Clamps - Twin
Elme Attachment - Model 750 - Gantry Carriage Additional Parts - Bracket For Hoses
Elme Attachment - Model 750 - Gantry Carriage Additional Parts - Miscellaneous Fittings
Elme Attachment - Model 818 - Canbus Gantry Mount
Mechanical Parts Main Frame
Mechanical Parts Wear Pads
Mechanical Parts Pendular Twistlock Assembly
Hydraulic Parts Extension Cylinder Assembly
Hydraulic Parts Sideshift Cylinder Assembly
Hydraulic Parts Slew-Reach Cylinder Assembly
Hydraulic Parts Valve Assembly - Extension
Hydraulic Parts Hydraulic System
Hydraulic Parts Miscellaneous Fittings
Additional Parts Hose Clamps - Single, Standard
Additional Parts Hose Clamps - Single, Rubber
Additional Parts Hose Clamps - Twin
Additional Parts Bracket For Deutsch Connectors
Additional Parts Pins For Hangers
Elme Attachment - Model 813 - Canbus Dedicated
Hydraulic Parts Valve Assembly - Sideshift And Slew-Reach
Additional Parts Plate And Bridge
Additional Parts Cover Plate
Additional Parts Bumpers - Flush
Additional Parts Bumpers - Inset
Options
Air Duct Assembly
Cab Recirculating Fan
Cab Sound And Thermal Insulation
Cab Sunshade Top
Cab Sunshade Rear
Camera Display Front
Camera Display Rear
Controller Seat Belt Sequencer
Dc-Dc Converter And Attaching Parts
Empty Seat Engine Shutdown
Engine Heater Assembly Tier 3 Engine
Engine Heater Assembly Tier 4(F) Engine
Forward Alarm
Heated Top Window
Insulation Mats And Air Duct
Map Reading Light
Optional Mounting Equipment (Handle)
Radio Console And Attaching Parts
Rear Camera
Rear Locking Console
Led Strobe Light With Condenser
Led Strobe Light Without Condenser
Second 12v Socket Option Only With Dc-Dc Converter
Speed Limiting Canbus Attachment
Start Aid
Telemetry Card Reader
Telemetry Hyster Checklist
Telemetry Monitoring And Interlock
Tilt Indicator
Training Seat
Wire Mesh Roof Protection
Numerical Index
