estemar1979
12
5,723
Hyster ETACC Electric Truck AC Controls Program Updated 2.42.15
Size: 30.4 MB (Winrar Files)
Type of Software: AC Controls Program
Type of vehicle: Forklift
Interface languages: English
Make: Hyster
OS: Windows 7, Windows 10 32 & 64 bit (Tested on Windows 10 pro 22h2 64bit)
Supporter: Present
Instruction: Present
Installation: Multiple PCs
****Software included on this CD-ROM:
Electric Truck AC Controls Program (ETACC). This program is used to change control settings. Revise dash display languages and administer passwords
***LOADING INSTRUCTIONS FOR "Electric Truck AC Controls Program" ***
1) If Previous versions of ETACC were installed go to "Control Panel - Add or Remove Programs" and uninstall the software.
2) Rename file folder C:\EVS to C:\EVS_OLD
3) Close all applications before loading this software.
4) Insert CD-ROM into drive and wait for "Choose Setup Language" box to appear. If the box appears skip to item 9)
5) If the " Choose Setup Language " box does not automatically appear, go to the WINDOWS START MENU and click on run.
6) From the run window select BROWSE, click on LOOK IN then click on the icon showing the CD-ROM (usually D: or E:)
7) Select "Setup_ETACC_HYSTER_41711_2.42.exe" and OPEN.
8) From the RUN screen click OK, wait for the "Choose Setup Language" to appear.
9) From the scroll down menu pick the desired language and click "OK"
10) A "Welcome Screen" will appear. To continue the installation click "NEXT"
11) Several "Software License Agreement" screens will appear. If you agree to the terms click "YES" for each screen
12) Select "NEXT" to choose the default Destination folder, Program folder and Destination folder for the truck configuration files.(Note: Default folders are
recommended)
13) The "Setup Complete" box should show. Select "Finish"
14) If Previous versions of ETACC were installed copy the files in the folders "C:\OLD_EVS\Custom Configurations" and "C:\OLD_EVS\Passwords" to the new folders C:\EVS\.....\Custom Configurations" and "C:\EVS\.....\Passwords".
See file "FAQ.doc" for solutions to common problems
