Hyster Forklift H1.6A H1.8A H2.0AS (H001) Parts Manual 4328566 2025
Brand: Hyster
Type of Machine: Forklift
Model: Hyster H1.6A H1.8A H2.0AS (H001) Forklift
Part Number: 4328566
Publication Date: 2025
Number of Pages: 670 Pages
Frame
COUNTERWEIGHT
COVERS OPERATOR COMPARTMENT
COVERS EXTERIOR
DOORS PVC (→ 7/2024)
DOORS PVC (7/2024 →)
DOORS STEEL
FRAME ASSEMBLY
FRONT SCREEN
FRONT SCREEN NON HEATED (10/2023 →)
FRONT SCREEN HEATED (10/2023 →)
HEADLINER CAB
HEADLINER NO CAB - ALTERNATE CONFIGURATION
HEADLINER ROCKER SWITCH ARRANGEMENT WITH DOME LIGHT
HEATER AND ATTACHING PARTS 2.2L LPG
HEATER AND ATTACHING PARTS 2.6L DIESEL
HOOD AND ATTACHING PARTS
MAST AND TILT CYLINDER INSTALLATION
OPERATOR COMPARTMENT SEALS
OVERHEAD GUARD FIG8
OVERHEAD GUARD RECTANGLE
RAIN TOP
REAR SCREEN
SEAT ASSEMBLY NON SUSPENSION
SEATS FULL AND AIR SUSPENSION
SEAT ASSEMBLY FULL SUSPENSION - GRAMMER
SEAT ASSEMBLY FULL SUSPENSION - TIANCHENG
SEAT ASSEMBLY AIR SUSPENSION - GRAMMER
SEAT BELT OPTIONS
MLM ARMREST SLIDER ASSEMBLY
TOP SCREEN
WASHER FLUID PLUMBING
WASHER FLUID RESERVOIR ASSEMBLY
LABELS MLM AND JOYSTICK
LABELS PAGE 1 OF 3
LABELS PAGE 2 OF 3
LABELS PAGE 3 OF 3
NOISE ABATEMENT HOOD LINERS
NOISE ABATEMENT DASH AND KICK PANEL LINERS
NOISE ABATEMENT OHG LINERS, FLOORMAT AND RADIATOR COVER
AIR INLET SYSTEM
AIR INLET SYSTEM OHG - 2.2L LPG/BI-FUEL
AIR INLET PRE-CLEANER AND DUCT
ENGINE ASSEMBLY - YANMAR 2.2L LPG
ENGINE MOUNTING AND TORQUE CONVERTER
CYLINDER BLOCK
GEAR HOUSING
FLYWHEEL AND HOUSING
CYLINDER HEAD AND COVER
CRANKSHAFT AND PISTON
CAMSHAFT AND IDLE GEAR
INTAKE MANIFOLD
EXHAUST MANIFOLD
OIL SYSTEM
WATER PUMP AND COOLING BELT
FUEL RAIL AND INJECTOR ASSEMBLY
STARTER
ALTERNATOR
ELECTRICAL PARTS
COOLING SYSTEM
HYDRAULIC FAN DRIVE
COOLING SYSTEM
EXHAUST SYSTEM
EXHAUST SYSTEM 2.2L LPG/BI-FUEL - WITH CATALYTIC CONVERTER
EXHAUST SYSTEM 2.2L LPG/BI-FUEL - WITH RESONATOR
FUEL SYSTEM
FUEL SYSTEM 2.6L DIESEL
FUEL SYSTEM BI-FUEL
FUEL SYSTEM LPG - WITH FUEL QUALITY SENSOR
THROTTLE PEDAL SINGLE
THROTTLE PEDAL MONOTROL
LPG HOSE GUIDE LPG BRACKET ASSEMBLY
LPG BRACKET ASSEMBLY SWING OUT - STEEL STRAP
LPG BRACKET ASSEMBLY DROP DOWN - STEEL STRAP
LPG BRACKET ASSEMBLY SWING OUT - FABRIC STRAP
LPG BRACKET ASSEMBLY DROP DOWN - FABRIC STRAP
LPG BRACKET ASSEMBLY SWING OUT DROP DOWN - TWIN STEEL STRAPS (MFG OPTION)
FUEL CAP BI-FUEL OPTION
ELECTRICAL SYSTEM
12V BATTERY ARRANGEMENT 2.2 LPG/GAS - W/ CONTACTOR
12V BATTERY ARRANGEMENT 2.2 LPG/GAS - W/ CONTACTOR AND DISCONNECT
12V BATTERY ARRANGEMENT 2.2 LPG/GAS - W/ DISCONNECT
AMBIENT LIGHT SENSOR
AUDIBLE ALARM
BATTERY 12V
BATTERY DISCONNECT SWITCH LOW VOLTAGE AND TYPE-S
CAB HARNESS
CONTROLLERS COWL MOUNTED
CONTROLLERS RH FRAME MOUNTED
CONTROL PANEL MHYD ACCESSORY 1
DASH ROCKER SWITCH ARRANGEMENT WORK LIGHT - WITH USB AND 12V OUTLETS
DISPLAY
FUSE BOX MOUNTING
HARNESS RETENTION ENGINE - 2.2L LPG/BI-FUEL
HARNESS RETENTION OHG, RADIATOR SHROUD, AND AUDIBLE ALARM
HARNESS RETENTION SINGLE SPEED TRANSMISSION
HORN
IMPACT SENSOR
JOYSTICK ASSEMBLY
LIFT HEIGHT SENSOR 2 STAGE LFL
LIFT HEIGHT SENSOR 2 AND 3 STAGE FFL
LIGHTS WORK LIGHTS - FRONT MARKER
LIGHTS WORK LIGHTS - TWO FRONT / ONE REAR
LIGHTS TAIL LIGHTS AND REFLECTORS
LIGHTS SPOT LIGHTS AND STROBE
LIGHTS RED LINE - WITH REAR WORK LIGHT
MAST ELECTRICAL ARRANGEMENT WITH MAST LIGHTS
MAST ELECTRICAL WIRE TAKE-UP - 2LFL
MAST ELECTRICAL WIRE TAKE-UP - 3FFL
MINI-LEVER CONTROLS THREE FUNCTION - WITHOUT RTST
MINI-LEVER CONTROLS THREE FUNCTION - WITH RTST
MINI-LEVER CONTROLS FOUR FUNCTION - WITHOUT RTST
MINI-LEVER CONTROLS FOUR FUNCTION - WITH RTST
MINI-LEVER CONTROLS THREE FUNCTION WITH SHELF HEIGHT SELECTOR - WITHOUT RTST
MINI-LEVER CONTROLS THREE FUNCTION WITH SHELF HEIGHT SELECTOR - WITH RTST
MINI-LEVER CONTROLS FOUR FUNCTION WITH SHELF HEIGHT SELECTOR - WITHOUT RTST
MINI-LEVER CONTROLS FOUR FUNCTION WITH SHELF HEIGHT SELECTOR - WITH RTST
OHG WITHOUT REAR LIGHT RESISTOR AND ATTACHING PARTS
POWER TO MAST HARNESS AND ANCILLARY PARTS
TELEMETRY OPTIONS
TILT SENSOR
TRUCK START PUSHBUTTON WITH REMOTE KEY SWITCH
WIRE HARNESS AUDIBLE ALARM JUMPER
WIRE HARNESS 12V AUXILIARY SUPPLY
WIRE HARNESS AUX 2 - CONTACTOR CONTROL POWER
WIRE HARNESS AUX 2 - CONTACTOR KEYED POWER
WIRE HARNESS AUX 2 - HYDRAULIC FAN DRIVE
WIRE HARNESS CAB - UPPER
WIRE HARNESS CAB - LOWER
WIRE HARNESS CAB - WASHER PUMP JUMPER
WIRE HARNESS CHASSIS
WIRE HARNESS DISPLAY
WIRE HARNESS E-HYDRAULICS
WIRE HARNESS FRONT OHG
WIRE HARNESS REAR CAMERA - WITH FRONT DISPLAY
WIRE HARNESS REAR CAMERA - WITH REAR DISPLAY
WIRE HARNESS STEER AXLE JUMPER
WIRE HARNESS FUEL PUMP
WIRE HARNESS SEAT - AIR RIDE SUSPENSION
WIRE HARNESS LOWER MAST WORK LIGHTS - 4 LIGHTS
WIRE HARNESS LOWER MAST WORK LIGHTS - 2 LIGHTS
WIRE HARNESS UPPER MAST WORK LIGHT
WIRE HARNESS SEAT - MECHANICAL SUSPENSION
WIRE HARNESS PARKING BRAKE - WET BRAKE ACTUATION (→ 12/2024)
WIRE HARNESS AUTO HIBERNATION - PARKING BRAKE (12/2024 →)
WIRE HARNESS REAR OHG - BASE OPTION
WIRE HARNESS REAR OHG - MID OPTION
WIRE HARNESS REAR OHG (FULL OPTION)
WIRE HARNESS COLUMN - BASE
WIRE HARNESS COLUMN - FULL LEVERS
TRANSMISSION
TRANSMISSION ASSEMBLY POWERSHIFT (WET OR DRY BRAKE) - PAGE 1 OF 2
TRANSMISSION ASSEMBLY POWERSHIFT (WET OR DRY BRAKE) - PAGE 2 OF 2
CONTROL VALVE POWERSHIFT (WET OR DRY BRAKE) - BASIC
CONTROL VALVE POWERSHIFT (WET OR DRY BRAKE) - PREMIUM
CLUTCH PACK FORWARD AND REVERSE - POWERSHIFT
DRIVE SHAFT
Drive Axle
DRIVE AXLE DRY BRAKE ASSEMBLY - PAGE 1 OF 3
DRIVE AXLE AXLE PLUMBING - DRY BRAKE (PAGE 2 OF 3)
DRIVE AXLE CENTER SECTION - DRY BRAKE (PAGE 3 OF 3)
DRIVE AXLE ASSEMBLY WET BRAKE - HOUSING
DRIVE AXLE ASSEMBLY DIFFERENTIAL - WET BRAKE
DRIVE AXLE ASSEMBLY ARM ASSEMBLY - WET BRAKE
DRIVE AXLE ASSEMBLY WHEEL HUB - WET BRAKE
DRIVE AXLE ASSEMBLY WET BRAKE - INPUT FLANGE
DRIVE TIRE AND WHEEL SOLID
FENDERS WITH ANTI-STATIC STRAP
STEERING SYSTEM
STEER AXLE
STEER CYLINDER ASSEMBLY
STEER COLUMN AND ATTACHING PARTS TILT ONLY
STEER COLUMN AND ATTACHING PARTS TILT AND TELESCOPE
STEER COLUMN ASSEMBLY TILT ONLY
SENSOR SYNCHRONOUS STEERING
STEER TIRE AND WHEEL 5.00 X 8
STEER TIRE AND WHEEL 18 X 7-8
BRAKE SYSTEM
BRAKE ASSEMBLY
BRAKE PEDAL SINGLE
BRAKE PEDAL DUAL
BRAKE MASTER CYLINDER ASSEMBLY DRY BRAKE
BRAKE ACTUATOR ARRANGEMENT DRY BRAKE
BRAKE ASSEMBLY DRY BRAKE
DRIVE AXLE BRAKE PLUMBING WET BRAKE AXLE
AUTOPARKING VALVE MOUNTING - POWERSHIFT TRANSMISSION
BRAKE ACTUATOR ARRANGEMENT WET BRAKE - BOOSTED
PARKING BRAKE LEVER
PARKING BRAKE LEVER ASSEMBLY (→ 9/2023)
PARKING BRAKE LEVER ASSEMBLY (9/2023 →)
HYDRAULIC SYSTEM
HYDRAULIC SUPPLY AND RETURN GEAR PUMP
HYDRAULIC SUPPLY AND RETURN PISTON PUMP
ACCUMULATOR HYDRAULIC SYSTEM - WITH VDP, WITHOUT HFD
ACCUMULATOR HYDRAULIC SYSTEM - WITH VDP, WITH HFD
TILT HYDRAULICS WITHOUT RTST
TILT HYDRAULICS WITH RTST AND MHYD - WITH AND WITHOUT HFD
TILT CYLINDERS
TRANSMISSION COOLING POWERSHIFT TRANSMISSION (→ 6/2024)
TRANSMISSION COOLING POWERSHIFT TRANSMISSION (6/2024 →)
HYDRAULIC HOSES HOIST AND AUXILIARY - 3FFL AND 2LFL
HYDRAULIC HOSES HOIST AND AUXILIARY - 2FFL
HAND LEVERS 2 FUNCTION - WITHOUT DETENT
HAND LEVERS 3 FUNCTION - WITHOUT DETENT
HAND LEVERS 4 FUNCTION - WITHOUT DETENT
HAND LEVERS 3 FUNCTION - WITH DETENT
HAND LEVERS 4 FUNCTION - WITH DETENT
HYDRAULIC LEVERS WITH RTST - 2 FUNCTION
HYDRAULIC LEVERS WITH RTST - 3 FUNCTION
HYDRAULIC LEVERS WITH RTST - 3 FUNCTION WITH DETENT
HYDRAULIC LEVERS WITH RTST - 4 FUNCTION
HYDRAULIC LEVERS WITH RTST - 4 FUNCTION WITH DETENT
HYDRAULIC CONTROL VALVE ASSEMBLY MANUAL HYDRAULICS
HYDRAULIC CONTROL VALVE ASSEMBLY INLET SECTION - MANUAL HYDRAULICS
HYDRAULIC CONTROL VALVE ASSEMBLY FAN DRIVE SECTION WITH VDP, WITH HFD - MANUAL HYDRAULICS
HYDRAULIC CONTROL VALVE ASSEMBLY LIFT AND LOWER - MANUAL HYDRAULICS
HYDRAULIC CONTROL VALVE ASSEMBLY TILT SECTION - MANUAL HYDRAULICS
HYDRAULIC CONTROL VALVE ASSEMBLY AUXILIARY VALVE - MANUAL HYDRAULICS
HYDRAULIC CONTROL VALVE ASSEMBLY OUTLET SECTION - MANUAL HYDRAULICS
HYDRAULIC CONTROL VALVE ASSEMBLY ELECTRONIC HYDRAULICS
HYDRAULIC CONTROL VALVE ASSEMBLY WITH VDP, WITH HFD - ELECTRONIC HYDRAULICS
HYDRAULIC CONTROL VALVE ASSEMBLY INLET SECTION - ELECTRONIC HYDRAULICS
HYDRAULIC CONTROL VALVE ASSEMBLY TILT AND AUXILIARY SECTION - ELECTRONIC HYDRAULICS
HYDRAULIC CONTROL VALVE ASSEMBLY LIFT SECTION - ELECTRONIC HYDRAULICS
HYDRAULIC CONTROL VALVE ASSEMBLY OUTLET SECTION - ELECTRONIC HYDRAULICS
HYDRAULIC CONTROL VALVE ASSEMBLY FAN DRIVE SECTION WITH VDP, WITH HFD - ELECTRONIC HYDRAULICS
HYDRAULIC PISTON PUMP
STEER HYDRAULICS
Mast-Two Stage Limited Free-Lift
MAST ASSEMBLY TWO STAGE LIMITED FREE-LIFT
MAIN LIFT CYLINDER ASSEMBLY TWO STAGE LIMITED FREE-LIFT
HEADER HOSE AND ATTACHING PARTS
CARRIAGE STANDARD - TWO STAGE LIMITED FREE-LIFT
CARRIAGE INTEGRAL SIDE-SHIFT - TWO STAGE LIMITED FREE-LIFT
Mast-Two Stage Full Free-Lift
MAST ASSEMBLY TWO STAGE FULL FREE-LIFT - PAGE 1 OF 2
MAST ASSEMBLY TWO STAGE FULL FREE-LIFT - PAGE 2 OF 2
LEFT HAND MAIN LIFT CYLINDER TWO STAGE FULL FREE-LIFT
RIGHT HAND MAIN LIFT CYLINDERS TWO STAGE FULL FREE-LIFT
FREE-LIFT CYLINDER TWO STAGE FULL FREE-LIFT
CARRIAGE STANDARD - TWO STAGE FULL FREE-LIFT
CARRIAGE INTEGRAL SIDE-SHIFT - TWO STAGE FULL FREE-LIFT
FREE LIFT TUBES TWO STAGE FULL FREE-LIFT
HEADER HOSE AND ATTACHING PARTS TWO STAGE FULL FREE- LIFT
Mast-Three Stage Full Free-Lift
MAST ASSEMBLY THREE STAGE FULL FREE-LIFT - PAGE 1 OF 3
MAST ASSEMBLY THREE STAGE FULL FREE-LIFT - PAGE 2 OF 3
MAST ASSEMBLY THREE STAGE FULL FREE-LIFT - PAGE 3 OF 3
MAIN LIFT CYLINDER THREE STAGE FULL FREE-LIFT
FREE-LIFT CYLINDER THREE STAGE FULL FREE-LIFT
HEADER HOSE AND ATTACHING PARTS THREE STAGE FULL FREE-LIFT
FREE LIFT TUBES THREE STAGE FULL FREE-LIFT - LOW
FREE LIFT TUBES THREE STAGE FULL FREE-LIFT - HIGH
CARRIAGE STANDARD - THREE STAGE FULL FREE-LIFT
CARRIAGE INTEGRAL SIDE-SHIFT - THREE STAGE FULL FREE-LIFT
FORKS AND LOAD BACKREST
FORKS BOLZONI
FORKS CASCADE - OPTIONAL
LOAD BACKREST EXTENSION
OPTIONS
ACCESSORY BAR FIXED
ACCESSORY BAR SWING OUT - FIGURE 8 OHG
ACCESSORY BAR SWING OUT - RECTANGULAR OHG
ACCESSORY BAR SWING OUT - RECTANGULAR OHG (ALTERNATE CONFIGURATION
ACCESSORY BAR OPTION CUP HOLDER
ACCESSORY BAR OPTION MONITOR HOLDER
ACCESSORY BAR OPTION PHONE HOLDER
ACCESSORY BAR OPTION SCANNER HOLDER
ACCESSORY BAR OPTION TABLET HOLDER
ACCESSORY BAR OPTION TAPE ROLL HOLDER
ACCUMULATOR MAST
AUXILIARY EXTENSION TUBES TWO STAGE LFL - STANDARD AND ISS CARRIAGE
AUXILIARY EXTENSION TUBES STANDARD CARRIAGE - TWO AND THREE STAGE FFL
AUXILIARY EXTENSION TUBES ISS CARRIAGE - TWO AND THREE STAGE FULL FREE-LIFT
BELLY SCREEN
BLOCK HEATER 240V - YANMAR 2.2L LPG
CAB SHADES TOP AND FRONT
CONVENIENCE TRAY TYPE S
CONVENIENCE TRAY
DUAL MIRRORS RECTANGLE OHG
FAN MOUNTED - NON CAB
FAN MOUNTED - CAB
FIRE EXTINGUISHER COWL MOUNTED
FORK POSITIONER BOLZONI
FORK POSITIONER CASCADE
FORK POSITIONER ASSEMBLY CASCADE
HOSE GUIDE LPG SYSTEM
LPG TANK BRACKET INTERLOCK SENSOR
OVERHEAD GUARD ACCESSORY OPTIONS MIRRORS AND REAR HANDLE - FIGURE 8 OHG
PANORAMIC MIRROR RECTANGLE OHG
REAR CAMERA
TILT CYLINDER BOOTS
FIELD CONVERSION KITS
ADD-ON OPTION KITS AUDIBLE BACKUP ALARM
ADD-ON KITS
ADD-ON KITS AUX EXTENSION TUBES
ADD-ON OPTION KITS HYDRAULIC
ADD-ON OPTION KITS LIGHTS
CONVERSION KITS CARRIAGE FRAME
CONVERSION KITS HYDRAULIC CONTROL VALVES - ELECTRIC HYDRAULICS
CONVERSION KITS HYDRAULIC CONTROL VALVES - EHYD JOYSTICK
CONVERSION KITS HYDRAULIC CONTROL VALVES - EHYD MINI LEVER MODULE
CONVERSION KITS HYDRAULIC CONTROL VALVES - MANUAL HYDRAULICS
HEADER HOSE KITS 2 TO 3 WAY - THREE STAGE FFL
HEADER HOSE KITS 2 TO 4 WAY - THREE STAGE FFL
HEADER HOSE KITS 3 TO 4 WAY - THREE STAGE FFL
REPAIR KITS
NUMERICAL INDEX
Brand: Hyster
Frame
COUNTERWEIGHT
COVERS EXTERIOR
DOORS STEEL
FRAME ASSEMBLY
FRONT SCREEN
HEADLINER CAB
OVERHEAD GUARD FIG8
RAIN TOP
REAR SCREEN
SEAT BELT OPTIONS
TOP SCREEN
LABELS PAGE 1 OF 3
LABELS PAGE 2 OF 3
LABELS PAGE 3 OF 3
AIR INLET SYSTEM
CYLINDER BLOCK
GEAR HOUSING
INTAKE MANIFOLD
EXHAUST MANIFOLD
OIL SYSTEM
STARTER
ALTERNATOR
ELECTRICAL PARTS
COOLING SYSTEM
HYDRAULIC FAN DRIVE
COOLING SYSTEM
EXHAUST SYSTEM
FUEL SYSTEM
FUEL SYSTEM BI-FUEL
ELECTRICAL SYSTEM
AUDIBLE ALARM
BATTERY 12V
CAB HARNESS
DISPLAY
FUSE BOX MOUNTING
HORN
IMPACT SENSOR
JOYSTICK ASSEMBLY
TELEMETRY OPTIONS
TILT SENSOR
TRANSMISSION
DRIVE SHAFT
Drive Axle
STEERING SYSTEM
STEER AXLE
BRAKE SYSTEM
BRAKE ASSEMBLY
BRAKE PEDAL SINGLE
BRAKE PEDAL DUAL
PARKING BRAKE LEVER
HYDRAULIC SYSTEM
TILT CYLINDERS
STEER HYDRAULICS
FORKS BOLZONI
OPTIONS
ACCESSORY BAR FIXED
ACCUMULATOR MAST
BELLY SCREEN
CONVENIENCE TRAY
FAN MOUNTED - CAB
REAR CAMERA
TILT CYLINDER BOOTS
ADD-ON KITS
REPAIR KITS
NUMERICAL INDEX
- Hyster Forklift Parts and Service Manual CD7
- Hyster Forklift Parts and Service Manual CD2
- Hyster Forklift Parts and Service Manual CD3
- Hyster Forklift Diagrams and Schematics
- Hyster Forklift Parts and Service Manual CD4
- Hyster Forklift Parts and Service Manual CD10
- Hyster Forklift Parts and Service Manual CD9
- HYSTER Forklift H4.0 Shop Manual
- Hyster Forklift Parts and Service Manual CD6
- Hyster THREE-SPEED POWERSHIFT TRANSMISSION REPAIR Manual
- Hyster Forklift Parts and Service Manual CD5
- Hyster Forklift Parts and Service Manual CD8
- Linde Forklift 353-02D Operator Manual , SAFETY TIPS,Electric and Hydraulic circuit diagram
- Perkins Diesel Engines 1004-42(AR) 1006-60(YG) 1006-60T(YH) Repair And Maintenance Manual
